RTEMS 6.1-rc5
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_i2s.h File Reference
Header file of I2S HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  I2S_InitTypeDef
 I2S Init structure definition. More...
struct  __I2S_HandleTypeDef
 I2S handle Structure definition. More...
#define HAL_I2S_ERROR_NONE   (0x00000000UL)
#define HAL_I2S_ERROR_TIMEOUT   (0x00000001UL)
#define HAL_I2S_ERROR_OVR   (0x00000002UL)
#define HAL_I2S_ERROR_UDR   (0x00000004UL)
#define HAL_I2S_ERROR_DMA   (0x00000008UL)
#define HAL_I2S_ERROR_PRESCALER   (0x00000010UL)
#define HAL_I2S_ERROR_FRE   (0x00000020UL)
#define HAL_I2S_ERROR_NO_OGT   (0x00000040UL)
#define HAL_I2S_ERROR_NOT_SUPPORTED   (0x00000080UL)
#define I2S_MODE_SLAVE_TX   (0x00000000UL)
#define I2S_MODE_SLAVE_RX   (SPI_I2SCFGR_I2SCFG_0)
#define I2S_MODE_MASTER_TX   (SPI_I2SCFGR_I2SCFG_1)
#define I2S_MODE_MASTER_RX   (SPI_I2SCFGR_I2SCFG_0 | SPI_I2SCFGR_I2SCFG_1)
#define I2S_MODE_SLAVE_FULLDUPLEX   (SPI_I2SCFGR_I2SCFG_2)
#define I2S_MODE_MASTER_FULLDUPLEX   (SPI_I2SCFGR_I2SCFG_2 | SPI_I2SCFGR_I2SCFG_0)
#define I2S_STANDARD_PHILIPS   (0x00000000UL)
#define I2S_STANDARD_MSB   (SPI_I2SCFGR_I2SSTD_0)
#define I2S_STANDARD_LSB   (SPI_I2SCFGR_I2SSTD_1)
#define I2S_STANDARD_PCM_SHORT   (SPI_I2SCFGR_I2SSTD_0 | SPI_I2SCFGR_I2SSTD_1)
#define I2S_STANDARD_PCM_LONG   (SPI_I2SCFGR_I2SSTD_0 | SPI_I2SCFGR_I2SSTD_1 | SPI_I2SCFGR_PCMSYNC)
#define I2S_DATAFORMAT_16B   (0x00000000UL)
#define I2S_DATAFORMAT_16B_EXTENDED   (SPI_I2SCFGR_CHLEN)
#define I2S_DATAFORMAT_24B   (SPI_I2SCFGR_DATLEN_0)
#define I2S_DATAFORMAT_32B   (SPI_I2SCFGR_DATLEN_1)
#define I2S_MCLKOUTPUT_ENABLE   (SPI_I2SCFGR_MCKOE)
#define I2S_MCLKOUTPUT_DISABLE   (0x00000000UL)
#define I2S_AUDIOFREQ_192K   (192000UL)
#define I2S_AUDIOFREQ_96K   (96000UL)
#define I2S_AUDIOFREQ_48K   (48000UL)
#define I2S_AUDIOFREQ_44K   (44100UL)
#define I2S_AUDIOFREQ_32K   (32000UL)
#define I2S_AUDIOFREQ_22K   (22050UL)
#define I2S_AUDIOFREQ_16K   (16000UL)
#define I2S_AUDIOFREQ_11K   (11025UL)
#define I2S_AUDIOFREQ_8K   (8000UL)
#define I2S_AUDIOFREQ_DEFAULT   (2UL)
#define I2S_CPOL_LOW   (0x00000000UL)
#define I2S_CPOL_HIGH   (SPI_I2SCFGR_CKPOL)
#define I2S_FIRSTBIT_MSB   (0x00000000UL)
#define I2S_FIRSTBIT_LSB   SPI_CFG2_LSBFRST
#define I2S_WS_INVERSION_DISABLE   (0x00000000UL)
#define I2S_WS_INVERSION_ENABLE   SPI_I2SCFGR_WSINV
#define I2S_DATA_24BIT_ALIGNMENT_RIGHT   (0x00000000UL)
#define I2S_DATA_24BIT_ALIGNMENT_LEFT   SPI_I2SCFGR_DATFMT
#define I2S_MASTER_KEEP_IO_STATE_DISABLE   (0x00000000U)
#define I2S_MASTER_KEEP_IO_STATE_ENABLE   SPI_CFG2_AFCNTR
#define I2S_IT_RXP   SPI_IER_RXPIE
#define I2S_IT_TXP   SPI_IER_TXPIE
#define I2S_IT_DXP   SPI_IER_DXPIE
#define I2S_IT_UDR   SPI_IER_UDRIE
#define I2S_IT_OVR   SPI_IER_OVRIE
#define I2S_IT_FRE   SPI_IER_TIFREIE
#define I2S_IT_ERR   (SPI_IER_UDRIE | SPI_IER_OVRIE | SPI_IER_TIFREIE)
#define I2S_FLAG_RXP   SPI_SR_RXP /* I2S status flag : Rx-Packet available flag */
#define I2S_FLAG_TXP   SPI_SR_TXP /* I2S status flag : Tx-Packet space available flag */
#define I2S_FLAG_DXP   SPI_SR_DXP /* I2S status flag : Dx-Packet space available flag */
#define I2S_FLAG_UDR   SPI_SR_UDR /* I2S Error flag : Underrun flag */
#define I2S_FLAG_OVR   SPI_SR_OVR /* I2S Error flag : Overrun flag */
#define I2S_FLAG_FRE   SPI_SR_TIFRE /* I2S Error flag : TI mode frame format error flag */
#define I2S_FLAG_MASK   (SPI_SR_RXP | SPI_SR_TXP | SPI_SR_DXP |SPI_SR_UDR | SPI_SR_OVR | SPI_SR_TIFRE)
#define __HAL_I2S_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_I2S_STATE_RESET)
 Reset I2S handle state.
#define __HAL_I2S_ENABLE(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_SPE))
 Enable the specified SPI peripheral (in I2S mode).
#define __HAL_I2S_DISABLE(__HANDLE__)   (CLEAR_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_SPE))
 Disable the specified SPI peripheral (in I2S mode).
#define __HAL_I2S_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IER |= (__INTERRUPT__))
 Enable the specified I2S interrupts.
#define __HAL_I2S_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->IER &= (~(__INTERRUPT__)))
 Disable the specified I2S interrupts.
#define __HAL_I2S_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check if the specified I2S interrupt source is enabled or disabled.
#define __HAL_I2S_GET_FLAG(__HANDLE__, __FLAG__)   ((((__HANDLE__)->Instance->SR) & (__FLAG__)) == (__FLAG__))
 Check whether the specified I2S flag is set or not.
#define __HAL_I2S_CLEAR_OVRFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_OVRC)
 Clear the I2S OVR pending flag.
#define __HAL_I2S_CLEAR_UDRFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_UDRC)
 Clear the I2S UDR pending flag.
#define __HAL_I2S_CLEAR_TIFREFLAG(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TIFREC)
 Clear the I2S FRE pending flag.
#define I2S_CHECK_FLAG(__SR__, __FLAG__)
 Check whether the specified SPI flag is set or not.
#define I2S_CHECK_IT_SOURCE(__IER__, __INTERRUPT__)
 Check whether the specified SPI Interrupt is set or not.
#define IS_I2S_MODE(__MODE__)
 Checks if I2S Mode parameter is in allowed range.
#define IS_I2S_MASTER(__MODE__)
#define IS_I2S_SLAVE(__MODE__)
#define IS_I2S_FULLDUPLEX(__MODE__)
#define IS_I2S_STANDARD(__STANDARD__)
#define IS_I2S_DATA_FORMAT(__FORMAT__)
#define IS_I2S_MCLK_OUTPUT(__OUTPUT__)
#define IS_I2S_AUDIO_FREQ(__FREQ__)
#define IS_I2S_CPOL(__CPOL__)
#define IS_I2S_FIRST_BIT(__BIT__)
#define IS_I2S_WS_INVERSION(__WSINV__)
#define IS_I2S_DATA_24BIT_ALIGNMENT(__ALIGNMENT__)
#define IS_I2S_MASTER_KEEP_IO_STATE(__AFCNTR__)
typedef struct __I2S_HandleTypeDef I2S_HandleTypeDef
enum  HAL_I2S_StateTypeDef {
  HAL_I2S_STATE_RESET = 0x00UL , HAL_I2S_STATE_READY = 0x01UL , HAL_I2S_STATE_BUSY = 0x02UL , HAL_I2S_STATE_BUSY_TX = 0x03UL ,
  HAL_I2S_STATE_BUSY_RX = 0x04UL , HAL_I2S_STATE_BUSY_TX_RX = 0x05UL , HAL_I2S_STATE_TIMEOUT = 0x06UL , HAL_I2S_STATE_ERROR = 0x07UL
 HAL State structures definition. More...
HAL_StatusTypeDef HAL_I2S_Init (I2S_HandleTypeDef *hi2s)
HAL_StatusTypeDef HAL_I2S_DeInit (I2S_HandleTypeDef *hi2s)
void HAL_I2S_MspInit (I2S_HandleTypeDef *hi2s)
void HAL_I2S_MspDeInit (I2S_HandleTypeDef *hi2s)
HAL_StatusTypeDef HAL_I2S_Transmit (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2S_Receive (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2SEx_TransmitReceive (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_I2S_Transmit_IT (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2S_Receive_IT (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2SEx_TransmitReceive_IT (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size)
void HAL_I2S_IRQHandler (I2S_HandleTypeDef *hi2s)
HAL_StatusTypeDef HAL_I2S_Transmit_DMA (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2S_Receive_DMA (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_I2SEx_TransmitReceive_DMA (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_I2S_DMAPause (I2S_HandleTypeDef *hi2s)
HAL_StatusTypeDef HAL_I2S_DMAResume (I2S_HandleTypeDef *hi2s)
HAL_StatusTypeDef HAL_I2S_DMAStop (I2S_HandleTypeDef *hi2s)
void HAL_I2S_TxHalfCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2S_TxCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2S_RxHalfCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2S_RxCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2SEx_TxRxHalfCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2SEx_TxRxCpltCallback (I2S_HandleTypeDef *hi2s)
void HAL_I2S_ErrorCallback (I2S_HandleTypeDef *hi2s)
HAL_I2S_StateTypeDef HAL_I2S_GetState (const I2S_HandleTypeDef *hi2s)
uint32_t HAL_I2S_GetError (const I2S_HandleTypeDef *hi2s)
Author
MCD Application Team
Attention
