RTEMS 6.1-rc6
#define | IS_RTC_BKP(__BKP__) ((__BKP__) < BKP_REG_NUMBER) |
#define | IS_TIMESTAMP_EDGE(EDGE) |
#define | IS_RTC_TIMESTAMP_PIN(PIN) (((PIN) == RTC_TIMESTAMPPIN_DEFAULT)) |
#define | IS_RTC_WAKEUP_CLOCK(CLOCK) |
#define | IS_RTC_WAKEUP_COUNTER(COUNTER) ((COUNTER) <= RTC_WUTR_WUT) |
#define | IS_RTC_SMOOTH_CALIB_PERIOD(PERIOD) |
#define | IS_RTC_SMOOTH_CALIB_PLUS(PLUS) |
#define | IS_RTC_SMOOTH_CALIB_MINUS(VALUE) ((VALUE) <= RTC_CALR_CALM) |
#define | IS_RTC_SHIFT_ADD1S(SEL) |
#define | IS_RTC_SHIFT_SUBFS(FS) ((FS) <= RTC_SHIFTR_SUBFS) |
#define | IS_RTC_CALIB_OUTPUT(OUTPUT) |
#define | IS_RTC_TAMPER(__TAMPER__) |
#define | IS_RTC_TAMPER_INTERRUPT(__INTERRUPT__) |
#define | IS_RTC_TAMPER_TRIGGER(__TRIGGER__) |
#define | IS_RTC_TAMPER_ERASE_MODE(__MODE__) |
#define | IS_RTC_TAMPER_MASKFLAG_STATE(__STATE__) |
#define | IS_RTC_TAMPER_FILTER(__FILTER__) |
#define | IS_RTC_TAMPER_SAMPLING_FREQ(__FREQ__) |
#define | IS_RTC_TAMPER_PRECHARGE_DURATION(__DURATION__) |
#define | IS_RTC_TAMPER_PULLUP_STATE(__STATE__) |
#define | IS_RTC_TAMPER_TIMESTAMPONTAMPER_DETECTION(__DETECTION__) |
#define | IS_RTC_TAMPER_FILTER_CONFIG_CORRECT(FILTER, TRIGGER) |
#define | IS_RTC_INTERNAL_TAMPER(__INT_TAMPER__) |
#define IS_RTC_CALIB_OUTPUT | ( | OUTPUT | ) |
#define IS_RTC_INTERNAL_TAMPER | ( | __INT_TAMPER__ | ) |
#define IS_RTC_SHIFT_ADD1S | ( | SEL | ) |
#define IS_RTC_SMOOTH_CALIB_PERIOD | ( | PERIOD | ) |
#define IS_RTC_SMOOTH_CALIB_PLUS | ( | PLUS | ) |
#define IS_RTC_TAMPER | ( | __TAMPER__ | ) |
#define IS_RTC_TAMPER_ERASE_MODE | ( | __MODE__ | ) |
#define IS_RTC_TAMPER_FILTER | ( | __FILTER__ | ) |
#define IS_RTC_TAMPER_FILTER_CONFIG_CORRECT | ( | FILTER, | |
TRIGGER | |||
#define IS_RTC_TAMPER_INTERRUPT | ( | __INTERRUPT__ | ) |
#define IS_RTC_TAMPER_MASKFLAG_STATE | ( | __STATE__ | ) |
#define IS_RTC_TAMPER_PRECHARGE_DURATION | ( | __DURATION__ | ) |
#define IS_RTC_TAMPER_PULLUP_STATE | ( | __STATE__ | ) |
#define IS_RTC_TAMPER_SAMPLING_FREQ | ( | __FREQ__ | ) |
#define IS_RTC_TAMPER_TIMESTAMPONTAMPER_DETECTION | ( | __DETECTION__ | ) |
#define IS_RTC_TAMPER_TRIGGER | ( | __TRIGGER__ | ) |
#define IS_RTC_WAKEUP_CLOCK | ( | CLOCK | ) |
#define IS_TIMESTAMP_EDGE | ( | EDGE | ) |
