RTEMS 6.1-rc7
VID_MUX_CTRL - Video mux Control Register | |
#define | VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_MASK (0x1U) |
#define | VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_SHIFT (0U) |
#define | VIDEO_MUX_VID_MUX_CTRL_CSI_SEL(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_MASK) |
#define | VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_MASK (0x2U) |
#define | VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_SHIFT (1U) |
#define | VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_MASK) |
#define | VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_MASK (0x4U) |
#define | VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_SHIFT (2U) |
#define | VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_MASK) |
#define | VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_MASK (0x8U) |
#define | VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_SHIFT (3U) |
#define | VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_MASK) |
PLM_CTRL - Pixel Link Master(PLM) Control Register | |
#define | VIDEO_MUX_PLM_CTRL_ENABLE_MASK (0x1U) |
#define | VIDEO_MUX_PLM_CTRL_ENABLE_SHIFT (0U) |
#define | VIDEO_MUX_PLM_CTRL_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_ENABLE_SHIFT)) & VIDEO_MUX_PLM_CTRL_ENABLE_MASK) |
#define | VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_MASK (0x2U) |
#define | VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_SHIFT (1U) |
#define | VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_MASK) |
#define | VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_MASK (0x4U) |
#define | VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_SHIFT (2U) |
#define | VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_MASK) |
#define | VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_MASK (0x8U) |
#define | VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_SHIFT (3U) |
#define | VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_MASK) |
#define | VIDEO_MUX_PLM_CTRL_POLARITY_MASK (0x10U) |
#define | VIDEO_MUX_PLM_CTRL_POLARITY_SHIFT (4U) |
#define | VIDEO_MUX_PLM_CTRL_POLARITY(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_POLARITY_SHIFT)) & VIDEO_MUX_PLM_CTRL_POLARITY_MASK) |
YUV420_CTRL - YUV420 Control Register | |
#define | VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_MASK (0x1U) |
#define | VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_SHIFT (0U) |
#define | VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_SHIFT)) & VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_MASK) |
CFG_DT_DISABLE - Data Disable Register | |
#define | VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_MASK (0xFFFFFFU) |
#define | VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_SHIFT (0U) |
#define | VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_SHIFT)) & VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_MASK) |
MIPI_DSI_CTRL - MIPI DSI Control Register | |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_MASK (0x1U) |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_SHIFT (0U) |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_SHIFT)) & VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_MASK) |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_MASK (0x2U) |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_SHIFT (1U) |
#define | VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM(x) (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_SHIFT)) & VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_MASK) |
#define VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_SHIFT)) & VIDEO_MUX_CFG_DT_DISABLE_CFG_DT_DISABLE_MASK) |
CFG_DT_DISABLE - Data Type Disable
#define VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_SHIFT)) & VIDEO_MUX_MIPI_DSI_CTRL_DPI_CM_MASK) |
DPI_CM - Color Mode control 0b0..Normal Mode 0b1..Low-color mode
#define VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_SHIFT)) & VIDEO_MUX_MIPI_DSI_CTRL_DPI_SD_MASK) |
DPI_SD - Shut Down - Control to shutdown display (type 4 only) 0b0..No effect 0b1..Send shutdown command
#define VIDEO_MUX_PLM_CTRL_ENABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_ENABLE_SHIFT)) & VIDEO_MUX_PLM_CTRL_ENABLE_MASK) |
ENABLE - Enable the output of HYSNC and VSYNC 0b0..No active HSYNC and VSYNC output 0b1..Active HSYNC and VSYNC output
#define VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_HSYNC_OVERRIDE_MASK) |
HSYNC_OVERRIDE - HSYNC override 0b1..HSYNC is asserted 0b0..HSYNC is not asserted
#define VIDEO_MUX_PLM_CTRL_POLARITY | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_POLARITY_SHIFT)) & VIDEO_MUX_PLM_CTRL_POLARITY_MASK) |
POLARITY - Polarity of HYSNC/VSYNC 0b0..Keep the current polarity of HSYNC and VSYNC 0b1..Invert the polarity of HSYNC and VSYNC
#define VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_VALID_OVERRIDE_MASK) |
VALID_OVERRIDE - Valid override 0b0..HSYNC and VSYNC is asserted 0b1..HSYNC and VSYNC is not asserted
#define VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_SHIFT)) & VIDEO_MUX_PLM_CTRL_VSYNC_OVERRIDE_MASK) |
VSYNC_OVERRIDE - VSYNC override 0b1..VSYNC is asserted 0b0..VSYNC is not asserted
#define VIDEO_MUX_VID_MUX_CTRL_CSI_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_CSI_SEL_MASK) |
CSI_SEL - CSI sensor data input mux selector 0b0..CSI sensor data is from Parallel CSI 0b1..CSI sensor data is from MIPI CSI
#define VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_LCDIF2_SEL_MASK) |
LCDIF2_SEL - LCDIF2 sensor data input mux selector 0b0..LCDIFv2 sensor data is from Parallel CSI 0b1..LCDIFv2 sensor data is from MIPI CSI
#define VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_MIPI_DSI_SEL_MASK) |
MIPI_DSI_SEL - MIPI DSI video data input mux selector 0b0..MIPI DSI video data is from eLCDIF 0b1..MIPI DSI video data is from LCDIFv2
#define VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_SHIFT)) & VIDEO_MUX_VID_MUX_CTRL_PARA_LCD_SEL_MASK) |
PARA_LCD_SEL - Parallel LCDIF video data input mux selector 0b0..Parallel LCDIF video data is from eLCDIF 0b1..Parallel LCDIF video data is from LCDIFv2
#define VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_SHIFT)) & VIDEO_MUX_YUV420_CTRL_FST_LN_DATA_TYPE_MASK) |
FST_LN_DATA_TYPE - Data type of First Line 0b0..Odd (default) 0b1..Even
