RTEMS 6.1-rc6
fsl-edma.c File Reference
Freescale / NXP Enhanced Direct Memory Access (eDMA). More...
#include <fsl/edma.h>
#include <fsl/regs-edma.h>
#include <assert.h>
#include <bsp.h>
#include <bsp/fatal.h>
#include <bsp/irq.h>
#define EDMA_CHANNELS_PER_GROUP   32U
#define EDMA_GROUP_COUNT   ((EDMA_CHANNEL_COUNT + 31U) / 32U)
#define EDMA_GROUP_INDEX(channel)   ((channel) / EDMA_CHANNELS_PER_GROUP)
#define EDMA_GROUP_BIT(channel)   (1U << ((channel) % EDMA_CHANNELS_PER_GROUP))
#define EDMA_MODULE_INDEX(channel)   ((channel) / EDMA_CHANNELS_PER_MODULE)
unsigned fsl_edma_channel_index_of_tcd (volatile struct fsl_edma_tcd *edma_tcd)
volatile struct fsl_edma_tcd * fsl_edma_tcd_of_channel_index (unsigned index)
void fsl_edma_init (void)
rtems_status_code fsl_edma_obtain_channel_by_tcd (volatile struct fsl_edma_tcd *edma_tcd)
 Obtains an eDMA channel.
void fsl_edma_release_channel_by_tcd (volatile struct fsl_edma_tcd *edma_tcd)
rtems_status_code fsl_edma_obtain_channel (fsl_edma_channel_context *ctx, unsigned irq_priority)
 Obtains a specific eDMA channel and registers the channel context.
rtems_status_code fsl_edma_obtain_next_free_channel (fsl_edma_channel_context *ctx)
 Obtains a free eDMA channel and registers the channel context.
void fsl_edma_release_channel (fsl_edma_channel_context *ctx)
void fsl_edma_copy (volatile struct fsl_edma_tcd *edma_tcd, const struct fsl_edma_tcd *source_tcd)
 Copies a source TCD to an eDMA TCD.
void fsl_edma_copy_and_enable_hardware_requests (volatile struct fsl_edma_tcd *edma_tcd, const struct fsl_edma_tcd *source_tcd)
 Copies a source TCD to an eDMA TCD and enables hardware requests.
void fsl_edma_sg_link (volatile struct fsl_edma_tcd *edma_tcd, const struct fsl_edma_tcd *source_tcd)
volatile struct fsl_edmaedma_inst [EDMA_MODULE_COUNT]
◆ fsl_edma_copy()
void fsl_edma_copy ( volatile struct fsl_edma_tcd *  edma_tcd,
const struct fsl_edma_tcd *  source_tcd
The DONE flag of the eDMA TCD is cleared before the actual copy operation. This enables the setting of channel link or scatter/gather options.
This function can be used to start the channel if the START flags is set in the source TCD.
◆ fsl_edma_copy_and_enable_hardware_requests()
void fsl_edma_copy_and_enable_hardware_requests ( volatile struct fsl_edma_tcd *  edma_tcd,
◆ fsl_edma_obtain_channel()
rtems_status_code fsl_edma_obtain_channel ( fsl_edma_channel_context ctx,
Tries to obtain the channel specified in the ctx.
irq_priority will be ignored on all targets but MPC55xx based ones.
The done handler of the channel context will be called
  • during minor or major loop completions if interrupts are enabled in the corresponding TCD, or
  • in case a channel error occurs.
An error status value not equal to zero indicates an error.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_RESOURCE_IN_USEThe channel is already in use.
RTEMS_IO_ERRORUnable to install interrupt handler for this channel.
◆ fsl_edma_obtain_channel_by_tcd()
rtems_status_code fsl_edma_obtain_channel_by_tcd ( volatile struct fsl_edma_tcd *  edma_tcd)
Return values
◆ fsl_edma_obtain_next_free_channel()
rtems_status_code fsl_edma_obtain_next_free_channel ( fsl_edma_channel_context ctx)
Tries to obtain the next free DMA channel. The tcd field of ctx will be set accordingly.
Return values
RTEMS_RESOURCE_IN_USENo channels left.
RTEMS_IO_ERRORUnable to install interrupt handler.
Variable Documentation
◆ edma_inst
volatile struct fsl_edma* edma_inst[EDMA_MODULE_COUNT]
Initial value:
