RTEMS 6.1-rc6
Data Structures | Macros | Typedefs
qreslib.h File Reference
Constants and Structures Associated with the QoS RES library in RTEMS. More...
#include <stdint.h>
#include <rtems/score/schedulercbs.h>
struct  qres_params_t
#define QOS_OK   SCHEDULER_CBS_OK
#define QOS_E_GENERIC   SCHEDULER_CBS_ERROR_GENERIC
#define QOS_E_NO_MEMORY   SCHEDULER_CBS_ERROR_NO_MEMORY
#define QOS_E_INVALID_PARAM   SCHEDULER_CBS_ERROR_INVALID_PARAMETER
#define QOS_E_UNAUTHORIZED   SCHEDULER_CBS_ERROR_UNAUTHORIZED
#define QOS_E_UNIMPLEMENTED   SCHEDULER_CBS_ERROR_UNIMPLEMENTED
#define QOS_E_MISSING_COMPONENT   SCHEDULER_CBS_ERROR_MISSING_COMPONENT
#define QOS_E_INCONSISTENT_STATE   SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
#define QOS_E_SYSTEM_OVERLOAD   SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
#define QOS_E_INTERNAL_ERROR   SCHEDULER_CBS_ERROR_INTERNAL_ERROR
#define QOS_E_NOT_FOUND   SCHEDULER_CBS_ERROR_NOT_FOUND
#define QOS_E_FULL   SCHEDULER_CBS_ERROR_FULL
#define QOS_E_EMPTY   SCHEDULER_CBS_ERROR_EMPTY
#define QOS_E_NOSERVER   SCHEDULER_CBS_ERROR_NOSERVER
typedef int qos_rv
typedef Scheduler_CBS_Server_id qres_sid_t
typedef rtems_id tid_t
typedef time_t qres_time_t
typedef time_t qres_atime_t
This include file contains all the constants and structures associated with the QoS RES library in RTEMS.
Note
The library is available only together with CBS scheduler.
Typedef Documentation
◆ qos_rv
typedef int qos_rv
Return values.
◆ qres_atime_t
Absolute time value
◆ qres_sid_t
Server id.
◆ qres_time_t
Time value.
◆ tid_t
Task id.
