bool | T_is_runner (void) |
int | T_snprintf (char *s, size_t n, char const *fmt,...) |
int | T_vprintf (char const *fmt, va_list ap) |
int | T_puts (const char *buf, size_t len) |
size_t | T_str_copy (char *dst, const char *src, size_t n) |
void | T_make_runner (void) |
int | T_printf (char const *fmt,...) |
void | T_log (T_verbosity verbosity, char const *fmt,...) |
T_NO_RETURN void | T_stop (void) |
void | T_plan (unsigned int planned_steps) |
void | T_push_plan (T_fixture_node *node, unsigned int planned_steps) |
void | T_pop_plan (void) |
void | T_check_step (const T_check_context *t, unsigned int expected) |
void | T_case_register (T_case_context *tc) |
T_verbosity | T_set_verbosity (T_verbosity verbosity) |
void * | T_fixture_context (void) |
void | T_set_fixture_context (void *context) |
const char * | T_case_name (void) |
void | T_check (const T_check_context *t, bool ok,...) |
void | T_add_destructor (T_destructor *dtor, void(*destroy)(T_destructor *)) |
void | T_remove_destructor (T_destructor *dtor) |
int | T_main (const T_config *config) |
void | T_register (void) |
void | T_run_initialize (const T_config *config) |
void | T_run_all (void) |
void | T_run_by_name (const char *name) |
void * | T_case_begin (const char *name, const T_fixture *fixture) |
void | T_case_end (void) |
bool | T_run_finalize (void) |
T_time | T_case_begin_time (void) |
void | T_set_putchar (T_putchar new_putchar, void *new_arg, T_putchar *old_putchar, void **old_arg) |
T_time | T_now (void) |
void * | T_push_fixture (T_fixture_node *node, const T_fixture *fixture) |
void | T_pop_fixture (void) |
void | T_add_remark (T_remark *remark) |
size_t | T_get_scope (const char *const *const *desc, char *buf, size_t n, const size_t *second_indices) |
| Gets the scope for nested fixtures.
struct | __attribute__ ((__aligned__(T_BIGGEST_ALIGNMENT))) |
void * | T_malloc (size_t size) |
void * | T_calloc (size_t nelem, size_t elsize) |
void * | T_zalloc (size_t size, void(*destroy)(void *)) |
void | T_free (void *ptr) |
This source file contains the core implementation of RTEMS Test Framework.
