RTEMS 6.1-rc7
Modules | Files | Macros | Functions
NXP LPC176X Board Support Package. More...
 DMA Support
 Direct memory access (DMA) support.
 System Clocks
 System clocks.
file  btimer.c
 Timer benchmark functions for the lpc176x bsp.
file  can.c
 CAN controller for the mbed lpc1768 board.
file  console-config.c
 Console configuration.
file  lpc-gpio.c
 GPIO library for the lpc176x bsp.
file  bsp.h
 Global BSP definitions.
file  adc-defs.h
 ADC library for the lpc176x bsp.
file  adc.h
file  can-defs.h
 CAN controller for the lpc176x controller.
file  can.h
file  common-types.h
 Definitions types used by some devices in common.
file  gpio-defs.h
 API definitions of the GPIO driver for the lpc176x bsp in RTEMS.
file  io-defs.h
 Input/output module definitions.
file  io.h
 Input/output module methods definitions.
file  lpc-clock-config.h
 Clock driver configuration.
file  lpc-gpio.h
 API of the GPIO driver for the lpc176x bsp in RTEMS.
file  lpc176x.h
 Specific register definitions according to lpc176x family boards.
file  mbed-pinmap.h
 Pins of the mbed lpc1768 See http://mbed.org/media/uploads/chris/mbed-005.1.pdf for references.
file  pwmout-defs.h
 PWM-Out controller for the mbed lpc1768 board.
file  pwmout.h
file  timer-defs.h
 API definitions of the for the timer of the lpc176x bsp.
file  timer.h
 Timer API for the lpc176x bsp.
file  watchdog-defs.h
 API definitions of the Watchdog driver for the lpc176x bsp in RTEMS.
file  watchdog.h
 API of the Watchdog driver for the lpc176x bsp in RTEMS.
file  pwmout.c
file  rtc-config.c
 RTC configuration.
file  adc.c
file  bspidle.c
 Idle task.
file  bspstart.c
 Startup code.
file  bspstarthooks.c
 First configurations and initializations to the correct functionality of the board.
file  io.c
 Input/output module methods.
file  restart.c
 Restart implementation.
file  watchdog.c
 Watchdog controller for the mbed lpc176x family boards.
file  timer.c
 Timer controller for the mbed lpc1768 board.
#define LPC176X_PCLK   ( LPC176X_CCLK / LPC176X_PCLKDIV )
#define LPC176X_MPU_REGION_COUNT   8u
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT   ( 29u << 3u )
#define BSP_ARMV7M_SYSTICK_PRIORITY   ( 30u << 3u )
#define BSP_ARMV7M_SYSTICK_FREQUENCY   LPC176X_CCLK
#define BSP_CONSOLE_UART_BASE   0x4000C000U
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
void bsp_restart (const void *addr)
 Restarts the bsp with "addr" address.
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
◆ bsp_restart()
void bsp_restart ( const void *  addr)
Parameters
addrAddress used to restart the bsp
