RTEMS 6.1-rc6
Files | Macros | Functions
LM32 EVR Board Support Package. More...
file  bsp.h
 Global BSP definitions.
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void BSP_uart_polled_write (char ch)
int BSP_uart_polled_read (void)
char BSP_uart_is_character_ready (char *ch)
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
