RTEMS 6.1-rc5
_qtmr_config Struct Reference
Quad Timer config structure. More...
#include <fsl_qtmr.h>
qtmr_primary_count_source_t primarySource
qtmr_input_source_t secondarySource
bool enableMasterMode
bool enableExternalForce
uint8_t faultFilterCount
uint8_t faultFilterPeriod
qtmr_debug_action_t debugMode
This structure holds the configuration settings for the Quad Timer peripheral. To initialize this structure to reasonable defaults, call the QTMR_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
Field Documentation
◆ debugMode
qtmr_debug_action_t _qtmr_config::debugMode
Operation in Debug mode
◆ enableExternalForce
bool _qtmr_config::enableExternalForce
true: Compare from another counter force state of OFLAG signal false: OFLAG controlled by local counter
◆ enableMasterMode
bool _qtmr_config::enableMasterMode
true: Broadcast compare function output to other counters; false no broadcast
◆ faultFilterCount
uint8_t _qtmr_config::faultFilterCount
Fault filter count
◆ faultFilterPeriod
uint8_t _qtmr_config::faultFilterPeriod
Fault filter period;value of 0 will bypass the filter
◆ primarySource
qtmr_primary_count_source_t _qtmr_config::primarySource
Specify the primary count source
◆ secondarySource
qtmr_input_source_t _qtmr_config::secondarySource
Specify the secondary count source
