20#ifndef STM32H7xx_HAL_I2C_H
21#define STM32H7xx_HAL_I2C_H
168#define HAL_I2C_ERROR_NONE (0x00000000U)
169#define HAL_I2C_ERROR_BERR (0x00000001U)
170#define HAL_I2C_ERROR_ARLO (0x00000002U)
171#define HAL_I2C_ERROR_AF (0x00000004U)
172#define HAL_I2C_ERROR_OVR (0x00000008U)
173#define HAL_I2C_ERROR_DMA (0x00000010U)
174#define HAL_I2C_ERROR_TIMEOUT (0x00000020U)
175#define HAL_I2C_ERROR_SIZE (0x00000040U)
176#define HAL_I2C_ERROR_DMA_PARAM (0x00000080U)
177#if (USE_HAL_I2C_REGISTER_CALLBACKS == 1)
178#define HAL_I2C_ERROR_INVALID_CALLBACK (0x00000100U)
180#define HAL_I2C_ERROR_INVALID_PARAM (0x00000200U)
229#if (USE_HAL_I2C_REGISTER_CALLBACKS == 1)
249 void (* AddrCallback)(
struct __I2C_HandleTypeDef *hi2c, uint8_t TransferDirection, uint16_t AddrMatchCode);
260#if (USE_HAL_I2C_REGISTER_CALLBACKS == 1)
266 HAL_I2C_MASTER_TX_COMPLETE_CB_ID = 0x00U,
267 HAL_I2C_MASTER_RX_COMPLETE_CB_ID = 0x01U,
268 HAL_I2C_SLAVE_TX_COMPLETE_CB_ID = 0x02U,
269 HAL_I2C_SLAVE_RX_COMPLETE_CB_ID = 0x03U,
270 HAL_I2C_LISTEN_COMPLETE_CB_ID = 0x04U,
271 HAL_I2C_MEM_TX_COMPLETE_CB_ID = 0x05U,
272 HAL_I2C_MEM_RX_COMPLETE_CB_ID = 0x06U,
273 HAL_I2C_ERROR_CB_ID = 0x07U,
274 HAL_I2C_ABORT_CB_ID = 0x08U,
276 HAL_I2C_MSPINIT_CB_ID = 0x09U,
277 HAL_I2C_MSPDEINIT_CB_ID = 0x0AU
279} HAL_I2C_CallbackIDTypeDef;
286typedef void (*pI2C_AddrCallbackTypeDef)(
287 uint16_t AddrMatchCode);
309#define I2C_FIRST_FRAME ((uint32_t)I2C_SOFTEND_MODE)
310#define I2C_FIRST_AND_NEXT_FRAME ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE))
311#define I2C_NEXT_FRAME ((uint32_t)(I2C_RELOAD_MODE | I2C_SOFTEND_MODE))
312#define I2C_FIRST_AND_LAST_FRAME ((uint32_t)I2C_AUTOEND_MODE)
313#define I2C_LAST_FRAME ((uint32_t)I2C_AUTOEND_MODE)
314#define I2C_LAST_FRAME_NO_STOP ((uint32_t)I2C_SOFTEND_MODE)
319#define I2C_OTHER_FRAME (0x000000AAU)
320#define I2C_OTHER_AND_LAST_FRAME (0x0000AA00U)
329#define I2C_ADDRESSINGMODE_7BIT (0x00000001U)
330#define I2C_ADDRESSINGMODE_10BIT (0x00000002U)
339#define I2C_DUALADDRESS_DISABLE (0x00000000U)
340#define I2C_DUALADDRESS_ENABLE I2C_OAR2_OA2EN
349#define I2C_OA2_NOMASK ((uint8_t)0x00U)
350#define I2C_OA2_MASK01 ((uint8_t)0x01U)
351#define I2C_OA2_MASK02 ((uint8_t)0x02U)
352#define I2C_OA2_MASK03 ((uint8_t)0x03U)
353#define I2C_OA2_MASK04 ((uint8_t)0x04U)
354#define I2C_OA2_MASK05 ((uint8_t)0x05U)
355#define I2C_OA2_MASK06 ((uint8_t)0x06U)
356#define I2C_OA2_MASK07 ((uint8_t)0x07U)
365#define I2C_GENERALCALL_DISABLE (0x00000000U)
366#define I2C_GENERALCALL_ENABLE I2C_CR1_GCEN
375#define I2C_NOSTRETCH_DISABLE (0x00000000U)
376#define I2C_NOSTRETCH_ENABLE I2C_CR1_NOSTRETCH
385#define I2C_MEMADD_SIZE_8BIT (0x00000001U)
386#define I2C_MEMADD_SIZE_16BIT (0x00000002U)
395#define I2C_DIRECTION_TRANSMIT (0x00000000U)
396#define I2C_DIRECTION_RECEIVE (0x00000001U)
405#define I2C_RELOAD_MODE I2C_CR2_RELOAD
406#define I2C_AUTOEND_MODE I2C_CR2_AUTOEND
407#define I2C_SOFTEND_MODE (0x00000000U)
416#define I2C_NO_STARTSTOP (0x00000000U)
417#define I2C_GENERATE_STOP (uint32_t)(0x80000000U | I2C_CR2_STOP)
418#define I2C_GENERATE_START_READ (uint32_t)(0x80000000U | I2C_CR2_START | I2C_CR2_RD_WRN)
419#define I2C_GENERATE_START_WRITE (uint32_t)(0x80000000U | I2C_CR2_START)
431#define I2C_IT_ERRI I2C_CR1_ERRIE
432#define I2C_IT_TCI I2C_CR1_TCIE
433#define I2C_IT_STOPI I2C_CR1_STOPIE
434#define I2C_IT_NACKI I2C_CR1_NACKIE
435#define I2C_IT_ADDRI I2C_CR1_ADDRIE
436#define I2C_IT_RXI I2C_CR1_RXIE
437#define I2C_IT_TXI I2C_CR1_TXIE
446#define I2C_FLAG_TXE I2C_ISR_TXE
447#define I2C_FLAG_TXIS I2C_ISR_TXIS
448#define I2C_FLAG_RXNE I2C_ISR_RXNE
449#define I2C_FLAG_ADDR I2C_ISR_ADDR
450#define I2C_FLAG_AF I2C_ISR_NACKF
451#define I2C_FLAG_STOPF I2C_ISR_STOPF
452#define I2C_FLAG_TC I2C_ISR_TC
453#define I2C_FLAG_TCR I2C_ISR_TCR
454#define I2C_FLAG_BERR I2C_ISR_BERR
455#define I2C_FLAG_ARLO I2C_ISR_ARLO
456#define I2C_FLAG_OVR I2C_ISR_OVR
457#define I2C_FLAG_PECERR I2C_ISR_PECERR
458#define I2C_FLAG_TIMEOUT I2C_ISR_TIMEOUT
459#define I2C_FLAG_ALERT I2C_ISR_ALERT
460#define I2C_FLAG_BUSY I2C_ISR_BUSY
461#define I2C_FLAG_DIR I2C_ISR_DIR
481#if (USE_HAL_I2C_REGISTER_CALLBACKS == 1)
482#define __HAL_I2C_RESET_HANDLE_STATE(__HANDLE__) do{ \
483 (__HANDLE__)->State = HAL_I2C_STATE_RESET; \
484 (__HANDLE__)->MspInitCallback = NULL; \
485 (__HANDLE__)->MspDeInitCallback = NULL; \
488#define __HAL_I2C_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_I2C_STATE_RESET)
505#define __HAL_I2C_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__))
521#define __HAL_I2C_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__)))
537#define __HAL_I2C_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->CR1 & \
538 (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET)
563#define I2C_FLAG_MASK (0x0001FFFFU)
564#define __HAL_I2C_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & \
565 (__FLAG__)) == (__FLAG__)) ? SET : RESET)
584#define __HAL_I2C_CLEAR_FLAG(__HANDLE__, __FLAG__) (((__FLAG__) == I2C_FLAG_TXE) ? \
585 ((__HANDLE__)->Instance->ISR |= (__FLAG__)) : \
586 ((__HANDLE__)->Instance->ICR = (__FLAG__)))
592#define __HAL_I2C_ENABLE(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
598#define __HAL_I2C_DISABLE(__HANDLE__) (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
604#define __HAL_I2C_GENERATE_NACK(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK))
627#if (USE_HAL_I2C_REGISTER_CALLBACKS == 1)
629 pI2C_CallbackTypeDef pCallback);
645 uint16_t Size, uint32_t Timeout);
647 uint16_t Size, uint32_t Timeout);
653 uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout);
655 uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout);
667 uint16_t MemAddSize, uint8_t *pData, uint16_t Size);
669 uint16_t MemAddSize, uint8_t *pData, uint16_t Size);
691 uint16_t MemAddSize, uint8_t *pData, uint16_t Size);
693 uint16_t MemAddSize, uint8_t *pData, uint16_t Size);
717void HAL_I2C_AddrCallback(
759#define IS_I2C_ADDRESSING_MODE(MODE) (((MODE) == I2C_ADDRESSINGMODE_7BIT) || \
760 ((MODE) == I2C_ADDRESSINGMODE_10BIT))
762#define IS_I2C_DUAL_ADDRESS(ADDRESS) (((ADDRESS) == I2C_DUALADDRESS_DISABLE) || \
763 ((ADDRESS) == I2C_DUALADDRESS_ENABLE))
765#define IS_I2C_OWN_ADDRESS2_MASK(MASK) (((MASK) == I2C_OA2_NOMASK) || \
766 ((MASK) == I2C_OA2_MASK01) || \
767 ((MASK) == I2C_OA2_MASK02) || \
768 ((MASK) == I2C_OA2_MASK03) || \
769 ((MASK) == I2C_OA2_MASK04) || \
770 ((MASK) == I2C_OA2_MASK05) || \
771 ((MASK) == I2C_OA2_MASK06) || \
772 ((MASK) == I2C_OA2_MASK07))
774#define IS_I2C_GENERAL_CALL(CALL) (((CALL) == I2C_GENERALCALL_DISABLE) || \
775 ((CALL) == I2C_GENERALCALL_ENABLE))
777#define IS_I2C_NO_STRETCH(STRETCH) (((STRETCH) == I2C_NOSTRETCH_DISABLE) || \
778 ((STRETCH) == I2C_NOSTRETCH_ENABLE))
780#define IS_I2C_MEMADD_SIZE(SIZE) (((SIZE) == I2C_MEMADD_SIZE_8BIT) || \
781 ((SIZE) == I2C_MEMADD_SIZE_16BIT))
783#define IS_TRANSFER_MODE(MODE) (((MODE) == I2C_RELOAD_MODE) || \
784 ((MODE) == I2C_AUTOEND_MODE) || \
785 ((MODE) == I2C_SOFTEND_MODE))
787#define IS_TRANSFER_REQUEST(REQUEST) (((REQUEST) == I2C_GENERATE_STOP) || \
788 ((REQUEST) == I2C_GENERATE_START_READ) || \
789 ((REQUEST) == I2C_GENERATE_START_WRITE) || \
790 ((REQUEST) == I2C_NO_STARTSTOP))
792#define IS_I2C_TRANSFER_OPTIONS_REQUEST(REQUEST) (((REQUEST) == I2C_FIRST_FRAME) || \
793 ((REQUEST) == I2C_FIRST_AND_NEXT_FRAME) || \
794 ((REQUEST) == I2C_NEXT_FRAME) || \
795 ((REQUEST) == I2C_FIRST_AND_LAST_FRAME) || \
796 ((REQUEST) == I2C_LAST_FRAME) || \
797 ((REQUEST) == I2C_LAST_FRAME_NO_STOP) || \
798 IS_I2C_TRANSFER_OTHER_OPTIONS_REQUEST(REQUEST))
800#define IS_I2C_TRANSFER_OTHER_OPTIONS_REQUEST(REQUEST) (((REQUEST) == I2C_OTHER_FRAME) || \
801 ((REQUEST) == I2C_OTHER_AND_LAST_FRAME))
803#define I2C_RESET_CR2(__HANDLE__) ((__HANDLE__)->Instance->CR2 &= \
804 (uint32_t)~((uint32_t)(I2C_CR2_SADD | I2C_CR2_HEAD10R | \
805 I2C_CR2_NBYTES | I2C_CR2_RELOAD | \
808#define I2C_GET_ADDR_MATCH(__HANDLE__) ((uint16_t)(((__HANDLE__)->Instance->ISR & I2C_ISR_ADDCODE) \
810#define I2C_GET_DIR(__HANDLE__) ((uint8_t)(((__HANDLE__)->Instance->ISR & I2C_ISR_DIR) \
812#define I2C_GET_STOP_MODE(__HANDLE__) ((__HANDLE__)->Instance->CR2 & I2C_CR2_AUTOEND)
813#define I2C_GET_OWN_ADDRESS1(__HANDLE__) ((uint16_t)((__HANDLE__)->Instance->OAR1 & I2C_OAR1_OA1))
814#define I2C_GET_OWN_ADDRESS2(__HANDLE__) ((uint16_t)((__HANDLE__)->Instance->OAR2 & I2C_OAR2_OA2))
816#define IS_I2C_OWN_ADDRESS1(ADDRESS1) ((ADDRESS1) <= 0x000003FFU)
817#define IS_I2C_OWN_ADDRESS2(ADDRESS2) ((ADDRESS2) <= (uint16_t)0x00FFU)
819#define I2C_MEM_ADD_MSB(__ADDRESS__) ((uint8_t)((uint16_t)(((uint16_t)((__ADDRESS__) & \
820 (uint16_t)(0xFF00U))) >> 8U)))
821#define I2C_MEM_ADD_LSB(__ADDRESS__) ((uint8_t)((uint16_t)((__ADDRESS__) & (uint16_t)(0x00FFU))))
823#define I2C_GENERATE_START(__ADDMODE__,__ADDRESS__) (((__ADDMODE__) == I2C_ADDRESSINGMODE_7BIT) ? \
824 (uint32_t)((((uint32_t)(__ADDRESS__) & (I2C_CR2_SADD)) | \
825 (I2C_CR2_START) | (I2C_CR2_AUTOEND)) & \
826 (~I2C_CR2_RD_WRN)) : \
827 (uint32_t)((((uint32_t)(__ADDRESS__) & (I2C_CR2_SADD)) | \
828 (I2C_CR2_ADD10) | (I2C_CR2_START) | \
829 (I2C_CR2_AUTOEND)) & (~I2C_CR2_RD_WRN)))
831#define I2C_CHECK_FLAG(__ISR__, __FLAG__) ((((__ISR__) & ((__FLAG__) & I2C_FLAG_MASK)) == \
832 ((__FLAG__) & I2C_FLAG_MASK)) ? SET : RESET)
833#define I2C_CHECK_IT_SOURCE(__CR1__, __IT__) ((((__CR1__) & (__IT__)) == (__IT__)) ? SET : RESET)
#define __IO
Definition: core_cm4.h:239
HAL_I2C_ModeTypeDef
Definition: stm32h7xx_hal_i2c.h:151
@ HAL_I2C_MODE_MASTER
Definition: stm32h7xx_hal_i2c.h:153
@ HAL_I2C_MODE_MEM
Definition: stm32h7xx_hal_i2c.h:155
@ HAL_I2C_MODE_SLAVE
Definition: stm32h7xx_hal_i2c.h:154
@ HAL_I2C_MODE_NONE
Definition: stm32h7xx_hal_i2c.h:152
HAL_I2C_StateTypeDef
Definition: stm32h7xx_hal_i2c.h:112
@ HAL_I2C_STATE_BUSY
Definition: stm32h7xx_hal_i2c.h:115
@ HAL_I2C_STATE_LISTEN
Definition: stm32h7xx_hal_i2c.h:118
@ HAL_I2C_STATE_BUSY_TX_LISTEN
Definition: stm32h7xx_hal_i2c.h:119
@ HAL_I2C_STATE_ABORT
Definition: stm32h7xx_hal_i2c.h:123
@ HAL_I2C_STATE_BUSY_RX
Definition: stm32h7xx_hal_i2c.h:117
@ HAL_I2C_STATE_BUSY_RX_LISTEN
Definition: stm32h7xx_hal_i2c.h:121
@ HAL_I2C_STATE_RESET
Definition: stm32h7xx_hal_i2c.h:113
Definition: stm32h7xx_hal_i2c.h:116
@ HAL_I2C_STATE_READY
Definition: stm32h7xx_hal_i2c.h:114
This file contains HAL common defines, enumeration, macros and structures definitions.
HAL_StatusTypeDef
HAL Status structures definition.
Definition: stm32h7xx_hal_def.h:47
HAL_LockTypeDef
HAL Lock structures definition.
Definition: stm32h7xx_hal_def.h:58
Header file of I2C HAL Extended module.
Definition: stm32h7xx_hal_i2c.h:50
uint32_t GeneralCallMode
Definition: stm32h7xx_hal_i2c.h:71
uint32_t NoStretchMode
Definition: stm32h7xx_hal_i2c.h:74
uint32_t OwnAddress2Masks
Definition: stm32h7xx_hal_i2c.h:67
uint32_t AddressingMode
Definition: stm32h7xx_hal_i2c.h:58
Definition: stm32h7xx_hal_i2c.h:64
uint32_t Timing
Definition: stm32h7xx_hal_i2c.h:51
uint32_t OwnAddress1
Definition: stm32h7xx_hal_i2c.h:55
uint32_t DualAddressMode
Definition: stm32h7xx_hal_i2c.h:61
Inter-integrated Circuit Interface.
Definition: stm32h723xx.h:1133
DMA handle Structure definition.
Definition: stm32h7xx_hal_dma.h:138
Definition: stm32h7xx_hal_i2c.h:191
__IO uint32_t PreviousState
Definition: stm32h7xx_hal_i2c.h:205
I2C_TypeDef * Instance
Definition: stm32h7xx_hal_i2c.h:192
uint16_t XferSize
Definition: stm32h7xx_hal_i2c.h:198
HAL_StatusTypeDef(* XferISR)(struct __I2C_HandleTypeDef *hi2c, uint32_t ITFlags, uint32_t ITSources)
Definition: stm32h7xx_hal_i2c.h:207
__IO uint16_t XferCount
Definition: stm32h7xx_hal_i2c.h:200
__IO HAL_I2C_StateTypeDef State
Definition: stm32h7xx_hal_i2c.h:217
__IO uint32_t Memaddress
Definition: stm32h7xx_hal_i2c.h:227
DMA_HandleTypeDef * hdmarx
Definition: stm32h7xx_hal_i2c.h:212
__IO uint32_t XferOptions
Definition: stm32h7xx_hal_i2c.h:202
__IO uint32_t Devaddress
Definition: stm32h7xx_hal_i2c.h:225
__IO uint32_t ErrorCode
Definition: stm32h7xx_hal_i2c.h:221
I2C_InitTypeDef Init
Definition: stm32h7xx_hal_i2c.h:194
HAL_LockTypeDef Lock
Definition: stm32h7xx_hal_i2c.h:215
__IO HAL_I2C_ModeTypeDef Mode
Definition: stm32h7xx_hal_i2c.h:219
__IO uint32_t AddrEventCount
Definition: stm32h7xx_hal_i2c.h:223
DMA_HandleTypeDef * hdmatx
Definition: stm32h7xx_hal_i2c.h:210
uint8_t * pBuffPtr
Definition: stm32h7xx_hal_i2c.h:196
