RTEMS 6.1-rc6
Modules | |
Lpi2c_master_driver | |
Lpi2c_slave_driver | |
uint32_t | LPI2C_GetInstance (LPI2C_Type *base) |
Returns an instance number given a base address. | |
IRQn_Type const | kLpi2cIrqs [] |
Array to map LPI2C instance number to IRQ number, used internally for LPI2C master interrupt and EDMA transactional APIs. | |
lpi2c_master_isr_t | s_lpi2cMasterIsr |
Pointer to master IRQ handler for each instance, used internally for LPI2C master interrupt and EDMA transactional APIs. | |
void * | s_lpi2cMasterHandle [] |
Pointers to master handles for each instance, used internally for LPI2C master interrupt and EDMA transactional APIs. | |
Driver version | |
enum | { kStatus_LPI2C_Busy = MAKE_STATUS(kStatusGroup_LPI2C, 0) , kStatus_LPI2C_Idle = MAKE_STATUS(kStatusGroup_LPI2C, 1) , kStatus_LPI2C_Nak = MAKE_STATUS(kStatusGroup_LPI2C, 2) , kStatus_LPI2C_FifoError = MAKE_STATUS(kStatusGroup_LPI2C, 3) , kStatus_LPI2C_BitError = MAKE_STATUS(kStatusGroup_LPI2C, 4) , kStatus_LPI2C_ArbitrationLost = MAKE_STATUS(kStatusGroup_LPI2C, 5) , kStatus_LPI2C_PinLowTimeout , kStatus_LPI2C_NoTransferInProgress , kStatus_LPI2C_DmaRequestFail = MAKE_STATUS(kStatusGroup_LPI2C, 8) , kStatus_LPI2C_Timeout = MAKE_STATUS(kStatusGroup_LPI2C, 9) } |
LPI2C status return codes. More... | |
#define | FSL_LPI2C_DRIVER_VERSION (MAKE_VERSION(2, 4, 1)) |
LPI2C driver version. | |
#define | I2C_RETRY_TIMES 0U /* Define to zero means keep waiting until the flag is assert/deassert. */ |
Retry times for waiting flag. | |
anonymous enum |
uint32_t LPI2C_GetInstance | ( | LPI2C_Type * | base | ) |
If an invalid base address is passed, debug builds will assert. Release builds will just return instance number 0.
base | The LPI2C peripheral base address. |
brief Returns an instance number given a base address.
param base The LPI2C peripheral base address. return LPI2C instance number starting from 0.
extern |
extern |
extern |
