RTEMS 6.1-rc5
_adc_config Struct Reference
Converter configuration. More...
#include <fsl_adc.h>
bool enableOverWrite
bool enableContinuousConversion
bool enableHighSpeed
bool enableLowPower
bool enableLongSample
bool enableAsynchronousClockOutput
adc_reference_voltage_source_t referenceVoltageSource
adc_sample_period_mode_t samplePeriodMode
adc_clock_source_t clockSource
adc_clock_driver_t clockDriver
adc_resolution_t resolution
Field Documentation
◆ clockDriver
adc_clock_driver_t _adc_config::clockDriver
Select the divide ratio used by the ADC to generate the internal clock ADCK.
◆ clockSource
adc_clock_source_t _adc_config::clockSource
Select the input clock source to generate the internal clock ADCK.
◆ enableAsynchronousClockOutput
bool _adc_config::enableAsynchronousClockOutput
Enable the asynchronous clock output.
◆ enableContinuousConversion
bool _adc_config::enableContinuousConversion
Enable the continuous conversion mode.
◆ enableHighSpeed
bool _adc_config::enableHighSpeed
Enable the high-speed mode.
◆ enableLongSample
bool _adc_config::enableLongSample
Enable the long sample mode.
◆ enableLowPower
bool _adc_config::enableLowPower
Enable the low power mode.
◆ enableOverWrite
bool _adc_config::enableOverWrite
Enable the overwriting.
◆ referenceVoltageSource
adc_reference_voltage_source_t _adc_config::referenceVoltageSource
Select the reference voltage source.
◆ resolution
adc_resolution_t _adc_config::resolution
Select the ADC resolution mode.
◆ samplePeriodMode
adc_sample_period_mode_t _adc_config::samplePeriodMode
Select the sample period in long sample mode or short mode.
