The red-black tree container provides data structures and directives to manage user-defined data structures in red-black trees.
More...
#define | RTEMS_RBTREE_INITIALIZER_EMPTY(name) RBTREE_INITIALIZER_EMPTY(name) |
| RBTree initializer for an empty rbtree with designator name.
#define | RTEMS_RBTREE_DEFINE_EMPTY(name) RBTREE_DEFINE_EMPTY(name) |
| RBTree definition for an empty rbtree with designator name.
void | rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique) |
| Initialize a RBTree header.
rtems_rbtree_node * | rtems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique) |
| Tries to find a node for the specified key in the tree.
rtems_rbtree_node * | rtems_rbtree_insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, rtems_rbtree_compare compare, bool is_unique) |
| Inserts the node into the red-black tree.
The red-black tree container offers no internal protection against concurrent access. The user must ensure that at most one thread at once can access a red-black tree instance.
◆ rtems_rbtree_compare
Compares two red-black tree nodes.
- Parameters
[in] | first | The first node. |
[in] | second | The second node. |
- Return values
positive | The key value of the first node is greater than the one of the second node. |
0 | The key value of the first node is equal to the one of the second node. |
negative | The key value of the first node is less than the one of the second node. |
◆ rtems_rbtree_compare_result
Integer type for compare results.
The type is large enough to represent pointers and 32-bit signed integers.
- See also
- rtems_rbtree_compare.
◆ rtems_rbtree_control
The rbtree's control anchors the rbtree.
◆ rtems_rbtree_node
A node that can be manipulated in the rbtree.
◆ rtems_rbtree_find()
- Parameters
[in] | the_rbtree | The red-black tree control. |
[in] | the_node | A node specifying the key. |
[in] | compare | The node compare function. |
[in] | is_unique | If true, then return the first node with a key equal to the one of the node specified if it exits, else return the last node if it exists. |
- Return values
node | A node corresponding to the key. If the tree is not unique and contains duplicate keys, the set of duplicate keys acts as FIFO. |
NULL | No node exists in the tree for the key. |
◆ rtems_rbtree_initialize()
This routine initializes the_rbtree structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
- Parameters
[in] | the_rbtree | is the pointer to rbtree header |
[in] | starting_address | is the starting address of first node |
[in] | number_nodes | is the number of nodes in rbtree |
[in] | node_size | is the size of node in bytes |
[in] | is_unique | If true, then reject nodes with a duplicate key, else otherwise. |
◆ rtems_rbtree_insert()
In case the node is already a node of a tree, then this function yields unpredictable results.
- Parameters
[in] | the_node | The node to insert. |
[in] | is_unique | If true, then reject nodes with a duplicate key, else insert nodes in FIFO order in case the key value is equal to existing nodes. |
- Return values
NULL | Successfully inserted. |
existing_node | This is a unique insert and there exists a node with an equal key in the tree already. |
