RTEMS 6.1-rc5
Parameters for the driver. More...
#include <spi-gpio.h>
spi_gpio_set_pin_fnset_clk
void * set_clk_arg
spi_gpio_set_pin_fnset_mosi
void * set_mosi_arg
spi_gpio_get_pin_fnget_miso
void * get_miso_arg
spi_gpio_set_pin_fnset_cs [SPI_GPIO_MAX_CS]
void * set_cs_arg [SPI_GPIO_MAX_CS]
bool cs_idle [SPI_GPIO_MAX_CS]
Parameters that should be provided by the application while registering the driver. Mainly functions to set single pins.
Field Documentation
◆ cs_idle
bool spi_gpio_params::cs_idle[SPI_GPIO_MAX_CS]
Idle level of the CS pin.
Set the value to 0 for a high active CS or to 1 for a low active CS pin.
◆ get_miso
spi_gpio_get_pin_fn* spi_gpio_params::get_miso
Function for reading the miso pin
◆ get_miso_arg
void* spi_gpio_params::get_miso_arg
Application specific argument for the miso pin getter function
◆ set_clk
spi_gpio_set_pin_fn* spi_gpio_params::set_clk
Function for setting the clock pin
◆ set_clk_arg
void* spi_gpio_params::set_clk_arg
Application specific argument for the clock pin setter function
◆ set_cs
spi_gpio_set_pin_fn* spi_gpio_params::set_cs[SPI_GPIO_MAX_CS]
Functions for setting the cs pins
◆ set_cs_arg
void* spi_gpio_params::set_cs_arg[SPI_GPIO_MAX_CS]
Application specific arguments for the cs pin getter functions
◆ set_mosi
spi_gpio_set_pin_fn* spi_gpio_params::set_mosi
Function for setting the mosi pin
◆ set_mosi_arg
void* spi_gpio_params::set_mosi_arg
Application specific argument for the mosi pin setter function
