RTEMS 6.1-rc5
Test context for spec:/score/mtx/req/surrender test case. More...
bool owner_caller
 If this member is true, then the calling thread shall be the owner of the mutex.
bool owner_other
 If this member is true, then a thread other than the calling thread shall be the owner of the mutex.
bool nested
 If this member is true, then the calling thread shall have seized the mutex recursively.
bool blocked
 If this member is true, then there shall be a thread blocked waiting for the mutex.
rtems_task_priority priority_real
 This member contains the real priority of the calling thread.
rtems_task_priority priority_before
 This member contains the current priority of the calling thread before the directive call.
Status_Control status
 This member contains the return status of the directive call.
const rtems_tcbowner_after
 This member contains the owner of the mutex after the directive call.
rtems_task_priority priority_after
 This member contains the current priority of the calling thread after the directive call.
uint32_t counter
 This member contains the counter snapshot after the directive call.
TQMtxContexttq_ctx
 This member contains a copy of the corresponding ScoreMtxReqSurrender_Run() parameter.
struct {
   size_t   pci [8]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [8]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreMtxReqSurrender_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
