Headers specific for framebuffer drivers utilizing VESA VBE.
More...
#include <bsp/vbe3.h>
#include <edid.h>
#include <stdint.h>
uint32_t | VBE_controller_information (VBE_vbe_info_block *info_block, uint16_t queried_VBE_Version) |
| Returns information about graphic's controller in the info_block structure.
uint32_t | VBE_mode_information (VBE_mode_info_block *info_block, uint16_t mode_number) |
| Fills structure info_block with informations about selected mode in mode_number variable.
uint32_t | VBE_set_mode (uint16_t mode_number, VBE_CRTC_info_block *info_block) |
| Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the info_block must be filled accordingly.
uint32_t | VBE_current_mode (uint16_t *mode_number) |
| Get currently set mode number.
uint32_t | VBE_report_DDC_capabilities (uint16_t controller_unit_number, uint8_t *seconds_to_transfer_EDID_block, uint8_t *DDC_level_supported) |
| Gets information about display data channel implemented in the graphic's controller.
uint32_t | VBE_read_EDID (uint16_t controller_unit_number, uint16_t EDID_block_number, EDID_edid1 *buffer) |
| Reads selected EDID block from display attached to controller's interface.
◆ VBE_controller_information()
uint32_t VBE_controller_information |
VBE_vbe_info_block * |
info_block, |
uint16_t |
queried_VBE_Version |
structure.
- Parameters
[out] | info_block | pointer to the struct to be filled with controller information |
[in] | queried_VBE_Version | if >0x200 then video bios is asked to fill in parameters which appeared with second version of VBE. |
- Return values
ax | register content as defined in VBE RETURN STATUS paragraph |
-1 | error calling graphical bios |
◆ VBE_current_mode()
uint32_t VBE_current_mode |
uint16_t * |
mode_number | ) |
- Parameters
[out] | mode_number | variable to be filled with current mode number |
- Return values
◆ VBE_mode_information()
uint32_t VBE_mode_information |
VBE_mode_info_block * |
info_block, |
uint16_t |
mode_number |
variable.
- Parameters
[out] | info_block | pointer to the struct to be filled with mode information |
[in] | mode_number | detailes of this mode to be filled |
- Return values
◆ VBE_read_EDID()
uint32_t VBE_read_EDID |
uint16_t |
controller_unit_number, |
uint16_t |
EDID_block_number, |
EDID_edid1 * |
buffer |
- Parameters
[in] | controller_unit_number | |
[in] | EDID_block_number | block no. to be read from the display |
[out] | buffer | place to store block fetched from the display |
- Return values
◆ VBE_report_DDC_capabilities()
uint32_t VBE_report_DDC_capabilities |
uint16_t |
uint8_t * |
seconds_to_transfer_EDID_block, |
uint8_t * |
DDC_level_supported |
- Parameters
[out] | seconds_to_transfer_EDID_block | approximate time to transfer one EDID block rounded up to seconds |
[out] | DDC_level_supported | contains DDC version supported and screen blanking state during transfer |
- Return values
◆ VBE_set_mode()
uint32_t VBE_set_mode |
uint16_t |
mode_number, |
VBE_CRTC_info_block * |
info_block |
- Parameters
[in] | mode_number | number of mode to be set |
[in] | info_block | pointer to struct containing refresh rate control info |
- Return values
