RTEMS 6.1-rc6
Provides a POSIX like user environment for tasks. More...
Files | |
file | userenv.h |
User Environment Support. | |
file | privateenv.c |
Instantiate a Private User Environment. | |
struct | rtems_user_env_t |
User environment. More... | |
#define | LOGIN_NAME_MAX 9 |
#define | rtems_current_user_env rtems_current_user_env_get() |
#define | rtems_filesystem_current (rtems_current_user_env->current_directory) |
#define | rtems_filesystem_root (rtems_current_user_env->root_directory) |
#define | rtems_filesystem_umask (rtems_current_user_env->umask) |
#define | _POSIX_types_Uid (rtems_current_user_env->uid) |
#define | _POSIX_types_Gid (rtems_current_user_env->gid) |
#define | _POSIX_types_Euid (rtems_current_user_env->euid) |
#define | _POSIX_types_Egid (rtems_current_user_env->egid) |
#define | _POSIX_types_Getlogin_buffer (rtems_current_user_env->login_buffer) |
Typedefs | |
typedef struct rtems_user_env_t | rtems_user_env_t |
rtems_user_env_t * | rtems_current_user_env_get (void) |
Fetch the pointer to the current user environment. | |
rtems_status_code | rtems_libio_set_private_env (void) |
Creates a private environment. | |
void | rtems_libio_use_global_env (void) |
Use the global environment. | |
void | rtems_current_user_env_getgroups (void) |
Gets the supplementary group IDs using the current user ID and updates the table of supplementary group IDs in the current user environment. | |
rtems_user_env_t | rtems_global_user_env |
rtems_user_env_t * rtems_current_user_env_get | ( | void | ) |
If the task has a private user environment the pointer to it will be returned. Otherwise the pointer to rtems_global_user_env will be returned.
void rtems_current_user_env_getgroups | ( | void | ) |
In case of an error, the count of supplementary group IDs is set to zero.
rtems_status_code rtems_libio_set_private_env | ( | void | ) |
If the task has already a private environment nothing will be changed. This function must be called from normal thread context and may block on a mutex. Thread dispatching is disabled to protect some critical sections.
The private environment internally uses a POSIX key. The key is added to the configuration implicitly. But for each thread that uses a private environment a key value pair has to be configured by the application. If only the global environment is used there is no need to configure a key value pair.
RTEMS_SUCCESSFUL | Successful operation. |
RTEMS_NO_MEMORY | Not enough memory. |
RTEMS_UNSATISFIED | Cloning of the current environment failed. |
RTEMS_TOO_MANY | Cannot register the private environment. |
void rtems_libio_use_global_env | ( | void | ) |
A private environment will be released. This function may be called from every thread context. Thread dispatching is disabled to protect the critical sections.
