RTEMS 6.1-rc7
Typedefs | Enumerations | Functions
typedef enum ALT_16550_BAUDRATE_e ALT_16550_BAUDRATE_t
enum  ALT_16550_BAUDRATE_e {
  ALT_16550_BAUDRATE_50 = 50 , ALT_16550_BAUDRATE_75 = 75 , ALT_16550_BAUDRATE_150 = 150 , ALT_16550_BAUDRATE_300 = 300 ,
  ALT_16550_BAUDRATE_600 = 600 , ALT_16550_BAUDRATE_900 = 900 , ALT_16550_BAUDRATE_1200 = 1200 , ALT_16550_BAUDRATE_1800 = 1800 ,
  ALT_16550_BAUDRATE_2400 = 2400 , ALT_16550_BAUDRATE_3600 = 3600 , ALT_16550_BAUDRATE_4800 = 4800 , ALT_16550_BAUDRATE_7200 = 7200 ,
  ALT_16550_BAUDRATE_9600 = 9600 , ALT_16550_BAUDRATE_14400 = 14400 , ALT_16550_BAUDRATE_19200 = 19200 , ALT_16550_BAUDRATE_28800 = 28800 ,
  ALT_16550_BAUDRATE_38400 = 38400 , ALT_16550_BAUDRATE_57600 = 57600 , ALT_16550_BAUDRATE_115200 = 115200
ALT_STATUS_CODE alt_16550_baudrate_get (ALT_16550_HANDLE_t *handle, uint32_t *baudrate)
ALT_STATUS_CODE alt_16550_baudrate_set (ALT_16550_HANDLE_t *handle, uint32_t baudrate)
ALT_STATUS_CODE alt_16550_divisor_get (ALT_16550_HANDLE_t *handle, uint32_t *divisor)
ALT_STATUS_CODE alt_16550_divisor_set (ALT_16550_HANDLE_t *handle, uint32_t divisor)
This group of APIs allows for the configuration of the UART's baudrate generation related functions.
The UART baudrate is determined by dividing the ALT_CLK_L4_SP clock with the configured divisor.
Typedef Documentation
◆ ALT_16550_BAUDRATE_t
This enumeration lists out the common baudrates used with modem and serial ports. Not every baudrate is available for the UART due to the limits of the serial clock frequency and divisor value.
◆ ALT_16550_BAUDRATE_e
50 bps baudrate.
75 bps baudrate.
150 bps baudrate.
300 bps baudrate.
600 bps baudrate.
900 bps baudrate.
1200 bps baudrate.
1800 bps baudrate.
2400 bps baudrate.
3600 bps baudrate.
4800 bps baudrate.
7200 bps baudrate.
9600 bps baudrate.
14400 bps baudrate.
19200 bps baudrate.
28800 bps baudrate.
38400 bps baudrate.
57600 bps baudrate.
115200 bps baudrate.
◆ alt_16550_baudrate_get()
ALT_STATUS_CODE alt_16550_baudrate_get ( ALT_16550_HANDLE_t handle,
uint32_t *  baudrate
Gets the baudrate for the UART.
This is done by calculating the baudrate from the divisor and the serial clock. The reported baudrate may not correspond exactly to the request baudrate.
Parameters
handleThe UART device handle.
baudrate[out] Pointer to an output paramter that contains the current baudrate of the UART.
Return values
ALT_E_SUCCESSThe operation was successful.
ALT_E_ERRORThe operation failed.
ALT_E_BAD_ARGThe given UART device handle is invalid.
◆ alt_16550_baudrate_set()
ALT_STATUS_CODE alt_16550_baudrate_set ( ALT_16550_HANDLE_t handle,
uint32_t  baudrate
Sets the baudrate for the UART. This change will take effect when the UART moves from disabled to enabled.
This is done by calculating the correct divisor using the request baudrate and the known serial clock.
Parameters
baudrateThe requested baudrate for the UART.
Return values
ALT_E_ARG_RANGEThe given baudrate is not possible due to limitations of the baudrate divisor and/or serial clock.
◆ alt_16550_divisor_get()
ALT_STATUS_CODE alt_16550_divisor_get ( ALT_16550_HANDLE_t handle,
uint32_t *  divisor
Gets the baudrate divisor for the UART.
The baudrate is determined by the following formula:
  • Baudrate = (serial clock frequency) / (16 * divisor)
Parameters
divisor[out] Pointer to an output parameter that contains the current divisor used for baudrate generation.
Return values
◆ alt_16550_divisor_set()
ALT_STATUS_CODE alt_16550_divisor_set ( ALT_16550_HANDLE_t handle,
uint32_t  divisor
Sets the baudrate divisor for the UART. This change will take effect when the UART moves from disabled to enabled.
Parameters
divisorThe specified divisor value to use for baudrate generation. Valid values are 1 - 65535.
Return values
ALT_E_BAD_ARGThe given UART identifier is invalid or the specified divisor is not supported by the UART.
