RTEMS 6.1-rc5
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_ramecc.h File Reference
Header file of RAMECC HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  RAMECC_HandleTypeDef
 RAMECC handle Structure definition. More...
#define HAL_RAMECC_ERROR_NONE   0x00000000U
#define HAL_RAMECC_ERROR_TIMEOUT   0x00000001U
#define HAL_RAMECC_ERROR_BUSY   0x00000002U
#define HAL_RAMECC_NO_ERROR   0x00000000U
#define HAL_RAMECC_SINGLEERROR_DETECTED   0x00000001U
#define HAL_RAMECC_DOUBLEERROR_DETECTED   0x00000002U
#define RAMECC_IT_GLOBAL_ID   0x10000000UL
#define RAMECC_IT_MONITOR_ID   0x20000000UL
#define RAMECC_IT_GLOBAL_ENABLE   (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GIE)
#define RAMECC_IT_GLOBAL_SINGLEERR_R   (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCSEIE)
#define RAMECC_IT_GLOBAL_DOUBLEERR_R   (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCDEIE)
#define RAMECC_IT_GLOBAL_DOUBLEERR_W   (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCDEBWIE)
#define RAMECC_IT_GLOBAL_ALL   (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GIE | RAMECC_IER_GECCSEIE | RAMECC_IER_GECCDEIE | RAMECC_IER_GECCDEBWIE)
#define RAMECC_IT_MONITOR_SINGLEERR_R   (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCSEIE)
#define RAMECC_IT_MONITOR_DOUBLEERR_R   (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEIE)
#define RAMECC_IT_MONITOR_DOUBLEERR_W   (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEBWIE)
#define RAMECC_IT_MONITOR_ALL   (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEBWIE | RAMECC_CR_ECCDEIE | RAMECC_CR_ECCSEIE)
#define RAMECC_FLAG_SINGLEERR_R   RAMECC_SR_SEDCF
#define RAMECC_FLAG_DOUBLEERR_R   RAMECC_SR_DEDF
#define RAMECC_FLAG_DOUBLEERR_W   RAMECC_SR_DEBWDF
#define RAMECC_FLAGS_ALL   (RAMECC_SR_SEDCF | RAMECC_SR_DEDF | RAMECC_SR_DEBWDF)
#define __HAL_RAMECC_ENABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__)   ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) |= ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID))
#define __HAL_RAMECC_ENABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR |= ((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID))
#define __HAL_RAMECC_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified RAMECC interrupts.
#define __HAL_RAMECC_DISABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__)   ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) &= ~((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID))
#define __HAL_RAMECC_DISABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR &= ~((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID))
#define __HAL_RAMECC_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified RAMECC interrupts.
#define __HAL_RAMECC_GET_GLOBAL_IT_SOURCE(__HANDLE__, __INTERRUPT__)   (((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET)
#define __HAL_RAMECC_GET_MONITOR_IT_SOURCE(__HANDLE__, __INTERRUPT__)   ((((__HANDLE__)->Instance->CR) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET)
#define __HAL_RAMECC_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified RAMECC interrupt source is enabled or not.
#define __HAL_RAMECC_GET_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->SR &= (__FLAG__))
 Get the RAMECC pending flags.
#define __HAL_RAMECC_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->SR &= ~(__FLAG__))
 Clear the RAMECC pending flags.
#define __HAL_RAMECC_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_RAMECC_STATE_RESET)
 Reset the RAMECC handle state.
#define IS_RAMECC_GLOBAL_INTERRUPT(INTERRUPT)
#define IS_RAMECC_MONITOR_INTERRUPT(INTERRUPT)
#define IS_RAMECC_INTERRUPT(INTERRUPT)
enum  HAL_RAMECC_StateTypeDef { HAL_RAMECC_STATE_RESET = 0x00U , HAL_RAMECC_STATE_READY = 0x01U , HAL_RAMECC_STATE_BUSY = 0x02U , HAL_RAMECC_STATE_ERROR = 0x03U }
 HAL RAMECC State structures definition. More...
HAL_StatusTypeDef HAL_RAMECC_Init (RAMECC_HandleTypeDef *hramecc)
HAL_StatusTypeDef HAL_RAMECC_DeInit (RAMECC_HandleTypeDef *hramecc)
HAL_StatusTypeDef HAL_RAMECC_StartMonitor (RAMECC_HandleTypeDef *hramecc)
HAL_StatusTypeDef HAL_RAMECC_StopMonitor (RAMECC_HandleTypeDef *hramecc)
HAL_StatusTypeDef HAL_RAMECC_EnableNotification (RAMECC_HandleTypeDef *hramecc, uint32_t Notifications)
HAL_StatusTypeDef HAL_RAMECC_DisableNotification (RAMECC_HandleTypeDef *hramecc, uint32_t Notifications)
void HAL_RAMECC_IRQHandler (RAMECC_HandleTypeDef *hramecc)
void HAL_RAMECC_DetectErrorCallback (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetFailingAddress (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetFailingDataLow (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetFailingDataHigh (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetHammingErrorCode (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_IsECCSingleErrorDetected (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_IsECCDoubleErrorDetected (RAMECC_HandleTypeDef *hramecc)
HAL_RAMECC_StateTypeDef HAL_RAMECC_GetState (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetError (RAMECC_HandleTypeDef *hramecc)
uint32_t HAL_RAMECC_GetRAMECCError (RAMECC_HandleTypeDef *hramecc)
Author
MCD Application Team
Attention
