RTEMS 6.1-rc5
Test context for spec:/rtems/timer/req/reset test case. More...
rtems_id timer_id
 This member contains a valid id of a timer.
rtems_id id_param
 This member specifies the id parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
void * data_a
 This member contains the user data for Timer Service Routine "A".
void * data_b
 This member contains the user data for Timer Service Routine "B".
int invocations_a
 This member contains the counter for invocations of Timer Service Routine "A".
int invocations_b
 This member contains the counter for invocations of Timer Service Routine "B".
Scheduling_Ticks ticks_till_fire
 This member contains the number of ticks needed to fire the Timer Service Routine.
void ** routine_user_data
 This member identifier the user data given to the Timer Service Routine when called. It either the address of member data_a or data_b.
void ** scheduled_user_data
 This member contains a reference to the user data to be used in the next call to the Timer Service Routine.
int scheduled_invocations_a
 This member contains 1 if the Timer Service Routine "A" has been scheduled otherwise 0.
int scheduled_invocations_b
 This member contains 1 if the Timer Service Routine "B" has been scheduled otherwise 0.
Scheduling_Ticks scheduled_ticks_till_fire
 This member specifies the number of ticks till the scheduled Timer Service Routine should fire.
PreConditionContext pre_cond_contex
 This member specifies which pre-condition context (none, interrupt context, server context) must be created before the rtems_timer_reset() action gets executed.
Timer_Classes pre_class
 This member stores internal clock and context settings of the timer before the execution of the test action.
Timer_States pre_state
 This member stores the state of the timer before the execution of the test action.
Timer_States post_state
 This member stores the state of the timer after the execution of the test action.
Timer_Scheduling_Data pre_scheduling_data
 This member stores the scheduling data of the timer before the execution of the test action.
Timer_Scheduling_Data post_scheduling_data
 This member stores the scheduling data of the timer after the execution of the test action.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTimerReqReset_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
