RTEMS 6.1-rc6
Data Structures | Macros | Typedefs
dsu4-regs.h File Reference
This header file defines the DSU4 register block interface. More...
#include <stdint.h>
struct  dsu4
 This structure defines the DSU4 register block memory map. More...
#define DSU4_CTRL_PW   0x800U
#define DSU4_CTRL_HL   0x400U
#define DSU4_CTRL_PE   0x200U
#define DSU4_CTRL_EB   0x100U
#define DSU4_CTRL_EE   0x80U
#define DSU4_CTRL_DM   0x40U
#define DSU4_CTRL_BZ   0x20U
#define DSU4_CTRL_BX   0x10U
#define DSU4_CTRL_BS   0x8U
#define DSU4_CTRL_BW   0x4U
#define DSU4_CTRL_BE   0x2U
#define DSU4_CTRL_TE   0x1U
#define DSU4_DTTC_TIMETAG_SHIFT   0
#define DSU4_DTTC_TIMETAG_MASK   0xffffffffU
#define DSU4_DTTC_TIMETAG_GET(_reg)
#define DSU4_DTTC_TIMETAG_SET(_reg, _val)
#define DSU4_DTTC_TIMETAG(_val)
#define DSU4_BRSS_SS_3_0_SHIFT   16
#define DSU4_BRSS_SS_3_0_MASK   0xf0000U
#define DSU4_BRSS_SS_3_0_GET(_reg)
#define DSU4_BRSS_SS_3_0_SET(_reg, _val)
#define DSU4_BRSS_SS_3_0(_val)
#define DSU4_BRSS_BN_3_0_SHIFT   0
#define DSU4_BRSS_BN_3_0_MASK   0xfU
#define DSU4_BRSS_BN_3_0_GET(_reg)
#define DSU4_BRSS_BN_3_0_SET(_reg, _val)
#define DSU4_BRSS_BN_3_0(_val)
#define DSU4_DBGM_DM_3_0_SHIFT   16
#define DSU4_DBGM_DM_3_0_MASK   0xf0000U
#define DSU4_DBGM_DM_3_0_GET(_reg)
#define DSU4_DBGM_DM_3_0_SET(_reg, _val)
#define DSU4_DBGM_DM_3_0(_val)
#define DSU4_DBGM_ED_3_0_SHIFT   0
#define DSU4_DBGM_ED_3_0_MASK   0xfU
#define DSU4_DBGM_ED_3_0_GET(_reg)
#define DSU4_DBGM_ED_3_0_SET(_reg, _val)
#define DSU4_DBGM_ED_3_0(_val)
#define DSU4_DTR_EM   0x1000U
#define DSU4_DTR_TRAPTYPE_SHIFT   4
#define DSU4_DTR_TRAPTYPE_MASK   0xff0U
#define DSU4_DTR_TRAPTYPE_GET(_reg)
#define DSU4_DTR_TRAPTYPE_SET(_reg, _val)
#define DSU4_DTR_TRAPTYPE(_val)
#define DSU4_DASI_ASI_SHIFT   0
#define DSU4_DASI_ASI_MASK   0xffU
#define DSU4_DASI_ASI_GET(_reg)
#define DSU4_DASI_ASI_SET(_reg, _val)
#define DSU4_DASI_ASI(_val)
#define DSU4_ATBC_DCNT_SHIFT   16
#define DSU4_ATBC_DCNT_MASK   0xff0000U
#define DSU4_ATBC_DCNT_GET(_reg)
#define DSU4_ATBC_DCNT_SET(_reg, _val)
#define DSU4_ATBC_DCNT(_val)
#define DSU4_ATBC_DF   0x100U
#define DSU4_ATBC_SF   0x80U
#define DSU4_ATBC_TE   0x40U
#define DSU4_ATBC_TF   0x20U
#define DSU4_ATBC_BW_SHIFT   3
#define DSU4_ATBC_BW_MASK   0x18U
#define DSU4_ATBC_BW_GET(_reg)
#define DSU4_ATBC_BW_SET(_reg, _val)
#define DSU4_ATBC_BW(_val)
#define DSU4_ATBC_BR   0x4U
#define DSU4_ATBC_DM   0x2U
#define DSU4_ATBC_EN   0x1U
#define DSU4_ATBI_INDEX_SHIFT   4
#define DSU4_ATBI_INDEX_MASK   0xff0U
#define DSU4_ATBI_INDEX_GET(_reg)
#define DSU4_ATBI_INDEX_SET(_reg, _val)
#define DSU4_ATBI_INDEX(_val)
#define DSU4_ATBFC_WPF_SHIFT   12
#define DSU4_ATBFC_WPF_MASK   0x3000U
#define DSU4_ATBFC_WPF_GET(_reg)
#define DSU4_ATBFC_WPF_SET(_reg, _val)
#define DSU4_ATBFC_WPF(_val)
#define DSU4_ATBFC_BPF_SHIFT   8
#define DSU4_ATBFC_BPF_MASK   0x300U
#define DSU4_ATBFC_BPF_GET(_reg)
#define DSU4_ATBFC_BPF_SET(_reg, _val)
#define DSU4_ATBFC_BPF(_val)
#define DSU4_ATBFC_PF   0x8U
#define DSU4_ATBFC_AF   0x4U
#define DSU4_ATBFC_FR   0x2U
#define DSU4_ATBFC_FW   0x1U
#define DSU4_ATBFM_SMASK_15_0_SHIFT   16
#define DSU4_ATBFM_SMASK_15_0_MASK   0xffff0000U
#define DSU4_ATBFM_SMASK_15_0_GET(_reg)
#define DSU4_ATBFM_SMASK_15_0_SET(_reg, _val)
#define DSU4_ATBFM_SMASK_15_0(_val)
#define DSU4_ATBFM_MMASK_15_0_SHIFT   0
#define DSU4_ATBFM_MMASK_15_0_MASK   0xffffU
#define DSU4_ATBFM_MMASK_15_0_GET(_reg)
#define DSU4_ATBFM_MMASK_15_0_SET(_reg, _val)
#define DSU4_ATBFM_MMASK_15_0(_val)
#define DSU4_ATBBA_BADDR_31_2_SHIFT   2
#define DSU4_ATBBA_BADDR_31_2_MASK   0xfffffffcU
#define DSU4_ATBBA_BADDR_31_2_GET(_reg)
#define DSU4_ATBBA_BADDR_31_2_SET(_reg, _val)
#define DSU4_ATBBA_BADDR_31_2(_val)
#define DSU4_ATBBM_BMASK_31_2_SHIFT   2
#define DSU4_ATBBM_BMASK_31_2_MASK   0xfffffffcU
#define DSU4_ATBBM_BMASK_31_2_GET(_reg)
#define DSU4_ATBBM_BMASK_31_2_SET(_reg, _val)
#define DSU4_ATBBM_BMASK_31_2(_val)
#define DSU4_ATBBM_LD   0x2U
#define DSU4_ATBBM_ST   0x1U
#define DSU4_ICNT_CE   0x80000000U
#define DSU4_ICNT_IC   0x40000000U
#define DSU4_ICNT_PE   0x20000000U
#define DSU4_ICNT_ICOUNT_28_0_SHIFT   0
#define DSU4_ICNT_ICOUNT_28_0_MASK   0x1fffffffU
#define DSU4_ICNT_ICOUNT_28_0_GET(_reg)
#define DSU4_ICNT_ICOUNT_28_0_SET(_reg, _val)
#define DSU4_ICNT_ICOUNT_28_0(_val)
#define DSU4_AHBWPC_IN   0x40U
#define DSU4_AHBWPC_CP   0x20U
#define DSU4_AHBWPC_EN   0x10U
#define DSU4_AHBWPC_IN   0x4U
#define DSU4_AHBWPC_CP   0x2U
#define DSU4_AHBWPC_EN   0x1U
#define DSU4_AHBWPD_DATA_SHIFT   0
#define DSU4_AHBWPD_DATA_MASK   0xffffffffU
#define DSU4_AHBWPD_DATA_GET(_reg)
#define DSU4_AHBWPD_DATA_SET(_reg, _val)
#define DSU4_AHBWPD_DATA(_val)
#define DSU4_AHBWPM_MASK_SHIFT   0
#define DSU4_AHBWPM_MASK_MASK   0xffffffffU
#define DSU4_AHBWPM_MASK_GET(_reg)
#define DSU4_AHBWPM_MASK_SET(_reg, _val)
#define DSU4_AHBWPM_MASK(_val)
#define DSU4_ITBC0_TFILT_SHIFT   28
#define DSU4_ITBC0_TFILT_MASK   0xf0000000U
#define DSU4_ITBC0_TFILT_GET(_reg)
#define DSU4_ITBC0_TFILT_SET(_reg, _val)
#define DSU4_ITBC0_TFILT(_val)
#define DSU4_ITBC0_ITPOINTER_SHIFT   0
#define DSU4_ITBC0_ITPOINTER_MASK   0xffffU
#define DSU4_ITBC0_ITPOINTER_GET(_reg)
#define DSU4_ITBC0_ITPOINTER_SET(_reg, _val)
#define DSU4_ITBC0_ITPOINTER(_val)
#define DSU4_ITBC1_WO   0x8000000U
#define DSU4_ITBC1_TLIM_SHIFT   24
#define DSU4_ITBC1_TLIM_MASK   0x7000000U
#define DSU4_ITBC1_TLIM_GET(_reg)
#define DSU4_ITBC1_TLIM_SET(_reg, _val)
#define DSU4_ITBC1_TLIM(_val)
#define DSU4_ITBC1_TOV   0x800000U
typedef struct dsu4 dsu4
