RTEMS 6.1-rc7
DMAEx MUX SyncSignalID selection. More...
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH0_EVT   0U
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH1_EVT   1U
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH2_EVT   2U
#define HAL_DMAMUX1_SYNC_LPTIM1_OUT   3U
#define HAL_DMAMUX1_SYNC_LPTIM2_OUT   4U
#define HAL_DMAMUX1_SYNC_LPTIM3_OUT   5U
#define HAL_DMAMUX1_SYNC_EXTI0   6U
#define HAL_DMAMUX1_SYNC_TIM12_TRGO   7U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH0_EVT   0U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH1_EVT   1U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH2_EVT   2U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH3_EVT   3U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH4_EVT   4U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH5_EVT   5U
#define HAL_DMAMUX2_SYNC_LPUART1_RX_WKUP   6U
#define HAL_DMAMUX2_SYNC_LPUART1_TX_WKUP   7U
#define HAL_DMAMUX2_SYNC_LPTIM2_OUT   8U
#define HAL_DMAMUX2_SYNC_LPTIM3_OUT   9U
#define HAL_DMAMUX2_SYNC_I2C4_WKUP   10U
#define HAL_DMAMUX2_SYNC_SPI6_WKUP   11U
#define HAL_DMAMUX2_SYNC_COMP1_OUT   12U
#define HAL_DMAMUX2_SYNC_RTC_WKUP   13U
#define HAL_DMAMUX2_SYNC_EXTI0   14U
#define HAL_DMAMUX2_SYNC_EXTI2   15U
◆ HAL_DMAMUX1_SYNC_DMAMUX1_CH0_EVT
DMAMUX1 synchronization Signal is DMAMUX1 Channel0 Event
◆ HAL_DMAMUX1_SYNC_DMAMUX1_CH1_EVT
DMAMUX1 synchronization Signal is DMAMUX1 Channel1 Event
◆ HAL_DMAMUX1_SYNC_DMAMUX1_CH2_EVT
DMAMUX1 synchronization Signal is DMAMUX1 Channel2 Event
◆ HAL_DMAMUX1_SYNC_EXTI0
DMAMUX1 synchronization Signal is EXTI0 IT
◆ HAL_DMAMUX1_SYNC_LPTIM1_OUT
DMAMUX1 synchronization Signal is LPTIM1 OUT
◆ HAL_DMAMUX1_SYNC_LPTIM2_OUT
DMAMUX1 synchronization Signal is LPTIM2 OUT
◆ HAL_DMAMUX1_SYNC_LPTIM3_OUT
DMAMUX1 synchronization Signal is LPTIM3 OUT
◆ HAL_DMAMUX1_SYNC_TIM12_TRGO
DMAMUX1 synchronization Signal is TIM12 TRGO
◆ HAL_DMAMUX2_SYNC_COMP1_OUT
DMAMUX2 synchronization Signal is Comparator 1 output
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH0_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel0 Event
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH1_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel1 Event
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH2_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel2 Event
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH3_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel3 Event
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH4_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel4 Event
◆ HAL_DMAMUX2_SYNC_DMAMUX2_CH5_EVT
DMAMUX2 synchronization Signal is DMAMUX2 Channel5 Event
◆ HAL_DMAMUX2_SYNC_EXTI0
DMAMUX2 synchronization Signal is EXTI0 IT
◆ HAL_DMAMUX2_SYNC_EXTI2
DMAMUX2 synchronization Signal is EXTI2 IT
◆ HAL_DMAMUX2_SYNC_I2C4_WKUP
DMAMUX2 synchronization Signal is I2C4 Wakeup
◆ HAL_DMAMUX2_SYNC_LPTIM2_OUT
DMAMUX2 synchronization Signal is LPTIM2 output
◆ HAL_DMAMUX2_SYNC_LPTIM3_OUT
DMAMUX2 synchronization Signal is LPTIM3 output
◆ HAL_DMAMUX2_SYNC_LPUART1_RX_WKUP
DMAMUX2 synchronization Signal is LPUART1 RX Wakeup
◆ HAL_DMAMUX2_SYNC_LPUART1_TX_WKUP
DMAMUX2 synchronization Signal is LPUART1 TX Wakeup
◆ HAL_DMAMUX2_SYNC_RTC_WKUP
DMAMUX2 synchronization Signal is RTC Wakeup
◆ HAL_DMAMUX2_SYNC_SPI6_WKUP
DMAMUX2 synchronization Signal is SPI6 Wakeup
