RTEMS 6.1-rc6
Task id and mask for the from trigger. More...
#include <capture.h>
Data Fields | |
rtems_name | name |
rtems_id | id |
uint32_t | trigger |
A from capture is a task id and a mask for the type of from trigger we are interested in. The mask uses the same bit maps as the flags field in the control structure. There will only be a from type trigger if the flags in the control structure has the specific *_BY bit set.
