RTEMS 6.1-rc6
Files | Data Structures | Macros | Functions | Variables
POSIX Timer Private Support
file  ptimer.c
 POSIX Timer Information with Zero Objects.
struct  POSIX_Timer_Control
#define POSIX_TIMER_INFORMATION_DEFINE(max)
 Macro to define the objects information for the POSIX Timer objects.
int _POSIX_Timer_Is_allowed (clockid_t clock_id)
 Follow POSIX or FACE Technical Standard on timer_create.
Objects_Information _POSIX_Timer_Information
 The POSIX Timer objects information.
◆ POSIX_TIMER_INFORMATION_DEFINE
#define POSIX_TIMER_INFORMATION_DEFINE (   max)
Value:
_POSIX_Timer, \
OBJECTS_POSIX_API, \
OBJECTS_POSIX_TIMERS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:123
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:449
Definition: timer.h:60
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _POSIX_Timer_Is_allowed()
int _POSIX_Timer_Is_allowed ( clockid_t  clock_id)
POSIX allows for the creation of timers based on CLOCK_REALTIME. This is viewed as a safety issue by the FACE Technical Standard and required to return an error. These are conflicting behaviors. This method is instanced by configuration when FACE conformant behavior is desired by the application.
Parameters
[in]clock_idis the clock ID to validate
Returns
0 if clock_id is allowed for use. Otherwise an errno value.
