RTEMS 6.1-rc5
Macros | Typedefs | Enumerations
stm32h7xx.h File Reference
CMSIS STM32H7xx Device Peripheral Access Layer Header File. More...
#define STM32H7
 STM32 Family.
#define __STM32H7xx_CMSIS_DEVICE_VERSION_MAIN   (0x01)
 Comment the line below if you will not use the peripherals drivers. In this case, these drivers will not be included and the application code will be based on direct access to peripherals registers.
#define __STM32H7xx_CMSIS_DEVICE_VERSION_SUB1   (0x0A)
#define __STM32H7xx_CMSIS_DEVICE_VERSION_SUB2   (0x04)
#define __STM32H7xx_CMSIS_DEVICE_VERSION_RC   (0x00)
#define IS_FUNCTIONAL_STATE(STATE)   (((STATE) == DISABLE) || ((STATE) == ENABLE))
#define SET_BIT(REG, BIT)   ((REG) |= (BIT))
#define CLEAR_BIT(REG, BIT)   ((REG) &= ~(BIT))
#define READ_BIT(REG, BIT)   ((REG) & (BIT))
#define CLEAR_REG(REG)   ((REG) = (0x0))
#define WRITE_REG(REG, VAL)   ((REG) = (VAL))
#define READ_REG(REG)   ((REG))
#define MODIFY_REG(REG, CLEARMASK, SETMASK)   WRITE_REG((REG), (((READ_REG(REG)) & (~(CLEARMASK))) | (SETMASK)))
#define POSITION_VAL(VAL)   (__CLZ(__RBIT(VAL)))
#define ATOMIC_SET_BIT(REG, BIT)
#define ATOMIC_CLEAR_BIT(REG, BIT)
#define ATOMIC_MODIFY_REG(REG, CLEARMSK, SETMASK)
#define ATOMIC_SETH_BIT(REG, BIT)
#define ATOMIC_CLEARH_BIT(REG, BIT)
#define ATOMIC_MODIFYH_REG(REG, CLEARMSK, SETMASK)
typedef enum FlagStatus ITStatus
enum  FlagStatus { RESET = 0 , SET = !RESET }
enum  FunctionalState { DISABLE = 0 , ENABLE = !DISABLE }
enum  ErrorStatus { SUCCESS = 0 , ERROR = !SUCCESS }
Author
MCD Application Team
     The file is the unique include file that the application programmer
     is using in the C source code, usually in main.c. This file contains:
      - Configuration section that allows to select:
         - The STM32H7xx device used in the target application
         - To use or not the peripheral's drivers in application code(i.e.
           code will be based on direct access to peripheral's registers
           rather than drivers API), this option is controlled by
           "#define USE_HAL_DRIVER"
Attention
