RTEMS 6.1-rc5
Test context for spec:/rtems/scheduler/req/ident-by-processor-set test case. More...
rtems_id second_scheduler_id
 This member contains the identifier of a second scheduler.
cpu_set_t cpuset_value
 This member provides the object referenced by the cpuset parameter.
rtems_id id_value
 This member provides the object referenced by the id parameter.
bool cpu_has_scheduler
 If this member is true, then the processor specified by the cpusetsize parameter shall be owned by a scheduler.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_ident_by_processor_set() call.
size_t cpusetsize
 This member specifies if the cpusetsize parameter value.
const cpu_set_t * cpuset
 This member specifies if the cpuset parameter value.
rtems_idid
 This member specifies if the id parameter value.
struct {
   size_t   pci [5]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [5]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSchedulerReqIdentByProcessorSet_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
