RTEMS 6.1-rc6
Macros | Functions
semaphoreimpl.h File Reference
Private Inlined Routines for POSIX Semaphores. More...
#include <rtems/posix/semaphore.h>
#include <rtems/posix/posixapi.h>
#include <rtems/score/semaphoreimpl.h>
#include <rtems/seterr.h>
#define POSIX_SEMAPHORE_MAGIC   0x5d367fe7UL
 This is a random number used to check if a semaphore object is properly initialized.
#define POSIX_SEMAPHORE_VALIDATE_OBJECT(sem)
void _POSIX_Semaphore_Delete (POSIX_Semaphore_Control *the_semaphore)
 POSIX Semaphore Delete.
This include file contains the static inline implementation of the private inlined routines for POSIX Semaphores.
◆ POSIX_SEMAPHORE_VALIDATE_OBJECT
#define POSIX_SEMAPHORE_VALIDATE_OBJECT (   sem)
Value:
do { \
if ( \
( sem ) == NULL \
|| ( (uintptr_t) ( sem ) ^ POSIX_SEMAPHORE_MAGIC ) != ( sem )->_flags \
rtems_set_errno_and_return_minus_one( EINVAL ); \
} while ( 0 )
Definition: semaphoreimpl.h:54
◆ _POSIX_Semaphore_Delete()
void _POSIX_Semaphore_Delete ( POSIX_Semaphore_Control the_semaphore)
This routine supports the sem_close and sem_unlink routines.
