RTEMS 6.1-rc7
struct | _flexio_i2s_type |
Define FlexIO I2S access structure typedef. More... | |
struct | _flexio_i2s_config |
FlexIO I2S configure structure. More... | |
struct | _flexio_i2s_format |
FlexIO I2S audio format, FlexIO I2S only support the same format in Tx and Rx. More... | |
struct | _flexio_i2s_transfer |
Define FlexIO I2S transfer structure. More... | |
struct | _flexio_i2s_handle |
Define FlexIO I2S handle structure. More... | |
Driver version | |
enum | { kStatus_FLEXIO_I2S_Idle = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 0) , kStatus_FLEXIO_I2S_TxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 1) , kStatus_FLEXIO_I2S_RxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 2) , kStatus_FLEXIO_I2S_Error = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 3) , kStatus_FLEXIO_I2S_QueueFull = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 4) , kStatus_FLEXIO_I2S_Timeout } |
FlexIO I2S transfer status. More... | |
enum | _flexio_i2s_master_slave { kFLEXIO_I2S_Master = 0x0U , kFLEXIO_I2S_Slave = 0x1U } |
Master or slave mode. More... | |
enum | { kFLEXIO_I2S_TxDataRegEmptyInterruptEnable = 0x1U , kFLEXIO_I2S_RxDataRegFullInterruptEnable = 0x2U } |
_flexio_i2s_interrupt_enable Define FlexIO FlexIO I2S interrupt mask. More... | |
enum | { kFLEXIO_I2S_TxDataRegEmptyFlag = 0x1U , kFLEXIO_I2S_RxDataRegFullFlag = 0x2U } |
_flexio_i2s_status_flags Define FlexIO FlexIO I2S status mask. More... | |
enum | _flexio_i2s_sample_rate { kFLEXIO_I2S_SampleRate8KHz = 8000U , kFLEXIO_I2S_SampleRate11025Hz = 11025U , kFLEXIO_I2S_SampleRate12KHz = 12000U , kFLEXIO_I2S_SampleRate16KHz = 16000U , kFLEXIO_I2S_SampleRate22050Hz = 22050U , kFLEXIO_I2S_SampleRate24KHz = 24000U , kFLEXIO_I2S_SampleRate32KHz = 32000U , kFLEXIO_I2S_SampleRate44100Hz = 44100U , kFLEXIO_I2S_SampleRate48KHz = 48000U , kFLEXIO_I2S_SampleRate96KHz = 96000U } |
Audio sample rate. More... | |
enum | _flexio_i2s_word_width { kFLEXIO_I2S_WordWidth8bits = 8U , kFLEXIO_I2S_WordWidth16bits = 16U , kFLEXIO_I2S_WordWidth24bits = 24U , kFLEXIO_I2S_WordWidth32bits = 32U } |
Audio word width. More... | |
typedef struct _flexio_i2s_type | FLEXIO_I2S_Type |
Define FlexIO I2S access structure typedef. | |
typedef enum _flexio_i2s_master_slave | flexio_i2s_master_slave_t |
Master or slave mode. | |
typedef struct _flexio_i2s_config | flexio_i2s_config_t |
FlexIO I2S configure structure. | |
typedef struct _flexio_i2s_format | flexio_i2s_format_t |
FlexIO I2S audio format, FlexIO I2S only support the same format in Tx and Rx. | |
typedef enum _flexio_i2s_sample_rate | flexio_i2s_sample_rate_t |
Audio sample rate. | |
typedef enum _flexio_i2s_word_width | flexio_i2s_word_width_t |
Audio word width. | |
typedef struct _flexio_i2s_transfer | flexio_i2s_transfer_t |
Define FlexIO I2S transfer structure. | |
typedef struct _flexio_i2s_handle | flexio_i2s_handle_t |
typedef void(* | flexio_i2s_callback_t) (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, status_t status, void *userData) |
FlexIO I2S xfer callback prototype. | |
#define | FSL_FLEXIO_I2S_DRIVER_VERSION (MAKE_VERSION(2, 2, 0)) |
FlexIO I2S driver version 2.2.0. | |
#define | I2S_RETRY_TIMES 0U /* Define to zero means keep waiting until the flag is assert/deassert. */ |
Retry times for waiting flag. | |
#define | FLEXIO_I2S_XFER_QUEUE_SIZE (4U) |
FlexIO I2S transfer queue size, user can refine it according to use case. | |
Initialization and deinitialization | |
void | FLEXIO_I2S_Init (FLEXIO_I2S_Type *base, const flexio_i2s_config_t *config) |
Initializes the FlexIO I2S. | |
void | FLEXIO_I2S_GetDefaultConfig (flexio_i2s_config_t *config) |
Sets the FlexIO I2S configuration structure to default values. | |
void | FLEXIO_I2S_Deinit (FLEXIO_I2S_Type *base) |
De-initializes the FlexIO I2S. | |
Status | |
uint32_t | FLEXIO_I2S_GetStatusFlags (FLEXIO_I2S_Type *base) |
Gets the FlexIO I2S status flags. | |
Interrupts | |
void | FLEXIO_I2S_EnableInterrupts (FLEXIO_I2S_Type *base, uint32_t mask) |
Enables the FlexIO I2S interrupt. | |
void | FLEXIO_I2S_DisableInterrupts (FLEXIO_I2S_Type *base, uint32_t mask) |
Disables the FlexIO I2S interrupt. | |
Bus Operations | |
void | FLEXIO_I2S_MasterSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_format_t *format, uint32_t srcClock_Hz) |
Configures the FlexIO I2S audio format in master mode. | |
void | FLEXIO_I2S_SlaveSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_format_t *format) |
Configures the FlexIO I2S audio format in slave mode. | |
status_t | FLEXIO_I2S_WriteBlocking (FLEXIO_I2S_Type *base, uint8_t bitWidth, uint8_t *txData, size_t size) |
Sends data using a blocking method. | |
status_t | FLEXIO_I2S_ReadBlocking (FLEXIO_I2S_Type *base, uint8_t bitWidth, uint8_t *rxData, size_t size) |
Receives a piece of data using a blocking method. | |
Transactional | |
void | FLEXIO_I2S_TransferTxCreateHandle (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_callback_t callback, void *userData) |
Initializes the FlexIO I2S handle. | |
void | FLEXIO_I2S_TransferSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_format_t *format, uint32_t srcClock_Hz) |
Configures the FlexIO I2S audio format. | |
void | FLEXIO_I2S_TransferRxCreateHandle (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_callback_t callback, void *userData) |
Initializes the FlexIO I2S receive handle. | |
status_t | FLEXIO_I2S_TransferSendNonBlocking (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_transfer_t *xfer) |
Performs an interrupt non-blocking send transfer on FlexIO I2S. | |
status_t | FLEXIO_I2S_TransferReceiveNonBlocking (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_transfer_t *xfer) |
Performs an interrupt non-blocking receive transfer on FlexIO I2S. | |
void | FLEXIO_I2S_TransferAbortSend (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle) |
Aborts the current send. | |
void | FLEXIO_I2S_TransferAbortReceive (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle) |
Aborts the current receive. | |
status_t | FLEXIO_I2S_TransferGetSendCount (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, size_t *count) |
Gets the remaining bytes to be sent. | |
status_t | FLEXIO_I2S_TransferGetReceiveCount (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, size_t *count) |
Gets the remaining bytes to be received. | |
void | FLEXIO_I2S_TransferTxHandleIRQ (void *i2sBase, void *i2sHandle) |
Tx interrupt handler. | |
void | FLEXIO_I2S_TransferRxHandleIRQ (void *i2sBase, void *i2sHandle) |
Rx interrupt handler. | |
anonymous enum |
anonymous enum |
anonymous enum |
Audio sample rate.
void FLEXIO_I2S_Deinit | ( | FLEXIO_I2S_Type * | base | ) |
Calling this API resets the FlexIO I2S shifter and timer config. After calling this API, call the FLEXO_I2S_Init to use the FlexIO I2S module.
base | FlexIO I2S base pointer |
brief De-initializes the FlexIO I2S.
param base FlexIO I2S base pointer
void FLEXIO_I2S_DisableInterrupts | ( | FLEXIO_I2S_Type * | base, |
uint32_t | mask | ||
This function enables the FlexIO UART interrupt.
base | pointer to FLEXIO_I2S_Type structure |
mask | interrupt source |
brief Disables the FlexIO I2S interrupt.
param base pointer to FLEXIO_I2S_Type structure param mask interrupt source
void FLEXIO_I2S_EnableInterrupts | ( | FLEXIO_I2S_Type * | base, |
base | Pointer to FLEXIO_I2S_Type structure |
brief Enables the FlexIO I2S interrupt.
param base Pointer to FLEXIO_I2S_Type structure param mask interrupt source
void FLEXIO_I2S_GetDefaultConfig | ( | flexio_i2s_config_t * | config | ) |
The purpose of this API is to get the configuration structure initialized for use in FLEXIO_I2S_Init(). Users may use the initialized structure unchanged in FLEXIO_I2S_Init() or modify some fields of the structure before calling FLEXIO_I2S_Init().
config | pointer to master configuration structure |
brief Sets the FlexIO I2S configuration structure to default values.
param config pointer to master configuration structure
uint32_t FLEXIO_I2S_GetStatusFlags | ( | FLEXIO_I2S_Type * | base | ) |
brief Gets the FlexIO I2S status flags.
param base Pointer to FLEXIO_I2S_Type structure return Status flag, which are ORed by the enumerators in the _flexio_i2s_status_flags.
void FLEXIO_I2S_Init | ( | FLEXIO_I2S_Type * | base, |
const flexio_i2s_config_t * | config | ||
This API configures FlexIO pins and shifter to I2S and configures the FlexIO I2S with a configuration structure. The configuration structure can be filled by the user, or be set with default values by FLEXIO_I2S_GetDefaultConfig().
config | FlexIO I2S configure structure. |
brief Initializes the FlexIO I2S.
note This API should be called at the beginning of the application to use the FlexIO I2S driver. Otherwise, any access to the FlexIO I2S module can cause hard fault because the clock is not enabled.
param base FlexIO I2S base pointer param config FlexIO I2S configure structure.
void FLEXIO_I2S_MasterSetFormat | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_format_t * | format, | ||
uint32_t | srcClock_Hz | ||
Audio format can be changed in run-time of FlexIO I2S. This function configures the sample rate and audio data format to be transferred.
format | Pointer to FlexIO I2S audio data format structure. |
srcClock_Hz | I2S master clock source frequency in Hz. |
brief Configures the FlexIO I2S audio format in master mode.
param base Pointer to FLEXIO_I2S_Type structure param format Pointer to FlexIO I2S audio data format structure. param srcClock_Hz I2S master clock source frequency in Hz.
status_t FLEXIO_I2S_ReadBlocking | ( | FLEXIO_I2S_Type * | base, |
uint8_t | bitWidth, | ||
uint8_t * | rxData, | ||
size_t | size | ||
bitWidth | How many bits in a audio word, usually 8/16/24/32 bits. |
rxData | Pointer to the data to be read. |
size | Bytes to be read. |
kStatus_Success | Successfully read data. |
kStatus_FLEXIO_I2C_Timeout | Timeout polling status flags. |
brief Receives a piece of data using a blocking method.
note This function blocks via polling until data is ready to be sent.
param base FlexIO I2S base pointer param bitWidth How many bits in a audio word, usually 8/16/24/32 bits. param rxData Pointer to the data to be read. param size Bytes to be read. retval kStatus_Success Successfully read data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
void FLEXIO_I2S_SlaveSetFormat | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_format_t * | format | ||
brief Configures the FlexIO I2S audio format in slave mode.
void FLEXIO_I2S_TransferAbortReceive | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_handle_t * | handle | ||
base | Pointer to FLEXIO_I2S_Type structure. |
handle | Pointer to flexio_i2s_handle_t structure which stores the transfer state |
brief Aborts the current receive.
note This API can be called at any time when interrupt non-blocking transfer initiates to abort the transfer in a early time.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state
void FLEXIO_I2S_TransferAbortSend | ( | FLEXIO_I2S_Type * | base, |
brief Aborts the current send.
status_t FLEXIO_I2S_TransferGetReceiveCount | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_handle_t * | handle, | ||
size_t * | count | ||
count | Bytes recieved. |
kStatus_Success | Succeed get the transfer count. |
kStatus_NoTransferInProgress | There is not a non-blocking transaction currently in progress. |
brief Gets the remaining bytes to be received.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state return count Bytes received. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
status_t FLEXIO_I2S_TransferGetSendCount | ( | FLEXIO_I2S_Type * | base, |
count | Bytes sent. |
brief Gets the remaining bytes to be sent.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param count Bytes sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
status_t FLEXIO_I2S_TransferReceiveNonBlocking | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_transfer_t * | xfer | ||
xfer | Pointer to flexio_i2s_transfer_t structure |
kStatus_Success | Successfully start the data receive. |
kStatus_FLEXIO_I2S_RxBusy | Previous receive still not finished. |
kStatus_InvalidArgument | The input parameter is invalid. |
brief Performs an interrupt non-blocking receive transfer on FlexIO I2S.
note The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status to check whether the transfer is finished. If the return status is 0, the transfer is finished.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param xfer Pointer to flexio_i2s_transfer_t structure retval kStatus_Success Successfully start the data receive. retval kStatus_FLEXIO_I2S_RxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
void FLEXIO_I2S_TransferRxCreateHandle | ( | FLEXIO_I2S_Type * | base, |
flexio_i2s_callback_t | callback, | ||
void * | userData | ||
This function initializes the FlexIO I2S handle which can be used for other FlexIO I2S transactional APIs. Call this API once to get the initialized handle.
handle | Pointer to flexio_i2s_handle_t structure to store the transfer state. |
callback | FlexIO I2S callback function, which is called while finished a block. |
userData | User parameter for the FlexIO I2S callback. |
brief Initializes the FlexIO I2S receive handle.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure to store the transfer state. param callback FlexIO I2S callback function, which is called while finished a block. param userData User parameter for the FlexIO I2S callback.
void FLEXIO_I2S_TransferRxHandleIRQ | ( | void * | i2sBase, |
void * | i2sHandle | ||
i2sBase | Pointer to FLEXIO_I2S_Type structure. |
i2sHandle | Pointer to flexio_i2s_handle_t structure. |
brief Rx interrupt handler.
param i2sBase Pointer to FLEXIO_I2S_Type structure. param i2sHandle Pointer to flexio_i2s_handle_t structure.
status_t FLEXIO_I2S_TransferSendNonBlocking | ( | FLEXIO_I2S_Type * | base, |
kStatus_Success | Successfully start the data transmission. |
kStatus_FLEXIO_I2S_TxBusy | Previous transmission still not finished, data not all written to TX register yet. |
brief Performs an interrupt non-blocking send transfer on FlexIO I2S.
note The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status and check whether the transfer is finished. If the return status is 0, the transfer is finished.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param xfer Pointer to flexio_i2s_transfer_t structure retval kStatus_Success Successfully start the data transmission. retval kStatus_FLEXIO_I2S_TxBusy Previous transmission still not finished, data not all written to TX register yet. retval kStatus_InvalidArgument The input parameter is invalid.
void FLEXIO_I2S_TransferSetFormat | ( | FLEXIO_I2S_Type * | base, |
Audio format can be changed at run-time of FlexIO I2S. This function configures the sample rate and audio data format to be transferred.
handle | FlexIO I2S handle pointer. |
format | Pointer to audio data format structure. |
srcClock_Hz | FlexIO I2S bit clock source frequency in Hz. This parameter should be 0 while in slave mode. |
brief Configures the FlexIO I2S audio format.
param base Pointer to FLEXIO_I2S_Type structure. param handle FlexIO I2S handle pointer. param format Pointer to audio data format structure. param srcClock_Hz FlexIO I2S bit clock source frequency in Hz. This parameter should be 0 while in slave mode.
void FLEXIO_I2S_TransferTxCreateHandle | ( | FLEXIO_I2S_Type * | base, |
brief Initializes the FlexIO I2S handle.
param base Pointer to FLEXIO_I2S_Type structure param handle Pointer to flexio_i2s_handle_t structure to store the transfer state. param callback FlexIO I2S callback function, which is called while finished a block. param userData User parameter for the FlexIO I2S callback.
void FLEXIO_I2S_TransferTxHandleIRQ | ( | void * | i2sBase, |
i2sHandle | Pointer to flexio_i2s_handle_t structure |
brief Tx interrupt handler.
status_t FLEXIO_I2S_WriteBlocking | ( | FLEXIO_I2S_Type * | base, |
uint8_t * | txData, | ||
size_t | size | ||
base | FlexIO I2S base pointer. |
txData | Pointer to the data to be written. |
size | Bytes to be written. |
kStatus_Success | Successfully write data. |
brief Sends data using a blocking method.
param base FlexIO I2S base pointer. param bitWidth How many bits in a audio word, usually 8/16/24/32 bits. param txData Pointer to the data to be written. param size Bytes to be written. retval kStatus_Success Successfully write data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
