RTEMS 6.1-rc5
_adc_hardware_compare_config Struct Reference
ADC hardware compare configuration. More...
#include <fsl_adc.h>
adc_hardware_compare_mode_t hardwareCompareMode
uint16_t value1
uint16_t value2
In kADC_HardwareCompareMode0, compare true if the result is less than the value1. In kADC_HardwareCompareMode1, compare true if the result is greater than or equal to value1. In kADC_HardwareCompareMode2, Value1 <= Value2, compare true if the result is less than value1 Or the result is Greater than value2. Value1 > Value2, compare true if the result is less than value1 And the result is Greater than value2. In kADC_HardwareCompareMode3, Value1 <= Value2, compare true if the result is greater than or equal to value1 And the result is less than or equal to value2. Value1 > Value2, compare true if the result is greater than or equal to value1 Or the result is less than or equal to value2.
Field Documentation
◆ hardwareCompareMode
adc_hardware_compare_mode_t _adc_hardware_compare_config::hardwareCompareMode
Select the hardware compare mode. See "adc_hardware_compare_mode_t".
◆ value1
uint16_t _adc_hardware_compare_config::value1
Setting value1(0-4095) for hardware compare mode.
◆ value2
uint16_t _adc_hardware_compare_config::value2
Setting value2(0-4095) for hardware compare mode.
