RTEMS 6.1-rc6
void LL_SetSystemCoreClock (uint32_t CPU_Frequency)
 This function sets directly SystemCoreClock CMSIS variable.
ErrorStatus LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock at maximum frequency with HSI as clock source of the PLL.
ErrorStatus LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock with HSE as clock source of the PLL.
ErrorStatus LL_SetFlashLatency (uint32_t HCLK_Frequency)
 Update number of Flash wait states in line with new frequency and current voltage range.
◆ LL_PLL_ConfigSystemClock_HSE()
ErrorStatus LL_PLL_ConfigSystemClock_HSE ( uint32_t  HSEFrequency,
uint32_t  HSEBypass,
LL_UTILS_PLLInitTypeDef UTILS_PLLInitStruct,
LL_UTILS_ClkInitTypeDef UTILS_ClkInitStruct
Note
The application need to ensure that PLL is disabled.
Function is based on the following formula:
  • PLL output frequency = (((HSE frequency / PLLM) * PLLN) / PLLP)
  • PLLM: ensure that the VCO input frequency ranges from 0.95 to 2.10 MHz (PLLVCO_input = HSE frequency / PLLM)
  • PLLN: ensure that the VCO output frequency is between 150 and 836 MHz or 128 to 560 MHz(***) (PLLVCO_output = PLLVCO_input * PLLN)
  • PLLP: ensure that max frequency at 550000000 Hz(*), 480000000 Hz(**) or 280000000 Hz(***) is reached (PLLVCO_output / PLLP)
Parameters
HSEFrequencyValue between Min_Data = 4000000 and Max_Data = 48000000
HSEBypassThis parameter can be one of the following values:
UTILS_PLLInitStructpointer to a LL_UTILS_PLLInitTypeDef structure that contains the configuration information for the PLL.
UTILS_ClkInitStructpointer to a LL_UTILS_ClkInitTypeDef structure that contains the configuration information for the BUS prescalers.
Return values
AnErrorStatus enumeration value:
  • SUCCESS: Max frequency configuration done
  • ERROR: Max frequency configuration not done
(*) : For stm32h72xxx and stm32h73xxx family lines and requires to enable the CPU_FREQ_BOOST flash option byte, 520MHZ otherwise. (**) : For stm32h74xxx and stm32h75xxx family lines and requires the board to be connected on LDO regulator not SMPS, 400MHZ otherwise. (***): For stm32h7a3xx, stm32h7b3xx and stm32h7b0xx family lines.
◆ LL_PLL_ConfigSystemClock_HSI()
ErrorStatus LL_PLL_ConfigSystemClock_HSI ( LL_UTILS_PLLInitTypeDef UTILS_PLLInitStruct,
Note
  • PLL output frequency = (((HSI frequency / PLLM) * PLLN) / PLLP)
  • PLLM: ensure that the VCO input frequency ranges from 1 to 16 MHz (PLLVCO_input = HSI frequency / PLLM)
  • PLLP: ensure that max frequency at 550000000 Hz(*), 480000000 Hz(**) or 280000000 Hz(***) is reach (PLLVCO_output / PLLP)
Parameters
Return values
◆ LL_SetFlashLatency()
ErrorStatus LL_SetFlashLatency ( uint32_t  HCLK_Frequency)
Parameters
HCLK_FrequencyHCLK frequency
Return values
  • SUCCESS: Latency has been modified
  • ERROR: Latency cannot be modified
◆ LL_SetSystemCoreClock()
void LL_SetSystemCoreClock ( uint32_t  CPU_Frequency)
Note
Variable can be calculated also through SystemCoreClockUpdate function.
Parameters
CPU_FrequencyCore frequency in Hz
Note
CPU_Frequency can be calculated thanks to RCC helper macro or function LL_RCC_GetSystemClocksFreq
Return values
None
