RTEMS 6.1-rc5
Test context for spec:/rtems/req/ident test case. More...
Data Fields | |
rtems_status_code | status |
rtems_name | name |
uint32_t | node |
rtems_id * | id |
rtems_id | id_value |
rtems_id | id_remote_object |
rtems_id | id_local_object |
This member contains a copy of the corresponding RtemsReqIdent_Run() parameter. | |
rtems_name | name_local_object |
rtems_status_code(* | action )(rtems_name, uint32_t, rtems_id *) |
struct { | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsReqIdent_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
