RTEMS 6.1-rc7
Regulator Internal Information. More...
Files | |
file | regulatorimpl.h |
Regulator Library Implementation Support. | |
struct | _Regulator_Message_t |
Regulator Message Instance Management Structure. More... | |
struct | _Regulator_Statistics |
Regulator Statistics Private Structure. More... | |
struct | _Regulator_Control |
Regulator Instance Private Structure. More... | |
#define | REGULATOR_INITIALIZED 0xDeadF00d |
rtems_status_code | rtems_regulator_create (rtems_regulator_attributes *attributes, rtems_regulator_instance **regulator) |
Create a regulator. | |
rtems_status_code | rtems_regulator_delete (rtems_regulator_instance *regulator, rtems_interval ticks) |
Delete a regulator. | |
rtems_status_code | rtems_regulator_obtain_buffer (rtems_regulator_instance *regulator, void **buffer) |
Obtain Buffer from Regulator. | |
rtems_status_code | rtems_regulator_release_buffer (rtems_regulator_instance *regulator, void *buffer) |
Release Previously Obtained Regulator Buffer. | |
rtems_status_code | rtems_regulator_send (rtems_regulator_instance *regulator, void *message, size_t length) |
Send to regulator instance. | |
rtems_status_code | rtems_regulator_get_statistics (rtems_regulator_instance *regulator, rtems_regulator_statistics *statistics) |
Obtain statistics for regulator instance. | |
This concerns implementation information about the Regulator.
#define REGULATOR_INITIALIZED 0xDeadF00d |
This constant is used to indicate the regulator instance is initialized.
rtems_status_code rtems_regulator_create | ( | rtems_regulator_attributes * | attributes, |
rtems_regulator_instance ** | regulator | ||
Create a regulator.
This function creates an instance of a regulator. It uses the provided attributes to create the instance return in regulator. This instance will allocate the buffers associated with the regulator instance as well as the Delivery thread.
The attributes structure defines the priority and stack size of the Delivery thread dedicated to this regulator instance. It also defines the period of the Delivery thread and the maximum number of messages that may be delivered per period via invocation of the delivery function.
For each regulator instance, the following resources are allocated:
[in] | attributes | specify the regulator instance attributes |
[in,out] | regulator | will point to the regulator instance |
Perform basic validation of parameters
Verify attributes are OK. Some are checked by calls to object create methods. Specifically the following are not checked:
Allocate memory for regulator instance
We do NOT want the delivery_thread_id field to be initialized to 0. If the rtems_task_create() fails, then the field will not be overwritten. This results in an attempt to rtems_task_delete(0) during clean up. The thread ID of 0 is self which results in the calling thread accidentally deleting itself.
Copy the attributes to an internal area for later use
Allocate memory for the messages. There is no need to zero out the message memory because the user should fill that in.
Associate message memory with a partition so allocations are atomic
Create the message queue between the sender and output thread
Create the output thread Using the priority and stack size attributes specified by the user.
Start the output thread.
The regulator is successfully initialized. Set the initialized field to reflect this and return the instance pointer.
rtems_status_code rtems_regulator_delete | ( | rtems_regulator_instance * | regulator, |
rtems_interval | ticks | ||
Delete a regulator.
This function is used to delete the specified regulator instance.
It is the responsibility of the user to ensure that any resources such as sockets or open file descriptors used by the delivery function are also deleted. It is likely safer to delete those delivery resources after deleting the regulator instance rather than before.
[in] | regulator | is the instance to delete |
[in] | ticks | is the maximum number of ticks to wait for the delivery thread to shutdown. |
Convert external handle to internal instance pointer
There can be no buffers outstanding
Free the resources associated with this regulator instance.
rtems_status_code rtems_regulator_get_statistics | ( | rtems_regulator_instance * | regulator, |
rtems_regulator_statistics * | statistics | ||
This function is used by the application to obtain statistics information about the regulator instance.
If the obtained and released fields in the returned statistics structure are equal, then there are no buffers outstanding from this regulator instance.
[in] | regulator | is the regulator instance to operate upon |
[in,out] | statistics | points to the statistics structure to fill in |
Validate the arguments and ensure the regulator was successfully initialized.
Zero out the statistics structure in case the get period statistics fails below.
Fill in the caller's statistics structure from information maintained by the regulator instance about buffers processed.
Attempt to retrieve the delivery thread's period's statistics.
NOTE; If the Delivery Thread has not run yet, the period will not exist yet. We should not fail for this reason but it is why we zeroed out the entire structure above.
rtems_status_code rtems_regulator_obtain_buffer | ( | rtems_regulator_instance * | regulator, |
void ** | buffer | ||
Allocate a buffer for the caller using the internal partition.
Allocate a buffer for the user application from the buffer pool managed by an Classic API partition.
rtems_status_code rtems_regulator_release_buffer | ( | rtems_regulator_instance * | regulator, |
void * | buffer | ||
Deallocate the buffer to the buffer pool managed by a Classic API partition.
rtems_status_code rtems_regulator_send | ( | rtems_regulator_instance * | regulator, |
void * | message, | ||
size_t | length | ||
This function is used by the producer to send a message to the regulator for later delivery by the Delivery thread. The message is contained in the memory pointed to by message and is length bytes in length.
It is required that the message buffer was obtained via rtems_regulator_obtain_buffer().
It is assumed that the message buffer has been filled in with application content to deliver.
If the rtems_regulator_send() is successful, the buffer is enqueued inside the regulator instance for subsequent delivery. After the message is delivered, it may be released by either delivery function or the application code depending on the implementation.
The status RTEMS_TOO_MANY is returned if the regulator's internal queue is full. This indicates that the configured maximum number of messages was insufficient. It is the responsibility of the caller to decide whether to hold messages, drop them, or print a message that the maximum number of messages should be increased.
If rtems_regulator_send() is unsuccessful, it is the application's responsibility to release the buffer. If it is successfully sent, then it becomes the responsibility of the delivery function to release it.
[out] | message | points to the message to deliver |
[out] | length | is the size of the message in bytes |
Place the message pointer and length into a temporary structure. This lets the implementation internally send the message by reference and have a zero-copy implementation.
Send the application message to the output thread for delivery using a Classic API message queue.
