RTEMS 6.1-rc5
Test context for spec:/score/sem/req/surrender test case. More...
uint32_t count_before
 This member specifies the semaphore count before the directive call.
Status_Control status
 This member contains the return status of the directive call.
uint32_t count_after
 This member contains the semaphore count after the directive call.
bool blocked
 If this member is true, then there shall be threads blocked on the semaphore.
TQSemContexttq_ctx
 This member contains a copy of the corresponding ScoreSemReqSurrender_Run() parameter.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreSemReqSurrender_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
