RTEMS 6.1-rc5
Test context for spec:/rtems/intr/req/get-priority test case. More...
uint32_t priority_obj
 This member provides the object referenced by the priority parameter.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
bool can_get_priority
 If this member is true, then getting the priority shall be supported.
uint32_t * priority
 This member specifies the priority parameter value.
rtems_status_code expected_status
 This member specifies the expected status.
void(* expected_priority )(uint32_t)
 This member specifies the expected value of the priority object.
struct {
   size_t   pci [3]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqGetPriority_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
