RTEMS 6.1-rc7
#define | MT25TL01G_FLASH_SIZE 0x8000000 /* 2 * 512 MBits => 2 * 64MBytes => 128MBytes*/ |
MT25TL01G Configuration. | |
#define | MT25TL01G_SECTOR_SIZE 0x10000 /* 2 * 1024 sectors of 64KBytes */ |
#define | MT25TL01G_SUBSECTOR_SIZE 0x1000 /* 2 * 16384 subsectors of 4kBytes */ |
#define | MT25TL01G_PAGE_SIZE 0x100 /* 2 * 262144 pages of 256 bytes */ |
#define | MT25TL01G_DIE_ERASE_MAX_TIME 460000 |
#define | MT25TL01G_SECTOR_ERASE_MAX_TIME 1000 |
#define | MT25TL01G_SUBSECTOR_ERASE_MAX_TIME 400 |
#define | MT25TL01G_RESET_ENABLE_CMD 0x66 |
MT25TL01G Commands. | |
#define | MT25TL01G_RESET_MEMORY_CMD 0x99 |
#define | MT25TL01G_READ_ID_CMD 0x9E |
#define | MT25TL01G_READ_ID_CMD2 0x9F |
#define | MT25TL01G_MULTIPLE_IO_READ_ID_CMD 0xAF |
#define | MT25TL01G_READ_SERIAL_FLASH_DISCO_PARAM_CMD 0x5A |
#define | MT25TL01G_READ_CMD 0x03 |
#define | MT25TL01G_READ_4_BYTE_ADDR_CMD 0x13 |
#define | MT25TL01G_FAST_READ_CMD 0x0B |
#define | MT25TL01G_FAST_READ_DTR_CMD 0x0D |
#define | MT25TL01G_FAST_READ_4_BYTE_ADDR_CMD 0x0C |
#define | MT25TL01G_FAST_READ_4_BYTE_DTR_CMD 0x0E |
#define | MT25TL01G_DUAL_OUT_FAST_READ_CMD 0x3B |
#define | MT25TL01G_DUAL_OUT_FAST_READ_DTR_CMD 0x3D |
#define | MT25TL01G_DUAL_OUT_FAST_READ_4_BYTE_ADDR_CMD 0x3C |
#define | MT25TL01G_DUAL_INOUT_FAST_READ_CMD 0xBB |
#define | MT25TL01G_DUAL_INOUT_FAST_READ_DTR_CMD 0xBD |
#define | MT25TL01G_DUAL_INOUT_FAST_READ_4_BYTE_ADDR_CMD 0xBC |
#define | MT25TL01G_QUAD_OUT_FAST_READ_CMD 0x6B |
#define | MT25TL01G_QUAD_OUT_FAST_READ_DTR_CMD 0x6D |
#define | MT25TL01G_QUAD_OUT_FAST_READ_4_BYTE_ADDR_CMD 0x6C |
#define | MT25TL01G_QUAD_INOUT_FAST_READ_CMD 0xEB |
#define | MT25TL01G_QUAD_INOUT_FAST_READ_DTR_CMD 0xED |
#define | MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_ADDR_CMD 0xEC |
#define | MT25TL01G_QUAD_INOUT_FAST_READ_4_BYTE_DTR_CMD 0xEE |
#define | MT25TL01G_WRITE_ENABLE_CMD 0x06 |
#define | MT25TL01G_WRITE_DISABLE_CMD 0x04 |
#define | MT25TL01G_READ_STATUS_REG_CMD 0x05 |
#define | MT25TL01G_WRITE_STATUS_REG_CMD 0x01 |
#define | MT25TL01G_READ_LOCK_REG_CMD 0xE8 |
#define | MT25TL01G_WRITE_LOCK_REG_CMD 0xE5 |
#define | MT25TL01G_READ_FLAG_STATUS_REG_CMD 0x70 |
#define | MT25TL01G_CLEAR_FLAG_STATUS_REG_CMD 0x50 |
#define | MT25TL01G_READ_NONVOL_CFG_REG_CMD 0xB5 |
#define | MT25TL01G_WRITE_NONVOL_CFG_REG_CMD 0xB1 |
#define | MT25TL01G_READ_VOL_CFG_REG_CMD 0x85 |
#define | MT25TL01G_WRITE_VOL_CFG_REG_CMD 0x81 |
#define | MT25TL01G_READ_ENHANCED_VOL_CFG_REG_CMD 0x65 |
#define | MT25TL01G_WRITE_ENHANCED_VOL_CFG_REG_CMD 0x61 |
#define | MT25TL01G_READ_EXT_ADDR_REG_CMD 0xC8 |
#define | MT25TL01G_WRITE_EXT_ADDR_REG_CMD 0xC5 |
#define | MT25TL01G_PAGE_PROG_CMD 0x02 |
#define | MT25TL01G_PAGE_PROG_4_BYTE_ADDR_CMD 0x12 |
#define | MT25TL01G_DUAL_IN_FAST_PROG_CMD 0xA2 |
#define | MT25TL01G_EXT_DUAL_IN_FAST_PROG_CMD 0xD2 |
#define | MT25TL01G_QUAD_IN_FAST_PROG_CMD 0x32 |
#define | MT25TL01G_EXT_QUAD_IN_FAST_PROG_CMD 0x38 |
#define | MT25TL01G_QUAD_IN_FAST_PROG_4_BYTE_ADDR_CMD 0x34 |
#define | MT25TL01G_SUBSECTOR_ERASE_CMD_4K 0x20 |
#define | MT25TL01G_SUBSECTOR_ERASE_4_BYTE_ADDR_CMD_4K 0x21 |
#define | MT25TL01G_SUBSECTOR_ERASE_CMD_32K 0x52 |
#define | MT25TL01G_SECTOR_ERASE_CMD 0xD8 |
#define | MT25TL01G_SECTOR_ERASE_4_BYTE_ADDR_CMD 0xDC |
#define | MT25TL01G_DIE_ERASE_CMD 0xC7 |
#define | MT25TL01G_PROG_ERASE_RESUME_CMD 0x7A |
#define | MT25TL01G_PROG_ERASE_SUSPEND_CMD 0x75 |
#define | MT25TL01G_READ_OTP_ARRAY_CMD 0x4B |
#define | MT25TL01G_PROG_OTP_ARRAY_CMD 0x42 |
#define | MT25TL01G_ENTER_4_BYTE_ADDR_MODE_CMD 0xB7 |
#define | MT25TL01G_EXIT_4_BYTE_ADDR_MODE_CMD 0xE9 |
#define | MT25TL01G_ENTER_QUAD_CMD 0x35 |
#define | MT25TL01G_EXIT_QUAD_CMD 0xF5 |
#define | MT25TL01G_ENTER_DEEP_POWER_DOWN 0xB9 |
#define | MT25TL01G_RELEASE_FROM_DEEP_POWER_DOWN 0xAB |
#define | MT25TL01G_READ_SECTOR_PROTECTION_CMD 0x2D |
#define | MT25TL01G_PROGRAM_SECTOR_PROTECTION 0x2C |
#define | MT25TL01G_READ_PASSWORD_CMD 0x27 |
#define | MT25TL01G_WRITE_PASSWORD_CMD 0x28 |
#define | MT25TL01G_UNLOCK_PASSWORD_CMD 0x29 |
#define | MT25TL01G_READ_GLOBAL_FREEZE_BIT 0xA7 |
#define | MT25TL01G_READ_VOLATILE_LOCK_BITS 0xE8 |
#define | MT25TL01G_WRITE_VOLATILE_LOCK_BITS 0xE5 |
#define | MT25TL01G_WRITE_4_BYTE_VOLATILE_LOCK_BITS 0xE1 |
#define | MT25TL01G_READ_4_BYTE_VOLATILE_LOCK_BITS 0xE0 |
#define | MT25TL01G_READ_OTP_ARRAY 0x4B |
#define | MT25TL01G_PROGRAM_OTP_ARRAY 0x42 |
#define | MT25TL01G_SR_WIP ((uint8_t)0x01) |
MT25TL01G Registers. | |
#define | MT25TL01G_SR_WREN ((uint8_t)0x02) |
#define | MT25TL01G_SR_BLOCKPR ((uint8_t)0x5C) |
#define | MT25TL01G_SR_PRBOTTOM ((uint8_t)0x20) |
#define | MT25TL01G_SR_SRWREN ((uint8_t)0x80) |
#define | MT25TL01G_NVCR_NBADDR ((uint16_t)0x0001) |
#define | MT25TL01G_NVCR_SEGMENT ((uint16_t)0x0002) |
#define | MT25TL01G_NVCR_DUAL ((uint16_t)0x0004) |
#define | MT25TL01G_NVCR_QUAB ((uint16_t)0x0008) |
#define | MT25TL01G_NVCR_RH ((uint16_t)0x0010) |
#define | MT25TL01G_NVCR_DTRP ((uint16_t)0x0020) |
#define | MT25TL01G_NVCR_ODS ((uint16_t)0x01C0) |
#define | MT25TL01G_NVCR_XIP ((uint16_t)0x0E00) |
#define | MT25TL01G_NVCR_NB_DUMMY ((uint16_t)0xF000) |
#define | MT25TL01G_VCR_WRAP ((uint8_t)0x03) |
#define | MT25TL01G_VCR_XIP ((uint8_t)0x08) |
#define | MT25TL01G_VCR_NB_DUMMY ((uint8_t)0xF0) |
#define | MT25TL01G_EAR_HIGHEST_SE ((uint8_t)0x03) |
#define | MT25TL01G_EAR_THIRD_SEG ((uint8_t)0x02) |
#define | MT25TL01G_EAR_SECOND_SEG ((uint8_t)0x01) |
#define | MT25TL01G_EAR_LOWEST_SEG ((uint8_t)0x00) |
#define | MT25TL01G_EVCR_ODS ((uint8_t)0x07) |
#define | MT25TL01G_EVCR_RH ((uint8_t)0x10) |
#define | MT25TL01G_EVCR_DTRP ((uint8_t)0x20) |
#define | MT25TL01G_EVCR_DUAL ((uint8_t)0x40) |
#define | MT25TL01G_EVCR_QUAD ((uint8_t)0x80) |
#define | MT25TL01G_FSR_NBADDR ((uint8_t)0x01) |
#define | MT25TL01G_FSR_PRERR ((uint8_t)0x02) |
#define | MT25TL01G_FSR_PGSUS ((uint8_t)0x04) |
#define | MT25TL01G_FSR_PGERR ((uint8_t)0x10) |
#define | MT25TL01G_FSR_ERERR ((uint8_t)0x20) |
#define | MT25TL01G_FSR_ERSUS ((uint8_t)0x40) |
#define | MT25TL01G_FSR_READY ((uint8_t)0x80) |
#define MT25TL01G_EAR_HIGHEST_SE ((uint8_t)0x03) |
Select the Highest 128Mb segment
#define MT25TL01G_EAR_LOWEST_SEG ((uint8_t)0x00) |
Select the Lowest 128Mb segment (default)
#define MT25TL01G_EAR_SECOND_SEG ((uint8_t)0x01) |
Select the Second 128Mb segment
#define MT25TL01G_EAR_THIRD_SEG ((uint8_t)0x02) |
Select the Third 128Mb segment
#define MT25TL01G_EVCR_DTRP ((uint8_t)0x20) |
Double transfer rate protocol
#define MT25TL01G_EVCR_DUAL ((uint8_t)0x40) |
Dual I/O protocol
#define MT25TL01G_EVCR_ODS ((uint8_t)0x07) |
Output driver strength
#define MT25TL01G_EVCR_QUAD ((uint8_t)0x80) |
Quad I/O protocol
#define MT25TL01G_EVCR_RH ((uint8_t)0x10) |
Reset/hold
#define MT25TL01G_FSR_ERERR ((uint8_t)0x20) |
Erase error
#define MT25TL01G_FSR_ERSUS ((uint8_t)0x40) |
Erase operation suspended
#define MT25TL01G_FSR_NBADDR ((uint8_t)0x01) |
3-bytes or 4-bytes addressing
#define MT25TL01G_FSR_PGERR ((uint8_t)0x10) |
Program error
#define MT25TL01G_FSR_PGSUS ((uint8_t)0x04) |
Program operation suspended
#define MT25TL01G_FSR_PRERR ((uint8_t)0x02) |
Protection error
#define MT25TL01G_FSR_READY ((uint8_t)0x80) |
Ready or command in progress
#define MT25TL01G_NVCR_DTRP ((uint16_t)0x0020) |
#define MT25TL01G_NVCR_DUAL ((uint16_t)0x0004) |
Dual I/O protocol
#define MT25TL01G_NVCR_NB_DUMMY ((uint16_t)0xF000) |
Number of dummy clock cycles
#define MT25TL01G_NVCR_NBADDR ((uint16_t)0x0001) |
#define MT25TL01G_NVCR_ODS ((uint16_t)0x01C0) |
#define MT25TL01G_NVCR_QUAB ((uint16_t)0x0008) |
Quad I/O protocol
#define MT25TL01G_NVCR_RH ((uint16_t)0x0010) |
Reset/hold
#define MT25TL01G_NVCR_SEGMENT ((uint16_t)0x0002) |
Upper or lower 128Mb segment selected by default
#define MT25TL01G_NVCR_XIP ((uint16_t)0x0E00) |
XIP mode at power-on reset
#define MT25TL01G_SR_BLOCKPR ((uint8_t)0x5C) |
Block protected against program and erase operations
#define MT25TL01G_SR_PRBOTTOM ((uint8_t)0x20) |
Protected memory area defined by BLOCKPR starts from top or bottom
#define MT25TL01G_SR_SRWREN ((uint8_t)0x80) |
Status register write enable/disable
#define MT25TL01G_SR_WIP ((uint8_t)0x01) |
Write in progress
#define MT25TL01G_SR_WREN ((uint8_t)0x02) |
Write enable latch
#define MT25TL01G_VCR_NB_DUMMY ((uint8_t)0xF0) |
#define MT25TL01G_VCR_WRAP ((uint8_t)0x03) |
Wrap
#define MT25TL01G_VCR_XIP ((uint8_t)0x08) |
XIP
