RTEMS 6.1-rc6
ARM PL011 Support Package. More...
struct | arm_pl011_uart |
struct | arm_pl011_context |
bool | arm_pl011_probe (rtems_termios_device_context *base) |
Initialize pl011 registers. | |
void | arm_pl011_write_polled (rtems_termios_device_context *base, char c) |
Write a char using polling mode. | |
int | arm_pl011_read_polled (rtems_termios_device_context *base) |
Read a char using polling mode. | |
volatile arm_pl011_uart * | arm_pl011_get_regs (rtems_termios_device_context *base) |
Get register base address. | |
int | arm_pl011_compute_baudrate_params (uint32_t *ibrd, uint32_t *fbrd, const uint32_t baudrate, const uint32_t clock, const unsigned short max_error) |
Compute baudrate params. | |
const rtems_termios_device_handler | arm_pl011_fns |
int arm_pl011_compute_baudrate_params | ( | uint32_t * | ibrd, |
uint32_t * | fbrd, | ||
const uint32_t | baudrate, | ||
const uint32_t | clock, | ||
const unsigned short | max_error | ||
ibrd | The integer part of the baud rate divisor value. |
fbrd | The fractional part of the baud rate divisor value. |
baudrate | Termios device context. |
clock | The UART reference clock frequency. |
max_error | Maximum error. |
0 | Success. |
1 | The error is too large. |
2 | ibrd is invalid. |
volatile arm_pl011_uart * arm_pl011_get_regs | ( | rtems_termios_device_context * | base | ) |
base | Termios device context. |
Register | base address. |
bool arm_pl011_probe | ( | rtems_termios_device_context * | base | ) |
true | Successfully initialized pl011 registers. |
int arm_pl011_read_polled | ( | rtems_termios_device_context * | base | ) |
Character | read. |
-1 | rxfifo is empty. |
void arm_pl011_write_polled | ( | rtems_termios_device_context * | base, |
char | c | ||
c | Character to be written. |
