RTEMS 6.1-rc5
Test context for spec:/rtems/io/req/getchark test case. More...
Data Fields | |
size_t | input_count |
This member contains the character input count. | |
BSP_polling_getchar_function_type | poll_char |
This member specifies the value for BSP_poll_char. | |
int | result |
This member contains the return value of the getchark() call. | |
struct { | |
size_t pcs [1] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsIoReqGetchark_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
