RTEMS 6.1-rc6
RTEMS File Systems Inode Routines. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-block.h>
#include <rtems/rfs/rtems-rfs-inode.h>
#include <rtems/rfs/rtems-rfs-dir.h>
int rtems_rfs_inode_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino)
int rtems_rfs_inode_free (rtems_rfs_file_system *fs, rtems_rfs_ino ino)
int rtems_rfs_inode_open (rtems_rfs_file_system *fs, rtems_rfs_ino ino, rtems_rfs_inode_handle *handle, bool load)
int rtems_rfs_inode_close (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
int rtems_rfs_inode_load (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
int rtems_rfs_inode_unload (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle, bool update_ctime)
int rtems_rfs_inode_create (rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino)
int rtems_rfs_inode_delete (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
int rtems_rfs_inode_initialise (rtems_rfs_inode_handle *handle, uint16_t links, uint16_t mode, uid_t uid, gid_t gid)
int rtems_rfs_inode_time_stamp_now (rtems_rfs_inode_handle *handle, bool atime, bool mtime)
rtems_rfs_pos rtems_rfs_inode_get_size (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
These functions manage inodes in the RFS file system. An inode is part of a block that reside after the bitmaps in the group.
◆ rtems_rfs_inode_alloc()
int rtems_rfs_inode_alloc ( rtems_rfs_file_system fs,
rtems_rfs_ino ino
Allocate an inode number and return it.
Parameters
[in]fsis the file system data.
[out]inowill contain the ino.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_inode_close()
int rtems_rfs_inode_close ( rtems_rfs_file_system fs,
rtems_rfs_inode_handle handle
The close inode handle. All opened inodes need to be closed.
Parameters
[in]fsis the file system.
[in]handleis the handle to close.
Return values
◆ rtems_rfs_inode_create()
int rtems_rfs_inode_create ( rtems_rfs_file_system fs,
const char *  name,
size_t  length,
uint16_t  mode,
uint16_t  links,
uid_t  uid,
gid_t  gid,
rtems_rfs_ino ino
Create an inode allocating, initialising and adding an entry to the parent directory.
Parameters
[in]parentis the parent inode number to add the directory entry to.
[in]nameis a pointer to the name of the directory entryinode to create.
◆ rtems_rfs_inode_delete()
int rtems_rfs_inode_delete ( rtems_rfs_file_system fs,
Delete the inode eraseing it and release the buffer to commit the write. You need to load the inode again if you wish to use it again.
Parameters
[in]handleis the inode handle to erase.
Return values
◆ rtems_rfs_inode_free()
int rtems_rfs_inode_free ( rtems_rfs_file_system fs,
rtems_rfs_ino  ino
Free an inode.
Parameters
[in]inois the ino too free.
Return values
◆ rtems_rfs_inode_get_size()
rtems_rfs_pos rtems_rfs_inode_get_size ( rtems_rfs_file_system fs,
Calculate the size of data attached to the inode.
Parameters
[in]handleis the inode handle.
Return values
sizeThe data size in bytes in the block map attched to the inode.
◆ rtems_rfs_inode_initialise()
int rtems_rfs_inode_initialise ( rtems_rfs_inode_handle handle,
uint16_t  links,
uint16_t  mode,
uid_t  uid,
gid_t  gid
Initialise a new inode.
Parameters
[in]handleis the inode handle to initialise.
[in]linksare the number of links to the inode.
[in]modeis the inode mode.
[in]uidis the user id.
[in]gidis the group id.
Return values
◆ rtems_rfs_inode_load()
int rtems_rfs_inode_load ( rtems_rfs_file_system fs,
Load the inode into memory.
Parameters
[in]handleis the inode handle to load.
Return values
◆ rtems_rfs_inode_open()
int rtems_rfs_inode_open ( rtems_rfs_file_system fs,
rtems_rfs_ino  ino,
bool  load
Open the inode handle. This reads the inode into the buffer and sets the data pointer. All data is in media byte order and needs to be accessed via the supporting calls.
Parameters
[in]inois the inode number.
[in]handleis the handle to the inode we are opening.
[in]loadIf true load the inode into memory from the media.
Return values
◆ rtems_rfs_inode_time_stamp_now()
int rtems_rfs_inode_time_stamp_now ( rtems_rfs_inode_handle handle,
bool  atime,
bool  mtime
Time stamp the inode with the current time. The ctime field is hanlded automatically.
Parameters
[in]atimeUpdate the atime field.
[in]mtimeUPdate the mtime field.
Return values
ENXIONo inode is loaded.
◆ rtems_rfs_inode_unload()
int rtems_rfs_inode_unload ( rtems_rfs_file_system fs,
bool  update_ctime
Unload the inode from memory.
Parameters
[in]handleis the inode handle to unload.
[in]update_ctimeUpdate the ctime field of the inode.
Return values
