RTEMS 6.1-rc6
Data Structures | Enumerator | Variables
Gpio_driver
struct  _gpio_pin_config
 GPIO Init structure definition. More...
gpio_pin_direction_t _gpio_pin_config::direction
uint8_t _gpio_pin_config::outputLogic
gpio_interrupt_mode_t _gpio_pin_config::interruptMode
Driver version
enum  _gpio_pin_direction { kGPIO_DigitalInput = 0U , kGPIO_DigitalOutput = 1U }
 GPIO direction definition. More...
enum  _gpio_interrupt_mode {
  kGPIO_NoIntmode = 0U , kGPIO_IntLowLevel = 1U , kGPIO_IntHighLevel = 2U , kGPIO_IntRisingEdge = 3U ,
  kGPIO_IntFallingEdge = 4U , kGPIO_IntRisingOrFallingEdge = 5U
 GPIO interrupt mode definition. More...
typedef enum _gpio_pin_direction gpio_pin_direction_t
typedef enum _gpio_interrupt_mode gpio_interrupt_mode_t
typedef struct _gpio_pin_config gpio_pin_config_t
#define FSL_GPIO_DRIVER_VERSION   (MAKE_VERSION(2, 0, 6))
 GPIO driver version.
GPIO Initialization and Configuration functions
void GPIO_PinInit (GPIO_Type *base, uint32_t pin, const gpio_pin_config_t *Config)
 Initializes the GPIO peripheral according to the specified parameters in the initConfig.
GPIO Reads and Write Functions
void GPIO_PinWrite (GPIO_Type *base, uint32_t pin, uint8_t output)
 Sets the output level of the individual GPIO pin to logic 1 or 0.
Interrupts and flags management functions
void GPIO_PinSetInterruptConfig (GPIO_Type *base, uint32_t pin, gpio_interrupt_mode_t pinInterruptMode)
 Sets the current pin interrupt mode.
◆ _gpio_interrupt_mode
kGPIO_NoIntmode
Set current pin general IO functionality.
kGPIO_IntLowLevel
Set current pin interrupt is low-level sensitive.
kGPIO_IntHighLevel
Set current pin interrupt is high-level sensitive.
kGPIO_IntRisingEdge
Set current pin interrupt is rising-edge sensitive.
Set current pin interrupt is falling-edge sensitive.
Enable the edge select bit to override the ICR register's configuration.
◆ _gpio_pin_direction
kGPIO_DigitalInput
Set current pin as digital input.
kGPIO_DigitalOutput
Set current pin as digital output.
◆ GPIO_PinInit()
void GPIO_PinInit ( GPIO_Type base,
uint32_t  pin,
const gpio_pin_config_t Config
Parameters
baseGPIO base pointer.
pinSpecifies the pin number
Configpointer to a gpio_pin_config_t structure that contains the configuration information.
brief Initializes the GPIO peripheral according to the specified parameters in the initConfig.
param base GPIO base pointer. param pin Specifies the pin number param initConfig pointer to a ref gpio_pin_config_t structure that contains the configuration information.
◆ GPIO_PinSetInterruptConfig()
void GPIO_PinSetInterruptConfig ( GPIO_Type base,
uint32_t  pin,
Parameters
pinGPIO port pin number.
pinInterruptModepointer to a gpio_interrupt_mode_t structure that contains the interrupt mode information.
brief Sets the current pin interrupt mode.
param base GPIO base pointer. param pin GPIO port pin number. param pininterruptMode pointer to a ref gpio_interrupt_mode_t structure that contains the interrupt mode information.
◆ GPIO_PinWrite()
void GPIO_PinWrite ( GPIO_Type base,
uint32_t  pin,
uint8_t  output
Parameters
outputGPIOpin output logic level.
  • 0: corresponding pin output low-logic level.
  • 1: corresponding pin output high-logic level.
brief Sets the output level of the individual GPIO pin to logic 1 or 0.
param base GPIO base pointer. param pin GPIO port pin number. param output GPIOpin output logic level.
Variable Documentation
◆ direction
Specifies the pin direction.
◆ interruptMode
Specifies the pin interrupt mode, a value of gpio_interrupt_mode_t.
◆ outputLogic
Set a default output logic, which has no use in input
