RTEMS 6.1-rc6
This file contains HAL common defines, enumeration, macros and structures definitions. More...
#define | HAL_MAX_DELAY 0xFFFFFFFFU |
#define | HAL_IS_BIT_SET(REG, BIT) (((REG) & (BIT)) == (BIT)) |
#define | HAL_IS_BIT_CLR(REG, BIT) (((REG) & (BIT)) == 0U) |
#define | __HAL_LINKDMA(__HANDLE__, __PPP_DMA_FIELD__, __DMA_HANDLE__) |
#define | UNUSED(x) ((void)(x)) /* To avoid gcc/g++ warnings */ |
#define | __HAL_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = 0) |
Reset the Handle's State field. | |
#define | __HAL_LOCK(__HANDLE__) |
#define | __HAL_UNLOCK(__HANDLE__) |
#define | __ALIGN_END |
Enumerations | |
enum | HAL_StatusTypeDef { HAL_OK = 0x00 , HAL_ERROR = 0x01 , HAL_BUSY = 0x02 , HAL_TIMEOUT = 0x03 } |
HAL Status structures definition. | |
enum | HAL_LockTypeDef { HAL_UNLOCKED = 0x00 , HAL_LOCKED = 0x01 } |
HAL Lock structures definition. | |
#define __HAL_LINKDMA | ( | __HANDLE__, | |
__PPP_DMA_FIELD__, | |||
__DMA_HANDLE__ | |||
#define __HAL_LOCK | ( | __HANDLE__ | ) |
#define __HAL_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = 0) |
__HANDLE__ | specifies the Peripheral Handle. |
None |
#define __HAL_UNLOCK | ( | __HANDLE__ | ) |
