RTEMS 6.1-rc5
Test context for spec:/c/req/clock-nanosleep test case. More...
T_scheduler_log_4 scheduler_log
 This member provides the scheduler operation records.
struct timespec now_realtime
 This member contains the CLOCK_REALTIME value before the clock_nanosleep() call.
struct timespec now_monotonic
 This member contains the CLOCK_MONOTONIC value before the clock_nanosleep() call.
rtems_id worker_id
 This member contains the worker task identifier.
TaskTimerInfo timer_info
 This member contains the timer information of the worker task.
struct timespec rqtp_obj
 This member provides the object referenced by the rqtp parameter.
struct timespec rmtp_obj
 This member provides the object referenced by the rmtp parameter.
int status
 This member contains the return value of the clock_nanosleep() call.
clockid_t clock_id
 This member specifies the clock_id parameter value.
int flags
 This member specifies the flags parameter value.
const struct timespec * rqtp
 This member specifies the rqtp parameter value.
struct timespec * rmtp
 This member specifies the rmtp parameter value.
struct {
   size_t   pci [6]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [6]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   CReqClockNanosleep_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
