RTEMS 6.1-rc6
Header file of FMC HAL module. More...
#include "stm32h7xx_hal_def.h"
struct | FMC_NORSRAM_InitTypeDef |
FMC NORSRAM Configuration Structure definition. More... | |
struct | FMC_NORSRAM_TimingTypeDef |
FMC NORSRAM Timing parameters structure definition. More... | |
struct | FMC_NAND_InitTypeDef |
FMC NAND Configuration Structure definition. More... | |
struct | FMC_NAND_PCC_TimingTypeDef |
FMC NAND Timing parameters structure definition. More... | |
struct | FMC_SDRAM_InitTypeDef |
FMC SDRAM Configuration Structure definition. More... | |
struct | FMC_SDRAM_TimingTypeDef |
FMC SDRAM Timing parameters structure definition. More... | |
struct | FMC_SDRAM_CommandTypeDef |
SDRAM command parameters structure definition. More... | |
#define | IS_FMC_NORSRAM_BANK(__BANK__) |
#define | IS_FMC_MUX(__MUX__) |
#define | IS_FMC_MEMORY(__MEMORY__) |
#define | IS_FMC_NORSRAM_MEMORY_WIDTH(__WIDTH__) |
#define | IS_FMC_PAGESIZE(__SIZE__) |
#define | IS_FMC_WRITE_FIFO(__FIFO__) |
#define | IS_FMC_ACCESS_MODE(__MODE__) |
#define | IS_FMC_BURSTMODE(__STATE__) |
#define | IS_FMC_WAIT_POLARITY(__POLARITY__) |
#define | IS_FMC_WAIT_SIGNAL_ACTIVE(__ACTIVE__) |
#define | IS_FMC_WRITE_OPERATION(__OPERATION__) |
#define | IS_FMC_WAITE_SIGNAL(__SIGNAL__) |
#define | IS_FMC_EXTENDED_MODE(__MODE__) |
#define | IS_FMC_ASYNWAIT(__STATE__) |
#define | IS_FMC_DATA_LATENCY(__LATENCY__) (((__LATENCY__) > 1U) && ((__LATENCY__) <= 17U)) |
#define | IS_FMC_WRITE_BURST(__BURST__) |
#define | IS_FMC_CONTINOUS_CLOCK(__CCLOCK__) |
#define | IS_FMC_ADDRESS_SETUP_TIME(__TIME__) ((__TIME__) <= 15U) |
#define | IS_FMC_ADDRESS_HOLD_TIME(__TIME__) (((__TIME__) > 0U) && ((__TIME__) <= 15U)) |
#define | IS_FMC_DATASETUP_TIME(__TIME__) (((__TIME__) > 0U) && ((__TIME__) <= 255U)) |
#define | IS_FMC_DATAHOLD_DURATION(__DATAHOLD__) ((__DATAHOLD__) <= 3U) |
#define | IS_FMC_TURNAROUND_TIME(__TIME__) ((__TIME__) <= 15U) |
#define | IS_FMC_CLK_DIV(__DIV__) (((__DIV__) > 1U) && ((__DIV__) <= 16U)) |
#define | IS_FMC_NORSRAM_DEVICE(__INSTANCE__) ((__INSTANCE__) == FMC_NORSRAM_DEVICE) |
#define | IS_FMC_NORSRAM_EXTENDED_DEVICE(__INSTANCE__) ((__INSTANCE__) == FMC_NORSRAM_EXTENDED_DEVICE) |
#define | IS_FMC_NAND_BANK(__BANK__) ((__BANK__) == FMC_NAND_BANK3) |
#define | IS_FMC_WAIT_FEATURE(__FEATURE__) |
#define | IS_FMC_NAND_MEMORY_WIDTH(__WIDTH__) |
#define | IS_FMC_ECC_STATE(__STATE__) |
#define | IS_FMC_ECCPAGE_SIZE(__SIZE__) |
#define | IS_FMC_TCLR_TIME(__TIME__) ((__TIME__) <= 255U) |
#define | IS_FMC_TAR_TIME(__TIME__) ((__TIME__) <= 255U) |
#define | IS_FMC_SETUP_TIME(__TIME__) ((__TIME__) <= 254U) |
#define | IS_FMC_WAIT_TIME(__TIME__) ((__TIME__) <= 254U) |
#define | IS_FMC_HOLD_TIME(__TIME__) ((__TIME__) <= 254U) |
#define | IS_FMC_HIZ_TIME(__TIME__) ((__TIME__) <= 254U) |
#define | IS_FMC_NAND_DEVICE(__INSTANCE__) ((__INSTANCE__) == FMC_NAND_DEVICE) |
#define | IS_FMC_SDMEMORY_WIDTH(__WIDTH__) |
#define | IS_FMC_WRITE_PROTECTION(__WRITE__) |
#define | IS_FMC_SDCLOCK_PERIOD(__PERIOD__) |
#define | IS_FMC_READ_BURST(__RBURST__) |
#define | IS_FMC_READPIPE_DELAY(__DELAY__) |
#define | IS_FMC_COMMAND_MODE(__COMMAND__) |
#define | IS_FMC_COMMAND_TARGET(__TARGET__) |
#define | IS_FMC_LOADTOACTIVE_DELAY(__DELAY__) (((__DELAY__) > 0U) && ((__DELAY__) <= 16U)) |
#define | IS_FMC_EXITSELFREFRESH_DELAY(__DELAY__) (((__DELAY__) > 0U) && ((__DELAY__) <= 16U)) |
#define | IS_FMC_SELFREFRESH_TIME(__TIME__) (((__TIME__) > 0U) && ((__TIME__) <= 16U)) |
#define | IS_FMC_ROWCYCLE_DELAY(__DELAY__) (((__DELAY__) > 0U) && ((__DELAY__) <= 16U)) |
#define | IS_FMC_WRITE_RECOVERY_TIME(__TIME__) (((__TIME__) > 0U) && ((__TIME__) <= 16U)) |
#define | IS_FMC_RP_DELAY(__DELAY__) (((__DELAY__) > 0U) && ((__DELAY__) <= 16U)) |
#define | IS_FMC_RCD_DELAY(__DELAY__) (((__DELAY__) > 0U) && ((__DELAY__) <= 16U)) |
#define | IS_FMC_AUTOREFRESH_NUMBER(__NUMBER__) (((__NUMBER__) > 0U) && ((__NUMBER__) <= 15U)) |
#define | IS_FMC_MODE_REGISTER(__CONTENT__) ((__CONTENT__) <= 8191U) |
#define | IS_FMC_REFRESH_RATE(__RATE__) ((__RATE__) <= 8191U) |
#define | IS_FMC_SDRAM_DEVICE(__INSTANCE__) ((__INSTANCE__) == FMC_SDRAM_DEVICE) |
#define | IS_FMC_SDRAM_BANK(__BANK__) |
#define | IS_FMC_COLUMNBITS_NUMBER(__COLUMN__) |
#define | IS_FMC_ROWBITS_NUMBER(__ROW__) |
#define | IS_FMC_INTERNALBANK_NUMBER(__NUMBER__) |
#define | IS_FMC_CAS_LATENCY(__LATENCY__) |
#define | FMC_NORSRAM_TypeDef FMC_Bank1_TypeDef |
#define | FMC_NORSRAM_EXTENDED_TypeDef FMC_Bank1E_TypeDef |
#define | FMC_NAND_TypeDef FMC_Bank3_TypeDef |
#define | FMC_SDRAM_TypeDef FMC_Bank5_6_TypeDef |
#define | FMC_NORSRAM_DEVICE FMC_Bank1_R |
#define | FMC_NORSRAM_EXTENDED_DEVICE FMC_Bank1E_R |
#define | FMC_NAND_DEVICE FMC_Bank3_R |
#define | FMC_SDRAM_DEVICE FMC_Bank5_6_R |
#define | FMC_NORSRAM_BANK1 (0x00000000U) |
#define | FMC_NORSRAM_BANK2 (0x00000002U) |
#define | FMC_NORSRAM_BANK3 (0x00000004U) |
#define | FMC_NORSRAM_BANK4 (0x00000006U) |
#define | FMC_DATA_ADDRESS_MUX_DISABLE (0x00000000U) |
#define | FMC_DATA_ADDRESS_MUX_ENABLE (0x00000002U) |
#define | FMC_MEMORY_TYPE_SRAM (0x00000000U) |
#define | FMC_MEMORY_TYPE_PSRAM (0x00000004U) |
#define | FMC_MEMORY_TYPE_NOR (0x00000008U) |
#define | FMC_NORSRAM_MEM_BUS_WIDTH_8 (0x00000000U) |
#define | FMC_NORSRAM_MEM_BUS_WIDTH_16 (0x00000010U) |
#define | FMC_NORSRAM_MEM_BUS_WIDTH_32 (0x00000020U) |
#define | FMC_NORSRAM_FLASH_ACCESS_ENABLE (0x00000040U) |
#define | FMC_NORSRAM_FLASH_ACCESS_DISABLE (0x00000000U) |
#define | FMC_BURST_ACCESS_MODE_DISABLE (0x00000000U) |
#define | FMC_BURST_ACCESS_MODE_ENABLE (0x00000100U) |
#define | FMC_WAIT_SIGNAL_POLARITY_LOW (0x00000000U) |
#define | FMC_WAIT_SIGNAL_POLARITY_HIGH (0x00000200U) |
#define | FMC_WAIT_TIMING_BEFORE_WS (0x00000000U) |
#define | FMC_WAIT_TIMING_DURING_WS (0x00000800U) |
#define | FMC_WRITE_OPERATION_DISABLE (0x00000000U) |
#define | FMC_WRITE_OPERATION_ENABLE (0x00001000U) |
#define | FMC_WAIT_SIGNAL_DISABLE (0x00000000U) |
#define | FMC_WAIT_SIGNAL_ENABLE (0x00002000U) |
#define | FMC_EXTENDED_MODE_DISABLE (0x00000000U) |
#define | FMC_EXTENDED_MODE_ENABLE (0x00004000U) |
#define | FMC_ASYNCHRONOUS_WAIT_DISABLE (0x00000000U) |
#define | FMC_ASYNCHRONOUS_WAIT_ENABLE (0x00008000U) |
#define | FMC_PAGE_SIZE_NONE (0x00000000U) |
#define | FMC_PAGE_SIZE_128 FMC_BCRx_CPSIZE_0 |
#define | FMC_PAGE_SIZE_256 FMC_BCRx_CPSIZE_1 |
#define | FMC_PAGE_SIZE_512 |
#define | FMC_PAGE_SIZE_1024 FMC_BCRx_CPSIZE_2 |
#define | FMC_WRITE_BURST_DISABLE (0x00000000U) |
#define | FMC_WRITE_BURST_ENABLE (0x00080000U) |
#define | FMC_CONTINUOUS_CLOCK_SYNC_ONLY (0x00000000U) |
#define | FMC_CONTINUOUS_CLOCK_SYNC_ASYNC (0x00100000U) |
#define | FMC_ACCESS_MODE_A (0x00000000U) |
#define | FMC_ACCESS_MODE_B (0x10000000U) |
#define | FMC_ACCESS_MODE_C (0x20000000U) |
#define | FMC_ACCESS_MODE_D (0x30000000U) |
#define | FMC_NAND_BANK3 (0x00000100U) |
#define | FMC_NAND_WAIT_FEATURE_DISABLE (0x00000000U) |
#define | FMC_NAND_WAIT_FEATURE_ENABLE (0x00000002U) |
#define | FMC_PCR_MEMORY_TYPE_NAND (0x00000008U) |
#define | FMC_NAND_MEM_BUS_WIDTH_8 (0x00000000U) |
#define | FMC_NAND_MEM_BUS_WIDTH_16 (0x00000010U) |
#define | FMC_NAND_ECC_DISABLE (0x00000000U) |
#define | FMC_NAND_ECC_ENABLE (0x00000040U) |
#define | FMC_NAND_ECC_PAGE_SIZE_256BYTE (0x00000000U) |
#define | FMC_NAND_ECC_PAGE_SIZE_512BYTE (0x00020000U) |
#define | FMC_NAND_ECC_PAGE_SIZE_1024BYTE (0x00040000U) |
#define | FMC_NAND_ECC_PAGE_SIZE_2048BYTE (0x00060000U) |
#define | FMC_NAND_ECC_PAGE_SIZE_4096BYTE (0x00080000U) |
#define | FMC_NAND_ECC_PAGE_SIZE_8192BYTE (0x000A0000U) |
#define | FMC_SDRAM_BANK1 (0x00000000U) |
#define | FMC_SDRAM_BANK2 (0x00000001U) |
#define | FMC_SDRAM_COLUMN_BITS_NUM_8 (0x00000000U) |
#define | FMC_SDRAM_COLUMN_BITS_NUM_9 (0x00000001U) |
#define | FMC_SDRAM_COLUMN_BITS_NUM_10 (0x00000002U) |
#define | FMC_SDRAM_COLUMN_BITS_NUM_11 (0x00000003U) |
#define | FMC_SDRAM_ROW_BITS_NUM_11 (0x00000000U) |
#define | FMC_SDRAM_ROW_BITS_NUM_12 (0x00000004U) |
#define | FMC_SDRAM_ROW_BITS_NUM_13 (0x00000008U) |
#define | FMC_SDRAM_MEM_BUS_WIDTH_8 (0x00000000U) |
#define | FMC_SDRAM_MEM_BUS_WIDTH_16 (0x00000010U) |
#define | FMC_SDRAM_MEM_BUS_WIDTH_32 (0x00000020U) |
#define | FMC_SDRAM_INTERN_BANKS_NUM_2 (0x00000000U) |
#define | FMC_SDRAM_INTERN_BANKS_NUM_4 (0x00000040U) |
#define | FMC_SDRAM_CAS_LATENCY_1 (0x00000080U) |
#define | FMC_SDRAM_CAS_LATENCY_2 (0x00000100U) |
#define | FMC_SDRAM_CAS_LATENCY_3 (0x00000180U) |
#define | FMC_SDRAM_WRITE_PROTECTION_DISABLE (0x00000000U) |
#define | FMC_SDRAM_WRITE_PROTECTION_ENABLE (0x00000200U) |
#define | FMC_SDRAM_CLOCK_DISABLE (0x00000000U) |
#define | FMC_SDRAM_CLOCK_PERIOD_2 (0x00000800U) |
#define | FMC_SDRAM_CLOCK_PERIOD_3 (0x00000C00U) |
#define | FMC_SDRAM_RBURST_DISABLE (0x00000000U) |
#define | FMC_SDRAM_RBURST_ENABLE (0x00001000U) |
#define | FMC_SDRAM_RPIPE_DELAY_0 (0x00000000U) |
#define | FMC_SDRAM_RPIPE_DELAY_1 (0x00002000U) |
#define | FMC_SDRAM_RPIPE_DELAY_2 (0x00004000U) |
#define | FMC_SDRAM_CMD_NORMAL_MODE (0x00000000U) |
#define | FMC_SDRAM_CMD_CLK_ENABLE (0x00000001U) |
#define | FMC_SDRAM_CMD_PALL (0x00000002U) |
#define | FMC_SDRAM_CMD_AUTOREFRESH_MODE (0x00000003U) |
#define | FMC_SDRAM_CMD_LOAD_MODE (0x00000004U) |
#define | FMC_SDRAM_CMD_SELFREFRESH_MODE (0x00000005U) |
#define | FMC_SDRAM_CMD_POWERDOWN_MODE (0x00000006U) |
#define | FMC_SDRAM_CMD_TARGET_BANK2 FMC_SDCMR_CTB2 |
#define | FMC_SDRAM_CMD_TARGET_BANK1 FMC_SDCMR_CTB1 |
#define | FMC_SDRAM_CMD_TARGET_BANK1_2 (0x00000018U) |
#define | FMC_SDRAM_NORMAL_MODE (0x00000000U) |
#define | FMC_SDRAM_SELF_REFRESH_MODE FMC_SDSR_MODES1_0 |
#define | FMC_SDRAM_POWER_DOWN_MODE FMC_SDSR_MODES1_1 |
#define | FMC_IT_RISING_EDGE (0x00000008U) |
#define | FMC_IT_LEVEL (0x00000010U) |
#define | FMC_IT_FALLING_EDGE (0x00000020U) |
#define | FMC_IT_REFRESH_ERROR (0x00004000U) |
#define | FMC_FLAG_RISING_EDGE (0x00000001U) |
#define | FMC_FLAG_LEVEL (0x00000002U) |
#define | FMC_FLAG_FALLING_EDGE (0x00000004U) |
#define | FMC_FLAG_FEMPT (0x00000040U) |
#define | FMC_SDRAM_FLAG_REFRESH_IT FMC_SDSR_RE |
#define | FMC_SDRAM_FLAG_BUSY FMC_SDSR_BUSY |
#define | FMC_SDRAM_FLAG_REFRESH_ERROR FMC_SDRTR_CRE |
#define | __FMC_ENABLE() (FMC_Bank1_R->BTCR[0] |= FMC_BCR1_FMCEN) |
Enable the FMC Peripheral. | |
#define | __FMC_DISABLE() (FMC_Bank1_R->BTCR[0] &= ~FMC_BCR1_FMCEN) |
Disable the FMC Peripheral. | |
#define | __FMC_NORSRAM_ENABLE(__INSTANCE__, __BANK__) |
Enable the NORSRAM device access. | |
#define | __FMC_NORSRAM_DISABLE(__INSTANCE__, __BANK__) |
Disable the NORSRAM device access. | |
#define | __FMC_NAND_ENABLE(__INSTANCE__) ((__INSTANCE__)->PCR |= FMC_PCR_PBKEN) |
Enable the NAND device access. | |
#define | __FMC_NAND_DISABLE(__INSTANCE__, __BANK__) CLEAR_BIT((__INSTANCE__)->PCR, FMC_PCR_PBKEN) |
Disable the NAND device access. | |
#define | __FMC_NAND_ENABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SR |= (__INTERRUPT__)) |
Enable the NAND device interrupt. | |
#define | __FMC_NAND_DISABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SR &= ~(__INTERRUPT__)) |
Disable the NAND device interrupt. | |
#define | __FMC_NAND_GET_FLAG(__INSTANCE__, __BANK__, __FLAG__) (((__INSTANCE__)->SR &(__FLAG__)) == (__FLAG__)) |
Get flag status of the NAND device. | |
#define | __FMC_NAND_CLEAR_FLAG(__INSTANCE__, __FLAG__) ((__INSTANCE__)->SR &= ~(__FLAG__)) |
Clear flag status of the NAND device. | |
#define | __FMC_SDRAM_ENABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SDRTR |= (__INTERRUPT__)) |
Enable the SDRAM device interrupt. | |
#define | __FMC_SDRAM_DISABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->SDRTR &= ~(__INTERRUPT__)) |
Disable the SDRAM device interrupt. | |
#define | __FMC_SDRAM_GET_FLAG(__INSTANCE__, __FLAG__) (((__INSTANCE__)->SDSR &(__FLAG__)) == (__FLAG__)) |
Get flag status of the SDRAM device. | |
#define | __FMC_SDRAM_CLEAR_FLAG(__INSTANCE__, __FLAG__) ((__INSTANCE__)->SDRTR |= (__FLAG__)) |
Clear flag status of the SDRAM device. | |
HAL_StatusTypeDef | FMC_NORSRAM_Init (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_InitTypeDef *Init) |
HAL_StatusTypeDef | FMC_NORSRAM_Timing_Init (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_TimingTypeDef *Timing, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NORSRAM_Extended_Timing_Init (FMC_NORSRAM_EXTENDED_TypeDef *Device, FMC_NORSRAM_TimingTypeDef *Timing, uint32_t Bank, uint32_t ExtendedMode) |
HAL_StatusTypeDef | FMC_NORSRAM_DeInit (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_EXTENDED_TypeDef *ExDevice, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NORSRAM_WriteOperation_Enable (FMC_NORSRAM_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NORSRAM_WriteOperation_Disable (FMC_NORSRAM_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_Init (FMC_NAND_TypeDef *Device, FMC_NAND_InitTypeDef *Init) |
HAL_StatusTypeDef | FMC_NAND_CommonSpace_Timing_Init (FMC_NAND_TypeDef *Device, FMC_NAND_PCC_TimingTypeDef *Timing, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_AttributeSpace_Timing_Init (FMC_NAND_TypeDef *Device, FMC_NAND_PCC_TimingTypeDef *Timing, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_DeInit (FMC_NAND_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_ECC_Enable (FMC_NAND_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_ECC_Disable (FMC_NAND_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_NAND_GetECC (FMC_NAND_TypeDef *Device, uint32_t *ECCval, uint32_t Bank, uint32_t Timeout) |
HAL_StatusTypeDef | FMC_SDRAM_Init (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_InitTypeDef *Init) |
HAL_StatusTypeDef | FMC_SDRAM_Timing_Init (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_TimingTypeDef *Timing, uint32_t Bank) |
HAL_StatusTypeDef | FMC_SDRAM_DeInit (FMC_SDRAM_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_SDRAM_WriteProtection_Enable (FMC_SDRAM_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_SDRAM_WriteProtection_Disable (FMC_SDRAM_TypeDef *Device, uint32_t Bank) |
HAL_StatusTypeDef | FMC_SDRAM_SendCommand (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_CommandTypeDef *Command, uint32_t Timeout) |
HAL_StatusTypeDef | FMC_SDRAM_ProgramRefreshRate (FMC_SDRAM_TypeDef *Device, uint32_t RefreshRate) |
HAL_StatusTypeDef | FMC_SDRAM_SetAutoRefreshNumber (FMC_SDRAM_TypeDef *Device, uint32_t AutoRefreshNumber) |
uint32_t | FMC_SDRAM_GetModeStatus (const FMC_SDRAM_TypeDef *Device, uint32_t Bank) |
