RTEMS 6.1-rc6
Macros | Functions
stm32h7xx_hal_smartcard_ex.h File Reference
Header file of SMARTCARD HAL Extended module. More...
#include "stm32h7xx_hal_def.h"
#define SMARTCARD_TCBGT   SMARTCARD_IT_TCBGT
#define SMARTCARD_TC   SMARTCARD_IT_TC
#define SMARTCARD_ADVFEATURE_NO_INIT   0x00000000U
#define SMARTCARD_ADVFEATURE_TXINVERT_INIT   0x00000001U
#define SMARTCARD_ADVFEATURE_RXINVERT_INIT   0x00000002U
#define SMARTCARD_ADVFEATURE_DATAINVERT_INIT   0x00000004U
#define SMARTCARD_ADVFEATURE_SWAP_INIT   0x00000008U
#define SMARTCARD_ADVFEATURE_RXOVERRUNDISABLE_INIT   0x00000010U
#define SMARTCARD_ADVFEATURE_DMADISABLEONERROR_INIT   0x00000020U
#define SMARTCARD_ADVFEATURE_MSBFIRST_INIT   0x00000080U
#define SMARTCARD_ADVFEATURE_TXCOMPLETION   0x00000100U
#define SMARTCARD_FIFOMODE_DISABLE   0x00000000U
#define SMARTCARD_FIFOMODE_ENABLE   USART_CR1_FIFOEN
#define SMARTCARD_TXFIFO_THRESHOLD_1_8   0x00000000U
#define SMARTCARD_TXFIFO_THRESHOLD_1_4   USART_CR3_TXFTCFG_0
#define SMARTCARD_TXFIFO_THRESHOLD_1_2   USART_CR3_TXFTCFG_1
#define SMARTCARD_TXFIFO_THRESHOLD_3_4   (USART_CR3_TXFTCFG_0|USART_CR3_TXFTCFG_1)
#define SMARTCARD_TXFIFO_THRESHOLD_7_8   USART_CR3_TXFTCFG_2
#define SMARTCARD_TXFIFO_THRESHOLD_8_8   (USART_CR3_TXFTCFG_2|USART_CR3_TXFTCFG_0)
#define SMARTCARD_RXFIFO_THRESHOLD_1_8   0x00000000U
#define SMARTCARD_RXFIFO_THRESHOLD_1_4   USART_CR3_RXFTCFG_0
#define SMARTCARD_RXFIFO_THRESHOLD_1_2   USART_CR3_RXFTCFG_1
#define SMARTCARD_RXFIFO_THRESHOLD_3_4   (USART_CR3_RXFTCFG_0|USART_CR3_RXFTCFG_1)
#define SMARTCARD_RXFIFO_THRESHOLD_7_8   USART_CR3_RXFTCFG_2
#define SMARTCARD_RXFIFO_THRESHOLD_8_8   (USART_CR3_RXFTCFG_2|USART_CR3_RXFTCFG_0)
#define SMARTCARD_FLAG_TCBGT   USART_ISR_TCBGT
#define SMARTCARD_FLAG_REACK   USART_ISR_REACK
#define SMARTCARD_FLAG_TEACK   USART_ISR_TEACK
#define SMARTCARD_FLAG_BUSY   USART_ISR_BUSY
#define SMARTCARD_FLAG_EOBF   USART_ISR_EOBF
#define SMARTCARD_FLAG_RTOF   USART_ISR_RTOF
#define SMARTCARD_FLAG_TXE   USART_ISR_TXE_TXFNF
#define SMARTCARD_FLAG_TXFNF   USART_ISR_TXE_TXFNF
#define SMARTCARD_FLAG_TC   USART_ISR_TC
#define SMARTCARD_FLAG_RXNE   USART_ISR_RXNE_RXFNE
#define SMARTCARD_FLAG_RXFNE   USART_ISR_RXNE_RXFNE
#define SMARTCARD_FLAG_IDLE   USART_ISR_IDLE
#define SMARTCARD_FLAG_ORE   USART_ISR_ORE
#define SMARTCARD_FLAG_NE   USART_ISR_NE
#define SMARTCARD_FLAG_FE   USART_ISR_FE
#define SMARTCARD_FLAG_PE   USART_ISR_PE
#define SMARTCARD_FLAG_TXFE   USART_ISR_TXFE
#define SMARTCARD_FLAG_RXFF   USART_ISR_RXFF
#define SMARTCARD_FLAG_RXFT   USART_ISR_RXFT
#define SMARTCARD_FLAG_TXFT   USART_ISR_TXFT
#define SMARTCARD_IT_PE   0x0028U
#define SMARTCARD_IT_TXE   0x0727U
#define SMARTCARD_IT_TXFNF   0x0727U
#define SMARTCARD_IT_TC   0x0626U
#define SMARTCARD_IT_RXNE   0x0525U
#define SMARTCARD_IT_RXFNE   0x0525U
#define SMARTCARD_IT_IDLE   0x0424U
#define SMARTCARD_IT_ERR   0x0060U
#define SMARTCARD_IT_ORE   0x0300U
#define SMARTCARD_IT_NE   0x0200U
#define SMARTCARD_IT_FE   0x0100U
#define SMARTCARD_IT_EOB   0x0C3BU
#define SMARTCARD_IT_RTO   0x0B3AU
#define SMARTCARD_IT_TCBGT   0x1978U
#define SMARTCARD_IT_RXFF   0x183FU
#define SMARTCARD_IT_TXFE   0x173EU
#define SMARTCARD_IT_RXFT   0x1A7CU
#define SMARTCARD_IT_TXFT   0x1B77U
#define SMARTCARD_CLEAR_PEF   USART_ICR_PECF
#define SMARTCARD_CLEAR_FEF   USART_ICR_FECF
#define SMARTCARD_CLEAR_NEF   USART_ICR_NECF
#define SMARTCARD_CLEAR_OREF   USART_ICR_ORECF
#define SMARTCARD_CLEAR_IDLEF   USART_ICR_IDLECF
#define SMARTCARD_CLEAR_TXFECF   USART_ICR_TXFECF
#define SMARTCARD_CLEAR_TCF   USART_ICR_TCCF
#define SMARTCARD_CLEAR_TCBGTF   USART_ICR_TCBGTCF
#define SMARTCARD_CLEAR_RTOF   USART_ICR_RTOCF
#define SMARTCARD_CLEAR_EOBF   USART_ICR_EOBCF
#define SMARTCARD_TRANSMISSION_COMPLETION_SETTING(__HANDLE__)
 Set the Transmission Completion flag.
#define SMARTCARD_TRANSMISSION_COMPLETION_FLAG(__HANDLE__)    (((__HANDLE__)->AdvancedInit.TxCompletionIndication == SMARTCARD_TC) ? (SMARTCARD_FLAG_TC) : (SMARTCARD_FLAG_TCBGT))
 Return the transmission completion flag.
#define IS_SMARTCARD_TRANSMISSION_COMPLETION(__TXCOMPLETE__)
 Ensure that SMARTCARD frame transmission completion used flag is valid.
#define IS_SMARTCARD_FIFOMODE_STATE(__STATE__)
 Ensure that SMARTCARD FIFO mode is valid.
#define IS_SMARTCARD_TXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that SMARTCARD TXFIFO threshold level is valid.
#define IS_SMARTCARD_RXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that SMARTCARD RXFIFO threshold level is valid.
void HAL_SMARTCARDEx_BlockLength_Config (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t BlockLength)
void HAL_SMARTCARDEx_TimeOut_Config (SMARTCARD_HandleTypeDef *hsmartcard, uint32_t TimeOutValue)
HAL_StatusTypeDef HAL_SMARTCARDEx_EnableReceiverTimeOut (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARDEx_DisableReceiverTimeOut (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARDEx_RxFifoFullCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARDEx_TxFifoEmptyCallback (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARDEx_EnableFifoMode (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARDEx_DisableFifoMode (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARDEx_SetTxFifoThreshold (SMARTCARD_HandleTypeDef *hsmartcard, uint32_t Threshold)
HAL_StatusTypeDef HAL_SMARTCARDEx_SetRxFifoThreshold (SMARTCARD_HandleTypeDef *hsmartcard, uint32_t Threshold)
Author
MCD Application Team
Attention
