volatile mpc5200_mm | mm |
volatile uint8_t | mc [0x100] |
volatile uint8_t | cdm [0x100] |
volatile mpc5200_csc | csc |
volatile uint8_t | sct [0x100] |
volatile uint32_t | per_mask |
volatile uint32_t | per_pri_1 |
volatile uint32_t | per_pri_2 |
volatile uint32_t | per_pri_3 |
volatile uint32_t | ext_en_type |
volatile uint32_t | crit_pri_main_mask |
volatile uint32_t | main_pri_1 |
volatile uint32_t | main_pri_2 |
volatile uint32_t | res1 |
volatile uint32_t | pmce |
volatile uint32_t | csa |
volatile uint32_t | msa |
volatile uint32_t | psa |
volatile uint32_t | res2 |
volatile uint32_t | psa_be |
volatile uint8_t | res3 [0xC4] |
struct mpc5200_::mpc5200_gpt | gpt [MPC5200_GPT_NO] |
volatile uint8_t | gpt_res [0x80] |
struct mpc5200_::mpc5200_slt | slt [MPC5200_SLT_NO] |
volatile uint8_t | slt_res [0xE0] |
volatile uint8_t | rtc [0x100] |
struct mpc5200_::mpc5200_mscan | mscan [MPC5200_CAN_NO] |
volatile uint8_t | res [0x100] |
volatile uint32_t | gpiopcr |
volatile uint32_t | gpiosen |
volatile uint32_t | gpiosod |
volatile uint32_t | gpiosdd |
volatile uint32_t | gpiosdo |
volatile uint32_t | gpiosdi |
volatile uint32_t | gpiooe |
volatile uint32_t | gpioodo |
volatile uint32_t | gpiosie |
volatile uint32_t | gpiosiod |
volatile uint32_t | gpiosidd |
volatile uint32_t | gpiosido |
volatile uint32_t | gpiosiie |
volatile uint32_t | gpiosiit |
volatile uint32_t | gpiosime |
volatile uint32_t | gpiosist |
volatile uint8_t | res4 [0xC0] |
volatile uint32_t | gpiowe |
volatile uint32_t | gpiowod |
volatile uint32_t | gpiowdd |
volatile uint32_t | gpiowdo |
volatile uint32_t | gpiowue |
volatile uint32_t | gpiowsie |
volatile uint32_t | gpiowt |
volatile uint32_t | gpiowme |
volatile uint32_t | gpiowi |
volatile uint32_t | gpiows |
volatile uint8_t | gpiow_res [0xD8] |
volatile uint8_t | ppci [0x100] |
volatile uint8_t | ir [0x100] |
volatile uint8_t | spi [0x100] |
volatile uint8_t | usb [0x200] |
volatile mpc5200_sdma | sdma |
volatile uint32_t | EU00 |
volatile uint32_t | EU01 |
volatile uint32_t | EU02 |
volatile uint32_t | EU03 |
volatile uint32_t | EU04 |
volatile uint32_t | EU05 |
volatile uint32_t | EU06 |
volatile uint32_t | EU07 |
volatile uint32_t | EU10 |
volatile uint32_t | EU11 |
volatile uint32_t | EU12 |
volatile uint32_t | EU13 |
volatile uint32_t | EU14 |
volatile uint32_t | EU15 |
volatile uint32_t | EU16 |
volatile uint32_t | EU17 |
volatile uint32_t | EU20 |
volatile uint32_t | EU21 |
volatile uint32_t | EU22 |
volatile uint32_t | EU23 |
volatile uint32_t | EU24 |
volatile uint32_t | EU25 |
volatile uint32_t | EU26 |
volatile uint32_t | EU27 |
volatile uint32_t | EU30 |
volatile uint32_t | EU31 |
volatile uint32_t | EU32 |
volatile uint32_t | EU33 |
volatile uint32_t | EU34 |
volatile uint32_t | EU35 |
volatile uint32_t | EU36 |
volatile uint32_t | EU37 |
volatile uint8_t | res_1300 [0xc00] |
volatile uint32_t | reserved0 |
volatile uint32_t | reserved1 |
volatile uint32_t | reserved2 |
volatile uint32_t | reserved3 |
volatile uint32_t | reserved4 |
volatile uint32_t | reserved5 |
volatile uint32_t | reserved6 |
volatile uint32_t | reserved7 |
volatile uint32_t | reserved8 |
volatile uint32_t | reserved9 |
volatile uint32_t | reserved10 |
volatile uint32_t | reserved11 |
volatile uint32_t | reserved12 |
volatile uint32_t | reserved13 |
volatile uint32_t | reserved14 |
volatile uint32_t | reserved15 |
volatile uint32_t | config |
volatile uint32_t | version |
volatile uint32_t | xlb_status |
volatile uint32_t | int_enable |
volatile uint32_t | add_capture |
volatile uint32_t | bus_sig_capture |
volatile uint32_t | add_time_out |
volatile uint32_t | data_time_out |
volatile uint32_t | bus_time_out |
volatile uint32_t | priority_enable |
volatile uint32_t | priority |
volatile uint32_t | arb_base_addr2 |
volatile uint32_t | snoop_window |
volatile uint32_t | reserved16 |
volatile uint32_t | reserved17 |
volatile uint32_t | reserved18 |
volatile uint32_t | control |
volatile uint32_t | init_total_count |
volatile uint32_t | int_total_count |
volatile uint32_t | reserved19 |
volatile uint32_t | lower_address |
volatile uint32_t | higher_address |
volatile uint32_t | int_window_count |
volatile uint32_t | window_ter_count |
volatile uint8_t | res_0x1fa0 [0x60] |
struct mpc5200_::mpc5200_psc | psc [MPC5200_PSC_REG_SETS] |
volatile uint8_t | irda [0x200] |
volatile uint32_t | fec_id |
volatile uint32_t | ievent |
volatile uint32_t | imask |
volatile uint32_t | res9 [1] |
volatile uint32_t | r_des_active |
volatile uint32_t | x_des_active |
volatile uint32_t | r_des_active_cl |
volatile uint32_t | x_des_active_cl |
volatile uint32_t | ivent_set |
volatile uint32_t | ecntrl |
volatile uint32_t | res10 [6] |
volatile uint32_t | mii_data |
volatile uint32_t | mii_speed |
volatile uint32_t | mii_status |
volatile uint32_t | res11 [5] |
volatile uint32_t | mib_data |
volatile uint32_t | mib_control |
volatile uint32_t | res12 [6] |
volatile uint32_t | r_activate |
volatile uint32_t | r_cntrl |
volatile uint32_t | r_hash |
volatile uint32_t | r_data |
volatile uint32_t | ar_done |
volatile uint32_t | r_test |
volatile uint32_t | r_mib |
volatile uint32_t | r_da_low |
volatile uint32_t | r_da_high |
volatile uint32_t | res13 [7] |
volatile uint32_t | x_activate |
volatile uint32_t | x_cntrl |
volatile uint32_t | backoff |
volatile uint32_t | x_data |
volatile uint32_t | x_status |
volatile uint32_t | x_mib |
volatile uint32_t | x_test |
volatile uint32_t | fdxfc_da1 |
volatile uint32_t | fdxfc_da2 |
volatile uint32_t | paddr1 |
volatile uint32_t | paddr2 |
volatile uint32_t | op_pause |
volatile uint32_t | res14 [4] |
volatile uint32_t | instr_reg |
volatile uint32_t | context_reg |
volatile uint32_t | test_cntrl |
volatile uint32_t | acc_reg |
volatile uint32_t | ones |
volatile uint32_t | zeros |
volatile uint32_t | iaddr1 |
volatile uint32_t | iaddr2 |
volatile uint32_t | gaddr1 |
volatile uint32_t | gaddr2 |
volatile uint32_t | random |
volatile uint32_t | rand1 |
volatile uint32_t | tmp |
volatile uint32_t | res15 [3] |
volatile uint32_t | fifo_id |
volatile uint32_t | x_wmrk |
volatile uint32_t | fcntrl |
volatile uint32_t | r_bound |
volatile uint32_t | r_fstart |
volatile uint32_t | r_count |
volatile uint32_t | r_lag |
volatile uint32_t | r_read |
volatile uint32_t | r_write |
volatile uint32_t | x_count |
volatile uint32_t | x_lag |
volatile uint32_t | x_retry |
volatile uint32_t | x_write |
volatile uint32_t | x_read |
volatile uint32_t | res16 [2] |
volatile uint32_t | fm_cntrl |
volatile uint32_t | rfifo_data |
volatile uint32_t | rfifo_status |
volatile uint32_t | rfifo_cntrl |
volatile uint32_t | rfifo_lrf_ptr |
volatile uint32_t | rfifo_lwf_ptr |
volatile uint32_t | rfifo_alarm |
volatile uint32_t | rfifo_rdptr |
volatile uint32_t | rfifo_wrptr |
volatile uint32_t | tfifo_data |
volatile uint32_t | tfifo_status |
volatile uint32_t | tfifo_cntrl |
volatile uint32_t | tfifo_lrf_ptr |
volatile uint32_t | tfifo_lwf_ptr |
volatile uint32_t | tfifo_alarm |
volatile uint32_t | tfifo_rdptr |
volatile uint32_t | tfifo_wrptr |
volatile uint32_t | reset_cntrl |
volatile uint32_t | xmit_fsm |
volatile uint32_t | res17 [3] |
volatile uint32_t | rdes_data0 |
volatile uint32_t | rdes_data1 |
volatile uint32_t | r_length |
volatile uint32_t | x_length |
volatile uint32_t | x_addr |
volatile uint32_t | cdes_data |
volatile uint32_t | status |
volatile uint32_t | dma_control |
volatile uint32_t | des_cmnd |
volatile uint32_t | data |
volatile uint8_t | RES [0x600] |
volatile uint8_t | pci [0x200] |
volatile uint32_t | ata_hcfg |
volatile uint32_t | ata_hsr |
volatile uint32_t | ata_pio1 |
volatile uint32_t | ata_pio2 |
volatile uint32_t | ata_dma1 |
volatile uint32_t | ata_dma2 |
volatile uint32_t | ata_udma1 |
volatile uint32_t | ata_udma2 |
volatile uint32_t | ata_udma3 |
volatile uint32_t | ata_udma4 |
volatile uint32_t | ata_udma5 |
volatile uint32_t | ata_res1 [4] |
volatile uint32_t | ata_rtfdwr |
volatile uint32_t | ata_rtfsr |
volatile uint32_t | ata_rtfcr |
volatile uint32_t | ata_rtfar |
volatile uint32_t | ata_rtfrpr |
volatile uint32_t | ata_rtfwpr |
volatile uint32_t | ata_res2 [2] |
volatile uint32_t | ata_dctr_dasr |
volatile uint32_t | ata_ddr |
volatile uint32_t | ata_dfr_der |
volatile uint32_t | ata_dscr |
volatile uint32_t | ata_dsnr |
volatile uint32_t | ata_dclr |
volatile uint32_t | ata_dchr |
volatile uint32_t | ata_ddhr |
volatile uint32_t | ata_dcr_dsr |
volatile uint32_t | ata_res3 [0xA0] |
struct mpc5200_::mpc5200_i2c_regs_s | i2c_regs [2] |
volatile uint8_t | res_3d80 [0x280] |
volatile uint8_t | sram_res0x4000 [0x4000] |
volatile uint8_t | sram [0x4000] |
