RTEMS 6.1-rc6
#define __HAL_CRC_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_CRC_STATE_RESET)
 Reset CRC handle state.
#define __HAL_CRC_DR_RESET(__HANDLE__)   ((__HANDLE__)->Instance->CR |= CRC_CR_RESET)
 Reset CRC Data Register.
#define __HAL_CRC_INITIALCRCVALUE_CONFIG(__HANDLE__, __INIT__)   ((__HANDLE__)->Instance->INIT = (__INIT__))
 Set CRC INIT non-default value.
#define __HAL_CRC_SET_IDR(__HANDLE__, __VALUE__)   (WRITE_REG((__HANDLE__)->Instance->IDR, (__VALUE__)))
 Store data in the Independent Data (ID) register.
#define __HAL_CRC_GET_IDR(__HANDLE__)   (((__HANDLE__)->Instance->IDR) & CRC_IDR_IDR)
 Return the data stored in the Independent Data (ID) register.
◆ __HAL_CRC_DR_RESET
#define __HAL_CRC_DR_RESET (   __HANDLE__)    ((__HANDLE__)->Instance->CR |= CRC_CR_RESET)
Parameters
__HANDLE__CRC handle
Return values
None
◆ __HAL_CRC_GET_IDR
#define __HAL_CRC_GET_IDR (   __HANDLE__)    (((__HANDLE__)->Instance->IDR) & CRC_IDR_IDR)
Parameters
Note
Refer to the Reference Manual to get the authorized VALUE length in bits
Return values
Valueof the ID register
◆ __HAL_CRC_INITIALCRCVALUE_CONFIG
#define __HAL_CRC_INITIALCRCVALUE_CONFIG (   __HANDLE__,
  __INIT__
Parameters
__INIT__32-bit initial value
Return values
None
◆ __HAL_CRC_RESET_HANDLE_STATE
#define __HAL_CRC_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_CRC_STATE_RESET)
Parameters
__HANDLE__CRC handle.
Return values
None
◆ __HAL_CRC_SET_IDR
#define __HAL_CRC_SET_IDR (   __HANDLE__,
  __VALUE__
Parameters
__VALUE__Value to be stored in the ID register
Note
Return values
None
