RTEMS 6.1-rc5
_src_setpoint_authentication Struct Reference
The structure of setpoint authentication. More...
#include <fsl_soc_src.h>
bool enableSetpointTranferReset
uint32_t whiteList
bool lockWhiteList
bool lockSetting
bool allowNonSecureModeAccess
bool allowUserModeAccess
Field Documentation
◆ allowNonSecureModeAccess
bool _src_setpoint_authentication::allowNonSecureModeAccess
Allow both secure and non-secure modes to config setpoint.
◆ allowUserModeAccess
bool _src_setpoint_authentication::allowUserModeAccess
Allow both privilege and user modes to config setpoint.
◆ enableSetpointTranferReset
bool _src_setpoint_authentication::enableSetpointTranferReset
Control whether reset slice is in setpoint mode.
  • true Slice hardware reset will be triggered by set point transition.
  • false Slice hardware reset will not be trigged by set point transition.
◆ lockSetting
bool _src_setpoint_authentication::lockSetting
Control whether lock the setpoint access setting.
◆ lockWhiteList
bool _src_setpoint_authentication::lockWhiteList
Control whether lock the value in white list
◆ whiteList
uint32_t _src_setpoint_authentication::whiteList
Select the core to access set point control register. The logic OR'ed value of src_core_name_t enumeration.
