RTEMS 6.1-rc6
Data Structures | Macros | Typedefs | Enumerations
Xbara
struct  XBARAControlConfig
 Defines the configuration structure of the XBARA control register. More...
#define FSL_XBARA_DRIVER_VERSION   (MAKE_VERSION(2, 0, 5))
#define XBARA_SELx(base, output)   (((volatile uint16_t *)(&((base)->SEL0)))[(uint32_t)(output) / 2UL])
#define XBARA_WR_SELx_SELx(base, input, output)   XBARA_SetSignalsConnection((base), (input), (output))
#define kXBARA_RequestInterruptEnalbe   kXBARA_RequestInterruptEnable
typedef enum _xbara_active_edge xbara_active_edge_t
 XBARA active edge for detection.
typedef enum _xbar_request xbara_request_t
 Defines the XBARA DMA and interrupt configurations.
typedef enum _xbara_status_flag_t xbara_status_flag_t
 XBARA status flags.
typedef struct XBARAControlConfig xbara_control_config_t
enum  _xbara_active_edge { kXBARA_EdgeNone = 0U , kXBARA_EdgeRising = 1U , kXBARA_EdgeFalling = 2U , kXBARA_EdgeRisingAndFalling = 3U }
 XBARA active edge for detection. More...
enum  _xbar_request { kXBARA_RequestDisable = 0U , kXBARA_RequestDMAEnable = 1U , kXBARA_RequestInterruptEnable = 2U }
 Defines the XBARA DMA and interrupt configurations. More...
enum  _xbara_status_flag_t { kXBARA_EdgeDetectionOut0 , kXBARA_EdgeDetectionOut1 , kXBARA_EdgeDetectionOut2 , kXBARA_EdgeDetectionOut3 }
 XBARA status flags. More...
XBARA functional Operation.
void XBARA_Init (XBARA_Type *base)
 Initializes the XBARA module.
void XBARA_Deinit (XBARA_Type *base)
 Shuts down the XBARA module.
void XBARA_SetSignalsConnection (XBARA_Type *base, xbar_input_signal_t input, xbar_output_signal_t output)
 Sets a connection between the selected XBARA_IN[*] input and the XBARA_OUT[*] output signal.
uint32_t XBARA_GetStatusFlags (XBARA_Type *base)
 Gets the active edge detection status.
void XBARA_ClearStatusFlags (XBARA_Type *base, uint32_t mask)
 Clears the edge detection status flags of relative mask.
void XBARA_SetOutputSignalConfig (XBARA_Type *base, xbar_output_signal_t output, const xbara_control_config_t *controlConfig)
 Configures the XBARA control register.
Typedef Documentation
◆ xbara_control_config_t
This structure keeps the configuration of XBARA control register for one output. Control registers are available only for a few outputs. Not every XBARA module has control registers.
◆ xbara_status_flag_t
XBARA status flags.
This provides constants for the XBARA status flags for use in the XBARA functions.
◆ _xbar_request
Interrupt and DMA are disabled.
DMA enabled, interrupt disabled.
Interrupt enabled, DMA disabled.
◆ _xbara_active_edge
kXBARA_EdgeNone
Edge detection status bit never asserts.
kXBARA_EdgeRising
Edge detection status bit asserts on rising edges.
kXBARA_EdgeFalling
Edge detection status bit asserts on falling edges.
Edge detection status bit asserts on rising and falling edges.
◆ _xbara_status_flag_t
XBARA status flags.
XBAR_OUT0 active edge interrupt flag, sets when active edge detected.
XBAR_OUT1 active edge interrupt flag, sets when active edge detected.
XBAR_OUT2 active edge interrupt flag, sets when active edge detected.
XBAR_OUT3 active edge interrupt flag, sets when active edge detected.
◆ XBARA_ClearStatusFlags()
void XBARA_ClearStatusFlags ( XBARA_Type base,
uint32_t  mask
Parameters
baseXBARA peripheral address.
maskthe status flags to clear.
brief Clears the edge detection status flags of relative mask.
param base XBARA peripheral address. param mask the status flags to clear.
◆ XBARA_Deinit()
void XBARA_Deinit ( XBARA_Type base)
This function disables XBARA clock.
Parameters
brief Shuts down the XBARA module.
◆ XBARA_GetStatusFlags()
uint32_t XBARA_GetStatusFlags ( XBARA_Type base)
This function gets the active edge detect status of all XBARA_OUTs. If the active edge occurs, the return value is asserted. When the interrupt or the DMA functionality is enabled for the XBARA_OUTx, this field is 1 when the interrupt or DMA request is asserted and 0 when the interrupt or DMA request has been cleared.
Parameters
Returns
the mask of these status flag bits.
brief Gets the active edge detection status.
param base XBARA peripheral address. return the mask of these status flag bits.
◆ XBARA_Init()
void XBARA_Init ( XBARA_Type base)
This function un-gates the XBARA clock.
Parameters
brief Initializes the XBARA module.
◆ XBARA_SetOutputSignalConfig()
void XBARA_SetOutputSignalConfig ( XBARA_Type base,
const xbara_control_config_t controlConfig
This function configures an XBARA control register. The active edge detection and the DMA/IRQ function on the corresponding XBARA output can be set.
Example:
userConfig.requestType = kXBARA_RequestInterruptEnalbe;
XBARA_SetOutputSignalConfig(XBARA, kXBARA_OutputDMAMUX18, &userConfig);
void XBARA_SetOutputSignalConfig(XBARA_Type *base, xbar_output_signal_t output, const xbara_control_config_t *controlConfig)
Definition: fsl_xbara.c:206
@ kXBARA_EdgeRising
Definition: fsl_xbara.h:40
Definition: fsl_xbara.h:80
xbara_request_t requestType
Definition: fsl_xbara.h:82
xbara_active_edge_t activeEdge
Definition: fsl_xbara.h:81
Parameters
outputXBARA output number.
controlConfigPointer to structure that keeps configuration of control register.
brief Configures the XBARA control register.
Example: code xbara_control_config_t userConfig; userConfig.activeEdge = kXBARA_EdgeRising; userConfig.requestType = kXBARA_RequestInterruptEnalbe; XBARA_SetOutputSignalConfig(XBARA, kXBARA_OutputDMAMUX18, &userConfig); endcode
param base XBARA peripheral address. param output XBARA output number. param controlConfig Pointer to structure that keeps configuration of control register.
◆ XBARA_SetSignalsConnection()
void XBARA_SetSignalsConnection ( XBARA_Type base,
This function connects the XBARA input to the selected XBARA output. If more than one XBARA module is available, only the inputs and outputs from the same module can be connected.
Example:
XBARA_SetSignalsConnection(XBARA, kXBARA_InputPIT_TRG0, kXBARA_OutputDMAMUX18);
void XBARA_SetSignalsConnection(XBARA_Type *base, xbar_input_signal_t input, xbar_output_signal_t output)
Definition: fsl_xbara.c:121
Parameters
inputXBARA input signal.
outputXBARA output signal.
brief Sets a connection between the selected XBARA_IN[*] input and the XBARA_OUT[*] output signal.
Example: code XBARA_SetSignalsConnection(XBARA, kXBARA_InputPIT_TRG0, kXBARA_OutputDMAMUX18); endcode
param base XBARA peripheral address. param input XBARA input signal. param output XBARA output signal.
