RTEMS 6.1-rc5
stm32h757xx.h
1
33#ifndef STM32H757xx_H
34#define STM32H757xx_H
35
36#ifdef __cplusplus
37 extern "C" {
38#endif /* __cplusplus */
39
48typedef enum
49{
50/****** Cortex-M Processor Exceptions Numbers *****************************************************************/
60/****** STM32 specific Interrupt Numbers **********************************************************************/
79 ADC_IRQn = 18,
89 TIM2_IRQn = 28,
90 TIM3_IRQn = 29,
91 TIM4_IRQn = 30,
96 SPI1_IRQn = 35,
97 SPI2_IRQn = 36,
108 FMC_IRQn = 48,
121 ETH_IRQn = 61,
139 FPU_IRQn = 81,
152 CEC_IRQn = 94,
172 SAI3_IRQn = 114,
179 JPEG_IRQn = 121,
180 MDMA_IRQn = 122,
181 DSI_IRQn = 123,
185 ADC3_IRQn = 127,
195 COMP_IRQn = 137 ,
202 CRS_IRQn = 144,
203 ECC_IRQn = 145,
204 SAI4_IRQn = 146,
207} IRQn_Type;
208
216#define DUAL_CORE
218#define SMPS
225#ifdef CORE_CM4
226#define __CM4_REV 0x0001U
227#define __MPU_PRESENT 1U
228#define __NVIC_PRIO_BITS 4U
229#define __Vendor_SysTickConfig 0U
230#define __FPU_PRESENT 1U
232#include "core_cm4.h"
233#else /* CORE_CM7 */
234#ifdef CORE_CM7
235#define __CM7_REV 0x0101U
236#define __MPU_PRESENT 1U
237#define __NVIC_PRIO_BITS 4U
238#define __Vendor_SysTickConfig 0U
239#define __FPU_PRESENT 1U
240#define __ICACHE_PRESENT 1U
241#define __DCACHE_PRESENT 1U
242#include "core_cm7.h"
243#else /* UNKNOWN_CORE */
244#error Please #define CORE_CM4 or CORE_CM7
245#endif /* CORE_CM7 */
246#endif /* CORE_CM4 */
247
255#include "system_stm32h7xx.h"
256#include <stdint.h>
257
266typedef struct
267{
268 __IO uint32_t ISR;
269 __IO uint32_t IER;
270 __IO uint32_t CR;
271 __IO uint32_t CFGR;
272 __IO uint32_t CFGR2;
273 __IO uint32_t SMPR1;
274 __IO uint32_t SMPR2;
275 __IO uint32_t PCSEL;
276 __IO uint32_t LTR1;
277 __IO uint32_t HTR1;
278 uint32_t RESERVED1;
279 uint32_t RESERVED2;
280 __IO uint32_t SQR1;
281 __IO uint32_t SQR2;
282 __IO uint32_t SQR3;
283 __IO uint32_t SQR4;
284 __IO uint32_t DR;
285 uint32_t RESERVED3;
286 uint32_t RESERVED4;
287 __IO uint32_t JSQR;
288 uint32_t RESERVED5[4];
289 __IO uint32_t OFR1;
290 __IO uint32_t OFR2;
291 __IO uint32_t OFR3;
292 __IO uint32_t OFR4;
293 uint32_t RESERVED6[4];
294 __IO uint32_t JDR1;
295 __IO uint32_t JDR2;
296 __IO uint32_t JDR3;
297 __IO uint32_t JDR4;
298 uint32_t RESERVED7[4];
299 __IO uint32_t AWD2CR;
300 __IO uint32_t AWD3CR;
301 uint32_t RESERVED8;
302 uint32_t RESERVED9;
303 __IO uint32_t LTR2;
304 __IO uint32_t HTR2;
305 __IO uint32_t LTR3;
306 __IO uint32_t HTR3;
307 __IO uint32_t DIFSEL;
308 __IO uint32_t CALFACT;
309 __IO uint32_t CALFACT2;
311
312
313typedef struct
314{
315__IO uint32_t CSR;
316uint32_t RESERVED;
317__IO uint32_t CCR;
318__IO uint32_t CDR;
319__IO uint32_t CDR2;
322
327typedef struct
328{
329 __IO uint32_t CTR;
331
336typedef struct
337{
338 __IO uint32_t CSR;
339 __IO uint32_t CCR;
341
342
347typedef struct
348{
349 __IO uint32_t CREL;
350 __IO uint32_t ENDN;
351 __IO uint32_t RESERVED1;
352 __IO uint32_t DBTP;
353 __IO uint32_t TEST;
354 __IO uint32_t RWD;
355 __IO uint32_t CCCR;
356 __IO uint32_t NBTP;
357 __IO uint32_t TSCC;
358 __IO uint32_t TSCV;
359 __IO uint32_t TOCC;
360 __IO uint32_t TOCV;
361 __IO uint32_t RESERVED2[4];
362 __IO uint32_t ECR;
363 __IO uint32_t PSR;
364 __IO uint32_t TDCR;
365 __IO uint32_t RESERVED3;
366 __IO uint32_t IR;
367 __IO uint32_t IE;
368 __IO uint32_t ILS;
369 __IO uint32_t ILE;
370 __IO uint32_t RESERVED4[8];
371 __IO uint32_t GFC;
372 __IO uint32_t SIDFC;
373 __IO uint32_t XIDFC;
374 __IO uint32_t RESERVED5;
375 __IO uint32_t XIDAM;
376 __IO uint32_t HPMS;
377 __IO uint32_t NDAT1;
378 __IO uint32_t NDAT2;
379 __IO uint32_t RXF0C;
380 __IO uint32_t RXF0S;
381 __IO uint32_t RXF0A;
382 __IO uint32_t RXBC;
383 __IO uint32_t RXF1C;
384 __IO uint32_t RXF1S;
385 __IO uint32_t RXF1A;
386 __IO uint32_t RXESC;
387 __IO uint32_t TXBC;
388 __IO uint32_t TXFQS;
389 __IO uint32_t TXESC;
390 __IO uint32_t TXBRP;
391 __IO uint32_t TXBAR;
392 __IO uint32_t TXBCR;
393 __IO uint32_t TXBTO;
394 __IO uint32_t TXBCF;
395 __IO uint32_t TXBTIE;
396 __IO uint32_t TXBCIE;
397 __IO uint32_t RESERVED6[2];
398 __IO uint32_t TXEFC;
399 __IO uint32_t TXEFS;
400 __IO uint32_t TXEFA;
401 __IO uint32_t RESERVED7;
403
408typedef struct
409{
410 __IO uint32_t TTTMC;
411 __IO uint32_t TTRMC;
412 __IO uint32_t TTOCF;
413 __IO uint32_t TTMLM;
414 __IO uint32_t TURCF;
415 __IO uint32_t TTOCN;
416 __IO uint32_t TTGTP;
417 __IO uint32_t TTTMK;
418 __IO uint32_t TTIR;
419 __IO uint32_t TTIE;
420 __IO uint32_t TTILS;
421 __IO uint32_t TTOST;
422 __IO uint32_t TURNA;
423 __IO uint32_t TTLGT;
424 __IO uint32_t TTCTC;
425 __IO uint32_t TTCPT;
426 __IO uint32_t TTCSM;
427 __IO uint32_t RESERVED1[111];
428 __IO uint32_t TTTS;
430
435typedef struct
436{
437 __IO uint32_t CREL;
438 __IO uint32_t CCFG;
439 __IO uint32_t CSTAT;
440 __IO uint32_t CWD;
441 __IO uint32_t IR;
442 __IO uint32_t IE;
444
445
450typedef struct
451{
452 __IO uint32_t CR;
453 __IO uint32_t CFGR;
454 __IO uint32_t TXDR;
455 __IO uint32_t RXDR;
456 __IO uint32_t ISR;
457 __IO uint32_t IER;
459
464typedef struct
465{
466 __IO uint32_t DR;
467 __IO uint32_t IDR;
468 __IO uint32_t CR;
469 uint32_t RESERVED2;
470 __IO uint32_t INIT;
471 __IO uint32_t POL;
473
474
478typedef struct
479{
480__IO uint32_t CR;
481__IO uint32_t CFGR;
482__IO uint32_t ISR;
483__IO uint32_t ICR;
485
486
491typedef struct
492{
493 __IO uint32_t CR;
494 __IO uint32_t SWTRIGR;
495 __IO uint32_t DHR12R1;
496 __IO uint32_t DHR12L1;
497 __IO uint32_t DHR8R1;
498 __IO uint32_t DHR12R2;
499 __IO uint32_t DHR12L2;
500 __IO uint32_t DHR8R2;
501 __IO uint32_t DHR12RD;
502 __IO uint32_t DHR12LD;
503 __IO uint32_t DHR8RD;
504 __IO uint32_t DOR1;
505 __IO uint32_t DOR2;
506 __IO uint32_t SR;
507 __IO uint32_t CCR;
508 __IO uint32_t MCR;
509 __IO uint32_t SHSR1;
510 __IO uint32_t SHSR2;
511 __IO uint32_t SHHR;
512 __IO uint32_t SHRR;
514
518typedef struct
519{
520 __IO uint32_t FLTCR1;
521 __IO uint32_t FLTCR2;
522 __IO uint32_t FLTISR;
523 __IO uint32_t FLTICR;
524 __IO uint32_t FLTJCHGR;
525 __IO uint32_t FLTFCR;
526 __IO uint32_t FLTJDATAR;
527 __IO uint32_t FLTRDATAR;
528 __IO uint32_t FLTAWHTR;
529 __IO uint32_t FLTAWLTR;
530 __IO uint32_t FLTAWSR;
531 __IO uint32_t FLTAWCFR;
532 __IO uint32_t FLTEXMAX;
533 __IO uint32_t FLTEXMIN;
534 __IO uint32_t FLTCNVTIMR;
536
540typedef struct
541{
542 __IO uint32_t CHCFGR1;
543 __IO uint32_t CHCFGR2;
544 __IO uint32_t CHAWSCDR;
546 __IO uint32_t CHWDATAR;
547 __IO uint32_t CHDATINR;
549
553typedef struct
554{
555 __IO uint32_t IDCODE;
556 __IO uint32_t CR;
557 __IO uint32_t RESERVED4[11];
558 __IO uint32_t APB3FZ1;
559 __IO uint32_t APB3FZ2;
560 __IO uint32_t APB1LFZ1;
561 __IO uint32_t APB1LFZ2;
562 __IO uint32_t APB1HFZ1;
563 __IO uint32_t APB1HFZ2;
564 __IO uint32_t APB2FZ1;
565 __IO uint32_t APB2FZ2;
566 __IO uint32_t APB4FZ1;
567 __IO uint32_t APB4FZ2;
574typedef struct
575{
576 __IO uint32_t CR;
577 __IO uint32_t SR;
578 __IO uint32_t RISR;
579 __IO uint32_t IER;
580 __IO uint32_t MISR;
581 __IO uint32_t ICR;
582 __IO uint32_t ESCR;
583 __IO uint32_t ESUR;
584 __IO uint32_t CWSTRTR;
585 __IO uint32_t CWSIZER;
586 __IO uint32_t DR;
588
593typedef struct
594{
595 __IO uint32_t CR;
596 __IO uint32_t NDTR;
597 __IO uint32_t PAR;
598 __IO uint32_t M0AR;
599 __IO uint32_t M1AR;
600 __IO uint32_t FCR;
602
603typedef struct
604{
605 __IO uint32_t LISR;
606 __IO uint32_t HISR;
607 __IO uint32_t LIFCR;
608 __IO uint32_t HIFCR;
610
611typedef struct
612{
613 __IO uint32_t CCR;
614 __IO uint32_t CNDTR;
615 __IO uint32_t CPAR;
616 __IO uint32_t CM0AR;
617 __IO uint32_t CM1AR;
619
620typedef struct
621{
622 __IO uint32_t ISR;
623 __IO uint32_t IFCR;
625
626typedef struct
627{
628 __IO uint32_t CCR;
630
631typedef struct
632{
633 __IO uint32_t CSR;
634 __IO uint32_t CFR;
636
637typedef struct
638{
639 __IO uint32_t RGCR;
641
642typedef struct
643{
644 __IO uint32_t RGSR;
645 __IO uint32_t RGCFR;
647
651typedef struct
652{
653 __IO uint32_t GISR0;
655
656typedef struct
657{
658 __IO uint32_t CISR;
659 __IO uint32_t CIFCR;
660 __IO uint32_t CESR;
661 __IO uint32_t CCR;
662 __IO uint32_t CTCR;
663 __IO uint32_t CBNDTR;
664 __IO uint32_t CSAR;
665 __IO uint32_t CDAR;
666 __IO uint32_t CBRUR;
667 __IO uint32_t CLAR;
668 __IO uint32_t CTBR;
669 uint32_t RESERVED0;
670 __IO uint32_t CMAR;
671 __IO uint32_t CMDR;
673
678typedef struct
679{
680 __IO uint32_t CR;
681 __IO uint32_t ISR;
682 __IO uint32_t IFCR;
683 __IO uint32_t FGMAR;
684 __IO uint32_t FGOR;
685 __IO uint32_t BGMAR;
686 __IO uint32_t BGOR;
687 __IO uint32_t FGPFCCR;
688 __IO uint32_t FGCOLR;
689 __IO uint32_t BGPFCCR;
690 __IO uint32_t BGCOLR;
691 __IO uint32_t FGCMAR;
692 __IO uint32_t BGCMAR;
693 __IO uint32_t OPFCCR;
694 __IO uint32_t OCOLR;
695 __IO uint32_t OMAR;
696 __IO uint32_t OOR;
697 __IO uint32_t NLR;
698 __IO uint32_t LWR;
699 __IO uint32_t AMTCR;
700 uint32_t RESERVED[236];
701 __IO uint32_t FGCLUT[256];
702 __IO uint32_t BGCLUT[256];
704
709typedef struct
710{
711 __IO uint32_t VR;
712 __IO uint32_t CR;
713 __IO uint32_t CCR;
714 __IO uint32_t LVCIDR;
715 __IO uint32_t LCOLCR;
716 __IO uint32_t LPCR;
717 __IO uint32_t LPMCR;
718 uint32_t RESERVED0[4];
719 __IO uint32_t PCR;
720 __IO uint32_t GVCIDR;
721 __IO uint32_t MCR;
722 __IO uint32_t VMCR;
723 __IO uint32_t VPCR;
724 __IO uint32_t VCCR;
725 __IO uint32_t VNPCR;
726 __IO uint32_t VHSACR;
727 __IO uint32_t VHBPCR;
728 __IO uint32_t VLCR;
729 __IO uint32_t VVSACR;
730 __IO uint32_t VVBPCR;
731 __IO uint32_t VVFPCR;
732 __IO uint32_t VVACR;
733 __IO uint32_t LCCR;
734 __IO uint32_t CMCR;
735 __IO uint32_t GHCR;
736 __IO uint32_t GPDR;
737 __IO uint32_t GPSR;
738 __IO uint32_t TCCR[6];
739 __IO uint32_t TDCR;
740 __IO uint32_t CLCR;
741 __IO uint32_t CLTCR;
742 __IO uint32_t DLTCR;
743 __IO uint32_t PCTLR;
744 __IO uint32_t PCONFR;
745 __IO uint32_t PUCR;
746 __IO uint32_t PTTCR;
747 __IO uint32_t PSR;
748 uint32_t RESERVED1[2];
749 __IO uint32_t ISR[2];
750 __IO uint32_t IER[2];
751 uint32_t RESERVED2[3];
752 __IO uint32_t FIR[2];
753 uint32_t RESERVED3[8];
754 __IO uint32_t VSCR;
755 uint32_t RESERVED4[2];
756 __IO uint32_t LCVCIDR;
757 __IO uint32_t LCCCR;
758 uint32_t RESERVED5;
759 __IO uint32_t LPMCCR;
760 uint32_t RESERVED6[7];
761 __IO uint32_t VMCCR;
762 __IO uint32_t VPCCR;
763 __IO uint32_t VCCCR;
764 __IO uint32_t VNPCCR;
765 __IO uint32_t VHSACCR;
766 __IO uint32_t VHBPCCR;
767 __IO uint32_t VLCCR;
768 __IO uint32_t VVSACCR;
769 __IO uint32_t VVBPCCR;
770 __IO uint32_t VVFPCCR;
771 __IO uint32_t VVACCR;
772 uint32_t RESERVED7[11];
773 __IO uint32_t TDCCR;
774 uint32_t RESERVED8[155];
775 __IO uint32_t WCFGR;
776 __IO uint32_t WCR;
777 __IO uint32_t WIER;
778 __IO uint32_t WISR;
779 __IO uint32_t WIFCR;
780 uint32_t RESERVED9;
781 __IO uint32_t WPCR[5];
782 uint32_t RESERVED10;
783 __IO uint32_t WRPCR;
785
789typedef struct
790{
791 __IO uint32_t MACCR;
792 __IO uint32_t MACECR;
793 __IO uint32_t MACPFR;
794 __IO uint32_t MACWTR;
795 __IO uint32_t MACHT0R;
796 __IO uint32_t MACHT1R;
797 uint32_t RESERVED1[14];
798 __IO uint32_t MACVTR;
799 uint32_t RESERVED2;
800 __IO uint32_t MACVHTR;
801 uint32_t RESERVED3;
802 __IO uint32_t MACVIR;
803 __IO uint32_t MACIVIR;
804 uint32_t RESERVED4[2];
805 __IO uint32_t MACTFCR;
806 uint32_t RESERVED5[7];
807 __IO uint32_t MACRFCR;
808 uint32_t RESERVED6[7];
809 __IO uint32_t MACISR;
810 __IO uint32_t MACIER;
811 __IO uint32_t MACRXTXSR;
812 uint32_t RESERVED7;
813 __IO uint32_t MACPCSR;
814 __IO uint32_t MACRWKPFR;
815 uint32_t RESERVED8[2];
816 __IO uint32_t MACLCSR;
817 __IO uint32_t MACLTCR;
818 __IO uint32_t MACLETR;
819 __IO uint32_t MAC1USTCR;
820 uint32_t RESERVED9[12];
821 __IO uint32_t MACVR;
822 __IO uint32_t MACDR;
823 uint32_t RESERVED10;
824 __IO uint32_t MACHWF0R;
825 __IO uint32_t MACHWF1R;
826 __IO uint32_t MACHWF2R;
827 uint32_t RESERVED11[54];
828 __IO uint32_t MACMDIOAR;
829 __IO uint32_t MACMDIODR;
830 uint32_t RESERVED12[2];
831 __IO uint32_t MACARPAR;
832 uint32_t RESERVED13[59];
833 __IO uint32_t MACA0HR;
834 __IO uint32_t MACA0LR;
835 __IO uint32_t MACA1HR;
836 __IO uint32_t MACA1LR;
837 __IO uint32_t MACA2HR;
838 __IO uint32_t MACA2LR;
839 __IO uint32_t MACA3HR;
840 __IO uint32_t MACA3LR;
841 uint32_t RESERVED14[248];
842 __IO uint32_t MMCCR;
843 __IO uint32_t MMCRIR;
844 __IO uint32_t MMCTIR;
845 __IO uint32_t MMCRIMR;
846 __IO uint32_t MMCTIMR;
847 uint32_t RESERVED15[14];
848 __IO uint32_t MMCTSCGPR;
849 __IO uint32_t MMCTMCGPR;
850 uint32_t RESERVED16[5];
851 __IO uint32_t MMCTPCGR;
852 uint32_t RESERVED17[10];
853 __IO uint32_t MMCRCRCEPR;
854 __IO uint32_t MMCRAEPR;
855 uint32_t RESERVED18[10];
856 __IO uint32_t MMCRUPGR;
857 uint32_t RESERVED19[9];
858 __IO uint32_t MMCTLPIMSTR;
859 __IO uint32_t MMCTLPITCR;
860 __IO uint32_t MMCRLPIMSTR;
861 __IO uint32_t MMCRLPITCR;
862 uint32_t RESERVED20[65];
863 __IO uint32_t MACL3L4C0R;
864 __IO uint32_t MACL4A0R;
865 uint32_t RESERVED21[2];
866 __IO uint32_t MACL3A0R0R;
867 __IO uint32_t MACL3A1R0R;
868 __IO uint32_t MACL3A2R0R;
869 __IO uint32_t MACL3A3R0R;
870 uint32_t RESERVED22[4];
871 __IO uint32_t MACL3L4C1R;
872 __IO uint32_t MACL4A1R;
873 uint32_t RESERVED23[2];
874 __IO uint32_t MACL3A0R1R;
875 __IO uint32_t MACL3A1R1R;
876 __IO uint32_t MACL3A2R1R;
877 __IO uint32_t MACL3A3R1R;
878 uint32_t RESERVED24[108];
879 __IO uint32_t MACTSCR;
880 __IO uint32_t MACSSIR;
881 __IO uint32_t MACSTSR;
882 __IO uint32_t MACSTNR;
883 __IO uint32_t MACSTSUR;
884 __IO uint32_t MACSTNUR;
885 __IO uint32_t MACTSAR;
886 uint32_t RESERVED25;
887 __IO uint32_t MACTSSR;
888 uint32_t RESERVED26[3];
889 __IO uint32_t MACTTSSNR;
890 __IO uint32_t MACTTSSSR;
891 uint32_t RESERVED27[2];
892 __IO uint32_t MACACR;
893 uint32_t RESERVED28;
894 __IO uint32_t MACATSNR;
895 __IO uint32_t MACATSSR;
896 __IO uint32_t MACTSIACR;
897 __IO uint32_t MACTSEACR;
898 __IO uint32_t MACTSICNR;
899 __IO uint32_t MACTSECNR;
900 uint32_t RESERVED29[4];
901 __IO uint32_t MACPPSCR;
902 uint32_t RESERVED30[3];
903 __IO uint32_t MACPPSTTSR;
904 __IO uint32_t MACPPSTTNR;
905 __IO uint32_t MACPPSIR;
906 __IO uint32_t MACPPSWR;
907 uint32_t RESERVED31[12];
908 __IO uint32_t MACPOCR;
909 __IO uint32_t MACSPI0R;
910 __IO uint32_t MACSPI1R;
911 __IO uint32_t MACSPI2R;
912 __IO uint32_t MACLMIR;
913 uint32_t RESERVED32[11];
914 __IO uint32_t MTLOMR;
915 uint32_t RESERVED33[7];
916 __IO uint32_t MTLISR;
917 uint32_t RESERVED34[55];
918 __IO uint32_t MTLTQOMR;
919 __IO uint32_t MTLTQUR;
920 __IO uint32_t MTLTQDR;
921 uint32_t RESERVED35[8];
922 __IO uint32_t MTLQICSR;
923 __IO uint32_t MTLRQOMR;
924 __IO uint32_t MTLRQMPOCR;
925 __IO uint32_t MTLRQDR;
926 uint32_t RESERVED36[177];
927 __IO uint32_t DMAMR;
928 __IO uint32_t DMASBMR;
929 __IO uint32_t DMAISR;
930 __IO uint32_t DMADSR;
931 uint32_t RESERVED37[60];
932 __IO uint32_t DMACCR;
933 __IO uint32_t DMACTCR;
934 __IO uint32_t DMACRCR;
935 uint32_t RESERVED38[2];
936 __IO uint32_t DMACTDLAR;
937 uint32_t RESERVED39;
938 __IO uint32_t DMACRDLAR;
939 __IO uint32_t DMACTDTPR;
940 uint32_t RESERVED40;
941 __IO uint32_t DMACRDTPR;
942 __IO uint32_t DMACTDRLR;
943 __IO uint32_t DMACRDRLR;
944 __IO uint32_t DMACIER;
945 __IO uint32_t DMACRIWTR;
946__IO uint32_t DMACSFCSR;
947 uint32_t RESERVED41;
948 __IO uint32_t DMACCATDR;
949 uint32_t RESERVED42;
950 __IO uint32_t DMACCARDR;
951 uint32_t RESERVED43;
952 __IO uint32_t DMACCATBR;
953 uint32_t RESERVED44;
954 __IO uint32_t DMACCARBR;
955 __IO uint32_t DMACSR;
956uint32_t RESERVED45[2];
957__IO uint32_t DMACMFCR;
963typedef struct
964{
965__IO uint32_t RTSR1;
966__IO uint32_t FTSR1;
967__IO uint32_t SWIER1;
968__IO uint32_t D3PMR1;
969__IO uint32_t D3PCR1L;
970__IO uint32_t D3PCR1H;
971uint32_t RESERVED1[2];
972__IO uint32_t RTSR2;
973__IO uint32_t FTSR2;
974__IO uint32_t SWIER2;
975__IO uint32_t D3PMR2;
976__IO uint32_t D3PCR2L;
977__IO uint32_t D3PCR2H;
978uint32_t RESERVED2[2];
979__IO uint32_t RTSR3;
980__IO uint32_t FTSR3;
981__IO uint32_t SWIER3;
982__IO uint32_t D3PMR3;
983__IO uint32_t D3PCR3L;
984__IO uint32_t D3PCR3H;
985uint32_t RESERVED3[10];
986__IO uint32_t IMR1;
987__IO uint32_t EMR1;
988__IO uint32_t PR1;
989uint32_t RESERVED4;
990__IO uint32_t IMR2;
991__IO uint32_t EMR2;
992__IO uint32_t PR2;
993uint32_t RESERVED5;
994__IO uint32_t IMR3;
995__IO uint32_t EMR3;
996__IO uint32_t PR3;
997uint32_t RESERVED6[5];
998__IO uint32_t C2IMR1;
999__IO uint32_t C2EMR1;
1000__IO uint32_t C2PR1;
1001uint32_t RESERVED7;
1002__IO uint32_t C2IMR2;
1003__IO uint32_t C2EMR2;
1004__IO uint32_t C2PR2;
1005uint32_t RESERVED8;
1006__IO uint32_t C2IMR3;
1007__IO uint32_t C2EMR3;
1008__IO uint32_t C2PR3;
1011
1021typedef struct
1022{
1023__IO uint32_t IMR1;
1024__IO uint32_t EMR1;
1025__IO uint32_t PR1;
1026uint32_t RESERVED1;
1027__IO uint32_t IMR2;
1028__IO uint32_t EMR2;
1029__IO uint32_t PR2;
1030uint32_t RESERVED2;
1031__IO uint32_t IMR3;
1032__IO uint32_t EMR3;
1033__IO uint32_t PR3;
1035
1036
1041typedef struct
1042{
1043 __IO uint32_t ACR;
1044 __IO uint32_t KEYR1;
1045 __IO uint32_t OPTKEYR;
1046 __IO uint32_t CR1;
1047 __IO uint32_t SR1;
1048 __IO uint32_t CCR1;
1049 __IO uint32_t OPTCR;
1050 __IO uint32_t OPTSR_CUR;
1051 __IO uint32_t OPTSR_PRG;
1052 __IO uint32_t OPTCCR;
1053 __IO uint32_t PRAR_CUR1;
1054 __IO uint32_t PRAR_PRG1;
1055 __IO uint32_t SCAR_CUR1;
1056 __IO uint32_t SCAR_PRG1;
1057 __IO uint32_t WPSN_CUR1;
1058 __IO uint32_t WPSN_PRG1;
1059 __IO uint32_t BOOT7_CUR;
1060 __IO uint32_t BOOT7_PRG;
1061 __IO uint32_t BOOT4_CUR;
1062 __IO uint32_t BOOT4_PRG;
1063 __IO uint32_t CRCCR1;
1064 __IO uint32_t CRCSADD1;
1065 __IO uint32_t CRCEADD1;
1066 __IO uint32_t CRCDATA;
1067 __IO uint32_t ECC_FA1;
1068 uint32_t RESERVED1[40];
1069 __IO uint32_t KEYR2;
1070 uint32_t RESERVED2;
1071 __IO uint32_t CR2;
1072 __IO uint32_t SR2;
1073 __IO uint32_t CCR2;
1074 uint32_t RESERVED3[4];
1075 __IO uint32_t PRAR_CUR2;
1076 __IO uint32_t PRAR_PRG2;
1077 __IO uint32_t SCAR_CUR2;
1078 __IO uint32_t SCAR_PRG2;
1079 __IO uint32_t WPSN_CUR2;
1080 __IO uint32_t WPSN_PRG2;
1081 uint32_t RESERVED4[4];
1082 __IO uint32_t CRCCR2;
1083 __IO uint32_t CRCSADD2;
1084 __IO uint32_t CRCEADD2;
1085 __IO uint32_t CRCDATA2;
1086 __IO uint32_t ECC_FA2;
1088
1093typedef struct
1094{
1095 __IO uint32_t BTCR[8];
1097
1102typedef struct
1103{
1104 __IO uint32_t BWTR[7];
1106
1111typedef struct
1112{
1113 __IO uint32_t PCR2;
1114 __IO uint32_t SR2;
1115 __IO uint32_t PMEM2;
1116 __IO uint32_t PATT2;
1117 uint32_t RESERVED0;
1118 __IO uint32_t ECCR2;
1120
1125typedef struct
1126{
1127 __IO uint32_t PCR;
1128 __IO uint32_t SR;
1129 __IO uint32_t PMEM;
1130 __IO uint32_t PATT;
1131 uint32_t RESERVED;
1132 __IO uint32_t ECCR;
1134
1140typedef struct
1141{
1142 __IO uint32_t SDCR[2];
1143 __IO uint32_t SDTR[2];
1144 __IO uint32_t SDCMR;
1145 __IO uint32_t SDRTR;
1146 __IO uint32_t SDSR;
1148
1153typedef struct
1154{
1155 __IO uint32_t MODER;
1156 __IO uint32_t OTYPER;
1157 __IO uint32_t OSPEEDR;
1158 __IO uint32_t PUPDR;
1159 __IO uint32_t IDR;
1160 __IO uint32_t ODR;
1161 __IO uint32_t BSRR;
1162 __IO uint32_t LCKR;
1163 __IO uint32_t AFR[2];
1164} GPIO_TypeDef;
1165
1170typedef struct
1171{
1172 __IO uint32_t CSR;
1173 __IO uint32_t OTR;
1174 __IO uint32_t HSOTR;
1176
1181typedef struct
1182{
1183 uint32_t RESERVED1;
1184 __IO uint32_t PMCR;
1185 __IO uint32_t EXTICR[4];
1186 __IO uint32_t CFGR;
1187 uint32_t RESERVED2;
1188 __IO uint32_t CCCSR;
1189 __IO uint32_t CCVR;
1190 __IO uint32_t CCCR;
1191 __IO uint32_t PWRCR;
1192 uint32_t RESERVED3[61];
1193 __IO uint32_t PKGR;
1194 uint32_t RESERVED4[118];
1195 __IO uint32_t UR0;
1196 __IO uint32_t UR1;
1197 __IO uint32_t UR2;
1198 __IO uint32_t UR3;
1199 __IO uint32_t UR4;
1200 __IO uint32_t UR5;
1201 __IO uint32_t UR6;
1202 __IO uint32_t UR7;
1203 __IO uint32_t UR8;
1204 __IO uint32_t UR9;
1205 __IO uint32_t UR10;
1206 __IO uint32_t UR11;
1207 __IO uint32_t UR12;
1208 __IO uint32_t UR13;
1209 __IO uint32_t UR14;
1210 __IO uint32_t UR15;
1211 __IO uint32_t UR16;
1212 __IO uint32_t UR17;
1215
1220typedef struct
1221{
1222 __IO uint32_t CR1;
1223 __IO uint32_t CR2;
1224 __IO uint32_t OAR1;
1225 __IO uint32_t OAR2;
1226 __IO uint32_t TIMINGR;
1227 __IO uint32_t TIMEOUTR;
1228 __IO uint32_t ISR;
1229 __IO uint32_t ICR;
1230 __IO uint32_t PECR;
1231 __IO uint32_t RXDR;
1232 __IO uint32_t TXDR;
1233} I2C_TypeDef;
1234
1239typedef struct
1240{
1241 __IO uint32_t KR;
1242 __IO uint32_t PR;
1243 __IO uint32_t RLR;
1244 __IO uint32_t SR;
1245 __IO uint32_t WINR;
1246} IWDG_TypeDef;
1247
1248
1252typedef struct
1253{
1254 __IO uint32_t CONFR0;
1255 __IO uint32_t CONFR1;
1256 __IO uint32_t CONFR2;
1257 __IO uint32_t CONFR3;
1258 __IO uint32_t CONFR4;
1259 __IO uint32_t CONFR5;
1260 __IO uint32_t CONFR6;
1261 __IO uint32_t CONFR7;
1262 uint32_t Reserved20[4]; /* Reserved Address offset: 20h-2Ch */
1263 __IO uint32_t CR;
1264 __IO uint32_t SR;
1265 __IO uint32_t CFR;
1266 uint32_t Reserved3c; /* Reserved Address offset: 3Ch */
1267 __IO uint32_t DIR;
1268 __IO uint32_t DOR;
1269 uint32_t Reserved48[2]; /* Reserved Address offset: 48h-4Ch */
1270 __IO uint32_t QMEM0[16];
1271 __IO uint32_t QMEM1[16];
1272 __IO uint32_t QMEM2[16];
1273 __IO uint32_t QMEM3[16];
1274 __IO uint32_t HUFFMIN[16];
1275 __IO uint32_t HUFFBASE[32];
1276 __IO uint32_t HUFFSYMB[84];
1277 __IO uint32_t DHTMEM[103];
1278 uint32_t Reserved4FC; /* Reserved Address offset: 4FCh */
1279 __IO uint32_t HUFFENC_AC0[88];
1280 __IO uint32_t HUFFENC_AC1[88];
1281 __IO uint32_t HUFFENC_DC0[8];
1282 __IO uint32_t HUFFENC_DC1[8];
1284} JPEG_TypeDef;
1285
1290typedef struct
1291{
1292 uint32_t RESERVED0[2];
1293 __IO uint32_t SSCR;
1294 __IO uint32_t BPCR;
1295 __IO uint32_t AWCR;
1296 __IO uint32_t TWCR;
1297 __IO uint32_t GCR;
1298 uint32_t RESERVED1[2];
1299 __IO uint32_t SRCR;
1300 uint32_t RESERVED2[1];
1301 __IO uint32_t BCCR;
1302 uint32_t RESERVED3[1];
1303 __IO uint32_t IER;
1304 __IO uint32_t ISR;
1305 __IO uint32_t ICR;
1306 __IO uint32_t LIPCR;
1307 __IO uint32_t CPSR;
1308 __IO uint32_t CDSR;
1309} LTDC_TypeDef;
1310
1315typedef struct
1316{
1317 __IO uint32_t CR;
1318 __IO uint32_t WHPCR;
1319 __IO uint32_t WVPCR;
1320 __IO uint32_t CKCR;
1321 __IO uint32_t PFCR;
1322 __IO uint32_t CACR;
1323 __IO uint32_t DCCR;
1324 __IO uint32_t BFCR;
1325 uint32_t RESERVED0[2];
1326 __IO uint32_t CFBAR;
1327 __IO uint32_t CFBLR;
1328 __IO uint32_t CFBLNR;
1329 uint32_t RESERVED1[3];
1330 __IO uint32_t CLUTWR;
1333
1338typedef struct
1339{
1340 __IO uint32_t CR1;
1341 __IO uint32_t CSR1;
1342 __IO uint32_t CR2;
1343 __IO uint32_t CR3;
1344 __IO uint32_t CPUCR;
1345 __IO uint32_t CPU2CR;
1346 __IO uint32_t D3CR;
1347 uint32_t RESERVED1;
1348 __IO uint32_t WKUPCR;
1349 __IO uint32_t WKUPFR;
1350 __IO uint32_t WKUPEPR;
1351} PWR_TypeDef;
1352
1357typedef struct
1358{
1359 __IO uint32_t CR;
1360 __IO uint32_t HSICFGR;
1361 __IO uint32_t CRRCR;
1362 __IO uint32_t CSICFGR;
1363 __IO uint32_t CFGR;
1364 uint32_t RESERVED1;
1365 __IO uint32_t D1CFGR;
1366 __IO uint32_t D2CFGR;
1367 __IO uint32_t D3CFGR;
1368 uint32_t RESERVED2;
1369 __IO uint32_t PLLCKSELR;
1370 __IO uint32_t PLLCFGR;
1371 __IO uint32_t PLL1DIVR;
1372 __IO uint32_t PLL1FRACR;
1373 __IO uint32_t PLL2DIVR;
1374 __IO uint32_t PLL2FRACR;
1375 __IO uint32_t PLL3DIVR;
1376 __IO uint32_t PLL3FRACR;
1377 uint32_t RESERVED3;
1378 __IO uint32_t D1CCIPR;
1379 __IO uint32_t D2CCIP1R;
1380 __IO uint32_t D2CCIP2R;
1381 __IO uint32_t D3CCIPR;
1382 uint32_t RESERVED4;
1383 __IO uint32_t CIER;
1384 __IO uint32_t CIFR;
1385 __IO uint32_t CICR;
1386 uint32_t RESERVED5;
1387 __IO uint32_t BDCR;
1388 __IO uint32_t CSR;
1389 uint32_t RESERVED6;
1390 __IO uint32_t AHB3RSTR;
1391 __IO uint32_t AHB1RSTR;
1392 __IO uint32_t AHB2RSTR;
1393 __IO uint32_t AHB4RSTR;
1394 __IO uint32_t APB3RSTR;
1395 __IO uint32_t APB1LRSTR;
1396 __IO uint32_t APB1HRSTR;
1397 __IO uint32_t APB2RSTR;
1398 __IO uint32_t APB4RSTR;
1399 __IO uint32_t GCR;
1400 uint32_t RESERVED8;
1401 __IO uint32_t D3AMR;
1402 uint32_t RESERVED11[9];
1403 __IO uint32_t RSR;
1404 __IO uint32_t AHB3ENR;
1405 __IO uint32_t AHB1ENR;
1406 __IO uint32_t AHB2ENR;
1407 __IO uint32_t AHB4ENR;
1408 __IO uint32_t APB3ENR;
1409 __IO uint32_t APB1LENR;
1410 __IO uint32_t APB1HENR;
1411 __IO uint32_t APB2ENR;
1412 __IO uint32_t APB4ENR;
1413 uint32_t RESERVED12;
1414 __IO uint32_t AHB3LPENR;
1415 __IO uint32_t AHB1LPENR;
1416 __IO uint32_t AHB2LPENR;
1417 __IO uint32_t AHB4LPENR;
1418 __IO uint32_t APB3LPENR;
1419 __IO uint32_t APB1LLPENR;
1420 __IO uint32_t APB1HLPENR;
1421 __IO uint32_t APB2LPENR;
1422 __IO uint32_t APB4LPENR;
1423 uint32_t RESERVED13[4];
1425} RCC_TypeDef;
1426
1427typedef struct
1428{
1429 __IO uint32_t RSR;
1430 __IO uint32_t AHB3ENR;
1431 __IO uint32_t AHB1ENR;
1432 __IO uint32_t AHB2ENR;
1433 __IO uint32_t AHB4ENR;
1434 __IO uint32_t APB3ENR;
1435 __IO uint32_t APB1LENR;
1436 __IO uint32_t APB1HENR;
1437 __IO uint32_t APB2ENR;
1438 __IO uint32_t APB4ENR;
1439 uint32_t RESERVED9;
1440 __IO uint32_t AHB3LPENR;
1441 __IO uint32_t AHB1LPENR;
1442 __IO uint32_t AHB2LPENR;
1443 __IO uint32_t AHB4LPENR;
1444 __IO uint32_t APB3LPENR;
1445 __IO uint32_t APB1LLPENR;
1446 __IO uint32_t APB1HLPENR;
1447 __IO uint32_t APB2LPENR;
1448 __IO uint32_t APB4LPENR;
1449 uint32_t RESERVED10[4];
1452
1456typedef struct
1457{
1458 __IO uint32_t TR;
1459 __IO uint32_t DR;
1460 __IO uint32_t CR;
1461 __IO uint32_t ISR;
1462 __IO uint32_t PRER;
1463 __IO uint32_t WUTR;
1464 uint32_t RESERVED;
1465 __IO uint32_t ALRMAR;
1466 __IO uint32_t ALRMBR;
1467 __IO uint32_t WPR;
1468 __IO uint32_t SSR;
1469 __IO uint32_t SHIFTR;
1470 __IO uint32_t TSTR;
1471 __IO uint32_t TSDR;
1472 __IO uint32_t TSSSR;
1473 __IO uint32_t CALR;
1474 __IO uint32_t TAMPCR;
1475 __IO uint32_t ALRMASSR;
1476 __IO uint32_t ALRMBSSR;
1477 __IO uint32_t OR;
1478 __IO uint32_t BKP0R;
1479 __IO uint32_t BKP1R;
1480 __IO uint32_t BKP2R;
1481 __IO uint32_t BKP3R;
1482 __IO uint32_t BKP4R;
1483 __IO uint32_t BKP5R;
1484 __IO uint32_t BKP6R;
1485 __IO uint32_t BKP7R;
1486 __IO uint32_t BKP8R;
1487 __IO uint32_t BKP9R;
1488 __IO uint32_t BKP10R;
1489 __IO uint32_t BKP11R;
1490 __IO uint32_t BKP12R;
1491 __IO uint32_t BKP13R;
1492 __IO uint32_t BKP14R;
1493 __IO uint32_t BKP15R;
1494 __IO uint32_t BKP16R;
1495 __IO uint32_t BKP17R;
1496 __IO uint32_t BKP18R;
1497 __IO uint32_t BKP19R;
1498 __IO uint32_t BKP20R;
1499 __IO uint32_t BKP21R;
1500 __IO uint32_t BKP22R;
1501 __IO uint32_t BKP23R;
1502 __IO uint32_t BKP24R;
1503 __IO uint32_t BKP25R;
1504 __IO uint32_t BKP26R;
1505 __IO uint32_t BKP27R;
1506 __IO uint32_t BKP28R;
1507 __IO uint32_t BKP29R;
1508 __IO uint32_t BKP30R;
1509 __IO uint32_t BKP31R;
1510} RTC_TypeDef;
1511
1516typedef struct
1517{
1518 __IO uint32_t GCR;
1519 uint32_t RESERVED0[16];
1520 __IO uint32_t PDMCR;
1521 __IO uint32_t PDMDLY;
1522} SAI_TypeDef;
1523
1524typedef struct
1525{
1526 __IO uint32_t CR1;
1527 __IO uint32_t CR2;
1528 __IO uint32_t FRCR;
1529 __IO uint32_t SLOTR;
1530 __IO uint32_t IMR;
1531 __IO uint32_t SR;
1532 __IO uint32_t CLRFR;
1533 __IO uint32_t DR;
1535
1540typedef struct
1541{
1542 __IO uint32_t CR;
1543 __IO uint32_t IMR;
1544 __IO uint32_t SR;
1545 __IO uint32_t IFCR;
1546 __IO uint32_t DR;
1547 __IO uint32_t CSR;
1548 __IO uint32_t DIR;
1549 uint32_t RESERVED2;
1551
1552
1557typedef struct
1558{
1559 __IO uint32_t POWER;
1560 __IO uint32_t CLKCR;
1561 __IO uint32_t ARG;
1562 __IO uint32_t CMD;
1563 __I uint32_t RESPCMD;
1564 __I uint32_t RESP1;
1565 __I uint32_t RESP2;
1566 __I uint32_t RESP3;
1567 __I uint32_t RESP4;
1568 __IO uint32_t DTIMER;
1569 __IO uint32_t DLEN;
1570 __IO uint32_t DCTRL;
1571 __I uint32_t DCOUNT;
1572 __I uint32_t STA;
1573 __IO uint32_t ICR;
1574 __IO uint32_t MASK;
1575 __IO uint32_t ACKTIME;
1576 uint32_t RESERVED0[3];
1577 __IO uint32_t IDMACTRL;
1578 __IO uint32_t IDMABSIZE;
1579 __IO uint32_t IDMABASE0;
1580 __IO uint32_t IDMABASE1;
1581 uint32_t RESERVED1[8];
1582 __IO uint32_t FIFO;
1583 uint32_t RESERVED2[222];
1584 __IO uint32_t IPVR;
1586
1587
1592typedef struct
1593{
1594 __IO uint32_t CR;
1595 __IO uint32_t CFGR;
1596} DLYB_TypeDef;
1597
1602typedef struct
1603{
1604 __IO uint32_t R[32];
1605 __IO uint32_t RLR[32];
1606 __IO uint32_t C1IER;
1607 __IO uint32_t C1ICR;
1608 __IO uint32_t C1ISR;
1609 __IO uint32_t C1MISR;
1610 __IO uint32_t C2IER;
1611 __IO uint32_t C2ICR;
1612 __IO uint32_t C2ISR;
1613 __IO uint32_t C2MISR;
1614 uint32_t Reserved[8]; /* Reserved Address offset: 120h-13Ch*/
1615 __IO uint32_t CR;
1616 __IO uint32_t KEYR;
1618} HSEM_TypeDef;
1619
1620typedef struct
1621{
1622 __IO uint32_t IER;
1623 __IO uint32_t ICR;
1624 __IO uint32_t ISR;
1625 __IO uint32_t MISR;
1627
1632typedef struct
1633{
1634 __IO uint32_t CR1;
1635 __IO uint32_t CR2;
1636 __IO uint32_t CFG1;
1637 __IO uint32_t CFG2;
1638 __IO uint32_t IER;
1639 __IO uint32_t SR;
1640 __IO uint32_t IFCR;
1641 uint32_t RESERVED0;
1642 __IO uint32_t TXDR;
1643 uint32_t RESERVED1[3];
1644 __IO uint32_t RXDR;
1645 uint32_t RESERVED2[3];
1646 __IO uint32_t CRCPOLY;
1647 __IO uint32_t TXCRC;
1648 __IO uint32_t RXCRC;
1649 __IO uint32_t UDRDR;
1650 __IO uint32_t I2SCFGR;
1652} SPI_TypeDef;
1657typedef struct
1658{
1659 __IO uint32_t CR;
1660 __IO uint32_t DCR;
1661 __IO uint32_t SR;
1662 __IO uint32_t FCR;
1663 __IO uint32_t DLR;
1664 __IO uint32_t CCR;
1665 __IO uint32_t AR;
1666 __IO uint32_t ABR;
1667 __IO uint32_t DR;
1668 __IO uint32_t PSMKR;
1669 __IO uint32_t PSMAR;
1670 __IO uint32_t PIR;
1671 __IO uint32_t LPTR;
1673
1678typedef struct
1679{
1680 __IO uint32_t CR1;
1681 __IO uint32_t CR2;
1682 __IO uint32_t SMCR;
1683 __IO uint32_t DIER;
1684 __IO uint32_t SR;
1685 __IO uint32_t EGR;
1686 __IO uint32_t CCMR1;
1687 __IO uint32_t CCMR2;
1688 __IO uint32_t CCER;
1689 __IO uint32_t CNT;
1690 __IO uint32_t PSC;
1691 __IO uint32_t ARR;
1692 __IO uint32_t RCR;
1693 __IO uint32_t CCR1;
1694 __IO uint32_t CCR2;
1695 __IO uint32_t CCR3;
1696 __IO uint32_t CCR4;
1697 __IO uint32_t BDTR;
1698 __IO uint32_t DCR;
1699 __IO uint32_t DMAR;
1700 uint32_t RESERVED1;
1701 __IO uint32_t CCMR3;
1702 __IO uint32_t CCR5;
1703 __IO uint32_t CCR6;
1704 __IO uint32_t AF1;
1705 __IO uint32_t AF2;
1706 __IO uint32_t TISEL;
1707} TIM_TypeDef;
1708
1712typedef struct
1713{
1714 __IO uint32_t ISR;
1715 __IO uint32_t ICR;
1716 __IO uint32_t IER;
1717 __IO uint32_t CFGR;
1718 __IO uint32_t CR;
1719 __IO uint32_t CMP;
1720 __IO uint32_t ARR;
1721 __IO uint32_t CNT;
1722 uint32_t RESERVED1;
1723 __IO uint32_t CFGR2;
1725
1729typedef struct
1730{
1731 __IO uint32_t SR;
1732 __IO uint32_t ICFR;
1733 __IO uint32_t OR;
1735
1736typedef struct
1737{
1738 __IO uint32_t CFGR;
1739} COMP_TypeDef;
1740
1741typedef struct
1742{
1743 __IO uint32_t CFGR;
1749typedef struct
1750{
1751 __IO uint32_t CR1;
1752 __IO uint32_t CR2;
1753 __IO uint32_t CR3;
1754 __IO uint32_t BRR;
1755 __IO uint32_t GTPR;
1756 __IO uint32_t RTOR;
1757 __IO uint32_t RQR;
1758 __IO uint32_t ISR;
1759 __IO uint32_t ICR;
1760 __IO uint32_t RDR;
1761 __IO uint32_t TDR;
1762 __IO uint32_t PRESC;
1764
1768typedef struct
1769{
1770 __IO uint32_t CR;
1771 __IO uint32_t BRR;
1772 uint32_t RESERVED1;
1773 __IO uint32_t ISR;
1774 __IO uint32_t ICR;
1775 __IO uint32_t IER;
1776 __IO uint32_t RFL;
1777 __IO uint32_t TDR;
1778 __IO uint32_t RDR;
1779 __IO uint32_t OR;
1781
1786typedef struct
1787{
1788 __IO uint32_t CR;
1789 __IO uint32_t CFR;
1790 __IO uint32_t SR;
1791} WWDG_TypeDef;
1792
1793
1797typedef struct
1798{
1799 __IO uint32_t CR;
1800 __IO uint32_t SR;
1801 __IO uint32_t FAR;
1802 __IO uint32_t FDRL;
1803 __IO uint32_t FDRH;
1804 __IO uint32_t FECR;
1806
1807typedef struct
1808{
1809 __IO uint32_t IER;
1820typedef struct
1821{
1822 __IO uint32_t CR;
1823 __IO uint32_t SR;
1824 __IO uint32_t DIN;
1825 __IO uint32_t DOUT;
1826 __IO uint32_t DMACR;
1827 __IO uint32_t IMSCR;
1828 __IO uint32_t RISR;
1829 __IO uint32_t MISR;
1830 __IO uint32_t K0LR;
1831 __IO uint32_t K0RR;
1832 __IO uint32_t K1LR;
1833 __IO uint32_t K1RR;
1834 __IO uint32_t K2LR;
1835 __IO uint32_t K2RR;
1836 __IO uint32_t K3LR;
1837 __IO uint32_t K3RR;
1838 __IO uint32_t IV0LR;
1839 __IO uint32_t IV0RR;
1840 __IO uint32_t IV1LR;
1841 __IO uint32_t IV1RR;
1842 __IO uint32_t CSGCMCCM0R;
1843 __IO uint32_t CSGCMCCM1R;
1844 __IO uint32_t CSGCMCCM2R;
1845 __IO uint32_t CSGCMCCM3R;
1846 __IO uint32_t CSGCMCCM4R;
1847 __IO uint32_t CSGCMCCM5R;
1848 __IO uint32_t CSGCMCCM6R;
1849 __IO uint32_t CSGCMCCM7R;
1850 __IO uint32_t CSGCM0R;
1851 __IO uint32_t CSGCM1R;
1852 __IO uint32_t CSGCM2R;
1853 __IO uint32_t CSGCM3R;
1854 __IO uint32_t CSGCM4R;
1855 __IO uint32_t CSGCM5R;
1856 __IO uint32_t CSGCM6R;
1857 __IO uint32_t CSGCM7R;
1858} CRYP_TypeDef;
1859
1864typedef struct
1865{
1866 __IO uint32_t CR;
1867 __IO uint32_t DIN;
1868 __IO uint32_t STR;
1869 __IO uint32_t HR[5];
1870 __IO uint32_t IMR;
1871 __IO uint32_t SR;
1872 uint32_t RESERVED[52];
1873 __IO uint32_t CSR[54];
1874} HASH_TypeDef;
1875
1880typedef struct
1881{
1882 __IO uint32_t HR[8];
1884
1885
1889/* HRTIM master registers definition */
1890typedef struct
1891{
1892 __IO uint32_t MCR;
1893 __IO uint32_t MISR;
1894 __IO uint32_t MICR;
1895 __IO uint32_t MDIER;
1896 __IO uint32_t MCNTR;
1897 __IO uint32_t MPER;
1898 __IO uint32_t MREP;
1899 __IO uint32_t MCMP1R;
1900 uint32_t RESERVED0;
1901 __IO uint32_t MCMP2R;
1902 __IO uint32_t MCMP3R;
1903 __IO uint32_t MCMP4R;
1904 uint32_t RESERVED1[20];
1906
1907/* HRTIM Timer A to E registers definition */
1908typedef struct
1909{
1910 __IO uint32_t TIMxCR;
1911 __IO uint32_t TIMxISR;
1912 __IO uint32_t TIMxICR;
1913 __IO uint32_t TIMxDIER;
1914 __IO uint32_t CNTxR;
1915 __IO uint32_t PERxR;
1916 __IO uint32_t REPxR;
1917 __IO uint32_t CMP1xR;
1918 __IO uint32_t CMP1CxR;
1919 __IO uint32_t CMP2xR;
1920 __IO uint32_t CMP3xR;
1921 __IO uint32_t CMP4xR;
1922 __IO uint32_t CPT1xR;
1923 __IO uint32_t CPT2xR;
1924 __IO uint32_t DTxR;
1925 __IO uint32_t SETx1R;
1926 __IO uint32_t RSTx1R;
1927 __IO uint32_t SETx2R;
1928 __IO uint32_t RSTx2R;
1929 __IO uint32_t EEFxR1;
1930 __IO uint32_t EEFxR2;
1931 __IO uint32_t RSTxR;
1932 __IO uint32_t CHPxR;
1933 __IO uint32_t CPT1xCR;
1934 __IO uint32_t CPT2xCR;
1935 __IO uint32_t OUTxR;
1936 __IO uint32_t FLTxR;
1937 uint32_t RESERVED0[5];
1939
1940/* HRTIM common register definition */
1941typedef struct
1942{
1943 __IO uint32_t CR1;
1944 __IO uint32_t CR2;
1945 __IO uint32_t ISR;
1946 __IO uint32_t ICR;
1947 __IO uint32_t IER;
1948 __IO uint32_t OENR;
1949 __IO uint32_t ODISR;
1950 __IO uint32_t ODSR;
1951 __IO uint32_t BMCR;
1952 __IO uint32_t BMTRGR;
1953 __IO uint32_t BMCMPR;
1954 __IO uint32_t BMPER;
1955 __IO uint32_t EECR1;
1956 __IO uint32_t EECR2;
1957 __IO uint32_t EECR3;
1958 __IO uint32_t ADC1R;
1959 __IO uint32_t ADC2R;
1960 __IO uint32_t ADC3R;
1961 __IO uint32_t ADC4R;
1962 __IO uint32_t RESERVED0;
1963 __IO uint32_t FLTINR1;
1964 __IO uint32_t FLTINR2;
1965 __IO uint32_t BDMUPR;
1966 __IO uint32_t BDTAUPR;
1967 __IO uint32_t BDTBUPR;
1968 __IO uint32_t BDTCUPR;
1969 __IO uint32_t BDTDUPR;
1970 __IO uint32_t BDTEUPR;
1971 __IO uint32_t BDMADR;
1973
1974/* HRTIM register definition */
1975typedef struct {
1976 HRTIM_Master_TypeDef sMasterRegs;
1977 HRTIM_Timerx_TypeDef sTimerxRegs[5];
1978 uint32_t RESERVED0[32];
1979 HRTIM_Common_TypeDef sCommonRegs;
1985typedef struct
1986{
1987 __IO uint32_t CR;
1988 __IO uint32_t SR;
1989 __IO uint32_t DR;
1990} RNG_TypeDef;
1991
1996typedef struct
1997{
1998 __IO uint32_t CR;
1999 __IO uint32_t WRFR;
2000 __IO uint32_t CWRFR;
2001 __IO uint32_t RDFR;
2002 __IO uint32_t CRDFR;
2003 __IO uint32_t SR;
2004 __IO uint32_t CLRFR;
2005 uint32_t RESERVED[57];
2006 __IO uint32_t DINR0;
2007 __IO uint32_t DINR1;
2008 __IO uint32_t DINR2;
2009 __IO uint32_t DINR3;
2010 __IO uint32_t DINR4;
2011 __IO uint32_t DINR5;
2012 __IO uint32_t DINR6;
2013 __IO uint32_t DINR7;
2014 __IO uint32_t DINR8;
2015 __IO uint32_t DINR9;
2016 __IO uint32_t DINR10;
2017 __IO uint32_t DINR11;
2018 __IO uint32_t DINR12;
2019 __IO uint32_t DINR13;
2020 __IO uint32_t DINR14;
2021 __IO uint32_t DINR15;
2022 __IO uint32_t DINR16;
2023 __IO uint32_t DINR17;
2024 __IO uint32_t DINR18;
2025 __IO uint32_t DINR19;
2026 __IO uint32_t DINR20;
2027 __IO uint32_t DINR21;
2028 __IO uint32_t DINR22;
2029 __IO uint32_t DINR23;
2030 __IO uint32_t DINR24;
2031 __IO uint32_t DINR25;
2032 __IO uint32_t DINR26;
2033 __IO uint32_t DINR27;
2034 __IO uint32_t DINR28;
2035 __IO uint32_t DINR29;
2036 __IO uint32_t DINR30;
2037 __IO uint32_t DINR31;
2038 __IO uint32_t DOUTR0;
2039 __IO uint32_t DOUTR1;
2040 __IO uint32_t DOUTR2;
2041 __IO uint32_t DOUTR3;
2042 __IO uint32_t DOUTR4;
2043 __IO uint32_t DOUTR5;
2044 __IO uint32_t DOUTR6;
2045 __IO uint32_t DOUTR7;
2046 __IO uint32_t DOUTR8;
2047 __IO uint32_t DOUTR9;
2048 __IO uint32_t DOUTR10;
2049 __IO uint32_t DOUTR11;
2050 __IO uint32_t DOUTR12;
2051 __IO uint32_t DOUTR13;
2052 __IO uint32_t DOUTR14;
2053 __IO uint32_t DOUTR15;
2054 __IO uint32_t DOUTR16;
2055 __IO uint32_t DOUTR17;
2056 __IO uint32_t DOUTR18;
2057 __IO uint32_t DOUTR19;
2058 __IO uint32_t DOUTR20;
2059 __IO uint32_t DOUTR21;
2060 __IO uint32_t DOUTR22;
2061 __IO uint32_t DOUTR23;
2062 __IO uint32_t DOUTR24;
2063 __IO uint32_t DOUTR25;
2064 __IO uint32_t DOUTR26;
2065 __IO uint32_t DOUTR27;
2066 __IO uint32_t DOUTR28;
2067 __IO uint32_t DOUTR29;
2068 __IO uint32_t DOUTR30;
2069 __IO uint32_t DOUTR31;
2071
2072
2076typedef struct
2077{
2078 __IO uint32_t GOTGCTL;
2079 __IO uint32_t GOTGINT;
2080 __IO uint32_t GAHBCFG;
2081 __IO uint32_t GUSBCFG;
2082 __IO uint32_t GRSTCTL;
2083 __IO uint32_t GINTSTS;
2084 __IO uint32_t GINTMSK;
2085 __IO uint32_t GRXSTSR;
2086 __IO uint32_t GRXSTSP;
2087 __IO uint32_t GRXFSIZ;
2088 __IO uint32_t DIEPTXF0_HNPTXFSIZ;
2089 __IO uint32_t HNPTXSTS;
2090 uint32_t Reserved30[2];
2091 __IO uint32_t GCCFG;
2092 __IO uint32_t CID;
2093 __IO uint32_t GSNPSID; /* USB_OTG core ID 040h*/
2094 __IO uint32_t GHWCFG1; /* User HW config1 044h*/
2095 __IO uint32_t GHWCFG2; /* User HW config2 048h*/
2096 __IO uint32_t GHWCFG3;
2097 uint32_t Reserved6;
2098 __IO uint32_t GLPMCFG;
2099 __IO uint32_t GPWRDN;
2100 __IO uint32_t GDFIFOCFG;
2101 __IO uint32_t GADPCTL;
2102 uint32_t Reserved43[39];
2103 __IO uint32_t HPTXFSIZ;
2104 __IO uint32_t DIEPTXF[0x0F];
2106
2107
2111typedef struct
2112{
2113 __IO uint32_t DCFG;
2114 __IO uint32_t DCTL;
2115 __IO uint32_t DSTS;
2116 uint32_t Reserved0C;
2117 __IO uint32_t DIEPMSK;
2118 __IO uint32_t DOEPMSK;
2119 __IO uint32_t DAINT;
2120 __IO uint32_t DAINTMSK;
2121 uint32_t Reserved20;
2122 uint32_t Reserved9;
2123 __IO uint32_t DVBUSDIS;
2124 __IO uint32_t DVBUSPULSE;
2125 __IO uint32_t DTHRCTL;
2126 __IO uint32_t DIEPEMPMSK;
2127 __IO uint32_t DEACHINT;
2128 __IO uint32_t DEACHMSK;
2129 uint32_t Reserved40;
2130 __IO uint32_t DINEP1MSK;
2131 uint32_t Reserved44[15];
2132 __IO uint32_t DOUTEP1MSK;
2134
2135
2139typedef struct
2140{
2141 __IO uint32_t DIEPCTL;
2142 uint32_t Reserved04;
2143 __IO uint32_t DIEPINT;
2144 uint32_t Reserved0C;
2145 __IO uint32_t DIEPTSIZ;
2146 __IO uint32_t DIEPDMA;
2147 __IO uint32_t DTXFSTS;
2148 uint32_t Reserved18;
2150
2151
2155typedef struct
2156{
2157 __IO uint32_t DOEPCTL;
2158 uint32_t Reserved04;
2159 __IO uint32_t DOEPINT;
2160 uint32_t Reserved0C;
2161 __IO uint32_t DOEPTSIZ;
2162 __IO uint32_t DOEPDMA;
2163 uint32_t Reserved18[2];
2165
2166
2170typedef struct
2171{
2172 __IO uint32_t HCFG;
2173 __IO uint32_t HFIR;
2174 __IO uint32_t HFNUM;
2175 uint32_t Reserved40C;
2176 __IO uint32_t HPTXSTS;
2177 __IO uint32_t HAINT;
2178 __IO uint32_t HAINTMSK;
2180
2184typedef struct
2185{
2186 __IO uint32_t HCCHAR;
2187 __IO uint32_t HCSPLT;
2188 __IO uint32_t HCINT;
2189 __IO uint32_t HCINTMSK;
2190 __IO uint32_t HCTSIZ;
2191 __IO uint32_t HCDMA;
2192 uint32_t Reserved[2];
2203typedef struct
2204{
2205 uint32_t RESERVED0[2036];
2206 __IO uint32_t AXI_PERIPH_ID_4;
2207 uint32_t AXI_PERIPH_ID_5;
2208 uint32_t AXI_PERIPH_ID_6;
2209 uint32_t AXI_PERIPH_ID_7;
2210 __IO uint32_t AXI_PERIPH_ID_0;
2211 __IO uint32_t AXI_PERIPH_ID_1;
2212 __IO uint32_t AXI_PERIPH_ID_2;
2213 __IO uint32_t AXI_PERIPH_ID_3;
2214 __IO uint32_t AXI_COMP_ID_0;
2215 __IO uint32_t AXI_COMP_ID_1;
2216 __IO uint32_t AXI_COMP_ID_2;
2217 __IO uint32_t AXI_COMP_ID_3;
2218 uint32_t RESERVED1[2];
2219 __IO uint32_t AXI_TARG1_FN_MOD_ISS_BM;
2220 uint32_t RESERVED2[6];
2221 __IO uint32_t AXI_TARG1_FN_MOD2;
2222 uint32_t RESERVED3;
2223 __IO uint32_t AXI_TARG1_FN_MOD_LB;
2224 uint32_t RESERVED4[54];
2225 __IO uint32_t AXI_TARG1_FN_MOD;
2226 uint32_t RESERVED5[959];
2227 __IO uint32_t AXI_TARG2_FN_MOD_ISS_BM;
2228 uint32_t RESERVED6[6];
2229 __IO uint32_t AXI_TARG2_FN_MOD2;
2230 uint32_t RESERVED7;
2231 __IO uint32_t AXI_TARG2_FN_MOD_LB;
2232 uint32_t RESERVED8[54];
2233 __IO uint32_t AXI_TARG2_FN_MOD;
2234 uint32_t RESERVED9[959];
2235 __IO uint32_t AXI_TARG3_FN_MOD_ISS_BM;
2236 uint32_t RESERVED10[1023];
2237 __IO uint32_t AXI_TARG4_FN_MOD_ISS_BM;
2238 uint32_t RESERVED11[1023];
2239 __IO uint32_t AXI_TARG5_FN_MOD_ISS_BM;
2240 uint32_t RESERVED12[1023];
2241 __IO uint32_t AXI_TARG6_FN_MOD_ISS_BM;
2242 uint32_t RESERVED13[1023];
2243 __IO uint32_t AXI_TARG7_FN_MOD_ISS_BM;
2244 uint32_t RESERVED14[6];
2245 __IO uint32_t AXI_TARG7_FN_MOD2;
2246 uint32_t RESERVED15;
2247 __IO uint32_t AXI_TARG7_FN_MOD_LB;
2248 uint32_t RESERVED16[54];
2249 __IO uint32_t AXI_TARG7_FN_MOD;
2250 uint32_t RESERVED17[59334];
2251 __IO uint32_t AXI_INI1_FN_MOD2;
2252 __IO uint32_t AXI_INI1_FN_MOD_AHB;
2253 uint32_t RESERVED18[53];
2254 __IO uint32_t AXI_INI1_READ_QOS;
2255 __IO uint32_t AXI_INI1_WRITE_QOS;
2256 __IO uint32_t AXI_INI1_FN_MOD;
2257 uint32_t RESERVED19[1021];
2258 __IO uint32_t AXI_INI2_READ_QOS;
2259 __IO uint32_t AXI_INI2_WRITE_QOS;
2260 __IO uint32_t AXI_INI2_FN_MOD;
2261 uint32_t RESERVED20[966];
2262 __IO uint32_t AXI_INI3_FN_MOD2;
2263 __IO uint32_t AXI_INI3_FN_MOD_AHB;
2264 uint32_t RESERVED21[53];
2265 __IO uint32_t AXI_INI3_READ_QOS;
2266 __IO uint32_t AXI_INI3_WRITE_QOS;
2267 __IO uint32_t AXI_INI3_FN_MOD;
2268 uint32_t RESERVED22[1021];
2269 __IO uint32_t AXI_INI4_READ_QOS;
2270 __IO uint32_t AXI_INI4_WRITE_QOS;
2271 __IO uint32_t AXI_INI4_FN_MOD;
2272 uint32_t RESERVED23[1021];
2273 __IO uint32_t AXI_INI5_READ_QOS;
2274 __IO uint32_t AXI_INI5_WRITE_QOS;
2275 __IO uint32_t AXI_INI5_FN_MOD;
2276 uint32_t RESERVED24[1021];
2277 __IO uint32_t AXI_INI6_READ_QOS;
2278 __IO uint32_t AXI_INI6_WRITE_QOS;
2279 __IO uint32_t AXI_INI6_FN_MOD;
2280 uint32_t RESERVED25[1021];
2281 __IO uint32_t AXI_INI7_READ_QOS;
2282 __IO uint32_t AXI_INI7_WRITE_QOS;
2283 __IO uint32_t AXI_INI7_FN_MOD;
2285} GPV_TypeDef;
2286
2290#define D1_ITCMRAM_BASE (0x00000000UL)
2291#define D1_ITCMICP_BASE (0x00100000UL)
2292#define D1_DTCMRAM_BASE (0x20000000UL)
2293#define D1_AXIFLASH_BASE (0x08000000UL)
2294#define D1_AXIICP_BASE (0x1FF00000UL)
2295#define D1_AXISRAM_BASE (0x24000000UL)
2297#define D2_AXISRAM_BASE (0x10000000UL)
2298#define D2_AHBSRAM_BASE (0x30000000UL)
2300#define D3_BKPSRAM_BASE (0x38800000UL)
2301#define D3_SRAM_BASE (0x38000000UL)
2303#define PERIPH_BASE (0x40000000UL)
2304#define QSPI_BASE (0x90000000UL)
2306#define FLASH_BANK1_BASE (0x08000000UL)
2307#define FLASH_BANK2_BASE (0x08100000UL)
2308#define FLASH_END (0x081FFFFFUL)
2310/* Legacy define */
2311#define FLASH_BASE FLASH_BANK1_BASE
2312
2314#define UID_BASE (0x1FF1E800UL)
2315#define FLASHSIZE_BASE (0x1FF1E880UL)
2319#define D2_APB1PERIPH_BASE PERIPH_BASE
2320#define D2_APB2PERIPH_BASE (PERIPH_BASE + 0x00010000UL)
2321#define D2_AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000UL)
2322#define D2_AHB2PERIPH_BASE (PERIPH_BASE + 0x08020000UL)
2323
2324#define D1_APB1PERIPH_BASE (PERIPH_BASE + 0x10000000UL)
2325#define D1_AHB1PERIPH_BASE (PERIPH_BASE + 0x12000000UL)
2326
2327#define D3_APB1PERIPH_BASE (PERIPH_BASE + 0x18000000UL)
2328#define D3_AHB1PERIPH_BASE (PERIPH_BASE + 0x18020000UL)
2329
2331#define APB1PERIPH_BASE PERIPH_BASE
2332#define APB2PERIPH_BASE (PERIPH_BASE + 0x00010000UL)
2333#define AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000UL)
2334#define AHB2PERIPH_BASE (PERIPH_BASE + 0x08000000UL)
2335
2336
2339#define MDMA_BASE (D1_AHB1PERIPH_BASE + 0x0000UL)
2340#define DMA2D_BASE (D1_AHB1PERIPH_BASE + 0x1000UL)
2341#define JPGDEC_BASE (D1_AHB1PERIPH_BASE + 0x3000UL)
2342#define FLASH_R_BASE (D1_AHB1PERIPH_BASE + 0x2000UL)
2343#define FMC_R_BASE (D1_AHB1PERIPH_BASE + 0x4000UL)
2344#define QSPI_R_BASE (D1_AHB1PERIPH_BASE + 0x5000UL)
2345#define DLYB_QSPI_BASE (D1_AHB1PERIPH_BASE + 0x6000UL)
2346#define SDMMC1_BASE (D1_AHB1PERIPH_BASE + 0x7000UL)
2347#define DLYB_SDMMC1_BASE (D1_AHB1PERIPH_BASE + 0x8000UL)
2348#define RAMECC1_BASE (D1_AHB1PERIPH_BASE + 0x9000UL)
2349
2352#define DMA1_BASE (D2_AHB1PERIPH_BASE + 0x0000UL)
2353#define DMA2_BASE (D2_AHB1PERIPH_BASE + 0x0400UL)
2354#define DMAMUX1_BASE (D2_AHB1PERIPH_BASE + 0x0800UL)
2355#define ADC1_BASE (D2_AHB1PERIPH_BASE + 0x2000UL)
2356#define ADC2_BASE (D2_AHB1PERIPH_BASE + 0x2100UL)
2357#define ADC12_COMMON_BASE (D2_AHB1PERIPH_BASE + 0x2300UL)
2358#define ART_BASE (D2_AHB1PERIPH_BASE + 0x4400UL)
2359#define ETH_BASE (D2_AHB1PERIPH_BASE + 0x8000UL)
2360#define ETH_MAC_BASE (ETH_BASE)
2361
2363#define USB1_OTG_HS_PERIPH_BASE (0x40040000UL)
2364#define USB2_OTG_FS_PERIPH_BASE (0x40080000UL)
2365#define USB_OTG_GLOBAL_BASE (0x000UL)
2366#define USB_OTG_DEVICE_BASE (0x800UL)
2367#define USB_OTG_IN_ENDPOINT_BASE (0x900UL)
2368#define USB_OTG_OUT_ENDPOINT_BASE (0xB00UL)
2369#define USB_OTG_EP_REG_SIZE (0x20UL)
2370#define USB_OTG_HOST_BASE (0x400UL)
2371#define USB_OTG_HOST_PORT_BASE (0x440UL)
2372#define USB_OTG_HOST_CHANNEL_BASE (0x500UL)
2373#define USB_OTG_HOST_CHANNEL_SIZE (0x20UL)
2374#define USB_OTG_PCGCCTL_BASE (0xE00UL)
2375#define USB_OTG_FIFO_BASE (0x1000UL)
2376#define USB_OTG_FIFO_SIZE (0x1000UL)
2377
2380#define DCMI_BASE (D2_AHB2PERIPH_BASE + 0x0000UL)
2381#define CRYP_BASE (D2_AHB2PERIPH_BASE + 0x1000UL)
2382#define HASH_BASE (D2_AHB2PERIPH_BASE + 0x1400UL)
2383#define HASH_DIGEST_BASE (D2_AHB2PERIPH_BASE + 0x1710UL)
2384#define RNG_BASE (D2_AHB2PERIPH_BASE + 0x1800UL)
2385#define SDMMC2_BASE (D2_AHB2PERIPH_BASE + 0x2400UL)
2386#define DLYB_SDMMC2_BASE (D2_AHB2PERIPH_BASE + 0x2800UL)
2387#define RAMECC2_BASE (D2_AHB2PERIPH_BASE + 0x3000UL)
2388
2390#define GPIOA_BASE (D3_AHB1PERIPH_BASE + 0x0000UL)
2391#define GPIOB_BASE (D3_AHB1PERIPH_BASE + 0x0400UL)
2392#define GPIOC_BASE (D3_AHB1PERIPH_BASE + 0x0800UL)
2393#define GPIOD_BASE (D3_AHB1PERIPH_BASE + 0x0C00UL)
2394#define GPIOE_BASE (D3_AHB1PERIPH_BASE + 0x1000UL)
2395#define GPIOF_BASE (D3_AHB1PERIPH_BASE + 0x1400UL)
2396#define GPIOG_BASE (D3_AHB1PERIPH_BASE + 0x1800UL)
2397#define GPIOH_BASE (D3_AHB1PERIPH_BASE + 0x1C00UL)
2398#define GPIOI_BASE (D3_AHB1PERIPH_BASE + 0x2000UL)
2399#define GPIOJ_BASE (D3_AHB1PERIPH_BASE + 0x2400UL)
2400#define GPIOK_BASE (D3_AHB1PERIPH_BASE + 0x2800UL)
2401#define RCC_BASE (D3_AHB1PERIPH_BASE + 0x4400UL)
2402#define RCC_C1_BASE (RCC_BASE + 0x130UL)
2403#define RCC_C2_BASE (RCC_BASE + 0x190UL)
2404#define PWR_BASE (D3_AHB1PERIPH_BASE + 0x4800UL)
2405#define CRC_BASE (D3_AHB1PERIPH_BASE + 0x4C00UL)
2406#define BDMA_BASE (D3_AHB1PERIPH_BASE + 0x5400UL)
2407#define DMAMUX2_BASE (D3_AHB1PERIPH_BASE + 0x5800UL)
2408#define ADC3_BASE (D3_AHB1PERIPH_BASE + 0x6000UL)
2409#define ADC3_COMMON_BASE (D3_AHB1PERIPH_BASE + 0x6300UL)
2410#define HSEM_BASE (D3_AHB1PERIPH_BASE + 0x6400UL)
2411#define RAMECC3_BASE (D3_AHB1PERIPH_BASE + 0x7000UL)
2412
2414#define LTDC_BASE (D1_APB1PERIPH_BASE + 0x1000UL)
2415#define LTDC_Layer1_BASE (LTDC_BASE + 0x84UL)
2416#define LTDC_Layer2_BASE (LTDC_BASE + 0x104UL)
2417#define DSI_BASE (D1_APB1PERIPH_BASE)
2418#define WWDG1_BASE (D1_APB1PERIPH_BASE + 0x3000UL)
2419
2421#define TIM2_BASE (D2_APB1PERIPH_BASE + 0x0000UL)
2422#define TIM3_BASE (D2_APB1PERIPH_BASE + 0x0400UL)
2423#define TIM4_BASE (D2_APB1PERIPH_BASE + 0x0800UL)
2424#define TIM5_BASE (D2_APB1PERIPH_BASE + 0x0C00UL)
2425#define TIM6_BASE (D2_APB1PERIPH_BASE + 0x1000UL)
2426#define TIM7_BASE (D2_APB1PERIPH_BASE + 0x1400UL)
2427#define TIM12_BASE (D2_APB1PERIPH_BASE + 0x1800UL)
2428#define TIM13_BASE (D2_APB1PERIPH_BASE + 0x1C00UL)
2429#define TIM14_BASE (D2_APB1PERIPH_BASE + 0x2000UL)
2430#define LPTIM1_BASE (D2_APB1PERIPH_BASE + 0x2400UL)
2431
2432#define WWDG2_BASE (D2_APB1PERIPH_BASE + 0x2C00UL)
2433
2434#define SPI2_BASE (D2_APB1PERIPH_BASE + 0x3800UL)
2435#define SPI3_BASE (D2_APB1PERIPH_BASE + 0x3C00UL)
2436#define SPDIFRX_BASE (D2_APB1PERIPH_BASE + 0x4000UL)
2437#define USART2_BASE (D2_APB1PERIPH_BASE + 0x4400UL)
2438#define USART3_BASE (D2_APB1PERIPH_BASE + 0x4800UL)
2439#define UART4_BASE (D2_APB1PERIPH_BASE + 0x4C00UL)
2440#define UART5_BASE (D2_APB1PERIPH_BASE + 0x5000UL)
2441#define I2C1_BASE (D2_APB1PERIPH_BASE + 0x5400UL)
2442#define I2C2_BASE (D2_APB1PERIPH_BASE + 0x5800UL)
2443#define I2C3_BASE (D2_APB1PERIPH_BASE + 0x5C00UL)
2444#define CEC_BASE (D2_APB1PERIPH_BASE + 0x6C00UL)
2445#define DAC1_BASE (D2_APB1PERIPH_BASE + 0x7400UL)
2446#define UART7_BASE (D2_APB1PERIPH_BASE + 0x7800UL)
2447#define UART8_BASE (D2_APB1PERIPH_BASE + 0x7C00UL)
2448#define CRS_BASE (D2_APB1PERIPH_BASE + 0x8400UL)
2449#define SWPMI1_BASE (D2_APB1PERIPH_BASE + 0x8800UL)
2450#define OPAMP_BASE (D2_APB1PERIPH_BASE + 0x9000UL)
2451#define OPAMP1_BASE (D2_APB1PERIPH_BASE + 0x9000UL)
2452#define OPAMP2_BASE (D2_APB1PERIPH_BASE + 0x9010UL)
2453#define MDIOS_BASE (D2_APB1PERIPH_BASE + 0x9400UL)
2454#define FDCAN1_BASE (D2_APB1PERIPH_BASE + 0xA000UL)
2455#define FDCAN2_BASE (D2_APB1PERIPH_BASE + 0xA400UL)
2456#define FDCAN_CCU_BASE (D2_APB1PERIPH_BASE + 0xA800UL)
2457#define SRAMCAN_BASE (D2_APB1PERIPH_BASE + 0xAC00UL)
2458
2461#define TIM1_BASE (D2_APB2PERIPH_BASE + 0x0000UL)
2462#define TIM8_BASE (D2_APB2PERIPH_BASE + 0x0400UL)
2463#define USART1_BASE (D2_APB2PERIPH_BASE + 0x1000UL)
2464#define USART6_BASE (D2_APB2PERIPH_BASE + 0x1400UL)
2465#define SPI1_BASE (D2_APB2PERIPH_BASE + 0x3000UL)
2466#define SPI4_BASE (D2_APB2PERIPH_BASE + 0x3400UL)
2467#define TIM15_BASE (D2_APB2PERIPH_BASE + 0x4000UL)
2468#define TIM16_BASE (D2_APB2PERIPH_BASE + 0x4400UL)
2469#define TIM17_BASE (D2_APB2PERIPH_BASE + 0x4800UL)
2470#define SPI5_BASE (D2_APB2PERIPH_BASE + 0x5000UL)
2471#define SAI1_BASE (D2_APB2PERIPH_BASE + 0x5800UL)
2472#define SAI1_Block_A_BASE (SAI1_BASE + 0x004UL)
2473#define SAI1_Block_B_BASE (SAI1_BASE + 0x024UL)
2474#define SAI2_BASE (D2_APB2PERIPH_BASE + 0x5C00UL)
2475#define SAI2_Block_A_BASE (SAI2_BASE + 0x004UL)
2476#define SAI2_Block_B_BASE (SAI2_BASE + 0x024UL)
2477#define SAI3_BASE (D2_APB2PERIPH_BASE + 0x6000UL)
2478#define SAI3_Block_A_BASE (SAI3_BASE + 0x004UL)
2479#define SAI3_Block_B_BASE (SAI3_BASE + 0x024UL)
2480#define DFSDM1_BASE (D2_APB2PERIPH_BASE + 0x7000UL)
2481#define DFSDM1_Channel0_BASE (DFSDM1_BASE + 0x00UL)
2482#define DFSDM1_Channel1_BASE (DFSDM1_BASE + 0x20UL)
2483#define DFSDM1_Channel2_BASE (DFSDM1_BASE + 0x40UL)
2484#define DFSDM1_Channel3_BASE (DFSDM1_BASE + 0x60UL)
2485#define DFSDM1_Channel4_BASE (DFSDM1_BASE + 0x80UL)
2486#define DFSDM1_Channel5_BASE (DFSDM1_BASE + 0xA0UL)
2487#define DFSDM1_Channel6_BASE (DFSDM1_BASE + 0xC0UL)
2488#define DFSDM1_Channel7_BASE (DFSDM1_BASE + 0xE0UL)
2489#define DFSDM1_Filter0_BASE (DFSDM1_BASE + 0x100UL)
2490#define DFSDM1_Filter1_BASE (DFSDM1_BASE + 0x180UL)
2491#define DFSDM1_Filter2_BASE (DFSDM1_BASE + 0x200UL)
2492#define DFSDM1_Filter3_BASE (DFSDM1_BASE + 0x280UL)
2493#define HRTIM1_BASE (D2_APB2PERIPH_BASE + 0x7400UL)
2494#define HRTIM1_TIMA_BASE (HRTIM1_BASE + 0x00000080UL)
2495#define HRTIM1_TIMB_BASE (HRTIM1_BASE + 0x00000100UL)
2496#define HRTIM1_TIMC_BASE (HRTIM1_BASE + 0x00000180UL)
2497#define HRTIM1_TIMD_BASE (HRTIM1_BASE + 0x00000200UL)
2498#define HRTIM1_TIME_BASE (HRTIM1_BASE + 0x00000280UL)
2499#define HRTIM1_COMMON_BASE (HRTIM1_BASE + 0x00000380UL)
2500
2501
2503#define EXTI_BASE (D3_APB1PERIPH_BASE + 0x0000UL)
2504#define EXTI_D1_BASE (EXTI_BASE + 0x0080UL)
2505#define EXTI_D2_BASE (EXTI_BASE + 0x00C0UL)
2506#define SYSCFG_BASE (D3_APB1PERIPH_BASE + 0x0400UL)
2507#define LPUART1_BASE (D3_APB1PERIPH_BASE + 0x0C00UL)
2508#define SPI6_BASE (D3_APB1PERIPH_BASE + 0x1400UL)
2509#define I2C4_BASE (D3_APB1PERIPH_BASE + 0x1C00UL)
2510#define LPTIM2_BASE (D3_APB1PERIPH_BASE + 0x2400UL)
2511#define LPTIM3_BASE (D3_APB1PERIPH_BASE + 0x2800UL)
2512#define LPTIM4_BASE (D3_APB1PERIPH_BASE + 0x2C00UL)
2513#define LPTIM5_BASE (D3_APB1PERIPH_BASE + 0x3000UL)
2514#define COMP12_BASE (D3_APB1PERIPH_BASE + 0x3800UL)
2515#define COMP1_BASE (COMP12_BASE + 0x0CUL)
2516#define COMP2_BASE (COMP12_BASE + 0x10UL)
2517#define VREFBUF_BASE (D3_APB1PERIPH_BASE + 0x3C00UL)
2518#define RTC_BASE (D3_APB1PERIPH_BASE + 0x4000UL)
2519#define IWDG1_BASE (D3_APB1PERIPH_BASE + 0x4800UL)
2520
2521#define IWDG2_BASE (D3_APB1PERIPH_BASE + 0x4C00UL)
2522
2523#define SAI4_BASE (D3_APB1PERIPH_BASE + 0x5400UL)
2524#define SAI4_Block_A_BASE (SAI4_BASE + 0x004UL)
2525#define SAI4_Block_B_BASE (SAI4_BASE + 0x024UL)
2526
2527
2528
2529
2530#define BDMA_Channel0_BASE (BDMA_BASE + 0x0008UL)
2531#define BDMA_Channel1_BASE (BDMA_BASE + 0x001CUL)
2532#define BDMA_Channel2_BASE (BDMA_BASE + 0x0030UL)
2533#define BDMA_Channel3_BASE (BDMA_BASE + 0x0044UL)
2534#define BDMA_Channel4_BASE (BDMA_BASE + 0x0058UL)
2535#define BDMA_Channel5_BASE (BDMA_BASE + 0x006CUL)
2536#define BDMA_Channel6_BASE (BDMA_BASE + 0x0080UL)
2537#define BDMA_Channel7_BASE (BDMA_BASE + 0x0094UL)
2538
2539#define DMAMUX2_Channel0_BASE (DMAMUX2_BASE)
2540#define DMAMUX2_Channel1_BASE (DMAMUX2_BASE + 0x0004UL)
2541#define DMAMUX2_Channel2_BASE (DMAMUX2_BASE + 0x0008UL)
2542#define DMAMUX2_Channel3_BASE (DMAMUX2_BASE + 0x000CUL)
2543#define DMAMUX2_Channel4_BASE (DMAMUX2_BASE + 0x0010UL)
2544#define DMAMUX2_Channel5_BASE (DMAMUX2_BASE + 0x0014UL)
2545#define DMAMUX2_Channel6_BASE (DMAMUX2_BASE + 0x0018UL)
2546#define DMAMUX2_Channel7_BASE (DMAMUX2_BASE + 0x001CUL)
2547
2548#define DMAMUX2_RequestGenerator0_BASE (DMAMUX2_BASE + 0x0100UL)
2549#define DMAMUX2_RequestGenerator1_BASE (DMAMUX2_BASE + 0x0104UL)
2550#define DMAMUX2_RequestGenerator2_BASE (DMAMUX2_BASE + 0x0108UL)
2551#define DMAMUX2_RequestGenerator3_BASE (DMAMUX2_BASE + 0x010CUL)
2552#define DMAMUX2_RequestGenerator4_BASE (DMAMUX2_BASE + 0x0110UL)
2553#define DMAMUX2_RequestGenerator5_BASE (DMAMUX2_BASE + 0x0114UL)
2554#define DMAMUX2_RequestGenerator6_BASE (DMAMUX2_BASE + 0x0118UL)
2555#define DMAMUX2_RequestGenerator7_BASE (DMAMUX2_BASE + 0x011CUL)
2556
2557#define DMAMUX2_ChannelStatus_BASE (DMAMUX2_BASE + 0x0080UL)
2558#define DMAMUX2_RequestGenStatus_BASE (DMAMUX2_BASE + 0x0140UL)
2559
2560#define DMA1_Stream0_BASE (DMA1_BASE + 0x010UL)
2561#define DMA1_Stream1_BASE (DMA1_BASE + 0x028UL)
2562#define DMA1_Stream2_BASE (DMA1_BASE + 0x040UL)
2563#define DMA1_Stream3_BASE (DMA1_BASE + 0x058UL)
2564#define DMA1_Stream4_BASE (DMA1_BASE + 0x070UL)
2565#define DMA1_Stream5_BASE (DMA1_BASE + 0x088UL)
2566#define DMA1_Stream6_BASE (DMA1_BASE + 0x0A0UL)
2567#define DMA1_Stream7_BASE (DMA1_BASE + 0x0B8UL)
2568
2569#define DMA2_Stream0_BASE (DMA2_BASE + 0x010UL)
2570#define DMA2_Stream1_BASE (DMA2_BASE + 0x028UL)
2571#define DMA2_Stream2_BASE (DMA2_BASE + 0x040UL)
2572#define DMA2_Stream3_BASE (DMA2_BASE + 0x058UL)
2573#define DMA2_Stream4_BASE (DMA2_BASE + 0x070UL)
2574#define DMA2_Stream5_BASE (DMA2_BASE + 0x088UL)
2575#define DMA2_Stream6_BASE (DMA2_BASE + 0x0A0UL)
2576#define DMA2_Stream7_BASE (DMA2_BASE + 0x0B8UL)
2577
2578#define DMAMUX1_Channel0_BASE (DMAMUX1_BASE)
2579#define DMAMUX1_Channel1_BASE (DMAMUX1_BASE + 0x0004UL)
2580#define DMAMUX1_Channel2_BASE (DMAMUX1_BASE + 0x0008UL)
2581#define DMAMUX1_Channel3_BASE (DMAMUX1_BASE + 0x000CUL)
2582#define DMAMUX1_Channel4_BASE (DMAMUX1_BASE + 0x0010UL)
2583#define DMAMUX1_Channel5_BASE (DMAMUX1_BASE + 0x0014UL)
2584#define DMAMUX1_Channel6_BASE (DMAMUX1_BASE + 0x0018UL)
2585#define DMAMUX1_Channel7_BASE (DMAMUX1_BASE + 0x001CUL)
2586#define DMAMUX1_Channel8_BASE (DMAMUX1_BASE + 0x0020UL)
2587#define DMAMUX1_Channel9_BASE (DMAMUX1_BASE + 0x0024UL)
2588#define DMAMUX1_Channel10_BASE (DMAMUX1_BASE + 0x0028UL)
2589#define DMAMUX1_Channel11_BASE (DMAMUX1_BASE + 0x002CUL)
2590#define DMAMUX1_Channel12_BASE (DMAMUX1_BASE + 0x0030UL)
2591#define DMAMUX1_Channel13_BASE (DMAMUX1_BASE + 0x0034UL)
2592#define DMAMUX1_Channel14_BASE (DMAMUX1_BASE + 0x0038UL)
2593#define DMAMUX1_Channel15_BASE (DMAMUX1_BASE + 0x003CUL)
2594
2595#define DMAMUX1_RequestGenerator0_BASE (DMAMUX1_BASE + 0x0100UL)
2596#define DMAMUX1_RequestGenerator1_BASE (DMAMUX1_BASE + 0x0104UL)
2597#define DMAMUX1_RequestGenerator2_BASE (DMAMUX1_BASE + 0x0108UL)
2598#define DMAMUX1_RequestGenerator3_BASE (DMAMUX1_BASE + 0x010CUL)
2599#define DMAMUX1_RequestGenerator4_BASE (DMAMUX1_BASE + 0x0110UL)
2600#define DMAMUX1_RequestGenerator5_BASE (DMAMUX1_BASE + 0x0114UL)
2601#define DMAMUX1_RequestGenerator6_BASE (DMAMUX1_BASE + 0x0118UL)
2602#define DMAMUX1_RequestGenerator7_BASE (DMAMUX1_BASE + 0x011CUL)
2603
2604#define DMAMUX1_ChannelStatus_BASE (DMAMUX1_BASE + 0x0080UL)
2605#define DMAMUX1_RequestGenStatus_BASE (DMAMUX1_BASE + 0x0140UL)
2606
2608#define FMC_Bank1_R_BASE (FMC_R_BASE + 0x0000UL)
2609#define FMC_Bank1E_R_BASE (FMC_R_BASE + 0x0104UL)
2610#define FMC_Bank2_R_BASE (FMC_R_BASE + 0x0060UL)
2611#define FMC_Bank3_R_BASE (FMC_R_BASE + 0x0080UL)
2612#define FMC_Bank5_6_R_BASE (FMC_R_BASE + 0x0140UL)
2613
2614/* Debug MCU registers base address */
2615#define DBGMCU_BASE (0x5C001000UL)
2616
2617#define MDMA_Channel0_BASE (MDMA_BASE + 0x00000040UL)
2618#define MDMA_Channel1_BASE (MDMA_BASE + 0x00000080UL)
2619#define MDMA_Channel2_BASE (MDMA_BASE + 0x000000C0UL)
2620#define MDMA_Channel3_BASE (MDMA_BASE + 0x00000100UL)
2621#define MDMA_Channel4_BASE (MDMA_BASE + 0x00000140UL)
2622#define MDMA_Channel5_BASE (MDMA_BASE + 0x00000180UL)
2623#define MDMA_Channel6_BASE (MDMA_BASE + 0x000001C0UL)
2624#define MDMA_Channel7_BASE (MDMA_BASE + 0x00000200UL)
2625#define MDMA_Channel8_BASE (MDMA_BASE + 0x00000240UL)
2626#define MDMA_Channel9_BASE (MDMA_BASE + 0x00000280UL)
2627#define MDMA_Channel10_BASE (MDMA_BASE + 0x000002C0UL)
2628#define MDMA_Channel11_BASE (MDMA_BASE + 0x00000300UL)
2629#define MDMA_Channel12_BASE (MDMA_BASE + 0x00000340UL)
2630#define MDMA_Channel13_BASE (MDMA_BASE + 0x00000380UL)
2631#define MDMA_Channel14_BASE (MDMA_BASE + 0x000003C0UL)
2632#define MDMA_Channel15_BASE (MDMA_BASE + 0x00000400UL)
2633
2634#define RAMECC1_Monitor1_BASE (RAMECC1_BASE + 0x20UL)
2635#define RAMECC1_Monitor2_BASE (RAMECC1_BASE + 0x40UL)
2636#define RAMECC1_Monitor3_BASE (RAMECC1_BASE + 0x60UL)
2637#define RAMECC1_Monitor4_BASE (RAMECC1_BASE + 0x80UL)
2638#define RAMECC1_Monitor5_BASE (RAMECC1_BASE + 0xA0UL)
2639
2640#define RAMECC2_Monitor1_BASE (RAMECC2_BASE + 0x20UL)
2641#define RAMECC2_Monitor2_BASE (RAMECC2_BASE + 0x40UL)
2642#define RAMECC2_Monitor3_BASE (RAMECC2_BASE + 0x60UL)
2643#define RAMECC2_Monitor4_BASE (RAMECC2_BASE + 0x80UL)
2644#define RAMECC2_Monitor5_BASE (RAMECC2_BASE + 0xA0UL)
2645
2646#define RAMECC3_Monitor1_BASE (RAMECC3_BASE + 0x20UL)
2647#define RAMECC3_Monitor2_BASE (RAMECC3_BASE + 0x40UL)
2648
2649
2650
2651#define GPV_BASE (PERIPH_BASE + 0x11000000UL)
2660#define TIM2 ((TIM_TypeDef *) TIM2_BASE)
2661#define TIM3 ((TIM_TypeDef *) TIM3_BASE)
2662#define TIM4 ((TIM_TypeDef *) TIM4_BASE)
2663#define TIM5 ((TIM_TypeDef *) TIM5_BASE)
2664#define TIM6 ((TIM_TypeDef *) TIM6_BASE)
2665#define TIM7 ((TIM_TypeDef *) TIM7_BASE)
2666#define TIM13 ((TIM_TypeDef *) TIM13_BASE)
2667#define TIM14 ((TIM_TypeDef *) TIM14_BASE)
2668#define VREFBUF ((VREFBUF_TypeDef *) VREFBUF_BASE)
2669#define RTC ((RTC_TypeDef *) RTC_BASE)
2670#define WWDG1 ((WWDG_TypeDef *) WWDG1_BASE)
2671
2672#define WWDG2 ((WWDG_TypeDef *) WWDG2_BASE)
2673#define IWDG2 ((IWDG_TypeDef *) IWDG2_BASE)
2674
2675#define IWDG1 ((IWDG_TypeDef *) IWDG1_BASE)
2676#define SPI2 ((SPI_TypeDef *) SPI2_BASE)
2677#define SPI3 ((SPI_TypeDef *) SPI3_BASE)
2678#define SPI4 ((SPI_TypeDef *) SPI4_BASE)
2679#define SPI5 ((SPI_TypeDef *) SPI5_BASE)
2680#define SPI6 ((SPI_TypeDef *) SPI6_BASE)
2681#define USART2 ((USART_TypeDef *) USART2_BASE)
2682#define USART3 ((USART_TypeDef *) USART3_BASE)
2683#define USART6 ((USART_TypeDef *) USART6_BASE)
2684#define UART7 ((USART_TypeDef *) UART7_BASE)
2685#define UART8 ((USART_TypeDef *) UART8_BASE)
2686#define CRS ((CRS_TypeDef *) CRS_BASE)
2687#define UART4 ((USART_TypeDef *) UART4_BASE)
2688#define UART5 ((USART_TypeDef *) UART5_BASE)
2689#define I2C1 ((I2C_TypeDef *) I2C1_BASE)
2690#define I2C2 ((I2C_TypeDef *) I2C2_BASE)
2691#define I2C3 ((I2C_TypeDef *) I2C3_BASE)
2692#define I2C4 ((I2C_TypeDef *) I2C4_BASE)
2693#define FDCAN1 ((FDCAN_GlobalTypeDef *) FDCAN1_BASE)
2694#define FDCAN2 ((FDCAN_GlobalTypeDef *) FDCAN2_BASE)
2695#define FDCAN_CCU ((FDCAN_ClockCalibrationUnit_TypeDef *) FDCAN_CCU_BASE)
2696#define CEC ((CEC_TypeDef *) CEC_BASE)
2697#define LPTIM1 ((LPTIM_TypeDef *) LPTIM1_BASE)
2698#define PWR ((PWR_TypeDef *) PWR_BASE)
2699#define DAC1 ((DAC_TypeDef *) DAC1_BASE)
2700#define LPUART1 ((USART_TypeDef *) LPUART1_BASE)
2701#define SWPMI1 ((SWPMI_TypeDef *) SWPMI1_BASE)
2702#define LPTIM2 ((LPTIM_TypeDef *) LPTIM2_BASE)
2703#define LPTIM3 ((LPTIM_TypeDef *) LPTIM3_BASE)
2704#define LPTIM4 ((LPTIM_TypeDef *) LPTIM4_BASE)
2705#define LPTIM5 ((LPTIM_TypeDef *) LPTIM5_BASE)
2706
2707#define SYSCFG ((SYSCFG_TypeDef *) SYSCFG_BASE)
2708#define COMP12 ((COMPOPT_TypeDef *) COMP12_BASE)
2709#define COMP1 ((COMP_TypeDef *) COMP1_BASE)
2710#define COMP2 ((COMP_TypeDef *) COMP2_BASE)
2711#define COMP12_COMMON ((COMP_Common_TypeDef *) COMP2_BASE)
2712#define OPAMP ((OPAMP_TypeDef *) OPAMP_BASE)
2713#define OPAMP1 ((OPAMP_TypeDef *) OPAMP1_BASE)
2714#define OPAMP2 ((OPAMP_TypeDef *) OPAMP2_BASE)
2715
2716
2717#define EXTI ((EXTI_TypeDef *) EXTI_BASE)
2718#define EXTI_D1 ((EXTI_Core_TypeDef *) EXTI_D1_BASE)
2719#define EXTI_D2 ((EXTI_Core_TypeDef *) EXTI_D2_BASE)
2720#define TIM1 ((TIM_TypeDef *) TIM1_BASE)
2721#define SPI1 ((SPI_TypeDef *) SPI1_BASE)
2722#define TIM8 ((TIM_TypeDef *) TIM8_BASE)
2723#define USART1 ((USART_TypeDef *) USART1_BASE)
2724#define TIM12 ((TIM_TypeDef *) TIM12_BASE)
2725#define TIM15 ((TIM_TypeDef *) TIM15_BASE)
2726#define TIM16 ((TIM_TypeDef *) TIM16_BASE)
2727#define TIM17 ((TIM_TypeDef *) TIM17_BASE)
2728#define HRTIM1 ((HRTIM_TypeDef *) HRTIM1_BASE)
2729#define HRTIM1_TIMA ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMA_BASE)
2730#define HRTIM1_TIMB ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMB_BASE)
2731#define HRTIM1_TIMC ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMC_BASE)
2732#define HRTIM1_TIMD ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMD_BASE)
2733#define HRTIM1_TIME ((HRTIM_Timerx_TypeDef *) HRTIM1_TIME_BASE)
2734#define HRTIM1_COMMON ((HRTIM_Common_TypeDef *) HRTIM1_COMMON_BASE)
2735#define SAI1 ((SAI_TypeDef *) SAI1_BASE)
2736#define SAI1_Block_A ((SAI_Block_TypeDef *)SAI1_Block_A_BASE)
2737#define SAI1_Block_B ((SAI_Block_TypeDef *)SAI1_Block_B_BASE)
2738#define SAI2 ((SAI_TypeDef *) SAI2_BASE)
2739#define SAI2_Block_A ((SAI_Block_TypeDef *)SAI2_Block_A_BASE)
2740#define SAI2_Block_B ((SAI_Block_TypeDef *)SAI2_Block_B_BASE)
2741#define SAI3 ((SAI_TypeDef *) SAI3_BASE)
2742#define SAI3_Block_A ((SAI_Block_TypeDef *)SAI3_Block_A_BASE)
2743#define SAI3_Block_B ((SAI_Block_TypeDef *)SAI3_Block_B_BASE)
2744#define SAI4 ((SAI_TypeDef *) SAI4_BASE)
2745#define SAI4_Block_A ((SAI_Block_TypeDef *)SAI4_Block_A_BASE)
2746#define SAI4_Block_B ((SAI_Block_TypeDef *)SAI4_Block_B_BASE)
2747
2748#define SPDIFRX ((SPDIFRX_TypeDef *) SPDIFRX_BASE)
2749#define DFSDM1_Channel0 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel0_BASE)
2750#define DFSDM1_Channel1 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel1_BASE)
2751#define DFSDM1_Channel2 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel2_BASE)
2752#define DFSDM1_Channel3 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel3_BASE)
2753#define DFSDM1_Channel4 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel4_BASE)
2754#define DFSDM1_Channel5 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel5_BASE)
2755#define DFSDM1_Channel6 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel6_BASE)
2756#define DFSDM1_Channel7 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel7_BASE)
2757#define DFSDM1_Filter0 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter0_BASE)
2758#define DFSDM1_Filter1 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter1_BASE)
2759#define DFSDM1_Filter2 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter2_BASE)
2760#define DFSDM1_Filter3 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter3_BASE)
2761#define DMA2D ((DMA2D_TypeDef *) DMA2D_BASE)
2762#define DCMI ((DCMI_TypeDef *) DCMI_BASE)
2763#define RCC ((RCC_TypeDef *) RCC_BASE)
2764#define RCC_C1 ((RCC_Core_TypeDef *) RCC_C1_BASE)
2765#define RCC_C2 ((RCC_Core_TypeDef *) RCC_C2_BASE)
2766
2767#define ART ((ART_TypeDef *) ART_BASE)
2768#define FLASH ((FLASH_TypeDef *) FLASH_R_BASE)
2769#define CRC ((CRC_TypeDef *) CRC_BASE)
2770
2771#define GPIOA ((GPIO_TypeDef *) GPIOA_BASE)
2772#define GPIOB ((GPIO_TypeDef *) GPIOB_BASE)
2773#define GPIOC ((GPIO_TypeDef *) GPIOC_BASE)
2774#define GPIOD ((GPIO_TypeDef *) GPIOD_BASE)
2775#define GPIOE ((GPIO_TypeDef *) GPIOE_BASE)
2776#define GPIOF ((GPIO_TypeDef *) GPIOF_BASE)
2777#define GPIOG ((GPIO_TypeDef *) GPIOG_BASE)
2778#define GPIOH ((GPIO_TypeDef *) GPIOH_BASE)
2779#define GPIOI ((GPIO_TypeDef *) GPIOI_BASE)
2780#define GPIOJ ((GPIO_TypeDef *) GPIOJ_BASE)
2781#define GPIOK ((GPIO_TypeDef *) GPIOK_BASE)
2782
2783#define ADC1 ((ADC_TypeDef *) ADC1_BASE)
2784#define ADC2 ((ADC_TypeDef *) ADC2_BASE)
2785#define ADC3 ((ADC_TypeDef *) ADC3_BASE)
2786#define ADC3_COMMON ((ADC_Common_TypeDef *) ADC3_COMMON_BASE)
2787#define ADC12_COMMON ((ADC_Common_TypeDef *) ADC12_COMMON_BASE)
2788
2789#define CRYP ((CRYP_TypeDef *) CRYP_BASE)
2790#define HASH ((HASH_TypeDef *) HASH_BASE)
2791#define HASH_DIGEST ((HASH_DIGEST_TypeDef *) HASH_DIGEST_BASE)
2792#define RNG ((RNG_TypeDef *) RNG_BASE)
2793#define SDMMC2 ((SDMMC_TypeDef *) SDMMC2_BASE)
2794#define DLYB_SDMMC2 ((DLYB_TypeDef *) DLYB_SDMMC2_BASE)
2795
2796#define BDMA ((BDMA_TypeDef *) BDMA_BASE)
2797#define BDMA_Channel0 ((BDMA_Channel_TypeDef *) BDMA_Channel0_BASE)
2798#define BDMA_Channel1 ((BDMA_Channel_TypeDef *) BDMA_Channel1_BASE)
2799#define BDMA_Channel2 ((BDMA_Channel_TypeDef *) BDMA_Channel2_BASE)
2800#define BDMA_Channel3 ((BDMA_Channel_TypeDef *) BDMA_Channel3_BASE)
2801#define BDMA_Channel4 ((BDMA_Channel_TypeDef *) BDMA_Channel4_BASE)
2802#define BDMA_Channel5 ((BDMA_Channel_TypeDef *) BDMA_Channel5_BASE)
2803#define BDMA_Channel6 ((BDMA_Channel_TypeDef *) BDMA_Channel6_BASE)
2804#define BDMA_Channel7 ((BDMA_Channel_TypeDef *) BDMA_Channel7_BASE)
2805
2806#define RAMECC1 ((RAMECC_TypeDef *)RAMECC1_BASE)
2807#define RAMECC1_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor1_BASE)
2808#define RAMECC1_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor2_BASE)
2809#define RAMECC1_Monitor3 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor3_BASE)
2810#define RAMECC1_Monitor4 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor4_BASE)
2811#define RAMECC1_Monitor5 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor5_BASE)
2812
2813#define RAMECC2 ((RAMECC_TypeDef *)RAMECC2_BASE)
2814#define RAMECC2_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor1_BASE)
2815#define RAMECC2_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor2_BASE)
2816#define RAMECC2_Monitor3 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor3_BASE)
2817#define RAMECC2_Monitor4 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor4_BASE)
2818#define RAMECC2_Monitor5 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor5_BASE)
2819
2820#define RAMECC3 ((RAMECC_TypeDef *)RAMECC3_BASE)
2821#define RAMECC3_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC3_Monitor1_BASE)
2822#define RAMECC3_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC3_Monitor2_BASE)
2823
2824#define DMAMUX2 ((DMAMUX_Channel_TypeDef *) DMAMUX2_BASE)
2825#define DMAMUX2_Channel0 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel0_BASE)
2826#define DMAMUX2_Channel1 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel1_BASE)
2827#define DMAMUX2_Channel2 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel2_BASE)
2828#define DMAMUX2_Channel3 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel3_BASE)
2829#define DMAMUX2_Channel4 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel4_BASE)
2830#define DMAMUX2_Channel5 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel5_BASE)
2831#define DMAMUX2_Channel6 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel6_BASE)
2832#define DMAMUX2_Channel7 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel7_BASE)
2833
2834
2835#define DMAMUX2_RequestGenerator0 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator0_BASE)
2836#define DMAMUX2_RequestGenerator1 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator1_BASE)
2837#define DMAMUX2_RequestGenerator2 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator2_BASE)
2838#define DMAMUX2_RequestGenerator3 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator3_BASE)
2839#define DMAMUX2_RequestGenerator4 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator4_BASE)
2840#define DMAMUX2_RequestGenerator5 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator5_BASE)
2841#define DMAMUX2_RequestGenerator6 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator6_BASE)
2842#define DMAMUX2_RequestGenerator7 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator7_BASE)
2843
2844#define DMAMUX2_ChannelStatus ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX2_ChannelStatus_BASE)
2845#define DMAMUX2_RequestGenStatus ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX2_RequestGenStatus_BASE)
2846
2847#define DMA2 ((DMA_TypeDef *) DMA2_BASE)
2848#define DMA2_Stream0 ((DMA_Stream_TypeDef *) DMA2_Stream0_BASE)
2849#define DMA2_Stream1 ((DMA_Stream_TypeDef *) DMA2_Stream1_BASE)
2850#define DMA2_Stream2 ((DMA_Stream_TypeDef *) DMA2_Stream2_BASE)
2851#define DMA2_Stream3 ((DMA_Stream_TypeDef *) DMA2_Stream3_BASE)
2852#define DMA2_Stream4 ((DMA_Stream_TypeDef *) DMA2_Stream4_BASE)
2853#define DMA2_Stream5 ((DMA_Stream_TypeDef *) DMA2_Stream5_BASE)
2854#define DMA2_Stream6 ((DMA_Stream_TypeDef *) DMA2_Stream6_BASE)
2855#define DMA2_Stream7 ((DMA_Stream_TypeDef *) DMA2_Stream7_BASE)
2856
2857#define DMA1 ((DMA_TypeDef *) DMA1_BASE)
2858#define DMA1_Stream0 ((DMA_Stream_TypeDef *) DMA1_Stream0_BASE)
2859#define DMA1_Stream1 ((DMA_Stream_TypeDef *) DMA1_Stream1_BASE)
2860#define DMA1_Stream2 ((DMA_Stream_TypeDef *) DMA1_Stream2_BASE)
2861#define DMA1_Stream3 ((DMA_Stream_TypeDef *) DMA1_Stream3_BASE)
2862#define DMA1_Stream4 ((DMA_Stream_TypeDef *) DMA1_Stream4_BASE)
2863#define DMA1_Stream5 ((DMA_Stream_TypeDef *) DMA1_Stream5_BASE)
2864#define DMA1_Stream6 ((DMA_Stream_TypeDef *) DMA1_Stream6_BASE)
2865#define DMA1_Stream7 ((DMA_Stream_TypeDef *) DMA1_Stream7_BASE)
2866
2867
2868#define DMAMUX1 ((DMAMUX_Channel_TypeDef *) DMAMUX1_BASE)
2869#define DMAMUX1_Channel0 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel0_BASE)
2870#define DMAMUX1_Channel1 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel1_BASE)
2871#define DMAMUX1_Channel2 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel2_BASE)
2872#define DMAMUX1_Channel3 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel3_BASE)
2873#define DMAMUX1_Channel4 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel4_BASE)
2874#define DMAMUX1_Channel5 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel5_BASE)
2875#define DMAMUX1_Channel6 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel6_BASE)
2876#define DMAMUX1_Channel7 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel7_BASE)
2877#define DMAMUX1_Channel8 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel8_BASE)
2878#define DMAMUX1_Channel9 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel9_BASE)
2879#define DMAMUX1_Channel10 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel10_BASE)
2880#define DMAMUX1_Channel11 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel11_BASE)
2881#define DMAMUX1_Channel12 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel12_BASE)
2882#define DMAMUX1_Channel13 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel13_BASE)
2883#define DMAMUX1_Channel14 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel14_BASE)
2884#define DMAMUX1_Channel15 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel15_BASE)
2885
2886#define DMAMUX1_RequestGenerator0 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator0_BASE)
2887#define DMAMUX1_RequestGenerator1 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator1_BASE)
2888#define DMAMUX1_RequestGenerator2 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator2_BASE)
2889#define DMAMUX1_RequestGenerator3 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator3_BASE)
2890#define DMAMUX1_RequestGenerator4 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator4_BASE)
2891#define DMAMUX1_RequestGenerator5 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator5_BASE)
2892#define DMAMUX1_RequestGenerator6 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator6_BASE)
2893#define DMAMUX1_RequestGenerator7 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator7_BASE)
2894
2895#define DMAMUX1_ChannelStatus ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX1_ChannelStatus_BASE)
2896#define DMAMUX1_RequestGenStatus ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX1_RequestGenStatus_BASE)
2897
2898
2899#define FMC_Bank1_R ((FMC_Bank1_TypeDef *) FMC_Bank1_R_BASE)
2900#define FMC_Bank1E_R ((FMC_Bank1E_TypeDef *) FMC_Bank1E_R_BASE)
2901#define FMC_Bank2_R ((FMC_Bank2_TypeDef *) FMC_Bank2_R_BASE)
2902#define FMC_Bank3_R ((FMC_Bank3_TypeDef *) FMC_Bank3_R_BASE)
2903#define FMC_Bank5_6_R ((FMC_Bank5_6_TypeDef *) FMC_Bank5_6_R_BASE)
2904
2905
2906#define QUADSPI ((QUADSPI_TypeDef *) QSPI_R_BASE)
2907#define DLYB_QUADSPI ((DLYB_TypeDef *) DLYB_QSPI_BASE)
2908#define SDMMC1 ((SDMMC_TypeDef *) SDMMC1_BASE)
2909#define DLYB_SDMMC1 ((DLYB_TypeDef *) DLYB_SDMMC1_BASE)
2910
2911#define DBGMCU ((DBGMCU_TypeDef *) DBGMCU_BASE)
2912
2913#define JPEG ((JPEG_TypeDef *) JPGDEC_BASE)
2914#define HSEM ((HSEM_TypeDef *) HSEM_BASE)
2915#if defined(CORE_CM4)
2916#define HSEM_COMMON ((HSEM_Common_TypeDef *) (HSEM_BASE + 0x110UL))
2917#else /* CORE_CM7 */
2918#define HSEM_COMMON ((HSEM_Common_TypeDef *) (HSEM_BASE + 0x100UL))
2919#endif /* CORE_CM4 */
2920
2921#define LTDC ((LTDC_TypeDef *)LTDC_BASE)
2922#define LTDC_Layer1 ((LTDC_Layer_TypeDef *)LTDC_Layer1_BASE)
2923#define LTDC_Layer2 ((LTDC_Layer_TypeDef *)LTDC_Layer2_BASE)
2924#define DSI ((DSI_TypeDef *)DSI_BASE)
2925
2926#define MDIOS ((MDIOS_TypeDef *) MDIOS_BASE)
2927
2928#define ETH ((ETH_TypeDef *)ETH_BASE)
2929#define MDMA ((MDMA_TypeDef *)MDMA_BASE)
2930#define MDMA_Channel0 ((MDMA_Channel_TypeDef *)MDMA_Channel0_BASE)
2931#define MDMA_Channel1 ((MDMA_Channel_TypeDef *)MDMA_Channel1_BASE)
2932#define MDMA_Channel2 ((MDMA_Channel_TypeDef *)MDMA_Channel2_BASE)
2933#define MDMA_Channel3 ((MDMA_Channel_TypeDef *)MDMA_Channel3_BASE)
2934#define MDMA_Channel4 ((MDMA_Channel_TypeDef *)MDMA_Channel4_BASE)
2935#define MDMA_Channel5 ((MDMA_Channel_TypeDef *)MDMA_Channel5_BASE)
2936#define MDMA_Channel6 ((MDMA_Channel_TypeDef *)MDMA_Channel6_BASE)
2937#define MDMA_Channel7 ((MDMA_Channel_TypeDef *)MDMA_Channel7_BASE)
2938#define MDMA_Channel8 ((MDMA_Channel_TypeDef *)MDMA_Channel8_BASE)
2939#define MDMA_Channel9 ((MDMA_Channel_TypeDef *)MDMA_Channel9_BASE)
2940#define MDMA_Channel10 ((MDMA_Channel_TypeDef *)MDMA_Channel10_BASE)
2941#define MDMA_Channel11 ((MDMA_Channel_TypeDef *)MDMA_Channel11_BASE)
2942#define MDMA_Channel12 ((MDMA_Channel_TypeDef *)MDMA_Channel12_BASE)
2943#define MDMA_Channel13 ((MDMA_Channel_TypeDef *)MDMA_Channel13_BASE)
2944#define MDMA_Channel14 ((MDMA_Channel_TypeDef *)MDMA_Channel14_BASE)
2945#define MDMA_Channel15 ((MDMA_Channel_TypeDef *)MDMA_Channel15_BASE)
2946
2947
2948#define USB1_OTG_HS ((USB_OTG_GlobalTypeDef *) USB1_OTG_HS_PERIPH_BASE)
2949#define USB2_OTG_FS ((USB_OTG_GlobalTypeDef *) USB2_OTG_FS_PERIPH_BASE)
2950
2951/* Legacy defines */
2952#define USB_OTG_HS USB1_OTG_HS
2953#define USB_OTG_HS_PERIPH_BASE USB1_OTG_HS_PERIPH_BASE
2954#define USB_OTG_FS USB2_OTG_FS
2955#define USB_OTG_FS_PERIPH_BASE USB2_OTG_FS_PERIPH_BASE
2956
2957#define GPV ((GPV_TypeDef *) GPV_BASE)
2958
2970#define LSI_STARTUP_TIME 130U
2980/******************************************************************************/
2981/* Peripheral Registers_Bits_Definition */
2982/******************************************************************************/
2983
2984/******************************************************************************/
2985/* */
2986/* Analog to Digital Converter */
2987/* */
2988/******************************************************************************/
2989/******************************* ADC VERSION ********************************/
2990#define ADC_VER_V5_X
2991/******************** Bit definition for ADC_ISR register ********************/
2992#define ADC_ISR_ADRDY_Pos (0U)
2993#define ADC_ISR_ADRDY_Msk (0x1UL << ADC_ISR_ADRDY_Pos)
2994#define ADC_ISR_ADRDY ADC_ISR_ADRDY_Msk
2995#define ADC_ISR_EOSMP_Pos (1U)
2996#define ADC_ISR_EOSMP_Msk (0x1UL << ADC_ISR_EOSMP_Pos)
2997#define ADC_ISR_EOSMP ADC_ISR_EOSMP_Msk
2998#define ADC_ISR_EOC_Pos (2U)
2999#define ADC_ISR_EOC_Msk (0x1UL << ADC_ISR_EOC_Pos)
3000#define ADC_ISR_EOC ADC_ISR_EOC_Msk
3001#define ADC_ISR_EOS_Pos (3U)
3002#define ADC_ISR_EOS_Msk (0x1UL << ADC_ISR_EOS_Pos)
3003#define ADC_ISR_EOS ADC_ISR_EOS_Msk
3004#define ADC_ISR_OVR_Pos (4U)
3005#define ADC_ISR_OVR_Msk (0x1UL << ADC_ISR_OVR_Pos)
3006#define ADC_ISR_OVR ADC_ISR_OVR_Msk
3007#define ADC_ISR_JEOC_Pos (5U)
3008#define ADC_ISR_JEOC_Msk (0x1UL << ADC_ISR_JEOC_Pos)
3009#define ADC_ISR_JEOC ADC_ISR_JEOC_Msk
3010#define ADC_ISR_JEOS_Pos (6U)
3011#define ADC_ISR_JEOS_Msk (0x1UL << ADC_ISR_JEOS_Pos)
3012#define ADC_ISR_JEOS ADC_ISR_JEOS_Msk
3013#define ADC_ISR_AWD1_Pos (7U)
3014#define ADC_ISR_AWD1_Msk (0x1UL << ADC_ISR_AWD1_Pos)
3015#define ADC_ISR_AWD1 ADC_ISR_AWD1_Msk
3016#define ADC_ISR_AWD2_Pos (8U)
3017#define ADC_ISR_AWD2_Msk (0x1UL << ADC_ISR_AWD2_Pos)
3018#define ADC_ISR_AWD2 ADC_ISR_AWD2_Msk
3019#define ADC_ISR_AWD3_Pos (9U)
3020#define ADC_ISR_AWD3_Msk (0x1UL << ADC_ISR_AWD3_Pos)
3021#define ADC_ISR_AWD3 ADC_ISR_AWD3_Msk
3022#define ADC_ISR_JQOVF_Pos (10U)
3023#define ADC_ISR_JQOVF_Msk (0x1UL << ADC_ISR_JQOVF_Pos)
3024#define ADC_ISR_JQOVF ADC_ISR_JQOVF_Msk
3025#define ADC_ISR_LDORDY_Pos (12U)
3026#define ADC_ISR_LDORDY_Msk (0x1UL << ADC_ISR_LDORDY_Pos)
3027#define ADC_ISR_LDORDY ADC_ISR_LDORDY_Msk
3029/******************** Bit definition for ADC_IER register ********************/
3030#define ADC_IER_ADRDYIE_Pos (0U)
3031#define ADC_IER_ADRDYIE_Msk (0x1UL << ADC_IER_ADRDYIE_Pos)
3032#define ADC_IER_ADRDYIE ADC_IER_ADRDYIE_Msk
3033#define ADC_IER_EOSMPIE_Pos (1U)
3034#define ADC_IER_EOSMPIE_Msk (0x1UL << ADC_IER_EOSMPIE_Pos)
3035#define ADC_IER_EOSMPIE ADC_IER_EOSMPIE_Msk
3036#define ADC_IER_EOCIE_Pos (2U)
3037#define ADC_IER_EOCIE_Msk (0x1UL << ADC_IER_EOCIE_Pos)
3038#define ADC_IER_EOCIE ADC_IER_EOCIE_Msk
3039#define ADC_IER_EOSIE_Pos (3U)
3040#define ADC_IER_EOSIE_Msk (0x1UL << ADC_IER_EOSIE_Pos)
3041#define ADC_IER_EOSIE ADC_IER_EOSIE_Msk
3042#define ADC_IER_OVRIE_Pos (4U)
3043#define ADC_IER_OVRIE_Msk (0x1UL << ADC_IER_OVRIE_Pos)
3044#define ADC_IER_OVRIE ADC_IER_OVRIE_Msk
3045#define ADC_IER_JEOCIE_Pos (5U)
3046#define ADC_IER_JEOCIE_Msk (0x1UL << ADC_IER_JEOCIE_Pos)
3047#define ADC_IER_JEOCIE ADC_IER_JEOCIE_Msk
3048#define ADC_IER_JEOSIE_Pos (6U)
3049#define ADC_IER_JEOSIE_Msk (0x1UL << ADC_IER_JEOSIE_Pos)
3050#define ADC_IER_JEOSIE ADC_IER_JEOSIE_Msk
3051#define ADC_IER_AWD1IE_Pos (7U)
3052#define ADC_IER_AWD1IE_Msk (0x1UL << ADC_IER_AWD1IE_Pos)
3053#define ADC_IER_AWD1IE ADC_IER_AWD1IE_Msk
3054#define ADC_IER_AWD2IE_Pos (8U)
3055#define ADC_IER_AWD2IE_Msk (0x1UL << ADC_IER_AWD2IE_Pos)
3056#define ADC_IER_AWD2IE ADC_IER_AWD2IE_Msk
3057#define ADC_IER_AWD3IE_Pos (9U)
3058#define ADC_IER_AWD3IE_Msk (0x1UL << ADC_IER_AWD3IE_Pos)
3059#define ADC_IER_AWD3IE ADC_IER_AWD3IE_Msk
3060#define ADC_IER_JQOVFIE_Pos (10U)
3061#define ADC_IER_JQOVFIE_Msk (0x1UL << ADC_IER_JQOVFIE_Pos)
3062#define ADC_IER_JQOVFIE ADC_IER_JQOVFIE_Msk
3064/******************** Bit definition for ADC_CR register ********************/
3065#define ADC_CR_ADEN_Pos (0U)
3066#define ADC_CR_ADEN_Msk (0x1UL << ADC_CR_ADEN_Pos)
3067#define ADC_CR_ADEN ADC_CR_ADEN_Msk
3068#define ADC_CR_ADDIS_Pos (1U)
3069#define ADC_CR_ADDIS_Msk (0x1UL << ADC_CR_ADDIS_Pos)
3070#define ADC_CR_ADDIS ADC_CR_ADDIS_Msk
3071#define ADC_CR_ADSTART_Pos (2U)
3072#define ADC_CR_ADSTART_Msk (0x1UL << ADC_CR_ADSTART_Pos)
3073#define ADC_CR_ADSTART ADC_CR_ADSTART_Msk
3074#define ADC_CR_JADSTART_Pos (3U)
3075#define ADC_CR_JADSTART_Msk (0x1UL << ADC_CR_JADSTART_Pos)
3076#define ADC_CR_JADSTART ADC_CR_JADSTART_Msk
3077#define ADC_CR_ADSTP_Pos (4U)
3078#define ADC_CR_ADSTP_Msk (0x1UL << ADC_CR_ADSTP_Pos)
3079#define ADC_CR_ADSTP ADC_CR_ADSTP_Msk
3080#define ADC_CR_JADSTP_Pos (5U)
3081#define ADC_CR_JADSTP_Msk (0x1UL << ADC_CR_JADSTP_Pos)
3082#define ADC_CR_JADSTP ADC_CR_JADSTP_Msk
3083#define ADC_CR_BOOST_Pos (8U)
3084#define ADC_CR_BOOST_Msk (0x3UL << ADC_CR_BOOST_Pos)
3085#define ADC_CR_BOOST ADC_CR_BOOST_Msk
3086#define ADC_CR_BOOST_0 (0x1UL << ADC_CR_BOOST_Pos)
3087#define ADC_CR_BOOST_1 (0x2UL << ADC_CR_BOOST_Pos)
3088#define ADC_CR_ADCALLIN_Pos (16U)
3089#define ADC_CR_ADCALLIN_Msk (0x1UL << ADC_CR_ADCALLIN_Pos)
3090#define ADC_CR_ADCALLIN ADC_CR_ADCALLIN_Msk
3091#define ADC_CR_LINCALRDYW1_Pos (22U)
3092#define ADC_CR_LINCALRDYW1_Msk (0x1UL << ADC_CR_LINCALRDYW1_Pos)
3093#define ADC_CR_LINCALRDYW1 ADC_CR_LINCALRDYW1_Msk
3094#define ADC_CR_LINCALRDYW2_Pos (23U)
3095#define ADC_CR_LINCALRDYW2_Msk (0x1UL << ADC_CR_LINCALRDYW2_Pos)
3096#define ADC_CR_LINCALRDYW2 ADC_CR_LINCALRDYW2_Msk
3097#define ADC_CR_LINCALRDYW3_Pos (24U)
3098#define ADC_CR_LINCALRDYW3_Msk (0x1UL << ADC_CR_LINCALRDYW3_Pos)
3099#define ADC_CR_LINCALRDYW3 ADC_CR_LINCALRDYW3_Msk
3100#define ADC_CR_LINCALRDYW4_Pos (25U)
3101#define ADC_CR_LINCALRDYW4_Msk (0x1UL << ADC_CR_LINCALRDYW4_Pos)
3102#define ADC_CR_LINCALRDYW4 ADC_CR_LINCALRDYW4_Msk
3103#define ADC_CR_LINCALRDYW5_Pos (26U)
3104#define ADC_CR_LINCALRDYW5_Msk (0x1UL << ADC_CR_LINCALRDYW5_Pos)
3105#define ADC_CR_LINCALRDYW5 ADC_CR_LINCALRDYW5_Msk
3106#define ADC_CR_LINCALRDYW6_Pos (27U)
3107#define ADC_CR_LINCALRDYW6_Msk (0x1UL << ADC_CR_LINCALRDYW6_Pos)
3108#define ADC_CR_LINCALRDYW6 ADC_CR_LINCALRDYW6_Msk
3109#define ADC_CR_ADVREGEN_Pos (28U)
3110#define ADC_CR_ADVREGEN_Msk (0x1UL << ADC_CR_ADVREGEN_Pos)
3111#define ADC_CR_ADVREGEN ADC_CR_ADVREGEN_Msk
3112#define ADC_CR_DEEPPWD_Pos (29U)
3113#define ADC_CR_DEEPPWD_Msk (0x1UL << ADC_CR_DEEPPWD_Pos)
3114#define ADC_CR_DEEPPWD ADC_CR_DEEPPWD_Msk
3115#define ADC_CR_ADCALDIF_Pos (30U)
3116#define ADC_CR_ADCALDIF_Msk (0x1UL << ADC_CR_ADCALDIF_Pos)
3117#define ADC_CR_ADCALDIF ADC_CR_ADCALDIF_Msk
3118#define ADC_CR_ADCAL_Pos (31U)
3119#define ADC_CR_ADCAL_Msk (0x1UL << ADC_CR_ADCAL_Pos)
3120#define ADC_CR_ADCAL ADC_CR_ADCAL_Msk
3122/******************** Bit definition for ADC_CFGR register ********************/
3123#define ADC_CFGR_DMNGT_Pos (0U)
3124#define ADC_CFGR_DMNGT_Msk (0x3UL << ADC_CFGR_DMNGT_Pos)
3125#define ADC_CFGR_DMNGT ADC_CFGR_DMNGT_Msk
3126#define ADC_CFGR_DMNGT_0 (0x1UL << ADC_CFGR_DMNGT_Pos)
3127#define ADC_CFGR_DMNGT_1 (0x2UL << ADC_CFGR_DMNGT_Pos)
3129#define ADC_CFGR_RES_Pos (2U)
3130#define ADC_CFGR_RES_Msk (0x7UL << ADC_CFGR_RES_Pos)
3131#define ADC_CFGR_RES ADC_CFGR_RES_Msk
3132#define ADC_CFGR_RES_0 (0x1UL << ADC_CFGR_RES_Pos)
3133#define ADC_CFGR_RES_1 (0x2UL << ADC_CFGR_RES_Pos)
3134#define ADC_CFGR_RES_2 (0x4UL << ADC_CFGR_RES_Pos)
3136#define ADC_CFGR_EXTSEL_Pos (5U)
3137#define ADC_CFGR_EXTSEL_Msk (0x1FUL << ADC_CFGR_EXTSEL_Pos)
3138#define ADC_CFGR_EXTSEL ADC_CFGR_EXTSEL_Msk
3139#define ADC_CFGR_EXTSEL_0 (0x01UL << ADC_CFGR_EXTSEL_Pos)
3140#define ADC_CFGR_EXTSEL_1 (0x02UL << ADC_CFGR_EXTSEL_Pos)
3141#define ADC_CFGR_EXTSEL_2 (0x04UL << ADC_CFGR_EXTSEL_Pos)
3142#define ADC_CFGR_EXTSEL_3 (0x08UL << ADC_CFGR_EXTSEL_Pos)
3143#define ADC_CFGR_EXTSEL_4 (0x10UL << ADC_CFGR_EXTSEL_Pos)
3145#define ADC_CFGR_EXTEN_Pos (10U)
3146#define ADC_CFGR_EXTEN_Msk (0x3UL << ADC_CFGR_EXTEN_Pos)
3147#define ADC_CFGR_EXTEN ADC_CFGR_EXTEN_Msk
3148#define ADC_CFGR_EXTEN_0 (0x1UL << ADC_CFGR_EXTEN_Pos)
3149#define ADC_CFGR_EXTEN_1 (0x2UL << ADC_CFGR_EXTEN_Pos)
3151#define ADC_CFGR_OVRMOD_Pos (12U)
3152#define ADC_CFGR_OVRMOD_Msk (0x1UL << ADC_CFGR_OVRMOD_Pos)
3153#define ADC_CFGR_OVRMOD ADC_CFGR_OVRMOD_Msk
3154#define ADC_CFGR_CONT_Pos (13U)
3155#define ADC_CFGR_CONT_Msk (0x1UL << ADC_CFGR_CONT_Pos)
3156#define ADC_CFGR_CONT ADC_CFGR_CONT_Msk
3157#define ADC_CFGR_AUTDLY_Pos (14U)
3158#define ADC_CFGR_AUTDLY_Msk (0x1UL << ADC_CFGR_AUTDLY_Pos)
3159#define ADC_CFGR_AUTDLY ADC_CFGR_AUTDLY_Msk
3161#define ADC_CFGR_DISCEN_Pos (16U)
3162#define ADC_CFGR_DISCEN_Msk (0x1UL << ADC_CFGR_DISCEN_Pos)
3163#define ADC_CFGR_DISCEN ADC_CFGR_DISCEN_Msk
3165#define ADC_CFGR_DISCNUM_Pos (17U)
3166#define ADC_CFGR_DISCNUM_Msk (0x7UL << ADC_CFGR_DISCNUM_Pos)
3167#define ADC_CFGR_DISCNUM ADC_CFGR_DISCNUM_Msk
3168#define ADC_CFGR_DISCNUM_0 (0x1UL << ADC_CFGR_DISCNUM_Pos)
3169#define ADC_CFGR_DISCNUM_1 (0x2UL << ADC_CFGR_DISCNUM_Pos)
3170#define ADC_CFGR_DISCNUM_2 (0x4UL << ADC_CFGR_DISCNUM_Pos)
3172#define ADC_CFGR_JDISCEN_Pos (20U)
3173#define ADC_CFGR_JDISCEN_Msk (0x1UL << ADC_CFGR_JDISCEN_Pos)
3174#define ADC_CFGR_JDISCEN ADC_CFGR_JDISCEN_Msk
3175#define ADC_CFGR_JQM_Pos (21U)
3176#define ADC_CFGR_JQM_Msk (0x1UL << ADC_CFGR_JQM_Pos)
3177#define ADC_CFGR_JQM ADC_CFGR_JQM_Msk
3178#define ADC_CFGR_AWD1SGL_Pos (22U)
3179#define ADC_CFGR_AWD1SGL_Msk (0x1UL << ADC_CFGR_AWD1SGL_Pos)
3180#define ADC_CFGR_AWD1SGL ADC_CFGR_AWD1SGL_Msk
3181#define ADC_CFGR_AWD1EN_Pos (23U)
3182#define ADC_CFGR_AWD1EN_Msk (0x1UL << ADC_CFGR_AWD1EN_Pos)
3183#define ADC_CFGR_AWD1EN ADC_CFGR_AWD1EN_Msk
3184#define ADC_CFGR_JAWD1EN_Pos (24U)
3185#define ADC_CFGR_JAWD1EN_Msk (0x1UL << ADC_CFGR_JAWD1EN_Pos)
3186#define ADC_CFGR_JAWD1EN ADC_CFGR_JAWD1EN_Msk
3187#define ADC_CFGR_JAUTO_Pos (25U)
3188#define ADC_CFGR_JAUTO_Msk (0x1UL << ADC_CFGR_JAUTO_Pos)
3189#define ADC_CFGR_JAUTO ADC_CFGR_JAUTO_Msk
3191#define ADC_CFGR_AWD1CH_Pos (26U)
3192#define ADC_CFGR_AWD1CH_Msk (0x1FUL << ADC_CFGR_AWD1CH_Pos)
3193#define ADC_CFGR_AWD1CH ADC_CFGR_AWD1CH_Msk
3194#define ADC_CFGR_AWD1CH_0 (0x01UL << ADC_CFGR_AWD1CH_Pos)
3195#define ADC_CFGR_AWD1CH_1 (0x02UL << ADC_CFGR_AWD1CH_Pos)
3196#define ADC_CFGR_AWD1CH_2 (0x04UL << ADC_CFGR_AWD1CH_Pos)
3197#define ADC_CFGR_AWD1CH_3 (0x08UL << ADC_CFGR_AWD1CH_Pos)
3198#define ADC_CFGR_AWD1CH_4 (0x10UL << ADC_CFGR_AWD1CH_Pos)
3200#define ADC_CFGR_JQDIS_Pos (31U)
3201#define ADC_CFGR_JQDIS_Msk (0x1UL << ADC_CFGR_JQDIS_Pos)
3202#define ADC_CFGR_JQDIS ADC_CFGR_JQDIS_Msk
3204/******************** Bit definition for ADC_CFGR2 register ********************/
3205#define ADC_CFGR2_ROVSE_Pos (0U)
3206#define ADC_CFGR2_ROVSE_Msk (0x1UL << ADC_CFGR2_ROVSE_Pos)
3207#define ADC_CFGR2_ROVSE ADC_CFGR2_ROVSE_Msk
3208#define ADC_CFGR2_JOVSE_Pos (1U)
3209#define ADC_CFGR2_JOVSE_Msk (0x1UL << ADC_CFGR2_JOVSE_Pos)
3210#define ADC_CFGR2_JOVSE ADC_CFGR2_JOVSE_Msk
3212#define ADC_CFGR2_OVSS_Pos (5U)
3213#define ADC_CFGR2_OVSS_Msk (0xFUL << ADC_CFGR2_OVSS_Pos)
3214#define ADC_CFGR2_OVSS ADC_CFGR2_OVSS_Msk
3215#define ADC_CFGR2_OVSS_0 (0x1UL << ADC_CFGR2_OVSS_Pos)
3216#define ADC_CFGR2_OVSS_1 (0x2UL << ADC_CFGR2_OVSS_Pos)
3217#define ADC_CFGR2_OVSS_2 (0x4UL << ADC_CFGR2_OVSS_Pos)
3218#define ADC_CFGR2_OVSS_3 (0x8UL << ADC_CFGR2_OVSS_Pos)
3220#define ADC_CFGR2_TROVS_Pos (9U)
3221#define ADC_CFGR2_TROVS_Msk (0x1UL << ADC_CFGR2_TROVS_Pos)
3222#define ADC_CFGR2_TROVS ADC_CFGR2_TROVS_Msk
3223#define ADC_CFGR2_ROVSM_Pos (10U)
3224#define ADC_CFGR2_ROVSM_Msk (0x1UL << ADC_CFGR2_ROVSM_Pos)
3225#define ADC_CFGR2_ROVSM ADC_CFGR2_ROVSM_Msk
3227#define ADC_CFGR2_RSHIFT1_Pos (11U)
3228#define ADC_CFGR2_RSHIFT1_Msk (0x1UL << ADC_CFGR2_RSHIFT1_Pos)
3229#define ADC_CFGR2_RSHIFT1 ADC_CFGR2_RSHIFT1_Msk
3230#define ADC_CFGR2_RSHIFT2_Pos (12U)
3231#define ADC_CFGR2_RSHIFT2_Msk (0x1UL << ADC_CFGR2_RSHIFT2_Pos)
3232#define ADC_CFGR2_RSHIFT2 ADC_CFGR2_RSHIFT2_Msk
3233#define ADC_CFGR2_RSHIFT3_Pos (13U)
3234#define ADC_CFGR2_RSHIFT3_Msk (0x1UL << ADC_CFGR2_RSHIFT3_Pos)
3235#define ADC_CFGR2_RSHIFT3 ADC_CFGR2_RSHIFT3_Msk
3236#define ADC_CFGR2_RSHIFT4_Pos (14U)
3237#define ADC_CFGR2_RSHIFT4_Msk (0x1UL << ADC_CFGR2_RSHIFT4_Pos)
3238#define ADC_CFGR2_RSHIFT4 ADC_CFGR2_RSHIFT4_Msk
3240#define ADC_CFGR2_OVSR_Pos (16U)
3241#define ADC_CFGR2_OVSR_Msk (0x3FFUL << ADC_CFGR2_OVSR_Pos)
3242#define ADC_CFGR2_OVSR ADC_CFGR2_OVSR_Msk
3243#define ADC_CFGR2_OVSR_0 (0x001UL << ADC_CFGR2_OVSR_Pos)
3244#define ADC_CFGR2_OVSR_1 (0x002UL << ADC_CFGR2_OVSR_Pos)
3245#define ADC_CFGR2_OVSR_2 (0x004UL << ADC_CFGR2_OVSR_Pos)
3246#define ADC_CFGR2_OVSR_3 (0x008UL << ADC_CFGR2_OVSR_Pos)
3247#define ADC_CFGR2_OVSR_4 (0x010UL << ADC_CFGR2_OVSR_Pos)
3248#define ADC_CFGR2_OVSR_5 (0x020UL << ADC_CFGR2_OVSR_Pos)
3249#define ADC_CFGR2_OVSR_6 (0x040UL << ADC_CFGR2_OVSR_Pos)
3250#define ADC_CFGR2_OVSR_7 (0x080UL << ADC_CFGR2_OVSR_Pos)
3251#define ADC_CFGR2_OVSR_8 (0x100UL << ADC_CFGR2_OVSR_Pos)
3252#define ADC_CFGR2_OVSR_9 (0x200UL << ADC_CFGR2_OVSR_Pos)
3254#define ADC_CFGR2_LSHIFT_Pos (28U)
3255#define ADC_CFGR2_LSHIFT_Msk (0xFUL << ADC_CFGR2_LSHIFT_Pos)
3256#define ADC_CFGR2_LSHIFT ADC_CFGR2_LSHIFT_Msk
3257#define ADC_CFGR2_LSHIFT_0 (0x1UL << ADC_CFGR2_LSHIFT_Pos)
3258#define ADC_CFGR2_LSHIFT_1 (0x2UL << ADC_CFGR2_LSHIFT_Pos)
3259#define ADC_CFGR2_LSHIFT_2 (0x4UL << ADC_CFGR2_LSHIFT_Pos)
3260#define ADC_CFGR2_LSHIFT_3 (0x8UL << ADC_CFGR2_LSHIFT_Pos)
3262/******************** Bit definition for ADC_SMPR1 register ********************/
3263#define ADC_SMPR1_SMP0_Pos (0U)
3264#define ADC_SMPR1_SMP0_Msk (0x7UL << ADC_SMPR1_SMP0_Pos)
3265#define ADC_SMPR1_SMP0 ADC_SMPR1_SMP0_Msk
3266#define ADC_SMPR1_SMP0_0 (0x1UL << ADC_SMPR1_SMP0_Pos)
3267#define ADC_SMPR1_SMP0_1 (0x2UL << ADC_SMPR1_SMP0_Pos)
3268#define ADC_SMPR1_SMP0_2 (0x4UL << ADC_SMPR1_SMP0_Pos)
3270#define ADC_SMPR1_SMP1_Pos (3U)
3271#define ADC_SMPR1_SMP1_Msk (0x7UL << ADC_SMPR1_SMP1_Pos)
3272#define ADC_SMPR1_SMP1 ADC_SMPR1_SMP1_Msk
3273#define ADC_SMPR1_SMP1_0 (0x1UL << ADC_SMPR1_SMP1_Pos)
3274#define ADC_SMPR1_SMP1_1 (0x2UL << ADC_SMPR1_SMP1_Pos)
3275#define ADC_SMPR1_SMP1_2 (0x4UL << ADC_SMPR1_SMP1_Pos)
3277#define ADC_SMPR1_SMP2_Pos (6U)
3278#define ADC_SMPR1_SMP2_Msk (0x7UL << ADC_SMPR1_SMP2_Pos)
3279#define ADC_SMPR1_SMP2 ADC_SMPR1_SMP2_Msk
3280#define ADC_SMPR1_SMP2_0 (0x1UL << ADC_SMPR1_SMP2_Pos)
3281#define ADC_SMPR1_SMP2_1 (0x2UL << ADC_SMPR1_SMP2_Pos)
3282#define ADC_SMPR1_SMP2_2 (0x4UL << ADC_SMPR1_SMP2_Pos)
3284#define ADC_SMPR1_SMP3_Pos (9U)
3285#define ADC_SMPR1_SMP3_Msk (0x7UL << ADC_SMPR1_SMP3_Pos)
3286#define ADC_SMPR1_SMP3 ADC_SMPR1_SMP3_Msk
3287#define ADC_SMPR1_SMP3_0 (0x1UL << ADC_SMPR1_SMP3_Pos)
3288#define ADC_SMPR1_SMP3_1 (0x2UL << ADC_SMPR1_SMP3_Pos)
3289#define ADC_SMPR1_SMP3_2 (0x4UL << ADC_SMPR1_SMP3_Pos)
3291#define ADC_SMPR1_SMP4_Pos (12U)
3292#define ADC_SMPR1_SMP4_Msk (0x7UL << ADC_SMPR1_SMP4_Pos)
3293#define ADC_SMPR1_SMP4 ADC_SMPR1_SMP4_Msk
3294#define ADC_SMPR1_SMP4_0 (0x1UL << ADC_SMPR1_SMP4_Pos)
3295#define ADC_SMPR1_SMP4_1 (0x2UL << ADC_SMPR1_SMP4_Pos)
3296#define ADC_SMPR1_SMP4_2 (0x4UL << ADC_SMPR1_SMP4_Pos)
3298#define ADC_SMPR1_SMP5_Pos (15U)
3299#define ADC_SMPR1_SMP5_Msk (0x7UL << ADC_SMPR1_SMP5_Pos)
3300#define ADC_SMPR1_SMP5 ADC_SMPR1_SMP5_Msk
3301#define ADC_SMPR1_SMP5_0 (0x1UL << ADC_SMPR1_SMP5_Pos)
3302#define ADC_SMPR1_SMP5_1 (0x2UL << ADC_SMPR1_SMP5_Pos)
3303#define ADC_SMPR1_SMP5_2 (0x4UL << ADC_SMPR1_SMP5_Pos)
3305#define ADC_SMPR1_SMP6_Pos (18U)
3306#define ADC_SMPR1_SMP6_Msk (0x7UL << ADC_SMPR1_SMP6_Pos)
3307#define ADC_SMPR1_SMP6 ADC_SMPR1_SMP6_Msk
3308#define ADC_SMPR1_SMP6_0 (0x1UL << ADC_SMPR1_SMP6_Pos)
3309#define ADC_SMPR1_SMP6_1 (0x2UL << ADC_SMPR1_SMP6_Pos)
3310#define ADC_SMPR1_SMP6_2 (0x4UL << ADC_SMPR1_SMP6_Pos)
3312#define ADC_SMPR1_SMP7_Pos (21U)
3313#define ADC_SMPR1_SMP7_Msk (0x7UL << ADC_SMPR1_SMP7_Pos)
3314#define ADC_SMPR1_SMP7 ADC_SMPR1_SMP7_Msk
3315#define ADC_SMPR1_SMP7_0 (0x1UL << ADC_SMPR1_SMP7_Pos)
3316#define ADC_SMPR1_SMP7_1 (0x2UL << ADC_SMPR1_SMP7_Pos)
3317#define ADC_SMPR1_SMP7_2 (0x4UL << ADC_SMPR1_SMP7_Pos)
3319#define ADC_SMPR1_SMP8_Pos (24U)
3320#define ADC_SMPR1_SMP8_Msk (0x7UL << ADC_SMPR1_SMP8_Pos)
3321#define ADC_SMPR1_SMP8 ADC_SMPR1_SMP8_Msk
3322#define ADC_SMPR1_SMP8_0 (0x1UL << ADC_SMPR1_SMP8_Pos)
3323#define ADC_SMPR1_SMP8_1 (0x2UL << ADC_SMPR1_SMP8_Pos)
3324#define ADC_SMPR1_SMP8_2 (0x4UL << ADC_SMPR1_SMP8_Pos)
3326#define ADC_SMPR1_SMP9_Pos (27U)
3327#define ADC_SMPR1_SMP9_Msk (0x7UL << ADC_SMPR1_SMP9_Pos)
3328#define ADC_SMPR1_SMP9 ADC_SMPR1_SMP9_Msk
3329#define ADC_SMPR1_SMP9_0 (0x1UL << ADC_SMPR1_SMP9_Pos)
3330#define ADC_SMPR1_SMP9_1 (0x2UL << ADC_SMPR1_SMP9_Pos)
3331#define ADC_SMPR1_SMP9_2 (0x4UL << ADC_SMPR1_SMP9_Pos)
3333/******************** Bit definition for ADC_SMPR2 register ********************/
3334#define ADC_SMPR2_SMP10_Pos (0U)
3335#define ADC_SMPR2_SMP10_Msk (0x7UL << ADC_SMPR2_SMP10_Pos)
3336#define ADC_SMPR2_SMP10 ADC_SMPR2_SMP10_Msk
3337#define ADC_SMPR2_SMP10_0 (0x1UL << ADC_SMPR2_SMP10_Pos)
3338#define ADC_SMPR2_SMP10_1 (0x2UL << ADC_SMPR2_SMP10_Pos)
3339#define ADC_SMPR2_SMP10_2 (0x4UL << ADC_SMPR2_SMP10_Pos)
3341#define ADC_SMPR2_SMP11_Pos (3U)
3342#define ADC_SMPR2_SMP11_Msk (0x7UL << ADC_SMPR2_SMP11_Pos)
3343#define ADC_SMPR2_SMP11 ADC_SMPR2_SMP11_Msk
3344#define ADC_SMPR2_SMP11_0 (0x1UL << ADC_SMPR2_SMP11_Pos)
3345#define ADC_SMPR2_SMP11_1 (0x2UL << ADC_SMPR2_SMP11_Pos)
3346#define ADC_SMPR2_SMP11_2 (0x4UL << ADC_SMPR2_SMP11_Pos)
3348#define ADC_SMPR2_SMP12_Pos (6U)
3349#define ADC_SMPR2_SMP12_Msk (0x7UL << ADC_SMPR2_SMP12_Pos)
3350#define ADC_SMPR2_SMP12 ADC_SMPR2_SMP12_Msk
3351#define ADC_SMPR2_SMP12_0 (0x1UL << ADC_SMPR2_SMP12_Pos)
3352#define ADC_SMPR2_SMP12_1 (0x2UL << ADC_SMPR2_SMP12_Pos)
3353#define ADC_SMPR2_SMP12_2 (0x4UL << ADC_SMPR2_SMP12_Pos)
3355#define ADC_SMPR2_SMP13_Pos (9U)
3356#define ADC_SMPR2_SMP13_Msk (0x7UL << ADC_SMPR2_SMP13_Pos)
3357#define ADC_SMPR2_SMP13 ADC_SMPR2_SMP13_Msk
3358#define ADC_SMPR2_SMP13_0 (0x1UL << ADC_SMPR2_SMP13_Pos)
3359#define ADC_SMPR2_SMP13_1 (0x2UL << ADC_SMPR2_SMP13_Pos)
3360#define ADC_SMPR2_SMP13_2 (0x4UL << ADC_SMPR2_SMP13_Pos)
3362#define ADC_SMPR2_SMP14_Pos (12U)
3363#define ADC_SMPR2_SMP14_Msk (0x7UL << ADC_SMPR2_SMP14_Pos)
3364#define ADC_SMPR2_SMP14 ADC_SMPR2_SMP14_Msk
3365#define ADC_SMPR2_SMP14_0 (0x1UL << ADC_SMPR2_SMP14_Pos)
3366#define ADC_SMPR2_SMP14_1 (0x2UL << ADC_SMPR2_SMP14_Pos)
3367#define ADC_SMPR2_SMP14_2 (0x4UL << ADC_SMPR2_SMP14_Pos)
3369#define ADC_SMPR2_SMP15_Pos (15U)
3370#define ADC_SMPR2_SMP15_Msk (0x7UL << ADC_SMPR2_SMP15_Pos)
3371#define ADC_SMPR2_SMP15 ADC_SMPR2_SMP15_Msk
3372#define ADC_SMPR2_SMP15_0 (0x1UL << ADC_SMPR2_SMP15_Pos)
3373#define ADC_SMPR2_SMP15_1 (0x2UL << ADC_SMPR2_SMP15_Pos)
3374#define ADC_SMPR2_SMP15_2 (0x4UL << ADC_SMPR2_SMP15_Pos)
3376#define ADC_SMPR2_SMP16_Pos (18U)
3377#define ADC_SMPR2_SMP16_Msk (0x7UL << ADC_SMPR2_SMP16_Pos)
3378#define ADC_SMPR2_SMP16 ADC_SMPR2_SMP16_Msk
3379#define ADC_SMPR2_SMP16_0 (0x1UL << ADC_SMPR2_SMP16_Pos)
3380#define ADC_SMPR2_SMP16_1 (0x2UL << ADC_SMPR2_SMP16_Pos)
3381#define ADC_SMPR2_SMP16_2 (0x4UL << ADC_SMPR2_SMP16_Pos)
3383#define ADC_SMPR2_SMP17_Pos (21U)
3384#define ADC_SMPR2_SMP17_Msk (0x7UL << ADC_SMPR2_SMP17_Pos)
3385#define ADC_SMPR2_SMP17 ADC_SMPR2_SMP17_Msk
3386#define ADC_SMPR2_SMP17_0 (0x1UL << ADC_SMPR2_SMP17_Pos)
3387#define ADC_SMPR2_SMP17_1 (0x2UL << ADC_SMPR2_SMP17_Pos)
3388#define ADC_SMPR2_SMP17_2 (0x4UL << ADC_SMPR2_SMP17_Pos)
3390#define ADC_SMPR2_SMP18_Pos (24U)
3391#define ADC_SMPR2_SMP18_Msk (0x7UL << ADC_SMPR2_SMP18_Pos)
3392#define ADC_SMPR2_SMP18 ADC_SMPR2_SMP18_Msk
3393#define ADC_SMPR2_SMP18_0 (0x1UL << ADC_SMPR2_SMP18_Pos)
3394#define ADC_SMPR2_SMP18_1 (0x2UL << ADC_SMPR2_SMP18_Pos)
3395#define ADC_SMPR2_SMP18_2 (0x4UL << ADC_SMPR2_SMP18_Pos)
3397#define ADC_SMPR2_SMP19_Pos (27U)
3398#define ADC_SMPR2_SMP19_Msk (0x7UL << ADC_SMPR2_SMP19_Pos)
3399#define ADC_SMPR2_SMP19 ADC_SMPR2_SMP19_Msk
3400#define ADC_SMPR2_SMP19_0 (0x1UL << ADC_SMPR2_SMP19_Pos)
3401#define ADC_SMPR2_SMP19_1 (0x2UL << ADC_SMPR2_SMP19_Pos)
3402#define ADC_SMPR2_SMP19_2 (0x4UL << ADC_SMPR2_SMP19_Pos)
3404/******************** Bit definition for ADC_PCSEL register ********************/
3405#define ADC_PCSEL_PCSEL_Pos (0U)
3406#define ADC_PCSEL_PCSEL_Msk (0xFFFFFUL << ADC_PCSEL_PCSEL_Pos)
3407#define ADC_PCSEL_PCSEL ADC_PCSEL_PCSEL_Msk
3408#define ADC_PCSEL_PCSEL_0 (0x00001UL << ADC_PCSEL_PCSEL_Pos)
3409#define ADC_PCSEL_PCSEL_1 (0x00002UL << ADC_PCSEL_PCSEL_Pos)
3410#define ADC_PCSEL_PCSEL_2 (0x00004UL << ADC_PCSEL_PCSEL_Pos)
3411#define ADC_PCSEL_PCSEL_3 (0x00008UL << ADC_PCSEL_PCSEL_Pos)
3412#define ADC_PCSEL_PCSEL_4 (0x00010UL << ADC_PCSEL_PCSEL_Pos)
3413#define ADC_PCSEL_PCSEL_5 (0x00020UL << ADC_PCSEL_PCSEL_Pos)
3414#define ADC_PCSEL_PCSEL_6 (0x00040UL << ADC_PCSEL_PCSEL_Pos)
3415#define ADC_PCSEL_PCSEL_7 (0x00080UL << ADC_PCSEL_PCSEL_Pos)
3416#define ADC_PCSEL_PCSEL_8 (0x00100UL << ADC_PCSEL_PCSEL_Pos)
3417#define ADC_PCSEL_PCSEL_9 (0x00200UL << ADC_PCSEL_PCSEL_Pos)
3418#define ADC_PCSEL_PCSEL_10 (0x00400UL << ADC_PCSEL_PCSEL_Pos)
3419#define ADC_PCSEL_PCSEL_11 (0x00800UL << ADC_PCSEL_PCSEL_Pos)
3420#define ADC_PCSEL_PCSEL_12 (0x01000UL << ADC_PCSEL_PCSEL_Pos)
3421#define ADC_PCSEL_PCSEL_13 (0x02000UL << ADC_PCSEL_PCSEL_Pos)
3422#define ADC_PCSEL_PCSEL_14 (0x04000UL << ADC_PCSEL_PCSEL_Pos)
3423#define ADC_PCSEL_PCSEL_15 (0x08000UL << ADC_PCSEL_PCSEL_Pos)
3424#define ADC_PCSEL_PCSEL_16 (0x10000UL << ADC_PCSEL_PCSEL_Pos)
3425#define ADC_PCSEL_PCSEL_17 (0x20000UL << ADC_PCSEL_PCSEL_Pos)
3426#define ADC_PCSEL_PCSEL_18 (0x40000UL << ADC_PCSEL_PCSEL_Pos)
3427#define ADC_PCSEL_PCSEL_19 (0x80000UL << ADC_PCSEL_PCSEL_Pos)
3429/***************** Bit definition for ADC_LTR1, 2, 3 registers *****************/
3430#define ADC_LTR_LT_Pos (0U)
3431#define ADC_LTR_LT_Msk (0x3FFFFFFUL << ADC_LTR_LT_Pos)
3432#define ADC_LTR_LT ADC_LTR_LT_Msk
3434/***************** Bit definition for ADC_HTR1, 2, 3 registers ****************/
3435#define ADC_HTR_HT_Pos (0U)
3436#define ADC_HTR_HT_Msk (0x3FFFFFFUL << ADC_HTR_HT_Pos)
3437#define ADC_HTR_HT ADC_HTR_HT_Msk
3440/******************** Bit definition for ADC_SQR1 register ********************/
3441#define ADC_SQR1_L_Pos (0U)
3442#define ADC_SQR1_L_Msk (0xFUL << ADC_SQR1_L_Pos)
3443#define ADC_SQR1_L ADC_SQR1_L_Msk
3444#define ADC_SQR1_L_0 (0x1UL << ADC_SQR1_L_Pos)
3445#define ADC_SQR1_L_1 (0x2UL << ADC_SQR1_L_Pos)
3446#define ADC_SQR1_L_2 (0x4UL << ADC_SQR1_L_Pos)
3447#define ADC_SQR1_L_3 (0x8UL << ADC_SQR1_L_Pos)
3449#define ADC_SQR1_SQ1_Pos (6U)
3450#define ADC_SQR1_SQ1_Msk (0x1FUL << ADC_SQR1_SQ1_Pos)
3451#define ADC_SQR1_SQ1 ADC_SQR1_SQ1_Msk
3452#define ADC_SQR1_SQ1_0 (0x01UL << ADC_SQR1_SQ1_Pos)
3453#define ADC_SQR1_SQ1_1 (0x02UL << ADC_SQR1_SQ1_Pos)
3454#define ADC_SQR1_SQ1_2 (0x04UL << ADC_SQR1_SQ1_Pos)
3455#define ADC_SQR1_SQ1_3 (0x08UL << ADC_SQR1_SQ1_Pos)
3456#define ADC_SQR1_SQ1_4 (0x10UL << ADC_SQR1_SQ1_Pos)
3458#define ADC_SQR1_SQ2_Pos (12U)
3459#define ADC_SQR1_SQ2_Msk (0x1FUL << ADC_SQR1_SQ2_Pos)
3460#define ADC_SQR1_SQ2 ADC_SQR1_SQ2_Msk
3461#define ADC_SQR1_SQ2_0 (0x01UL << ADC_SQR1_SQ2_Pos)
3462#define ADC_SQR1_SQ2_1 (0x02UL << ADC_SQR1_SQ2_Pos)
3463#define ADC_SQR1_SQ2_2 (0x04UL << ADC_SQR1_SQ2_Pos)
3464#define ADC_SQR1_SQ2_3 (0x08UL << ADC_SQR1_SQ2_Pos)
3465#define ADC_SQR1_SQ2_4 (0x10UL << ADC_SQR1_SQ2_Pos)
3467#define ADC_SQR1_SQ3_Pos (18U)
3468#define ADC_SQR1_SQ3_Msk (0x1FUL << ADC_SQR1_SQ3_Pos)
3469#define ADC_SQR1_SQ3 ADC_SQR1_SQ3_Msk
3470#define ADC_SQR1_SQ3_0 (0x01UL << ADC_SQR1_SQ3_Pos)
3471#define ADC_SQR1_SQ3_1 (0x02UL << ADC_SQR1_SQ3_Pos)
3472#define ADC_SQR1_SQ3_2 (0x04UL << ADC_SQR1_SQ3_Pos)
3473#define ADC_SQR1_SQ3_3 (0x08UL << ADC_SQR1_SQ3_Pos)
3474#define ADC_SQR1_SQ3_4 (0x10UL << ADC_SQR1_SQ3_Pos)
3476#define ADC_SQR1_SQ4_Pos (24U)
3477#define ADC_SQR1_SQ4_Msk (0x1FUL << ADC_SQR1_SQ4_Pos)
3478#define ADC_SQR1_SQ4 ADC_SQR1_SQ4_Msk
3479#define ADC_SQR1_SQ4_0 (0x01UL << ADC_SQR1_SQ4_Pos)
3480#define ADC_SQR1_SQ4_1 (0x02UL << ADC_SQR1_SQ4_Pos)
3481#define ADC_SQR1_SQ4_2 (0x04UL << ADC_SQR1_SQ4_Pos)
3482#define ADC_SQR1_SQ4_3 (0x08UL << ADC_SQR1_SQ4_Pos)
3483#define ADC_SQR1_SQ4_4 (0x10UL << ADC_SQR1_SQ4_Pos)
3485/******************** Bit definition for ADC_SQR2 register ********************/
3486#define ADC_SQR2_SQ5_Pos (0U)
3487#define ADC_SQR2_SQ5_Msk (0x1FUL << ADC_SQR2_SQ5_Pos)
3488#define ADC_SQR2_SQ5 ADC_SQR2_SQ5_Msk
3489#define ADC_SQR2_SQ5_0 (0x01UL << ADC_SQR2_SQ5_Pos)
3490#define ADC_SQR2_SQ5_1 (0x02UL << ADC_SQR2_SQ5_Pos)
3491#define ADC_SQR2_SQ5_2 (0x04UL << ADC_SQR2_SQ5_Pos)
3492#define ADC_SQR2_SQ5_3 (0x08UL << ADC_SQR2_SQ5_Pos)
3493#define ADC_SQR2_SQ5_4 (0x10UL << ADC_SQR2_SQ5_Pos)
3495#define ADC_SQR2_SQ6_Pos (6U)
3496#define ADC_SQR2_SQ6_Msk (0x1FUL << ADC_SQR2_SQ6_Pos)
3497#define ADC_SQR2_SQ6 ADC_SQR2_SQ6_Msk
3498#define ADC_SQR2_SQ6_0 (0x01UL << ADC_SQR2_SQ6_Pos)
3499#define ADC_SQR2_SQ6_1 (0x02UL << ADC_SQR2_SQ6_Pos)
3500#define ADC_SQR2_SQ6_2 (0x04UL << ADC_SQR2_SQ6_Pos)
3501#define ADC_SQR2_SQ6_3 (0x08UL << ADC_SQR2_SQ6_Pos)
3502#define ADC_SQR2_SQ6_4 (0x10UL << ADC_SQR2_SQ6_Pos)
3504#define ADC_SQR2_SQ7_Pos (12U)
3505#define ADC_SQR2_SQ7_Msk (0x1FUL << ADC_SQR2_SQ7_Pos)
3506#define ADC_SQR2_SQ7 ADC_SQR2_SQ7_Msk
3507#define ADC_SQR2_SQ7_0 (0x01UL << ADC_SQR2_SQ7_Pos)
3508#define ADC_SQR2_SQ7_1 (0x02UL << ADC_SQR2_SQ7_Pos)
3509#define ADC_SQR2_SQ7_2 (0x04UL << ADC_SQR2_SQ7_Pos)
3510#define ADC_SQR2_SQ7_3 (0x08UL << ADC_SQR2_SQ7_Pos)
3511#define ADC_SQR2_SQ7_4 (0x10UL << ADC_SQR2_SQ7_Pos)
3513#define ADC_SQR2_SQ8_Pos (18U)
3514#define ADC_SQR2_SQ8_Msk (0x1FUL << ADC_SQR2_SQ8_Pos)
3515#define ADC_SQR2_SQ8 ADC_SQR2_SQ8_Msk
3516#define ADC_SQR2_SQ8_0 (0x01UL << ADC_SQR2_SQ8_Pos)
3517#define ADC_SQR2_SQ8_1 (0x02UL << ADC_SQR2_SQ8_Pos)
3518#define ADC_SQR2_SQ8_2 (0x04UL << ADC_SQR2_SQ8_Pos)
3519#define ADC_SQR2_SQ8_3 (0x08UL << ADC_SQR2_SQ8_Pos)
3520#define ADC_SQR2_SQ8_4 (0x10UL << ADC_SQR2_SQ8_Pos)
3522#define ADC_SQR2_SQ9_Pos (24U)
3523#define ADC_SQR2_SQ9_Msk (0x1FUL << ADC_SQR2_SQ9_Pos)
3524#define ADC_SQR2_SQ9 ADC_SQR2_SQ9_Msk
3525#define ADC_SQR2_SQ9_0 (0x01UL << ADC_SQR2_SQ9_Pos)
3526#define ADC_SQR2_SQ9_1 (0x02UL << ADC_SQR2_SQ9_Pos)
3527#define ADC_SQR2_SQ9_2 (0x04UL << ADC_SQR2_SQ9_Pos)
3528#define ADC_SQR2_SQ9_3 (0x08UL << ADC_SQR2_SQ9_Pos)
3529#define ADC_SQR2_SQ9_4 (0x10UL << ADC_SQR2_SQ9_Pos)
3531/******************** Bit definition for ADC_SQR3 register ********************/
3532#define ADC_SQR3_SQ10_Pos (0U)
3533#define ADC_SQR3_SQ10_Msk (0x1FUL << ADC_SQR3_SQ10_Pos)
3534#define ADC_SQR3_SQ10 ADC_SQR3_SQ10_Msk
3535#define ADC_SQR3_SQ10_0 (0x01UL << ADC_SQR3_SQ10_Pos)
3536#define ADC_SQR3_SQ10_1 (0x02UL << ADC_SQR3_SQ10_Pos)
3537#define ADC_SQR3_SQ10_2 (0x04UL << ADC_SQR3_SQ10_Pos)
3538#define ADC_SQR3_SQ10_3 (0x08UL << ADC_SQR3_SQ10_Pos)
3539#define ADC_SQR3_SQ10_4 (0x10UL << ADC_SQR3_SQ10_Pos)
3541#define ADC_SQR3_SQ11_Pos (6U)
3542#define ADC_SQR3_SQ11_Msk (0x1FUL << ADC_SQR3_SQ11_Pos)
3543#define ADC_SQR3_SQ11 ADC_SQR3_SQ11_Msk
3544#define ADC_SQR3_SQ11_0 (0x01UL << ADC_SQR3_SQ11_Pos)
3545#define ADC_SQR3_SQ11_1 (0x02UL << ADC_SQR3_SQ11_Pos)
3546#define ADC_SQR3_SQ11_2 (0x04UL << ADC_SQR3_SQ11_Pos)
3547#define ADC_SQR3_SQ11_3 (0x08UL << ADC_SQR3_SQ11_Pos)
3548#define ADC_SQR3_SQ11_4 (0x10UL << ADC_SQR3_SQ11_Pos)
3550#define ADC_SQR3_SQ12_Pos (12U)
3551#define ADC_SQR3_SQ12_Msk (0x1FUL << ADC_SQR3_SQ12_Pos)
3552#define ADC_SQR3_SQ12 ADC_SQR3_SQ12_Msk
3553#define ADC_SQR3_SQ12_0 (0x01UL << ADC_SQR3_SQ12_Pos)
3554#define ADC_SQR3_SQ12_1 (0x02UL << ADC_SQR3_SQ12_Pos)
3555#define ADC_SQR3_SQ12_2 (0x04UL << ADC_SQR3_SQ12_Pos)
3556#define ADC_SQR3_SQ12_3 (0x08UL << ADC_SQR3_SQ12_Pos)
3557#define ADC_SQR3_SQ12_4 (0x10UL << ADC_SQR3_SQ12_Pos)
3559#define ADC_SQR3_SQ13_Pos (18U)
3560#define ADC_SQR3_SQ13_Msk (0x1FUL << ADC_SQR3_SQ13_Pos)
3561#define ADC_SQR3_SQ13 ADC_SQR3_SQ13_Msk
3562#define ADC_SQR3_SQ13_0 (0x01UL << ADC_SQR3_SQ13_Pos)
3563#define ADC_SQR3_SQ13_1 (0x02UL << ADC_SQR3_SQ13_Pos)
3564#define ADC_SQR3_SQ13_2 (0x04UL << ADC_SQR3_SQ13_Pos)
3565#define ADC_SQR3_SQ13_3 (0x08UL << ADC_SQR3_SQ13_Pos)
3566#define ADC_SQR3_SQ13_4 (0x10UL << ADC_SQR3_SQ13_Pos)
3568#define ADC_SQR3_SQ14_Pos (24U)
3569#define ADC_SQR3_SQ14_Msk (0x1FUL << ADC_SQR3_SQ14_Pos)
3570#define ADC_SQR3_SQ14 ADC_SQR3_SQ14_Msk
3571#define ADC_SQR3_SQ14_0 (0x01UL << ADC_SQR3_SQ14_Pos)
3572#define ADC_SQR3_SQ14_1 (0x02UL << ADC_SQR3_SQ14_Pos)
3573#define ADC_SQR3_SQ14_2 (0x04UL << ADC_SQR3_SQ14_Pos)
3574#define ADC_SQR3_SQ14_3 (0x08UL << ADC_SQR3_SQ14_Pos)
3575#define ADC_SQR3_SQ14_4 (0x10UL << ADC_SQR3_SQ14_Pos)
3577/******************** Bit definition for ADC_SQR4 register ********************/
3578#define ADC_SQR4_SQ15_Pos (0U)
3579#define ADC_SQR4_SQ15_Msk (0x1FUL << ADC_SQR4_SQ15_Pos)
3580#define ADC_SQR4_SQ15 ADC_SQR4_SQ15_Msk
3581#define ADC_SQR4_SQ15_0 (0x01UL << ADC_SQR4_SQ15_Pos)
3582#define ADC_SQR4_SQ15_1 (0x02UL << ADC_SQR4_SQ15_Pos)
3583#define ADC_SQR4_SQ15_2 (0x04UL << ADC_SQR4_SQ15_Pos)
3584#define ADC_SQR4_SQ15_3 (0x08UL << ADC_SQR4_SQ15_Pos)
3585#define ADC_SQR4_SQ15_4 (0x10UL << ADC_SQR4_SQ15_Pos)
3587#define ADC_SQR4_SQ16_Pos (6U)
3588#define ADC_SQR4_SQ16_Msk (0x1FUL << ADC_SQR4_SQ16_Pos)
3589#define ADC_SQR4_SQ16 ADC_SQR4_SQ16_Msk
3590#define ADC_SQR4_SQ16_0 (0x01UL << ADC_SQR4_SQ16_Pos)
3591#define ADC_SQR4_SQ16_1 (0x02UL << ADC_SQR4_SQ16_Pos)
3592#define ADC_SQR4_SQ16_2 (0x04UL << ADC_SQR4_SQ16_Pos)
3593#define ADC_SQR4_SQ16_3 (0x08UL << ADC_SQR4_SQ16_Pos)
3594#define ADC_SQR4_SQ16_4 (0x10UL << ADC_SQR4_SQ16_Pos)
3595/******************** Bit definition for ADC_DR register ********************/
3596#define ADC_DR_RDATA_Pos (0U)
3597#define ADC_DR_RDATA_Msk (0xFFFFFFFFUL << ADC_DR_RDATA_Pos)
3598#define ADC_DR_RDATA ADC_DR_RDATA_Msk
3600/******************** Bit definition for ADC_JSQR register ********************/
3601#define ADC_JSQR_JL_Pos (0U)
3602#define ADC_JSQR_JL_Msk (0x3UL << ADC_JSQR_JL_Pos)
3603#define ADC_JSQR_JL ADC_JSQR_JL_Msk
3604#define ADC_JSQR_JL_0 (0x1UL << ADC_JSQR_JL_Pos)
3605#define ADC_JSQR_JL_1 (0x2UL << ADC_JSQR_JL_Pos)
3607#define ADC_JSQR_JEXTSEL_Pos (2U)
3608#define ADC_JSQR_JEXTSEL_Msk (0x1FUL << ADC_JSQR_JEXTSEL_Pos)
3609#define ADC_JSQR_JEXTSEL ADC_JSQR_JEXTSEL_Msk
3610#define ADC_JSQR_JEXTSEL_0 (0x01UL << ADC_JSQR_JEXTSEL_Pos)
3611#define ADC_JSQR_JEXTSEL_1 (0x02UL << ADC_JSQR_JEXTSEL_Pos)
3612#define ADC_JSQR_JEXTSEL_2 (0x04UL << ADC_JSQR_JEXTSEL_Pos)
3613#define ADC_JSQR_JEXTSEL_3 (0x08UL << ADC_JSQR_JEXTSEL_Pos)
3614#define ADC_JSQR_JEXTSEL_4 (0x10UL << ADC_JSQR_JEXTSEL_Pos)
3616#define ADC_JSQR_JEXTEN_Pos (7U)
3617#define ADC_JSQR_JEXTEN_Msk (0x3UL << ADC_JSQR_JEXTEN_Pos)
3618#define ADC_JSQR_JEXTEN ADC_JSQR_JEXTEN_Msk
3619#define ADC_JSQR_JEXTEN_0 (0x1UL << ADC_JSQR_JEXTEN_Pos)
3620#define ADC_JSQR_JEXTEN_1 (0x2UL << ADC_JSQR_JEXTEN_Pos)
3622#define ADC_JSQR_JSQ1_Pos (9U)
3623#define ADC_JSQR_JSQ1_Msk (0x1FUL << ADC_JSQR_JSQ1_Pos)
3624#define ADC_JSQR_JSQ1 ADC_JSQR_JSQ1_Msk
3625#define ADC_JSQR_JSQ1_0 (0x01UL << ADC_JSQR_JSQ1_Pos)
3626#define ADC_JSQR_JSQ1_1 (0x02UL << ADC_JSQR_JSQ1_Pos)
3627#define ADC_JSQR_JSQ1_2 (0x04UL << ADC_JSQR_JSQ1_Pos)
3628#define ADC_JSQR_JSQ1_3 (0x08UL << ADC_JSQR_JSQ1_Pos)
3629#define ADC_JSQR_JSQ1_4 (0x10UL << ADC_JSQR_JSQ1_Pos)
3631#define ADC_JSQR_JSQ2_Pos (15U)
3632#define ADC_JSQR_JSQ2_Msk (0x1FUL << ADC_JSQR_JSQ2_Pos)
3633#define ADC_JSQR_JSQ2 ADC_JSQR_JSQ2_Msk
3634#define ADC_JSQR_JSQ2_0 (0x01UL << ADC_JSQR_JSQ2_Pos)
3635#define ADC_JSQR_JSQ2_1 (0x02UL << ADC_JSQR_JSQ2_Pos)
3636#define ADC_JSQR_JSQ2_2 (0x04UL << ADC_JSQR_JSQ2_Pos)
3637#define ADC_JSQR_JSQ2_3 (0x08UL << ADC_JSQR_JSQ2_Pos)
3638#define ADC_JSQR_JSQ2_4 (0x10UL << ADC_JSQR_JSQ2_Pos)
3640#define ADC_JSQR_JSQ3_Pos (21U)
3641#define ADC_JSQR_JSQ3_Msk (0x1FUL << ADC_JSQR_JSQ3_Pos)
3642#define ADC_JSQR_JSQ3 ADC_JSQR_JSQ3_Msk
3643#define ADC_JSQR_JSQ3_0 (0x01UL << ADC_JSQR_JSQ3_Pos)
3644#define ADC_JSQR_JSQ3_1 (0x02UL << ADC_JSQR_JSQ3_Pos)
3645#define ADC_JSQR_JSQ3_2 (0x04UL << ADC_JSQR_JSQ3_Pos)
3646#define ADC_JSQR_JSQ3_3 (0x08UL << ADC_JSQR_JSQ3_Pos)
3647#define ADC_JSQR_JSQ3_4 (0x10UL << ADC_JSQR_JSQ3_Pos)
3649#define ADC_JSQR_JSQ4_Pos (27U)
3650#define ADC_JSQR_JSQ4_Msk (0x1FUL << ADC_JSQR_JSQ4_Pos)
3651#define ADC_JSQR_JSQ4 ADC_JSQR_JSQ4_Msk
3652#define ADC_JSQR_JSQ4_0 (0x01UL << ADC_JSQR_JSQ4_Pos)
3653#define ADC_JSQR_JSQ4_1 (0x02UL << ADC_JSQR_JSQ4_Pos)
3654#define ADC_JSQR_JSQ4_2 (0x04UL << ADC_JSQR_JSQ4_Pos)
3655#define ADC_JSQR_JSQ4_3 (0x08UL << ADC_JSQR_JSQ4_Pos)
3656#define ADC_JSQR_JSQ4_4 (0x10UL << ADC_JSQR_JSQ4_Pos)
3658/******************** Bit definition for ADC_OFR1 register ********************/
3659#define ADC_OFR1_OFFSET1_Pos (0U)
3660#define ADC_OFR1_OFFSET1_Msk (0x3FFFFFFUL << ADC_OFR1_OFFSET1_Pos)
3661#define ADC_OFR1_OFFSET1 ADC_OFR1_OFFSET1_Msk
3662#define ADC_OFR1_OFFSET1_0 (0x0000001UL << ADC_OFR1_OFFSET1_Pos)
3663#define ADC_OFR1_OFFSET1_1 (0x0000002UL << ADC_OFR1_OFFSET1_Pos)
3664#define ADC_OFR1_OFFSET1_2 (0x0000004UL << ADC_OFR1_OFFSET1_Pos)
3665#define ADC_OFR1_OFFSET1_3 (0x0000008UL << ADC_OFR1_OFFSET1_Pos)
3666#define ADC_OFR1_OFFSET1_4 (0x0000010UL << ADC_OFR1_OFFSET1_Pos)
3667#define ADC_OFR1_OFFSET1_5 (0x0000020UL << ADC_OFR1_OFFSET1_Pos)
3668#define ADC_OFR1_OFFSET1_6 (0x0000040UL << ADC_OFR1_OFFSET1_Pos)
3669#define ADC_OFR1_OFFSET1_7 (0x0000080UL << ADC_OFR1_OFFSET1_Pos)
3670#define ADC_OFR1_OFFSET1_8 (0x0000100UL << ADC_OFR1_OFFSET1_Pos)
3671#define ADC_OFR1_OFFSET1_9 (0x0000200UL << ADC_OFR1_OFFSET1_Pos)
3672#define ADC_OFR1_OFFSET1_10 (0x0000400UL << ADC_OFR1_OFFSET1_Pos)
3673#define ADC_OFR1_OFFSET1_11 (0x0000800UL << ADC_OFR1_OFFSET1_Pos)
3674#define ADC_OFR1_OFFSET1_12 (0x0001000UL << ADC_OFR1_OFFSET1_Pos)
3675#define ADC_OFR1_OFFSET1_13 (0x0002000UL << ADC_OFR1_OFFSET1_Pos)
3676#define ADC_OFR1_OFFSET1_14 (0x0004000UL << ADC_OFR1_OFFSET1_Pos)
3677#define ADC_OFR1_OFFSET1_15 (0x0008000UL << ADC_OFR1_OFFSET1_Pos)
3678#define ADC_OFR1_OFFSET1_16 (0x0010000UL << ADC_OFR1_OFFSET1_Pos)
3679#define ADC_OFR1_OFFSET1_17 (0x0020000UL << ADC_OFR1_OFFSET1_Pos)
3680#define ADC_OFR1_OFFSET1_18 (0x0040000UL << ADC_OFR1_OFFSET1_Pos)
3681#define ADC_OFR1_OFFSET1_19 (0x0080000UL << ADC_OFR1_OFFSET1_Pos)
3682#define ADC_OFR1_OFFSET1_20 (0x0100000UL << ADC_OFR1_OFFSET1_Pos)
3683#define ADC_OFR1_OFFSET1_21 (0x0200000UL << ADC_OFR1_OFFSET1_Pos)
3684#define ADC_OFR1_OFFSET1_22 (0x0400000UL << ADC_OFR1_OFFSET1_Pos)
3685#define ADC_OFR1_OFFSET1_23 (0x0800000UL << ADC_OFR1_OFFSET1_Pos)
3686#define ADC_OFR1_OFFSET1_24 (0x1000000UL << ADC_OFR1_OFFSET1_Pos)
3687#define ADC_OFR1_OFFSET1_25 (0x2000000UL << ADC_OFR1_OFFSET1_Pos)
3689#define ADC_OFR1_OFFSET1_CH_Pos (26U)
3690#define ADC_OFR1_OFFSET1_CH_Msk (0x1FUL << ADC_OFR1_OFFSET1_CH_Pos)
3691#define ADC_OFR1_OFFSET1_CH ADC_OFR1_OFFSET1_CH_Msk
3692#define ADC_OFR1_OFFSET1_CH_0 (0x01UL << ADC_OFR1_OFFSET1_CH_Pos)
3693#define ADC_OFR1_OFFSET1_CH_1 (0x02UL << ADC_OFR1_OFFSET1_CH_Pos)
3694#define ADC_OFR1_OFFSET1_CH_2 (0x04UL << ADC_OFR1_OFFSET1_CH_Pos)
3695#define ADC_OFR1_OFFSET1_CH_3 (0x08UL << ADC_OFR1_OFFSET1_CH_Pos)
3696#define ADC_OFR1_OFFSET1_CH_4 (0x10UL << ADC_OFR1_OFFSET1_CH_Pos)
3698#define ADC_OFR1_SSATE_Pos (31U)
3699#define ADC_OFR1_SSATE_Msk (0x1UL << ADC_OFR1_SSATE_Pos)
3700#define ADC_OFR1_SSATE ADC_OFR1_SSATE_Msk
3703/******************** Bit definition for ADC_OFR2 register ********************/
3704#define ADC_OFR2_OFFSET2_Pos (0U)
3705#define ADC_OFR2_OFFSET2_Msk (0x3FFFFFFUL << ADC_OFR2_OFFSET2_Pos)
3706#define ADC_OFR2_OFFSET2 ADC_OFR2_OFFSET2_Msk
3707#define ADC_OFR2_OFFSET2_0 (0x0000001UL << ADC_OFR2_OFFSET2_Pos)
3708#define ADC_OFR2_OFFSET2_1 (0x0000002UL << ADC_OFR2_OFFSET2_Pos)
3709#define ADC_OFR2_OFFSET2_2 (0x0000004UL << ADC_OFR2_OFFSET2_Pos)
3710#define ADC_OFR2_OFFSET2_3 (0x0000008UL << ADC_OFR2_OFFSET2_Pos)
3711#define ADC_OFR2_OFFSET2_4 (0x0000010UL << ADC_OFR2_OFFSET2_Pos)
3712#define ADC_OFR2_OFFSET2_5 (0x0000020UL << ADC_OFR2_OFFSET2_Pos)
3713#define ADC_OFR2_OFFSET2_6 (0x0000040UL << ADC_OFR2_OFFSET2_Pos)
3714#define ADC_OFR2_OFFSET2_7 (0x0000080UL << ADC_OFR2_OFFSET2_Pos)
3715#define ADC_OFR2_OFFSET2_8 (0x0000100UL << ADC_OFR2_OFFSET2_Pos)
3716#define ADC_OFR2_OFFSET2_9 (0x0000200UL << ADC_OFR2_OFFSET2_Pos)
3717#define ADC_OFR2_OFFSET2_10 (0x0000400UL << ADC_OFR2_OFFSET2_Pos)
3718#define ADC_OFR2_OFFSET2_11 (0x0000800UL << ADC_OFR2_OFFSET2_Pos)
3719#define ADC_OFR2_OFFSET2_12 (0x0001000UL << ADC_OFR2_OFFSET2_Pos)
3720#define ADC_OFR2_OFFSET2_13 (0x0002000UL << ADC_OFR2_OFFSET2_Pos)
3721#define ADC_OFR2_OFFSET2_14 (0x0004000UL << ADC_OFR2_OFFSET2_Pos)
3722#define ADC_OFR2_OFFSET2_15 (0x0008000UL << ADC_OFR2_OFFSET2_Pos)
3723#define ADC_OFR2_OFFSET2_16 (0x0010000UL << ADC_OFR2_OFFSET2_Pos)
3724#define ADC_OFR2_OFFSET2_17 (0x0020000UL << ADC_OFR2_OFFSET2_Pos)
3725#define ADC_OFR2_OFFSET2_18 (0x0040000UL << ADC_OFR2_OFFSET2_Pos)
3726#define ADC_OFR2_OFFSET2_19 (0x0080000UL << ADC_OFR2_OFFSET2_Pos)
3727#define ADC_OFR2_OFFSET2_20 (0x0100000UL << ADC_OFR2_OFFSET2_Pos)
3728#define ADC_OFR2_OFFSET2_21 (0x0200000UL << ADC_OFR2_OFFSET2_Pos)
3729#define ADC_OFR2_OFFSET2_22 (0x0400000UL << ADC_OFR2_OFFSET2_Pos)
3730#define ADC_OFR2_OFFSET2_23 (0x0800000UL << ADC_OFR2_OFFSET2_Pos)
3731#define ADC_OFR2_OFFSET2_24 (0x1000000UL << ADC_OFR2_OFFSET2_Pos)
3732#define ADC_OFR2_OFFSET2_25 (0x2000000UL << ADC_OFR2_OFFSET2_Pos)
3734#define ADC_OFR2_OFFSET2_CH_Pos (26U)
3735#define ADC_OFR2_OFFSET2_CH_Msk (0x1FUL << ADC_OFR2_OFFSET2_CH_Pos)
3736#define ADC_OFR2_OFFSET2_CH ADC_OFR2_OFFSET2_CH_Msk
3737#define ADC_OFR2_OFFSET2_CH_0 (0x01UL << ADC_OFR2_OFFSET2_CH_Pos)
3738#define ADC_OFR2_OFFSET2_CH_1 (0x02UL << ADC_OFR2_OFFSET2_CH_Pos)
3739#define ADC_OFR2_OFFSET2_CH_2 (0x04UL << ADC_OFR2_OFFSET2_CH_Pos)
3740#define ADC_OFR2_OFFSET2_CH_3 (0x08UL << ADC_OFR2_OFFSET2_CH_Pos)
3741#define ADC_OFR2_OFFSET2_CH_4 (0x10UL << ADC_OFR2_OFFSET2_CH_Pos)
3743#define ADC_OFR2_SSATE_Pos (31U)
3744#define ADC_OFR2_SSATE_Msk (0x1UL << ADC_OFR2_SSATE_Pos)
3745#define ADC_OFR2_SSATE ADC_OFR2_SSATE_Msk
3748/******************** Bit definition for ADC_OFR3 register ********************/
3749#define ADC_OFR3_OFFSET3_Pos (0U)
3750#define ADC_OFR3_OFFSET3_Msk (0x3FFFFFFUL << ADC_OFR3_OFFSET3_Pos)
3751#define ADC_OFR3_OFFSET3 ADC_OFR3_OFFSET3_Msk
3752#define ADC_OFR3_OFFSET3_0 (0x0000001UL << ADC_OFR3_OFFSET3_Pos)
3753#define ADC_OFR3_OFFSET3_1 (0x0000002UL << ADC_OFR3_OFFSET3_Pos)
3754#define ADC_OFR3_OFFSET3_2 (0x0000004UL << ADC_OFR3_OFFSET3_Pos)
3755#define ADC_OFR3_OFFSET3_3 (0x0000008UL << ADC_OFR3_OFFSET3_Pos)
3756#define ADC_OFR3_OFFSET3_4 (0x0000010UL << ADC_OFR3_OFFSET3_Pos)
3757#define ADC_OFR3_OFFSET3_5 (0x0000020UL << ADC_OFR3_OFFSET3_Pos)
3758#define ADC_OFR3_OFFSET3_6 (0x0000040UL << ADC_OFR3_OFFSET3_Pos)
3759#define ADC_OFR3_OFFSET3_7 (0x0000080UL << ADC_OFR3_OFFSET3_Pos)
3760#define ADC_OFR3_OFFSET3_8 (0x0000100UL << ADC_OFR3_OFFSET3_Pos)
3761#define ADC_OFR3_OFFSET3_9 (0x0000200UL << ADC_OFR3_OFFSET3_Pos)
3762#define ADC_OFR3_OFFSET3_10 (0x0000400UL << ADC_OFR3_OFFSET3_Pos)
3763#define ADC_OFR3_OFFSET3_11 (0x0000800UL << ADC_OFR3_OFFSET3_Pos)
3764#define ADC_OFR3_OFFSET3_12 (0x0001000UL << ADC_OFR3_OFFSET3_Pos)
3765#define ADC_OFR3_OFFSET3_13 (0x0002000UL << ADC_OFR3_OFFSET3_Pos)
3766#define ADC_OFR3_OFFSET3_14 (0x0004000UL << ADC_OFR3_OFFSET3_Pos)
3767#define ADC_OFR3_OFFSET3_15 (0x0008000UL << ADC_OFR3_OFFSET3_Pos)
3768#define ADC_OFR3_OFFSET3_16 (0x0010000UL << ADC_OFR3_OFFSET3_Pos)
3769#define ADC_OFR3_OFFSET3_17 (0x0020000UL << ADC_OFR3_OFFSET3_Pos)
3770#define ADC_OFR3_OFFSET3_18 (0x0040000UL << ADC_OFR3_OFFSET3_Pos)
3771#define ADC_OFR3_OFFSET3_19 (0x0080000UL << ADC_OFR3_OFFSET3_Pos)
3772#define ADC_OFR3_OFFSET3_20 (0x0100000UL << ADC_OFR3_OFFSET3_Pos)
3773#define ADC_OFR3_OFFSET3_21 (0x0200000UL << ADC_OFR3_OFFSET3_Pos)
3774#define ADC_OFR3_OFFSET3_22 (0x0400000UL << ADC_OFR3_OFFSET3_Pos)
3775#define ADC_OFR3_OFFSET3_23 (0x0800000UL << ADC_OFR3_OFFSET3_Pos)
3776#define ADC_OFR3_OFFSET3_24 (0x1000000UL << ADC_OFR3_OFFSET3_Pos)
3777#define ADC_OFR3_OFFSET3_25 (0x2000000UL << ADC_OFR3_OFFSET3_Pos)
3779#define ADC_OFR3_OFFSET3_CH_Pos (26U)
3780#define ADC_OFR3_OFFSET3_CH_Msk (0x1FUL << ADC_OFR3_OFFSET3_CH_Pos)
3781#define ADC_OFR3_OFFSET3_CH ADC_OFR3_OFFSET3_CH_Msk
3782#define ADC_OFR3_OFFSET3_CH_0 (0x01UL << ADC_OFR3_OFFSET3_CH_Pos)
3783#define ADC_OFR3_OFFSET3_CH_1 (0x02UL << ADC_OFR3_OFFSET3_CH_Pos)
3784#define ADC_OFR3_OFFSET3_CH_2 (0x04UL << ADC_OFR3_OFFSET3_CH_Pos)
3785#define ADC_OFR3_OFFSET3_CH_3 (0x08UL << ADC_OFR3_OFFSET3_CH_Pos)
3786#define ADC_OFR3_OFFSET3_CH_4 (0x10UL << ADC_OFR3_OFFSET3_CH_Pos)
3788#define ADC_OFR3_SSATE_Pos (31U)
3789#define ADC_OFR3_SSATE_Msk (0x1UL << ADC_OFR3_SSATE_Pos)
3790#define ADC_OFR3_SSATE ADC_OFR3_SSATE_Msk
3793/******************** Bit definition for ADC_OFR4 register ********************/
3794#define ADC_OFR4_OFFSET4_Pos (0U)
3795#define ADC_OFR4_OFFSET4_Msk (0x3FFFFFFUL << ADC_OFR4_OFFSET4_Pos)
3796#define ADC_OFR4_OFFSET4 ADC_OFR4_OFFSET4_Msk
3797#define ADC_OFR4_OFFSET4_0 (0x0000001UL << ADC_OFR4_OFFSET4_Pos)
3798#define ADC_OFR4_OFFSET4_1 (0x0000002UL << ADC_OFR4_OFFSET4_Pos)
3799#define ADC_OFR4_OFFSET4_2 (0x0000004UL << ADC_OFR4_OFFSET4_Pos)
3800#define ADC_OFR4_OFFSET4_3 (0x0000008UL << ADC_OFR4_OFFSET4_Pos)
3801#define ADC_OFR4_OFFSET4_4 (0x0000010UL << ADC_OFR4_OFFSET4_Pos)
3802#define ADC_OFR4_OFFSET4_5 (0x0000020UL << ADC_OFR4_OFFSET4_Pos)
3803#define ADC_OFR4_OFFSET4_6 (0x0000040UL << ADC_OFR4_OFFSET4_Pos)
3804#define ADC_OFR4_OFFSET4_7 (0x0000080UL << ADC_OFR4_OFFSET4_Pos)
3805#define ADC_OFR4_OFFSET4_8 (0x0000100UL << ADC_OFR4_OFFSET4_Pos)
3806#define ADC_OFR4_OFFSET4_9 (0x0000200UL << ADC_OFR4_OFFSET4_Pos)
3807#define ADC_OFR4_OFFSET4_10 (0x0000400UL << ADC_OFR4_OFFSET4_Pos)
3808#define ADC_OFR4_OFFSET4_11 (0x0000800UL << ADC_OFR4_OFFSET4_Pos)
3809#define ADC_OFR4_OFFSET4_12 (0x0001000UL << ADC_OFR4_OFFSET4_Pos)
3810#define ADC_OFR4_OFFSET4_13 (0x0002000UL << ADC_OFR4_OFFSET4_Pos)
3811#define ADC_OFR4_OFFSET4_14 (0x0004000UL << ADC_OFR4_OFFSET4_Pos)
3812#define ADC_OFR4_OFFSET4_15 (0x0008000UL << ADC_OFR4_OFFSET4_Pos)
3813#define ADC_OFR4_OFFSET4_16 (0x0010000UL << ADC_OFR4_OFFSET4_Pos)
3814#define ADC_OFR4_OFFSET4_17 (0x0020000UL << ADC_OFR4_OFFSET4_Pos)
3815#define ADC_OFR4_OFFSET4_18 (0x0040000UL << ADC_OFR4_OFFSET4_Pos)
3816#define ADC_OFR4_OFFSET4_19 (0x0080000UL << ADC_OFR4_OFFSET4_Pos)
3817#define ADC_OFR4_OFFSET4_20 (0x0100000UL << ADC_OFR4_OFFSET4_Pos)
3818#define ADC_OFR4_OFFSET4_21 (0x0200000UL << ADC_OFR4_OFFSET4_Pos)
3819#define ADC_OFR4_OFFSET4_22 (0x0400000UL << ADC_OFR4_OFFSET4_Pos)
3820#define ADC_OFR4_OFFSET4_23 (0x0800000UL << ADC_OFR4_OFFSET4_Pos)
3821#define ADC_OFR4_OFFSET4_24 (0x1000000UL << ADC_OFR4_OFFSET4_Pos)
3822#define ADC_OFR4_OFFSET4_25 (0x2000000UL << ADC_OFR4_OFFSET4_Pos)
3824#define ADC_OFR4_OFFSET4_CH_Pos (26U)
3825#define ADC_OFR4_OFFSET4_CH_Msk (0x1FUL << ADC_OFR4_OFFSET4_CH_Pos)
3826#define ADC_OFR4_OFFSET4_CH ADC_OFR4_OFFSET4_CH_Msk
3827#define ADC_OFR4_OFFSET4_CH_0 (0x01UL << ADC_OFR4_OFFSET4_CH_Pos)
3828#define ADC_OFR4_OFFSET4_CH_1 (0x02UL << ADC_OFR4_OFFSET4_CH_Pos)
3829#define ADC_OFR4_OFFSET4_CH_2 (0x04UL << ADC_OFR4_OFFSET4_CH_Pos)
3830#define ADC_OFR4_OFFSET4_CH_3 (0x08UL << ADC_OFR4_OFFSET4_CH_Pos)
3831#define ADC_OFR4_OFFSET4_CH_4 (0x10UL << ADC_OFR4_OFFSET4_CH_Pos)
3833#define ADC_OFR4_SSATE_Pos (31U)
3834#define ADC_OFR4_SSATE_Msk (0x1UL << ADC_OFR4_SSATE_Pos)
3835#define ADC_OFR4_SSATE ADC_OFR4_SSATE_Msk
3838/******************** Bit definition for ADC_JDR1 register ********************/
3839#define ADC_JDR1_JDATA_Pos (0U)
3840#define ADC_JDR1_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR1_JDATA_Pos)
3841#define ADC_JDR1_JDATA ADC_JDR1_JDATA_Msk
3842#define ADC_JDR1_JDATA_0 (0x00000001UL << ADC_JDR1_JDATA_Pos)
3843#define ADC_JDR1_JDATA_1 (0x00000002UL << ADC_JDR1_JDATA_Pos)
3844#define ADC_JDR1_JDATA_2 (0x00000004UL << ADC_JDR1_JDATA_Pos)
3845#define ADC_JDR1_JDATA_3 (0x00000008UL << ADC_JDR1_JDATA_Pos)
3846#define ADC_JDR1_JDATA_4 (0x00000010UL << ADC_JDR1_JDATA_Pos)
3847#define ADC_JDR1_JDATA_5 (0x00000020UL << ADC_JDR1_JDATA_Pos)
3848#define ADC_JDR1_JDATA_6 (0x00000040UL << ADC_JDR1_JDATA_Pos)
3849#define ADC_JDR1_JDATA_7 (0x00000080UL << ADC_JDR1_JDATA_Pos)
3850#define ADC_JDR1_JDATA_8 (0x00000100UL << ADC_JDR1_JDATA_Pos)
3851#define ADC_JDR1_JDATA_9 (0x00000200UL << ADC_JDR1_JDATA_Pos)
3852#define ADC_JDR1_JDATA_10 (0x00000400UL << ADC_JDR1_JDATA_Pos)
3853#define ADC_JDR1_JDATA_11 (0x00000800UL << ADC_JDR1_JDATA_Pos)
3854#define ADC_JDR1_JDATA_12 (0x00001000UL << ADC_JDR1_JDATA_Pos)
3855#define ADC_JDR1_JDATA_13 (0x00002000UL << ADC_JDR1_JDATA_Pos)
3856#define ADC_JDR1_JDATA_14 (0x00004000UL << ADC_JDR1_JDATA_Pos)
3857#define ADC_JDR1_JDATA_15 (0x00008000UL << ADC_JDR1_JDATA_Pos)
3858#define ADC_JDR1_JDATA_16 (0x00010000UL << ADC_JDR1_JDATA_Pos)
3859#define ADC_JDR1_JDATA_17 (0x00020000UL << ADC_JDR1_JDATA_Pos)
3860#define ADC_JDR1_JDATA_18 (0x00040000UL << ADC_JDR1_JDATA_Pos)
3861#define ADC_JDR1_JDATA_19 (0x00080000UL << ADC_JDR1_JDATA_Pos)
3862#define ADC_JDR1_JDATA_20 (0x00100000UL << ADC_JDR1_JDATA_Pos)
3863#define ADC_JDR1_JDATA_21 (0x00200000UL << ADC_JDR1_JDATA_Pos)
3864#define ADC_JDR1_JDATA_22 (0x00400000UL << ADC_JDR1_JDATA_Pos)
3865#define ADC_JDR1_JDATA_23 (0x00800000UL << ADC_JDR1_JDATA_Pos)
3866#define ADC_JDR1_JDATA_24 (0x01000000UL << ADC_JDR1_JDATA_Pos)
3867#define ADC_JDR1_JDATA_25 (0x02000000UL << ADC_JDR1_JDATA_Pos)
3868#define ADC_JDR1_JDATA_26 (0x04000000UL << ADC_JDR1_JDATA_Pos)
3869#define ADC_JDR1_JDATA_27 (0x08000000UL << ADC_JDR1_JDATA_Pos)
3870#define ADC_JDR1_JDATA_28 (0x10000000UL << ADC_JDR1_JDATA_Pos)
3871#define ADC_JDR1_JDATA_29 (0x20000000UL << ADC_JDR1_JDATA_Pos)
3872#define ADC_JDR1_JDATA_30 (0x40000000UL << ADC_JDR1_JDATA_Pos)
3873#define ADC_JDR1_JDATA_31 (0x80000000UL << ADC_JDR1_JDATA_Pos)
3875/******************** Bit definition for ADC_JDR2 register ********************/
3876#define ADC_JDR2_JDATA_Pos (0U)
3877#define ADC_JDR2_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR2_JDATA_Pos)
3878#define ADC_JDR2_JDATA ADC_JDR2_JDATA_Msk
3879#define ADC_JDR2_JDATA_0 (0x00000001UL << ADC_JDR2_JDATA_Pos)
3880#define ADC_JDR2_JDATA_1 (0x00000002UL << ADC_JDR2_JDATA_Pos)
3881#define ADC_JDR2_JDATA_2 (0x00000004UL << ADC_JDR2_JDATA_Pos)
3882#define ADC_JDR2_JDATA_3 (0x00000008UL << ADC_JDR2_JDATA_Pos)
3883#define ADC_JDR2_JDATA_4 (0x00000010UL << ADC_JDR2_JDATA_Pos)
3884#define ADC_JDR2_JDATA_5 (0x00000020UL << ADC_JDR2_JDATA_Pos)
3885#define ADC_JDR2_JDATA_6 (0x00000040UL << ADC_JDR2_JDATA_Pos)
3886#define ADC_JDR2_JDATA_7 (0x00000080UL << ADC_JDR2_JDATA_Pos)
3887#define ADC_JDR2_JDATA_8 (0x00000100UL << ADC_JDR2_JDATA_Pos)
3888#define ADC_JDR2_JDATA_9 (0x00000200UL << ADC_JDR2_JDATA_Pos)
3889#define ADC_JDR2_JDATA_10 (0x00000400UL << ADC_JDR2_JDATA_Pos)
3890#define ADC_JDR2_JDATA_11 (0x00000800UL << ADC_JDR2_JDATA_Pos)
3891#define ADC_JDR2_JDATA_12 (0x00001000UL << ADC_JDR2_JDATA_Pos)
3892#define ADC_JDR2_JDATA_13 (0x00002000UL << ADC_JDR2_JDATA_Pos)
3893#define ADC_JDR2_JDATA_14 (0x00004000UL << ADC_JDR2_JDATA_Pos)
3894#define ADC_JDR2_JDATA_15 (0x00008000UL << ADC_JDR2_JDATA_Pos)
3895#define ADC_JDR2_JDATA_16 (0x00010000UL << ADC_JDR2_JDATA_Pos)
3896#define ADC_JDR2_JDATA_17 (0x00020000UL << ADC_JDR2_JDATA_Pos)
3897#define ADC_JDR2_JDATA_18 (0x00040000UL << ADC_JDR2_JDATA_Pos)
3898#define ADC_JDR2_JDATA_19 (0x00080000UL << ADC_JDR2_JDATA_Pos)
3899#define ADC_JDR2_JDATA_20 (0x00100000UL << ADC_JDR2_JDATA_Pos)
3900#define ADC_JDR2_JDATA_21 (0x00200000UL << ADC_JDR2_JDATA_Pos)
3901#define ADC_JDR2_JDATA_22 (0x00400000UL << ADC_JDR2_JDATA_Pos)
3902#define ADC_JDR2_JDATA_23 (0x00800000UL << ADC_JDR2_JDATA_Pos)
3903#define ADC_JDR2_JDATA_24 (0x01000000UL << ADC_JDR2_JDATA_Pos)
3904#define ADC_JDR2_JDATA_25 (0x02000000UL << ADC_JDR2_JDATA_Pos)
3905#define ADC_JDR2_JDATA_26 (0x04000000UL << ADC_JDR2_JDATA_Pos)
3906#define ADC_JDR2_JDATA_27 (0x08000000UL << ADC_JDR2_JDATA_Pos)
3907#define ADC_JDR2_JDATA_28 (0x10000000UL << ADC_JDR2_JDATA_Pos)
3908#define ADC_JDR2_JDATA_29 (0x20000000UL << ADC_JDR2_JDATA_Pos)
3909#define ADC_JDR2_JDATA_30 (0x40000000UL << ADC_JDR2_JDATA_Pos)
3910#define ADC_JDR2_JDATA_31 (0x80000000UL << ADC_JDR2_JDATA_Pos)
3912/******************** Bit definition for ADC_JDR3 register ********************/
3913#define ADC_JDR3_JDATA_Pos (0U)
3914#define ADC_JDR3_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR3_JDATA_Pos)
3915#define ADC_JDR3_JDATA ADC_JDR3_JDATA_Msk
3916#define ADC_JDR3_JDATA_0 (0x00000001UL << ADC_JDR3_JDATA_Pos)
3917#define ADC_JDR3_JDATA_1 (0x00000002UL << ADC_JDR3_JDATA_Pos)
3918#define ADC_JDR3_JDATA_2 (0x00000004UL << ADC_JDR3_JDATA_Pos)
3919#define ADC_JDR3_JDATA_3 (0x00000008UL << ADC_JDR3_JDATA_Pos)
3920#define ADC_JDR3_JDATA_4 (0x00000010UL << ADC_JDR3_JDATA_Pos)
3921#define ADC_JDR3_JDATA_5 (0x00000020UL << ADC_JDR3_JDATA_Pos)
3922#define ADC_JDR3_JDATA_6 (0x00000040UL << ADC_JDR3_JDATA_Pos)
3923#define ADC_JDR3_JDATA_7 (0x00000080UL << ADC_JDR3_JDATA_Pos)
3924#define ADC_JDR3_JDATA_8 (0x00000100UL << ADC_JDR3_JDATA_Pos)
3925#define ADC_JDR3_JDATA_9 (0x00000200UL << ADC_JDR3_JDATA_Pos)
3926#define ADC_JDR3_JDATA_10 (0x00000400UL << ADC_JDR3_JDATA_Pos)
3927#define ADC_JDR3_JDATA_11 (0x00000800UL << ADC_JDR3_JDATA_Pos)
3928#define ADC_JDR3_JDATA_12 (0x00001000UL << ADC_JDR3_JDATA_Pos)
3929#define ADC_JDR3_JDATA_13 (0x00002000UL << ADC_JDR3_JDATA_Pos)
3930#define ADC_JDR3_JDATA_14 (0x00004000UL << ADC_JDR3_JDATA_Pos)
3931#define ADC_JDR3_JDATA_15 (0x00008000UL << ADC_JDR3_JDATA_Pos)
3932#define ADC_JDR3_JDATA_16 (0x00010000UL << ADC_JDR3_JDATA_Pos)
3933#define ADC_JDR3_JDATA_17 (0x00020000UL << ADC_JDR3_JDATA_Pos)
3934#define ADC_JDR3_JDATA_18 (0x00040000UL << ADC_JDR3_JDATA_Pos)
3935#define ADC_JDR3_JDATA_19 (0x00080000UL << ADC_JDR3_JDATA_Pos)
3936#define ADC_JDR3_JDATA_20 (0x00100000UL << ADC_JDR3_JDATA_Pos)
3937#define ADC_JDR3_JDATA_21 (0x00200000UL << ADC_JDR3_JDATA_Pos)
3938#define ADC_JDR3_JDATA_22 (0x00400000UL << ADC_JDR3_JDATA_Pos)
3939#define ADC_JDR3_JDATA_23 (0x00800000UL << ADC_JDR3_JDATA_Pos)
3940#define ADC_JDR3_JDATA_24 (0x01000000UL << ADC_JDR3_JDATA_Pos)
3941#define ADC_JDR3_JDATA_25 (0x02000000UL << ADC_JDR3_JDATA_Pos)
3942#define ADC_JDR3_JDATA_26 (0x04000000UL << ADC_JDR3_JDATA_Pos)
3943#define ADC_JDR3_JDATA_27 (0x08000000UL << ADC_JDR3_JDATA_Pos)
3944#define ADC_JDR3_JDATA_28 (0x10000000UL << ADC_JDR3_JDATA_Pos)
3945#define ADC_JDR3_JDATA_29 (0x20000000UL << ADC_JDR3_JDATA_Pos)
3946#define ADC_JDR3_JDATA_30 (0x40000000UL << ADC_JDR3_JDATA_Pos)
3947#define ADC_JDR3_JDATA_31 (0x80000000UL << ADC_JDR3_JDATA_Pos)
3949/******************** Bit definition for ADC_JDR4 register ********************/
3950#define ADC_JDR4_JDATA_Pos (0U)
3951#define ADC_JDR4_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR4_JDATA_Pos)
3952#define ADC_JDR4_JDATA ADC_JDR4_JDATA_Msk
3953#define ADC_JDR4_JDATA_0 (0x00000001UL << ADC_JDR4_JDATA_Pos)
3954#define ADC_JDR4_JDATA_1 (0x00000002UL << ADC_JDR4_JDATA_Pos)
3955#define ADC_JDR4_JDATA_2 (0x00000004UL << ADC_JDR4_JDATA_Pos)
3956#define ADC_JDR4_JDATA_3 (0x00000008UL << ADC_JDR4_JDATA_Pos)
3957#define ADC_JDR4_JDATA_4 (0x00000010UL << ADC_JDR4_JDATA_Pos)
3958#define ADC_JDR4_JDATA_5 (0x00000020UL << ADC_JDR4_JDATA_Pos)
3959#define ADC_JDR4_JDATA_6 (0x00000040UL << ADC_JDR4_JDATA_Pos)
3960#define ADC_JDR4_JDATA_7 (0x00000080UL << ADC_JDR4_JDATA_Pos)
3961#define ADC_JDR4_JDATA_8 (0x00000100UL << ADC_JDR4_JDATA_Pos)
3962#define ADC_JDR4_JDATA_9 (0x00000200UL << ADC_JDR4_JDATA_Pos)
3963#define ADC_JDR4_JDATA_10 (0x00000400UL << ADC_JDR4_JDATA_Pos)
3964#define ADC_JDR4_JDATA_11 (0x00000800UL << ADC_JDR4_JDATA_Pos)
3965#define ADC_JDR4_JDATA_12 (0x00001000UL << ADC_JDR4_JDATA_Pos)
3966#define ADC_JDR4_JDATA_13 (0x00002000UL << ADC_JDR4_JDATA_Pos)
3967#define ADC_JDR4_JDATA_14 (0x00004000UL << ADC_JDR4_JDATA_Pos)
3968#define ADC_JDR4_JDATA_15 (0x00008000UL << ADC_JDR4_JDATA_Pos)
3969#define ADC_JDR4_JDATA_16 (0x00010000UL << ADC_JDR4_JDATA_Pos)
3970#define ADC_JDR4_JDATA_17 (0x00020000UL << ADC_JDR4_JDATA_Pos)
3971#define ADC_JDR4_JDATA_18 (0x00040000UL << ADC_JDR4_JDATA_Pos)
3972#define ADC_JDR4_JDATA_19 (0x00080000UL << ADC_JDR4_JDATA_Pos)
3973#define ADC_JDR4_JDATA_20 (0x00100000UL << ADC_JDR4_JDATA_Pos)
3974#define ADC_JDR4_JDATA_21 (0x00200000UL << ADC_JDR4_JDATA_Pos)
3975#define ADC_JDR4_JDATA_22 (0x00400000UL << ADC_JDR4_JDATA_Pos)
3976#define ADC_JDR4_JDATA_23 (0x00800000UL << ADC_JDR4_JDATA_Pos)
3977#define ADC_JDR4_JDATA_24 (0x01000000UL << ADC_JDR4_JDATA_Pos)
3978#define ADC_JDR4_JDATA_25 (0x02000000UL << ADC_JDR4_JDATA_Pos)
3979#define ADC_JDR4_JDATA_26 (0x04000000UL << ADC_JDR4_JDATA_Pos)
3980#define ADC_JDR4_JDATA_27 (0x08000000UL << ADC_JDR4_JDATA_Pos)
3981#define ADC_JDR4_JDATA_28 (0x10000000UL << ADC_JDR4_JDATA_Pos)
3982#define ADC_JDR4_JDATA_29 (0x20000000UL << ADC_JDR4_JDATA_Pos)
3983#define ADC_JDR4_JDATA_30 (0x40000000UL << ADC_JDR4_JDATA_Pos)
3984#define ADC_JDR4_JDATA_31 (0x80000000UL << ADC_JDR4_JDATA_Pos)
3986/******************** Bit definition for ADC_AWD2CR register ********************/
3987#define ADC_AWD2CR_AWD2CH_Pos (0U)
3988#define ADC_AWD2CR_AWD2CH_Msk (0xFFFFFUL << ADC_AWD2CR_AWD2CH_Pos)
3989#define ADC_AWD2CR_AWD2CH ADC_AWD2CR_AWD2CH_Msk
3990#define ADC_AWD2CR_AWD2CH_0 (0x00001UL << ADC_AWD2CR_AWD2CH_Pos)
3991#define ADC_AWD2CR_AWD2CH_1 (0x00002UL << ADC_AWD2CR_AWD2CH_Pos)
3992#define ADC_AWD2CR_AWD2CH_2 (0x00004UL << ADC_AWD2CR_AWD2CH_Pos)
3993#define ADC_AWD2CR_AWD2CH_3 (0x00008UL << ADC_AWD2CR_AWD2CH_Pos)
3994#define ADC_AWD2CR_AWD2CH_4 (0x00010UL << ADC_AWD2CR_AWD2CH_Pos)
3995#define ADC_AWD2CR_AWD2CH_5 (0x00020UL << ADC_AWD2CR_AWD2CH_Pos)
3996#define ADC_AWD2CR_AWD2CH_6 (0x00040UL << ADC_AWD2CR_AWD2CH_Pos)
3997#define ADC_AWD2CR_AWD2CH_7 (0x00080UL << ADC_AWD2CR_AWD2CH_Pos)
3998#define ADC_AWD2CR_AWD2CH_8 (0x00100UL << ADC_AWD2CR_AWD2CH_Pos)
3999#define ADC_AWD2CR_AWD2CH_9 (0x00200UL << ADC_AWD2CR_AWD2CH_Pos)
4000#define ADC_AWD2CR_AWD2CH_10 (0x00400UL << ADC_AWD2CR_AWD2CH_Pos)
4001#define ADC_AWD2CR_AWD2CH_11 (0x00800UL << ADC_AWD2CR_AWD2CH_Pos)
4002#define ADC_AWD2CR_AWD2CH_12 (0x01000UL << ADC_AWD2CR_AWD2CH_Pos)
4003#define ADC_AWD2CR_AWD2CH_13 (0x02000UL << ADC_AWD2CR_AWD2CH_Pos)
4004#define ADC_AWD2CR_AWD2CH_14 (0x04000UL << ADC_AWD2CR_AWD2CH_Pos)
4005#define ADC_AWD2CR_AWD2CH_15 (0x08000UL << ADC_AWD2CR_AWD2CH_Pos)
4006#define ADC_AWD2CR_AWD2CH_16 (0x10000UL << ADC_AWD2CR_AWD2CH_Pos)
4007#define ADC_AWD2CR_AWD2CH_17 (0x20000UL << ADC_AWD2CR_AWD2CH_Pos)
4008#define ADC_AWD2CR_AWD2CH_18 (0x40000UL << ADC_AWD2CR_AWD2CH_Pos)
4009#define ADC_AWD2CR_AWD2CH_19 (0x80000UL << ADC_AWD2CR_AWD2CH_Pos)
4011/******************** Bit definition for ADC_AWD3CR register ********************/
4012#define ADC_AWD3CR_AWD3CH_Pos (0U)
4013#define ADC_AWD3CR_AWD3CH_Msk (0xFFFFFUL << ADC_AWD3CR_AWD3CH_Pos)
4014#define ADC_AWD3CR_AWD3CH ADC_AWD3CR_AWD3CH_Msk
4015#define ADC_AWD3CR_AWD3CH_0 (0x00001UL << ADC_AWD3CR_AWD3CH_Pos)
4016#define ADC_AWD3CR_AWD3CH_1 (0x00002UL << ADC_AWD3CR_AWD3CH_Pos)
4017#define ADC_AWD3CR_AWD3CH_2 (0x00004UL << ADC_AWD3CR_AWD3CH_Pos)
4018#define ADC_AWD3CR_AWD3CH_3 (0x00008UL << ADC_AWD3CR_AWD3CH_Pos)
4019#define ADC_AWD3CR_AWD3CH_4 (0x00010UL << ADC_AWD3CR_AWD3CH_Pos)
4020#define ADC_AWD3CR_AWD3CH_5 (0x00020UL << ADC_AWD3CR_AWD3CH_Pos)
4021#define ADC_AWD3CR_AWD3CH_6 (0x00040UL << ADC_AWD3CR_AWD3CH_Pos)
4022#define ADC_AWD3CR_AWD3CH_7 (0x00080UL << ADC_AWD3CR_AWD3CH_Pos)
4023#define ADC_AWD3CR_AWD3CH_8 (0x00100UL << ADC_AWD3CR_AWD3CH_Pos)
4024#define ADC_AWD3CR_AWD3CH_9 (0x00200UL << ADC_AWD3CR_AWD3CH_Pos)
4025#define ADC_AWD3CR_AWD3CH_10 (0x00400UL << ADC_AWD3CR_AWD3CH_Pos)
4026#define ADC_AWD3CR_AWD3CH_11 (0x00800UL << ADC_AWD3CR_AWD3CH_Pos)
4027#define ADC_AWD3CR_AWD3CH_12 (0x01000UL << ADC_AWD3CR_AWD3CH_Pos)
4028#define ADC_AWD3CR_AWD3CH_13 (0x02000UL << ADC_AWD3CR_AWD3CH_Pos)
4029#define ADC_AWD3CR_AWD3CH_14 (0x04000UL << ADC_AWD3CR_AWD3CH_Pos)
4030#define ADC_AWD3CR_AWD3CH_15 (0x08000UL << ADC_AWD3CR_AWD3CH_Pos)
4031#define ADC_AWD3CR_AWD3CH_16 (0x10000UL << ADC_AWD3CR_AWD3CH_Pos)
4032#define ADC_AWD3CR_AWD3CH_17 (0x20000UL << ADC_AWD3CR_AWD3CH_Pos)
4033#define ADC_AWD3CR_AWD3CH_18 (0x40000UL << ADC_AWD3CR_AWD3CH_Pos)
4034#define ADC_AWD3CR_AWD3CH_19 (0x80000UL << ADC_AWD3CR_AWD3CH_Pos)
4036/******************** Bit definition for ADC_DIFSEL register ********************/
4037#define ADC_DIFSEL_DIFSEL_Pos (0U)
4038#define ADC_DIFSEL_DIFSEL_Msk (0xFFFFFUL << ADC_DIFSEL_DIFSEL_Pos)
4039#define ADC_DIFSEL_DIFSEL ADC_DIFSEL_DIFSEL_Msk
4040#define ADC_DIFSEL_DIFSEL_0 (0x00001UL << ADC_DIFSEL_DIFSEL_Pos)
4041#define ADC_DIFSEL_DIFSEL_1 (0x00002UL << ADC_DIFSEL_DIFSEL_Pos)
4042#define ADC_DIFSEL_DIFSEL_2 (0x00004UL << ADC_DIFSEL_DIFSEL_Pos)
4043#define ADC_DIFSEL_DIFSEL_3 (0x00008UL << ADC_DIFSEL_DIFSEL_Pos)
4044#define ADC_DIFSEL_DIFSEL_4 (0x00010UL << ADC_DIFSEL_DIFSEL_Pos)
4045#define ADC_DIFSEL_DIFSEL_5 (0x00020UL << ADC_DIFSEL_DIFSEL_Pos)
4046#define ADC_DIFSEL_DIFSEL_6 (0x00040UL << ADC_DIFSEL_DIFSEL_Pos)
4047#define ADC_DIFSEL_DIFSEL_7 (0x00080UL << ADC_DIFSEL_DIFSEL_Pos)
4048#define ADC_DIFSEL_DIFSEL_8 (0x00100UL << ADC_DIFSEL_DIFSEL_Pos)
4049#define ADC_DIFSEL_DIFSEL_9 (0x00200UL << ADC_DIFSEL_DIFSEL_Pos)
4050#define ADC_DIFSEL_DIFSEL_10 (0x00400UL << ADC_DIFSEL_DIFSEL_Pos)
4051#define ADC_DIFSEL_DIFSEL_11 (0x00800UL << ADC_DIFSEL_DIFSEL_Pos)
4052#define ADC_DIFSEL_DIFSEL_12 (0x01000UL << ADC_DIFSEL_DIFSEL_Pos)
4053#define ADC_DIFSEL_DIFSEL_13 (0x02000UL << ADC_DIFSEL_DIFSEL_Pos)
4054#define ADC_DIFSEL_DIFSEL_14 (0x04000UL << ADC_DIFSEL_DIFSEL_Pos)
4055#define ADC_DIFSEL_DIFSEL_15 (0x08000UL << ADC_DIFSEL_DIFSEL_Pos)
4056#define ADC_DIFSEL_DIFSEL_16 (0x10000UL << ADC_DIFSEL_DIFSEL_Pos)
4057#define ADC_DIFSEL_DIFSEL_17 (0x20000UL << ADC_DIFSEL_DIFSEL_Pos)
4058#define ADC_DIFSEL_DIFSEL_18 (0x40000UL << ADC_DIFSEL_DIFSEL_Pos)
4059#define ADC_DIFSEL_DIFSEL_19 (0x80000UL << ADC_DIFSEL_DIFSEL_Pos)
4061/******************** Bit definition for ADC_CALFACT register ********************/
4062#define ADC_CALFACT_CALFACT_S_Pos (0U)
4063#define ADC_CALFACT_CALFACT_S_Msk (0x7FFUL << ADC_CALFACT_CALFACT_S_Pos)
4064#define ADC_CALFACT_CALFACT_S ADC_CALFACT_CALFACT_S_Msk
4065#define ADC_CALFACT_CALFACT_S_0 (0x001UL << ADC_CALFACT_CALFACT_S_Pos)
4066#define ADC_CALFACT_CALFACT_S_1 (0x002UL << ADC_CALFACT_CALFACT_S_Pos)
4067#define ADC_CALFACT_CALFACT_S_2 (0x004UL << ADC_CALFACT_CALFACT_S_Pos)
4068#define ADC_CALFACT_CALFACT_S_3 (0x008UL << ADC_CALFACT_CALFACT_S_Pos)
4069#define ADC_CALFACT_CALFACT_S_4 (0x010UL << ADC_CALFACT_CALFACT_S_Pos)
4070#define ADC_CALFACT_CALFACT_S_5 (0x020UL << ADC_CALFACT_CALFACT_S_Pos)
4071#define ADC_CALFACT_CALFACT_S_6 (0x040UL << ADC_CALFACT_CALFACT_S_Pos)
4072#define ADC_CALFACT_CALFACT_S_7 (0x080UL << ADC_CALFACT_CALFACT_S_Pos)
4073#define ADC_CALFACT_CALFACT_S_8 (0x100UL << ADC_CALFACT_CALFACT_S_Pos)
4074#define ADC_CALFACT_CALFACT_S_9 (0x200UL << ADC_CALFACT_CALFACT_S_Pos)
4075#define ADC_CALFACT_CALFACT_S_10 (0x400UL << ADC_CALFACT_CALFACT_S_Pos)
4076#define ADC_CALFACT_CALFACT_D_Pos (16U)
4077#define ADC_CALFACT_CALFACT_D_Msk (0x7FFUL << ADC_CALFACT_CALFACT_D_Pos)
4078#define ADC_CALFACT_CALFACT_D ADC_CALFACT_CALFACT_D_Msk
4079#define ADC_CALFACT_CALFACT_D_0 (0x001UL << ADC_CALFACT_CALFACT_D_Pos)
4080#define ADC_CALFACT_CALFACT_D_1 (0x002UL << ADC_CALFACT_CALFACT_D_Pos)
4081#define ADC_CALFACT_CALFACT_D_2 (0x004UL << ADC_CALFACT_CALFACT_D_Pos)
4082#define ADC_CALFACT_CALFACT_D_3 (0x008UL << ADC_CALFACT_CALFACT_D_Pos)
4083#define ADC_CALFACT_CALFACT_D_4 (0x010UL << ADC_CALFACT_CALFACT_D_Pos)
4084#define ADC_CALFACT_CALFACT_D_5 (0x020UL << ADC_CALFACT_CALFACT_D_Pos)
4085#define ADC_CALFACT_CALFACT_D_6 (0x040UL << ADC_CALFACT_CALFACT_D_Pos)
4086#define ADC_CALFACT_CALFACT_D_7 (0x080UL << ADC_CALFACT_CALFACT_D_Pos)
4087#define ADC_CALFACT_CALFACT_D_8 (0x100UL << ADC_CALFACT_CALFACT_D_Pos)
4088#define ADC_CALFACT_CALFACT_D_9 (0x200UL << ADC_CALFACT_CALFACT_D_Pos)
4089#define ADC_CALFACT_CALFACT_D_10 (0x400UL << ADC_CALFACT_CALFACT_D_Pos)
4091/******************** Bit definition for ADC_CALFACT2 register ********************/
4092#define ADC_CALFACT2_LINCALFACT_Pos (0U)
4093#define ADC_CALFACT2_LINCALFACT_Msk (0x3FFFFFFFUL << ADC_CALFACT2_LINCALFACT_Pos)
4094#define ADC_CALFACT2_LINCALFACT ADC_CALFACT2_LINCALFACT_Msk
4095#define ADC_CALFACT2_LINCALFACT_0 (0x00000001UL << ADC_CALFACT2_LINCALFACT_Pos)
4096#define ADC_CALFACT2_LINCALFACT_1 (0x00000002UL << ADC_CALFACT2_LINCALFACT_Pos)
4097#define ADC_CALFACT2_LINCALFACT_2 (0x00000004UL << ADC_CALFACT2_LINCALFACT_Pos)
4098#define ADC_CALFACT2_LINCALFACT_3 (0x00000008UL << ADC_CALFACT2_LINCALFACT_Pos)
4099#define ADC_CALFACT2_LINCALFACT_4 (0x00000010UL << ADC_CALFACT2_LINCALFACT_Pos)
4100#define ADC_CALFACT2_LINCALFACT_5 (0x00000020UL << ADC_CALFACT2_LINCALFACT_Pos)
4101#define ADC_CALFACT2_LINCALFACT_6 (0x00000040UL << ADC_CALFACT2_LINCALFACT_Pos)
4102#define ADC_CALFACT2_LINCALFACT_7 (0x00000080UL << ADC_CALFACT2_LINCALFACT_Pos)
4103#define ADC_CALFACT2_LINCALFACT_8 (0x00000100UL << ADC_CALFACT2_LINCALFACT_Pos)
4104#define ADC_CALFACT2_LINCALFACT_9 (0x00000200UL << ADC_CALFACT2_LINCALFACT_Pos)
4105#define ADC_CALFACT2_LINCALFACT_10 (0x00000400UL << ADC_CALFACT2_LINCALFACT_Pos)
4106#define ADC_CALFACT2_LINCALFACT_11 (0x00000800UL << ADC_CALFACT2_LINCALFACT_Pos)
4107#define ADC_CALFACT2_LINCALFACT_12 (0x00001000UL << ADC_CALFACT2_LINCALFACT_Pos)
4108#define ADC_CALFACT2_LINCALFACT_13 (0x00002000UL << ADC_CALFACT2_LINCALFACT_Pos)
4109#define ADC_CALFACT2_LINCALFACT_14 (0x00004000UL << ADC_CALFACT2_LINCALFACT_Pos)
4110#define ADC_CALFACT2_LINCALFACT_15 (0x00008000UL << ADC_CALFACT2_LINCALFACT_Pos)
4111#define ADC_CALFACT2_LINCALFACT_16 (0x00010000UL << ADC_CALFACT2_LINCALFACT_Pos)
4112#define ADC_CALFACT2_LINCALFACT_17 (0x00020000UL << ADC_CALFACT2_LINCALFACT_Pos)
4113#define ADC_CALFACT2_LINCALFACT_18 (0x00040000UL << ADC_CALFACT2_LINCALFACT_Pos)
4114#define ADC_CALFACT2_LINCALFACT_19 (0x00080000UL << ADC_CALFACT2_LINCALFACT_Pos)
4115#define ADC_CALFACT2_LINCALFACT_20 (0x00100000UL << ADC_CALFACT2_LINCALFACT_Pos)
4116#define ADC_CALFACT2_LINCALFACT_21 (0x00200000UL << ADC_CALFACT2_LINCALFACT_Pos)
4117#define ADC_CALFACT2_LINCALFACT_22 (0x00400000UL << ADC_CALFACT2_LINCALFACT_Pos)
4118#define ADC_CALFACT2_LINCALFACT_23 (0x00800000UL << ADC_CALFACT2_LINCALFACT_Pos)
4119#define ADC_CALFACT2_LINCALFACT_24 (0x01000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4120#define ADC_CALFACT2_LINCALFACT_25 (0x02000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4121#define ADC_CALFACT2_LINCALFACT_26 (0x04000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4122#define ADC_CALFACT2_LINCALFACT_27 (0x08000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4123#define ADC_CALFACT2_LINCALFACT_28 (0x10000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4124#define ADC_CALFACT2_LINCALFACT_29 (0x20000000UL << ADC_CALFACT2_LINCALFACT_Pos)
4126/************************* ADC Common registers *****************************/
4127/******************** Bit definition for ADC_CSR register ********************/
4128#define ADC_CSR_ADRDY_MST_Pos (0U)
4129#define ADC_CSR_ADRDY_MST_Msk (0x1UL << ADC_CSR_ADRDY_MST_Pos)
4130#define ADC_CSR_ADRDY_MST ADC_CSR_ADRDY_MST_Msk
4131#define ADC_CSR_EOSMP_MST_Pos (1U)
4132#define ADC_CSR_EOSMP_MST_Msk (0x1UL << ADC_CSR_EOSMP_MST_Pos)
4133#define ADC_CSR_EOSMP_MST ADC_CSR_EOSMP_MST_Msk
4134#define ADC_CSR_EOC_MST_Pos (2U)
4135#define ADC_CSR_EOC_MST_Msk (0x1UL << ADC_CSR_EOC_MST_Pos)
4136#define ADC_CSR_EOC_MST ADC_CSR_EOC_MST_Msk
4137#define ADC_CSR_EOS_MST_Pos (3U)
4138#define ADC_CSR_EOS_MST_Msk (0x1UL << ADC_CSR_EOS_MST_Pos)
4139#define ADC_CSR_EOS_MST ADC_CSR_EOS_MST_Msk
4140#define ADC_CSR_OVR_MST_Pos (4U)
4141#define ADC_CSR_OVR_MST_Msk (0x1UL << ADC_CSR_OVR_MST_Pos)
4142#define ADC_CSR_OVR_MST ADC_CSR_OVR_MST_Msk
4143#define ADC_CSR_JEOC_MST_Pos (5U)
4144#define ADC_CSR_JEOC_MST_Msk (0x1UL << ADC_CSR_JEOC_MST_Pos)
4145#define ADC_CSR_JEOC_MST ADC_CSR_JEOC_MST_Msk
4146#define ADC_CSR_JEOS_MST_Pos (6U)
4147#define ADC_CSR_JEOS_MST_Msk (0x1UL << ADC_CSR_JEOS_MST_Pos)
4148#define ADC_CSR_JEOS_MST ADC_CSR_JEOS_MST_Msk
4149#define ADC_CSR_AWD1_MST_Pos (7U)
4150#define ADC_CSR_AWD1_MST_Msk (0x1UL << ADC_CSR_AWD1_MST_Pos)
4151#define ADC_CSR_AWD1_MST ADC_CSR_AWD1_MST_Msk
4152#define ADC_CSR_AWD2_MST_Pos (8U)
4153#define ADC_CSR_AWD2_MST_Msk (0x1UL << ADC_CSR_AWD2_MST_Pos)
4154#define ADC_CSR_AWD2_MST ADC_CSR_AWD2_MST_Msk
4155#define ADC_CSR_AWD3_MST_Pos (9U)
4156#define ADC_CSR_AWD3_MST_Msk (0x1UL << ADC_CSR_AWD3_MST_Pos)
4157#define ADC_CSR_AWD3_MST ADC_CSR_AWD3_MST_Msk
4158#define ADC_CSR_JQOVF_MST_Pos (10U)
4159#define ADC_CSR_JQOVF_MST_Msk (0x1UL << ADC_CSR_JQOVF_MST_Pos)
4160#define ADC_CSR_JQOVF_MST ADC_CSR_JQOVF_MST_Msk
4161#define ADC_CSR_ADRDY_SLV_Pos (16U)
4162#define ADC_CSR_ADRDY_SLV_Msk (0x1UL << ADC_CSR_ADRDY_SLV_Pos)
4163#define ADC_CSR_ADRDY_SLV ADC_CSR_ADRDY_SLV_Msk
4164#define ADC_CSR_EOSMP_SLV_Pos (17U)
4165#define ADC_CSR_EOSMP_SLV_Msk (0x1UL << ADC_CSR_EOSMP_SLV_Pos)
4166#define ADC_CSR_EOSMP_SLV ADC_CSR_EOSMP_SLV_Msk
4167#define ADC_CSR_EOC_SLV_Pos (18U)
4168#define ADC_CSR_EOC_SLV_Msk (0x1UL << ADC_CSR_EOC_SLV_Pos)
4169#define ADC_CSR_EOC_SLV ADC_CSR_EOC_SLV_Msk
4170#define ADC_CSR_EOS_SLV_Pos (19U)
4171#define ADC_CSR_EOS_SLV_Msk (0x1UL << ADC_CSR_EOS_SLV_Pos)
4172#define ADC_CSR_EOS_SLV ADC_CSR_EOS_SLV_Msk
4173#define ADC_CSR_OVR_SLV_Pos (20U)
4174#define ADC_CSR_OVR_SLV_Msk (0x1UL << ADC_CSR_OVR_SLV_Pos)
4175#define ADC_CSR_OVR_SLV ADC_CSR_OVR_SLV_Msk
4176#define ADC_CSR_JEOC_SLV_Pos (21U)
4177#define ADC_CSR_JEOC_SLV_Msk (0x1UL << ADC_CSR_JEOC_SLV_Pos)
4178#define ADC_CSR_JEOC_SLV ADC_CSR_JEOC_SLV_Msk
4179#define ADC_CSR_JEOS_SLV_Pos (22U)
4180#define ADC_CSR_JEOS_SLV_Msk (0x1UL << ADC_CSR_JEOS_SLV_Pos)
4181#define ADC_CSR_JEOS_SLV ADC_CSR_JEOS_SLV_Msk
4182#define ADC_CSR_AWD1_SLV_Pos (23U)
4183#define ADC_CSR_AWD1_SLV_Msk (0x1UL << ADC_CSR_AWD1_SLV_Pos)
4184#define ADC_CSR_AWD1_SLV ADC_CSR_AWD1_SLV_Msk
4185#define ADC_CSR_AWD2_SLV_Pos (24U)
4186#define ADC_CSR_AWD2_SLV_Msk (0x1UL << ADC_CSR_AWD2_SLV_Pos)
4187#define ADC_CSR_AWD2_SLV ADC_CSR_AWD2_SLV_Msk
4188#define ADC_CSR_AWD3_SLV_Pos (25U)
4189#define ADC_CSR_AWD3_SLV_Msk (0x1UL << ADC_CSR_AWD3_SLV_Pos)
4190#define ADC_CSR_AWD3_SLV ADC_CSR_AWD3_SLV_Msk
4191#define ADC_CSR_JQOVF_SLV_Pos (26U)
4192#define ADC_CSR_JQOVF_SLV_Msk (0x1UL << ADC_CSR_JQOVF_SLV_Pos)
4193#define ADC_CSR_JQOVF_SLV ADC_CSR_JQOVF_SLV_Msk
4195/******************** Bit definition for ADC_CCR register ********************/
4196#define ADC_CCR_DUAL_Pos (0U)
4197#define ADC_CCR_DUAL_Msk (0x1FUL << ADC_CCR_DUAL_Pos)
4198#define ADC_CCR_DUAL ADC_CCR_DUAL_Msk
4199#define ADC_CCR_DUAL_0 (0x01UL << ADC_CCR_DUAL_Pos)
4200#define ADC_CCR_DUAL_1 (0x02UL << ADC_CCR_DUAL_Pos)
4201#define ADC_CCR_DUAL_2 (0x04UL << ADC_CCR_DUAL_Pos)
4202#define ADC_CCR_DUAL_3 (0x08UL << ADC_CCR_DUAL_Pos)
4203#define ADC_CCR_DUAL_4 (0x10UL << ADC_CCR_DUAL_Pos)
4205#define ADC_CCR_DELAY_Pos (8U)
4206#define ADC_CCR_DELAY_Msk (0xFUL << ADC_CCR_DELAY_Pos)
4207#define ADC_CCR_DELAY ADC_CCR_DELAY_Msk
4208#define ADC_CCR_DELAY_0 (0x1UL << ADC_CCR_DELAY_Pos)
4209#define ADC_CCR_DELAY_1 (0x2UL << ADC_CCR_DELAY_Pos)
4210#define ADC_CCR_DELAY_2 (0x4UL << ADC_CCR_DELAY_Pos)
4211#define ADC_CCR_DELAY_3 (0x8UL << ADC_CCR_DELAY_Pos)
4214#define ADC_CCR_DAMDF_Pos (14U)
4215#define ADC_CCR_DAMDF_Msk (0x3UL << ADC_CCR_DAMDF_Pos)
4216#define ADC_CCR_DAMDF ADC_CCR_DAMDF_Msk
4217#define ADC_CCR_DAMDF_0 (0x1UL << ADC_CCR_DAMDF_Pos)
4218#define ADC_CCR_DAMDF_1 (0x2UL << ADC_CCR_DAMDF_Pos)
4220#define ADC_CCR_CKMODE_Pos (16U)
4221#define ADC_CCR_CKMODE_Msk (0x3UL << ADC_CCR_CKMODE_Pos)
4222#define ADC_CCR_CKMODE ADC_CCR_CKMODE_Msk
4223#define ADC_CCR_CKMODE_0 (0x1UL << ADC_CCR_CKMODE_Pos)
4224#define ADC_CCR_CKMODE_1 (0x2UL << ADC_CCR_CKMODE_Pos)
4226#define ADC_CCR_PRESC_Pos (18U)
4227#define ADC_CCR_PRESC_Msk (0xFUL << ADC_CCR_PRESC_Pos)
4228#define ADC_CCR_PRESC ADC_CCR_PRESC_Msk
4229#define ADC_CCR_PRESC_0 (0x1UL << ADC_CCR_PRESC_Pos)
4230#define ADC_CCR_PRESC_1 (0x2UL << ADC_CCR_PRESC_Pos)
4231#define ADC_CCR_PRESC_2 (0x4UL << ADC_CCR_PRESC_Pos)
4232#define ADC_CCR_PRESC_3 (0x8UL << ADC_CCR_PRESC_Pos)
4234#define ADC_CCR_VREFEN_Pos (22U)
4235#define ADC_CCR_VREFEN_Msk (0x1UL << ADC_CCR_VREFEN_Pos)
4236#define ADC_CCR_VREFEN ADC_CCR_VREFEN_Msk
4237#define ADC_CCR_TSEN_Pos (23U)
4238#define ADC_CCR_TSEN_Msk (0x1UL << ADC_CCR_TSEN_Pos)
4239#define ADC_CCR_TSEN ADC_CCR_TSEN_Msk
4240#define ADC_CCR_VBATEN_Pos (24U)
4241#define ADC_CCR_VBATEN_Msk (0x1UL << ADC_CCR_VBATEN_Pos)
4242#define ADC_CCR_VBATEN ADC_CCR_VBATEN_Msk
4244/******************** Bit definition for ADC_CDR register *******************/
4245#define ADC_CDR_RDATA_MST_Pos (0U)
4246#define ADC_CDR_RDATA_MST_Msk (0xFFFFUL << ADC_CDR_RDATA_MST_Pos)
4247#define ADC_CDR_RDATA_MST ADC_CDR_RDATA_MST_Msk
4249#define ADC_CDR_RDATA_SLV_Pos (16U)
4250#define ADC_CDR_RDATA_SLV_Msk (0xFFFFUL << ADC_CDR_RDATA_SLV_Pos)
4251#define ADC_CDR_RDATA_SLV ADC_CDR_RDATA_SLV_Msk
4253/******************** Bit definition for ADC_CDR2 register ******************/
4254#define ADC_CDR2_RDATA_ALT_Pos (0U)
4255#define ADC_CDR2_RDATA_ALT_Msk (0xFFFFFFFFUL << ADC_CDR2_RDATA_ALT_Pos)
4256#define ADC_CDR2_RDATA_ALT ADC_CDR2_RDATA_ALT_Msk
4258/******************************************************************************/
4259/* */
4260/* ART accelerator */
4261/* */
4262/******************************************************************************/
4263/******************* Bit definition for ART_CTR register ********************/
4264#define ART_CTR_EN_Pos (0U)
4265#define ART_CTR_EN_Msk (0x1UL << ART_CTR_EN_Pos)
4266#define ART_CTR_EN ART_CTR_EN_Msk
4268#define ART_CTR_PCACHEADDR_Pos (8U)
4269#define ART_CTR_PCACHEADDR_Msk (0xFFFUL << ART_CTR_PCACHEADDR_Pos)
4270#define ART_CTR_PCACHEADDR ART_CTR_PCACHEADDR_Msk
4272/******************************************************************************/
4273/* */
4274/* VREFBUF */
4275/* */
4276/******************************************************************************/
4277/******************* Bit definition for VREFBUF_CSR register ****************/
4278#define VREFBUF_CSR_ENVR_Pos (0U)
4279#define VREFBUF_CSR_ENVR_Msk (0x1UL << VREFBUF_CSR_ENVR_Pos)
4280#define VREFBUF_CSR_ENVR VREFBUF_CSR_ENVR_Msk
4281#define VREFBUF_CSR_HIZ_Pos (1U)
4282#define VREFBUF_CSR_HIZ_Msk (0x1UL << VREFBUF_CSR_HIZ_Pos)
4283#define VREFBUF_CSR_HIZ VREFBUF_CSR_HIZ_Msk
4284#define VREFBUF_CSR_VRR_Pos (3U)
4285#define VREFBUF_CSR_VRR_Msk (0x1UL << VREFBUF_CSR_VRR_Pos)
4286#define VREFBUF_CSR_VRR VREFBUF_CSR_VRR_Msk
4287#define VREFBUF_CSR_VRS_Pos (4U)
4288#define VREFBUF_CSR_VRS_Msk (0x7UL << VREFBUF_CSR_VRS_Pos)
4289#define VREFBUF_CSR_VRS VREFBUF_CSR_VRS_Msk
4291#define VREFBUF_CSR_VRS_OUT1 (0U)
4292#define VREFBUF_CSR_VRS_OUT2_Pos (4U)
4293#define VREFBUF_CSR_VRS_OUT2_Msk (0x1UL << VREFBUF_CSR_VRS_OUT2_Pos)
4294#define VREFBUF_CSR_VRS_OUT2 VREFBUF_CSR_VRS_OUT2_Msk
4295#define VREFBUF_CSR_VRS_OUT3_Pos (5U)
4296#define VREFBUF_CSR_VRS_OUT3_Msk (0x1UL << VREFBUF_CSR_VRS_OUT3_Pos)
4297#define VREFBUF_CSR_VRS_OUT3 VREFBUF_CSR_VRS_OUT3_Msk
4298#define VREFBUF_CSR_VRS_OUT4_Pos (4U)
4299#define VREFBUF_CSR_VRS_OUT4_Msk (0x3UL << VREFBUF_CSR_VRS_OUT4_Pos)
4300#define VREFBUF_CSR_VRS_OUT4 VREFBUF_CSR_VRS_OUT4_Msk
4302/******************* Bit definition for VREFBUF_CCR register ****************/
4303#define VREFBUF_CCR_TRIM_Pos (0U)
4304#define VREFBUF_CCR_TRIM_Msk (0x3FUL << VREFBUF_CCR_TRIM_Pos)
4305#define VREFBUF_CCR_TRIM VREFBUF_CCR_TRIM_Msk
4307/******************************************************************************/
4308/* */
4309/* Flexible Datarate Controller Area Network */
4310/* */
4311/******************************************************************************/
4313/***************** Bit definition for FDCAN_CREL register *******************/
4314#define FDCAN_CREL_DAY_Pos (0U)
4315#define FDCAN_CREL_DAY_Msk (0xFFUL << FDCAN_CREL_DAY_Pos)
4316#define FDCAN_CREL_DAY FDCAN_CREL_DAY_Msk
4317#define FDCAN_CREL_MON_Pos (8U)
4318#define FDCAN_CREL_MON_Msk (0xFFUL << FDCAN_CREL_MON_Pos)
4319#define FDCAN_CREL_MON FDCAN_CREL_MON_Msk
4320#define FDCAN_CREL_YEAR_Pos (16U)
4321#define FDCAN_CREL_YEAR_Msk (0xFUL << FDCAN_CREL_YEAR_Pos)
4322#define FDCAN_CREL_YEAR FDCAN_CREL_YEAR_Msk
4323#define FDCAN_CREL_SUBSTEP_Pos (20U)
4324#define FDCAN_CREL_SUBSTEP_Msk (0xFUL << FDCAN_CREL_SUBSTEP_Pos)
4325#define FDCAN_CREL_SUBSTEP FDCAN_CREL_SUBSTEP_Msk
4326#define FDCAN_CREL_STEP_Pos (24U)
4327#define FDCAN_CREL_STEP_Msk (0xFUL << FDCAN_CREL_STEP_Pos)
4328#define FDCAN_CREL_STEP FDCAN_CREL_STEP_Msk
4329#define FDCAN_CREL_REL_Pos (28U)
4330#define FDCAN_CREL_REL_Msk (0xFUL << FDCAN_CREL_REL_Pos)
4331#define FDCAN_CREL_REL FDCAN_CREL_REL_Msk
4333/***************** Bit definition for FDCAN_ENDN register *******************/
4334#define FDCAN_ENDN_ETV_Pos (0U)
4335#define FDCAN_ENDN_ETV_Msk (0xFFFFFFFFUL << FDCAN_ENDN_ETV_Pos)
4336#define FDCAN_ENDN_ETV FDCAN_ENDN_ETV_Msk
4338/***************** Bit definition for FDCAN_DBTP register *******************/
4339#define FDCAN_DBTP_DSJW_Pos (0U)
4340#define FDCAN_DBTP_DSJW_Msk (0xFUL << FDCAN_DBTP_DSJW_Pos)
4341#define FDCAN_DBTP_DSJW FDCAN_DBTP_DSJW_Msk
4342#define FDCAN_DBTP_DTSEG2_Pos (4U)
4343#define FDCAN_DBTP_DTSEG2_Msk (0xFUL << FDCAN_DBTP_DTSEG2_Pos)
4344#define FDCAN_DBTP_DTSEG2 FDCAN_DBTP_DTSEG2_Msk
4345#define FDCAN_DBTP_DTSEG1_Pos (8U)
4346#define FDCAN_DBTP_DTSEG1_Msk (0x1FUL << FDCAN_DBTP_DTSEG1_Pos)
4347#define FDCAN_DBTP_DTSEG1 FDCAN_DBTP_DTSEG1_Msk
4348#define FDCAN_DBTP_DBRP_Pos (16U)
4349#define FDCAN_DBTP_DBRP_Msk (0x1FUL << FDCAN_DBTP_DBRP_Pos)
4350#define FDCAN_DBTP_DBRP FDCAN_DBTP_DBRP_Msk
4351#define FDCAN_DBTP_TDC_Pos (23U)
4352#define FDCAN_DBTP_TDC_Msk (0x1UL << FDCAN_DBTP_TDC_Pos)
4353#define FDCAN_DBTP_TDC FDCAN_DBTP_TDC_Msk
4355/***************** Bit definition for FDCAN_TEST register *******************/
4356#define FDCAN_TEST_LBCK_Pos (4U)
4357#define FDCAN_TEST_LBCK_Msk (0x1UL << FDCAN_TEST_LBCK_Pos)
4358#define FDCAN_TEST_LBCK FDCAN_TEST_LBCK_Msk
4359#define FDCAN_TEST_TX_Pos (5U)
4360#define FDCAN_TEST_TX_Msk (0x3UL << FDCAN_TEST_TX_Pos)
4361#define FDCAN_TEST_TX FDCAN_TEST_TX_Msk
4362#define FDCAN_TEST_RX_Pos (7U)
4363#define FDCAN_TEST_RX_Msk (0x1UL << FDCAN_TEST_RX_Pos)
4364#define FDCAN_TEST_RX FDCAN_TEST_RX_Msk
4366/***************** Bit definition for FDCAN_RWD register ********************/
4367#define FDCAN_RWD_WDC_Pos (0U)
4368#define FDCAN_RWD_WDC_Msk (0xFFUL << FDCAN_RWD_WDC_Pos)
4369#define FDCAN_RWD_WDC FDCAN_RWD_WDC_Msk
4370#define FDCAN_RWD_WDV_Pos (8U)
4371#define FDCAN_RWD_WDV_Msk (0xFFUL << FDCAN_RWD_WDV_Pos)
4372#define FDCAN_RWD_WDV FDCAN_RWD_WDV_Msk
4374/***************** Bit definition for FDCAN_CCCR register ********************/
4375#define FDCAN_CCCR_INIT_Pos (0U)
4376#define FDCAN_CCCR_INIT_Msk (0x1UL << FDCAN_CCCR_INIT_Pos)
4377#define FDCAN_CCCR_INIT FDCAN_CCCR_INIT_Msk
4378#define FDCAN_CCCR_CCE_Pos (1U)
4379#define FDCAN_CCCR_CCE_Msk (0x1UL << FDCAN_CCCR_CCE_Pos)
4380#define FDCAN_CCCR_CCE FDCAN_CCCR_CCE_Msk
4381#define FDCAN_CCCR_ASM_Pos (2U)
4382#define FDCAN_CCCR_ASM_Msk (0x1UL << FDCAN_CCCR_ASM_Pos)
4383#define FDCAN_CCCR_ASM FDCAN_CCCR_ASM_Msk
4384#define FDCAN_CCCR_CSA_Pos (3U)
4385#define FDCAN_CCCR_CSA_Msk (0x1UL << FDCAN_CCCR_CSA_Pos)
4386#define FDCAN_CCCR_CSA FDCAN_CCCR_CSA_Msk
4387#define FDCAN_CCCR_CSR_Pos (4U)
4388#define FDCAN_CCCR_CSR_Msk (0x1UL << FDCAN_CCCR_CSR_Pos)
4389#define FDCAN_CCCR_CSR FDCAN_CCCR_CSR_Msk
4390#define FDCAN_CCCR_MON_Pos (5U)
4391#define FDCAN_CCCR_MON_Msk (0x1UL << FDCAN_CCCR_MON_Pos)
4392#define FDCAN_CCCR_MON FDCAN_CCCR_MON_Msk
4393#define FDCAN_CCCR_DAR_Pos (6U)
4394#define FDCAN_CCCR_DAR_Msk (0x1UL << FDCAN_CCCR_DAR_Pos)
4395#define FDCAN_CCCR_DAR FDCAN_CCCR_DAR_Msk
4396#define FDCAN_CCCR_TEST_Pos (7U)
4397#define FDCAN_CCCR_TEST_Msk (0x1UL << FDCAN_CCCR_TEST_Pos)
4398#define FDCAN_CCCR_TEST FDCAN_CCCR_TEST_Msk
4399#define FDCAN_CCCR_FDOE_Pos (8U)
4400#define FDCAN_CCCR_FDOE_Msk (0x1UL << FDCAN_CCCR_FDOE_Pos)
4401#define FDCAN_CCCR_FDOE FDCAN_CCCR_FDOE_Msk
4402#define FDCAN_CCCR_BRSE_Pos (9U)
4403#define FDCAN_CCCR_BRSE_Msk (0x1UL << FDCAN_CCCR_BRSE_Pos)
4404#define FDCAN_CCCR_BRSE FDCAN_CCCR_BRSE_Msk
4405#define FDCAN_CCCR_PXHD_Pos (12U)
4406#define FDCAN_CCCR_PXHD_Msk (0x1UL << FDCAN_CCCR_PXHD_Pos)
4407#define FDCAN_CCCR_PXHD FDCAN_CCCR_PXHD_Msk
4408#define FDCAN_CCCR_EFBI_Pos (13U)
4409#define FDCAN_CCCR_EFBI_Msk (0x1UL << FDCAN_CCCR_EFBI_Pos)
4410#define FDCAN_CCCR_EFBI FDCAN_CCCR_EFBI_Msk
4411#define FDCAN_CCCR_TXP_Pos (14U)
4412#define FDCAN_CCCR_TXP_Msk (0x1UL << FDCAN_CCCR_TXP_Pos)
4413#define FDCAN_CCCR_TXP FDCAN_CCCR_TXP_Msk
4414#define FDCAN_CCCR_NISO_Pos (15U)
4415#define FDCAN_CCCR_NISO_Msk (0x1UL << FDCAN_CCCR_NISO_Pos)
4416#define FDCAN_CCCR_NISO FDCAN_CCCR_NISO_Msk
4418/***************** Bit definition for FDCAN_NBTP register ********************/
4419#define FDCAN_NBTP_NTSEG2_Pos (0U)
4420#define FDCAN_NBTP_NTSEG2_Msk (0x7FUL << FDCAN_NBTP_NTSEG2_Pos)
4421#define FDCAN_NBTP_NTSEG2 FDCAN_NBTP_NTSEG2_Msk
4422#define FDCAN_NBTP_NTSEG1_Pos (8U)
4423#define FDCAN_NBTP_NTSEG1_Msk (0xFFUL << FDCAN_NBTP_NTSEG1_Pos)
4424#define FDCAN_NBTP_NTSEG1 FDCAN_NBTP_NTSEG1_Msk
4425#define FDCAN_NBTP_NBRP_Pos (16U)
4426#define FDCAN_NBTP_NBRP_Msk (0x1FFUL << FDCAN_NBTP_NBRP_Pos)
4427#define FDCAN_NBTP_NBRP FDCAN_NBTP_NBRP_Msk
4428#define FDCAN_NBTP_NSJW_Pos (25U)
4429#define FDCAN_NBTP_NSJW_Msk (0x7FUL << FDCAN_NBTP_NSJW_Pos)
4430#define FDCAN_NBTP_NSJW FDCAN_NBTP_NSJW_Msk
4432/***************** Bit definition for FDCAN_TSCC register ********************/
4433#define FDCAN_TSCC_TSS_Pos (0U)
4434#define FDCAN_TSCC_TSS_Msk (0x3UL << FDCAN_TSCC_TSS_Pos)
4435#define FDCAN_TSCC_TSS FDCAN_TSCC_TSS_Msk
4436#define FDCAN_TSCC_TCP_Pos (16U)
4437#define FDCAN_TSCC_TCP_Msk (0xFUL << FDCAN_TSCC_TCP_Pos)
4438#define FDCAN_TSCC_TCP FDCAN_TSCC_TCP_Msk
4440/***************** Bit definition for FDCAN_TSCV register ********************/
4441#define FDCAN_TSCV_TSC_Pos (0U)
4442#define FDCAN_TSCV_TSC_Msk (0xFFFFUL << FDCAN_TSCV_TSC_Pos)
4443#define FDCAN_TSCV_TSC FDCAN_TSCV_TSC_Msk
4445/***************** Bit definition for FDCAN_TOCC register ********************/
4446#define FDCAN_TOCC_ETOC_Pos (0U)
4447#define FDCAN_TOCC_ETOC_Msk (0x1UL << FDCAN_TOCC_ETOC_Pos)
4448#define FDCAN_TOCC_ETOC FDCAN_TOCC_ETOC_Msk
4449#define FDCAN_TOCC_TOS_Pos (1U)
4450#define FDCAN_TOCC_TOS_Msk (0x3UL << FDCAN_TOCC_TOS_Pos)
4451#define FDCAN_TOCC_TOS FDCAN_TOCC_TOS_Msk
4452#define FDCAN_TOCC_TOP_Pos (16U)
4453#define FDCAN_TOCC_TOP_Msk (0xFFFFUL << FDCAN_TOCC_TOP_Pos)
4454#define FDCAN_TOCC_TOP FDCAN_TOCC_TOP_Msk
4456/***************** Bit definition for FDCAN_TOCV register ********************/
4457#define FDCAN_TOCV_TOC_Pos (0U)
4458#define FDCAN_TOCV_TOC_Msk (0xFFFFUL << FDCAN_TOCV_TOC_Pos)
4459#define FDCAN_TOCV_TOC FDCAN_TOCV_TOC_Msk
4461/***************** Bit definition for FDCAN_ECR register *********************/
4462#define FDCAN_ECR_TEC_Pos (0U)
4463#define FDCAN_ECR_TEC_Msk (0xFFUL << FDCAN_ECR_TEC_Pos)
4464#define FDCAN_ECR_TEC FDCAN_ECR_TEC_Msk
4465#define FDCAN_ECR_REC_Pos (8U)
4466#define FDCAN_ECR_REC_Msk (0x7FUL << FDCAN_ECR_REC_Pos)
4467#define FDCAN_ECR_REC FDCAN_ECR_REC_Msk
4468#define FDCAN_ECR_RP_Pos (15U)
4469#define FDCAN_ECR_RP_Msk (0x1UL << FDCAN_ECR_RP_Pos)
4470#define FDCAN_ECR_RP FDCAN_ECR_RP_Msk
4471#define FDCAN_ECR_CEL_Pos (16U)
4472#define FDCAN_ECR_CEL_Msk (0xFFUL << FDCAN_ECR_CEL_Pos)
4473#define FDCAN_ECR_CEL FDCAN_ECR_CEL_Msk
4475/***************** Bit definition for FDCAN_PSR register *********************/
4476#define FDCAN_PSR_LEC_Pos (0U)
4477#define FDCAN_PSR_LEC_Msk (0x7UL << FDCAN_PSR_LEC_Pos)
4478#define FDCAN_PSR_LEC FDCAN_PSR_LEC_Msk
4479#define FDCAN_PSR_ACT_Pos (3U)
4480#define FDCAN_PSR_ACT_Msk (0x3UL << FDCAN_PSR_ACT_Pos)
4481#define FDCAN_PSR_ACT FDCAN_PSR_ACT_Msk
4482#define FDCAN_PSR_EP_Pos (5U)
4483#define FDCAN_PSR_EP_Msk (0x1UL << FDCAN_PSR_EP_Pos)
4484#define FDCAN_PSR_EP FDCAN_PSR_EP_Msk
4485#define FDCAN_PSR_EW_Pos (6U)
4486#define FDCAN_PSR_EW_Msk (0x1UL << FDCAN_PSR_EW_Pos)
4487#define FDCAN_PSR_EW FDCAN_PSR_EW_Msk
4488#define FDCAN_PSR_BO_Pos (7U)
4489#define FDCAN_PSR_BO_Msk (0x1UL << FDCAN_PSR_BO_Pos)
4490#define FDCAN_PSR_BO FDCAN_PSR_BO_Msk
4491#define FDCAN_PSR_DLEC_Pos (8U)
4492#define FDCAN_PSR_DLEC_Msk (0x7UL << FDCAN_PSR_DLEC_Pos)
4493#define FDCAN_PSR_DLEC FDCAN_PSR_DLEC_Msk
4494#define FDCAN_PSR_RESI_Pos (11U)
4495#define FDCAN_PSR_RESI_Msk (0x1UL << FDCAN_PSR_RESI_Pos)
4496#define FDCAN_PSR_RESI FDCAN_PSR_RESI_Msk
4497#define FDCAN_PSR_RBRS_Pos (12U)
4498#define FDCAN_PSR_RBRS_Msk (0x1UL << FDCAN_PSR_RBRS_Pos)
4499#define FDCAN_PSR_RBRS FDCAN_PSR_RBRS_Msk
4500#define FDCAN_PSR_REDL_Pos (13U)
4501#define FDCAN_PSR_REDL_Msk (0x1UL << FDCAN_PSR_REDL_Pos)
4502#define FDCAN_PSR_REDL FDCAN_PSR_REDL_Msk
4503#define FDCAN_PSR_PXE_Pos (14U)
4504#define FDCAN_PSR_PXE_Msk (0x1UL << FDCAN_PSR_PXE_Pos)
4505#define FDCAN_PSR_PXE FDCAN_PSR_PXE_Msk
4506#define FDCAN_PSR_TDCV_Pos (16U)
4507#define FDCAN_PSR_TDCV_Msk (0x7FUL << FDCAN_PSR_TDCV_Pos)
4508#define FDCAN_PSR_TDCV FDCAN_PSR_TDCV_Msk
4510/***************** Bit definition for FDCAN_TDCR register ********************/
4511#define FDCAN_TDCR_TDCF_Pos (0U)
4512#define FDCAN_TDCR_TDCF_Msk (0x7FUL << FDCAN_TDCR_TDCF_Pos)
4513#define FDCAN_TDCR_TDCF FDCAN_TDCR_TDCF_Msk
4514#define FDCAN_TDCR_TDCO_Pos (8U)
4515#define FDCAN_TDCR_TDCO_Msk (0x7FUL << FDCAN_TDCR_TDCO_Pos)
4516#define FDCAN_TDCR_TDCO FDCAN_TDCR_TDCO_Msk
4518/***************** Bit definition for FDCAN_IR register **********************/
4519#define FDCAN_IR_RF0N_Pos (0U)
4520#define FDCAN_IR_RF0N_Msk (0x1UL << FDCAN_IR_RF0N_Pos)
4521#define FDCAN_IR_RF0N FDCAN_IR_RF0N_Msk
4522#define FDCAN_IR_RF0W_Pos (1U)
4523#define FDCAN_IR_RF0W_Msk (0x1UL << FDCAN_IR_RF0W_Pos)
4524#define FDCAN_IR_RF0W FDCAN_IR_RF0W_Msk
4525#define FDCAN_IR_RF0F_Pos (2U)
4526#define FDCAN_IR_RF0F_Msk (0x1UL << FDCAN_IR_RF0F_Pos)
4527#define FDCAN_IR_RF0F FDCAN_IR_RF0F_Msk
4528#define FDCAN_IR_RF0L_Pos (3U)
4529#define FDCAN_IR_RF0L_Msk (0x1UL << FDCAN_IR_RF0L_Pos)
4530#define FDCAN_IR_RF0L FDCAN_IR_RF0L_Msk
4531#define FDCAN_IR_RF1N_Pos (4U)
4532#define FDCAN_IR_RF1N_Msk (0x1UL << FDCAN_IR_RF1N_Pos)
4533#define FDCAN_IR_RF1N FDCAN_IR_RF1N_Msk
4534#define FDCAN_IR_RF1W_Pos (5U)
4535#define FDCAN_IR_RF1W_Msk (0x1UL << FDCAN_IR_RF1W_Pos)
4536#define FDCAN_IR_RF1W FDCAN_IR_RF1W_Msk
4537#define FDCAN_IR_RF1F_Pos (6U)
4538#define FDCAN_IR_RF1F_Msk (0x1UL << FDCAN_IR_RF1F_Pos)
4539#define FDCAN_IR_RF1F FDCAN_IR_RF1F_Msk
4540#define FDCAN_IR_RF1L_Pos (7U)
4541#define FDCAN_IR_RF1L_Msk (0x1UL << FDCAN_IR_RF1L_Pos)
4542#define FDCAN_IR_RF1L FDCAN_IR_RF1L_Msk
4543#define FDCAN_IR_HPM_Pos (8U)
4544#define FDCAN_IR_HPM_Msk (0x1UL << FDCAN_IR_HPM_Pos)
4545#define FDCAN_IR_HPM FDCAN_IR_HPM_Msk
4546#define FDCAN_IR_TC_Pos (9U)
4547#define FDCAN_IR_TC_Msk (0x1UL << FDCAN_IR_TC_Pos)
4548#define FDCAN_IR_TC FDCAN_IR_TC_Msk
4549#define FDCAN_IR_TCF_Pos (10U)
4550#define FDCAN_IR_TCF_Msk (0x1UL << FDCAN_IR_TCF_Pos)
4551#define FDCAN_IR_TCF FDCAN_IR_TCF_Msk
4552#define FDCAN_IR_TFE_Pos (11U)
4553#define FDCAN_IR_TFE_Msk (0x1UL << FDCAN_IR_TFE_Pos)
4554#define FDCAN_IR_TFE FDCAN_IR_TFE_Msk
4555#define FDCAN_IR_TEFN_Pos (12U)
4556#define FDCAN_IR_TEFN_Msk (0x1UL << FDCAN_IR_TEFN_Pos)
4557#define FDCAN_IR_TEFN FDCAN_IR_TEFN_Msk
4558#define FDCAN_IR_TEFW_Pos (13U)
4559#define FDCAN_IR_TEFW_Msk (0x1UL << FDCAN_IR_TEFW_Pos)
4560#define FDCAN_IR_TEFW FDCAN_IR_TEFW_Msk
4561#define FDCAN_IR_TEFF_Pos (14U)
4562#define FDCAN_IR_TEFF_Msk (0x1UL << FDCAN_IR_TEFF_Pos)
4563#define FDCAN_IR_TEFF FDCAN_IR_TEFF_Msk
4564#define FDCAN_IR_TEFL_Pos (15U)
4565#define FDCAN_IR_TEFL_Msk (0x1UL << FDCAN_IR_TEFL_Pos)
4566#define FDCAN_IR_TEFL FDCAN_IR_TEFL_Msk
4567#define FDCAN_IR_TSW_Pos (16U)
4568#define FDCAN_IR_TSW_Msk (0x1UL << FDCAN_IR_TSW_Pos)
4569#define FDCAN_IR_TSW FDCAN_IR_TSW_Msk
4570#define FDCAN_IR_MRAF_Pos (17U)
4571#define FDCAN_IR_MRAF_Msk (0x1UL << FDCAN_IR_MRAF_Pos)
4572#define FDCAN_IR_MRAF FDCAN_IR_MRAF_Msk
4573#define FDCAN_IR_TOO_Pos (18U)
4574#define FDCAN_IR_TOO_Msk (0x1UL << FDCAN_IR_TOO_Pos)
4575#define FDCAN_IR_TOO FDCAN_IR_TOO_Msk
4576#define FDCAN_IR_DRX_Pos (19U)
4577#define FDCAN_IR_DRX_Msk (0x1UL << FDCAN_IR_DRX_Pos)
4578#define FDCAN_IR_DRX FDCAN_IR_DRX_Msk
4579#define FDCAN_IR_ELO_Pos (22U)
4580#define FDCAN_IR_ELO_Msk (0x1UL << FDCAN_IR_ELO_Pos)
4581#define FDCAN_IR_ELO FDCAN_IR_ELO_Msk
4582#define FDCAN_IR_EP_Pos (23U)
4583#define FDCAN_IR_EP_Msk (0x1UL << FDCAN_IR_EP_Pos)
4584#define FDCAN_IR_EP FDCAN_IR_EP_Msk
4585#define FDCAN_IR_EW_Pos (24U)
4586#define FDCAN_IR_EW_Msk (0x1UL << FDCAN_IR_EW_Pos)
4587#define FDCAN_IR_EW FDCAN_IR_EW_Msk
4588#define FDCAN_IR_BO_Pos (25U)
4589#define FDCAN_IR_BO_Msk (0x1UL << FDCAN_IR_BO_Pos)
4590#define FDCAN_IR_BO FDCAN_IR_BO_Msk
4591#define FDCAN_IR_WDI_Pos (26U)
4592#define FDCAN_IR_WDI_Msk (0x1UL << FDCAN_IR_WDI_Pos)
4593#define FDCAN_IR_WDI FDCAN_IR_WDI_Msk
4594#define FDCAN_IR_PEA_Pos (27U)
4595#define FDCAN_IR_PEA_Msk (0x1UL << FDCAN_IR_PEA_Pos)
4596#define FDCAN_IR_PEA FDCAN_IR_PEA_Msk
4597#define FDCAN_IR_PED_Pos (28U)
4598#define FDCAN_IR_PED_Msk (0x1UL << FDCAN_IR_PED_Pos)
4599#define FDCAN_IR_PED FDCAN_IR_PED_Msk
4600#define FDCAN_IR_ARA_Pos (29U)
4601#define FDCAN_IR_ARA_Msk (0x1UL << FDCAN_IR_ARA_Pos)
4602#define FDCAN_IR_ARA FDCAN_IR_ARA_Msk
4604/***************** Bit definition for FDCAN_IE register **********************/
4605#define FDCAN_IE_RF0NE_Pos (0U)
4606#define FDCAN_IE_RF0NE_Msk (0x1UL << FDCAN_IE_RF0NE_Pos)
4607#define FDCAN_IE_RF0NE FDCAN_IE_RF0NE_Msk
4608#define FDCAN_IE_RF0WE_Pos (1U)
4609#define FDCAN_IE_RF0WE_Msk (0x1UL << FDCAN_IE_RF0WE_Pos)
4610#define FDCAN_IE_RF0WE FDCAN_IE_RF0WE_Msk
4611#define FDCAN_IE_RF0FE_Pos (2U)
4612#define FDCAN_IE_RF0FE_Msk (0x1UL << FDCAN_IE_RF0FE_Pos)
4613#define FDCAN_IE_RF0FE FDCAN_IE_RF0FE_Msk
4614#define FDCAN_IE_RF0LE_Pos (3U)
4615#define FDCAN_IE_RF0LE_Msk (0x1UL << FDCAN_IE_RF0LE_Pos)
4616#define FDCAN_IE_RF0LE FDCAN_IE_RF0LE_Msk
4617#define FDCAN_IE_RF1NE_Pos (4U)
4618#define FDCAN_IE_RF1NE_Msk (0x1UL << FDCAN_IE_RF1NE_Pos)
4619#define FDCAN_IE_RF1NE FDCAN_IE_RF1NE_Msk
4620#define FDCAN_IE_RF1WE_Pos (5U)
4621#define FDCAN_IE_RF1WE_Msk (0x1UL << FDCAN_IE_RF1WE_Pos)
4622#define FDCAN_IE_RF1WE FDCAN_IE_RF1WE_Msk
4623#define FDCAN_IE_RF1FE_Pos (6U)
4624#define FDCAN_IE_RF1FE_Msk (0x1UL << FDCAN_IE_RF1FE_Pos)
4625#define FDCAN_IE_RF1FE FDCAN_IE_RF1FE_Msk
4626#define FDCAN_IE_RF1LE_Pos (7U)
4627#define FDCAN_IE_RF1LE_Msk (0x1UL << FDCAN_IE_RF1LE_Pos)
4628#define FDCAN_IE_RF1LE FDCAN_IE_RF1LE_Msk
4629#define FDCAN_IE_HPME_Pos (8U)
4630#define FDCAN_IE_HPME_Msk (0x1UL << FDCAN_IE_HPME_Pos)
4631#define FDCAN_IE_HPME FDCAN_IE_HPME_Msk
4632#define FDCAN_IE_TCE_Pos (9U)
4633#define FDCAN_IE_TCE_Msk (0x1UL << FDCAN_IE_TCE_Pos)
4634#define FDCAN_IE_TCE FDCAN_IE_TCE_Msk
4635#define FDCAN_IE_TCFE_Pos (10U)
4636#define FDCAN_IE_TCFE_Msk (0x1UL << FDCAN_IE_TCFE_Pos)
4637#define FDCAN_IE_TCFE FDCAN_IE_TCFE_Msk
4638#define FDCAN_IE_TFEE_Pos (11U)
4639#define FDCAN_IE_TFEE_Msk (0x1UL << FDCAN_IE_TFEE_Pos)
4640#define FDCAN_IE_TFEE FDCAN_IE_TFEE_Msk
4641#define FDCAN_IE_TEFNE_Pos (12U)
4642#define FDCAN_IE_TEFNE_Msk (0x1UL << FDCAN_IE_TEFNE_Pos)
4643#define FDCAN_IE_TEFNE FDCAN_IE_TEFNE_Msk
4644#define FDCAN_IE_TEFWE_Pos (13U)
4645#define FDCAN_IE_TEFWE_Msk (0x1UL << FDCAN_IE_TEFWE_Pos)
4646#define FDCAN_IE_TEFWE FDCAN_IE_TEFWE_Msk
4647#define FDCAN_IE_TEFFE_Pos (14U)
4648#define FDCAN_IE_TEFFE_Msk (0x1UL << FDCAN_IE_TEFFE_Pos)
4649#define FDCAN_IE_TEFFE FDCAN_IE_TEFFE_Msk
4650#define FDCAN_IE_TEFLE_Pos (15U)
4651#define FDCAN_IE_TEFLE_Msk (0x1UL << FDCAN_IE_TEFLE_Pos)
4652#define FDCAN_IE_TEFLE FDCAN_IE_TEFLE_Msk
4653#define FDCAN_IE_TSWE_Pos (16U)
4654#define FDCAN_IE_TSWE_Msk (0x1UL << FDCAN_IE_TSWE_Pos)
4655#define FDCAN_IE_TSWE FDCAN_IE_TSWE_Msk
4656#define FDCAN_IE_MRAFE_Pos (17U)
4657#define FDCAN_IE_MRAFE_Msk (0x1UL << FDCAN_IE_MRAFE_Pos)
4658#define FDCAN_IE_MRAFE FDCAN_IE_MRAFE_Msk
4659#define FDCAN_IE_TOOE_Pos (18U)
4660#define FDCAN_IE_TOOE_Msk (0x1UL << FDCAN_IE_TOOE_Pos)
4661#define FDCAN_IE_TOOE FDCAN_IE_TOOE_Msk
4662#define FDCAN_IE_DRXE_Pos (19U)
4663#define FDCAN_IE_DRXE_Msk (0x1UL << FDCAN_IE_DRXE_Pos)
4664#define FDCAN_IE_DRXE FDCAN_IE_DRXE_Msk
4665#define FDCAN_IE_BECE_Pos (20U)
4666#define FDCAN_IE_BECE_Msk (0x1UL << FDCAN_IE_BECE_Pos)
4667#define FDCAN_IE_BECE FDCAN_IE_BECE_Msk
4668#define FDCAN_IE_BEUE_Pos (21U)
4669#define FDCAN_IE_BEUE_Msk (0x1UL << FDCAN_IE_BEUE_Pos)
4670#define FDCAN_IE_BEUE FDCAN_IE_BEUE_Msk
4671#define FDCAN_IE_ELOE_Pos (22U)
4672#define FDCAN_IE_ELOE_Msk (0x1UL << FDCAN_IE_ELOE_Pos)
4673#define FDCAN_IE_ELOE FDCAN_IE_ELOE_Msk
4674#define FDCAN_IE_EPE_Pos (23U)
4675#define FDCAN_IE_EPE_Msk (0x1UL << FDCAN_IE_EPE_Pos)
4676#define FDCAN_IE_EPE FDCAN_IE_EPE_Msk
4677#define FDCAN_IE_EWE_Pos (24U)
4678#define FDCAN_IE_EWE_Msk (0x1UL << FDCAN_IE_EWE_Pos)
4679#define FDCAN_IE_EWE FDCAN_IE_EWE_Msk
4680#define FDCAN_IE_BOE_Pos (25U)
4681#define FDCAN_IE_BOE_Msk (0x1UL << FDCAN_IE_BOE_Pos)
4682#define FDCAN_IE_BOE FDCAN_IE_BOE_Msk
4683#define FDCAN_IE_WDIE_Pos (26U)
4684#define FDCAN_IE_WDIE_Msk (0x1UL << FDCAN_IE_WDIE_Pos)
4685#define FDCAN_IE_WDIE FDCAN_IE_WDIE_Msk
4686#define FDCAN_IE_PEAE_Pos (27U)
4687#define FDCAN_IE_PEAE_Msk (0x1UL << FDCAN_IE_PEAE_Pos)
4688#define FDCAN_IE_PEAE FDCAN_IE_PEAE_Msk
4689#define FDCAN_IE_PEDE_Pos (28U)
4690#define FDCAN_IE_PEDE_Msk (0x1UL << FDCAN_IE_PEDE_Pos)
4691#define FDCAN_IE_PEDE FDCAN_IE_PEDE_Msk
4692#define FDCAN_IE_ARAE_Pos (29U)
4693#define FDCAN_IE_ARAE_Msk (0x1UL << FDCAN_IE_ARAE_Pos)
4694#define FDCAN_IE_ARAE FDCAN_IE_ARAE_Msk
4696/***************** Bit definition for FDCAN_ILS register **********************/
4697#define FDCAN_ILS_RF0NL_Pos (0U)
4698#define FDCAN_ILS_RF0NL_Msk (0x1UL << FDCAN_ILS_RF0NL_Pos)
4699#define FDCAN_ILS_RF0NL FDCAN_ILS_RF0NL_Msk
4700#define FDCAN_ILS_RF0WL_Pos (1U)
4701#define FDCAN_ILS_RF0WL_Msk (0x1UL << FDCAN_ILS_RF0WL_Pos)
4702#define FDCAN_ILS_RF0WL FDCAN_ILS_RF0WL_Msk
4703#define FDCAN_ILS_RF0FL_Pos (2U)
4704#define FDCAN_ILS_RF0FL_Msk (0x1UL << FDCAN_ILS_RF0FL_Pos)
4705#define FDCAN_ILS_RF0FL FDCAN_ILS_RF0FL_Msk
4706#define FDCAN_ILS_RF0LL_Pos (3U)
4707#define FDCAN_ILS_RF0LL_Msk (0x1UL << FDCAN_ILS_RF0LL_Pos)
4708#define FDCAN_ILS_RF0LL FDCAN_ILS_RF0LL_Msk
4709#define FDCAN_ILS_RF1NL_Pos (4U)
4710#define FDCAN_ILS_RF1NL_Msk (0x1UL << FDCAN_ILS_RF1NL_Pos)
4711#define FDCAN_ILS_RF1NL FDCAN_ILS_RF1NL_Msk
4712#define FDCAN_ILS_RF1WL_Pos (5U)
4713#define FDCAN_ILS_RF1WL_Msk (0x1UL << FDCAN_ILS_RF1WL_Pos)
4714#define FDCAN_ILS_RF1WL FDCAN_ILS_RF1WL_Msk
4715#define FDCAN_ILS_RF1FL_Pos (6U)
4716#define FDCAN_ILS_RF1FL_Msk (0x1UL << FDCAN_ILS_RF1FL_Pos)
4717#define FDCAN_ILS_RF1FL FDCAN_ILS_RF1FL_Msk
4718#define FDCAN_ILS_RF1LL_Pos (7U)
4719#define FDCAN_ILS_RF1LL_Msk (0x1UL << FDCAN_ILS_RF1LL_Pos)
4720#define FDCAN_ILS_RF1LL FDCAN_ILS_RF1LL_Msk
4721#define FDCAN_ILS_HPML_Pos (8U)
4722#define FDCAN_ILS_HPML_Msk (0x1UL << FDCAN_ILS_HPML_Pos)
4723#define FDCAN_ILS_HPML FDCAN_ILS_HPML_Msk
4724#define FDCAN_ILS_TCL_Pos (9U)
4725#define FDCAN_ILS_TCL_Msk (0x1UL << FDCAN_ILS_TCL_Pos)
4726#define FDCAN_ILS_TCL FDCAN_ILS_TCL_Msk
4727#define FDCAN_ILS_TCFL_Pos (10U)
4728#define FDCAN_ILS_TCFL_Msk (0x1UL << FDCAN_ILS_TCFL_Pos)
4729#define FDCAN_ILS_TCFL FDCAN_ILS_TCFL_Msk
4730#define FDCAN_ILS_TFEL_Pos (11U)
4731#define FDCAN_ILS_TFEL_Msk (0x1UL << FDCAN_ILS_TFEL_Pos)
4732#define FDCAN_ILS_TFEL FDCAN_ILS_TFEL_Msk
4733#define FDCAN_ILS_TEFNL_Pos (12U)
4734#define FDCAN_ILS_TEFNL_Msk (0x1UL << FDCAN_ILS_TEFNL_Pos)
4735#define FDCAN_ILS_TEFNL FDCAN_ILS_TEFNL_Msk
4736#define FDCAN_ILS_TEFWL_Pos (13U)
4737#define FDCAN_ILS_TEFWL_Msk (0x1UL << FDCAN_ILS_TEFWL_Pos)
4738#define FDCAN_ILS_TEFWL FDCAN_ILS_TEFWL_Msk
4739#define FDCAN_ILS_TEFFL_Pos (14U)
4740#define FDCAN_ILS_TEFFL_Msk (0x1UL << FDCAN_ILS_TEFFL_Pos)
4741#define FDCAN_ILS_TEFFL FDCAN_ILS_TEFFL_Msk
4742#define FDCAN_ILS_TEFLL_Pos (15U)
4743#define FDCAN_ILS_TEFLL_Msk (0x1UL << FDCAN_ILS_TEFLL_Pos)
4744#define FDCAN_ILS_TEFLL FDCAN_ILS_TEFLL_Msk
4745#define FDCAN_ILS_TSWL_Pos (16U)
4746#define FDCAN_ILS_TSWL_Msk (0x1UL << FDCAN_ILS_TSWL_Pos)
4747#define FDCAN_ILS_TSWL FDCAN_ILS_TSWL_Msk
4748#define FDCAN_ILS_MRAFE_Pos (17U)
4749#define FDCAN_ILS_MRAFE_Msk (0x1UL << FDCAN_ILS_MRAFE_Pos)
4750#define FDCAN_ILS_MRAFE FDCAN_ILS_MRAFE_Msk
4751#define FDCAN_ILS_TOOE_Pos (18U)
4752#define FDCAN_ILS_TOOE_Msk (0x1UL << FDCAN_ILS_TOOE_Pos)
4753#define FDCAN_ILS_TOOE FDCAN_ILS_TOOE_Msk
4754#define FDCAN_ILS_DRXE_Pos (19U)
4755#define FDCAN_ILS_DRXE_Msk (0x1UL << FDCAN_ILS_DRXE_Pos)
4756#define FDCAN_ILS_DRXE FDCAN_ILS_DRXE_Msk
4757#define FDCAN_ILS_BECE_Pos (20U)
4758#define FDCAN_ILS_BECE_Msk (0x1UL << FDCAN_ILS_BECE_Pos)
4759#define FDCAN_ILS_BECE FDCAN_ILS_BECE_Msk
4760#define FDCAN_ILS_BEUE_Pos (21U)
4761#define FDCAN_ILS_BEUE_Msk (0x1UL << FDCAN_ILS_BEUE_Pos)
4762#define FDCAN_ILS_BEUE FDCAN_ILS_BEUE_Msk
4763#define FDCAN_ILS_ELOE_Pos (22U)
4764#define FDCAN_ILS_ELOE_Msk (0x1UL << FDCAN_ILS_ELOE_Pos)
4765#define FDCAN_ILS_ELOE FDCAN_ILS_ELOE_Msk
4766#define FDCAN_ILS_EPE_Pos (23U)
4767#define FDCAN_ILS_EPE_Msk (0x1UL << FDCAN_ILS_EPE_Pos)
4768#define FDCAN_ILS_EPE FDCAN_ILS_EPE_Msk
4769#define FDCAN_ILS_EWE_Pos (24U)
4770#define FDCAN_ILS_EWE_Msk (0x1UL << FDCAN_ILS_EWE_Pos)
4771#define FDCAN_ILS_EWE FDCAN_ILS_EWE_Msk
4772#define FDCAN_ILS_BOE_Pos (25U)
4773#define FDCAN_ILS_BOE_Msk (0x1UL << FDCAN_ILS_BOE_Pos)
4774#define FDCAN_ILS_BOE FDCAN_ILS_BOE_Msk
4775#define FDCAN_ILS_WDIE_Pos (26U)
4776#define FDCAN_ILS_WDIE_Msk (0x1UL << FDCAN_ILS_WDIE_Pos)
4777#define FDCAN_ILS_WDIE FDCAN_ILS_WDIE_Msk
4778#define FDCAN_ILS_PEAE_Pos (27U)
4779#define FDCAN_ILS_PEAE_Msk (0x1UL << FDCAN_ILS_PEAE_Pos)
4780#define FDCAN_ILS_PEAE FDCAN_ILS_PEAE_Msk
4781#define FDCAN_ILS_PEDE_Pos (28U)
4782#define FDCAN_ILS_PEDE_Msk (0x1UL << FDCAN_ILS_PEDE_Pos)
4783#define FDCAN_ILS_PEDE FDCAN_ILS_PEDE_Msk
4784#define FDCAN_ILS_ARAE_Pos (29U)
4785#define FDCAN_ILS_ARAE_Msk (0x1UL << FDCAN_ILS_ARAE_Pos)
4786#define FDCAN_ILS_ARAE FDCAN_ILS_ARAE_Msk
4788/***************** Bit definition for FDCAN_ILE register **********************/
4789#define FDCAN_ILE_EINT0_Pos (0U)
4790#define FDCAN_ILE_EINT0_Msk (0x1UL << FDCAN_ILE_EINT0_Pos)
4791#define FDCAN_ILE_EINT0 FDCAN_ILE_EINT0_Msk
4792#define FDCAN_ILE_EINT1_Pos (1U)
4793#define FDCAN_ILE_EINT1_Msk (0x1UL << FDCAN_ILE_EINT1_Pos)
4794#define FDCAN_ILE_EINT1 FDCAN_ILE_EINT1_Msk
4796/***************** Bit definition for FDCAN_GFC register **********************/
4797#define FDCAN_GFC_RRFE_Pos (0U)
4798#define FDCAN_GFC_RRFE_Msk (0x1UL << FDCAN_GFC_RRFE_Pos)
4799#define FDCAN_GFC_RRFE FDCAN_GFC_RRFE_Msk
4800#define FDCAN_GFC_RRFS_Pos (1U)
4801#define FDCAN_GFC_RRFS_Msk (0x1UL << FDCAN_GFC_RRFS_Pos)
4802#define FDCAN_GFC_RRFS FDCAN_GFC_RRFS_Msk
4803#define FDCAN_GFC_ANFE_Pos (2U)
4804#define FDCAN_GFC_ANFE_Msk (0x3UL << FDCAN_GFC_ANFE_Pos)
4805#define FDCAN_GFC_ANFE FDCAN_GFC_ANFE_Msk
4806#define FDCAN_GFC_ANFS_Pos (4U)
4807#define FDCAN_GFC_ANFS_Msk (0x3UL << FDCAN_GFC_ANFS_Pos)
4808#define FDCAN_GFC_ANFS FDCAN_GFC_ANFS_Msk
4810/***************** Bit definition for FDCAN_SIDFC register ********************/
4811#define FDCAN_SIDFC_FLSSA_Pos (2U)
4812#define FDCAN_SIDFC_FLSSA_Msk (0x3FFFUL << FDCAN_SIDFC_FLSSA_Pos)
4813#define FDCAN_SIDFC_FLSSA FDCAN_SIDFC_FLSSA_Msk
4814#define FDCAN_SIDFC_LSS_Pos (16U)
4815#define FDCAN_SIDFC_LSS_Msk (0xFFUL << FDCAN_SIDFC_LSS_Pos)
4816#define FDCAN_SIDFC_LSS FDCAN_SIDFC_LSS_Msk
4818/***************** Bit definition for FDCAN_XIDFC register ********************/
4819#define FDCAN_XIDFC_FLESA_Pos (2U)
4820#define FDCAN_XIDFC_FLESA_Msk (0x3FFFUL << FDCAN_XIDFC_FLESA_Pos)
4821#define FDCAN_XIDFC_FLESA FDCAN_XIDFC_FLESA_Msk
4822#define FDCAN_XIDFC_LSE_Pos (16U)
4823#define FDCAN_XIDFC_LSE_Msk (0x7FUL << FDCAN_XIDFC_LSE_Pos)
4824#define FDCAN_XIDFC_LSE FDCAN_XIDFC_LSE_Msk
4826/***************** Bit definition for FDCAN_XIDAM register ********************/
4827#define FDCAN_XIDAM_EIDM_Pos (0U)
4828#define FDCAN_XIDAM_EIDM_Msk (0x1FFFFFFFUL << FDCAN_XIDAM_EIDM_Pos)
4829#define FDCAN_XIDAM_EIDM FDCAN_XIDAM_EIDM_Msk
4831/***************** Bit definition for FDCAN_HPMS register *********************/
4832#define FDCAN_HPMS_BIDX_Pos (0U)
4833#define FDCAN_HPMS_BIDX_Msk (0x3FUL << FDCAN_HPMS_BIDX_Pos)
4834#define FDCAN_HPMS_BIDX FDCAN_HPMS_BIDX_Msk
4835#define FDCAN_HPMS_MSI_Pos (6U)
4836#define FDCAN_HPMS_MSI_Msk (0x3UL << FDCAN_HPMS_MSI_Pos)
4837#define FDCAN_HPMS_MSI FDCAN_HPMS_MSI_Msk
4838#define FDCAN_HPMS_FIDX_Pos (8U)
4839#define FDCAN_HPMS_FIDX_Msk (0x7FUL << FDCAN_HPMS_FIDX_Pos)
4840#define FDCAN_HPMS_FIDX FDCAN_HPMS_FIDX_Msk
4841#define FDCAN_HPMS_FLST_Pos (15U)
4842#define FDCAN_HPMS_FLST_Msk (0x1UL << FDCAN_HPMS_FLST_Pos)
4843#define FDCAN_HPMS_FLST FDCAN_HPMS_FLST_Msk
4845/***************** Bit definition for FDCAN_NDAT1 register ********************/
4846#define FDCAN_NDAT1_ND0_Pos (0U)
4847#define FDCAN_NDAT1_ND0_Msk (0x1UL << FDCAN_NDAT1_ND0_Pos)
4848#define FDCAN_NDAT1_ND0 FDCAN_NDAT1_ND0_Msk
4849#define FDCAN_NDAT1_ND1_Pos (1U)
4850#define FDCAN_NDAT1_ND1_Msk (0x1UL << FDCAN_NDAT1_ND1_Pos)
4851#define FDCAN_NDAT1_ND1 FDCAN_NDAT1_ND1_Msk
4852#define FDCAN_NDAT1_ND2_Pos (2U)
4853#define FDCAN_NDAT1_ND2_Msk (0x1UL << FDCAN_NDAT1_ND2_Pos)
4854#define FDCAN_NDAT1_ND2 FDCAN_NDAT1_ND2_Msk
4855#define FDCAN_NDAT1_ND3_Pos (3U)
4856#define FDCAN_NDAT1_ND3_Msk (0x1UL << FDCAN_NDAT1_ND3_Pos)
4857#define FDCAN_NDAT1_ND3 FDCAN_NDAT1_ND3_Msk
4858#define FDCAN_NDAT1_ND4_Pos (4U)
4859#define FDCAN_NDAT1_ND4_Msk (0x1UL << FDCAN_NDAT1_ND4_Pos)
4860#define FDCAN_NDAT1_ND4 FDCAN_NDAT1_ND4_Msk
4861#define FDCAN_NDAT1_ND5_Pos (5U)
4862#define FDCAN_NDAT1_ND5_Msk (0x1UL << FDCAN_NDAT1_ND5_Pos)
4863#define FDCAN_NDAT1_ND5 FDCAN_NDAT1_ND5_Msk
4864#define FDCAN_NDAT1_ND6_Pos (6U)
4865#define FDCAN_NDAT1_ND6_Msk (0x1UL << FDCAN_NDAT1_ND6_Pos)
4866#define FDCAN_NDAT1_ND6 FDCAN_NDAT1_ND6_Msk
4867#define FDCAN_NDAT1_ND7_Pos (7U)
4868#define FDCAN_NDAT1_ND7_Msk (0x1UL << FDCAN_NDAT1_ND7_Pos)
4869#define FDCAN_NDAT1_ND7 FDCAN_NDAT1_ND7_Msk
4870#define FDCAN_NDAT1_ND8_Pos (8U)
4871#define FDCAN_NDAT1_ND8_Msk (0x1UL << FDCAN_NDAT1_ND8_Pos)
4872#define FDCAN_NDAT1_ND8 FDCAN_NDAT1_ND8_Msk
4873#define FDCAN_NDAT1_ND9_Pos (9U)
4874#define FDCAN_NDAT1_ND9_Msk (0x1UL << FDCAN_NDAT1_ND9_Pos)
4875#define FDCAN_NDAT1_ND9 FDCAN_NDAT1_ND9_Msk
4876#define FDCAN_NDAT1_ND10_Pos (10U)
4877#define FDCAN_NDAT1_ND10_Msk (0x1UL << FDCAN_NDAT1_ND10_Pos)
4878#define FDCAN_NDAT1_ND10 FDCAN_NDAT1_ND10_Msk
4879#define FDCAN_NDAT1_ND11_Pos (11U)
4880#define FDCAN_NDAT1_ND11_Msk (0x1UL << FDCAN_NDAT1_ND11_Pos)
4881#define FDCAN_NDAT1_ND11 FDCAN_NDAT1_ND11_Msk
4882#define FDCAN_NDAT1_ND12_Pos (12U)
4883#define FDCAN_NDAT1_ND12_Msk (0x1UL << FDCAN_NDAT1_ND12_Pos)
4884#define FDCAN_NDAT1_ND12 FDCAN_NDAT1_ND12_Msk
4885#define FDCAN_NDAT1_ND13_Pos (13U)
4886#define FDCAN_NDAT1_ND13_Msk (0x1UL << FDCAN_NDAT1_ND13_Pos)
4887#define FDCAN_NDAT1_ND13 FDCAN_NDAT1_ND13_Msk
4888#define FDCAN_NDAT1_ND14_Pos (14U)
4889#define FDCAN_NDAT1_ND14_Msk (0x1UL << FDCAN_NDAT1_ND14_Pos)
4890#define FDCAN_NDAT1_ND14 FDCAN_NDAT1_ND14_Msk
4891#define FDCAN_NDAT1_ND15_Pos (15U)
4892#define FDCAN_NDAT1_ND15_Msk (0x1UL << FDCAN_NDAT1_ND15_Pos)
4893#define FDCAN_NDAT1_ND15 FDCAN_NDAT1_ND15_Msk
4894#define FDCAN_NDAT1_ND16_Pos (16U)
4895#define FDCAN_NDAT1_ND16_Msk (0x1UL << FDCAN_NDAT1_ND16_Pos)
4896#define FDCAN_NDAT1_ND16 FDCAN_NDAT1_ND16_Msk
4897#define FDCAN_NDAT1_ND17_Pos (17U)
4898#define FDCAN_NDAT1_ND17_Msk (0x1UL << FDCAN_NDAT1_ND17_Pos)
4899#define FDCAN_NDAT1_ND17 FDCAN_NDAT1_ND17_Msk
4900#define FDCAN_NDAT1_ND18_Pos (18U)
4901#define FDCAN_NDAT1_ND18_Msk (0x1UL << FDCAN_NDAT1_ND18_Pos)
4902#define FDCAN_NDAT1_ND18 FDCAN_NDAT1_ND18_Msk
4903#define FDCAN_NDAT1_ND19_Pos (19U)
4904#define FDCAN_NDAT1_ND19_Msk (0x1UL << FDCAN_NDAT1_ND19_Pos)
4905#define FDCAN_NDAT1_ND19 FDCAN_NDAT1_ND19_Msk
4906#define FDCAN_NDAT1_ND20_Pos (20U)
4907#define FDCAN_NDAT1_ND20_Msk (0x1UL << FDCAN_NDAT1_ND20_Pos)
4908#define FDCAN_NDAT1_ND20 FDCAN_NDAT1_ND20_Msk
4909#define FDCAN_NDAT1_ND21_Pos (21U)
4910#define FDCAN_NDAT1_ND21_Msk (0x1UL << FDCAN_NDAT1_ND21_Pos)
4911#define FDCAN_NDAT1_ND21 FDCAN_NDAT1_ND21_Msk
4912#define FDCAN_NDAT1_ND22_Pos (22U)
4913#define FDCAN_NDAT1_ND22_Msk (0x1UL << FDCAN_NDAT1_ND22_Pos)
4914#define FDCAN_NDAT1_ND22 FDCAN_NDAT1_ND22_Msk
4915#define FDCAN_NDAT1_ND23_Pos (23U)
4916#define FDCAN_NDAT1_ND23_Msk (0x1UL << FDCAN_NDAT1_ND23_Pos)
4917#define FDCAN_NDAT1_ND23 FDCAN_NDAT1_ND23_Msk
4918#define FDCAN_NDAT1_ND24_Pos (24U)
4919#define FDCAN_NDAT1_ND24_Msk (0x1UL << FDCAN_NDAT1_ND24_Pos)
4920#define FDCAN_NDAT1_ND24 FDCAN_NDAT1_ND24_Msk
4921#define FDCAN_NDAT1_ND25_Pos (25U)
4922#define FDCAN_NDAT1_ND25_Msk (0x1UL << FDCAN_NDAT1_ND25_Pos)
4923#define FDCAN_NDAT1_ND25 FDCAN_NDAT1_ND25_Msk
4924#define FDCAN_NDAT1_ND26_Pos (26U)
4925#define FDCAN_NDAT1_ND26_Msk (0x1UL << FDCAN_NDAT1_ND26_Pos)
4926#define FDCAN_NDAT1_ND26 FDCAN_NDAT1_ND26_Msk
4927#define FDCAN_NDAT1_ND27_Pos (27U)
4928#define FDCAN_NDAT1_ND27_Msk (0x1UL << FDCAN_NDAT1_ND27_Pos)
4929#define FDCAN_NDAT1_ND27 FDCAN_NDAT1_ND27_Msk
4930#define FDCAN_NDAT1_ND28_Pos (28U)
4931#define FDCAN_NDAT1_ND28_Msk (0x1UL << FDCAN_NDAT1_ND28_Pos)
4932#define FDCAN_NDAT1_ND28 FDCAN_NDAT1_ND28_Msk
4933#define FDCAN_NDAT1_ND29_Pos (29U)
4934#define FDCAN_NDAT1_ND29_Msk (0x1UL << FDCAN_NDAT1_ND29_Pos)
4935#define FDCAN_NDAT1_ND29 FDCAN_NDAT1_ND29_Msk
4936#define FDCAN_NDAT1_ND30_Pos (30U)
4937#define FDCAN_NDAT1_ND30_Msk (0x1UL << FDCAN_NDAT1_ND30_Pos)
4938#define FDCAN_NDAT1_ND30 FDCAN_NDAT1_ND30_Msk
4939#define FDCAN_NDAT1_ND31_Pos (31U)
4940#define FDCAN_NDAT1_ND31_Msk (0x1UL << FDCAN_NDAT1_ND31_Pos)
4941#define FDCAN_NDAT1_ND31 FDCAN_NDAT1_ND31_Msk
4943/***************** Bit definition for FDCAN_NDAT2 register ********************/
4944#define FDCAN_NDAT2_ND32_Pos (0U)
4945#define FDCAN_NDAT2_ND32_Msk (0x1UL << FDCAN_NDAT2_ND32_Pos)
4946#define FDCAN_NDAT2_ND32 FDCAN_NDAT2_ND32_Msk
4947#define FDCAN_NDAT2_ND33_Pos (1U)
4948#define FDCAN_NDAT2_ND33_Msk (0x1UL << FDCAN_NDAT2_ND33_Pos)
4949#define FDCAN_NDAT2_ND33 FDCAN_NDAT2_ND33_Msk
4950#define FDCAN_NDAT2_ND34_Pos (2U)
4951#define FDCAN_NDAT2_ND34_Msk (0x1UL << FDCAN_NDAT2_ND34_Pos)
4952#define FDCAN_NDAT2_ND34 FDCAN_NDAT2_ND34_Msk
4953#define FDCAN_NDAT2_ND35_Pos (3U)
4954#define FDCAN_NDAT2_ND35_Msk (0x1UL << FDCAN_NDAT2_ND35_Pos)
4955#define FDCAN_NDAT2_ND35 FDCAN_NDAT2_ND35_Msk
4956#define FDCAN_NDAT2_ND36_Pos (4U)
4957#define FDCAN_NDAT2_ND36_Msk (0x1UL << FDCAN_NDAT2_ND36_Pos)
4958#define FDCAN_NDAT2_ND36 FDCAN_NDAT2_ND36_Msk
4959#define FDCAN_NDAT2_ND37_Pos (5U)
4960#define FDCAN_NDAT2_ND37_Msk (0x1UL << FDCAN_NDAT2_ND37_Pos)
4961#define FDCAN_NDAT2_ND37 FDCAN_NDAT2_ND37_Msk
4962#define FDCAN_NDAT2_ND38_Pos (6U)
4963#define FDCAN_NDAT2_ND38_Msk (0x1UL << FDCAN_NDAT2_ND38_Pos)
4964#define FDCAN_NDAT2_ND38 FDCAN_NDAT2_ND38_Msk
4965#define FDCAN_NDAT2_ND39_Pos (7U)
4966#define FDCAN_NDAT2_ND39_Msk (0x1UL << FDCAN_NDAT2_ND39_Pos)
4967#define FDCAN_NDAT2_ND39 FDCAN_NDAT2_ND39_Msk
4968#define FDCAN_NDAT2_ND40_Pos (8U)
4969#define FDCAN_NDAT2_ND40_Msk (0x1UL << FDCAN_NDAT2_ND40_Pos)
4970#define FDCAN_NDAT2_ND40 FDCAN_NDAT2_ND40_Msk
4971#define FDCAN_NDAT2_ND41_Pos (9U)
4972#define FDCAN_NDAT2_ND41_Msk (0x1UL << FDCAN_NDAT2_ND41_Pos)
4973#define FDCAN_NDAT2_ND41 FDCAN_NDAT2_ND41_Msk
4974#define FDCAN_NDAT2_ND42_Pos (10U)
4975#define FDCAN_NDAT2_ND42_Msk (0x1UL << FDCAN_NDAT2_ND42_Pos)
4976#define FDCAN_NDAT2_ND42 FDCAN_NDAT2_ND42_Msk
4977#define FDCAN_NDAT2_ND43_Pos (11U)
4978#define FDCAN_NDAT2_ND43_Msk (0x1UL << FDCAN_NDAT2_ND43_Pos)
4979#define FDCAN_NDAT2_ND43 FDCAN_NDAT2_ND43_Msk
4980#define FDCAN_NDAT2_ND44_Pos (12U)
4981#define FDCAN_NDAT2_ND44_Msk (0x1UL << FDCAN_NDAT2_ND44_Pos)
4982#define FDCAN_NDAT2_ND44 FDCAN_NDAT2_ND44_Msk
4983#define FDCAN_NDAT2_ND45_Pos (13U)
4984#define FDCAN_NDAT2_ND45_Msk (0x1UL << FDCAN_NDAT2_ND45_Pos)
4985#define FDCAN_NDAT2_ND45 FDCAN_NDAT2_ND45_Msk
4986#define FDCAN_NDAT2_ND46_Pos (14U)
4987#define FDCAN_NDAT2_ND46_Msk (0x1UL << FDCAN_NDAT2_ND46_Pos)
4988#define FDCAN_NDAT2_ND46 FDCAN_NDAT2_ND46_Msk
4989#define FDCAN_NDAT2_ND47_Pos (15U)
4990#define FDCAN_NDAT2_ND47_Msk (0x1UL << FDCAN_NDAT2_ND47_Pos)
4991#define FDCAN_NDAT2_ND47 FDCAN_NDAT2_ND47_Msk
4992#define FDCAN_NDAT2_ND48_Pos (16U)
4993#define FDCAN_NDAT2_ND48_Msk (0x1UL << FDCAN_NDAT2_ND48_Pos)
4994#define FDCAN_NDAT2_ND48 FDCAN_NDAT2_ND48_Msk
4995#define FDCAN_NDAT2_ND49_Pos (17U)
4996#define FDCAN_NDAT2_ND49_Msk (0x1UL << FDCAN_NDAT2_ND49_Pos)
4997#define FDCAN_NDAT2_ND49 FDCAN_NDAT2_ND49_Msk
4998#define FDCAN_NDAT2_ND50_Pos (18U)
4999#define FDCAN_NDAT2_ND50_Msk (0x1UL << FDCAN_NDAT2_ND50_Pos)
5000#define FDCAN_NDAT2_ND50 FDCAN_NDAT2_ND50_Msk
5001#define FDCAN_NDAT2_ND51_Pos (19U)
5002#define FDCAN_NDAT2_ND51_Msk (0x1UL << FDCAN_NDAT2_ND51_Pos)
5003#define FDCAN_NDAT2_ND51 FDCAN_NDAT2_ND51_Msk
5004#define FDCAN_NDAT2_ND52_Pos (20U)
5005#define FDCAN_NDAT2_ND52_Msk (0x1UL << FDCAN_NDAT2_ND52_Pos)
5006#define FDCAN_NDAT2_ND52 FDCAN_NDAT2_ND52_Msk
5007#define FDCAN_NDAT2_ND53_Pos (21U)
5008#define FDCAN_NDAT2_ND53_Msk (0x1UL << FDCAN_NDAT2_ND53_Pos)
5009#define FDCAN_NDAT2_ND53 FDCAN_NDAT2_ND53_Msk
5010#define FDCAN_NDAT2_ND54_Pos (22U)
5011#define FDCAN_NDAT2_ND54_Msk (0x1UL << FDCAN_NDAT2_ND54_Pos)
5012#define FDCAN_NDAT2_ND54 FDCAN_NDAT2_ND54_Msk
5013#define FDCAN_NDAT2_ND55_Pos (23U)
5014#define FDCAN_NDAT2_ND55_Msk (0x1UL << FDCAN_NDAT2_ND55_Pos)
5015#define FDCAN_NDAT2_ND55 FDCAN_NDAT2_ND55_Msk
5016#define FDCAN_NDAT2_ND56_Pos (24U)
5017#define FDCAN_NDAT2_ND56_Msk (0x1UL << FDCAN_NDAT2_ND56_Pos)
5018#define FDCAN_NDAT2_ND56 FDCAN_NDAT2_ND56_Msk
5019#define FDCAN_NDAT2_ND57_Pos (25U)
5020#define FDCAN_NDAT2_ND57_Msk (0x1UL << FDCAN_NDAT2_ND57_Pos)
5021#define FDCAN_NDAT2_ND57 FDCAN_NDAT2_ND57_Msk
5022#define FDCAN_NDAT2_ND58_Pos (26U)
5023#define FDCAN_NDAT2_ND58_Msk (0x1UL << FDCAN_NDAT2_ND58_Pos)
5024#define FDCAN_NDAT2_ND58 FDCAN_NDAT2_ND58_Msk
5025#define FDCAN_NDAT2_ND59_Pos (27U)
5026#define FDCAN_NDAT2_ND59_Msk (0x1UL << FDCAN_NDAT2_ND59_Pos)
5027#define FDCAN_NDAT2_ND59 FDCAN_NDAT2_ND59_Msk
5028#define FDCAN_NDAT2_ND60_Pos (28U)
5029#define FDCAN_NDAT2_ND60_Msk (0x1UL << FDCAN_NDAT2_ND60_Pos)
5030#define FDCAN_NDAT2_ND60 FDCAN_NDAT2_ND60_Msk
5031#define FDCAN_NDAT2_ND61_Pos (29U)
5032#define FDCAN_NDAT2_ND61_Msk (0x1UL << FDCAN_NDAT2_ND61_Pos)
5033#define FDCAN_NDAT2_ND61 FDCAN_NDAT2_ND61_Msk
5034#define FDCAN_NDAT2_ND62_Pos (30U)
5035#define FDCAN_NDAT2_ND62_Msk (0x1UL << FDCAN_NDAT2_ND62_Pos)
5036#define FDCAN_NDAT2_ND62 FDCAN_NDAT2_ND62_Msk
5037#define FDCAN_NDAT2_ND63_Pos (31U)
5038#define FDCAN_NDAT2_ND63_Msk (0x1UL << FDCAN_NDAT2_ND63_Pos)
5039#define FDCAN_NDAT2_ND63 FDCAN_NDAT2_ND63_Msk
5041/***************** Bit definition for FDCAN_RXF0C register ********************/
5042#define FDCAN_RXF0C_F0SA_Pos (2U)
5043#define FDCAN_RXF0C_F0SA_Msk (0x3FFFUL << FDCAN_RXF0C_F0SA_Pos)
5044#define FDCAN_RXF0C_F0SA FDCAN_RXF0C_F0SA_Msk
5045#define FDCAN_RXF0C_F0S_Pos (16U)
5046#define FDCAN_RXF0C_F0S_Msk (0x7FUL << FDCAN_RXF0C_F0S_Pos)
5047#define FDCAN_RXF0C_F0S FDCAN_RXF0C_F0S_Msk
5048#define FDCAN_RXF0C_F0WM_Pos (24U)
5049#define FDCAN_RXF0C_F0WM_Msk (0x7FUL << FDCAN_RXF0C_F0WM_Pos)
5050#define FDCAN_RXF0C_F0WM FDCAN_RXF0C_F0WM_Msk
5051#define FDCAN_RXF0C_F0OM_Pos (31U)
5052#define FDCAN_RXF0C_F0OM_Msk (0x1UL << FDCAN_RXF0C_F0OM_Pos)
5053#define FDCAN_RXF0C_F0OM FDCAN_RXF0C_F0OM_Msk
5055/***************** Bit definition for FDCAN_RXF0S register ********************/
5056#define FDCAN_RXF0S_F0FL_Pos (0U)
5057#define FDCAN_RXF0S_F0FL_Msk (0x7FUL << FDCAN_RXF0S_F0FL_Pos)
5058#define FDCAN_RXF0S_F0FL FDCAN_RXF0S_F0FL_Msk
5059#define FDCAN_RXF0S_F0GI_Pos (8U)
5060#define FDCAN_RXF0S_F0GI_Msk (0x3FUL << FDCAN_RXF0S_F0GI_Pos)
5061#define FDCAN_RXF0S_F0GI FDCAN_RXF0S_F0GI_Msk
5062#define FDCAN_RXF0S_F0PI_Pos (16U)
5063#define FDCAN_RXF0S_F0PI_Msk (0x3FUL << FDCAN_RXF0S_F0PI_Pos)
5064#define FDCAN_RXF0S_F0PI FDCAN_RXF0S_F0PI_Msk
5065#define FDCAN_RXF0S_F0F_Pos (24U)
5066#define FDCAN_RXF0S_F0F_Msk (0x1UL << FDCAN_RXF0S_F0F_Pos)
5067#define FDCAN_RXF0S_F0F FDCAN_RXF0S_F0F_Msk
5068#define FDCAN_RXF0S_RF0L_Pos (25U)
5069#define FDCAN_RXF0S_RF0L_Msk (0x1UL << FDCAN_RXF0S_RF0L_Pos)
5070#define FDCAN_RXF0S_RF0L FDCAN_RXF0S_RF0L_Msk
5072/***************** Bit definition for FDCAN_RXF0A register ********************/
5073#define FDCAN_RXF0A_F0AI_Pos (0U)
5074#define FDCAN_RXF0A_F0AI_Msk (0x3FUL << FDCAN_RXF0A_F0AI_Pos)
5075#define FDCAN_RXF0A_F0AI FDCAN_RXF0A_F0AI_Msk
5077/***************** Bit definition for FDCAN_RXBC register ********************/
5078#define FDCAN_RXBC_RBSA_Pos (2U)
5079#define FDCAN_RXBC_RBSA_Msk (0x3FFFUL << FDCAN_RXBC_RBSA_Pos)
5080#define FDCAN_RXBC_RBSA FDCAN_RXBC_RBSA_Msk
5082/***************** Bit definition for FDCAN_RXF1C register ********************/
5083#define FDCAN_RXF1C_F1SA_Pos (2U)
5084#define FDCAN_RXF1C_F1SA_Msk (0x3FFFUL << FDCAN_RXF1C_F1SA_Pos)
5085#define FDCAN_RXF1C_F1SA FDCAN_RXF1C_F1SA_Msk
5086#define FDCAN_RXF1C_F1S_Pos (16U)
5087#define FDCAN_RXF1C_F1S_Msk (0x7FUL << FDCAN_RXF1C_F1S_Pos)
5088#define FDCAN_RXF1C_F1S FDCAN_RXF1C_F1S_Msk
5089#define FDCAN_RXF1C_F1WM_Pos (24U)
5090#define FDCAN_RXF1C_F1WM_Msk (0x7FUL << FDCAN_RXF1C_F1WM_Pos)
5091#define FDCAN_RXF1C_F1WM FDCAN_RXF1C_F1WM_Msk
5092#define FDCAN_RXF1C_F1OM_Pos (31U)
5093#define FDCAN_RXF1C_F1OM_Msk (0x1UL << FDCAN_RXF1C_F1OM_Pos)
5094#define FDCAN_RXF1C_F1OM FDCAN_RXF1C_F1OM_Msk
5096/***************** Bit definition for FDCAN_RXF1S register ********************/
5097#define FDCAN_RXF1S_F1FL_Pos (0U)
5098#define FDCAN_RXF1S_F1FL_Msk (0x7FUL << FDCAN_RXF1S_F1FL_Pos)
5099#define FDCAN_RXF1S_F1FL FDCAN_RXF1S_F1FL_Msk
5100#define FDCAN_RXF1S_F1GI_Pos (8U)
5101#define FDCAN_RXF1S_F1GI_Msk (0x3FUL << FDCAN_RXF1S_F1GI_Pos)
5102#define FDCAN_RXF1S_F1GI FDCAN_RXF1S_F1GI_Msk
5103#define FDCAN_RXF1S_F1PI_Pos (16U)
5104#define FDCAN_RXF1S_F1PI_Msk (0x3FUL << FDCAN_RXF1S_F1PI_Pos)
5105#define FDCAN_RXF1S_F1PI FDCAN_RXF1S_F1PI_Msk
5106#define FDCAN_RXF1S_F1F_Pos (24U)
5107#define FDCAN_RXF1S_F1F_Msk (0x1UL << FDCAN_RXF1S_F1F_Pos)
5108#define FDCAN_RXF1S_F1F FDCAN_RXF1S_F1F_Msk
5109#define FDCAN_RXF1S_RF1L_Pos (25U)
5110#define FDCAN_RXF1S_RF1L_Msk (0x1UL << FDCAN_RXF1S_RF1L_Pos)
5111#define FDCAN_RXF1S_RF1L FDCAN_RXF1S_RF1L_Msk
5113/***************** Bit definition for FDCAN_RXF1A register ********************/
5114#define FDCAN_RXF1A_F1AI_Pos (0U)
5115#define FDCAN_RXF1A_F1AI_Msk (0x3FUL << FDCAN_RXF1A_F1AI_Pos)
5116#define FDCAN_RXF1A_F1AI FDCAN_RXF1A_F1AI_Msk
5118/***************** Bit definition for FDCAN_RXESC register ********************/
5119#define FDCAN_RXESC_F0DS_Pos (0U)
5120#define FDCAN_RXESC_F0DS_Msk (0x7UL << FDCAN_RXESC_F0DS_Pos)
5121#define FDCAN_RXESC_F0DS FDCAN_RXESC_F0DS_Msk
5122#define FDCAN_RXESC_F1DS_Pos (4U)
5123#define FDCAN_RXESC_F1DS_Msk (0x7UL << FDCAN_RXESC_F1DS_Pos)
5124#define FDCAN_RXESC_F1DS FDCAN_RXESC_F1DS_Msk
5125#define FDCAN_RXESC_RBDS_Pos (8U)
5126#define FDCAN_RXESC_RBDS_Msk (0x7UL << FDCAN_RXESC_RBDS_Pos)
5127#define FDCAN_RXESC_RBDS FDCAN_RXESC_RBDS_Msk
5129/***************** Bit definition for FDCAN_TXBC register *********************/
5130#define FDCAN_TXBC_TBSA_Pos (2U)
5131#define FDCAN_TXBC_TBSA_Msk (0x3FFFUL << FDCAN_TXBC_TBSA_Pos)
5132#define FDCAN_TXBC_TBSA FDCAN_TXBC_TBSA_Msk
5133#define FDCAN_TXBC_NDTB_Pos (16U)
5134#define FDCAN_TXBC_NDTB_Msk (0x3FUL << FDCAN_TXBC_NDTB_Pos)
5135#define FDCAN_TXBC_NDTB FDCAN_TXBC_NDTB_Msk
5136#define FDCAN_TXBC_TFQS_Pos (24U)
5137#define FDCAN_TXBC_TFQS_Msk (0x3FUL << FDCAN_TXBC_TFQS_Pos)
5138#define FDCAN_TXBC_TFQS FDCAN_TXBC_TFQS_Msk
5139#define FDCAN_TXBC_TFQM_Pos (30U)
5140#define FDCAN_TXBC_TFQM_Msk (0x1UL << FDCAN_TXBC_TFQM_Pos)
5141#define FDCAN_TXBC_TFQM FDCAN_TXBC_TFQM_Msk
5143/***************** Bit definition for FDCAN_TXFQS register *********************/
5144#define FDCAN_TXFQS_TFFL_Pos (0U)
5145#define FDCAN_TXFQS_TFFL_Msk (0x3FUL << FDCAN_TXFQS_TFFL_Pos)
5146#define FDCAN_TXFQS_TFFL FDCAN_TXFQS_TFFL_Msk
5147#define FDCAN_TXFQS_TFGI_Pos (8U)
5148#define FDCAN_TXFQS_TFGI_Msk (0x1FUL << FDCAN_TXFQS_TFGI_Pos)
5149#define FDCAN_TXFQS_TFGI FDCAN_TXFQS_TFGI_Msk
5150#define FDCAN_TXFQS_TFQPI_Pos (16U)
5151#define FDCAN_TXFQS_TFQPI_Msk (0x1FUL << FDCAN_TXFQS_TFQPI_Pos)
5152#define FDCAN_TXFQS_TFQPI FDCAN_TXFQS_TFQPI_Msk
5153#define FDCAN_TXFQS_TFQF_Pos (21U)
5154#define FDCAN_TXFQS_TFQF_Msk (0x1UL << FDCAN_TXFQS_TFQF_Pos)
5155#define FDCAN_TXFQS_TFQF FDCAN_TXFQS_TFQF_Msk
5157/***************** Bit definition for FDCAN_TXESC register *********************/
5158#define FDCAN_TXESC_TBDS_Pos (0U)
5159#define FDCAN_TXESC_TBDS_Msk (0x7UL << FDCAN_TXESC_TBDS_Pos)
5160#define FDCAN_TXESC_TBDS FDCAN_TXESC_TBDS_Msk
5162/***************** Bit definition for FDCAN_TXBRP register *********************/
5163#define FDCAN_TXBRP_TRP_Pos (0U)
5164#define FDCAN_TXBRP_TRP_Msk (0xFFFFFFFFUL << FDCAN_TXBRP_TRP_Pos)
5165#define FDCAN_TXBRP_TRP FDCAN_TXBRP_TRP_Msk
5167/***************** Bit definition for FDCAN_TXBAR register *********************/
5168#define FDCAN_TXBAR_AR_Pos (0U)
5169#define FDCAN_TXBAR_AR_Msk (0xFFFFFFFFUL << FDCAN_TXBAR_AR_Pos)
5170#define FDCAN_TXBAR_AR FDCAN_TXBAR_AR_Msk
5172/***************** Bit definition for FDCAN_TXBCR register *********************/
5173#define FDCAN_TXBCR_CR_Pos (0U)
5174#define FDCAN_TXBCR_CR_Msk (0xFFFFFFFFUL << FDCAN_TXBCR_CR_Pos)
5175#define FDCAN_TXBCR_CR FDCAN_TXBCR_CR_Msk
5177/***************** Bit definition for FDCAN_TXBTO register *********************/
5178#define FDCAN_TXBTO_TO_Pos (0U)
5179#define FDCAN_TXBTO_TO_Msk (0xFFFFFFFFUL << FDCAN_TXBTO_TO_Pos)
5180#define FDCAN_TXBTO_TO FDCAN_TXBTO_TO_Msk
5182/***************** Bit definition for FDCAN_TXBCF register *********************/
5183#define FDCAN_TXBCF_CF_Pos (0U)
5184#define FDCAN_TXBCF_CF_Msk (0xFFFFFFFFUL << FDCAN_TXBCF_CF_Pos)
5185#define FDCAN_TXBCF_CF FDCAN_TXBCF_CF_Msk
5187/***************** Bit definition for FDCAN_TXBTIE register ********************/
5188#define FDCAN_TXBTIE_TIE_Pos (0U)
5189#define FDCAN_TXBTIE_TIE_Msk (0xFFFFFFFFUL << FDCAN_TXBTIE_TIE_Pos)
5190#define FDCAN_TXBTIE_TIE FDCAN_TXBTIE_TIE_Msk
5192/***************** Bit definition for FDCAN_ TXBCIE register *******************/
5193#define FDCAN_TXBCIE_CFIE_Pos (0U)
5194#define FDCAN_TXBCIE_CFIE_Msk (0xFFFFFFFFUL << FDCAN_TXBCIE_CFIE_Pos)
5195#define FDCAN_TXBCIE_CFIE FDCAN_TXBCIE_CFIE_Msk
5197/***************** Bit definition for FDCAN_TXEFC register *********************/
5198#define FDCAN_TXEFC_EFSA_Pos (2U)
5199#define FDCAN_TXEFC_EFSA_Msk (0x3FFFUL << FDCAN_TXEFC_EFSA_Pos)
5200#define FDCAN_TXEFC_EFSA FDCAN_TXEFC_EFSA_Msk
5201#define FDCAN_TXEFC_EFS_Pos (16U)
5202#define FDCAN_TXEFC_EFS_Msk (0x3FUL << FDCAN_TXEFC_EFS_Pos)
5203#define FDCAN_TXEFC_EFS FDCAN_TXEFC_EFS_Msk
5204#define FDCAN_TXEFC_EFWM_Pos (24U)
5205#define FDCAN_TXEFC_EFWM_Msk (0x3FUL << FDCAN_TXEFC_EFWM_Pos)
5206#define FDCAN_TXEFC_EFWM FDCAN_TXEFC_EFWM_Msk
5208/***************** Bit definition for FDCAN_TXEFS register *********************/
5209#define FDCAN_TXEFS_EFFL_Pos (0U)
5210#define FDCAN_TXEFS_EFFL_Msk (0x3FUL << FDCAN_TXEFS_EFFL_Pos)
5211#define FDCAN_TXEFS_EFFL FDCAN_TXEFS_EFFL_Msk
5212#define FDCAN_TXEFS_EFGI_Pos (8U)
5213#define FDCAN_TXEFS_EFGI_Msk (0x1FUL << FDCAN_TXEFS_EFGI_Pos)
5214#define FDCAN_TXEFS_EFGI FDCAN_TXEFS_EFGI_Msk
5215#define FDCAN_TXEFS_EFPI_Pos (16U)
5216#define FDCAN_TXEFS_EFPI_Msk (0x1FUL << FDCAN_TXEFS_EFPI_Pos)
5217#define FDCAN_TXEFS_EFPI FDCAN_TXEFS_EFPI_Msk
5218#define FDCAN_TXEFS_EFF_Pos (24U)
5219#define FDCAN_TXEFS_EFF_Msk (0x1UL << FDCAN_TXEFS_EFF_Pos)
5220#define FDCAN_TXEFS_EFF FDCAN_TXEFS_EFF_Msk
5221#define FDCAN_TXEFS_TEFL_Pos (25U)
5222#define FDCAN_TXEFS_TEFL_Msk (0x1UL << FDCAN_TXEFS_TEFL_Pos)
5223#define FDCAN_TXEFS_TEFL FDCAN_TXEFS_TEFL_Msk
5225/***************** Bit definition for FDCAN_TXEFA register *********************/
5226#define FDCAN_TXEFA_EFAI_Pos (0U)
5227#define FDCAN_TXEFA_EFAI_Msk (0x1FUL << FDCAN_TXEFA_EFAI_Pos)
5228#define FDCAN_TXEFA_EFAI FDCAN_TXEFA_EFAI_Msk
5230/***************** Bit definition for FDCAN_TTTMC register *********************/
5231#define FDCAN_TTTMC_TMSA_Pos (2U)
5232#define FDCAN_TTTMC_TMSA_Msk (0x3FFFUL << FDCAN_TTTMC_TMSA_Pos)
5233#define FDCAN_TTTMC_TMSA FDCAN_TTTMC_TMSA_Msk
5234#define FDCAN_TTTMC_TME_Pos (16U)
5235#define FDCAN_TTTMC_TME_Msk (0x7FUL << FDCAN_TTTMC_TME_Pos)
5236#define FDCAN_TTTMC_TME FDCAN_TTTMC_TME_Msk
5238/***************** Bit definition for FDCAN_TTRMC register *********************/
5239#define FDCAN_TTRMC_RID_Pos (0U)
5240#define FDCAN_TTRMC_RID_Msk (0x1FFFFFFFUL << FDCAN_TTRMC_RID_Pos)
5241#define FDCAN_TTRMC_RID FDCAN_TTRMC_RID_Msk
5242#define FDCAN_TTRMC_XTD_Pos (30U)
5243#define FDCAN_TTRMC_XTD_Msk (0x1UL << FDCAN_TTRMC_XTD_Pos)
5244#define FDCAN_TTRMC_XTD FDCAN_TTRMC_XTD_Msk
5245#define FDCAN_TTRMC_RMPS_Pos (31U)
5246#define FDCAN_TTRMC_RMPS_Msk (0x1UL << FDCAN_TTRMC_RMPS_Pos)
5247#define FDCAN_TTRMC_RMPS FDCAN_TTRMC_RMPS_Msk
5249/***************** Bit definition for FDCAN_TTOCF register *********************/
5250#define FDCAN_TTOCF_OM_Pos (0U)
5251#define FDCAN_TTOCF_OM_Msk (0x3UL << FDCAN_TTOCF_OM_Pos)
5252#define FDCAN_TTOCF_OM FDCAN_TTOCF_OM_Msk
5253#define FDCAN_TTOCF_GEN_Pos (3U)
5254#define FDCAN_TTOCF_GEN_Msk (0x1UL << FDCAN_TTOCF_GEN_Pos)
5255#define FDCAN_TTOCF_GEN FDCAN_TTOCF_GEN_Msk
5256#define FDCAN_TTOCF_TM_Pos (4U)
5257#define FDCAN_TTOCF_TM_Msk (0x1UL << FDCAN_TTOCF_TM_Pos)
5258#define FDCAN_TTOCF_TM FDCAN_TTOCF_TM_Msk
5259#define FDCAN_TTOCF_LDSDL_Pos (5U)
5260#define FDCAN_TTOCF_LDSDL_Msk (0x7UL << FDCAN_TTOCF_LDSDL_Pos)
5261#define FDCAN_TTOCF_LDSDL FDCAN_TTOCF_LDSDL_Msk
5262#define FDCAN_TTOCF_IRTO_Pos (8U)
5263#define FDCAN_TTOCF_IRTO_Msk (0x7FUL << FDCAN_TTOCF_IRTO_Pos)
5264#define FDCAN_TTOCF_IRTO FDCAN_TTOCF_IRTO_Msk
5265#define FDCAN_TTOCF_EECS_Pos (15U)
5266#define FDCAN_TTOCF_EECS_Msk (0x1UL << FDCAN_TTOCF_EECS_Pos)
5267#define FDCAN_TTOCF_EECS FDCAN_TTOCF_EECS_Msk
5268#define FDCAN_TTOCF_AWL_Pos (16U)
5269#define FDCAN_TTOCF_AWL_Msk (0xFFUL << FDCAN_TTOCF_AWL_Pos)
5270#define FDCAN_TTOCF_AWL FDCAN_TTOCF_AWL_Msk
5271#define FDCAN_TTOCF_EGTF_Pos (24U)
5272#define FDCAN_TTOCF_EGTF_Msk (0x1UL << FDCAN_TTOCF_EGTF_Pos)
5273#define FDCAN_TTOCF_EGTF FDCAN_TTOCF_EGTF_Msk
5274#define FDCAN_TTOCF_ECC_Pos (25U)
5275#define FDCAN_TTOCF_ECC_Msk (0x1UL << FDCAN_TTOCF_ECC_Pos)
5276#define FDCAN_TTOCF_ECC FDCAN_TTOCF_ECC_Msk
5277#define FDCAN_TTOCF_EVTP_Pos (26U)
5278#define FDCAN_TTOCF_EVTP_Msk (0x1UL << FDCAN_TTOCF_EVTP_Pos)
5279#define FDCAN_TTOCF_EVTP FDCAN_TTOCF_EVTP_Msk
5281/***************** Bit definition for FDCAN_TTMLM register *********************/
5282#define FDCAN_TTMLM_CCM_Pos (0U)
5283#define FDCAN_TTMLM_CCM_Msk (0x3FUL << FDCAN_TTMLM_CCM_Pos)
5284#define FDCAN_TTMLM_CCM FDCAN_TTMLM_CCM_Msk
5285#define FDCAN_TTMLM_CSS_Pos (6U)
5286#define FDCAN_TTMLM_CSS_Msk (0x3UL << FDCAN_TTMLM_CSS_Pos)
5287#define FDCAN_TTMLM_CSS FDCAN_TTMLM_CSS_Msk
5288#define FDCAN_TTMLM_TXEW_Pos (8U)
5289#define FDCAN_TTMLM_TXEW_Msk (0xFUL << FDCAN_TTMLM_TXEW_Pos)
5290#define FDCAN_TTMLM_TXEW FDCAN_TTMLM_TXEW_Msk
5291#define FDCAN_TTMLM_ENTT_Pos (16U)
5292#define FDCAN_TTMLM_ENTT_Msk (0xFFFUL << FDCAN_TTMLM_ENTT_Pos)
5293#define FDCAN_TTMLM_ENTT FDCAN_TTMLM_ENTT_Msk
5295/***************** Bit definition for FDCAN_TURCF register *********************/
5296#define FDCAN_TURCF_NCL_Pos (0U)
5297#define FDCAN_TURCF_NCL_Msk (0xFFFFUL << FDCAN_TURCF_NCL_Pos)
5298#define FDCAN_TURCF_NCL FDCAN_TURCF_NCL_Msk
5299#define FDCAN_TURCF_DC_Pos (16U)
5300#define FDCAN_TURCF_DC_Msk (0x3FFFUL << FDCAN_TURCF_DC_Pos)
5301#define FDCAN_TURCF_DC FDCAN_TURCF_DC_Msk
5302#define FDCAN_TURCF_ELT_Pos (31U)
5303#define FDCAN_TURCF_ELT_Msk (0x1UL << FDCAN_TURCF_ELT_Pos)
5304#define FDCAN_TURCF_ELT FDCAN_TURCF_ELT_Msk
5306/***************** Bit definition for FDCAN_TTOCN register ********************/
5307#define FDCAN_TTOCN_SGT_Pos (0U)
5308#define FDCAN_TTOCN_SGT_Msk (0x1UL << FDCAN_TTOCN_SGT_Pos)
5309#define FDCAN_TTOCN_SGT FDCAN_TTOCN_SGT_Msk
5310#define FDCAN_TTOCN_ECS_Pos (1U)
5311#define FDCAN_TTOCN_ECS_Msk (0x1UL << FDCAN_TTOCN_ECS_Pos)
5312#define FDCAN_TTOCN_ECS FDCAN_TTOCN_ECS_Msk
5313#define FDCAN_TTOCN_SWP_Pos (2U)
5314#define FDCAN_TTOCN_SWP_Msk (0x1UL << FDCAN_TTOCN_SWP_Pos)
5315#define FDCAN_TTOCN_SWP FDCAN_TTOCN_SWP_Msk
5316#define FDCAN_TTOCN_SWS_Pos (3U)
5317#define FDCAN_TTOCN_SWS_Msk (0x3UL << FDCAN_TTOCN_SWS_Pos)
5318#define FDCAN_TTOCN_SWS FDCAN_TTOCN_SWS_Msk
5319#define FDCAN_TTOCN_RTIE_Pos (5U)
5320#define FDCAN_TTOCN_RTIE_Msk (0x1UL << FDCAN_TTOCN_RTIE_Pos)
5321#define FDCAN_TTOCN_RTIE FDCAN_TTOCN_RTIE_Msk
5322#define FDCAN_TTOCN_TMC_Pos (6U)
5323#define FDCAN_TTOCN_TMC_Msk (0x3UL << FDCAN_TTOCN_TMC_Pos)
5324#define FDCAN_TTOCN_TMC FDCAN_TTOCN_TMC_Msk
5325#define FDCAN_TTOCN_TTIE_Pos (8U)
5326#define FDCAN_TTOCN_TTIE_Msk (0x1UL << FDCAN_TTOCN_TTIE_Pos)
5327#define FDCAN_TTOCN_TTIE FDCAN_TTOCN_TTIE_Msk
5328#define FDCAN_TTOCN_GCS_Pos (9U)
5329#define FDCAN_TTOCN_GCS_Msk (0x1UL << FDCAN_TTOCN_GCS_Pos)
5330#define FDCAN_TTOCN_GCS FDCAN_TTOCN_GCS_Msk
5331#define FDCAN_TTOCN_FGP_Pos (10U)
5332#define FDCAN_TTOCN_FGP_Msk (0x1UL << FDCAN_TTOCN_FGP_Pos)
5333#define FDCAN_TTOCN_FGP FDCAN_TTOCN_FGP_Msk
5334#define FDCAN_TTOCN_TMG_Pos (11U)
5335#define FDCAN_TTOCN_TMG_Msk (0x1UL << FDCAN_TTOCN_TMG_Pos)
5336#define FDCAN_TTOCN_TMG FDCAN_TTOCN_TMG_Msk
5337#define FDCAN_TTOCN_NIG_Pos (12U)
5338#define FDCAN_TTOCN_NIG_Msk (0x1UL << FDCAN_TTOCN_NIG_Pos)
5339#define FDCAN_TTOCN_NIG FDCAN_TTOCN_NIG_Msk
5340#define FDCAN_TTOCN_ESCN_Pos (13U)
5341#define FDCAN_TTOCN_ESCN_Msk (0x1UL << FDCAN_TTOCN_ESCN_Pos)
5342#define FDCAN_TTOCN_ESCN FDCAN_TTOCN_ESCN_Msk
5343#define FDCAN_TTOCN_LCKC_Pos (15U)
5344#define FDCAN_TTOCN_LCKC_Msk (0x1UL << FDCAN_TTOCN_LCKC_Pos)
5345#define FDCAN_TTOCN_LCKC FDCAN_TTOCN_LCKC_Msk
5347/***************** Bit definition for FDCAN_TTGTP register ********************/
5348#define FDCAN_TTGTP_TP_Pos (0U)
5349#define FDCAN_TTGTP_TP_Msk (0xFFFFUL << FDCAN_TTGTP_TP_Pos)
5350#define FDCAN_TTGTP_TP FDCAN_TTGTP_TP_Msk
5351#define FDCAN_TTGTP_CTP_Pos (16U)
5352#define FDCAN_TTGTP_CTP_Msk (0xFFFFUL << FDCAN_TTGTP_CTP_Pos)
5353#define FDCAN_TTGTP_CTP FDCAN_TTGTP_CTP_Msk
5355/***************** Bit definition for FDCAN_TTTMK register ********************/
5356#define FDCAN_TTTMK_TM_Pos (0U)
5357#define FDCAN_TTTMK_TM_Msk (0xFFFFUL << FDCAN_TTTMK_TM_Pos)
5358#define FDCAN_TTTMK_TM FDCAN_TTTMK_TM_Msk
5359#define FDCAN_TTTMK_TICC_Pos (16U)
5360#define FDCAN_TTTMK_TICC_Msk (0x7FUL << FDCAN_TTTMK_TICC_Pos)
5361#define FDCAN_TTTMK_TICC FDCAN_TTTMK_TICC_Msk
5362#define FDCAN_TTTMK_LCKM_Pos (31U)
5363#define FDCAN_TTTMK_LCKM_Msk (0x1UL << FDCAN_TTTMK_LCKM_Pos)
5364#define FDCAN_TTTMK_LCKM FDCAN_TTTMK_LCKM_Msk
5366/***************** Bit definition for FDCAN_TTIR register ********************/
5367#define FDCAN_TTIR_SBC_Pos (0U)
5368#define FDCAN_TTIR_SBC_Msk (0x1UL << FDCAN_TTIR_SBC_Pos)
5369#define FDCAN_TTIR_SBC FDCAN_TTIR_SBC_Msk
5370#define FDCAN_TTIR_SMC_Pos (1U)
5371#define FDCAN_TTIR_SMC_Msk (0x1UL << FDCAN_TTIR_SMC_Pos)
5372#define FDCAN_TTIR_SMC FDCAN_TTIR_SMC_Msk
5373#define FDCAN_TTIR_CSM_Pos (2U)
5374#define FDCAN_TTIR_CSM_Msk (0x1UL << FDCAN_TTIR_CSM_Pos)
5375#define FDCAN_TTIR_CSM FDCAN_TTIR_CSM_Msk
5376#define FDCAN_TTIR_SOG_Pos (3U)
5377#define FDCAN_TTIR_SOG_Msk (0x1UL << FDCAN_TTIR_SOG_Pos)
5378#define FDCAN_TTIR_SOG FDCAN_TTIR_SOG_Msk
5379#define FDCAN_TTIR_RTMI_Pos (4U)
5380#define FDCAN_TTIR_RTMI_Msk (0x1UL << FDCAN_TTIR_RTMI_Pos)
5381#define FDCAN_TTIR_RTMI FDCAN_TTIR_RTMI_Msk
5382#define FDCAN_TTIR_TTMI_Pos (5U)
5383#define FDCAN_TTIR_TTMI_Msk (0x1UL << FDCAN_TTIR_TTMI_Pos)
5384#define FDCAN_TTIR_TTMI FDCAN_TTIR_TTMI_Msk
5385#define FDCAN_TTIR_SWE_Pos (6U)
5386#define FDCAN_TTIR_SWE_Msk (0x1UL << FDCAN_TTIR_SWE_Pos)
5387#define FDCAN_TTIR_SWE FDCAN_TTIR_SWE_Msk
5388#define FDCAN_TTIR_GTW_Pos (7U)
5389#define FDCAN_TTIR_GTW_Msk (0x1UL << FDCAN_TTIR_GTW_Pos)
5390#define FDCAN_TTIR_GTW FDCAN_TTIR_GTW_Msk
5391#define FDCAN_TTIR_GTD_Pos (8U)
5392#define FDCAN_TTIR_GTD_Msk (0x1UL << FDCAN_TTIR_GTD_Pos)
5393#define FDCAN_TTIR_GTD FDCAN_TTIR_GTD_Msk
5394#define FDCAN_TTIR_GTE_Pos (9U)
5395#define FDCAN_TTIR_GTE_Msk (0x1UL << FDCAN_TTIR_GTE_Pos)
5396#define FDCAN_TTIR_GTE FDCAN_TTIR_GTE_Msk
5397#define FDCAN_TTIR_TXU_Pos (10U)
5398#define FDCAN_TTIR_TXU_Msk (0x1UL << FDCAN_TTIR_TXU_Pos)
5399#define FDCAN_TTIR_TXU FDCAN_TTIR_TXU_Msk
5400#define FDCAN_TTIR_TXO_Pos (11U)
5401#define FDCAN_TTIR_TXO_Msk (0x1UL << FDCAN_TTIR_TXO_Pos)
5402#define FDCAN_TTIR_TXO FDCAN_TTIR_TXO_Msk
5403#define FDCAN_TTIR_SE1_Pos (12U)
5404#define FDCAN_TTIR_SE1_Msk (0x1UL << FDCAN_TTIR_SE1_Pos)
5405#define FDCAN_TTIR_SE1 FDCAN_TTIR_SE1_Msk
5406#define FDCAN_TTIR_SE2_Pos (13U)
5407#define FDCAN_TTIR_SE2_Msk (0x1UL << FDCAN_TTIR_SE2_Pos)
5408#define FDCAN_TTIR_SE2 FDCAN_TTIR_SE2_Msk
5409#define FDCAN_TTIR_ELC_Pos (14U)
5410#define FDCAN_TTIR_ELC_Msk (0x1UL << FDCAN_TTIR_ELC_Pos)
5411#define FDCAN_TTIR_ELC FDCAN_TTIR_ELC_Msk
5412#define FDCAN_TTIR_IWT_Pos (15U)
5413#define FDCAN_TTIR_IWT_Msk (0x1UL << FDCAN_TTIR_IWT_Pos)
5414#define FDCAN_TTIR_IWT FDCAN_TTIR_IWT_Msk
5415#define FDCAN_TTIR_WT_Pos (16U)
5416#define FDCAN_TTIR_WT_Msk (0x1UL << FDCAN_TTIR_WT_Pos)
5417#define FDCAN_TTIR_WT FDCAN_TTIR_WT_Msk
5418#define FDCAN_TTIR_AW_Pos (17U)
5419#define FDCAN_TTIR_AW_Msk (0x1UL << FDCAN_TTIR_AW_Pos)
5420#define FDCAN_TTIR_AW FDCAN_TTIR_AW_Msk
5421#define FDCAN_TTIR_CER_Pos (18U)
5422#define FDCAN_TTIR_CER_Msk (0x1UL << FDCAN_TTIR_CER_Pos)
5423#define FDCAN_TTIR_CER FDCAN_TTIR_CER_Msk
5425/***************** Bit definition for FDCAN_TTIE register ********************/
5426#define FDCAN_TTIE_SBCE_Pos (0U)
5427#define FDCAN_TTIE_SBCE_Msk (0x1UL << FDCAN_TTIE_SBCE_Pos)
5428#define FDCAN_TTIE_SBCE FDCAN_TTIE_SBCE_Msk
5429#define FDCAN_TTIE_SMCE_Pos (1U)
5430#define FDCAN_TTIE_SMCE_Msk (0x1UL << FDCAN_TTIE_SMCE_Pos)
5431#define FDCAN_TTIE_SMCE FDCAN_TTIE_SMCE_Msk
5432#define FDCAN_TTIE_CSME_Pos (2U)
5433#define FDCAN_TTIE_CSME_Msk (0x1UL << FDCAN_TTIE_CSME_Pos)
5434#define FDCAN_TTIE_CSME FDCAN_TTIE_CSME_Msk
5435#define FDCAN_TTIE_SOGE_Pos (3U)
5436#define FDCAN_TTIE_SOGE_Msk (0x1UL << FDCAN_TTIE_SOGE_Pos)
5437#define FDCAN_TTIE_SOGE FDCAN_TTIE_SOGE_Msk
5438#define FDCAN_TTIE_RTMIE_Pos (4U)
5439#define FDCAN_TTIE_RTMIE_Msk (0x1UL << FDCAN_TTIE_RTMIE_Pos)
5440#define FDCAN_TTIE_RTMIE FDCAN_TTIE_RTMIE_Msk
5441#define FDCAN_TTIE_TTMIE_Pos (5U)
5442#define FDCAN_TTIE_TTMIE_Msk (0x1UL << FDCAN_TTIE_TTMIE_Pos)
5443#define FDCAN_TTIE_TTMIE FDCAN_TTIE_TTMIE_Msk
5444#define FDCAN_TTIE_SWEE_Pos (6U)
5445#define FDCAN_TTIE_SWEE_Msk (0x1UL << FDCAN_TTIE_SWEE_Pos)
5446#define FDCAN_TTIE_SWEE FDCAN_TTIE_SWEE_Msk
5447#define FDCAN_TTIE_GTWE_Pos (7U)
5448#define FDCAN_TTIE_GTWE_Msk (0x1UL << FDCAN_TTIE_GTWE_Pos)
5449#define FDCAN_TTIE_GTWE FDCAN_TTIE_GTWE_Msk
5450#define FDCAN_TTIE_GTDE_Pos (8U)
5451#define FDCAN_TTIE_GTDE_Msk (0x1UL << FDCAN_TTIE_GTDE_Pos)
5452#define FDCAN_TTIE_GTDE FDCAN_TTIE_GTDE_Msk
5453#define FDCAN_TTIE_GTEE_Pos (9U)
5454#define FDCAN_TTIE_GTEE_Msk (0x1UL << FDCAN_TTIE_GTEE_Pos)
5455#define FDCAN_TTIE_GTEE FDCAN_TTIE_GTEE_Msk
5456#define FDCAN_TTIE_TXUE_Pos (10U)
5457#define FDCAN_TTIE_TXUE_Msk (0x1UL << FDCAN_TTIE_TXUE_Pos)
5458#define FDCAN_TTIE_TXUE FDCAN_TTIE_TXUE_Msk
5459#define FDCAN_TTIE_TXOE_Pos (11U)
5460#define FDCAN_TTIE_TXOE_Msk (0x1UL << FDCAN_TTIE_TXOE_Pos)
5461#define FDCAN_TTIE_TXOE FDCAN_TTIE_TXOE_Msk
5462#define FDCAN_TTIE_SE1E_Pos (12U)
5463#define FDCAN_TTIE_SE1E_Msk (0x1UL << FDCAN_TTIE_SE1E_Pos)
5464#define FDCAN_TTIE_SE1E FDCAN_TTIE_SE1E_Msk
5465#define FDCAN_TTIE_SE2E_Pos (13U)
5466#define FDCAN_TTIE_SE2E_Msk (0x1UL << FDCAN_TTIE_SE2E_Pos)
5467#define FDCAN_TTIE_SE2E FDCAN_TTIE_SE2E_Msk
5468#define FDCAN_TTIE_ELCE_Pos (14U)
5469#define FDCAN_TTIE_ELCE_Msk (0x1UL << FDCAN_TTIE_ELCE_Pos)
5470#define FDCAN_TTIE_ELCE FDCAN_TTIE_ELCE_Msk
5471#define FDCAN_TTIE_IWTE_Pos (15U)
5472#define FDCAN_TTIE_IWTE_Msk (0x1UL << FDCAN_TTIE_IWTE_Pos)
5473#define FDCAN_TTIE_IWTE FDCAN_TTIE_IWTE_Msk
5474#define FDCAN_TTIE_WTE_Pos (16U)
5475#define FDCAN_TTIE_WTE_Msk (0x1UL << FDCAN_TTIE_WTE_Pos)
5476#define FDCAN_TTIE_WTE FDCAN_TTIE_WTE_Msk
5477#define FDCAN_TTIE_AWE_Pos (17U)
5478#define FDCAN_TTIE_AWE_Msk (0x1UL << FDCAN_TTIE_AWE_Pos)
5479#define FDCAN_TTIE_AWE FDCAN_TTIE_AWE_Msk
5480#define FDCAN_TTIE_CERE_Pos (18U)
5481#define FDCAN_TTIE_CERE_Msk (0x1UL << FDCAN_TTIE_CERE_Pos)
5482#define FDCAN_TTIE_CERE FDCAN_TTIE_CERE_Msk
5484/***************** Bit definition for FDCAN_TTILS register ********************/
5485#define FDCAN_TTILS_SBCS_Pos (0U)
5486#define FDCAN_TTILS_SBCS_Msk (0x1UL << FDCAN_TTILS_SBCS_Pos)
5487#define FDCAN_TTILS_SBCS FDCAN_TTILS_SBCS_Msk
5488#define FDCAN_TTILS_SMCS_Pos (1U)
5489#define FDCAN_TTILS_SMCS_Msk (0x1UL << FDCAN_TTILS_SMCS_Pos)
5490#define FDCAN_TTILS_SMCS FDCAN_TTILS_SMCS_Msk
5491#define FDCAN_TTILS_CSMS_Pos (2U)
5492#define FDCAN_TTILS_CSMS_Msk (0x1UL << FDCAN_TTILS_CSMS_Pos)
5493#define FDCAN_TTILS_CSMS FDCAN_TTILS_CSMS_Msk
5494#define FDCAN_TTILS_SOGS_Pos (3U)
5495#define FDCAN_TTILS_SOGS_Msk (0x1UL << FDCAN_TTILS_SOGS_Pos)
5496#define FDCAN_TTILS_SOGS FDCAN_TTILS_SOGS_Msk
5497#define FDCAN_TTILS_RTMIS_Pos (4U)
5498#define FDCAN_TTILS_RTMIS_Msk (0x1UL << FDCAN_TTILS_RTMIS_Pos)
5499#define FDCAN_TTILS_RTMIS FDCAN_TTILS_RTMIS_Msk
5500#define FDCAN_TTILS_TTMIS_Pos (5U)
5501#define FDCAN_TTILS_TTMIS_Msk (0x1UL << FDCAN_TTILS_TTMIS_Pos)
5502#define FDCAN_TTILS_TTMIS FDCAN_TTILS_TTMIS_Msk
5503#define FDCAN_TTILS_SWES_Pos (6U)
5504#define FDCAN_TTILS_SWES_Msk (0x1UL << FDCAN_TTILS_SWES_Pos)
5505#define FDCAN_TTILS_SWES FDCAN_TTILS_SWES_Msk
5506#define FDCAN_TTILS_GTWS_Pos (7U)
5507#define FDCAN_TTILS_GTWS_Msk (0x1UL << FDCAN_TTILS_GTWS_Pos)
5508#define FDCAN_TTILS_GTWS FDCAN_TTILS_GTWS_Msk
5509#define FDCAN_TTILS_GTDS_Pos (8U)
5510#define FDCAN_TTILS_GTDS_Msk (0x1UL << FDCAN_TTILS_GTDS_Pos)
5511#define FDCAN_TTILS_GTDS FDCAN_TTILS_GTDS_Msk
5512#define FDCAN_TTILS_GTES_Pos (9U)
5513#define FDCAN_TTILS_GTES_Msk (0x1UL << FDCAN_TTILS_GTES_Pos)
5514#define FDCAN_TTILS_GTES FDCAN_TTILS_GTES_Msk
5515#define FDCAN_TTILS_TXUS_Pos (10U)
5516#define FDCAN_TTILS_TXUS_Msk (0x1UL << FDCAN_TTILS_TXUS_Pos)
5517#define FDCAN_TTILS_TXUS FDCAN_TTILS_TXUS_Msk
5518#define FDCAN_TTILS_TXOS_Pos (11U)
5519#define FDCAN_TTILS_TXOS_Msk (0x1UL << FDCAN_TTILS_TXOS_Pos)
5520#define FDCAN_TTILS_TXOS FDCAN_TTILS_TXOS_Msk
5521#define FDCAN_TTILS_SE1S_Pos (12U)
5522#define FDCAN_TTILS_SE1S_Msk (0x1UL << FDCAN_TTILS_SE1S_Pos)
5523#define FDCAN_TTILS_SE1S FDCAN_TTILS_SE1S_Msk
5524#define FDCAN_TTILS_SE2S_Pos (13U)
5525#define FDCAN_TTILS_SE2S_Msk (0x1UL << FDCAN_TTILS_SE2S_Pos)
5526#define FDCAN_TTILS_SE2S FDCAN_TTILS_SE2S_Msk
5527#define FDCAN_TTILS_ELCS_Pos (14U)
5528#define FDCAN_TTILS_ELCS_Msk (0x1UL << FDCAN_TTILS_ELCS_Pos)
5529#define FDCAN_TTILS_ELCS FDCAN_TTILS_ELCS_Msk
5530#define FDCAN_TTILS_IWTS_Pos (15U)
5531#define FDCAN_TTILS_IWTS_Msk (0x1UL << FDCAN_TTILS_IWTS_Pos)
5532#define FDCAN_TTILS_IWTS FDCAN_TTILS_IWTS_Msk
5533#define FDCAN_TTILS_WTS_Pos (16U)
5534#define FDCAN_TTILS_WTS_Msk (0x1UL << FDCAN_TTILS_WTS_Pos)
5535#define FDCAN_TTILS_WTS FDCAN_TTILS_WTS_Msk
5536#define FDCAN_TTILS_AWS_Pos (17U)
5537#define FDCAN_TTILS_AWS_Msk (0x1UL << FDCAN_TTILS_AWS_Pos)
5538#define FDCAN_TTILS_AWS FDCAN_TTILS_AWS_Msk
5539#define FDCAN_TTILS_CERS_Pos (18U)
5540#define FDCAN_TTILS_CERS_Msk (0x1UL << FDCAN_TTILS_CERS_Pos)
5541#define FDCAN_TTILS_CERS FDCAN_TTILS_CERS_Msk
5543/***************** Bit definition for FDCAN_TTOST register ********************/
5544#define FDCAN_TTOST_EL_Pos (0U)
5545#define FDCAN_TTOST_EL_Msk (0x3UL << FDCAN_TTOST_EL_Pos)
5546#define FDCAN_TTOST_EL FDCAN_TTOST_EL_Msk
5547#define FDCAN_TTOST_MS_Pos (2U)
5548#define FDCAN_TTOST_MS_Msk (0x3UL << FDCAN_TTOST_MS_Pos)
5549#define FDCAN_TTOST_MS FDCAN_TTOST_MS_Msk
5550#define FDCAN_TTOST_SYS_Pos (4U)
5551#define FDCAN_TTOST_SYS_Msk (0x3UL << FDCAN_TTOST_SYS_Pos)
5552#define FDCAN_TTOST_SYS FDCAN_TTOST_SYS_Msk
5553#define FDCAN_TTOST_QGTP_Pos (6U)
5554#define FDCAN_TTOST_QGTP_Msk (0x1UL << FDCAN_TTOST_QGTP_Pos)
5555#define FDCAN_TTOST_QGTP FDCAN_TTOST_QGTP_Msk
5556#define FDCAN_TTOST_QCS_Pos (7U)
5557#define FDCAN_TTOST_QCS_Msk (0x1UL << FDCAN_TTOST_QCS_Pos)
5558#define FDCAN_TTOST_QCS FDCAN_TTOST_QCS_Msk
5559#define FDCAN_TTOST_RTO_Pos (8U)
5560#define FDCAN_TTOST_RTO_Msk (0xFFUL << FDCAN_TTOST_RTO_Pos)
5561#define FDCAN_TTOST_RTO FDCAN_TTOST_RTO_Msk
5562#define FDCAN_TTOST_WGTD_Pos (22U)
5563#define FDCAN_TTOST_WGTD_Msk (0x1UL << FDCAN_TTOST_WGTD_Pos)
5564#define FDCAN_TTOST_WGTD FDCAN_TTOST_WGTD_Msk
5565#define FDCAN_TTOST_GFI_Pos (23U)
5566#define FDCAN_TTOST_GFI_Msk (0x1UL << FDCAN_TTOST_GFI_Pos)
5567#define FDCAN_TTOST_GFI FDCAN_TTOST_GFI_Msk
5568#define FDCAN_TTOST_TMP_Pos (24U)
5569#define FDCAN_TTOST_TMP_Msk (0x7UL << FDCAN_TTOST_TMP_Pos)
5570#define FDCAN_TTOST_TMP FDCAN_TTOST_TMP_Msk
5571#define FDCAN_TTOST_GSI_Pos (27U)
5572#define FDCAN_TTOST_GSI_Msk (0x1UL << FDCAN_TTOST_GSI_Pos)
5573#define FDCAN_TTOST_GSI FDCAN_TTOST_GSI_Msk
5574#define FDCAN_TTOST_WFE_Pos (28U)
5575#define FDCAN_TTOST_WFE_Msk (0x1UL << FDCAN_TTOST_WFE_Pos)
5576#define FDCAN_TTOST_WFE FDCAN_TTOST_WFE_Msk
5577#define FDCAN_TTOST_AWE_Pos (29U)
5578#define FDCAN_TTOST_AWE_Msk (0x1UL << FDCAN_TTOST_AWE_Pos)
5579#define FDCAN_TTOST_AWE FDCAN_TTOST_AWE_Msk
5580#define FDCAN_TTOST_WECS_Pos (30U)
5581#define FDCAN_TTOST_WECS_Msk (0x1UL << FDCAN_TTOST_WECS_Pos)
5582#define FDCAN_TTOST_WECS FDCAN_TTOST_WECS_Msk
5583#define FDCAN_TTOST_SPL_Pos (31U)
5584#define FDCAN_TTOST_SPL_Msk (0x1UL << FDCAN_TTOST_SPL_Pos)
5585#define FDCAN_TTOST_SPL FDCAN_TTOST_SPL_Msk
5587/***************** Bit definition for FDCAN_TURNA register ********************/
5588#define FDCAN_TURNA_NAV_Pos (0U)
5589#define FDCAN_TURNA_NAV_Msk (0x3FFFFUL << FDCAN_TURNA_NAV_Pos)
5590#define FDCAN_TURNA_NAV FDCAN_TURNA_NAV_Msk
5592/***************** Bit definition for FDCAN_TTLGT register ********************/
5593#define FDCAN_TTLGT_LT_Pos (0U)
5594#define FDCAN_TTLGT_LT_Msk (0xFFFFUL << FDCAN_TTLGT_LT_Pos)
5595#define FDCAN_TTLGT_LT FDCAN_TTLGT_LT_Msk
5596#define FDCAN_TTLGT_GT_Pos (16U)
5597#define FDCAN_TTLGT_GT_Msk (0xFFFFUL << FDCAN_TTLGT_GT_Pos)
5598#define FDCAN_TTLGT_GT FDCAN_TTLGT_GT_Msk
5600/***************** Bit definition for FDCAN_TTCTC register ********************/
5601#define FDCAN_TTCTC_CT_Pos (0U)
5602#define FDCAN_TTCTC_CT_Msk (0xFFFFUL << FDCAN_TTCTC_CT_Pos)
5603#define FDCAN_TTCTC_CT FDCAN_TTCTC_CT_Msk
5604#define FDCAN_TTCTC_CC_Pos (16U)
5605#define FDCAN_TTCTC_CC_Msk (0x3FUL << FDCAN_TTCTC_CC_Pos)
5606#define FDCAN_TTCTC_CC FDCAN_TTCTC_CC_Msk
5608/***************** Bit definition for FDCAN_TTCPT register ********************/
5609#define FDCAN_TTCPT_CCV_Pos (0U)
5610#define FDCAN_TTCPT_CCV_Msk (0x3FUL << FDCAN_TTCPT_CCV_Pos)
5611#define FDCAN_TTCPT_CCV FDCAN_TTCPT_CCV_Msk
5612#define FDCAN_TTCPT_SWV_Pos (16U)
5613#define FDCAN_TTCPT_SWV_Msk (0xFFFFUL << FDCAN_TTCPT_SWV_Pos)
5614#define FDCAN_TTCPT_SWV FDCAN_TTCPT_SWV_Msk
5616/***************** Bit definition for FDCAN_TTCSM register ********************/
5617#define FDCAN_TTCSM_CSM_Pos (0U)
5618#define FDCAN_TTCSM_CSM_Msk (0xFFFFUL << FDCAN_TTCSM_CSM_Pos)
5619#define FDCAN_TTCSM_CSM FDCAN_TTCSM_CSM_Msk
5621/***************** Bit definition for FDCAN_TTTS register *********************/
5622#define FDCAN_TTTS_SWTSEL_Pos (0U)
5623#define FDCAN_TTTS_SWTSEL_Msk (0x3UL << FDCAN_TTTS_SWTSEL_Pos)
5624#define FDCAN_TTTS_SWTSEL FDCAN_TTTS_SWTSEL_Msk
5625#define FDCAN_TTTS_EVTSEL_Pos (4U)
5626#define FDCAN_TTTS_EVTSEL_Msk (0x3UL << FDCAN_TTTS_EVTSEL_Pos)
5627#define FDCAN_TTTS_EVTSEL FDCAN_TTTS_EVTSEL_Msk
5629/********************************************************************************/
5630/* */
5631/* FDCANCCU (Clock Calibration unit) */
5632/* */
5633/********************************************************************************/
5634
5635/***************** Bit definition for FDCANCCU_CREL register ******************/
5636#define FDCANCCU_CREL_DAY_Pos (0U)
5637#define FDCANCCU_CREL_DAY_Msk (0xFFUL << FDCANCCU_CREL_DAY_Pos)
5638#define FDCANCCU_CREL_DAY FDCANCCU_CREL_DAY_Msk
5639#define FDCANCCU_CREL_MON_Pos (8U)
5640#define FDCANCCU_CREL_MON_Msk (0xFFUL << FDCANCCU_CREL_MON_Pos)
5641#define FDCANCCU_CREL_MON FDCANCCU_CREL_MON_Msk
5642#define FDCANCCU_CREL_YEAR_Pos (16U)
5643#define FDCANCCU_CREL_YEAR_Msk (0xFUL << FDCANCCU_CREL_YEAR_Pos)
5644#define FDCANCCU_CREL_YEAR FDCANCCU_CREL_YEAR_Msk
5645#define FDCANCCU_CREL_SUBSTEP_Pos (20U)
5646#define FDCANCCU_CREL_SUBSTEP_Msk (0xFUL << FDCANCCU_CREL_SUBSTEP_Pos)
5647#define FDCANCCU_CREL_SUBSTEP FDCANCCU_CREL_SUBSTEP_Msk
5648#define FDCANCCU_CREL_STEP_Pos (24U)
5649#define FDCANCCU_CREL_STEP_Msk (0xFUL << FDCANCCU_CREL_STEP_Pos)
5650#define FDCANCCU_CREL_STEP FDCANCCU_CREL_STEP_Msk
5651#define FDCANCCU_CREL_REL_Pos (28U)
5652#define FDCANCCU_CREL_REL_Msk (0xFUL << FDCANCCU_CREL_REL_Pos)
5653#define FDCANCCU_CREL_REL FDCANCCU_CREL_REL_Msk
5655/***************** Bit definition for FDCANCCU_CCFG register ******************/
5656#define FDCANCCU_CCFG_TQBT_Pos (0U)
5657#define FDCANCCU_CCFG_TQBT_Msk (0x1FUL << FDCANCCU_CCFG_TQBT_Pos)
5658#define FDCANCCU_CCFG_TQBT FDCANCCU_CCFG_TQBT_Msk
5659#define FDCANCCU_CCFG_BCC_Pos (6U)
5660#define FDCANCCU_CCFG_BCC_Msk (0x1UL << FDCANCCU_CCFG_BCC_Pos)
5661#define FDCANCCU_CCFG_BCC FDCANCCU_CCFG_BCC_Msk
5662#define FDCANCCU_CCFG_CFL_Pos (7U)
5663#define FDCANCCU_CCFG_CFL_Msk (0x1UL << FDCANCCU_CCFG_CFL_Pos)
5664#define FDCANCCU_CCFG_CFL FDCANCCU_CCFG_CFL_Msk
5665#define FDCANCCU_CCFG_OCPM_Pos (8U)
5666#define FDCANCCU_CCFG_OCPM_Msk (0xFFUL << FDCANCCU_CCFG_OCPM_Pos)
5667#define FDCANCCU_CCFG_OCPM FDCANCCU_CCFG_OCPM_Msk
5668#define FDCANCCU_CCFG_CDIV_Pos (16U)
5669#define FDCANCCU_CCFG_CDIV_Msk (0xFUL << FDCANCCU_CCFG_CDIV_Pos)
5670#define FDCANCCU_CCFG_CDIV FDCANCCU_CCFG_CDIV_Msk
5671#define FDCANCCU_CCFG_SWR_Pos (31U)
5672#define FDCANCCU_CCFG_SWR_Msk (0x1UL << FDCANCCU_CCFG_SWR_Pos)
5673#define FDCANCCU_CCFG_SWR FDCANCCU_CCFG_SWR_Msk
5675/***************** Bit definition for FDCANCCU_CSTAT register *****************/
5676#define FDCANCCU_CSTAT_OCPC_Pos (0U)
5677#define FDCANCCU_CSTAT_OCPC_Msk (0x3FFFFUL << FDCANCCU_CSTAT_OCPC_Pos)
5678#define FDCANCCU_CSTAT_OCPC FDCANCCU_CSTAT_OCPC_Msk
5679#define FDCANCCU_CSTAT_TQC_Pos (18U)
5680#define FDCANCCU_CSTAT_TQC_Msk (0x7FFUL << FDCANCCU_CSTAT_TQC_Pos)
5681#define FDCANCCU_CSTAT_TQC FDCANCCU_CSTAT_TQC_Msk
5682#define FDCANCCU_CSTAT_CALS_Pos (30U)
5683#define FDCANCCU_CSTAT_CALS_Msk (0x3UL << FDCANCCU_CSTAT_CALS_Pos)
5684#define FDCANCCU_CSTAT_CALS FDCANCCU_CSTAT_CALS_Msk
5686/****************** Bit definition for FDCANCCU_CWD register ******************/
5687#define FDCANCCU_CWD_WDC_Pos (0U)
5688#define FDCANCCU_CWD_WDC_Msk (0xFFFFUL << FDCANCCU_CWD_WDC_Pos)
5689#define FDCANCCU_CWD_WDC FDCANCCU_CWD_WDC_Msk
5690#define FDCANCCU_CWD_WDV_Pos (16U)
5691#define FDCANCCU_CWD_WDV_Msk (0xFFFFUL << FDCANCCU_CWD_WDV_Pos)
5692#define FDCANCCU_CWD_WDV FDCANCCU_CWD_WDV_Msk
5694/****************** Bit definition for FDCANCCU_IR register *******************/
5695#define FDCANCCU_IR_CWE_Pos (0U)
5696#define FDCANCCU_IR_CWE_Msk (0x1UL << FDCANCCU_IR_CWE_Pos)
5697#define FDCANCCU_IR_CWE FDCANCCU_IR_CWE_Msk
5698#define FDCANCCU_IR_CSC_Pos (1U)
5699#define FDCANCCU_IR_CSC_Msk (0x1UL << FDCANCCU_IR_CSC_Pos)
5700#define FDCANCCU_IR_CSC FDCANCCU_IR_CSC_Msk
5702/****************** Bit definition for FDCANCCU_IE register *******************/
5703#define FDCANCCU_IE_CWEE_Pos (0U)
5704#define FDCANCCU_IE_CWEE_Msk (0x1UL << FDCANCCU_IE_CWEE_Pos)
5705#define FDCANCCU_IE_CWEE FDCANCCU_IE_CWEE_Msk
5706#define FDCANCCU_IE_CSCE_Pos (1U)
5707#define FDCANCCU_IE_CSCE_Msk (0x1UL << FDCANCCU_IE_CSCE_Pos)
5708#define FDCANCCU_IE_CSCE FDCANCCU_IE_CSCE_Msk
5710/******************************************************************************/
5711/* */
5712/* HDMI-CEC (CEC) */
5713/* */
5714/******************************************************************************/
5715
5716/******************* Bit definition for CEC_CR register *********************/
5717#define CEC_CR_CECEN_Pos (0U)
5718#define CEC_CR_CECEN_Msk (0x1UL << CEC_CR_CECEN_Pos)
5719#define CEC_CR_CECEN CEC_CR_CECEN_Msk
5720#define CEC_CR_TXSOM_Pos (1U)
5721#define CEC_CR_TXSOM_Msk (0x1UL << CEC_CR_TXSOM_Pos)
5722#define CEC_CR_TXSOM CEC_CR_TXSOM_Msk
5723#define CEC_CR_TXEOM_Pos (2U)
5724#define CEC_CR_TXEOM_Msk (0x1UL << CEC_CR_TXEOM_Pos)
5725#define CEC_CR_TXEOM CEC_CR_TXEOM_Msk
5727/******************* Bit definition for CEC_CFGR register *******************/
5728#define CEC_CFGR_SFT_Pos (0U)
5729#define CEC_CFGR_SFT_Msk (0x7UL << CEC_CFGR_SFT_Pos)
5730#define CEC_CFGR_SFT CEC_CFGR_SFT_Msk
5731#define CEC_CFGR_RXTOL_Pos (3U)
5732#define CEC_CFGR_RXTOL_Msk (0x1UL << CEC_CFGR_RXTOL_Pos)
5733#define CEC_CFGR_RXTOL CEC_CFGR_RXTOL_Msk
5734#define CEC_CFGR_BRESTP_Pos (4U)
5735#define CEC_CFGR_BRESTP_Msk (0x1UL << CEC_CFGR_BRESTP_Pos)
5736#define CEC_CFGR_BRESTP CEC_CFGR_BRESTP_Msk
5737#define CEC_CFGR_BREGEN_Pos (5U)
5738#define CEC_CFGR_BREGEN_Msk (0x1UL << CEC_CFGR_BREGEN_Pos)
5739#define CEC_CFGR_BREGEN CEC_CFGR_BREGEN_Msk
5740#define CEC_CFGR_LBPEGEN_Pos (6U)
5741#define CEC_CFGR_LBPEGEN_Msk (0x1UL << CEC_CFGR_LBPEGEN_Pos)
5742#define CEC_CFGR_LBPEGEN CEC_CFGR_LBPEGEN_Msk
5743#define CEC_CFGR_SFTOPT_Pos (8U)
5744#define CEC_CFGR_SFTOPT_Msk (0x1UL << CEC_CFGR_SFTOPT_Pos)
5745#define CEC_CFGR_SFTOPT CEC_CFGR_SFTOPT_Msk
5746#define CEC_CFGR_BRDNOGEN_Pos (7U)
5747#define CEC_CFGR_BRDNOGEN_Msk (0x1UL << CEC_CFGR_BRDNOGEN_Pos)
5748#define CEC_CFGR_BRDNOGEN CEC_CFGR_BRDNOGEN_Msk
5749#define CEC_CFGR_OAR_Pos (16U)
5750#define CEC_CFGR_OAR_Msk (0x7FFFUL << CEC_CFGR_OAR_Pos)
5751#define CEC_CFGR_OAR CEC_CFGR_OAR_Msk
5752#define CEC_CFGR_LSTN_Pos (31U)
5753#define CEC_CFGR_LSTN_Msk (0x1UL << CEC_CFGR_LSTN_Pos)
5754#define CEC_CFGR_LSTN CEC_CFGR_LSTN_Msk
5756/******************* Bit definition for CEC_TXDR register *******************/
5757#define CEC_TXDR_TXD_Pos (0U)
5758#define CEC_TXDR_TXD_Msk (0xFFUL << CEC_TXDR_TXD_Pos)
5759#define CEC_TXDR_TXD CEC_TXDR_TXD_Msk
5761/******************* Bit definition for CEC_RXDR register *******************/
5762#define CEC_RXDR_RXD_Pos (0U)
5763#define CEC_RXDR_RXD_Msk (0xFFUL << CEC_RXDR_RXD_Pos)
5764#define CEC_RXDR_RXD CEC_RXDR_RXD_Msk
5766/******************* Bit definition for CEC_ISR register ********************/
5767#define CEC_ISR_RXBR_Pos (0U)
5768#define CEC_ISR_RXBR_Msk (0x1UL << CEC_ISR_RXBR_Pos)
5769#define CEC_ISR_RXBR CEC_ISR_RXBR_Msk
5770#define CEC_ISR_RXEND_Pos (1U)
5771#define CEC_ISR_RXEND_Msk (0x1UL << CEC_ISR_RXEND_Pos)
5772#define CEC_ISR_RXEND CEC_ISR_RXEND_Msk
5773#define CEC_ISR_RXOVR_Pos (2U)
5774#define CEC_ISR_RXOVR_Msk (0x1UL << CEC_ISR_RXOVR_Pos)
5775#define CEC_ISR_RXOVR CEC_ISR_RXOVR_Msk
5776#define CEC_ISR_BRE_Pos (3U)
5777#define CEC_ISR_BRE_Msk (0x1UL << CEC_ISR_BRE_Pos)
5778#define CEC_ISR_BRE CEC_ISR_BRE_Msk
5779#define CEC_ISR_SBPE_Pos (4U)
5780#define CEC_ISR_SBPE_Msk (0x1UL << CEC_ISR_SBPE_Pos)
5781#define CEC_ISR_SBPE CEC_ISR_SBPE_Msk
5782#define CEC_ISR_LBPE_Pos (5U)
5783#define CEC_ISR_LBPE_Msk (0x1UL << CEC_ISR_LBPE_Pos)
5784#define CEC_ISR_LBPE CEC_ISR_LBPE_Msk
5785#define CEC_ISR_RXACKE_Pos (6U)
5786#define CEC_ISR_RXACKE_Msk (0x1UL << CEC_ISR_RXACKE_Pos)
5787#define CEC_ISR_RXACKE CEC_ISR_RXACKE_Msk
5788#define CEC_ISR_ARBLST_Pos (7U)
5789#define CEC_ISR_ARBLST_Msk (0x1UL << CEC_ISR_ARBLST_Pos)
5790#define CEC_ISR_ARBLST CEC_ISR_ARBLST_Msk
5791#define CEC_ISR_TXBR_Pos (8U)
5792#define CEC_ISR_TXBR_Msk (0x1UL << CEC_ISR_TXBR_Pos)
5793#define CEC_ISR_TXBR CEC_ISR_TXBR_Msk
5794#define CEC_ISR_TXEND_Pos (9U)
5795#define CEC_ISR_TXEND_Msk (0x1UL << CEC_ISR_TXEND_Pos)
5796#define CEC_ISR_TXEND CEC_ISR_TXEND_Msk
5797#define CEC_ISR_TXUDR_Pos (10U)
5798#define CEC_ISR_TXUDR_Msk (0x1UL << CEC_ISR_TXUDR_Pos)
5799#define CEC_ISR_TXUDR CEC_ISR_TXUDR_Msk
5800#define CEC_ISR_TXERR_Pos (11U)
5801#define CEC_ISR_TXERR_Msk (0x1UL << CEC_ISR_TXERR_Pos)
5802#define CEC_ISR_TXERR CEC_ISR_TXERR_Msk
5803#define CEC_ISR_TXACKE_Pos (12U)
5804#define CEC_ISR_TXACKE_Msk (0x1UL << CEC_ISR_TXACKE_Pos)
5805#define CEC_ISR_TXACKE CEC_ISR_TXACKE_Msk
5807/******************* Bit definition for CEC_IER register ********************/
5808#define CEC_IER_RXBRIE_Pos (0U)
5809#define CEC_IER_RXBRIE_Msk (0x1UL << CEC_IER_RXBRIE_Pos)
5810#define CEC_IER_RXBRIE CEC_IER_RXBRIE_Msk
5811#define CEC_IER_RXENDIE_Pos (1U)
5812#define CEC_IER_RXENDIE_Msk (0x1UL << CEC_IER_RXENDIE_Pos)
5813#define CEC_IER_RXENDIE CEC_IER_RXENDIE_Msk
5814#define CEC_IER_RXOVRIE_Pos (2U)
5815#define CEC_IER_RXOVRIE_Msk (0x1UL << CEC_IER_RXOVRIE_Pos)
5816#define CEC_IER_RXOVRIE CEC_IER_RXOVRIE_Msk
5817#define CEC_IER_BREIE_Pos (3U)
5818#define CEC_IER_BREIE_Msk (0x1UL << CEC_IER_BREIE_Pos)
5819#define CEC_IER_BREIE CEC_IER_BREIE_Msk
5820#define CEC_IER_SBPEIE_Pos (4U)
5821#define CEC_IER_SBPEIE_Msk (0x1UL << CEC_IER_SBPEIE_Pos)
5822#define CEC_IER_SBPEIE CEC_IER_SBPEIE_Msk
5823#define CEC_IER_LBPEIE_Pos (5U)
5824#define CEC_IER_LBPEIE_Msk (0x1UL << CEC_IER_LBPEIE_Pos)
5825#define CEC_IER_LBPEIE CEC_IER_LBPEIE_Msk
5826#define CEC_IER_RXACKEIE_Pos (6U)
5827#define CEC_IER_RXACKEIE_Msk (0x1UL << CEC_IER_RXACKEIE_Pos)
5828#define CEC_IER_RXACKEIE CEC_IER_RXACKEIE_Msk
5829#define CEC_IER_ARBLSTIE_Pos (7U)
5830#define CEC_IER_ARBLSTIE_Msk (0x1UL << CEC_IER_ARBLSTIE_Pos)
5831#define CEC_IER_ARBLSTIE CEC_IER_ARBLSTIE_Msk
5832#define CEC_IER_TXBRIE_Pos (8U)
5833#define CEC_IER_TXBRIE_Msk (0x1UL << CEC_IER_TXBRIE_Pos)
5834#define CEC_IER_TXBRIE CEC_IER_TXBRIE_Msk
5835#define CEC_IER_TXENDIE_Pos (9U)
5836#define CEC_IER_TXENDIE_Msk (0x1UL << CEC_IER_TXENDIE_Pos)
5837#define CEC_IER_TXENDIE CEC_IER_TXENDIE_Msk
5838#define CEC_IER_TXUDRIE_Pos (10U)
5839#define CEC_IER_TXUDRIE_Msk (0x1UL << CEC_IER_TXUDRIE_Pos)
5840#define CEC_IER_TXUDRIE CEC_IER_TXUDRIE_Msk
5841#define CEC_IER_TXERRIE_Pos (11U)
5842#define CEC_IER_TXERRIE_Msk (0x1UL << CEC_IER_TXERRIE_Pos)
5843#define CEC_IER_TXERRIE CEC_IER_TXERRIE_Msk
5844#define CEC_IER_TXACKEIE_Pos (12U)
5845#define CEC_IER_TXACKEIE_Msk (0x1UL << CEC_IER_TXACKEIE_Pos)
5846#define CEC_IER_TXACKEIE CEC_IER_TXACKEIE_Msk
5848/******************************************************************************/
5849/* */
5850/* CRC calculation unit */
5851/* */
5852/******************************************************************************/
5853/******************* Bit definition for CRC_DR register *********************/
5854#define CRC_DR_DR_Pos (0U)
5855#define CRC_DR_DR_Msk (0xFFFFFFFFUL << CRC_DR_DR_Pos)
5856#define CRC_DR_DR CRC_DR_DR_Msk
5858/******************* Bit definition for CRC_IDR register ********************/
5859#define CRC_IDR_IDR_Pos (0U)
5860#define CRC_IDR_IDR_Msk (0xFFFFFFFFUL << CRC_IDR_IDR_Pos)
5861#define CRC_IDR_IDR CRC_IDR_IDR_Msk
5863/******************** Bit definition for CRC_CR register ********************/
5864#define CRC_CR_RESET_Pos (0U)
5865#define CRC_CR_RESET_Msk (0x1UL << CRC_CR_RESET_Pos)
5866#define CRC_CR_RESET CRC_CR_RESET_Msk
5867#define CRC_CR_POLYSIZE_Pos (3U)
5868#define CRC_CR_POLYSIZE_Msk (0x3UL << CRC_CR_POLYSIZE_Pos)
5869#define CRC_CR_POLYSIZE CRC_CR_POLYSIZE_Msk
5870#define CRC_CR_POLYSIZE_0 (0x1UL << CRC_CR_POLYSIZE_Pos)
5871#define CRC_CR_POLYSIZE_1 (0x2UL << CRC_CR_POLYSIZE_Pos)
5872#define CRC_CR_REV_IN_Pos (5U)
5873#define CRC_CR_REV_IN_Msk (0x3UL << CRC_CR_REV_IN_Pos)
5874#define CRC_CR_REV_IN CRC_CR_REV_IN_Msk
5875#define CRC_CR_REV_IN_0 (0x1UL << CRC_CR_REV_IN_Pos)
5876#define CRC_CR_REV_IN_1 (0x2UL << CRC_CR_REV_IN_Pos)
5877#define CRC_CR_REV_OUT_Pos (7U)
5878#define CRC_CR_REV_OUT_Msk (0x1UL << CRC_CR_REV_OUT_Pos)
5879#define CRC_CR_REV_OUT CRC_CR_REV_OUT_Msk
5881/******************* Bit definition for CRC_INIT register *******************/
5882#define CRC_INIT_INIT_Pos (0U)
5883#define CRC_INIT_INIT_Msk (0xFFFFFFFFUL << CRC_INIT_INIT_Pos)
5884#define CRC_INIT_INIT CRC_INIT_INIT_Msk
5886/******************* Bit definition for CRC_POL register ********************/
5887#define CRC_POL_POL_Pos (0U)
5888#define CRC_POL_POL_Msk (0xFFFFFFFFUL << CRC_POL_POL_Pos)
5889#define CRC_POL_POL CRC_POL_POL_Msk
5891/******************************************************************************/
5892/* */
5893/* CRS Clock Recovery System */
5894/******************************************************************************/
5895
5896/******************* Bit definition for CRS_CR register *********************/
5897#define CRS_CR_SYNCOKIE_Pos (0U)
5898#define CRS_CR_SYNCOKIE_Msk (0x1UL << CRS_CR_SYNCOKIE_Pos)
5899#define CRS_CR_SYNCOKIE CRS_CR_SYNCOKIE_Msk
5900#define CRS_CR_SYNCWARNIE_Pos (1U)
5901#define CRS_CR_SYNCWARNIE_Msk (0x1UL << CRS_CR_SYNCWARNIE_Pos)
5902#define CRS_CR_SYNCWARNIE CRS_CR_SYNCWARNIE_Msk
5903#define CRS_CR_ERRIE_Pos (2U)
5904#define CRS_CR_ERRIE_Msk (0x1UL << CRS_CR_ERRIE_Pos)
5905#define CRS_CR_ERRIE CRS_CR_ERRIE_Msk
5906#define CRS_CR_ESYNCIE_Pos (3U)
5907#define CRS_CR_ESYNCIE_Msk (0x1UL << CRS_CR_ESYNCIE_Pos)
5908#define CRS_CR_ESYNCIE CRS_CR_ESYNCIE_Msk
5909#define CRS_CR_CEN_Pos (5U)
5910#define CRS_CR_CEN_Msk (0x1UL << CRS_CR_CEN_Pos)
5911#define CRS_CR_CEN CRS_CR_CEN_Msk
5912#define CRS_CR_AUTOTRIMEN_Pos (6U)
5913#define CRS_CR_AUTOTRIMEN_Msk (0x1UL << CRS_CR_AUTOTRIMEN_Pos)
5914#define CRS_CR_AUTOTRIMEN CRS_CR_AUTOTRIMEN_Msk
5915#define CRS_CR_SWSYNC_Pos (7U)
5916#define CRS_CR_SWSYNC_Msk (0x1UL << CRS_CR_SWSYNC_Pos)
5917#define CRS_CR_SWSYNC CRS_CR_SWSYNC_Msk
5918#define CRS_CR_TRIM_Pos (8U)
5919#define CRS_CR_TRIM_Msk (0x3FUL << CRS_CR_TRIM_Pos)
5920#define CRS_CR_TRIM CRS_CR_TRIM_Msk
5922/******************* Bit definition for CRS_CFGR register *********************/
5923#define CRS_CFGR_RELOAD_Pos (0U)
5924#define CRS_CFGR_RELOAD_Msk (0xFFFFUL << CRS_CFGR_RELOAD_Pos)
5925#define CRS_CFGR_RELOAD CRS_CFGR_RELOAD_Msk
5926#define CRS_CFGR_FELIM_Pos (16U)
5927#define CRS_CFGR_FELIM_Msk (0xFFUL << CRS_CFGR_FELIM_Pos)
5928#define CRS_CFGR_FELIM CRS_CFGR_FELIM_Msk
5930#define CRS_CFGR_SYNCDIV_Pos (24U)
5931#define CRS_CFGR_SYNCDIV_Msk (0x7UL << CRS_CFGR_SYNCDIV_Pos)
5932#define CRS_CFGR_SYNCDIV CRS_CFGR_SYNCDIV_Msk
5933#define CRS_CFGR_SYNCDIV_0 (0x1UL << CRS_CFGR_SYNCDIV_Pos)
5934#define CRS_CFGR_SYNCDIV_1 (0x2UL << CRS_CFGR_SYNCDIV_Pos)
5935#define CRS_CFGR_SYNCDIV_2 (0x4UL << CRS_CFGR_SYNCDIV_Pos)
5937#define CRS_CFGR_SYNCSRC_Pos (28U)
5938#define CRS_CFGR_SYNCSRC_Msk (0x3UL << CRS_CFGR_SYNCSRC_Pos)
5939#define CRS_CFGR_SYNCSRC CRS_CFGR_SYNCSRC_Msk
5940#define CRS_CFGR_SYNCSRC_0 (0x1UL << CRS_CFGR_SYNCSRC_Pos)
5941#define CRS_CFGR_SYNCSRC_1 (0x2UL << CRS_CFGR_SYNCSRC_Pos)
5943#define CRS_CFGR_SYNCPOL_Pos (31U)
5944#define CRS_CFGR_SYNCPOL_Msk (0x1UL << CRS_CFGR_SYNCPOL_Pos)
5945#define CRS_CFGR_SYNCPOL CRS_CFGR_SYNCPOL_Msk
5947/******************* Bit definition for CRS_ISR register *********************/
5948#define CRS_ISR_SYNCOKF_Pos (0U)
5949#define CRS_ISR_SYNCOKF_Msk (0x1UL << CRS_ISR_SYNCOKF_Pos)
5950#define CRS_ISR_SYNCOKF CRS_ISR_SYNCOKF_Msk
5951#define CRS_ISR_SYNCWARNF_Pos (1U)
5952#define CRS_ISR_SYNCWARNF_Msk (0x1UL << CRS_ISR_SYNCWARNF_Pos)
5953#define CRS_ISR_SYNCWARNF CRS_ISR_SYNCWARNF_Msk
5954#define CRS_ISR_ERRF_Pos (2U)
5955#define CRS_ISR_ERRF_Msk (0x1UL << CRS_ISR_ERRF_Pos)
5956#define CRS_ISR_ERRF CRS_ISR_ERRF_Msk
5957#define CRS_ISR_ESYNCF_Pos (3U)
5958#define CRS_ISR_ESYNCF_Msk (0x1UL << CRS_ISR_ESYNCF_Pos)
5959#define CRS_ISR_ESYNCF CRS_ISR_ESYNCF_Msk
5960#define CRS_ISR_SYNCERR_Pos (8U)
5961#define CRS_ISR_SYNCERR_Msk (0x1UL << CRS_ISR_SYNCERR_Pos)
5962#define CRS_ISR_SYNCERR CRS_ISR_SYNCERR_Msk
5963#define CRS_ISR_SYNCMISS_Pos (9U)
5964#define CRS_ISR_SYNCMISS_Msk (0x1UL << CRS_ISR_SYNCMISS_Pos)
5965#define CRS_ISR_SYNCMISS CRS_ISR_SYNCMISS_Msk
5966#define CRS_ISR_TRIMOVF_Pos (10U)
5967#define CRS_ISR_TRIMOVF_Msk (0x1UL << CRS_ISR_TRIMOVF_Pos)
5968#define CRS_ISR_TRIMOVF CRS_ISR_TRIMOVF_Msk
5969#define CRS_ISR_FEDIR_Pos (15U)
5970#define CRS_ISR_FEDIR_Msk (0x1UL << CRS_ISR_FEDIR_Pos)
5971#define CRS_ISR_FEDIR CRS_ISR_FEDIR_Msk
5972#define CRS_ISR_FECAP_Pos (16U)
5973#define CRS_ISR_FECAP_Msk (0xFFFFUL << CRS_ISR_FECAP_Pos)
5974#define CRS_ISR_FECAP CRS_ISR_FECAP_Msk
5976/******************* Bit definition for CRS_ICR register *********************/
5977#define CRS_ICR_SYNCOKC_Pos (0U)
5978#define CRS_ICR_SYNCOKC_Msk (0x1UL << CRS_ICR_SYNCOKC_Pos)
5979#define CRS_ICR_SYNCOKC CRS_ICR_SYNCOKC_Msk
5980#define CRS_ICR_SYNCWARNC_Pos (1U)
5981#define CRS_ICR_SYNCWARNC_Msk (0x1UL << CRS_ICR_SYNCWARNC_Pos)
5982#define CRS_ICR_SYNCWARNC CRS_ICR_SYNCWARNC_Msk
5983#define CRS_ICR_ERRC_Pos (2U)
5984#define CRS_ICR_ERRC_Msk (0x1UL << CRS_ICR_ERRC_Pos)
5985#define CRS_ICR_ERRC CRS_ICR_ERRC_Msk
5986#define CRS_ICR_ESYNCC_Pos (3U)
5987#define CRS_ICR_ESYNCC_Msk (0x1UL << CRS_ICR_ESYNCC_Pos)
5988#define CRS_ICR_ESYNCC CRS_ICR_ESYNCC_Msk
5990/******************************************************************************/
5991/* */
5992/* Crypto Processor */
5993/* */
5994/******************************************************************************/
5995/******************* Bits definition for CRYP_CR register ********************/
5996#define CRYP_CR_ALGODIR_Pos (2U)
5997#define CRYP_CR_ALGODIR_Msk (0x1UL << CRYP_CR_ALGODIR_Pos)
5998#define CRYP_CR_ALGODIR CRYP_CR_ALGODIR_Msk
5999
6000#define CRYP_CR_ALGOMODE_Pos (3U)
6001#define CRYP_CR_ALGOMODE_Msk (0x10007UL << CRYP_CR_ALGOMODE_Pos)
6002#define CRYP_CR_ALGOMODE CRYP_CR_ALGOMODE_Msk
6003#define CRYP_CR_ALGOMODE_0 (0x00001UL << CRYP_CR_ALGOMODE_Pos)
6004#define CRYP_CR_ALGOMODE_1 (0x00002UL << CRYP_CR_ALGOMODE_Pos)
6005#define CRYP_CR_ALGOMODE_2 (0x00004UL << CRYP_CR_ALGOMODE_Pos)
6006#define CRYP_CR_ALGOMODE_TDES_ECB (0U)
6007#define CRYP_CR_ALGOMODE_TDES_CBC_Pos (3U)
6008#define CRYP_CR_ALGOMODE_TDES_CBC_Msk (0x1UL << CRYP_CR_ALGOMODE_TDES_CBC_Pos)
6009#define CRYP_CR_ALGOMODE_TDES_CBC CRYP_CR_ALGOMODE_TDES_CBC_Msk
6010#define CRYP_CR_ALGOMODE_DES_ECB_Pos (4U)
6011#define CRYP_CR_ALGOMODE_DES_ECB_Msk (0x1UL << CRYP_CR_ALGOMODE_DES_ECB_Pos)
6012#define CRYP_CR_ALGOMODE_DES_ECB CRYP_CR_ALGOMODE_DES_ECB_Msk
6013#define CRYP_CR_ALGOMODE_DES_CBC_Pos (3U)
6014#define CRYP_CR_ALGOMODE_DES_CBC_Msk (0x3UL << CRYP_CR_ALGOMODE_DES_CBC_Pos)
6015#define CRYP_CR_ALGOMODE_DES_CBC CRYP_CR_ALGOMODE_DES_CBC_Msk
6016#define CRYP_CR_ALGOMODE_AES_ECB_Pos (5U)
6017#define CRYP_CR_ALGOMODE_AES_ECB_Msk (0x1UL << CRYP_CR_ALGOMODE_AES_ECB_Pos)
6018#define CRYP_CR_ALGOMODE_AES_ECB CRYP_CR_ALGOMODE_AES_ECB_Msk
6019#define CRYP_CR_ALGOMODE_AES_CBC_Pos (3U)
6020#define CRYP_CR_ALGOMODE_AES_CBC_Msk (0x5UL << CRYP_CR_ALGOMODE_AES_CBC_Pos)
6021#define CRYP_CR_ALGOMODE_AES_CBC CRYP_CR_ALGOMODE_AES_CBC_Msk
6022#define CRYP_CR_ALGOMODE_AES_CTR_Pos (4U)
6023#define CRYP_CR_ALGOMODE_AES_CTR_Msk (0x3UL << CRYP_CR_ALGOMODE_AES_CTR_Pos)
6024#define CRYP_CR_ALGOMODE_AES_CTR CRYP_CR_ALGOMODE_AES_CTR_Msk
6025#define CRYP_CR_ALGOMODE_AES_KEY_Pos (3U)
6026#define CRYP_CR_ALGOMODE_AES_KEY_Msk (0x7UL << CRYP_CR_ALGOMODE_AES_KEY_Pos)
6027#define CRYP_CR_ALGOMODE_AES_KEY CRYP_CR_ALGOMODE_AES_KEY_Msk
6028#define CRYP_CR_ALGOMODE_AES_GCM_Pos (19U)
6029#define CRYP_CR_ALGOMODE_AES_GCM_Msk (0x1UL << CRYP_CR_ALGOMODE_AES_GCM_Pos)
6030#define CRYP_CR_ALGOMODE_AES_GCM CRYP_CR_ALGOMODE_AES_GCM_Msk
6031#define CRYP_CR_ALGOMODE_AES_CCM_Pos (3U)
6032#define CRYP_CR_ALGOMODE_AES_CCM_Msk (0x10001UL << CRYP_CR_ALGOMODE_AES_CCM_Pos)
6033#define CRYP_CR_ALGOMODE_AES_CCM CRYP_CR_ALGOMODE_AES_CCM_Msk
6034
6035#define CRYP_CR_DATATYPE_Pos (6U)
6036#define CRYP_CR_DATATYPE_Msk (0x3UL << CRYP_CR_DATATYPE_Pos)
6037#define CRYP_CR_DATATYPE CRYP_CR_DATATYPE_Msk
6038#define CRYP_CR_DATATYPE_0 (0x1UL << CRYP_CR_DATATYPE_Pos)
6039#define CRYP_CR_DATATYPE_1 (0x2UL << CRYP_CR_DATATYPE_Pos)
6040#define CRYP_CR_KEYSIZE_Pos (8U)
6041#define CRYP_CR_KEYSIZE_Msk (0x3UL << CRYP_CR_KEYSIZE_Pos)
6042#define CRYP_CR_KEYSIZE CRYP_CR_KEYSIZE_Msk
6043#define CRYP_CR_KEYSIZE_0 (0x1UL << CRYP_CR_KEYSIZE_Pos)
6044#define CRYP_CR_KEYSIZE_1 (0x2UL << CRYP_CR_KEYSIZE_Pos)
6045#define CRYP_CR_FFLUSH_Pos (14U)
6046#define CRYP_CR_FFLUSH_Msk (0x1UL << CRYP_CR_FFLUSH_Pos)
6047#define CRYP_CR_FFLUSH CRYP_CR_FFLUSH_Msk
6048#define CRYP_CR_CRYPEN_Pos (15U)
6049#define CRYP_CR_CRYPEN_Msk (0x1UL << CRYP_CR_CRYPEN_Pos)
6050#define CRYP_CR_CRYPEN CRYP_CR_CRYPEN_Msk
6051
6052#define CRYP_CR_GCM_CCMPH_Pos (16U)
6053#define CRYP_CR_GCM_CCMPH_Msk (0x3UL << CRYP_CR_GCM_CCMPH_Pos)
6054#define CRYP_CR_GCM_CCMPH CRYP_CR_GCM_CCMPH_Msk
6055#define CRYP_CR_GCM_CCMPH_0 (0x1UL << CRYP_CR_GCM_CCMPH_Pos)
6056#define CRYP_CR_GCM_CCMPH_1 (0x2UL << CRYP_CR_GCM_CCMPH_Pos)
6057#define CRYP_CR_ALGOMODE_3 (0x00080000U)
6058#define CRYP_CR_NPBLB_Pos (20U)
6059#define CRYP_CR_NPBLB_Msk (0xFUL << CRYP_CR_NPBLB_Pos)
6060#define CRYP_CR_NPBLB CRYP_CR_NPBLB_Msk
6061
6062/****************** Bits definition for CRYP_SR register *********************/
6063#define CRYP_SR_IFEM_Pos (0U)
6064#define CRYP_SR_IFEM_Msk (0x1UL << CRYP_SR_IFEM_Pos)
6065#define CRYP_SR_IFEM CRYP_SR_IFEM_Msk
6066#define CRYP_SR_IFNF_Pos (1U)
6067#define CRYP_SR_IFNF_Msk (0x1UL << CRYP_SR_IFNF_Pos)
6068#define CRYP_SR_IFNF CRYP_SR_IFNF_Msk
6069#define CRYP_SR_OFNE_Pos (2U)
6070#define CRYP_SR_OFNE_Msk (0x1UL << CRYP_SR_OFNE_Pos)
6071#define CRYP_SR_OFNE CRYP_SR_OFNE_Msk
6072#define CRYP_SR_OFFU_Pos (3U)
6073#define CRYP_SR_OFFU_Msk (0x1UL << CRYP_SR_OFFU_Pos)
6074#define CRYP_SR_OFFU CRYP_SR_OFFU_Msk
6075#define CRYP_SR_BUSY_Pos (4U)
6076#define CRYP_SR_BUSY_Msk (0x1UL << CRYP_SR_BUSY_Pos)
6077#define CRYP_SR_BUSY CRYP_SR_BUSY_Msk
6078/****************** Bits definition for CRYP_DMACR register ******************/
6079#define CRYP_DMACR_DIEN_Pos (0U)
6080#define CRYP_DMACR_DIEN_Msk (0x1UL << CRYP_DMACR_DIEN_Pos)
6081#define CRYP_DMACR_DIEN CRYP_DMACR_DIEN_Msk
6082#define CRYP_DMACR_DOEN_Pos (1U)
6083#define CRYP_DMACR_DOEN_Msk (0x1UL << CRYP_DMACR_DOEN_Pos)
6084#define CRYP_DMACR_DOEN CRYP_DMACR_DOEN_Msk
6085/***************** Bits definition for CRYP_IMSCR register ******************/
6086#define CRYP_IMSCR_INIM_Pos (0U)
6087#define CRYP_IMSCR_INIM_Msk (0x1UL << CRYP_IMSCR_INIM_Pos)
6088#define CRYP_IMSCR_INIM CRYP_IMSCR_INIM_Msk
6089#define CRYP_IMSCR_OUTIM_Pos (1U)
6090#define CRYP_IMSCR_OUTIM_Msk (0x1UL << CRYP_IMSCR_OUTIM_Pos)
6091#define CRYP_IMSCR_OUTIM CRYP_IMSCR_OUTIM_Msk
6092/****************** Bits definition for CRYP_RISR register *******************/
6093#define CRYP_RISR_INRIS_Pos (0U)
6094#define CRYP_RISR_INRIS_Msk (0x1UL << CRYP_RISR_INRIS_Pos)
6095#define CRYP_RISR_INRIS CRYP_RISR_INRIS_Msk
6096#define CRYP_RISR_OUTRIS_Pos (1U)
6097#define CRYP_RISR_OUTRIS_Msk (0x1UL << CRYP_RISR_OUTRIS_Pos)
6098#define CRYP_RISR_OUTRIS CRYP_RISR_OUTRIS_Msk
6099/****************** Bits definition for CRYP_MISR register *******************/
6100#define CRYP_MISR_INMIS_Pos (0U)
6101#define CRYP_MISR_INMIS_Msk (0x1UL << CRYP_MISR_INMIS_Pos)
6102#define CRYP_MISR_INMIS CRYP_MISR_INMIS_Msk
6103#define CRYP_MISR_OUTMIS_Pos (1U)
6104#define CRYP_MISR_OUTMIS_Msk (0x1UL << CRYP_MISR_OUTMIS_Pos)
6105#define CRYP_MISR_OUTMIS CRYP_MISR_OUTMIS_Msk
6106
6107/******************************************************************************/
6108/* */
6109/* Digital to Analog Converter */
6110/* */
6111/******************************************************************************/
6112/******************** Bit definition for DAC_CR register ********************/
6113#define DAC_CR_EN1_Pos (0U)
6114#define DAC_CR_EN1_Msk (0x1UL << DAC_CR_EN1_Pos)
6115#define DAC_CR_EN1 DAC_CR_EN1_Msk
6116#define DAC_CR_TEN1_Pos (1U)
6117#define DAC_CR_TEN1_Msk (0x1UL << DAC_CR_TEN1_Pos)
6118#define DAC_CR_TEN1 DAC_CR_TEN1_Msk
6120#define DAC_CR_TSEL1_Pos (2U)
6121#define DAC_CR_TSEL1_Msk (0xFUL << DAC_CR_TSEL1_Pos)
6122#define DAC_CR_TSEL1 DAC_CR_TSEL1_Msk
6123#define DAC_CR_TSEL1_0 (0x1UL << DAC_CR_TSEL1_Pos)
6124#define DAC_CR_TSEL1_1 (0x2UL << DAC_CR_TSEL1_Pos)
6125#define DAC_CR_TSEL1_2 (0x4UL << DAC_CR_TSEL1_Pos)
6126#define DAC_CR_TSEL1_3 (0x8UL << DAC_CR_TSEL1_Pos)
6129#define DAC_CR_WAVE1_Pos (6U)
6130#define DAC_CR_WAVE1_Msk (0x3UL << DAC_CR_WAVE1_Pos)
6131#define DAC_CR_WAVE1 DAC_CR_WAVE1_Msk
6132#define DAC_CR_WAVE1_0 (0x1UL << DAC_CR_WAVE1_Pos)
6133#define DAC_CR_WAVE1_1 (0x2UL << DAC_CR_WAVE1_Pos)
6135#define DAC_CR_MAMP1_Pos (8U)
6136#define DAC_CR_MAMP1_Msk (0xFUL << DAC_CR_MAMP1_Pos)
6137#define DAC_CR_MAMP1 DAC_CR_MAMP1_Msk
6138#define DAC_CR_MAMP1_0 (0x1UL << DAC_CR_MAMP1_Pos)
6139#define DAC_CR_MAMP1_1 (0x2UL << DAC_CR_MAMP1_Pos)
6140#define DAC_CR_MAMP1_2 (0x4UL << DAC_CR_MAMP1_Pos)
6141#define DAC_CR_MAMP1_3 (0x8UL << DAC_CR_MAMP1_Pos)
6143#define DAC_CR_DMAEN1_Pos (12U)
6144#define DAC_CR_DMAEN1_Msk (0x1UL << DAC_CR_DMAEN1_Pos)
6145#define DAC_CR_DMAEN1 DAC_CR_DMAEN1_Msk
6146#define DAC_CR_DMAUDRIE1_Pos (13U)
6147#define DAC_CR_DMAUDRIE1_Msk (0x1UL << DAC_CR_DMAUDRIE1_Pos)
6148#define DAC_CR_DMAUDRIE1 DAC_CR_DMAUDRIE1_Msk
6149#define DAC_CR_CEN1_Pos (14U)
6150#define DAC_CR_CEN1_Msk (0x1UL << DAC_CR_CEN1_Pos)
6151#define DAC_CR_CEN1 DAC_CR_CEN1_Msk
6153#define DAC_CR_EN2_Pos (16U)
6154#define DAC_CR_EN2_Msk (0x1UL << DAC_CR_EN2_Pos)
6155#define DAC_CR_EN2 DAC_CR_EN2_Msk
6156#define DAC_CR_TEN2_Pos (17U)
6157#define DAC_CR_TEN2_Msk (0x1UL << DAC_CR_TEN2_Pos)
6158#define DAC_CR_TEN2 DAC_CR_TEN2_Msk
6160#define DAC_CR_TSEL2_Pos (18U)
6161#define DAC_CR_TSEL2_Msk (0xFUL << DAC_CR_TSEL2_Pos)
6162#define DAC_CR_TSEL2 DAC_CR_TSEL2_Msk
6163#define DAC_CR_TSEL2_0 (0x1UL << DAC_CR_TSEL2_Pos)
6164#define DAC_CR_TSEL2_1 (0x2UL << DAC_CR_TSEL2_Pos)
6165#define DAC_CR_TSEL2_2 (0x4UL << DAC_CR_TSEL2_Pos)
6166#define DAC_CR_TSEL2_3 (0x8UL << DAC_CR_TSEL2_Pos)
6169#define DAC_CR_WAVE2_Pos (22U)
6170#define DAC_CR_WAVE2_Msk (0x3UL << DAC_CR_WAVE2_Pos)
6171#define DAC_CR_WAVE2 DAC_CR_WAVE2_Msk
6172#define DAC_CR_WAVE2_0 (0x1UL << DAC_CR_WAVE2_Pos)
6173#define DAC_CR_WAVE2_1 (0x2UL << DAC_CR_WAVE2_Pos)
6175#define DAC_CR_MAMP2_Pos (24U)
6176#define DAC_CR_MAMP2_Msk (0xFUL << DAC_CR_MAMP2_Pos)
6177#define DAC_CR_MAMP2 DAC_CR_MAMP2_Msk
6178#define DAC_CR_MAMP2_0 (0x1UL << DAC_CR_MAMP2_Pos)
6179#define DAC_CR_MAMP2_1 (0x2UL << DAC_CR_MAMP2_Pos)
6180#define DAC_CR_MAMP2_2 (0x4UL << DAC_CR_MAMP2_Pos)
6181#define DAC_CR_MAMP2_3 (0x8UL << DAC_CR_MAMP2_Pos)
6183#define DAC_CR_DMAEN2_Pos (28U)
6184#define DAC_CR_DMAEN2_Msk (0x1UL << DAC_CR_DMAEN2_Pos)
6185#define DAC_CR_DMAEN2 DAC_CR_DMAEN2_Msk
6186#define DAC_CR_DMAUDRIE2_Pos (29U)
6187#define DAC_CR_DMAUDRIE2_Msk (0x1UL << DAC_CR_DMAUDRIE2_Pos)
6188#define DAC_CR_DMAUDRIE2 DAC_CR_DMAUDRIE2_Msk
6189#define DAC_CR_CEN2_Pos (30U)
6190#define DAC_CR_CEN2_Msk (0x1UL << DAC_CR_CEN2_Pos)
6191#define DAC_CR_CEN2 DAC_CR_CEN2_Msk
6193/***************** Bit definition for DAC_SWTRIGR register ******************/
6194#define DAC_SWTRIGR_SWTRIG1_Pos (0U)
6195#define DAC_SWTRIGR_SWTRIG1_Msk (0x1UL << DAC_SWTRIGR_SWTRIG1_Pos)
6196#define DAC_SWTRIGR_SWTRIG1 DAC_SWTRIGR_SWTRIG1_Msk
6197#define DAC_SWTRIGR_SWTRIG2_Pos (1U)
6198#define DAC_SWTRIGR_SWTRIG2_Msk (0x1UL << DAC_SWTRIGR_SWTRIG2_Pos)
6199#define DAC_SWTRIGR_SWTRIG2 DAC_SWTRIGR_SWTRIG2_Msk
6201/***************** Bit definition for DAC_DHR12R1 register ******************/
6202#define DAC_DHR12R1_DACC1DHR_Pos (0U)
6203#define DAC_DHR12R1_DACC1DHR_Msk (0xFFFUL << DAC_DHR12R1_DACC1DHR_Pos)
6204#define DAC_DHR12R1_DACC1DHR DAC_DHR12R1_DACC1DHR_Msk
6206/***************** Bit definition for DAC_DHR12L1 register ******************/
6207#define DAC_DHR12L1_DACC1DHR_Pos (4U)
6208#define DAC_DHR12L1_DACC1DHR_Msk (0xFFFUL << DAC_DHR12L1_DACC1DHR_Pos)
6209#define DAC_DHR12L1_DACC1DHR DAC_DHR12L1_DACC1DHR_Msk
6211/****************** Bit definition for DAC_DHR8R1 register ******************/
6212#define DAC_DHR8R1_DACC1DHR_Pos (0U)
6213#define DAC_DHR8R1_DACC1DHR_Msk (0xFFUL << DAC_DHR8R1_DACC1DHR_Pos)
6214#define DAC_DHR8R1_DACC1DHR DAC_DHR8R1_DACC1DHR_Msk
6216/***************** Bit definition for DAC_DHR12R2 register ******************/
6217#define DAC_DHR12R2_DACC2DHR_Pos (0U)
6218#define DAC_DHR12R2_DACC2DHR_Msk (0xFFFUL << DAC_DHR12R2_DACC2DHR_Pos)
6219#define DAC_DHR12R2_DACC2DHR DAC_DHR12R2_DACC2DHR_Msk
6221/***************** Bit definition for DAC_DHR12L2 register ******************/
6222#define DAC_DHR12L2_DACC2DHR_Pos (4U)
6223#define DAC_DHR12L2_DACC2DHR_Msk (0xFFFUL << DAC_DHR12L2_DACC2DHR_Pos)
6224#define DAC_DHR12L2_DACC2DHR DAC_DHR12L2_DACC2DHR_Msk
6226/****************** Bit definition for DAC_DHR8R2 register ******************/
6227#define DAC_DHR8R2_DACC2DHR_Pos (0U)
6228#define DAC_DHR8R2_DACC2DHR_Msk (0xFFUL << DAC_DHR8R2_DACC2DHR_Pos)
6229#define DAC_DHR8R2_DACC2DHR DAC_DHR8R2_DACC2DHR_Msk
6231/***************** Bit definition for DAC_DHR12RD register ******************/
6232#define DAC_DHR12RD_DACC1DHR_Pos (0U)
6233#define DAC_DHR12RD_DACC1DHR_Msk (0xFFFUL << DAC_DHR12RD_DACC1DHR_Pos)
6234#define DAC_DHR12RD_DACC1DHR DAC_DHR12RD_DACC1DHR_Msk
6235#define DAC_DHR12RD_DACC2DHR_Pos (16U)
6236#define DAC_DHR12RD_DACC2DHR_Msk (0xFFFUL << DAC_DHR12RD_DACC2DHR_Pos)
6237#define DAC_DHR12RD_DACC2DHR DAC_DHR12RD_DACC2DHR_Msk
6239/***************** Bit definition for DAC_DHR12LD register ******************/
6240#define DAC_DHR12LD_DACC1DHR_Pos (4U)
6241#define DAC_DHR12LD_DACC1DHR_Msk (0xFFFUL << DAC_DHR12LD_DACC1DHR_Pos)
6242#define DAC_DHR12LD_DACC1DHR DAC_DHR12LD_DACC1DHR_Msk
6243#define DAC_DHR12LD_DACC2DHR_Pos (20U)
6244#define DAC_DHR12LD_DACC2DHR_Msk (0xFFFUL << DAC_DHR12LD_DACC2DHR_Pos)
6245#define DAC_DHR12LD_DACC2DHR DAC_DHR12LD_DACC2DHR_Msk
6247/****************** Bit definition for DAC_DHR8RD register ******************/
6248#define DAC_DHR8RD_DACC1DHR_Pos (0U)
6249#define DAC_DHR8RD_DACC1DHR_Msk (0xFFUL << DAC_DHR8RD_DACC1DHR_Pos)
6250#define DAC_DHR8RD_DACC1DHR DAC_DHR8RD_DACC1DHR_Msk
6251#define DAC_DHR8RD_DACC2DHR_Pos (8U)
6252#define DAC_DHR8RD_DACC2DHR_Msk (0xFFUL << DAC_DHR8RD_DACC2DHR_Pos)
6253#define DAC_DHR8RD_DACC2DHR DAC_DHR8RD_DACC2DHR_Msk
6255/******************* Bit definition for DAC_DOR1 register *******************/
6256#define DAC_DOR1_DACC1DOR_Pos (0U)
6257#define DAC_DOR1_DACC1DOR_Msk (0xFFFUL << DAC_DOR1_DACC1DOR_Pos)
6258#define DAC_DOR1_DACC1DOR DAC_DOR1_DACC1DOR_Msk
6260/******************* Bit definition for DAC_DOR2 register *******************/
6261#define DAC_DOR2_DACC2DOR_Pos (0U)
6262#define DAC_DOR2_DACC2DOR_Msk (0xFFFUL << DAC_DOR2_DACC2DOR_Pos)
6263#define DAC_DOR2_DACC2DOR DAC_DOR2_DACC2DOR_Msk
6265/******************** Bit definition for DAC_SR register ********************/
6266#define DAC_SR_DMAUDR1_Pos (13U)
6267#define DAC_SR_DMAUDR1_Msk (0x1UL << DAC_SR_DMAUDR1_Pos)
6268#define DAC_SR_DMAUDR1 DAC_SR_DMAUDR1_Msk
6269#define DAC_SR_CAL_FLAG1_Pos (14U)
6270#define DAC_SR_CAL_FLAG1_Msk (0x1UL << DAC_SR_CAL_FLAG1_Pos)
6271#define DAC_SR_CAL_FLAG1 DAC_SR_CAL_FLAG1_Msk
6272#define DAC_SR_BWST1_Pos (15U)
6273#define DAC_SR_BWST1_Msk (0x4001UL << DAC_SR_BWST1_Pos)
6274#define DAC_SR_BWST1 DAC_SR_BWST1_Msk
6276#define DAC_SR_DMAUDR2_Pos (29U)
6277#define DAC_SR_DMAUDR2_Msk (0x1UL << DAC_SR_DMAUDR2_Pos)
6278#define DAC_SR_DMAUDR2 DAC_SR_DMAUDR2_Msk
6279#define DAC_SR_CAL_FLAG2_Pos (30U)
6280#define DAC_SR_CAL_FLAG2_Msk (0x1UL << DAC_SR_CAL_FLAG2_Pos)
6281#define DAC_SR_CAL_FLAG2 DAC_SR_CAL_FLAG2_Msk
6282#define DAC_SR_BWST2_Pos (31U)
6283#define DAC_SR_BWST2_Msk (0x1UL << DAC_SR_BWST2_Pos)
6284#define DAC_SR_BWST2 DAC_SR_BWST2_Msk
6286/******************* Bit definition for DAC_CCR register ********************/
6287#define DAC_CCR_OTRIM1_Pos (0U)
6288#define DAC_CCR_OTRIM1_Msk (0x1FUL << DAC_CCR_OTRIM1_Pos)
6289#define DAC_CCR_OTRIM1 DAC_CCR_OTRIM1_Msk
6290#define DAC_CCR_OTRIM2_Pos (16U)
6291#define DAC_CCR_OTRIM2_Msk (0x1FUL << DAC_CCR_OTRIM2_Pos)
6292#define DAC_CCR_OTRIM2 DAC_CCR_OTRIM2_Msk
6294/******************* Bit definition for DAC_MCR register *******************/
6295#define DAC_MCR_MODE1_Pos (0U)
6296#define DAC_MCR_MODE1_Msk (0x7UL << DAC_MCR_MODE1_Pos)
6297#define DAC_MCR_MODE1 DAC_MCR_MODE1_Msk
6298#define DAC_MCR_MODE1_0 (0x1UL << DAC_MCR_MODE1_Pos)
6299#define DAC_MCR_MODE1_1 (0x2UL << DAC_MCR_MODE1_Pos)
6300#define DAC_MCR_MODE1_2 (0x4UL << DAC_MCR_MODE1_Pos)
6302#define DAC_MCR_MODE2_Pos (16U)
6303#define DAC_MCR_MODE2_Msk (0x7UL << DAC_MCR_MODE2_Pos)
6304#define DAC_MCR_MODE2 DAC_MCR_MODE2_Msk
6305#define DAC_MCR_MODE2_0 (0x1UL << DAC_MCR_MODE2_Pos)
6306#define DAC_MCR_MODE2_1 (0x2UL << DAC_MCR_MODE2_Pos)
6307#define DAC_MCR_MODE2_2 (0x4UL << DAC_MCR_MODE2_Pos)
6309/****************** Bit definition for DAC_SHSR1 register ******************/
6310#define DAC_SHSR1_TSAMPLE1_Pos (0U)
6311#define DAC_SHSR1_TSAMPLE1_Msk (0x3FFUL << DAC_SHSR1_TSAMPLE1_Pos)
6312#define DAC_SHSR1_TSAMPLE1 DAC_SHSR1_TSAMPLE1_Msk
6314/****************** Bit definition for DAC_SHSR2 register ******************/
6315#define DAC_SHSR2_TSAMPLE2_Pos (0U)
6316#define DAC_SHSR2_TSAMPLE2_Msk (0x3FFUL << DAC_SHSR2_TSAMPLE2_Pos)
6317#define DAC_SHSR2_TSAMPLE2 DAC_SHSR2_TSAMPLE2_Msk
6319/****************** Bit definition for DAC_SHHR register ******************/
6320#define DAC_SHHR_THOLD1_Pos (0U)
6321#define DAC_SHHR_THOLD1_Msk (0x3FFUL << DAC_SHHR_THOLD1_Pos)
6322#define DAC_SHHR_THOLD1 DAC_SHHR_THOLD1_Msk
6323#define DAC_SHHR_THOLD2_Pos (16U)
6324#define DAC_SHHR_THOLD2_Msk (0x3FFUL << DAC_SHHR_THOLD2_Pos)
6325#define DAC_SHHR_THOLD2 DAC_SHHR_THOLD2_Msk
6327/****************** Bit definition for DAC_SHRR register ******************/
6328#define DAC_SHRR_TREFRESH1_Pos (0U)
6329#define DAC_SHRR_TREFRESH1_Msk (0xFFUL << DAC_SHRR_TREFRESH1_Pos)
6330#define DAC_SHRR_TREFRESH1 DAC_SHRR_TREFRESH1_Msk
6331#define DAC_SHRR_TREFRESH2_Pos (16U)
6332#define DAC_SHRR_TREFRESH2_Msk (0xFFUL << DAC_SHRR_TREFRESH2_Pos)
6333#define DAC_SHRR_TREFRESH2 DAC_SHRR_TREFRESH2_Msk
6335/******************************************************************************/
6336/* */
6337/* DCMI */
6338/* */
6339/******************************************************************************/
6340/******************** Bits definition for DCMI_CR register ******************/
6341#define DCMI_CR_CAPTURE_Pos (0U)
6342#define DCMI_CR_CAPTURE_Msk (0x1UL << DCMI_CR_CAPTURE_Pos)
6343#define DCMI_CR_CAPTURE DCMI_CR_CAPTURE_Msk
6344#define DCMI_CR_CM_Pos (1U)
6345#define DCMI_CR_CM_Msk (0x1UL << DCMI_CR_CM_Pos)
6346#define DCMI_CR_CM DCMI_CR_CM_Msk
6347#define DCMI_CR_CROP_Pos (2U)
6348#define DCMI_CR_CROP_Msk (0x1UL << DCMI_CR_CROP_Pos)
6349#define DCMI_CR_CROP DCMI_CR_CROP_Msk
6350#define DCMI_CR_JPEG_Pos (3U)
6351#define DCMI_CR_JPEG_Msk (0x1UL << DCMI_CR_JPEG_Pos)
6352#define DCMI_CR_JPEG DCMI_CR_JPEG_Msk
6353#define DCMI_CR_ESS_Pos (4U)
6354#define DCMI_CR_ESS_Msk (0x1UL << DCMI_CR_ESS_Pos)
6355#define DCMI_CR_ESS DCMI_CR_ESS_Msk
6356#define DCMI_CR_PCKPOL_Pos (5U)
6357#define DCMI_CR_PCKPOL_Msk (0x1UL << DCMI_CR_PCKPOL_Pos)
6358#define DCMI_CR_PCKPOL DCMI_CR_PCKPOL_Msk
6359#define DCMI_CR_HSPOL_Pos (6U)
6360#define DCMI_CR_HSPOL_Msk (0x1UL << DCMI_CR_HSPOL_Pos)
6361#define DCMI_CR_HSPOL DCMI_CR_HSPOL_Msk
6362#define DCMI_CR_VSPOL_Pos (7U)
6363#define DCMI_CR_VSPOL_Msk (0x1UL << DCMI_CR_VSPOL_Pos)
6364#define DCMI_CR_VSPOL DCMI_CR_VSPOL_Msk
6365#define DCMI_CR_FCRC_0 (0x00000100U)
6366#define DCMI_CR_FCRC_1 (0x00000200U)
6367#define DCMI_CR_EDM_0 (0x00000400U)
6368#define DCMI_CR_EDM_1 (0x00000800U)
6369#define DCMI_CR_CRE_Pos (12U)
6370#define DCMI_CR_CRE_Msk (0x1UL << DCMI_CR_CRE_Pos)
6371#define DCMI_CR_CRE DCMI_CR_CRE_Msk
6372#define DCMI_CR_ENABLE_Pos (14U)
6373#define DCMI_CR_ENABLE_Msk (0x1UL << DCMI_CR_ENABLE_Pos)
6374#define DCMI_CR_ENABLE DCMI_CR_ENABLE_Msk
6375#define DCMI_CR_BSM_Pos (16U)
6376#define DCMI_CR_BSM_Msk (0x3UL << DCMI_CR_BSM_Pos)
6377#define DCMI_CR_BSM DCMI_CR_BSM_Msk
6378#define DCMI_CR_BSM_0 (0x1UL << DCMI_CR_BSM_Pos)
6379#define DCMI_CR_BSM_1 (0x2UL << DCMI_CR_BSM_Pos)
6380#define DCMI_CR_OEBS_Pos (18U)
6381#define DCMI_CR_OEBS_Msk (0x1UL << DCMI_CR_OEBS_Pos)
6382#define DCMI_CR_OEBS DCMI_CR_OEBS_Msk
6383#define DCMI_CR_LSM_Pos (19U)
6384#define DCMI_CR_LSM_Msk (0x1UL << DCMI_CR_LSM_Pos)
6385#define DCMI_CR_LSM DCMI_CR_LSM_Msk
6386#define DCMI_CR_OELS_Pos (20U)
6387#define DCMI_CR_OELS_Msk (0x1UL << DCMI_CR_OELS_Pos)
6388#define DCMI_CR_OELS DCMI_CR_OELS_Msk
6389
6390/******************** Bits definition for DCMI_SR register ******************/
6391#define DCMI_SR_HSYNC_Pos (0U)
6392#define DCMI_SR_HSYNC_Msk (0x1UL << DCMI_SR_HSYNC_Pos)
6393#define DCMI_SR_HSYNC DCMI_SR_HSYNC_Msk
6394#define DCMI_SR_VSYNC_Pos (1U)
6395#define DCMI_SR_VSYNC_Msk (0x1UL << DCMI_SR_VSYNC_Pos)
6396#define DCMI_SR_VSYNC DCMI_SR_VSYNC_Msk
6397#define DCMI_SR_FNE_Pos (2U)
6398#define DCMI_SR_FNE_Msk (0x1UL << DCMI_SR_FNE_Pos)
6399#define DCMI_SR_FNE DCMI_SR_FNE_Msk
6400
6401/******************** Bits definition for DCMI_RIS register ****************/
6402#define DCMI_RIS_FRAME_RIS_Pos (0U)
6403#define DCMI_RIS_FRAME_RIS_Msk (0x1UL << DCMI_RIS_FRAME_RIS_Pos)
6404#define DCMI_RIS_FRAME_RIS DCMI_RIS_FRAME_RIS_Msk
6405#define DCMI_RIS_OVR_RIS_Pos (1U)
6406#define DCMI_RIS_OVR_RIS_Msk (0x1UL << DCMI_RIS_OVR_RIS_Pos)
6407#define DCMI_RIS_OVR_RIS DCMI_RIS_OVR_RIS_Msk
6408#define DCMI_RIS_ERR_RIS_Pos (2U)
6409#define DCMI_RIS_ERR_RIS_Msk (0x1UL << DCMI_RIS_ERR_RIS_Pos)
6410#define DCMI_RIS_ERR_RIS DCMI_RIS_ERR_RIS_Msk
6411#define DCMI_RIS_VSYNC_RIS_Pos (3U)
6412#define DCMI_RIS_VSYNC_RIS_Msk (0x1UL << DCMI_RIS_VSYNC_RIS_Pos)
6413#define DCMI_RIS_VSYNC_RIS DCMI_RIS_VSYNC_RIS_Msk
6414#define DCMI_RIS_LINE_RIS_Pos (4U)
6415#define DCMI_RIS_LINE_RIS_Msk (0x1UL << DCMI_RIS_LINE_RIS_Pos)
6416#define DCMI_RIS_LINE_RIS DCMI_RIS_LINE_RIS_Msk
6417
6418/******************** Bits definition for DCMI_IER register *****************/
6419#define DCMI_IER_FRAME_IE_Pos (0U)
6420#define DCMI_IER_FRAME_IE_Msk (0x1UL << DCMI_IER_FRAME_IE_Pos)
6421#define DCMI_IER_FRAME_IE DCMI_IER_FRAME_IE_Msk
6422#define DCMI_IER_OVR_IE_Pos (1U)
6423#define DCMI_IER_OVR_IE_Msk (0x1UL << DCMI_IER_OVR_IE_Pos)
6424#define DCMI_IER_OVR_IE DCMI_IER_OVR_IE_Msk
6425#define DCMI_IER_ERR_IE_Pos (2U)
6426#define DCMI_IER_ERR_IE_Msk (0x1UL << DCMI_IER_ERR_IE_Pos)
6427#define DCMI_IER_ERR_IE DCMI_IER_ERR_IE_Msk
6428#define DCMI_IER_VSYNC_IE_Pos (3U)
6429#define DCMI_IER_VSYNC_IE_Msk (0x1UL << DCMI_IER_VSYNC_IE_Pos)
6430#define DCMI_IER_VSYNC_IE DCMI_IER_VSYNC_IE_Msk
6431#define DCMI_IER_LINE_IE_Pos (4U)
6432#define DCMI_IER_LINE_IE_Msk (0x1UL << DCMI_IER_LINE_IE_Pos)
6433#define DCMI_IER_LINE_IE DCMI_IER_LINE_IE_Msk
6434
6435
6436/******************** Bits definition for DCMI_MIS register *****************/
6437#define DCMI_MIS_FRAME_MIS_Pos (0U)
6438#define DCMI_MIS_FRAME_MIS_Msk (0x1UL << DCMI_MIS_FRAME_MIS_Pos)
6439#define DCMI_MIS_FRAME_MIS DCMI_MIS_FRAME_MIS_Msk
6440#define DCMI_MIS_OVR_MIS_Pos (1U)
6441#define DCMI_MIS_OVR_MIS_Msk (0x1UL << DCMI_MIS_OVR_MIS_Pos)
6442#define DCMI_MIS_OVR_MIS DCMI_MIS_OVR_MIS_Msk
6443#define DCMI_MIS_ERR_MIS_Pos (2U)
6444#define DCMI_MIS_ERR_MIS_Msk (0x1UL << DCMI_MIS_ERR_MIS_Pos)
6445#define DCMI_MIS_ERR_MIS DCMI_MIS_ERR_MIS_Msk
6446#define DCMI_MIS_VSYNC_MIS_Pos (3U)
6447#define DCMI_MIS_VSYNC_MIS_Msk (0x1UL << DCMI_MIS_VSYNC_MIS_Pos)
6448#define DCMI_MIS_VSYNC_MIS DCMI_MIS_VSYNC_MIS_Msk
6449#define DCMI_MIS_LINE_MIS_Pos (4U)
6450#define DCMI_MIS_LINE_MIS_Msk (0x1UL << DCMI_MIS_LINE_MIS_Pos)
6451#define DCMI_MIS_LINE_MIS DCMI_MIS_LINE_MIS_Msk
6452
6453
6454/******************** Bits definition for DCMI_ICR register *****************/
6455#define DCMI_ICR_FRAME_ISC_Pos (0U)
6456#define DCMI_ICR_FRAME_ISC_Msk (0x1UL << DCMI_ICR_FRAME_ISC_Pos)
6457#define DCMI_ICR_FRAME_ISC DCMI_ICR_FRAME_ISC_Msk
6458#define DCMI_ICR_OVR_ISC_Pos (1U)
6459#define DCMI_ICR_OVR_ISC_Msk (0x1UL << DCMI_ICR_OVR_ISC_Pos)
6460#define DCMI_ICR_OVR_ISC DCMI_ICR_OVR_ISC_Msk
6461#define DCMI_ICR_ERR_ISC_Pos (2U)
6462#define DCMI_ICR_ERR_ISC_Msk (0x1UL << DCMI_ICR_ERR_ISC_Pos)
6463#define DCMI_ICR_ERR_ISC DCMI_ICR_ERR_ISC_Msk
6464#define DCMI_ICR_VSYNC_ISC_Pos (3U)
6465#define DCMI_ICR_VSYNC_ISC_Msk (0x1UL << DCMI_ICR_VSYNC_ISC_Pos)
6466#define DCMI_ICR_VSYNC_ISC DCMI_ICR_VSYNC_ISC_Msk
6467#define DCMI_ICR_LINE_ISC_Pos (4U)
6468#define DCMI_ICR_LINE_ISC_Msk (0x1UL << DCMI_ICR_LINE_ISC_Pos)
6469#define DCMI_ICR_LINE_ISC DCMI_ICR_LINE_ISC_Msk
6470
6471
6472/******************** Bits definition for DCMI_ESCR register ******************/
6473#define DCMI_ESCR_FSC_Pos (0U)
6474#define DCMI_ESCR_FSC_Msk (0xFFUL << DCMI_ESCR_FSC_Pos)
6475#define DCMI_ESCR_FSC DCMI_ESCR_FSC_Msk
6476#define DCMI_ESCR_LSC_Pos (8U)
6477#define DCMI_ESCR_LSC_Msk (0xFFUL << DCMI_ESCR_LSC_Pos)
6478#define DCMI_ESCR_LSC DCMI_ESCR_LSC_Msk
6479#define DCMI_ESCR_LEC_Pos (16U)
6480#define DCMI_ESCR_LEC_Msk (0xFFUL << DCMI_ESCR_LEC_Pos)
6481#define DCMI_ESCR_LEC DCMI_ESCR_LEC_Msk
6482#define DCMI_ESCR_FEC_Pos (24U)
6483#define DCMI_ESCR_FEC_Msk (0xFFUL << DCMI_ESCR_FEC_Pos)
6484#define DCMI_ESCR_FEC DCMI_ESCR_FEC_Msk
6485
6486/******************** Bits definition for DCMI_ESUR register ******************/
6487#define DCMI_ESUR_FSU_Pos (0U)
6488#define DCMI_ESUR_FSU_Msk (0xFFUL << DCMI_ESUR_FSU_Pos)
6489#define DCMI_ESUR_FSU DCMI_ESUR_FSU_Msk
6490#define DCMI_ESUR_LSU_Pos (8U)
6491#define DCMI_ESUR_LSU_Msk (0xFFUL << DCMI_ESUR_LSU_Pos)
6492#define DCMI_ESUR_LSU DCMI_ESUR_LSU_Msk
6493#define DCMI_ESUR_LEU_Pos (16U)
6494#define DCMI_ESUR_LEU_Msk (0xFFUL << DCMI_ESUR_LEU_Pos)
6495#define DCMI_ESUR_LEU DCMI_ESUR_LEU_Msk
6496#define DCMI_ESUR_FEU_Pos (24U)
6497#define DCMI_ESUR_FEU_Msk (0xFFUL << DCMI_ESUR_FEU_Pos)
6498#define DCMI_ESUR_FEU DCMI_ESUR_FEU_Msk
6499
6500/******************** Bits definition for DCMI_CWSTRT register ******************/
6501#define DCMI_CWSTRT_HOFFCNT_Pos (0U)
6502#define DCMI_CWSTRT_HOFFCNT_Msk (0x3FFFUL << DCMI_CWSTRT_HOFFCNT_Pos)
6503#define DCMI_CWSTRT_HOFFCNT DCMI_CWSTRT_HOFFCNT_Msk
6504#define DCMI_CWSTRT_VST_Pos (16U)
6505#define DCMI_CWSTRT_VST_Msk (0x1FFFUL << DCMI_CWSTRT_VST_Pos)
6506#define DCMI_CWSTRT_VST DCMI_CWSTRT_VST_Msk
6507
6508/******************** Bits definition for DCMI_CWSIZE register ******************/
6509#define DCMI_CWSIZE_CAPCNT_Pos (0U)
6510#define DCMI_CWSIZE_CAPCNT_Msk (0x3FFFUL << DCMI_CWSIZE_CAPCNT_Pos)
6511#define DCMI_CWSIZE_CAPCNT DCMI_CWSIZE_CAPCNT_Msk
6512#define DCMI_CWSIZE_VLINE_Pos (16U)
6513#define DCMI_CWSIZE_VLINE_Msk (0x3FFFUL << DCMI_CWSIZE_VLINE_Pos)
6514#define DCMI_CWSIZE_VLINE DCMI_CWSIZE_VLINE_Msk
6515
6516/******************** Bits definition for DCMI_DR register ******************/
6517#define DCMI_DR_BYTE0_Pos (0U)
6518#define DCMI_DR_BYTE0_Msk (0xFFUL << DCMI_DR_BYTE0_Pos)
6519#define DCMI_DR_BYTE0 DCMI_DR_BYTE0_Msk
6520#define DCMI_DR_BYTE1_Pos (8U)
6521#define DCMI_DR_BYTE1_Msk (0xFFUL << DCMI_DR_BYTE1_Pos)
6522#define DCMI_DR_BYTE1 DCMI_DR_BYTE1_Msk
6523#define DCMI_DR_BYTE2_Pos (16U)
6524#define DCMI_DR_BYTE2_Msk (0xFFUL << DCMI_DR_BYTE2_Pos)
6525#define DCMI_DR_BYTE2 DCMI_DR_BYTE2_Msk
6526#define DCMI_DR_BYTE3_Pos (24U)
6527#define DCMI_DR_BYTE3_Msk (0xFFUL << DCMI_DR_BYTE3_Pos)
6528#define DCMI_DR_BYTE3 DCMI_DR_BYTE3_Msk
6529
6530/******************************************************************************/
6531/* */
6532/* Digital Filter for Sigma Delta Modulators */
6533/* */
6534/******************************************************************************/
6535
6536/**************** DFSDM channel configuration registers ********************/
6537
6538/*************** Bit definition for DFSDM_CHCFGR1 register ******************/
6539#define DFSDM_CHCFGR1_DFSDMEN_Pos (31U)
6540#define DFSDM_CHCFGR1_DFSDMEN_Msk (0x1UL << DFSDM_CHCFGR1_DFSDMEN_Pos)
6541#define DFSDM_CHCFGR1_DFSDMEN DFSDM_CHCFGR1_DFSDMEN_Msk
6542#define DFSDM_CHCFGR1_CKOUTSRC_Pos (30U)
6543#define DFSDM_CHCFGR1_CKOUTSRC_Msk (0x1UL << DFSDM_CHCFGR1_CKOUTSRC_Pos)
6544#define DFSDM_CHCFGR1_CKOUTSRC DFSDM_CHCFGR1_CKOUTSRC_Msk
6545#define DFSDM_CHCFGR1_CKOUTDIV_Pos (16U)
6546#define DFSDM_CHCFGR1_CKOUTDIV_Msk (0xFFUL << DFSDM_CHCFGR1_CKOUTDIV_Pos)
6547#define DFSDM_CHCFGR1_CKOUTDIV DFSDM_CHCFGR1_CKOUTDIV_Msk
6548#define DFSDM_CHCFGR1_DATPACK_Pos (14U)
6549#define DFSDM_CHCFGR1_DATPACK_Msk (0x3UL << DFSDM_CHCFGR1_DATPACK_Pos)
6550#define DFSDM_CHCFGR1_DATPACK DFSDM_CHCFGR1_DATPACK_Msk
6551#define DFSDM_CHCFGR1_DATPACK_1 (0x2UL << DFSDM_CHCFGR1_DATPACK_Pos)
6552#define DFSDM_CHCFGR1_DATPACK_0 (0x1UL << DFSDM_CHCFGR1_DATPACK_Pos)
6553#define DFSDM_CHCFGR1_DATMPX_Pos (12U)
6554#define DFSDM_CHCFGR1_DATMPX_Msk (0x3UL << DFSDM_CHCFGR1_DATMPX_Pos)
6555#define DFSDM_CHCFGR1_DATMPX DFSDM_CHCFGR1_DATMPX_Msk
6556#define DFSDM_CHCFGR1_DATMPX_1 (0x2UL << DFSDM_CHCFGR1_DATMPX_Pos)
6557#define DFSDM_CHCFGR1_DATMPX_0 (0x1UL << DFSDM_CHCFGR1_DATMPX_Pos)
6558#define DFSDM_CHCFGR1_CHINSEL_Pos (8U)
6559#define DFSDM_CHCFGR1_CHINSEL_Msk (0x1UL << DFSDM_CHCFGR1_CHINSEL_Pos)
6560#define DFSDM_CHCFGR1_CHINSEL DFSDM_CHCFGR1_CHINSEL_Msk
6561#define DFSDM_CHCFGR1_CHEN_Pos (7U)
6562#define DFSDM_CHCFGR1_CHEN_Msk (0x1UL << DFSDM_CHCFGR1_CHEN_Pos)
6563#define DFSDM_CHCFGR1_CHEN DFSDM_CHCFGR1_CHEN_Msk
6564#define DFSDM_CHCFGR1_CKABEN_Pos (6U)
6565#define DFSDM_CHCFGR1_CKABEN_Msk (0x1UL << DFSDM_CHCFGR1_CKABEN_Pos)
6566#define DFSDM_CHCFGR1_CKABEN DFSDM_CHCFGR1_CKABEN_Msk
6567#define DFSDM_CHCFGR1_SCDEN_Pos (5U)
6568#define DFSDM_CHCFGR1_SCDEN_Msk (0x1UL << DFSDM_CHCFGR1_SCDEN_Pos)
6569#define DFSDM_CHCFGR1_SCDEN DFSDM_CHCFGR1_SCDEN_Msk
6570#define DFSDM_CHCFGR1_SPICKSEL_Pos (2U)
6571#define DFSDM_CHCFGR1_SPICKSEL_Msk (0x3UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
6572#define DFSDM_CHCFGR1_SPICKSEL DFSDM_CHCFGR1_SPICKSEL_Msk
6573#define DFSDM_CHCFGR1_SPICKSEL_1 (0x2UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
6574#define DFSDM_CHCFGR1_SPICKSEL_0 (0x1UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
6575#define DFSDM_CHCFGR1_SITP_Pos (0U)
6576#define DFSDM_CHCFGR1_SITP_Msk (0x3UL << DFSDM_CHCFGR1_SITP_Pos)
6577#define DFSDM_CHCFGR1_SITP DFSDM_CHCFGR1_SITP_Msk
6578#define DFSDM_CHCFGR1_SITP_1 (0x2UL << DFSDM_CHCFGR1_SITP_Pos)
6579#define DFSDM_CHCFGR1_SITP_0 (0x1UL << DFSDM_CHCFGR1_SITP_Pos)
6581/*************** Bit definition for DFSDM_CHCFGR2 register ******************/
6582#define DFSDM_CHCFGR2_OFFSET_Pos (8U)
6583#define DFSDM_CHCFGR2_OFFSET_Msk (0xFFFFFFUL << DFSDM_CHCFGR2_OFFSET_Pos)
6584#define DFSDM_CHCFGR2_OFFSET DFSDM_CHCFGR2_OFFSET_Msk
6585#define DFSDM_CHCFGR2_DTRBS_Pos (3U)
6586#define DFSDM_CHCFGR2_DTRBS_Msk (0x1FUL << DFSDM_CHCFGR2_DTRBS_Pos)
6587#define DFSDM_CHCFGR2_DTRBS DFSDM_CHCFGR2_DTRBS_Msk
6589/****************** Bit definition for DFSDM_CHAWSCDR register *****************/
6590#define DFSDM_CHAWSCDR_AWFORD_Pos (22U)
6591#define DFSDM_CHAWSCDR_AWFORD_Msk (0x3UL << DFSDM_CHAWSCDR_AWFORD_Pos)
6592#define DFSDM_CHAWSCDR_AWFORD DFSDM_CHAWSCDR_AWFORD_Msk
6593#define DFSDM_CHAWSCDR_AWFORD_1 (0x2UL << DFSDM_CHAWSCDR_AWFORD_Pos)
6594#define DFSDM_CHAWSCDR_AWFORD_0 (0x1UL << DFSDM_CHAWSCDR_AWFORD_Pos)
6595#define DFSDM_CHAWSCDR_AWFOSR_Pos (16U)
6596#define DFSDM_CHAWSCDR_AWFOSR_Msk (0x1FUL << DFSDM_CHAWSCDR_AWFOSR_Pos)
6597#define DFSDM_CHAWSCDR_AWFOSR DFSDM_CHAWSCDR_AWFOSR_Msk
6598#define DFSDM_CHAWSCDR_BKSCD_Pos (12U)
6599#define DFSDM_CHAWSCDR_BKSCD_Msk (0xFUL << DFSDM_CHAWSCDR_BKSCD_Pos)
6600#define DFSDM_CHAWSCDR_BKSCD DFSDM_CHAWSCDR_BKSCD_Msk
6601#define DFSDM_CHAWSCDR_SCDT_Pos (0U)
6602#define DFSDM_CHAWSCDR_SCDT_Msk (0xFFUL << DFSDM_CHAWSCDR_SCDT_Pos)
6603#define DFSDM_CHAWSCDR_SCDT DFSDM_CHAWSCDR_SCDT_Msk
6605/**************** Bit definition for DFSDM_CHWDATR register *******************/
6606#define DFSDM_CHWDATR_WDATA_Pos (0U)
6607#define DFSDM_CHWDATR_WDATA_Msk (0xFFFFUL << DFSDM_CHWDATR_WDATA_Pos)
6608#define DFSDM_CHWDATR_WDATA DFSDM_CHWDATR_WDATA_Msk
6610/**************** Bit definition for DFSDM_CHDATINR register *****************/
6611#define DFSDM_CHDATINR_INDAT0_Pos (0U)
6612#define DFSDM_CHDATINR_INDAT0_Msk (0xFFFFUL << DFSDM_CHDATINR_INDAT0_Pos)
6613#define DFSDM_CHDATINR_INDAT0 DFSDM_CHDATINR_INDAT0_Msk
6614#define DFSDM_CHDATINR_INDAT1_Pos (16U)
6615#define DFSDM_CHDATINR_INDAT1_Msk (0xFFFFUL << DFSDM_CHDATINR_INDAT1_Pos)
6616#define DFSDM_CHDATINR_INDAT1 DFSDM_CHDATINR_INDAT1_Msk
6618/************************ DFSDM module registers ****************************/
6619
6620/******************** Bit definition for DFSDM_FLTCR1 register *******************/
6621#define DFSDM_FLTCR1_AWFSEL_Pos (30U)
6622#define DFSDM_FLTCR1_AWFSEL_Msk (0x1UL << DFSDM_FLTCR1_AWFSEL_Pos)
6623#define DFSDM_FLTCR1_AWFSEL DFSDM_FLTCR1_AWFSEL_Msk
6624#define DFSDM_FLTCR1_FAST_Pos (29U)
6625#define DFSDM_FLTCR1_FAST_Msk (0x1UL << DFSDM_FLTCR1_FAST_Pos)
6626#define DFSDM_FLTCR1_FAST DFSDM_FLTCR1_FAST_Msk
6627#define DFSDM_FLTCR1_RCH_Pos (24U)
6628#define DFSDM_FLTCR1_RCH_Msk (0x7UL << DFSDM_FLTCR1_RCH_Pos)
6629#define DFSDM_FLTCR1_RCH DFSDM_FLTCR1_RCH_Msk
6630#define DFSDM_FLTCR1_RDMAEN_Pos (21U)
6631#define DFSDM_FLTCR1_RDMAEN_Msk (0x1UL << DFSDM_FLTCR1_RDMAEN_Pos)
6632#define DFSDM_FLTCR1_RDMAEN DFSDM_FLTCR1_RDMAEN_Msk
6633#define DFSDM_FLTCR1_RSYNC_Pos (19U)
6634#define DFSDM_FLTCR1_RSYNC_Msk (0x1UL << DFSDM_FLTCR1_RSYNC_Pos)
6635#define DFSDM_FLTCR1_RSYNC DFSDM_FLTCR1_RSYNC_Msk
6636#define DFSDM_FLTCR1_RCONT_Pos (18U)
6637#define DFSDM_FLTCR1_RCONT_Msk (0x1UL << DFSDM_FLTCR1_RCONT_Pos)
6638#define DFSDM_FLTCR1_RCONT DFSDM_FLTCR1_RCONT_Msk
6639#define DFSDM_FLTCR1_RSWSTART_Pos (17U)
6640#define DFSDM_FLTCR1_RSWSTART_Msk (0x1UL << DFSDM_FLTCR1_RSWSTART_Pos)
6641#define DFSDM_FLTCR1_RSWSTART DFSDM_FLTCR1_RSWSTART_Msk
6642#define DFSDM_FLTCR1_JEXTEN_Pos (13U)
6643#define DFSDM_FLTCR1_JEXTEN_Msk (0x3UL << DFSDM_FLTCR1_JEXTEN_Pos)
6644#define DFSDM_FLTCR1_JEXTEN DFSDM_FLTCR1_JEXTEN_Msk
6645#define DFSDM_FLTCR1_JEXTEN_1 (0x2UL << DFSDM_FLTCR1_JEXTEN_Pos)
6646#define DFSDM_FLTCR1_JEXTEN_0 (0x1UL << DFSDM_FLTCR1_JEXTEN_Pos)
6647#define DFSDM_FLTCR1_JEXTSEL_Pos (8U)
6648#define DFSDM_FLTCR1_JEXTSEL_Msk (0x1FUL << DFSDM_FLTCR1_JEXTSEL_Pos)
6649#define DFSDM_FLTCR1_JEXTSEL DFSDM_FLTCR1_JEXTSEL_Msk
6650#define DFSDM_FLTCR1_JEXTSEL_0 (0x01UL << DFSDM_FLTCR1_JEXTSEL_Pos)
6651#define DFSDM_FLTCR1_JEXTSEL_1 (0x02UL << DFSDM_FLTCR1_JEXTSEL_Pos)
6652#define DFSDM_FLTCR1_JEXTSEL_2 (0x04UL << DFSDM_FLTCR1_JEXTSEL_Pos)
6653#define DFSDM_FLTCR1_JEXTSEL_3 (0x08UL << DFSDM_FLTCR1_JEXTSEL_Pos)
6654#define DFSDM_FLTCR1_JEXTSEL_4 (0x10UL << DFSDM_FLTCR1_JEXTSEL_Pos)
6656#define DFSDM_FLTCR1_JDMAEN_Pos (5U)
6657#define DFSDM_FLTCR1_JDMAEN_Msk (0x1UL << DFSDM_FLTCR1_JDMAEN_Pos)
6658#define DFSDM_FLTCR1_JDMAEN DFSDM_FLTCR1_JDMAEN_Msk
6659#define DFSDM_FLTCR1_JSCAN_Pos (4U)
6660#define DFSDM_FLTCR1_JSCAN_Msk (0x1UL << DFSDM_FLTCR1_JSCAN_Pos)
6661#define DFSDM_FLTCR1_JSCAN DFSDM_FLTCR1_JSCAN_Msk
6662#define DFSDM_FLTCR1_JSYNC_Pos (3U)
6663#define DFSDM_FLTCR1_JSYNC_Msk (0x1UL << DFSDM_FLTCR1_JSYNC_Pos)
6664#define DFSDM_FLTCR1_JSYNC DFSDM_FLTCR1_JSYNC_Msk
6665#define DFSDM_FLTCR1_JSWSTART_Pos (1U)
6666#define DFSDM_FLTCR1_JSWSTART_Msk (0x1UL << DFSDM_FLTCR1_JSWSTART_Pos)
6667#define DFSDM_FLTCR1_JSWSTART DFSDM_FLTCR1_JSWSTART_Msk
6668#define DFSDM_FLTCR1_DFEN_Pos (0U)
6669#define DFSDM_FLTCR1_DFEN_Msk (0x1UL << DFSDM_FLTCR1_DFEN_Pos)
6670#define DFSDM_FLTCR1_DFEN DFSDM_FLTCR1_DFEN_Msk
6672/******************** Bit definition for DFSDM_FLTCR2 register *******************/
6673#define DFSDM_FLTCR2_AWDCH_Pos (16U)
6674#define DFSDM_FLTCR2_AWDCH_Msk (0xFFUL << DFSDM_FLTCR2_AWDCH_Pos)
6675#define DFSDM_FLTCR2_AWDCH DFSDM_FLTCR2_AWDCH_Msk
6676#define DFSDM_FLTCR2_EXCH_Pos (8U)
6677#define DFSDM_FLTCR2_EXCH_Msk (0xFFUL << DFSDM_FLTCR2_EXCH_Pos)
6678#define DFSDM_FLTCR2_EXCH DFSDM_FLTCR2_EXCH_Msk
6679#define DFSDM_FLTCR2_CKABIE_Pos (6U)
6680#define DFSDM_FLTCR2_CKABIE_Msk (0x1UL << DFSDM_FLTCR2_CKABIE_Pos)
6681#define DFSDM_FLTCR2_CKABIE DFSDM_FLTCR2_CKABIE_Msk
6682#define DFSDM_FLTCR2_SCDIE_Pos (5U)
6683#define DFSDM_FLTCR2_SCDIE_Msk (0x1UL << DFSDM_FLTCR2_SCDIE_Pos)
6684#define DFSDM_FLTCR2_SCDIE DFSDM_FLTCR2_SCDIE_Msk
6685#define DFSDM_FLTCR2_AWDIE_Pos (4U)
6686#define DFSDM_FLTCR2_AWDIE_Msk (0x1UL << DFSDM_FLTCR2_AWDIE_Pos)
6687#define DFSDM_FLTCR2_AWDIE DFSDM_FLTCR2_AWDIE_Msk
6688#define DFSDM_FLTCR2_ROVRIE_Pos (3U)
6689#define DFSDM_FLTCR2_ROVRIE_Msk (0x1UL << DFSDM_FLTCR2_ROVRIE_Pos)
6690#define DFSDM_FLTCR2_ROVRIE DFSDM_FLTCR2_ROVRIE_Msk
6691#define DFSDM_FLTCR2_JOVRIE_Pos (2U)
6692#define DFSDM_FLTCR2_JOVRIE_Msk (0x1UL << DFSDM_FLTCR2_JOVRIE_Pos)
6693#define DFSDM_FLTCR2_JOVRIE DFSDM_FLTCR2_JOVRIE_Msk
6694#define DFSDM_FLTCR2_REOCIE_Pos (1U)
6695#define DFSDM_FLTCR2_REOCIE_Msk (0x1UL << DFSDM_FLTCR2_REOCIE_Pos)
6696#define DFSDM_FLTCR2_REOCIE DFSDM_FLTCR2_REOCIE_Msk
6697#define DFSDM_FLTCR2_JEOCIE_Pos (0U)
6698#define DFSDM_FLTCR2_JEOCIE_Msk (0x1UL << DFSDM_FLTCR2_JEOCIE_Pos)
6699#define DFSDM_FLTCR2_JEOCIE DFSDM_FLTCR2_JEOCIE_Msk
6701/******************** Bit definition for DFSDM_FLTISR register *******************/
6702#define DFSDM_FLTISR_SCDF_Pos (24U)
6703#define DFSDM_FLTISR_SCDF_Msk (0xFFUL << DFSDM_FLTISR_SCDF_Pos)
6704#define DFSDM_FLTISR_SCDF DFSDM_FLTISR_SCDF_Msk
6705#define DFSDM_FLTISR_CKABF_Pos (16U)
6706#define DFSDM_FLTISR_CKABF_Msk (0xFFUL << DFSDM_FLTISR_CKABF_Pos)
6707#define DFSDM_FLTISR_CKABF DFSDM_FLTISR_CKABF_Msk
6708#define DFSDM_FLTISR_RCIP_Pos (14U)
6709#define DFSDM_FLTISR_RCIP_Msk (0x1UL << DFSDM_FLTISR_RCIP_Pos)
6710#define DFSDM_FLTISR_RCIP DFSDM_FLTISR_RCIP_Msk
6711#define DFSDM_FLTISR_JCIP_Pos (13U)
6712#define DFSDM_FLTISR_JCIP_Msk (0x1UL << DFSDM_FLTISR_JCIP_Pos)
6713#define DFSDM_FLTISR_JCIP DFSDM_FLTISR_JCIP_Msk
6714#define DFSDM_FLTISR_AWDF_Pos (4U)
6715#define DFSDM_FLTISR_AWDF_Msk (0x1UL << DFSDM_FLTISR_AWDF_Pos)
6716#define DFSDM_FLTISR_AWDF DFSDM_FLTISR_AWDF_Msk
6717#define DFSDM_FLTISR_ROVRF_Pos (3U)
6718#define DFSDM_FLTISR_ROVRF_Msk (0x1UL << DFSDM_FLTISR_ROVRF_Pos)
6719#define DFSDM_FLTISR_ROVRF DFSDM_FLTISR_ROVRF_Msk
6720#define DFSDM_FLTISR_JOVRF_Pos (2U)
6721#define DFSDM_FLTISR_JOVRF_Msk (0x1UL << DFSDM_FLTISR_JOVRF_Pos)
6722#define DFSDM_FLTISR_JOVRF DFSDM_FLTISR_JOVRF_Msk
6723#define DFSDM_FLTISR_REOCF_Pos (1U)
6724#define DFSDM_FLTISR_REOCF_Msk (0x1UL << DFSDM_FLTISR_REOCF_Pos)
6725#define DFSDM_FLTISR_REOCF DFSDM_FLTISR_REOCF_Msk
6726#define DFSDM_FLTISR_JEOCF_Pos (0U)
6727#define DFSDM_FLTISR_JEOCF_Msk (0x1UL << DFSDM_FLTISR_JEOCF_Pos)
6728#define DFSDM_FLTISR_JEOCF DFSDM_FLTISR_JEOCF_Msk
6730/******************** Bit definition for DFSDM_FLTICR register *******************/
6731#define DFSDM_FLTICR_CLRSCDF_Pos (24U)
6732#define DFSDM_FLTICR_CLRSCDF_Msk (0xFFUL << DFSDM_FLTICR_CLRSCDF_Pos)
6733#define DFSDM_FLTICR_CLRSCDF DFSDM_FLTICR_CLRSCDF_Msk
6734#define DFSDM_FLTICR_CLRCKABF_Pos (16U)
6735#define DFSDM_FLTICR_CLRCKABF_Msk (0xFFUL << DFSDM_FLTICR_CLRCKABF_Pos)
6736#define DFSDM_FLTICR_CLRCKABF DFSDM_FLTICR_CLRCKABF_Msk
6737#define DFSDM_FLTICR_CLRROVRF_Pos (3U)
6738#define DFSDM_FLTICR_CLRROVRF_Msk (0x1UL << DFSDM_FLTICR_CLRROVRF_Pos)
6739#define DFSDM_FLTICR_CLRROVRF DFSDM_FLTICR_CLRROVRF_Msk
6740#define DFSDM_FLTICR_CLRJOVRF_Pos (2U)
6741#define DFSDM_FLTICR_CLRJOVRF_Msk (0x1UL << DFSDM_FLTICR_CLRJOVRF_Pos)
6742#define DFSDM_FLTICR_CLRJOVRF DFSDM_FLTICR_CLRJOVRF_Msk
6744/******************* Bit definition for DFSDM_FLTJCHGR register ******************/
6745#define DFSDM_FLTJCHGR_JCHG_Pos (0U)
6746#define DFSDM_FLTJCHGR_JCHG_Msk (0xFFUL << DFSDM_FLTJCHGR_JCHG_Pos)
6747#define DFSDM_FLTJCHGR_JCHG DFSDM_FLTJCHGR_JCHG_Msk
6749/******************** Bit definition for DFSDM_FLTFCR register *******************/
6750#define DFSDM_FLTFCR_FORD_Pos (29U)
6751#define DFSDM_FLTFCR_FORD_Msk (0x7UL << DFSDM_FLTFCR_FORD_Pos)
6752#define DFSDM_FLTFCR_FORD DFSDM_FLTFCR_FORD_Msk
6753#define DFSDM_FLTFCR_FORD_2 (0x4UL << DFSDM_FLTFCR_FORD_Pos)
6754#define DFSDM_FLTFCR_FORD_1 (0x2UL << DFSDM_FLTFCR_FORD_Pos)
6755#define DFSDM_FLTFCR_FORD_0 (0x1UL << DFSDM_FLTFCR_FORD_Pos)
6756#define DFSDM_FLTFCR_FOSR_Pos (16U)
6757#define DFSDM_FLTFCR_FOSR_Msk (0x3FFUL << DFSDM_FLTFCR_FOSR_Pos)
6758#define DFSDM_FLTFCR_FOSR DFSDM_FLTFCR_FOSR_Msk
6759#define DFSDM_FLTFCR_IOSR_Pos (0U)
6760#define DFSDM_FLTFCR_IOSR_Msk (0xFFUL << DFSDM_FLTFCR_IOSR_Pos)
6761#define DFSDM_FLTFCR_IOSR DFSDM_FLTFCR_IOSR_Msk
6763/****************** Bit definition for DFSDM_FLTJDATAR register *****************/
6764#define DFSDM_FLTJDATAR_JDATA_Pos (8U)
6765#define DFSDM_FLTJDATAR_JDATA_Msk (0xFFFFFFUL << DFSDM_FLTJDATAR_JDATA_Pos)
6766#define DFSDM_FLTJDATAR_JDATA DFSDM_FLTJDATAR_JDATA_Msk
6767#define DFSDM_FLTJDATAR_JDATACH_Pos (0U)
6768#define DFSDM_FLTJDATAR_JDATACH_Msk (0x7UL << DFSDM_FLTJDATAR_JDATACH_Pos)
6769#define DFSDM_FLTJDATAR_JDATACH DFSDM_FLTJDATAR_JDATACH_Msk
6771/****************** Bit definition for DFSDM_FLTRDATAR register *****************/
6772#define DFSDM_FLTRDATAR_RDATA_Pos (8U)
6773#define DFSDM_FLTRDATAR_RDATA_Msk (0xFFFFFFUL << DFSDM_FLTRDATAR_RDATA_Pos)
6774#define DFSDM_FLTRDATAR_RDATA DFSDM_FLTRDATAR_RDATA_Msk
6775#define DFSDM_FLTRDATAR_RPEND_Pos (4U)
6776#define DFSDM_FLTRDATAR_RPEND_Msk (0x1UL << DFSDM_FLTRDATAR_RPEND_Pos)
6777#define DFSDM_FLTRDATAR_RPEND DFSDM_FLTRDATAR_RPEND_Msk
6778#define DFSDM_FLTRDATAR_RDATACH_Pos (0U)
6779#define DFSDM_FLTRDATAR_RDATACH_Msk (0x7UL << DFSDM_FLTRDATAR_RDATACH_Pos)
6780#define DFSDM_FLTRDATAR_RDATACH DFSDM_FLTRDATAR_RDATACH_Msk
6782/****************** Bit definition for DFSDM_FLTAWHTR register ******************/
6783#define DFSDM_FLTAWHTR_AWHT_Pos (8U)
6784#define DFSDM_FLTAWHTR_AWHT_Msk (0xFFFFFFUL << DFSDM_FLTAWHTR_AWHT_Pos)
6785#define DFSDM_FLTAWHTR_AWHT DFSDM_FLTAWHTR_AWHT_Msk
6786#define DFSDM_FLTAWHTR_BKAWH_Pos (0U)
6787#define DFSDM_FLTAWHTR_BKAWH_Msk (0xFUL << DFSDM_FLTAWHTR_BKAWH_Pos)
6788#define DFSDM_FLTAWHTR_BKAWH DFSDM_FLTAWHTR_BKAWH_Msk
6790/****************** Bit definition for DFSDM_FLTAWLTR register ******************/
6791#define DFSDM_FLTAWLTR_AWLT_Pos (8U)
6792#define DFSDM_FLTAWLTR_AWLT_Msk (0xFFFFFFUL << DFSDM_FLTAWLTR_AWLT_Pos)
6793#define DFSDM_FLTAWLTR_AWLT DFSDM_FLTAWLTR_AWLT_Msk
6794#define DFSDM_FLTAWLTR_BKAWL_Pos (0U)
6795#define DFSDM_FLTAWLTR_BKAWL_Msk (0xFUL << DFSDM_FLTAWLTR_BKAWL_Pos)
6796#define DFSDM_FLTAWLTR_BKAWL DFSDM_FLTAWLTR_BKAWL_Msk
6798/****************** Bit definition for DFSDM_FLTAWSR register ******************/
6799#define DFSDM_FLTAWSR_AWHTF_Pos (8U)
6800#define DFSDM_FLTAWSR_AWHTF_Msk (0xFFUL << DFSDM_FLTAWSR_AWHTF_Pos)
6801#define DFSDM_FLTAWSR_AWHTF DFSDM_FLTAWSR_AWHTF_Msk
6802#define DFSDM_FLTAWSR_AWLTF_Pos (0U)
6803#define DFSDM_FLTAWSR_AWLTF_Msk (0xFFUL << DFSDM_FLTAWSR_AWLTF_Pos)
6804#define DFSDM_FLTAWSR_AWLTF DFSDM_FLTAWSR_AWLTF_Msk
6806/****************** Bit definition for DFSDM_FLTAWCFR) register *****************/
6807#define DFSDM_FLTAWCFR_CLRAWHTF_Pos (8U)
6808#define DFSDM_FLTAWCFR_CLRAWHTF_Msk (0xFFUL << DFSDM_FLTAWCFR_CLRAWHTF_Pos)
6809#define DFSDM_FLTAWCFR_CLRAWHTF DFSDM_FLTAWCFR_CLRAWHTF_Msk
6810#define DFSDM_FLTAWCFR_CLRAWLTF_Pos (0U)
6811#define DFSDM_FLTAWCFR_CLRAWLTF_Msk (0xFFUL << DFSDM_FLTAWCFR_CLRAWLTF_Pos)
6812#define DFSDM_FLTAWCFR_CLRAWLTF DFSDM_FLTAWCFR_CLRAWLTF_Msk
6814/****************** Bit definition for DFSDM_FLTEXMAX register ******************/
6815#define DFSDM_FLTEXMAX_EXMAX_Pos (8U)
6816#define DFSDM_FLTEXMAX_EXMAX_Msk (0xFFFFFFUL << DFSDM_FLTEXMAX_EXMAX_Pos)
6817#define DFSDM_FLTEXMAX_EXMAX DFSDM_FLTEXMAX_EXMAX_Msk
6818#define DFSDM_FLTEXMAX_EXMAXCH_Pos (0U)
6819#define DFSDM_FLTEXMAX_EXMAXCH_Msk (0x7UL << DFSDM_FLTEXMAX_EXMAXCH_Pos)
6820#define DFSDM_FLTEXMAX_EXMAXCH DFSDM_FLTEXMAX_EXMAXCH_Msk
6822/****************** Bit definition for DFSDM_FLTEXMIN register ******************/
6823#define DFSDM_FLTEXMIN_EXMIN_Pos (8U)
6824#define DFSDM_FLTEXMIN_EXMIN_Msk (0xFFFFFFUL << DFSDM_FLTEXMIN_EXMIN_Pos)
6825#define DFSDM_FLTEXMIN_EXMIN DFSDM_FLTEXMIN_EXMIN_Msk
6826#define DFSDM_FLTEXMIN_EXMINCH_Pos (0U)
6827#define DFSDM_FLTEXMIN_EXMINCH_Msk (0x7UL << DFSDM_FLTEXMIN_EXMINCH_Pos)
6828#define DFSDM_FLTEXMIN_EXMINCH DFSDM_FLTEXMIN_EXMINCH_Msk
6830/****************** Bit definition for DFSDM_FLTCNVTIMR register ******************/
6831#define DFSDM_FLTCNVTIMR_CNVCNT_Pos (4U)
6832#define DFSDM_FLTCNVTIMR_CNVCNT_Msk (0xFFFFFFFUL << DFSDM_FLTCNVTIMR_CNVCNT_Pos)
6833#define DFSDM_FLTCNVTIMR_CNVCNT DFSDM_FLTCNVTIMR_CNVCNT_Msk
6835/******************************************************************************/
6836/* */
6837/* BDMA Controller */
6838/* */
6839/******************************************************************************/
6840
6841/******************* Bit definition for BDMA_ISR register ********************/
6842#define BDMA_ISR_GIF0_Pos (0U)
6843#define BDMA_ISR_GIF0_Msk (0x1UL << BDMA_ISR_GIF0_Pos)
6844#define BDMA_ISR_GIF0 BDMA_ISR_GIF0_Msk
6845#define BDMA_ISR_TCIF0_Pos (1U)
6846#define BDMA_ISR_TCIF0_Msk (0x1UL << BDMA_ISR_TCIF0_Pos)
6847#define BDMA_ISR_TCIF0 BDMA_ISR_TCIF0_Msk
6848#define BDMA_ISR_HTIF0_Pos (2U)
6849#define BDMA_ISR_HTIF0_Msk (0x1UL << BDMA_ISR_HTIF0_Pos)
6850#define BDMA_ISR_HTIF0 BDMA_ISR_HTIF0_Msk
6851#define BDMA_ISR_TEIF0_Pos (3U)
6852#define BDMA_ISR_TEIF0_Msk (0x1UL << BDMA_ISR_TEIF0_Pos)
6853#define BDMA_ISR_TEIF0 BDMA_ISR_TEIF0_Msk
6854#define BDMA_ISR_GIF1_Pos (4U)
6855#define BDMA_ISR_GIF1_Msk (0x1UL << BDMA_ISR_GIF1_Pos)
6856#define BDMA_ISR_GIF1 BDMA_ISR_GIF1_Msk
6857#define BDMA_ISR_TCIF1_Pos (5U)
6858#define BDMA_ISR_TCIF1_Msk (0x1UL << BDMA_ISR_TCIF1_Pos)
6859#define BDMA_ISR_TCIF1 BDMA_ISR_TCIF1_Msk
6860#define BDMA_ISR_HTIF1_Pos (6U)
6861#define BDMA_ISR_HTIF1_Msk (0x1UL << BDMA_ISR_HTIF1_Pos)
6862#define BDMA_ISR_HTIF1 BDMA_ISR_HTIF1_Msk
6863#define BDMA_ISR_TEIF1_Pos (7U)
6864#define BDMA_ISR_TEIF1_Msk (0x1UL << BDMA_ISR_TEIF1_Pos)
6865#define BDMA_ISR_TEIF1 BDMA_ISR_TEIF1_Msk
6866#define BDMA_ISR_GIF2_Pos (8U)
6867#define BDMA_ISR_GIF2_Msk (0x1UL << BDMA_ISR_GIF2_Pos)
6868#define BDMA_ISR_GIF2 BDMA_ISR_GIF2_Msk
6869#define BDMA_ISR_TCIF2_Pos (9U)
6870#define BDMA_ISR_TCIF2_Msk (0x1UL << BDMA_ISR_TCIF2_Pos)
6871#define BDMA_ISR_TCIF2 BDMA_ISR_TCIF2_Msk
6872#define BDMA_ISR_HTIF2_Pos (10U)
6873#define BDMA_ISR_HTIF2_Msk (0x1UL << BDMA_ISR_HTIF2_Pos)
6874#define BDMA_ISR_HTIF2 BDMA_ISR_HTIF2_Msk
6875#define BDMA_ISR_TEIF2_Pos (11U)
6876#define BDMA_ISR_TEIF2_Msk (0x1UL << BDMA_ISR_TEIF2_Pos)
6877#define BDMA_ISR_TEIF2 BDMA_ISR_TEIF2_Msk
6878#define BDMA_ISR_GIF3_Pos (12U)
6879#define BDMA_ISR_GIF3_Msk (0x1UL << BDMA_ISR_GIF3_Pos)
6880#define BDMA_ISR_GIF3 BDMA_ISR_GIF3_Msk
6881#define BDMA_ISR_TCIF3_Pos (13U)
6882#define BDMA_ISR_TCIF3_Msk (0x1UL << BDMA_ISR_TCIF3_Pos)
6883#define BDMA_ISR_TCIF3 BDMA_ISR_TCIF3_Msk
6884#define BDMA_ISR_HTIF3_Pos (14U)
6885#define BDMA_ISR_HTIF3_Msk (0x1UL << BDMA_ISR_HTIF3_Pos)
6886#define BDMA_ISR_HTIF3 BDMA_ISR_HTIF3_Msk
6887#define BDMA_ISR_TEIF3_Pos (15U)
6888#define BDMA_ISR_TEIF3_Msk (0x1UL << BDMA_ISR_TEIF3_Pos)
6889#define BDMA_ISR_TEIF3 BDMA_ISR_TEIF3_Msk
6890#define BDMA_ISR_GIF4_Pos (16U)
6891#define BDMA_ISR_GIF4_Msk (0x1UL << BDMA_ISR_GIF4_Pos)
6892#define BDMA_ISR_GIF4 BDMA_ISR_GIF4_Msk
6893#define BDMA_ISR_TCIF4_Pos (17U)
6894#define BDMA_ISR_TCIF4_Msk (0x1UL << BDMA_ISR_TCIF4_Pos)
6895#define BDMA_ISR_TCIF4 BDMA_ISR_TCIF4_Msk
6896#define BDMA_ISR_HTIF4_Pos (18U)
6897#define BDMA_ISR_HTIF4_Msk (0x1UL << BDMA_ISR_HTIF4_Pos)
6898#define BDMA_ISR_HTIF4 BDMA_ISR_HTIF4_Msk
6899#define BDMA_ISR_TEIF4_Pos (19U)
6900#define BDMA_ISR_TEIF4_Msk (0x1UL << BDMA_ISR_TEIF4_Pos)
6901#define BDMA_ISR_TEIF4 BDMA_ISR_TEIF4_Msk
6902#define BDMA_ISR_GIF5_Pos (20U)
6903#define BDMA_ISR_GIF5_Msk (0x1UL << BDMA_ISR_GIF5_Pos)
6904#define BDMA_ISR_GIF5 BDMA_ISR_GIF5_Msk
6905#define BDMA_ISR_TCIF5_Pos (21U)
6906#define BDMA_ISR_TCIF5_Msk (0x1UL << BDMA_ISR_TCIF5_Pos)
6907#define BDMA_ISR_TCIF5 BDMA_ISR_TCIF5_Msk
6908#define BDMA_ISR_HTIF5_Pos (22U)
6909#define BDMA_ISR_HTIF5_Msk (0x1UL << BDMA_ISR_HTIF5_Pos)
6910#define BDMA_ISR_HTIF5 BDMA_ISR_HTIF5_Msk
6911#define BDMA_ISR_TEIF5_Pos (23U)
6912#define BDMA_ISR_TEIF5_Msk (0x1UL << BDMA_ISR_TEIF5_Pos)
6913#define BDMA_ISR_TEIF5 BDMA_ISR_TEIF5_Msk
6914#define BDMA_ISR_GIF6_Pos (24U)
6915#define BDMA_ISR_GIF6_Msk (0x1UL << BDMA_ISR_GIF6_Pos)
6916#define BDMA_ISR_GIF6 BDMA_ISR_GIF6_Msk
6917#define BDMA_ISR_TCIF6_Pos (25U)
6918#define BDMA_ISR_TCIF6_Msk (0x1UL << BDMA_ISR_TCIF6_Pos)
6919#define BDMA_ISR_TCIF6 BDMA_ISR_TCIF6_Msk
6920#define BDMA_ISR_HTIF6_Pos (26U)
6921#define BDMA_ISR_HTIF6_Msk (0x1UL << BDMA_ISR_HTIF6_Pos)
6922#define BDMA_ISR_HTIF6 BDMA_ISR_HTIF6_Msk
6923#define BDMA_ISR_TEIF6_Pos (27U)
6924#define BDMA_ISR_TEIF6_Msk (0x1UL << BDMA_ISR_TEIF6_Pos)
6925#define BDMA_ISR_TEIF6 BDMA_ISR_TEIF6_Msk
6926#define BDMA_ISR_GIF7_Pos (28U)
6927#define BDMA_ISR_GIF7_Msk (0x1UL << BDMA_ISR_GIF7_Pos)
6928#define BDMA_ISR_GIF7 BDMA_ISR_GIF7_Msk
6929#define BDMA_ISR_TCIF7_Pos (29U)
6930#define BDMA_ISR_TCIF7_Msk (0x1UL << BDMA_ISR_TCIF7_Pos)
6931#define BDMA_ISR_TCIF7 BDMA_ISR_TCIF7_Msk
6932#define BDMA_ISR_HTIF7_Pos (30U)
6933#define BDMA_ISR_HTIF7_Msk (0x1UL << BDMA_ISR_HTIF7_Pos)
6934#define BDMA_ISR_HTIF7 BDMA_ISR_HTIF7_Msk
6935#define BDMA_ISR_TEIF7_Pos (31U)
6936#define BDMA_ISR_TEIF7_Msk (0x1UL << BDMA_ISR_TEIF7_Pos)
6937#define BDMA_ISR_TEIF7 BDMA_ISR_TEIF7_Msk
6939/******************* Bit definition for BDMA_IFCR register *******************/
6940#define BDMA_IFCR_CGIF0_Pos (0U)
6941#define BDMA_IFCR_CGIF0_Msk (0x1UL << BDMA_IFCR_CGIF0_Pos)
6942#define BDMA_IFCR_CGIF0 BDMA_IFCR_CGIF0_Msk
6943#define BDMA_IFCR_CTCIF0_Pos (1U)
6944#define BDMA_IFCR_CTCIF0_Msk (0x1UL << BDMA_IFCR_CTCIF0_Pos)
6945#define BDMA_IFCR_CTCIF0 BDMA_IFCR_CTCIF0_Msk
6946#define BDMA_IFCR_CHTIF0_Pos (2U)
6947#define BDMA_IFCR_CHTIF0_Msk (0x1UL << BDMA_IFCR_CHTIF0_Pos)
6948#define BDMA_IFCR_CHTIF0 BDMA_IFCR_CHTIF0_Msk
6949#define BDMA_IFCR_CTEIF0_Pos (3U)
6950#define BDMA_IFCR_CTEIF0_Msk (0x1UL << BDMA_IFCR_CTEIF0_Pos)
6951#define BDMA_IFCR_CTEIF0 BDMA_IFCR_CTEIF0_Msk
6952#define BDMA_IFCR_CGIF1_Pos (4U)
6953#define BDMA_IFCR_CGIF1_Msk (0x1UL << BDMA_IFCR_CGIF1_Pos)
6954#define BDMA_IFCR_CGIF1 BDMA_IFCR_CGIF1_Msk
6955#define BDMA_IFCR_CTCIF1_Pos (5U)
6956#define BDMA_IFCR_CTCIF1_Msk (0x1UL << BDMA_IFCR_CTCIF1_Pos)
6957#define BDMA_IFCR_CTCIF1 BDMA_IFCR_CTCIF1_Msk
6958#define BDMA_IFCR_CHTIF1_Pos (6U)
6959#define BDMA_IFCR_CHTIF1_Msk (0x1UL << BDMA_IFCR_CHTIF1_Pos)
6960#define BDMA_IFCR_CHTIF1 BDMA_IFCR_CHTIF1_Msk
6961#define BDMA_IFCR_CTEIF1_Pos (7U)
6962#define BDMA_IFCR_CTEIF1_Msk (0x1UL << BDMA_IFCR_CTEIF1_Pos)
6963#define BDMA_IFCR_CTEIF1 BDMA_IFCR_CTEIF1_Msk
6964#define BDMA_IFCR_CGIF2_Pos (8U)
6965#define BDMA_IFCR_CGIF2_Msk (0x1UL << BDMA_IFCR_CGIF2_Pos)
6966#define BDMA_IFCR_CGIF2 BDMA_IFCR_CGIF2_Msk
6967#define BDMA_IFCR_CTCIF2_Pos (9U)
6968#define BDMA_IFCR_CTCIF2_Msk (0x1UL << BDMA_IFCR_CTCIF2_Pos)
6969#define BDMA_IFCR_CTCIF2 BDMA_IFCR_CTCIF2_Msk
6970#define BDMA_IFCR_CHTIF2_Pos (10U)
6971#define BDMA_IFCR_CHTIF2_Msk (0x1UL << BDMA_IFCR_CHTIF2_Pos)
6972#define BDMA_IFCR_CHTIF2 BDMA_IFCR_CHTIF2_Msk
6973#define BDMA_IFCR_CTEIF2_Pos (11U)
6974#define BDMA_IFCR_CTEIF2_Msk (0x1UL << BDMA_IFCR_CTEIF2_Pos)
6975#define BDMA_IFCR_CTEIF2 BDMA_IFCR_CTEIF2_Msk
6976#define BDMA_IFCR_CGIF3_Pos (12U)
6977#define BDMA_IFCR_CGIF3_Msk (0x1UL << BDMA_IFCR_CGIF3_Pos)
6978#define BDMA_IFCR_CGIF3 BDMA_IFCR_CGIF3_Msk
6979#define BDMA_IFCR_CTCIF3_Pos (13U)
6980#define BDMA_IFCR_CTCIF3_Msk (0x1UL << BDMA_IFCR_CTCIF3_Pos)
6981#define BDMA_IFCR_CTCIF3 BDMA_IFCR_CTCIF3_Msk
6982#define BDMA_IFCR_CHTIF3_Pos (14U)
6983#define BDMA_IFCR_CHTIF3_Msk (0x1UL << BDMA_IFCR_CHTIF3_Pos)
6984#define BDMA_IFCR_CHTIF3 BDMA_IFCR_CHTIF3_Msk
6985#define BDMA_IFCR_CTEIF3_Pos (15U)
6986#define BDMA_IFCR_CTEIF3_Msk (0x1UL << BDMA_IFCR_CTEIF3_Pos)
6987#define BDMA_IFCR_CTEIF3 BDMA_IFCR_CTEIF3_Msk
6988#define BDMA_IFCR_CGIF4_Pos (16U)
6989#define BDMA_IFCR_CGIF4_Msk (0x1UL << BDMA_IFCR_CGIF4_Pos)
6990#define BDMA_IFCR_CGIF4 BDMA_IFCR_CGIF4_Msk
6991#define BDMA_IFCR_CTCIF4_Pos (17U)
6992#define BDMA_IFCR_CTCIF4_Msk (0x1UL << BDMA_IFCR_CTCIF4_Pos)
6993#define BDMA_IFCR_CTCIF4 BDMA_IFCR_CTCIF4_Msk
6994#define BDMA_IFCR_CHTIF4_Pos (18U)
6995#define BDMA_IFCR_CHTIF4_Msk (0x1UL << BDMA_IFCR_CHTIF4_Pos)
6996#define BDMA_IFCR_CHTIF4 BDMA_IFCR_CHTIF4_Msk
6997#define BDMA_IFCR_CTEIF4_Pos (19U)
6998#define BDMA_IFCR_CTEIF4_Msk (0x1UL << BDMA_IFCR_CTEIF4_Pos)
6999#define BDMA_IFCR_CTEIF4 BDMA_IFCR_CTEIF4_Msk
7000#define BDMA_IFCR_CGIF5_Pos (20U)
7001#define BDMA_IFCR_CGIF5_Msk (0x1UL << BDMA_IFCR_CGIF5_Pos)
7002#define BDMA_IFCR_CGIF5 BDMA_IFCR_CGIF5_Msk
7003#define BDMA_IFCR_CTCIF5_Pos (21U)
7004#define BDMA_IFCR_CTCIF5_Msk (0x1UL << BDMA_IFCR_CTCIF5_Pos)
7005#define BDMA_IFCR_CTCIF5 BDMA_IFCR_CTCIF5_Msk
7006#define BDMA_IFCR_CHTIF5_Pos (22U)
7007#define BDMA_IFCR_CHTIF5_Msk (0x1UL << BDMA_IFCR_CHTIF5_Pos)
7008#define BDMA_IFCR_CHTIF5 BDMA_IFCR_CHTIF5_Msk
7009#define BDMA_IFCR_CTEIF5_Pos (23U)
7010#define BDMA_IFCR_CTEIF5_Msk (0x1UL << BDMA_IFCR_CTEIF5_Pos)
7011#define BDMA_IFCR_CTEIF5 BDMA_IFCR_CTEIF5_Msk
7012#define BDMA_IFCR_CGIF6_Pos (24U)
7013#define BDMA_IFCR_CGIF6_Msk (0x1UL << BDMA_IFCR_CGIF6_Pos)
7014#define BDMA_IFCR_CGIF6 BDMA_IFCR_CGIF6_Msk
7015#define BDMA_IFCR_CTCIF6_Pos (25U)
7016#define BDMA_IFCR_CTCIF6_Msk (0x1UL << BDMA_IFCR_CTCIF6_Pos)
7017#define BDMA_IFCR_CTCIF6 BDMA_IFCR_CTCIF6_Msk
7018#define BDMA_IFCR_CHTIF6_Pos (26U)
7019#define BDMA_IFCR_CHTIF6_Msk (0x1UL << BDMA_IFCR_CHTIF6_Pos)
7020#define BDMA_IFCR_CHTIF6 BDMA_IFCR_CHTIF6_Msk
7021#define BDMA_IFCR_CTEIF6_Pos (27U)
7022#define BDMA_IFCR_CTEIF6_Msk (0x1UL << BDMA_IFCR_CTEIF6_Pos)
7023#define BDMA_IFCR_CTEIF6 BDMA_IFCR_CTEIF6_Msk
7024#define BDMA_IFCR_CGIF7_Pos (28U)
7025#define BDMA_IFCR_CGIF7_Msk (0x1UL << BDMA_IFCR_CGIF7_Pos)
7026#define BDMA_IFCR_CGIF7 BDMA_IFCR_CGIF7_Msk
7027#define BDMA_IFCR_CTCIF7_Pos (29U)
7028#define BDMA_IFCR_CTCIF7_Msk (0x1UL << BDMA_IFCR_CTCIF7_Pos)
7029#define BDMA_IFCR_CTCIF7 BDMA_IFCR_CTCIF7_Msk
7030#define BDMA_IFCR_CHTIF7_Pos (30U)
7031#define BDMA_IFCR_CHTIF7_Msk (0x1UL << BDMA_IFCR_CHTIF7_Pos)
7032#define BDMA_IFCR_CHTIF7 BDMA_IFCR_CHTIF7_Msk
7033#define BDMA_IFCR_CTEIF7_Pos (31U)
7034#define BDMA_IFCR_CTEIF7_Msk (0x1UL << BDMA_IFCR_CTEIF7_Pos)
7035#define BDMA_IFCR_CTEIF7 BDMA_IFCR_CTEIF7_Msk
7037/******************* Bit definition for BDMA_CCR register ********************/
7038#define BDMA_CCR_EN_Pos (0U)
7039#define BDMA_CCR_EN_Msk (0x1UL << BDMA_CCR_EN_Pos)
7040#define BDMA_CCR_EN BDMA_CCR_EN_Msk
7041#define BDMA_CCR_TCIE_Pos (1U)
7042#define BDMA_CCR_TCIE_Msk (0x1UL << BDMA_CCR_TCIE_Pos)
7043#define BDMA_CCR_TCIE BDMA_CCR_TCIE_Msk
7044#define BDMA_CCR_HTIE_Pos (2U)
7045#define BDMA_CCR_HTIE_Msk (0x1UL << BDMA_CCR_HTIE_Pos)
7046#define BDMA_CCR_HTIE BDMA_CCR_HTIE_Msk
7047#define BDMA_CCR_TEIE_Pos (3U)
7048#define BDMA_CCR_TEIE_Msk (0x1UL << BDMA_CCR_TEIE_Pos)
7049#define BDMA_CCR_TEIE BDMA_CCR_TEIE_Msk
7050#define BDMA_CCR_DIR_Pos (4U)
7051#define BDMA_CCR_DIR_Msk (0x1UL << BDMA_CCR_DIR_Pos)
7052#define BDMA_CCR_DIR BDMA_CCR_DIR_Msk
7053#define BDMA_CCR_CIRC_Pos (5U)
7054#define BDMA_CCR_CIRC_Msk (0x1UL << BDMA_CCR_CIRC_Pos)
7055#define BDMA_CCR_CIRC BDMA_CCR_CIRC_Msk
7056#define BDMA_CCR_PINC_Pos (6U)
7057#define BDMA_CCR_PINC_Msk (0x1UL << BDMA_CCR_PINC_Pos)
7058#define BDMA_CCR_PINC BDMA_CCR_PINC_Msk
7059#define BDMA_CCR_MINC_Pos (7U)
7060#define BDMA_CCR_MINC_Msk (0x1UL << BDMA_CCR_MINC_Pos)
7061#define BDMA_CCR_MINC BDMA_CCR_MINC_Msk
7063#define BDMA_CCR_PSIZE_Pos (8U)
7064#define BDMA_CCR_PSIZE_Msk (0x3UL << BDMA_CCR_PSIZE_Pos)
7065#define BDMA_CCR_PSIZE BDMA_CCR_PSIZE_Msk
7066#define BDMA_CCR_PSIZE_0 (0x1UL << BDMA_CCR_PSIZE_Pos)
7067#define BDMA_CCR_PSIZE_1 (0x2UL << BDMA_CCR_PSIZE_Pos)
7069#define BDMA_CCR_MSIZE_Pos (10U)
7070#define BDMA_CCR_MSIZE_Msk (0x3UL << BDMA_CCR_MSIZE_Pos)
7071#define BDMA_CCR_MSIZE BDMA_CCR_MSIZE_Msk
7072#define BDMA_CCR_MSIZE_0 (0x1UL << BDMA_CCR_MSIZE_Pos)
7073#define BDMA_CCR_MSIZE_1 (0x2UL << BDMA_CCR_MSIZE_Pos)
7075#define BDMA_CCR_PL_Pos (12U)
7076#define BDMA_CCR_PL_Msk (0x3UL << BDMA_CCR_PL_Pos)
7077#define BDMA_CCR_PL BDMA_CCR_PL_Msk
7078#define BDMA_CCR_PL_0 (0x1UL << BDMA_CCR_PL_Pos)
7079#define BDMA_CCR_PL_1 (0x2UL << BDMA_CCR_PL_Pos)
7081#define BDMA_CCR_MEM2MEM_Pos (14U)
7082#define BDMA_CCR_MEM2MEM_Msk (0x1UL << BDMA_CCR_MEM2MEM_Pos)
7083#define BDMA_CCR_MEM2MEM BDMA_CCR_MEM2MEM_Msk
7084#define BDMA_CCR_DBM_Pos (15U)
7085#define BDMA_CCR_DBM_Msk (0x1UL << BDMA_CCR_DBM_Pos)
7086#define BDMA_CCR_DBM BDMA_CCR_DBM_Msk
7087#define BDMA_CCR_CT_Pos (16U)
7088#define BDMA_CCR_CT_Msk (0x1UL << BDMA_CCR_CT_Pos)
7089#define BDMA_CCR_CT BDMA_CCR_CT_Msk
7091/****************** Bit definition for BDMA_CNDTR register *******************/
7092#define BDMA_CNDTR_NDT_Pos (0U)
7093#define BDMA_CNDTR_NDT_Msk (0xFFFFUL << BDMA_CNDTR_NDT_Pos)
7094#define BDMA_CNDTR_NDT BDMA_CNDTR_NDT_Msk
7096/****************** Bit definition for BDMA_CPAR register ********************/
7097#define BDMA_CPAR_PA_Pos (0U)
7098#define BDMA_CPAR_PA_Msk (0xFFFFFFFFUL << BDMA_CPAR_PA_Pos)
7099#define BDMA_CPAR_PA BDMA_CPAR_PA_Msk
7101/****************** Bit definition for BDMA_CM0AR register ********************/
7102#define BDMA_CM0AR_MA_Pos (0U)
7103#define BDMA_CM0AR_MA_Msk (0xFFFFFFFFUL << BDMA_CM0AR_MA_Pos)
7104#define BDMA_CM0AR_MA BDMA_CM0AR_MA_Msk
7106/****************** Bit definition for BDMA_CM1AR register ********************/
7107#define BDMA_CM1AR_MA_Pos (0U)
7108#define BDMA_CM1AR_MA_Msk (0xFFFFFFFFUL << BDMA_CM1AR_MA_Pos)
7109#define BDMA_CM1AR_MA BDMA_CM1AR_MA_Msk
7111/******************************************************************************/
7112/* */
7113/* Ethernet MAC Registers bits definitions */
7114/* */
7115/******************************************************************************/
7116/* Bit definition for Ethernet MAC Configuration Register register */
7117#define ETH_MACCR_ARP_Pos (31U)
7118#define ETH_MACCR_ARP_Msk (0x1UL << ETH_MACCR_ARP_Pos)
7119#define ETH_MACCR_ARP ETH_MACCR_ARP_Msk /* ARP Offload Enable */
7120#define ETH_MACCR_SARC_Pos (28U)
7121#define ETH_MACCR_SARC_Msk (0x7UL << ETH_MACCR_SARC_Pos)
7122#define ETH_MACCR_SARC ETH_MACCR_SARC_Msk /* Source Address Insertion or Replacement Control */
7123#define ETH_MACCR_SARC_MTIATI (0U) /* The mti_sa_ctrl_i and ati_sa_ctrl_i input signals control the SA field generation. */
7124#define ETH_MACCR_SARC_INSADDR0_Pos (29U)
7125#define ETH_MACCR_SARC_INSADDR0_Msk (0x1UL << ETH_MACCR_SARC_INSADDR0_Pos)
7126#define ETH_MACCR_SARC_INSADDR0 ETH_MACCR_SARC_INSADDR0_Msk /* Insert MAC Address0 in the SA field of all transmitted packets. */
7127#define ETH_MACCR_SARC_INSADDR1_Pos (29U)
7128#define ETH_MACCR_SARC_INSADDR1_Msk (0x3UL << ETH_MACCR_SARC_INSADDR1_Pos)
7129#define ETH_MACCR_SARC_INSADDR1 ETH_MACCR_SARC_INSADDR1_Msk /* Insert MAC Address1 in the SA field of all transmitted packets. */
7130#define ETH_MACCR_SARC_REPADDR0_Pos (28U)
7131#define ETH_MACCR_SARC_REPADDR0_Msk (0x3UL << ETH_MACCR_SARC_REPADDR0_Pos)
7132#define ETH_MACCR_SARC_REPADDR0 ETH_MACCR_SARC_REPADDR0_Msk /* Replace MAC Address0 in the SA field of all transmitted packets. */
7133#define ETH_MACCR_SARC_REPADDR1_Pos (28U)
7134#define ETH_MACCR_SARC_REPADDR1_Msk (0x7UL << ETH_MACCR_SARC_REPADDR1_Pos)
7135#define ETH_MACCR_SARC_REPADDR1 ETH_MACCR_SARC_REPADDR1_Msk /* Replace MAC Address1 in the SA field of all transmitted packets. */
7136#define ETH_MACCR_IPC_Pos (27U)
7137#define ETH_MACCR_IPC_Msk (0x1UL << ETH_MACCR_IPC_Pos)
7138#define ETH_MACCR_IPC ETH_MACCR_IPC_Msk /* Checksum Offload */
7139#define ETH_MACCR_IPG_Pos (24U)
7140#define ETH_MACCR_IPG_Msk (0x7UL << ETH_MACCR_IPG_Pos)
7141#define ETH_MACCR_IPG ETH_MACCR_IPG_Msk /* Inter-Packet Gap */
7142#define ETH_MACCR_IPG_96BIT (0U) /* Minimum IFG between Packets during transmission is 96Bit */
7143#define ETH_MACCR_IPG_88BIT (0x01000000U) /* Minimum IFG between Packets during transmission is 88Bit */
7144#define ETH_MACCR_IPG_80BIT (0x02000000U) /* Minimum IFG between Packets during transmission is 80Bit */
7145#define ETH_MACCR_IPG_72BIT (0x03000000U) /* Minimum IFG between Packets during transmission is 72Bit */
7146#define ETH_MACCR_IPG_64BIT (0x04000000U) /* Minimum IFG between Packets during transmission is 64Bit */
7147#define ETH_MACCR_IPG_56BIT (0x05000000U) /* Minimum IFG between Packets during transmission is 56Bit */
7148#define ETH_MACCR_IPG_48BIT (0x06000000U) /* Minimum IFG between Packets during transmission is 48Bit */
7149#define ETH_MACCR_IPG_40BIT (0x07000000U) /* Minimum IFG between Packets during transmission is 40Bit */
7150#define ETH_MACCR_GPSLCE_Pos (23U)
7151#define ETH_MACCR_GPSLCE_Msk (0x1UL << ETH_MACCR_GPSLCE_Pos)
7152#define ETH_MACCR_GPSLCE ETH_MACCR_GPSLCE_Msk /* Giant Packet Size Limit Control Enable */
7153#define ETH_MACCR_S2KP_Pos (22U)
7154#define ETH_MACCR_S2KP_Msk (0x1UL << ETH_MACCR_S2KP_Pos)
7155#define ETH_MACCR_S2KP ETH_MACCR_S2KP_Msk /* IEEE 802.3as Support for 2K Packets */
7156#define ETH_MACCR_CST_Pos (21U)
7157#define ETH_MACCR_CST_Msk (0x1UL << ETH_MACCR_CST_Pos)
7158#define ETH_MACCR_CST ETH_MACCR_CST_Msk /* CRC stripping for Type packets */
7159#define ETH_MACCR_ACS_Pos (20U)
7160#define ETH_MACCR_ACS_Msk (0x1UL << ETH_MACCR_ACS_Pos)
7161#define ETH_MACCR_ACS ETH_MACCR_ACS_Msk /* Automatic Pad or CRC Stripping */
7162#define ETH_MACCR_WD_Pos (19U)
7163#define ETH_MACCR_WD_Msk (0x1UL << ETH_MACCR_WD_Pos)
7164#define ETH_MACCR_WD ETH_MACCR_WD_Msk /* Watchdog disable */
7165#define ETH_MACCR_JD_Pos (17U)
7166#define ETH_MACCR_JD_Msk (0x1UL << ETH_MACCR_JD_Pos)
7167#define ETH_MACCR_JD ETH_MACCR_JD_Msk /* Jabber disable */
7168#define ETH_MACCR_JE_Pos (16U)
7169#define ETH_MACCR_JE_Msk (0x1UL << ETH_MACCR_JE_Pos)
7170#define ETH_MACCR_JE ETH_MACCR_JE_Msk /* Jumbo Packet Enable */
7171#define ETH_MACCR_FES_Pos (14U)
7172#define ETH_MACCR_FES_Msk (0x1UL << ETH_MACCR_FES_Pos)
7173#define ETH_MACCR_FES ETH_MACCR_FES_Msk /* Fast ethernet speed */
7174#define ETH_MACCR_DM_Pos (13U)
7175#define ETH_MACCR_DM_Msk (0x1UL << ETH_MACCR_DM_Pos)
7176#define ETH_MACCR_DM ETH_MACCR_DM_Msk /* Duplex mode */
7177#define ETH_MACCR_LM_Pos (12U)
7178#define ETH_MACCR_LM_Msk (0x1UL << ETH_MACCR_LM_Pos)
7179#define ETH_MACCR_LM ETH_MACCR_LM_Msk /* loopback mode */
7180#define ETH_MACCR_ECRSFD_Pos (11U)
7181#define ETH_MACCR_ECRSFD_Msk (0x1UL << ETH_MACCR_ECRSFD_Pos)
7182#define ETH_MACCR_ECRSFD ETH_MACCR_ECRSFD_Msk /* Enable Carrier Sense Before Transmission in Full-Duplex Mode */
7183#define ETH_MACCR_DO_Pos (10U)
7184#define ETH_MACCR_DO_Msk (0x1UL << ETH_MACCR_DO_Pos)
7185#define ETH_MACCR_DO ETH_MACCR_DO_Msk /* Disable Receive own */
7186#define ETH_MACCR_DCRS_Pos (9U)
7187#define ETH_MACCR_DCRS_Msk (0x1UL << ETH_MACCR_DCRS_Pos)
7188#define ETH_MACCR_DCRS ETH_MACCR_DCRS_Msk /* Disable Carrier Sense During Transmission */
7189#define ETH_MACCR_DR_Pos (8U)
7190#define ETH_MACCR_DR_Msk (0x1UL << ETH_MACCR_DR_Pos)
7191#define ETH_MACCR_DR ETH_MACCR_DR_Msk /* Disable Retry */
7192#define ETH_MACCR_BL_Pos (5U)
7193#define ETH_MACCR_BL_Msk (0x3UL << ETH_MACCR_BL_Pos)
7194#define ETH_MACCR_BL ETH_MACCR_BL_Msk /* Back-off limit mask */
7195#define ETH_MACCR_BL_10 (0x0UL << ETH_MACCR_BL_Pos)
7196#define ETH_MACCR_BL_8 (0x1UL << ETH_MACCR_BL_Pos)
7197#define ETH_MACCR_BL_4 (0x2UL << ETH_MACCR_BL_Pos)
7198#define ETH_MACCR_BL_1 (0x3UL << ETH_MACCR_BL_Pos)
7199#define ETH_MACCR_DC_Pos (4U)
7200#define ETH_MACCR_DC_Msk (0x1UL << ETH_MACCR_DC_Pos)
7201#define ETH_MACCR_DC ETH_MACCR_DC_Msk /* Defferal check */
7202#define ETH_MACCR_PRELEN_Pos (2U)
7203#define ETH_MACCR_PRELEN_Msk (0x3UL << ETH_MACCR_PRELEN_Pos)
7204#define ETH_MACCR_PRELEN ETH_MACCR_PRELEN_Msk /* Preamble Length for Transmit packets */
7205#define ETH_MACCR_PRELEN_7 (0x0UL << ETH_MACCR_PRELEN_Pos)
7206#define ETH_MACCR_PRELEN_5 (0x1UL << ETH_MACCR_PRELEN_Pos)
7207#define ETH_MACCR_PRELEN_3 (0x2UL << ETH_MACCR_PRELEN_Pos)
7208#define ETH_MACCR_TE_Pos (1U)
7209#define ETH_MACCR_TE_Msk (0x1UL << ETH_MACCR_TE_Pos)
7210#define ETH_MACCR_TE ETH_MACCR_TE_Msk /* Transmitter enable */
7211#define ETH_MACCR_RE_Pos (0U)
7212#define ETH_MACCR_RE_Msk (0x1UL << ETH_MACCR_RE_Pos)
7213#define ETH_MACCR_RE ETH_MACCR_RE_Msk /* Receiver enable */
7214
7215/* Bit definition for Ethernet MAC Extended Configuration Register register */
7216#define ETH_MACECR_EIPG_Pos (25U)
7217#define ETH_MACECR_EIPG_Msk (0x1FUL << ETH_MACECR_EIPG_Pos)
7218#define ETH_MACECR_EIPG ETH_MACECR_EIPG_Msk /* Extended Inter-Packet Gap */
7219#define ETH_MACECR_EIPGEN_Pos (24U)
7220#define ETH_MACECR_EIPGEN_Msk (0x1UL << ETH_MACECR_EIPGEN_Pos)
7221#define ETH_MACECR_EIPGEN ETH_MACECR_EIPGEN_Msk /* Extended Inter-Packet Gap Enable */
7222#define ETH_MACECR_USP_Pos (18U)
7223#define ETH_MACECR_USP_Msk (0x1UL << ETH_MACECR_USP_Pos)
7224#define ETH_MACECR_USP ETH_MACECR_USP_Msk /* Unicast Slow Protocol Packet Detect */
7225#define ETH_MACECR_SPEN_Pos (17U)
7226#define ETH_MACECR_SPEN_Msk (0x1UL << ETH_MACECR_SPEN_Pos)
7227#define ETH_MACECR_SPEN ETH_MACECR_SPEN_Msk /* Slow Protocol Detection Enable */
7228#define ETH_MACECR_DCRCC_Pos (16U)
7229#define ETH_MACECR_DCRCC_Msk (0x1UL << ETH_MACECR_DCRCC_Pos)
7230#define ETH_MACECR_DCRCC ETH_MACECR_DCRCC_Msk /* Disable CRC Checking for Received Packets */
7231#define ETH_MACECR_GPSL_Pos (0U)
7232#define ETH_MACECR_GPSL_Msk (0x3FFFUL << ETH_MACECR_GPSL_Pos)
7233#define ETH_MACECR_GPSL ETH_MACECR_GPSL_Msk /* Giant Packet Size Limit */
7234
7235/* Bit definition for Ethernet MAC Packet Filter Register */
7236#define ETH_MACPFR_RA_Pos (31U)
7237#define ETH_MACPFR_RA_Msk (0x1UL << ETH_MACPFR_RA_Pos)
7238#define ETH_MACPFR_RA ETH_MACPFR_RA_Msk /* Receive all */
7239#define ETH_MACPFR_DNTU_Pos (21U)
7240#define ETH_MACPFR_DNTU_Msk (0x1UL << ETH_MACPFR_DNTU_Pos)
7241#define ETH_MACPFR_DNTU ETH_MACPFR_DNTU_Msk /* Drop Non-TCP/UDP over IP Packets */
7242#define ETH_MACPFR_IPFE_Pos (20U)
7243#define ETH_MACPFR_IPFE_Msk (0x1UL << ETH_MACPFR_IPFE_Pos)
7244#define ETH_MACPFR_IPFE ETH_MACPFR_IPFE_Msk /* Layer 3 and Layer 4 Filter Enable */
7245#define ETH_MACPFR_VTFE_Pos (16U)
7246#define ETH_MACPFR_VTFE_Msk (0x1UL << ETH_MACPFR_VTFE_Pos)
7247#define ETH_MACPFR_VTFE ETH_MACPFR_VTFE_Msk /* VLAN Tag Filter Enable */
7248#define ETH_MACPFR_HPF_Pos (10U)
7249#define ETH_MACPFR_HPF_Msk (0x1UL << ETH_MACPFR_HPF_Pos)
7250#define ETH_MACPFR_HPF ETH_MACPFR_HPF_Msk /* Hash or perfect filter */
7251#define ETH_MACPFR_SAF_Pos (9U)
7252#define ETH_MACPFR_SAF_Msk (0x1UL << ETH_MACPFR_SAF_Pos)
7253#define ETH_MACPFR_SAF ETH_MACPFR_SAF_Msk /* Source address filter enable */
7254#define ETH_MACPFR_SAIF_Pos (8U)
7255#define ETH_MACPFR_SAIF_Msk (0x1UL << ETH_MACPFR_SAIF_Pos)
7256#define ETH_MACPFR_SAIF ETH_MACPFR_SAIF_Msk /* SA inverse filtering */
7257#define ETH_MACPFR_PCF_Pos (6U)
7258#define ETH_MACPFR_PCF_Msk (0x3UL << ETH_MACPFR_PCF_Pos)
7259#define ETH_MACPFR_PCF ETH_MACPFR_PCF_Msk /* Pass control frames: 4 cases */
7260#define ETH_MACPFR_PCF_BLOCKALL (0U) /* MAC filters all control frames from reaching the application */
7261#define ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Pos (6U)
7262#define ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Msk (0x1UL << ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Pos)
7263#define ETH_MACPFR_PCF_FORWARDALLEXCEPTPA ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Msk /* MAC forwards all control frames except Pause packets to application even if they fail the Address Filter */
7264#define ETH_MACPFR_PCF_FORWARDALL_Pos (7U)
7265#define ETH_MACPFR_PCF_FORWARDALL_Msk (0x1UL << ETH_MACPFR_PCF_FORWARDALL_Pos)
7266#define ETH_MACPFR_PCF_FORWARDALL ETH_MACPFR_PCF_FORWARDALL_Msk /* MAC forwards all control frames to application even if they fail the Address Filter */
7267#define ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Pos (6U)
7268#define ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Msk (0x3UL << ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Pos)
7269#define ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Msk /* MAC forwards control frames that pass the Address Filter. */
7270#define ETH_MACPFR_DBF_Pos (5U)
7271#define ETH_MACPFR_DBF_Msk (0x1UL << ETH_MACPFR_DBF_Pos)
7272#define ETH_MACPFR_DBF ETH_MACPFR_DBF_Msk /* Disable Broadcast Packets */
7273#define ETH_MACPFR_PM_Pos (4U)
7274#define ETH_MACPFR_PM_Msk (0x1UL << ETH_MACPFR_PM_Pos)
7275#define ETH_MACPFR_PM ETH_MACPFR_PM_Msk /* Pass all mutlicast */
7276#define ETH_MACPFR_DAIF_Pos (3U)
7277#define ETH_MACPFR_DAIF_Msk (0x1UL << ETH_MACPFR_DAIF_Pos)
7278#define ETH_MACPFR_DAIF ETH_MACPFR_DAIF_Msk /* DA Inverse filtering */
7279#define ETH_MACPFR_HMC_Pos (2U)
7280#define ETH_MACPFR_HMC_Msk (0x1UL << ETH_MACPFR_HMC_Pos)
7281#define ETH_MACPFR_HMC ETH_MACPFR_HMC_Msk /* Hash multicast */
7282#define ETH_MACPFR_HUC_Pos (1U)
7283#define ETH_MACPFR_HUC_Msk (0x1UL << ETH_MACPFR_HUC_Pos)
7284#define ETH_MACPFR_HUC ETH_MACPFR_HUC_Msk /* Hash unicast */
7285#define ETH_MACPFR_PR_Pos (0U)
7286#define ETH_MACPFR_PR_Msk (0x1UL << ETH_MACPFR_PR_Pos)
7287#define ETH_MACPFR_PR ETH_MACPFR_PR_Msk /* Promiscuous mode */
7288
7289/* Bit definition for Ethernet MAC Watchdog Timeout Register */
7290#define ETH_MACWTR_PWE_Pos (8U)
7291#define ETH_MACWTR_PWE_Msk (0x1UL << ETH_MACWTR_PWE_Pos)
7292#define ETH_MACWTR_PWE ETH_MACWTR_PWE_Msk /* Programmable Watchdog Enable */
7293#define ETH_MACWTR_WTO_Pos (0U)
7294#define ETH_MACWTR_WTO_Msk (0xFUL << ETH_MACWTR_WTO_Pos)
7295#define ETH_MACWTR_WTO ETH_MACWTR_WTO_Msk /* Watchdog Timeout */
7296#define ETH_MACWTR_WTO_2KB (0U) /* Maximum received packet length 2KB*/
7297#define ETH_MACWTR_WTO_3KB (0x00000001U) /* Maximum received packet length 3KB */
7298#define ETH_MACWTR_WTO_4KB (0x00000002U) /* Maximum received packet length 4KB */
7299#define ETH_MACWTR_WTO_5KB (0x00000003U) /* Maximum received packet length 5KB */
7300#define ETH_MACWTR_WTO_6KB (0x00000004U) /* Maximum received packet length 6KB */
7301#define ETH_MACWTR_WTO_7KB (0x00000005U) /* Maximum received packet length 7KB */
7302#define ETH_MACWTR_WTO_8KB (0x00000006U) /* Maximum received packet length 8KB */
7303#define ETH_MACWTR_WTO_9KB (0x00000007U) /* Maximum received packet length 9KB */
7304#define ETH_MACWTR_WTO_10KB (0x00000008U) /* Maximum received packet length 10KB */
7305#define ETH_MACWTR_WTO_11KB (0x00000009U) /* Maximum received packet length 11KB */
7306#define ETH_MACWTR_WTO_12KB (0x0000000AU) /* Maximum received packet length 12KB */
7307#define ETH_MACWTR_WTO_13KB (0x0000000BU) /* Maximum received packet length 13KB */
7308#define ETH_MACWTR_WTO_14KB (0x0000000CU) /* Maximum received packet length 14KB */
7309#define ETH_MACWTR_WTO_15KB (0x0000000DU) /* Maximum received packet length 15KB */
7310#define ETH_MACWTR_WTO_16KB (0x0000000EU) /* Maximum received packet length 16KB */
7311
7312/* Bit definition for Ethernet MAC Hash Table High Register */
7313#define ETH_MACHTHR_HTH_Pos (0U)
7314#define ETH_MACHTHR_HTH_Msk (0xFFFFFFFFUL << ETH_MACHTHR_HTH_Pos)
7315#define ETH_MACHTHR_HTH ETH_MACHTHR_HTH_Msk /* Hash table high */
7316
7317/* Bit definition for Ethernet MAC Hash Table Low Register */
7318#define ETH_MACHTLR_HTL_Pos (0U)
7319#define ETH_MACHTLR_HTL_Msk (0xFFFFFFFFUL << ETH_MACHTLR_HTL_Pos)
7320#define ETH_MACHTLR_HTL ETH_MACHTLR_HTL_Msk /* Hash table low */
7321
7322/* Bit definition for Ethernet MAC VLAN Tag Register */
7323#define ETH_MACVTR_EIVLRXS_Pos (31U)
7324#define ETH_MACVTR_EIVLRXS_Msk (0x1UL << ETH_MACVTR_EIVLRXS_Pos)
7325#define ETH_MACVTR_EIVLRXS ETH_MACVTR_EIVLRXS_Msk /* Enable Inner VLAN Tag in Rx Status */
7326#define ETH_MACVTR_EIVLS_Pos (28U)
7327#define ETH_MACVTR_EIVLS_Msk (0x3UL << ETH_MACVTR_EIVLS_Pos)
7328#define ETH_MACVTR_EIVLS ETH_MACVTR_EIVLS_Msk /* Enable Inner VLAN Tag Stripping on Receive */
7329#define ETH_MACVTR_EIVLS_DONOTSTRIP (0U) /* Do not strip */
7330#define ETH_MACVTR_EIVLS_STRIPIFPASS_Pos (28U)
7331#define ETH_MACVTR_EIVLS_STRIPIFPASS_Msk (0x1UL << ETH_MACVTR_EIVLS_STRIPIFPASS_Pos)
7332#define ETH_MACVTR_EIVLS_STRIPIFPASS ETH_MACVTR_EIVLS_STRIPIFPASS_Msk /* Strip if VLAN filter passes */
7333#define ETH_MACVTR_EIVLS_STRIPIFFAILS_Pos (29U)
7334#define ETH_MACVTR_EIVLS_STRIPIFFAILS_Msk (0x1UL << ETH_MACVTR_EIVLS_STRIPIFFAILS_Pos)
7335#define ETH_MACVTR_EIVLS_STRIPIFFAILS ETH_MACVTR_EIVLS_STRIPIFFAILS_Msk /* Strip if VLAN filter fails */
7336#define ETH_MACVTR_EIVLS_ALWAYSSTRIP_Pos (28U)
7337#define ETH_MACVTR_EIVLS_ALWAYSSTRIP_Msk (0x3UL << ETH_MACVTR_EIVLS_ALWAYSSTRIP_Pos)
7338#define ETH_MACVTR_EIVLS_ALWAYSSTRIP ETH_MACVTR_EIVLS_ALWAYSSTRIP_Msk /* Always strip */
7339#define ETH_MACVTR_ERIVLT_Pos (27U)
7340#define ETH_MACVTR_ERIVLT_Msk (0x1UL << ETH_MACVTR_ERIVLT_Pos)
7341#define ETH_MACVTR_ERIVLT ETH_MACVTR_ERIVLT_Msk /* Enable Inner VLAN Tag */
7342#define ETH_MACVTR_EDVLP_Pos (26U)
7343#define ETH_MACVTR_EDVLP_Msk (0x1UL << ETH_MACVTR_EDVLP_Pos)
7344#define ETH_MACVTR_EDVLP ETH_MACVTR_EDVLP_Msk /* Enable Double VLAN Processing */
7345#define ETH_MACVTR_VTHM_Pos (25U)
7346#define ETH_MACVTR_VTHM_Msk (0x1UL << ETH_MACVTR_VTHM_Pos)
7347#define ETH_MACVTR_VTHM ETH_MACVTR_VTHM_Msk /* VLAN Tag Hash Table Match Enable */
7348#define ETH_MACVTR_EVLRXS_Pos (24U)
7349#define ETH_MACVTR_EVLRXS_Msk (0x1UL << ETH_MACVTR_EVLRXS_Pos)
7350#define ETH_MACVTR_EVLRXS ETH_MACVTR_EVLRXS_Msk /* Enable VLAN Tag in Rx status */
7351#define ETH_MACVTR_EVLS_Pos (21U)
7352#define ETH_MACVTR_EVLS_Msk (0x3UL << ETH_MACVTR_EVLS_Pos)
7353#define ETH_MACVTR_EVLS ETH_MACVTR_EVLS_Msk /* Enable VLAN Tag Stripping on Receive */
7354#define ETH_MACVTR_EVLS_DONOTSTRIP (0U) /* Do not strip */
7355#define ETH_MACVTR_EVLS_STRIPIFPASS_Pos (21U)
7356#define ETH_MACVTR_EVLS_STRIPIFPASS_Msk (0x1UL << ETH_MACVTR_EVLS_STRIPIFPASS_Pos)
7357#define ETH_MACVTR_EVLS_STRIPIFPASS ETH_MACVTR_EVLS_STRIPIFPASS_Msk /* Strip if VLAN filter passes */
7358#define ETH_MACVTR_EVLS_STRIPIFFAILS_Pos (22U)
7359#define ETH_MACVTR_EVLS_STRIPIFFAILS_Msk (0x1UL << ETH_MACVTR_EVLS_STRIPIFFAILS_Pos)
7360#define ETH_MACVTR_EVLS_STRIPIFFAILS ETH_MACVTR_EVLS_STRIPIFFAILS_Msk /* Strip if VLAN filter fails */
7361#define ETH_MACVTR_EVLS_ALWAYSSTRIP_Pos (21U)
7362#define ETH_MACVTR_EVLS_ALWAYSSTRIP_Msk (0x3UL << ETH_MACVTR_EVLS_ALWAYSSTRIP_Pos)
7363#define ETH_MACVTR_EVLS_ALWAYSSTRIP ETH_MACVTR_EVLS_ALWAYSSTRIP_Msk /* Always strip */
7364#define ETH_MACVTR_DOVLTC_Pos (20U)
7365#define ETH_MACVTR_DOVLTC_Msk (0x1UL << ETH_MACVTR_DOVLTC_Pos)
7366#define ETH_MACVTR_DOVLTC ETH_MACVTR_DOVLTC_Msk /* Disable VLAN Type Check */
7367#define ETH_MACVTR_ERSVLM_Pos (19U)
7368#define ETH_MACVTR_ERSVLM_Msk (0x1UL << ETH_MACVTR_ERSVLM_Pos)
7369#define ETH_MACVTR_ERSVLM ETH_MACVTR_ERSVLM_Msk /* Enable Receive S-VLAN Match */
7370#define ETH_MACVTR_ESVL_Pos (18U)
7371#define ETH_MACVTR_ESVL_Msk (0x1UL << ETH_MACVTR_ESVL_Pos)
7372#define ETH_MACVTR_ESVL ETH_MACVTR_ESVL_Msk /* Enable S-VLAN */
7373#define ETH_MACVTR_VTIM_Pos (17U)
7374#define ETH_MACVTR_VTIM_Msk (0x1UL << ETH_MACVTR_VTIM_Pos)
7375#define ETH_MACVTR_VTIM ETH_MACVTR_VTIM_Msk /* VLAN Tag Inverse Match Enable */
7376#define ETH_MACVTR_ETV_Pos (16U)
7377#define ETH_MACVTR_ETV_Msk (0x1UL << ETH_MACVTR_ETV_Pos)
7378#define ETH_MACVTR_ETV ETH_MACVTR_ETV_Msk /* Enable 12-Bit VLAN Tag Comparison */
7379#define ETH_MACVTR_VL_Pos (0U)
7380#define ETH_MACVTR_VL_Msk (0xFFFFUL << ETH_MACVTR_VL_Pos)
7381#define ETH_MACVTR_VL ETH_MACVTR_VL_Msk /* VLAN Tag Identifier for Receive Packets */
7382#define ETH_MACVTR_VL_UP_Pos (13U)
7383#define ETH_MACVTR_VL_UP_Msk (0x7UL << ETH_MACVTR_VL_UP_Pos)
7384#define ETH_MACVTR_VL_UP ETH_MACVTR_VL_UP_Msk /* User Priority */
7385#define ETH_MACVTR_VL_CFIDEI_Pos (12U)
7386#define ETH_MACVTR_VL_CFIDEI_Msk (0x1UL << ETH_MACVTR_VL_CFIDEI_Pos)
7387#define ETH_MACVTR_VL_CFIDEI ETH_MACVTR_VL_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */
7388#define ETH_MACVTR_VL_VID_Pos (0U)
7389#define ETH_MACVTR_VL_VID_Msk (0xFFFUL << ETH_MACVTR_VL_VID_Pos)
7390#define ETH_MACVTR_VL_VID ETH_MACVTR_VL_VID_Msk /* VLAN Identifier field of VLAN tag */
7391
7392/* Bit definition for Ethernet MAC VLAN Hash Table Register */
7393#define ETH_MACVHTR_VLHT_Pos (0U)
7394#define ETH_MACVHTR_VLHT_Msk (0xFFFFUL << ETH_MACVHTR_VLHT_Pos)
7395#define ETH_MACVHTR_VLHT ETH_MACVHTR_VLHT_Msk /* VLAN Hash Table */
7396
7397/* Bit definition for Ethernet MAC VLAN Incl Register */
7398#define ETH_MACVIR_VLTI_Pos (20U)
7399#define ETH_MACVIR_VLTI_Msk (0x1UL << ETH_MACVIR_VLTI_Pos)
7400#define ETH_MACVIR_VLTI ETH_MACVIR_VLTI_Msk /* VLAN Tag Input */
7401#define ETH_MACVIR_CSVL_Pos (19U)
7402#define ETH_MACVIR_CSVL_Msk (0x1UL << ETH_MACVIR_CSVL_Pos)
7403#define ETH_MACVIR_CSVL ETH_MACVIR_CSVL_Msk /* C-VLAN or S-VLAN */
7404#define ETH_MACVIR_VLP_Pos (18U)
7405#define ETH_MACVIR_VLP_Msk (0x1UL << ETH_MACVIR_VLP_Pos)
7406#define ETH_MACVIR_VLP ETH_MACVIR_VLP_Msk /* VLAN Priority Control */
7407#define ETH_MACVIR_VLC_Pos (16U)
7408#define ETH_MACVIR_VLC_Msk (0x3UL << ETH_MACVIR_VLC_Pos)
7409#define ETH_MACVIR_VLC ETH_MACVIR_VLC_Msk /* VLAN Tag Control in Transmit Packets */
7410#define ETH_MACVIR_VLC_NOVLANTAG (0U) /* No VLAN tag deletion, insertion, or replacement */
7411#define ETH_MACVIR_VLC_VLANTAGDELETE_Pos (16U)
7412#define ETH_MACVIR_VLC_VLANTAGDELETE_Msk (0x1UL << ETH_MACVIR_VLC_VLANTAGDELETE_Pos)
7413#define ETH_MACVIR_VLC_VLANTAGDELETE ETH_MACVIR_VLC_VLANTAGDELETE_Msk /* VLAN tag deletion */
7414#define ETH_MACVIR_VLC_VLANTAGINSERT_Pos (17U)
7415#define ETH_MACVIR_VLC_VLANTAGINSERT_Msk (0x1UL << ETH_MACVIR_VLC_VLANTAGINSERT_Pos)
7416#define ETH_MACVIR_VLC_VLANTAGINSERT ETH_MACVIR_VLC_VLANTAGINSERT_Msk /* VLAN tag insertion */
7417#define ETH_MACVIR_VLC_VLANTAGREPLACE_Pos (16U)
7418#define ETH_MACVIR_VLC_VLANTAGREPLACE_Msk (0x3UL << ETH_MACVIR_VLC_VLANTAGREPLACE_Pos)
7419#define ETH_MACVIR_VLC_VLANTAGREPLACE ETH_MACVIR_VLC_VLANTAGREPLACE_Msk /* VLAN tag replacement */
7420#define ETH_MACVIR_VLT_Pos (0U)
7421#define ETH_MACVIR_VLT_Msk (0xFFFFUL << ETH_MACVIR_VLT_Pos)
7422#define ETH_MACVIR_VLT ETH_MACVIR_VLT_Msk /* VLAN Tag for Transmit Packets */
7423#define ETH_MACVIR_VLT_UP_Pos (13U)
7424#define ETH_MACVIR_VLT_UP_Msk (0x7UL << ETH_MACVIR_VLT_UP_Pos)
7425#define ETH_MACVIR_VLT_UP ETH_MACVIR_VLT_UP_Msk /* User Priority */
7426#define ETH_MACVIR_VLT_CFIDEI_Pos (12U)
7427#define ETH_MACVIR_VLT_CFIDEI_Msk (0x1UL << ETH_MACVIR_VLT_CFIDEI_Pos)
7428#define ETH_MACVIR_VLT_CFIDEI ETH_MACVIR_VLT_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */
7429#define ETH_MACVIR_VLT_VID_Pos (0U)
7430#define ETH_MACVIR_VLT_VID_Msk (0xFFFUL << ETH_MACVIR_VLT_VID_Pos)
7431#define ETH_MACVIR_VLT_VID ETH_MACVIR_VLT_VID_Msk /* VLAN Identifier field of VLAN tag */
7432
7433/* Bit definition for Ethernet MAC Inner_VLAN Incl Register */
7434#define ETH_MACIVIR_VLTI_Pos (20U)
7435#define ETH_MACIVIR_VLTI_Msk (0x1UL << ETH_MACIVIR_VLTI_Pos)
7436#define ETH_MACIVIR_VLTI ETH_MACIVIR_VLTI_Msk /* VLAN Tag Input */
7437#define ETH_MACIVIR_CSVL_Pos (19U)
7438#define ETH_MACIVIR_CSVL_Msk (0x1UL << ETH_MACIVIR_CSVL_Pos)
7439#define ETH_MACIVIR_CSVL ETH_MACIVIR_CSVL_Msk /* C-VLAN or S-VLAN */
7440#define ETH_MACIVIR_VLP_Pos (18U)
7441#define ETH_MACIVIR_VLP_Msk (0x1UL << ETH_MACIVIR_VLP_Pos)
7442#define ETH_MACIVIR_VLP ETH_MACIVIR_VLP_Msk /* VLAN Priority Control */
7443#define ETH_MACIVIR_VLC_Pos (16U)
7444#define ETH_MACIVIR_VLC_Msk (0x3UL << ETH_MACIVIR_VLC_Pos)
7445#define ETH_MACIVIR_VLC ETH_MACIVIR_VLC_Msk /* VLAN Tag Control in Transmit Packets */
7446#define ETH_MACIVIR_VLC_NOVLANTAG (0U) /* No VLAN tag deletion, insertion, or replacement */
7447#define ETH_MACIVIR_VLC_VLANTAGDELETE_Pos (16U)
7448#define ETH_MACIVIR_VLC_VLANTAGDELETE_Msk (0x1UL << ETH_MACIVIR_VLC_VLANTAGDELETE_Pos)
7449#define ETH_MACIVIR_VLC_VLANTAGDELETE ETH_MACIVIR_VLC_VLANTAGDELETE_Msk /* VLAN tag deletion */
7450#define ETH_MACIVIR_VLC_VLANTAGINSERT_Pos (17U)
7451#define ETH_MACIVIR_VLC_VLANTAGINSERT_Msk (0x1UL << ETH_MACIVIR_VLC_VLANTAGINSERT_Pos)
7452#define ETH_MACIVIR_VLC_VLANTAGINSERT ETH_MACIVIR_VLC_VLANTAGINSERT_Msk /* VLAN tag insertion */
7453#define ETH_MACIVIR_VLC_VLANTAGREPLACE_Pos (16U)
7454#define ETH_MACIVIR_VLC_VLANTAGREPLACE_Msk (0x3UL << ETH_MACIVIR_VLC_VLANTAGREPLACE_Pos)
7455#define ETH_MACIVIR_VLC_VLANTAGREPLACE ETH_MACIVIR_VLC_VLANTAGREPLACE_Msk /* VLAN tag replacement */
7456#define ETH_MACIVIR_VLT_Pos (0U)
7457#define ETH_MACIVIR_VLT_Msk (0xFFFFUL << ETH_MACIVIR_VLT_Pos)
7458#define ETH_MACIVIR_VLT ETH_MACIVIR_VLT_Msk /* VLAN Tag for Transmit Packets */
7459#define ETH_MACIVIR_VLT_UP_Pos (13U)
7460#define ETH_MACIVIR_VLT_UP_Msk (0x7UL << ETH_MACIVIR_VLT_UP_Pos)
7461#define ETH_MACIVIR_VLT_UP ETH_MACIVIR_VLT_UP_Msk /* User Priority */
7462#define ETH_MACIVIR_VLT_CFIDEI_Pos (12U)
7463#define ETH_MACIVIR_VLT_CFIDEI_Msk (0x1UL << ETH_MACIVIR_VLT_CFIDEI_Pos)
7464#define ETH_MACIVIR_VLT_CFIDEI ETH_MACIVIR_VLT_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */
7465#define ETH_MACIVIR_VLT_VID_Pos (0U)
7466#define ETH_MACIVIR_VLT_VID_Msk (0xFFFUL << ETH_MACIVIR_VLT_VID_Pos)
7467#define ETH_MACIVIR_VLT_VID ETH_MACIVIR_VLT_VID_Msk /* VLAN Identifier field of VLAN tag */
7468
7469/* Bit definition for Ethernet MAC Tx Flow Ctrl Register */
7470#define ETH_MACTFCR_PT_Pos (16U)
7471#define ETH_MACTFCR_PT_Msk (0xFFFFUL << ETH_MACTFCR_PT_Pos)
7472#define ETH_MACTFCR_PT ETH_MACTFCR_PT_Msk /* Pause Time */
7473#define ETH_MACTFCR_DZPQ_Pos (7U)
7474#define ETH_MACTFCR_DZPQ_Msk (0x1UL << ETH_MACTFCR_DZPQ_Pos)
7475#define ETH_MACTFCR_DZPQ ETH_MACTFCR_DZPQ_Msk /* Disable Zero-Quanta Pause */
7476#define ETH_MACTFCR_PLT_Pos (4U)
7477#define ETH_MACTFCR_PLT_Msk (0x7UL << ETH_MACTFCR_PLT_Pos)
7478#define ETH_MACTFCR_PLT ETH_MACTFCR_PLT_Msk /* Pause Low Threshold */
7479#define ETH_MACTFCR_PLT_MINUS4 (0U) /* Pause time minus 4 slot times */
7480#define ETH_MACTFCR_PLT_MINUS28_Pos (4U)
7481#define ETH_MACTFCR_PLT_MINUS28_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS28_Pos)
7482#define ETH_MACTFCR_PLT_MINUS28 ETH_MACTFCR_PLT_MINUS28_Msk /* Pause time minus 28 slot times */
7483#define ETH_MACTFCR_PLT_MINUS36_Pos (5U)
7484#define ETH_MACTFCR_PLT_MINUS36_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS36_Pos)
7485#define ETH_MACTFCR_PLT_MINUS36 ETH_MACTFCR_PLT_MINUS36_Msk /* Pause time minus 36 slot times */
7486#define ETH_MACTFCR_PLT_MINUS144_Pos (4U)
7487#define ETH_MACTFCR_PLT_MINUS144_Msk (0x3UL << ETH_MACTFCR_PLT_MINUS144_Pos)
7488#define ETH_MACTFCR_PLT_MINUS144 ETH_MACTFCR_PLT_MINUS144_Msk /* Pause time minus 144 slot times */
7489#define ETH_MACTFCR_PLT_MINUS256_Pos (6U)
7490#define ETH_MACTFCR_PLT_MINUS256_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS256_Pos)
7491#define ETH_MACTFCR_PLT_MINUS256 ETH_MACTFCR_PLT_MINUS256_Msk /* Pause time minus 256 slot times */
7492#define ETH_MACTFCR_PLT_MINUS512_Pos (4U)
7493#define ETH_MACTFCR_PLT_MINUS512_Msk (0x5UL << ETH_MACTFCR_PLT_MINUS512_Pos)
7494#define ETH_MACTFCR_PLT_MINUS512 ETH_MACTFCR_PLT_MINUS512_Msk /* Pause time minus 512 slot times */
7495#define ETH_MACTFCR_TFE_Pos (1U)
7496#define ETH_MACTFCR_TFE_Msk (0x1UL << ETH_MACTFCR_TFE_Pos)
7497#define ETH_MACTFCR_TFE ETH_MACTFCR_TFE_Msk /* Transmit Flow Control Enable */
7498#define ETH_MACTFCR_FCB_Pos (0U)
7499#define ETH_MACTFCR_FCB_Msk (0x1UL << ETH_MACTFCR_FCB_Pos)
7500#define ETH_MACTFCR_FCB ETH_MACTFCR_FCB_Msk /* Flow Control Busy or Backpressure Activate */
7501
7502/* Bit definition for Ethernet MAC Rx Flow Ctrl Register */
7503#define ETH_MACRFCR_UP_Pos (1U)
7504#define ETH_MACRFCR_UP_Msk (0x1UL << ETH_MACRFCR_UP_Pos)
7505#define ETH_MACRFCR_UP ETH_MACRFCR_UP_Msk /* Unicast Pause Packet Detect */
7506#define ETH_MACRFCR_RFE_Pos (0U)
7507#define ETH_MACRFCR_RFE_Msk (0x1UL << ETH_MACRFCR_RFE_Pos)
7508#define ETH_MACRFCR_RFE ETH_MACRFCR_RFE_Msk /* Receive Flow Control Enable */
7509
7510/* Bit definition for Ethernet MAC Interrupt Status Register */
7511#define ETH_MACISR_RXSTSIS_Pos (14U)
7512#define ETH_MACISR_RXSTSIS_Msk (0x1UL << ETH_MACISR_RXSTSIS_Pos)
7513#define ETH_MACISR_RXSTSIS ETH_MACISR_RXSTSIS_Msk /* Receive Status Interrupt */
7514#define ETH_MACISR_TXSTSIS_Pos (13U)
7515#define ETH_MACISR_TXSTSIS_Msk (0x1UL << ETH_MACISR_TXSTSIS_Pos)
7516#define ETH_MACISR_TXSTSIS ETH_MACISR_TXSTSIS_Msk /* Transmit Status Interrupt */
7517#define ETH_MACISR_TSIS_Pos (12U)
7518#define ETH_MACISR_TSIS_Msk (0x1UL << ETH_MACISR_TSIS_Pos)
7519#define ETH_MACISR_TSIS ETH_MACISR_TSIS_Msk /* Timestamp Interrupt Status */
7520#define ETH_MACISR_MMCTXIS_Pos (10U)
7521#define ETH_MACISR_MMCTXIS_Msk (0x1UL << ETH_MACISR_MMCTXIS_Pos)
7522#define ETH_MACISR_MMCTXIS ETH_MACISR_MMCTXIS_Msk /* MMC Transmit Interrupt Status */
7523#define ETH_MACISR_MMCRXIS_Pos (9U)
7524#define ETH_MACISR_MMCRXIS_Msk (0x1UL << ETH_MACISR_MMCRXIS_Pos)
7525#define ETH_MACISR_MMCRXIS ETH_MACISR_MMCRXIS_Msk /* MMC Receive Interrupt Status */
7526#define ETH_MACISR_MMCIS_Pos (8U)
7527#define ETH_MACISR_MMCIS_Msk (0x1UL << ETH_MACISR_MMCIS_Pos)
7528#define ETH_MACISR_MMCIS ETH_MACISR_MMCIS_Msk /* MMC Interrupt Status */
7529#define ETH_MACISR_LPIIS_Pos (5U)
7530#define ETH_MACISR_LPIIS_Msk (0x1UL << ETH_MACISR_LPIIS_Pos)
7531#define ETH_MACISR_LPIIS ETH_MACISR_LPIIS_Msk /* LPI Interrupt Status */
7532#define ETH_MACISR_PMTIS_Pos (4U)
7533#define ETH_MACISR_PMTIS_Msk (0x1UL << ETH_MACISR_PMTIS_Pos)
7534#define ETH_MACISR_PMTIS ETH_MACISR_PMTIS_Msk /* PMT Interrupt Status */
7535#define ETH_MACISR_PHYIS_Pos (3U)
7536#define ETH_MACISR_PHYIS_Msk (0x1UL << ETH_MACISR_PHYIS_Pos)
7537#define ETH_MACISR_PHYIS ETH_MACISR_PHYIS_Msk /* PHY Interrupt */
7538
7539/* Bit definition for Ethernet MAC Interrupt Enable Register */
7540#define ETH_MACIER_RXSTSIE_Pos (14U)
7541#define ETH_MACIER_RXSTSIE_Msk (0x1UL << ETH_MACIER_RXSTSIE_Pos)
7542#define ETH_MACIER_RXSTSIE ETH_MACIER_RXSTSIE_Msk /* Receive Status Interrupt Enable */
7543#define ETH_MACIER_TXSTSIE_Pos (13U)
7544#define ETH_MACIER_TXSTSIE_Msk (0x1UL << ETH_MACIER_TXSTSIE_Pos)
7545#define ETH_MACIER_TXSTSIE ETH_MACIER_TXSTSIE_Msk /* Transmit Status Interrupt Enable */
7546#define ETH_MACIER_TSIE_Pos (12U)
7547#define ETH_MACIER_TSIE_Msk (0x1UL << ETH_MACIER_TSIE_Pos)
7548#define ETH_MACIER_TSIE ETH_MACIER_TSIE_Msk /* Timestamp Interrupt Enable */
7549#define ETH_MACIER_LPIIE_Pos (5U)
7550#define ETH_MACIER_LPIIE_Msk (0x1UL << ETH_MACIER_LPIIE_Pos)
7551#define ETH_MACIER_LPIIE ETH_MACIER_LPIIE_Msk /* LPI Interrupt Enable */
7552#define ETH_MACIER_PMTIE_Pos (4U)
7553#define ETH_MACIER_PMTIE_Msk (0x1UL << ETH_MACIER_PMTIE_Pos)
7554#define ETH_MACIER_PMTIE ETH_MACIER_PMTIE_Msk /* PMT Interrupt Enable */
7555#define ETH_MACIER_PHYIE_Pos (3U)
7556#define ETH_MACIER_PHYIE_Msk (0x1UL << ETH_MACIER_PHYIE_Pos)
7557#define ETH_MACIER_PHYIE ETH_MACIER_PHYIE_Msk /* PHY Interrupt Enable */
7558
7559/* Bit definition for Ethernet MAC Rx Tx Status Register */
7560#define ETH_MACRXTXSR_RWT_Pos (8U)
7561#define ETH_MACRXTXSR_RWT_Msk (0x1UL << ETH_MACRXTXSR_RWT_Pos)
7562#define ETH_MACRXTXSR_RWT ETH_MACRXTXSR_RWT_Msk /* Receive Watchdog Timeout */
7563#define ETH_MACRXTXSR_EXCOL_Pos (5U)
7564#define ETH_MACRXTXSR_EXCOL_Msk (0x1UL << ETH_MACRXTXSR_EXCOL_Pos)
7565#define ETH_MACRXTXSR_EXCOL ETH_MACRXTXSR_EXCOL_Msk /* Excessive Collisions */
7566#define ETH_MACRXTXSR_LCOL_Pos (4U)
7567#define ETH_MACRXTXSR_LCOL_Msk (0x1UL << ETH_MACRXTXSR_LCOL_Pos)
7568#define ETH_MACRXTXSR_LCOL ETH_MACRXTXSR_LCOL_Msk /* Late Collision */
7569#define ETH_MACRXTXSR_EXDEF_Pos (3U)
7570#define ETH_MACRXTXSR_EXDEF_Msk (0x1UL << ETH_MACRXTXSR_EXDEF_Pos)
7571#define ETH_MACRXTXSR_EXDEF ETH_MACRXTXSR_EXDEF_Msk /* Excessive Deferral */
7572#define ETH_MACRXTXSR_LCARR_Pos (2U)
7573#define ETH_MACRXTXSR_LCARR_Msk (0x1UL << ETH_MACRXTXSR_LCARR_Pos)
7574#define ETH_MACRXTXSR_LCARR ETH_MACRXTXSR_LCARR_Msk /* Loss of Carrier */
7575#define ETH_MACRXTXSR_NCARR_Pos (1U)
7576#define ETH_MACRXTXSR_NCARR_Msk (0x1UL << ETH_MACRXTXSR_NCARR_Pos)
7577#define ETH_MACRXTXSR_NCARR ETH_MACRXTXSR_NCARR_Msk /* No Carrier */
7578#define ETH_MACRXTXSR_TJT_Pos (0U)
7579#define ETH_MACRXTXSR_TJT_Msk (0x1UL << ETH_MACRXTXSR_TJT_Pos)
7580#define ETH_MACRXTXSR_TJT ETH_MACRXTXSR_TJT_Msk /* Transmit Jabber Timeout */
7581
7582/* Bit definition for Ethernet MAC PMT Control Status Register */
7583#define ETH_MACPCSR_RWKFILTRST_Pos (31U)
7584#define ETH_MACPCSR_RWKFILTRST_Msk (0x1UL << ETH_MACPCSR_RWKFILTRST_Pos)
7585#define ETH_MACPCSR_RWKFILTRST ETH_MACPCSR_RWKFILTRST_Msk /* Remote Wake-Up Packet Filter Register Pointer Reset */
7586#define ETH_MACPCSR_RWKPTR_Pos (24U)
7587#define ETH_MACPCSR_RWKPTR_Msk (0x1FUL << ETH_MACPCSR_RWKPTR_Pos)
7588#define ETH_MACPCSR_RWKPTR ETH_MACPCSR_RWKPTR_Msk /* Remote Wake-up FIFO Pointer */
7589#define ETH_MACPCSR_RWKPFE_Pos (10U)
7590#define ETH_MACPCSR_RWKPFE_Msk (0x1UL << ETH_MACPCSR_RWKPFE_Pos)
7591#define ETH_MACPCSR_RWKPFE ETH_MACPCSR_RWKPFE_Msk /* Remote Wake-up Packet Forwarding Enable */
7592#define ETH_MACPCSR_GLBLUCAST_Pos (9U)
7593#define ETH_MACPCSR_GLBLUCAST_Msk (0x1UL << ETH_MACPCSR_GLBLUCAST_Pos)
7594#define ETH_MACPCSR_GLBLUCAST ETH_MACPCSR_GLBLUCAST_Msk /* Global Unicast */
7595#define ETH_MACPCSR_RWKPRCVD_Pos (6U)
7596#define ETH_MACPCSR_RWKPRCVD_Msk (0x1UL << ETH_MACPCSR_RWKPRCVD_Pos)
7597#define ETH_MACPCSR_RWKPRCVD ETH_MACPCSR_RWKPRCVD_Msk /* Remote Wake-Up Packet Received */
7598#define ETH_MACPCSR_MGKPRCVD_Pos (5U)
7599#define ETH_MACPCSR_MGKPRCVD_Msk (0x1UL << ETH_MACPCSR_MGKPRCVD_Pos)
7600#define ETH_MACPCSR_MGKPRCVD ETH_MACPCSR_MGKPRCVD_Msk /* Magic Packet Received */
7601#define ETH_MACPCSR_RWKPKTEN_Pos (2U)
7602#define ETH_MACPCSR_RWKPKTEN_Msk (0x1UL << ETH_MACPCSR_RWKPKTEN_Pos)
7603#define ETH_MACPCSR_RWKPKTEN ETH_MACPCSR_RWKPKTEN_Msk /* Remote Wake-Up Packet Enable */
7604#define ETH_MACPCSR_MGKPKTEN_Pos (1U)
7605#define ETH_MACPCSR_MGKPKTEN_Msk (0x1UL << ETH_MACPCSR_MGKPKTEN_Pos)
7606#define ETH_MACPCSR_MGKPKTEN ETH_MACPCSR_MGKPKTEN_Msk /* Magic Packet Enable */
7607#define ETH_MACPCSR_PWRDWN_Pos (0U)
7608#define ETH_MACPCSR_PWRDWN_Msk (0x1UL << ETH_MACPCSR_PWRDWN_Pos)
7609#define ETH_MACPCSR_PWRDWN ETH_MACPCSR_PWRDWN_Msk /* Power Down */
7610
7611/* Bit definition for Ethernet MAC Remote Wake-Up Packet Filter Register */
7612#define ETH_MACRWUPFR_D_Pos (0U)
7613#define ETH_MACRWUPFR_D_Msk (0xFFFFFFFFUL << ETH_MACRWUPFR_D_Pos)
7614#define ETH_MACRWUPFR_D ETH_MACRWUPFR_D_Msk /* Wake-up Packet filter register data */
7615
7616/* Bit definition for Ethernet MAC LPI Control Status Register */
7617#define ETH_MACLCSR_LPITCSE_Pos (21U)
7618#define ETH_MACLCSR_LPITCSE_Msk (0x1UL << ETH_MACLCSR_LPITCSE_Pos)
7619#define ETH_MACLCSR_LPITCSE ETH_MACLCSR_LPITCSE_Msk /* LPI Tx Clock Stop Enable */
7620#define ETH_MACLCSR_LPITE_Pos (20U)
7621#define ETH_MACLCSR_LPITE_Msk (0x1UL << ETH_MACLCSR_LPITE_Pos)
7622#define ETH_MACLCSR_LPITE ETH_MACLCSR_LPITE_Msk /* LPI Timer Enable */
7623#define ETH_MACLCSR_LPITXA_Pos (19U)
7624#define ETH_MACLCSR_LPITXA_Msk (0x1UL << ETH_MACLCSR_LPITXA_Pos)
7625#define ETH_MACLCSR_LPITXA ETH_MACLCSR_LPITXA_Msk /* LPI Tx Automate */
7626#define ETH_MACLCSR_PLS_Pos (17U)
7627#define ETH_MACLCSR_PLS_Msk (0x1UL << ETH_MACLCSR_PLS_Pos)
7628#define ETH_MACLCSR_PLS ETH_MACLCSR_PLS_Msk /* PHY Link Status */
7629#define ETH_MACLCSR_LPIEN_Pos (16U)
7630#define ETH_MACLCSR_LPIEN_Msk (0x1UL << ETH_MACLCSR_LPIEN_Pos)
7631#define ETH_MACLCSR_LPIEN ETH_MACLCSR_LPIEN_Msk /* LPI Enable */
7632#define ETH_MACLCSR_RLPIST_Pos (9U)
7633#define ETH_MACLCSR_RLPIST_Msk (0x1UL << ETH_MACLCSR_RLPIST_Pos)
7634#define ETH_MACLCSR_RLPIST ETH_MACLCSR_RLPIST_Msk /* Receive LPI State */
7635#define ETH_MACLCSR_TLPIST_Pos (8U)
7636#define ETH_MACLCSR_TLPIST_Msk (0x1UL << ETH_MACLCSR_TLPIST_Pos)
7637#define ETH_MACLCSR_TLPIST ETH_MACLCSR_TLPIST_Msk /* Transmit LPI State */
7638#define ETH_MACLCSR_RLPIEX_Pos (3U)
7639#define ETH_MACLCSR_RLPIEX_Msk (0x1UL << ETH_MACLCSR_RLPIEX_Pos)
7640#define ETH_MACLCSR_RLPIEX ETH_MACLCSR_RLPIEX_Msk /* Receive LPI Exit */
7641#define ETH_MACLCSR_RLPIEN_Pos (2U)
7642#define ETH_MACLCSR_RLPIEN_Msk (0x1UL << ETH_MACLCSR_RLPIEN_Pos)
7643#define ETH_MACLCSR_RLPIEN ETH_MACLCSR_RLPIEN_Msk /* Receive LPI Entry */
7644#define ETH_MACLCSR_TLPIEX_Pos (1U)
7645#define ETH_MACLCSR_TLPIEX_Msk (0x1UL << ETH_MACLCSR_TLPIEX_Pos)
7646#define ETH_MACLCSR_TLPIEX ETH_MACLCSR_TLPIEX_Msk /* Transmit LPI Exit */
7647#define ETH_MACLCSR_TLPIEN_Pos (0U)
7648#define ETH_MACLCSR_TLPIEN_Msk (0x1UL << ETH_MACLCSR_TLPIEN_Pos)
7649#define ETH_MACLCSR_TLPIEN ETH_MACLCSR_TLPIEN_Msk /* Transmit LPI Entry */
7650
7651/* Bit definition for Ethernet MAC LPI Timers Control Register */
7652#define ETH_MACLTCR_LST_Pos (16U)
7653#define ETH_MACLTCR_LST_Msk (0x3FFUL << ETH_MACLTCR_LST_Pos)
7654#define ETH_MACLTCR_LST ETH_MACLTCR_LST_Msk /* LPI LS TIMER */
7655#define ETH_MACLTCR_TWT_Pos (0U)
7656#define ETH_MACLTCR_TWT_Msk (0xFFFFUL << ETH_MACLTCR_TWT_Pos)
7657#define ETH_MACLTCR_TWT ETH_MACLTCR_TWT_Msk /* LPI TW TIMER */
7658
7659/* Bit definition for Ethernet MAC LPI Entry Timer Register */
7660#define ETH_MACLETR_LPIET_Pos (0U)
7661#define ETH_MACLETR_LPIET_Msk (0xFFFFFUL << ETH_MACLETR_LPIET_Pos)
7662#define ETH_MACLETR_LPIET ETH_MACLETR_LPIET_Msk /* LPI Entry Timer */
7663
7664/* Bit definition for Ethernet MAC 1US Tic Counter Register */
7665#define ETH_MAC1USTCR_TIC1USCNTR_Pos (0U)
7666#define ETH_MAC1USTCR_TIC1USCNTR_Msk (0xFFFUL << ETH_MAC1USTCR_TIC1USCNTR_Pos)
7667#define ETH_MAC1USTCR_TIC1USCNTR ETH_MAC1USTCR_TIC1USCNTR_Msk /* 1US TIC Counter */
7668
7669/* Bit definition for Ethernet MAC Version Register */
7670#define ETH_MACVR_USERVER_Pos (8U)
7671#define ETH_MACVR_USERVER_Msk (0xFFUL << ETH_MACVR_USERVER_Pos)
7672#define ETH_MACVR_USERVER ETH_MACVR_USERVER_Msk /* User-defined Version */
7673#define ETH_MACVR_SNPSVER_Pos (0U)
7674#define ETH_MACVR_SNPSVER_Msk (0xFFUL << ETH_MACVR_SNPSVER_Pos)
7675#define ETH_MACVR_SNPSVER ETH_MACVR_SNPSVER_Msk /* Synopsys-defined Version */
7676
7677/* Bit definition for Ethernet MAC Debug Register */
7678#define ETH_MACDR_TFCSTS_Pos (17U)
7679#define ETH_MACDR_TFCSTS_Msk (0x3UL << ETH_MACDR_TFCSTS_Pos)
7680#define ETH_MACDR_TFCSTS ETH_MACDR_TFCSTS_Msk /* MAC Transmit Packet Controller Status */
7681#define ETH_MACDR_TFCSTS_IDLE (0U) /* Idle state */
7682#define ETH_MACDR_TFCSTS_WAIT_Pos (17U)
7683#define ETH_MACDR_TFCSTS_WAIT_Msk (0x1UL << ETH_MACDR_TFCSTS_WAIT_Pos)
7684#define ETH_MACDR_TFCSTS_WAIT ETH_MACDR_TFCSTS_WAIT_Msk /* Waiting for status of the previous packet, IPG or backoff period to be over */
7685#define ETH_MACDR_TFCSTS_GENERATEPCP_Pos (18U)
7686#define ETH_MACDR_TFCSTS_GENERATEPCP_Msk (0x1UL << ETH_MACDR_TFCSTS_GENERATEPCP_Pos)
7687#define ETH_MACDR_TFCSTS_GENERATEPCP ETH_MACDR_TFCSTS_GENERATEPCP_Msk /* Generating and transmitting a Pause control packet */
7688#define ETH_MACDR_TFCSTS_TRASFERIP_Pos (17U)
7689#define ETH_MACDR_TFCSTS_TRASFERIP_Msk (0x3UL << ETH_MACDR_TFCSTS_TRASFERIP_Pos)
7690#define ETH_MACDR_TFCSTS_TRASFERIP ETH_MACDR_TFCSTS_TRASFERIP_Msk /* Transferring input packet for transmission */
7691#define ETH_MACDR_TPESTS_Pos (16U)
7692#define ETH_MACDR_TPESTS_Msk (0x1UL << ETH_MACDR_TPESTS_Pos)
7693#define ETH_MACDR_TPESTS ETH_MACDR_TPESTS_Msk /* MAC Receive Packet Controller FIFO Status */
7694#define ETH_MACDR_RFCFCSTS_Pos (1U)
7695#define ETH_MACDR_RFCFCSTS_Msk (0x3UL << ETH_MACDR_RFCFCSTS_Pos)
7696#define ETH_MACDR_RFCFCSTS ETH_MACDR_RFCFCSTS_Msk /* MAC MII Transmit Protocol Engine Status */
7697#define ETH_MACDR_RPESTS_Pos (0U)
7698#define ETH_MACDR_RPESTS_Msk (0x1UL << ETH_MACDR_RPESTS_Pos)
7699#define ETH_MACDR_RPESTS ETH_MACDR_RPESTS_Msk /* MAC MII Receive Protocol Engine Status */
7700
7701/* Bit definition for Ethernet MAC HW Feature0 Register */
7702#define ETH_MACHWF0R_ACTPHYSEL_Pos (28U)
7703#define ETH_MACHWF0R_ACTPHYSEL_Msk (0x7UL << ETH_MACHWF0R_ACTPHYSEL_Pos)
7704#define ETH_MACHWF0R_ACTPHYSEL ETH_MACHWF0R_ACTPHYSEL_Msk /* Active PHY Selected */
7705#define ETH_MACHWF0R_ACTPHYSEL_MII (0U) /* MII */
7706#define ETH_MACHWF0R_ACTPHYSEL_RMII_Pos (30U)
7707#define ETH_MACHWF0R_ACTPHYSEL_RMII_Msk (0x1UL << ETH_MACHWF0R_ACTPHYSEL_RMII_Pos)
7708#define ETH_MACHWF0R_ACTPHYSEL_RMII ETH_MACHWF0R_ACTPHYSEL_RMII_Msk /* RMII */
7709#define ETH_MACHWF0R_ACTPHYSEL_REVMII_Pos (28U)
7710#define ETH_MACHWF0R_ACTPHYSEL_REVMII_Msk (0x7UL << ETH_MACHWF0R_ACTPHYSEL_REVMII_Pos)
7711#define ETH_MACHWF0R_ACTPHYSEL_REVMII ETH_MACHWF0R_ACTPHYSEL_REVMII_Msk /* RevMII */
7712#define ETH_MACHWF0R_SAVLANINS_Pos (27U)
7713#define ETH_MACHWF0R_SAVLANINS_Msk (0x1UL << ETH_MACHWF0R_SAVLANINS_Pos)
7714#define ETH_MACHWF0R_SAVLANINS ETH_MACHWF0R_SAVLANINS_Msk /* Source Address or VLAN Insertion Enable */
7715#define ETH_MACHWF0R_TSSTSSEL_Pos (25U)
7716#define ETH_MACHWF0R_TSSTSSEL_Msk (0x3UL << ETH_MACHWF0R_TSSTSSEL_Pos)
7717#define ETH_MACHWF0R_TSSTSSEL ETH_MACHWF0R_TSSTSSEL_Msk /* Timestamp System Time Source */
7718#define ETH_MACHWF0R_TSSTSSEL_INTERNAL_Pos (25U)
7719#define ETH_MACHWF0R_TSSTSSEL_INTERNAL_Msk (0x1UL << ETH_MACHWF0R_TSSTSSEL_INTERNAL_Pos)
7720#define ETH_MACHWF0R_TSSTSSEL_INTERNAL ETH_MACHWF0R_TSSTSSEL_INTERNAL_Msk /* Timestamp System Time Source: Internal */
7721#define ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Pos (26U)
7722#define ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Msk (0x1UL << ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Pos)
7723#define ETH_MACHWF0R_TSSTSSEL_EXTERNAL ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Msk /* Timestamp System Time Source: External */
7724#define ETH_MACHWF0R_TSSTSSEL_BOTH_Pos (25U)
7725#define ETH_MACHWF0R_TSSTSSEL_BOTH_Msk (0x3UL << ETH_MACHWF0R_TSSTSSEL_BOTH_Pos)
7726#define ETH_MACHWF0R_TSSTSSEL_BOTH ETH_MACHWF0R_TSSTSSEL_BOTH_Msk /* Timestamp System Time Source: Internal & External */
7727#define ETH_MACHWF0R_MACADR64SEL_Pos (24U)
7728#define ETH_MACHWF0R_MACADR64SEL_Msk (0x1UL << ETH_MACHWF0R_MACADR64SEL_Pos)
7729#define ETH_MACHWF0R_MACADR64SEL ETH_MACHWF0R_MACADR64SEL_Msk /* MAC Addresses 64-127 Selected */
7730#define ETH_MACHWF0R_MACADR32SEL_Pos (23U)
7731#define ETH_MACHWF0R_MACADR32SEL_Msk (0x1UL << ETH_MACHWF0R_MACADR32SEL_Pos)
7732#define ETH_MACHWF0R_MACADR32SEL ETH_MACHWF0R_MACADR32SEL_Msk /* MAC Addresses 32-63 Selected */
7733#define ETH_MACHWF0R_ADDMACADRSEL_Pos (18U)
7734#define ETH_MACHWF0R_ADDMACADRSEL_Msk (0x1FUL << ETH_MACHWF0R_ADDMACADRSEL_Pos)
7735#define ETH_MACHWF0R_ADDMACADRSEL ETH_MACHWF0R_ADDMACADRSEL_Msk /* MAC Addresses 1- 31 Selected */
7736#define ETH_MACHWF0R_RXCOESEL_Pos (16U)
7737#define ETH_MACHWF0R_RXCOESEL_Msk (0x1UL << ETH_MACHWF0R_RXCOESEL_Pos)
7738#define ETH_MACHWF0R_RXCOESEL ETH_MACHWF0R_RXCOESEL_Msk /* Receive Checksum Offload Enabled */
7739#define ETH_MACHWF0R_TXCOESEL_Pos (14U)
7740#define ETH_MACHWF0R_TXCOESEL_Msk (0x1UL << ETH_MACHWF0R_TXCOESEL_Pos)
7741#define ETH_MACHWF0R_TXCOESEL ETH_MACHWF0R_TXCOESEL_Msk /* Transmit Checksum Offload Enabled */
7742#define ETH_MACHWF0R_EEESEL_Pos (13U)
7743#define ETH_MACHWF0R_EEESEL_Msk (0x1UL << ETH_MACHWF0R_EEESEL_Pos)
7744#define ETH_MACHWF0R_EEESEL ETH_MACHWF0R_EEESEL_Msk /* Energy Efficient Ethernet Enabled */
7745#define ETH_MACHWF0R_TSSEL_Pos (12U)
7746#define ETH_MACHWF0R_TSSEL_Msk (0x1UL << ETH_MACHWF0R_TSSEL_Pos)
7747#define ETH_MACHWF0R_TSSEL ETH_MACHWF0R_TSSEL_Msk /* IEEE 1588-2008 Timestamp Enabled */
7748#define ETH_MACHWF0R_ARPOFFSEL_Pos (9U)
7749#define ETH_MACHWF0R_ARPOFFSEL_Msk (0x1UL << ETH_MACHWF0R_ARPOFFSEL_Pos)
7750#define ETH_MACHWF0R_ARPOFFSEL ETH_MACHWF0R_ARPOFFSEL_Msk /* ARP Offload Enabled */
7751#define ETH_MACHWF0R_MMCSEL_Pos (8U)
7752#define ETH_MACHWF0R_MMCSEL_Msk (0x1UL << ETH_MACHWF0R_MMCSEL_Pos)
7753#define ETH_MACHWF0R_MMCSEL ETH_MACHWF0R_MMCSEL_Msk /* RMON Module Enable */
7754#define ETH_MACHWF0R_MGKSEL_Pos (7U)
7755#define ETH_MACHWF0R_MGKSEL_Msk (0x1UL << ETH_MACHWF0R_MGKSEL_Pos)
7756#define ETH_MACHWF0R_MGKSEL ETH_MACHWF0R_MGKSEL_Msk /* PMT Magic Packet Enable */
7757#define ETH_MACHWF0R_RWKSEL_Pos (6U)
7758#define ETH_MACHWF0R_RWKSEL_Msk (0x1UL << ETH_MACHWF0R_RWKSEL_Pos)
7759#define ETH_MACHWF0R_RWKSEL ETH_MACHWF0R_RWKSEL_Msk /* PMT Remote Wake-up Packet Enable */
7760#define ETH_MACHWF0R_SMASEL_Pos (5U)
7761#define ETH_MACHWF0R_SMASEL_Msk (0x1UL << ETH_MACHWF0R_SMASEL_Pos)
7762#define ETH_MACHWF0R_SMASEL ETH_MACHWF0R_SMASEL_Msk /* SMA (MDIO) Interface */
7763#define ETH_MACHWF0R_VLHASH_Pos (4U)
7764#define ETH_MACHWF0R_VLHASH_Msk (0x1UL << ETH_MACHWF0R_VLHASH_Pos)
7765#define ETH_MACHWF0R_VLHASH ETH_MACHWF0R_VLHASH_Msk /* VLAN Hash Filter Selected */
7766#define ETH_MACHWF0R_PCSSEL_Pos (3U)
7767#define ETH_MACHWF0R_PCSSEL_Msk (0x1UL << ETH_MACHWF0R_PCSSEL_Pos)
7768#define ETH_MACHWF0R_PCSSEL ETH_MACHWF0R_PCSSEL_Msk /* PCS Registers (TBI, SGMII, or RTBI PHY interface) */
7769#define ETH_MACHWF0R_HDSEL_Pos (2U)
7770#define ETH_MACHWF0R_HDSEL_Msk (0x1UL << ETH_MACHWF0R_HDSEL_Pos)
7771#define ETH_MACHWF0R_HDSEL ETH_MACHWF0R_HDSEL_Msk /* Half-duplex Support */
7772#define ETH_MACHWF0R_GMIISEL_Pos (1U)
7773#define ETH_MACHWF0R_GMIISEL_Msk (0x1UL << ETH_MACHWF0R_GMIISEL_Pos)
7774#define ETH_MACHWF0R_GMIISEL ETH_MACHWF0R_GMIISEL_Msk /* 1000 Mbps Support */
7775#define ETH_MACHWF0R_MIISEL_Pos (0U)
7776#define ETH_MACHWF0R_MIISEL_Msk (0x1UL << ETH_MACHWF0R_MIISEL_Pos)
7777#define ETH_MACHWF0R_MIISEL ETH_MACHWF0R_MIISEL_Msk /* 10 or 100 Mbps Support */
7778
7779/* Bit definition for Ethernet MAC HW Feature1 Register */
7780#define ETH_MACHWF1R_L3L4FNUM_Pos (27U)
7781#define ETH_MACHWF1R_L3L4FNUM_Msk (0xFUL << ETH_MACHWF1R_L3L4FNUM_Pos)
7782#define ETH_MACHWF1R_L3L4FNUM ETH_MACHWF1R_L3L4FNUM_Msk /* Total number of L3 or L4 Filters */
7783#define ETH_MACHWF1R_HASHTBLSZ_Pos (24U)
7784#define ETH_MACHWF1R_HASHTBLSZ_Msk (0x3UL << ETH_MACHWF1R_HASHTBLSZ_Pos)
7785#define ETH_MACHWF1R_HASHTBLSZ ETH_MACHWF1R_HASHTBLSZ_Msk /* Hash Table Size */
7786#define ETH_MACHWF1R_AVSEL_Pos (20U)
7787#define ETH_MACHWF1R_AVSEL_Msk (0x1UL << ETH_MACHWF1R_AVSEL_Pos)
7788#define ETH_MACHWF1R_AVSEL ETH_MACHWF1R_AVSEL_Msk /* AV Feature Enabled */
7789#define ETH_MACHWF1R_DBGMEMA_Pos (19U)
7790#define ETH_MACHWF1R_DBGMEMA_Msk (0x1UL << ETH_MACHWF1R_DBGMEMA_Pos)
7791#define ETH_MACHWF1R_DBGMEMA ETH_MACHWF1R_DBGMEMA_Msk /* Debug Memory Interface Enabled */
7792#define ETH_MACHWF1R_TSOEN_Pos (18U)
7793#define ETH_MACHWF1R_TSOEN_Msk (0x1UL << ETH_MACHWF1R_TSOEN_Pos)
7794#define ETH_MACHWF1R_TSOEN ETH_MACHWF1R_TSOEN_Msk /* TCP Segmentation Offload Enable */
7795#define ETH_MACHWF1R_SPHEN_Pos (17U)
7796#define ETH_MACHWF1R_SPHEN_Msk (0x1UL << ETH_MACHWF1R_SPHEN_Pos)
7797#define ETH_MACHWF1R_SPHEN ETH_MACHWF1R_SPHEN_Msk /* Split Header Feature Enable */
7798#define ETH_MACHWF1R_DCBEN_Pos (16U)
7799#define ETH_MACHWF1R_DCBEN_Msk (0x1UL << ETH_MACHWF1R_DCBEN_Pos)
7800#define ETH_MACHWF1R_DCBEN ETH_MACHWF1R_DCBEN_Msk /* DCB Feature Enable */
7801#define ETH_MACHWF1R_ADDR64_Pos (14U)
7802#define ETH_MACHWF1R_ADDR64_Msk (0x3UL << ETH_MACHWF1R_ADDR64_Pos)
7803#define ETH_MACHWF1R_ADDR64 ETH_MACHWF1R_ADDR64_Msk /* Address Width */
7804#define ETH_MACHWF1R_ADDR64_32 (0x0UL << ETH_MACHWF1R_ADDR64_Pos)
7805#define ETH_MACHWF1R_ADDR64_40 (0x1UL << ETH_MACHWF1R_ADDR64_Pos)
7806#define ETH_MACHWF1R_ADDR64_48 (0x2UL << ETH_MACHWF1R_ADDR64_Pos)
7807#define ETH_MACHWF1R_ADVTHWORD_Pos (13U)
7808#define ETH_MACHWF1R_ADVTHWORD_Msk (0x1UL << ETH_MACHWF1R_ADVTHWORD_Pos)
7809#define ETH_MACHWF1R_ADVTHWORD ETH_MACHWF1R_ADVTHWORD_Msk /* IEEE 1588 High Word Register Enable */
7810#define ETH_MACHWF1R_PTOEN_Pos (12U)
7811#define ETH_MACHWF1R_PTOEN_Msk (0x1UL << ETH_MACHWF1R_PTOEN_Pos)
7812#define ETH_MACHWF1R_PTOEN ETH_MACHWF1R_PTOEN_Msk /* PTP Offload Enable */
7813#define ETH_MACHWF1R_OSTEN_Pos (11U)
7814#define ETH_MACHWF1R_OSTEN_Msk (0x1UL << ETH_MACHWF1R_OSTEN_Pos)
7815#define ETH_MACHWF1R_OSTEN ETH_MACHWF1R_OSTEN_Msk /* One-Step Timestamping Enable */
7816#define ETH_MACHWF1R_TXFIFOSIZE_Pos (6U)
7817#define ETH_MACHWF1R_TXFIFOSIZE_Msk (0x1FUL << ETH_MACHWF1R_TXFIFOSIZE_Pos)
7818#define ETH_MACHWF1R_TXFIFOSIZE ETH_MACHWF1R_TXFIFOSIZE_Msk /* MTL Transmit FIFO Size */
7819#define ETH_MACHWF1R_RXFIFOSIZE_Pos (0U)
7820#define ETH_MACHWF1R_RXFIFOSIZE_Msk (0x1FUL << ETH_MACHWF1R_RXFIFOSIZE_Pos)
7821#define ETH_MACHWF1R_RXFIFOSIZE ETH_MACHWF1R_RXFIFOSIZE_Msk /* MTL Receive FIFO Size */
7822
7823/* Bit definition for Ethernet MAC HW Feature2 Register */
7824#define ETH_MACHWF2R_AUXSNAPNUM_Pos (28U)
7825#define ETH_MACHWF2R_AUXSNAPNUM_Msk (0x7UL << ETH_MACHWF2R_AUXSNAPNUM_Pos)
7826#define ETH_MACHWF2R_AUXSNAPNUM ETH_MACHWF2R_AUXSNAPNUM_Msk /* Number of Auxiliary Snapshot Inputs */
7827#define ETH_MACHWF2R_PPSOUTNUM_Pos (24U)
7828#define ETH_MACHWF2R_PPSOUTNUM_Msk (0x7UL << ETH_MACHWF2R_PPSOUTNUM_Pos)
7829#define ETH_MACHWF2R_PPSOUTNUM ETH_MACHWF2R_PPSOUTNUM_Msk /* Number of PPS Outputs */
7830#define ETH_MACHWF2R_TXCHCNT_Pos (18U)
7831#define ETH_MACHWF2R_TXCHCNT_Msk (0xFUL << ETH_MACHWF2R_TXCHCNT_Pos)
7832#define ETH_MACHWF2R_TXCHCNT ETH_MACHWF2R_TXCHCNT_Msk /* Number of DMA Transmit Channels */
7833#define ETH_MACHWF2R_RXCHCNT_Pos (13U)
7834#define ETH_MACHWF2R_RXCHCNT_Msk (0x7UL << ETH_MACHWF2R_RXCHCNT_Pos)
7835#define ETH_MACHWF2R_RXCHCNT ETH_MACHWF2R_RXCHCNT_Msk /* Number of DMA Receive Channels */
7836#define ETH_MACHWF2R_TXQCNT_Pos (6U)
7837#define ETH_MACHWF2R_TXQCNT_Msk (0xFUL << ETH_MACHWF2R_TXQCNT_Pos)
7838#define ETH_MACHWF2R_TXQCNT ETH_MACHWF2R_TXQCNT_Msk /* Number of MTL Transmit Queues */
7839#define ETH_MACHWF2R_RXQCNT_Pos (0U)
7840#define ETH_MACHWF2R_RXQCNT_Msk (0xFUL << ETH_MACHWF2R_RXQCNT_Pos)
7841#define ETH_MACHWF2R_RXQCNT ETH_MACHWF2R_RXQCNT_Msk /* Number of MTL Receive Queues */
7842
7843/* Bit definition for Ethernet MAC MDIO Address Register */
7844#define ETH_MACMDIOAR_PSE_Pos (27U)
7845#define ETH_MACMDIOAR_PSE_Msk (0x1UL << ETH_MACMDIOAR_PSE_Pos)
7846#define ETH_MACMDIOAR_PSE ETH_MACMDIOAR_PSE_Msk /* Preamble Suppression Enable */
7847#define ETH_MACMDIOAR_BTB_Pos (26U)
7848#define ETH_MACMDIOAR_BTB_Msk (0x1UL << ETH_MACMDIOAR_BTB_Pos)
7849#define ETH_MACMDIOAR_BTB ETH_MACMDIOAR_BTB_Msk /* Back to Back transactions */
7850#define ETH_MACMDIOAR_PA_Pos (21U)
7851#define ETH_MACMDIOAR_PA_Msk (0x1FUL << ETH_MACMDIOAR_PA_Pos)
7852#define ETH_MACMDIOAR_PA ETH_MACMDIOAR_PA_Msk /* Physical Layer Address */
7853#define ETH_MACMDIOAR_RDA_Pos (16U)
7854#define ETH_MACMDIOAR_RDA_Msk (0x1FUL << ETH_MACMDIOAR_RDA_Pos)
7855#define ETH_MACMDIOAR_RDA ETH_MACMDIOAR_RDA_Msk /* Register/Device Address */
7856#define ETH_MACMDIOAR_NTC_Pos (12U)
7857#define ETH_MACMDIOAR_NTC_Msk (0x7UL << ETH_MACMDIOAR_NTC_Pos)
7858#define ETH_MACMDIOAR_NTC ETH_MACMDIOAR_NTC_Msk /* Number of Trailing Clocks */
7859#define ETH_MACMDIOAR_CR_Pos (8U)
7860#define ETH_MACMDIOAR_CR_Msk (0xFUL << ETH_MACMDIOAR_CR_Pos)
7861#define ETH_MACMDIOAR_CR ETH_MACMDIOAR_CR_Msk /* CSR Clock Range */
7862#define ETH_MACMDIOAR_CR_DIV42 (0U) /* CSR clock/42 */
7863#define ETH_MACMDIOAR_CR_DIV62_Pos (8U)
7864#define ETH_MACMDIOAR_CR_DIV62_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV62_Pos)
7865#define ETH_MACMDIOAR_CR_DIV62 ETH_MACMDIOAR_CR_DIV62_Msk /* CSR clock/62 */
7866#define ETH_MACMDIOAR_CR_DIV16_Pos (9U)
7867#define ETH_MACMDIOAR_CR_DIV16_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV16_Pos)
7868#define ETH_MACMDIOAR_CR_DIV16 ETH_MACMDIOAR_CR_DIV16_Msk /* CSR clock/16 */
7869#define ETH_MACMDIOAR_CR_DIV26_Pos (8U)
7870#define ETH_MACMDIOAR_CR_DIV26_Msk (0x3UL << ETH_MACMDIOAR_CR_DIV26_Pos)
7871#define ETH_MACMDIOAR_CR_DIV26 ETH_MACMDIOAR_CR_DIV26_Msk /* CSR clock/26 */
7872#define ETH_MACMDIOAR_CR_DIV102_Pos (10U)
7873#define ETH_MACMDIOAR_CR_DIV102_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV102_Pos)
7874#define ETH_MACMDIOAR_CR_DIV102 ETH_MACMDIOAR_CR_DIV102_Msk /* CSR clock/102 */
7875#define ETH_MACMDIOAR_CR_DIV124_Pos (8U)
7876#define ETH_MACMDIOAR_CR_DIV124_Msk (0x5UL << ETH_MACMDIOAR_CR_DIV124_Pos)
7877#define ETH_MACMDIOAR_CR_DIV124 ETH_MACMDIOAR_CR_DIV124_Msk /* CSR clock/124 */
7878#define ETH_MACMDIOAR_CR_DIV4AR_Pos (11U)
7879#define ETH_MACMDIOAR_CR_DIV4AR_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV4AR_Pos)
7880#define ETH_MACMDIOAR_CR_DIV4AR ETH_MACMDIOAR_CR_DIV4AR_Msk /* CSR clock/4: MDC clock above range specified in IEEE */
7881#define ETH_MACMDIOAR_CR_DIV6AR_Pos (8U)
7882#define ETH_MACMDIOAR_CR_DIV6AR_Msk (0x9UL << ETH_MACMDIOAR_CR_DIV6AR_Pos)
7883#define ETH_MACMDIOAR_CR_DIV6AR ETH_MACMDIOAR_CR_DIV6AR_Msk /* CSR clock/6: MDC clock above range specified in IEEE */
7884#define ETH_MACMDIOAR_CR_DIV8AR_Pos (9U)
7885#define ETH_MACMDIOAR_CR_DIV8AR_Msk (0x5UL << ETH_MACMDIOAR_CR_DIV8AR_Pos)
7886#define ETH_MACMDIOAR_CR_DIV8AR ETH_MACMDIOAR_CR_DIV8AR_Msk /* CSR clock/8: MDC clock above range specified in IEEE */
7887#define ETH_MACMDIOAR_CR_DIV10AR_Pos (8U)
7888#define ETH_MACMDIOAR_CR_DIV10AR_Msk (0xBUL << ETH_MACMDIOAR_CR_DIV10AR_Pos)
7889#define ETH_MACMDIOAR_CR_DIV10AR ETH_MACMDIOAR_CR_DIV10AR_Msk /* CSR clock/10: MDC clock above range specified in IEEE */
7890#define ETH_MACMDIOAR_CR_DIV12AR_Pos (10U)
7891#define ETH_MACMDIOAR_CR_DIV12AR_Msk (0x3UL << ETH_MACMDIOAR_CR_DIV12AR_Pos)
7892#define ETH_MACMDIOAR_CR_DIV12AR ETH_MACMDIOAR_CR_DIV12AR_Msk /* CSR clock/12: MDC clock above range specified in IEEE */
7893#define ETH_MACMDIOAR_CR_DIV14AR_Pos (8U)
7894#define ETH_MACMDIOAR_CR_DIV14AR_Msk (0xDUL << ETH_MACMDIOAR_CR_DIV14AR_Pos)
7895#define ETH_MACMDIOAR_CR_DIV14AR ETH_MACMDIOAR_CR_DIV14AR_Msk /* CSR clock/14: MDC clock above range specified in IEEE */
7896#define ETH_MACMDIOAR_CR_DIV16AR_Pos (9U)
7897#define ETH_MACMDIOAR_CR_DIV16AR_Msk (0x7UL << ETH_MACMDIOAR_CR_DIV16AR_Pos)
7898#define ETH_MACMDIOAR_CR_DIV16AR ETH_MACMDIOAR_CR_DIV16AR_Msk /* CSR clock/16: MDC clock above range specified in IEEE */
7899#define ETH_MACMDIOAR_CR_DIV18AR_Pos (8U)
7900#define ETH_MACMDIOAR_CR_DIV18AR_Msk (0xFUL << ETH_MACMDIOAR_CR_DIV18AR_Pos)
7901#define ETH_MACMDIOAR_CR_DIV18AR ETH_MACMDIOAR_CR_DIV18AR_Msk /* CSR clock/18: MDC clock above range specified in IEEE */
7902#define ETH_MACMDIOAR_SKAP_Pos (4U)
7903#define ETH_MACMDIOAR_SKAP_Msk (0x1UL << ETH_MACMDIOAR_SKAP_Pos)
7904#define ETH_MACMDIOAR_SKAP ETH_MACMDIOAR_SKAP_Msk /* Skip Address Packet */
7905#define ETH_MACMDIOAR_MOC_Pos (2U)
7906#define ETH_MACMDIOAR_MOC_Msk (0x3UL << ETH_MACMDIOAR_MOC_Pos)
7907#define ETH_MACMDIOAR_MOC ETH_MACMDIOAR_MOC_Msk /* MII Operation Command */
7908#define ETH_MACMDIOAR_MOC_WR_Pos (2U)
7909#define ETH_MACMDIOAR_MOC_WR_Msk (0x1UL << ETH_MACMDIOAR_MOC_WR_Pos)
7910#define ETH_MACMDIOAR_MOC_WR ETH_MACMDIOAR_MOC_WR_Msk /* Write */
7911#define ETH_MACMDIOAR_MOC_PRDIA_Pos (3U)
7912#define ETH_MACMDIOAR_MOC_PRDIA_Msk (0x1UL << ETH_MACMDIOAR_MOC_PRDIA_Pos)
7913#define ETH_MACMDIOAR_MOC_PRDIA ETH_MACMDIOAR_MOC_PRDIA_Msk /* Post Read Increment Address for Clause 45 PHY */
7914#define ETH_MACMDIOAR_MOC_RD_Pos (2U)
7915#define ETH_MACMDIOAR_MOC_RD_Msk (0x3UL << ETH_MACMDIOAR_MOC_RD_Pos)
7916#define ETH_MACMDIOAR_MOC_RD ETH_MACMDIOAR_MOC_RD_Msk /* Read */
7917#define ETH_MACMDIOAR_C45E_Pos (1U)
7918#define ETH_MACMDIOAR_C45E_Msk (0x1UL << ETH_MACMDIOAR_C45E_Pos)
7919#define ETH_MACMDIOAR_C45E ETH_MACMDIOAR_C45E_Msk /* Clause 45 PHY Enable */
7920#define ETH_MACMDIOAR_MB_Pos (0U)
7921#define ETH_MACMDIOAR_MB_Msk (0x1UL << ETH_MACMDIOAR_MB_Pos)
7922#define ETH_MACMDIOAR_MB ETH_MACMDIOAR_MB_Msk /* MII Busy */
7923
7924/* Bit definition for Ethernet MAC MDIO Data Register */
7925#define ETH_MACMDIODR_RA_Pos (16U)
7926#define ETH_MACMDIODR_RA_Msk (0xFFFFUL << ETH_MACMDIODR_RA_Pos)
7927#define ETH_MACMDIODR_RA ETH_MACMDIODR_RA_Msk /* Register Address */
7928#define ETH_MACMDIODR_MD_Pos (0U)
7929#define ETH_MACMDIODR_MD_Msk (0xFFFFUL << ETH_MACMDIODR_MD_Pos)
7930#define ETH_MACMDIODR_MD ETH_MACMDIODR_MD_Msk /* MII Data */
7931
7932/* Bit definition for Ethernet ARP Address Register */
7933#define ETH_MACARPAR_ARPPA_Pos (0U)
7934#define ETH_MACARPAR_ARPPA_Msk (0xFFFFFFFFUL << ETH_MACARPAR_ARPPA_Pos)
7935#define ETH_MACARPAR_ARPPA ETH_MACARPAR_ARPPA_Msk /* ARP Protocol Address */
7936
7937/* Bit definition for Ethernet MAC Address 0 High Register */
7938#define ETH_MACA0HR_AE_Pos (31U)
7939#define ETH_MACA0HR_AE_Msk (0x1UL << ETH_MACA0HR_AE_Pos)
7940#define ETH_MACA0HR_AE ETH_MACA0HR_AE_Msk /* Address Enable*/
7941#define ETH_MACA0HR_ADDRHI_Pos (0U)
7942#define ETH_MACA0HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA0HR_ADDRHI_Pos)
7943#define ETH_MACA0HR_ADDRHI ETH_MACA0HR_ADDRHI_Msk /* MAC Address 0*/
7944
7945/* Bit definition for Ethernet MAC Address 0 Low Register */
7946#define ETH_MACA0LR_ADDRLO_Pos (0U)
7947#define ETH_MACA0LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA0LR_ADDRLO_Pos)
7948#define ETH_MACA0LR_ADDRLO ETH_MACA0LR_ADDRLO_Msk /* MAC Address 0*/
7949
7950/* Bit definition for Ethernet MAC Address 1 High Register */
7951#define ETH_MACA1HR_AE_Pos (31U)
7952#define ETH_MACA1HR_AE_Msk (0x1UL << ETH_MACA1HR_AE_Pos)
7953#define ETH_MACA1HR_AE ETH_MACA1HR_AE_Msk /* Address Enable*/
7954#define ETH_MACA1HR_SA_Pos (30U)
7955#define ETH_MACA1HR_SA_Msk (0x1UL << ETH_MACA1HR_SA_Pos)
7956#define ETH_MACA1HR_SA ETH_MACA1HR_SA_Msk /* Source Address */
7957#define ETH_MACA1HR_MBC_Pos (24U)
7958#define ETH_MACA1HR_MBC_Msk (0x3FUL << ETH_MACA1HR_MBC_Pos)
7959#define ETH_MACA1HR_MBC ETH_MACA1HR_MBC_Msk /* Mask Byte Control */
7960#define ETH_MACA1HR_ADDRHI_Pos (0U)
7961#define ETH_MACA1HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA1HR_ADDRHI_Pos)
7962#define ETH_MACA1HR_ADDRHI ETH_MACA1HR_ADDRHI_Msk /* MAC Address 1*/
7963
7964/* Bit definition for Ethernet MAC Address 1 Low Register */
7965#define ETH_MACA1LR_ADDRLO_Pos (0U)
7966#define ETH_MACA1LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA1LR_ADDRLO_Pos)
7967#define ETH_MACA1LR_ADDRLO ETH_MACA1LR_ADDRLO_Msk /* MAC Address 1*/
7968
7969/* Bit definition for Ethernet MAC Address 2 High Register */
7970#define ETH_MACA2HR_AE_Pos (31U)
7971#define ETH_MACA2HR_AE_Msk (0x1UL << ETH_MACA2HR_AE_Pos)
7972#define ETH_MACA2HR_AE ETH_MACA2HR_AE_Msk /* Address Enable*/
7973#define ETH_MACA2HR_SA_Pos (30U)
7974#define ETH_MACA2HR_SA_Msk (0x1UL << ETH_MACA2HR_SA_Pos)
7975#define ETH_MACA2HR_SA ETH_MACA2HR_SA_Msk /* Source Address */
7976#define ETH_MACA2HR_MBC_Pos (24U)
7977#define ETH_MACA2HR_MBC_Msk (0x3FUL << ETH_MACA2HR_MBC_Pos)
7978#define ETH_MACA2HR_MBC ETH_MACA2HR_MBC_Msk /* Mask Byte Control */
7979#define ETH_MACA2HR_ADDRHI_Pos (0U)
7980#define ETH_MACA2HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA2HR_ADDRHI_Pos)
7981#define ETH_MACA2HR_ADDRHI ETH_MACA2HR_ADDRHI_Msk /* MAC Address 1*/
7982
7983/* Bit definition for Ethernet MAC Address 2 Low Register */
7984#define ETH_MACA2LR_ADDRLO_Pos (0U)
7985#define ETH_MACA2LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA2LR_ADDRLO_Pos)
7986#define ETH_MACA2LR_ADDRLO ETH_MACA2LR_ADDRLO_Msk /* MAC Address 2*/
7987
7988/* Bit definition for Ethernet MAC Address 3 High Register */
7989#define ETH_MACA3HR_AE_Pos (31U)
7990#define ETH_MACA3HR_AE_Msk (0x1UL << ETH_MACA3HR_AE_Pos)
7991#define ETH_MACA3HR_AE ETH_MACA3HR_AE_Msk /* Address Enable*/
7992#define ETH_MACA3HR_SA_Pos (30U)
7993#define ETH_MACA3HR_SA_Msk (0x1UL << ETH_MACA3HR_SA_Pos)
7994#define ETH_MACA3HR_SA ETH_MACA3HR_SA_Msk /* Source Address */
7995#define ETH_MACA3HR_MBC_Pos (24U)
7996#define ETH_MACA3HR_MBC_Msk (0x3FUL << ETH_MACA3HR_MBC_Pos)
7997#define ETH_MACA3HR_MBC ETH_MACA3HR_MBC_Msk /* Mask Byte Control */
7998#define ETH_MACA3HR_ADDRHI_Pos (0U)
7999#define ETH_MACA3HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA3HR_ADDRHI_Pos)
8000#define ETH_MACA3HR_ADDRHI ETH_MACA3HR_ADDRHI_Msk /* MAC Address 1*/
8001
8002/* Bit definition for Ethernet MAC Address 3 Low Register */
8003#define ETH_MACA3LR_ADDRLO_Pos (0U)
8004#define ETH_MACA3LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA3LR_ADDRLO_Pos)
8005#define ETH_MACA3LR_ADDRLO ETH_MACA3LR_ADDRLO_Msk /* MAC Address 3*/
8006
8007/* Bit definition for Ethernet MAC Address High Register */
8008#define ETH_MACAHR_AE_Pos (31U)
8009#define ETH_MACAHR_AE_Msk (0x1UL << ETH_MACAHR_AE_Pos)
8010#define ETH_MACAHR_AE ETH_MACAHR_AE_Msk /* Address enable */
8011#define ETH_MACAHR_SA_Pos (30U)
8012#define ETH_MACAHR_SA_Msk (0x1UL << ETH_MACAHR_SA_Pos)
8013#define ETH_MACAHR_SA ETH_MACAHR_SA_Msk /* Source address */
8014#define ETH_MACAHR_MBC_Pos (24U)
8015#define ETH_MACAHR_MBC_Msk (0x3FUL << ETH_MACAHR_MBC_Pos)
8016#define ETH_MACAHR_MBC ETH_MACAHR_MBC_Msk /* Mask byte control: bits to mask for comparison of the MAC Address bytes */
8017#define ETH_MACAHR_MBC_HBITS15_8 (0x20000000U) /* Mask MAC Address high reg bits [15:8] */
8018#define ETH_MACAHR_MBC_HBITS7_0 (0x10000000U) /* Mask MAC Address high reg bits [7:0] */
8019#define ETH_MACAHR_MBC_LBITS31_24 (0x08000000U) /* Mask MAC Address low reg bits [31:24] */
8020#define ETH_MACAHR_MBC_LBITS23_16 (0x04000000U) /* Mask MAC Address low reg bits [23:16] */
8021#define ETH_MACAHR_MBC_LBITS15_8 (0x02000000U) /* Mask MAC Address low reg bits [15:8] */
8022#define ETH_MACAHR_MBC_LBITS7_0 (0x01000000U) /* Mask MAC Address low reg bits [7:0] */
8023#define ETH_MACAHR_MACAH_Pos (0U)
8024#define ETH_MACAHR_MACAH_Msk (0xFFFFUL << ETH_MACAHR_MACAH_Pos)
8025#define ETH_MACAHR_MACAH ETH_MACAHR_MACAH_Msk /* MAC address high */
8026
8027/* Bit definition for Ethernet MAC Address Low Register */
8028#define ETH_MACALR_MACAL_Pos (0U)
8029#define ETH_MACALR_MACAL_Msk (0xFFFFFFFFUL << ETH_MACALR_MACAL_Pos)
8030#define ETH_MACALR_MACAL ETH_MACALR_MACAL_Msk /* MAC address low */
8031
8032/* Bit definition for Ethernet MMC Control Register */
8033#define ETH_MMCCR_UCDBC_Pos (8U)
8034#define ETH_MMCCR_UCDBC_Msk (0x1UL << ETH_MMCCR_UCDBC_Pos)
8035#define ETH_MMCCR_UCDBC ETH_MMCCR_UCDBC_Msk /* Update MMC Counters for Dropped Broadcast Packets */
8036#define ETH_MMCCR_CNTPRSTLVL_Pos (5U)
8037#define ETH_MMCCR_CNTPRSTLVL_Msk (0x1UL << ETH_MMCCR_CNTPRSTLVL_Pos)
8038#define ETH_MMCCR_CNTPRSTLVL ETH_MMCCR_CNTPRSTLVL_Msk /* Full-Half Preset */
8039#define ETH_MMCCR_CNTPRST_Pos (4U)
8040#define ETH_MMCCR_CNTPRST_Msk (0x1UL << ETH_MMCCR_CNTPRST_Pos)
8041#define ETH_MMCCR_CNTPRST ETH_MMCCR_CNTPRST_Msk /* Counters Reset */
8042#define ETH_MMCCR_CNTFREEZ_Pos (3U)
8043#define ETH_MMCCR_CNTFREEZ_Msk (0x1UL << ETH_MMCCR_CNTFREEZ_Pos)
8044#define ETH_MMCCR_CNTFREEZ ETH_MMCCR_CNTFREEZ_Msk /* MMC Counter Freeze */
8045#define ETH_MMCCR_RSTONRD_Pos (2U)
8046#define ETH_MMCCR_RSTONRD_Msk (0x1UL << ETH_MMCCR_RSTONRD_Pos)
8047#define ETH_MMCCR_RSTONRD ETH_MMCCR_RSTONRD_Msk /* Reset On Read */
8048#define ETH_MMCCR_CNTSTOPRO_Pos (1U)
8049#define ETH_MMCCR_CNTSTOPRO_Msk (0x1UL << ETH_MMCCR_CNTSTOPRO_Pos)
8050#define ETH_MMCCR_CNTSTOPRO ETH_MMCCR_CNTSTOPRO_Msk /* Counter Stop Rollover */
8051#define ETH_MMCCR_CNTRST_Pos (0U)
8052#define ETH_MMCCR_CNTRST_Msk (0x1UL << ETH_MMCCR_CNTRST_Pos)
8053#define ETH_MMCCR_CNTRST ETH_MMCCR_CNTRST_Msk /* Counters Reset */
8054
8055/* Bit definition for Ethernet MMC Rx Interrupt Register */
8056#define ETH_MMCRIR_RXLPITRCIS_Pos (27U)
8057#define ETH_MMCRIR_RXLPITRCIS_Msk (0x1UL << ETH_MMCRIR_RXLPITRCIS_Pos)
8058#define ETH_MMCRIR_RXLPITRCIS ETH_MMCRIR_RXLPITRCIS_Msk /* MMC Receive LPI transition counter interrupt status */
8059#define ETH_MMCRIR_RXLPIUSCIS_Pos (26U)
8060#define ETH_MMCRIR_RXLPIUSCIS_Msk (0x1UL << ETH_MMCRIR_RXLPIUSCIS_Pos)
8061#define ETH_MMCRIR_RXLPIUSCIS ETH_MMCRIR_RXLPIUSCIS_Msk /* MMC Receive LPI microsecond counter interrupt status */
8062#define ETH_MMCRIR_RXUCGPIS_Pos (17U)
8063#define ETH_MMCRIR_RXUCGPIS_Msk (0x1UL << ETH_MMCRIR_RXUCGPIS_Pos)
8064#define ETH_MMCRIR_RXUCGPIS ETH_MMCRIR_RXUCGPIS_Msk /* MMC Receive Unicast Good Packet Counter Interrupt Status */
8065#define ETH_MMCRIR_RXALGNERPIS_Pos (6U)
8066#define ETH_MMCRIR_RXALGNERPIS_Msk (0x1UL << ETH_MMCRIR_RXALGNERPIS_Pos)
8067#define ETH_MMCRIR_RXALGNERPIS ETH_MMCRIR_RXALGNERPIS_Msk /* MMC Receive Alignment Error Packet Counter Interrupt Status */
8068#define ETH_MMCRIR_RXCRCERPIS_Pos (5U)
8069#define ETH_MMCRIR_RXCRCERPIS_Msk (0x1UL << ETH_MMCRIR_RXCRCERPIS_Pos)
8070#define ETH_MMCRIR_RXCRCERPIS ETH_MMCRIR_RXCRCERPIS_Msk /* MMC Receive CRC Error Packet Counter Interrupt Status */
8071
8072/* Bit definition for Ethernet MMC Tx Interrupt Register */
8073#define ETH_MMCTIR_TXLPITRCIS_Pos (27U)
8074#define ETH_MMCTIR_TXLPITRCIS_Msk (0x1UL << ETH_MMCTIR_TXLPITRCIS_Pos)
8075#define ETH_MMCTIR_TXLPITRCIS ETH_MMCTIR_TXLPITRCIS_Msk /* MMC Transmit LPI transition counter interrupt status */
8076#define ETH_MMCTIR_TXLPIUSCIS_Pos (26U)
8077#define ETH_MMCTIR_TXLPIUSCIS_Msk (0x1UL << ETH_MMCTIR_TXLPIUSCIS_Pos)
8078#define ETH_MMCTIR_TXLPIUSCIS ETH_MMCTIR_TXLPIUSCIS_Msk /* MMC Transmit LPI microsecond counter interrupt status */
8079#define ETH_MMCTIR_TXGPKTIS_Pos (21U)
8080#define ETH_MMCTIR_TXGPKTIS_Msk (0x1UL << ETH_MMCTIR_TXGPKTIS_Pos)
8081#define ETH_MMCTIR_TXGPKTIS ETH_MMCTIR_TXGPKTIS_Msk /* MMC Transmit Good Packet Counter Interrupt Status */
8082#define ETH_MMCTIR_TXMCOLGPIS_Pos (15U)
8083#define ETH_MMCTIR_TXMCOLGPIS_Msk (0x1UL << ETH_MMCTIR_TXMCOLGPIS_Pos)
8084#define ETH_MMCTIR_TXMCOLGPIS ETH_MMCTIR_TXMCOLGPIS_Msk /* MMC Transmit Multiple Collision Good Packet Counter Interrupt Status */
8085#define ETH_MMCTIR_TXSCOLGPIS_Pos (14U)
8086#define ETH_MMCTIR_TXSCOLGPIS_Msk (0x1UL << ETH_MMCTIR_TXSCOLGPIS_Pos)
8087#define ETH_MMCTIR_TXSCOLGPIS ETH_MMCTIR_TXSCOLGPIS_Msk /* MMC Transmit Single Collision Good Packet Counter Interrupt Status */
8088
8089/* Bit definition for Ethernet MMC Rx interrupt Mask register */
8090#define ETH_MMCRIMR_RXLPITRCIM_Pos (27U)
8091#define ETH_MMCRIMR_RXLPITRCIM_Msk (0x1UL << ETH_MMCRIMR_RXLPITRCIM_Pos)
8092#define ETH_MMCRIMR_RXLPITRCIM ETH_MMCRIMR_RXLPITRCIM_Msk /* MMC Receive LPI transition counter interrupt Mask */
8093#define ETH_MMCRIMR_RXLPIUSCIM_Pos (26U)
8094#define ETH_MMCRIMR_RXLPIUSCIM_Msk (0x1UL << ETH_MMCRIMR_RXLPIUSCIM_Pos)
8095#define ETH_MMCRIMR_RXLPIUSCIM ETH_MMCRIMR_RXLPIUSCIM_Msk /* MMC Receive LPI microsecond counter interrupt Mask */
8096#define ETH_MMCRIMR_RXUCGPIM_Pos (17U)
8097#define ETH_MMCRIMR_RXUCGPIM_Msk (0x1UL << ETH_MMCRIMR_RXUCGPIM_Pos)
8098#define ETH_MMCRIMR_RXUCGPIM ETH_MMCRIMR_RXUCGPIM_Msk /* MMC Receive Unicast Good Packet Counter Interrupt Mask */
8099#define ETH_MMCRIMR_RXALGNERPIM_Pos (6U)
8100#define ETH_MMCRIMR_RXALGNERPIM_Msk (0x1UL << ETH_MMCRIMR_RXALGNERPIM_Pos)
8101#define ETH_MMCRIMR_RXALGNERPIM ETH_MMCRIMR_RXALGNERPIM_Msk /* MMC Receive Alignment Error Packet Counter Interrupt Mask */
8102#define ETH_MMCRIMR_RXCRCERPIM_Pos (5U)
8103#define ETH_MMCRIMR_RXCRCERPIM_Msk (0x1UL << ETH_MMCRIMR_RXCRCERPIM_Pos)
8104#define ETH_MMCRIMR_RXCRCERPIM ETH_MMCRIMR_RXCRCERPIM_Msk /* MMC Receive CRC Error Packet Counter Interrupt Mask */
8105
8106/* Bit definition for Ethernet MMC Tx Interrupt Mask Register */
8107#define ETH_MMCTIMR_TXLPITRCIM_Pos (27U)
8108#define ETH_MMCTIMR_TXLPITRCIM_Msk (0x1UL << ETH_MMCTIMR_TXLPITRCIM_Pos)
8109#define ETH_MMCTIMR_TXLPITRCIM ETH_MMCTIMR_TXLPITRCIM_Msk /* MMC Transmit LPI transition counter interrupt Mask*/
8110#define ETH_MMCTIMR_TXLPIUSCIM_Pos (26U)
8111#define ETH_MMCTIMR_TXLPIUSCIM_Msk (0x1UL << ETH_MMCTIMR_TXLPIUSCIM_Pos)
8112#define ETH_MMCTIMR_TXLPIUSCIM ETH_MMCTIMR_TXLPIUSCIM_Msk /* MMC Transmit LPI microsecond counter interrupt Mask*/
8113#define ETH_MMCTIMR_TXGPKTIM_Pos (21U)
8114#define ETH_MMCTIMR_TXGPKTIM_Msk (0x1UL << ETH_MMCTIMR_TXGPKTIM_Pos)
8115#define ETH_MMCTIMR_TXGPKTIM ETH_MMCTIMR_TXGPKTIM_Msk /* MMC Transmit Good Packet Counter Interrupt Mask*/
8116#define ETH_MMCTIMR_TXMCOLGPIM_Pos (15U)
8117#define ETH_MMCTIMR_TXMCOLGPIM_Msk (0x1UL << ETH_MMCTIMR_TXMCOLGPIM_Pos)
8118#define ETH_MMCTIMR_TXMCOLGPIM ETH_MMCTIMR_TXMCOLGPIM_Msk /* MMC Transmit Multiple Collision Good Packet Counter Interrupt Mask */
8119#define ETH_MMCTIMR_TXSCOLGPIM_Pos (14U)
8120#define ETH_MMCTIMR_TXSCOLGPIM_Msk (0x1UL << ETH_MMCTIMR_TXSCOLGPIM_Pos)
8121#define ETH_MMCTIMR_TXSCOLGPIM ETH_MMCTIMR_TXSCOLGPIM_Msk /* MMC Transmit Single Collision Good Packet Counter Interrupt Mask */
8122
8123/* Bit definition for Ethernet MMC Tx Single Collision Good Packets Register */
8124#define ETH_MMCTSCGPR_TXSNGLCOLG_Pos (0U)
8125#define ETH_MMCTSCGPR_TXSNGLCOLG_msk (0xFFFFFFFFUL << ETH_MMCTSCGPR_TXSNGLCOLG_Pos)
8126#define ETH_MMCTSCGPR_TXSNGLCOLG ETH_MMCTSCGPR_TXSNGLCOLG_msk /* Tx Single Collision Good Packets */
8127
8128/* Bit definition for Ethernet MMC Tx Multiple Collision Good Packets Register */
8129#define ETH_MMCTMCGPR_TXMULTCOLG_Pos (0U)
8130#define ETH_MMCTMCGPR_TXMULTCOLG_msk (0xFFFFFFFFUL << ETH_MMCTMCGPR_TXMULTCOLG_Pos)
8131#define ETH_MMCTMCGPR_TXMULTCOLG ETH_MMCTMCGPR_TXMULTCOLG_msk /* Tx Multiple Collision Good Packets */
8132
8133/* Bit definition for Ethernet MMC Tx Packet Count Good Register */
8134#define ETH_MMCTPCGR_TXPKTG_Pos (0U)
8135#define ETH_MMCTPCGR_TXPKTG_msk (0xFFFFFFFFUL << ETH_MMCTPCGR_TXPKTG_Pos)
8136#define ETH_MMCTPCGR_TXPKTG ETH_MMCTPCGR_TXPKTG_msk /* Tx Packet Count Good */
8137
8138/* Bit definition for Ethernet MMC Rx CRC Error Packets Register */
8139#define ETH_MMCRCRCEPR_RXCRCERR_Pos (0U)
8140#define ETH_MMCRCRCEPR_RXCRCERR_msk (0xFFFFFFFFUL << ETH_MMCRCRCEPR_RXCRCERR_Pos)
8141#define ETH_MMCRCRCEPR_RXCRCERR ETH_MMCRCRCEPR_RXCRCERR_msk /* Rx CRC Error Packets */
8142
8143/* Bit definition for Ethernet MMC Rx alignment error packets register */
8144#define ETH_MMCRAEPR_RXALGNERR_Pos (0U)
8145#define ETH_MMCRAEPR_RXALGNERR_msk (0xFFFFFFFFUL << ETH_MMCRAEPR_RXALGNERR_Pos)
8146#define ETH_MMCRAEPR_RXALGNERR ETH_MMCRAEPR_RXALGNERR_msk /* Rx Alignment Error Packets */
8147
8148/* Bit definition for Ethernet MMC Rx Unicast Packets Good Register */
8149#define ETH_MMCRUPGR_RXUCASTG_Pos (0U)
8150#define ETH_MMCRUPGR_RXUCASTG_msk (0xFFFFFFFFUL << ETH_MMCRUPGR_RXUCASTG_Pos)
8151#define ETH_MMCRUPGR_RXUCASTG ETH_MMCRUPGR_RXUCASTG_msk /* Rx Unicast Packets Good */
8152
8153/* Bit definition for Ethernet MMC Tx LPI Microsecond Timer Register */
8154#define ETH_MMCTLPIMSTR_TXLPIUSC_Pos (0U)
8155#define ETH_MMCTLPIMSTR_TXLPIUSC_msk (0xFFFFFFFFUL << ETH_MMCTLPIMSTR_TXLPIUSC_Pos)
8156#define ETH_MMCTLPIMSTR_TXLPIUSC ETH_MMCTLPIMSTR_TXLPIUSC_msk /* Tx LPI Microseconds Counter */
8157
8158/* Bit definition for Ethernet MMC Tx LPI Transition Counter Register */
8159#define ETH_MMCTLPITCR_TXLPITRC_Pos (0U)
8160#define ETH_MMCTLPITCR_TXLPITRC_msk (0xFFFFFFFFUL << ETH_MMCTLPITCR_TXLPITRC_Pos)
8161#define ETH_MMCTLPITCR_TXLPITRC ETH_MMCTLPITCR_TXLPITRC_msk /* Tx LPI Transition counter */
8162
8163/* Bit definition for Ethernet MMC Rx LPI Microsecond Counter Register */
8164#define ETH_MMCRLPIMSTR_RXLPIUSC_Pos (0U)
8165#define ETH_MMCRLPIMSTR_RXLPIUSC_msk (0xFFFFFFFFUL << ETH_MMCRLPIMSTR_RXLPIUSC_Pos)
8166#define ETH_MMCRLPIMSTR_RXLPIUSC ETH_MMCRLPIMSTR_RXLPIUSC_msk /* Rx LPI Microseconds Counter */
8167
8168/* Bit definition for Ethernet MMC Rx LPI Transition Counter Register */
8169#define ETH_MMCRLPITCR_RXLPITRC_Pos (0U)
8170#define ETH_MMCRLPITCR_RXLPITRC_msk (0xFFFFFFFFUL << ETH_MMCRLPITCR_RXLPITRC_Pos)
8171#define ETH_MMCRLPITCR_RXLPITRC ETH_MMCRLPITCR_RXLPITRC_msk /* Rx LPI Transition counter */
8172
8173/* Bit definition for Ethernet MAC L3 L4 Control Register */
8174#define ETH_MACL3L4CR_L4DPIM_Pos (21U)
8175#define ETH_MACL3L4CR_L4DPIM_Msk (0x1UL << ETH_MACL3L4CR_L4DPIM_Pos)
8176#define ETH_MACL3L4CR_L4DPIM ETH_MACL3L4CR_L4DPIM_Msk /* Layer 4 Destination Port Inverse Match Enable */
8177#define ETH_MACL3L4CR_L4DPM_Pos (20U)
8178#define ETH_MACL3L4CR_L4DPM_Msk (0x1UL << ETH_MACL3L4CR_L4DPM_Pos)
8179#define ETH_MACL3L4CR_L4DPM ETH_MACL3L4CR_L4DPM_Msk /* Layer 4 Destination Port Match Enable */
8180#define ETH_MACL3L4CR_L4SPIM_Pos (19U)
8181#define ETH_MACL3L4CR_L4SPIM_Msk (0x1UL << ETH_MACL3L4CR_L4SPIM_Pos)
8182#define ETH_MACL3L4CR_L4SPIM ETH_MACL3L4CR_L4SPIM_Msk /* Layer 4 Source Port Inverse Match Enable */
8183#define ETH_MACL3L4CR_L4SPM_Pos (18U)
8184#define ETH_MACL3L4CR_L4SPM_Msk (0x1UL << ETH_MACL3L4CR_L4SPM_Pos)
8185#define ETH_MACL3L4CR_L4SPM ETH_MACL3L4CR_L4SPM_Msk /* Layer 4 Source Port Match Enable */
8186#define ETH_MACL3L4CR_L4PEN_Pos (16U)
8187#define ETH_MACL3L4CR_L4PEN_Msk (0x1UL << ETH_MACL3L4CR_L4PEN_Pos)
8188#define ETH_MACL3L4CR_L4PEN ETH_MACL3L4CR_L4PEN_Msk /* Layer 4 Protocol Enable */
8189#define ETH_MACL3L4CR_L3HDBM_Pos (11U)
8190#define ETH_MACL3L4CR_L3HDBM_Msk (0x1FUL << ETH_MACL3L4CR_L3HDBM_Pos)
8191#define ETH_MACL3L4CR_L3HDBM ETH_MACL3L4CR_L3HDBM_Msk /* Layer 3 IP DA Higher Bits Match */
8192#define ETH_MACL3L4CR_L3HSBM_Pos (6U)
8193#define ETH_MACL3L4CR_L3HSBM_Msk (0x1FUL << ETH_MACL3L4CR_L3HSBM_Pos)
8194#define ETH_MACL3L4CR_L3HSBM ETH_MACL3L4CR_L3HSBM_Msk /* Layer 3 IP SA Higher Bits Match */
8195#define ETH_MACL3L4CR_L3DAIM_Pos (5U)
8196#define ETH_MACL3L4CR_L3DAIM_Msk (0x1UL << ETH_MACL3L4CR_L3DAIM_Pos)
8197#define ETH_MACL3L4CR_L3DAIM ETH_MACL3L4CR_L3DAIM_Msk /* Layer 3 IP DA Inverse Match Enable */
8198#define ETH_MACL3L4CR_L3DAM_Pos (4U)
8199#define ETH_MACL3L4CR_L3DAM_Msk (0x1UL << ETH_MACL3L4CR_L3DAM_Pos)
8200#define ETH_MACL3L4CR_L3DAM ETH_MACL3L4CR_L3DAM_Msk /* Layer 3 IP DA Match Enable */
8201#define ETH_MACL3L4CR_L3SAIM_Pos (3U)
8202#define ETH_MACL3L4CR_L3SAIM_Msk (0x1UL << ETH_MACL3L4CR_L3SAIM_Pos)
8203#define ETH_MACL3L4CR_L3SAIM ETH_MACL3L4CR_L3SAIM_Msk /* Layer 3 IP SA Inverse Match Enable */
8204#define ETH_MACL3L4CR_L3SAM_Pos (2U)
8205#define ETH_MACL3L4CR_L3SAM_Msk (0x1UL << ETH_MACL3L4CR_L3SAM_Pos)
8206#define ETH_MACL3L4CR_L3SAM ETH_MACL3L4CR_L3SAM_Msk /* Layer 3 IP SA Match Enable*/
8207#define ETH_MACL3L4CR_L3PEN_Pos (0U)
8208#define ETH_MACL3L4CR_L3PEN_Msk (0x1UL << ETH_MACL3L4CR_L3PEN_Pos)
8209#define ETH_MACL3L4CR_L3PEN ETH_MACL3L4CR_L3PEN_Msk /* Layer 3 Protocol Enable */
8210
8211/* Bit definition for Ethernet MAC L4 Address Register */
8212#define ETH_MACL4AR_L4DP_Pos (16U)
8213#define ETH_MACL4AR_L4DP_Msk (0xFFFFUL << ETH_MACL4AR_L4DP_Pos)
8214#define ETH_MACL4AR_L4DP ETH_MACL4AR_L4DP_Msk /* Layer 4 Destination Port Number Field */
8215#define ETH_MACL4AR_L4SP_Pos (0U)
8216#define ETH_MACL4AR_L4SP_Msk (0xFFFFUL << ETH_MACL4AR_L4SP_Pos)
8217#define ETH_MACL4AR_L4SP ETH_MACL4AR_L4SP_Msk /* Layer 4 Source Port Number Field */
8218
8219/* Bit definition for Ethernet MAC L3 Address0 Register */
8220#define ETH_MACL3A0R_L3A0_Pos (0U)
8221#define ETH_MACL3A0R_L3A0_Msk (0xFFFFFFFFUL << ETH_MACL3A0R_L3A0_Pos)
8222#define ETH_MACL3A0R_L3A0 ETH_MACL3A0R_L3A0_Msk /* Layer 3 Address 0 Field */
8223
8224/* Bit definition for Ethernet MAC L4 Address1 Register */
8225#define ETH_MACL3A1R_L3A1_Pos (0U)
8226#define ETH_MACL3A1R_L3A1_Msk (0xFFFFFFFFUL << ETH_MACL3A1R_L3A1_Pos)
8227#define ETH_MACL3A1R_L3A1 ETH_MACL3A1R_L3A1_Msk /* Layer 3 Address 1 Field */
8228
8229/* Bit definition for Ethernet MAC L4 Address2 Register */
8230#define ETH_MACL3A2R_L3A2_Pos (0U)
8231#define ETH_MACL3A2R_L3A2_Msk (0xFFFFFFFFUL << ETH_MACL3A2R_L3A2_Pos)
8232#define ETH_MACL3A2R_L3A2 ETH_MACL3A2R_L3A2_Msk /* Layer 3 Address 2 Field */
8233
8234/* Bit definition for Ethernet MAC L4 Address3 Register */
8235#define ETH_MACL3A3R_L3A3_Pos (0U)
8236#define ETH_MACL3A3R_L3A3_Msk (0xFFFFFFFFUL << ETH_MACL3A3R_L3A3_Pos)
8237#define ETH_MACL3A3R_L3A3 ETH_MACL3A3R_L3A3_Msk /* Layer 3 Address 3 Field */
8238
8239/* Bit definition for Ethernet MAC Timestamp Control Register */
8240#define ETH_MACTSCR_TXTSSTSM_Pos (24U)
8241#define ETH_MACTSCR_TXTSSTSM_Msk (0x1UL << ETH_MACTSCR_TXTSSTSM_Pos)
8242#define ETH_MACTSCR_TXTSSTSM ETH_MACTSCR_TXTSSTSM_Msk /* Transmit Timestamp Status Mode */
8243#define ETH_MACTSCR_CSC_Pos (19U)
8244#define ETH_MACTSCR_CSC_Msk (0x1UL << ETH_MACTSCR_CSC_Pos)
8245#define ETH_MACTSCR_CSC ETH_MACTSCR_CSC_Msk /* Enable checksum correction during OST for PTP over UDP/IPv4 packets */
8246#define ETH_MACTSCR_TSENMACADDR_Pos (18U)
8247#define ETH_MACTSCR_TSENMACADDR_Msk (0x1UL << ETH_MACTSCR_TSENMACADDR_Pos)
8248#define ETH_MACTSCR_TSENMACADDR ETH_MACTSCR_TSENMACADDR_Msk /* Enable MAC Address for PTP Packet Filtering */
8249#define ETH_MACTSCR_SNAPTYPSEL_Pos (16U)
8250#define ETH_MACTSCR_SNAPTYPSEL_Msk (0x3UL << ETH_MACTSCR_SNAPTYPSEL_Pos)
8251#define ETH_MACTSCR_SNAPTYPSEL ETH_MACTSCR_SNAPTYPSEL_Msk /* Select PTP packets for Taking Snapshots */
8252#define ETH_MACTSCR_TSMSTRENA_Pos (15U)
8253#define ETH_MACTSCR_TSMSTRENA_Msk (0x1UL << ETH_MACTSCR_TSMSTRENA_Pos)
8254#define ETH_MACTSCR_TSMSTRENA ETH_MACTSCR_TSMSTRENA_Msk /* Enable Snapshot for Messages Relevant to Master */
8255#define ETH_MACTSCR_TSEVNTENA_Pos (14U)
8256#define ETH_MACTSCR_TSEVNTENA_Msk (0x1UL << ETH_MACTSCR_TSEVNTENA_Pos)
8257#define ETH_MACTSCR_TSEVNTENA ETH_MACTSCR_TSEVNTENA_Msk /* Enable Timestamp Snapshot for Event Messages */
8258#define ETH_MACTSCR_TSIPV4ENA_Pos (13U)
8259#define ETH_MACTSCR_TSIPV4ENA_Msk (0x1UL << ETH_MACTSCR_TSIPV4ENA_Pos)
8260#define ETH_MACTSCR_TSIPV4ENA ETH_MACTSCR_TSIPV4ENA_Msk /* Enable Processing of PTP Packets Sent over IPv4-UDP */
8261#define ETH_MACTSCR_TSIPV6ENA_Pos (12U)
8262#define ETH_MACTSCR_TSIPV6ENA_Msk (0x1UL << ETH_MACTSCR_TSIPV6ENA_Pos)
8263#define ETH_MACTSCR_TSIPV6ENA ETH_MACTSCR_TSIPV6ENA_Msk /* Enable Processing of PTP Packets Sent over IPv6-UDP */
8264#define ETH_MACTSCR_TSIPENA_Pos (11U)
8265#define ETH_MACTSCR_TSIPENA_Msk (0x1UL << ETH_MACTSCR_TSIPENA_Pos)
8266#define ETH_MACTSCR_TSIPENA ETH_MACTSCR_TSIPENA_Msk /* Enable Processing of PTP over Ethernet Packets */
8267#define ETH_MACTSCR_TSVER2ENA_Pos (10U)
8268#define ETH_MACTSCR_TSVER2ENA_Msk (0x1UL << ETH_MACTSCR_TSVER2ENA_Pos)
8269#define ETH_MACTSCR_TSVER2ENA ETH_MACTSCR_TSVER2ENA_Msk /* Enable PTP Packet Processing for Version 2 Format */
8270#define ETH_MACTSCR_TSCTRLSSR_Pos (9U)
8271#define ETH_MACTSCR_TSCTRLSSR_Msk (0x1UL << ETH_MACTSCR_TSCTRLSSR_Pos)
8272#define ETH_MACTSCR_TSCTRLSSR ETH_MACTSCR_TSCTRLSSR_Msk /* Timestamp Digital or Binary Rollover Control */
8273#define ETH_MACTSCR_TSENALL_Pos (8U)
8274#define ETH_MACTSCR_TSENALL_Msk (0x1UL << ETH_MACTSCR_TSENALL_Pos)
8275#define ETH_MACTSCR_TSENALL ETH_MACTSCR_TSENALL_Msk /* Enable Timestamp for All Packets */
8276#define ETH_MACTSCR_TSADDREG_Pos (5U)
8277#define ETH_MACTSCR_TSADDREG_Msk (0x1UL << ETH_MACTSCR_TSADDREG_Pos)
8278#define ETH_MACTSCR_TSADDREG ETH_MACTSCR_TSADDREG_Msk /* Update Addend Register */
8279#define ETH_MACTSCR_TSUPDT_Pos (3U)
8280#define ETH_MACTSCR_TSUPDT_Msk (0x1UL << ETH_MACTSCR_TSUPDT_Pos)
8281#define ETH_MACTSCR_TSUPDT ETH_MACTSCR_TSUPDT_Msk /* Update Timestamp */
8282#define ETH_MACTSCR_TSINIT_Pos (2U)
8283#define ETH_MACTSCR_TSINIT_Msk (0x1UL << ETH_MACTSCR_TSINIT_Pos)
8284#define ETH_MACTSCR_TSINIT ETH_MACTSCR_TSINIT_Msk /* Initialize Timestamp */
8285#define ETH_MACTSCR_TSCFUPDT_Pos (1U)
8286#define ETH_MACTSCR_TSCFUPDT_Msk (0x1UL << ETH_MACTSCR_TSCFUPDT_Pos)
8287#define ETH_MACTSCR_TSCFUPDT ETH_MACTSCR_TSCFUPDT_Msk /* Fine or Coarse Timestamp Update*/
8288#define ETH_MACTSCR_TSENA_Pos (0U)
8289#define ETH_MACTSCR_TSENA_Msk (0x1UL << ETH_MACTSCR_TSENA_Pos)
8290#define ETH_MACTSCR_TSENA ETH_MACTSCR_TSENA_Msk /* Enable Timestamp */
8291
8292/* Bit definition for Ethernet MAC Sub-second Increment Register */
8293#define ETH_MACMACSSIR_SSINC_Pos (16U)
8294#define ETH_MACMACSSIR_SSINC_Msk (0xFFUL << ETH_MACMACSSIR_SSINC_Pos)
8295#define ETH_MACMACSSIR_SSINC ETH_MACMACSSIR_SSINC_Msk /* Sub-second Increment Value */
8296#define ETH_MACMACSSIR_SNSINC_Pos (8U)
8297#define ETH_MACMACSSIR_SNSINC_Msk (0xFFUL << ETH_MACMACSSIR_SNSINC_Pos)
8298#define ETH_MACMACSSIR_SNSINC ETH_MACMACSSIR_SNSINC_Msk /* Sub-nanosecond Increment Value */
8299
8300/* Bit definition for Ethernet MAC System Time Seconds Register */
8301#define ETH_MACSTSR_TSS_Pos (0U)
8302#define ETH_MACSTSR_TSS_Msk (0xFFFFFFFFUL << ETH_MACSTSR_TSS_Pos)
8303#define ETH_MACSTSR_TSS ETH_MACSTSR_TSS_Msk /* Timestamp Second */
8304
8305/* Bit definition for Ethernet MAC System Time Nanoseconds Register */
8306#define ETH_MACSTNR_TSSS_Pos (0U)
8307#define ETH_MACSTNR_TSSS_Msk (0x7FFFFFFFUL << ETH_MACSTNR_TSSS_Pos)
8308#define ETH_MACSTNR_TSSS ETH_MACSTNR_TSSS_Msk /* Timestamp Sub-seconds */
8309
8310/* Bit definition for Ethernet MAC System Time Seconds Update Register */
8311#define ETH_MACSTSUR_TSS_Pos (0U)
8312#define ETH_MACSTSUR_TSS_Msk (0xFFFFFFFFUL << ETH_MACSTSUR_TSS_Pos)
8313#define ETH_MACSTSUR_TSS ETH_MACSTSUR_TSS_Msk /* Timestamp Seconds */
8314
8315/* Bit definition for Ethernet MAC System Time Nanoseconds Update Register */
8316#define ETH_MACSTNUR_ADDSUB_Pos (31U)
8317#define ETH_MACSTNUR_ADDSUB_Msk (0x1UL << ETH_MACSTNUR_ADDSUB_Pos)
8318#define ETH_MACSTNUR_ADDSUB ETH_MACSTNUR_ADDSUB_Msk /* Add or Subtract Time */
8319#define ETH_MACSTNUR_TSSS_Pos (0U)
8320#define ETH_MACSTNUR_TSSS_Msk (0x7FFFFFFFUL << ETH_MACSTNUR_TSSS_Pos)
8321#define ETH_MACSTNUR_TSSS ETH_MACSTNUR_TSSS_Msk /* Timestamp Sub-seconds */
8322
8323/* Bit definition for Ethernet MAC Timestamp Addend Register */
8324#define ETH_MACTSAR_TSAR_Pos (0U)
8325#define ETH_MACTSAR_TSAR_Msk (0xFFFFFFFFUL << ETH_MACTSAR_TSAR_Pos)
8326#define ETH_MACTSAR_TSAR ETH_MACTSAR_TSAR_Msk /* Timestamp Addend Register */
8327
8328/* Bit definition for Ethernet MAC Timestamp Status Register */
8329#define ETH_MACTSSR_ATSNS_Pos (25U)
8330#define ETH_MACTSSR_ATSNS_Msk (0x1FUL << ETH_MACTSSR_ATSNS_Pos)
8331#define ETH_MACTSSR_ATSNS ETH_MACTSSR_ATSNS_Msk /* Number of Auxiliary Timestamp Snapshots */
8332#define ETH_MACTSSR_ATSSTM_Pos (24U)
8333#define ETH_MACTSSR_ATSSTM_Msk (0x1UL << ETH_MACTSSR_ATSSTM_Pos)
8334#define ETH_MACTSSR_ATSSTM ETH_MACTSSR_ATSSTM_Msk /* Auxiliary Timestamp Snapshot Trigger Missed */
8335#define ETH_MACTSSR_ATSSTN_Pos (16U)
8336#define ETH_MACTSSR_ATSSTN_Msk (0xFUL << ETH_MACTSSR_ATSSTN_Pos)
8337#define ETH_MACTSSR_ATSSTN ETH_MACTSSR_ATSSTN_Msk /* Auxiliary Timestamp Snapshot Trigger Identifier */
8338#define ETH_MACTSSR_TXTSSIS_Pos (15U)
8339#define ETH_MACTSSR_TXTSSIS_Msk (0x1UL << ETH_MACTSSR_TXTSSIS_Pos)
8340#define ETH_MACTSSR_TXTSSIS ETH_MACTSSR_TXTSSIS_Msk /* Tx Timestamp Status Interrupt Status */
8341#define ETH_MACTSSR_TSTRGTERR0_Pos (3U)
8342#define ETH_MACTSSR_TSTRGTERR0_Msk (0x1UL << ETH_MACTSSR_TSTRGTERR0_Pos)
8343#define ETH_MACTSSR_TSTRGTERR0 ETH_MACTSSR_TSTRGTERR0_Msk /* Timestamp Target Time Error */
8344#define ETH_MACTSSR_AUXTSTRIG_Pos (2U)
8345#define ETH_MACTSSR_AUXTSTRIG_Msk (0x1UL << ETH_MACTSSR_AUXTSTRIG_Pos)
8346#define ETH_MACTSSR_AUXTSTRIG ETH_MACTSSR_AUXTSTRIG_Msk /* Auxiliary Timestamp Trigger Snapshot*/
8347#define ETH_MACTSSR_TSTARGT0_Pos (1U)
8348#define ETH_MACTSSR_TSTARGT0_Msk (0x1UL << ETH_MACTSSR_TSTARGT0_Pos)
8349#define ETH_MACTSSR_TSTARGT0 ETH_MACTSSR_TSTARGT0_Msk /* Timestamp Target Time Reached */
8350#define ETH_MACTSSR_TSSOVF_Pos (0U)
8351#define ETH_MACTSSR_TSSOVF_Msk (0x1UL << ETH_MACTSSR_TSSOVF_Pos)
8352#define ETH_MACTSSR_TSSOVF ETH_MACTSSR_TSSOVF_Msk /* Timestamp Seconds Overflow */
8353
8354/* Bit definition for Ethernet MAC Tx Timestamp Status Nanoseconds Register */
8355#define ETH_MACTTSSNR_TXTSSMIS_Pos (31U)
8356#define ETH_MACTTSSNR_TXTSSMIS_Msk (0x1UL << ETH_MACTTSSNR_TXTSSMIS_Pos)
8357#define ETH_MACTTSSNR_TXTSSMIS ETH_MACTTSSNR_TXTSSMIS_Msk /* Transmit Timestamp Status Missed */
8358#define ETH_MACTTSSNR_TXTSSLO_Pos (0U)
8359#define ETH_MACTTSSNR_TXTSSLO_Msk (0x7FFFFFFFUL << ETH_MACTTSSNR_TXTSSLO_Pos)
8360#define ETH_MACTTSSNR_TXTSSLO ETH_MACTTSSNR_TXTSSLO_Msk /* Transmit Timestamp Status Low */
8361
8362/* Bit definition for Ethernet MAC Tx Timestamp Status Seconds Register */
8363#define ETH_MACTTSSSR_TXTSSHI_Pos (0U)
8364#define ETH_MACTTSSSR_TXTSSHI_Msk (0xFFFFFFFFUL << ETH_MACTTSSSR_TXTSSHI_Pos)
8365#define ETH_MACTTSSSR_TXTSSHI ETH_MACTTSSSR_TXTSSHI_Msk /* Transmit Timestamp Status High */
8366
8367/* Bit definition for Ethernet MAC Auxiliary Control Register*/
8368#define ETH_MACACR_ATSEN3_Pos (7U)
8369#define ETH_MACACR_ATSEN3_Msk (0x1UL << ETH_MACACR_ATSEN3_Pos)
8370#define ETH_MACACR_ATSEN3 ETH_MACACR_ATSEN3_Msk /* Auxiliary Snapshot 3 Enable */
8371#define ETH_MACACR_ATSEN2_Pos (6U)
8372#define ETH_MACACR_ATSEN2_Msk (0x1UL << ETH_MACACR_ATSEN2_Pos)
8373#define ETH_MACACR_ATSEN2 ETH_MACACR_ATSEN2_Msk /* Auxiliary Snapshot 2 Enable */
8374#define ETH_MACACR_ATSEN1_Pos (5U)
8375#define ETH_MACACR_ATSEN1_Msk (0x1UL << ETH_MACACR_ATSEN1_Pos)
8376#define ETH_MACACR_ATSEN1 ETH_MACACR_ATSEN1_Msk /* Auxiliary Snapshot 1 Enable */
8377#define ETH_MACACR_ATSEN0_Pos (4U)
8378#define ETH_MACACR_ATSEN0_Msk (0x1UL << ETH_MACACR_ATSEN0_Pos)
8379#define ETH_MACACR_ATSEN0 ETH_MACACR_ATSEN0_Msk /* Auxiliary Snapshot 0 Enable */
8380#define ETH_MACACR_ATSFC_Pos (0U)
8381#define ETH_MACACR_ATSFC_Msk (0x1UL << ETH_MACACR_ATSFC_Pos)
8382#define ETH_MACACR_ATSFC ETH_MACACR_ATSFC_Msk /* Auxiliary Snapshot FIFO Clear */
8383
8384/* Bit definition for Ethernet MAC Auxiliary Timestamp Nanoseconds Register */
8385#define ETH_MACATSNR_AUXTSLO_Pos (0U)
8386#define ETH_MACATSNR_AUXTSLO_Msk (0x7FFFFFFFUL << ETH_MACATSNR_AUXTSLO_Pos)
8387#define ETH_MACATSNR_AUXTSLO ETH_MACATSNR_AUXTSLO_Msk /* Auxiliary Timestamp */
8388
8389/* Bit definition for Ethernet MAC Auxiliary Timestamp Seconds Register */
8390#define ETH_MACATSSR_AUXTSHI_Pos (0U)
8391#define ETH_MACATSSR_AUXTSHI_Msk (0xFFFFFFFFUL << ETH_MACATSSR_AUXTSHI_Pos)
8392#define ETH_MACATSSR_AUXTSHI ETH_MACATSSR_AUXTSHI_Msk /* Auxiliary Timestamp */
8393
8394/* Bit definition for Ethernet MAC Timestamp Ingress Asymmetric Correction Register */
8395#define ETH_MACTSIACR_OSTIAC_Pos (0U)
8396#define ETH_MACTSIACR_OSTIAC_Msk (0xFFFFFFFFUL << ETH_MACTSIACR_OSTIAC_Pos)
8397#define ETH_MACTSIACR_OSTIAC ETH_MACTSIACR_OSTIAC_Msk /* One-Step Timestamp Ingress Asymmetry Correction */
8398
8399/* Bit definition for Ethernet MAC Timestamp Egress Asymmetric Correction Register */
8400#define ETH_MACTSEACR_OSTEAC_Pos (0U)
8401#define ETH_MACTSEACR_OSTEAC_Msk (0xFFFFFFFFUL << ETH_MACTSEACR_OSTEAC_Pos)
8402#define ETH_MACTSEACR_OSTEAC ETH_MACTSEACR_OSTEAC_Msk /* One-Step Timestamp Egress Asymmetry Correction */
8403
8404/* Bit definition for Ethernet MAC Timestamp Ingress Correction Nanosecond Register */
8405#define ETH_MACTSICNR_TSIC_Pos (0U)
8406#define ETH_MACTSICNR_TSIC_Msk (0xFFFFFFFFUL << ETH_MACTSICNR_TSIC_Pos)
8407#define ETH_MACTSICNR_TSIC ETH_MACTSICNR_TSIC_Msk /* Timestamp Ingress Correction */
8408
8409/* Bit definition for Ethernet MAC Timestamp Egress correction Nanosecond Register */
8410#define ETH_MACTSECNR_TSEC_Pos (0U)
8411#define ETH_MACTSECNR_TSEC_Msk (0xFFFFFFFFUL << ETH_MACTSECNR_TSEC_Pos)
8412#define ETH_MACTSECNR_TSEC ETH_MACTSECNR_TSEC_Msk /* Timestamp Egress Correction */
8413
8414/* Bit definition for Ethernet MAC PPS Control Register */
8415#define ETH_MACPPSCR_TRGTMODSEL0_Pos (5U)
8416#define ETH_MACPPSCR_TRGTMODSEL0_Msk (0x3UL << ETH_MACPPSCR_TRGTMODSEL0_Pos)
8417#define ETH_MACPPSCR_TRGTMODSEL0 ETH_MACPPSCR_TRGTMODSEL0_Msk /* Target Time Register Mode for PPS Output */
8418#define ETH_MACPPSCR_PPSEN0_Pos (4U)
8419#define ETH_MACPPSCR_PPSEN0_Msk (0x1UL << ETH_MACPPSCR_PPSEN0_Pos)
8420#define ETH_MACPPSCR_PPSEN0 ETH_MACPPSCR_PPSEN0_Msk /* Flexible PPS Output Mode Enable */
8421#define ETH_MACPPSCR_PPSCTRL_Pos (0U)
8422#define ETH_MACPPSCR_PPSCTRL_Msk (0xFUL << ETH_MACPPSCR_PPSCTRL_Pos)
8423#define ETH_MACPPSCR_PPSCTRL ETH_MACPPSCR_PPSCTRL_Msk /* PPS Output Frequency Control */
8424
8425/* Bit definition for Ethernet MAC PPS Target Time Seconds Register */
8426#define ETH_MACPPSTTSR_TSTRH0_Pos (0U)
8427#define ETH_MACPPSTTSR_TSTRH0_Msk (0xFFFFFFFFUL << ETH_MACPPSTTSR_TSTRH0_Pos)
8428#define ETH_MACPPSTTSR_TSTRH0 ETH_MACPPSTTSR_TSTRH0_Msk /* PPS Target Time Seconds Register */
8429
8430/* Bit definition for Ethernet MAC PPS Target Time Nanoseconds Register */
8431#define ETH_MACPPSTTNR_TRGTBUSY0_Pos (31U)
8432#define ETH_MACPPSTTNR_TRGTBUSY0_Msk (0x1UL << ETH_MACPPSTTNR_TRGTBUSY0_Pos)
8433#define ETH_MACPPSTTNR_TRGTBUSY0 ETH_MACPPSTTNR_TRGTBUSY0_Msk /* PPS Target Time Register Busy */
8434#define ETH_MACPPSTTNR_TTSL0_Pos (0U)
8435#define ETH_MACPPSTTNR_TTSL0_Msk (0x7FFFFFFFUL << ETH_MACPPSTTNR_TTSL0_Pos)
8436#define ETH_MACPPSTTNR_TTSL0 ETH_MACPPSTTNR_TTSL0_Msk /* Target Time Low for PPS Register */
8437
8438/* Bit definition for Ethernet MAC PPS Interval Register */
8439#define ETH_MACPPSIR_PPSINT0_Pos (0U)
8440#define ETH_MACPPSIR_PPSINT0_Msk (0xFFFFFFFFUL << ETH_MACPPSIR_PPSINT0_Pos)
8441#define ETH_MACPPSIR_PPSINT0 ETH_MACPPSIR_PPSINT0_Msk /* PPS Output Signal Interval */
8442
8443/* Bit definition for Ethernet MAC PPS Width Register */
8444#define ETH_MACPPSWR_PPSWIDTH0_Pos (0U)
8445#define ETH_MACPPSWR_PPSWIDTH0_Msk (0xFFFFFFFFUL << ETH_MACPPSWR_PPSWIDTH0_Pos)
8446#define ETH_MACPPSWR_PPSWIDTH0 ETH_MACPPSWR_PPSWIDTH0_Msk /* PPS Output Signal Width */
8447
8448/* Bit definition for Ethernet MAC PTP Offload Control Register */
8449#define ETH_MACPOCR_DN_Pos (8U)
8450#define ETH_MACPOCR_DN_Msk (0xFFUL << ETH_MACPOCR_DN_Pos)
8451#define ETH_MACPOCR_DN ETH_MACPOCR_DN_Msk /* Domain Number */
8452#define ETH_MACPOCR_DRRDIS_Pos (6U)
8453#define ETH_MACPOCR_DRRDIS_Msk (0x1UL << ETH_MACPOCR_DRRDIS_Pos)
8454#define ETH_MACPOCR_DRRDIS ETH_MACPOCR_DRRDIS_Msk /* Disable PTO Delay Request/Response response generation */
8455#define ETH_MACPOCR_APDREQTRIG_Pos (5U)
8456#define ETH_MACPOCR_APDREQTRIG_Msk (0x1UL << ETH_MACPOCR_APDREQTRIG_Pos)
8457#define ETH_MACPOCR_APDREQTRIG ETH_MACPOCR_APDREQTRIG_Msk /* Automatic PTP Pdelay_Req message Trigger */
8458#define ETH_MACPOCR_ASYNCTRIG_Pos (4U)
8459#define ETH_MACPOCR_ASYNCTRIG_Msk (0x1UL << ETH_MACPOCR_ASYNCTRIG_Pos)
8460#define ETH_MACPOCR_ASYNCTRIG ETH_MACPOCR_ASYNCTRIG_Msk /* Automatic PTP SYNC message Trigger */
8461#define ETH_MACPOCR_APDREQEN_Pos (2U)
8462#define ETH_MACPOCR_APDREQEN_Msk (0x1UL << ETH_MACPOCR_APDREQEN_Pos)
8463#define ETH_MACPOCR_APDREQEN ETH_MACPOCR_APDREQEN_Msk /* Automatic PTP Pdelay_Req message Enable */
8464#define ETH_MACPOCR_ASYNCEN_Pos (1U)
8465#define ETH_MACPOCR_ASYNCEN_Msk (0x1UL << ETH_MACPOCR_ASYNCEN_Pos)
8466#define ETH_MACPOCR_ASYNCEN ETH_MACPOCR_ASYNCEN_Msk /* Automatic PTP SYNC message Enable */
8467#define ETH_MACPOCR_PTOEN_Pos (0U)
8468#define ETH_MACPOCR_PTOEN_Msk (0x1UL << ETH_MACPOCR_PTOEN_Pos)
8469#define ETH_MACPOCR_PTOEN ETH_MACPOCR_PTOEN_Msk /* PTP Offload Enable */
8470
8471/* Bit definition for Ethernet MAC PTP Source Port Identity 0 Register */
8472#define ETH_MACSPI0R_SPI0_Pos (0U)
8473#define ETH_MACSPI0R_SPI0_Msk (0xFFFFFFFFUL << ETH_MACSPI0R_SPI0_Pos)
8474#define ETH_MACSPI0R_SPI0 ETH_MACSPI0R_SPI0_Msk /* Source Port Identity 0 */
8475
8476/* Bit definition for Ethernet MAC PTP Source Port Identity 1 Register */
8477#define ETH_MACSPI1R_SPI1_Pos (0U)
8478#define ETH_MACSPI1R_SPI1_Msk (0xFFFFFFFFUL << ETH_MACSPI1R_SPI1_Pos)
8479#define ETH_MACSPI1R_SPI1 ETH_MACSPI1R_SPI1_Msk /* Source Port Identity 1 */
8480
8481/* Bit definition for Ethernet MAC PTP Source Port Identity 2 Register */
8482#define ETH_MACSPI2R_SPI2_Pos (0U)
8483#define ETH_MACSPI2R_SPI2_Msk (0xFFFFUL << ETH_MACSPI2R_SPI2_Pos)
8484#define ETH_MACSPI2R_SPI2 ETH_MACSPI2R_SPI2_Msk /* Source Port Identity 2 */
8485
8486/* Bit definition for Ethernet MAC Log Message Interval Register */
8487#define ETH_MACLMIR_LMPDRI_Pos (24U)
8488#define ETH_MACLMIR_LMPDRI_Msk (0xFFUL << ETH_MACLMIR_LMPDRI_Pos)
8489#define ETH_MACLMIR_LMPDRI ETH_MACLMIR_LMPDRI_Msk /* Log Min Pdelay_Req Interval */
8490#define ETH_MACLMIR_DRSYNCR_Pos (8U)
8491#define ETH_MACLMIR_DRSYNCR_Msk (0x7UL << ETH_MACLMIR_DRSYNCR_Pos)
8492#define ETH_MACLMIR_DRSYNCR ETH_MACLMIR_DRSYNCR_Msk /* Delay_Req to SYNC Ratio */
8493#define ETH_MACLMIR_LSI_Pos (0U)
8494#define ETH_MACLMIR_LSI_Msk (0xFFUL << ETH_MACLMIR_LSI_Pos)
8495#define ETH_MACLMIR_LSI ETH_MACLMIR_LSI_Msk /* Log Sync Interval */
8496
8497/* Bit definition for Ethernet MTL Operation Mode Register */
8498#define ETH_MTLOMR_CNTCLR_Pos (9U)
8499#define ETH_MTLOMR_CNTCLR_Msk (0x1UL << ETH_MTLOMR_CNTCLR_Pos)
8500#define ETH_MTLOMR_CNTCLR ETH_MTLOMR_CNTCLR_Msk /* Counters Reset */
8501#define ETH_MTLOMR_CNTPRST_Pos (8U)
8502#define ETH_MTLOMR_CNTPRST_Msk (0x1UL << ETH_MTLOMR_CNTPRST_Pos)
8503#define ETH_MTLOMR_CNTPRST ETH_MTLOMR_CNTPRST_Msk /* Counters Preset */
8504#define ETH_MTLOMR_DTXSTS_Pos (1U)
8505#define ETH_MTLOMR_DTXSTS_Msk (0x1UL << ETH_MTLOMR_DTXSTS_Pos)
8506#define ETH_MTLOMR_DTXSTS ETH_MTLOMR_DTXSTS_Msk /* Drop Transmit Status */
8507
8508/* Bit definition for Ethernet MTL Interrupt Status Register */
8509#define ETH_MTLISR_MACIS_Pos (16U)
8510#define ETH_MTLISR_MACIS_Msk (0x1UL << ETH_MTLISR_MACIS_Pos)
8511#define ETH_MTLISR_MACIS ETH_MTLISR_MACIS_Msk /* MAC Interrupt Status */
8512#define ETH_MTLISR_QIS_Pos (0U)
8513#define ETH_MTLISR_QIS_Msk (0x1UL << ETH_MTLISR_QIS_Pos)
8514#define ETH_MTLISR_QIS ETH_MTLISR_QIS_Msk /* Queue Interrupt status */
8515
8516/* Bit definition for Ethernet MTL Tx Queue Operation Mode Register */
8517#define ETH_MTLTQOMR_TTC_Pos (4U)
8518#define ETH_MTLTQOMR_TTC_Msk (0x7UL << ETH_MTLTQOMR_TTC_Pos)
8519#define ETH_MTLTQOMR_TTC ETH_MTLTQOMR_TTC_Msk /* Transmit Threshold Control */
8520#define ETH_MTLTQOMR_TTC_32BITS (0U) /* 32 bits Threshold */
8521#define ETH_MTLTQOMR_TTC_64BITS (0x00000010U) /* 64 bits Threshold */
8522#define ETH_MTLTQOMR_TTC_96BITS (0x00000020U) /* 96 bits Threshold */
8523#define ETH_MTLTQOMR_TTC_128BITS (0x00000030U) /* 128 bits Threshold */
8524#define ETH_MTLTQOMR_TTC_192BITS (0x00000040U) /* 192 bits Threshold */
8525#define ETH_MTLTQOMR_TTC_256BITS (0x00000050U) /* 256 bits Threshold */
8526#define ETH_MTLTQOMR_TTC_384BITS (0x00000060U) /* 384 bits Threshold */
8527#define ETH_MTLTQOMR_TTC_512BITS (0x00000070U) /* 512 bits Threshold */
8528#define ETH_MTLTQOMR_TSF_Pos (1U)
8529#define ETH_MTLTQOMR_TSF_Msk (0x1UL << ETH_MTLTQOMR_TSF_Pos)
8530#define ETH_MTLTQOMR_TSF ETH_MTLTQOMR_TSF_Msk /* Transmit Store and Forward */
8531#define ETH_MTLTQOMR_FTQ_Pos (0U)
8532#define ETH_MTLTQOMR_FTQ_Msk (0x1UL << ETH_MTLTQOMR_FTQ_Pos)
8533#define ETH_MTLTQOMR_FTQ ETH_MTLTQOMR_FTQ_Msk /* Flush Transmit Queue */
8534
8535/* Bit definition for Ethernet MTL Tx Queue Underflow Register */
8536#define ETH_MTLTQUR_UFCNTOVF_Pos (11U)
8537#define ETH_MTLTQUR_UFCNTOVF_Msk (0x1UL << ETH_MTLTQUR_UFCNTOVF_Pos)
8538#define ETH_MTLTQUR_UFCNTOVF ETH_MTLTQUR_UFCNTOVF_Msk /* Overflow Bit for Underflow Packet Counter */
8539#define ETH_MTLTQUR_UFPKTCNT_Pos (0U)
8540#define ETH_MTLTQUR_UFPKTCNT_Msk (0x7FFUL << ETH_MTLTQUR_UFPKTCNT_Pos)
8541#define ETH_MTLTQUR_UFPKTCNT ETH_MTLTQUR_UFPKTCNT_Msk /* Underflow Packet Counter */
8542
8543/* Bit definition for Ethernet MTL Tx Queue Debug Register */
8544#define ETH_MTLTQDR_STXSTSF_Pos (20U)
8545#define ETH_MTLTQDR_STXSTSF_Msk (0x7UL << ETH_MTLTQDR_STXSTSF_Pos)
8546#define ETH_MTLTQDR_STXSTSF ETH_MTLTQDR_STXSTSF_Msk /* Number of Status Words in the Tx Status FIFO of Queue */
8547#define ETH_MTLTQDR_PTXQ_Pos (16U)
8548#define ETH_MTLTQDR_PTXQ_Msk (0x7UL << ETH_MTLTQDR_PTXQ_Pos)
8549#define ETH_MTLTQDR_PTXQ ETH_MTLTQDR_PTXQ_Msk /* Number of Packets in the Transmit Queue */
8550#define ETH_MTLTQDR_TXSTSFSTS_Pos (5U)
8551#define ETH_MTLTQDR_TXSTSFSTS_Msk (0x1UL << ETH_MTLTQDR_TXSTSFSTS_Pos)
8552#define ETH_MTLTQDR_TXSTSFSTS ETH_MTLTQDR_TXSTSFSTS_Msk /* MTL Tx Status FIFO Full Status */
8553#define ETH_MTLTQDR_TXQSTS_Pos (4U)
8554#define ETH_MTLTQDR_TXQSTS_Msk (0x1UL << ETH_MTLTQDR_TXQSTS_Pos)
8555#define ETH_MTLTQDR_TXQSTS ETH_MTLTQDR_TXQSTS_Msk /* MTL Tx Queue Not Empty Status */
8556#define ETH_MTLTQDR_TWCSTS_Pos (3U)
8557#define ETH_MTLTQDR_TWCSTS_Msk (0x1UL << ETH_MTLTQDR_TWCSTS_Pos)
8558#define ETH_MTLTQDR_TWCSTS ETH_MTLTQDR_TWCSTS_Msk /* MTL Tx Queue Write Controller Status */
8559#define ETH_MTLTQDR_TRCSTS_Pos (1U)
8560#define ETH_MTLTQDR_TRCSTS_Msk (0x3UL << ETH_MTLTQDR_TRCSTS_Pos)
8561#define ETH_MTLTQDR_TRCSTS ETH_MTLTQDR_TRCSTS_Msk /* MTL Tx Queue Read Controller Status */
8562#define ETH_MTLTQDR_TRCSTS_IDLE (0U) /* Idle state */
8563#define ETH_MTLTQDR_TRCSTS_READ (0x00000002U) /* Read state (transferring data to the MAC transmitter) */
8564#define ETH_MTLTQDR_TRCSTS_WAITING (0x00000004U) /* Waiting for pending Tx Status from the MAC transmitter */
8565#define ETH_MTLTQDR_TRCSTS_FLUSHING (0x00000006U) /* Flushing the Tx queue because of the Packet Abort request from the MAC */
8566#define ETH_MTLTQDR_TXQPAUSED_Pos (0U)
8567#define ETH_MTLTQDR_TXQPAUSED_Msk (0x1UL << ETH_MTLTQDR_TXQPAUSED_Pos)
8568#define ETH_MTLTQDR_TXQPAUSED ETH_MTLTQDR_TXQPAUSED_Msk /* Transmit Queue in Pause */
8569
8570/* Bit definition for Ethernet MTL Queue Interrupt Control Status Register */
8571#define ETH_MTLQICSR_RXOIE_Pos (24U)
8572#define ETH_MTLQICSR_RXOIE_Msk (0x1UL << ETH_MTLQICSR_RXOIE_Pos)
8573#define ETH_MTLQICSR_RXOIE ETH_MTLQICSR_RXOIE_Msk /* Receive Queue Overflow Interrupt Enable */
8574#define ETH_MTLQICSR_RXOVFIS_Pos (16U)
8575#define ETH_MTLQICSR_RXOVFIS_Msk (0x1UL << ETH_MTLQICSR_RXOVFIS_Pos)
8576#define ETH_MTLQICSR_RXOVFIS ETH_MTLQICSR_RXOVFIS_Msk /* Receive Queue Overflow Interrupt Status */
8577#define ETH_MTLQICSR_TXUIE_Pos (8U)
8578#define ETH_MTLQICSR_TXUIE_Msk (0x1UL << ETH_MTLQICSR_TXUIE_Pos)
8579#define ETH_MTLQICSR_TXUIE ETH_MTLQICSR_TXUIE_Msk /* Transmit Queue Underflow Interrupt Enable */
8580#define ETH_MTLQICSR_TXUNFIS_Pos (0U)
8581#define ETH_MTLQICSR_TXUNFIS_Msk (0x1UL << ETH_MTLQICSR_TXUNFIS_Pos)
8582#define ETH_MTLQICSR_TXUNFIS ETH_MTLQICSR_TXUNFIS_Msk /* Transmit Queue Underflow Interrupt Status */
8583
8584/* Bit definition for Ethernet MTL Rx Queue Operation Mode Register */
8585#define ETH_MTLRQOMR_RQS_Pos (20U)
8586#define ETH_MTLRQOMR_RQS_Msk (0x7UL << ETH_MTLRQOMR_RQS_Pos)
8587#define ETH_MTLRQOMR_RQS ETH_MTLRQOMR_RQS_Msk /* Receive Queue Size */
8588#define ETH_MTLRQOMR_RFD_Pos (14U)
8589#define ETH_MTLRQOMR_RFD_Msk (0x7UL << ETH_MTLRQOMR_RFD_Pos)
8590#define ETH_MTLRQOMR_RFD ETH_MTLRQOMR_RFD_Msk /* Threshold for Deactivating Flow Control (in half-duplex and full-duplex modes) */
8591#define ETH_MTLRQOMR_RFA_Pos (8U)
8592#define ETH_MTLRQOMR_RFA_Msk (0x7UL << ETH_MTLRQOMR_RFA_Pos)
8593#define ETH_MTLRQOMR_RFA ETH_MTLRQOMR_RFA_Msk /* Threshold for Activating Flow Control (in half-duplex and full-duplex */
8594#define ETH_MTLRQOMR_EHFC_Pos (7U)
8595#define ETH_MTLRQOMR_EHFC_Msk (0x1UL << ETH_MTLRQOMR_EHFC_Pos)
8596#define ETH_MTLRQOMR_EHFC ETH_MTLRQOMR_EHFC_Msk /* DEnable Hardware Flow Control */
8597#define ETH_MTLRQOMR_DISTCPEF_Pos (6U)
8598#define ETH_MTLRQOMR_DISTCPEF_Msk (0x1UL << ETH_MTLRQOMR_DISTCPEF_Pos)
8599#define ETH_MTLRQOMR_DISTCPEF ETH_MTLRQOMR_DISTCPEF_Msk /* Disable Dropping of TCP/IP Checksum Error Packets */
8600#define ETH_MTLRQOMR_RSF_Pos (5U)
8601#define ETH_MTLRQOMR_RSF_Msk (0x1UL << ETH_MTLRQOMR_RSF_Pos)
8602#define ETH_MTLRQOMR_RSF ETH_MTLRQOMR_RSF_Msk /* Receive Queue Store and Forward */
8603#define ETH_MTLRQOMR_FEP_Pos (4U)
8604#define ETH_MTLRQOMR_FEP_Msk (0x1UL << ETH_MTLRQOMR_FEP_Pos)
8605#define ETH_MTLRQOMR_FEP ETH_MTLRQOMR_FEP_Msk /* Forward Error Packets */
8606#define ETH_MTLRQOMR_FUP_Pos (3U)
8607#define ETH_MTLRQOMR_FUP_Msk (0x1UL << ETH_MTLRQOMR_FUP_Pos)
8608#define ETH_MTLRQOMR_FUP ETH_MTLRQOMR_FUP_Msk /* Forward Undersized Good Packets */
8609#define ETH_MTLRQOMR_RTC_Pos (0U)
8610#define ETH_MTLRQOMR_RTC_Msk (0x3UL << ETH_MTLRQOMR_RTC_Pos)
8611#define ETH_MTLRQOMR_RTC ETH_MTLRQOMR_RTC_Msk /* Receive Queue Threshold Control */
8612#define ETH_MTLRQOMR_RTC_64BITS (0U) /* 64 bits Threshold */
8613#define ETH_MTLRQOMR_RTC_32BITS (0x00000001U) /* 32 bits Threshold */
8614#define ETH_MTLRQOMR_RTC_96BITS (0x00000002U) /* 96 bits Threshold */
8615#define ETH_MTLRQOMR_RTC_128BITS (0x00000003U) /* 128 bits Threshold */
8616
8617/* Bit definition for Ethernet MTL Rx Queue Missed Packet Overflow Cnt Register */
8618#define ETH_MTLRQMPOCR_MISCNTOVF_Pos (27U)
8619#define ETH_MTLRQMPOCR_MISCNTOVF_Msk (0x1UL << ETH_MTLRQMPOCR_MISCNTOVF_Pos)
8620#define ETH_MTLRQMPOCR_MISCNTOVF ETH_MTLRQMPOCR_MISCNTOVF_Msk /* Missed Packet Counter Overflow Bit */
8621#define ETH_MTLRQMPOCR_MISPKTCNT_Pos (16U)
8622#define ETH_MTLRQMPOCR_MISPKTCNT_Msk (0x7FFUL << ETH_MTLRQMPOCR_MISPKTCNT_Pos)
8623#define ETH_MTLRQMPOCR_MISPKTCNT ETH_MTLRQMPOCR_MISPKTCNT_Msk /* Missed Packet Counter */
8624#define ETH_MTLRQMPOCR_OVFCNTOVF_Pos (11U)
8625#define ETH_MTLRQMPOCR_OVFCNTOVF_Msk (0x1UL << ETH_MTLRQMPOCR_OVFCNTOVF_Pos)
8626#define ETH_MTLRQMPOCR_OVFCNTOVF ETH_MTLRQMPOCR_OVFCNTOVF_Msk /* Overflow Counter Overflow Bit */
8627#define ETH_MTLRQMPOCR_OVFPKTCNT_Pos (0U)
8628#define ETH_MTLRQMPOCR_OVFPKTCNT_Msk (0x7FFUL << ETH_MTLRQMPOCR_OVFPKTCNT_Pos)
8629#define ETH_MTLRQMPOCR_OVFPKTCNT ETH_MTLRQMPOCR_OVFPKTCNT_Msk /* Overflow Packet Counter */
8630
8631/* Bit definition for Ethernet MTL Rx Queue Debug Register */
8632#define ETH_MTLRQDR_PRXQ_Pos (16U)
8633#define ETH_MTLRQDR_PRXQ_Msk (0x3FFFUL << ETH_MTLRQDR_PRXQ_Pos)
8634#define ETH_MTLRQDR_PRXQ ETH_MTLRQDR_PRXQ_Msk /* Number of Packets in Receive Queue */
8635#define ETH_MTLRQDR_RXQSTS_Pos (4U)
8636#define ETH_MTLRQDR_RXQSTS_Msk (0x3UL << ETH_MTLRQDR_RXQSTS_Pos)
8637#define ETH_MTLRQDR_RXQSTS ETH_MTLRQDR_RXQSTS_Msk /* MTL Rx Queue Fill-Level Status */
8638#define ETH_MTLRQDR_RXQSTS_EMPTY (0U) /* Rx Queue empty */
8639#define ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Pos (4U)
8640#define ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Msk (0x1UL << ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Pos)
8641#define ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Msk /* Rx Queue fill-level below flow-control deactivate threshold */
8642#define ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Pos (5U)
8643#define ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Msk (0x1UL << ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Pos)
8644#define ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Msk /* Rx Queue fill-level above flow-control activate threshold */
8645#define ETH_MTLRQDR_RXQSTS_FULL_Pos (4U)
8646#define ETH_MTLRQDR_RXQSTS_FULL_Msk (0x3UL << ETH_MTLRQDR_RXQSTS_FULL_Pos)
8647#define ETH_MTLRQDR_RXQSTS_FULL ETH_MTLRQDR_RXQSTS_FULL_Msk /* Rx Queue full */
8648#define ETH_MTLRQDR_RRCSTS_Pos (1U)
8649#define ETH_MTLRQDR_RRCSTS_Msk (0x3UL << ETH_MTLRQDR_RRCSTS_Pos)
8650#define ETH_MTLRQDR_RRCSTS ETH_MTLRQDR_RRCSTS_Msk /* MTL Rx Queue Read Controller State */
8651#define ETH_MTLRQDR_RRCSTS_IDLE (0U) /* Idle state */
8652#define ETH_MTLRQDR_RRCSTS_READINGDATA_Pos (1U)
8653#define ETH_MTLRQDR_RRCSTS_READINGDATA_Msk (0x1UL << ETH_MTLRQDR_RRCSTS_READINGDATA_Pos)
8654#define ETH_MTLRQDR_RRCSTS_READINGDATA ETH_MTLRQDR_RRCSTS_READINGDATA_Msk /* Reading packet data */
8655#define ETH_MTLRQDR_RRCSTS_READINGSTATUS_Pos (2U)
8656#define ETH_MTLRQDR_RRCSTS_READINGSTATUS_Msk (0x1UL << ETH_MTLRQDR_RRCSTS_READINGSTATUS_Pos)
8657#define ETH_MTLRQDR_RRCSTS_READINGSTATUS ETH_MTLRQDR_RRCSTS_READINGSTATUS_Msk /* Reading packet status (or timestamp) */
8658#define ETH_MTLRQDR_RRCSTS_FLUSHING_Pos (1U)
8659#define ETH_MTLRQDR_RRCSTS_FLUSHING_Msk (0x3UL << ETH_MTLRQDR_RRCSTS_FLUSHING_Pos)
8660#define ETH_MTLRQDR_RRCSTS_FLUSHING ETH_MTLRQDR_RRCSTS_FLUSHING_Msk /* Flushing the packet data and status */
8661#define ETH_MTLRQDR_RWCSTS_Pos (0U)
8662#define ETH_MTLRQDR_RWCSTS_Msk (0x1UL << ETH_MTLRQDR_RWCSTS_Pos)
8663#define ETH_MTLRQDR_RWCSTS ETH_MTLRQDR_RWCSTS_Msk /* MTL Rx Queue Write Controller Active Status */
8664
8665/* Bit definition for Ethernet MTL Rx Queue Control Register */
8666#define ETH_MTLRQCR_RQPA_Pos (3U)
8667#define ETH_MTLRQCR_RQPA_Msk (0x1UL << ETH_MTLRQCR_RQPA_Pos)
8668#define ETH_MTLRQCR_RQPA ETH_MTLRQCR_RQPA_Msk /* Receive Queue Packet Arbitration */
8669#define ETH_MTLRQCR_RQW_Pos (0U)
8670#define ETH_MTLRQCR_RQW_Msk (0x7UL << ETH_MTLRQCR_RQW_Pos)
8671#define ETH_MTLRQCR_RQW ETH_MTLRQCR_RQW_Msk /* Receive Queue Weight */
8672
8673/* Bit definition for Ethernet DMA Mode Register */
8674#define ETH_DMAMR_INTM_Pos (16U)
8675#define ETH_DMAMR_INTM_Msk (0x3UL << ETH_DMAMR_INTM_Pos)
8676#define ETH_DMAMR_INTM ETH_DMAMR_INTM_Msk /* This field defines the interrupt mode */
8677#define ETH_DMAMR_INTM_0 (0x0UL << ETH_DMAMR_INTM_Pos)
8678#define ETH_DMAMR_INTM_1 (0x1UL << ETH_DMAMR_INTM_Pos)
8679#define ETH_DMAMR_INTM_2 (0x2UL << ETH_DMAMR_INTM_Pos)
8680#define ETH_DMAMR_PR_Pos (12U)
8681#define ETH_DMAMR_PR_Msk (0x7UL << ETH_DMAMR_PR_Pos)
8682#define ETH_DMAMR_PR ETH_DMAMR_PR_Msk /* Priority Ratio */
8683#define ETH_DMAMR_PR_1_1 (0U) /* The priority ratio is 1:1 */
8684#define ETH_DMAMR_PR_2_1 (0x00001000U) /* The priority ratio is 2:1 */
8685#define ETH_DMAMR_PR_3_1 (0x00002000U) /* The priority ratio is 3:1 */
8686#define ETH_DMAMR_PR_4_1 (0x00003000U) /* The priority ratio is 4:1 */
8687#define ETH_DMAMR_PR_5_1 (0x00004000U) /* The priority ratio is 5:1 */
8688#define ETH_DMAMR_PR_6_1 (0x00005000U) /* The priority ratio is 6:1 */
8689#define ETH_DMAMR_PR_7_1 (0x00006000U) /* The priority ratio is 7:1 */
8690#define ETH_DMAMR_PR_8_1 (0x00007000U) /* The priority ratio is 8:1 */
8691#define ETH_DMAMR_TXPR_Pos (11U)
8692#define ETH_DMAMR_TXPR_Msk (0x1UL << ETH_DMAMR_TXPR_Pos)
8693#define ETH_DMAMR_TXPR ETH_DMAMR_TXPR_Msk /* Transmit Priority */
8694#define ETH_DMAMR_DA_Pos (1U)
8695#define ETH_DMAMR_DA_Msk (0x1UL << ETH_DMAMR_DA_Pos)
8696#define ETH_DMAMR_DA ETH_DMAMR_DA_Msk /* DMA Tx or Rx Arbitration Scheme */
8697#define ETH_DMAMR_SWR_Pos (0U)
8698#define ETH_DMAMR_SWR_Msk (0x1UL << ETH_DMAMR_SWR_Pos)
8699#define ETH_DMAMR_SWR ETH_DMAMR_SWR_Msk /* Software Reset */
8700
8701/* Bit definition for Ethernet DMA SysBus Mode Register */
8702#define ETH_DMASBMR_RB_Pos (15U)
8703#define ETH_DMASBMR_RB_Msk (0x1UL << ETH_DMASBMR_RB_Pos)
8704#define ETH_DMASBMR_RB ETH_DMASBMR_RB_Msk /* Rebuild INCRx Burst */
8705#define ETH_DMASBMR_MB_Pos (14U)
8706#define ETH_DMASBMR_MB_Msk (0x1UL << ETH_DMASBMR_MB_Pos)
8707#define ETH_DMASBMR_MB ETH_DMASBMR_MB_Msk /* Mixed Burst */
8708#define ETH_DMASBMR_AAL_Pos (12U)
8709#define ETH_DMASBMR_AAL_Msk (0x1UL << ETH_DMASBMR_AAL_Pos)
8710#define ETH_DMASBMR_AAL ETH_DMASBMR_AAL_Msk /* Address-Aligned Beats */
8711#define ETH_DMASBMR_FB_Pos (0U)
8712#define ETH_DMASBMR_FB_Msk (0x1UL << ETH_DMASBMR_FB_Pos)
8713#define ETH_DMASBMR_FB ETH_DMASBMR_FB_Msk /* Fixed Burst Length */
8714
8715/* Bit definition for Ethernet DMA Interrupt Status Register */
8716#define ETH_DMAISR_MACIS_Pos (17U)
8717#define ETH_DMAISR_MACIS_Msk (0x1UL << ETH_DMAISR_MACIS_Pos)
8718#define ETH_DMAISR_MACIS ETH_DMAISR_MACIS_Msk /* MAC Interrupt Status */
8719#define ETH_DMAISR_MTLIS_Pos (16U)
8720#define ETH_DMAISR_MTLIS_Msk (0x1UL << ETH_DMAISR_MTLIS_Pos)
8721#define ETH_DMAISR_MTLIS ETH_DMAISR_MTLIS_Msk /* MAC Interrupt Status */
8722#define ETH_DMAISR_DMACIS_Pos (0U)
8723#define ETH_DMAISR_DMACIS_Msk (0x1UL << ETH_DMAISR_DMACIS_Pos)
8724#define ETH_DMAISR_DMACIS ETH_DMAISR_DMACIS_Msk /* DMA Channel Interrupt Status */
8725
8726/* Bit definition for Ethernet DMA Debug Status Register */
8727#define ETH_DMADSR_TPS_Pos (12U)
8728#define ETH_DMADSR_TPS_Msk (0xFUL << ETH_DMADSR_TPS_Pos)
8729#define ETH_DMADSR_TPS ETH_DMADSR_TPS_Msk /* DMA Channel Transmit Process State */
8730#define ETH_DMADSR_TPS_STOPPED (0U) /* Stopped (Reset or Stop Transmit Command issued) */
8731#define ETH_DMADSR_TPS_FETCHING_Pos (12U)
8732#define ETH_DMADSR_TPS_FETCHING_Msk (0x1UL << ETH_DMADSR_TPS_FETCHING_Pos)
8733#define ETH_DMADSR_TPS_FETCHING ETH_DMADSR_TPS_FETCHING_Msk /* Running (Fetching Tx Transfer Descriptor) */
8734#define ETH_DMADSR_TPS_WAITING_Pos (13U)
8735#define ETH_DMADSR_TPS_WAITING_Msk (0x1UL << ETH_DMADSR_TPS_WAITING_Pos)
8736#define ETH_DMADSR_TPS_WAITING ETH_DMADSR_TPS_WAITING_Msk /* Running (Waiting for status) */
8737#define ETH_DMADSR_TPS_READING_Pos (12U)
8738#define ETH_DMADSR_TPS_READING_Msk (0x3UL << ETH_DMADSR_TPS_READING_Pos)
8739#define ETH_DMADSR_TPS_READING ETH_DMADSR_TPS_READING_Msk /* Running (Reading Data from system memory buffer and queuing it to the Tx buffer (Tx FIFO)) */
8740#define ETH_DMADSR_TPS_TIMESTAMP_WR_Pos (14U)
8741#define ETH_DMADSR_TPS_TIMESTAMP_WR_Msk (0x1UL << ETH_DMADSR_TPS_TIMESTAMP_WR_Pos)
8742#define ETH_DMADSR_TPS_TIMESTAMP_WR ETH_DMADSR_TPS_TIMESTAMP_WR_Msk /* Timestamp write state */
8743#define ETH_DMADSR_TPS_SUSPENDED_Pos (13U)
8744#define ETH_DMADSR_TPS_SUSPENDED_Msk (0x3UL << ETH_DMADSR_TPS_SUSPENDED_Pos)
8745#define ETH_DMADSR_TPS_SUSPENDED ETH_DMADSR_TPS_SUSPENDED_Msk /* Suspended (Tx Descriptor Unavailable or Tx Buffer Underflow) */
8746#define ETH_DMADSR_TPS_CLOSING_Pos (12U)
8747#define ETH_DMADSR_TPS_CLOSING_Msk (0x7UL << ETH_DMADSR_TPS_CLOSING_Pos)
8748#define ETH_DMADSR_TPS_CLOSING ETH_DMADSR_TPS_CLOSING_Msk /* Running (Closing Tx Descriptor) */
8749#define ETH_DMADSR_RPS_Pos (8U)
8750#define ETH_DMADSR_RPS_Msk (0xFUL << ETH_DMADSR_RPS_Pos)
8751#define ETH_DMADSR_RPS ETH_DMADSR_RPS_Msk /* DMA Channel Receive Process State */
8752#define ETH_DMADSR_RPS_STOPPED (0U) /* Stopped (Reset or Stop Receive Command issued) */
8753#define ETH_DMADSR_RPS_FETCHING_Pos (12U)
8754#define ETH_DMADSR_RPS_FETCHING_Msk (0x1UL << ETH_DMADSR_RPS_FETCHING_Pos)
8755#define ETH_DMADSR_RPS_FETCHING ETH_DMADSR_RPS_FETCHING_Msk /* Running (Fetching Rx Transfer Descriptor) */
8756#define ETH_DMADSR_RPS_WAITING_Pos (12U)
8757#define ETH_DMADSR_RPS_WAITING_Msk (0x3UL << ETH_DMADSR_RPS_WAITING_Pos)
8758#define ETH_DMADSR_RPS_WAITING ETH_DMADSR_RPS_WAITING_Msk /* Running (Waiting for status) */
8759#define ETH_DMADSR_RPS_SUSPENDED_Pos (14U)
8760#define ETH_DMADSR_RPS_SUSPENDED_Msk (0x1UL << ETH_DMADSR_RPS_SUSPENDED_Pos)
8761#define ETH_DMADSR_RPS_SUSPENDED ETH_DMADSR_RPS_SUSPENDED_Msk /* Suspended (Rx Descriptor Unavailable) */
8762#define ETH_DMADSR_RPS_CLOSING_Pos (12U)
8763#define ETH_DMADSR_RPS_CLOSING_Msk (0x5UL << ETH_DMADSR_RPS_CLOSING_Pos)
8764#define ETH_DMADSR_RPS_CLOSING ETH_DMADSR_RPS_CLOSING_Msk /* Running (Closing the Rx Descriptor) */
8765#define ETH_DMADSR_RPS_TIMESTAMP_WR_Pos (13U)
8766#define ETH_DMADSR_RPS_TIMESTAMP_WR_Msk (0x3UL << ETH_DMADSR_RPS_TIMESTAMP_WR_Pos)
8767#define ETH_DMADSR_RPS_TIMESTAMP_WR ETH_DMADSR_RPS_TIMESTAMP_WR_Msk /* Timestamp write state */
8768#define ETH_DMADSR_RPS_TRANSFERRING_Pos (12U)
8769#define ETH_DMADSR_RPS_TRANSFERRING_Msk (0x7UL << ETH_DMADSR_RPS_TRANSFERRING_Pos)
8770#define ETH_DMADSR_RPS_TRANSFERRING ETH_DMADSR_RPS_TRANSFERRING_Msk /* Running (Transferring the received packet data from the Rx buffer to the system memory) */
8771
8772/* Bit definition for Ethernet DMA Channel Control Register */
8773#define ETH_DMACCR_DSL_Pos (18U)
8774#define ETH_DMACCR_DSL_Msk (0x7UL << ETH_DMACCR_DSL_Pos)
8775#define ETH_DMACCR_DSL ETH_DMACCR_DSL_Msk /* Descriptor Skip Length */
8776#define ETH_DMACCR_DSL_0BIT (0U)
8777#define ETH_DMACCR_DSL_32BIT (0x00040000U)
8778#define ETH_DMACCR_DSL_64BIT (0x00080000U)
8779#define ETH_DMACCR_DSL_128BIT (0x00100000U)
8780#define ETH_DMACCR_8PBL (0x00010000U) /* 8xPBL mode */
8781#define ETH_DMACCR_MSS_Pos (0U)
8782#define ETH_DMACCR_MSS_Msk (0x3FFFUL << ETH_DMACCR_MSS_Pos)
8783#define ETH_DMACCR_MSS ETH_DMACCR_MSS_Msk /* Maximum Segment Size */
8784
8785/* Bit definition for Ethernet DMA Channel Tx Control Register */
8786#define ETH_DMACTCR_TPBL_Pos (16U)
8787#define ETH_DMACTCR_TPBL_Msk (0x3FUL << ETH_DMACTCR_TPBL_Pos)
8788#define ETH_DMACTCR_TPBL ETH_DMACTCR_TPBL_Msk /* Transmit Programmable Burst Length */
8789#define ETH_DMACTCR_TPBL_1PBL (0x00010000U) /* Transmit Programmable Burst Length 1 */
8790#define ETH_DMACTCR_TPBL_2PBL (0x00020000U) /* Transmit Programmable Burst Length 2 */
8791#define ETH_DMACTCR_TPBL_4PBL (0x00040000U) /* Transmit Programmable Burst Length 4 */
8792#define ETH_DMACTCR_TPBL_8PBL (0x00080000U) /* Transmit Programmable Burst Length 8 */
8793#define ETH_DMACTCR_TPBL_16PBL (0x00100000U) /* Transmit Programmable Burst Length 16 */
8794#define ETH_DMACTCR_TPBL_32PBL (0x00200000U) /* Transmit Programmable Burst Length 32 */
8795#define ETH_DMACTCR_TSE_Pos (12U)
8796#define ETH_DMACTCR_TSE_Msk (0x1UL << ETH_DMACTCR_TSE_Pos)
8797#define ETH_DMACTCR_TSE ETH_DMACTCR_TSE_Msk /* TCP Segmentation Enabled */
8798#define ETH_DMACTCR_OSP_Pos (4U)
8799#define ETH_DMACTCR_OSP_Msk (0x1UL << ETH_DMACTCR_OSP_Pos)
8800#define ETH_DMACTCR_OSP ETH_DMACTCR_OSP_Msk /* Operate on Second Packet */
8801#define ETH_DMACTCR_ST_Pos (0U)
8802#define ETH_DMACTCR_ST_Msk (0x1UL << ETH_DMACTCR_ST_Pos)
8803#define ETH_DMACTCR_ST ETH_DMACTCR_ST_Msk /* Start or Stop Transmission Command */
8804
8805/* Bit definition for Ethernet DMA Channel Rx Control Register */
8806#define ETH_DMACRCR_RPF_Pos (31U)
8807#define ETH_DMACRCR_RPF_Msk (0x1UL << ETH_DMACRCR_RPF_Pos)
8808#define ETH_DMACRCR_RPF ETH_DMACRCR_RPF_Msk /* Rx Packet Flush */
8809#define ETH_DMACRCR_RPBL_Pos (16U)
8810#define ETH_DMACRCR_RPBL_Msk (0x3FUL << ETH_DMACRCR_RPBL_Pos)
8811#define ETH_DMACRCR_RPBL ETH_DMACRCR_RPBL_Msk /* Receive Programmable Burst Length */
8812#define ETH_DMACRCR_RPBL_1PBL (0x00010000U) /* Receive Programmable Burst Length 1 */
8813#define ETH_DMACRCR_RPBL_2PBL (0x00020000U) /* Receive Programmable Burst Length 2 */
8814#define ETH_DMACRCR_RPBL_4PBL (0x00040000U) /* Receive Programmable Burst Length 4 */
8815#define ETH_DMACRCR_RPBL_8PBL (0x00080000U) /* Receive Programmable Burst Length 8 */
8816#define ETH_DMACRCR_RPBL_16PBL (0x00100000U) /* Receive Programmable Burst Length 16 */
8817#define ETH_DMACRCR_RPBL_32PBL (0x00200000U) /* Receive Programmable Burst Length 32 */
8818#define ETH_DMACRCR_RBSZ_Pos (1U)
8819#define ETH_DMACRCR_RBSZ_Msk (0x3FFFUL << ETH_DMACRCR_RBSZ_Pos)
8820#define ETH_DMACRCR_RBSZ ETH_DMACRCR_RBSZ_Msk /* Receive Buffer size */
8821#define ETH_DMACRCR_SR_Pos (0U)
8822#define ETH_DMACRCR_SR_Msk (0x1UL << ETH_DMACRCR_SR_Pos)
8823#define ETH_DMACRCR_SR ETH_DMACRCR_SR_Msk /* Start or Stop Receive */
8824
8825/* Bit definition for Ethernet DMA CH Tx Desc List Address Register */
8826#define ETH_DMACTDLAR_TDESLA_Pos (2U)
8827#define ETH_DMACTDLAR_TDESLA_Msk (0x3FFFFFFFUL << ETH_DMACTDLAR_TDESLA_Pos)
8828#define ETH_DMACTDLAR_TDESLA ETH_DMACTDLAR_TDESLA_Msk /* Start of Transmit List */
8829
8830/* Bit definition for Ethernet DMA CH Rx Desc List Address Register */
8831#define ETH_DMACRDLAR_RDESLA_Pos (2U)
8832#define ETH_DMACRDLAR_RDESLA_Msk (0x3FFFFFFFUL << ETH_DMACRDLAR_RDESLA_Pos)
8833#define ETH_DMACRDLAR_RDESLA ETH_DMACRDLAR_RDESLA_Msk /* Start of Receive List */
8834
8835/* Bit definition for Ethernet DMA CH Tx Desc Tail Pointer Register */
8836#define ETH_DMACTDTPR_TDT_Pos (2U)
8837#define ETH_DMACTDTPR_TDT_Msk (0x3FFFFFFFUL << ETH_DMACTDTPR_TDT_Pos)
8838#define ETH_DMACTDTPR_TDT ETH_DMACTDTPR_TDT_Msk /* Transmit Descriptor Tail Pointer */
8839
8840/* Bit definition for Ethernet DMA CH Rx Desc Tail Pointer Register */
8841#define ETH_DMACRDTPR_RDT_Pos (2U)
8842#define ETH_DMACRDTPR_RDT_Msk (0x3FFFFFFFUL << ETH_DMACRDTPR_RDT_Pos)
8843#define ETH_DMACRDTPR_RDT ETH_DMACRDTPR_RDT_Msk /* Receive Descriptor Tail Pointer */
8844
8845/* Bit definition for Ethernet DMA CH Tx Desc Ring Length Register */
8846#define ETH_DMACTDRLR_TDRL_Pos (0U)
8847#define ETH_DMACTDRLR_TDRL_Msk (0x3FFUL << ETH_DMACTDRLR_TDRL_Pos)
8848#define ETH_DMACTDRLR_TDRL ETH_DMACTDRLR_TDRL_Msk /* Transmit Descriptor Ring Length */
8849
8850/* Bit definition for Ethernet DMA CH Rx Desc Ring Length Register */
8851#define ETH_DMACRDRLR_RDRL_Pos (0U)
8852#define ETH_DMACRDRLR_RDRL_Msk (0x3FFUL << ETH_DMACRDRLR_RDRL_Pos)
8853#define ETH_DMACRDRLR_RDRL ETH_DMACRDRLR_RDRL_Msk /* Receive Descriptor Ring Length */
8854
8855/* Bit definition for Ethernet DMA Channel Interrupt Enable Register */
8856#define ETH_DMACIER_NIE_Pos (15U)
8857#define ETH_DMACIER_NIE_Msk (0x1UL << ETH_DMACIER_NIE_Pos)
8858#define ETH_DMACIER_NIE ETH_DMACIER_NIE_Msk /* Normal Interrupt Summary Enable */
8859#define ETH_DMACIER_AIE_Pos (14U)
8860#define ETH_DMACIER_AIE_Msk (0x1UL << ETH_DMACIER_AIE_Pos)
8861#define ETH_DMACIER_AIE ETH_DMACIER_AIE_Msk /* Abnormal Interrupt Summary Enable */
8862#define ETH_DMACIER_CDEE_Pos (13U)
8863#define ETH_DMACIER_CDEE_Msk (0x1UL << ETH_DMACIER_CDEE_Pos)
8864#define ETH_DMACIER_CDEE ETH_DMACIER_CDEE_Msk /* Context Descriptor Error Enable */
8865#define ETH_DMACIER_FBEE_Pos (12U)
8866#define ETH_DMACIER_FBEE_Msk (0x1UL << ETH_DMACIER_FBEE_Pos)
8867#define ETH_DMACIER_FBEE ETH_DMACIER_FBEE_Msk /* Fatal Bus Error Enable */
8868#define ETH_DMACIER_ERIE_Pos (11U)
8869#define ETH_DMACIER_ERIE_Msk (0x1UL << ETH_DMACIER_ERIE_Pos)
8870#define ETH_DMACIER_ERIE ETH_DMACIER_ERIE_Msk /* Early Receive Interrupt Enable */
8871#define ETH_DMACIER_ETIE_Pos (10U)
8872#define ETH_DMACIER_ETIE_Msk (0x1UL << ETH_DMACIER_ETIE_Pos)
8873#define ETH_DMACIER_ETIE ETH_DMACIER_ETIE_Msk /* Early Transmit Interrupt Enable */
8874#define ETH_DMACIER_RWTE_Pos (9U)
8875#define ETH_DMACIER_RWTE_Msk (0x1UL << ETH_DMACIER_RWTE_Pos)
8876#define ETH_DMACIER_RWTE ETH_DMACIER_RWTE_Msk /* Receive Watchdog Timeout Enable */
8877#define ETH_DMACIER_RSE_Pos (8U)
8878#define ETH_DMACIER_RSE_Msk (0x1UL << ETH_DMACIER_RSE_Pos)
8879#define ETH_DMACIER_RSE ETH_DMACIER_RSE_Msk /* Receive Stopped Enable */
8880#define ETH_DMACIER_RBUE_Pos (7U)
8881#define ETH_DMACIER_RBUE_Msk (0x1UL << ETH_DMACIER_RBUE_Pos)
8882#define ETH_DMACIER_RBUE ETH_DMACIER_RBUE_Msk /* Receive Buffer Unavailable Enable */
8883#define ETH_DMACIER_RIE_Pos (6U)
8884#define ETH_DMACIER_RIE_Msk (0x1UL << ETH_DMACIER_RIE_Pos)
8885#define ETH_DMACIER_RIE ETH_DMACIER_RIE_Msk /* Receive Interrupt Enable */
8886#define ETH_DMACIER_TBUE_Pos (2U)
8887#define ETH_DMACIER_TBUE_Msk (0x1UL << ETH_DMACIER_TBUE_Pos)
8888#define ETH_DMACIER_TBUE ETH_DMACIER_TBUE_Msk /* Transmit Buffer Unavailable Enable */
8889#define ETH_DMACIER_TXSE_Pos (1U)
8890#define ETH_DMACIER_TXSE_Msk (0x1UL << ETH_DMACIER_TXSE_Pos)
8891#define ETH_DMACIER_TXSE ETH_DMACIER_TXSE_Msk /* Transmit Stopped Enable */
8892#define ETH_DMACIER_TIE_Pos (0U)
8893#define ETH_DMACIER_TIE_Msk (0x1UL << ETH_DMACIER_TIE_Pos)
8894#define ETH_DMACIER_TIE ETH_DMACIER_TIE_Msk /* Transmit Interrupt Enable */
8895
8896/* Bit definition for Ethernet DMA Channel Rx Interrupt Watchdog Timer Register */
8897#define ETH_DMACRIWTR_RWT_Pos (0U)
8898#define ETH_DMACRIWTR_RWT_Msk (0xFFUL << ETH_DMACRIWTR_RWT_Pos)
8899#define ETH_DMACRIWTR_RWT ETH_DMACRIWTR_RWT_Msk /* Receive Interrupt Watchdog Timer Count */
8900
8901/* Bit definition for Ethernet DMA Channel Current App Tx Desc Register */
8902#define ETH_DMACCATDR_CURTDESAPTR_Pos (0U)
8903#define ETH_DMACCATDR_CURTDESAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCATDR_CURTDESAPTR_Pos)
8904#define ETH_DMACCATDR_CURTDESAPTR ETH_DMACCATDR_CURTDESAPTR_Msk /* Application Transmit Descriptor Address Pointer */
8905
8906/* Bit definition for Ethernet DMA Channel Current App Rx Desc Register */
8907#define ETH_DMACCARDR_CURRDESAPTR_Pos (0U)
8908#define ETH_DMACCARDR_CURRDESAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCARDR_CURRDESAPTR_Pos)
8909#define ETH_DMACCARDR_CURRDESAPTR ETH_DMACCARDR_CURRDESAPTR_Msk /* Application Receive Descriptor Address Pointer */
8910
8911/* Bit definition for Ethernet DMA Channel Current App Tx Buffer Register */
8912#define ETH_DMACCATBR_CURTBUFAPTR_Pos (0U)
8913#define ETH_DMACCATBR_CURTBUFAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCATBR_CURTBUFAPTR_Pos)
8914#define ETH_DMACCATBR_CURTBUFAPTR ETH_DMACCATBR_CURTBUFAPTR_Msk /* Application Transmit Buffer Address Pointer */
8915
8916/* Bit definition for Ethernet DMA Channel Current App Rx Buffer Register */
8917#define ETH_DMACCARBR_CURRBUFAPTR_Pos (0U)
8918#define ETH_DMACCARBR_CURRBUFAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCARBR_CURRBUFAPTR_Pos)
8919#define ETH_DMACCARBR_CURRBUFAPTR ETH_DMACCARBR_CURRBUFAPTR_Msk /* Application Receive Buffer Address Pointer */
8920
8921/* Bit definition for Ethernet DMA Channel Status Register */
8922#define ETH_DMACSR_REB_Pos (19U)
8923#define ETH_DMACSR_REB_Msk (0x7UL << ETH_DMACSR_REB_Pos)
8924#define ETH_DMACSR_REB ETH_DMACSR_REB_Msk /* Rx DMA Error Bits */
8925#define ETH_DMACSR_TEB_Pos (16U)
8926#define ETH_DMACSR_TEB_Msk (0x7UL << ETH_DMACSR_TEB_Pos)
8927#define ETH_DMACSR_TEB ETH_DMACSR_TEB_Msk /* Tx DMA Error Bits */
8928#define ETH_DMACSR_NIS_Pos (15U)
8929#define ETH_DMACSR_NIS_Msk (0x1UL << ETH_DMACSR_NIS_Pos)
8930#define ETH_DMACSR_NIS ETH_DMACSR_NIS_Msk /* Normal Interrupt Summary */
8931#define ETH_DMACSR_AIS_Pos (14U)
8932#define ETH_DMACSR_AIS_Msk (0x1UL << ETH_DMACSR_AIS_Pos)
8933#define ETH_DMACSR_AIS ETH_DMACSR_AIS_Msk /* Abnormal Interrupt Summary */
8934#define ETH_DMACSR_CDE_Pos (13U)
8935#define ETH_DMACSR_CDE_Msk (0x1UL << ETH_DMACSR_CDE_Pos)
8936#define ETH_DMACSR_CDE ETH_DMACSR_CDE_Msk /* Context Descriptor Error */
8937#define ETH_DMACSR_FBE_Pos (12U)
8938#define ETH_DMACSR_FBE_Msk (0x1UL << ETH_DMACSR_FBE_Pos)
8939#define ETH_DMACSR_FBE ETH_DMACSR_FBE_Msk /* Fatal Bus Error */
8940#define ETH_DMACSR_ERI_Pos (11U)
8941#define ETH_DMACSR_ERI_Msk (0x1UL << ETH_DMACSR_ERI_Pos)
8942#define ETH_DMACSR_ERI ETH_DMACSR_ERI_Msk /* Early Receive Interrupt */
8943#define ETH_DMACSR_ETI_Pos (10U)
8944#define ETH_DMACSR_ETI_Msk (0x1UL << ETH_DMACSR_ETI_Pos)
8945#define ETH_DMACSR_ETI ETH_DMACSR_ETI_Msk /* Early Transmit Interrupt */
8946#define ETH_DMACSR_RWT_Pos (9U)
8947#define ETH_DMACSR_RWT_Msk (0x1UL << ETH_DMACSR_RWT_Pos)
8948#define ETH_DMACSR_RWT ETH_DMACSR_RWT_Msk /* Receive Watchdog Timeout */
8949#define ETH_DMACSR_RPS_Pos (8U)
8950#define ETH_DMACSR_RPS_Msk (0x1UL << ETH_DMACSR_RPS_Pos)
8951#define ETH_DMACSR_RPS ETH_DMACSR_RPS_Msk /* Receive Process Stopped */
8952#define ETH_DMACSR_RBU_Pos (7U)
8953#define ETH_DMACSR_RBU_Msk (0x1UL << ETH_DMACSR_RBU_Pos)
8954#define ETH_DMACSR_RBU ETH_DMACSR_RBU_Msk /* Receive Buffer Unavailable */
8955#define ETH_DMACSR_RI_Pos (6U)
8956#define ETH_DMACSR_RI_Msk (0x1UL << ETH_DMACSR_RI_Pos)
8957#define ETH_DMACSR_RI ETH_DMACSR_RI_Msk /* Receive Interrupt */
8958#define ETH_DMACSR_TBU_Pos (2U)
8959#define ETH_DMACSR_TBU_Msk (0x1UL << ETH_DMACSR_TBU_Pos)
8960#define ETH_DMACSR_TBU ETH_DMACSR_TBU_Msk /* Transmit Buffer Unavailable */
8961#define ETH_DMACSR_TPS_Pos (1U)
8962#define ETH_DMACSR_TPS_Msk (0x1UL << ETH_DMACSR_TPS_Pos)
8963#define ETH_DMACSR_TPS ETH_DMACSR_TPS_Msk /* Transmit Process Stopped */
8964#define ETH_DMACSR_TI_Pos (0U)
8965#define ETH_DMACSR_TI_Msk (0x1UL << ETH_DMACSR_TI_Pos)
8966#define ETH_DMACSR_TI ETH_DMACSR_TI_Msk /* Transmit Interrupt */
8967
8968/* Bit definition for Ethernet DMA Channel missed frame count register */
8969#define ETH_DMACMFCR_MFCO_Pos (15U)
8970#define ETH_DMACMFCR_MFCO_Msk (0x1UL << ETH_DMACMFCR_MFCO_Pos)
8971#define ETH_DMACMFCR_MFCO ETH_DMACMFCR_MFCO_Msk /* Overflow status of the MFC Counter */
8972#define ETH_DMACMFCR_MFC_Pos (0U)
8973#define ETH_DMACMFCR_MFC_Msk (0x7FFUL << ETH_DMACMFCR_MFC_Pos)
8974#define ETH_DMACMFCR_MFC ETH_DMACMFCR_MFC_Msk /* The number of packet counters dropped by the DMA */
8975
8976/******************************************************************************/
8977/* */
8978/* DMA Controller */
8979/* */
8980/******************************************************************************/
8981/******************** Bits definition for DMA_SxCR register *****************/
8982#define DMA_SxCR_MBURST_Pos (23U)
8983#define DMA_SxCR_MBURST_Msk (0x3UL << DMA_SxCR_MBURST_Pos)
8984#define DMA_SxCR_MBURST DMA_SxCR_MBURST_Msk
8985#define DMA_SxCR_MBURST_0 (0x1UL << DMA_SxCR_MBURST_Pos)
8986#define DMA_SxCR_MBURST_1 (0x2UL << DMA_SxCR_MBURST_Pos)
8987#define DMA_SxCR_PBURST_Pos (21U)
8988#define DMA_SxCR_PBURST_Msk (0x3UL << DMA_SxCR_PBURST_Pos)
8989#define DMA_SxCR_PBURST DMA_SxCR_PBURST_Msk
8990#define DMA_SxCR_PBURST_0 (0x1UL << DMA_SxCR_PBURST_Pos)
8991#define DMA_SxCR_PBURST_1 (0x2UL << DMA_SxCR_PBURST_Pos)
8992#define DMA_SxCR_TRBUFF_Pos (20U)
8993#define DMA_SxCR_TRBUFF_Msk (0x1UL << DMA_SxCR_TRBUFF_Pos)
8994#define DMA_SxCR_TRBUFF DMA_SxCR_TRBUFF_Msk
8995#define DMA_SxCR_CT_Pos (19U)
8996#define DMA_SxCR_CT_Msk (0x1UL << DMA_SxCR_CT_Pos)
8997#define DMA_SxCR_CT DMA_SxCR_CT_Msk
8998#define DMA_SxCR_DBM_Pos (18U)
8999#define DMA_SxCR_DBM_Msk (0x1UL << DMA_SxCR_DBM_Pos)
9000#define DMA_SxCR_DBM DMA_SxCR_DBM_Msk
9001#define DMA_SxCR_PL_Pos (16U)
9002#define DMA_SxCR_PL_Msk (0x3UL << DMA_SxCR_PL_Pos)
9003#define DMA_SxCR_PL DMA_SxCR_PL_Msk
9004#define DMA_SxCR_PL_0 (0x1UL << DMA_SxCR_PL_Pos)
9005#define DMA_SxCR_PL_1 (0x2UL << DMA_SxCR_PL_Pos)
9006#define DMA_SxCR_PINCOS_Pos (15U)
9007#define DMA_SxCR_PINCOS_Msk (0x1UL << DMA_SxCR_PINCOS_Pos)
9008#define DMA_SxCR_PINCOS DMA_SxCR_PINCOS_Msk
9009#define DMA_SxCR_MSIZE_Pos (13U)
9010#define DMA_SxCR_MSIZE_Msk (0x3UL << DMA_SxCR_MSIZE_Pos)
9011#define DMA_SxCR_MSIZE DMA_SxCR_MSIZE_Msk
9012#define DMA_SxCR_MSIZE_0 (0x1UL << DMA_SxCR_MSIZE_Pos)
9013#define DMA_SxCR_MSIZE_1 (0x2UL << DMA_SxCR_MSIZE_Pos)
9014#define DMA_SxCR_PSIZE_Pos (11U)
9015#define DMA_SxCR_PSIZE_Msk (0x3UL << DMA_SxCR_PSIZE_Pos)
9016#define DMA_SxCR_PSIZE DMA_SxCR_PSIZE_Msk /*< Peripheral data size */
9017#define DMA_SxCR_PSIZE_0 (0x1UL << DMA_SxCR_PSIZE_Pos)
9018#define DMA_SxCR_PSIZE_1 (0x2UL << DMA_SxCR_PSIZE_Pos)
9019#define DMA_SxCR_MINC_Pos (10U)
9020#define DMA_SxCR_MINC_Msk (0x1UL << DMA_SxCR_MINC_Pos)
9021#define DMA_SxCR_MINC DMA_SxCR_MINC_Msk
9022#define DMA_SxCR_PINC_Pos (9U)
9023#define DMA_SxCR_PINC_Msk (0x1UL << DMA_SxCR_PINC_Pos)
9024#define DMA_SxCR_PINC DMA_SxCR_PINC_Msk
9025#define DMA_SxCR_CIRC_Pos (8U)
9026#define DMA_SxCR_CIRC_Msk (0x1UL << DMA_SxCR_CIRC_Pos)
9027#define DMA_SxCR_CIRC DMA_SxCR_CIRC_Msk
9028#define DMA_SxCR_DIR_Pos (6U)
9029#define DMA_SxCR_DIR_Msk (0x3UL << DMA_SxCR_DIR_Pos)
9030#define DMA_SxCR_DIR DMA_SxCR_DIR_Msk
9031#define DMA_SxCR_DIR_0 (0x1UL << DMA_SxCR_DIR_Pos)
9032#define DMA_SxCR_DIR_1 (0x2UL << DMA_SxCR_DIR_Pos)
9033#define DMA_SxCR_PFCTRL_Pos (5U)
9034#define DMA_SxCR_PFCTRL_Msk (0x1UL << DMA_SxCR_PFCTRL_Pos)
9035#define DMA_SxCR_PFCTRL DMA_SxCR_PFCTRL_Msk
9036#define DMA_SxCR_TCIE_Pos (4U)
9037#define DMA_SxCR_TCIE_Msk (0x1UL << DMA_SxCR_TCIE_Pos)
9038#define DMA_SxCR_TCIE DMA_SxCR_TCIE_Msk
9039#define DMA_SxCR_HTIE_Pos (3U)
9040#define DMA_SxCR_HTIE_Msk (0x1UL << DMA_SxCR_HTIE_Pos)
9041#define DMA_SxCR_HTIE DMA_SxCR_HTIE_Msk
9042#define DMA_SxCR_TEIE_Pos (2U)
9043#define DMA_SxCR_TEIE_Msk (0x1UL << DMA_SxCR_TEIE_Pos)
9044#define DMA_SxCR_TEIE DMA_SxCR_TEIE_Msk
9045#define DMA_SxCR_DMEIE_Pos (1U)
9046#define DMA_SxCR_DMEIE_Msk (0x1UL << DMA_SxCR_DMEIE_Pos)
9047#define DMA_SxCR_DMEIE DMA_SxCR_DMEIE_Msk
9048#define DMA_SxCR_EN_Pos (0U)
9049#define DMA_SxCR_EN_Msk (0x1UL << DMA_SxCR_EN_Pos)
9050#define DMA_SxCR_EN DMA_SxCR_EN_Msk
9052/******************** Bits definition for DMA_SxCNDTR register **************/
9053#define DMA_SxNDT_Pos (0U)
9054#define DMA_SxNDT_Msk (0xFFFFUL << DMA_SxNDT_Pos)
9055#define DMA_SxNDT DMA_SxNDT_Msk
9056#define DMA_SxNDT_0 (0x0001UL << DMA_SxNDT_Pos)
9057#define DMA_SxNDT_1 (0x0002UL << DMA_SxNDT_Pos)
9058#define DMA_SxNDT_2 (0x0004UL << DMA_SxNDT_Pos)
9059#define DMA_SxNDT_3 (0x0008UL << DMA_SxNDT_Pos)
9060#define DMA_SxNDT_4 (0x0010UL << DMA_SxNDT_Pos)
9061#define DMA_SxNDT_5 (0x0020UL << DMA_SxNDT_Pos)
9062#define DMA_SxNDT_6 (0x0040UL << DMA_SxNDT_Pos)
9063#define DMA_SxNDT_7 (0x0080UL << DMA_SxNDT_Pos)
9064#define DMA_SxNDT_8 (0x0100UL << DMA_SxNDT_Pos)
9065#define DMA_SxNDT_9 (0x0200UL << DMA_SxNDT_Pos)
9066#define DMA_SxNDT_10 (0x0400UL << DMA_SxNDT_Pos)
9067#define DMA_SxNDT_11 (0x0800UL << DMA_SxNDT_Pos)
9068#define DMA_SxNDT_12 (0x1000UL << DMA_SxNDT_Pos)
9069#define DMA_SxNDT_13 (0x2000UL << DMA_SxNDT_Pos)
9070#define DMA_SxNDT_14 (0x4000UL << DMA_SxNDT_Pos)
9071#define DMA_SxNDT_15 (0x8000UL << DMA_SxNDT_Pos)
9073/******************** Bits definition for DMA_SxFCR register ****************/
9074#define DMA_SxFCR_FEIE_Pos (7U)
9075#define DMA_SxFCR_FEIE_Msk (0x1UL << DMA_SxFCR_FEIE_Pos)
9076#define DMA_SxFCR_FEIE DMA_SxFCR_FEIE_Msk
9077#define DMA_SxFCR_FS_Pos (3U)
9078#define DMA_SxFCR_FS_Msk (0x7UL << DMA_SxFCR_FS_Pos)
9079#define DMA_SxFCR_FS DMA_SxFCR_FS_Msk
9080#define DMA_SxFCR_FS_0 (0x1UL << DMA_SxFCR_FS_Pos)
9081#define DMA_SxFCR_FS_1 (0x2UL << DMA_SxFCR_FS_Pos)
9082#define DMA_SxFCR_FS_2 (0x4UL << DMA_SxFCR_FS_Pos)
9083#define DMA_SxFCR_DMDIS_Pos (2U)
9084#define DMA_SxFCR_DMDIS_Msk (0x1UL << DMA_SxFCR_DMDIS_Pos)
9085#define DMA_SxFCR_DMDIS DMA_SxFCR_DMDIS_Msk
9086#define DMA_SxFCR_FTH_Pos (0U)
9087#define DMA_SxFCR_FTH_Msk (0x3UL << DMA_SxFCR_FTH_Pos)
9088#define DMA_SxFCR_FTH DMA_SxFCR_FTH_Msk
9089#define DMA_SxFCR_FTH_0 (0x1UL << DMA_SxFCR_FTH_Pos)
9090#define DMA_SxFCR_FTH_1 (0x2UL << DMA_SxFCR_FTH_Pos)
9092/******************** Bits definition for DMA_LISR register *****************/
9093#define DMA_LISR_TCIF3_Pos (27U)
9094#define DMA_LISR_TCIF3_Msk (0x1UL << DMA_LISR_TCIF3_Pos)
9095#define DMA_LISR_TCIF3 DMA_LISR_TCIF3_Msk
9096#define DMA_LISR_HTIF3_Pos (26U)
9097#define DMA_LISR_HTIF3_Msk (0x1UL << DMA_LISR_HTIF3_Pos)
9098#define DMA_LISR_HTIF3 DMA_LISR_HTIF3_Msk
9099#define DMA_LISR_TEIF3_Pos (25U)
9100#define DMA_LISR_TEIF3_Msk (0x1UL << DMA_LISR_TEIF3_Pos)
9101#define DMA_LISR_TEIF3 DMA_LISR_TEIF3_Msk
9102#define DMA_LISR_DMEIF3_Pos (24U)
9103#define DMA_LISR_DMEIF3_Msk (0x1UL << DMA_LISR_DMEIF3_Pos)
9104#define DMA_LISR_DMEIF3 DMA_LISR_DMEIF3_Msk
9105#define DMA_LISR_FEIF3_Pos (22U)
9106#define DMA_LISR_FEIF3_Msk (0x1UL << DMA_LISR_FEIF3_Pos)
9107#define DMA_LISR_FEIF3 DMA_LISR_FEIF3_Msk
9108#define DMA_LISR_TCIF2_Pos (21U)
9109#define DMA_LISR_TCIF2_Msk (0x1UL << DMA_LISR_TCIF2_Pos)
9110#define DMA_LISR_TCIF2 DMA_LISR_TCIF2_Msk
9111#define DMA_LISR_HTIF2_Pos (20U)
9112#define DMA_LISR_HTIF2_Msk (0x1UL << DMA_LISR_HTIF2_Pos)
9113#define DMA_LISR_HTIF2 DMA_LISR_HTIF2_Msk
9114#define DMA_LISR_TEIF2_Pos (19U)
9115#define DMA_LISR_TEIF2_Msk (0x1UL << DMA_LISR_TEIF2_Pos)
9116#define DMA_LISR_TEIF2 DMA_LISR_TEIF2_Msk
9117#define DMA_LISR_DMEIF2_Pos (18U)
9118#define DMA_LISR_DMEIF2_Msk (0x1UL << DMA_LISR_DMEIF2_Pos)
9119#define DMA_LISR_DMEIF2 DMA_LISR_DMEIF2_Msk
9120#define DMA_LISR_FEIF2_Pos (16U)
9121#define DMA_LISR_FEIF2_Msk (0x1UL << DMA_LISR_FEIF2_Pos)
9122#define DMA_LISR_FEIF2 DMA_LISR_FEIF2_Msk
9123#define DMA_LISR_TCIF1_Pos (11U)
9124#define DMA_LISR_TCIF1_Msk (0x1UL << DMA_LISR_TCIF1_Pos)
9125#define DMA_LISR_TCIF1 DMA_LISR_TCIF1_Msk
9126#define DMA_LISR_HTIF1_Pos (10U)
9127#define DMA_LISR_HTIF1_Msk (0x1UL << DMA_LISR_HTIF1_Pos)
9128#define DMA_LISR_HTIF1 DMA_LISR_HTIF1_Msk
9129#define DMA_LISR_TEIF1_Pos (9U)
9130#define DMA_LISR_TEIF1_Msk (0x1UL << DMA_LISR_TEIF1_Pos)
9131#define DMA_LISR_TEIF1 DMA_LISR_TEIF1_Msk
9132#define DMA_LISR_DMEIF1_Pos (8U)
9133#define DMA_LISR_DMEIF1_Msk (0x1UL << DMA_LISR_DMEIF1_Pos)
9134#define DMA_LISR_DMEIF1 DMA_LISR_DMEIF1_Msk
9135#define DMA_LISR_FEIF1_Pos (6U)
9136#define DMA_LISR_FEIF1_Msk (0x1UL << DMA_LISR_FEIF1_Pos)
9137#define DMA_LISR_FEIF1 DMA_LISR_FEIF1_Msk
9138#define DMA_LISR_TCIF0_Pos (5U)
9139#define DMA_LISR_TCIF0_Msk (0x1UL << DMA_LISR_TCIF0_Pos)
9140#define DMA_LISR_TCIF0 DMA_LISR_TCIF0_Msk
9141#define DMA_LISR_HTIF0_Pos (4U)
9142#define DMA_LISR_HTIF0_Msk (0x1UL << DMA_LISR_HTIF0_Pos)
9143#define DMA_LISR_HTIF0 DMA_LISR_HTIF0_Msk
9144#define DMA_LISR_TEIF0_Pos (3U)
9145#define DMA_LISR_TEIF0_Msk (0x1UL << DMA_LISR_TEIF0_Pos)
9146#define DMA_LISR_TEIF0 DMA_LISR_TEIF0_Msk
9147#define DMA_LISR_DMEIF0_Pos (2U)
9148#define DMA_LISR_DMEIF0_Msk (0x1UL << DMA_LISR_DMEIF0_Pos)
9149#define DMA_LISR_DMEIF0 DMA_LISR_DMEIF0_Msk
9150#define DMA_LISR_FEIF0_Pos (0U)
9151#define DMA_LISR_FEIF0_Msk (0x1UL << DMA_LISR_FEIF0_Pos)
9152#define DMA_LISR_FEIF0 DMA_LISR_FEIF0_Msk
9154/******************** Bits definition for DMA_HISR register *****************/
9155#define DMA_HISR_TCIF7_Pos (27U)
9156#define DMA_HISR_TCIF7_Msk (0x1UL << DMA_HISR_TCIF7_Pos)
9157#define DMA_HISR_TCIF7 DMA_HISR_TCIF7_Msk
9158#define DMA_HISR_HTIF7_Pos (26U)
9159#define DMA_HISR_HTIF7_Msk (0x1UL << DMA_HISR_HTIF7_Pos)
9160#define DMA_HISR_HTIF7 DMA_HISR_HTIF7_Msk
9161#define DMA_HISR_TEIF7_Pos (25U)
9162#define DMA_HISR_TEIF7_Msk (0x1UL << DMA_HISR_TEIF7_Pos)
9163#define DMA_HISR_TEIF7 DMA_HISR_TEIF7_Msk
9164#define DMA_HISR_DMEIF7_Pos (24U)
9165#define DMA_HISR_DMEIF7_Msk (0x1UL << DMA_HISR_DMEIF7_Pos)
9166#define DMA_HISR_DMEIF7 DMA_HISR_DMEIF7_Msk
9167#define DMA_HISR_FEIF7_Pos (22U)
9168#define DMA_HISR_FEIF7_Msk (0x1UL << DMA_HISR_FEIF7_Pos)
9169#define DMA_HISR_FEIF7 DMA_HISR_FEIF7_Msk
9170#define DMA_HISR_TCIF6_Pos (21U)
9171#define DMA_HISR_TCIF6_Msk (0x1UL << DMA_HISR_TCIF6_Pos)
9172#define DMA_HISR_TCIF6 DMA_HISR_TCIF6_Msk
9173#define DMA_HISR_HTIF6_Pos (20U)
9174#define DMA_HISR_HTIF6_Msk (0x1UL << DMA_HISR_HTIF6_Pos)
9175#define DMA_HISR_HTIF6 DMA_HISR_HTIF6_Msk
9176#define DMA_HISR_TEIF6_Pos (19U)
9177#define DMA_HISR_TEIF6_Msk (0x1UL << DMA_HISR_TEIF6_Pos)
9178#define DMA_HISR_TEIF6 DMA_HISR_TEIF6_Msk
9179#define DMA_HISR_DMEIF6_Pos (18U)
9180#define DMA_HISR_DMEIF6_Msk (0x1UL << DMA_HISR_DMEIF6_Pos)
9181#define DMA_HISR_DMEIF6 DMA_HISR_DMEIF6_Msk
9182#define DMA_HISR_FEIF6_Pos (16U)
9183#define DMA_HISR_FEIF6_Msk (0x1UL << DMA_HISR_FEIF6_Pos)
9184#define DMA_HISR_FEIF6 DMA_HISR_FEIF6_Msk
9185#define DMA_HISR_TCIF5_Pos (11U)
9186#define DMA_HISR_TCIF5_Msk (0x1UL << DMA_HISR_TCIF5_Pos)
9187#define DMA_HISR_TCIF5 DMA_HISR_TCIF5_Msk
9188#define DMA_HISR_HTIF5_Pos (10U)
9189#define DMA_HISR_HTIF5_Msk (0x1UL << DMA_HISR_HTIF5_Pos)
9190#define DMA_HISR_HTIF5 DMA_HISR_HTIF5_Msk
9191#define DMA_HISR_TEIF5_Pos (9U)
9192#define DMA_HISR_TEIF5_Msk (0x1UL << DMA_HISR_TEIF5_Pos)
9193#define DMA_HISR_TEIF5 DMA_HISR_TEIF5_Msk
9194#define DMA_HISR_DMEIF5_Pos (8U)
9195#define DMA_HISR_DMEIF5_Msk (0x1UL << DMA_HISR_DMEIF5_Pos)
9196#define DMA_HISR_DMEIF5 DMA_HISR_DMEIF5_Msk
9197#define DMA_HISR_FEIF5_Pos (6U)
9198#define DMA_HISR_FEIF5_Msk (0x1UL << DMA_HISR_FEIF5_Pos)
9199#define DMA_HISR_FEIF5 DMA_HISR_FEIF5_Msk
9200#define DMA_HISR_TCIF4_Pos (5U)
9201#define DMA_HISR_TCIF4_Msk (0x1UL << DMA_HISR_TCIF4_Pos)
9202#define DMA_HISR_TCIF4 DMA_HISR_TCIF4_Msk
9203#define DMA_HISR_HTIF4_Pos (4U)
9204#define DMA_HISR_HTIF4_Msk (0x1UL << DMA_HISR_HTIF4_Pos)
9205#define DMA_HISR_HTIF4 DMA_HISR_HTIF4_Msk
9206#define DMA_HISR_TEIF4_Pos (3U)
9207#define DMA_HISR_TEIF4_Msk (0x1UL << DMA_HISR_TEIF4_Pos)
9208#define DMA_HISR_TEIF4 DMA_HISR_TEIF4_Msk
9209#define DMA_HISR_DMEIF4_Pos (2U)
9210#define DMA_HISR_DMEIF4_Msk (0x1UL << DMA_HISR_DMEIF4_Pos)
9211#define DMA_HISR_DMEIF4 DMA_HISR_DMEIF4_Msk
9212#define DMA_HISR_FEIF4_Pos (0U)
9213#define DMA_HISR_FEIF4_Msk (0x1UL << DMA_HISR_FEIF4_Pos)
9214#define DMA_HISR_FEIF4 DMA_HISR_FEIF4_Msk
9216/******************** Bits definition for DMA_LIFCR register ****************/
9217#define DMA_LIFCR_CTCIF3_Pos (27U)
9218#define DMA_LIFCR_CTCIF3_Msk (0x1UL << DMA_LIFCR_CTCIF3_Pos)
9219#define DMA_LIFCR_CTCIF3 DMA_LIFCR_CTCIF3_Msk
9220#define DMA_LIFCR_CHTIF3_Pos (26U)
9221#define DMA_LIFCR_CHTIF3_Msk (0x1UL << DMA_LIFCR_CHTIF3_Pos)
9222#define DMA_LIFCR_CHTIF3 DMA_LIFCR_CHTIF3_Msk
9223#define DMA_LIFCR_CTEIF3_Pos (25U)
9224#define DMA_LIFCR_CTEIF3_Msk (0x1UL << DMA_LIFCR_CTEIF3_Pos)
9225#define DMA_LIFCR_CTEIF3 DMA_LIFCR_CTEIF3_Msk
9226#define DMA_LIFCR_CDMEIF3_Pos (24U)
9227#define DMA_LIFCR_CDMEIF3_Msk (0x1UL << DMA_LIFCR_CDMEIF3_Pos)
9228#define DMA_LIFCR_CDMEIF3 DMA_LIFCR_CDMEIF3_Msk
9229#define DMA_LIFCR_CFEIF3_Pos (22U)
9230#define DMA_LIFCR_CFEIF3_Msk (0x1UL << DMA_LIFCR_CFEIF3_Pos)
9231#define DMA_LIFCR_CFEIF3 DMA_LIFCR_CFEIF3_Msk
9232#define DMA_LIFCR_CTCIF2_Pos (21U)
9233#define DMA_LIFCR_CTCIF2_Msk (0x1UL << DMA_LIFCR_CTCIF2_Pos)
9234#define DMA_LIFCR_CTCIF2 DMA_LIFCR_CTCIF2_Msk
9235#define DMA_LIFCR_CHTIF2_Pos (20U)
9236#define DMA_LIFCR_CHTIF2_Msk (0x1UL << DMA_LIFCR_CHTIF2_Pos)
9237#define DMA_LIFCR_CHTIF2 DMA_LIFCR_CHTIF2_Msk
9238#define DMA_LIFCR_CTEIF2_Pos (19U)
9239#define DMA_LIFCR_CTEIF2_Msk (0x1UL << DMA_LIFCR_CTEIF2_Pos)
9240#define DMA_LIFCR_CTEIF2 DMA_LIFCR_CTEIF2_Msk
9241#define DMA_LIFCR_CDMEIF2_Pos (18U)
9242#define DMA_LIFCR_CDMEIF2_Msk (0x1UL << DMA_LIFCR_CDMEIF2_Pos)
9243#define DMA_LIFCR_CDMEIF2 DMA_LIFCR_CDMEIF2_Msk
9244#define DMA_LIFCR_CFEIF2_Pos (16U)
9245#define DMA_LIFCR_CFEIF2_Msk (0x1UL << DMA_LIFCR_CFEIF2_Pos)
9246#define DMA_LIFCR_CFEIF2 DMA_LIFCR_CFEIF2_Msk
9247#define DMA_LIFCR_CTCIF1_Pos (11U)
9248#define DMA_LIFCR_CTCIF1_Msk (0x1UL << DMA_LIFCR_CTCIF1_Pos)
9249#define DMA_LIFCR_CTCIF1 DMA_LIFCR_CTCIF1_Msk
9250#define DMA_LIFCR_CHTIF1_Pos (10U)
9251#define DMA_LIFCR_CHTIF1_Msk (0x1UL << DMA_LIFCR_CHTIF1_Pos)
9252#define DMA_LIFCR_CHTIF1 DMA_LIFCR_CHTIF1_Msk
9253#define DMA_LIFCR_CTEIF1_Pos (9U)
9254#define DMA_LIFCR_CTEIF1_Msk (0x1UL << DMA_LIFCR_CTEIF1_Pos)
9255#define DMA_LIFCR_CTEIF1 DMA_LIFCR_CTEIF1_Msk
9256#define DMA_LIFCR_CDMEIF1_Pos (8U)
9257#define DMA_LIFCR_CDMEIF1_Msk (0x1UL << DMA_LIFCR_CDMEIF1_Pos)
9258#define DMA_LIFCR_CDMEIF1 DMA_LIFCR_CDMEIF1_Msk
9259#define DMA_LIFCR_CFEIF1_Pos (6U)
9260#define DMA_LIFCR_CFEIF1_Msk (0x1UL << DMA_LIFCR_CFEIF1_Pos)
9261#define DMA_LIFCR_CFEIF1 DMA_LIFCR_CFEIF1_Msk
9262#define DMA_LIFCR_CTCIF0_Pos (5U)
9263#define DMA_LIFCR_CTCIF0_Msk (0x1UL << DMA_LIFCR_CTCIF0_Pos)
9264#define DMA_LIFCR_CTCIF0 DMA_LIFCR_CTCIF0_Msk
9265#define DMA_LIFCR_CHTIF0_Pos (4U)
9266#define DMA_LIFCR_CHTIF0_Msk (0x1UL << DMA_LIFCR_CHTIF0_Pos)
9267#define DMA_LIFCR_CHTIF0 DMA_LIFCR_CHTIF0_Msk
9268#define DMA_LIFCR_CTEIF0_Pos (3U)
9269#define DMA_LIFCR_CTEIF0_Msk (0x1UL << DMA_LIFCR_CTEIF0_Pos)
9270#define DMA_LIFCR_CTEIF0 DMA_LIFCR_CTEIF0_Msk
9271#define DMA_LIFCR_CDMEIF0_Pos (2U)
9272#define DMA_LIFCR_CDMEIF0_Msk (0x1UL << DMA_LIFCR_CDMEIF0_Pos)
9273#define DMA_LIFCR_CDMEIF0 DMA_LIFCR_CDMEIF0_Msk
9274#define DMA_LIFCR_CFEIF0_Pos (0U)
9275#define DMA_LIFCR_CFEIF0_Msk (0x1UL << DMA_LIFCR_CFEIF0_Pos)
9276#define DMA_LIFCR_CFEIF0 DMA_LIFCR_CFEIF0_Msk
9278/******************** Bits definition for DMA_HIFCR register ****************/
9279#define DMA_HIFCR_CTCIF7_Pos (27U)
9280#define DMA_HIFCR_CTCIF7_Msk (0x1UL << DMA_HIFCR_CTCIF7_Pos)
9281#define DMA_HIFCR_CTCIF7 DMA_HIFCR_CTCIF7_Msk
9282#define DMA_HIFCR_CHTIF7_Pos (26U)
9283#define DMA_HIFCR_CHTIF7_Msk (0x1UL << DMA_HIFCR_CHTIF7_Pos)
9284#define DMA_HIFCR_CHTIF7 DMA_HIFCR_CHTIF7_Msk
9285#define DMA_HIFCR_CTEIF7_Pos (25U)
9286#define DMA_HIFCR_CTEIF7_Msk (0x1UL << DMA_HIFCR_CTEIF7_Pos)
9287#define DMA_HIFCR_CTEIF7 DMA_HIFCR_CTEIF7_Msk
9288#define DMA_HIFCR_CDMEIF7_Pos (24U)
9289#define DMA_HIFCR_CDMEIF7_Msk (0x1UL << DMA_HIFCR_CDMEIF7_Pos)
9290#define DMA_HIFCR_CDMEIF7 DMA_HIFCR_CDMEIF7_Msk
9291#define DMA_HIFCR_CFEIF7_Pos (22U)
9292#define DMA_HIFCR_CFEIF7_Msk (0x1UL << DMA_HIFCR_CFEIF7_Pos)
9293#define DMA_HIFCR_CFEIF7 DMA_HIFCR_CFEIF7_Msk
9294#define DMA_HIFCR_CTCIF6_Pos (21U)
9295#define DMA_HIFCR_CTCIF6_Msk (0x1UL << DMA_HIFCR_CTCIF6_Pos)
9296#define DMA_HIFCR_CTCIF6 DMA_HIFCR_CTCIF6_Msk
9297#define DMA_HIFCR_CHTIF6_Pos (20U)
9298#define DMA_HIFCR_CHTIF6_Msk (0x1UL << DMA_HIFCR_CHTIF6_Pos)
9299#define DMA_HIFCR_CHTIF6 DMA_HIFCR_CHTIF6_Msk
9300#define DMA_HIFCR_CTEIF6_Pos (19U)
9301#define DMA_HIFCR_CTEIF6_Msk (0x1UL << DMA_HIFCR_CTEIF6_Pos)
9302#define DMA_HIFCR_CTEIF6 DMA_HIFCR_CTEIF6_Msk
9303#define DMA_HIFCR_CDMEIF6_Pos (18U)
9304#define DMA_HIFCR_CDMEIF6_Msk (0x1UL << DMA_HIFCR_CDMEIF6_Pos)
9305#define DMA_HIFCR_CDMEIF6 DMA_HIFCR_CDMEIF6_Msk
9306#define DMA_HIFCR_CFEIF6_Pos (16U)
9307#define DMA_HIFCR_CFEIF6_Msk (0x1UL << DMA_HIFCR_CFEIF6_Pos)
9308#define DMA_HIFCR_CFEIF6 DMA_HIFCR_CFEIF6_Msk
9309#define DMA_HIFCR_CTCIF5_Pos (11U)
9310#define DMA_HIFCR_CTCIF5_Msk (0x1UL << DMA_HIFCR_CTCIF5_Pos)
9311#define DMA_HIFCR_CTCIF5 DMA_HIFCR_CTCIF5_Msk
9312#define DMA_HIFCR_CHTIF5_Pos (10U)
9313#define DMA_HIFCR_CHTIF5_Msk (0x1UL << DMA_HIFCR_CHTIF5_Pos)
9314#define DMA_HIFCR_CHTIF5 DMA_HIFCR_CHTIF5_Msk
9315#define DMA_HIFCR_CTEIF5_Pos (9U)
9316#define DMA_HIFCR_CTEIF5_Msk (0x1UL << DMA_HIFCR_CTEIF5_Pos)
9317#define DMA_HIFCR_CTEIF5 DMA_HIFCR_CTEIF5_Msk
9318#define DMA_HIFCR_CDMEIF5_Pos (8U)
9319#define DMA_HIFCR_CDMEIF5_Msk (0x1UL << DMA_HIFCR_CDMEIF5_Pos)
9320#define DMA_HIFCR_CDMEIF5 DMA_HIFCR_CDMEIF5_Msk
9321#define DMA_HIFCR_CFEIF5_Pos (6U)
9322#define DMA_HIFCR_CFEIF5_Msk (0x1UL << DMA_HIFCR_CFEIF5_Pos)
9323#define DMA_HIFCR_CFEIF5 DMA_HIFCR_CFEIF5_Msk
9324#define DMA_HIFCR_CTCIF4_Pos (5U)
9325#define DMA_HIFCR_CTCIF4_Msk (0x1UL << DMA_HIFCR_CTCIF4_Pos)
9326#define DMA_HIFCR_CTCIF4 DMA_HIFCR_CTCIF4_Msk
9327#define DMA_HIFCR_CHTIF4_Pos (4U)
9328#define DMA_HIFCR_CHTIF4_Msk (0x1UL << DMA_HIFCR_CHTIF4_Pos)
9329#define DMA_HIFCR_CHTIF4 DMA_HIFCR_CHTIF4_Msk
9330#define DMA_HIFCR_CTEIF4_Pos (3U)
9331#define DMA_HIFCR_CTEIF4_Msk (0x1UL << DMA_HIFCR_CTEIF4_Pos)
9332#define DMA_HIFCR_CTEIF4 DMA_HIFCR_CTEIF4_Msk
9333#define DMA_HIFCR_CDMEIF4_Pos (2U)
9334#define DMA_HIFCR_CDMEIF4_Msk (0x1UL << DMA_HIFCR_CDMEIF4_Pos)
9335#define DMA_HIFCR_CDMEIF4 DMA_HIFCR_CDMEIF4_Msk
9336#define DMA_HIFCR_CFEIF4_Pos (0U)
9337#define DMA_HIFCR_CFEIF4_Msk (0x1UL << DMA_HIFCR_CFEIF4_Pos)
9338#define DMA_HIFCR_CFEIF4 DMA_HIFCR_CFEIF4_Msk
9340/****************** Bit definition for DMA_SxPAR register ********************/
9341#define DMA_SxPAR_PA_Pos (0U)
9342#define DMA_SxPAR_PA_Msk (0xFFFFFFFFUL << DMA_SxPAR_PA_Pos)
9343#define DMA_SxPAR_PA DMA_SxPAR_PA_Msk
9345/****************** Bit definition for DMA_SxM0AR register ********************/
9346#define DMA_SxM0AR_M0A_Pos (0U)
9347#define DMA_SxM0AR_M0A_Msk (0xFFFFFFFFUL << DMA_SxM0AR_M0A_Pos)
9348#define DMA_SxM0AR_M0A DMA_SxM0AR_M0A_Msk
9350/****************** Bit definition for DMA_SxM1AR register ********************/
9351#define DMA_SxM1AR_M1A_Pos (0U)
9352#define DMA_SxM1AR_M1A_Msk (0xFFFFFFFFUL << DMA_SxM1AR_M1A_Pos)
9353#define DMA_SxM1AR_M1A DMA_SxM1AR_M1A_Msk
9355/******************************************************************************/
9356/* */
9357/* DMAMUX Controller */
9358/* */
9359/******************************************************************************/
9360/******************** Bits definition for DMAMUX_CxCR register **************/
9361#define DMAMUX_CxCR_DMAREQ_ID_Pos (0U)
9362#define DMAMUX_CxCR_DMAREQ_ID_Msk (0xFFUL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9363#define DMAMUX_CxCR_DMAREQ_ID DMAMUX_CxCR_DMAREQ_ID_Msk
9364#define DMAMUX_CxCR_DMAREQ_ID_0 (0x01UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9365#define DMAMUX_CxCR_DMAREQ_ID_1 (0x02UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9366#define DMAMUX_CxCR_DMAREQ_ID_2 (0x04UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9367#define DMAMUX_CxCR_DMAREQ_ID_3 (0x08UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9368#define DMAMUX_CxCR_DMAREQ_ID_4 (0x10UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9369#define DMAMUX_CxCR_DMAREQ_ID_5 (0x20UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9370#define DMAMUX_CxCR_DMAREQ_ID_6 (0x40UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9371#define DMAMUX_CxCR_DMAREQ_ID_7 (0x80UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
9372#define DMAMUX_CxCR_SOIE_Pos (8U)
9373#define DMAMUX_CxCR_SOIE_Msk (0x1UL << DMAMUX_CxCR_SOIE_Pos)
9374#define DMAMUX_CxCR_SOIE DMAMUX_CxCR_SOIE_Msk
9375#define DMAMUX_CxCR_EGE_Pos (9U)
9376#define DMAMUX_CxCR_EGE_Msk (0x1UL << DMAMUX_CxCR_EGE_Pos)
9377#define DMAMUX_CxCR_EGE DMAMUX_CxCR_EGE_Msk
9378#define DMAMUX_CxCR_SE_Pos (16U)
9379#define DMAMUX_CxCR_SE_Msk (0x1UL << DMAMUX_CxCR_SE_Pos)
9380#define DMAMUX_CxCR_SE DMAMUX_CxCR_SE_Msk
9381#define DMAMUX_CxCR_SPOL_Pos (17U)
9382#define DMAMUX_CxCR_SPOL_Msk (0x3UL << DMAMUX_CxCR_SPOL_Pos)
9383#define DMAMUX_CxCR_SPOL DMAMUX_CxCR_SPOL_Msk
9384#define DMAMUX_CxCR_SPOL_0 (0x1UL << DMAMUX_CxCR_SPOL_Pos)
9385#define DMAMUX_CxCR_SPOL_1 (0x2UL << DMAMUX_CxCR_SPOL_Pos)
9386#define DMAMUX_CxCR_NBREQ_Pos (19U)
9387#define DMAMUX_CxCR_NBREQ_Msk (0x1FUL << DMAMUX_CxCR_NBREQ_Pos)
9388#define DMAMUX_CxCR_NBREQ DMAMUX_CxCR_NBREQ_Msk
9389#define DMAMUX_CxCR_NBREQ_0 (0x01UL << DMAMUX_CxCR_NBREQ_Pos)
9390#define DMAMUX_CxCR_NBREQ_1 (0x02UL << DMAMUX_CxCR_NBREQ_Pos)
9391#define DMAMUX_CxCR_NBREQ_2 (0x04UL << DMAMUX_CxCR_NBREQ_Pos)
9392#define DMAMUX_CxCR_NBREQ_3 (0x08UL << DMAMUX_CxCR_NBREQ_Pos)
9393#define DMAMUX_CxCR_NBREQ_4 (0x10UL << DMAMUX_CxCR_NBREQ_Pos)
9394#define DMAMUX_CxCR_SYNC_ID_Pos (24U)
9395#define DMAMUX_CxCR_SYNC_ID_Msk (0x1FUL << DMAMUX_CxCR_SYNC_ID_Pos)
9396#define DMAMUX_CxCR_SYNC_ID DMAMUX_CxCR_SYNC_ID_Msk
9397#define DMAMUX_CxCR_SYNC_ID_0 (0x01UL << DMAMUX_CxCR_SYNC_ID_Pos)
9398#define DMAMUX_CxCR_SYNC_ID_1 (0x02UL << DMAMUX_CxCR_SYNC_ID_Pos)
9399#define DMAMUX_CxCR_SYNC_ID_2 (0x04UL << DMAMUX_CxCR_SYNC_ID_Pos)
9400#define DMAMUX_CxCR_SYNC_ID_3 (0x08UL << DMAMUX_CxCR_SYNC_ID_Pos)
9401#define DMAMUX_CxCR_SYNC_ID_4 (0x10UL << DMAMUX_CxCR_SYNC_ID_Pos)
9403/******************** Bits definition for DMAMUX_CSR register **************/
9404#define DMAMUX_CSR_SOF0_Pos (0U)
9405#define DMAMUX_CSR_SOF0_Msk (0x1UL << DMAMUX_CSR_SOF0_Pos)
9406#define DMAMUX_CSR_SOF0 DMAMUX_CSR_SOF0_Msk
9407#define DMAMUX_CSR_SOF1_Pos (1U)
9408#define DMAMUX_CSR_SOF1_Msk (0x1UL << DMAMUX_CSR_SOF1_Pos)
9409#define DMAMUX_CSR_SOF1 DMAMUX_CSR_SOF1_Msk
9410#define DMAMUX_CSR_SOF2_Pos (2U)
9411#define DMAMUX_CSR_SOF2_Msk (0x1UL << DMAMUX_CSR_SOF2_Pos)
9412#define DMAMUX_CSR_SOF2 DMAMUX_CSR_SOF2_Msk
9413#define DMAMUX_CSR_SOF3_Pos (3U)
9414#define DMAMUX_CSR_SOF3_Msk (0x1UL << DMAMUX_CSR_SOF3_Pos)
9415#define DMAMUX_CSR_SOF3 DMAMUX_CSR_SOF3_Msk
9416#define DMAMUX_CSR_SOF4_Pos (4U)
9417#define DMAMUX_CSR_SOF4_Msk (0x1UL << DMAMUX_CSR_SOF4_Pos)
9418#define DMAMUX_CSR_SOF4 DMAMUX_CSR_SOF4_Msk
9419#define DMAMUX_CSR_SOF5_Pos (5U)
9420#define DMAMUX_CSR_SOF5_Msk (0x1UL << DMAMUX_CSR_SOF5_Pos)
9421#define DMAMUX_CSR_SOF5 DMAMUX_CSR_SOF5_Msk
9422#define DMAMUX_CSR_SOF6_Pos (6U)
9423#define DMAMUX_CSR_SOF6_Msk (0x1UL << DMAMUX_CSR_SOF6_Pos)
9424#define DMAMUX_CSR_SOF6 DMAMUX_CSR_SOF6_Msk
9425#define DMAMUX_CSR_SOF7_Pos (7U)
9426#define DMAMUX_CSR_SOF7_Msk (0x1UL << DMAMUX_CSR_SOF7_Pos)
9427#define DMAMUX_CSR_SOF7 DMAMUX_CSR_SOF7_Msk
9428#define DMAMUX_CSR_SOF8_Pos (8U)
9429#define DMAMUX_CSR_SOF8_Msk (0x1UL << DMAMUX_CSR_SOF8_Pos)
9430#define DMAMUX_CSR_SOF8 DMAMUX_CSR_SOF8_Msk
9431#define DMAMUX_CSR_SOF9_Pos (9U)
9432#define DMAMUX_CSR_SOF9_Msk (0x1UL << DMAMUX_CSR_SOF9_Pos)
9433#define DMAMUX_CSR_SOF9 DMAMUX_CSR_SOF9_Msk
9434#define DMAMUX_CSR_SOF10_Pos (10U)
9435#define DMAMUX_CSR_SOF10_Msk (0x1UL << DMAMUX_CSR_SOF10_Pos)
9436#define DMAMUX_CSR_SOF10 DMAMUX_CSR_SOF10_Msk
9437#define DMAMUX_CSR_SOF11_Pos (11U)
9438#define DMAMUX_CSR_SOF11_Msk (0x1UL << DMAMUX_CSR_SOF11_Pos)
9439#define DMAMUX_CSR_SOF11 DMAMUX_CSR_SOF11_Msk
9440#define DMAMUX_CSR_SOF12_Pos (12U)
9441#define DMAMUX_CSR_SOF12_Msk (0x1UL << DMAMUX_CSR_SOF12_Pos)
9442#define DMAMUX_CSR_SOF12 DMAMUX_CSR_SOF12_Msk
9443#define DMAMUX_CSR_SOF13_Pos (13U)
9444#define DMAMUX_CSR_SOF13_Msk (0x1UL << DMAMUX_CSR_SOF13_Pos)
9445#define DMAMUX_CSR_SOF13 DMAMUX_CSR_SOF13_Msk
9446#define DMAMUX_CSR_SOF14_Pos (14U)
9447#define DMAMUX_CSR_SOF14_Msk (0x1UL << DMAMUX_CSR_SOF14_Pos)
9448#define DMAMUX_CSR_SOF14 DMAMUX_CSR_SOF14_Msk
9449#define DMAMUX_CSR_SOF15_Pos (15U)
9450#define DMAMUX_CSR_SOF15_Msk (0x1UL << DMAMUX_CSR_SOF15_Pos)
9451#define DMAMUX_CSR_SOF15 DMAMUX_CSR_SOF15_Msk
9453/******************** Bits definition for DMAMUX_CFR register **************/
9454#define DMAMUX_CFR_CSOF0_Pos (0U)
9455#define DMAMUX_CFR_CSOF0_Msk (0x1UL << DMAMUX_CFR_CSOF0_Pos)
9456#define DMAMUX_CFR_CSOF0 DMAMUX_CFR_CSOF0_Msk
9457#define DMAMUX_CFR_CSOF1_Pos (1U)
9458#define DMAMUX_CFR_CSOF1_Msk (0x1UL << DMAMUX_CFR_CSOF1_Pos)
9459#define DMAMUX_CFR_CSOF1 DMAMUX_CFR_CSOF1_Msk
9460#define DMAMUX_CFR_CSOF2_Pos (2U)
9461#define DMAMUX_CFR_CSOF2_Msk (0x1UL << DMAMUX_CFR_CSOF2_Pos)
9462#define DMAMUX_CFR_CSOF2 DMAMUX_CFR_CSOF2_Msk
9463#define DMAMUX_CFR_CSOF3_Pos (3U)
9464#define DMAMUX_CFR_CSOF3_Msk (0x1UL << DMAMUX_CFR_CSOF3_Pos)
9465#define DMAMUX_CFR_CSOF3 DMAMUX_CFR_CSOF3_Msk
9466#define DMAMUX_CFR_CSOF4_Pos (4U)
9467#define DMAMUX_CFR_CSOF4_Msk (0x1UL << DMAMUX_CFR_CSOF4_Pos)
9468#define DMAMUX_CFR_CSOF4 DMAMUX_CFR_CSOF4_Msk
9469#define DMAMUX_CFR_CSOF5_Pos (5U)
9470#define DMAMUX_CFR_CSOF5_Msk (0x1UL << DMAMUX_CFR_CSOF5_Pos)
9471#define DMAMUX_CFR_CSOF5 DMAMUX_CFR_CSOF5_Msk
9472#define DMAMUX_CFR_CSOF6_Pos (6U)
9473#define DMAMUX_CFR_CSOF6_Msk (0x1UL << DMAMUX_CFR_CSOF6_Pos)
9474#define DMAMUX_CFR_CSOF6 DMAMUX_CFR_CSOF6_Msk
9475#define DMAMUX_CFR_CSOF7_Pos (7U)
9476#define DMAMUX_CFR_CSOF7_Msk (0x1UL << DMAMUX_CFR_CSOF7_Pos)
9477#define DMAMUX_CFR_CSOF7 DMAMUX_CFR_CSOF7_Msk
9478#define DMAMUX_CFR_CSOF8_Pos (8U)
9479#define DMAMUX_CFR_CSOF8_Msk (0x1UL << DMAMUX_CFR_CSOF8_Pos)
9480#define DMAMUX_CFR_CSOF8 DMAMUX_CFR_CSOF8_Msk
9481#define DMAMUX_CFR_CSOF9_Pos (9U)
9482#define DMAMUX_CFR_CSOF9_Msk (0x1UL << DMAMUX_CFR_CSOF9_Pos)
9483#define DMAMUX_CFR_CSOF9 DMAMUX_CFR_CSOF9_Msk
9484#define DMAMUX_CFR_CSOF10_Pos (10U)
9485#define DMAMUX_CFR_CSOF10_Msk (0x1UL << DMAMUX_CFR_CSOF10_Pos)
9486#define DMAMUX_CFR_CSOF10 DMAMUX_CFR_CSOF10_Msk
9487#define DMAMUX_CFR_CSOF11_Pos (11U)
9488#define DMAMUX_CFR_CSOF11_Msk (0x1UL << DMAMUX_CFR_CSOF11_Pos)
9489#define DMAMUX_CFR_CSOF11 DMAMUX_CFR_CSOF11_Msk
9490#define DMAMUX_CFR_CSOF12_Pos (12U)
9491#define DMAMUX_CFR_CSOF12_Msk (0x1UL << DMAMUX_CFR_CSOF12_Pos)
9492#define DMAMUX_CFR_CSOF12 DMAMUX_CFR_CSOF12_Msk
9493#define DMAMUX_CFR_CSOF13_Pos (13U)
9494#define DMAMUX_CFR_CSOF13_Msk (0x1UL << DMAMUX_CFR_CSOF13_Pos)
9495#define DMAMUX_CFR_CSOF13 DMAMUX_CFR_CSOF13_Msk
9496#define DMAMUX_CFR_CSOF14_Pos (14U)
9497#define DMAMUX_CFR_CSOF14_Msk (0x1UL << DMAMUX_CFR_CSOF14_Pos)
9498#define DMAMUX_CFR_CSOF14 DMAMUX_CFR_CSOF14_Msk
9499#define DMAMUX_CFR_CSOF15_Pos (15U)
9500#define DMAMUX_CFR_CSOF15_Msk (0x1UL << DMAMUX_CFR_CSOF15_Pos)
9501#define DMAMUX_CFR_CSOF15 DMAMUX_CFR_CSOF15_Msk
9503/******************** Bits definition for DMAMUX_RGxCR register ************/
9504#define DMAMUX_RGxCR_SIG_ID_Pos (0U)
9505#define DMAMUX_RGxCR_SIG_ID_Msk (0x1FUL << DMAMUX_RGxCR_SIG_ID_Pos)
9506#define DMAMUX_RGxCR_SIG_ID DMAMUX_RGxCR_SIG_ID_Msk
9507#define DMAMUX_RGxCR_SIG_ID_0 (0x01UL << DMAMUX_RGxCR_SIG_ID_Pos)
9508#define DMAMUX_RGxCR_SIG_ID_1 (0x02UL << DMAMUX_RGxCR_SIG_ID_Pos)
9509#define DMAMUX_RGxCR_SIG_ID_2 (0x04UL << DMAMUX_RGxCR_SIG_ID_Pos)
9510#define DMAMUX_RGxCR_SIG_ID_3 (0x08UL << DMAMUX_RGxCR_SIG_ID_Pos)
9511#define DMAMUX_RGxCR_SIG_ID_4 (0x10UL << DMAMUX_RGxCR_SIG_ID_Pos)
9512#define DMAMUX_RGxCR_OIE_Pos (8U)
9513#define DMAMUX_RGxCR_OIE_Msk (0x1UL << DMAMUX_RGxCR_OIE_Pos)
9514#define DMAMUX_RGxCR_OIE DMAMUX_RGxCR_OIE_Msk
9515#define DMAMUX_RGxCR_GE_Pos (16U)
9516#define DMAMUX_RGxCR_GE_Msk (0x1UL << DMAMUX_RGxCR_GE_Pos)
9517#define DMAMUX_RGxCR_GE DMAMUX_RGxCR_GE_Msk
9518#define DMAMUX_RGxCR_GPOL_Pos (17U)
9519#define DMAMUX_RGxCR_GPOL_Msk (0x3UL << DMAMUX_RGxCR_GPOL_Pos)
9520#define DMAMUX_RGxCR_GPOL DMAMUX_RGxCR_GPOL_Msk
9521#define DMAMUX_RGxCR_GPOL_0 (0x1UL << DMAMUX_RGxCR_GPOL_Pos)
9522#define DMAMUX_RGxCR_GPOL_1 (0x2UL << DMAMUX_RGxCR_GPOL_Pos)
9523#define DMAMUX_RGxCR_GNBREQ_Pos (19U)
9524#define DMAMUX_RGxCR_GNBREQ_Msk (0x1FUL << DMAMUX_RGxCR_GNBREQ_Pos)
9525#define DMAMUX_RGxCR_GNBREQ DMAMUX_RGxCR_GNBREQ_Msk
9526#define DMAMUX_RGxCR_GNBREQ_0 (0x01UL << DMAMUX_RGxCR_GNBREQ_Pos)
9527#define DMAMUX_RGxCR_GNBREQ_1 (0x02UL << DMAMUX_RGxCR_GNBREQ_Pos)
9528#define DMAMUX_RGxCR_GNBREQ_2 (0x04UL << DMAMUX_RGxCR_GNBREQ_Pos)
9529#define DMAMUX_RGxCR_GNBREQ_3 (0x08UL << DMAMUX_RGxCR_GNBREQ_Pos)
9530#define DMAMUX_RGxCR_GNBREQ_4 (0x10UL << DMAMUX_RGxCR_GNBREQ_Pos)
9532/******************** Bits definition for DMAMUX_RGSR register **************/
9533#define DMAMUX_RGSR_OF0_Pos (0U)
9534#define DMAMUX_RGSR_OF0_Msk (0x1UL << DMAMUX_RGSR_OF0_Pos)
9535#define DMAMUX_RGSR_OF0 DMAMUX_RGSR_OF0_Msk
9536#define DMAMUX_RGSR_OF1_Pos (1U)
9537#define DMAMUX_RGSR_OF1_Msk (0x1UL << DMAMUX_RGSR_OF1_Pos)
9538#define DMAMUX_RGSR_OF1 DMAMUX_RGSR_OF1_Msk
9539#define DMAMUX_RGSR_OF2_Pos (2U)
9540#define DMAMUX_RGSR_OF2_Msk (0x1UL << DMAMUX_RGSR_OF2_Pos)
9541#define DMAMUX_RGSR_OF2 DMAMUX_RGSR_OF2_Msk
9542#define DMAMUX_RGSR_OF3_Pos (3U)
9543#define DMAMUX_RGSR_OF3_Msk (0x1UL << DMAMUX_RGSR_OF3_Pos)
9544#define DMAMUX_RGSR_OF3 DMAMUX_RGSR_OF3_Msk
9545#define DMAMUX_RGSR_OF4_Pos (4U)
9546#define DMAMUX_RGSR_OF4_Msk (0x1UL << DMAMUX_RGSR_OF4_Pos)
9547#define DMAMUX_RGSR_OF4 DMAMUX_RGSR_OF4_Msk
9548#define DMAMUX_RGSR_OF5_Pos (5U)
9549#define DMAMUX_RGSR_OF5_Msk (0x1UL << DMAMUX_RGSR_OF5_Pos)
9550#define DMAMUX_RGSR_OF5 DMAMUX_RGSR_OF5_Msk
9551#define DMAMUX_RGSR_OF6_Pos (6U)
9552#define DMAMUX_RGSR_OF6_Msk (0x1UL << DMAMUX_RGSR_OF6_Pos)
9553#define DMAMUX_RGSR_OF6 DMAMUX_RGSR_OF6_Msk
9554#define DMAMUX_RGSR_OF7_Pos (7U)
9555#define DMAMUX_RGSR_OF7_Msk (0x1UL << DMAMUX_RGSR_OF7_Pos)
9556#define DMAMUX_RGSR_OF7 DMAMUX_RGSR_OF7_Msk
9558/******************** Bits definition for DMAMUX_RGCFR register **************/
9559#define DMAMUX_RGCFR_COF0_Pos (0U)
9560#define DMAMUX_RGCFR_COF0_Msk (0x1UL << DMAMUX_RGCFR_COF0_Pos)
9561#define DMAMUX_RGCFR_COF0 DMAMUX_RGCFR_COF0_Msk
9562#define DMAMUX_RGCFR_COF1_Pos (1U)
9563#define DMAMUX_RGCFR_COF1_Msk (0x1UL << DMAMUX_RGCFR_COF1_Pos)
9564#define DMAMUX_RGCFR_COF1 DMAMUX_RGCFR_COF1_Msk
9565#define DMAMUX_RGCFR_COF2_Pos (2U)
9566#define DMAMUX_RGCFR_COF2_Msk (0x1UL << DMAMUX_RGCFR_COF2_Pos)
9567#define DMAMUX_RGCFR_COF2 DMAMUX_RGCFR_COF2_Msk
9568#define DMAMUX_RGCFR_COF3_Pos (3U)
9569#define DMAMUX_RGCFR_COF3_Msk (0x1UL << DMAMUX_RGCFR_COF3_Pos)
9570#define DMAMUX_RGCFR_COF3 DMAMUX_RGCFR_COF3_Msk
9571#define DMAMUX_RGCFR_COF4_Pos (4U)
9572#define DMAMUX_RGCFR_COF4_Msk (0x1UL << DMAMUX_RGCFR_COF4_Pos)
9573#define DMAMUX_RGCFR_COF4 DMAMUX_RGCFR_COF4_Msk
9574#define DMAMUX_RGCFR_COF5_Pos (5U)
9575#define DMAMUX_RGCFR_COF5_Msk (0x1UL << DMAMUX_RGCFR_COF5_Pos)
9576#define DMAMUX_RGCFR_COF5 DMAMUX_RGCFR_COF5_Msk
9577#define DMAMUX_RGCFR_COF6_Pos (6U)
9578#define DMAMUX_RGCFR_COF6_Msk (0x1UL << DMAMUX_RGCFR_COF6_Pos)
9579#define DMAMUX_RGCFR_COF6 DMAMUX_RGCFR_COF6_Msk
9580#define DMAMUX_RGCFR_COF7_Pos (7U)
9581#define DMAMUX_RGCFR_COF7_Msk (0x1UL << DMAMUX_RGCFR_COF7_Pos)
9582#define DMAMUX_RGCFR_COF7 DMAMUX_RGCFR_COF7_Msk
9584/******************************************************************************/
9585/* */
9586/* AHB Master DMA2D Controller (DMA2D) */
9587/* */
9588/******************************************************************************/
9589
9590/******************** Bit definition for DMA2D_CR register ******************/
9591
9592#define DMA2D_CR_START_Pos (0U)
9593#define DMA2D_CR_START_Msk (0x1UL << DMA2D_CR_START_Pos)
9594#define DMA2D_CR_START DMA2D_CR_START_Msk
9595#define DMA2D_CR_SUSP_Pos (1U)
9596#define DMA2D_CR_SUSP_Msk (0x1UL << DMA2D_CR_SUSP_Pos)
9597#define DMA2D_CR_SUSP DMA2D_CR_SUSP_Msk
9598#define DMA2D_CR_ABORT_Pos (2U)
9599#define DMA2D_CR_ABORT_Msk (0x1UL << DMA2D_CR_ABORT_Pos)
9600#define DMA2D_CR_ABORT DMA2D_CR_ABORT_Msk
9601#define DMA2D_CR_LOM_Pos (6U)
9602#define DMA2D_CR_LOM_Msk (0x1UL << DMA2D_CR_LOM_Pos)
9603#define DMA2D_CR_LOM DMA2D_CR_LOM_Msk
9604#define DMA2D_CR_TEIE_Pos (8U)
9605#define DMA2D_CR_TEIE_Msk (0x1UL << DMA2D_CR_TEIE_Pos)
9606#define DMA2D_CR_TEIE DMA2D_CR_TEIE_Msk
9607#define DMA2D_CR_TCIE_Pos (9U)
9608#define DMA2D_CR_TCIE_Msk (0x1UL << DMA2D_CR_TCIE_Pos)
9609#define DMA2D_CR_TCIE DMA2D_CR_TCIE_Msk
9610#define DMA2D_CR_TWIE_Pos (10U)
9611#define DMA2D_CR_TWIE_Msk (0x1UL << DMA2D_CR_TWIE_Pos)
9612#define DMA2D_CR_TWIE DMA2D_CR_TWIE_Msk
9613#define DMA2D_CR_CAEIE_Pos (11U)
9614#define DMA2D_CR_CAEIE_Msk (0x1UL << DMA2D_CR_CAEIE_Pos)
9615#define DMA2D_CR_CAEIE DMA2D_CR_CAEIE_Msk
9616#define DMA2D_CR_CTCIE_Pos (12U)
9617#define DMA2D_CR_CTCIE_Msk (0x1UL << DMA2D_CR_CTCIE_Pos)
9618#define DMA2D_CR_CTCIE DMA2D_CR_CTCIE_Msk
9619#define DMA2D_CR_CEIE_Pos (13U)
9620#define DMA2D_CR_CEIE_Msk (0x1UL << DMA2D_CR_CEIE_Pos)
9621#define DMA2D_CR_CEIE DMA2D_CR_CEIE_Msk
9622#define DMA2D_CR_MODE_Pos (16U)
9623#define DMA2D_CR_MODE_Msk (0x7UL << DMA2D_CR_MODE_Pos)
9624#define DMA2D_CR_MODE DMA2D_CR_MODE_Msk
9625#define DMA2D_CR_MODE_0 (0x1UL << DMA2D_CR_MODE_Pos)
9626#define DMA2D_CR_MODE_1 (0x2UL << DMA2D_CR_MODE_Pos)
9627#define DMA2D_CR_MODE_2 (0x4UL << DMA2D_CR_MODE_Pos)
9629/******************** Bit definition for DMA2D_ISR register *****************/
9630
9631#define DMA2D_ISR_TEIF_Pos (0U)
9632#define DMA2D_ISR_TEIF_Msk (0x1UL << DMA2D_ISR_TEIF_Pos)
9633#define DMA2D_ISR_TEIF DMA2D_ISR_TEIF_Msk
9634#define DMA2D_ISR_TCIF_Pos (1U)
9635#define DMA2D_ISR_TCIF_Msk (0x1UL << DMA2D_ISR_TCIF_Pos)
9636#define DMA2D_ISR_TCIF DMA2D_ISR_TCIF_Msk
9637#define DMA2D_ISR_TWIF_Pos (2U)
9638#define DMA2D_ISR_TWIF_Msk (0x1UL << DMA2D_ISR_TWIF_Pos)
9639#define DMA2D_ISR_TWIF DMA2D_ISR_TWIF_Msk
9640#define DMA2D_ISR_CAEIF_Pos (3U)
9641#define DMA2D_ISR_CAEIF_Msk (0x1UL << DMA2D_ISR_CAEIF_Pos)
9642#define DMA2D_ISR_CAEIF DMA2D_ISR_CAEIF_Msk
9643#define DMA2D_ISR_CTCIF_Pos (4U)
9644#define DMA2D_ISR_CTCIF_Msk (0x1UL << DMA2D_ISR_CTCIF_Pos)
9645#define DMA2D_ISR_CTCIF DMA2D_ISR_CTCIF_Msk
9646#define DMA2D_ISR_CEIF_Pos (5U)
9647#define DMA2D_ISR_CEIF_Msk (0x1UL << DMA2D_ISR_CEIF_Pos)
9648#define DMA2D_ISR_CEIF DMA2D_ISR_CEIF_Msk
9650/******************** Bit definition for DMA2D_IFCR register ****************/
9651
9652#define DMA2D_IFCR_CTEIF_Pos (0U)
9653#define DMA2D_IFCR_CTEIF_Msk (0x1UL << DMA2D_IFCR_CTEIF_Pos)
9654#define DMA2D_IFCR_CTEIF DMA2D_IFCR_CTEIF_Msk
9655#define DMA2D_IFCR_CTCIF_Pos (1U)
9656#define DMA2D_IFCR_CTCIF_Msk (0x1UL << DMA2D_IFCR_CTCIF_Pos)
9657#define DMA2D_IFCR_CTCIF DMA2D_IFCR_CTCIF_Msk
9658#define DMA2D_IFCR_CTWIF_Pos (2U)
9659#define DMA2D_IFCR_CTWIF_Msk (0x1UL << DMA2D_IFCR_CTWIF_Pos)
9660#define DMA2D_IFCR_CTWIF DMA2D_IFCR_CTWIF_Msk
9661#define DMA2D_IFCR_CAECIF_Pos (3U)
9662#define DMA2D_IFCR_CAECIF_Msk (0x1UL << DMA2D_IFCR_CAECIF_Pos)
9663#define DMA2D_IFCR_CAECIF DMA2D_IFCR_CAECIF_Msk
9664#define DMA2D_IFCR_CCTCIF_Pos (4U)
9665#define DMA2D_IFCR_CCTCIF_Msk (0x1UL << DMA2D_IFCR_CCTCIF_Pos)
9666#define DMA2D_IFCR_CCTCIF DMA2D_IFCR_CCTCIF_Msk
9667#define DMA2D_IFCR_CCEIF_Pos (5U)
9668#define DMA2D_IFCR_CCEIF_Msk (0x1UL << DMA2D_IFCR_CCEIF_Pos)
9669#define DMA2D_IFCR_CCEIF DMA2D_IFCR_CCEIF_Msk
9671/******************** Bit definition for DMA2D_FGMAR register ***************/
9672
9673#define DMA2D_FGMAR_MA_Pos (0U)
9674#define DMA2D_FGMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_FGMAR_MA_Pos)
9675#define DMA2D_FGMAR_MA DMA2D_FGMAR_MA_Msk
9677/******************** Bit definition for DMA2D_FGOR register ****************/
9678
9679#define DMA2D_FGOR_LO_Pos (0U)
9680#define DMA2D_FGOR_LO_Msk (0xFFFFUL << DMA2D_FGOR_LO_Pos)
9681#define DMA2D_FGOR_LO DMA2D_FGOR_LO_Msk
9683/******************** Bit definition for DMA2D_BGMAR register ***************/
9684
9685#define DMA2D_BGMAR_MA_Pos (0U)
9686#define DMA2D_BGMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_BGMAR_MA_Pos)
9687#define DMA2D_BGMAR_MA DMA2D_BGMAR_MA_Msk
9689/******************** Bit definition for DMA2D_BGOR register ****************/
9690
9691#define DMA2D_BGOR_LO_Pos (0U)
9692#define DMA2D_BGOR_LO_Msk (0xFFFFUL << DMA2D_BGOR_LO_Pos)
9693#define DMA2D_BGOR_LO DMA2D_BGOR_LO_Msk
9695/******************** Bit definition for DMA2D_FGPFCCR register *************/
9696
9697#define DMA2D_FGPFCCR_CM_Pos (0U)
9698#define DMA2D_FGPFCCR_CM_Msk (0xFUL << DMA2D_FGPFCCR_CM_Pos)
9699#define DMA2D_FGPFCCR_CM DMA2D_FGPFCCR_CM_Msk
9700#define DMA2D_FGPFCCR_CM_0 (0x1UL << DMA2D_FGPFCCR_CM_Pos)
9701#define DMA2D_FGPFCCR_CM_1 (0x2UL << DMA2D_FGPFCCR_CM_Pos)
9702#define DMA2D_FGPFCCR_CM_2 (0x4UL << DMA2D_FGPFCCR_CM_Pos)
9703#define DMA2D_FGPFCCR_CM_3 (0x8UL << DMA2D_FGPFCCR_CM_Pos)
9704#define DMA2D_FGPFCCR_CCM_Pos (4U)
9705#define DMA2D_FGPFCCR_CCM_Msk (0x1UL << DMA2D_FGPFCCR_CCM_Pos)
9706#define DMA2D_FGPFCCR_CCM DMA2D_FGPFCCR_CCM_Msk
9707#define DMA2D_FGPFCCR_START_Pos (5U)
9708#define DMA2D_FGPFCCR_START_Msk (0x1UL << DMA2D_FGPFCCR_START_Pos)
9709#define DMA2D_FGPFCCR_START DMA2D_FGPFCCR_START_Msk
9710#define DMA2D_FGPFCCR_CS_Pos (8U)
9711#define DMA2D_FGPFCCR_CS_Msk (0xFFUL << DMA2D_FGPFCCR_CS_Pos)
9712#define DMA2D_FGPFCCR_CS DMA2D_FGPFCCR_CS_Msk
9713#define DMA2D_FGPFCCR_AM_Pos (16U)
9714#define DMA2D_FGPFCCR_AM_Msk (0x3UL << DMA2D_FGPFCCR_AM_Pos)
9715#define DMA2D_FGPFCCR_AM DMA2D_FGPFCCR_AM_Msk
9716#define DMA2D_FGPFCCR_AM_0 (0x1UL << DMA2D_FGPFCCR_AM_Pos)
9717#define DMA2D_FGPFCCR_AM_1 (0x2UL << DMA2D_FGPFCCR_AM_Pos)
9718#define DMA2D_FGPFCCR_CSS_Pos (18U)
9719#define DMA2D_FGPFCCR_CSS_Msk (0x3UL << DMA2D_FGPFCCR_CSS_Pos)
9720#define DMA2D_FGPFCCR_CSS DMA2D_FGPFCCR_CSS_Msk /* !< Chroma Sub-Sampling */
9721#define DMA2D_FGPFCCR_CSS_0 (0x1UL << DMA2D_FGPFCCR_CSS_Pos)
9722#define DMA2D_FGPFCCR_CSS_1 (0x2UL << DMA2D_FGPFCCR_CSS_Pos)
9723#define DMA2D_FGPFCCR_AI_Pos (20U)
9724#define DMA2D_FGPFCCR_AI_Msk (0x1UL << DMA2D_FGPFCCR_AI_Pos)
9725#define DMA2D_FGPFCCR_AI DMA2D_FGPFCCR_AI_Msk
9726#define DMA2D_FGPFCCR_RBS_Pos (21U)
9727#define DMA2D_FGPFCCR_RBS_Msk (0x1UL << DMA2D_FGPFCCR_RBS_Pos)
9728#define DMA2D_FGPFCCR_RBS DMA2D_FGPFCCR_RBS_Msk
9729#define DMA2D_FGPFCCR_ALPHA_Pos (24U)
9730#define DMA2D_FGPFCCR_ALPHA_Msk (0xFFUL << DMA2D_FGPFCCR_ALPHA_Pos)
9731#define DMA2D_FGPFCCR_ALPHA DMA2D_FGPFCCR_ALPHA_Msk
9733/******************** Bit definition for DMA2D_FGCOLR register **************/
9734
9735#define DMA2D_FGCOLR_BLUE_Pos (0U)
9736#define DMA2D_FGCOLR_BLUE_Msk (0xFFUL << DMA2D_FGCOLR_BLUE_Pos)
9737#define DMA2D_FGCOLR_BLUE DMA2D_FGCOLR_BLUE_Msk
9738#define DMA2D_FGCOLR_GREEN_Pos (8U)
9739#define DMA2D_FGCOLR_GREEN_Msk (0xFFUL << DMA2D_FGCOLR_GREEN_Pos)
9740#define DMA2D_FGCOLR_GREEN DMA2D_FGCOLR_GREEN_Msk
9741#define DMA2D_FGCOLR_RED_Pos (16U)
9742#define DMA2D_FGCOLR_RED_Msk (0xFFUL << DMA2D_FGCOLR_RED_Pos)
9743#define DMA2D_FGCOLR_RED DMA2D_FGCOLR_RED_Msk
9745/******************** Bit definition for DMA2D_BGPFCCR register *************/
9746
9747#define DMA2D_BGPFCCR_CM_Pos (0U)
9748#define DMA2D_BGPFCCR_CM_Msk (0xFUL << DMA2D_BGPFCCR_CM_Pos)
9749#define DMA2D_BGPFCCR_CM DMA2D_BGPFCCR_CM_Msk
9750#define DMA2D_BGPFCCR_CM_0 (0x1UL << DMA2D_BGPFCCR_CM_Pos)
9751#define DMA2D_BGPFCCR_CM_1 (0x2UL << DMA2D_BGPFCCR_CM_Pos)
9752#define DMA2D_BGPFCCR_CM_2 (0x4UL << DMA2D_BGPFCCR_CM_Pos)
9753#define DMA2D_BGPFCCR_CM_3 (0x8UL << DMA2D_BGPFCCR_CM_Pos)
9754#define DMA2D_BGPFCCR_CCM_Pos (4U)
9755#define DMA2D_BGPFCCR_CCM_Msk (0x1UL << DMA2D_BGPFCCR_CCM_Pos)
9756#define DMA2D_BGPFCCR_CCM DMA2D_BGPFCCR_CCM_Msk
9757#define DMA2D_BGPFCCR_START_Pos (5U)
9758#define DMA2D_BGPFCCR_START_Msk (0x1UL << DMA2D_BGPFCCR_START_Pos)
9759#define DMA2D_BGPFCCR_START DMA2D_BGPFCCR_START_Msk
9760#define DMA2D_BGPFCCR_CS_Pos (8U)
9761#define DMA2D_BGPFCCR_CS_Msk (0xFFUL << DMA2D_BGPFCCR_CS_Pos)
9762#define DMA2D_BGPFCCR_CS DMA2D_BGPFCCR_CS_Msk
9763#define DMA2D_BGPFCCR_AM_Pos (16U)
9764#define DMA2D_BGPFCCR_AM_Msk (0x3UL << DMA2D_BGPFCCR_AM_Pos)
9765#define DMA2D_BGPFCCR_AM DMA2D_BGPFCCR_AM_Msk
9766#define DMA2D_BGPFCCR_AM_0 (0x1UL << DMA2D_BGPFCCR_AM_Pos)
9767#define DMA2D_BGPFCCR_AM_1 (0x2UL << DMA2D_BGPFCCR_AM_Pos)
9768#define DMA2D_BGPFCCR_AI_Pos (20U)
9769#define DMA2D_BGPFCCR_AI_Msk (0x1UL << DMA2D_BGPFCCR_AI_Pos)
9770#define DMA2D_BGPFCCR_AI DMA2D_BGPFCCR_AI_Msk
9771#define DMA2D_BGPFCCR_RBS_Pos (21U)
9772#define DMA2D_BGPFCCR_RBS_Msk (0x1UL << DMA2D_BGPFCCR_RBS_Pos)
9773#define DMA2D_BGPFCCR_RBS DMA2D_BGPFCCR_RBS_Msk
9774#define DMA2D_BGPFCCR_ALPHA_Pos (24U)
9775#define DMA2D_BGPFCCR_ALPHA_Msk (0xFFUL << DMA2D_BGPFCCR_ALPHA_Pos)
9776#define DMA2D_BGPFCCR_ALPHA DMA2D_BGPFCCR_ALPHA_Msk
9778/******************** Bit definition for DMA2D_BGCOLR register **************/
9779
9780#define DMA2D_BGCOLR_BLUE_Pos (0U)
9781#define DMA2D_BGCOLR_BLUE_Msk (0xFFUL << DMA2D_BGCOLR_BLUE_Pos)
9782#define DMA2D_BGCOLR_BLUE DMA2D_BGCOLR_BLUE_Msk
9783#define DMA2D_BGCOLR_GREEN_Pos (8U)
9784#define DMA2D_BGCOLR_GREEN_Msk (0xFFUL << DMA2D_BGCOLR_GREEN_Pos)
9785#define DMA2D_BGCOLR_GREEN DMA2D_BGCOLR_GREEN_Msk
9786#define DMA2D_BGCOLR_RED_Pos (16U)
9787#define DMA2D_BGCOLR_RED_Msk (0xFFUL << DMA2D_BGCOLR_RED_Pos)
9788#define DMA2D_BGCOLR_RED DMA2D_BGCOLR_RED_Msk
9790/******************** Bit definition for DMA2D_FGCMAR register **************/
9791
9792#define DMA2D_FGCMAR_MA_Pos (0U)
9793#define DMA2D_FGCMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_FGCMAR_MA_Pos)
9794#define DMA2D_FGCMAR_MA DMA2D_FGCMAR_MA_Msk
9796/******************** Bit definition for DMA2D_BGCMAR register **************/
9797
9798#define DMA2D_BGCMAR_MA_Pos (0U)
9799#define DMA2D_BGCMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_BGCMAR_MA_Pos)
9800#define DMA2D_BGCMAR_MA DMA2D_BGCMAR_MA_Msk
9802/******************** Bit definition for DMA2D_OPFCCR register **************/
9803
9804#define DMA2D_OPFCCR_CM_Pos (0U)
9805#define DMA2D_OPFCCR_CM_Msk (0x7UL << DMA2D_OPFCCR_CM_Pos)
9806#define DMA2D_OPFCCR_CM DMA2D_OPFCCR_CM_Msk
9807#define DMA2D_OPFCCR_CM_0 (0x1UL << DMA2D_OPFCCR_CM_Pos)
9808#define DMA2D_OPFCCR_CM_1 (0x2UL << DMA2D_OPFCCR_CM_Pos)
9809#define DMA2D_OPFCCR_CM_2 (0x4UL << DMA2D_OPFCCR_CM_Pos)
9810#define DMA2D_OPFCCR_SB_Pos (8U)
9811#define DMA2D_OPFCCR_SB_Msk (0x1UL << DMA2D_OPFCCR_SB_Pos)
9812#define DMA2D_OPFCCR_SB DMA2D_OPFCCR_SB_Msk
9813#define DMA2D_OPFCCR_AI_Pos (20U)
9814#define DMA2D_OPFCCR_AI_Msk (0x1UL << DMA2D_OPFCCR_AI_Pos)
9815#define DMA2D_OPFCCR_AI DMA2D_OPFCCR_AI_Msk
9816#define DMA2D_OPFCCR_RBS_Pos (21U)
9817#define DMA2D_OPFCCR_RBS_Msk (0x1UL << DMA2D_OPFCCR_RBS_Pos)
9818#define DMA2D_OPFCCR_RBS DMA2D_OPFCCR_RBS_Msk
9820/******************** Bit definition for DMA2D_OCOLR register ***************/
9821
9824#define DMA2D_OCOLR_BLUE_1_Pos (0U)
9825#define DMA2D_OCOLR_BLUE_1_Msk (0xFFUL <<DMA2D_OCOLR_BLUE_1_Pos) /*0x000000FFU*/
9826#define DMA2D_OCOLR_BLUE_1 DMA2D_OCOLR_BLUE_1_Msk
9827#define DMA2D_OCOLR_GREEN_1_Pos (8U)
9828#define DMA2D_OCOLR_GREEN_1_Msk (0xFFUL<<DMA2D_OCOLR_GREEN_1_Pos) /*0x0000FF00U)*/
9829#define DMA2D_OCOLR_GREEN_1 DMA2D_OCOLR_GREEN_1_Msk
9830#define DMA2D_OCOLR_RED_1_Pos (16U)
9831#define DMA2D_OCOLR_RED_1_Msk (0xFFUL << DMA2D_OCOLR_RED_1_Pos) /*0x00FF0000U */
9832#define DMA2D_OCOLR_RED_1 DMA2D_OCOLR_RED_1_Msk
9833#define DMA2D_OCOLR_ALPHA_1_Pos (24U)
9834#define DMA2D_OCOLR_ALPHA_1_Msk (0xFFUL << DMA2D_OCOLR_ALPHA_1_Pos) /*0xFF000000U*/
9835#define DMA2D_OCOLR_ALPHA_1 DMA2D_OCOLR_ALPHA_1_Msk
9838#define DMA2D_OCOLR_BLUE_2_Pos (0U)
9839#define DMA2D_OCOLR_BLUE_2_Msk (0x1FUL <<DMA2D_OCOLR_BLUE_2_Pos) /*0x0000001FU*/
9840#define DMA2D_OCOLR_BLUE_2 DMA2D_OCOLR_BLUE_2_Msk
9841#define DMA2D_OCOLR_GREEN_2_Pos (5U)
9842#define DMA2D_OCOLR_GREEN_2_Msk (0x7EUL << DMA2D_OCOLR_GREEN_2_Pos) /* 0x000007E0U */
9843#define DMA2D_OCOLR_GREEN_2 DMA2D_OCOLR_GREEN_2_Msk
9844#define DMA2D_OCOLR_RED_2_Pos (11U)
9845#define DMA2D_OCOLR_RED_2_Msk (0xF8UL<<DMA2D_OCOLR_RED_2_Pos) /*0x0000F800U*/
9846#define DMA2D_OCOLR_RED_2 DMA2D_OCOLR_RED_2_Msk
9849#define DMA2D_OCOLR_BLUE_3_Pos (0U)
9850#define DMA2D_OCOLR_BLUE_3_Msk (0x1FUL << DMA2D_OCOLR_BLUE_3_Pos) /*0x0000001FU*/
9851#define DMA2D_OCOLR_BLUE_3 DMA2D_OCOLR_BLUE_3_Msk
9852#define DMA2D_OCOLR_GREEN_3_Pos (5U)
9853#define DMA2D_OCOLR_GREEN_3_Msk (0x3EUL << DMA2D_OCOLR_GREEN_3_Pos) /*0x000003E0U*/
9854#define DMA2D_OCOLR_GREEN_3 DMA2D_OCOLR_GREEN_3_Msk
9855#define DMA2D_OCOLR_RED_3_Pos (10U)
9856#define DMA2D_OCOLR_RED_3_Msk (0x7CUL << DMA2D_OCOLR_RED_3_Pos) /* 0x00007C00U*/
9857#define DMA2D_OCOLR_RED_3 DMA2D_OCOLR_RED_3_Msk
9858#define DMA2D_OCOLR_ALPHA_3_Pos (15U)
9859#define DMA2D_OCOLR_ALPHA_3_Msk (0x1UL << DMA2D_OCOLR_ALPHA_3_Pos) /*0x00008000U*/
9860#define DMA2D_OCOLR_ALPHA_3 DMA2D_OCOLR_ALPHA_3_Msk
9863#define DMA2D_OCOLR_BLUE_4_Pos (0U)
9864#define DMA2D_OCOLR_BLUE_4_Msk (0xFUL << DMA2D_OCOLR_BLUE_4_Pos) /*0x0000000FU*/
9865#define DMA2D_OCOLR_BLUE_4 DMA2D_OCOLR_BLUE_4_Msk
9866#define DMA2D_OCOLR_GREEN_4_Pos (4U)
9867#define DMA2D_OCOLR_GREEN_4_Msk (0xFUL << DMA2D_OCOLR_GREEN_4_Pos) /*0x000000F0U*/
9868#define DMA2D_OCOLR_GREEN_4 DMA2D_OCOLR_GREEN_4_Msk
9869#define DMA2D_OCOLR_RED_4_Pos (8U)
9870#define DMA2D_OCOLR_RED_4_Msk (0xFUL << DMA2D_OCOLR_RED_4_Pos) /*0x00000F00U*/
9871#define DMA2D_OCOLR_RED_4 DMA2D_OCOLR_RED_4_Msk
9872#define DMA2D_OCOLR_ALPHA_4_Pos (12U)
9873#define DMA2D_OCOLR_ALPHA_4_Msk (0xFUL << DMA2D_OCOLR_ALPHA_4_Pos) /*0x0000F000U*/
9874#define DMA2D_OCOLR_ALPHA_4 DMA2D_OCOLR_ALPHA_4_Msk
9876/******************** Bit definition for DMA2D_OMAR register ****************/
9877
9878#define DMA2D_OMAR_MA_Pos (0U)
9879#define DMA2D_OMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_OMAR_MA_Pos)
9880#define DMA2D_OMAR_MA DMA2D_OMAR_MA_Msk
9882/******************** Bit definition for DMA2D_OOR register *****************/
9883
9884#define DMA2D_OOR_LO_Pos (0U)
9885#define DMA2D_OOR_LO_Msk (0xFFFFUL << DMA2D_OOR_LO_Pos)
9886#define DMA2D_OOR_LO DMA2D_OOR_LO_Msk
9888/******************** Bit definition for DMA2D_NLR register *****************/
9889
9890#define DMA2D_NLR_NL_Pos (0U)
9891#define DMA2D_NLR_NL_Msk (0xFFFFUL << DMA2D_NLR_NL_Pos)
9892#define DMA2D_NLR_NL DMA2D_NLR_NL_Msk
9893#define DMA2D_NLR_PL_Pos (16U)
9894#define DMA2D_NLR_PL_Msk (0x3FFFUL << DMA2D_NLR_PL_Pos)
9895#define DMA2D_NLR_PL DMA2D_NLR_PL_Msk
9897/******************** Bit definition for DMA2D_LWR register *****************/
9898
9899#define DMA2D_LWR_LW_Pos (0U)
9900#define DMA2D_LWR_LW_Msk (0xFFFFUL << DMA2D_LWR_LW_Pos)
9901#define DMA2D_LWR_LW DMA2D_LWR_LW_Msk
9903/******************** Bit definition for DMA2D_AMTCR register ***************/
9904
9905#define DMA2D_AMTCR_EN_Pos (0U)
9906#define DMA2D_AMTCR_EN_Msk (0x1UL << DMA2D_AMTCR_EN_Pos)
9907#define DMA2D_AMTCR_EN DMA2D_AMTCR_EN_Msk
9908#define DMA2D_AMTCR_DT_Pos (8U)
9909#define DMA2D_AMTCR_DT_Msk (0xFFUL << DMA2D_AMTCR_DT_Pos)
9910#define DMA2D_AMTCR_DT DMA2D_AMTCR_DT_Msk
9913/******************** Bit definition for DMA2D_FGCLUT register **************/
9914
9915/******************** Bit definition for DMA2D_BGCLUT register **************/
9916
9917/******************************************************************************/
9918/* */
9919/* Display Serial Interface (DSI) */
9920/* */
9921/******************************************************************************/
9922/******************* Bit definition for DSI_VR register *****************/
9923#define DSI_VR_Pos (1U)
9924#define DSI_VR_Msk (0x18999815UL << DSI_VR_Pos)
9925#define DSI_VR DSI_VR_Msk
9927/******************* Bit definition for DSI_CR register *****************/
9928#define DSI_CR_EN_Pos (0U)
9929#define DSI_CR_EN_Msk (0x1UL << DSI_CR_EN_Pos)
9930#define DSI_CR_EN DSI_CR_EN_Msk
9932/******************* Bit definition for DSI_CCR register ****************/
9933#define DSI_CCR_TXECKDIV_Pos (0U)
9934#define DSI_CCR_TXECKDIV_Msk (0xFFUL << DSI_CCR_TXECKDIV_Pos)
9935#define DSI_CCR_TXECKDIV DSI_CCR_TXECKDIV_Msk
9936#define DSI_CCR_TXECKDIV0_Pos (0U)
9937#define DSI_CCR_TXECKDIV0_Msk (0x1UL << DSI_CCR_TXECKDIV0_Pos)
9938#define DSI_CCR_TXECKDIV0 DSI_CCR_TXECKDIV0_Msk
9939#define DSI_CCR_TXECKDIV1_Pos (1U)
9940#define DSI_CCR_TXECKDIV1_Msk (0x1UL << DSI_CCR_TXECKDIV1_Pos)
9941#define DSI_CCR_TXECKDIV1 DSI_CCR_TXECKDIV1_Msk
9942#define DSI_CCR_TXECKDIV2_Pos (2U)
9943#define DSI_CCR_TXECKDIV2_Msk (0x1UL << DSI_CCR_TXECKDIV2_Pos)
9944#define DSI_CCR_TXECKDIV2 DSI_CCR_TXECKDIV2_Msk
9945#define DSI_CCR_TXECKDIV3_Pos (3U)
9946#define DSI_CCR_TXECKDIV3_Msk (0x1UL << DSI_CCR_TXECKDIV3_Pos)
9947#define DSI_CCR_TXECKDIV3 DSI_CCR_TXECKDIV3_Msk
9948#define DSI_CCR_TXECKDIV4_Pos (4U)
9949#define DSI_CCR_TXECKDIV4_Msk (0x1UL << DSI_CCR_TXECKDIV4_Pos)
9950#define DSI_CCR_TXECKDIV4 DSI_CCR_TXECKDIV4_Msk
9951#define DSI_CCR_TXECKDIV5_Pos (5U)
9952#define DSI_CCR_TXECKDIV5_Msk (0x1UL << DSI_CCR_TXECKDIV5_Pos)
9953#define DSI_CCR_TXECKDIV5 DSI_CCR_TXECKDIV5_Msk
9954#define DSI_CCR_TXECKDIV6_Pos (6U)
9955#define DSI_CCR_TXECKDIV6_Msk (0x1UL << DSI_CCR_TXECKDIV6_Pos)
9956#define DSI_CCR_TXECKDIV6 DSI_CCR_TXECKDIV6_Msk
9957#define DSI_CCR_TXECKDIV7_Pos (7U)
9958#define DSI_CCR_TXECKDIV7_Msk (0x1UL << DSI_CCR_TXECKDIV7_Pos)
9959#define DSI_CCR_TXECKDIV7 DSI_CCR_TXECKDIV7_Msk
9960
9961#define DSI_CCR_TOCKDIV_Pos (8U)
9962#define DSI_CCR_TOCKDIV_Msk (0xFFUL << DSI_CCR_TOCKDIV_Pos)
9963#define DSI_CCR_TOCKDIV DSI_CCR_TOCKDIV_Msk
9964#define DSI_CCR_TOCKDIV0_Pos (8U)
9965#define DSI_CCR_TOCKDIV0_Msk (0x1UL << DSI_CCR_TOCKDIV0_Pos)
9966#define DSI_CCR_TOCKDIV0 DSI_CCR_TOCKDIV0_Msk
9967#define DSI_CCR_TOCKDIV1_Pos (9U)
9968#define DSI_CCR_TOCKDIV1_Msk (0x1UL << DSI_CCR_TOCKDIV1_Pos)
9969#define DSI_CCR_TOCKDIV1 DSI_CCR_TOCKDIV1_Msk
9970#define DSI_CCR_TOCKDIV2_Pos (10U)
9971#define DSI_CCR_TOCKDIV2_Msk (0x1UL << DSI_CCR_TOCKDIV2_Pos)
9972#define DSI_CCR_TOCKDIV2 DSI_CCR_TOCKDIV2_Msk
9973#define DSI_CCR_TOCKDIV3_Pos (11U)
9974#define DSI_CCR_TOCKDIV3_Msk (0x1UL << DSI_CCR_TOCKDIV3_Pos)
9975#define DSI_CCR_TOCKDIV3 DSI_CCR_TOCKDIV3_Msk
9976#define DSI_CCR_TOCKDIV4_Pos (12U)
9977#define DSI_CCR_TOCKDIV4_Msk (0x1UL << DSI_CCR_TOCKDIV4_Pos)
9978#define DSI_CCR_TOCKDIV4 DSI_CCR_TOCKDIV4_Msk
9979#define DSI_CCR_TOCKDIV5_Pos (13U)
9980#define DSI_CCR_TOCKDIV5_Msk (0x1UL << DSI_CCR_TOCKDIV5_Pos)
9981#define DSI_CCR_TOCKDIV5 DSI_CCR_TOCKDIV5_Msk
9982#define DSI_CCR_TOCKDIV6_Pos (14U)
9983#define DSI_CCR_TOCKDIV6_Msk (0x1UL << DSI_CCR_TOCKDIV6_Pos)
9984#define DSI_CCR_TOCKDIV6 DSI_CCR_TOCKDIV6_Msk
9985#define DSI_CCR_TOCKDIV7_Pos (15U)
9986#define DSI_CCR_TOCKDIV7_Msk (0x1UL << DSI_CCR_TOCKDIV7_Pos)
9987#define DSI_CCR_TOCKDIV7 DSI_CCR_TOCKDIV7_Msk
9988
9989/******************* Bit definition for DSI_LVCIDR register *************/
9990#define DSI_LVCIDR_VCID_Pos (0U)
9991#define DSI_LVCIDR_VCID_Msk (0x3UL << DSI_LVCIDR_VCID_Pos)
9992#define DSI_LVCIDR_VCID DSI_LVCIDR_VCID_Msk
9993#define DSI_LVCIDR_VCID0_Pos (0U)
9994#define DSI_LVCIDR_VCID0_Msk (0x1UL << DSI_LVCIDR_VCID0_Pos)
9995#define DSI_LVCIDR_VCID0 DSI_LVCIDR_VCID0_Msk
9996#define DSI_LVCIDR_VCID1_Pos (1U)
9997#define DSI_LVCIDR_VCID1_Msk (0x1UL << DSI_LVCIDR_VCID1_Pos)
9998#define DSI_LVCIDR_VCID1 DSI_LVCIDR_VCID1_Msk
9999
10000/******************* Bit definition for DSI_LCOLCR register *************/
10001#define DSI_LCOLCR_COLC_Pos (0U)
10002#define DSI_LCOLCR_COLC_Msk (0xFUL << DSI_LCOLCR_COLC_Pos)
10003#define DSI_LCOLCR_COLC DSI_LCOLCR_COLC_Msk
10004#define DSI_LCOLCR_COLC0_Pos (0U)
10005#define DSI_LCOLCR_COLC0_Msk (0x1UL << DSI_LCOLCR_COLC0_Pos)
10006#define DSI_LCOLCR_COLC0 DSI_LCOLCR_COLC0_Msk
10007#define DSI_LCOLCR_COLC1_Pos (5U)
10008#define DSI_LCOLCR_COLC1_Msk (0x1UL << DSI_LCOLCR_COLC1_Pos)
10009#define DSI_LCOLCR_COLC1 DSI_LCOLCR_COLC1_Msk
10010#define DSI_LCOLCR_COLC2_Pos (6U)
10011#define DSI_LCOLCR_COLC2_Msk (0x1UL << DSI_LCOLCR_COLC2_Pos)
10012#define DSI_LCOLCR_COLC2 DSI_LCOLCR_COLC2_Msk
10013#define DSI_LCOLCR_COLC3_Pos (7U)
10014#define DSI_LCOLCR_COLC3_Msk (0x1UL << DSI_LCOLCR_COLC3_Pos)
10015#define DSI_LCOLCR_COLC3 DSI_LCOLCR_COLC3_Msk
10016
10017#define DSI_LCOLCR_LPE_Pos (8U)
10018#define DSI_LCOLCR_LPE_Msk (0x1UL << DSI_LCOLCR_LPE_Pos)
10019#define DSI_LCOLCR_LPE DSI_LCOLCR_LPE_Msk
10021/******************* Bit definition for DSI_LPCR register ***************/
10022#define DSI_LPCR_DEP_Pos (0U)
10023#define DSI_LPCR_DEP_Msk (0x1UL << DSI_LPCR_DEP_Pos)
10024#define DSI_LPCR_DEP DSI_LPCR_DEP_Msk
10025#define DSI_LPCR_VSP_Pos (1U)
10026#define DSI_LPCR_VSP_Msk (0x1UL << DSI_LPCR_VSP_Pos)
10027#define DSI_LPCR_VSP DSI_LPCR_VSP_Msk
10028#define DSI_LPCR_HSP_Pos (2U)
10029#define DSI_LPCR_HSP_Msk (0x1UL << DSI_LPCR_HSP_Pos)
10030#define DSI_LPCR_HSP DSI_LPCR_HSP_Msk
10032/******************* Bit definition for DSI_LPMCR register **************/
10033#define DSI_LPMCR_VLPSIZE_Pos (0U)
10034#define DSI_LPMCR_VLPSIZE_Msk (0xFFUL << DSI_LPMCR_VLPSIZE_Pos)
10035#define DSI_LPMCR_VLPSIZE DSI_LPMCR_VLPSIZE_Msk
10036#define DSI_LPMCR_VLPSIZE0_Pos (0U)
10037#define DSI_LPMCR_VLPSIZE0_Msk (0x1UL << DSI_LPMCR_VLPSIZE0_Pos)
10038#define DSI_LPMCR_VLPSIZE0 DSI_LPMCR_VLPSIZE0_Msk
10039#define DSI_LPMCR_VLPSIZE1_Pos (1U)
10040#define DSI_LPMCR_VLPSIZE1_Msk (0x1UL << DSI_LPMCR_VLPSIZE1_Pos)
10041#define DSI_LPMCR_VLPSIZE1 DSI_LPMCR_VLPSIZE1_Msk
10042#define DSI_LPMCR_VLPSIZE2_Pos (2U)
10043#define DSI_LPMCR_VLPSIZE2_Msk (0x1UL << DSI_LPMCR_VLPSIZE2_Pos)
10044#define DSI_LPMCR_VLPSIZE2 DSI_LPMCR_VLPSIZE2_Msk
10045#define DSI_LPMCR_VLPSIZE3_Pos (3U)
10046#define DSI_LPMCR_VLPSIZE3_Msk (0x1UL << DSI_LPMCR_VLPSIZE3_Pos)
10047#define DSI_LPMCR_VLPSIZE3 DSI_LPMCR_VLPSIZE3_Msk
10048#define DSI_LPMCR_VLPSIZE4_Pos (4U)
10049#define DSI_LPMCR_VLPSIZE4_Msk (0x1UL << DSI_LPMCR_VLPSIZE4_Pos)
10050#define DSI_LPMCR_VLPSIZE4 DSI_LPMCR_VLPSIZE4_Msk
10051#define DSI_LPMCR_VLPSIZE5_Pos (5U)
10052#define DSI_LPMCR_VLPSIZE5_Msk (0x1UL << DSI_LPMCR_VLPSIZE5_Pos)
10053#define DSI_LPMCR_VLPSIZE5 DSI_LPMCR_VLPSIZE5_Msk
10054#define DSI_LPMCR_VLPSIZE6_Pos (6U)
10055#define DSI_LPMCR_VLPSIZE6_Msk (0x1UL << DSI_LPMCR_VLPSIZE6_Pos)
10056#define DSI_LPMCR_VLPSIZE6 DSI_LPMCR_VLPSIZE6_Msk
10057#define DSI_LPMCR_VLPSIZE7_Pos (7U)
10058#define DSI_LPMCR_VLPSIZE7_Msk (0x1UL << DSI_LPMCR_VLPSIZE7_Pos)
10059#define DSI_LPMCR_VLPSIZE7 DSI_LPMCR_VLPSIZE7_Msk
10060
10061#define DSI_LPMCR_LPSIZE_Pos (16U)
10062#define DSI_LPMCR_LPSIZE_Msk (0xFFUL << DSI_LPMCR_LPSIZE_Pos)
10063#define DSI_LPMCR_LPSIZE DSI_LPMCR_LPSIZE_Msk
10064#define DSI_LPMCR_LPSIZE0_Pos (16U)
10065#define DSI_LPMCR_LPSIZE0_Msk (0x1UL << DSI_LPMCR_LPSIZE0_Pos)
10066#define DSI_LPMCR_LPSIZE0 DSI_LPMCR_LPSIZE0_Msk
10067#define DSI_LPMCR_LPSIZE1_Pos (17U)
10068#define DSI_LPMCR_LPSIZE1_Msk (0x1UL << DSI_LPMCR_LPSIZE1_Pos)
10069#define DSI_LPMCR_LPSIZE1 DSI_LPMCR_LPSIZE1_Msk
10070#define DSI_LPMCR_LPSIZE2_Pos (18U)
10071#define DSI_LPMCR_LPSIZE2_Msk (0x1UL << DSI_LPMCR_LPSIZE2_Pos)
10072#define DSI_LPMCR_LPSIZE2 DSI_LPMCR_LPSIZE2_Msk
10073#define DSI_LPMCR_LPSIZE3_Pos (19U)
10074#define DSI_LPMCR_LPSIZE3_Msk (0x1UL << DSI_LPMCR_LPSIZE3_Pos)
10075#define DSI_LPMCR_LPSIZE3 DSI_LPMCR_LPSIZE3_Msk
10076#define DSI_LPMCR_LPSIZE4_Pos (20U)
10077#define DSI_LPMCR_LPSIZE4_Msk (0x1UL << DSI_LPMCR_LPSIZE4_Pos)
10078#define DSI_LPMCR_LPSIZE4 DSI_LPMCR_LPSIZE4_Msk
10079#define DSI_LPMCR_LPSIZE5_Pos (21U)
10080#define DSI_LPMCR_LPSIZE5_Msk (0x1UL << DSI_LPMCR_LPSIZE5_Pos)
10081#define DSI_LPMCR_LPSIZE5 DSI_LPMCR_LPSIZE5_Msk
10082#define DSI_LPMCR_LPSIZE6_Pos (22U)
10083#define DSI_LPMCR_LPSIZE6_Msk (0x1UL << DSI_LPMCR_LPSIZE6_Pos)
10084#define DSI_LPMCR_LPSIZE6 DSI_LPMCR_LPSIZE6_Msk
10085#define DSI_LPMCR_LPSIZE7_Pos (23U)
10086#define DSI_LPMCR_LPSIZE7_Msk (0x1UL << DSI_LPMCR_LPSIZE7_Pos)
10087#define DSI_LPMCR_LPSIZE7 DSI_LPMCR_LPSIZE7_Msk
10088
10089/******************* Bit definition for DSI_PCR register ****************/
10090#define DSI_PCR_ETTXE_Pos (0U)
10091#define DSI_PCR_ETTXE_Msk (0x1UL << DSI_PCR_ETTXE_Pos)
10092#define DSI_PCR_ETTXE DSI_PCR_ETTXE_Msk
10093#define DSI_PCR_ETRXE_Pos (1U)
10094#define DSI_PCR_ETRXE_Msk (0x1UL << DSI_PCR_ETRXE_Pos)
10095#define DSI_PCR_ETRXE DSI_PCR_ETRXE_Msk
10096#define DSI_PCR_BTAE_Pos (2U)
10097#define DSI_PCR_BTAE_Msk (0x1UL << DSI_PCR_BTAE_Pos)
10098#define DSI_PCR_BTAE DSI_PCR_BTAE_Msk
10099#define DSI_PCR_ECCRXE_Pos (3U)
10100#define DSI_PCR_ECCRXE_Msk (0x1UL << DSI_PCR_ECCRXE_Pos)
10101#define DSI_PCR_ECCRXE DSI_PCR_ECCRXE_Msk
10102#define DSI_PCR_CRCRXE_Pos (4U)
10103#define DSI_PCR_CRCRXE_Msk (0x1UL << DSI_PCR_CRCRXE_Pos)
10104#define DSI_PCR_CRCRXE DSI_PCR_CRCRXE_Msk
10106/******************* Bit definition for DSI_GVCIDR register *************/
10107#define DSI_GVCIDR_VCID_Pos (0U)
10108#define DSI_GVCIDR_VCID_Msk (0x3UL << DSI_GVCIDR_VCID_Pos)
10109#define DSI_GVCIDR_VCID DSI_GVCIDR_VCID_Msk
10110#define DSI_GVCIDR_VCID0_Pos (0U)
10111#define DSI_GVCIDR_VCID0_Msk (0x1UL << DSI_GVCIDR_VCID0_Pos)
10112#define DSI_GVCIDR_VCID0 DSI_GVCIDR_VCID0_Msk
10113#define DSI_GVCIDR_VCID1_Pos (1U)
10114#define DSI_GVCIDR_VCID1_Msk (0x1UL << DSI_GVCIDR_VCID1_Pos)
10115#define DSI_GVCIDR_VCID1 DSI_GVCIDR_VCID1_Msk
10116
10117/******************* Bit definition for DSI_MCR register ****************/
10118#define DSI_MCR_CMDM_Pos (0U)
10119#define DSI_MCR_CMDM_Msk (0x1UL << DSI_MCR_CMDM_Pos)
10120#define DSI_MCR_CMDM DSI_MCR_CMDM_Msk
10122/******************* Bit definition for DSI_VMCR register ***************/
10123#define DSI_VMCR_VMT_Pos (0U)
10124#define DSI_VMCR_VMT_Msk (0x3UL << DSI_VMCR_VMT_Pos)
10125#define DSI_VMCR_VMT DSI_VMCR_VMT_Msk
10126#define DSI_VMCR_VMT0_Pos (0U)
10127#define DSI_VMCR_VMT0_Msk (0x1UL << DSI_VMCR_VMT0_Pos)
10128#define DSI_VMCR_VMT0 DSI_VMCR_VMT0_Msk
10129#define DSI_VMCR_VMT1_Pos (1U)
10130#define DSI_VMCR_VMT1_Msk (0x1UL << DSI_VMCR_VMT1_Pos)
10131#define DSI_VMCR_VMT1 DSI_VMCR_VMT1_Msk
10132
10133#define DSI_VMCR_LPVSAE_Pos (8U)
10134#define DSI_VMCR_LPVSAE_Msk (0x1UL << DSI_VMCR_LPVSAE_Pos)
10135#define DSI_VMCR_LPVSAE DSI_VMCR_LPVSAE_Msk
10136#define DSI_VMCR_LPVBPE_Pos (9U)
10137#define DSI_VMCR_LPVBPE_Msk (0x1UL << DSI_VMCR_LPVBPE_Pos)
10138#define DSI_VMCR_LPVBPE DSI_VMCR_LPVBPE_Msk
10139#define DSI_VMCR_LPVFPE_Pos (10U)
10140#define DSI_VMCR_LPVFPE_Msk (0x1UL << DSI_VMCR_LPVFPE_Pos)
10141#define DSI_VMCR_LPVFPE DSI_VMCR_LPVFPE_Msk
10142#define DSI_VMCR_LPVAE_Pos (11U)
10143#define DSI_VMCR_LPVAE_Msk (0x1UL << DSI_VMCR_LPVAE_Pos)
10144#define DSI_VMCR_LPVAE DSI_VMCR_LPVAE_Msk
10145#define DSI_VMCR_LPHBPE_Pos (12U)
10146#define DSI_VMCR_LPHBPE_Msk (0x1UL << DSI_VMCR_LPHBPE_Pos)
10147#define DSI_VMCR_LPHBPE DSI_VMCR_LPHBPE_Msk
10148#define DSI_VMCR_LPHFPE_Pos (13U)
10149#define DSI_VMCR_LPHFPE_Msk (0x1UL << DSI_VMCR_LPHFPE_Pos)
10150#define DSI_VMCR_LPHFPE DSI_VMCR_LPHFPE_Msk
10151#define DSI_VMCR_FBTAAE_Pos (14U)
10152#define DSI_VMCR_FBTAAE_Msk (0x1UL << DSI_VMCR_FBTAAE_Pos)
10153#define DSI_VMCR_FBTAAE DSI_VMCR_FBTAAE_Msk
10154#define DSI_VMCR_LPCE_Pos (15U)
10155#define DSI_VMCR_LPCE_Msk (0x1UL << DSI_VMCR_LPCE_Pos)
10156#define DSI_VMCR_LPCE DSI_VMCR_LPCE_Msk
10157#define DSI_VMCR_PGE_Pos (16U)
10158#define DSI_VMCR_PGE_Msk (0x1UL << DSI_VMCR_PGE_Pos)
10159#define DSI_VMCR_PGE DSI_VMCR_PGE_Msk
10160#define DSI_VMCR_PGM_Pos (20U)
10161#define DSI_VMCR_PGM_Msk (0x1UL << DSI_VMCR_PGM_Pos)
10162#define DSI_VMCR_PGM DSI_VMCR_PGM_Msk
10163#define DSI_VMCR_PGO_Pos (24U)
10164#define DSI_VMCR_PGO_Msk (0x1UL << DSI_VMCR_PGO_Pos)
10165#define DSI_VMCR_PGO DSI_VMCR_PGO_Msk
10167/******************* Bit definition for DSI_VPCR register ***************/
10168#define DSI_VPCR_VPSIZE_Pos (0U)
10169#define DSI_VPCR_VPSIZE_Msk (0x3FFFUL << DSI_VPCR_VPSIZE_Pos)
10170#define DSI_VPCR_VPSIZE DSI_VPCR_VPSIZE_Msk
10171#define DSI_VPCR_VPSIZE0_Pos (0U)
10172#define DSI_VPCR_VPSIZE0_Msk (0x1UL << DSI_VPCR_VPSIZE0_Pos)
10173#define DSI_VPCR_VPSIZE0 DSI_VPCR_VPSIZE0_Msk
10174#define DSI_VPCR_VPSIZE1_Pos (1U)
10175#define DSI_VPCR_VPSIZE1_Msk (0x1UL << DSI_VPCR_VPSIZE1_Pos)
10176#define DSI_VPCR_VPSIZE1 DSI_VPCR_VPSIZE1_Msk
10177#define DSI_VPCR_VPSIZE2_Pos (2U)
10178#define DSI_VPCR_VPSIZE2_Msk (0x1UL << DSI_VPCR_VPSIZE2_Pos)
10179#define DSI_VPCR_VPSIZE2 DSI_VPCR_VPSIZE2_Msk
10180#define DSI_VPCR_VPSIZE3_Pos (3U)
10181#define DSI_VPCR_VPSIZE3_Msk (0x1UL << DSI_VPCR_VPSIZE3_Pos)
10182#define DSI_VPCR_VPSIZE3 DSI_VPCR_VPSIZE3_Msk
10183#define DSI_VPCR_VPSIZE4_Pos (4U)
10184#define DSI_VPCR_VPSIZE4_Msk (0x1UL << DSI_VPCR_VPSIZE4_Pos)
10185#define DSI_VPCR_VPSIZE4 DSI_VPCR_VPSIZE4_Msk
10186#define DSI_VPCR_VPSIZE5_Pos (5U)
10187#define DSI_VPCR_VPSIZE5_Msk (0x1UL << DSI_VPCR_VPSIZE5_Pos)
10188#define DSI_VPCR_VPSIZE5 DSI_VPCR_VPSIZE5_Msk
10189#define DSI_VPCR_VPSIZE6_Pos (6U)
10190#define DSI_VPCR_VPSIZE6_Msk (0x1UL << DSI_VPCR_VPSIZE6_Pos)
10191#define DSI_VPCR_VPSIZE6 DSI_VPCR_VPSIZE6_Msk
10192#define DSI_VPCR_VPSIZE7_Pos (7U)
10193#define DSI_VPCR_VPSIZE7_Msk (0x1UL << DSI_VPCR_VPSIZE7_Pos)
10194#define DSI_VPCR_VPSIZE7 DSI_VPCR_VPSIZE7_Msk
10195#define DSI_VPCR_VPSIZE8_Pos (8U)
10196#define DSI_VPCR_VPSIZE8_Msk (0x1UL << DSI_VPCR_VPSIZE8_Pos)
10197#define DSI_VPCR_VPSIZE8 DSI_VPCR_VPSIZE8_Msk
10198#define DSI_VPCR_VPSIZE9_Pos (9U)
10199#define DSI_VPCR_VPSIZE9_Msk (0x1UL << DSI_VPCR_VPSIZE9_Pos)
10200#define DSI_VPCR_VPSIZE9 DSI_VPCR_VPSIZE9_Msk
10201#define DSI_VPCR_VPSIZE10_Pos (10U)
10202#define DSI_VPCR_VPSIZE10_Msk (0x1UL << DSI_VPCR_VPSIZE10_Pos)
10203#define DSI_VPCR_VPSIZE10 DSI_VPCR_VPSIZE10_Msk
10204#define DSI_VPCR_VPSIZE11_Pos (11U)
10205#define DSI_VPCR_VPSIZE11_Msk (0x1UL << DSI_VPCR_VPSIZE11_Pos)
10206#define DSI_VPCR_VPSIZE11 DSI_VPCR_VPSIZE11_Msk
10207#define DSI_VPCR_VPSIZE12_Pos (12U)
10208#define DSI_VPCR_VPSIZE12_Msk (0x1UL << DSI_VPCR_VPSIZE12_Pos)
10209#define DSI_VPCR_VPSIZE12 DSI_VPCR_VPSIZE12_Msk
10210#define DSI_VPCR_VPSIZE13_Pos (13U)
10211#define DSI_VPCR_VPSIZE13_Msk (0x1UL << DSI_VPCR_VPSIZE13_Pos)
10212#define DSI_VPCR_VPSIZE13 DSI_VPCR_VPSIZE13_Msk
10213
10214/******************* Bit definition for DSI_VCCR register ***************/
10215#define DSI_VCCR_NUMC_Pos (0U)
10216#define DSI_VCCR_NUMC_Msk (0x1FFFUL << DSI_VCCR_NUMC_Pos)
10217#define DSI_VCCR_NUMC DSI_VCCR_NUMC_Msk
10218#define DSI_VCCR_NUMC0_Pos (0U)
10219#define DSI_VCCR_NUMC0_Msk (0x1UL << DSI_VCCR_NUMC0_Pos)
10220#define DSI_VCCR_NUMC0 DSI_VCCR_NUMC0_Msk
10221#define DSI_VCCR_NUMC1_Pos (1U)
10222#define DSI_VCCR_NUMC1_Msk (0x1UL << DSI_VCCR_NUMC1_Pos)
10223#define DSI_VCCR_NUMC1 DSI_VCCR_NUMC1_Msk
10224#define DSI_VCCR_NUMC2_Pos (2U)
10225#define DSI_VCCR_NUMC2_Msk (0x1UL << DSI_VCCR_NUMC2_Pos)
10226#define DSI_VCCR_NUMC2 DSI_VCCR_NUMC2_Msk
10227#define DSI_VCCR_NUMC3_Pos (3U)
10228#define DSI_VCCR_NUMC3_Msk (0x1UL << DSI_VCCR_NUMC3_Pos)
10229#define DSI_VCCR_NUMC3 DSI_VCCR_NUMC3_Msk
10230#define DSI_VCCR_NUMC4_Pos (4U)
10231#define DSI_VCCR_NUMC4_Msk (0x1UL << DSI_VCCR_NUMC4_Pos)
10232#define DSI_VCCR_NUMC4 DSI_VCCR_NUMC4_Msk
10233#define DSI_VCCR_NUMC5_Pos (5U)
10234#define DSI_VCCR_NUMC5_Msk (0x1UL << DSI_VCCR_NUMC5_Pos)
10235#define DSI_VCCR_NUMC5 DSI_VCCR_NUMC5_Msk
10236#define DSI_VCCR_NUMC6_Pos (6U)
10237#define DSI_VCCR_NUMC6_Msk (0x1UL << DSI_VCCR_NUMC6_Pos)
10238#define DSI_VCCR_NUMC6 DSI_VCCR_NUMC6_Msk
10239#define DSI_VCCR_NUMC7_Pos (7U)
10240#define DSI_VCCR_NUMC7_Msk (0x1UL << DSI_VCCR_NUMC7_Pos)
10241#define DSI_VCCR_NUMC7 DSI_VCCR_NUMC7_Msk
10242#define DSI_VCCR_NUMC8_Pos (8U)
10243#define DSI_VCCR_NUMC8_Msk (0x1UL << DSI_VCCR_NUMC8_Pos)
10244#define DSI_VCCR_NUMC8 DSI_VCCR_NUMC8_Msk
10245#define DSI_VCCR_NUMC9_Pos (9U)
10246#define DSI_VCCR_NUMC9_Msk (0x1UL << DSI_VCCR_NUMC9_Pos)
10247#define DSI_VCCR_NUMC9 DSI_VCCR_NUMC9_Msk
10248#define DSI_VCCR_NUMC10_Pos (10U)
10249#define DSI_VCCR_NUMC10_Msk (0x1UL << DSI_VCCR_NUMC10_Pos)
10250#define DSI_VCCR_NUMC10 DSI_VCCR_NUMC10_Msk
10251#define DSI_VCCR_NUMC11_Pos (11U)
10252#define DSI_VCCR_NUMC11_Msk (0x1UL << DSI_VCCR_NUMC11_Pos)
10253#define DSI_VCCR_NUMC11 DSI_VCCR_NUMC11_Msk
10254#define DSI_VCCR_NUMC12_Pos (12U)
10255#define DSI_VCCR_NUMC12_Msk (0x1UL << DSI_VCCR_NUMC12_Pos)
10256#define DSI_VCCR_NUMC12 DSI_VCCR_NUMC12_Msk
10257
10258/******************* Bit definition for DSI_VNPCR register **************/
10259#define DSI_VNPCR_NPSIZE_Pos (0U)
10260#define DSI_VNPCR_NPSIZE_Msk (0x1FFFUL << DSI_VNPCR_NPSIZE_Pos)
10261#define DSI_VNPCR_NPSIZE DSI_VNPCR_NPSIZE_Msk
10262#define DSI_VNPCR_NPSIZE0_Pos (0U)
10263#define DSI_VNPCR_NPSIZE0_Msk (0x1UL << DSI_VNPCR_NPSIZE0_Pos)
10264#define DSI_VNPCR_NPSIZE0 DSI_VNPCR_NPSIZE0_Msk
10265#define DSI_VNPCR_NPSIZE1_Pos (1U)
10266#define DSI_VNPCR_NPSIZE1_Msk (0x1UL << DSI_VNPCR_NPSIZE1_Pos)
10267#define DSI_VNPCR_NPSIZE1 DSI_VNPCR_NPSIZE1_Msk
10268#define DSI_VNPCR_NPSIZE2_Pos (2U)
10269#define DSI_VNPCR_NPSIZE2_Msk (0x1UL << DSI_VNPCR_NPSIZE2_Pos)
10270#define DSI_VNPCR_NPSIZE2 DSI_VNPCR_NPSIZE2_Msk
10271#define DSI_VNPCR_NPSIZE3_Pos (3U)
10272#define DSI_VNPCR_NPSIZE3_Msk (0x1UL << DSI_VNPCR_NPSIZE3_Pos)
10273#define DSI_VNPCR_NPSIZE3 DSI_VNPCR_NPSIZE3_Msk
10274#define DSI_VNPCR_NPSIZE4_Pos (4U)
10275#define DSI_VNPCR_NPSIZE4_Msk (0x1UL << DSI_VNPCR_NPSIZE4_Pos)
10276#define DSI_VNPCR_NPSIZE4 DSI_VNPCR_NPSIZE4_Msk
10277#define DSI_VNPCR_NPSIZE5_Pos (5U)
10278#define DSI_VNPCR_NPSIZE5_Msk (0x1UL << DSI_VNPCR_NPSIZE5_Pos)
10279#define DSI_VNPCR_NPSIZE5 DSI_VNPCR_NPSIZE5_Msk
10280#define DSI_VNPCR_NPSIZE6_Pos (6U)
10281#define DSI_VNPCR_NPSIZE6_Msk (0x1UL << DSI_VNPCR_NPSIZE6_Pos)
10282#define DSI_VNPCR_NPSIZE6 DSI_VNPCR_NPSIZE6_Msk
10283#define DSI_VNPCR_NPSIZE7_Pos (7U)
10284#define DSI_VNPCR_NPSIZE7_Msk (0x1UL << DSI_VNPCR_NPSIZE7_Pos)
10285#define DSI_VNPCR_NPSIZE7 DSI_VNPCR_NPSIZE7_Msk
10286#define DSI_VNPCR_NPSIZE8_Pos (8U)
10287#define DSI_VNPCR_NPSIZE8_Msk (0x1UL << DSI_VNPCR_NPSIZE8_Pos)
10288#define DSI_VNPCR_NPSIZE8 DSI_VNPCR_NPSIZE8_Msk
10289#define DSI_VNPCR_NPSIZE9_Pos (9U)
10290#define DSI_VNPCR_NPSIZE9_Msk (0x1UL << DSI_VNPCR_NPSIZE9_Pos)
10291#define DSI_VNPCR_NPSIZE9 DSI_VNPCR_NPSIZE9_Msk
10292#define DSI_VNPCR_NPSIZE10_Pos (10U)
10293#define DSI_VNPCR_NPSIZE10_Msk (0x1UL << DSI_VNPCR_NPSIZE10_Pos)
10294#define DSI_VNPCR_NPSIZE10 DSI_VNPCR_NPSIZE10_Msk
10295#define DSI_VNPCR_NPSIZE11_Pos (11U)
10296#define DSI_VNPCR_NPSIZE11_Msk (0x1UL << DSI_VNPCR_NPSIZE11_Pos)
10297#define DSI_VNPCR_NPSIZE11 DSI_VNPCR_NPSIZE11_Msk
10298#define DSI_VNPCR_NPSIZE12_Pos (12U)
10299#define DSI_VNPCR_NPSIZE12_Msk (0x1UL << DSI_VNPCR_NPSIZE12_Pos)
10300#define DSI_VNPCR_NPSIZE12 DSI_VNPCR_NPSIZE12_Msk
10301
10302/******************* Bit definition for DSI_VHSACR register *************/
10303#define DSI_VHSACR_HSA_Pos (0U)
10304#define DSI_VHSACR_HSA_Msk (0xFFFUL << DSI_VHSACR_HSA_Pos)
10305#define DSI_VHSACR_HSA DSI_VHSACR_HSA_Msk
10306#define DSI_VHSACR_HSA0_Pos (0U)
10307#define DSI_VHSACR_HSA0_Msk (0x1UL << DSI_VHSACR_HSA0_Pos)
10308#define DSI_VHSACR_HSA0 DSI_VHSACR_HSA0_Msk
10309#define DSI_VHSACR_HSA1_Pos (1U)
10310#define DSI_VHSACR_HSA1_Msk (0x1UL << DSI_VHSACR_HSA1_Pos)
10311#define DSI_VHSACR_HSA1 DSI_VHSACR_HSA1_Msk
10312#define DSI_VHSACR_HSA2_Pos (2U)
10313#define DSI_VHSACR_HSA2_Msk (0x1UL << DSI_VHSACR_HSA2_Pos)
10314#define DSI_VHSACR_HSA2 DSI_VHSACR_HSA2_Msk
10315#define DSI_VHSACR_HSA3_Pos (3U)
10316#define DSI_VHSACR_HSA3_Msk (0x1UL << DSI_VHSACR_HSA3_Pos)
10317#define DSI_VHSACR_HSA3 DSI_VHSACR_HSA3_Msk
10318#define DSI_VHSACR_HSA4_Pos (4U)
10319#define DSI_VHSACR_HSA4_Msk (0x1UL << DSI_VHSACR_HSA4_Pos)
10320#define DSI_VHSACR_HSA4 DSI_VHSACR_HSA4_Msk
10321#define DSI_VHSACR_HSA5_Pos (5U)
10322#define DSI_VHSACR_HSA5_Msk (0x1UL << DSI_VHSACR_HSA5_Pos)
10323#define DSI_VHSACR_HSA5 DSI_VHSACR_HSA5_Msk
10324#define DSI_VHSACR_HSA6_Pos (6U)
10325#define DSI_VHSACR_HSA6_Msk (0x1UL << DSI_VHSACR_HSA6_Pos)
10326#define DSI_VHSACR_HSA6 DSI_VHSACR_HSA6_Msk
10327#define DSI_VHSACR_HSA7_Pos (7U)
10328#define DSI_VHSACR_HSA7_Msk (0x1UL << DSI_VHSACR_HSA7_Pos)
10329#define DSI_VHSACR_HSA7 DSI_VHSACR_HSA7_Msk
10330#define DSI_VHSACR_HSA8_Pos (8U)
10331#define DSI_VHSACR_HSA8_Msk (0x1UL << DSI_VHSACR_HSA8_Pos)
10332#define DSI_VHSACR_HSA8 DSI_VHSACR_HSA8_Msk
10333#define DSI_VHSACR_HSA9_Pos (9U)
10334#define DSI_VHSACR_HSA9_Msk (0x1UL << DSI_VHSACR_HSA9_Pos)
10335#define DSI_VHSACR_HSA9 DSI_VHSACR_HSA9_Msk
10336#define DSI_VHSACR_HSA10_Pos (10U)
10337#define DSI_VHSACR_HSA10_Msk (0x1UL << DSI_VHSACR_HSA10_Pos)
10338#define DSI_VHSACR_HSA10 DSI_VHSACR_HSA10_Msk
10339#define DSI_VHSACR_HSA11_Pos (11U)
10340#define DSI_VHSACR_HSA11_Msk (0x1UL << DSI_VHSACR_HSA11_Pos)
10341#define DSI_VHSACR_HSA11 DSI_VHSACR_HSA11_Msk
10342
10343/******************* Bit definition for DSI_VHBPCR register *************/
10344#define DSI_VHBPCR_HBP_Pos (0U)
10345#define DSI_VHBPCR_HBP_Msk (0xFFFUL << DSI_VHBPCR_HBP_Pos)
10346#define DSI_VHBPCR_HBP DSI_VHBPCR_HBP_Msk
10347#define DSI_VHBPCR_HBP0_Pos (0U)
10348#define DSI_VHBPCR_HBP0_Msk (0x1UL << DSI_VHBPCR_HBP0_Pos)
10349#define DSI_VHBPCR_HBP0 DSI_VHBPCR_HBP0_Msk
10350#define DSI_VHBPCR_HBP1_Pos (1U)
10351#define DSI_VHBPCR_HBP1_Msk (0x1UL << DSI_VHBPCR_HBP1_Pos)
10352#define DSI_VHBPCR_HBP1 DSI_VHBPCR_HBP1_Msk
10353#define DSI_VHBPCR_HBP2_Pos (2U)
10354#define DSI_VHBPCR_HBP2_Msk (0x1UL << DSI_VHBPCR_HBP2_Pos)
10355#define DSI_VHBPCR_HBP2 DSI_VHBPCR_HBP2_Msk
10356#define DSI_VHBPCR_HBP3_Pos (3U)
10357#define DSI_VHBPCR_HBP3_Msk (0x1UL << DSI_VHBPCR_HBP3_Pos)
10358#define DSI_VHBPCR_HBP3 DSI_VHBPCR_HBP3_Msk
10359#define DSI_VHBPCR_HBP4_Pos (4U)
10360#define DSI_VHBPCR_HBP4_Msk (0x1UL << DSI_VHBPCR_HBP4_Pos)
10361#define DSI_VHBPCR_HBP4 DSI_VHBPCR_HBP4_Msk
10362#define DSI_VHBPCR_HBP5_Pos (5U)
10363#define DSI_VHBPCR_HBP5_Msk (0x1UL << DSI_VHBPCR_HBP5_Pos)
10364#define DSI_VHBPCR_HBP5 DSI_VHBPCR_HBP5_Msk
10365#define DSI_VHBPCR_HBP6_Pos (6U)
10366#define DSI_VHBPCR_HBP6_Msk (0x1UL << DSI_VHBPCR_HBP6_Pos)
10367#define DSI_VHBPCR_HBP6 DSI_VHBPCR_HBP6_Msk
10368#define DSI_VHBPCR_HBP7_Pos (7U)
10369#define DSI_VHBPCR_HBP7_Msk (0x1UL << DSI_VHBPCR_HBP7_Pos)
10370#define DSI_VHBPCR_HBP7 DSI_VHBPCR_HBP7_Msk
10371#define DSI_VHBPCR_HBP8_Pos (8U)
10372#define DSI_VHBPCR_HBP8_Msk (0x1UL << DSI_VHBPCR_HBP8_Pos)
10373#define DSI_VHBPCR_HBP8 DSI_VHBPCR_HBP8_Msk
10374#define DSI_VHBPCR_HBP9_Pos (9U)
10375#define DSI_VHBPCR_HBP9_Msk (0x1UL << DSI_VHBPCR_HBP9_Pos)
10376#define DSI_VHBPCR_HBP9 DSI_VHBPCR_HBP9_Msk
10377#define DSI_VHBPCR_HBP10_Pos (10U)
10378#define DSI_VHBPCR_HBP10_Msk (0x1UL << DSI_VHBPCR_HBP10_Pos)
10379#define DSI_VHBPCR_HBP10 DSI_VHBPCR_HBP10_Msk
10380#define DSI_VHBPCR_HBP11_Pos (11U)
10381#define DSI_VHBPCR_HBP11_Msk (0x1UL << DSI_VHBPCR_HBP11_Pos)
10382#define DSI_VHBPCR_HBP11 DSI_VHBPCR_HBP11_Msk
10383
10384/******************* Bit definition for DSI_VLCR register ***************/
10385#define DSI_VLCR_HLINE_Pos (0U)
10386#define DSI_VLCR_HLINE_Msk (0x7FFFUL << DSI_VLCR_HLINE_Pos)
10387#define DSI_VLCR_HLINE DSI_VLCR_HLINE_Msk
10388#define DSI_VLCR_HLINE0_Pos (0U)
10389#define DSI_VLCR_HLINE0_Msk (0x1UL << DSI_VLCR_HLINE0_Pos)
10390#define DSI_VLCR_HLINE0 DSI_VLCR_HLINE0_Msk
10391#define DSI_VLCR_HLINE1_Pos (1U)
10392#define DSI_VLCR_HLINE1_Msk (0x1UL << DSI_VLCR_HLINE1_Pos)
10393#define DSI_VLCR_HLINE1 DSI_VLCR_HLINE1_Msk
10394#define DSI_VLCR_HLINE2_Pos (2U)
10395#define DSI_VLCR_HLINE2_Msk (0x1UL << DSI_VLCR_HLINE2_Pos)
10396#define DSI_VLCR_HLINE2 DSI_VLCR_HLINE2_Msk
10397#define DSI_VLCR_HLINE3_Pos (3U)
10398#define DSI_VLCR_HLINE3_Msk (0x1UL << DSI_VLCR_HLINE3_Pos)
10399#define DSI_VLCR_HLINE3 DSI_VLCR_HLINE3_Msk
10400#define DSI_VLCR_HLINE4_Pos (4U)
10401#define DSI_VLCR_HLINE4_Msk (0x1UL << DSI_VLCR_HLINE4_Pos)
10402#define DSI_VLCR_HLINE4 DSI_VLCR_HLINE4_Msk
10403#define DSI_VLCR_HLINE5_Pos (5U)
10404#define DSI_VLCR_HLINE5_Msk (0x1UL << DSI_VLCR_HLINE5_Pos)
10405#define DSI_VLCR_HLINE5 DSI_VLCR_HLINE5_Msk
10406#define DSI_VLCR_HLINE6_Pos (6U)
10407#define DSI_VLCR_HLINE6_Msk (0x1UL << DSI_VLCR_HLINE6_Pos)
10408#define DSI_VLCR_HLINE6 DSI_VLCR_HLINE6_Msk
10409#define DSI_VLCR_HLINE7_Pos (7U)
10410#define DSI_VLCR_HLINE7_Msk (0x1UL << DSI_VLCR_HLINE7_Pos)
10411#define DSI_VLCR_HLINE7 DSI_VLCR_HLINE7_Msk
10412#define DSI_VLCR_HLINE8_Pos (8U)
10413#define DSI_VLCR_HLINE8_Msk (0x1UL << DSI_VLCR_HLINE8_Pos)
10414#define DSI_VLCR_HLINE8 DSI_VLCR_HLINE8_Msk
10415#define DSI_VLCR_HLINE9_Pos (9U)
10416#define DSI_VLCR_HLINE9_Msk (0x1UL << DSI_VLCR_HLINE9_Pos)
10417#define DSI_VLCR_HLINE9 DSI_VLCR_HLINE9_Msk
10418#define DSI_VLCR_HLINE10_Pos (10U)
10419#define DSI_VLCR_HLINE10_Msk (0x1UL << DSI_VLCR_HLINE10_Pos)
10420#define DSI_VLCR_HLINE10 DSI_VLCR_HLINE10_Msk
10421#define DSI_VLCR_HLINE11_Pos (11U)
10422#define DSI_VLCR_HLINE11_Msk (0x1UL << DSI_VLCR_HLINE11_Pos)
10423#define DSI_VLCR_HLINE11 DSI_VLCR_HLINE11_Msk
10424#define DSI_VLCR_HLINE12_Pos (12U)
10425#define DSI_VLCR_HLINE12_Msk (0x1UL << DSI_VLCR_HLINE12_Pos)
10426#define DSI_VLCR_HLINE12 DSI_VLCR_HLINE12_Msk
10427#define DSI_VLCR_HLINE13_Pos (13U)
10428#define DSI_VLCR_HLINE13_Msk (0x1UL << DSI_VLCR_HLINE13_Pos)
10429#define DSI_VLCR_HLINE13 DSI_VLCR_HLINE13_Msk
10430#define DSI_VLCR_HLINE14_Pos (14U)
10431#define DSI_VLCR_HLINE14_Msk (0x1UL << DSI_VLCR_HLINE14_Pos)
10432#define DSI_VLCR_HLINE14 DSI_VLCR_HLINE14_Msk
10433
10434/******************* Bit definition for DSI_VVSACR register *************/
10435#define DSI_VVSACR_VSA_Pos (0U)
10436#define DSI_VVSACR_VSA_Msk (0x3FFUL << DSI_VVSACR_VSA_Pos)
10437#define DSI_VVSACR_VSA DSI_VVSACR_VSA_Msk
10438#define DSI_VVSACR_VSA0_Pos (0U)
10439#define DSI_VVSACR_VSA0_Msk (0x1UL << DSI_VVSACR_VSA0_Pos)
10440#define DSI_VVSACR_VSA0 DSI_VVSACR_VSA0_Msk
10441#define DSI_VVSACR_VSA1_Pos (1U)
10442#define DSI_VVSACR_VSA1_Msk (0x1UL << DSI_VVSACR_VSA1_Pos)
10443#define DSI_VVSACR_VSA1 DSI_VVSACR_VSA1_Msk
10444#define DSI_VVSACR_VSA2_Pos (2U)
10445#define DSI_VVSACR_VSA2_Msk (0x1UL << DSI_VVSACR_VSA2_Pos)
10446#define DSI_VVSACR_VSA2 DSI_VVSACR_VSA2_Msk
10447#define DSI_VVSACR_VSA3_Pos (3U)
10448#define DSI_VVSACR_VSA3_Msk (0x1UL << DSI_VVSACR_VSA3_Pos)
10449#define DSI_VVSACR_VSA3 DSI_VVSACR_VSA3_Msk
10450#define DSI_VVSACR_VSA4_Pos (4U)
10451#define DSI_VVSACR_VSA4_Msk (0x1UL << DSI_VVSACR_VSA4_Pos)
10452#define DSI_VVSACR_VSA4 DSI_VVSACR_VSA4_Msk
10453#define DSI_VVSACR_VSA5_Pos (5U)
10454#define DSI_VVSACR_VSA5_Msk (0x1UL << DSI_VVSACR_VSA5_Pos)
10455#define DSI_VVSACR_VSA5 DSI_VVSACR_VSA5_Msk
10456#define DSI_VVSACR_VSA6_Pos (6U)
10457#define DSI_VVSACR_VSA6_Msk (0x1UL << DSI_VVSACR_VSA6_Pos)
10458#define DSI_VVSACR_VSA6 DSI_VVSACR_VSA6_Msk
10459#define DSI_VVSACR_VSA7_Pos (7U)
10460#define DSI_VVSACR_VSA7_Msk (0x1UL << DSI_VVSACR_VSA7_Pos)
10461#define DSI_VVSACR_VSA7 DSI_VVSACR_VSA7_Msk
10462#define DSI_VVSACR_VSA8_Pos (8U)
10463#define DSI_VVSACR_VSA8_Msk (0x1UL << DSI_VVSACR_VSA8_Pos)
10464#define DSI_VVSACR_VSA8 DSI_VVSACR_VSA8_Msk
10465#define DSI_VVSACR_VSA9_Pos (9U)
10466#define DSI_VVSACR_VSA9_Msk (0x1UL << DSI_VVSACR_VSA9_Pos)
10467#define DSI_VVSACR_VSA9 DSI_VVSACR_VSA9_Msk
10468
10469/******************* Bit definition for DSI_VVBPCR register *************/
10470#define DSI_VVBPCR_VBP_Pos (0U)
10471#define DSI_VVBPCR_VBP_Msk (0x3FFUL << DSI_VVBPCR_VBP_Pos)
10472#define DSI_VVBPCR_VBP DSI_VVBPCR_VBP_Msk
10473#define DSI_VVBPCR_VBP0_Pos (0U)
10474#define DSI_VVBPCR_VBP0_Msk (0x1UL << DSI_VVBPCR_VBP0_Pos)
10475#define DSI_VVBPCR_VBP0 DSI_VVBPCR_VBP0_Msk
10476#define DSI_VVBPCR_VBP1_Pos (1U)
10477#define DSI_VVBPCR_VBP1_Msk (0x1UL << DSI_VVBPCR_VBP1_Pos)
10478#define DSI_VVBPCR_VBP1 DSI_VVBPCR_VBP1_Msk
10479#define DSI_VVBPCR_VBP2_Pos (2U)
10480#define DSI_VVBPCR_VBP2_Msk (0x1UL << DSI_VVBPCR_VBP2_Pos)
10481#define DSI_VVBPCR_VBP2 DSI_VVBPCR_VBP2_Msk
10482#define DSI_VVBPCR_VBP3_Pos (3U)
10483#define DSI_VVBPCR_VBP3_Msk (0x1UL << DSI_VVBPCR_VBP3_Pos)
10484#define DSI_VVBPCR_VBP3 DSI_VVBPCR_VBP3_Msk
10485#define DSI_VVBPCR_VBP4_Pos (4U)
10486#define DSI_VVBPCR_VBP4_Msk (0x1UL << DSI_VVBPCR_VBP4_Pos)
10487#define DSI_VVBPCR_VBP4 DSI_VVBPCR_VBP4_Msk
10488#define DSI_VVBPCR_VBP5_Pos (5U)
10489#define DSI_VVBPCR_VBP5_Msk (0x1UL << DSI_VVBPCR_VBP5_Pos)
10490#define DSI_VVBPCR_VBP5 DSI_VVBPCR_VBP5_Msk
10491#define DSI_VVBPCR_VBP6_Pos (6U)
10492#define DSI_VVBPCR_VBP6_Msk (0x1UL << DSI_VVBPCR_VBP6_Pos)
10493#define DSI_VVBPCR_VBP6 DSI_VVBPCR_VBP6_Msk
10494#define DSI_VVBPCR_VBP7_Pos (7U)
10495#define DSI_VVBPCR_VBP7_Msk (0x1UL << DSI_VVBPCR_VBP7_Pos)
10496#define DSI_VVBPCR_VBP7 DSI_VVBPCR_VBP7_Msk
10497#define DSI_VVBPCR_VBP8_Pos (8U)
10498#define DSI_VVBPCR_VBP8_Msk (0x1UL << DSI_VVBPCR_VBP8_Pos)
10499#define DSI_VVBPCR_VBP8 DSI_VVBPCR_VBP8_Msk
10500#define DSI_VVBPCR_VBP9_Pos (9U)
10501#define DSI_VVBPCR_VBP9_Msk (0x1UL << DSI_VVBPCR_VBP9_Pos)
10502#define DSI_VVBPCR_VBP9 DSI_VVBPCR_VBP9_Msk
10503
10504/******************* Bit definition for DSI_VVFPCR register *************/
10505#define DSI_VVFPCR_VFP_Pos (0U)
10506#define DSI_VVFPCR_VFP_Msk (0x3FFUL << DSI_VVFPCR_VFP_Pos)
10507#define DSI_VVFPCR_VFP DSI_VVFPCR_VFP_Msk
10508#define DSI_VVFPCR_VFP0_Pos (0U)
10509#define DSI_VVFPCR_VFP0_Msk (0x1UL << DSI_VVFPCR_VFP0_Pos)
10510#define DSI_VVFPCR_VFP0 DSI_VVFPCR_VFP0_Msk
10511#define DSI_VVFPCR_VFP1_Pos (1U)
10512#define DSI_VVFPCR_VFP1_Msk (0x1UL << DSI_VVFPCR_VFP1_Pos)
10513#define DSI_VVFPCR_VFP1 DSI_VVFPCR_VFP1_Msk
10514#define DSI_VVFPCR_VFP2_Pos (2U)
10515#define DSI_VVFPCR_VFP2_Msk (0x1UL << DSI_VVFPCR_VFP2_Pos)
10516#define DSI_VVFPCR_VFP2 DSI_VVFPCR_VFP2_Msk
10517#define DSI_VVFPCR_VFP3_Pos (3U)
10518#define DSI_VVFPCR_VFP3_Msk (0x1UL << DSI_VVFPCR_VFP3_Pos)
10519#define DSI_VVFPCR_VFP3 DSI_VVFPCR_VFP3_Msk
10520#define DSI_VVFPCR_VFP4_Pos (4U)
10521#define DSI_VVFPCR_VFP4_Msk (0x1UL << DSI_VVFPCR_VFP4_Pos)
10522#define DSI_VVFPCR_VFP4 DSI_VVFPCR_VFP4_Msk
10523#define DSI_VVFPCR_VFP5_Pos (5U)
10524#define DSI_VVFPCR_VFP5_Msk (0x1UL << DSI_VVFPCR_VFP5_Pos)
10525#define DSI_VVFPCR_VFP5 DSI_VVFPCR_VFP5_Msk
10526#define DSI_VVFPCR_VFP6_Pos (6U)
10527#define DSI_VVFPCR_VFP6_Msk (0x1UL << DSI_VVFPCR_VFP6_Pos)
10528#define DSI_VVFPCR_VFP6 DSI_VVFPCR_VFP6_Msk
10529#define DSI_VVFPCR_VFP7_Pos (7U)
10530#define DSI_VVFPCR_VFP7_Msk (0x1UL << DSI_VVFPCR_VFP7_Pos)
10531#define DSI_VVFPCR_VFP7 DSI_VVFPCR_VFP7_Msk
10532#define DSI_VVFPCR_VFP8_Pos (8U)
10533#define DSI_VVFPCR_VFP8_Msk (0x1UL << DSI_VVFPCR_VFP8_Pos)
10534#define DSI_VVFPCR_VFP8 DSI_VVFPCR_VFP8_Msk
10535#define DSI_VVFPCR_VFP9_Pos (9U)
10536#define DSI_VVFPCR_VFP9_Msk (0x1UL << DSI_VVFPCR_VFP9_Pos)
10537#define DSI_VVFPCR_VFP9 DSI_VVFPCR_VFP9_Msk
10538
10539/******************* Bit definition for DSI_VVACR register **************/
10540#define DSI_VVACR_VA_Pos (0U)
10541#define DSI_VVACR_VA_Msk (0x3FFFUL << DSI_VVACR_VA_Pos)
10542#define DSI_VVACR_VA DSI_VVACR_VA_Msk
10543#define DSI_VVACR_VA0_Pos (0U)
10544#define DSI_VVACR_VA0_Msk (0x1UL << DSI_VVACR_VA0_Pos)
10545#define DSI_VVACR_VA0 DSI_VVACR_VA0_Msk
10546#define DSI_VVACR_VA1_Pos (1U)
10547#define DSI_VVACR_VA1_Msk (0x1UL << DSI_VVACR_VA1_Pos)
10548#define DSI_VVACR_VA1 DSI_VVACR_VA1_Msk
10549#define DSI_VVACR_VA2_Pos (2U)
10550#define DSI_VVACR_VA2_Msk (0x1UL << DSI_VVACR_VA2_Pos)
10551#define DSI_VVACR_VA2 DSI_VVACR_VA2_Msk
10552#define DSI_VVACR_VA3_Pos (3U)
10553#define DSI_VVACR_VA3_Msk (0x1UL << DSI_VVACR_VA3_Pos)
10554#define DSI_VVACR_VA3 DSI_VVACR_VA3_Msk
10555#define DSI_VVACR_VA4_Pos (4U)
10556#define DSI_VVACR_VA4_Msk (0x1UL << DSI_VVACR_VA4_Pos)
10557#define DSI_VVACR_VA4 DSI_VVACR_VA4_Msk
10558#define DSI_VVACR_VA5_Pos (5U)
10559#define DSI_VVACR_VA5_Msk (0x1UL << DSI_VVACR_VA5_Pos)
10560#define DSI_VVACR_VA5 DSI_VVACR_VA5_Msk
10561#define DSI_VVACR_VA6_Pos (6U)
10562#define DSI_VVACR_VA6_Msk (0x1UL << DSI_VVACR_VA6_Pos)
10563#define DSI_VVACR_VA6 DSI_VVACR_VA6_Msk
10564#define DSI_VVACR_VA7_Pos (7U)
10565#define DSI_VVACR_VA7_Msk (0x1UL << DSI_VVACR_VA7_Pos)
10566#define DSI_VVACR_VA7 DSI_VVACR_VA7_Msk
10567#define DSI_VVACR_VA8_Pos (8U)
10568#define DSI_VVACR_VA8_Msk (0x1UL << DSI_VVACR_VA8_Pos)
10569#define DSI_VVACR_VA8 DSI_VVACR_VA8_Msk
10570#define DSI_VVACR_VA9_Pos (9U)
10571#define DSI_VVACR_VA9_Msk (0x1UL << DSI_VVACR_VA9_Pos)
10572#define DSI_VVACR_VA9 DSI_VVACR_VA9_Msk
10573#define DSI_VVACR_VA10_Pos (10U)
10574#define DSI_VVACR_VA10_Msk (0x1UL << DSI_VVACR_VA10_Pos)
10575#define DSI_VVACR_VA10 DSI_VVACR_VA10_Msk
10576#define DSI_VVACR_VA11_Pos (11U)
10577#define DSI_VVACR_VA11_Msk (0x1UL << DSI_VVACR_VA11_Pos)
10578#define DSI_VVACR_VA11 DSI_VVACR_VA11_Msk
10579#define DSI_VVACR_VA12_Pos (12U)
10580#define DSI_VVACR_VA12_Msk (0x1UL << DSI_VVACR_VA12_Pos)
10581#define DSI_VVACR_VA12 DSI_VVACR_VA12_Msk
10582#define DSI_VVACR_VA13_Pos (13U)
10583#define DSI_VVACR_VA13_Msk (0x1UL << DSI_VVACR_VA13_Pos)
10584#define DSI_VVACR_VA13 DSI_VVACR_VA13_Msk
10585
10586/******************* Bit definition for DSI_LCCR register ***************/
10587#define DSI_LCCR_CMDSIZE_Pos (0U)
10588#define DSI_LCCR_CMDSIZE_Msk (0xFFFFUL << DSI_LCCR_CMDSIZE_Pos)
10589#define DSI_LCCR_CMDSIZE DSI_LCCR_CMDSIZE_Msk
10590#define DSI_LCCR_CMDSIZE0_Pos (0U)
10591#define DSI_LCCR_CMDSIZE0_Msk (0x1UL << DSI_LCCR_CMDSIZE0_Pos)
10592#define DSI_LCCR_CMDSIZE0 DSI_LCCR_CMDSIZE0_Msk
10593#define DSI_LCCR_CMDSIZE1_Pos (1U)
10594#define DSI_LCCR_CMDSIZE1_Msk (0x1UL << DSI_LCCR_CMDSIZE1_Pos)
10595#define DSI_LCCR_CMDSIZE1 DSI_LCCR_CMDSIZE1_Msk
10596#define DSI_LCCR_CMDSIZE2_Pos (2U)
10597#define DSI_LCCR_CMDSIZE2_Msk (0x1UL << DSI_LCCR_CMDSIZE2_Pos)
10598#define DSI_LCCR_CMDSIZE2 DSI_LCCR_CMDSIZE2_Msk
10599#define DSI_LCCR_CMDSIZE3_Pos (3U)
10600#define DSI_LCCR_CMDSIZE3_Msk (0x1UL << DSI_LCCR_CMDSIZE3_Pos)
10601#define DSI_LCCR_CMDSIZE3 DSI_LCCR_CMDSIZE3_Msk
10602#define DSI_LCCR_CMDSIZE4_Pos (4U)
10603#define DSI_LCCR_CMDSIZE4_Msk (0x1UL << DSI_LCCR_CMDSIZE4_Pos)
10604#define DSI_LCCR_CMDSIZE4 DSI_LCCR_CMDSIZE4_Msk
10605#define DSI_LCCR_CMDSIZE5_Pos (5U)
10606#define DSI_LCCR_CMDSIZE5_Msk (0x1UL << DSI_LCCR_CMDSIZE5_Pos)
10607#define DSI_LCCR_CMDSIZE5 DSI_LCCR_CMDSIZE5_Msk
10608#define DSI_LCCR_CMDSIZE6_Pos (6U)
10609#define DSI_LCCR_CMDSIZE6_Msk (0x1UL << DSI_LCCR_CMDSIZE6_Pos)
10610#define DSI_LCCR_CMDSIZE6 DSI_LCCR_CMDSIZE6_Msk
10611#define DSI_LCCR_CMDSIZE7_Pos (7U)
10612#define DSI_LCCR_CMDSIZE7_Msk (0x1UL << DSI_LCCR_CMDSIZE7_Pos)
10613#define DSI_LCCR_CMDSIZE7 DSI_LCCR_CMDSIZE7_Msk
10614#define DSI_LCCR_CMDSIZE8_Pos (8U)
10615#define DSI_LCCR_CMDSIZE8_Msk (0x1UL << DSI_LCCR_CMDSIZE8_Pos)
10616#define DSI_LCCR_CMDSIZE8 DSI_LCCR_CMDSIZE8_Msk
10617#define DSI_LCCR_CMDSIZE9_Pos (9U)
10618#define DSI_LCCR_CMDSIZE9_Msk (0x1UL << DSI_LCCR_CMDSIZE9_Pos)
10619#define DSI_LCCR_CMDSIZE9 DSI_LCCR_CMDSIZE9_Msk
10620#define DSI_LCCR_CMDSIZE10_Pos (10U)
10621#define DSI_LCCR_CMDSIZE10_Msk (0x1UL << DSI_LCCR_CMDSIZE10_Pos)
10622#define DSI_LCCR_CMDSIZE10 DSI_LCCR_CMDSIZE10_Msk
10623#define DSI_LCCR_CMDSIZE11_Pos (11U)
10624#define DSI_LCCR_CMDSIZE11_Msk (0x1UL << DSI_LCCR_CMDSIZE11_Pos)
10625#define DSI_LCCR_CMDSIZE11 DSI_LCCR_CMDSIZE11_Msk
10626#define DSI_LCCR_CMDSIZE12_Pos (12U)
10627#define DSI_LCCR_CMDSIZE12_Msk (0x1UL << DSI_LCCR_CMDSIZE12_Pos)
10628#define DSI_LCCR_CMDSIZE12 DSI_LCCR_CMDSIZE12_Msk
10629#define DSI_LCCR_CMDSIZE13_Pos (13U)
10630#define DSI_LCCR_CMDSIZE13_Msk (0x1UL << DSI_LCCR_CMDSIZE13_Pos)
10631#define DSI_LCCR_CMDSIZE13 DSI_LCCR_CMDSIZE13_Msk
10632#define DSI_LCCR_CMDSIZE14_Pos (14U)
10633#define DSI_LCCR_CMDSIZE14_Msk (0x1UL << DSI_LCCR_CMDSIZE14_Pos)
10634#define DSI_LCCR_CMDSIZE14 DSI_LCCR_CMDSIZE14_Msk
10635#define DSI_LCCR_CMDSIZE15_Pos (15U)
10636#define DSI_LCCR_CMDSIZE15_Msk (0x1UL << DSI_LCCR_CMDSIZE15_Pos)
10637#define DSI_LCCR_CMDSIZE15 DSI_LCCR_CMDSIZE15_Msk
10638
10639/******************* Bit definition for DSI_CMCR register ***************/
10640#define DSI_CMCR_TEARE_Pos (0U)
10641#define DSI_CMCR_TEARE_Msk (0x1UL << DSI_CMCR_TEARE_Pos)
10642#define DSI_CMCR_TEARE DSI_CMCR_TEARE_Msk
10643#define DSI_CMCR_ARE_Pos (1U)
10644#define DSI_CMCR_ARE_Msk (0x1UL << DSI_CMCR_ARE_Pos)
10645#define DSI_CMCR_ARE DSI_CMCR_ARE_Msk
10646#define DSI_CMCR_GSW0TX_Pos (8U)
10647#define DSI_CMCR_GSW0TX_Msk (0x1UL << DSI_CMCR_GSW0TX_Pos)
10648#define DSI_CMCR_GSW0TX DSI_CMCR_GSW0TX_Msk
10649#define DSI_CMCR_GSW1TX_Pos (9U)
10650#define DSI_CMCR_GSW1TX_Msk (0x1UL << DSI_CMCR_GSW1TX_Pos)
10651#define DSI_CMCR_GSW1TX DSI_CMCR_GSW1TX_Msk
10652#define DSI_CMCR_GSW2TX_Pos (10U)
10653#define DSI_CMCR_GSW2TX_Msk (0x1UL << DSI_CMCR_GSW2TX_Pos)
10654#define DSI_CMCR_GSW2TX DSI_CMCR_GSW2TX_Msk
10655#define DSI_CMCR_GSR0TX_Pos (11U)
10656#define DSI_CMCR_GSR0TX_Msk (0x1UL << DSI_CMCR_GSR0TX_Pos)
10657#define DSI_CMCR_GSR0TX DSI_CMCR_GSR0TX_Msk
10658#define DSI_CMCR_GSR1TX_Pos (12U)
10659#define DSI_CMCR_GSR1TX_Msk (0x1UL << DSI_CMCR_GSR1TX_Pos)
10660#define DSI_CMCR_GSR1TX DSI_CMCR_GSR1TX_Msk
10661#define DSI_CMCR_GSR2TX_Pos (13U)
10662#define DSI_CMCR_GSR2TX_Msk (0x1UL << DSI_CMCR_GSR2TX_Pos)
10663#define DSI_CMCR_GSR2TX DSI_CMCR_GSR2TX_Msk
10664#define DSI_CMCR_GLWTX_Pos (14U)
10665#define DSI_CMCR_GLWTX_Msk (0x1UL << DSI_CMCR_GLWTX_Pos)
10666#define DSI_CMCR_GLWTX DSI_CMCR_GLWTX_Msk
10667#define DSI_CMCR_DSW0TX_Pos (16U)
10668#define DSI_CMCR_DSW0TX_Msk (0x1UL << DSI_CMCR_DSW0TX_Pos)
10669#define DSI_CMCR_DSW0TX DSI_CMCR_DSW0TX_Msk
10670#define DSI_CMCR_DSW1TX_Pos (17U)
10671#define DSI_CMCR_DSW1TX_Msk (0x1UL << DSI_CMCR_DSW1TX_Pos)
10672#define DSI_CMCR_DSW1TX DSI_CMCR_DSW1TX_Msk
10673#define DSI_CMCR_DSR0TX_Pos (18U)
10674#define DSI_CMCR_DSR0TX_Msk (0x1UL << DSI_CMCR_DSR0TX_Pos)
10675#define DSI_CMCR_DSR0TX DSI_CMCR_DSR0TX_Msk
10676#define DSI_CMCR_DLWTX_Pos (19U)
10677#define DSI_CMCR_DLWTX_Msk (0x1UL << DSI_CMCR_DLWTX_Pos)
10678#define DSI_CMCR_DLWTX DSI_CMCR_DLWTX_Msk
10679#define DSI_CMCR_MRDPS_Pos (24U)
10680#define DSI_CMCR_MRDPS_Msk (0x1UL << DSI_CMCR_MRDPS_Pos)
10681#define DSI_CMCR_MRDPS DSI_CMCR_MRDPS_Msk
10683/******************* Bit definition for DSI_GHCR register ***************/
10684#define DSI_GHCR_DT_Pos (0U)
10685#define DSI_GHCR_DT_Msk (0x3FUL << DSI_GHCR_DT_Pos)
10686#define DSI_GHCR_DT DSI_GHCR_DT_Msk
10687#define DSI_GHCR_DT0_Pos (0U)
10688#define DSI_GHCR_DT0_Msk (0x1UL << DSI_GHCR_DT0_Pos)
10689#define DSI_GHCR_DT0 DSI_GHCR_DT0_Msk
10690#define DSI_GHCR_DT1_Pos (1U)
10691#define DSI_GHCR_DT1_Msk (0x1UL << DSI_GHCR_DT1_Pos)
10692#define DSI_GHCR_DT1 DSI_GHCR_DT1_Msk
10693#define DSI_GHCR_DT2_Pos (2U)
10694#define DSI_GHCR_DT2_Msk (0x1UL << DSI_GHCR_DT2_Pos)
10695#define DSI_GHCR_DT2 DSI_GHCR_DT2_Msk
10696#define DSI_GHCR_DT3_Pos (3U)
10697#define DSI_GHCR_DT3_Msk (0x1UL << DSI_GHCR_DT3_Pos)
10698#define DSI_GHCR_DT3 DSI_GHCR_DT3_Msk
10699#define DSI_GHCR_DT4_Pos (4U)
10700#define DSI_GHCR_DT4_Msk (0x1UL << DSI_GHCR_DT4_Pos)
10701#define DSI_GHCR_DT4 DSI_GHCR_DT4_Msk
10702#define DSI_GHCR_DT5_Pos (5U)
10703#define DSI_GHCR_DT5_Msk (0x1UL << DSI_GHCR_DT5_Pos)
10704#define DSI_GHCR_DT5 DSI_GHCR_DT5_Msk
10705
10706#define DSI_GHCR_VCID_Pos (6U)
10707#define DSI_GHCR_VCID_Msk (0x3UL << DSI_GHCR_VCID_Pos)
10708#define DSI_GHCR_VCID DSI_GHCR_VCID_Msk
10709#define DSI_GHCR_VCID0_Pos (6U)
10710#define DSI_GHCR_VCID0_Msk (0x1UL << DSI_GHCR_VCID0_Pos)
10711#define DSI_GHCR_VCID0 DSI_GHCR_VCID0_Msk
10712#define DSI_GHCR_VCID1_Pos (7U)
10713#define DSI_GHCR_VCID1_Msk (0x1UL << DSI_GHCR_VCID1_Pos)
10714#define DSI_GHCR_VCID1 DSI_GHCR_VCID1_Msk
10715
10716#define DSI_GHCR_WCLSB_Pos (8U)
10717#define DSI_GHCR_WCLSB_Msk (0xFFUL << DSI_GHCR_WCLSB_Pos)
10718#define DSI_GHCR_WCLSB DSI_GHCR_WCLSB_Msk
10719#define DSI_GHCR_WCLSB0_Pos (8U)
10720#define DSI_GHCR_WCLSB0_Msk (0x1UL << DSI_GHCR_WCLSB0_Pos)
10721#define DSI_GHCR_WCLSB0 DSI_GHCR_WCLSB0_Msk
10722#define DSI_GHCR_WCLSB1_Pos (9U)
10723#define DSI_GHCR_WCLSB1_Msk (0x1UL << DSI_GHCR_WCLSB1_Pos)
10724#define DSI_GHCR_WCLSB1 DSI_GHCR_WCLSB1_Msk
10725#define DSI_GHCR_WCLSB2_Pos (10U)
10726#define DSI_GHCR_WCLSB2_Msk (0x1UL << DSI_GHCR_WCLSB2_Pos)
10727#define DSI_GHCR_WCLSB2 DSI_GHCR_WCLSB2_Msk
10728#define DSI_GHCR_WCLSB3_Pos (11U)
10729#define DSI_GHCR_WCLSB3_Msk (0x1UL << DSI_GHCR_WCLSB3_Pos)
10730#define DSI_GHCR_WCLSB3 DSI_GHCR_WCLSB3_Msk
10731#define DSI_GHCR_WCLSB4_Pos (12U)
10732#define DSI_GHCR_WCLSB4_Msk (0x1UL << DSI_GHCR_WCLSB4_Pos)
10733#define DSI_GHCR_WCLSB4 DSI_GHCR_WCLSB4_Msk
10734#define DSI_GHCR_WCLSB5_Pos (13U)
10735#define DSI_GHCR_WCLSB5_Msk (0x1UL << DSI_GHCR_WCLSB5_Pos)
10736#define DSI_GHCR_WCLSB5 DSI_GHCR_WCLSB5_Msk
10737#define DSI_GHCR_WCLSB6_Pos (14U)
10738#define DSI_GHCR_WCLSB6_Msk (0x1UL << DSI_GHCR_WCLSB6_Pos)
10739#define DSI_GHCR_WCLSB6 DSI_GHCR_WCLSB6_Msk
10740#define DSI_GHCR_WCLSB7_Pos (15U)
10741#define DSI_GHCR_WCLSB7_Msk (0x1UL << DSI_GHCR_WCLSB7_Pos)
10742#define DSI_GHCR_WCLSB7 DSI_GHCR_WCLSB7_Msk
10743
10744#define DSI_GHCR_WCMSB_Pos (16U)
10745#define DSI_GHCR_WCMSB_Msk (0xFFUL << DSI_GHCR_WCMSB_Pos)
10746#define DSI_GHCR_WCMSB DSI_GHCR_WCMSB_Msk
10747#define DSI_GHCR_WCMSB0_Pos (16U)
10748#define DSI_GHCR_WCMSB0_Msk (0x1UL << DSI_GHCR_WCMSB0_Pos)
10749#define DSI_GHCR_WCMSB0 DSI_GHCR_WCMSB0_Msk
10750#define DSI_GHCR_WCMSB1_Pos (17U)
10751#define DSI_GHCR_WCMSB1_Msk (0x1UL << DSI_GHCR_WCMSB1_Pos)
10752#define DSI_GHCR_WCMSB1 DSI_GHCR_WCMSB1_Msk
10753#define DSI_GHCR_WCMSB2_Pos (18U)
10754#define DSI_GHCR_WCMSB2_Msk (0x1UL << DSI_GHCR_WCMSB2_Pos)
10755#define DSI_GHCR_WCMSB2 DSI_GHCR_WCMSB2_Msk
10756#define DSI_GHCR_WCMSB3_Pos (19U)
10757#define DSI_GHCR_WCMSB3_Msk (0x1UL << DSI_GHCR_WCMSB3_Pos)
10758#define DSI_GHCR_WCMSB3 DSI_GHCR_WCMSB3_Msk
10759#define DSI_GHCR_WCMSB4_Pos (20U)
10760#define DSI_GHCR_WCMSB4_Msk (0x1UL << DSI_GHCR_WCMSB4_Pos)
10761#define DSI_GHCR_WCMSB4 DSI_GHCR_WCMSB4_Msk
10762#define DSI_GHCR_WCMSB5_Pos (21U)
10763#define DSI_GHCR_WCMSB5_Msk (0x1UL << DSI_GHCR_WCMSB5_Pos)
10764#define DSI_GHCR_WCMSB5 DSI_GHCR_WCMSB5_Msk
10765#define DSI_GHCR_WCMSB6_Pos (22U)
10766#define DSI_GHCR_WCMSB6_Msk (0x1UL << DSI_GHCR_WCMSB6_Pos)
10767#define DSI_GHCR_WCMSB6 DSI_GHCR_WCMSB6_Msk
10768#define DSI_GHCR_WCMSB7_Pos (23U)
10769#define DSI_GHCR_WCMSB7_Msk (0x1UL << DSI_GHCR_WCMSB7_Pos)
10770#define DSI_GHCR_WCMSB7 DSI_GHCR_WCMSB7_Msk
10771
10772/******************* Bit definition for DSI_GPDR register ***************/
10773#define DSI_GPDR_DATA1_Pos (0U)
10774#define DSI_GPDR_DATA1_Msk (0xFFUL << DSI_GPDR_DATA1_Pos)
10775#define DSI_GPDR_DATA1 DSI_GPDR_DATA1_Msk
10776#define DSI_GPDR_DATA1_0 (0x01UL << DSI_GPDR_DATA1_Pos)
10777#define DSI_GPDR_DATA1_1 (0x02UL << DSI_GPDR_DATA1_Pos)
10778#define DSI_GPDR_DATA1_2 (0x04UL << DSI_GPDR_DATA1_Pos)
10779#define DSI_GPDR_DATA1_3 (0x08UL << DSI_GPDR_DATA1_Pos)
10780#define DSI_GPDR_DATA1_4 (0x10UL << DSI_GPDR_DATA1_Pos)
10781#define DSI_GPDR_DATA1_5 (0x20UL << DSI_GPDR_DATA1_Pos)
10782#define DSI_GPDR_DATA1_6 (0x40UL << DSI_GPDR_DATA1_Pos)
10783#define DSI_GPDR_DATA1_7 (0x80UL << DSI_GPDR_DATA1_Pos)
10785#define DSI_GPDR_DATA2_Pos (8U)
10786#define DSI_GPDR_DATA2_Msk (0xFFUL << DSI_GPDR_DATA2_Pos)
10787#define DSI_GPDR_DATA2 DSI_GPDR_DATA2_Msk
10788#define DSI_GPDR_DATA2_0 (0x01UL << DSI_GPDR_DATA2_Pos)
10789#define DSI_GPDR_DATA2_1 (0x02UL << DSI_GPDR_DATA2_Pos)
10790#define DSI_GPDR_DATA2_2 (0x04UL << DSI_GPDR_DATA2_Pos)
10791#define DSI_GPDR_DATA2_3 (0x08UL << DSI_GPDR_DATA2_Pos)
10792#define DSI_GPDR_DATA2_4 (0x10UL << DSI_GPDR_DATA2_Pos)
10793#define DSI_GPDR_DATA2_5 (0x20UL << DSI_GPDR_DATA2_Pos)
10794#define DSI_GPDR_DATA2_6 (0x40UL << DSI_GPDR_DATA2_Pos)
10795#define DSI_GPDR_DATA2_7 (0x80UL << DSI_GPDR_DATA2_Pos)
10797#define DSI_GPDR_DATA3_Pos (16U)
10798#define DSI_GPDR_DATA3_Msk (0xFFUL << DSI_GPDR_DATA3_Pos)
10799#define DSI_GPDR_DATA3 DSI_GPDR_DATA3_Msk
10800#define DSI_GPDR_DATA3_0 (0x01UL << DSI_GPDR_DATA3_Pos)
10801#define DSI_GPDR_DATA3_1 (0x02UL << DSI_GPDR_DATA3_Pos)
10802#define DSI_GPDR_DATA3_2 (0x04UL << DSI_GPDR_DATA3_Pos)
10803#define DSI_GPDR_DATA3_3 (0x08UL << DSI_GPDR_DATA3_Pos)
10804#define DSI_GPDR_DATA3_4 (0x10UL << DSI_GPDR_DATA3_Pos)
10805#define DSI_GPDR_DATA3_5 (0x20UL << DSI_GPDR_DATA3_Pos)
10806#define DSI_GPDR_DATA3_6 (0x40UL << DSI_GPDR_DATA3_Pos)
10807#define DSI_GPDR_DATA3_7 (0x80UL << DSI_GPDR_DATA3_Pos)
10809#define DSI_GPDR_DATA4_Pos (24U)
10810#define DSI_GPDR_DATA4_Msk (0xFFUL << DSI_GPDR_DATA4_Pos)
10811#define DSI_GPDR_DATA4 DSI_GPDR_DATA4_Msk
10812#define DSI_GPDR_DATA4_0 (0x01UL << DSI_GPDR_DATA4_Pos)
10813#define DSI_GPDR_DATA4_1 (0x02UL << DSI_GPDR_DATA4_Pos)
10814#define DSI_GPDR_DATA4_2 (0x04UL << DSI_GPDR_DATA4_Pos)
10815#define DSI_GPDR_DATA4_3 (0x08UL << DSI_GPDR_DATA4_Pos)
10816#define DSI_GPDR_DATA4_4 (0x10UL << DSI_GPDR_DATA4_Pos)
10817#define DSI_GPDR_DATA4_5 (0x20UL << DSI_GPDR_DATA4_Pos)
10818#define DSI_GPDR_DATA4_6 (0x40UL << DSI_GPDR_DATA4_Pos)
10819#define DSI_GPDR_DATA4_7 (0x80UL << DSI_GPDR_DATA4_Pos)
10821/******************* Bit definition for DSI_GPSR register ***************/
10822#define DSI_GPSR_CMDFE_Pos (0U)
10823#define DSI_GPSR_CMDFE_Msk (0x1UL << DSI_GPSR_CMDFE_Pos)
10824#define DSI_GPSR_CMDFE DSI_GPSR_CMDFE_Msk
10825#define DSI_GPSR_CMDFF_Pos (1U)
10826#define DSI_GPSR_CMDFF_Msk (0x1UL << DSI_GPSR_CMDFF_Pos)
10827#define DSI_GPSR_CMDFF DSI_GPSR_CMDFF_Msk
10828#define DSI_GPSR_PWRFE_Pos (2U)
10829#define DSI_GPSR_PWRFE_Msk (0x1UL << DSI_GPSR_PWRFE_Pos)
10830#define DSI_GPSR_PWRFE DSI_GPSR_PWRFE_Msk
10831#define DSI_GPSR_PWRFF_Pos (3U)
10832#define DSI_GPSR_PWRFF_Msk (0x1UL << DSI_GPSR_PWRFF_Pos)
10833#define DSI_GPSR_PWRFF DSI_GPSR_PWRFF_Msk
10834#define DSI_GPSR_PRDFE_Pos (4U)
10835#define DSI_GPSR_PRDFE_Msk (0x1UL << DSI_GPSR_PRDFE_Pos)
10836#define DSI_GPSR_PRDFE DSI_GPSR_PRDFE_Msk
10837#define DSI_GPSR_PRDFF_Pos (5U)
10838#define DSI_GPSR_PRDFF_Msk (0x1UL << DSI_GPSR_PRDFF_Pos)
10839#define DSI_GPSR_PRDFF DSI_GPSR_PRDFF_Msk
10840#define DSI_GPSR_RCB_Pos (6U)
10841#define DSI_GPSR_RCB_Msk (0x1UL << DSI_GPSR_RCB_Pos)
10842#define DSI_GPSR_RCB DSI_GPSR_RCB_Msk
10844/******************* Bit definition for DSI_TCCR0 register **************/
10845#define DSI_TCCR0_LPRX_TOCNT_Pos (0U)
10846#define DSI_TCCR0_LPRX_TOCNT_Msk (0xFFFFUL << DSI_TCCR0_LPRX_TOCNT_Pos)
10847#define DSI_TCCR0_LPRX_TOCNT DSI_TCCR0_LPRX_TOCNT_Msk
10848#define DSI_TCCR0_LPRX_TOCNT0_Pos (0U)
10849#define DSI_TCCR0_LPRX_TOCNT0_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT0_Pos)
10850#define DSI_TCCR0_LPRX_TOCNT0 DSI_TCCR0_LPRX_TOCNT0_Msk
10851#define DSI_TCCR0_LPRX_TOCNT1_Pos (1U)
10852#define DSI_TCCR0_LPRX_TOCNT1_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT1_Pos)
10853#define DSI_TCCR0_LPRX_TOCNT1 DSI_TCCR0_LPRX_TOCNT1_Msk
10854#define DSI_TCCR0_LPRX_TOCNT2_Pos (2U)
10855#define DSI_TCCR0_LPRX_TOCNT2_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT2_Pos)
10856#define DSI_TCCR0_LPRX_TOCNT2 DSI_TCCR0_LPRX_TOCNT2_Msk
10857#define DSI_TCCR0_LPRX_TOCNT3_Pos (3U)
10858#define DSI_TCCR0_LPRX_TOCNT3_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT3_Pos)
10859#define DSI_TCCR0_LPRX_TOCNT3 DSI_TCCR0_LPRX_TOCNT3_Msk
10860#define DSI_TCCR0_LPRX_TOCNT4_Pos (4U)
10861#define DSI_TCCR0_LPRX_TOCNT4_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT4_Pos)
10862#define DSI_TCCR0_LPRX_TOCNT4 DSI_TCCR0_LPRX_TOCNT4_Msk
10863#define DSI_TCCR0_LPRX_TOCNT5_Pos (5U)
10864#define DSI_TCCR0_LPRX_TOCNT5_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT5_Pos)
10865#define DSI_TCCR0_LPRX_TOCNT5 DSI_TCCR0_LPRX_TOCNT5_Msk
10866#define DSI_TCCR0_LPRX_TOCNT6_Pos (6U)
10867#define DSI_TCCR0_LPRX_TOCNT6_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT6_Pos)
10868#define DSI_TCCR0_LPRX_TOCNT6 DSI_TCCR0_LPRX_TOCNT6_Msk
10869#define DSI_TCCR0_LPRX_TOCNT7_Pos (7U)
10870#define DSI_TCCR0_LPRX_TOCNT7_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT7_Pos)
10871#define DSI_TCCR0_LPRX_TOCNT7 DSI_TCCR0_LPRX_TOCNT7_Msk
10872#define DSI_TCCR0_LPRX_TOCNT8_Pos (8U)
10873#define DSI_TCCR0_LPRX_TOCNT8_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT8_Pos)
10874#define DSI_TCCR0_LPRX_TOCNT8 DSI_TCCR0_LPRX_TOCNT8_Msk
10875#define DSI_TCCR0_LPRX_TOCNT9_Pos (9U)
10876#define DSI_TCCR0_LPRX_TOCNT9_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT9_Pos)
10877#define DSI_TCCR0_LPRX_TOCNT9 DSI_TCCR0_LPRX_TOCNT9_Msk
10878#define DSI_TCCR0_LPRX_TOCNT10_Pos (10U)
10879#define DSI_TCCR0_LPRX_TOCNT10_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT10_Pos)
10880#define DSI_TCCR0_LPRX_TOCNT10 DSI_TCCR0_LPRX_TOCNT10_Msk
10881#define DSI_TCCR0_LPRX_TOCNT11_Pos (11U)
10882#define DSI_TCCR0_LPRX_TOCNT11_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT11_Pos)
10883#define DSI_TCCR0_LPRX_TOCNT11 DSI_TCCR0_LPRX_TOCNT11_Msk
10884#define DSI_TCCR0_LPRX_TOCNT12_Pos (12U)
10885#define DSI_TCCR0_LPRX_TOCNT12_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT12_Pos)
10886#define DSI_TCCR0_LPRX_TOCNT12 DSI_TCCR0_LPRX_TOCNT12_Msk
10887#define DSI_TCCR0_LPRX_TOCNT13_Pos (13U)
10888#define DSI_TCCR0_LPRX_TOCNT13_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT13_Pos)
10889#define DSI_TCCR0_LPRX_TOCNT13 DSI_TCCR0_LPRX_TOCNT13_Msk
10890#define DSI_TCCR0_LPRX_TOCNT14_Pos (14U)
10891#define DSI_TCCR0_LPRX_TOCNT14_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT14_Pos)
10892#define DSI_TCCR0_LPRX_TOCNT14 DSI_TCCR0_LPRX_TOCNT14_Msk
10893#define DSI_TCCR0_LPRX_TOCNT15_Pos (15U)
10894#define DSI_TCCR0_LPRX_TOCNT15_Msk (0x1UL << DSI_TCCR0_LPRX_TOCNT15_Pos)
10895#define DSI_TCCR0_LPRX_TOCNT15 DSI_TCCR0_LPRX_TOCNT15_Msk
10896
10897#define DSI_TCCR0_HSTX_TOCNT_Pos (16U)
10898#define DSI_TCCR0_HSTX_TOCNT_Msk (0xFFFFUL << DSI_TCCR0_HSTX_TOCNT_Pos)
10899#define DSI_TCCR0_HSTX_TOCNT DSI_TCCR0_HSTX_TOCNT_Msk
10900#define DSI_TCCR0_HSTX_TOCNT0_Pos (16U)
10901#define DSI_TCCR0_HSTX_TOCNT0_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT0_Pos)
10902#define DSI_TCCR0_HSTX_TOCNT0 DSI_TCCR0_HSTX_TOCNT0_Msk
10903#define DSI_TCCR0_HSTX_TOCNT1_Pos (17U)
10904#define DSI_TCCR0_HSTX_TOCNT1_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT1_Pos)
10905#define DSI_TCCR0_HSTX_TOCNT1 DSI_TCCR0_HSTX_TOCNT1_Msk
10906#define DSI_TCCR0_HSTX_TOCNT2_Pos (18U)
10907#define DSI_TCCR0_HSTX_TOCNT2_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT2_Pos)
10908#define DSI_TCCR0_HSTX_TOCNT2 DSI_TCCR0_HSTX_TOCNT2_Msk
10909#define DSI_TCCR0_HSTX_TOCNT3_Pos (19U)
10910#define DSI_TCCR0_HSTX_TOCNT3_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT3_Pos)
10911#define DSI_TCCR0_HSTX_TOCNT3 DSI_TCCR0_HSTX_TOCNT3_Msk
10912#define DSI_TCCR0_HSTX_TOCNT4_Pos (20U)
10913#define DSI_TCCR0_HSTX_TOCNT4_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT4_Pos)
10914#define DSI_TCCR0_HSTX_TOCNT4 DSI_TCCR0_HSTX_TOCNT4_Msk
10915#define DSI_TCCR0_HSTX_TOCNT5_Pos (21U)
10916#define DSI_TCCR0_HSTX_TOCNT5_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT5_Pos)
10917#define DSI_TCCR0_HSTX_TOCNT5 DSI_TCCR0_HSTX_TOCNT5_Msk
10918#define DSI_TCCR0_HSTX_TOCNT6_Pos (22U)
10919#define DSI_TCCR0_HSTX_TOCNT6_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT6_Pos)
10920#define DSI_TCCR0_HSTX_TOCNT6 DSI_TCCR0_HSTX_TOCNT6_Msk
10921#define DSI_TCCR0_HSTX_TOCNT7_Pos (23U)
10922#define DSI_TCCR0_HSTX_TOCNT7_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT7_Pos)
10923#define DSI_TCCR0_HSTX_TOCNT7 DSI_TCCR0_HSTX_TOCNT7_Msk
10924#define DSI_TCCR0_HSTX_TOCNT8_Pos (24U)
10925#define DSI_TCCR0_HSTX_TOCNT8_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT8_Pos)
10926#define DSI_TCCR0_HSTX_TOCNT8 DSI_TCCR0_HSTX_TOCNT8_Msk
10927#define DSI_TCCR0_HSTX_TOCNT9_Pos (25U)
10928#define DSI_TCCR0_HSTX_TOCNT9_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT9_Pos)
10929#define DSI_TCCR0_HSTX_TOCNT9 DSI_TCCR0_HSTX_TOCNT9_Msk
10930#define DSI_TCCR0_HSTX_TOCNT10_Pos (26U)
10931#define DSI_TCCR0_HSTX_TOCNT10_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT10_Pos)
10932#define DSI_TCCR0_HSTX_TOCNT10 DSI_TCCR0_HSTX_TOCNT10_Msk
10933#define DSI_TCCR0_HSTX_TOCNT11_Pos (27U)
10934#define DSI_TCCR0_HSTX_TOCNT11_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT11_Pos)
10935#define DSI_TCCR0_HSTX_TOCNT11 DSI_TCCR0_HSTX_TOCNT11_Msk
10936#define DSI_TCCR0_HSTX_TOCNT12_Pos (28U)
10937#define DSI_TCCR0_HSTX_TOCNT12_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT12_Pos)
10938#define DSI_TCCR0_HSTX_TOCNT12 DSI_TCCR0_HSTX_TOCNT12_Msk
10939#define DSI_TCCR0_HSTX_TOCNT13_Pos (29U)
10940#define DSI_TCCR0_HSTX_TOCNT13_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT13_Pos)
10941#define DSI_TCCR0_HSTX_TOCNT13 DSI_TCCR0_HSTX_TOCNT13_Msk
10942#define DSI_TCCR0_HSTX_TOCNT14_Pos (30U)
10943#define DSI_TCCR0_HSTX_TOCNT14_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT14_Pos)
10944#define DSI_TCCR0_HSTX_TOCNT14 DSI_TCCR0_HSTX_TOCNT14_Msk
10945#define DSI_TCCR0_HSTX_TOCNT15_Pos (31U)
10946#define DSI_TCCR0_HSTX_TOCNT15_Msk (0x1UL << DSI_TCCR0_HSTX_TOCNT15_Pos)
10947#define DSI_TCCR0_HSTX_TOCNT15 DSI_TCCR0_HSTX_TOCNT15_Msk
10948
10949/******************* Bit definition for DSI_TCCR1 register **************/
10950#define DSI_TCCR1_HSRD_TOCNT_Pos (0U)
10951#define DSI_TCCR1_HSRD_TOCNT_Msk (0xFFFFUL << DSI_TCCR1_HSRD_TOCNT_Pos)
10952#define DSI_TCCR1_HSRD_TOCNT DSI_TCCR1_HSRD_TOCNT_Msk
10953#define DSI_TCCR1_HSRD_TOCNT0_Pos (0U)
10954#define DSI_TCCR1_HSRD_TOCNT0_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT0_Pos)
10955#define DSI_TCCR1_HSRD_TOCNT0 DSI_TCCR1_HSRD_TOCNT0_Msk
10956#define DSI_TCCR1_HSRD_TOCNT1_Pos (1U)
10957#define DSI_TCCR1_HSRD_TOCNT1_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT1_Pos)
10958#define DSI_TCCR1_HSRD_TOCNT1 DSI_TCCR1_HSRD_TOCNT1_Msk
10959#define DSI_TCCR1_HSRD_TOCNT2_Pos (2U)
10960#define DSI_TCCR1_HSRD_TOCNT2_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT2_Pos)
10961#define DSI_TCCR1_HSRD_TOCNT2 DSI_TCCR1_HSRD_TOCNT2_Msk
10962#define DSI_TCCR1_HSRD_TOCNT3_Pos (3U)
10963#define DSI_TCCR1_HSRD_TOCNT3_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT3_Pos)
10964#define DSI_TCCR1_HSRD_TOCNT3 DSI_TCCR1_HSRD_TOCNT3_Msk
10965#define DSI_TCCR1_HSRD_TOCNT4_Pos (4U)
10966#define DSI_TCCR1_HSRD_TOCNT4_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT4_Pos)
10967#define DSI_TCCR1_HSRD_TOCNT4 DSI_TCCR1_HSRD_TOCNT4_Msk
10968#define DSI_TCCR1_HSRD_TOCNT5_Pos (5U)
10969#define DSI_TCCR1_HSRD_TOCNT5_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT5_Pos)
10970#define DSI_TCCR1_HSRD_TOCNT5 DSI_TCCR1_HSRD_TOCNT5_Msk
10971#define DSI_TCCR1_HSRD_TOCNT6_Pos (6U)
10972#define DSI_TCCR1_HSRD_TOCNT6_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT6_Pos)
10973#define DSI_TCCR1_HSRD_TOCNT6 DSI_TCCR1_HSRD_TOCNT6_Msk
10974#define DSI_TCCR1_HSRD_TOCNT7_Pos (7U)
10975#define DSI_TCCR1_HSRD_TOCNT7_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT7_Pos)
10976#define DSI_TCCR1_HSRD_TOCNT7 DSI_TCCR1_HSRD_TOCNT7_Msk
10977#define DSI_TCCR1_HSRD_TOCNT8_Pos (8U)
10978#define DSI_TCCR1_HSRD_TOCNT8_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT8_Pos)
10979#define DSI_TCCR1_HSRD_TOCNT8 DSI_TCCR1_HSRD_TOCNT8_Msk
10980#define DSI_TCCR1_HSRD_TOCNT9_Pos (9U)
10981#define DSI_TCCR1_HSRD_TOCNT9_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT9_Pos)
10982#define DSI_TCCR1_HSRD_TOCNT9 DSI_TCCR1_HSRD_TOCNT9_Msk
10983#define DSI_TCCR1_HSRD_TOCNT10_Pos (10U)
10984#define DSI_TCCR1_HSRD_TOCNT10_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT10_Pos)
10985#define DSI_TCCR1_HSRD_TOCNT10 DSI_TCCR1_HSRD_TOCNT10_Msk
10986#define DSI_TCCR1_HSRD_TOCNT11_Pos (11U)
10987#define DSI_TCCR1_HSRD_TOCNT11_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT11_Pos)
10988#define DSI_TCCR1_HSRD_TOCNT11 DSI_TCCR1_HSRD_TOCNT11_Msk
10989#define DSI_TCCR1_HSRD_TOCNT12_Pos (12U)
10990#define DSI_TCCR1_HSRD_TOCNT12_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT12_Pos)
10991#define DSI_TCCR1_HSRD_TOCNT12 DSI_TCCR1_HSRD_TOCNT12_Msk
10992#define DSI_TCCR1_HSRD_TOCNT13_Pos (13U)
10993#define DSI_TCCR1_HSRD_TOCNT13_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT13_Pos)
10994#define DSI_TCCR1_HSRD_TOCNT13 DSI_TCCR1_HSRD_TOCNT13_Msk
10995#define DSI_TCCR1_HSRD_TOCNT14_Pos (14U)
10996#define DSI_TCCR1_HSRD_TOCNT14_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT14_Pos)
10997#define DSI_TCCR1_HSRD_TOCNT14 DSI_TCCR1_HSRD_TOCNT14_Msk
10998#define DSI_TCCR1_HSRD_TOCNT15_Pos (15U)
10999#define DSI_TCCR1_HSRD_TOCNT15_Msk (0x1UL << DSI_TCCR1_HSRD_TOCNT15_Pos)
11000#define DSI_TCCR1_HSRD_TOCNT15 DSI_TCCR1_HSRD_TOCNT15_Msk
11001
11002/******************* Bit definition for DSI_TCCR2 register **************/
11003#define DSI_TCCR2_LPRD_TOCNT_Pos (0U)
11004#define DSI_TCCR2_LPRD_TOCNT_Msk (0xFFFFUL << DSI_TCCR2_LPRD_TOCNT_Pos)
11005#define DSI_TCCR2_LPRD_TOCNT DSI_TCCR2_LPRD_TOCNT_Msk
11006#define DSI_TCCR2_LPRD_TOCNT0_Pos (0U)
11007#define DSI_TCCR2_LPRD_TOCNT0_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT0_Pos)
11008#define DSI_TCCR2_LPRD_TOCNT0 DSI_TCCR2_LPRD_TOCNT0_Msk
11009#define DSI_TCCR2_LPRD_TOCNT1_Pos (1U)
11010#define DSI_TCCR2_LPRD_TOCNT1_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT1_Pos)
11011#define DSI_TCCR2_LPRD_TOCNT1 DSI_TCCR2_LPRD_TOCNT1_Msk
11012#define DSI_TCCR2_LPRD_TOCNT2_Pos (2U)
11013#define DSI_TCCR2_LPRD_TOCNT2_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT2_Pos)
11014#define DSI_TCCR2_LPRD_TOCNT2 DSI_TCCR2_LPRD_TOCNT2_Msk
11015#define DSI_TCCR2_LPRD_TOCNT3_Pos (3U)
11016#define DSI_TCCR2_LPRD_TOCNT3_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT3_Pos)
11017#define DSI_TCCR2_LPRD_TOCNT3 DSI_TCCR2_LPRD_TOCNT3_Msk
11018#define DSI_TCCR2_LPRD_TOCNT4_Pos (4U)
11019#define DSI_TCCR2_LPRD_TOCNT4_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT4_Pos)
11020#define DSI_TCCR2_LPRD_TOCNT4 DSI_TCCR2_LPRD_TOCNT4_Msk
11021#define DSI_TCCR2_LPRD_TOCNT5_Pos (5U)
11022#define DSI_TCCR2_LPRD_TOCNT5_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT5_Pos)
11023#define DSI_TCCR2_LPRD_TOCNT5 DSI_TCCR2_LPRD_TOCNT5_Msk
11024#define DSI_TCCR2_LPRD_TOCNT6_Pos (6U)
11025#define DSI_TCCR2_LPRD_TOCNT6_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT6_Pos)
11026#define DSI_TCCR2_LPRD_TOCNT6 DSI_TCCR2_LPRD_TOCNT6_Msk
11027#define DSI_TCCR2_LPRD_TOCNT7_Pos (7U)
11028#define DSI_TCCR2_LPRD_TOCNT7_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT7_Pos)
11029#define DSI_TCCR2_LPRD_TOCNT7 DSI_TCCR2_LPRD_TOCNT7_Msk
11030#define DSI_TCCR2_LPRD_TOCNT8_Pos (8U)
11031#define DSI_TCCR2_LPRD_TOCNT8_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT8_Pos)
11032#define DSI_TCCR2_LPRD_TOCNT8 DSI_TCCR2_LPRD_TOCNT8_Msk
11033#define DSI_TCCR2_LPRD_TOCNT9_Pos (9U)
11034#define DSI_TCCR2_LPRD_TOCNT9_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT9_Pos)
11035#define DSI_TCCR2_LPRD_TOCNT9 DSI_TCCR2_LPRD_TOCNT9_Msk
11036#define DSI_TCCR2_LPRD_TOCNT10_Pos (10U)
11037#define DSI_TCCR2_LPRD_TOCNT10_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT10_Pos)
11038#define DSI_TCCR2_LPRD_TOCNT10 DSI_TCCR2_LPRD_TOCNT10_Msk
11039#define DSI_TCCR2_LPRD_TOCNT11_Pos (11U)
11040#define DSI_TCCR2_LPRD_TOCNT11_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT11_Pos)
11041#define DSI_TCCR2_LPRD_TOCNT11 DSI_TCCR2_LPRD_TOCNT11_Msk
11042#define DSI_TCCR2_LPRD_TOCNT12_Pos (12U)
11043#define DSI_TCCR2_LPRD_TOCNT12_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT12_Pos)
11044#define DSI_TCCR2_LPRD_TOCNT12 DSI_TCCR2_LPRD_TOCNT12_Msk
11045#define DSI_TCCR2_LPRD_TOCNT13_Pos (13U)
11046#define DSI_TCCR2_LPRD_TOCNT13_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT13_Pos)
11047#define DSI_TCCR2_LPRD_TOCNT13 DSI_TCCR2_LPRD_TOCNT13_Msk
11048#define DSI_TCCR2_LPRD_TOCNT14_Pos (14U)
11049#define DSI_TCCR2_LPRD_TOCNT14_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT14_Pos)
11050#define DSI_TCCR2_LPRD_TOCNT14 DSI_TCCR2_LPRD_TOCNT14_Msk
11051#define DSI_TCCR2_LPRD_TOCNT15_Pos (15U)
11052#define DSI_TCCR2_LPRD_TOCNT15_Msk (0x1UL << DSI_TCCR2_LPRD_TOCNT15_Pos)
11053#define DSI_TCCR2_LPRD_TOCNT15 DSI_TCCR2_LPRD_TOCNT15_Msk
11054
11055/******************* Bit definition for DSI_TCCR3 register **************/
11056#define DSI_TCCR3_HSWR_TOCNT_Pos (0U)
11057#define DSI_TCCR3_HSWR_TOCNT_Msk (0xFFFFUL << DSI_TCCR3_HSWR_TOCNT_Pos)
11058#define DSI_TCCR3_HSWR_TOCNT DSI_TCCR3_HSWR_TOCNT_Msk
11059#define DSI_TCCR3_HSWR_TOCNT0_Pos (0U)
11060#define DSI_TCCR3_HSWR_TOCNT0_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT0_Pos)
11061#define DSI_TCCR3_HSWR_TOCNT0 DSI_TCCR3_HSWR_TOCNT0_Msk
11062#define DSI_TCCR3_HSWR_TOCNT1_Pos (1U)
11063#define DSI_TCCR3_HSWR_TOCNT1_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT1_Pos)
11064#define DSI_TCCR3_HSWR_TOCNT1 DSI_TCCR3_HSWR_TOCNT1_Msk
11065#define DSI_TCCR3_HSWR_TOCNT2_Pos (2U)
11066#define DSI_TCCR3_HSWR_TOCNT2_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT2_Pos)
11067#define DSI_TCCR3_HSWR_TOCNT2 DSI_TCCR3_HSWR_TOCNT2_Msk
11068#define DSI_TCCR3_HSWR_TOCNT3_Pos (3U)
11069#define DSI_TCCR3_HSWR_TOCNT3_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT3_Pos)
11070#define DSI_TCCR3_HSWR_TOCNT3 DSI_TCCR3_HSWR_TOCNT3_Msk
11071#define DSI_TCCR3_HSWR_TOCNT4_Pos (4U)
11072#define DSI_TCCR3_HSWR_TOCNT4_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT4_Pos)
11073#define DSI_TCCR3_HSWR_TOCNT4 DSI_TCCR3_HSWR_TOCNT4_Msk
11074#define DSI_TCCR3_HSWR_TOCNT5_Pos (5U)
11075#define DSI_TCCR3_HSWR_TOCNT5_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT5_Pos)
11076#define DSI_TCCR3_HSWR_TOCNT5 DSI_TCCR3_HSWR_TOCNT5_Msk
11077#define DSI_TCCR3_HSWR_TOCNT6_Pos (6U)
11078#define DSI_TCCR3_HSWR_TOCNT6_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT6_Pos)
11079#define DSI_TCCR3_HSWR_TOCNT6 DSI_TCCR3_HSWR_TOCNT6_Msk
11080#define DSI_TCCR3_HSWR_TOCNT7_Pos (7U)
11081#define DSI_TCCR3_HSWR_TOCNT7_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT7_Pos)
11082#define DSI_TCCR3_HSWR_TOCNT7 DSI_TCCR3_HSWR_TOCNT7_Msk
11083#define DSI_TCCR3_HSWR_TOCNT8_Pos (8U)
11084#define DSI_TCCR3_HSWR_TOCNT8_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT8_Pos)
11085#define DSI_TCCR3_HSWR_TOCNT8 DSI_TCCR3_HSWR_TOCNT8_Msk
11086#define DSI_TCCR3_HSWR_TOCNT9_Pos (9U)
11087#define DSI_TCCR3_HSWR_TOCNT9_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT9_Pos)
11088#define DSI_TCCR3_HSWR_TOCNT9 DSI_TCCR3_HSWR_TOCNT9_Msk
11089#define DSI_TCCR3_HSWR_TOCNT10_Pos (10U)
11090#define DSI_TCCR3_HSWR_TOCNT10_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT10_Pos)
11091#define DSI_TCCR3_HSWR_TOCNT10 DSI_TCCR3_HSWR_TOCNT10_Msk
11092#define DSI_TCCR3_HSWR_TOCNT11_Pos (11U)
11093#define DSI_TCCR3_HSWR_TOCNT11_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT11_Pos)
11094#define DSI_TCCR3_HSWR_TOCNT11 DSI_TCCR3_HSWR_TOCNT11_Msk
11095#define DSI_TCCR3_HSWR_TOCNT12_Pos (12U)
11096#define DSI_TCCR3_HSWR_TOCNT12_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT12_Pos)
11097#define DSI_TCCR3_HSWR_TOCNT12 DSI_TCCR3_HSWR_TOCNT12_Msk
11098#define DSI_TCCR3_HSWR_TOCNT13_Pos (13U)
11099#define DSI_TCCR3_HSWR_TOCNT13_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT13_Pos)
11100#define DSI_TCCR3_HSWR_TOCNT13 DSI_TCCR3_HSWR_TOCNT13_Msk
11101#define DSI_TCCR3_HSWR_TOCNT14_Pos (14U)
11102#define DSI_TCCR3_HSWR_TOCNT14_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT14_Pos)
11103#define DSI_TCCR3_HSWR_TOCNT14 DSI_TCCR3_HSWR_TOCNT14_Msk
11104#define DSI_TCCR3_HSWR_TOCNT15_Pos (15U)
11105#define DSI_TCCR3_HSWR_TOCNT15_Msk (0x1UL << DSI_TCCR3_HSWR_TOCNT15_Pos)
11106#define DSI_TCCR3_HSWR_TOCNT15 DSI_TCCR3_HSWR_TOCNT15_Msk
11107
11108#define DSI_TCCR3_PM_Pos (24U)
11109#define DSI_TCCR3_PM_Msk (0x1UL << DSI_TCCR3_PM_Pos)
11110#define DSI_TCCR3_PM DSI_TCCR3_PM_Msk
11112/******************* Bit definition for DSI_TCCR4 register **************/
11113#define DSI_TCCR4_LPWR_TOCNT_Pos (0U)
11114#define DSI_TCCR4_LPWR_TOCNT_Msk (0xFFFFUL << DSI_TCCR4_LPWR_TOCNT_Pos)
11115#define DSI_TCCR4_LPWR_TOCNT DSI_TCCR4_LPWR_TOCNT_Msk
11116#define DSI_TCCR4_LPWR_TOCNT0_Pos (0U)
11117#define DSI_TCCR4_LPWR_TOCNT0_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT0_Pos)
11118#define DSI_TCCR4_LPWR_TOCNT0 DSI_TCCR4_LPWR_TOCNT0_Msk
11119#define DSI_TCCR4_LPWR_TOCNT1_Pos (1U)
11120#define DSI_TCCR4_LPWR_TOCNT1_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT1_Pos)
11121#define DSI_TCCR4_LPWR_TOCNT1 DSI_TCCR4_LPWR_TOCNT1_Msk
11122#define DSI_TCCR4_LPWR_TOCNT2_Pos (2U)
11123#define DSI_TCCR4_LPWR_TOCNT2_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT2_Pos)
11124#define DSI_TCCR4_LPWR_TOCNT2 DSI_TCCR4_LPWR_TOCNT2_Msk
11125#define DSI_TCCR4_LPWR_TOCNT3_Pos (3U)
11126#define DSI_TCCR4_LPWR_TOCNT3_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT3_Pos)
11127#define DSI_TCCR4_LPWR_TOCNT3 DSI_TCCR4_LPWR_TOCNT3_Msk
11128#define DSI_TCCR4_LPWR_TOCNT4_Pos (4U)
11129#define DSI_TCCR4_LPWR_TOCNT4_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT4_Pos)
11130#define DSI_TCCR4_LPWR_TOCNT4 DSI_TCCR4_LPWR_TOCNT4_Msk
11131#define DSI_TCCR4_LPWR_TOCNT5_Pos (5U)
11132#define DSI_TCCR4_LPWR_TOCNT5_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT5_Pos)
11133#define DSI_TCCR4_LPWR_TOCNT5 DSI_TCCR4_LPWR_TOCNT5_Msk
11134#define DSI_TCCR4_LPWR_TOCNT6_Pos (6U)
11135#define DSI_TCCR4_LPWR_TOCNT6_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT6_Pos)
11136#define DSI_TCCR4_LPWR_TOCNT6 DSI_TCCR4_LPWR_TOCNT6_Msk
11137#define DSI_TCCR4_LPWR_TOCNT7_Pos (7U)
11138#define DSI_TCCR4_LPWR_TOCNT7_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT7_Pos)
11139#define DSI_TCCR4_LPWR_TOCNT7 DSI_TCCR4_LPWR_TOCNT7_Msk
11140#define DSI_TCCR4_LPWR_TOCNT8_Pos (8U)
11141#define DSI_TCCR4_LPWR_TOCNT8_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT8_Pos)
11142#define DSI_TCCR4_LPWR_TOCNT8 DSI_TCCR4_LPWR_TOCNT8_Msk
11143#define DSI_TCCR4_LPWR_TOCNT9_Pos (9U)
11144#define DSI_TCCR4_LPWR_TOCNT9_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT9_Pos)
11145#define DSI_TCCR4_LPWR_TOCNT9 DSI_TCCR4_LPWR_TOCNT9_Msk
11146#define DSI_TCCR4_LPWR_TOCNT10_Pos (10U)
11147#define DSI_TCCR4_LPWR_TOCNT10_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT10_Pos)
11148#define DSI_TCCR4_LPWR_TOCNT10 DSI_TCCR4_LPWR_TOCNT10_Msk
11149#define DSI_TCCR4_LPWR_TOCNT11_Pos (11U)
11150#define DSI_TCCR4_LPWR_TOCNT11_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT11_Pos)
11151#define DSI_TCCR4_LPWR_TOCNT11 DSI_TCCR4_LPWR_TOCNT11_Msk
11152#define DSI_TCCR4_LPWR_TOCNT12_Pos (12U)
11153#define DSI_TCCR4_LPWR_TOCNT12_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT12_Pos)
11154#define DSI_TCCR4_LPWR_TOCNT12 DSI_TCCR4_LPWR_TOCNT12_Msk
11155#define DSI_TCCR4_LPWR_TOCNT13_Pos (13U)
11156#define DSI_TCCR4_LPWR_TOCNT13_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT13_Pos)
11157#define DSI_TCCR4_LPWR_TOCNT13 DSI_TCCR4_LPWR_TOCNT13_Msk
11158#define DSI_TCCR4_LPWR_TOCNT14_Pos (14U)
11159#define DSI_TCCR4_LPWR_TOCNT14_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT14_Pos)
11160#define DSI_TCCR4_LPWR_TOCNT14 DSI_TCCR4_LPWR_TOCNT14_Msk
11161#define DSI_TCCR4_LPWR_TOCNT15_Pos (15U)
11162#define DSI_TCCR4_LPWR_TOCNT15_Msk (0x1UL << DSI_TCCR4_LPWR_TOCNT15_Pos)
11163#define DSI_TCCR4_LPWR_TOCNT15 DSI_TCCR4_LPWR_TOCNT15_Msk
11164
11165/******************* Bit definition for DSI_TCCR5 register **************/
11166#define DSI_TCCR5_BTA_TOCNT_Pos (0U)
11167#define DSI_TCCR5_BTA_TOCNT_Msk (0xFFFFUL << DSI_TCCR5_BTA_TOCNT_Pos)
11168#define DSI_TCCR5_BTA_TOCNT DSI_TCCR5_BTA_TOCNT_Msk
11169#define DSI_TCCR5_BTA_TOCNT0_Pos (0U)
11170#define DSI_TCCR5_BTA_TOCNT0_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT0_Pos)
11171#define DSI_TCCR5_BTA_TOCNT0 DSI_TCCR5_BTA_TOCNT0_Msk
11172#define DSI_TCCR5_BTA_TOCNT1_Pos (1U)
11173#define DSI_TCCR5_BTA_TOCNT1_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT1_Pos)
11174#define DSI_TCCR5_BTA_TOCNT1 DSI_TCCR5_BTA_TOCNT1_Msk
11175#define DSI_TCCR5_BTA_TOCNT2_Pos (2U)
11176#define DSI_TCCR5_BTA_TOCNT2_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT2_Pos)
11177#define DSI_TCCR5_BTA_TOCNT2 DSI_TCCR5_BTA_TOCNT2_Msk
11178#define DSI_TCCR5_BTA_TOCNT3_Pos (3U)
11179#define DSI_TCCR5_BTA_TOCNT3_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT3_Pos)
11180#define DSI_TCCR5_BTA_TOCNT3 DSI_TCCR5_BTA_TOCNT3_Msk
11181#define DSI_TCCR5_BTA_TOCNT4_Pos (4U)
11182#define DSI_TCCR5_BTA_TOCNT4_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT4_Pos)
11183#define DSI_TCCR5_BTA_TOCNT4 DSI_TCCR5_BTA_TOCNT4_Msk
11184#define DSI_TCCR5_BTA_TOCNT5_Pos (5U)
11185#define DSI_TCCR5_BTA_TOCNT5_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT5_Pos)
11186#define DSI_TCCR5_BTA_TOCNT5 DSI_TCCR5_BTA_TOCNT5_Msk
11187#define DSI_TCCR5_BTA_TOCNT6_Pos (6U)
11188#define DSI_TCCR5_BTA_TOCNT6_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT6_Pos)
11189#define DSI_TCCR5_BTA_TOCNT6 DSI_TCCR5_BTA_TOCNT6_Msk
11190#define DSI_TCCR5_BTA_TOCNT7_Pos (7U)
11191#define DSI_TCCR5_BTA_TOCNT7_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT7_Pos)
11192#define DSI_TCCR5_BTA_TOCNT7 DSI_TCCR5_BTA_TOCNT7_Msk
11193#define DSI_TCCR5_BTA_TOCNT8_Pos (8U)
11194#define DSI_TCCR5_BTA_TOCNT8_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT8_Pos)
11195#define DSI_TCCR5_BTA_TOCNT8 DSI_TCCR5_BTA_TOCNT8_Msk
11196#define DSI_TCCR5_BTA_TOCNT9_Pos (9U)
11197#define DSI_TCCR5_BTA_TOCNT9_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT9_Pos)
11198#define DSI_TCCR5_BTA_TOCNT9 DSI_TCCR5_BTA_TOCNT9_Msk
11199#define DSI_TCCR5_BTA_TOCNT10_Pos (10U)
11200#define DSI_TCCR5_BTA_TOCNT10_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT10_Pos)
11201#define DSI_TCCR5_BTA_TOCNT10 DSI_TCCR5_BTA_TOCNT10_Msk
11202#define DSI_TCCR5_BTA_TOCNT11_Pos (11U)
11203#define DSI_TCCR5_BTA_TOCNT11_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT11_Pos)
11204#define DSI_TCCR5_BTA_TOCNT11 DSI_TCCR5_BTA_TOCNT11_Msk
11205#define DSI_TCCR5_BTA_TOCNT12_Pos (12U)
11206#define DSI_TCCR5_BTA_TOCNT12_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT12_Pos)
11207#define DSI_TCCR5_BTA_TOCNT12 DSI_TCCR5_BTA_TOCNT12_Msk
11208#define DSI_TCCR5_BTA_TOCNT13_Pos (13U)
11209#define DSI_TCCR5_BTA_TOCNT13_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT13_Pos)
11210#define DSI_TCCR5_BTA_TOCNT13 DSI_TCCR5_BTA_TOCNT13_Msk
11211#define DSI_TCCR5_BTA_TOCNT14_Pos (14U)
11212#define DSI_TCCR5_BTA_TOCNT14_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT14_Pos)
11213#define DSI_TCCR5_BTA_TOCNT14 DSI_TCCR5_BTA_TOCNT14_Msk
11214#define DSI_TCCR5_BTA_TOCNT15_Pos (15U)
11215#define DSI_TCCR5_BTA_TOCNT15_Msk (0x1UL << DSI_TCCR5_BTA_TOCNT15_Pos)
11216#define DSI_TCCR5_BTA_TOCNT15 DSI_TCCR5_BTA_TOCNT15_Msk
11217
11218/******************* Bit definition for DSI_TDCR register ***************/
11219#define DSI_TDCR_3DM (0x00000003U)
11220#define DSI_TDCR_3DM0 (0x00000001U)
11221#define DSI_TDCR_3DM1 (0x00000002U)
11222
11223#define DSI_TDCR_3DF (0x0000000CU)
11224#define DSI_TDCR_3DF0 (0x00000004U)
11225#define DSI_TDCR_3DF1 (0x00000008U)
11226
11227#define DSI_TDCR_SVS_Pos (4U)
11228#define DSI_TDCR_SVS_Msk (0x1UL << DSI_TDCR_SVS_Pos)
11229#define DSI_TDCR_SVS DSI_TDCR_SVS_Msk
11230#define DSI_TDCR_RF_Pos (5U)
11231#define DSI_TDCR_RF_Msk (0x1UL << DSI_TDCR_RF_Pos)
11232#define DSI_TDCR_RF DSI_TDCR_RF_Msk
11233#define DSI_TDCR_S3DC_Pos (16U)
11234#define DSI_TDCR_S3DC_Msk (0x1UL << DSI_TDCR_S3DC_Pos)
11235#define DSI_TDCR_S3DC DSI_TDCR_S3DC_Msk
11237/******************* Bit definition for DSI_CLCR register ***************/
11238#define DSI_CLCR_DPCC_Pos (0U)
11239#define DSI_CLCR_DPCC_Msk (0x1UL << DSI_CLCR_DPCC_Pos)
11240#define DSI_CLCR_DPCC DSI_CLCR_DPCC_Msk
11241#define DSI_CLCR_ACR_Pos (1U)
11242#define DSI_CLCR_ACR_Msk (0x1UL << DSI_CLCR_ACR_Pos)
11243#define DSI_CLCR_ACR DSI_CLCR_ACR_Msk
11245/******************* Bit definition for DSI_CLTCR register **************/
11246#define DSI_CLTCR_LP2HS_TIME_Pos (0U)
11247#define DSI_CLTCR_LP2HS_TIME_Msk (0x3FFUL << DSI_CLTCR_LP2HS_TIME_Pos)
11248#define DSI_CLTCR_LP2HS_TIME DSI_CLTCR_LP2HS_TIME_Msk
11249#define DSI_CLTCR_LP2HS_TIME0_Pos (0U)
11250#define DSI_CLTCR_LP2HS_TIME0_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME0_Pos)
11251#define DSI_CLTCR_LP2HS_TIME0 DSI_CLTCR_LP2HS_TIME0_Msk
11252#define DSI_CLTCR_LP2HS_TIME1_Pos (1U)
11253#define DSI_CLTCR_LP2HS_TIME1_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME1_Pos)
11254#define DSI_CLTCR_LP2HS_TIME1 DSI_CLTCR_LP2HS_TIME1_Msk
11255#define DSI_CLTCR_LP2HS_TIME2_Pos (2U)
11256#define DSI_CLTCR_LP2HS_TIME2_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME2_Pos)
11257#define DSI_CLTCR_LP2HS_TIME2 DSI_CLTCR_LP2HS_TIME2_Msk
11258#define DSI_CLTCR_LP2HS_TIME3_Pos (3U)
11259#define DSI_CLTCR_LP2HS_TIME3_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME3_Pos)
11260#define DSI_CLTCR_LP2HS_TIME3 DSI_CLTCR_LP2HS_TIME3_Msk
11261#define DSI_CLTCR_LP2HS_TIME4_Pos (4U)
11262#define DSI_CLTCR_LP2HS_TIME4_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME4_Pos)
11263#define DSI_CLTCR_LP2HS_TIME4 DSI_CLTCR_LP2HS_TIME4_Msk
11264#define DSI_CLTCR_LP2HS_TIME5_Pos (5U)
11265#define DSI_CLTCR_LP2HS_TIME5_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME5_Pos)
11266#define DSI_CLTCR_LP2HS_TIME5 DSI_CLTCR_LP2HS_TIME5_Msk
11267#define DSI_CLTCR_LP2HS_TIME6_Pos (6U)
11268#define DSI_CLTCR_LP2HS_TIME6_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME6_Pos)
11269#define DSI_CLTCR_LP2HS_TIME6 DSI_CLTCR_LP2HS_TIME6_Msk
11270#define DSI_CLTCR_LP2HS_TIME7_Pos (7U)
11271#define DSI_CLTCR_LP2HS_TIME7_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME7_Pos)
11272#define DSI_CLTCR_LP2HS_TIME7 DSI_CLTCR_LP2HS_TIME7_Msk
11273#define DSI_CLTCR_LP2HS_TIME8_Pos (8U)
11274#define DSI_CLTCR_LP2HS_TIME8_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME8_Pos)
11275#define DSI_CLTCR_LP2HS_TIME8 DSI_CLTCR_LP2HS_TIME8_Msk
11276#define DSI_CLTCR_LP2HS_TIME9_Pos (9U)
11277#define DSI_CLTCR_LP2HS_TIME9_Msk (0x1UL << DSI_CLTCR_LP2HS_TIME9_Pos)
11278#define DSI_CLTCR_LP2HS_TIME9 DSI_CLTCR_LP2HS_TIME9_Msk
11279
11280#define DSI_CLTCR_HS2LP_TIME_Pos (16U)
11281#define DSI_CLTCR_HS2LP_TIME_Msk (0x3FFUL << DSI_CLTCR_HS2LP_TIME_Pos)
11282#define DSI_CLTCR_HS2LP_TIME DSI_CLTCR_HS2LP_TIME_Msk
11283#define DSI_CLTCR_HS2LP_TIME0_Pos (16U)
11284#define DSI_CLTCR_HS2LP_TIME0_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME0_Pos)
11285#define DSI_CLTCR_HS2LP_TIME0 DSI_CLTCR_HS2LP_TIME0_Msk
11286#define DSI_CLTCR_HS2LP_TIME1_Pos (17U)
11287#define DSI_CLTCR_HS2LP_TIME1_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME1_Pos)
11288#define DSI_CLTCR_HS2LP_TIME1 DSI_CLTCR_HS2LP_TIME1_Msk
11289#define DSI_CLTCR_HS2LP_TIME2_Pos (18U)
11290#define DSI_CLTCR_HS2LP_TIME2_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME2_Pos)
11291#define DSI_CLTCR_HS2LP_TIME2 DSI_CLTCR_HS2LP_TIME2_Msk
11292#define DSI_CLTCR_HS2LP_TIME3_Pos (19U)
11293#define DSI_CLTCR_HS2LP_TIME3_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME3_Pos)
11294#define DSI_CLTCR_HS2LP_TIME3 DSI_CLTCR_HS2LP_TIME3_Msk
11295#define DSI_CLTCR_HS2LP_TIME4_Pos (20U)
11296#define DSI_CLTCR_HS2LP_TIME4_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME4_Pos)
11297#define DSI_CLTCR_HS2LP_TIME4 DSI_CLTCR_HS2LP_TIME4_Msk
11298#define DSI_CLTCR_HS2LP_TIME5_Pos (21U)
11299#define DSI_CLTCR_HS2LP_TIME5_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME5_Pos)
11300#define DSI_CLTCR_HS2LP_TIME5 DSI_CLTCR_HS2LP_TIME5_Msk
11301#define DSI_CLTCR_HS2LP_TIME6_Pos (22U)
11302#define DSI_CLTCR_HS2LP_TIME6_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME6_Pos)
11303#define DSI_CLTCR_HS2LP_TIME6 DSI_CLTCR_HS2LP_TIME6_Msk
11304#define DSI_CLTCR_HS2LP_TIME7_Pos (23U)
11305#define DSI_CLTCR_HS2LP_TIME7_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME7_Pos)
11306#define DSI_CLTCR_HS2LP_TIME7 DSI_CLTCR_HS2LP_TIME7_Msk
11307#define DSI_CLTCR_HS2LP_TIME8_Pos (24U)
11308#define DSI_CLTCR_HS2LP_TIME8_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME8_Pos)
11309#define DSI_CLTCR_HS2LP_TIME8 DSI_CLTCR_HS2LP_TIME8_Msk
11310#define DSI_CLTCR_HS2LP_TIME9_Pos (25U)
11311#define DSI_CLTCR_HS2LP_TIME9_Msk (0x1UL << DSI_CLTCR_HS2LP_TIME9_Pos)
11312#define DSI_CLTCR_HS2LP_TIME9 DSI_CLTCR_HS2LP_TIME9_Msk
11313
11314/******************* Bit definition for DSI_DLTCR register **************/
11315#define DSI_DLTCR_MRD_TIME_Pos (0U)
11316#define DSI_DLTCR_MRD_TIME_Msk (0x7FFFUL << DSI_DLTCR_MRD_TIME_Pos)
11317#define DSI_DLTCR_MRD_TIME DSI_DLTCR_MRD_TIME_Msk
11318#define DSI_DLTCR_MRD_TIME0_Pos (0U)
11319#define DSI_DLTCR_MRD_TIME0_Msk (0x1UL << DSI_DLTCR_MRD_TIME0_Pos)
11320#define DSI_DLTCR_MRD_TIME0 DSI_DLTCR_MRD_TIME0_Msk
11321#define DSI_DLTCR_MRD_TIME1_Pos (1U)
11322#define DSI_DLTCR_MRD_TIME1_Msk (0x1UL << DSI_DLTCR_MRD_TIME1_Pos)
11323#define DSI_DLTCR_MRD_TIME1 DSI_DLTCR_MRD_TIME1_Msk
11324#define DSI_DLTCR_MRD_TIME2_Pos (2U)
11325#define DSI_DLTCR_MRD_TIME2_Msk (0x1UL << DSI_DLTCR_MRD_TIME2_Pos)
11326#define DSI_DLTCR_MRD_TIME2 DSI_DLTCR_MRD_TIME2_Msk
11327#define DSI_DLTCR_MRD_TIME3_Pos (3U)
11328#define DSI_DLTCR_MRD_TIME3_Msk (0x1UL << DSI_DLTCR_MRD_TIME3_Pos)
11329#define DSI_DLTCR_MRD_TIME3 DSI_DLTCR_MRD_TIME3_Msk
11330#define DSI_DLTCR_MRD_TIME4_Pos (4U)
11331#define DSI_DLTCR_MRD_TIME4_Msk (0x1UL << DSI_DLTCR_MRD_TIME4_Pos)
11332#define DSI_DLTCR_MRD_TIME4 DSI_DLTCR_MRD_TIME4_Msk
11333#define DSI_DLTCR_MRD_TIME5_Pos (5U)
11334#define DSI_DLTCR_MRD_TIME5_Msk (0x1UL << DSI_DLTCR_MRD_TIME5_Pos)
11335#define DSI_DLTCR_MRD_TIME5 DSI_DLTCR_MRD_TIME5_Msk
11336#define DSI_DLTCR_MRD_TIME6_Pos (6U)
11337#define DSI_DLTCR_MRD_TIME6_Msk (0x1UL << DSI_DLTCR_MRD_TIME6_Pos)
11338#define DSI_DLTCR_MRD_TIME6 DSI_DLTCR_MRD_TIME6_Msk
11339#define DSI_DLTCR_MRD_TIME7_Pos (7U)
11340#define DSI_DLTCR_MRD_TIME7_Msk (0x1UL << DSI_DLTCR_MRD_TIME7_Pos)
11341#define DSI_DLTCR_MRD_TIME7 DSI_DLTCR_MRD_TIME7_Msk
11342#define DSI_DLTCR_MRD_TIME8_Pos (8U)
11343#define DSI_DLTCR_MRD_TIME8_Msk (0x1UL << DSI_DLTCR_MRD_TIME8_Pos)
11344#define DSI_DLTCR_MRD_TIME8 DSI_DLTCR_MRD_TIME8_Msk
11345#define DSI_DLTCR_MRD_TIME9_Pos (9U)
11346#define DSI_DLTCR_MRD_TIME9_Msk (0x1UL << DSI_DLTCR_MRD_TIME9_Pos)
11347#define DSI_DLTCR_MRD_TIME9 DSI_DLTCR_MRD_TIME9_Msk
11348#define DSI_DLTCR_MRD_TIME10_Pos (10U)
11349#define DSI_DLTCR_MRD_TIME10_Msk (0x1UL << DSI_DLTCR_MRD_TIME10_Pos)
11350#define DSI_DLTCR_MRD_TIME10 DSI_DLTCR_MRD_TIME10_Msk
11351#define DSI_DLTCR_MRD_TIME11_Pos (11U)
11352#define DSI_DLTCR_MRD_TIME11_Msk (0x1UL << DSI_DLTCR_MRD_TIME11_Pos)
11353#define DSI_DLTCR_MRD_TIME11 DSI_DLTCR_MRD_TIME11_Msk
11354#define DSI_DLTCR_MRD_TIME12_Pos (12U)
11355#define DSI_DLTCR_MRD_TIME12_Msk (0x1UL << DSI_DLTCR_MRD_TIME12_Pos)
11356#define DSI_DLTCR_MRD_TIME12 DSI_DLTCR_MRD_TIME12_Msk
11357#define DSI_DLTCR_MRD_TIME13_Pos (13U)
11358#define DSI_DLTCR_MRD_TIME13_Msk (0x1UL << DSI_DLTCR_MRD_TIME13_Pos)
11359#define DSI_DLTCR_MRD_TIME13 DSI_DLTCR_MRD_TIME13_Msk
11360#define DSI_DLTCR_MRD_TIME14_Pos (14U)
11361#define DSI_DLTCR_MRD_TIME14_Msk (0x1UL << DSI_DLTCR_MRD_TIME14_Pos)
11362#define DSI_DLTCR_MRD_TIME14 DSI_DLTCR_MRD_TIME14_Msk
11363
11364#define DSI_DLTCR_LP2HS_TIME_Pos (16U)
11365#define DSI_DLTCR_LP2HS_TIME_Msk (0xFFUL << DSI_DLTCR_LP2HS_TIME_Pos)
11366#define DSI_DLTCR_LP2HS_TIME DSI_DLTCR_LP2HS_TIME_Msk
11367#define DSI_DLTCR_LP2HS_TIME0_Pos (16U)
11368#define DSI_DLTCR_LP2HS_TIME0_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME0_Pos)
11369#define DSI_DLTCR_LP2HS_TIME0 DSI_DLTCR_LP2HS_TIME0_Msk
11370#define DSI_DLTCR_LP2HS_TIME1_Pos (17U)
11371#define DSI_DLTCR_LP2HS_TIME1_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME1_Pos)
11372#define DSI_DLTCR_LP2HS_TIME1 DSI_DLTCR_LP2HS_TIME1_Msk
11373#define DSI_DLTCR_LP2HS_TIME2_Pos (18U)
11374#define DSI_DLTCR_LP2HS_TIME2_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME2_Pos)
11375#define DSI_DLTCR_LP2HS_TIME2 DSI_DLTCR_LP2HS_TIME2_Msk
11376#define DSI_DLTCR_LP2HS_TIME3_Pos (19U)
11377#define DSI_DLTCR_LP2HS_TIME3_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME3_Pos)
11378#define DSI_DLTCR_LP2HS_TIME3 DSI_DLTCR_LP2HS_TIME3_Msk
11379#define DSI_DLTCR_LP2HS_TIME4_Pos (20U)
11380#define DSI_DLTCR_LP2HS_TIME4_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME4_Pos)
11381#define DSI_DLTCR_LP2HS_TIME4 DSI_DLTCR_LP2HS_TIME4_Msk
11382#define DSI_DLTCR_LP2HS_TIME5_Pos (21U)
11383#define DSI_DLTCR_LP2HS_TIME5_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME5_Pos)
11384#define DSI_DLTCR_LP2HS_TIME5 DSI_DLTCR_LP2HS_TIME5_Msk
11385#define DSI_DLTCR_LP2HS_TIME6_Pos (22U)
11386#define DSI_DLTCR_LP2HS_TIME6_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME6_Pos)
11387#define DSI_DLTCR_LP2HS_TIME6 DSI_DLTCR_LP2HS_TIME6_Msk
11388#define DSI_DLTCR_LP2HS_TIME7_Pos (23U)
11389#define DSI_DLTCR_LP2HS_TIME7_Msk (0x1UL << DSI_DLTCR_LP2HS_TIME7_Pos)
11390#define DSI_DLTCR_LP2HS_TIME7 DSI_DLTCR_LP2HS_TIME7_Msk
11391
11392#define DSI_DLTCR_HS2LP_TIME_Pos (24U)
11393#define DSI_DLTCR_HS2LP_TIME_Msk (0xFFUL << DSI_DLTCR_HS2LP_TIME_Pos)
11394#define DSI_DLTCR_HS2LP_TIME DSI_DLTCR_HS2LP_TIME_Msk
11395#define DSI_DLTCR_HS2LP_TIME0_Pos (24U)
11396#define DSI_DLTCR_HS2LP_TIME0_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME0_Pos)
11397#define DSI_DLTCR_HS2LP_TIME0 DSI_DLTCR_HS2LP_TIME0_Msk
11398#define DSI_DLTCR_HS2LP_TIME1_Pos (25U)
11399#define DSI_DLTCR_HS2LP_TIME1_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME1_Pos)
11400#define DSI_DLTCR_HS2LP_TIME1 DSI_DLTCR_HS2LP_TIME1_Msk
11401#define DSI_DLTCR_HS2LP_TIME2_Pos (26U)
11402#define DSI_DLTCR_HS2LP_TIME2_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME2_Pos)
11403#define DSI_DLTCR_HS2LP_TIME2 DSI_DLTCR_HS2LP_TIME2_Msk
11404#define DSI_DLTCR_HS2LP_TIME3_Pos (27U)
11405#define DSI_DLTCR_HS2LP_TIME3_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME3_Pos)
11406#define DSI_DLTCR_HS2LP_TIME3 DSI_DLTCR_HS2LP_TIME3_Msk
11407#define DSI_DLTCR_HS2LP_TIME4_Pos (28U)
11408#define DSI_DLTCR_HS2LP_TIME4_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME4_Pos)
11409#define DSI_DLTCR_HS2LP_TIME4 DSI_DLTCR_HS2LP_TIME4_Msk
11410#define DSI_DLTCR_HS2LP_TIME5_Pos (29U)
11411#define DSI_DLTCR_HS2LP_TIME5_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME5_Pos)
11412#define DSI_DLTCR_HS2LP_TIME5 DSI_DLTCR_HS2LP_TIME5_Msk
11413#define DSI_DLTCR_HS2LP_TIME6_Pos (30U)
11414#define DSI_DLTCR_HS2LP_TIME6_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME6_Pos)
11415#define DSI_DLTCR_HS2LP_TIME6 DSI_DLTCR_HS2LP_TIME6_Msk
11416#define DSI_DLTCR_HS2LP_TIME7_Pos (31U)
11417#define DSI_DLTCR_HS2LP_TIME7_Msk (0x1UL << DSI_DLTCR_HS2LP_TIME7_Pos)
11418#define DSI_DLTCR_HS2LP_TIME7 DSI_DLTCR_HS2LP_TIME7_Msk
11419
11420/******************* Bit definition for DSI_PCTLR register **************/
11421#define DSI_PCTLR_DEN_Pos (1U)
11422#define DSI_PCTLR_DEN_Msk (0x1UL << DSI_PCTLR_DEN_Pos)
11423#define DSI_PCTLR_DEN DSI_PCTLR_DEN_Msk
11424#define DSI_PCTLR_CKE_Pos (2U)
11425#define DSI_PCTLR_CKE_Msk (0x1UL << DSI_PCTLR_CKE_Pos)
11426#define DSI_PCTLR_CKE DSI_PCTLR_CKE_Msk
11428/******************* Bit definition for DSI_PCONFR register *************/
11429#define DSI_PCONFR_NL_Pos (0U)
11430#define DSI_PCONFR_NL_Msk (0x3UL << DSI_PCONFR_NL_Pos)
11431#define DSI_PCONFR_NL DSI_PCONFR_NL_Msk
11432#define DSI_PCONFR_NL0_Pos (0U)
11433#define DSI_PCONFR_NL0_Msk (0x1UL << DSI_PCONFR_NL0_Pos)
11434#define DSI_PCONFR_NL0 DSI_PCONFR_NL0_Msk
11435#define DSI_PCONFR_NL1_Pos (1U)
11436#define DSI_PCONFR_NL1_Msk (0x1UL << DSI_PCONFR_NL1_Pos)
11437#define DSI_PCONFR_NL1 DSI_PCONFR_NL1_Msk
11438
11439#define DSI_PCONFR_SW_TIME_Pos (8U)
11440#define DSI_PCONFR_SW_TIME_Msk (0xFFUL << DSI_PCONFR_SW_TIME_Pos)
11441#define DSI_PCONFR_SW_TIME DSI_PCONFR_SW_TIME_Msk
11442#define DSI_PCONFR_SW_TIME0_Pos (8U)
11443#define DSI_PCONFR_SW_TIME0_Msk (0x1UL << DSI_PCONFR_SW_TIME0_Pos)
11444#define DSI_PCONFR_SW_TIME0 DSI_PCONFR_SW_TIME0_Msk
11445#define DSI_PCONFR_SW_TIME1_Pos (9U)
11446#define DSI_PCONFR_SW_TIME1_Msk (0x1UL << DSI_PCONFR_SW_TIME1_Pos)
11447#define DSI_PCONFR_SW_TIME1 DSI_PCONFR_SW_TIME1_Msk
11448#define DSI_PCONFR_SW_TIME2_Pos (10U)
11449#define DSI_PCONFR_SW_TIME2_Msk (0x1UL << DSI_PCONFR_SW_TIME2_Pos)
11450#define DSI_PCONFR_SW_TIME2 DSI_PCONFR_SW_TIME2_Msk
11451#define DSI_PCONFR_SW_TIME3_Pos (11U)
11452#define DSI_PCONFR_SW_TIME3_Msk (0x1UL << DSI_PCONFR_SW_TIME3_Pos)
11453#define DSI_PCONFR_SW_TIME3 DSI_PCONFR_SW_TIME3_Msk
11454#define DSI_PCONFR_SW_TIME4_Pos (12U)
11455#define DSI_PCONFR_SW_TIME4_Msk (0x1UL << DSI_PCONFR_SW_TIME4_Pos)
11456#define DSI_PCONFR_SW_TIME4 DSI_PCONFR_SW_TIME4_Msk
11457#define DSI_PCONFR_SW_TIME5_Pos (13U)
11458#define DSI_PCONFR_SW_TIME5_Msk (0x1UL << DSI_PCONFR_SW_TIME5_Pos)
11459#define DSI_PCONFR_SW_TIME5 DSI_PCONFR_SW_TIME5_Msk
11460#define DSI_PCONFR_SW_TIME6_Pos (14U)
11461#define DSI_PCONFR_SW_TIME6_Msk (0x1UL << DSI_PCONFR_SW_TIME6_Pos)
11462#define DSI_PCONFR_SW_TIME6 DSI_PCONFR_SW_TIME6_Msk
11463#define DSI_PCONFR_SW_TIME7_Pos (15U)
11464#define DSI_PCONFR_SW_TIME7_Msk (0x1UL << DSI_PCONFR_SW_TIME7_Pos)
11465#define DSI_PCONFR_SW_TIME7 DSI_PCONFR_SW_TIME7_Msk
11466
11467/******************* Bit definition for DSI_PUCR register ***************/
11468#define DSI_PUCR_URCL_Pos (0U)
11469#define DSI_PUCR_URCL_Msk (0x1UL << DSI_PUCR_URCL_Pos)
11470#define DSI_PUCR_URCL DSI_PUCR_URCL_Msk
11471#define DSI_PUCR_UECL_Pos (1U)
11472#define DSI_PUCR_UECL_Msk (0x1UL << DSI_PUCR_UECL_Pos)
11473#define DSI_PUCR_UECL DSI_PUCR_UECL_Msk
11474#define DSI_PUCR_URDL_Pos (2U)
11475#define DSI_PUCR_URDL_Msk (0x1UL << DSI_PUCR_URDL_Pos)
11476#define DSI_PUCR_URDL DSI_PUCR_URDL_Msk
11477#define DSI_PUCR_UEDL_Pos (3U)
11478#define DSI_PUCR_UEDL_Msk (0x1UL << DSI_PUCR_UEDL_Pos)
11479#define DSI_PUCR_UEDL DSI_PUCR_UEDL_Msk
11481/******************* Bit definition for DSI_PTTCR register **************/
11482#define DSI_PTTCR_TX_TRIG_Pos (0U)
11483#define DSI_PTTCR_TX_TRIG_Msk (0xFUL << DSI_PTTCR_TX_TRIG_Pos)
11484#define DSI_PTTCR_TX_TRIG DSI_PTTCR_TX_TRIG_Msk
11485#define DSI_PTTCR_TX_TRIG0_Pos (0U)
11486#define DSI_PTTCR_TX_TRIG0_Msk (0x1UL << DSI_PTTCR_TX_TRIG0_Pos)
11487#define DSI_PTTCR_TX_TRIG0 DSI_PTTCR_TX_TRIG0_Msk
11488#define DSI_PTTCR_TX_TRIG1_Pos (1U)
11489#define DSI_PTTCR_TX_TRIG1_Msk (0x1UL << DSI_PTTCR_TX_TRIG1_Pos)
11490#define DSI_PTTCR_TX_TRIG1 DSI_PTTCR_TX_TRIG1_Msk
11491#define DSI_PTTCR_TX_TRIG2_Pos (2U)
11492#define DSI_PTTCR_TX_TRIG2_Msk (0x1UL << DSI_PTTCR_TX_TRIG2_Pos)
11493#define DSI_PTTCR_TX_TRIG2 DSI_PTTCR_TX_TRIG2_Msk
11494#define DSI_PTTCR_TX_TRIG3_Pos (3U)
11495#define DSI_PTTCR_TX_TRIG3_Msk (0x1UL << DSI_PTTCR_TX_TRIG3_Pos)
11496#define DSI_PTTCR_TX_TRIG3 DSI_PTTCR_TX_TRIG3_Msk
11497
11498/******************* Bit definition for DSI_PSR register ****************/
11499#define DSI_PSR_PD_Pos (1U)
11500#define DSI_PSR_PD_Msk (0x1UL << DSI_PSR_PD_Pos)
11501#define DSI_PSR_PD DSI_PSR_PD_Msk
11502#define DSI_PSR_PSSC_Pos (2U)
11503#define DSI_PSR_PSSC_Msk (0x1UL << DSI_PSR_PSSC_Pos)
11504#define DSI_PSR_PSSC DSI_PSR_PSSC_Msk
11505#define DSI_PSR_UANC_Pos (3U)
11506#define DSI_PSR_UANC_Msk (0x1UL << DSI_PSR_UANC_Pos)
11507#define DSI_PSR_UANC DSI_PSR_UANC_Msk
11508#define DSI_PSR_PSS0_Pos (4U)
11509#define DSI_PSR_PSS0_Msk (0x1UL << DSI_PSR_PSS0_Pos)
11510#define DSI_PSR_PSS0 DSI_PSR_PSS0_Msk
11511#define DSI_PSR_UAN0_Pos (5U)
11512#define DSI_PSR_UAN0_Msk (0x1UL << DSI_PSR_UAN0_Pos)
11513#define DSI_PSR_UAN0 DSI_PSR_UAN0_Msk
11514#define DSI_PSR_RUE0_Pos (6U)
11515#define DSI_PSR_RUE0_Msk (0x1UL << DSI_PSR_RUE0_Pos)
11516#define DSI_PSR_RUE0 DSI_PSR_RUE0_Msk
11517#define DSI_PSR_PSS1_Pos (7U)
11518#define DSI_PSR_PSS1_Msk (0x1UL << DSI_PSR_PSS1_Pos)
11519#define DSI_PSR_PSS1 DSI_PSR_PSS1_Msk
11520#define DSI_PSR_UAN1_Pos (8U)
11521#define DSI_PSR_UAN1_Msk (0x1UL << DSI_PSR_UAN1_Pos)
11522#define DSI_PSR_UAN1 DSI_PSR_UAN1_Msk
11524/******************* Bit definition for DSI_ISR0 register ***************/
11525#define DSI_ISR0_AE0_Pos (0U)
11526#define DSI_ISR0_AE0_Msk (0x1UL << DSI_ISR0_AE0_Pos)
11527#define DSI_ISR0_AE0 DSI_ISR0_AE0_Msk
11528#define DSI_ISR0_AE1_Pos (1U)
11529#define DSI_ISR0_AE1_Msk (0x1UL << DSI_ISR0_AE1_Pos)
11530#define DSI_ISR0_AE1 DSI_ISR0_AE1_Msk
11531#define DSI_ISR0_AE2_Pos (2U)
11532#define DSI_ISR0_AE2_Msk (0x1UL << DSI_ISR0_AE2_Pos)
11533#define DSI_ISR0_AE2 DSI_ISR0_AE2_Msk
11534#define DSI_ISR0_AE3_Pos (3U)
11535#define DSI_ISR0_AE3_Msk (0x1UL << DSI_ISR0_AE3_Pos)
11536#define DSI_ISR0_AE3 DSI_ISR0_AE3_Msk
11537#define DSI_ISR0_AE4_Pos (4U)
11538#define DSI_ISR0_AE4_Msk (0x1UL << DSI_ISR0_AE4_Pos)
11539#define DSI_ISR0_AE4 DSI_ISR0_AE4_Msk
11540#define DSI_ISR0_AE5_Pos (5U)
11541#define DSI_ISR0_AE5_Msk (0x1UL << DSI_ISR0_AE5_Pos)
11542#define DSI_ISR0_AE5 DSI_ISR0_AE5_Msk
11543#define DSI_ISR0_AE6_Pos (6U)
11544#define DSI_ISR0_AE6_Msk (0x1UL << DSI_ISR0_AE6_Pos)
11545#define DSI_ISR0_AE6 DSI_ISR0_AE6_Msk
11546#define DSI_ISR0_AE7_Pos (7U)
11547#define DSI_ISR0_AE7_Msk (0x1UL << DSI_ISR0_AE7_Pos)
11548#define DSI_ISR0_AE7 DSI_ISR0_AE7_Msk
11549#define DSI_ISR0_AE8_Pos (8U)
11550#define DSI_ISR0_AE8_Msk (0x1UL << DSI_ISR0_AE8_Pos)
11551#define DSI_ISR0_AE8 DSI_ISR0_AE8_Msk
11552#define DSI_ISR0_AE9_Pos (9U)
11553#define DSI_ISR0_AE9_Msk (0x1UL << DSI_ISR0_AE9_Pos)
11554#define DSI_ISR0_AE9 DSI_ISR0_AE9_Msk
11555#define DSI_ISR0_AE10_Pos (10U)
11556#define DSI_ISR0_AE10_Msk (0x1UL << DSI_ISR0_AE10_Pos)
11557#define DSI_ISR0_AE10 DSI_ISR0_AE10_Msk
11558#define DSI_ISR0_AE11_Pos (11U)
11559#define DSI_ISR0_AE11_Msk (0x1UL << DSI_ISR0_AE11_Pos)
11560#define DSI_ISR0_AE11 DSI_ISR0_AE11_Msk
11561#define DSI_ISR0_AE12_Pos (12U)
11562#define DSI_ISR0_AE12_Msk (0x1UL << DSI_ISR0_AE12_Pos)
11563#define DSI_ISR0_AE12 DSI_ISR0_AE12_Msk
11564#define DSI_ISR0_AE13_Pos (13U)
11565#define DSI_ISR0_AE13_Msk (0x1UL << DSI_ISR0_AE13_Pos)
11566#define DSI_ISR0_AE13 DSI_ISR0_AE13_Msk
11567#define DSI_ISR0_AE14_Pos (14U)
11568#define DSI_ISR0_AE14_Msk (0x1UL << DSI_ISR0_AE14_Pos)
11569#define DSI_ISR0_AE14 DSI_ISR0_AE14_Msk
11570#define DSI_ISR0_AE15_Pos (15U)
11571#define DSI_ISR0_AE15_Msk (0x1UL << DSI_ISR0_AE15_Pos)
11572#define DSI_ISR0_AE15 DSI_ISR0_AE15_Msk
11573#define DSI_ISR0_PE0_Pos (16U)
11574#define DSI_ISR0_PE0_Msk (0x1UL << DSI_ISR0_PE0_Pos)
11575#define DSI_ISR0_PE0 DSI_ISR0_PE0_Msk
11576#define DSI_ISR0_PE1_Pos (17U)
11577#define DSI_ISR0_PE1_Msk (0x1UL << DSI_ISR0_PE1_Pos)
11578#define DSI_ISR0_PE1 DSI_ISR0_PE1_Msk
11579#define DSI_ISR0_PE2_Pos (18U)
11580#define DSI_ISR0_PE2_Msk (0x1UL << DSI_ISR0_PE2_Pos)
11581#define DSI_ISR0_PE2 DSI_ISR0_PE2_Msk
11582#define DSI_ISR0_PE3_Pos (19U)
11583#define DSI_ISR0_PE3_Msk (0x1UL << DSI_ISR0_PE3_Pos)
11584#define DSI_ISR0_PE3 DSI_ISR0_PE3_Msk
11585#define DSI_ISR0_PE4_Pos (20U)
11586#define DSI_ISR0_PE4_Msk (0x1UL << DSI_ISR0_PE4_Pos)
11587#define DSI_ISR0_PE4 DSI_ISR0_PE4_Msk
11589/******************* Bit definition for DSI_ISR1 register ***************/
11590#define DSI_ISR1_TOHSTX_Pos (0U)
11591#define DSI_ISR1_TOHSTX_Msk (0x1UL << DSI_ISR1_TOHSTX_Pos)
11592#define DSI_ISR1_TOHSTX DSI_ISR1_TOHSTX_Msk
11593#define DSI_ISR1_TOLPRX_Pos (1U)
11594#define DSI_ISR1_TOLPRX_Msk (0x1UL << DSI_ISR1_TOLPRX_Pos)
11595#define DSI_ISR1_TOLPRX DSI_ISR1_TOLPRX_Msk
11596#define DSI_ISR1_ECCSE_Pos (2U)
11597#define DSI_ISR1_ECCSE_Msk (0x1UL << DSI_ISR1_ECCSE_Pos)
11598#define DSI_ISR1_ECCSE DSI_ISR1_ECCSE_Msk
11599#define DSI_ISR1_ECCME_Pos (3U)
11600#define DSI_ISR1_ECCME_Msk (0x1UL << DSI_ISR1_ECCME_Pos)
11601#define DSI_ISR1_ECCME DSI_ISR1_ECCME_Msk
11602#define DSI_ISR1_CRCE_Pos (4U)
11603#define DSI_ISR1_CRCE_Msk (0x1UL << DSI_ISR1_CRCE_Pos)
11604#define DSI_ISR1_CRCE DSI_ISR1_CRCE_Msk
11605#define DSI_ISR1_PSE_Pos (5U)
11606#define DSI_ISR1_PSE_Msk (0x1UL << DSI_ISR1_PSE_Pos)
11607#define DSI_ISR1_PSE DSI_ISR1_PSE_Msk
11608#define DSI_ISR1_EOTPE_Pos (6U)
11609#define DSI_ISR1_EOTPE_Msk (0x1UL << DSI_ISR1_EOTPE_Pos)
11610#define DSI_ISR1_EOTPE DSI_ISR1_EOTPE_Msk
11611#define DSI_ISR1_LPWRE_Pos (7U)
11612#define DSI_ISR1_LPWRE_Msk (0x1UL << DSI_ISR1_LPWRE_Pos)
11613#define DSI_ISR1_LPWRE DSI_ISR1_LPWRE_Msk
11614#define DSI_ISR1_GCWRE_Pos (8U)
11615#define DSI_ISR1_GCWRE_Msk (0x1UL << DSI_ISR1_GCWRE_Pos)
11616#define DSI_ISR1_GCWRE DSI_ISR1_GCWRE_Msk
11617#define DSI_ISR1_GPWRE_Pos (9U)
11618#define DSI_ISR1_GPWRE_Msk (0x1UL << DSI_ISR1_GPWRE_Pos)
11619#define DSI_ISR1_GPWRE DSI_ISR1_GPWRE_Msk
11620#define DSI_ISR1_GPTXE_Pos (10U)
11621#define DSI_ISR1_GPTXE_Msk (0x1UL << DSI_ISR1_GPTXE_Pos)
11622#define DSI_ISR1_GPTXE DSI_ISR1_GPTXE_Msk
11623#define DSI_ISR1_GPRDE_Pos (11U)
11624#define DSI_ISR1_GPRDE_Msk (0x1UL << DSI_ISR1_GPRDE_Pos)
11625#define DSI_ISR1_GPRDE DSI_ISR1_GPRDE_Msk
11626#define DSI_ISR1_GPRXE_Pos (12U)
11627#define DSI_ISR1_GPRXE_Msk (0x1UL << DSI_ISR1_GPRXE_Pos)
11628#define DSI_ISR1_GPRXE DSI_ISR1_GPRXE_Msk
11630/******************* Bit definition for DSI_IER0 register ***************/
11631#define DSI_IER0_AE0IE_Pos (0U)
11632#define DSI_IER0_AE0IE_Msk (0x1UL << DSI_IER0_AE0IE_Pos)
11633#define DSI_IER0_AE0IE DSI_IER0_AE0IE_Msk
11634#define DSI_IER0_AE1IE_Pos (1U)
11635#define DSI_IER0_AE1IE_Msk (0x1UL << DSI_IER0_AE1IE_Pos)
11636#define DSI_IER0_AE1IE DSI_IER0_AE1IE_Msk
11637#define DSI_IER0_AE2IE_Pos (2U)
11638#define DSI_IER0_AE2IE_Msk (0x1UL << DSI_IER0_AE2IE_Pos)
11639#define DSI_IER0_AE2IE DSI_IER0_AE2IE_Msk
11640#define DSI_IER0_AE3IE_Pos (3U)
11641#define DSI_IER0_AE3IE_Msk (0x1UL << DSI_IER0_AE3IE_Pos)
11642#define DSI_IER0_AE3IE DSI_IER0_AE3IE_Msk
11643#define DSI_IER0_AE4IE_Pos (4U)
11644#define DSI_IER0_AE4IE_Msk (0x1UL << DSI_IER0_AE4IE_Pos)
11645#define DSI_IER0_AE4IE DSI_IER0_AE4IE_Msk
11646#define DSI_IER0_AE5IE_Pos (5U)
11647#define DSI_IER0_AE5IE_Msk (0x1UL << DSI_IER0_AE5IE_Pos)
11648#define DSI_IER0_AE5IE DSI_IER0_AE5IE_Msk
11649#define DSI_IER0_AE6IE_Pos (6U)
11650#define DSI_IER0_AE6IE_Msk (0x1UL << DSI_IER0_AE6IE_Pos)
11651#define DSI_IER0_AE6IE DSI_IER0_AE6IE_Msk
11652#define DSI_IER0_AE7IE_Pos (7U)
11653#define DSI_IER0_AE7IE_Msk (0x1UL << DSI_IER0_AE7IE_Pos)
11654#define DSI_IER0_AE7IE DSI_IER0_AE7IE_Msk
11655#define DSI_IER0_AE8IE_Pos (8U)
11656#define DSI_IER0_AE8IE_Msk (0x1UL << DSI_IER0_AE8IE_Pos)
11657#define DSI_IER0_AE8IE DSI_IER0_AE8IE_Msk
11658#define DSI_IER0_AE9IE_Pos (9U)
11659#define DSI_IER0_AE9IE_Msk (0x1UL << DSI_IER0_AE9IE_Pos)
11660#define DSI_IER0_AE9IE DSI_IER0_AE9IE_Msk
11661#define DSI_IER0_AE10IE_Pos (10U)
11662#define DSI_IER0_AE10IE_Msk (0x1UL << DSI_IER0_AE10IE_Pos)
11663#define DSI_IER0_AE10IE DSI_IER0_AE10IE_Msk
11664#define DSI_IER0_AE11IE_Pos (11U)
11665#define DSI_IER0_AE11IE_Msk (0x1UL << DSI_IER0_AE11IE_Pos)
11666#define DSI_IER0_AE11IE DSI_IER0_AE11IE_Msk
11667#define DSI_IER0_AE12IE_Pos (12U)
11668#define DSI_IER0_AE12IE_Msk (0x1UL << DSI_IER0_AE12IE_Pos)
11669#define DSI_IER0_AE12IE DSI_IER0_AE12IE_Msk
11670#define DSI_IER0_AE13IE_Pos (13U)
11671#define DSI_IER0_AE13IE_Msk (0x1UL << DSI_IER0_AE13IE_Pos)
11672#define DSI_IER0_AE13IE DSI_IER0_AE13IE_Msk
11673#define DSI_IER0_AE14IE_Pos (14U)
11674#define DSI_IER0_AE14IE_Msk (0x1UL << DSI_IER0_AE14IE_Pos)
11675#define DSI_IER0_AE14IE DSI_IER0_AE14IE_Msk
11676#define DSI_IER0_AE15IE_Pos (15U)
11677#define DSI_IER0_AE15IE_Msk (0x1UL << DSI_IER0_AE15IE_Pos)
11678#define DSI_IER0_AE15IE DSI_IER0_AE15IE_Msk
11679#define DSI_IER0_PE0IE_Pos (16U)
11680#define DSI_IER0_PE0IE_Msk (0x1UL << DSI_IER0_PE0IE_Pos)
11681#define DSI_IER0_PE0IE DSI_IER0_PE0IE_Msk
11682#define DSI_IER0_PE1IE_Pos (17U)
11683#define DSI_IER0_PE1IE_Msk (0x1UL << DSI_IER0_PE1IE_Pos)
11684#define DSI_IER0_PE1IE DSI_IER0_PE1IE_Msk
11685#define DSI_IER0_PE2IE_Pos (18U)
11686#define DSI_IER0_PE2IE_Msk (0x1UL << DSI_IER0_PE2IE_Pos)
11687#define DSI_IER0_PE2IE DSI_IER0_PE2IE_Msk
11688#define DSI_IER0_PE3IE_Pos (19U)
11689#define DSI_IER0_PE3IE_Msk (0x1UL << DSI_IER0_PE3IE_Pos)
11690#define DSI_IER0_PE3IE DSI_IER0_PE3IE_Msk
11691#define DSI_IER0_PE4IE_Pos (20U)
11692#define DSI_IER0_PE4IE_Msk (0x1UL << DSI_IER0_PE4IE_Pos)
11693#define DSI_IER0_PE4IE DSI_IER0_PE4IE_Msk
11695/******************* Bit definition for DSI_IER1 register ***************/
11696#define DSI_IER1_TOHSTXIE_Pos (0U)
11697#define DSI_IER1_TOHSTXIE_Msk (0x1UL << DSI_IER1_TOHSTXIE_Pos)
11698#define DSI_IER1_TOHSTXIE DSI_IER1_TOHSTXIE_Msk
11699#define DSI_IER1_TOLPRXIE_Pos (1U)
11700#define DSI_IER1_TOLPRXIE_Msk (0x1UL << DSI_IER1_TOLPRXIE_Pos)
11701#define DSI_IER1_TOLPRXIE DSI_IER1_TOLPRXIE_Msk
11702#define DSI_IER1_ECCSEIE_Pos (2U)
11703#define DSI_IER1_ECCSEIE_Msk (0x1UL << DSI_IER1_ECCSEIE_Pos)
11704#define DSI_IER1_ECCSEIE DSI_IER1_ECCSEIE_Msk
11705#define DSI_IER1_ECCMEIE_Pos (3U)
11706#define DSI_IER1_ECCMEIE_Msk (0x1UL << DSI_IER1_ECCMEIE_Pos)
11707#define DSI_IER1_ECCMEIE DSI_IER1_ECCMEIE_Msk
11708#define DSI_IER1_CRCEIE_Pos (4U)
11709#define DSI_IER1_CRCEIE_Msk (0x1UL << DSI_IER1_CRCEIE_Pos)
11710#define DSI_IER1_CRCEIE DSI_IER1_CRCEIE_Msk
11711#define DSI_IER1_PSEIE_Pos (5U)
11712#define DSI_IER1_PSEIE_Msk (0x1UL << DSI_IER1_PSEIE_Pos)
11713#define DSI_IER1_PSEIE DSI_IER1_PSEIE_Msk
11714#define DSI_IER1_EOTPEIE_Pos (6U)
11715#define DSI_IER1_EOTPEIE_Msk (0x1UL << DSI_IER1_EOTPEIE_Pos)
11716#define DSI_IER1_EOTPEIE DSI_IER1_EOTPEIE_Msk
11717#define DSI_IER1_LPWREIE_Pos (7U)
11718#define DSI_IER1_LPWREIE_Msk (0x1UL << DSI_IER1_LPWREIE_Pos)
11719#define DSI_IER1_LPWREIE DSI_IER1_LPWREIE_Msk
11720#define DSI_IER1_GCWREIE_Pos (8U)
11721#define DSI_IER1_GCWREIE_Msk (0x1UL << DSI_IER1_GCWREIE_Pos)
11722#define DSI_IER1_GCWREIE DSI_IER1_GCWREIE_Msk
11723#define DSI_IER1_GPWREIE_Pos (9U)
11724#define DSI_IER1_GPWREIE_Msk (0x1UL << DSI_IER1_GPWREIE_Pos)
11725#define DSI_IER1_GPWREIE DSI_IER1_GPWREIE_Msk
11726#define DSI_IER1_GPTXEIE_Pos (10U)
11727#define DSI_IER1_GPTXEIE_Msk (0x1UL << DSI_IER1_GPTXEIE_Pos)
11728#define DSI_IER1_GPTXEIE DSI_IER1_GPTXEIE_Msk
11729#define DSI_IER1_GPRDEIE_Pos (11U)
11730#define DSI_IER1_GPRDEIE_Msk (0x1UL << DSI_IER1_GPRDEIE_Pos)
11731#define DSI_IER1_GPRDEIE DSI_IER1_GPRDEIE_Msk
11732#define DSI_IER1_GPRXEIE_Pos (12U)
11733#define DSI_IER1_GPRXEIE_Msk (0x1UL << DSI_IER1_GPRXEIE_Pos)
11734#define DSI_IER1_GPRXEIE DSI_IER1_GPRXEIE_Msk
11736/******************* Bit definition for DSI_FIR0 register ***************/
11737#define DSI_FIR0_FAE0_Pos (0U)
11738#define DSI_FIR0_FAE0_Msk (0x1UL << DSI_FIR0_FAE0_Pos)
11739#define DSI_FIR0_FAE0 DSI_FIR0_FAE0_Msk
11740#define DSI_FIR0_FAE1_Pos (1U)
11741#define DSI_FIR0_FAE1_Msk (0x1UL << DSI_FIR0_FAE1_Pos)
11742#define DSI_FIR0_FAE1 DSI_FIR0_FAE1_Msk
11743#define DSI_FIR0_FAE2_Pos (2U)
11744#define DSI_FIR0_FAE2_Msk (0x1UL << DSI_FIR0_FAE2_Pos)
11745#define DSI_FIR0_FAE2 DSI_FIR0_FAE2_Msk
11746#define DSI_FIR0_FAE3_Pos (3U)
11747#define DSI_FIR0_FAE3_Msk (0x1UL << DSI_FIR0_FAE3_Pos)
11748#define DSI_FIR0_FAE3 DSI_FIR0_FAE3_Msk
11749#define DSI_FIR0_FAE4_Pos (4U)
11750#define DSI_FIR0_FAE4_Msk (0x1UL << DSI_FIR0_FAE4_Pos)
11751#define DSI_FIR0_FAE4 DSI_FIR0_FAE4_Msk
11752#define DSI_FIR0_FAE5_Pos (5U)
11753#define DSI_FIR0_FAE5_Msk (0x1UL << DSI_FIR0_FAE5_Pos)
11754#define DSI_FIR0_FAE5 DSI_FIR0_FAE5_Msk
11755#define DSI_FIR0_FAE6_Pos (6U)
11756#define DSI_FIR0_FAE6_Msk (0x1UL << DSI_FIR0_FAE6_Pos)
11757#define DSI_FIR0_FAE6 DSI_FIR0_FAE6_Msk
11758#define DSI_FIR0_FAE7_Pos (7U)
11759#define DSI_FIR0_FAE7_Msk (0x1UL << DSI_FIR0_FAE7_Pos)
11760#define DSI_FIR0_FAE7 DSI_FIR0_FAE7_Msk
11761#define DSI_FIR0_FAE8_Pos (8U)
11762#define DSI_FIR0_FAE8_Msk (0x1UL << DSI_FIR0_FAE8_Pos)
11763#define DSI_FIR0_FAE8 DSI_FIR0_FAE8_Msk
11764#define DSI_FIR0_FAE9_Pos (9U)
11765#define DSI_FIR0_FAE9_Msk (0x1UL << DSI_FIR0_FAE9_Pos)
11766#define DSI_FIR0_FAE9 DSI_FIR0_FAE9_Msk
11767#define DSI_FIR0_FAE10_Pos (10U)
11768#define DSI_FIR0_FAE10_Msk (0x1UL << DSI_FIR0_FAE10_Pos)
11769#define DSI_FIR0_FAE10 DSI_FIR0_FAE10_Msk
11770#define DSI_FIR0_FAE11_Pos (11U)
11771#define DSI_FIR0_FAE11_Msk (0x1UL << DSI_FIR0_FAE11_Pos)
11772#define DSI_FIR0_FAE11 DSI_FIR0_FAE11_Msk
11773#define DSI_FIR0_FAE12_Pos (12U)
11774#define DSI_FIR0_FAE12_Msk (0x1UL << DSI_FIR0_FAE12_Pos)
11775#define DSI_FIR0_FAE12 DSI_FIR0_FAE12_Msk
11776#define DSI_FIR0_FAE13_Pos (13U)
11777#define DSI_FIR0_FAE13_Msk (0x1UL << DSI_FIR0_FAE13_Pos)
11778#define DSI_FIR0_FAE13 DSI_FIR0_FAE13_Msk
11779#define DSI_FIR0_FAE14_Pos (14U)
11780#define DSI_FIR0_FAE14_Msk (0x1UL << DSI_FIR0_FAE14_Pos)
11781#define DSI_FIR0_FAE14 DSI_FIR0_FAE14_Msk
11782#define DSI_FIR0_FAE15_Pos (15U)
11783#define DSI_FIR0_FAE15_Msk (0x1UL << DSI_FIR0_FAE15_Pos)
11784#define DSI_FIR0_FAE15 DSI_FIR0_FAE15_Msk
11785#define DSI_FIR0_FPE0_Pos (16U)
11786#define DSI_FIR0_FPE0_Msk (0x1UL << DSI_FIR0_FPE0_Pos)
11787#define DSI_FIR0_FPE0 DSI_FIR0_FPE0_Msk
11788#define DSI_FIR0_FPE1_Pos (17U)
11789#define DSI_FIR0_FPE1_Msk (0x1UL << DSI_FIR0_FPE1_Pos)
11790#define DSI_FIR0_FPE1 DSI_FIR0_FPE1_Msk
11791#define DSI_FIR0_FPE2_Pos (18U)
11792#define DSI_FIR0_FPE2_Msk (0x1UL << DSI_FIR0_FPE2_Pos)
11793#define DSI_FIR0_FPE2 DSI_FIR0_FPE2_Msk
11794#define DSI_FIR0_FPE3_Pos (19U)
11795#define DSI_FIR0_FPE3_Msk (0x1UL << DSI_FIR0_FPE3_Pos)
11796#define DSI_FIR0_FPE3 DSI_FIR0_FPE3_Msk
11797#define DSI_FIR0_FPE4_Pos (20U)
11798#define DSI_FIR0_FPE4_Msk (0x1UL << DSI_FIR0_FPE4_Pos)
11799#define DSI_FIR0_FPE4 DSI_FIR0_FPE4_Msk
11801/******************* Bit definition for DSI_FIR1 register ***************/
11802#define DSI_FIR1_FTOHSTX_Pos (0U)
11803#define DSI_FIR1_FTOHSTX_Msk (0x1UL << DSI_FIR1_FTOHSTX_Pos)
11804#define DSI_FIR1_FTOHSTX DSI_FIR1_FTOHSTX_Msk
11805#define DSI_FIR1_FTOLPRX_Pos (1U)
11806#define DSI_FIR1_FTOLPRX_Msk (0x1UL << DSI_FIR1_FTOLPRX_Pos)
11807#define DSI_FIR1_FTOLPRX DSI_FIR1_FTOLPRX_Msk
11808#define DSI_FIR1_FECCSE_Pos (2U)
11809#define DSI_FIR1_FECCSE_Msk (0x1UL << DSI_FIR1_FECCSE_Pos)
11810#define DSI_FIR1_FECCSE DSI_FIR1_FECCSE_Msk
11811#define DSI_FIR1_FECCME_Pos (3U)
11812#define DSI_FIR1_FECCME_Msk (0x1UL << DSI_FIR1_FECCME_Pos)
11813#define DSI_FIR1_FECCME DSI_FIR1_FECCME_Msk
11814#define DSI_FIR1_FCRCE_Pos (4U)
11815#define DSI_FIR1_FCRCE_Msk (0x1UL << DSI_FIR1_FCRCE_Pos)
11816#define DSI_FIR1_FCRCE DSI_FIR1_FCRCE_Msk
11817#define DSI_FIR1_FPSE_Pos (5U)
11818#define DSI_FIR1_FPSE_Msk (0x1UL << DSI_FIR1_FPSE_Pos)
11819#define DSI_FIR1_FPSE DSI_FIR1_FPSE_Msk
11820#define DSI_FIR1_FEOTPE_Pos (6U)
11821#define DSI_FIR1_FEOTPE_Msk (0x1UL << DSI_FIR1_FEOTPE_Pos)
11822#define DSI_FIR1_FEOTPE DSI_FIR1_FEOTPE_Msk
11823#define DSI_FIR1_FLPWRE_Pos (7U)
11824#define DSI_FIR1_FLPWRE_Msk (0x1UL << DSI_FIR1_FLPWRE_Pos)
11825#define DSI_FIR1_FLPWRE DSI_FIR1_FLPWRE_Msk
11826#define DSI_FIR1_FGCWRE_Pos (8U)
11827#define DSI_FIR1_FGCWRE_Msk (0x1UL << DSI_FIR1_FGCWRE_Pos)
11828#define DSI_FIR1_FGCWRE DSI_FIR1_FGCWRE_Msk
11829#define DSI_FIR1_FGPWRE_Pos (9U)
11830#define DSI_FIR1_FGPWRE_Msk (0x1UL << DSI_FIR1_FGPWRE_Pos)
11831#define DSI_FIR1_FGPWRE DSI_FIR1_FGPWRE_Msk
11832#define DSI_FIR1_FGPTXE_Pos (10U)
11833#define DSI_FIR1_FGPTXE_Msk (0x1UL << DSI_FIR1_FGPTXE_Pos)
11834#define DSI_FIR1_FGPTXE DSI_FIR1_FGPTXE_Msk
11835#define DSI_FIR1_FGPRDE_Pos (11U)
11836#define DSI_FIR1_FGPRDE_Msk (0x1UL << DSI_FIR1_FGPRDE_Pos)
11837#define DSI_FIR1_FGPRDE DSI_FIR1_FGPRDE_Msk
11838#define DSI_FIR1_FGPRXE_Pos (12U)
11839#define DSI_FIR1_FGPRXE_Msk (0x1UL << DSI_FIR1_FGPRXE_Pos)
11840#define DSI_FIR1_FGPRXE DSI_FIR1_FGPRXE_Msk
11842/******************* Bit definition for DSI_VSCR register ***************/
11843#define DSI_VSCR_EN_Pos (0U)
11844#define DSI_VSCR_EN_Msk (0x1UL << DSI_VSCR_EN_Pos)
11845#define DSI_VSCR_EN DSI_VSCR_EN_Msk
11846#define DSI_VSCR_UR_Pos (8U)
11847#define DSI_VSCR_UR_Msk (0x1UL << DSI_VSCR_UR_Pos)
11848#define DSI_VSCR_UR DSI_VSCR_UR_Msk
11850/******************* Bit definition for DSI_LCVCIDR register ************/
11851#define DSI_LCVCIDR_VCID_Pos (0U)
11852#define DSI_LCVCIDR_VCID_Msk (0x3UL << DSI_LCVCIDR_VCID_Pos)
11853#define DSI_LCVCIDR_VCID DSI_LCVCIDR_VCID_Msk
11854#define DSI_LCVCIDR_VCID0_Pos (0U)
11855#define DSI_LCVCIDR_VCID0_Msk (0x1UL << DSI_LCVCIDR_VCID0_Pos)
11856#define DSI_LCVCIDR_VCID0 DSI_LCVCIDR_VCID0_Msk
11857#define DSI_LCVCIDR_VCID1_Pos (1U)
11858#define DSI_LCVCIDR_VCID1_Msk (0x1UL << DSI_LCVCIDR_VCID1_Pos)
11859#define DSI_LCVCIDR_VCID1 DSI_LCVCIDR_VCID1_Msk
11860
11861/******************* Bit definition for DSI_LCCCR register **************/
11862#define DSI_LCCCR_COLC_Pos (0U)
11863#define DSI_LCCCR_COLC_Msk (0xFUL << DSI_LCCCR_COLC_Pos)
11864#define DSI_LCCCR_COLC DSI_LCCCR_COLC_Msk
11865#define DSI_LCCCR_COLC0_Pos (0U)
11866#define DSI_LCCCR_COLC0_Msk (0x1UL << DSI_LCCCR_COLC0_Pos)
11867#define DSI_LCCCR_COLC0 DSI_LCCCR_COLC0_Msk
11868#define DSI_LCCCR_COLC1_Pos (1U)
11869#define DSI_LCCCR_COLC1_Msk (0x1UL << DSI_LCCCR_COLC1_Pos)
11870#define DSI_LCCCR_COLC1 DSI_LCCCR_COLC1_Msk
11871#define DSI_LCCCR_COLC2_Pos (2U)
11872#define DSI_LCCCR_COLC2_Msk (0x1UL << DSI_LCCCR_COLC2_Pos)
11873#define DSI_LCCCR_COLC2 DSI_LCCCR_COLC2_Msk
11874#define DSI_LCCCR_COLC3_Pos (3U)
11875#define DSI_LCCCR_COLC3_Msk (0x1UL << DSI_LCCCR_COLC3_Pos)
11876#define DSI_LCCCR_COLC3 DSI_LCCCR_COLC3_Msk
11877
11878#define DSI_LCCCR_LPE_Pos (8U)
11879#define DSI_LCCCR_LPE_Msk (0x1UL << DSI_LCCCR_LPE_Pos)
11880#define DSI_LCCCR_LPE DSI_LCCCR_LPE_Msk
11882/******************* Bit definition for DSI_LPMCCR register *************/
11883#define DSI_LPMCCR_VLPSIZE_Pos (0U)
11884#define DSI_LPMCCR_VLPSIZE_Msk (0xFFUL << DSI_LPMCCR_VLPSIZE_Pos)
11885#define DSI_LPMCCR_VLPSIZE DSI_LPMCCR_VLPSIZE_Msk
11886#define DSI_LPMCCR_VLPSIZE0_Pos (0U)
11887#define DSI_LPMCCR_VLPSIZE0_Msk (0x1UL << DSI_LPMCCR_VLPSIZE0_Pos)
11888#define DSI_LPMCCR_VLPSIZE0 DSI_LPMCCR_VLPSIZE0_Msk
11889#define DSI_LPMCCR_VLPSIZE1_Pos (1U)
11890#define DSI_LPMCCR_VLPSIZE1_Msk (0x1UL << DSI_LPMCCR_VLPSIZE1_Pos)
11891#define DSI_LPMCCR_VLPSIZE1 DSI_LPMCCR_VLPSIZE1_Msk
11892#define DSI_LPMCCR_VLPSIZE2_Pos (2U)
11893#define DSI_LPMCCR_VLPSIZE2_Msk (0x1UL << DSI_LPMCCR_VLPSIZE2_Pos)
11894#define DSI_LPMCCR_VLPSIZE2 DSI_LPMCCR_VLPSIZE2_Msk
11895#define DSI_LPMCCR_VLPSIZE3_Pos (3U)
11896#define DSI_LPMCCR_VLPSIZE3_Msk (0x1UL << DSI_LPMCCR_VLPSIZE3_Pos)
11897#define DSI_LPMCCR_VLPSIZE3 DSI_LPMCCR_VLPSIZE3_Msk
11898#define DSI_LPMCCR_VLPSIZE4_Pos (4U)
11899#define DSI_LPMCCR_VLPSIZE4_Msk (0x1UL << DSI_LPMCCR_VLPSIZE4_Pos)
11900#define DSI_LPMCCR_VLPSIZE4 DSI_LPMCCR_VLPSIZE4_Msk
11901#define DSI_LPMCCR_VLPSIZE5_Pos (5U)
11902#define DSI_LPMCCR_VLPSIZE5_Msk (0x1UL << DSI_LPMCCR_VLPSIZE5_Pos)
11903#define DSI_LPMCCR_VLPSIZE5 DSI_LPMCCR_VLPSIZE5_Msk
11904#define DSI_LPMCCR_VLPSIZE6_Pos (6U)
11905#define DSI_LPMCCR_VLPSIZE6_Msk (0x1UL << DSI_LPMCCR_VLPSIZE6_Pos)
11906#define DSI_LPMCCR_VLPSIZE6 DSI_LPMCCR_VLPSIZE6_Msk
11907#define DSI_LPMCCR_VLPSIZE7_Pos (7U)
11908#define DSI_LPMCCR_VLPSIZE7_Msk (0x1UL << DSI_LPMCCR_VLPSIZE7_Pos)
11909#define DSI_LPMCCR_VLPSIZE7 DSI_LPMCCR_VLPSIZE7_Msk
11910
11911#define DSI_LPMCCR_LPSIZE_Pos (16U)
11912#define DSI_LPMCCR_LPSIZE_Msk (0xFFUL << DSI_LPMCCR_LPSIZE_Pos)
11913#define DSI_LPMCCR_LPSIZE DSI_LPMCCR_LPSIZE_Msk
11914#define DSI_LPMCCR_LPSIZE0_Pos (16U)
11915#define DSI_LPMCCR_LPSIZE0_Msk (0x1UL << DSI_LPMCCR_LPSIZE0_Pos)
11916#define DSI_LPMCCR_LPSIZE0 DSI_LPMCCR_LPSIZE0_Msk
11917#define DSI_LPMCCR_LPSIZE1_Pos (17U)
11918#define DSI_LPMCCR_LPSIZE1_Msk (0x1UL << DSI_LPMCCR_LPSIZE1_Pos)
11919#define DSI_LPMCCR_LPSIZE1 DSI_LPMCCR_LPSIZE1_Msk
11920#define DSI_LPMCCR_LPSIZE2_Pos (18U)
11921#define DSI_LPMCCR_LPSIZE2_Msk (0x1UL << DSI_LPMCCR_LPSIZE2_Pos)
11922#define DSI_LPMCCR_LPSIZE2 DSI_LPMCCR_LPSIZE2_Msk
11923#define DSI_LPMCCR_LPSIZE3_Pos (19U)
11924#define DSI_LPMCCR_LPSIZE3_Msk (0x1UL << DSI_LPMCCR_LPSIZE3_Pos)
11925#define DSI_LPMCCR_LPSIZE3 DSI_LPMCCR_LPSIZE3_Msk
11926#define DSI_LPMCCR_LPSIZE4_Pos (20U)
11927#define DSI_LPMCCR_LPSIZE4_Msk (0x1UL << DSI_LPMCCR_LPSIZE4_Pos)
11928#define DSI_LPMCCR_LPSIZE4 DSI_LPMCCR_LPSIZE4_Msk
11929#define DSI_LPMCCR_LPSIZE5_Pos (21U)
11930#define DSI_LPMCCR_LPSIZE5_Msk (0x1UL << DSI_LPMCCR_LPSIZE5_Pos)
11931#define DSI_LPMCCR_LPSIZE5 DSI_LPMCCR_LPSIZE5_Msk
11932#define DSI_LPMCCR_LPSIZE6_Pos (22U)
11933#define DSI_LPMCCR_LPSIZE6_Msk (0x1UL << DSI_LPMCCR_LPSIZE6_Pos)
11934#define DSI_LPMCCR_LPSIZE6 DSI_LPMCCR_LPSIZE6_Msk
11935#define DSI_LPMCCR_LPSIZE7_Pos (23U)
11936#define DSI_LPMCCR_LPSIZE7_Msk (0x1UL << DSI_LPMCCR_LPSIZE7_Pos)
11937#define DSI_LPMCCR_LPSIZE7 DSI_LPMCCR_LPSIZE7_Msk
11938
11939/******************* Bit definition for DSI_VMCCR register **************/
11940#define DSI_VMCCR_VMT_Pos (0U)
11941#define DSI_VMCCR_VMT_Msk (0x3UL << DSI_VMCCR_VMT_Pos)
11942#define DSI_VMCCR_VMT DSI_VMCCR_VMT_Msk
11943#define DSI_VMCCR_VMT0_Pos (0U)
11944#define DSI_VMCCR_VMT0_Msk (0x1UL << DSI_VMCCR_VMT0_Pos)
11945#define DSI_VMCCR_VMT0 DSI_VMCCR_VMT0_Msk
11946#define DSI_VMCCR_VMT1_Pos (1U)
11947#define DSI_VMCCR_VMT1_Msk (0x1UL << DSI_VMCCR_VMT1_Pos)
11948#define DSI_VMCCR_VMT1 DSI_VMCCR_VMT1_Msk
11949
11950#define DSI_VMCCR_LPVSAE_Pos (8U)
11951#define DSI_VMCCR_LPVSAE_Msk (0x1UL << DSI_VMCCR_LPVSAE_Pos)
11952#define DSI_VMCCR_LPVSAE DSI_VMCCR_LPVSAE_Msk
11953#define DSI_VMCCR_LPVBPE_Pos (9U)
11954#define DSI_VMCCR_LPVBPE_Msk (0x1UL << DSI_VMCCR_LPVBPE_Pos)
11955#define DSI_VMCCR_LPVBPE DSI_VMCCR_LPVBPE_Msk
11956#define DSI_VMCCR_LPVFPE_Pos (10U)
11957#define DSI_VMCCR_LPVFPE_Msk (0x1UL << DSI_VMCCR_LPVFPE_Pos)
11958#define DSI_VMCCR_LPVFPE DSI_VMCCR_LPVFPE_Msk
11959#define DSI_VMCCR_LPVAE_Pos (11U)
11960#define DSI_VMCCR_LPVAE_Msk (0x1UL << DSI_VMCCR_LPVAE_Pos)
11961#define DSI_VMCCR_LPVAE DSI_VMCCR_LPVAE_Msk
11962#define DSI_VMCCR_LPHBPE_Pos (12U)
11963#define DSI_VMCCR_LPHBPE_Msk (0x1UL << DSI_VMCCR_LPHBPE_Pos)
11964#define DSI_VMCCR_LPHBPE DSI_VMCCR_LPHBPE_Msk
11965#define DSI_VMCCR_LPHFE_Pos (13U)
11966#define DSI_VMCCR_LPHFE_Msk (0x1UL << DSI_VMCCR_LPHFE_Pos)
11967#define DSI_VMCCR_LPHFE DSI_VMCCR_LPHFE_Msk
11968#define DSI_VMCCR_FBTAAE_Pos (14U)
11969#define DSI_VMCCR_FBTAAE_Msk (0x1UL << DSI_VMCCR_FBTAAE_Pos)
11970#define DSI_VMCCR_FBTAAE DSI_VMCCR_FBTAAE_Msk
11971#define DSI_VMCCR_LPCE_Pos (15U)
11972#define DSI_VMCCR_LPCE_Msk (0x1UL << DSI_VMCCR_LPCE_Pos)
11973#define DSI_VMCCR_LPCE DSI_VMCCR_LPCE_Msk
11975/******************* Bit definition for DSI_VPCCR register **************/
11976#define DSI_VPCCR_VPSIZE_Pos (0U)
11977#define DSI_VPCCR_VPSIZE_Msk (0x3FFFUL << DSI_VPCCR_VPSIZE_Pos)
11978#define DSI_VPCCR_VPSIZE DSI_VPCCR_VPSIZE_Msk
11979#define DSI_VPCCR_VPSIZE0_Pos (0U)
11980#define DSI_VPCCR_VPSIZE0_Msk (0x1UL << DSI_VPCCR_VPSIZE0_Pos)
11981#define DSI_VPCCR_VPSIZE0 DSI_VPCCR_VPSIZE0_Msk
11982#define DSI_VPCCR_VPSIZE1_Pos (1U)
11983#define DSI_VPCCR_VPSIZE1_Msk (0x1UL << DSI_VPCCR_VPSIZE1_Pos)
11984#define DSI_VPCCR_VPSIZE1 DSI_VPCCR_VPSIZE1_Msk
11985#define DSI_VPCCR_VPSIZE2_Pos (2U)
11986#define DSI_VPCCR_VPSIZE2_Msk (0x1UL << DSI_VPCCR_VPSIZE2_Pos)
11987#define DSI_VPCCR_VPSIZE2 DSI_VPCCR_VPSIZE2_Msk
11988#define DSI_VPCCR_VPSIZE3_Pos (3U)
11989#define DSI_VPCCR_VPSIZE3_Msk (0x1UL << DSI_VPCCR_VPSIZE3_Pos)
11990#define DSI_VPCCR_VPSIZE3 DSI_VPCCR_VPSIZE3_Msk
11991#define DSI_VPCCR_VPSIZE4_Pos (4U)
11992#define DSI_VPCCR_VPSIZE4_Msk (0x1UL << DSI_VPCCR_VPSIZE4_Pos)
11993#define DSI_VPCCR_VPSIZE4 DSI_VPCCR_VPSIZE4_Msk
11994#define DSI_VPCCR_VPSIZE5_Pos (5U)
11995#define DSI_VPCCR_VPSIZE5_Msk (0x1UL << DSI_VPCCR_VPSIZE5_Pos)
11996#define DSI_VPCCR_VPSIZE5 DSI_VPCCR_VPSIZE5_Msk
11997#define DSI_VPCCR_VPSIZE6_Pos (6U)
11998#define DSI_VPCCR_VPSIZE6_Msk (0x1UL << DSI_VPCCR_VPSIZE6_Pos)
11999#define DSI_VPCCR_VPSIZE6 DSI_VPCCR_VPSIZE6_Msk
12000#define DSI_VPCCR_VPSIZE7_Pos (7U)
12001#define DSI_VPCCR_VPSIZE7_Msk (0x1UL << DSI_VPCCR_VPSIZE7_Pos)
12002#define DSI_VPCCR_VPSIZE7 DSI_VPCCR_VPSIZE7_Msk
12003#define DSI_VPCCR_VPSIZE8_Pos (8U)
12004#define DSI_VPCCR_VPSIZE8_Msk (0x1UL << DSI_VPCCR_VPSIZE8_Pos)
12005#define DSI_VPCCR_VPSIZE8 DSI_VPCCR_VPSIZE8_Msk
12006#define DSI_VPCCR_VPSIZE9_Pos (9U)
12007#define DSI_VPCCR_VPSIZE9_Msk (0x1UL << DSI_VPCCR_VPSIZE9_Pos)
12008#define DSI_VPCCR_VPSIZE9 DSI_VPCCR_VPSIZE9_Msk
12009#define DSI_VPCCR_VPSIZE10_Pos (10U)
12010#define DSI_VPCCR_VPSIZE10_Msk (0x1UL << DSI_VPCCR_VPSIZE10_Pos)
12011#define DSI_VPCCR_VPSIZE10 DSI_VPCCR_VPSIZE10_Msk
12012#define DSI_VPCCR_VPSIZE11_Pos (11U)
12013#define DSI_VPCCR_VPSIZE11_Msk (0x1UL << DSI_VPCCR_VPSIZE11_Pos)
12014#define DSI_VPCCR_VPSIZE11 DSI_VPCCR_VPSIZE11_Msk
12015#define DSI_VPCCR_VPSIZE12_Pos (12U)
12016#define DSI_VPCCR_VPSIZE12_Msk (0x1UL << DSI_VPCCR_VPSIZE12_Pos)
12017#define DSI_VPCCR_VPSIZE12 DSI_VPCCR_VPSIZE12_Msk
12018#define DSI_VPCCR_VPSIZE13_Pos (13U)
12019#define DSI_VPCCR_VPSIZE13_Msk (0x1UL << DSI_VPCCR_VPSIZE13_Pos)
12020#define DSI_VPCCR_VPSIZE13 DSI_VPCCR_VPSIZE13_Msk
12021
12022/******************* Bit definition for DSI_VCCCR register **************/
12023#define DSI_VCCCR_NUMC_Pos (0U)
12024#define DSI_VCCCR_NUMC_Msk (0x1FFFUL << DSI_VCCCR_NUMC_Pos)
12025#define DSI_VCCCR_NUMC DSI_VCCCR_NUMC_Msk
12026#define DSI_VCCCR_NUMC0_Pos (0U)
12027#define DSI_VCCCR_NUMC0_Msk (0x1UL << DSI_VCCCR_NUMC0_Pos)
12028#define DSI_VCCCR_NUMC0 DSI_VCCCR_NUMC0_Msk
12029#define DSI_VCCCR_NUMC1_Pos (1U)
12030#define DSI_VCCCR_NUMC1_Msk (0x1UL << DSI_VCCCR_NUMC1_Pos)
12031#define DSI_VCCCR_NUMC1 DSI_VCCCR_NUMC1_Msk
12032#define DSI_VCCCR_NUMC2_Pos (2U)
12033#define DSI_VCCCR_NUMC2_Msk (0x1UL << DSI_VCCCR_NUMC2_Pos)
12034#define DSI_VCCCR_NUMC2 DSI_VCCCR_NUMC2_Msk
12035#define DSI_VCCCR_NUMC3_Pos (3U)
12036#define DSI_VCCCR_NUMC3_Msk (0x1UL << DSI_VCCCR_NUMC3_Pos)
12037#define DSI_VCCCR_NUMC3 DSI_VCCCR_NUMC3_Msk
12038#define DSI_VCCCR_NUMC4_Pos (4U)
12039#define DSI_VCCCR_NUMC4_Msk (0x1UL << DSI_VCCCR_NUMC4_Pos)
12040#define DSI_VCCCR_NUMC4 DSI_VCCCR_NUMC4_Msk
12041#define DSI_VCCCR_NUMC5_Pos (5U)
12042#define DSI_VCCCR_NUMC5_Msk (0x1UL << DSI_VCCCR_NUMC5_Pos)
12043#define DSI_VCCCR_NUMC5 DSI_VCCCR_NUMC5_Msk
12044#define DSI_VCCCR_NUMC6_Pos (6U)
12045#define DSI_VCCCR_NUMC6_Msk (0x1UL << DSI_VCCCR_NUMC6_Pos)
12046#define DSI_VCCCR_NUMC6 DSI_VCCCR_NUMC6_Msk
12047#define DSI_VCCCR_NUMC7_Pos (7U)
12048#define DSI_VCCCR_NUMC7_Msk (0x1UL << DSI_VCCCR_NUMC7_Pos)
12049#define DSI_VCCCR_NUMC7 DSI_VCCCR_NUMC7_Msk
12050#define DSI_VCCCR_NUMC8_Pos (8U)
12051#define DSI_VCCCR_NUMC8_Msk (0x1UL << DSI_VCCCR_NUMC8_Pos)
12052#define DSI_VCCCR_NUMC8 DSI_VCCCR_NUMC8_Msk
12053#define DSI_VCCCR_NUMC9_Pos (9U)
12054#define DSI_VCCCR_NUMC9_Msk (0x1UL << DSI_VCCCR_NUMC9_Pos)
12055#define DSI_VCCCR_NUMC9 DSI_VCCCR_NUMC9_Msk
12056#define DSI_VCCCR_NUMC10_Pos (10U)
12057#define DSI_VCCCR_NUMC10_Msk (0x1UL << DSI_VCCCR_NUMC10_Pos)
12058#define DSI_VCCCR_NUMC10 DSI_VCCCR_NUMC10_Msk
12059#define DSI_VCCCR_NUMC11_Pos (11U)
12060#define DSI_VCCCR_NUMC11_Msk (0x1UL << DSI_VCCCR_NUMC11_Pos)
12061#define DSI_VCCCR_NUMC11 DSI_VCCCR_NUMC11_Msk
12062#define DSI_VCCCR_NUMC12_Pos (12U)
12063#define DSI_VCCCR_NUMC12_Msk (0x1UL << DSI_VCCCR_NUMC12_Pos)
12064#define DSI_VCCCR_NUMC12 DSI_VCCCR_NUMC12_Msk
12065
12066/******************* Bit definition for DSI_VNPCCR register *************/
12067#define DSI_VNPCCR_NPSIZE_Pos (0U)
12068#define DSI_VNPCCR_NPSIZE_Msk (0x1FFFUL << DSI_VNPCCR_NPSIZE_Pos)
12069#define DSI_VNPCCR_NPSIZE DSI_VNPCCR_NPSIZE_Msk
12070#define DSI_VNPCCR_NPSIZE0_Pos (0U)
12071#define DSI_VNPCCR_NPSIZE0_Msk (0x1UL << DSI_VNPCCR_NPSIZE0_Pos)
12072#define DSI_VNPCCR_NPSIZE0 DSI_VNPCCR_NPSIZE0_Msk
12073#define DSI_VNPCCR_NPSIZE1_Pos (1U)
12074#define DSI_VNPCCR_NPSIZE1_Msk (0x1UL << DSI_VNPCCR_NPSIZE1_Pos)
12075#define DSI_VNPCCR_NPSIZE1 DSI_VNPCCR_NPSIZE1_Msk
12076#define DSI_VNPCCR_NPSIZE2_Pos (2U)
12077#define DSI_VNPCCR_NPSIZE2_Msk (0x1UL << DSI_VNPCCR_NPSIZE2_Pos)
12078#define DSI_VNPCCR_NPSIZE2 DSI_VNPCCR_NPSIZE2_Msk
12079#define DSI_VNPCCR_NPSIZE3_Pos (3U)
12080#define DSI_VNPCCR_NPSIZE3_Msk (0x1UL << DSI_VNPCCR_NPSIZE3_Pos)
12081#define DSI_VNPCCR_NPSIZE3 DSI_VNPCCR_NPSIZE3_Msk
12082#define DSI_VNPCCR_NPSIZE4_Pos (4U)
12083#define DSI_VNPCCR_NPSIZE4_Msk (0x1UL << DSI_VNPCCR_NPSIZE4_Pos)
12084#define DSI_VNPCCR_NPSIZE4 DSI_VNPCCR_NPSIZE4_Msk
12085#define DSI_VNPCCR_NPSIZE5_Pos (5U)
12086#define DSI_VNPCCR_NPSIZE5_Msk (0x1UL << DSI_VNPCCR_NPSIZE5_Pos)
12087#define DSI_VNPCCR_NPSIZE5 DSI_VNPCCR_NPSIZE5_Msk
12088#define DSI_VNPCCR_NPSIZE6_Pos (6U)
12089#define DSI_VNPCCR_NPSIZE6_Msk (0x1UL << DSI_VNPCCR_NPSIZE6_Pos)
12090#define DSI_VNPCCR_NPSIZE6 DSI_VNPCCR_NPSIZE6_Msk
12091#define DSI_VNPCCR_NPSIZE7_Pos (7U)
12092#define DSI_VNPCCR_NPSIZE7_Msk (0x1UL << DSI_VNPCCR_NPSIZE7_Pos)
12093#define DSI_VNPCCR_NPSIZE7 DSI_VNPCCR_NPSIZE7_Msk
12094#define DSI_VNPCCR_NPSIZE8_Pos (8U)
12095#define DSI_VNPCCR_NPSIZE8_Msk (0x1UL << DSI_VNPCCR_NPSIZE8_Pos)
12096#define DSI_VNPCCR_NPSIZE8 DSI_VNPCCR_NPSIZE8_Msk
12097#define DSI_VNPCCR_NPSIZE9_Pos (9U)
12098#define DSI_VNPCCR_NPSIZE9_Msk (0x1UL << DSI_VNPCCR_NPSIZE9_Pos)
12099#define DSI_VNPCCR_NPSIZE9 DSI_VNPCCR_NPSIZE9_Msk
12100#define DSI_VNPCCR_NPSIZE10_Pos (10U)
12101#define DSI_VNPCCR_NPSIZE10_Msk (0x1UL << DSI_VNPCCR_NPSIZE10_Pos)
12102#define DSI_VNPCCR_NPSIZE10 DSI_VNPCCR_NPSIZE10_Msk
12103#define DSI_VNPCCR_NPSIZE11_Pos (11U)
12104#define DSI_VNPCCR_NPSIZE11_Msk (0x1UL << DSI_VNPCCR_NPSIZE11_Pos)
12105#define DSI_VNPCCR_NPSIZE11 DSI_VNPCCR_NPSIZE11_Msk
12106#define DSI_VNPCCR_NPSIZE12_Pos (12U)
12107#define DSI_VNPCCR_NPSIZE12_Msk (0x1UL << DSI_VNPCCR_NPSIZE12_Pos)
12108#define DSI_VNPCCR_NPSIZE12 DSI_VNPCCR_NPSIZE12_Msk
12109
12110/******************* Bit definition for DSI_VHSACCR register ************/
12111#define DSI_VHSACCR_HSA_Pos (0U)
12112#define DSI_VHSACCR_HSA_Msk (0xFFFUL << DSI_VHSACCR_HSA_Pos)
12113#define DSI_VHSACCR_HSA DSI_VHSACCR_HSA_Msk
12114#define DSI_VHSACCR_HSA0_Pos (0U)
12115#define DSI_VHSACCR_HSA0_Msk (0x1UL << DSI_VHSACCR_HSA0_Pos)
12116#define DSI_VHSACCR_HSA0 DSI_VHSACCR_HSA0_Msk
12117#define DSI_VHSACCR_HSA1_Pos (1U)
12118#define DSI_VHSACCR_HSA1_Msk (0x1UL << DSI_VHSACCR_HSA1_Pos)
12119#define DSI_VHSACCR_HSA1 DSI_VHSACCR_HSA1_Msk
12120#define DSI_VHSACCR_HSA2_Pos (2U)
12121#define DSI_VHSACCR_HSA2_Msk (0x1UL << DSI_VHSACCR_HSA2_Pos)
12122#define DSI_VHSACCR_HSA2 DSI_VHSACCR_HSA2_Msk
12123#define DSI_VHSACCR_HSA3_Pos (3U)
12124#define DSI_VHSACCR_HSA3_Msk (0x1UL << DSI_VHSACCR_HSA3_Pos)
12125#define DSI_VHSACCR_HSA3 DSI_VHSACCR_HSA3_Msk
12126#define DSI_VHSACCR_HSA4_Pos (4U)
12127#define DSI_VHSACCR_HSA4_Msk (0x1UL << DSI_VHSACCR_HSA4_Pos)
12128#define DSI_VHSACCR_HSA4 DSI_VHSACCR_HSA4_Msk
12129#define DSI_VHSACCR_HSA5_Pos (5U)
12130#define DSI_VHSACCR_HSA5_Msk (0x1UL << DSI_VHSACCR_HSA5_Pos)
12131#define DSI_VHSACCR_HSA5 DSI_VHSACCR_HSA5_Msk
12132#define DSI_VHSACCR_HSA6_Pos (6U)
12133#define DSI_VHSACCR_HSA6_Msk (0x1UL << DSI_VHSACCR_HSA6_Pos)
12134#define DSI_VHSACCR_HSA6 DSI_VHSACCR_HSA6_Msk
12135#define DSI_VHSACCR_HSA7_Pos (7U)
12136#define DSI_VHSACCR_HSA7_Msk (0x1UL << DSI_VHSACCR_HSA7_Pos)
12137#define DSI_VHSACCR_HSA7 DSI_VHSACCR_HSA7_Msk
12138#define DSI_VHSACCR_HSA8_Pos (8U)
12139#define DSI_VHSACCR_HSA8_Msk (0x1UL << DSI_VHSACCR_HSA8_Pos)
12140#define DSI_VHSACCR_HSA8 DSI_VHSACCR_HSA8_Msk
12141#define DSI_VHSACCR_HSA9_Pos (9U)
12142#define DSI_VHSACCR_HSA9_Msk (0x1UL << DSI_VHSACCR_HSA9_Pos)
12143#define DSI_VHSACCR_HSA9 DSI_VHSACCR_HSA9_Msk
12144#define DSI_VHSACCR_HSA10_Pos (10U)
12145#define DSI_VHSACCR_HSA10_Msk (0x1UL << DSI_VHSACCR_HSA10_Pos)
12146#define DSI_VHSACCR_HSA10 DSI_VHSACCR_HSA10_Msk
12147#define DSI_VHSACCR_HSA11_Pos (11U)
12148#define DSI_VHSACCR_HSA11_Msk (0x1UL << DSI_VHSACCR_HSA11_Pos)
12149#define DSI_VHSACCR_HSA11 DSI_VHSACCR_HSA11_Msk
12150
12151/******************* Bit definition for DSI_VHBPCCR register ************/
12152#define DSI_VHBPCCR_HBP_Pos (0U)
12153#define DSI_VHBPCCR_HBP_Msk (0xFFFUL << DSI_VHBPCCR_HBP_Pos)
12154#define DSI_VHBPCCR_HBP DSI_VHBPCCR_HBP_Msk
12155#define DSI_VHBPCCR_HBP0_Pos (0U)
12156#define DSI_VHBPCCR_HBP0_Msk (0x1UL << DSI_VHBPCCR_HBP0_Pos)
12157#define DSI_VHBPCCR_HBP0 DSI_VHBPCCR_HBP0_Msk
12158#define DSI_VHBPCCR_HBP1_Pos (1U)
12159#define DSI_VHBPCCR_HBP1_Msk (0x1UL << DSI_VHBPCCR_HBP1_Pos)
12160#define DSI_VHBPCCR_HBP1 DSI_VHBPCCR_HBP1_Msk
12161#define DSI_VHBPCCR_HBP2_Pos (2U)
12162#define DSI_VHBPCCR_HBP2_Msk (0x1UL << DSI_VHBPCCR_HBP2_Pos)
12163#define DSI_VHBPCCR_HBP2 DSI_VHBPCCR_HBP2_Msk
12164#define DSI_VHBPCCR_HBP3_Pos (3U)
12165#define DSI_VHBPCCR_HBP3_Msk (0x1UL << DSI_VHBPCCR_HBP3_Pos)
12166#define DSI_VHBPCCR_HBP3 DSI_VHBPCCR_HBP3_Msk
12167#define DSI_VHBPCCR_HBP4_Pos (4U)
12168#define DSI_VHBPCCR_HBP4_Msk (0x1UL << DSI_VHBPCCR_HBP4_Pos)
12169#define DSI_VHBPCCR_HBP4 DSI_VHBPCCR_HBP4_Msk
12170#define DSI_VHBPCCR_HBP5_Pos (5U)
12171#define DSI_VHBPCCR_HBP5_Msk (0x1UL << DSI_VHBPCCR_HBP5_Pos)
12172#define DSI_VHBPCCR_HBP5 DSI_VHBPCCR_HBP5_Msk
12173#define DSI_VHBPCCR_HBP6_Pos (6U)
12174#define DSI_VHBPCCR_HBP6_Msk (0x1UL << DSI_VHBPCCR_HBP6_Pos)
12175#define DSI_VHBPCCR_HBP6 DSI_VHBPCCR_HBP6_Msk
12176#define DSI_VHBPCCR_HBP7_Pos (7U)
12177#define DSI_VHBPCCR_HBP7_Msk (0x1UL << DSI_VHBPCCR_HBP7_Pos)
12178#define DSI_VHBPCCR_HBP7 DSI_VHBPCCR_HBP7_Msk
12179#define DSI_VHBPCCR_HBP8_Pos (8U)
12180#define DSI_VHBPCCR_HBP8_Msk (0x1UL << DSI_VHBPCCR_HBP8_Pos)
12181#define DSI_VHBPCCR_HBP8 DSI_VHBPCCR_HBP8_Msk
12182#define DSI_VHBPCCR_HBP9_Pos (9U)
12183#define DSI_VHBPCCR_HBP9_Msk (0x1UL << DSI_VHBPCCR_HBP9_Pos)
12184#define DSI_VHBPCCR_HBP9 DSI_VHBPCCR_HBP9_Msk
12185#define DSI_VHBPCCR_HBP10_Pos (10U)
12186#define DSI_VHBPCCR_HBP10_Msk (0x1UL << DSI_VHBPCCR_HBP10_Pos)
12187#define DSI_VHBPCCR_HBP10 DSI_VHBPCCR_HBP10_Msk
12188#define DSI_VHBPCCR_HBP11_Pos (11U)
12189#define DSI_VHBPCCR_HBP11_Msk (0x1UL << DSI_VHBPCCR_HBP11_Pos)
12190#define DSI_VHBPCCR_HBP11 DSI_VHBPCCR_HBP11_Msk
12191
12192/******************* Bit definition for DSI_VLCCR register **************/
12193#define DSI_VLCCR_HLINE_Pos (0U)
12194#define DSI_VLCCR_HLINE_Msk (0x7FFFUL << DSI_VLCCR_HLINE_Pos)
12195#define DSI_VLCCR_HLINE DSI_VLCCR_HLINE_Msk
12196#define DSI_VLCCR_HLINE0_Pos (0U)
12197#define DSI_VLCCR_HLINE0_Msk (0x1UL << DSI_VLCCR_HLINE0_Pos)
12198#define DSI_VLCCR_HLINE0 DSI_VLCCR_HLINE0_Msk
12199#define DSI_VLCCR_HLINE1_Pos (1U)
12200#define DSI_VLCCR_HLINE1_Msk (0x1UL << DSI_VLCCR_HLINE1_Pos)
12201#define DSI_VLCCR_HLINE1 DSI_VLCCR_HLINE1_Msk
12202#define DSI_VLCCR_HLINE2_Pos (2U)
12203#define DSI_VLCCR_HLINE2_Msk (0x1UL << DSI_VLCCR_HLINE2_Pos)
12204#define DSI_VLCCR_HLINE2 DSI_VLCCR_HLINE2_Msk
12205#define DSI_VLCCR_HLINE3_Pos (3U)
12206#define DSI_VLCCR_HLINE3_Msk (0x1UL << DSI_VLCCR_HLINE3_Pos)
12207#define DSI_VLCCR_HLINE3 DSI_VLCCR_HLINE3_Msk
12208#define DSI_VLCCR_HLINE4_Pos (4U)
12209#define DSI_VLCCR_HLINE4_Msk (0x1UL << DSI_VLCCR_HLINE4_Pos)
12210#define DSI_VLCCR_HLINE4 DSI_VLCCR_HLINE4_Msk
12211#define DSI_VLCCR_HLINE5_Pos (5U)
12212#define DSI_VLCCR_HLINE5_Msk (0x1UL << DSI_VLCCR_HLINE5_Pos)
12213#define DSI_VLCCR_HLINE5 DSI_VLCCR_HLINE5_Msk
12214#define DSI_VLCCR_HLINE6_Pos (6U)
12215#define DSI_VLCCR_HLINE6_Msk (0x1UL << DSI_VLCCR_HLINE6_Pos)
12216#define DSI_VLCCR_HLINE6 DSI_VLCCR_HLINE6_Msk
12217#define DSI_VLCCR_HLINE7_Pos (7U)
12218#define DSI_VLCCR_HLINE7_Msk (0x1UL << DSI_VLCCR_HLINE7_Pos)
12219#define DSI_VLCCR_HLINE7 DSI_VLCCR_HLINE7_Msk
12220#define DSI_VLCCR_HLINE8_Pos (8U)
12221#define DSI_VLCCR_HLINE8_Msk (0x1UL << DSI_VLCCR_HLINE8_Pos)
12222#define DSI_VLCCR_HLINE8 DSI_VLCCR_HLINE8_Msk
12223#define DSI_VLCCR_HLINE9_Pos (9U)
12224#define DSI_VLCCR_HLINE9_Msk (0x1UL << DSI_VLCCR_HLINE9_Pos)
12225#define DSI_VLCCR_HLINE9 DSI_VLCCR_HLINE9_Msk
12226#define DSI_VLCCR_HLINE10_Pos (10U)
12227#define DSI_VLCCR_HLINE10_Msk (0x1UL << DSI_VLCCR_HLINE10_Pos)
12228#define DSI_VLCCR_HLINE10 DSI_VLCCR_HLINE10_Msk
12229#define DSI_VLCCR_HLINE11_Pos (11U)
12230#define DSI_VLCCR_HLINE11_Msk (0x1UL << DSI_VLCCR_HLINE11_Pos)
12231#define DSI_VLCCR_HLINE11 DSI_VLCCR_HLINE11_Msk
12232#define DSI_VLCCR_HLINE12_Pos (12U)
12233#define DSI_VLCCR_HLINE12_Msk (0x1UL << DSI_VLCCR_HLINE12_Pos)
12234#define DSI_VLCCR_HLINE12 DSI_VLCCR_HLINE12_Msk
12235#define DSI_VLCCR_HLINE13_Pos (13U)
12236#define DSI_VLCCR_HLINE13_Msk (0x1UL << DSI_VLCCR_HLINE13_Pos)
12237#define DSI_VLCCR_HLINE13 DSI_VLCCR_HLINE13_Msk
12238#define DSI_VLCCR_HLINE14_Pos (14U)
12239#define DSI_VLCCR_HLINE14_Msk (0x1UL << DSI_VLCCR_HLINE14_Pos)
12240#define DSI_VLCCR_HLINE14 DSI_VLCCR_HLINE14_Msk
12241
12242/******************* Bit definition for DSI_VVSACCR register ***************/
12243#define DSI_VVSACCR_VSA_Pos (0U)
12244#define DSI_VVSACCR_VSA_Msk (0x3FFUL << DSI_VVSACCR_VSA_Pos)
12245#define DSI_VVSACCR_VSA DSI_VVSACCR_VSA_Msk
12246#define DSI_VVSACCR_VSA0_Pos (0U)
12247#define DSI_VVSACCR_VSA0_Msk (0x1UL << DSI_VVSACCR_VSA0_Pos)
12248#define DSI_VVSACCR_VSA0 DSI_VVSACCR_VSA0_Msk
12249#define DSI_VVSACCR_VSA1_Pos (1U)
12250#define DSI_VVSACCR_VSA1_Msk (0x1UL << DSI_VVSACCR_VSA1_Pos)
12251#define DSI_VVSACCR_VSA1 DSI_VVSACCR_VSA1_Msk
12252#define DSI_VVSACCR_VSA2_Pos (2U)
12253#define DSI_VVSACCR_VSA2_Msk (0x1UL << DSI_VVSACCR_VSA2_Pos)
12254#define DSI_VVSACCR_VSA2 DSI_VVSACCR_VSA2_Msk
12255#define DSI_VVSACCR_VSA3_Pos (3U)
12256#define DSI_VVSACCR_VSA3_Msk (0x1UL << DSI_VVSACCR_VSA3_Pos)
12257#define DSI_VVSACCR_VSA3 DSI_VVSACCR_VSA3_Msk
12258#define DSI_VVSACCR_VSA4_Pos (4U)
12259#define DSI_VVSACCR_VSA4_Msk (0x1UL << DSI_VVSACCR_VSA4_Pos)
12260#define DSI_VVSACCR_VSA4 DSI_VVSACCR_VSA4_Msk
12261#define DSI_VVSACCR_VSA5_Pos (5U)
12262#define DSI_VVSACCR_VSA5_Msk (0x1UL << DSI_VVSACCR_VSA5_Pos)
12263#define DSI_VVSACCR_VSA5 DSI_VVSACCR_VSA5_Msk
12264#define DSI_VVSACCR_VSA6_Pos (6U)
12265#define DSI_VVSACCR_VSA6_Msk (0x1UL << DSI_VVSACCR_VSA6_Pos)
12266#define DSI_VVSACCR_VSA6 DSI_VVSACCR_VSA6_Msk
12267#define DSI_VVSACCR_VSA7_Pos (7U)
12268#define DSI_VVSACCR_VSA7_Msk (0x1UL << DSI_VVSACCR_VSA7_Pos)
12269#define DSI_VVSACCR_VSA7 DSI_VVSACCR_VSA7_Msk
12270#define DSI_VVSACCR_VSA8_Pos (8U)
12271#define DSI_VVSACCR_VSA8_Msk (0x1UL << DSI_VVSACCR_VSA8_Pos)
12272#define DSI_VVSACCR_VSA8 DSI_VVSACCR_VSA8_Msk
12273#define DSI_VVSACCR_VSA9_Pos (9U)
12274#define DSI_VVSACCR_VSA9_Msk (0x1UL << DSI_VVSACCR_VSA9_Pos)
12275#define DSI_VVSACCR_VSA9 DSI_VVSACCR_VSA9_Msk
12276
12277/******************* Bit definition for DSI_VVBPCCR register ************/
12278#define DSI_VVBPCCR_VBP_Pos (0U)
12279#define DSI_VVBPCCR_VBP_Msk (0x3FFUL << DSI_VVBPCCR_VBP_Pos)
12280#define DSI_VVBPCCR_VBP DSI_VVBPCCR_VBP_Msk
12281#define DSI_VVBPCCR_VBP0_Pos (0U)
12282#define DSI_VVBPCCR_VBP0_Msk (0x1UL << DSI_VVBPCCR_VBP0_Pos)
12283#define DSI_VVBPCCR_VBP0 DSI_VVBPCCR_VBP0_Msk
12284#define DSI_VVBPCCR_VBP1_Pos (1U)
12285#define DSI_VVBPCCR_VBP1_Msk (0x1UL << DSI_VVBPCCR_VBP1_Pos)
12286#define DSI_VVBPCCR_VBP1 DSI_VVBPCCR_VBP1_Msk
12287#define DSI_VVBPCCR_VBP2_Pos (2U)
12288#define DSI_VVBPCCR_VBP2_Msk (0x1UL << DSI_VVBPCCR_VBP2_Pos)
12289#define DSI_VVBPCCR_VBP2 DSI_VVBPCCR_VBP2_Msk
12290#define DSI_VVBPCCR_VBP3_Pos (3U)
12291#define DSI_VVBPCCR_VBP3_Msk (0x1UL << DSI_VVBPCCR_VBP3_Pos)
12292#define DSI_VVBPCCR_VBP3 DSI_VVBPCCR_VBP3_Msk
12293#define DSI_VVBPCCR_VBP4_Pos (4U)
12294#define DSI_VVBPCCR_VBP4_Msk (0x1UL << DSI_VVBPCCR_VBP4_Pos)
12295#define DSI_VVBPCCR_VBP4 DSI_VVBPCCR_VBP4_Msk
12296#define DSI_VVBPCCR_VBP5_Pos (5U)
12297#define DSI_VVBPCCR_VBP5_Msk (0x1UL << DSI_VVBPCCR_VBP5_Pos)
12298#define DSI_VVBPCCR_VBP5 DSI_VVBPCCR_VBP5_Msk
12299#define DSI_VVBPCCR_VBP6_Pos (6U)
12300#define DSI_VVBPCCR_VBP6_Msk (0x1UL << DSI_VVBPCCR_VBP6_Pos)
12301#define DSI_VVBPCCR_VBP6 DSI_VVBPCCR_VBP6_Msk
12302#define DSI_VVBPCCR_VBP7_Pos (7U)
12303#define DSI_VVBPCCR_VBP7_Msk (0x1UL << DSI_VVBPCCR_VBP7_Pos)
12304#define DSI_VVBPCCR_VBP7 DSI_VVBPCCR_VBP7_Msk
12305#define DSI_VVBPCCR_VBP8_Pos (8U)
12306#define DSI_VVBPCCR_VBP8_Msk (0x1UL << DSI_VVBPCCR_VBP8_Pos)
12307#define DSI_VVBPCCR_VBP8 DSI_VVBPCCR_VBP8_Msk
12308#define DSI_VVBPCCR_VBP9_Pos (9U)
12309#define DSI_VVBPCCR_VBP9_Msk (0x1UL << DSI_VVBPCCR_VBP9_Pos)
12310#define DSI_VVBPCCR_VBP9 DSI_VVBPCCR_VBP9_Msk
12311
12312/******************* Bit definition for DSI_VVFPCCR register ************/
12313#define DSI_VVFPCCR_VFP_Pos (0U)
12314#define DSI_VVFPCCR_VFP_Msk (0x3FFUL << DSI_VVFPCCR_VFP_Pos)
12315#define DSI_VVFPCCR_VFP DSI_VVFPCCR_VFP_Msk
12316#define DSI_VVFPCCR_VFP0_Pos (0U)
12317#define DSI_VVFPCCR_VFP0_Msk (0x1UL << DSI_VVFPCCR_VFP0_Pos)
12318#define DSI_VVFPCCR_VFP0 DSI_VVFPCCR_VFP0_Msk
12319#define DSI_VVFPCCR_VFP1_Pos (1U)
12320#define DSI_VVFPCCR_VFP1_Msk (0x1UL << DSI_VVFPCCR_VFP1_Pos)
12321#define DSI_VVFPCCR_VFP1 DSI_VVFPCCR_VFP1_Msk
12322#define DSI_VVFPCCR_VFP2_Pos (2U)
12323#define DSI_VVFPCCR_VFP2_Msk (0x1UL << DSI_VVFPCCR_VFP2_Pos)
12324#define DSI_VVFPCCR_VFP2 DSI_VVFPCCR_VFP2_Msk
12325#define DSI_VVFPCCR_VFP3_Pos (3U)
12326#define DSI_VVFPCCR_VFP3_Msk (0x1UL << DSI_VVFPCCR_VFP3_Pos)
12327#define DSI_VVFPCCR_VFP3 DSI_VVFPCCR_VFP3_Msk
12328#define DSI_VVFPCCR_VFP4_Pos (4U)
12329#define DSI_VVFPCCR_VFP4_Msk (0x1UL << DSI_VVFPCCR_VFP4_Pos)
12330#define DSI_VVFPCCR_VFP4 DSI_VVFPCCR_VFP4_Msk
12331#define DSI_VVFPCCR_VFP5_Pos (5U)
12332#define DSI_VVFPCCR_VFP5_Msk (0x1UL << DSI_VVFPCCR_VFP5_Pos)
12333#define DSI_VVFPCCR_VFP5 DSI_VVFPCCR_VFP5_Msk
12334#define DSI_VVFPCCR_VFP6_Pos (6U)
12335#define DSI_VVFPCCR_VFP6_Msk (0x1UL << DSI_VVFPCCR_VFP6_Pos)
12336#define DSI_VVFPCCR_VFP6 DSI_VVFPCCR_VFP6_Msk
12337#define DSI_VVFPCCR_VFP7_Pos (7U)
12338#define DSI_VVFPCCR_VFP7_Msk (0x1UL << DSI_VVFPCCR_VFP7_Pos)
12339#define DSI_VVFPCCR_VFP7 DSI_VVFPCCR_VFP7_Msk
12340#define DSI_VVFPCCR_VFP8_Pos (8U)
12341#define DSI_VVFPCCR_VFP8_Msk (0x1UL << DSI_VVFPCCR_VFP8_Pos)
12342#define DSI_VVFPCCR_VFP8 DSI_VVFPCCR_VFP8_Msk
12343#define DSI_VVFPCCR_VFP9_Pos (9U)
12344#define DSI_VVFPCCR_VFP9_Msk (0x1UL << DSI_VVFPCCR_VFP9_Pos)
12345#define DSI_VVFPCCR_VFP9 DSI_VVFPCCR_VFP9_Msk
12346
12347/******************* Bit definition for DSI_VVACCR register *************/
12348#define DSI_VVACCR_VA_Pos (0U)
12349#define DSI_VVACCR_VA_Msk (0x3FFFUL << DSI_VVACCR_VA_Pos)
12350#define DSI_VVACCR_VA DSI_VVACCR_VA_Msk
12351#define DSI_VVACCR_VA0_Pos (0U)
12352#define DSI_VVACCR_VA0_Msk (0x1UL << DSI_VVACCR_VA0_Pos)
12353#define DSI_VVACCR_VA0 DSI_VVACCR_VA0_Msk
12354#define DSI_VVACCR_VA1_Pos (1U)
12355#define DSI_VVACCR_VA1_Msk (0x1UL << DSI_VVACCR_VA1_Pos)
12356#define DSI_VVACCR_VA1 DSI_VVACCR_VA1_Msk
12357#define DSI_VVACCR_VA2_Pos (2U)
12358#define DSI_VVACCR_VA2_Msk (0x1UL << DSI_VVACCR_VA2_Pos)
12359#define DSI_VVACCR_VA2 DSI_VVACCR_VA2_Msk
12360#define DSI_VVACCR_VA3_Pos (3U)
12361#define DSI_VVACCR_VA3_Msk (0x1UL << DSI_VVACCR_VA3_Pos)
12362#define DSI_VVACCR_VA3 DSI_VVACCR_VA3_Msk
12363#define DSI_VVACCR_VA4_Pos (4U)
12364#define DSI_VVACCR_VA4_Msk (0x1UL << DSI_VVACCR_VA4_Pos)
12365#define DSI_VVACCR_VA4 DSI_VVACCR_VA4_Msk
12366#define DSI_VVACCR_VA5_Pos (5U)
12367#define DSI_VVACCR_VA5_Msk (0x1UL << DSI_VVACCR_VA5_Pos)
12368#define DSI_VVACCR_VA5 DSI_VVACCR_VA5_Msk
12369#define DSI_VVACCR_VA6_Pos (6U)
12370#define DSI_VVACCR_VA6_Msk (0x1UL << DSI_VVACCR_VA6_Pos)
12371#define DSI_VVACCR_VA6 DSI_VVACCR_VA6_Msk
12372#define DSI_VVACCR_VA7_Pos (7U)
12373#define DSI_VVACCR_VA7_Msk (0x1UL << DSI_VVACCR_VA7_Pos)
12374#define DSI_VVACCR_VA7 DSI_VVACCR_VA7_Msk
12375#define DSI_VVACCR_VA8_Pos (8U)
12376#define DSI_VVACCR_VA8_Msk (0x1UL << DSI_VVACCR_VA8_Pos)
12377#define DSI_VVACCR_VA8 DSI_VVACCR_VA8_Msk
12378#define DSI_VVACCR_VA9_Pos (9U)
12379#define DSI_VVACCR_VA9_Msk (0x1UL << DSI_VVACCR_VA9_Pos)
12380#define DSI_VVACCR_VA9 DSI_VVACCR_VA9_Msk
12381#define DSI_VVACCR_VA10_Pos (10U)
12382#define DSI_VVACCR_VA10_Msk (0x1UL << DSI_VVACCR_VA10_Pos)
12383#define DSI_VVACCR_VA10 DSI_VVACCR_VA10_Msk
12384#define DSI_VVACCR_VA11_Pos (11U)
12385#define DSI_VVACCR_VA11_Msk (0x1UL << DSI_VVACCR_VA11_Pos)
12386#define DSI_VVACCR_VA11 DSI_VVACCR_VA11_Msk
12387#define DSI_VVACCR_VA12_Pos (12U)
12388#define DSI_VVACCR_VA12_Msk (0x1UL << DSI_VVACCR_VA12_Pos)
12389#define DSI_VVACCR_VA12 DSI_VVACCR_VA12_Msk
12390#define DSI_VVACCR_VA13_Pos (13U)
12391#define DSI_VVACCR_VA13_Msk (0x1UL << DSI_VVACCR_VA13_Pos)
12392#define DSI_VVACCR_VA13 DSI_VVACCR_VA13_Msk
12393
12394/******************* Bit definition for DSI_TDCCR register **************/
12395#define DSI_TDCCR_3DM (0x00000003U)
12396#define DSI_TDCCR_3DM0 (0x00000001U)
12397#define DSI_TDCCR_3DM1 (0x00000002U)
12398
12399#define DSI_TDCCR_3DF (0x0000000CU)
12400#define DSI_TDCCR_3DF0 (0x00000004U)
12401#define DSI_TDCCR_3DF1 (0x00000008U)
12402
12403#define DSI_TDCCR_SVS_Pos (4U)
12404#define DSI_TDCCR_SVS_Msk (0x1UL << DSI_TDCCR_SVS_Pos)
12405#define DSI_TDCCR_SVS DSI_TDCCR_SVS_Msk
12406#define DSI_TDCCR_RF_Pos (5U)
12407#define DSI_TDCCR_RF_Msk (0x1UL << DSI_TDCCR_RF_Pos)
12408#define DSI_TDCCR_RF DSI_TDCCR_RF_Msk
12409#define DSI_TDCCR_S3DC_Pos (16U)
12410#define DSI_TDCCR_S3DC_Msk (0x1UL << DSI_TDCCR_S3DC_Pos)
12411#define DSI_TDCCR_S3DC DSI_TDCCR_S3DC_Msk
12413/******************* Bit definition for DSI_WCFGR register ***************/
12414#define DSI_WCFGR_DSIM_Pos (0U)
12415#define DSI_WCFGR_DSIM_Msk (0x1UL << DSI_WCFGR_DSIM_Pos)
12416#define DSI_WCFGR_DSIM DSI_WCFGR_DSIM_Msk
12417#define DSI_WCFGR_COLMUX_Pos (1U)
12418#define DSI_WCFGR_COLMUX_Msk (0x7UL << DSI_WCFGR_COLMUX_Pos)
12419#define DSI_WCFGR_COLMUX DSI_WCFGR_COLMUX_Msk
12420#define DSI_WCFGR_COLMUX0_Pos (1U)
12421#define DSI_WCFGR_COLMUX0_Msk (0x1UL << DSI_WCFGR_COLMUX0_Pos)
12422#define DSI_WCFGR_COLMUX0 DSI_WCFGR_COLMUX0_Msk
12423#define DSI_WCFGR_COLMUX1_Pos (2U)
12424#define DSI_WCFGR_COLMUX1_Msk (0x1UL << DSI_WCFGR_COLMUX1_Pos)
12425#define DSI_WCFGR_COLMUX1 DSI_WCFGR_COLMUX1_Msk
12426#define DSI_WCFGR_COLMUX2_Pos (3U)
12427#define DSI_WCFGR_COLMUX2_Msk (0x1UL << DSI_WCFGR_COLMUX2_Pos)
12428#define DSI_WCFGR_COLMUX2 DSI_WCFGR_COLMUX2_Msk
12429
12430#define DSI_WCFGR_TESRC_Pos (4U)
12431#define DSI_WCFGR_TESRC_Msk (0x1UL << DSI_WCFGR_TESRC_Pos)
12432#define DSI_WCFGR_TESRC DSI_WCFGR_TESRC_Msk
12433#define DSI_WCFGR_TEPOL_Pos (5U)
12434#define DSI_WCFGR_TEPOL_Msk (0x1UL << DSI_WCFGR_TEPOL_Pos)
12435#define DSI_WCFGR_TEPOL DSI_WCFGR_TEPOL_Msk
12436#define DSI_WCFGR_AR_Pos (6U)
12437#define DSI_WCFGR_AR_Msk (0x1UL << DSI_WCFGR_AR_Pos)
12438#define DSI_WCFGR_AR DSI_WCFGR_AR_Msk
12439#define DSI_WCFGR_VSPOL_Pos (7U)
12440#define DSI_WCFGR_VSPOL_Msk (0x1UL << DSI_WCFGR_VSPOL_Pos)
12441#define DSI_WCFGR_VSPOL DSI_WCFGR_VSPOL_Msk
12443/******************* Bit definition for DSI_WCR register *****************/
12444#define DSI_WCR_COLM_Pos (0U)
12445#define DSI_WCR_COLM_Msk (0x1UL << DSI_WCR_COLM_Pos)
12446#define DSI_WCR_COLM DSI_WCR_COLM_Msk
12447#define DSI_WCR_SHTDN_Pos (1U)
12448#define DSI_WCR_SHTDN_Msk (0x1UL << DSI_WCR_SHTDN_Pos)
12449#define DSI_WCR_SHTDN DSI_WCR_SHTDN_Msk
12450#define DSI_WCR_LTDCEN_Pos (2U)
12451#define DSI_WCR_LTDCEN_Msk (0x1UL << DSI_WCR_LTDCEN_Pos)
12452#define DSI_WCR_LTDCEN DSI_WCR_LTDCEN_Msk
12453#define DSI_WCR_DSIEN_Pos (3U)
12454#define DSI_WCR_DSIEN_Msk (0x1UL << DSI_WCR_DSIEN_Pos)
12455#define DSI_WCR_DSIEN DSI_WCR_DSIEN_Msk
12457/******************* Bit definition for DSI_WIER register ****************/
12458#define DSI_WIER_TEIE_Pos (0U)
12459#define DSI_WIER_TEIE_Msk (0x1UL << DSI_WIER_TEIE_Pos)
12460#define DSI_WIER_TEIE DSI_WIER_TEIE_Msk
12461#define DSI_WIER_ERIE_Pos (1U)
12462#define DSI_WIER_ERIE_Msk (0x1UL << DSI_WIER_ERIE_Pos)
12463#define DSI_WIER_ERIE DSI_WIER_ERIE_Msk
12464#define DSI_WIER_PLLLIE_Pos (9U)
12465#define DSI_WIER_PLLLIE_Msk (0x1UL << DSI_WIER_PLLLIE_Pos)
12466#define DSI_WIER_PLLLIE DSI_WIER_PLLLIE_Msk
12467#define DSI_WIER_PLLUIE_Pos (10U)
12468#define DSI_WIER_PLLUIE_Msk (0x1UL << DSI_WIER_PLLUIE_Pos)
12469#define DSI_WIER_PLLUIE DSI_WIER_PLLUIE_Msk
12470#define DSI_WIER_RRIE_Pos (13U)
12471#define DSI_WIER_RRIE_Msk (0x1UL << DSI_WIER_RRIE_Pos)
12472#define DSI_WIER_RRIE DSI_WIER_RRIE_Msk
12474/******************* Bit definition for DSI_WISR register ****************/
12475#define DSI_WISR_TEIF_Pos (0U)
12476#define DSI_WISR_TEIF_Msk (0x1UL << DSI_WISR_TEIF_Pos)
12477#define DSI_WISR_TEIF DSI_WISR_TEIF_Msk
12478#define DSI_WISR_ERIF_Pos (1U)
12479#define DSI_WISR_ERIF_Msk (0x1UL << DSI_WISR_ERIF_Pos)
12480#define DSI_WISR_ERIF DSI_WISR_ERIF_Msk
12481#define DSI_WISR_BUSY_Pos (2U)
12482#define DSI_WISR_BUSY_Msk (0x1UL << DSI_WISR_BUSY_Pos)
12483#define DSI_WISR_BUSY DSI_WISR_BUSY_Msk
12484#define DSI_WISR_PLLLS_Pos (8U)
12485#define DSI_WISR_PLLLS_Msk (0x1UL << DSI_WISR_PLLLS_Pos)
12486#define DSI_WISR_PLLLS DSI_WISR_PLLLS_Msk
12487#define DSI_WISR_PLLLIF_Pos (9U)
12488#define DSI_WISR_PLLLIF_Msk (0x1UL << DSI_WISR_PLLLIF_Pos)
12489#define DSI_WISR_PLLLIF DSI_WISR_PLLLIF_Msk
12490#define DSI_WISR_PLLUIF_Pos (10U)
12491#define DSI_WISR_PLLUIF_Msk (0x1UL << DSI_WISR_PLLUIF_Pos)
12492#define DSI_WISR_PLLUIF DSI_WISR_PLLUIF_Msk
12493#define DSI_WISR_RRS_Pos (12U)
12494#define DSI_WISR_RRS_Msk (0x1UL << DSI_WISR_RRS_Pos)
12495#define DSI_WISR_RRS DSI_WISR_RRS_Msk
12496#define DSI_WISR_RRIF_Pos (13U)
12497#define DSI_WISR_RRIF_Msk (0x1UL << DSI_WISR_RRIF_Pos)
12498#define DSI_WISR_RRIF DSI_WISR_RRIF_Msk
12500/******************* Bit definition for DSI_WIFCR register ***************/
12501#define DSI_WIFCR_CTEIF_Pos (0U)
12502#define DSI_WIFCR_CTEIF_Msk (0x1UL << DSI_WIFCR_CTEIF_Pos)
12503#define DSI_WIFCR_CTEIF DSI_WIFCR_CTEIF_Msk
12504#define DSI_WIFCR_CERIF_Pos (1U)
12505#define DSI_WIFCR_CERIF_Msk (0x1UL << DSI_WIFCR_CERIF_Pos)
12506#define DSI_WIFCR_CERIF DSI_WIFCR_CERIF_Msk
12507#define DSI_WIFCR_CPLLLIF_Pos (9U)
12508#define DSI_WIFCR_CPLLLIF_Msk (0x1UL << DSI_WIFCR_CPLLLIF_Pos)
12509#define DSI_WIFCR_CPLLLIF DSI_WIFCR_CPLLLIF_Msk
12510#define DSI_WIFCR_CPLLUIF_Pos (10U)
12511#define DSI_WIFCR_CPLLUIF_Msk (0x1UL << DSI_WIFCR_CPLLUIF_Pos)
12512#define DSI_WIFCR_CPLLUIF DSI_WIFCR_CPLLUIF_Msk
12513#define DSI_WIFCR_CRRIF_Pos (13U)
12514#define DSI_WIFCR_CRRIF_Msk (0x1UL << DSI_WIFCR_CRRIF_Pos)
12515#define DSI_WIFCR_CRRIF DSI_WIFCR_CRRIF_Msk
12517/******************* Bit definition for DSI_WPCR0 register ***************/
12518#define DSI_WPCR0_UIX4_Pos (0U)
12519#define DSI_WPCR0_UIX4_Msk (0x3FUL << DSI_WPCR0_UIX4_Pos)
12520#define DSI_WPCR0_UIX4 DSI_WPCR0_UIX4_Msk
12521#define DSI_WPCR0_UIX4_0 (0x01UL << DSI_WPCR0_UIX4_Pos)
12522#define DSI_WPCR0_UIX4_1 (0x02UL << DSI_WPCR0_UIX4_Pos)
12523#define DSI_WPCR0_UIX4_2 (0x04UL << DSI_WPCR0_UIX4_Pos)
12524#define DSI_WPCR0_UIX4_3 (0x08UL << DSI_WPCR0_UIX4_Pos)
12525#define DSI_WPCR0_UIX4_4 (0x10UL << DSI_WPCR0_UIX4_Pos)
12526#define DSI_WPCR0_UIX4_5 (0x20UL << DSI_WPCR0_UIX4_Pos)
12528#define DSI_WPCR0_SWCL_Pos (6U)
12529#define DSI_WPCR0_SWCL_Msk (0x1UL << DSI_WPCR0_SWCL_Pos)
12530#define DSI_WPCR0_SWCL DSI_WPCR0_SWCL_Msk
12531#define DSI_WPCR0_SWDL0_Pos (7U)
12532#define DSI_WPCR0_SWDL0_Msk (0x1UL << DSI_WPCR0_SWDL0_Pos)
12533#define DSI_WPCR0_SWDL0 DSI_WPCR0_SWDL0_Msk
12534#define DSI_WPCR0_SWDL1_Pos (8U)
12535#define DSI_WPCR0_SWDL1_Msk (0x1UL << DSI_WPCR0_SWDL1_Pos)
12536#define DSI_WPCR0_SWDL1 DSI_WPCR0_SWDL1_Msk
12537#define DSI_WPCR0_HSICL_Pos (9U)
12538#define DSI_WPCR0_HSICL_Msk (0x1UL << DSI_WPCR0_HSICL_Pos)
12539#define DSI_WPCR0_HSICL DSI_WPCR0_HSICL_Msk
12540#define DSI_WPCR0_HSIDL0_Pos (10U)
12541#define DSI_WPCR0_HSIDL0_Msk (0x1UL << DSI_WPCR0_HSIDL0_Pos)
12542#define DSI_WPCR0_HSIDL0 DSI_WPCR0_HSIDL0_Msk
12543#define DSI_WPCR0_HSIDL1_Pos (11U)
12544#define DSI_WPCR0_HSIDL1_Msk (0x1UL << DSI_WPCR0_HSIDL1_Pos)
12545#define DSI_WPCR0_HSIDL1 DSI_WPCR0_HSIDL1_Msk
12546#define DSI_WPCR0_FTXSMCL_Pos (12U)
12547#define DSI_WPCR0_FTXSMCL_Msk (0x1UL << DSI_WPCR0_FTXSMCL_Pos)
12548#define DSI_WPCR0_FTXSMCL DSI_WPCR0_FTXSMCL_Msk
12549#define DSI_WPCR0_FTXSMDL_Pos (13U)
12550#define DSI_WPCR0_FTXSMDL_Msk (0x1UL << DSI_WPCR0_FTXSMDL_Pos)
12551#define DSI_WPCR0_FTXSMDL DSI_WPCR0_FTXSMDL_Msk
12552#define DSI_WPCR0_CDOFFDL_Pos (14U)
12553#define DSI_WPCR0_CDOFFDL_Msk (0x1UL << DSI_WPCR0_CDOFFDL_Pos)
12554#define DSI_WPCR0_CDOFFDL DSI_WPCR0_CDOFFDL_Msk
12555#define DSI_WPCR0_TDDL_Pos (16U)
12556#define DSI_WPCR0_TDDL_Msk (0x1UL << DSI_WPCR0_TDDL_Pos)
12557#define DSI_WPCR0_TDDL DSI_WPCR0_TDDL_Msk
12558#define DSI_WPCR0_PDEN_Pos (18U)
12559#define DSI_WPCR0_PDEN_Msk (0x1UL << DSI_WPCR0_PDEN_Pos)
12560#define DSI_WPCR0_PDEN DSI_WPCR0_PDEN_Msk
12561#define DSI_WPCR0_TCLKPREPEN_Pos (19U)
12562#define DSI_WPCR0_TCLKPREPEN_Msk (0x1UL << DSI_WPCR0_TCLKPREPEN_Pos)
12563#define DSI_WPCR0_TCLKPREPEN DSI_WPCR0_TCLKPREPEN_Msk
12564#define DSI_WPCR0_TCLKZEROEN_Pos (20U)
12565#define DSI_WPCR0_TCLKZEROEN_Msk (0x1UL << DSI_WPCR0_TCLKZEROEN_Pos)
12566#define DSI_WPCR0_TCLKZEROEN DSI_WPCR0_TCLKZEROEN_Msk
12567#define DSI_WPCR0_THSPREPEN_Pos (21U)
12568#define DSI_WPCR0_THSPREPEN_Msk (0x1UL << DSI_WPCR0_THSPREPEN_Pos)
12569#define DSI_WPCR0_THSPREPEN DSI_WPCR0_THSPREPEN_Msk
12570#define DSI_WPCR0_THSTRAILEN_Pos (22U)
12571#define DSI_WPCR0_THSTRAILEN_Msk (0x1UL << DSI_WPCR0_THSTRAILEN_Pos)
12572#define DSI_WPCR0_THSTRAILEN DSI_WPCR0_THSTRAILEN_Msk
12573#define DSI_WPCR0_THSZEROEN_Pos (23U)
12574#define DSI_WPCR0_THSZEROEN_Msk (0x1UL << DSI_WPCR0_THSZEROEN_Pos)
12575#define DSI_WPCR0_THSZEROEN DSI_WPCR0_THSZEROEN_Msk
12576#define DSI_WPCR0_TLPXDEN_Pos (24U)
12577#define DSI_WPCR0_TLPXDEN_Msk (0x1UL << DSI_WPCR0_TLPXDEN_Pos)
12578#define DSI_WPCR0_TLPXDEN DSI_WPCR0_TLPXDEN_Msk
12579#define DSI_WPCR0_THSEXITEN_Pos (25U)
12580#define DSI_WPCR0_THSEXITEN_Msk (0x1UL << DSI_WPCR0_THSEXITEN_Pos)
12581#define DSI_WPCR0_THSEXITEN DSI_WPCR0_THSEXITEN_Msk
12582#define DSI_WPCR0_TLPXCEN_Pos (26U)
12583#define DSI_WPCR0_TLPXCEN_Msk (0x1UL << DSI_WPCR0_TLPXCEN_Pos)
12584#define DSI_WPCR0_TLPXCEN DSI_WPCR0_TLPXCEN_Msk
12585#define DSI_WPCR0_TCLKPOSTEN_Pos (27U)
12586#define DSI_WPCR0_TCLKPOSTEN_Msk (0x1UL << DSI_WPCR0_TCLKPOSTEN_Pos)
12587#define DSI_WPCR0_TCLKPOSTEN DSI_WPCR0_TCLKPOSTEN_Msk
12589/******************* Bit definition for DSI_WPCR1 register ***************/
12590#define DSI_WPCR1_HSTXDCL_Pos (0U)
12591#define DSI_WPCR1_HSTXDCL_Msk (0x3UL << DSI_WPCR1_HSTXDCL_Pos)
12592#define DSI_WPCR1_HSTXDCL DSI_WPCR1_HSTXDCL_Msk
12593#define DSI_WPCR1_HSTXDCL0_Pos (0U)
12594#define DSI_WPCR1_HSTXDCL0_Msk (0x1UL << DSI_WPCR1_HSTXDCL0_Pos)
12595#define DSI_WPCR1_HSTXDCL0 DSI_WPCR1_HSTXDCL0_Msk
12596#define DSI_WPCR1_HSTXDCL1_Pos (1U)
12597#define DSI_WPCR1_HSTXDCL1_Msk (0x1UL << DSI_WPCR1_HSTXDCL1_Pos)
12598#define DSI_WPCR1_HSTXDCL1 DSI_WPCR1_HSTXDCL1_Msk
12599
12600#define DSI_WPCR1_HSTXDDL_Pos (2U)
12601#define DSI_WPCR1_HSTXDDL_Msk (0x3UL << DSI_WPCR1_HSTXDDL_Pos)
12602#define DSI_WPCR1_HSTXDDL DSI_WPCR1_HSTXDDL_Msk
12603#define DSI_WPCR1_HSTXDDL0_Pos (2U)
12604#define DSI_WPCR1_HSTXDDL0_Msk (0x1UL << DSI_WPCR1_HSTXDDL0_Pos)
12605#define DSI_WPCR1_HSTXDDL0 DSI_WPCR1_HSTXDDL0_Msk
12606#define DSI_WPCR1_HSTXDDL1_Pos (3U)
12607#define DSI_WPCR1_HSTXDDL1_Msk (0x1UL << DSI_WPCR1_HSTXDDL1_Pos)
12608#define DSI_WPCR1_HSTXDDL1 DSI_WPCR1_HSTXDDL1_Msk
12609
12610#define DSI_WPCR1_LPSRCCL_Pos (6U)
12611#define DSI_WPCR1_LPSRCCL_Msk (0x3UL << DSI_WPCR1_LPSRCCL_Pos)
12612#define DSI_WPCR1_LPSRCCL DSI_WPCR1_LPSRCCL_Msk
12613#define DSI_WPCR1_LPSRCCL0_Pos (6U)
12614#define DSI_WPCR1_LPSRCCL0_Msk (0x1UL << DSI_WPCR1_LPSRCCL0_Pos)
12615#define DSI_WPCR1_LPSRCCL0 DSI_WPCR1_LPSRCCL0_Msk
12616#define DSI_WPCR1_LPSRCCL1_Pos (7U)
12617#define DSI_WPCR1_LPSRCCL1_Msk (0x1UL << DSI_WPCR1_LPSRCCL1_Pos)
12618#define DSI_WPCR1_LPSRCCL1 DSI_WPCR1_LPSRCCL1_Msk
12619
12620#define DSI_WPCR1_LPSRCDL_Pos (8U)
12621#define DSI_WPCR1_LPSRCDL_Msk (0x3UL << DSI_WPCR1_LPSRCDL_Pos)
12622#define DSI_WPCR1_LPSRCDL DSI_WPCR1_LPSRCDL_Msk
12623#define DSI_WPCR1_LPSRCDL0_Pos (8U)
12624#define DSI_WPCR1_LPSRCDL0_Msk (0x1UL << DSI_WPCR1_LPSRCDL0_Pos)
12625#define DSI_WPCR1_LPSRCDL0 DSI_WPCR1_LPSRCDL0_Msk
12626#define DSI_WPCR1_LPSRCDL1_Pos (9U)
12627#define DSI_WPCR1_LPSRCDL1_Msk (0x1UL << DSI_WPCR1_LPSRCDL1_Pos)
12628#define DSI_WPCR1_LPSRCDL1 DSI_WPCR1_LPSRCDL1_Msk
12629
12630#define DSI_WPCR1_SDDC_Pos (12U)
12631#define DSI_WPCR1_SDDC_Msk (0x1UL << DSI_WPCR1_SDDC_Pos)
12632#define DSI_WPCR1_SDDC DSI_WPCR1_SDDC_Msk
12634#define DSI_WPCR1_LPRXVCDL_Pos (14U)
12635#define DSI_WPCR1_LPRXVCDL_Msk (0x3UL << DSI_WPCR1_LPRXVCDL_Pos)
12636#define DSI_WPCR1_LPRXVCDL DSI_WPCR1_LPRXVCDL_Msk
12637#define DSI_WPCR1_LPRXVCDL0_Pos (14U)
12638#define DSI_WPCR1_LPRXVCDL0_Msk (0x1UL << DSI_WPCR1_LPRXVCDL0_Pos)
12639#define DSI_WPCR1_LPRXVCDL0 DSI_WPCR1_LPRXVCDL0_Msk
12640#define DSI_WPCR1_LPRXVCDL1_Pos (15U)
12641#define DSI_WPCR1_LPRXVCDL1_Msk (0x1UL << DSI_WPCR1_LPRXVCDL1_Pos)
12642#define DSI_WPCR1_LPRXVCDL1 DSI_WPCR1_LPRXVCDL1_Msk
12643
12644#define DSI_WPCR1_HSTXSRCCL_Pos (16U)
12645#define DSI_WPCR1_HSTXSRCCL_Msk (0x3UL << DSI_WPCR1_HSTXSRCCL_Pos)
12646#define DSI_WPCR1_HSTXSRCCL DSI_WPCR1_HSTXSRCCL_Msk
12647#define DSI_WPCR1_HSTXSRCCL0_Pos (16U)
12648#define DSI_WPCR1_HSTXSRCCL0_Msk (0x1UL << DSI_WPCR1_HSTXSRCCL0_Pos)
12649#define DSI_WPCR1_HSTXSRCCL0 DSI_WPCR1_HSTXSRCCL0_Msk
12650#define DSI_WPCR1_HSTXSRCCL1_Pos (17U)
12651#define DSI_WPCR1_HSTXSRCCL1_Msk (0x1UL << DSI_WPCR1_HSTXSRCCL1_Pos)
12652#define DSI_WPCR1_HSTXSRCCL1 DSI_WPCR1_HSTXSRCCL1_Msk
12653
12654#define DSI_WPCR1_HSTXSRCDL_Pos (18U)
12655#define DSI_WPCR1_HSTXSRCDL_Msk (0x3UL << DSI_WPCR1_HSTXSRCDL_Pos)
12656#define DSI_WPCR1_HSTXSRCDL DSI_WPCR1_HSTXSRCDL_Msk
12657#define DSI_WPCR1_HSTXSRCDL0_Pos (18U)
12658#define DSI_WPCR1_HSTXSRCDL0_Msk (0x1UL << DSI_WPCR1_HSTXSRCDL0_Pos)
12659#define DSI_WPCR1_HSTXSRCDL0 DSI_WPCR1_HSTXSRCDL0_Msk
12660#define DSI_WPCR1_HSTXSRCDL1_Pos (19U)
12661#define DSI_WPCR1_HSTXSRCDL1_Msk (0x1UL << DSI_WPCR1_HSTXSRCDL1_Pos)
12662#define DSI_WPCR1_HSTXSRCDL1 DSI_WPCR1_HSTXSRCDL1_Msk
12663
12664#define DSI_WPCR1_FLPRXLPM_Pos (22U)
12665#define DSI_WPCR1_FLPRXLPM_Msk (0x1UL << DSI_WPCR1_FLPRXLPM_Pos)
12666#define DSI_WPCR1_FLPRXLPM DSI_WPCR1_FLPRXLPM_Msk
12668#define DSI_WPCR1_LPRXFT_Pos (25U)
12669#define DSI_WPCR1_LPRXFT_Msk (0x3UL << DSI_WPCR1_LPRXFT_Pos)
12670#define DSI_WPCR1_LPRXFT DSI_WPCR1_LPRXFT_Msk
12671#define DSI_WPCR1_LPRXFT0_Pos (25U)
12672#define DSI_WPCR1_LPRXFT0_Msk (0x1UL << DSI_WPCR1_LPRXFT0_Pos)
12673#define DSI_WPCR1_LPRXFT0 DSI_WPCR1_LPRXFT0_Msk
12674#define DSI_WPCR1_LPRXFT1_Pos (26U)
12675#define DSI_WPCR1_LPRXFT1_Msk (0x1UL << DSI_WPCR1_LPRXFT1_Pos)
12676#define DSI_WPCR1_LPRXFT1 DSI_WPCR1_LPRXFT1_Msk
12677
12678/******************* Bit definition for DSI_WPCR2 register ***************/
12679#define DSI_WPCR2_TCLKPREP_Pos (0U)
12680#define DSI_WPCR2_TCLKPREP_Msk (0xFFUL << DSI_WPCR2_TCLKPREP_Pos)
12681#define DSI_WPCR2_TCLKPREP DSI_WPCR2_TCLKPREP_Msk
12682#define DSI_WPCR2_TCLKPREP0_Pos (0U)
12683#define DSI_WPCR2_TCLKPREP0_Msk (0x1UL << DSI_WPCR2_TCLKPREP0_Pos)
12684#define DSI_WPCR2_TCLKPREP0 DSI_WPCR2_TCLKPREP0_Msk
12685#define DSI_WPCR2_TCLKPREP1_Pos (1U)
12686#define DSI_WPCR2_TCLKPREP1_Msk (0x1UL << DSI_WPCR2_TCLKPREP1_Pos)
12687#define DSI_WPCR2_TCLKPREP1 DSI_WPCR2_TCLKPREP1_Msk
12688#define DSI_WPCR2_TCLKPREP2_Pos (2U)
12689#define DSI_WPCR2_TCLKPREP2_Msk (0x1UL << DSI_WPCR2_TCLKPREP2_Pos)
12690#define DSI_WPCR2_TCLKPREP2 DSI_WPCR2_TCLKPREP2_Msk
12691#define DSI_WPCR2_TCLKPREP3_Pos (3U)
12692#define DSI_WPCR2_TCLKPREP3_Msk (0x1UL << DSI_WPCR2_TCLKPREP3_Pos)
12693#define DSI_WPCR2_TCLKPREP3 DSI_WPCR2_TCLKPREP3_Msk
12694#define DSI_WPCR2_TCLKPREP4_Pos (4U)
12695#define DSI_WPCR2_TCLKPREP4_Msk (0x1UL << DSI_WPCR2_TCLKPREP4_Pos)
12696#define DSI_WPCR2_TCLKPREP4 DSI_WPCR2_TCLKPREP4_Msk
12697#define DSI_WPCR2_TCLKPREP5_Pos (5U)
12698#define DSI_WPCR2_TCLKPREP5_Msk (0x1UL << DSI_WPCR2_TCLKPREP5_Pos)
12699#define DSI_WPCR2_TCLKPREP5 DSI_WPCR2_TCLKPREP5_Msk
12700#define DSI_WPCR2_TCLKPREP6_Pos (6U)
12701#define DSI_WPCR2_TCLKPREP6_Msk (0x1UL << DSI_WPCR2_TCLKPREP6_Pos)
12702#define DSI_WPCR2_TCLKPREP6 DSI_WPCR2_TCLKPREP6_Msk
12703#define DSI_WPCR2_TCLKPREP7_Pos (7U)
12704#define DSI_WPCR2_TCLKPREP7_Msk (0x1UL << DSI_WPCR2_TCLKPREP7_Pos)
12705#define DSI_WPCR2_TCLKPREP7 DSI_WPCR2_TCLKPREP7_Msk
12706
12707#define DSI_WPCR2_TCLKZERO_Pos (8U)
12708#define DSI_WPCR2_TCLKZERO_Msk (0xFFUL << DSI_WPCR2_TCLKZERO_Pos)
12709#define DSI_WPCR2_TCLKZERO DSI_WPCR2_TCLKZERO_Msk
12710#define DSI_WPCR2_TCLKZERO0_Pos (8U)
12711#define DSI_WPCR2_TCLKZERO0_Msk (0x1UL << DSI_WPCR2_TCLKZERO0_Pos)
12712#define DSI_WPCR2_TCLKZERO0 DSI_WPCR2_TCLKZERO0_Msk
12713#define DSI_WPCR2_TCLKZERO1_Pos (9U)
12714#define DSI_WPCR2_TCLKZERO1_Msk (0x1UL << DSI_WPCR2_TCLKZERO1_Pos)
12715#define DSI_WPCR2_TCLKZERO1 DSI_WPCR2_TCLKZERO1_Msk
12716#define DSI_WPCR2_TCLKZERO2_Pos (10U)
12717#define DSI_WPCR2_TCLKZERO2_Msk (0x1UL << DSI_WPCR2_TCLKZERO2_Pos)
12718#define DSI_WPCR2_TCLKZERO2 DSI_WPCR2_TCLKZERO2_Msk
12719#define DSI_WPCR2_TCLKZERO3_Pos (11U)
12720#define DSI_WPCR2_TCLKZERO3_Msk (0x1UL << DSI_WPCR2_TCLKZERO3_Pos)
12721#define DSI_WPCR2_TCLKZERO3 DSI_WPCR2_TCLKZERO3_Msk
12722#define DSI_WPCR2_TCLKZERO4_Pos (12U)
12723#define DSI_WPCR2_TCLKZERO4_Msk (0x1UL << DSI_WPCR2_TCLKZERO4_Pos)
12724#define DSI_WPCR2_TCLKZERO4 DSI_WPCR2_TCLKZERO4_Msk
12725#define DSI_WPCR2_TCLKZERO5_Pos (13U)
12726#define DSI_WPCR2_TCLKZERO5_Msk (0x1UL << DSI_WPCR2_TCLKZERO5_Pos)
12727#define DSI_WPCR2_TCLKZERO5 DSI_WPCR2_TCLKZERO5_Msk
12728#define DSI_WPCR2_TCLKZERO6_Pos (14U)
12729#define DSI_WPCR2_TCLKZERO6_Msk (0x1UL << DSI_WPCR2_TCLKZERO6_Pos)
12730#define DSI_WPCR2_TCLKZERO6 DSI_WPCR2_TCLKZERO6_Msk
12731#define DSI_WPCR2_TCLKZERO7_Pos (15U)
12732#define DSI_WPCR2_TCLKZERO7_Msk (0x1UL << DSI_WPCR2_TCLKZERO7_Pos)
12733#define DSI_WPCR2_TCLKZERO7 DSI_WPCR2_TCLKZERO7_Msk
12734
12735#define DSI_WPCR2_THSPREP_Pos (16U)
12736#define DSI_WPCR2_THSPREP_Msk (0xFFUL << DSI_WPCR2_THSPREP_Pos)
12737#define DSI_WPCR2_THSPREP DSI_WPCR2_THSPREP_Msk
12738#define DSI_WPCR2_THSPREP0_Pos (16U)
12739#define DSI_WPCR2_THSPREP0_Msk (0x1UL << DSI_WPCR2_THSPREP0_Pos)
12740#define DSI_WPCR2_THSPREP0 DSI_WPCR2_THSPREP0_Msk
12741#define DSI_WPCR2_THSPREP1_Pos (17U)
12742#define DSI_WPCR2_THSPREP1_Msk (0x1UL << DSI_WPCR2_THSPREP1_Pos)
12743#define DSI_WPCR2_THSPREP1 DSI_WPCR2_THSPREP1_Msk
12744#define DSI_WPCR2_THSPREP2_Pos (18U)
12745#define DSI_WPCR2_THSPREP2_Msk (0x1UL << DSI_WPCR2_THSPREP2_Pos)
12746#define DSI_WPCR2_THSPREP2 DSI_WPCR2_THSPREP2_Msk
12747#define DSI_WPCR2_THSPREP3_Pos (19U)
12748#define DSI_WPCR2_THSPREP3_Msk (0x1UL << DSI_WPCR2_THSPREP3_Pos)
12749#define DSI_WPCR2_THSPREP3 DSI_WPCR2_THSPREP3_Msk
12750#define DSI_WPCR2_THSPREP4_Pos (20U)
12751#define DSI_WPCR2_THSPREP4_Msk (0x1UL << DSI_WPCR2_THSPREP4_Pos)
12752#define DSI_WPCR2_THSPREP4 DSI_WPCR2_THSPREP4_Msk
12753#define DSI_WPCR2_THSPREP5_Pos (21U)
12754#define DSI_WPCR2_THSPREP5_Msk (0x1UL << DSI_WPCR2_THSPREP5_Pos)
12755#define DSI_WPCR2_THSPREP5 DSI_WPCR2_THSPREP5_Msk
12756#define DSI_WPCR2_THSPREP6_Pos (22U)
12757#define DSI_WPCR2_THSPREP6_Msk (0x1UL << DSI_WPCR2_THSPREP6_Pos)
12758#define DSI_WPCR2_THSPREP6 DSI_WPCR2_THSPREP6_Msk
12759#define DSI_WPCR2_THSPREP7_Pos (23U)
12760#define DSI_WPCR2_THSPREP7_Msk (0x1UL << DSI_WPCR2_THSPREP7_Pos)
12761#define DSI_WPCR2_THSPREP7 DSI_WPCR2_THSPREP7_Msk
12762
12763#define DSI_WPCR2_THSTRAIL_Pos (24U)
12764#define DSI_WPCR2_THSTRAIL_Msk (0xFFUL << DSI_WPCR2_THSTRAIL_Pos)
12765#define DSI_WPCR2_THSTRAIL DSI_WPCR2_THSTRAIL_Msk
12766#define DSI_WPCR2_THSTRAIL0_Pos (24U)
12767#define DSI_WPCR2_THSTRAIL0_Msk (0x1UL << DSI_WPCR2_THSTRAIL0_Pos)
12768#define DSI_WPCR2_THSTRAIL0 DSI_WPCR2_THSTRAIL0_Msk
12769#define DSI_WPCR2_THSTRAIL1_Pos (25U)
12770#define DSI_WPCR2_THSTRAIL1_Msk (0x1UL << DSI_WPCR2_THSTRAIL1_Pos)
12771#define DSI_WPCR2_THSTRAIL1 DSI_WPCR2_THSTRAIL1_Msk
12772#define DSI_WPCR2_THSTRAIL2_Pos (26U)
12773#define DSI_WPCR2_THSTRAIL2_Msk (0x1UL << DSI_WPCR2_THSTRAIL2_Pos)
12774#define DSI_WPCR2_THSTRAIL2 DSI_WPCR2_THSTRAIL2_Msk
12775#define DSI_WPCR2_THSTRAIL3_Pos (27U)
12776#define DSI_WPCR2_THSTRAIL3_Msk (0x1UL << DSI_WPCR2_THSTRAIL3_Pos)
12777#define DSI_WPCR2_THSTRAIL3 DSI_WPCR2_THSTRAIL3_Msk
12778#define DSI_WPCR2_THSTRAIL4_Pos (28U)
12779#define DSI_WPCR2_THSTRAIL4_Msk (0x1UL << DSI_WPCR2_THSTRAIL4_Pos)
12780#define DSI_WPCR2_THSTRAIL4 DSI_WPCR2_THSTRAIL4_Msk
12781#define DSI_WPCR2_THSTRAIL5_Pos (29U)
12782#define DSI_WPCR2_THSTRAIL5_Msk (0x1UL << DSI_WPCR2_THSTRAIL5_Pos)
12783#define DSI_WPCR2_THSTRAIL5 DSI_WPCR2_THSTRAIL5_Msk
12784#define DSI_WPCR2_THSTRAIL6_Pos (30U)
12785#define DSI_WPCR2_THSTRAIL6_Msk (0x1UL << DSI_WPCR2_THSTRAIL6_Pos)
12786#define DSI_WPCR2_THSTRAIL6 DSI_WPCR2_THSTRAIL6_Msk
12787#define DSI_WPCR2_THSTRAIL7_Pos (31U)
12788#define DSI_WPCR2_THSTRAIL7_Msk (0x1UL << DSI_WPCR2_THSTRAIL7_Pos)
12789#define DSI_WPCR2_THSTRAIL7 DSI_WPCR2_THSTRAIL7_Msk
12790
12791/******************* Bit definition for DSI_WPCR3 register ***************/
12792#define DSI_WPCR3_THSZERO_Pos (0U)
12793#define DSI_WPCR3_THSZERO_Msk (0xFFUL << DSI_WPCR3_THSZERO_Pos)
12794#define DSI_WPCR3_THSZERO DSI_WPCR3_THSZERO_Msk
12795#define DSI_WPCR3_THSZERO0_Pos (0U)
12796#define DSI_WPCR3_THSZERO0_Msk (0x1UL << DSI_WPCR3_THSZERO0_Pos)
12797#define DSI_WPCR3_THSZERO0 DSI_WPCR3_THSZERO0_Msk
12798#define DSI_WPCR3_THSZERO1_Pos (1U)
12799#define DSI_WPCR3_THSZERO1_Msk (0x1UL << DSI_WPCR3_THSZERO1_Pos)
12800#define DSI_WPCR3_THSZERO1 DSI_WPCR3_THSZERO1_Msk
12801#define DSI_WPCR3_THSZERO2_Pos (2U)
12802#define DSI_WPCR3_THSZERO2_Msk (0x1UL << DSI_WPCR3_THSZERO2_Pos)
12803#define DSI_WPCR3_THSZERO2 DSI_WPCR3_THSZERO2_Msk
12804#define DSI_WPCR3_THSZERO3_Pos (3U)
12805#define DSI_WPCR3_THSZERO3_Msk (0x1UL << DSI_WPCR3_THSZERO3_Pos)
12806#define DSI_WPCR3_THSZERO3 DSI_WPCR3_THSZERO3_Msk
12807#define DSI_WPCR3_THSZERO4_Pos (4U)
12808#define DSI_WPCR3_THSZERO4_Msk (0x1UL << DSI_WPCR3_THSZERO4_Pos)
12809#define DSI_WPCR3_THSZERO4 DSI_WPCR3_THSZERO4_Msk
12810#define DSI_WPCR3_THSZERO5_Pos (5U)
12811#define DSI_WPCR3_THSZERO5_Msk (0x1UL << DSI_WPCR3_THSZERO5_Pos)
12812#define DSI_WPCR3_THSZERO5 DSI_WPCR3_THSZERO5_Msk
12813#define DSI_WPCR3_THSZERO6_Pos (6U)
12814#define DSI_WPCR3_THSZERO6_Msk (0x1UL << DSI_WPCR3_THSZERO6_Pos)
12815#define DSI_WPCR3_THSZERO6 DSI_WPCR3_THSZERO6_Msk
12816#define DSI_WPCR3_THSZERO7_Pos (7U)
12817#define DSI_WPCR3_THSZERO7_Msk (0x1UL << DSI_WPCR3_THSZERO7_Pos)
12818#define DSI_WPCR3_THSZERO7 DSI_WPCR3_THSZERO7_Msk
12819
12820#define DSI_WPCR3_TLPXD_Pos (8U)
12821#define DSI_WPCR3_TLPXD_Msk (0xFFUL << DSI_WPCR3_TLPXD_Pos)
12822#define DSI_WPCR3_TLPXD DSI_WPCR3_TLPXD_Msk
12823#define DSI_WPCR3_TLPXD0_Pos (8U)
12824#define DSI_WPCR3_TLPXD0_Msk (0x1UL << DSI_WPCR3_TLPXD0_Pos)
12825#define DSI_WPCR3_TLPXD0 DSI_WPCR3_TLPXD0_Msk
12826#define DSI_WPCR3_TLPXD1_Pos (9U)
12827#define DSI_WPCR3_TLPXD1_Msk (0x1UL << DSI_WPCR3_TLPXD1_Pos)
12828#define DSI_WPCR3_TLPXD1 DSI_WPCR3_TLPXD1_Msk
12829#define DSI_WPCR3_TLPXD2_Pos (10U)
12830#define DSI_WPCR3_TLPXD2_Msk (0x1UL << DSI_WPCR3_TLPXD2_Pos)
12831#define DSI_WPCR3_TLPXD2 DSI_WPCR3_TLPXD2_Msk
12832#define DSI_WPCR3_TLPXD3_Pos (11U)
12833#define DSI_WPCR3_TLPXD3_Msk (0x1UL << DSI_WPCR3_TLPXD3_Pos)
12834#define DSI_WPCR3_TLPXD3 DSI_WPCR3_TLPXD3_Msk
12835#define DSI_WPCR3_TLPXD4_Pos (12U)
12836#define DSI_WPCR3_TLPXD4_Msk (0x1UL << DSI_WPCR3_TLPXD4_Pos)
12837#define DSI_WPCR3_TLPXD4 DSI_WPCR3_TLPXD4_Msk
12838#define DSI_WPCR3_TLPXD5_Pos (13U)
12839#define DSI_WPCR3_TLPXD5_Msk (0x1UL << DSI_WPCR3_TLPXD5_Pos)
12840#define DSI_WPCR3_TLPXD5 DSI_WPCR3_TLPXD5_Msk
12841#define DSI_WPCR3_TLPXD6_Pos (14U)
12842#define DSI_WPCR3_TLPXD6_Msk (0x1UL << DSI_WPCR3_TLPXD6_Pos)
12843#define DSI_WPCR3_TLPXD6 DSI_WPCR3_TLPXD6_Msk
12844#define DSI_WPCR3_TLPXD7_Pos (15U)
12845#define DSI_WPCR3_TLPXD7_Msk (0x1UL << DSI_WPCR3_TLPXD7_Pos)
12846#define DSI_WPCR3_TLPXD7 DSI_WPCR3_TLPXD7_Msk
12847
12848#define DSI_WPCR3_THSEXIT_Pos (16U)
12849#define DSI_WPCR3_THSEXIT_Msk (0xFFUL << DSI_WPCR3_THSEXIT_Pos)
12850#define DSI_WPCR3_THSEXIT DSI_WPCR3_THSEXIT_Msk
12851#define DSI_WPCR3_THSEXIT0_Pos (16U)
12852#define DSI_WPCR3_THSEXIT0_Msk (0x1UL << DSI_WPCR3_THSEXIT0_Pos)
12853#define DSI_WPCR3_THSEXIT0 DSI_WPCR3_THSEXIT0_Msk
12854#define DSI_WPCR3_THSEXIT1_Pos (17U)
12855#define DSI_WPCR3_THSEXIT1_Msk (0x1UL << DSI_WPCR3_THSEXIT1_Pos)
12856#define DSI_WPCR3_THSEXIT1 DSI_WPCR3_THSEXIT1_Msk
12857#define DSI_WPCR3_THSEXIT2_Pos (18U)
12858#define DSI_WPCR3_THSEXIT2_Msk (0x1UL << DSI_WPCR3_THSEXIT2_Pos)
12859#define DSI_WPCR3_THSEXIT2 DSI_WPCR3_THSEXIT2_Msk
12860#define DSI_WPCR3_THSEXIT3_Pos (19U)
12861#define DSI_WPCR3_THSEXIT3_Msk (0x1UL << DSI_WPCR3_THSEXIT3_Pos)
12862#define DSI_WPCR3_THSEXIT3 DSI_WPCR3_THSEXIT3_Msk
12863#define DSI_WPCR3_THSEXIT4_Pos (20U)
12864#define DSI_WPCR3_THSEXIT4_Msk (0x1UL << DSI_WPCR3_THSEXIT4_Pos)
12865#define DSI_WPCR3_THSEXIT4 DSI_WPCR3_THSEXIT4_Msk
12866#define DSI_WPCR3_THSEXIT5_Pos (21U)
12867#define DSI_WPCR3_THSEXIT5_Msk (0x1UL << DSI_WPCR3_THSEXIT5_Pos)
12868#define DSI_WPCR3_THSEXIT5 DSI_WPCR3_THSEXIT5_Msk
12869#define DSI_WPCR3_THSEXIT6_Pos (22U)
12870#define DSI_WPCR3_THSEXIT6_Msk (0x1UL << DSI_WPCR3_THSEXIT6_Pos)
12871#define DSI_WPCR3_THSEXIT6 DSI_WPCR3_THSEXIT6_Msk
12872#define DSI_WPCR3_THSEXIT7_Pos (23U)
12873#define DSI_WPCR3_THSEXIT7_Msk (0x1UL << DSI_WPCR3_THSEXIT7_Pos)
12874#define DSI_WPCR3_THSEXIT7 DSI_WPCR3_THSEXIT7_Msk
12875
12876#define DSI_WPCR3_TLPXC_Pos (24U)
12877#define DSI_WPCR3_TLPXC_Msk (0xFFUL << DSI_WPCR3_TLPXC_Pos)
12878#define DSI_WPCR3_TLPXC DSI_WPCR3_TLPXC_Msk
12879#define DSI_WPCR3_TLPXC0_Pos (24U)
12880#define DSI_WPCR3_TLPXC0_Msk (0x1UL << DSI_WPCR3_TLPXC0_Pos)
12881#define DSI_WPCR3_TLPXC0 DSI_WPCR3_TLPXC0_Msk
12882#define DSI_WPCR3_TLPXC1_Pos (25U)
12883#define DSI_WPCR3_TLPXC1_Msk (0x1UL << DSI_WPCR3_TLPXC1_Pos)
12884#define DSI_WPCR3_TLPXC1 DSI_WPCR3_TLPXC1_Msk
12885#define DSI_WPCR3_TLPXC2_Pos (26U)
12886#define DSI_WPCR3_TLPXC2_Msk (0x1UL << DSI_WPCR3_TLPXC2_Pos)
12887#define DSI_WPCR3_TLPXC2 DSI_WPCR3_TLPXC2_Msk
12888#define DSI_WPCR3_TLPXC3_Pos (27U)
12889#define DSI_WPCR3_TLPXC3_Msk (0x1UL << DSI_WPCR3_TLPXC3_Pos)
12890#define DSI_WPCR3_TLPXC3 DSI_WPCR3_TLPXC3_Msk
12891#define DSI_WPCR3_TLPXC4_Pos (28U)
12892#define DSI_WPCR3_TLPXC4_Msk (0x1UL << DSI_WPCR3_TLPXC4_Pos)
12893#define DSI_WPCR3_TLPXC4 DSI_WPCR3_TLPXC4_Msk
12894#define DSI_WPCR3_TLPXC5_Pos (29U)
12895#define DSI_WPCR3_TLPXC5_Msk (0x1UL << DSI_WPCR3_TLPXC5_Pos)
12896#define DSI_WPCR3_TLPXC5 DSI_WPCR3_TLPXC5_Msk
12897#define DSI_WPCR3_TLPXC6_Pos (30U)
12898#define DSI_WPCR3_TLPXC6_Msk (0x1UL << DSI_WPCR3_TLPXC6_Pos)
12899#define DSI_WPCR3_TLPXC6 DSI_WPCR3_TLPXC6_Msk
12900#define DSI_WPCR3_TLPXC7_Pos (31U)
12901#define DSI_WPCR3_TLPXC7_Msk (0x1UL << DSI_WPCR3_TLPXC7_Pos)
12902#define DSI_WPCR3_TLPXC7 DSI_WPCR3_TLPXC7_Msk
12903
12904/******************* Bit definition for DSI_WPCR4 register ***************/
12905#define DSI_WPCR4_TCLKPOST_Pos (0U)
12906#define DSI_WPCR4_TCLKPOST_Msk (0xFFUL << DSI_WPCR4_TCLKPOST_Pos)
12907#define DSI_WPCR4_TCLKPOST DSI_WPCR4_TCLKPOST_Msk
12908#define DSI_WPCR4_TCLKPOST0_Pos (0U)
12909#define DSI_WPCR4_TCLKPOST0_Msk (0x1UL << DSI_WPCR4_TCLKPOST0_Pos)
12910#define DSI_WPCR4_TCLKPOST0 DSI_WPCR4_TCLKPOST0_Msk
12911#define DSI_WPCR4_TCLKPOST1_Pos (1U)
12912#define DSI_WPCR4_TCLKPOST1_Msk (0x1UL << DSI_WPCR4_TCLKPOST1_Pos)
12913#define DSI_WPCR4_TCLKPOST1 DSI_WPCR4_TCLKPOST1_Msk
12914#define DSI_WPCR4_TCLKPOST2_Pos (2U)
12915#define DSI_WPCR4_TCLKPOST2_Msk (0x1UL << DSI_WPCR4_TCLKPOST2_Pos)
12916#define DSI_WPCR4_TCLKPOST2 DSI_WPCR4_TCLKPOST2_Msk
12917#define DSI_WPCR4_TCLKPOST3_Pos (3U)
12918#define DSI_WPCR4_TCLKPOST3_Msk (0x1UL << DSI_WPCR4_TCLKPOST3_Pos)
12919#define DSI_WPCR4_TCLKPOST3 DSI_WPCR4_TCLKPOST3_Msk
12920#define DSI_WPCR4_TCLKPOST4_Pos (4U)
12921#define DSI_WPCR4_TCLKPOST4_Msk (0x1UL << DSI_WPCR4_TCLKPOST4_Pos)
12922#define DSI_WPCR4_TCLKPOST4 DSI_WPCR4_TCLKPOST4_Msk
12923#define DSI_WPCR4_TCLKPOST5_Pos (5U)
12924#define DSI_WPCR4_TCLKPOST5_Msk (0x1UL << DSI_WPCR4_TCLKPOST5_Pos)
12925#define DSI_WPCR4_TCLKPOST5 DSI_WPCR4_TCLKPOST5_Msk
12926#define DSI_WPCR4_TCLKPOST6_Pos (6U)
12927#define DSI_WPCR4_TCLKPOST6_Msk (0x1UL << DSI_WPCR4_TCLKPOST6_Pos)
12928#define DSI_WPCR4_TCLKPOST6 DSI_WPCR4_TCLKPOST6_Msk
12929#define DSI_WPCR4_TCLKPOST7_Pos (7U)
12930#define DSI_WPCR4_TCLKPOST7_Msk (0x1UL << DSI_WPCR4_TCLKPOST7_Pos)
12931#define DSI_WPCR4_TCLKPOST7 DSI_WPCR4_TCLKPOST7_Msk
12932
12933/******************* Bit definition for DSI_WRPCR register ***************/
12934#define DSI_WRPCR_PLLEN_Pos (0U)
12935#define DSI_WRPCR_PLLEN_Msk (0x1UL << DSI_WRPCR_PLLEN_Pos)
12936#define DSI_WRPCR_PLLEN DSI_WRPCR_PLLEN_Msk
12937#define DSI_WRPCR_PLL_NDIV_Pos (2U)
12938#define DSI_WRPCR_PLL_NDIV_Msk (0x7FUL << DSI_WRPCR_PLL_NDIV_Pos)
12939#define DSI_WRPCR_PLL_NDIV DSI_WRPCR_PLL_NDIV_Msk
12940#define DSI_WRPCR_PLL_NDIV0_Pos (2U)
12941#define DSI_WRPCR_PLL_NDIV0_Msk (0x1UL << DSI_WRPCR_PLL_NDIV0_Pos)
12942#define DSI_WRPCR_PLL_NDIV0 DSI_WRPCR_PLL_NDIV0_Msk
12943#define DSI_WRPCR_PLL_NDIV1_Pos (3U)
12944#define DSI_WRPCR_PLL_NDIV1_Msk (0x1UL << DSI_WRPCR_PLL_NDIV1_Pos)
12945#define DSI_WRPCR_PLL_NDIV1 DSI_WRPCR_PLL_NDIV1_Msk
12946#define DSI_WRPCR_PLL_NDIV2_Pos (4U)
12947#define DSI_WRPCR_PLL_NDIV2_Msk (0x1UL << DSI_WRPCR_PLL_NDIV2_Pos)
12948#define DSI_WRPCR_PLL_NDIV2 DSI_WRPCR_PLL_NDIV2_Msk
12949#define DSI_WRPCR_PLL_NDIV3_Pos (5U)
12950#define DSI_WRPCR_PLL_NDIV3_Msk (0x1UL << DSI_WRPCR_PLL_NDIV3_Pos)
12951#define DSI_WRPCR_PLL_NDIV3 DSI_WRPCR_PLL_NDIV3_Msk
12952#define DSI_WRPCR_PLL_NDIV4_Pos (6U)
12953#define DSI_WRPCR_PLL_NDIV4_Msk (0x1UL << DSI_WRPCR_PLL_NDIV4_Pos)
12954#define DSI_WRPCR_PLL_NDIV4 DSI_WRPCR_PLL_NDIV4_Msk
12955#define DSI_WRPCR_PLL_NDIV5_Pos (7U)
12956#define DSI_WRPCR_PLL_NDIV5_Msk (0x1UL << DSI_WRPCR_PLL_NDIV5_Pos)
12957#define DSI_WRPCR_PLL_NDIV5 DSI_WRPCR_PLL_NDIV5_Msk
12958#define DSI_WRPCR_PLL_NDIV6_Pos (8U)
12959#define DSI_WRPCR_PLL_NDIV6_Msk (0x1UL << DSI_WRPCR_PLL_NDIV6_Pos)
12960#define DSI_WRPCR_PLL_NDIV6 DSI_WRPCR_PLL_NDIV6_Msk
12961
12962#define DSI_WRPCR_PLL_IDF_Pos (11U)
12963#define DSI_WRPCR_PLL_IDF_Msk (0xFUL << DSI_WRPCR_PLL_IDF_Pos)
12964#define DSI_WRPCR_PLL_IDF DSI_WRPCR_PLL_IDF_Msk
12965#define DSI_WRPCR_PLL_IDF0_Pos (11U)
12966#define DSI_WRPCR_PLL_IDF0_Msk (0x1UL << DSI_WRPCR_PLL_IDF0_Pos)
12967#define DSI_WRPCR_PLL_IDF0 DSI_WRPCR_PLL_IDF0_Msk
12968#define DSI_WRPCR_PLL_IDF1_Pos (12U)
12969#define DSI_WRPCR_PLL_IDF1_Msk (0x1UL << DSI_WRPCR_PLL_IDF1_Pos)
12970#define DSI_WRPCR_PLL_IDF1 DSI_WRPCR_PLL_IDF1_Msk
12971#define DSI_WRPCR_PLL_IDF2_Pos (13U)
12972#define DSI_WRPCR_PLL_IDF2_Msk (0x1UL << DSI_WRPCR_PLL_IDF2_Pos)
12973#define DSI_WRPCR_PLL_IDF2 DSI_WRPCR_PLL_IDF2_Msk
12974#define DSI_WRPCR_PLL_IDF3_Pos (14U)
12975#define DSI_WRPCR_PLL_IDF3_Msk (0x1UL << DSI_WRPCR_PLL_IDF3_Pos)
12976#define DSI_WRPCR_PLL_IDF3 DSI_WRPCR_PLL_IDF3_Msk
12977
12978#define DSI_WRPCR_PLL_ODF_Pos (16U)
12979#define DSI_WRPCR_PLL_ODF_Msk (0x3UL << DSI_WRPCR_PLL_ODF_Pos)
12980#define DSI_WRPCR_PLL_ODF DSI_WRPCR_PLL_ODF_Msk
12981#define DSI_WRPCR_PLL_ODF0_Pos (16U)
12982#define DSI_WRPCR_PLL_ODF0_Msk (0x1UL << DSI_WRPCR_PLL_ODF0_Pos)
12983#define DSI_WRPCR_PLL_ODF0 DSI_WRPCR_PLL_ODF0_Msk
12984#define DSI_WRPCR_PLL_ODF1_Pos (17U)
12985#define DSI_WRPCR_PLL_ODF1_Msk (0x1UL << DSI_WRPCR_PLL_ODF1_Pos)
12986#define DSI_WRPCR_PLL_ODF1 DSI_WRPCR_PLL_ODF1_Msk
12987
12988#define DSI_WRPCR_REGEN_Pos (24U)
12989#define DSI_WRPCR_REGEN_Msk (0x1UL << DSI_WRPCR_REGEN_Pos)
12990#define DSI_WRPCR_REGEN DSI_WRPCR_REGEN_Msk
12992/******************************************************************************/
12993/* */
12994/* External Interrupt/Event Controller */
12995/* */
12996/******************************************************************************/
12997/****************** Bit definition for EXTI_RTSR1 register *******************/
12998#define EXTI_RTSR1_TR_Pos (0U)
12999#define EXTI_RTSR1_TR_Msk (0x3FFFFFUL << EXTI_RTSR1_TR_Pos)
13000#define EXTI_RTSR1_TR EXTI_RTSR1_TR_Msk
13001#define EXTI_RTSR1_TR0_Pos (0U)
13002#define EXTI_RTSR1_TR0_Msk (0x1UL << EXTI_RTSR1_TR0_Pos)
13003#define EXTI_RTSR1_TR0 EXTI_RTSR1_TR0_Msk
13004#define EXTI_RTSR1_TR1_Pos (1U)
13005#define EXTI_RTSR1_TR1_Msk (0x1UL << EXTI_RTSR1_TR1_Pos)
13006#define EXTI_RTSR1_TR1 EXTI_RTSR1_TR1_Msk
13007#define EXTI_RTSR1_TR2_Pos (2U)
13008#define EXTI_RTSR1_TR2_Msk (0x1UL << EXTI_RTSR1_TR2_Pos)
13009#define EXTI_RTSR1_TR2 EXTI_RTSR1_TR2_Msk
13010#define EXTI_RTSR1_TR3_Pos (3U)
13011#define EXTI_RTSR1_TR3_Msk (0x1UL << EXTI_RTSR1_TR3_Pos)
13012#define EXTI_RTSR1_TR3 EXTI_RTSR1_TR3_Msk
13013#define EXTI_RTSR1_TR4_Pos (4U)
13014#define EXTI_RTSR1_TR4_Msk (0x1UL << EXTI_RTSR1_TR4_Pos)
13015#define EXTI_RTSR1_TR4 EXTI_RTSR1_TR4_Msk
13016#define EXTI_RTSR1_TR5_Pos (5U)
13017#define EXTI_RTSR1_TR5_Msk (0x1UL << EXTI_RTSR1_TR5_Pos)
13018#define EXTI_RTSR1_TR5 EXTI_RTSR1_TR5_Msk
13019#define EXTI_RTSR1_TR6_Pos (6U)
13020#define EXTI_RTSR1_TR6_Msk (0x1UL << EXTI_RTSR1_TR6_Pos)
13021#define EXTI_RTSR1_TR6 EXTI_RTSR1_TR6_Msk
13022#define EXTI_RTSR1_TR7_Pos (7U)
13023#define EXTI_RTSR1_TR7_Msk (0x1UL << EXTI_RTSR1_TR7_Pos)
13024#define EXTI_RTSR1_TR7 EXTI_RTSR1_TR7_Msk
13025#define EXTI_RTSR1_TR8_Pos (8U)
13026#define EXTI_RTSR1_TR8_Msk (0x1UL << EXTI_RTSR1_TR8_Pos)
13027#define EXTI_RTSR1_TR8 EXTI_RTSR1_TR8_Msk
13028#define EXTI_RTSR1_TR9_Pos (9U)
13029#define EXTI_RTSR1_TR9_Msk (0x1UL << EXTI_RTSR1_TR9_Pos)
13030#define EXTI_RTSR1_TR9 EXTI_RTSR1_TR9_Msk
13031#define EXTI_RTSR1_TR10_Pos (10U)
13032#define EXTI_RTSR1_TR10_Msk (0x1UL << EXTI_RTSR1_TR10_Pos)
13033#define EXTI_RTSR1_TR10 EXTI_RTSR1_TR10_Msk
13034#define EXTI_RTSR1_TR11_Pos (11U)
13035#define EXTI_RTSR1_TR11_Msk (0x1UL << EXTI_RTSR1_TR11_Pos)
13036#define EXTI_RTSR1_TR11 EXTI_RTSR1_TR11_Msk
13037#define EXTI_RTSR1_TR12_Pos (12U)
13038#define EXTI_RTSR1_TR12_Msk (0x1UL << EXTI_RTSR1_TR12_Pos)
13039#define EXTI_RTSR1_TR12 EXTI_RTSR1_TR12_Msk
13040#define EXTI_RTSR1_TR13_Pos (13U)
13041#define EXTI_RTSR1_TR13_Msk (0x1UL << EXTI_RTSR1_TR13_Pos)
13042#define EXTI_RTSR1_TR13 EXTI_RTSR1_TR13_Msk
13043#define EXTI_RTSR1_TR14_Pos (14U)
13044#define EXTI_RTSR1_TR14_Msk (0x1UL << EXTI_RTSR1_TR14_Pos)
13045#define EXTI_RTSR1_TR14 EXTI_RTSR1_TR14_Msk
13046#define EXTI_RTSR1_TR15_Pos (15U)
13047#define EXTI_RTSR1_TR15_Msk (0x1UL << EXTI_RTSR1_TR15_Pos)
13048#define EXTI_RTSR1_TR15 EXTI_RTSR1_TR15_Msk
13049#define EXTI_RTSR1_TR16_Pos (16U)
13050#define EXTI_RTSR1_TR16_Msk (0x1UL << EXTI_RTSR1_TR16_Pos)
13051#define EXTI_RTSR1_TR16 EXTI_RTSR1_TR16_Msk
13052#define EXTI_RTSR1_TR17_Pos (17U)
13053#define EXTI_RTSR1_TR17_Msk (0x1UL << EXTI_RTSR1_TR17_Pos)
13054#define EXTI_RTSR1_TR17 EXTI_RTSR1_TR17_Msk
13055#define EXTI_RTSR1_TR18_Pos (18U)
13056#define EXTI_RTSR1_TR18_Msk (0x1UL << EXTI_RTSR1_TR18_Pos)
13057#define EXTI_RTSR1_TR18 EXTI_RTSR1_TR18_Msk
13058#define EXTI_RTSR1_TR19_Pos (19U)
13059#define EXTI_RTSR1_TR19_Msk (0x1UL << EXTI_RTSR1_TR19_Pos)
13060#define EXTI_RTSR1_TR19 EXTI_RTSR1_TR19_Msk
13061#define EXTI_RTSR1_TR20_Pos (20U)
13062#define EXTI_RTSR1_TR20_Msk (0x1UL << EXTI_RTSR1_TR20_Pos)
13063#define EXTI_RTSR1_TR20 EXTI_RTSR1_TR20_Msk
13064#define EXTI_RTSR1_TR21_Pos (21U)
13065#define EXTI_RTSR1_TR21_Msk (0x1UL << EXTI_RTSR1_TR21_Pos)
13066#define EXTI_RTSR1_TR21 EXTI_RTSR1_TR21_Msk
13068/****************** Bit definition for EXTI_FTSR1 register *******************/
13069#define EXTI_FTSR1_TR_Pos (0U)
13070#define EXTI_FTSR1_TR_Msk (0x3FFFFFUL << EXTI_FTSR1_TR_Pos)
13071#define EXTI_FTSR1_TR EXTI_FTSR1_TR_Msk
13072#define EXTI_FTSR1_TR0_Pos (0U)
13073#define EXTI_FTSR1_TR0_Msk (0x1UL << EXTI_FTSR1_TR0_Pos)
13074#define EXTI_FTSR1_TR0 EXTI_FTSR1_TR0_Msk
13075#define EXTI_FTSR1_TR1_Pos (1U)
13076#define EXTI_FTSR1_TR1_Msk (0x1UL << EXTI_FTSR1_TR1_Pos)
13077#define EXTI_FTSR1_TR1 EXTI_FTSR1_TR1_Msk
13078#define EXTI_FTSR1_TR2_Pos (2U)
13079#define EXTI_FTSR1_TR2_Msk (0x1UL << EXTI_FTSR1_TR2_Pos)
13080#define EXTI_FTSR1_TR2 EXTI_FTSR1_TR2_Msk
13081#define EXTI_FTSR1_TR3_Pos (3U)
13082#define EXTI_FTSR1_TR3_Msk (0x1UL << EXTI_FTSR1_TR3_Pos)
13083#define EXTI_FTSR1_TR3 EXTI_FTSR1_TR3_Msk
13084#define EXTI_FTSR1_TR4_Pos (4U)
13085#define EXTI_FTSR1_TR4_Msk (0x1UL << EXTI_FTSR1_TR4_Pos)
13086#define EXTI_FTSR1_TR4 EXTI_FTSR1_TR4_Msk
13087#define EXTI_FTSR1_TR5_Pos (5U)
13088#define EXTI_FTSR1_TR5_Msk (0x1UL << EXTI_FTSR1_TR5_Pos)
13089#define EXTI_FTSR1_TR5 EXTI_FTSR1_TR5_Msk
13090#define EXTI_FTSR1_TR6_Pos (6U)
13091#define EXTI_FTSR1_TR6_Msk (0x1UL << EXTI_FTSR1_TR6_Pos)
13092#define EXTI_FTSR1_TR6 EXTI_FTSR1_TR6_Msk
13093#define EXTI_FTSR1_TR7_Pos (7U)
13094#define EXTI_FTSR1_TR7_Msk (0x1UL << EXTI_FTSR1_TR7_Pos)
13095#define EXTI_FTSR1_TR7 EXTI_FTSR1_TR7_Msk
13096#define EXTI_FTSR1_TR8_Pos (8U)
13097#define EXTI_FTSR1_TR8_Msk (0x1UL << EXTI_FTSR1_TR8_Pos)
13098#define EXTI_FTSR1_TR8 EXTI_FTSR1_TR8_Msk
13099#define EXTI_FTSR1_TR9_Pos (9U)
13100#define EXTI_FTSR1_TR9_Msk (0x1UL << EXTI_FTSR1_TR9_Pos)
13101#define EXTI_FTSR1_TR9 EXTI_FTSR1_TR9_Msk
13102#define EXTI_FTSR1_TR10_Pos (10U)
13103#define EXTI_FTSR1_TR10_Msk (0x1UL << EXTI_FTSR1_TR10_Pos)
13104#define EXTI_FTSR1_TR10 EXTI_FTSR1_TR10_Msk
13105#define EXTI_FTSR1_TR11_Pos (11U)
13106#define EXTI_FTSR1_TR11_Msk (0x1UL << EXTI_FTSR1_TR11_Pos)
13107#define EXTI_FTSR1_TR11 EXTI_FTSR1_TR11_Msk
13108#define EXTI_FTSR1_TR12_Pos (12U)
13109#define EXTI_FTSR1_TR12_Msk (0x1UL << EXTI_FTSR1_TR12_Pos)
13110#define EXTI_FTSR1_TR12 EXTI_FTSR1_TR12_Msk
13111#define EXTI_FTSR1_TR13_Pos (13U)
13112#define EXTI_FTSR1_TR13_Msk (0x1UL << EXTI_FTSR1_TR13_Pos)
13113#define EXTI_FTSR1_TR13 EXTI_FTSR1_TR13_Msk
13114#define EXTI_FTSR1_TR14_Pos (14U)
13115#define EXTI_FTSR1_TR14_Msk (0x1UL << EXTI_FTSR1_TR14_Pos)
13116#define EXTI_FTSR1_TR14 EXTI_FTSR1_TR14_Msk
13117#define EXTI_FTSR1_TR15_Pos (15U)
13118#define EXTI_FTSR1_TR15_Msk (0x1UL << EXTI_FTSR1_TR15_Pos)
13119#define EXTI_FTSR1_TR15 EXTI_FTSR1_TR15_Msk
13120#define EXTI_FTSR1_TR16_Pos (16U)
13121#define EXTI_FTSR1_TR16_Msk (0x1UL << EXTI_FTSR1_TR16_Pos)
13122#define EXTI_FTSR1_TR16 EXTI_FTSR1_TR16_Msk
13123#define EXTI_FTSR1_TR17_Pos (17U)
13124#define EXTI_FTSR1_TR17_Msk (0x1UL << EXTI_FTSR1_TR17_Pos)
13125#define EXTI_FTSR1_TR17 EXTI_FTSR1_TR17_Msk
13126#define EXTI_FTSR1_TR18_Pos (18U)
13127#define EXTI_FTSR1_TR18_Msk (0x1UL << EXTI_FTSR1_TR18_Pos)
13128#define EXTI_FTSR1_TR18 EXTI_FTSR1_TR18_Msk
13129#define EXTI_FTSR1_TR19_Pos (19U)
13130#define EXTI_FTSR1_TR19_Msk (0x1UL << EXTI_FTSR1_TR19_Pos)
13131#define EXTI_FTSR1_TR19 EXTI_FTSR1_TR19_Msk
13132#define EXTI_FTSR1_TR20_Pos (20U)
13133#define EXTI_FTSR1_TR20_Msk (0x1UL << EXTI_FTSR1_TR20_Pos)
13134#define EXTI_FTSR1_TR20 EXTI_FTSR1_TR20_Msk
13135#define EXTI_FTSR1_TR21_Pos (21U)
13136#define EXTI_FTSR1_TR21_Msk (0x1UL << EXTI_FTSR1_TR21_Pos)
13137#define EXTI_FTSR1_TR21 EXTI_FTSR1_TR21_Msk
13139/****************** Bit definition for EXTI_SWIER1 register ******************/
13140#define EXTI_SWIER1_SWIER0_Pos (0U)
13141#define EXTI_SWIER1_SWIER0_Msk (0x1UL << EXTI_SWIER1_SWIER0_Pos)
13142#define EXTI_SWIER1_SWIER0 EXTI_SWIER1_SWIER0_Msk
13143#define EXTI_SWIER1_SWIER1_Pos (1U)
13144#define EXTI_SWIER1_SWIER1_Msk (0x1UL << EXTI_SWIER1_SWIER1_Pos)
13145#define EXTI_SWIER1_SWIER1 EXTI_SWIER1_SWIER1_Msk
13146#define EXTI_SWIER1_SWIER2_Pos (2U)
13147#define EXTI_SWIER1_SWIER2_Msk (0x1UL << EXTI_SWIER1_SWIER2_Pos)
13148#define EXTI_SWIER1_SWIER2 EXTI_SWIER1_SWIER2_Msk
13149#define EXTI_SWIER1_SWIER3_Pos (3U)
13150#define EXTI_SWIER1_SWIER3_Msk (0x1UL << EXTI_SWIER1_SWIER3_Pos)
13151#define EXTI_SWIER1_SWIER3 EXTI_SWIER1_SWIER3_Msk
13152#define EXTI_SWIER1_SWIER4_Pos (4U)
13153#define EXTI_SWIER1_SWIER4_Msk (0x1UL << EXTI_SWIER1_SWIER4_Pos)
13154#define EXTI_SWIER1_SWIER4 EXTI_SWIER1_SWIER4_Msk
13155#define EXTI_SWIER1_SWIER5_Pos (5U)
13156#define EXTI_SWIER1_SWIER5_Msk (0x1UL << EXTI_SWIER1_SWIER5_Pos)
13157#define EXTI_SWIER1_SWIER5 EXTI_SWIER1_SWIER5_Msk
13158#define EXTI_SWIER1_SWIER6_Pos (6U)
13159#define EXTI_SWIER1_SWIER6_Msk (0x1UL << EXTI_SWIER1_SWIER6_Pos)
13160#define EXTI_SWIER1_SWIER6 EXTI_SWIER1_SWIER6_Msk
13161#define EXTI_SWIER1_SWIER7_Pos (7U)
13162#define EXTI_SWIER1_SWIER7_Msk (0x1UL << EXTI_SWIER1_SWIER7_Pos)
13163#define EXTI_SWIER1_SWIER7 EXTI_SWIER1_SWIER7_Msk
13164#define EXTI_SWIER1_SWIER8_Pos (8U)
13165#define EXTI_SWIER1_SWIER8_Msk (0x1UL << EXTI_SWIER1_SWIER8_Pos)
13166#define EXTI_SWIER1_SWIER8 EXTI_SWIER1_SWIER8_Msk
13167#define EXTI_SWIER1_SWIER9_Pos (9U)
13168#define EXTI_SWIER1_SWIER9_Msk (0x1UL << EXTI_SWIER1_SWIER9_Pos)
13169#define EXTI_SWIER1_SWIER9 EXTI_SWIER1_SWIER9_Msk
13170#define EXTI_SWIER1_SWIER10_Pos (10U)
13171#define EXTI_SWIER1_SWIER10_Msk (0x1UL << EXTI_SWIER1_SWIER10_Pos)
13172#define EXTI_SWIER1_SWIER10 EXTI_SWIER1_SWIER10_Msk
13173#define EXTI_SWIER1_SWIER11_Pos (11U)
13174#define EXTI_SWIER1_SWIER11_Msk (0x1UL << EXTI_SWIER1_SWIER11_Pos)
13175#define EXTI_SWIER1_SWIER11 EXTI_SWIER1_SWIER11_Msk
13176#define EXTI_SWIER1_SWIER12_Pos (12U)
13177#define EXTI_SWIER1_SWIER12_Msk (0x1UL << EXTI_SWIER1_SWIER12_Pos)
13178#define EXTI_SWIER1_SWIER12 EXTI_SWIER1_SWIER12_Msk
13179#define EXTI_SWIER1_SWIER13_Pos (13U)
13180#define EXTI_SWIER1_SWIER13_Msk (0x1UL << EXTI_SWIER1_SWIER13_Pos)
13181#define EXTI_SWIER1_SWIER13 EXTI_SWIER1_SWIER13_Msk
13182#define EXTI_SWIER1_SWIER14_Pos (14U)
13183#define EXTI_SWIER1_SWIER14_Msk (0x1UL << EXTI_SWIER1_SWIER14_Pos)
13184#define EXTI_SWIER1_SWIER14 EXTI_SWIER1_SWIER14_Msk
13185#define EXTI_SWIER1_SWIER15_Pos (15U)
13186#define EXTI_SWIER1_SWIER15_Msk (0x1UL << EXTI_SWIER1_SWIER15_Pos)
13187#define EXTI_SWIER1_SWIER15 EXTI_SWIER1_SWIER15_Msk
13188#define EXTI_SWIER1_SWIER16_Pos (16U)
13189#define EXTI_SWIER1_SWIER16_Msk (0x1UL << EXTI_SWIER1_SWIER16_Pos)
13190#define EXTI_SWIER1_SWIER16 EXTI_SWIER1_SWIER16_Msk
13191#define EXTI_SWIER1_SWIER17_Pos (17U)
13192#define EXTI_SWIER1_SWIER17_Msk (0x1UL << EXTI_SWIER1_SWIER17_Pos)
13193#define EXTI_SWIER1_SWIER17 EXTI_SWIER1_SWIER17_Msk
13194#define EXTI_SWIER1_SWIER18_Pos (18U)
13195#define EXTI_SWIER1_SWIER18_Msk (0x1UL << EXTI_SWIER1_SWIER18_Pos)
13196#define EXTI_SWIER1_SWIER18 EXTI_SWIER1_SWIER18_Msk
13197#define EXTI_SWIER1_SWIER19_Pos (19U)
13198#define EXTI_SWIER1_SWIER19_Msk (0x1UL << EXTI_SWIER1_SWIER19_Pos)
13199#define EXTI_SWIER1_SWIER19 EXTI_SWIER1_SWIER19_Msk
13200#define EXTI_SWIER1_SWIER20_Pos (20U)
13201#define EXTI_SWIER1_SWIER20_Msk (0x1UL << EXTI_SWIER1_SWIER20_Pos)
13202#define EXTI_SWIER1_SWIER20 EXTI_SWIER1_SWIER20_Msk
13203#define EXTI_SWIER1_SWIER21_Pos (21U)
13204#define EXTI_SWIER1_SWIER21_Msk (0x1UL << EXTI_SWIER1_SWIER21_Pos)
13205#define EXTI_SWIER1_SWIER21 EXTI_SWIER1_SWIER21_Msk
13207/****************** Bit definition for EXTI_D3PMR1 register ******************/
13208#define EXTI_D3PMR1_MR0_Pos (0U)
13209#define EXTI_D3PMR1_MR0_Msk (0x1UL << EXTI_D3PMR1_MR0_Pos)
13210#define EXTI_D3PMR1_MR0 EXTI_D3PMR1_MR0_Msk
13211#define EXTI_D3PMR1_MR1_Pos (1U)
13212#define EXTI_D3PMR1_MR1_Msk (0x1UL << EXTI_D3PMR1_MR1_Pos)
13213#define EXTI_D3PMR1_MR1 EXTI_D3PMR1_MR1_Msk
13214#define EXTI_D3PMR1_MR2_Pos (2U)
13215#define EXTI_D3PMR1_MR2_Msk (0x1UL << EXTI_D3PMR1_MR2_Pos)
13216#define EXTI_D3PMR1_MR2 EXTI_D3PMR1_MR2_Msk
13217#define EXTI_D3PMR1_MR3_Pos (3U)
13218#define EXTI_D3PMR1_MR3_Msk (0x1UL << EXTI_D3PMR1_MR3_Pos)
13219#define EXTI_D3PMR1_MR3 EXTI_D3PMR1_MR3_Msk
13220#define EXTI_D3PMR1_MR4_Pos (4U)
13221#define EXTI_D3PMR1_MR4_Msk (0x1UL << EXTI_D3PMR1_MR4_Pos)
13222#define EXTI_D3PMR1_MR4 EXTI_D3PMR1_MR4_Msk
13223#define EXTI_D3PMR1_MR5_Pos (5U)
13224#define EXTI_D3PMR1_MR5_Msk (0x1UL << EXTI_D3PMR1_MR5_Pos)
13225#define EXTI_D3PMR1_MR5 EXTI_D3PMR1_MR5_Msk
13226#define EXTI_D3PMR1_MR6_Pos (6U)
13227#define EXTI_D3PMR1_MR6_Msk (0x1UL << EXTI_D3PMR1_MR6_Pos)
13228#define EXTI_D3PMR1_MR6 EXTI_D3PMR1_MR6_Msk
13229#define EXTI_D3PMR1_MR7_Pos (7U)
13230#define EXTI_D3PMR1_MR7_Msk (0x1UL << EXTI_D3PMR1_MR7_Pos)
13231#define EXTI_D3PMR1_MR7 EXTI_D3PMR1_MR7_Msk
13232#define EXTI_D3PMR1_MR8_Pos (8U)
13233#define EXTI_D3PMR1_MR8_Msk (0x1UL << EXTI_D3PMR1_MR8_Pos)
13234#define EXTI_D3PMR1_MR8 EXTI_D3PMR1_MR8_Msk
13235#define EXTI_D3PMR1_MR9_Pos (9U)
13236#define EXTI_D3PMR1_MR9_Msk (0x1UL << EXTI_D3PMR1_MR9_Pos)
13237#define EXTI_D3PMR1_MR9 EXTI_D3PMR1_MR9_Msk
13238#define EXTI_D3PMR1_MR10_Pos (10U)
13239#define EXTI_D3PMR1_MR10_Msk (0x1UL << EXTI_D3PMR1_MR10_Pos)
13240#define EXTI_D3PMR1_MR10 EXTI_D3PMR1_MR10_Msk
13241#define EXTI_D3PMR1_MR11_Pos (11U)
13242#define EXTI_D3PMR1_MR11_Msk (0x1UL << EXTI_D3PMR1_MR11_Pos)
13243#define EXTI_D3PMR1_MR11 EXTI_D3PMR1_MR11_Msk
13244#define EXTI_D3PMR1_MR12_Pos (12U)
13245#define EXTI_D3PMR1_MR12_Msk (0x1UL << EXTI_D3PMR1_MR12_Pos)
13246#define EXTI_D3PMR1_MR12 EXTI_D3PMR1_MR12_Msk
13247#define EXTI_D3PMR1_MR13_Pos (13U)
13248#define EXTI_D3PMR1_MR13_Msk (0x1UL << EXTI_D3PMR1_MR13_Pos)
13249#define EXTI_D3PMR1_MR13 EXTI_D3PMR1_MR13_Msk
13250#define EXTI_D3PMR1_MR14_Pos (14U)
13251#define EXTI_D3PMR1_MR14_Msk (0x1UL << EXTI_D3PMR1_MR14_Pos)
13252#define EXTI_D3PMR1_MR14 EXTI_D3PMR1_MR14_Msk
13253#define EXTI_D3PMR1_MR15_Pos (15U)
13254#define EXTI_D3PMR1_MR15_Msk (0x1UL << EXTI_D3PMR1_MR15_Pos)
13255#define EXTI_D3PMR1_MR15 EXTI_D3PMR1_MR15_Msk
13256#define EXTI_D3PMR1_MR19_Pos (19U)
13257#define EXTI_D3PMR1_MR19_Msk (0x1UL << EXTI_D3PMR1_MR19_Pos)
13258#define EXTI_D3PMR1_MR19 EXTI_D3PMR1_MR19_Msk
13259#define EXTI_D3PMR1_MR20_Pos (20U)
13260#define EXTI_D3PMR1_MR20_Msk (0x1UL << EXTI_D3PMR1_MR20_Pos)
13261#define EXTI_D3PMR1_MR20 EXTI_D3PMR1_MR20_Msk
13262#define EXTI_D3PMR1_MR21_Pos (21U)
13263#define EXTI_D3PMR1_MR21_Msk (0x1UL << EXTI_D3PMR1_MR21_Pos)
13264#define EXTI_D3PMR1_MR21 EXTI_D3PMR1_MR21_Msk
13265#define EXTI_D3PMR1_MR25_Pos (24U)
13266#define EXTI_D3PMR1_MR25_Msk (0x1UL << EXTI_D3PMR1_MR25_Pos)
13267#define EXTI_D3PMR1_MR25 EXTI_D3PMR1_MR25_Msk
13269/******************* Bit definition for EXTI_D3PCR1L register ****************/
13270#define EXTI_D3PCR1L_PCS0_Pos (0U)
13271#define EXTI_D3PCR1L_PCS0_Msk (0x3UL << EXTI_D3PCR1L_PCS0_Pos)
13272#define EXTI_D3PCR1L_PCS0 EXTI_D3PCR1L_PCS0_Msk
13273#define EXTI_D3PCR1L_PCS1_Pos (2U)
13274#define EXTI_D3PCR1L_PCS1_Msk (0x3UL << EXTI_D3PCR1L_PCS1_Pos)
13275#define EXTI_D3PCR1L_PCS1 EXTI_D3PCR1L_PCS1_Msk
13276#define EXTI_D3PCR1L_PCS2_Pos (4U)
13277#define EXTI_D3PCR1L_PCS2_Msk (0x3UL << EXTI_D3PCR1L_PCS2_Pos)
13278#define EXTI_D3PCR1L_PCS2 EXTI_D3PCR1L_PCS2_Msk
13279#define EXTI_D3PCR1L_PCS3_Pos (6U)
13280#define EXTI_D3PCR1L_PCS3_Msk (0x3UL << EXTI_D3PCR1L_PCS3_Pos)
13281#define EXTI_D3PCR1L_PCS3 EXTI_D3PCR1L_PCS3_Msk
13282#define EXTI_D3PCR1L_PCS4_Pos (8U)
13283#define EXTI_D3PCR1L_PCS4_Msk (0x3UL << EXTI_D3PCR1L_PCS4_Pos)
13284#define EXTI_D3PCR1L_PCS4 EXTI_D3PCR1L_PCS4_Msk
13285#define EXTI_D3PCR1L_PCS5_Pos (10U)
13286#define EXTI_D3PCR1L_PCS5_Msk (0x3UL << EXTI_D3PCR1L_PCS5_Pos)
13287#define EXTI_D3PCR1L_PCS5 EXTI_D3PCR1L_PCS5_Msk
13288#define EXTI_D3PCR1L_PCS6_Pos (12U)
13289#define EXTI_D3PCR1L_PCS6_Msk (0x3UL << EXTI_D3PCR1L_PCS6_Pos)
13290#define EXTI_D3PCR1L_PCS6 EXTI_D3PCR1L_PCS6_Msk
13291#define EXTI_D3PCR1L_PCS7_Pos (14U)
13292#define EXTI_D3PCR1L_PCS7_Msk (0x3UL << EXTI_D3PCR1L_PCS7_Pos)
13293#define EXTI_D3PCR1L_PCS7 EXTI_D3PCR1L_PCS7_Msk
13294#define EXTI_D3PCR1L_PCS8_Pos (16U)
13295#define EXTI_D3PCR1L_PCS8_Msk (0x3UL << EXTI_D3PCR1L_PCS8_Pos)
13296#define EXTI_D3PCR1L_PCS8 EXTI_D3PCR1L_PCS8_Msk
13297#define EXTI_D3PCR1L_PCS9_Pos (18U)
13298#define EXTI_D3PCR1L_PCS9_Msk (0x3UL << EXTI_D3PCR1L_PCS9_Pos)
13299#define EXTI_D3PCR1L_PCS9 EXTI_D3PCR1L_PCS9_Msk
13300#define EXTI_D3PCR1L_PCS10_Pos (20U)
13301#define EXTI_D3PCR1L_PCS10_Msk (0x3UL << EXTI_D3PCR1L_PCS10_Pos)
13302#define EXTI_D3PCR1L_PCS10 EXTI_D3PCR1L_PCS10_Msk
13303#define EXTI_D3PCR1L_PCS11_Pos (22U)
13304#define EXTI_D3PCR1L_PCS11_Msk (0x3UL << EXTI_D3PCR1L_PCS11_Pos)
13305#define EXTI_D3PCR1L_PCS11 EXTI_D3PCR1L_PCS11_Msk
13306#define EXTI_D3PCR1L_PCS12_Pos (24U)
13307#define EXTI_D3PCR1L_PCS12_Msk (0x3UL << EXTI_D3PCR1L_PCS12_Pos)
13308#define EXTI_D3PCR1L_PCS12 EXTI_D3PCR1L_PCS12_Msk
13309#define EXTI_D3PCR1L_PCS13_Pos (26U)
13310#define EXTI_D3PCR1L_PCS13_Msk (0x3UL << EXTI_D3PCR1L_PCS13_Pos)
13311#define EXTI_D3PCR1L_PCS13 EXTI_D3PCR1L_PCS13_Msk
13312#define EXTI_D3PCR1L_PCS14_Pos (28U)
13313#define EXTI_D3PCR1L_PCS14_Msk (0x3UL << EXTI_D3PCR1L_PCS14_Pos)
13314#define EXTI_D3PCR1L_PCS14 EXTI_D3PCR1L_PCS14_Msk
13315#define EXTI_D3PCR1L_PCS15_Pos (30U)
13316#define EXTI_D3PCR1L_PCS15_Msk (0x3UL << EXTI_D3PCR1L_PCS15_Pos)
13317#define EXTI_D3PCR1L_PCS15 EXTI_D3PCR1L_PCS15_Msk
13319/******************* Bit definition for EXTI_D3PCR1H register ****************/
13320#define EXTI_D3PCR1H_PCS19_Pos (6U)
13321#define EXTI_D3PCR1H_PCS19_Msk (0x3UL << EXTI_D3PCR1H_PCS19_Pos)
13322#define EXTI_D3PCR1H_PCS19 EXTI_D3PCR1H_PCS19_Msk
13323#define EXTI_D3PCR1H_PCS20_Pos (8U)
13324#define EXTI_D3PCR1H_PCS20_Msk (0x3UL << EXTI_D3PCR1H_PCS20_Pos)
13325#define EXTI_D3PCR1H_PCS20 EXTI_D3PCR1H_PCS20_Msk
13326#define EXTI_D3PCR1H_PCS21_Pos (10U)
13327#define EXTI_D3PCR1H_PCS21_Msk (0x3UL << EXTI_D3PCR1H_PCS21_Pos)
13328#define EXTI_D3PCR1H_PCS21 EXTI_D3PCR1H_PCS21_Msk
13329#define EXTI_D3PCR1H_PCS25_Pos (18U)
13330#define EXTI_D3PCR1H_PCS25_Msk (0x3UL << EXTI_D3PCR1H_PCS25_Pos)
13331#define EXTI_D3PCR1H_PCS25 EXTI_D3PCR1H_PCS25_Msk
13333/****************** Bit definition for EXTI_RTSR2 register *******************/
13334#define EXTI_RTSR2_TR_Pos (17U)
13335#define EXTI_RTSR2_TR_Msk (0x5UL << EXTI_RTSR2_TR_Pos)
13336#define EXTI_RTSR2_TR EXTI_RTSR2_TR_Msk
13337#define EXTI_RTSR2_TR49_Pos (17U)
13338#define EXTI_RTSR2_TR49_Msk (0x1UL << EXTI_RTSR2_TR49_Pos)
13339#define EXTI_RTSR2_TR49 EXTI_RTSR2_TR49_Msk
13340#define EXTI_RTSR2_TR51_Pos (19U)
13341#define EXTI_RTSR2_TR51_Msk (0x1UL << EXTI_RTSR2_TR51_Pos)
13342#define EXTI_RTSR2_TR51 EXTI_RTSR2_TR51_Msk
13344/****************** Bit definition for EXTI_FTSR2 register *******************/
13345#define EXTI_FTSR2_TR_Pos (17U)
13346#define EXTI_FTSR2_TR_Msk (0x5UL << EXTI_FTSR2_TR_Pos)
13347#define EXTI_FTSR2_TR EXTI_FTSR2_TR_Msk
13348#define EXTI_FTSR2_TR49_Pos (17U)
13349#define EXTI_FTSR2_TR49_Msk (0x1UL << EXTI_FTSR2_TR49_Pos)
13350#define EXTI_FTSR2_TR49 EXTI_FTSR2_TR49_Msk
13351#define EXTI_FTSR2_TR51_Pos (19U)
13352#define EXTI_FTSR2_TR51_Msk (0x1UL << EXTI_FTSR2_TR51_Pos)
13353#define EXTI_FTSR2_TR51 EXTI_FTSR2_TR51_Msk
13355/****************** Bit definition for EXTI_SWIER2 register ******************/
13356#define EXTI_SWIER2_SWIER49_Pos (17U)
13357#define EXTI_SWIER2_SWIER49_Msk (0x1UL << EXTI_SWIER2_SWIER49_Pos)
13358#define EXTI_SWIER2_SWIER49 EXTI_SWIER2_SWIER49_Msk
13359#define EXTI_SWIER2_SWIER51_Pos (19U)
13360#define EXTI_SWIER2_SWIER51_Msk (0x1UL << EXTI_SWIER2_SWIER51_Pos)
13361#define EXTI_SWIER2_SWIER51 EXTI_SWIER2_SWIER51_Msk
13363/****************** Bit definition for EXTI_D3PMR2 register ******************/
13364#define EXTI_D3PMR2_MR34_Pos (2U)
13365#define EXTI_D3PMR2_MR34_Msk (0x1UL << EXTI_D3PMR2_MR34_Pos)
13366#define EXTI_D3PMR2_MR34 EXTI_D3PMR2_MR34_Msk
13367#define EXTI_D3PMR2_MR35_Pos (3U)
13368#define EXTI_D3PMR2_MR35_Msk (0x1UL << EXTI_D3PMR2_MR35_Pos)
13369#define EXTI_D3PMR2_MR35 EXTI_D3PMR2_MR35_Msk
13370#define EXTI_D3PMR2_MR41_Pos (9U)
13371#define EXTI_D3PMR2_MR41_Msk (0x1UL << EXTI_D3PMR2_MR41_Pos)
13372#define EXTI_D3PMR2_MR41 EXTI_D3PMR2_MR41_Msk
13373#define EXTI_D3PMR2_MR48_Pos (16U)
13374#define EXTI_D3PMR2_MR48_Msk (0x1UL << EXTI_D3PMR2_MR48_Pos)
13375#define EXTI_D3PMR2_MR48 EXTI_D3PMR2_MR48_Msk
13376#define EXTI_D3PMR2_MR49_Pos (17U)
13377#define EXTI_D3PMR2_MR49_Msk (0x1UL << EXTI_D3PMR2_MR49_Pos)
13378#define EXTI_D3PMR2_MR49 EXTI_D3PMR2_MR49_Msk
13379#define EXTI_D3PMR2_MR50_Pos (18U)
13380#define EXTI_D3PMR2_MR50_Msk (0x1UL << EXTI_D3PMR2_MR50_Pos)
13381#define EXTI_D3PMR2_MR50 EXTI_D3PMR2_MR50_Msk
13382#define EXTI_D3PMR2_MR51_Pos (19U)
13383#define EXTI_D3PMR2_MR51_Msk (0x1UL << EXTI_D3PMR2_MR51_Pos)
13384#define EXTI_D3PMR2_MR51 EXTI_D3PMR2_MR51_Msk
13385#define EXTI_D3PMR2_MR52_Pos (20U)
13386#define EXTI_D3PMR2_MR52_Msk (0x1UL << EXTI_D3PMR2_MR52_Pos)
13387#define EXTI_D3PMR2_MR52 EXTI_D3PMR2_MR52_Msk
13388#define EXTI_D3PMR2_MR53_Pos (21U)
13389#define EXTI_D3PMR2_MR53_Msk (0x1UL << EXTI_D3PMR2_MR53_Pos)
13390#define EXTI_D3PMR2_MR53 EXTI_D3PMR2_MR53_Msk
13391/******************* Bit definition for EXTI_D3PCR2L register ****************/
13392#define EXTI_D3PCR2L_PCS34_Pos (4U)
13393#define EXTI_D3PCR2L_PCS34_Msk (0x3UL << EXTI_D3PCR2L_PCS34_Pos)
13394#define EXTI_D3PCR2L_PCS34 EXTI_D3PCR2L_PCS34_Msk
13395#define EXTI_D3PCR2L_PCS35_Pos (6U)
13396#define EXTI_D3PCR2L_PCS35_Msk (0x3UL << EXTI_D3PCR2L_PCS35_Pos)
13397#define EXTI_D3PCR2L_PCS35 EXTI_D3PCR2L_PCS35_Msk
13398#define EXTI_D3PCR2L_PCS41_Pos (18U)
13399#define EXTI_D3PCR2L_PCS41_Msk (0x3UL << EXTI_D3PCR2L_PCS41_Pos)
13400#define EXTI_D3PCR2L_PCS41 EXTI_D3PCR2L_PCS41_Msk
13403/******************* Bit definition for EXTI_D3PCR2H register ****************/
13404#define EXTI_D3PCR2H_PCS48_Pos (0U)
13405#define EXTI_D3PCR2H_PCS48_Msk (0x3UL << EXTI_D3PCR2H_PCS48_Pos)
13406#define EXTI_D3PCR2H_PCS48 EXTI_D3PCR2H_PCS48_Msk
13407#define EXTI_D3PCR2H_PCS49_Pos (2U)
13408#define EXTI_D3PCR2H_PCS49_Msk (0x3UL << EXTI_D3PCR2H_PCS49_Pos)
13409#define EXTI_D3PCR2H_PCS49 EXTI_D3PCR2H_PCS49_Msk
13410#define EXTI_D3PCR2H_PCS50_Pos (4U)
13411#define EXTI_D3PCR2H_PCS50_Msk (0x3UL << EXTI_D3PCR2H_PCS50_Pos)
13412#define EXTI_D3PCR2H_PCS50 EXTI_D3PCR2H_PCS50_Msk
13413#define EXTI_D3PCR2H_PCS51_Pos (6U)
13414#define EXTI_D3PCR2H_PCS51_Msk (0x3UL << EXTI_D3PCR2H_PCS51_Pos)
13415#define EXTI_D3PCR2H_PCS51 EXTI_D3PCR2H_PCS51_Msk
13416#define EXTI_D3PCR2H_PCS52_Pos (8U)
13417#define EXTI_D3PCR2H_PCS52_Msk (0x3UL << EXTI_D3PCR2H_PCS52_Pos)
13418#define EXTI_D3PCR2H_PCS52 EXTI_D3PCR2H_PCS52_Msk
13419#define EXTI_D3PCR2H_PCS53_Pos (10U)
13420#define EXTI_D3PCR2H_PCS53_Msk (0x3UL << EXTI_D3PCR2H_PCS53_Pos)
13421#define EXTI_D3PCR2H_PCS53 EXTI_D3PCR2H_PCS53_Msk
13422/****************** Bit definition for EXTI_RTSR3 register *******************/
13423#define EXTI_RTSR3_TR_Pos (18U)
13424#define EXTI_RTSR3_TR_Msk (0x1DUL << EXTI_RTSR3_TR_Pos)
13425#define EXTI_RTSR3_TR EXTI_RTSR3_TR_Msk
13426#define EXTI_RTSR3_TR82_Pos (18U)
13427#define EXTI_RTSR3_TR82_Msk (0x1UL << EXTI_RTSR3_TR82_Pos)
13428#define EXTI_RTSR3_TR82 EXTI_RTSR3_TR82_Msk
13429#define EXTI_RTSR3_TR84_Pos (20U)
13430#define EXTI_RTSR3_TR84_Msk (0x1UL << EXTI_RTSR3_TR84_Pos)
13431#define EXTI_RTSR3_TR84 EXTI_RTSR3_TR84_Msk
13432#define EXTI_RTSR3_TR85_Pos (21U)
13433#define EXTI_RTSR3_TR85_Msk (0x1UL << EXTI_RTSR3_TR85_Pos)
13434#define EXTI_RTSR3_TR85 EXTI_RTSR3_TR85_Msk
13435#define EXTI_RTSR3_TR86_Pos (22U)
13436#define EXTI_RTSR3_TR86_Msk (0x1UL << EXTI_RTSR3_TR86_Pos)
13437#define EXTI_RTSR3_TR86 EXTI_RTSR3_TR86_Msk
13439/****************** Bit definition for EXTI_FTSR3 register *******************/
13440#define EXTI_FTSR3_TR_Pos (18U)
13441#define EXTI_FTSR3_TR_Msk (0x1DUL << EXTI_FTSR3_TR_Pos)
13442#define EXTI_FTSR3_TR EXTI_FTSR3_TR_Msk
13443#define EXTI_FTSR3_TR82_Pos (18U)
13444#define EXTI_FTSR3_TR82_Msk (0x1UL << EXTI_FTSR3_TR82_Pos)
13445#define EXTI_FTSR3_TR82 EXTI_FTSR3_TR82_Msk
13446#define EXTI_FTSR3_TR84_Pos (20U)
13447#define EXTI_FTSR3_TR84_Msk (0x1UL << EXTI_FTSR3_TR84_Pos)
13448#define EXTI_FTSR3_TR84 EXTI_FTSR3_TR84_Msk
13449#define EXTI_FTSR3_TR85_Pos (21U)
13450#define EXTI_FTSR3_TR85_Msk (0x1UL << EXTI_FTSR3_TR85_Pos)
13451#define EXTI_FTSR3_TR85 EXTI_FTSR3_TR85_Msk
13452#define EXTI_FTSR3_TR86_Pos (22U)
13453#define EXTI_FTSR3_TR86_Msk (0x1UL << EXTI_FTSR3_TR86_Pos)
13454#define EXTI_FTSR3_TR86 EXTI_FTSR3_TR86_Msk
13456/****************** Bit definition for EXTI_SWIER3 register ******************/
13457#define EXTI_SWIER3_SWI_Pos (18U)
13458#define EXTI_SWIER3_SWI_Msk (0x1DUL << EXTI_SWIER3_SWI_Pos)
13459#define EXTI_SWIER3_SWI EXTI_SWIER3_SWI_Msk
13460#define EXTI_SWIER3_SWIER82_Pos (18U)
13461#define EXTI_SWIER3_SWIER82_Msk (0x1UL << EXTI_SWIER3_SWIER82_Pos)
13462#define EXTI_SWIER3_SWIER82 EXTI_SWIER3_SWIER82_Msk
13463#define EXTI_SWIER3_SWIER84_Pos (20U)
13464#define EXTI_SWIER3_SWIER84_Msk (0x1UL << EXTI_SWIER3_SWIER84_Pos)
13465#define EXTI_SWIER3_SWIER84 EXTI_SWIER3_SWIER84_Msk
13466#define EXTI_SWIER3_SWIER85_Pos (21U)
13467#define EXTI_SWIER3_SWIER85_Msk (0x1UL << EXTI_SWIER3_SWIER85_Pos)
13468#define EXTI_SWIER3_SWIER85 EXTI_SWIER3_SWIER85_Msk
13469#define EXTI_SWIER3_SWIER86_Pos (22U)
13470#define EXTI_SWIER3_SWIER86_Msk (0x1UL << EXTI_SWIER3_SWIER86_Pos)
13471#define EXTI_SWIER3_SWIER86 EXTI_SWIER3_SWIER86_Msk
13473/******************* Bit definition for EXTI_IMR1 register *******************/
13474#define EXTI_IMR1_IM_Pos (0U)
13475#define EXTI_IMR1_IM_Msk (0xFFFFFFFFUL << EXTI_IMR1_IM_Pos)
13476#define EXTI_IMR1_IM EXTI_IMR1_IM_Msk
13477#define EXTI_IMR1_IM0_Pos (0U)
13478#define EXTI_IMR1_IM0_Msk (0x1UL << EXTI_IMR1_IM0_Pos)
13479#define EXTI_IMR1_IM0 EXTI_IMR1_IM0_Msk
13480#define EXTI_IMR1_IM1_Pos (1U)
13481#define EXTI_IMR1_IM1_Msk (0x1UL << EXTI_IMR1_IM1_Pos)
13482#define EXTI_IMR1_IM1 EXTI_IMR1_IM1_Msk
13483#define EXTI_IMR1_IM2_Pos (2U)
13484#define EXTI_IMR1_IM2_Msk (0x1UL << EXTI_IMR1_IM2_Pos)
13485#define EXTI_IMR1_IM2 EXTI_IMR1_IM2_Msk
13486#define EXTI_IMR1_IM3_Pos (3U)
13487#define EXTI_IMR1_IM3_Msk (0x1UL << EXTI_IMR1_IM3_Pos)
13488#define EXTI_IMR1_IM3 EXTI_IMR1_IM3_Msk
13489#define EXTI_IMR1_IM4_Pos (4U)
13490#define EXTI_IMR1_IM4_Msk (0x1UL << EXTI_IMR1_IM4_Pos)
13491#define EXTI_IMR1_IM4 EXTI_IMR1_IM4_Msk
13492#define EXTI_IMR1_IM5_Pos (5U)
13493#define EXTI_IMR1_IM5_Msk (0x1UL << EXTI_IMR1_IM5_Pos)
13494#define EXTI_IMR1_IM5 EXTI_IMR1_IM5_Msk
13495#define EXTI_IMR1_IM6_Pos (6U)
13496#define EXTI_IMR1_IM6_Msk (0x1UL << EXTI_IMR1_IM6_Pos)
13497#define EXTI_IMR1_IM6 EXTI_IMR1_IM6_Msk
13498#define EXTI_IMR1_IM7_Pos (7U)
13499#define EXTI_IMR1_IM7_Msk (0x1UL << EXTI_IMR1_IM7_Pos)
13500#define EXTI_IMR1_IM7 EXTI_IMR1_IM7_Msk
13501#define EXTI_IMR1_IM8_Pos (8U)
13502#define EXTI_IMR1_IM8_Msk (0x1UL << EXTI_IMR1_IM8_Pos)
13503#define EXTI_IMR1_IM8 EXTI_IMR1_IM8_Msk
13504#define EXTI_IMR1_IM9_Pos (9U)
13505#define EXTI_IMR1_IM9_Msk (0x1UL << EXTI_IMR1_IM9_Pos)
13506#define EXTI_IMR1_IM9 EXTI_IMR1_IM9_Msk
13507#define EXTI_IMR1_IM10_Pos (10U)
13508#define EXTI_IMR1_IM10_Msk (0x1UL << EXTI_IMR1_IM10_Pos)
13509#define EXTI_IMR1_IM10 EXTI_IMR1_IM10_Msk
13510#define EXTI_IMR1_IM11_Pos (11U)
13511#define EXTI_IMR1_IM11_Msk (0x1UL << EXTI_IMR1_IM11_Pos)
13512#define EXTI_IMR1_IM11 EXTI_IMR1_IM11_Msk
13513#define EXTI_IMR1_IM12_Pos (12U)
13514#define EXTI_IMR1_IM12_Msk (0x1UL << EXTI_IMR1_IM12_Pos)
13515#define EXTI_IMR1_IM12 EXTI_IMR1_IM12_Msk
13516#define EXTI_IMR1_IM13_Pos (13U)
13517#define EXTI_IMR1_IM13_Msk (0x1UL << EXTI_IMR1_IM13_Pos)
13518#define EXTI_IMR1_IM13 EXTI_IMR1_IM13_Msk
13519#define EXTI_IMR1_IM14_Pos (14U)
13520#define EXTI_IMR1_IM14_Msk (0x1UL << EXTI_IMR1_IM14_Pos)
13521#define EXTI_IMR1_IM14 EXTI_IMR1_IM14_Msk
13522#define EXTI_IMR1_IM15_Pos (15U)
13523#define EXTI_IMR1_IM15_Msk (0x1UL << EXTI_IMR1_IM15_Pos)
13524#define EXTI_IMR1_IM15 EXTI_IMR1_IM15_Msk
13525#define EXTI_IMR1_IM16_Pos (16U)
13526#define EXTI_IMR1_IM16_Msk (0x1UL << EXTI_IMR1_IM16_Pos)
13527#define EXTI_IMR1_IM16 EXTI_IMR1_IM16_Msk
13528#define EXTI_IMR1_IM17_Pos (17U)
13529#define EXTI_IMR1_IM17_Msk (0x1UL << EXTI_IMR1_IM17_Pos)
13530#define EXTI_IMR1_IM17 EXTI_IMR1_IM17_Msk
13531#define EXTI_IMR1_IM18_Pos (18U)
13532#define EXTI_IMR1_IM18_Msk (0x1UL << EXTI_IMR1_IM18_Pos)
13533#define EXTI_IMR1_IM18 EXTI_IMR1_IM18_Msk
13534#define EXTI_IMR1_IM19_Pos (19U)
13535#define EXTI_IMR1_IM19_Msk (0x1UL << EXTI_IMR1_IM19_Pos)
13536#define EXTI_IMR1_IM19 EXTI_IMR1_IM19_Msk
13537#define EXTI_IMR1_IM20_Pos (20U)
13538#define EXTI_IMR1_IM20_Msk (0x1UL << EXTI_IMR1_IM20_Pos)
13539#define EXTI_IMR1_IM20 EXTI_IMR1_IM20_Msk
13540#define EXTI_IMR1_IM21_Pos (21U)
13541#define EXTI_IMR1_IM21_Msk (0x1UL << EXTI_IMR1_IM21_Pos)
13542#define EXTI_IMR1_IM21 EXTI_IMR1_IM21_Msk
13543#define EXTI_IMR1_IM22_Pos (22U)
13544#define EXTI_IMR1_IM22_Msk (0x1UL << EXTI_IMR1_IM22_Pos)
13545#define EXTI_IMR1_IM22 EXTI_IMR1_IM22_Msk
13546#define EXTI_IMR1_IM23_Pos (23U)
13547#define EXTI_IMR1_IM23_Msk (0x1UL << EXTI_IMR1_IM23_Pos)
13548#define EXTI_IMR1_IM23 EXTI_IMR1_IM23_Msk
13549#define EXTI_IMR1_IM24_Pos (24U)
13550#define EXTI_IMR1_IM24_Msk (0x1UL << EXTI_IMR1_IM24_Pos)
13551#define EXTI_IMR1_IM24 EXTI_IMR1_IM24_Msk
13552#define EXTI_IMR1_IM25_Pos (25U)
13553#define EXTI_IMR1_IM25_Msk (0x1UL << EXTI_IMR1_IM25_Pos)
13554#define EXTI_IMR1_IM25 EXTI_IMR1_IM25_Msk
13555#define EXTI_IMR1_IM26_Pos (26U)
13556#define EXTI_IMR1_IM26_Msk (0x1UL << EXTI_IMR1_IM26_Pos)
13557#define EXTI_IMR1_IM26 EXTI_IMR1_IM26_Msk
13558#define EXTI_IMR1_IM27_Pos (27U)
13559#define EXTI_IMR1_IM27_Msk (0x1UL << EXTI_IMR1_IM27_Pos)
13560#define EXTI_IMR1_IM27 EXTI_IMR1_IM27_Msk
13561#define EXTI_IMR1_IM28_Pos (28U)
13562#define EXTI_IMR1_IM28_Msk (0x1UL << EXTI_IMR1_IM28_Pos)
13563#define EXTI_IMR1_IM28 EXTI_IMR1_IM28_Msk
13564#define EXTI_IMR1_IM29_Pos (29U)
13565#define EXTI_IMR1_IM29_Msk (0x1UL << EXTI_IMR1_IM29_Pos)
13566#define EXTI_IMR1_IM29 EXTI_IMR1_IM29_Msk
13567#define EXTI_IMR1_IM30_Pos (30U)
13568#define EXTI_IMR1_IM30_Msk (0x1UL << EXTI_IMR1_IM30_Pos)
13569#define EXTI_IMR1_IM30 EXTI_IMR1_IM30_Msk
13570#define EXTI_IMR1_IM31_Pos (31U)
13571#define EXTI_IMR1_IM31_Msk (0x1UL << EXTI_IMR1_IM31_Pos)
13572#define EXTI_IMR1_IM31 EXTI_IMR1_IM31_Msk
13574/******************* Bit definition for EXTI_EMR1 register *******************/
13575#define EXTI_EMR1_EM_Pos (0U)
13576#define EXTI_EMR1_EM_Msk (0xFFFFFFFFUL << EXTI_EMR1_EM_Pos)
13577#define EXTI_EMR1_EM EXTI_EMR1_EM_Msk
13578#define EXTI_EMR1_EM0_Pos (0U)
13579#define EXTI_EMR1_EM0_Msk (0x1UL << EXTI_EMR1_EM0_Pos)
13580#define EXTI_EMR1_EM0 EXTI_EMR1_EM0_Msk
13581#define EXTI_EMR1_EM1_Pos (1U)
13582#define EXTI_EMR1_EM1_Msk (0x1UL << EXTI_EMR1_EM1_Pos)
13583#define EXTI_EMR1_EM1 EXTI_EMR1_EM1_Msk
13584#define EXTI_EMR1_EM2_Pos (2U)
13585#define EXTI_EMR1_EM2_Msk (0x1UL << EXTI_EMR1_EM2_Pos)
13586#define EXTI_EMR1_EM2 EXTI_EMR1_EM2_Msk
13587#define EXTI_EMR1_EM3_Pos (3U)
13588#define EXTI_EMR1_EM3_Msk (0x1UL << EXTI_EMR1_EM3_Pos)
13589#define EXTI_EMR1_EM3 EXTI_EMR1_EM3_Msk
13590#define EXTI_EMR1_EM4_Pos (4U)
13591#define EXTI_EMR1_EM4_Msk (0x1UL << EXTI_EMR1_EM4_Pos)
13592#define EXTI_EMR1_EM4 EXTI_EMR1_EM4_Msk
13593#define EXTI_EMR1_EM5_Pos (5U)
13594#define EXTI_EMR1_EM5_Msk (0x1UL << EXTI_EMR1_EM5_Pos)
13595#define EXTI_EMR1_EM5 EXTI_EMR1_EM5_Msk
13596#define EXTI_EMR1_EM6_Pos (6U)
13597#define EXTI_EMR1_EM6_Msk (0x1UL << EXTI_EMR1_EM6_Pos)
13598#define EXTI_EMR1_EM6 EXTI_EMR1_EM6_Msk
13599#define EXTI_EMR1_EM7_Pos (7U)
13600#define EXTI_EMR1_EM7_Msk (0x1UL << EXTI_EMR1_EM7_Pos)
13601#define EXTI_EMR1_EM7 EXTI_EMR1_EM7_Msk
13602#define EXTI_EMR1_EM8_Pos (8U)
13603#define EXTI_EMR1_EM8_Msk (0x1UL << EXTI_EMR1_EM8_Pos)
13604#define EXTI_EMR1_EM8 EXTI_EMR1_EM8_Msk
13605#define EXTI_EMR1_EM9_Pos (9U)
13606#define EXTI_EMR1_EM9_Msk (0x1UL << EXTI_EMR1_EM9_Pos)
13607#define EXTI_EMR1_EM9 EXTI_EMR1_EM9_Msk
13608#define EXTI_EMR1_EM10_Pos (10U)
13609#define EXTI_EMR1_EM10_Msk (0x1UL << EXTI_EMR1_EM10_Pos)
13610#define EXTI_EMR1_EM10 EXTI_EMR1_EM10_Msk
13611#define EXTI_EMR1_EM11_Pos (11U)
13612#define EXTI_EMR1_EM11_Msk (0x1UL << EXTI_EMR1_EM11_Pos)
13613#define EXTI_EMR1_EM11 EXTI_EMR1_EM11_Msk
13614#define EXTI_EMR1_EM12_Pos (12U)
13615#define EXTI_EMR1_EM12_Msk (0x1UL << EXTI_EMR1_EM12_Pos)
13616#define EXTI_EMR1_EM12 EXTI_EMR1_EM12_Msk
13617#define EXTI_EMR1_EM13_Pos (13U)
13618#define EXTI_EMR1_EM13_Msk (0x1UL << EXTI_EMR1_EM13_Pos)
13619#define EXTI_EMR1_EM13 EXTI_EMR1_EM13_Msk
13620#define EXTI_EMR1_EM14_Pos (14U)
13621#define EXTI_EMR1_EM14_Msk (0x1UL << EXTI_EMR1_EM14_Pos)
13622#define EXTI_EMR1_EM14 EXTI_EMR1_EM14_Msk
13623#define EXTI_EMR1_EM15_Pos (15U)
13624#define EXTI_EMR1_EM15_Msk (0x1UL << EXTI_EMR1_EM15_Pos)
13625#define EXTI_EMR1_EM15 EXTI_EMR1_EM15_Msk
13626#define EXTI_EMR1_EM16_Pos (16U)
13627#define EXTI_EMR1_EM16_Msk (0x1UL << EXTI_EMR1_EM16_Pos)
13628#define EXTI_EMR1_EM16 EXTI_EMR1_EM16_Msk
13629#define EXTI_EMR1_EM17_Pos (17U)
13630#define EXTI_EMR1_EM17_Msk (0x1UL << EXTI_EMR1_EM17_Pos)
13631#define EXTI_EMR1_EM17 EXTI_EMR1_EM17_Msk
13632#define EXTI_EMR1_EM18_Pos (18U)
13633#define EXTI_EMR1_EM18_Msk (0x1UL << EXTI_EMR1_EM18_Pos)
13634#define EXTI_EMR1_EM18 EXTI_EMR1_EM18_Msk
13635#define EXTI_EMR1_EM20_Pos (20U)
13636#define EXTI_EMR1_EM20_Msk (0x1UL << EXTI_EMR1_EM20_Pos)
13637#define EXTI_EMR1_EM20 EXTI_EMR1_EM20_Msk
13638#define EXTI_EMR1_EM21_Pos (21U)
13639#define EXTI_EMR1_EM21_Msk (0x1UL << EXTI_EMR1_EM21_Pos)
13640#define EXTI_EMR1_EM21 EXTI_EMR1_EM21_Msk
13641#define EXTI_EMR1_EM22_Pos (22U)
13642#define EXTI_EMR1_EM22_Msk (0x1UL << EXTI_EMR1_EM22_Pos)
13643#define EXTI_EMR1_EM22 EXTI_EMR1_EM22_Msk
13644#define EXTI_EMR1_EM23_Pos (23U)
13645#define EXTI_EMR1_EM23_Msk (0x1UL << EXTI_EMR1_EM23_Pos)
13646#define EXTI_EMR1_EM23 EXTI_EMR1_EM23_Msk
13647#define EXTI_EMR1_EM24_Pos (24U)
13648#define EXTI_EMR1_EM24_Msk (0x1UL << EXTI_EMR1_EM24_Pos)
13649#define EXTI_EMR1_EM24 EXTI_EMR1_EM24_Msk
13650#define EXTI_EMR1_EM25_Pos (25U)
13651#define EXTI_EMR1_EM25_Msk (0x1UL << EXTI_EMR1_EM25_Pos)
13652#define EXTI_EMR1_EM25 EXTI_EMR1_EM25_Msk
13653#define EXTI_EMR1_EM26_Pos (26U)
13654#define EXTI_EMR1_EM26_Msk (0x1UL << EXTI_EMR1_EM26_Pos)
13655#define EXTI_EMR1_EM26 EXTI_EMR1_EM26_Msk
13656#define EXTI_EMR1_EM27_Pos (27U)
13657#define EXTI_EMR1_EM27_Msk (0x1UL << EXTI_EMR1_EM27_Pos)
13658#define EXTI_EMR1_EM27 EXTI_EMR1_EM27_Msk
13659#define EXTI_EMR1_EM28_Pos (28U)
13660#define EXTI_EMR1_EM28_Msk (0x1UL << EXTI_EMR1_EM28_Pos)
13661#define EXTI_EMR1_EM28 EXTI_EMR1_EM28_Msk
13662#define EXTI_EMR1_EM29_Pos (29U)
13663#define EXTI_EMR1_EM29_Msk (0x1UL << EXTI_EMR1_EM29_Pos)
13664#define EXTI_EMR1_EM29 EXTI_EMR1_EM29_Msk
13665#define EXTI_EMR1_EM30_Pos (30U)
13666#define EXTI_EMR1_EM30_Msk (0x1UL << EXTI_EMR1_EM30_Pos)
13667#define EXTI_EMR1_EM30 EXTI_EMR1_EM30_Msk
13668#define EXTI_EMR1_EM31_Pos (31U)
13669#define EXTI_EMR1_EM31_Msk (0x1UL << EXTI_EMR1_EM31_Pos)
13670#define EXTI_EMR1_EM31 EXTI_EMR1_EM31_Msk
13672/******************* Bit definition for EXTI_PR1 register ********************/
13673#define EXTI_PR1_PR_Pos (0U)
13674#define EXTI_PR1_PR_Msk (0x3FFFFFUL << EXTI_PR1_PR_Pos)
13675#define EXTI_PR1_PR EXTI_PR1_PR_Msk
13676#define EXTI_PR1_PR0_Pos (0U)
13677#define EXTI_PR1_PR0_Msk (0x1UL << EXTI_PR1_PR0_Pos)
13678#define EXTI_PR1_PR0 EXTI_PR1_PR0_Msk
13679#define EXTI_PR1_PR1_Pos (1U)
13680#define EXTI_PR1_PR1_Msk (0x1UL << EXTI_PR1_PR1_Pos)
13681#define EXTI_PR1_PR1 EXTI_PR1_PR1_Msk
13682#define EXTI_PR1_PR2_Pos (2U)
13683#define EXTI_PR1_PR2_Msk (0x1UL << EXTI_PR1_PR2_Pos)
13684#define EXTI_PR1_PR2 EXTI_PR1_PR2_Msk
13685#define EXTI_PR1_PR3_Pos (3U)
13686#define EXTI_PR1_PR3_Msk (0x1UL << EXTI_PR1_PR3_Pos)
13687#define EXTI_PR1_PR3 EXTI_PR1_PR3_Msk
13688#define EXTI_PR1_PR4_Pos (4U)
13689#define EXTI_PR1_PR4_Msk (0x1UL << EXTI_PR1_PR4_Pos)
13690#define EXTI_PR1_PR4 EXTI_PR1_PR4_Msk
13691#define EXTI_PR1_PR5_Pos (5U)
13692#define EXTI_PR1_PR5_Msk (0x1UL << EXTI_PR1_PR5_Pos)
13693#define EXTI_PR1_PR5 EXTI_PR1_PR5_Msk
13694#define EXTI_PR1_PR6_Pos (6U)
13695#define EXTI_PR1_PR6_Msk (0x1UL << EXTI_PR1_PR6_Pos)
13696#define EXTI_PR1_PR6 EXTI_PR1_PR6_Msk
13697#define EXTI_PR1_PR7_Pos (7U)
13698#define EXTI_PR1_PR7_Msk (0x1UL << EXTI_PR1_PR7_Pos)
13699#define EXTI_PR1_PR7 EXTI_PR1_PR7_Msk
13700#define EXTI_PR1_PR8_Pos (8U)
13701#define EXTI_PR1_PR8_Msk (0x1UL << EXTI_PR1_PR8_Pos)
13702#define EXTI_PR1_PR8 EXTI_PR1_PR8_Msk
13703#define EXTI_PR1_PR9_Pos (9U)
13704#define EXTI_PR1_PR9_Msk (0x1UL << EXTI_PR1_PR9_Pos)
13705#define EXTI_PR1_PR9 EXTI_PR1_PR9_Msk
13706#define EXTI_PR1_PR10_Pos (10U)
13707#define EXTI_PR1_PR10_Msk (0x1UL << EXTI_PR1_PR10_Pos)
13708#define EXTI_PR1_PR10 EXTI_PR1_PR10_Msk
13709#define EXTI_PR1_PR11_Pos (11U)
13710#define EXTI_PR1_PR11_Msk (0x1UL << EXTI_PR1_PR11_Pos)
13711#define EXTI_PR1_PR11 EXTI_PR1_PR11_Msk
13712#define EXTI_PR1_PR12_Pos (12U)
13713#define EXTI_PR1_PR12_Msk (0x1UL << EXTI_PR1_PR12_Pos)
13714#define EXTI_PR1_PR12 EXTI_PR1_PR12_Msk
13715#define EXTI_PR1_PR13_Pos (13U)
13716#define EXTI_PR1_PR13_Msk (0x1UL << EXTI_PR1_PR13_Pos)
13717#define EXTI_PR1_PR13 EXTI_PR1_PR13_Msk
13718#define EXTI_PR1_PR14_Pos (14U)
13719#define EXTI_PR1_PR14_Msk (0x1UL << EXTI_PR1_PR14_Pos)
13720#define EXTI_PR1_PR14 EXTI_PR1_PR14_Msk
13721#define EXTI_PR1_PR15_Pos (15U)
13722#define EXTI_PR1_PR15_Msk (0x1UL << EXTI_PR1_PR15_Pos)
13723#define EXTI_PR1_PR15 EXTI_PR1_PR15_Msk
13724#define EXTI_PR1_PR16_Pos (16U)
13725#define EXTI_PR1_PR16_Msk (0x1UL << EXTI_PR1_PR16_Pos)
13726#define EXTI_PR1_PR16 EXTI_PR1_PR16_Msk
13727#define EXTI_PR1_PR17_Pos (17U)
13728#define EXTI_PR1_PR17_Msk (0x1UL << EXTI_PR1_PR17_Pos)
13729#define EXTI_PR1_PR17 EXTI_PR1_PR17_Msk
13730#define EXTI_PR1_PR18_Pos (18U)
13731#define EXTI_PR1_PR18_Msk (0x1UL << EXTI_PR1_PR18_Pos)
13732#define EXTI_PR1_PR18 EXTI_PR1_PR18_Msk
13733#define EXTI_PR1_PR19_Pos (19U)
13734#define EXTI_PR1_PR19_Msk (0x1UL << EXTI_PR1_PR19_Pos)
13735#define EXTI_PR1_PR19 EXTI_PR1_PR19_Msk
13736#define EXTI_PR1_PR20_Pos (20U)
13737#define EXTI_PR1_PR20_Msk (0x1UL << EXTI_PR1_PR20_Pos)
13738#define EXTI_PR1_PR20 EXTI_PR1_PR20_Msk
13739#define EXTI_PR1_PR21_Pos (21U)
13740#define EXTI_PR1_PR21_Msk (0x1UL << EXTI_PR1_PR21_Pos)
13741#define EXTI_PR1_PR21 EXTI_PR1_PR21_Msk
13743/******************* Bit definition for EXTI_IMR2 register *******************/
13744#define EXTI_IMR2_IM_Pos (0U)
13745#define EXTI_IMR2_IM_Msk (0xFFFFDFFFUL << EXTI_IMR2_IM_Pos)
13746#define EXTI_IMR2_IM EXTI_IMR2_IM_Msk
13747#define EXTI_IMR2_IM32_Pos (0U)
13748#define EXTI_IMR2_IM32_Msk (0x1UL << EXTI_IMR2_IM32_Pos)
13749#define EXTI_IMR2_IM32 EXTI_IMR2_IM32_Msk
13750#define EXTI_IMR2_IM33_Pos (1U)
13751#define EXTI_IMR2_IM33_Msk (0x1UL << EXTI_IMR2_IM33_Pos)
13752#define EXTI_IMR2_IM33 EXTI_IMR2_IM33_Msk
13753#define EXTI_IMR2_IM34_Pos (2U)
13754#define EXTI_IMR2_IM34_Msk (0x1UL << EXTI_IMR2_IM34_Pos)
13755#define EXTI_IMR2_IM34 EXTI_IMR2_IM34_Msk
13756#define EXTI_IMR2_IM35_Pos (3U)
13757#define EXTI_IMR2_IM35_Msk (0x1UL << EXTI_IMR2_IM35_Pos)
13758#define EXTI_IMR2_IM35 EXTI_IMR2_IM35_Msk
13759#define EXTI_IMR2_IM36_Pos (4U)
13760#define EXTI_IMR2_IM36_Msk (0x1UL << EXTI_IMR2_IM36_Pos)
13761#define EXTI_IMR2_IM36 EXTI_IMR2_IM36_Msk
13762#define EXTI_IMR2_IM37_Pos (5U)
13763#define EXTI_IMR2_IM37_Msk (0x1UL << EXTI_IMR2_IM37_Pos)
13764#define EXTI_IMR2_IM37 EXTI_IMR2_IM37_Msk
13765#define EXTI_IMR2_IM38_Pos (6U)
13766#define EXTI_IMR2_IM38_Msk (0x1UL << EXTI_IMR2_IM38_Pos)
13767#define EXTI_IMR2_IM38 EXTI_IMR2_IM38_Msk
13768#define EXTI_IMR2_IM39_Pos (7U)
13769#define EXTI_IMR2_IM39_Msk (0x1UL << EXTI_IMR2_IM39_Pos)
13770#define EXTI_IMR2_IM39 EXTI_IMR2_IM39_Msk
13771#define EXTI_IMR2_IM40_Pos (8U)
13772#define EXTI_IMR2_IM40_Msk (0x1UL << EXTI_IMR2_IM40_Pos)
13773#define EXTI_IMR2_IM40 EXTI_IMR2_IM40_Msk
13774#define EXTI_IMR2_IM41_Pos (9U)
13775#define EXTI_IMR2_IM41_Msk (0x1UL << EXTI_IMR2_IM41_Pos)
13776#define EXTI_IMR2_IM41 EXTI_IMR2_IM41_Msk
13777#define EXTI_IMR2_IM42_Pos (10U)
13778#define EXTI_IMR2_IM42_Msk (0x1UL << EXTI_IMR2_IM42_Pos)
13779#define EXTI_IMR2_IM42 EXTI_IMR2_IM42_Msk
13780#define EXTI_IMR2_IM43_Pos (11U)
13781#define EXTI_IMR2_IM43_Msk (0x1UL << EXTI_IMR2_IM43_Pos)
13782#define EXTI_IMR2_IM43 EXTI_IMR2_IM43_Msk
13783#define EXTI_IMR2_IM44_Pos (12U)
13784#define EXTI_IMR2_IM44_Msk (0x1UL << EXTI_IMR2_IM44_Pos)
13785#define EXTI_IMR2_IM44 EXTI_IMR2_IM44_Msk
13786#define EXTI_IMR2_IM46_Pos (14U)
13787#define EXTI_IMR2_IM46_Msk (0x1UL << EXTI_IMR2_IM46_Pos)
13788#define EXTI_IMR2_IM46 EXTI_IMR2_IM46_Msk
13789#define EXTI_IMR2_IM47_Pos (15U)
13790#define EXTI_IMR2_IM47_Msk (0x1UL << EXTI_IMR2_IM47_Pos)
13791#define EXTI_IMR2_IM47 EXTI_IMR2_IM47_Msk
13792#define EXTI_IMR2_IM48_Pos (16U)
13793#define EXTI_IMR2_IM48_Msk (0x1UL << EXTI_IMR2_IM48_Pos)
13794#define EXTI_IMR2_IM48 EXTI_IMR2_IM48_Msk
13795#define EXTI_IMR2_IM49_Pos (17U)
13796#define EXTI_IMR2_IM49_Msk (0x1UL << EXTI_IMR2_IM49_Pos)
13797#define EXTI_IMR2_IM49 EXTI_IMR2_IM49_Msk
13798#define EXTI_IMR2_IM50_Pos (18U)
13799#define EXTI_IMR2_IM50_Msk (0x1UL << EXTI_IMR2_IM50_Pos)
13800#define EXTI_IMR2_IM50 EXTI_IMR2_IM50_Msk
13801#define EXTI_IMR2_IM51_Pos (19U)
13802#define EXTI_IMR2_IM51_Msk (0x1UL << EXTI_IMR2_IM51_Pos)
13803#define EXTI_IMR2_IM51 EXTI_IMR2_IM51_Msk
13804#define EXTI_IMR2_IM52_Pos (20U)
13805#define EXTI_IMR2_IM52_Msk (0x1UL << EXTI_IMR2_IM52_Pos)
13806#define EXTI_IMR2_IM52 EXTI_IMR2_IM52_Msk
13807#define EXTI_IMR2_IM53_Pos (21U)
13808#define EXTI_IMR2_IM53_Msk (0x1UL << EXTI_IMR2_IM53_Pos)
13809#define EXTI_IMR2_IM53 EXTI_IMR2_IM53_Msk
13810#define EXTI_IMR2_IM54_Pos (22U)
13811#define EXTI_IMR2_IM54_Msk (0x1UL << EXTI_IMR2_IM54_Pos)
13812#define EXTI_IMR2_IM54 EXTI_IMR2_IM54_Msk
13813#define EXTI_IMR2_IM55_Pos (23U)
13814#define EXTI_IMR2_IM55_Msk (0x1UL << EXTI_IMR2_IM55_Pos)
13815#define EXTI_IMR2_IM55 EXTI_IMR2_IM55_Msk
13816#define EXTI_IMR2_IM56_Pos (24U)
13817#define EXTI_IMR2_IM56_Msk (0x1UL << EXTI_IMR2_IM56_Pos)
13818#define EXTI_IMR2_IM56 EXTI_IMR2_IM56_Msk
13819#define EXTI_IMR2_IM57_Pos (25U)
13820#define EXTI_IMR2_IM57_Msk (0x1UL << EXTI_IMR2_IM57_Pos)
13821#define EXTI_IMR2_IM57 EXTI_IMR2_IM57_Msk
13822#define EXTI_IMR2_IM58_Pos (26U)
13823#define EXTI_IMR2_IM58_Msk (0x1UL << EXTI_IMR2_IM58_Pos)
13824#define EXTI_IMR2_IM58 EXTI_IMR2_IM58_Msk
13825#define EXTI_IMR2_IM59_Pos (27U)
13826#define EXTI_IMR2_IM59_Msk (0x1UL << EXTI_IMR2_IM59_Pos)
13827#define EXTI_IMR2_IM59 EXTI_IMR2_IM59_Msk
13828#define EXTI_IMR2_IM60_Pos (28U)
13829#define EXTI_IMR2_IM60_Msk (0x1UL << EXTI_IMR2_IM60_Pos)
13830#define EXTI_IMR2_IM60 EXTI_IMR2_IM60_Msk
13831#define EXTI_IMR2_IM61_Pos (29U)
13832#define EXTI_IMR2_IM61_Msk (0x1UL << EXTI_IMR2_IM61_Pos)
13833#define EXTI_IMR2_IM61 EXTI_IMR2_IM61_Msk
13834#define EXTI_IMR2_IM62_Pos (30U)
13835#define EXTI_IMR2_IM62_Msk (0x1UL << EXTI_IMR2_IM62_Pos)
13836#define EXTI_IMR2_IM62 EXTI_IMR2_IM62_Msk
13837#define EXTI_IMR2_IM63_Pos (31U)
13838#define EXTI_IMR2_IM63_Msk (0x1UL << EXTI_IMR2_IM63_Pos)
13839#define EXTI_IMR2_IM63 EXTI_IMR2_IM63_Msk
13841/******************* Bit definition for EXTI_EMR2 register *******************/
13842#define EXTI_EMR2_EM_Pos (0U)
13843#define EXTI_EMR2_EM_Msk (0xFFFFDFFFUL << EXTI_EMR2_EM_Pos)
13844#define EXTI_EMR2_EM EXTI_EMR2_EM_Msk
13845#define EXTI_EMR2_EM32_Pos (0U)
13846#define EXTI_EMR2_EM32_Msk (0x1UL << EXTI_EMR2_EM32_Pos)
13847#define EXTI_EMR2_EM32 EXTI_EMR2_EM32_Msk
13848#define EXTI_EMR2_EM33_Pos (1U)
13849#define EXTI_EMR2_EM33_Msk (0x1UL << EXTI_EMR2_EM33_Pos)
13850#define EXTI_EMR2_EM33 EXTI_EMR2_EM33_Msk
13851#define EXTI_EMR2_EM34_Pos (2U)
13852#define EXTI_EMR2_EM34_Msk (0x1UL << EXTI_EMR2_EM34_Pos)
13853#define EXTI_EMR2_EM34 EXTI_EMR2_EM34_Msk
13854#define EXTI_EMR2_EM35_Pos (3U)
13855#define EXTI_EMR2_EM35_Msk (0x1UL << EXTI_EMR2_EM35_Pos)
13856#define EXTI_EMR2_EM35 EXTI_EMR2_EM35_Msk
13857#define EXTI_EMR2_EM36_Pos (4U)
13858#define EXTI_EMR2_EM36_Msk (0x1UL << EXTI_EMR2_EM36_Pos)
13859#define EXTI_EMR2_EM36 EXTI_EMR2_EM36_Msk
13860#define EXTI_EMR2_EM37_Pos (5U)
13861#define EXTI_EMR2_EM37_Msk (0x1UL << EXTI_EMR2_EM37_Pos)
13862#define EXTI_EMR2_EM37 EXTI_EMR2_EM37_Msk
13863#define EXTI_EMR2_EM38_Pos (6U)
13864#define EXTI_EMR2_EM38_Msk (0x1UL << EXTI_EMR2_EM38_Pos)
13865#define EXTI_EMR2_EM38 EXTI_EMR2_EM38_Msk
13866#define EXTI_EMR2_EM39_Pos (7U)
13867#define EXTI_EMR2_EM39_Msk (0x1UL << EXTI_EMR2_EM39_Pos)
13868#define EXTI_EMR2_EM39 EXTI_EMR2_EM39_Msk
13869#define EXTI_EMR2_EM40_Pos (8U)
13870#define EXTI_EMR2_EM40_Msk (0x1UL << EXTI_EMR2_EM40_Pos)
13871#define EXTI_EMR2_EM40 EXTI_EMR2_EM40_Msk
13872#define EXTI_EMR2_EM41_Pos (9U)
13873#define EXTI_EMR2_EM41_Msk (0x1UL << EXTI_EMR2_EM41_Pos)
13874#define EXTI_EMR2_EM41 EXTI_EMR2_EM41_Msk
13875#define EXTI_EMR2_EM42_Pos (10U)
13876#define EXTI_EMR2_EM42_Msk (0x1UL << EXTI_EMR2_EM42_Pos)
13877#define EXTI_EMR2_EM42 EXTI_EMR2_EM42_Msk
13878#define EXTI_EMR2_EM43_Pos (11U)
13879#define EXTI_EMR2_EM43_Msk (0x1UL << EXTI_EMR2_EM43_Pos)
13880#define EXTI_EMR2_EM43 EXTI_EMR2_EM43_Msk
13881#define EXTI_EMR2_EM44_Pos (12U)
13882#define EXTI_EMR2_EM44_Msk (0x1UL << EXTI_EMR2_EM44_Pos)
13883#define EXTI_EMR2_EM44 EXTI_EMR2_EM44_Msk
13884#define EXTI_EMR2_EM46_Pos (14U)
13885#define EXTI_EMR2_EM46_Msk (0x1UL << EXTI_EMR2_EM46_Pos)
13886#define EXTI_EMR2_EM46 EXTI_EMR2_EM46_Msk
13887#define EXTI_EMR2_EM47_Pos (15U)
13888#define EXTI_EMR2_EM47_Msk (0x1UL << EXTI_EMR2_EM47_Pos)
13889#define EXTI_EMR2_EM47 EXTI_EMR2_EM47_Msk
13890#define EXTI_EMR2_EM48_Pos (16U)
13891#define EXTI_EMR2_EM48_Msk (0x1UL << EXTI_EMR2_EM48_Pos)
13892#define EXTI_EMR2_EM48 EXTI_EMR2_EM48_Msk
13893#define EXTI_EMR2_EM49_Pos (17U)
13894#define EXTI_EMR2_EM49_Msk (0x1UL << EXTI_EMR2_EM49_Pos)
13895#define EXTI_EMR2_EM49 EXTI_EMR2_EM49_Msk
13896#define EXTI_EMR2_EM50_Pos (18U)
13897#define EXTI_EMR2_EM50_Msk (0x1UL << EXTI_EMR2_EM50_Pos)
13898#define EXTI_EMR2_EM50 EXTI_EMR2_EM50_Msk
13899#define EXTI_EMR2_EM51_Pos (19U)
13900#define EXTI_EMR2_EM51_Msk (0x1UL << EXTI_EMR2_EM51_Pos)
13901#define EXTI_EMR2_EM51 EXTI_EMR2_EM51_Msk
13902#define EXTI_EMR2_EM52_Pos (20U)
13903#define EXTI_EMR2_EM52_Msk (0x1UL << EXTI_EMR2_EM52_Pos)
13904#define EXTI_EMR2_EM52 EXTI_EMR2_EM52_Msk
13905#define EXTI_EMR2_EM53_Pos (21U)
13906#define EXTI_EMR2_EM53_Msk (0x1UL << EXTI_EMR2_EM53_Pos)
13907#define EXTI_EMR2_EM53 EXTI_EMR2_EM53_Msk
13908#define EXTI_EMR2_EM54_Pos (22U)
13909#define EXTI_EMR2_EM54_Msk (0x1UL << EXTI_EMR2_EM54_Pos)
13910#define EXTI_EMR2_EM54 EXTI_EMR2_EM54_Msk
13911#define EXTI_EMR2_EM55_Pos (23U)
13912#define EXTI_EMR2_EM55_Msk (0x1UL << EXTI_EMR2_EM55_Pos)
13913#define EXTI_EMR2_EM55 EXTI_EMR2_EM55_Msk
13914#define EXTI_EMR2_EM56_Pos (24U)
13915#define EXTI_EMR2_EM56_Msk (0x1UL << EXTI_EMR2_EM56_Pos)
13916#define EXTI_EMR2_EM56 EXTI_EMR2_EM56_Msk
13917#define EXTI_EMR2_EM57_Pos (25U)
13918#define EXTI_EMR2_EM57_Msk (0x1UL << EXTI_EMR2_EM57_Pos)
13919#define EXTI_EMR2_EM57 EXTI_EMR2_EM57_Msk
13920#define EXTI_EMR2_EM58_Pos (26U)
13921#define EXTI_EMR2_EM58_Msk (0x1UL << EXTI_EMR2_EM58_Pos)
13922#define EXTI_EMR2_EM58 EXTI_EMR2_EM58_Msk
13923#define EXTI_EMR2_EM59_Pos (27U)
13924#define EXTI_EMR2_EM59_Msk (0x1UL << EXTI_EMR2_EM59_Pos)
13925#define EXTI_EMR2_EM59 EXTI_EMR2_EM59_Msk
13926#define EXTI_EMR2_EM60_Pos (28U)
13927#define EXTI_EMR2_EM60_Msk (0x1UL << EXTI_EMR2_EM60_Pos)
13928#define EXTI_EMR2_EM60 EXTI_EMR2_EM60_Msk
13929#define EXTI_EMR2_EM61_Pos (29U)
13930#define EXTI_EMR2_EM61_Msk (0x1UL << EXTI_EMR2_EM61_Pos)
13931#define EXTI_EMR2_EM61 EXTI_EMR2_EM61_Msk
13932#define EXTI_EMR2_EM62_Pos (30U)
13933#define EXTI_EMR2_EM62_Msk (0x1UL << EXTI_EMR2_EM62_Pos)
13934#define EXTI_EMR2_EM62 EXTI_EMR2_EM62_Msk
13935#define EXTI_EMR2_EM63_Pos (31U)
13936#define EXTI_EMR2_EM63_Msk (0x1UL << EXTI_EMR2_EM63_Pos)
13937#define EXTI_EMR2_EM63 EXTI_EMR2_EM63_Msk
13939/******************* Bit definition for EXTI_PR2 register ********************/
13940#define EXTI_PR2_PR_Pos (17U)
13941#define EXTI_PR2_PR_Msk (0x5UL << EXTI_PR2_PR_Pos)
13942#define EXTI_PR2_PR EXTI_PR2_PR_Msk
13943#define EXTI_PR2_PR49_Pos (17U)
13944#define EXTI_PR2_PR49_Msk (0x1UL << EXTI_PR2_PR49_Pos)
13945#define EXTI_PR2_PR49 EXTI_PR2_PR49_Msk
13946#define EXTI_PR2_PR51_Pos (19U)
13947#define EXTI_PR2_PR51_Msk (0x1UL << EXTI_PR2_PR51_Pos)
13948#define EXTI_PR2_PR51 EXTI_PR2_PR51_Msk
13950/******************* Bit definition for EXTI_IMR3 register *******************/
13951#define EXTI_IMR3_IM_Pos (0U)
13952#define EXTI_IMR3_IM_Msk (0x00F5FFFFUL << EXTI_IMR3_IM_Pos)
13953#define EXTI_IMR3_IM EXTI_IMR3_IM_Msk
13954#define EXTI_IMR3_IM64_Pos (0U)
13955#define EXTI_IMR3_IM64_Msk (0x1UL << EXTI_IMR3_IM64_Pos)
13956#define EXTI_IMR3_IM64 EXTI_IMR3_IM64_Msk
13957#define EXTI_IMR3_IM65_Pos (1U)
13958#define EXTI_IMR3_IM65_Msk (0x1UL << EXTI_IMR3_IM65_Pos)
13959#define EXTI_IMR3_IM65 EXTI_IMR3_IM65_Msk
13960#define EXTI_IMR3_IM66_Pos (2U)
13961#define EXTI_IMR3_IM66_Msk (0x1UL << EXTI_IMR3_IM66_Pos)
13962#define EXTI_IMR3_IM66 EXTI_IMR3_IM66_Msk
13963#define EXTI_IMR3_IM67_Pos (3U)
13964#define EXTI_IMR3_IM67_Msk (0x1UL << EXTI_IMR3_IM67_Pos)
13965#define EXTI_IMR3_IM67 EXTI_IMR3_IM67_Msk
13966#define EXTI_IMR3_IM68_Pos (4U)
13967#define EXTI_IMR3_IM68_Msk (0x1UL << EXTI_IMR3_IM68_Pos)
13968#define EXTI_IMR3_IM68 EXTI_IMR3_IM68_Msk
13969#define EXTI_IMR3_IM69_Pos (5U)
13970#define EXTI_IMR3_IM69_Msk (0x1UL << EXTI_IMR3_IM69_Pos)
13971#define EXTI_IMR3_IM69 EXTI_IMR3_IM69_Msk
13972#define EXTI_IMR3_IM70_Pos (6U)
13973#define EXTI_IMR3_IM70_Msk (0x1UL << EXTI_IMR3_IM70_Pos)
13974#define EXTI_IMR3_IM70 EXTI_IMR3_IM70_Msk
13975#define EXTI_IMR3_IM71_Pos (7U)
13976#define EXTI_IMR3_IM71_Msk (0x1UL << EXTI_IMR3_IM71_Pos)
13977#define EXTI_IMR3_IM71 EXTI_IMR3_IM71_Msk
13978#define EXTI_IMR3_IM72_Pos (8U)
13979#define EXTI_IMR3_IM72_Msk (0x1UL << EXTI_IMR3_IM72_Pos)
13980#define EXTI_IMR3_IM72 EXTI_IMR3_IM72_Msk
13981#define EXTI_IMR3_IM73_Pos (9U)
13982#define EXTI_IMR3_IM73_Msk (0x1UL << EXTI_IMR3_IM73_Pos)
13983#define EXTI_IMR3_IM73 EXTI_IMR3_IM73_Msk
13984#define EXTI_IMR3_IM74_Pos (10U)
13985#define EXTI_IMR3_IM74_Msk (0x1UL << EXTI_IMR3_IM74_Pos)
13986#define EXTI_IMR3_IM74 EXTI_IMR3_IM74_Msk
13987#define EXTI_IMR3_IM75_Pos (11U)
13988#define EXTI_IMR3_IM75_Msk (0x1UL << EXTI_IMR3_IM75_Pos)
13989#define EXTI_IMR3_IM75 EXTI_IMR3_IM75_Msk
13990#define EXTI_IMR3_IM76_Pos (12U)
13991#define EXTI_IMR3_IM76_Msk (0x1UL << EXTI_IMR3_IM76_Pos)
13992#define EXTI_IMR3_IM76 EXTI_IMR3_IM76_Msk
13993#define EXTI_IMR3_IM77_Pos (13U)
13994#define EXTI_IMR3_IM77_Msk (0x1UL << EXTI_IMR3_IM77_Pos)
13995#define EXTI_IMR3_IM77 EXTI_IMR3_IM77_Msk
13996#define EXTI_IMR3_IM78_Pos (14U)
13997#define EXTI_IMR3_IM78_Msk (0x1UL << EXTI_IMR3_IM78_Pos)
13998#define EXTI_IMR3_IM78 EXTI_IMR3_IM78_Msk
13999#define EXTI_IMR3_IM79_Pos (15U)
14000#define EXTI_IMR3_IM79_Msk (0x1UL << EXTI_IMR3_IM79_Pos)
14001#define EXTI_IMR3_IM79 EXTI_IMR3_IM79_Msk
14002#define EXTI_IMR3_IM80_Pos (16U)
14003#define EXTI_IMR3_IM80_Msk (0x1UL << EXTI_IMR3_IM80_Pos)
14004#define EXTI_IMR3_IM80 EXTI_IMR3_IM80_Msk
14005#define EXTI_IMR3_IM82_Pos (18U)
14006#define EXTI_IMR3_IM82_Msk (0x1UL << EXTI_IMR3_IM82_Pos)
14007#define EXTI_IMR3_IM82 EXTI_IMR3_IM82_Msk
14008#define EXTI_IMR3_IM84_Pos (20U)
14009#define EXTI_IMR3_IM84_Msk (0x1UL << EXTI_IMR3_IM84_Pos)
14010#define EXTI_IMR3_IM84 EXTI_IMR3_IM84_Msk
14011#define EXTI_IMR3_IM85_Pos (21U)
14012#define EXTI_IMR3_IM85_Msk (0x1UL << EXTI_IMR3_IM85_Pos)
14013#define EXTI_IMR3_IM85 EXTI_IMR3_IM85_Msk
14014#define EXTI_IMR3_IM86_Pos (22U)
14015#define EXTI_IMR3_IM86_Msk (0x1UL << EXTI_IMR3_IM86_Pos)
14016#define EXTI_IMR3_IM86 EXTI_IMR3_IM86_Msk
14017#define EXTI_IMR3_IM87_Pos (23U)
14018#define EXTI_IMR3_IM87_Msk (0x1UL << EXTI_IMR3_IM87_Pos)
14019#define EXTI_IMR3_IM87 EXTI_IMR3_IM87_Msk
14022/******************* Bit definition for EXTI_EMR3 register *******************/
14023#define EXTI_EMR3_EM_Pos (0U)
14024#define EXTI_EMR3_EM_Msk (0x00F5FFFFUL << EXTI_EMR3_EM_Pos)
14025#define EXTI_EMR3_EM EXTI_EMR3_EM_Msk
14026#define EXTI_EMR3_EM64_Pos (0U)
14027#define EXTI_EMR3_EM64_Msk (0x1UL << EXTI_EMR3_EM64_Pos)
14028#define EXTI_EMR3_EM64 EXTI_EMR3_EM64_Msk
14029#define EXTI_EMR3_EM65_Pos (1U)
14030#define EXTI_EMR3_EM65_Msk (0x1UL << EXTI_EMR3_EM65_Pos)
14031#define EXTI_EMR3_EM65 EXTI_EMR3_EM65_Msk
14032#define EXTI_EMR3_EM66_Pos (2U)
14033#define EXTI_EMR3_EM66_Msk (0x1UL << EXTI_EMR3_EM66_Pos)
14034#define EXTI_EMR3_EM66 EXTI_EMR3_EM66_Msk
14035#define EXTI_EMR3_EM67_Pos (3U)
14036#define EXTI_EMR3_EM67_Msk (0x1UL << EXTI_EMR3_EM67_Pos)
14037#define EXTI_EMR3_EM67 EXTI_EMR3_EM67_Msk
14038#define EXTI_EMR3_EM68_Pos (4U)
14039#define EXTI_EMR3_EM68_Msk (0x1UL << EXTI_EMR3_EM68_Pos)
14040#define EXTI_EMR3_EM68 EXTI_EMR3_EM68_Msk
14041#define EXTI_EMR3_EM69_Pos (5U)
14042#define EXTI_EMR3_EM69_Msk (0x1UL << EXTI_EMR3_EM69_Pos)
14043#define EXTI_EMR3_EM69 EXTI_EMR3_EM69_Msk
14044#define EXTI_EMR3_EM70_Pos (6U)
14045#define EXTI_EMR3_EM70_Msk (0x1UL << EXTI_EMR3_EM70_Pos)
14046#define EXTI_EMR3_EM70 EXTI_EMR3_EM70_Msk
14047#define EXTI_EMR3_EM71_Pos (7U)
14048#define EXTI_EMR3_EM71_Msk (0x1UL << EXTI_EMR3_EM71_Pos)
14049#define EXTI_EMR3_EM71 EXTI_EMR3_EM71_Msk
14050#define EXTI_EMR3_EM72_Pos (8U)
14051#define EXTI_EMR3_EM72_Msk (0x1UL << EXTI_EMR3_EM72_Pos)
14052#define EXTI_EMR3_EM72 EXTI_EMR3_EM72_Msk
14053#define EXTI_EMR3_EM73_Pos (9U)
14054#define EXTI_EMR3_EM73_Msk (0x1UL << EXTI_EMR3_EM73_Pos)
14055#define EXTI_EMR3_EM73 EXTI_EMR3_EM73_Msk
14056#define EXTI_EMR3_EM74_Pos (10U)
14057#define EXTI_EMR3_EM74_Msk (0x1UL << EXTI_EMR3_EM74_Pos)
14058#define EXTI_EMR3_EM74 EXTI_EMR3_EM74_Msk
14059#define EXTI_EMR3_EM75_Pos (11U)
14060#define EXTI_EMR3_EM75_Msk (0x1UL << EXTI_EMR3_EM75_Pos)
14061#define EXTI_EMR3_EM75 EXTI_EMR3_EM75_Msk
14062#define EXTI_EMR3_EM76_Pos (12U)
14063#define EXTI_EMR3_EM76_Msk (0x1UL << EXTI_EMR3_EM76_Pos)
14064#define EXTI_EMR3_EM76 EXTI_EMR3_EM76_Msk
14065#define EXTI_EMR3_EM77_Pos (13U)
14066#define EXTI_EMR3_EM77_Msk (0x1UL << EXTI_EMR3_EM77_Pos)
14067#define EXTI_EMR3_EM77 EXTI_EMR3_EM77_Msk
14068#define EXTI_EMR3_EM78_Pos (14U)
14069#define EXTI_EMR3_EM78_Msk (0x1UL << EXTI_EMR3_EM78_Pos)
14070#define EXTI_EMR3_EM78 EXTI_EMR3_EM78_Msk
14071#define EXTI_EMR3_EM79_Pos (15U)
14072#define EXTI_EMR3_EM79_Msk (0x1UL << EXTI_EMR3_EM79_Pos)
14073#define EXTI_EMR3_EM79 EXTI_EMR3_EM79_Msk
14074#define EXTI_EMR3_EM80_Pos (16U)
14075#define EXTI_EMR3_EM80_Msk (0x1UL << EXTI_EMR3_EM80_Pos)
14076#define EXTI_EMR3_EM80 EXTI_EMR3_EM80_Msk
14077#define EXTI_EMR3_EM81_Pos (17U)
14078#define EXTI_EMR3_EM81_Msk (0x1UL << EXTI_EMR3_EM81_Pos)
14079#define EXTI_EMR3_EM81 EXTI_EMR3_EM81_Msk
14080#define EXTI_EMR3_EM82_Pos (18U)
14081#define EXTI_EMR3_EM82_Msk (0x1UL << EXTI_EMR3_EM82_Pos)
14082#define EXTI_EMR3_EM82 EXTI_EMR3_EM82_Msk
14083#define EXTI_EMR3_EM84_Pos (20U)
14084#define EXTI_EMR3_EM84_Msk (0x1UL << EXTI_EMR3_EM84_Pos)
14085#define EXTI_EMR3_EM84 EXTI_EMR3_EM84_Msk
14086#define EXTI_EMR3_EM85_Pos (21U)
14087#define EXTI_EMR3_EM85_Msk (0x1UL << EXTI_EMR3_EM85_Pos)
14088#define EXTI_EMR3_EM85 EXTI_EMR3_EM85_Msk
14089#define EXTI_EMR3_EM86_Pos (22U)
14090#define EXTI_EMR3_EM86_Msk (0x1UL << EXTI_EMR3_EM86_Pos)
14091#define EXTI_EMR3_EM86 EXTI_EMR3_EM86_Msk
14092#define EXTI_EMR3_EM87_Pos (23U)
14093#define EXTI_EMR3_EM87_Msk (0x1UL << EXTI_EMR3_EM87_Pos)
14094#define EXTI_EMR3_EM87 EXTI_EMR3_EM87_Msk
14096/******************* Bit definition for EXTI_PR3 register ********************/
14097#define EXTI_PR3_PR_Pos (18U)
14098#define EXTI_PR3_PR_Msk (0x1DUL << EXTI_PR3_PR_Pos)
14099#define EXTI_PR3_PR EXTI_PR3_PR_Msk
14100#define EXTI_PR3_PR82_Pos (18U)
14101#define EXTI_PR3_PR82_Msk (0x1UL << EXTI_PR3_PR82_Pos)
14102#define EXTI_PR3_PR82 EXTI_PR3_PR82_Msk
14103#define EXTI_PR3_PR84_Pos (20U)
14104#define EXTI_PR3_PR84_Msk (0x1UL << EXTI_PR3_PR84_Pos)
14105#define EXTI_PR3_PR84 EXTI_PR3_PR84_Msk
14106#define EXTI_PR3_PR85_Pos (21U)
14107#define EXTI_PR3_PR85_Msk (0x1UL << EXTI_PR3_PR85_Pos)
14108#define EXTI_PR3_PR85 EXTI_PR3_PR85_Msk
14109#define EXTI_PR3_PR86_Pos (22U)
14110#define EXTI_PR3_PR86_Msk (0x1UL << EXTI_PR3_PR86_Pos)
14111#define EXTI_PR3_PR86 EXTI_PR3_PR86_Msk
14112/******************************************************************************/
14113/* */
14114/* FLASH */
14115/* */
14116/******************************************************************************/
14117/*
14118* @brief FLASH Global Defines
14119*/
14120#if defined(CORE_CM4)
14121#define FLASH_SIZE 0x200000UL /* 2 MB */
14122#else
14123#define FLASH_SIZE_DATA_REGISTER 0x1FF1E880U
14124#define FLASH_SIZE ((((*((uint16_t *)FLASH_SIZE_DATA_REGISTER)) == 0xFFFFU)) ? 0x200000U : \
14125 ((((*((uint16_t *)FLASH_SIZE_DATA_REGISTER)) == 0x0000U)) ? 0x200000U : \
14126 (((uint32_t)(*((uint16_t *)FLASH_SIZE_DATA_REGISTER)) & (0x0FFFU)) << 10U))) /* 2 MB */
14127#endif /* CORE_CM4 */
14128#define FLASH_SECTOR_TOTAL 8U /* 8 sectors */
14129#define FLASH_BANK_SIZE (FLASH_SIZE >> 1) /* 1 MB */
14130#define FLASH_SECTOR_SIZE 0x00020000UL /* 128 KB */
14131#define FLASH_LATENCY_DEFAULT FLASH_ACR_LATENCY_7WS /* FLASH Seven Latency cycles */
14132#define FLASH_NB_32BITWORD_IN_FLASHWORD 8U /* 256 bits */
14133#define DUAL_BANK /* Dual-bank Flash */
14134
14135/******************* Bits definition for FLASH_ACR register **********************/
14136#define FLASH_ACR_LATENCY_Pos (0U)
14137#define FLASH_ACR_LATENCY_Msk (0xFUL << FLASH_ACR_LATENCY_Pos)
14138#define FLASH_ACR_LATENCY FLASH_ACR_LATENCY_Msk
14139#define FLASH_ACR_LATENCY_0WS (0x00000000UL)
14140#define FLASH_ACR_LATENCY_1WS (0x00000001UL)
14141#define FLASH_ACR_LATENCY_2WS (0x00000002UL)
14142#define FLASH_ACR_LATENCY_3WS (0x00000003UL)
14143#define FLASH_ACR_LATENCY_4WS (0x00000004UL)
14144#define FLASH_ACR_LATENCY_5WS (0x00000005UL)
14145#define FLASH_ACR_LATENCY_6WS (0x00000006UL)
14146#define FLASH_ACR_LATENCY_7WS (0x00000007UL)
14147
14148#define FLASH_ACR_WRHIGHFREQ_Pos (4U)
14149#define FLASH_ACR_WRHIGHFREQ_Msk (0x3UL << FLASH_ACR_WRHIGHFREQ_Pos)
14150#define FLASH_ACR_WRHIGHFREQ FLASH_ACR_WRHIGHFREQ_Msk
14151#define FLASH_ACR_WRHIGHFREQ_0 (0x1UL << FLASH_ACR_WRHIGHFREQ_Pos)
14152#define FLASH_ACR_WRHIGHFREQ_1 (0x2UL << FLASH_ACR_WRHIGHFREQ_Pos)
14154/* Legacy FLASH Latency defines */
14155#define FLASH_ACR_LATENCY_8WS (0x00000008UL)
14156#define FLASH_ACR_LATENCY_9WS (0x00000009UL)
14157#define FLASH_ACR_LATENCY_10WS (0x0000000AUL)
14158#define FLASH_ACR_LATENCY_11WS (0x0000000BUL)
14159#define FLASH_ACR_LATENCY_12WS (0x0000000CUL)
14160#define FLASH_ACR_LATENCY_13WS (0x0000000DUL)
14161#define FLASH_ACR_LATENCY_14WS (0x0000000EUL)
14162#define FLASH_ACR_LATENCY_15WS (0x0000000FUL)
14163/******************* Bits definition for FLASH_CR register ***********************/
14164#define FLASH_CR_LOCK_Pos (0U)
14165#define FLASH_CR_LOCK_Msk (0x1UL << FLASH_CR_LOCK_Pos)
14166#define FLASH_CR_LOCK FLASH_CR_LOCK_Msk
14167#define FLASH_CR_PG_Pos (1U)
14168#define FLASH_CR_PG_Msk (0x1UL << FLASH_CR_PG_Pos)
14169#define FLASH_CR_PG FLASH_CR_PG_Msk
14170#define FLASH_CR_SER_Pos (2U)
14171#define FLASH_CR_SER_Msk (0x1UL << FLASH_CR_SER_Pos)
14172#define FLASH_CR_SER FLASH_CR_SER_Msk
14173#define FLASH_CR_BER_Pos (3U)
14174#define FLASH_CR_BER_Msk (0x1UL << FLASH_CR_BER_Pos)
14175#define FLASH_CR_BER FLASH_CR_BER_Msk
14176#define FLASH_CR_PSIZE_Pos (4U)
14177#define FLASH_CR_PSIZE_Msk (0x3UL << FLASH_CR_PSIZE_Pos)
14178#define FLASH_CR_PSIZE FLASH_CR_PSIZE_Msk
14179#define FLASH_CR_PSIZE_0 (0x1UL << FLASH_CR_PSIZE_Pos)
14180#define FLASH_CR_PSIZE_1 (0x2UL << FLASH_CR_PSIZE_Pos)
14181#define FLASH_CR_FW_Pos (6U)
14182#define FLASH_CR_FW_Msk (0x1UL << FLASH_CR_FW_Pos)
14183#define FLASH_CR_FW FLASH_CR_FW_Msk
14184#define FLASH_CR_START_Pos (7U)
14185#define FLASH_CR_START_Msk (0x1UL << FLASH_CR_START_Pos)
14186#define FLASH_CR_START FLASH_CR_START_Msk
14187#define FLASH_CR_SNB_Pos (8U)
14188#define FLASH_CR_SNB_Msk (0x7UL << FLASH_CR_SNB_Pos)
14189#define FLASH_CR_SNB FLASH_CR_SNB_Msk
14190#define FLASH_CR_SNB_0 (0x1UL << FLASH_CR_SNB_Pos)
14191#define FLASH_CR_SNB_1 (0x2UL << FLASH_CR_SNB_Pos)
14192#define FLASH_CR_SNB_2 (0x4UL << FLASH_CR_SNB_Pos)
14193#define FLASH_CR_CRC_EN_Pos (15U)
14194#define FLASH_CR_CRC_EN_Msk (0x1UL << FLASH_CR_CRC_EN_Pos)
14195#define FLASH_CR_CRC_EN FLASH_CR_CRC_EN_Msk
14196#define FLASH_CR_EOPIE_Pos (16U)
14197#define FLASH_CR_EOPIE_Msk (0x1UL << FLASH_CR_EOPIE_Pos)
14198#define FLASH_CR_EOPIE FLASH_CR_EOPIE_Msk
14199#define FLASH_CR_WRPERRIE_Pos (17U)
14200#define FLASH_CR_WRPERRIE_Msk (0x1UL << FLASH_CR_WRPERRIE_Pos)
14201#define FLASH_CR_WRPERRIE FLASH_CR_WRPERRIE_Msk
14202#define FLASH_CR_PGSERRIE_Pos (18U)
14203#define FLASH_CR_PGSERRIE_Msk (0x1UL << FLASH_CR_PGSERRIE_Pos)
14204#define FLASH_CR_PGSERRIE FLASH_CR_PGSERRIE_Msk
14205#define FLASH_CR_STRBERRIE_Pos (19U)
14206#define FLASH_CR_STRBERRIE_Msk (0x1UL << FLASH_CR_STRBERRIE_Pos)
14207#define FLASH_CR_STRBERRIE FLASH_CR_STRBERRIE_Msk
14208#define FLASH_CR_INCERRIE_Pos (21U)
14209#define FLASH_CR_INCERRIE_Msk (0x1UL << FLASH_CR_INCERRIE_Pos)
14210#define FLASH_CR_INCERRIE FLASH_CR_INCERRIE_Msk
14211#define FLASH_CR_OPERRIE_Pos (22U)
14212#define FLASH_CR_OPERRIE_Msk (0x1UL << FLASH_CR_OPERRIE_Pos)
14213#define FLASH_CR_OPERRIE FLASH_CR_OPERRIE_Msk
14214#define FLASH_CR_RDPERRIE_Pos (23U)
14215#define FLASH_CR_RDPERRIE_Msk (0x1UL << FLASH_CR_RDPERRIE_Pos)
14216#define FLASH_CR_RDPERRIE FLASH_CR_RDPERRIE_Msk
14217#define FLASH_CR_RDSERRIE_Pos (24U)
14218#define FLASH_CR_RDSERRIE_Msk (0x1UL << FLASH_CR_RDSERRIE_Pos)
14219#define FLASH_CR_RDSERRIE FLASH_CR_RDSERRIE_Msk
14220#define FLASH_CR_SNECCERRIE_Pos (25U)
14221#define FLASH_CR_SNECCERRIE_Msk (0x1UL << FLASH_CR_SNECCERRIE_Pos)
14222#define FLASH_CR_SNECCERRIE FLASH_CR_SNECCERRIE_Msk
14223#define FLASH_CR_DBECCERRIE_Pos (26U)
14224#define FLASH_CR_DBECCERRIE_Msk (0x1UL << FLASH_CR_DBECCERRIE_Pos)
14225#define FLASH_CR_DBECCERRIE FLASH_CR_DBECCERRIE_Msk
14226#define FLASH_CR_CRCENDIE_Pos (27U)
14227#define FLASH_CR_CRCENDIE_Msk (0x1UL << FLASH_CR_CRCENDIE_Pos)
14228#define FLASH_CR_CRCENDIE FLASH_CR_CRCENDIE_Msk
14229#define FLASH_CR_CRCRDERRIE_Pos (28U)
14230#define FLASH_CR_CRCRDERRIE_Msk (0x1UL << FLASH_CR_CRCRDERRIE_Pos)
14231#define FLASH_CR_CRCRDERRIE FLASH_CR_CRCRDERRIE_Msk
14233/******************* Bits definition for FLASH_SR register ***********************/
14234#define FLASH_SR_BSY_Pos (0U)
14235#define FLASH_SR_BSY_Msk (0x1UL << FLASH_SR_BSY_Pos)
14236#define FLASH_SR_BSY FLASH_SR_BSY_Msk
14237#define FLASH_SR_WBNE_Pos (1U)
14238#define FLASH_SR_WBNE_Msk (0x1UL << FLASH_SR_WBNE_Pos)
14239#define FLASH_SR_WBNE FLASH_SR_WBNE_Msk
14240#define FLASH_SR_QW_Pos (2U)
14241#define FLASH_SR_QW_Msk (0x1UL << FLASH_SR_QW_Pos)
14242#define FLASH_SR_QW FLASH_SR_QW_Msk
14243#define FLASH_SR_CRC_BUSY_Pos (3U)
14244#define FLASH_SR_CRC_BUSY_Msk (0x1UL << FLASH_SR_CRC_BUSY_Pos)
14245#define FLASH_SR_CRC_BUSY FLASH_SR_CRC_BUSY_Msk
14246#define FLASH_SR_EOP_Pos (16U)
14247#define FLASH_SR_EOP_Msk (0x1UL << FLASH_SR_EOP_Pos)
14248#define FLASH_SR_EOP FLASH_SR_EOP_Msk
14249#define FLASH_SR_WRPERR_Pos (17U)
14250#define FLASH_SR_WRPERR_Msk (0x1UL << FLASH_SR_WRPERR_Pos)
14251#define FLASH_SR_WRPERR FLASH_SR_WRPERR_Msk
14252#define FLASH_SR_PGSERR_Pos (18U)
14253#define FLASH_SR_PGSERR_Msk (0x1UL << FLASH_SR_PGSERR_Pos)
14254#define FLASH_SR_PGSERR FLASH_SR_PGSERR_Msk
14255#define FLASH_SR_STRBERR_Pos (19U)
14256#define FLASH_SR_STRBERR_Msk (0x1UL << FLASH_SR_STRBERR_Pos)
14257#define FLASH_SR_STRBERR FLASH_SR_STRBERR_Msk
14258#define FLASH_SR_INCERR_Pos (21U)
14259#define FLASH_SR_INCERR_Msk (0x1UL << FLASH_SR_INCERR_Pos)
14260#define FLASH_SR_INCERR FLASH_SR_INCERR_Msk
14261#define FLASH_SR_OPERR_Pos (22U)
14262#define FLASH_SR_OPERR_Msk (0x1UL << FLASH_SR_OPERR_Pos)
14263#define FLASH_SR_OPERR FLASH_SR_OPERR_Msk
14264#define FLASH_SR_RDPERR_Pos (23U)
14265#define FLASH_SR_RDPERR_Msk (0x1UL << FLASH_SR_RDPERR_Pos)
14266#define FLASH_SR_RDPERR FLASH_SR_RDPERR_Msk
14267#define FLASH_SR_RDSERR_Pos (24U)
14268#define FLASH_SR_RDSERR_Msk (0x1UL << FLASH_SR_RDSERR_Pos)
14269#define FLASH_SR_RDSERR FLASH_SR_RDSERR_Msk
14270#define FLASH_SR_SNECCERR_Pos (25U)
14271#define FLASH_SR_SNECCERR_Msk (0x1UL << FLASH_SR_SNECCERR_Pos)
14272#define FLASH_SR_SNECCERR FLASH_SR_SNECCERR_Msk
14273#define FLASH_SR_DBECCERR_Pos (26U)
14274#define FLASH_SR_DBECCERR_Msk (0x1UL << FLASH_SR_DBECCERR_Pos)
14275#define FLASH_SR_DBECCERR FLASH_SR_DBECCERR_Msk
14276#define FLASH_SR_CRCEND_Pos (27U)
14277#define FLASH_SR_CRCEND_Msk (0x1UL << FLASH_SR_CRCEND_Pos)
14278#define FLASH_SR_CRCEND FLASH_SR_CRCEND_Msk
14279#define FLASH_SR_CRCRDERR_Pos (28U)
14280#define FLASH_SR_CRCRDERR_Msk (0x1UL << FLASH_SR_CRCRDERR_Pos)
14281#define FLASH_SR_CRCRDERR FLASH_SR_CRCRDERR_Msk
14283/******************* Bits definition for FLASH_CCR register *******************/
14284#define FLASH_CCR_CLR_EOP_Pos (16U)
14285#define FLASH_CCR_CLR_EOP_Msk (0x1UL << FLASH_CCR_CLR_EOP_Pos)
14286#define FLASH_CCR_CLR_EOP FLASH_CCR_CLR_EOP_Msk
14287#define FLASH_CCR_CLR_WRPERR_Pos (17U)
14288#define FLASH_CCR_CLR_WRPERR_Msk (0x1UL << FLASH_CCR_CLR_WRPERR_Pos)
14289#define FLASH_CCR_CLR_WRPERR FLASH_CCR_CLR_WRPERR_Msk
14290#define FLASH_CCR_CLR_PGSERR_Pos (18U)
14291#define FLASH_CCR_CLR_PGSERR_Msk (0x1UL << FLASH_CCR_CLR_PGSERR_Pos)
14292#define FLASH_CCR_CLR_PGSERR FLASH_CCR_CLR_PGSERR_Msk
14293#define FLASH_CCR_CLR_STRBERR_Pos (19U)
14294#define FLASH_CCR_CLR_STRBERR_Msk (0x1UL << FLASH_CCR_CLR_STRBERR_Pos)
14295#define FLASH_CCR_CLR_STRBERR FLASH_CCR_CLR_STRBERR_Msk
14296#define FLASH_CCR_CLR_INCERR_Pos (21U)
14297#define FLASH_CCR_CLR_INCERR_Msk (0x1UL << FLASH_CCR_CLR_INCERR_Pos)
14298#define FLASH_CCR_CLR_INCERR FLASH_CCR_CLR_INCERR_Msk
14299#define FLASH_CCR_CLR_OPERR_Pos (22U)
14300#define FLASH_CCR_CLR_OPERR_Msk (0x1UL << FLASH_CCR_CLR_OPERR_Pos)
14301#define FLASH_CCR_CLR_OPERR FLASH_CCR_CLR_OPERR_Msk
14302#define FLASH_CCR_CLR_RDPERR_Pos (23U)
14303#define FLASH_CCR_CLR_RDPERR_Msk (0x1UL << FLASH_CCR_CLR_RDPERR_Pos)
14304#define FLASH_CCR_CLR_RDPERR FLASH_CCR_CLR_RDPERR_Msk
14305#define FLASH_CCR_CLR_RDSERR_Pos (24U)
14306#define FLASH_CCR_CLR_RDSERR_Msk (0x1UL << FLASH_CCR_CLR_RDSERR_Pos)
14307#define FLASH_CCR_CLR_RDSERR FLASH_CCR_CLR_RDSERR_Msk
14308#define FLASH_CCR_CLR_SNECCERR_Pos (25U)
14309#define FLASH_CCR_CLR_SNECCERR_Msk (0x1UL << FLASH_CCR_CLR_SNECCERR_Pos)
14310#define FLASH_CCR_CLR_SNECCERR FLASH_CCR_CLR_SNECCERR_Msk
14311#define FLASH_CCR_CLR_DBECCERR_Pos (26U)
14312#define FLASH_CCR_CLR_DBECCERR_Msk (0x1UL << FLASH_CCR_CLR_DBECCERR_Pos)
14313#define FLASH_CCR_CLR_DBECCERR FLASH_CCR_CLR_DBECCERR_Msk
14314#define FLASH_CCR_CLR_CRCEND_Pos (27U)
14315#define FLASH_CCR_CLR_CRCEND_Msk (0x1UL << FLASH_CCR_CLR_CRCEND_Pos)
14316#define FLASH_CCR_CLR_CRCEND FLASH_CCR_CLR_CRCEND_Msk
14317#define FLASH_CCR_CLR_CRCRDERR_Pos (28U)
14318#define FLASH_CCR_CLR_CRCRDERR_Msk (0x1UL << FLASH_CCR_CLR_CRCRDERR_Pos)
14319#define FLASH_CCR_CLR_CRCRDERR FLASH_CCR_CLR_CRCRDERR_Msk
14321/******************* Bits definition for FLASH_OPTCR register *******************/
14322#define FLASH_OPTCR_OPTLOCK_Pos (0U)
14323#define FLASH_OPTCR_OPTLOCK_Msk (0x1UL << FLASH_OPTCR_OPTLOCK_Pos)
14324#define FLASH_OPTCR_OPTLOCK FLASH_OPTCR_OPTLOCK_Msk
14325#define FLASH_OPTCR_OPTSTART_Pos (1U)
14326#define FLASH_OPTCR_OPTSTART_Msk (0x1UL << FLASH_OPTCR_OPTSTART_Pos)
14327#define FLASH_OPTCR_OPTSTART FLASH_OPTCR_OPTSTART_Msk
14328#define FLASH_OPTCR_MER_Pos (4U)
14329#define FLASH_OPTCR_MER_Msk (0x1UL << FLASH_OPTCR_MER_Pos)
14330#define FLASH_OPTCR_MER FLASH_OPTCR_MER_Msk
14331#define FLASH_OPTCR_OPTCHANGEERRIE_Pos (30U)
14332#define FLASH_OPTCR_OPTCHANGEERRIE_Msk (0x1UL << FLASH_OPTCR_OPTCHANGEERRIE_Pos)
14333#define FLASH_OPTCR_OPTCHANGEERRIE FLASH_OPTCR_OPTCHANGEERRIE_Msk
14334#define FLASH_OPTCR_SWAP_BANK_Pos (31U)
14335#define FLASH_OPTCR_SWAP_BANK_Msk (0x1UL << FLASH_OPTCR_SWAP_BANK_Pos)
14336#define FLASH_OPTCR_SWAP_BANK FLASH_OPTCR_SWAP_BANK_Msk
14338/******************* Bits definition for FLASH_OPTSR register ***************/
14339#define FLASH_OPTSR_OPT_BUSY_Pos (0U)
14340#define FLASH_OPTSR_OPT_BUSY_Msk (0x1UL << FLASH_OPTSR_OPT_BUSY_Pos)
14341#define FLASH_OPTSR_OPT_BUSY FLASH_OPTSR_OPT_BUSY_Msk
14342#define FLASH_OPTSR_BOR_LEV_Pos (2U)
14343#define FLASH_OPTSR_BOR_LEV_Msk (0x3UL << FLASH_OPTSR_BOR_LEV_Pos)
14344#define FLASH_OPTSR_BOR_LEV FLASH_OPTSR_BOR_LEV_Msk
14345#define FLASH_OPTSR_BOR_LEV_0 (0x1UL << FLASH_OPTSR_BOR_LEV_Pos)
14346#define FLASH_OPTSR_BOR_LEV_1 (0x2UL << FLASH_OPTSR_BOR_LEV_Pos)
14347#define FLASH_OPTSR_IWDG1_SW_Pos (4U)
14348#define FLASH_OPTSR_IWDG1_SW_Msk (0x1UL << FLASH_OPTSR_IWDG1_SW_Pos)
14349#define FLASH_OPTSR_IWDG1_SW FLASH_OPTSR_IWDG1_SW_Msk
14350#define FLASH_OPTSR_IWDG2_SW_Pos (5U)
14351#define FLASH_OPTSR_IWDG2_SW_Msk (0x1UL << FLASH_OPTSR_IWDG2_SW_Pos)
14352#define FLASH_OPTSR_IWDG2_SW FLASH_OPTSR_IWDG2_SW_Msk
14353#define FLASH_OPTSR_NRST_STOP_D1_Pos (6U)
14354#define FLASH_OPTSR_NRST_STOP_D1_Msk (0x1UL << FLASH_OPTSR_NRST_STOP_D1_Pos)
14355#define FLASH_OPTSR_NRST_STOP_D1 FLASH_OPTSR_NRST_STOP_D1_Msk
14356#define FLASH_OPTSR_NRST_STBY_D1_Pos (7U)
14357#define FLASH_OPTSR_NRST_STBY_D1_Msk (0x1UL << FLASH_OPTSR_NRST_STBY_D1_Pos)
14358#define FLASH_OPTSR_NRST_STBY_D1 FLASH_OPTSR_NRST_STBY_D1_Msk
14359#define FLASH_OPTSR_RDP_Pos (8U)
14360#define FLASH_OPTSR_RDP_Msk (0xFFUL << FLASH_OPTSR_RDP_Pos)
14361#define FLASH_OPTSR_RDP FLASH_OPTSR_RDP_Msk
14362#define FLASH_OPTSR_FZ_IWDG_STOP_Pos (17U)
14363#define FLASH_OPTSR_FZ_IWDG_STOP_Msk (0x1UL << FLASH_OPTSR_FZ_IWDG_STOP_Pos)
14364#define FLASH_OPTSR_FZ_IWDG_STOP FLASH_OPTSR_FZ_IWDG_STOP_Msk
14365#define FLASH_OPTSR_FZ_IWDG_SDBY_Pos (18U)
14366#define FLASH_OPTSR_FZ_IWDG_SDBY_Msk (0x1UL << FLASH_OPTSR_FZ_IWDG_SDBY_Pos)
14367#define FLASH_OPTSR_FZ_IWDG_SDBY FLASH_OPTSR_FZ_IWDG_SDBY_Msk
14368#define FLASH_OPTSR_ST_RAM_SIZE_Pos (19U)
14369#define FLASH_OPTSR_ST_RAM_SIZE_Msk (0x3UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
14370#define FLASH_OPTSR_ST_RAM_SIZE FLASH_OPTSR_ST_RAM_SIZE_Msk
14371#define FLASH_OPTSR_ST_RAM_SIZE_0 (0x1UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
14372#define FLASH_OPTSR_ST_RAM_SIZE_1 (0x2UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
14373#define FLASH_OPTSR_SECURITY_Pos (21U)
14374#define FLASH_OPTSR_SECURITY_Msk (0x1UL << FLASH_OPTSR_SECURITY_Pos)
14375#define FLASH_OPTSR_SECURITY FLASH_OPTSR_SECURITY_Msk
14376#define FLASH_OPTSR_BCM4_Pos (22U)
14377#define FLASH_OPTSR_BCM4_Msk (0x1UL << FLASH_OPTSR_BCM4_Pos)
14378#define FLASH_OPTSR_BCM4 FLASH_OPTSR_BCM4_Msk
14379#define FLASH_OPTSR_BCM7_Pos (23U)
14380#define FLASH_OPTSR_BCM7_Msk (0x1UL << FLASH_OPTSR_BCM7_Pos)
14381#define FLASH_OPTSR_BCM7 FLASH_OPTSR_BCM7_Msk
14382#define FLASH_OPTSR_NRST_STOP_D2_Pos (24U)
14383#define FLASH_OPTSR_NRST_STOP_D2_Msk (0x1UL << FLASH_OPTSR_NRST_STOP_D2_Pos)
14384#define FLASH_OPTSR_NRST_STOP_D2 FLASH_OPTSR_NRST_STOP_D2_Msk
14385#define FLASH_OPTSR_NRST_STBY_D2_Pos (25U)
14386#define FLASH_OPTSR_NRST_STBY_D2_Msk (0x1UL << FLASH_OPTSR_NRST_STBY_D2_Pos)
14387#define FLASH_OPTSR_NRST_STBY_D2 FLASH_OPTSR_NRST_STBY_D2_Msk
14388#define FLASH_OPTSR_IO_HSLV_Pos (29U)
14389#define FLASH_OPTSR_IO_HSLV_Msk (0x1UL << FLASH_OPTSR_IO_HSLV_Pos)
14390#define FLASH_OPTSR_IO_HSLV FLASH_OPTSR_IO_HSLV_Msk
14391#define FLASH_OPTSR_OPTCHANGEERR_Pos (30U)
14392#define FLASH_OPTSR_OPTCHANGEERR_Msk (0x1UL << FLASH_OPTSR_OPTCHANGEERR_Pos)
14393#define FLASH_OPTSR_OPTCHANGEERR FLASH_OPTSR_OPTCHANGEERR_Msk
14394#define FLASH_OPTSR_SWAP_BANK_OPT_Pos (31U)
14395#define FLASH_OPTSR_SWAP_BANK_OPT_Msk (0x1UL << FLASH_OPTSR_SWAP_BANK_OPT_Pos)
14396#define FLASH_OPTSR_SWAP_BANK_OPT FLASH_OPTSR_SWAP_BANK_OPT_Msk
14398/******************* Bits definition for FLASH_OPTCCR register *******************/
14399#define FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos (30U)
14400#define FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk (0x1UL << FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos)
14401#define FLASH_OPTCCR_CLR_OPTCHANGEERR FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk
14403/******************* Bits definition for FLASH_PRAR register *********************/
14404#define FLASH_PRAR_PROT_AREA_START_Pos (0U)
14405#define FLASH_PRAR_PROT_AREA_START_Msk (0xFFFUL << FLASH_PRAR_PROT_AREA_START_Pos)
14406#define FLASH_PRAR_PROT_AREA_START FLASH_PRAR_PROT_AREA_START_Msk
14407#define FLASH_PRAR_PROT_AREA_END_Pos (16U)
14408#define FLASH_PRAR_PROT_AREA_END_Msk (0xFFFUL << FLASH_PRAR_PROT_AREA_END_Pos)
14409#define FLASH_PRAR_PROT_AREA_END FLASH_PRAR_PROT_AREA_END_Msk
14410#define FLASH_PRAR_DMEP_Pos (31U)
14411#define FLASH_PRAR_DMEP_Msk (0x1UL << FLASH_PRAR_DMEP_Pos)
14412#define FLASH_PRAR_DMEP FLASH_PRAR_DMEP_Msk
14414/******************* Bits definition for FLASH_SCAR register *********************/
14415#define FLASH_SCAR_SEC_AREA_START_Pos (0U)
14416#define FLASH_SCAR_SEC_AREA_START_Msk (0xFFFUL << FLASH_SCAR_SEC_AREA_START_Pos)
14417#define FLASH_SCAR_SEC_AREA_START FLASH_SCAR_SEC_AREA_START_Msk
14418#define FLASH_SCAR_SEC_AREA_END_Pos (16U)
14419#define FLASH_SCAR_SEC_AREA_END_Msk (0xFFFUL << FLASH_SCAR_SEC_AREA_END_Pos)
14420#define FLASH_SCAR_SEC_AREA_END FLASH_SCAR_SEC_AREA_END_Msk
14421#define FLASH_SCAR_DMES_Pos (31U)
14422#define FLASH_SCAR_DMES_Msk (0x1UL << FLASH_SCAR_DMES_Pos)
14423#define FLASH_SCAR_DMES FLASH_SCAR_DMES_Msk
14425/******************* Bits definition for FLASH_WPSN register *********************/
14426#define FLASH_WPSN_WRPSN_Pos (0U)
14427#define FLASH_WPSN_WRPSN_Msk (0xFFUL << FLASH_WPSN_WRPSN_Pos)
14428#define FLASH_WPSN_WRPSN FLASH_WPSN_WRPSN_Msk
14430/******************* Bits definition for FLASH_BOOT7_CUR register ****************/
14431#define FLASH_BOOT7_BCM7_ADD0_Pos (0U)
14432#define FLASH_BOOT7_BCM7_ADD0_Msk (0xFFFFUL << FLASH_BOOT7_BCM7_ADD0_Pos)
14433#define FLASH_BOOT7_BCM7_ADD0 FLASH_BOOT7_BCM7_ADD0_Msk
14434#define FLASH_BOOT7_BCM7_ADD1_Pos (16U)
14435#define FLASH_BOOT7_BCM7_ADD1_Msk (0xFFFFUL << FLASH_BOOT7_BCM7_ADD1_Pos)
14436#define FLASH_BOOT7_BCM7_ADD1 FLASH_BOOT7_BCM7_ADD1_Msk
14438/******************* Bits definition for FLASH_BOOT4 register ********************/
14439#define FLASH_BOOT4_BCM4_ADD0_Pos (0U)
14440#define FLASH_BOOT4_BCM4_ADD0_Msk (0xFFFFUL << FLASH_BOOT4_BCM4_ADD0_Pos)
14441#define FLASH_BOOT4_BCM4_ADD0 FLASH_BOOT4_BCM4_ADD0_Msk
14442#define FLASH_BOOT4_BCM4_ADD1_Pos (16U)
14443#define FLASH_BOOT4_BCM4_ADD1_Msk (0xFFFFUL << FLASH_BOOT4_BCM4_ADD1_Pos)
14444#define FLASH_BOOT4_BCM4_ADD1 FLASH_BOOT4_BCM4_ADD1_Msk
14446/******************* Bits definition for FLASH_CRCCR register ********************/
14447#define FLASH_CRCCR_CRC_SECT_Pos (0U)
14448#define FLASH_CRCCR_CRC_SECT_Msk (0x7UL << FLASH_CRCCR_CRC_SECT_Pos)
14449#define FLASH_CRCCR_CRC_SECT FLASH_CRCCR_CRC_SECT_Msk
14450#define FLASH_CRCCR_CRC_BY_SECT_Pos (8U)
14451#define FLASH_CRCCR_CRC_BY_SECT_Msk (0x1UL << FLASH_CRCCR_CRC_BY_SECT_Pos)
14452#define FLASH_CRCCR_CRC_BY_SECT FLASH_CRCCR_CRC_BY_SECT_Msk
14453#define FLASH_CRCCR_ADD_SECT_Pos (9U)
14454#define FLASH_CRCCR_ADD_SECT_Msk (0x1UL << FLASH_CRCCR_ADD_SECT_Pos)
14455#define FLASH_CRCCR_ADD_SECT FLASH_CRCCR_ADD_SECT_Msk
14456#define FLASH_CRCCR_CLEAN_SECT_Pos (10U)
14457#define FLASH_CRCCR_CLEAN_SECT_Msk (0x1UL << FLASH_CRCCR_CLEAN_SECT_Pos)
14458#define FLASH_CRCCR_CLEAN_SECT FLASH_CRCCR_CLEAN_SECT_Msk
14459#define FLASH_CRCCR_START_CRC_Pos (16U)
14460#define FLASH_CRCCR_START_CRC_Msk (0x1UL << FLASH_CRCCR_START_CRC_Pos)
14461#define FLASH_CRCCR_START_CRC FLASH_CRCCR_START_CRC_Msk
14462#define FLASH_CRCCR_CLEAN_CRC_Pos (17U)
14463#define FLASH_CRCCR_CLEAN_CRC_Msk (0x1UL << FLASH_CRCCR_CLEAN_CRC_Pos)
14464#define FLASH_CRCCR_CLEAN_CRC FLASH_CRCCR_CLEAN_CRC_Msk
14465#define FLASH_CRCCR_CRC_BURST_Pos (20U)
14466#define FLASH_CRCCR_CRC_BURST_Msk (0x3UL << FLASH_CRCCR_CRC_BURST_Pos)
14467#define FLASH_CRCCR_CRC_BURST FLASH_CRCCR_CRC_BURST_Msk
14468#define FLASH_CRCCR_CRC_BURST_0 (0x1UL << FLASH_CRCCR_CRC_BURST_Pos)
14469#define FLASH_CRCCR_CRC_BURST_1 (0x2UL << FLASH_CRCCR_CRC_BURST_Pos)
14470#define FLASH_CRCCR_ALL_BANK_Pos (22U)
14471#define FLASH_CRCCR_ALL_BANK_Msk (0x1UL << FLASH_CRCCR_ALL_BANK_Pos)
14472#define FLASH_CRCCR_ALL_BANK FLASH_CRCCR_ALL_BANK_Msk
14474/******************* Bits definition for FLASH_CRCSADD register ****************/
14475#define FLASH_CRCSADD_CRC_START_ADDR_Pos (0U)
14476#define FLASH_CRCSADD_CRC_START_ADDR_Msk (0xFFFFFFFFUL << FLASH_CRCSADD_CRC_START_ADDR_Pos)
14477#define FLASH_CRCSADD_CRC_START_ADDR FLASH_CRCSADD_CRC_START_ADDR_Msk
14479/******************* Bits definition for FLASH_CRCEADD register ****************/
14480#define FLASH_CRCEADD_CRC_END_ADDR_Pos (0U)
14481#define FLASH_CRCEADD_CRC_END_ADDR_Msk (0xFFFFFFFFUL << FLASH_CRCEADD_CRC_END_ADDR_Pos)
14482#define FLASH_CRCEADD_CRC_END_ADDR FLASH_CRCEADD_CRC_END_ADDR_Msk
14484/******************* Bits definition for FLASH_CRCDATA register ***************/
14485#define FLASH_CRCDATA_CRC_DATA_Pos (0U)
14486#define FLASH_CRCDATA_CRC_DATA_Msk (0xFFFFFFFFUL << FLASH_CRCDATA_CRC_DATA_Pos)
14487#define FLASH_CRCDATA_CRC_DATA FLASH_CRCDATA_CRC_DATA_Msk
14489/******************* Bits definition for FLASH_ECC_FA register *******************/
14490#define FLASH_ECC_FA_FAIL_ECC_ADDR_Pos (0U)
14491#define FLASH_ECC_FA_FAIL_ECC_ADDR_Msk (0x7FFFUL << FLASH_ECC_FA_FAIL_ECC_ADDR_Pos)
14492#define FLASH_ECC_FA_FAIL_ECC_ADDR FLASH_ECC_FA_FAIL_ECC_ADDR_Msk
14494/******************************************************************************/
14495/* */
14496/* Flexible Memory Controller */
14497/* */
14498/******************************************************************************/
14499/****************** Bit definition for FMC_BCR1 register *******************/
14500#define FMC_BCR1_CCLKEN_Pos (20U)
14501#define FMC_BCR1_CCLKEN_Msk (0x1UL << FMC_BCR1_CCLKEN_Pos)
14502#define FMC_BCR1_CCLKEN FMC_BCR1_CCLKEN_Msk
14503#define FMC_BCR1_WFDIS_Pos (21U)
14504#define FMC_BCR1_WFDIS_Msk (0x1UL << FMC_BCR1_WFDIS_Pos)
14505#define FMC_BCR1_WFDIS FMC_BCR1_WFDIS_Msk
14507#define FMC_BCR1_BMAP_Pos (24U)
14508#define FMC_BCR1_BMAP_Msk (0x3UL << FMC_BCR1_BMAP_Pos)
14509#define FMC_BCR1_BMAP FMC_BCR1_BMAP_Msk
14510#define FMC_BCR1_BMAP_0 (0x1UL << FMC_BCR1_BMAP_Pos)
14511#define FMC_BCR1_BMAP_1 (0x2UL << FMC_BCR1_BMAP_Pos)
14513#define FMC_BCR1_FMCEN_Pos (31U)
14514#define FMC_BCR1_FMCEN_Msk (0x1UL << FMC_BCR1_FMCEN_Pos)
14515#define FMC_BCR1_FMCEN FMC_BCR1_FMCEN_Msk
14516/****************** Bit definition for FMC_BCRx registers (x=1..4) *********/
14517#define FMC_BCRx_MBKEN_Pos (0U)
14518#define FMC_BCRx_MBKEN_Msk (0x1UL << FMC_BCRx_MBKEN_Pos)
14519#define FMC_BCRx_MBKEN FMC_BCRx_MBKEN_Msk
14520#define FMC_BCRx_MUXEN_Pos (1U)
14521#define FMC_BCRx_MUXEN_Msk (0x1UL << FMC_BCRx_MUXEN_Pos)
14522#define FMC_BCRx_MUXEN FMC_BCRx_MUXEN_Msk
14524#define FMC_BCRx_MTYP_Pos (2U)
14525#define FMC_BCRx_MTYP_Msk (0x3UL << FMC_BCRx_MTYP_Pos)
14526#define FMC_BCRx_MTYP FMC_BCRx_MTYP_Msk
14527#define FMC_BCRx_MTYP_0 (0x1UL << FMC_BCRx_MTYP_Pos)
14528#define FMC_BCRx_MTYP_1 (0x2UL << FMC_BCRx_MTYP_Pos)
14530#define FMC_BCRx_MWID_Pos (4U)
14531#define FMC_BCRx_MWID_Msk (0x3UL << FMC_BCRx_MWID_Pos)
14532#define FMC_BCRx_MWID FMC_BCRx_MWID_Msk
14533#define FMC_BCRx_MWID_0 (0x1UL << FMC_BCRx_MWID_Pos)
14534#define FMC_BCRx_MWID_1 (0x2UL << FMC_BCRx_MWID_Pos)
14536#define FMC_BCRx_FACCEN_Pos (6U)
14537#define FMC_BCRx_FACCEN_Msk (0x1UL << FMC_BCRx_FACCEN_Pos)
14538#define FMC_BCRx_FACCEN FMC_BCRx_FACCEN_Msk
14539#define FMC_BCRx_BURSTEN_Pos (8U)
14540#define FMC_BCRx_BURSTEN_Msk (0x1UL << FMC_BCRx_BURSTEN_Pos)
14541#define FMC_BCRx_BURSTEN FMC_BCRx_BURSTEN_Msk
14542#define FMC_BCRx_WAITPOL_Pos (9U)
14543#define FMC_BCRx_WAITPOL_Msk (0x1UL << FMC_BCRx_WAITPOL_Pos)
14544#define FMC_BCRx_WAITPOL FMC_BCRx_WAITPOL_Msk
14545#define FMC_BCRx_WAITCFG_Pos (11U)
14546#define FMC_BCRx_WAITCFG_Msk (0x1UL << FMC_BCRx_WAITCFG_Pos)
14547#define FMC_BCRx_WAITCFG FMC_BCRx_WAITCFG_Msk
14548#define FMC_BCRx_WREN_Pos (12U)
14549#define FMC_BCRx_WREN_Msk (0x1UL << FMC_BCRx_WREN_Pos)
14550#define FMC_BCRx_WREN FMC_BCRx_WREN_Msk
14551#define FMC_BCRx_WAITEN_Pos (13U)
14552#define FMC_BCRx_WAITEN_Msk (0x1UL << FMC_BCRx_WAITEN_Pos)
14553#define FMC_BCRx_WAITEN FMC_BCRx_WAITEN_Msk
14554#define FMC_BCRx_EXTMOD_Pos (14U)
14555#define FMC_BCRx_EXTMOD_Msk (0x1UL << FMC_BCRx_EXTMOD_Pos)
14556#define FMC_BCRx_EXTMOD FMC_BCRx_EXTMOD_Msk
14557#define FMC_BCRx_ASYNCWAIT_Pos (15U)
14558#define FMC_BCRx_ASYNCWAIT_Msk (0x1UL << FMC_BCRx_ASYNCWAIT_Pos)
14559#define FMC_BCRx_ASYNCWAIT FMC_BCRx_ASYNCWAIT_Msk
14561#define FMC_BCRx_CPSIZE_Pos (16U)
14562#define FMC_BCRx_CPSIZE_Msk (0x7UL << FMC_BCRx_CPSIZE_Pos)
14563#define FMC_BCRx_CPSIZE FMC_BCRx_CPSIZE_Msk
14564#define FMC_BCRx_CPSIZE_0 (0x1UL << FMC_BCRx_CPSIZE_Pos)
14565#define FMC_BCRx_CPSIZE_1 (0x2UL << FMC_BCRx_CPSIZE_Pos)
14566#define FMC_BCRx_CPSIZE_2 (0x4UL << FMC_BCRx_CPSIZE_Pos)
14568#define FMC_BCRx_CBURSTRW_Pos (19U)
14569#define FMC_BCRx_CBURSTRW_Msk (0x1UL << FMC_BCRx_CBURSTRW_Pos)
14570#define FMC_BCRx_CBURSTRW FMC_BCRx_CBURSTRW_Msk
14572/****************** Bit definition for FMC_BTRx registers (x=1..4) *********/
14573#define FMC_BTRx_ADDSET_Pos (0U)
14574#define FMC_BTRx_ADDSET_Msk (0xFUL << FMC_BTRx_ADDSET_Pos)
14575#define FMC_BTRx_ADDSET FMC_BTRx_ADDSET_Msk
14576#define FMC_BTRx_ADDSET_0 (0x1UL << FMC_BTRx_ADDSET_Pos)
14577#define FMC_BTRx_ADDSET_1 (0x2UL << FMC_BTRx_ADDSET_Pos)
14578#define FMC_BTRx_ADDSET_2 (0x4UL << FMC_BTRx_ADDSET_Pos)
14579#define FMC_BTRx_ADDSET_3 (0x8UL << FMC_BTRx_ADDSET_Pos)
14581#define FMC_BTRx_ADDHLD_Pos (4U)
14582#define FMC_BTRx_ADDHLD_Msk (0xFUL << FMC_BTRx_ADDHLD_Pos)
14583#define FMC_BTRx_ADDHLD FMC_BTRx_ADDHLD_Msk
14584#define FMC_BTRx_ADDHLD_0 (0x1UL << FMC_BTRx_ADDHLD_Pos)
14585#define FMC_BTRx_ADDHLD_1 (0x2UL << FMC_BTRx_ADDHLD_Pos)
14586#define FMC_BTRx_ADDHLD_2 (0x4UL << FMC_BTRx_ADDHLD_Pos)
14587#define FMC_BTRx_ADDHLD_3 (0x8UL << FMC_BTRx_ADDHLD_Pos)
14589#define FMC_BTRx_DATAST_Pos (8U)
14590#define FMC_BTRx_DATAST_Msk (0xFFUL << FMC_BTRx_DATAST_Pos)
14591#define FMC_BTRx_DATAST FMC_BTRx_DATAST_Msk
14592#define FMC_BTRx_DATAST_0 (0x01UL << FMC_BTRx_DATAST_Pos)
14593#define FMC_BTRx_DATAST_1 (0x02UL << FMC_BTRx_DATAST_Pos)
14594#define FMC_BTRx_DATAST_2 (0x04UL << FMC_BTRx_DATAST_Pos)
14595#define FMC_BTRx_DATAST_3 (0x08UL << FMC_BTRx_DATAST_Pos)
14596#define FMC_BTRx_DATAST_4 (0x10UL << FMC_BTRx_DATAST_Pos)
14597#define FMC_BTRx_DATAST_5 (0x20UL << FMC_BTRx_DATAST_Pos)
14598#define FMC_BTRx_DATAST_6 (0x40UL << FMC_BTRx_DATAST_Pos)
14599#define FMC_BTRx_DATAST_7 (0x80UL << FMC_BTRx_DATAST_Pos)
14601#define FMC_BTRx_BUSTURN_Pos (16U)
14602#define FMC_BTRx_BUSTURN_Msk (0xFUL << FMC_BTRx_BUSTURN_Pos)
14603#define FMC_BTRx_BUSTURN FMC_BTRx_BUSTURN_Msk
14604#define FMC_BTRx_BUSTURN_0 (0x1UL << FMC_BTRx_BUSTURN_Pos)
14605#define FMC_BTRx_BUSTURN_1 (0x2UL << FMC_BTRx_BUSTURN_Pos)
14606#define FMC_BTRx_BUSTURN_2 (0x4UL << FMC_BTRx_BUSTURN_Pos)
14607#define FMC_BTRx_BUSTURN_3 (0x8UL << FMC_BTRx_BUSTURN_Pos)
14609#define FMC_BTRx_CLKDIV_Pos (20U)
14610#define FMC_BTRx_CLKDIV_Msk (0xFUL << FMC_BTRx_CLKDIV_Pos)
14611#define FMC_BTRx_CLKDIV FMC_BTRx_CLKDIV_Msk
14612#define FMC_BTRx_CLKDIV_0 (0x1UL << FMC_BTRx_CLKDIV_Pos)
14613#define FMC_BTRx_CLKDIV_1 (0x2UL << FMC_BTRx_CLKDIV_Pos)
14614#define FMC_BTRx_CLKDIV_2 (0x4UL << FMC_BTRx_CLKDIV_Pos)
14615#define FMC_BTRx_CLKDIV_3 (0x8UL << FMC_BTRx_CLKDIV_Pos)
14617#define FMC_BTRx_DATLAT_Pos (24U)
14618#define FMC_BTRx_DATLAT_Msk (0xFUL << FMC_BTRx_DATLAT_Pos)
14619#define FMC_BTRx_DATLAT FMC_BTRx_DATLAT_Msk
14620#define FMC_BTRx_DATLAT_0 (0x1UL << FMC_BTRx_DATLAT_Pos)
14621#define FMC_BTRx_DATLAT_1 (0x2UL << FMC_BTRx_DATLAT_Pos)
14622#define FMC_BTRx_DATLAT_2 (0x4UL << FMC_BTRx_DATLAT_Pos)
14623#define FMC_BTRx_DATLAT_3 (0x8UL << FMC_BTRx_DATLAT_Pos)
14625#define FMC_BTRx_ACCMOD_Pos (28U)
14626#define FMC_BTRx_ACCMOD_Msk (0x3UL << FMC_BTRx_ACCMOD_Pos)
14627#define FMC_BTRx_ACCMOD FMC_BTRx_ACCMOD_Msk
14628#define FMC_BTRx_ACCMOD_0 (0x1UL << FMC_BTRx_ACCMOD_Pos)
14629#define FMC_BTRx_ACCMOD_1 (0x2UL << FMC_BTRx_ACCMOD_Pos)
14631/****************** Bit definition for FMC_BWTRx registers (x=1..4) *********/
14632#define FMC_BWTRx_ADDSET_Pos (0U)
14633#define FMC_BWTRx_ADDSET_Msk (0xFUL << FMC_BWTRx_ADDSET_Pos)
14634#define FMC_BWTRx_ADDSET FMC_BWTRx_ADDSET_Msk
14635#define FMC_BWTRx_ADDSET_0 (0x1UL << FMC_BWTRx_ADDSET_Pos)
14636#define FMC_BWTRx_ADDSET_1 (0x2UL << FMC_BWTRx_ADDSET_Pos)
14637#define FMC_BWTRx_ADDSET_2 (0x4UL << FMC_BWTRx_ADDSET_Pos)
14638#define FMC_BWTRx_ADDSET_3 (0x8UL << FMC_BWTRx_ADDSET_Pos)
14640#define FMC_BWTRx_ADDHLD_Pos (4U)
14641#define FMC_BWTRx_ADDHLD_Msk (0xFUL << FMC_BWTRx_ADDHLD_Pos)
14642#define FMC_BWTRx_ADDHLD FMC_BWTRx_ADDHLD_Msk
14643#define FMC_BWTRx_ADDHLD_0 (0x1UL << FMC_BWTRx_ADDHLD_Pos)
14644#define FMC_BWTRx_ADDHLD_1 (0x2UL << FMC_BWTRx_ADDHLD_Pos)
14645#define FMC_BWTRx_ADDHLD_2 (0x4UL << FMC_BWTRx_ADDHLD_Pos)
14646#define FMC_BWTRx_ADDHLD_3 (0x8UL << FMC_BWTRx_ADDHLD_Pos)
14648#define FMC_BWTRx_DATAST_Pos (8U)
14649#define FMC_BWTRx_DATAST_Msk (0xFFUL << FMC_BWTRx_DATAST_Pos)
14650#define FMC_BWTRx_DATAST FMC_BWTRx_DATAST_Msk
14651#define FMC_BWTRx_DATAST_0 (0x01UL << FMC_BWTRx_DATAST_Pos)
14652#define FMC_BWTRx_DATAST_1 (0x02UL << FMC_BWTRx_DATAST_Pos)
14653#define FMC_BWTRx_DATAST_2 (0x04UL << FMC_BWTRx_DATAST_Pos)
14654#define FMC_BWTRx_DATAST_3 (0x08UL << FMC_BWTRx_DATAST_Pos)
14655#define FMC_BWTRx_DATAST_4 (0x10UL << FMC_BWTRx_DATAST_Pos)
14656#define FMC_BWTRx_DATAST_5 (0x20UL << FMC_BWTRx_DATAST_Pos)
14657#define FMC_BWTRx_DATAST_6 (0x40UL << FMC_BWTRx_DATAST_Pos)
14658#define FMC_BWTRx_DATAST_7 (0x80UL << FMC_BWTRx_DATAST_Pos)
14660#define FMC_BWTRx_BUSTURN_Pos (16U)
14661#define FMC_BWTRx_BUSTURN_Msk (0xFUL << FMC_BWTRx_BUSTURN_Pos)
14662#define FMC_BWTRx_BUSTURN FMC_BWTRx_BUSTURN_Msk
14663#define FMC_BWTRx_BUSTURN_0 (0x1UL << FMC_BWTRx_BUSTURN_Pos)
14664#define FMC_BWTRx_BUSTURN_1 (0x2UL << FMC_BWTRx_BUSTURN_Pos)
14665#define FMC_BWTRx_BUSTURN_2 (0x4UL << FMC_BWTRx_BUSTURN_Pos)
14666#define FMC_BWTRx_BUSTURN_3 (0x8UL << FMC_BWTRx_BUSTURN_Pos)
14668#define FMC_BWTRx_ACCMOD_Pos (28U)
14669#define FMC_BWTRx_ACCMOD_Msk (0x3UL << FMC_BWTRx_ACCMOD_Pos)
14670#define FMC_BWTRx_ACCMOD FMC_BWTRx_ACCMOD_Msk
14671#define FMC_BWTRx_ACCMOD_0 (0x1UL << FMC_BWTRx_ACCMOD_Pos)
14672#define FMC_BWTRx_ACCMOD_1 (0x2UL << FMC_BWTRx_ACCMOD_Pos)
14674/****************** Bit definition for FMC_PCR register *******************/
14675#define FMC_PCR_PWAITEN_Pos (1U)
14676#define FMC_PCR_PWAITEN_Msk (0x1UL << FMC_PCR_PWAITEN_Pos)
14677#define FMC_PCR_PWAITEN FMC_PCR_PWAITEN_Msk
14678#define FMC_PCR_PBKEN_Pos (2U)
14679#define FMC_PCR_PBKEN_Msk (0x1UL << FMC_PCR_PBKEN_Pos)
14680#define FMC_PCR_PBKEN FMC_PCR_PBKEN_Msk
14682#define FMC_PCR_PWID_Pos (4U)
14683#define FMC_PCR_PWID_Msk (0x3UL << FMC_PCR_PWID_Pos)
14684#define FMC_PCR_PWID FMC_PCR_PWID_Msk
14685#define FMC_PCR_PWID_0 (0x1UL << FMC_PCR_PWID_Pos)
14686#define FMC_PCR_PWID_1 (0x2UL << FMC_PCR_PWID_Pos)
14688#define FMC_PCR_ECCEN_Pos (6U)
14689#define FMC_PCR_ECCEN_Msk (0x1UL << FMC_PCR_ECCEN_Pos)
14690#define FMC_PCR_ECCEN FMC_PCR_ECCEN_Msk
14692#define FMC_PCR_TCLR_Pos (9U)
14693#define FMC_PCR_TCLR_Msk (0xFUL << FMC_PCR_TCLR_Pos)
14694#define FMC_PCR_TCLR FMC_PCR_TCLR_Msk
14695#define FMC_PCR_TCLR_0 (0x1UL << FMC_PCR_TCLR_Pos)
14696#define FMC_PCR_TCLR_1 (0x2UL << FMC_PCR_TCLR_Pos)
14697#define FMC_PCR_TCLR_2 (0x4UL << FMC_PCR_TCLR_Pos)
14698#define FMC_PCR_TCLR_3 (0x8UL << FMC_PCR_TCLR_Pos)
14700#define FMC_PCR_TAR_Pos (13U)
14701#define FMC_PCR_TAR_Msk (0xFUL << FMC_PCR_TAR_Pos)
14702#define FMC_PCR_TAR FMC_PCR_TAR_Msk
14703#define FMC_PCR_TAR_0 (0x1UL << FMC_PCR_TAR_Pos)
14704#define FMC_PCR_TAR_1 (0x2UL << FMC_PCR_TAR_Pos)
14705#define FMC_PCR_TAR_2 (0x4UL << FMC_PCR_TAR_Pos)
14706#define FMC_PCR_TAR_3 (0x8UL << FMC_PCR_TAR_Pos)
14708#define FMC_PCR_ECCPS_Pos (17U)
14709#define FMC_PCR_ECCPS_Msk (0x7UL << FMC_PCR_ECCPS_Pos)
14710#define FMC_PCR_ECCPS FMC_PCR_ECCPS_Msk
14711#define FMC_PCR_ECCPS_0 (0x1UL << FMC_PCR_ECCPS_Pos)
14712#define FMC_PCR_ECCPS_1 (0x2UL << FMC_PCR_ECCPS_Pos)
14713#define FMC_PCR_ECCPS_2 (0x4UL << FMC_PCR_ECCPS_Pos)
14715/******************* Bit definition for FMC_SR register *******************/
14716#define FMC_SR_IRS_Pos (0U)
14717#define FMC_SR_IRS_Msk (0x1UL << FMC_SR_IRS_Pos)
14718#define FMC_SR_IRS FMC_SR_IRS_Msk
14719#define FMC_SR_ILS_Pos (1U)
14720#define FMC_SR_ILS_Msk (0x1UL << FMC_SR_ILS_Pos)
14721#define FMC_SR_ILS FMC_SR_ILS_Msk
14722#define FMC_SR_IFS_Pos (2U)
14723#define FMC_SR_IFS_Msk (0x1UL << FMC_SR_IFS_Pos)
14724#define FMC_SR_IFS FMC_SR_IFS_Msk
14725#define FMC_SR_IREN_Pos (3U)
14726#define FMC_SR_IREN_Msk (0x1UL << FMC_SR_IREN_Pos)
14727#define FMC_SR_IREN FMC_SR_IREN_Msk
14728#define FMC_SR_ILEN_Pos (4U)
14729#define FMC_SR_ILEN_Msk (0x1UL << FMC_SR_ILEN_Pos)
14730#define FMC_SR_ILEN FMC_SR_ILEN_Msk
14731#define FMC_SR_IFEN_Pos (5U)
14732#define FMC_SR_IFEN_Msk (0x1UL << FMC_SR_IFEN_Pos)
14733#define FMC_SR_IFEN FMC_SR_IFEN_Msk
14734#define FMC_SR_FEMPT_Pos (6U)
14735#define FMC_SR_FEMPT_Msk (0x1UL << FMC_SR_FEMPT_Pos)
14736#define FMC_SR_FEMPT FMC_SR_FEMPT_Msk
14738/****************** Bit definition for FMC_PMEM register ******************/
14739#define FMC_PMEM_MEMSET_Pos (0U)
14740#define FMC_PMEM_MEMSET_Msk (0xFFUL << FMC_PMEM_MEMSET_Pos)
14741#define FMC_PMEM_MEMSET FMC_PMEM_MEMSET_Msk
14742#define FMC_PMEM_MEMSET_0 (0x01UL << FMC_PMEM_MEMSET_Pos)
14743#define FMC_PMEM_MEMSET_1 (0x02UL << FMC_PMEM_MEMSET_Pos)
14744#define FMC_PMEM_MEMSET_2 (0x04UL << FMC_PMEM_MEMSET_Pos)
14745#define FMC_PMEM_MEMSET_3 (0x08UL << FMC_PMEM_MEMSET_Pos)
14746#define FMC_PMEM_MEMSET_4 (0x10UL << FMC_PMEM_MEMSET_Pos)
14747#define FMC_PMEM_MEMSET_5 (0x20UL << FMC_PMEM_MEMSET_Pos)
14748#define FMC_PMEM_MEMSET_6 (0x40UL << FMC_PMEM_MEMSET_Pos)
14749#define FMC_PMEM_MEMSET_7 (0x80UL << FMC_PMEM_MEMSET_Pos)
14751#define FMC_PMEM_MEMWAIT_Pos (8U)
14752#define FMC_PMEM_MEMWAIT_Msk (0xFFUL << FMC_PMEM_MEMWAIT_Pos)
14753#define FMC_PMEM_MEMWAIT FMC_PMEM_MEMWAIT_Msk
14754#define FMC_PMEM_MEMWAIT_0 (0x01UL << FMC_PMEM_MEMWAIT_Pos)
14755#define FMC_PMEM_MEMWAIT_1 (0x02UL << FMC_PMEM_MEMWAIT_Pos)
14756#define FMC_PMEM_MEMWAIT_2 (0x04UL << FMC_PMEM_MEMWAIT_Pos)
14757#define FMC_PMEM_MEMWAIT_3 (0x08UL << FMC_PMEM_MEMWAIT_Pos)
14758#define FMC_PMEM_MEMWAIT_4 (0x10UL << FMC_PMEM_MEMWAIT_Pos)
14759#define FMC_PMEM_MEMWAIT_5 (0x20UL << FMC_PMEM_MEMWAIT_Pos)
14760#define FMC_PMEM_MEMWAIT_6 (0x40UL << FMC_PMEM_MEMWAIT_Pos)
14761#define FMC_PMEM_MEMWAIT_7 (0x80UL << FMC_PMEM_MEMWAIT_Pos)
14763#define FMC_PMEM_MEMHOLD_Pos (16U)
14764#define FMC_PMEM_MEMHOLD_Msk (0xFFUL << FMC_PMEM_MEMHOLD_Pos)
14765#define FMC_PMEM_MEMHOLD FMC_PMEM_MEMHOLD_Msk
14766#define FMC_PMEM_MEMHOLD_0 (0x01UL << FMC_PMEM_MEMHOLD_Pos)
14767#define FMC_PMEM_MEMHOLD_1 (0x02UL << FMC_PMEM_MEMHOLD_Pos)
14768#define FMC_PMEM_MEMHOLD_2 (0x04UL << FMC_PMEM_MEMHOLD_Pos)
14769#define FMC_PMEM_MEMHOLD_3 (0x08UL << FMC_PMEM_MEMHOLD_Pos)
14770#define FMC_PMEM_MEMHOLD_4 (0x10UL << FMC_PMEM_MEMHOLD_Pos)
14771#define FMC_PMEM_MEMHOLD_5 (0x20UL << FMC_PMEM_MEMHOLD_Pos)
14772#define FMC_PMEM_MEMHOLD_6 (0x40UL << FMC_PMEM_MEMHOLD_Pos)
14773#define FMC_PMEM_MEMHOLD_7 (0x80UL << FMC_PMEM_MEMHOLD_Pos)
14775#define FMC_PMEM_MEMHIZ_Pos (24U)
14776#define FMC_PMEM_MEMHIZ_Msk (0xFFUL << FMC_PMEM_MEMHIZ_Pos)
14777#define FMC_PMEM_MEMHIZ FMC_PMEM_MEMHIZ_Msk
14778#define FMC_PMEM_MEMHIZ_0 (0x01UL << FMC_PMEM_MEMHIZ_Pos)
14779#define FMC_PMEM_MEMHIZ_1 (0x02UL << FMC_PMEM_MEMHIZ_Pos)
14780#define FMC_PMEM_MEMHIZ_2 (0x04UL << FMC_PMEM_MEMHIZ_Pos)
14781#define FMC_PMEM_MEMHIZ_3 (0x08UL << FMC_PMEM_MEMHIZ_Pos)
14782#define FMC_PMEM_MEMHIZ_4 (0x10UL << FMC_PMEM_MEMHIZ_Pos)
14783#define FMC_PMEM_MEMHIZ_5 (0x20UL << FMC_PMEM_MEMHIZ_Pos)
14784#define FMC_PMEM_MEMHIZ_6 (0x40UL << FMC_PMEM_MEMHIZ_Pos)
14785#define FMC_PMEM_MEMHIZ_7 (0x80UL << FMC_PMEM_MEMHIZ_Pos)
14787/****************** Bit definition for FMC_PATT register ******************/
14788#define FMC_PATT_ATTSET_Pos (0U)
14789#define FMC_PATT_ATTSET_Msk (0xFFUL << FMC_PATT_ATTSET_Pos)
14790#define FMC_PATT_ATTSET FMC_PATT_ATTSET_Msk
14791#define FMC_PATT_ATTSET_0 (0x01UL << FMC_PATT_ATTSET_Pos)
14792#define FMC_PATT_ATTSET_1 (0x02UL << FMC_PATT_ATTSET_Pos)
14793#define FMC_PATT_ATTSET_2 (0x04UL << FMC_PATT_ATTSET_Pos)
14794#define FMC_PATT_ATTSET_3 (0x08UL << FMC_PATT_ATTSET_Pos)
14795#define FMC_PATT_ATTSET_4 (0x10UL << FMC_PATT_ATTSET_Pos)
14796#define FMC_PATT_ATTSET_5 (0x20UL << FMC_PATT_ATTSET_Pos)
14797#define FMC_PATT_ATTSET_6 (0x40UL << FMC_PATT_ATTSET_Pos)
14798#define FMC_PATT_ATTSET_7 (0x80UL << FMC_PATT_ATTSET_Pos)
14800#define FMC_PATT_ATTWAIT_Pos (8U)
14801#define FMC_PATT_ATTWAIT_Msk (0xFFUL << FMC_PATT_ATTWAIT_Pos)
14802#define FMC_PATT_ATTWAIT FMC_PATT_ATTWAIT_Msk
14803#define FMC_PATT_ATTWAIT_0 (0x01UL << FMC_PATT_ATTWAIT_Pos)
14804#define FMC_PATT_ATTWAIT_1 (0x02UL << FMC_PATT_ATTWAIT_Pos)
14805#define FMC_PATT_ATTWAIT_2 (0x04UL << FMC_PATT_ATTWAIT_Pos)
14806#define FMC_PATT_ATTWAIT_3 (0x08UL << FMC_PATT_ATTWAIT_Pos)
14807#define FMC_PATT_ATTWAIT_4 (0x10UL << FMC_PATT_ATTWAIT_Pos)
14808#define FMC_PATT_ATTWAIT_5 (0x20UL << FMC_PATT_ATTWAIT_Pos)
14809#define FMC_PATT_ATTWAIT_6 (0x40UL << FMC_PATT_ATTWAIT_Pos)
14810#define FMC_PATT_ATTWAIT_7 (0x80UL << FMC_PATT_ATTWAIT_Pos)
14812#define FMC_PATT_ATTHOLD_Pos (16U)
14813#define FMC_PATT_ATTHOLD_Msk (0xFFUL << FMC_PATT_ATTHOLD_Pos)
14814#define FMC_PATT_ATTHOLD FMC_PATT_ATTHOLD_Msk
14815#define FMC_PATT_ATTHOLD_0 (0x01UL << FMC_PATT_ATTHOLD_Pos)
14816#define FMC_PATT_ATTHOLD_1 (0x02UL << FMC_PATT_ATTHOLD_Pos)
14817#define FMC_PATT_ATTHOLD_2 (0x04UL << FMC_PATT_ATTHOLD_Pos)
14818#define FMC_PATT_ATTHOLD_3 (0x08UL << FMC_PATT_ATTHOLD_Pos)
14819#define FMC_PATT_ATTHOLD_4 (0x10UL << FMC_PATT_ATTHOLD_Pos)
14820#define FMC_PATT_ATTHOLD_5 (0x20UL << FMC_PATT_ATTHOLD_Pos)
14821#define FMC_PATT_ATTHOLD_6 (0x40UL << FMC_PATT_ATTHOLD_Pos)
14822#define FMC_PATT_ATTHOLD_7 (0x80UL << FMC_PATT_ATTHOLD_Pos)
14824#define FMC_PATT_ATTHIZ_Pos (24U)
14825#define FMC_PATT_ATTHIZ_Msk (0xFFUL << FMC_PATT_ATTHIZ_Pos)
14826#define FMC_PATT_ATTHIZ FMC_PATT_ATTHIZ_Msk
14827#define FMC_PATT_ATTHIZ_0 (0x01UL << FMC_PATT_ATTHIZ_Pos)
14828#define FMC_PATT_ATTHIZ_1 (0x02UL << FMC_PATT_ATTHIZ_Pos)
14829#define FMC_PATT_ATTHIZ_2 (0x04UL << FMC_PATT_ATTHIZ_Pos)
14830#define FMC_PATT_ATTHIZ_3 (0x08UL << FMC_PATT_ATTHIZ_Pos)
14831#define FMC_PATT_ATTHIZ_4 (0x10UL << FMC_PATT_ATTHIZ_Pos)
14832#define FMC_PATT_ATTHIZ_5 (0x20UL << FMC_PATT_ATTHIZ_Pos)
14833#define FMC_PATT_ATTHIZ_6 (0x40UL << FMC_PATT_ATTHIZ_Pos)
14834#define FMC_PATT_ATTHIZ_7 (0x80UL << FMC_PATT_ATTHIZ_Pos)
14836/****************** Bit definition for FMC_ECCR3 register ******************/
14837#define FMC_ECCR3_ECC3_Pos (0U)
14838#define FMC_ECCR3_ECC3_Msk (0xFFFFFFFFUL << FMC_ECCR3_ECC3_Pos)
14839#define FMC_ECCR3_ECC3 FMC_ECCR3_ECC3_Msk
14841/****************** Bit definition for FMC_SDCRx registers (x=1..4) *********/
14842#define FMC_SDCRx_NC_Pos (0U)
14843#define FMC_SDCRx_NC_Msk (0x3UL << FMC_SDCRx_NC_Pos)
14844#define FMC_SDCRx_NC FMC_SDCRx_NC_Msk
14845#define FMC_SDCRx_NC_0 (0x1UL << FMC_SDCRx_NC_Pos)
14846#define FMC_SDCRx_NC_1 (0x2UL << FMC_SDCRx_NC_Pos)
14848#define FMC_SDCRx_NR_Pos (2U)
14849#define FMC_SDCRx_NR_Msk (0x3UL << FMC_SDCRx_NR_Pos)
14850#define FMC_SDCRx_NR FMC_SDCRx_NR_Msk
14851#define FMC_SDCRx_NR_0 (0x1UL << FMC_SDCRx_NR_Pos)
14852#define FMC_SDCRx_NR_1 (0x2UL << FMC_SDCRx_NR_Pos)
14854#define FMC_SDCRx_MWID_Pos (4U)
14855#define FMC_SDCRx_MWID_Msk (0x3UL << FMC_SDCRx_MWID_Pos)
14856#define FMC_SDCRx_MWID FMC_SDCRx_MWID_Msk
14857#define FMC_SDCRx_MWID_0 (0x1UL << FMC_SDCRx_MWID_Pos)
14858#define FMC_SDCRx_MWID_1 (0x2UL << FMC_SDCRx_MWID_Pos)
14860#define FMC_SDCRx_NB_Pos (6U)
14861#define FMC_SDCRx_NB_Msk (0x1UL << FMC_SDCRx_NB_Pos)
14862#define FMC_SDCRx_NB FMC_SDCRx_NB_Msk
14864#define FMC_SDCRx_CAS_Pos (7U)
14865#define FMC_SDCRx_CAS_Msk (0x3UL << FMC_SDCRx_CAS_Pos)
14866#define FMC_SDCRx_CAS FMC_SDCRx_CAS_Msk
14867#define FMC_SDCRx_CAS_0 (0x1UL << FMC_SDCRx_CAS_Pos)
14868#define FMC_SDCRx_CAS_1 (0x2UL << FMC_SDCRx_CAS_Pos)
14870#define FMC_SDCRx_WP_Pos (9U)
14871#define FMC_SDCRx_WP_Msk (0x1UL << FMC_SDCRx_WP_Pos)
14872#define FMC_SDCRx_WP FMC_SDCRx_WP_Msk
14874#define FMC_SDCRx_SDCLK_Pos (10U)
14875#define FMC_SDCRx_SDCLK_Msk (0x3UL << FMC_SDCRx_SDCLK_Pos)
14876#define FMC_SDCRx_SDCLK FMC_SDCRx_SDCLK_Msk
14877#define FMC_SDCRx_SDCLK_0 (0x1UL << FMC_SDCRx_SDCLK_Pos)
14878#define FMC_SDCRx_SDCLK_1 (0x2UL << FMC_SDCRx_SDCLK_Pos)
14880#define FMC_SDCRx_RBURST_Pos (12U)
14881#define FMC_SDCRx_RBURST_Msk (0x1UL << FMC_SDCRx_RBURST_Pos)
14882#define FMC_SDCRx_RBURST FMC_SDCRx_RBURST_Msk
14884#define FMC_SDCRx_RPIPE_Pos (13U)
14885#define FMC_SDCRx_RPIPE_Msk (0x3UL << FMC_SDCRx_RPIPE_Pos)
14886#define FMC_SDCRx_RPIPE FMC_SDCRx_RPIPE_Msk
14887#define FMC_SDCRx_RPIPE_0 (0x1UL << FMC_SDCRx_RPIPE_Pos)
14888#define FMC_SDCRx_RPIPE_1 (0x2UL << FMC_SDCRx_RPIPE_Pos)
14890/****************** Bit definition for FMC_SDTRx(1,2) register ******************/
14891#define FMC_SDTRx_TMRD_Pos (0U)
14892#define FMC_SDTRx_TMRD_Msk (0xFUL << FMC_SDTRx_TMRD_Pos)
14893#define FMC_SDTRx_TMRD FMC_SDTRx_TMRD_Msk
14894#define FMC_SDTRx_TMRD_0 (0x1UL << FMC_SDTRx_TMRD_Pos)
14895#define FMC_SDTRx_TMRD_1 (0x2UL << FMC_SDTRx_TMRD_Pos)
14896#define FMC_SDTRx_TMRD_2 (0x4UL << FMC_SDTRx_TMRD_Pos)
14897#define FMC_SDTRx_TMRD_3 (0x8UL << FMC_SDTRx_TMRD_Pos)
14899#define FMC_SDTRx_TXSR_Pos (4U)
14900#define FMC_SDTRx_TXSR_Msk (0xFUL << FMC_SDTRx_TXSR_Pos)
14901#define FMC_SDTRx_TXSR FMC_SDTRx_TXSR_Msk
14902#define FMC_SDTRx_TXSR_0 (0x1UL << FMC_SDTRx_TXSR_Pos)
14903#define FMC_SDTRx_TXSR_1 (0x2UL << FMC_SDTRx_TXSR_Pos)
14904#define FMC_SDTRx_TXSR_2 (0x4UL << FMC_SDTRx_TXSR_Pos)
14905#define FMC_SDTRx_TXSR_3 (0x8UL << FMC_SDTRx_TXSR_Pos)
14907#define FMC_SDTRx_TRAS_Pos (8U)
14908#define FMC_SDTRx_TRAS_Msk (0xFUL << FMC_SDTRx_TRAS_Pos)
14909#define FMC_SDTRx_TRAS FMC_SDTRx_TRAS_Msk
14910#define FMC_SDTRx_TRAS_0 (0x1UL << FMC_SDTRx_TRAS_Pos)
14911#define FMC_SDTRx_TRAS_1 (0x2UL << FMC_SDTRx_TRAS_Pos)
14912#define FMC_SDTRx_TRAS_2 (0x4UL << FMC_SDTRx_TRAS_Pos)
14913#define FMC_SDTRx_TRAS_3 (0x8UL << FMC_SDTRx_TRAS_Pos)
14915#define FMC_SDTRx_TRC_Pos (12U)
14916#define FMC_SDTRx_TRC_Msk (0xFUL << FMC_SDTRx_TRC_Pos)
14917#define FMC_SDTRx_TRC FMC_SDTRx_TRC_Msk
14918#define FMC_SDTRx_TRC_0 (0x1UL << FMC_SDTRx_TRC_Pos)
14919#define FMC_SDTRx_TRC_1 (0x2UL << FMC_SDTRx_TRC_Pos)
14920#define FMC_SDTRx_TRC_2 (0x4UL << FMC_SDTRx_TRC_Pos)
14922#define FMC_SDTRx_TWR_Pos (16U)
14923#define FMC_SDTRx_TWR_Msk (0xFUL << FMC_SDTRx_TWR_Pos)
14924#define FMC_SDTRx_TWR FMC_SDTRx_TWR_Msk
14925#define FMC_SDTRx_TWR_0 (0x1UL << FMC_SDTRx_TWR_Pos)
14926#define FMC_SDTRx_TWR_1 (0x2UL << FMC_SDTRx_TWR_Pos)
14927#define FMC_SDTRx_TWR_2 (0x4UL << FMC_SDTRx_TWR_Pos)
14929#define FMC_SDTRx_TRP_Pos (20U)
14930#define FMC_SDTRx_TRP_Msk (0xFUL << FMC_SDTRx_TRP_Pos)
14931#define FMC_SDTRx_TRP FMC_SDTRx_TRP_Msk
14932#define FMC_SDTRx_TRP_0 (0x1UL << FMC_SDTRx_TRP_Pos)
14933#define FMC_SDTRx_TRP_1 (0x2UL << FMC_SDTRx_TRP_Pos)
14934#define FMC_SDTRx_TRP_2 (0x4UL << FMC_SDTRx_TRP_Pos)
14936#define FMC_SDTRx_TRCD_Pos (24U)
14937#define FMC_SDTRx_TRCD_Msk (0xFUL << FMC_SDTRx_TRCD_Pos)
14938#define FMC_SDTRx_TRCD FMC_SDTRx_TRCD_Msk
14939#define FMC_SDTRx_TRCD_0 (0x1UL << FMC_SDTRx_TRCD_Pos)
14940#define FMC_SDTRx_TRCD_1 (0x2UL << FMC_SDTRx_TRCD_Pos)
14941#define FMC_SDTRx_TRCD_2 (0x4UL << FMC_SDTRx_TRCD_Pos)
14943/****************** Bit definition for FMC_SDCMR register ******************/
14944#define FMC_SDCMR_MODE_Pos (0U)
14945#define FMC_SDCMR_MODE_Msk (0x7UL << FMC_SDCMR_MODE_Pos)
14946#define FMC_SDCMR_MODE FMC_SDCMR_MODE_Msk
14947#define FMC_SDCMR_MODE_0 (0x1UL << FMC_SDCMR_MODE_Pos)
14948#define FMC_SDCMR_MODE_1 (0x2UL << FMC_SDCMR_MODE_Pos)
14949#define FMC_SDCMR_MODE_2 (0x4UL << FMC_SDCMR_MODE_Pos)
14951#define FMC_SDCMR_CTB2_Pos (3U)
14952#define FMC_SDCMR_CTB2_Msk (0x1UL << FMC_SDCMR_CTB2_Pos)
14953#define FMC_SDCMR_CTB2 FMC_SDCMR_CTB2_Msk
14955#define FMC_SDCMR_CTB1_Pos (4U)
14956#define FMC_SDCMR_CTB1_Msk (0x1UL << FMC_SDCMR_CTB1_Pos)
14957#define FMC_SDCMR_CTB1 FMC_SDCMR_CTB1_Msk
14959#define FMC_SDCMR_NRFS_Pos (5U)
14960#define FMC_SDCMR_NRFS_Msk (0xFUL << FMC_SDCMR_NRFS_Pos)
14961#define FMC_SDCMR_NRFS FMC_SDCMR_NRFS_Msk
14962#define FMC_SDCMR_NRFS_0 (0x1UL << FMC_SDCMR_NRFS_Pos)
14963#define FMC_SDCMR_NRFS_1 (0x2UL << FMC_SDCMR_NRFS_Pos)
14964#define FMC_SDCMR_NRFS_2 (0x4UL << FMC_SDCMR_NRFS_Pos)
14965#define FMC_SDCMR_NRFS_3 (0x8UL << FMC_SDCMR_NRFS_Pos)
14967#define FMC_SDCMR_MRD_Pos (9U)
14968#define FMC_SDCMR_MRD_Msk (0x1FFFUL << FMC_SDCMR_MRD_Pos)
14969#define FMC_SDCMR_MRD FMC_SDCMR_MRD_Msk
14971/****************** Bit definition for FMC_SDRTR register ******************/
14972#define FMC_SDRTR_CRE_Pos (0U)
14973#define FMC_SDRTR_CRE_Msk (0x1UL << FMC_SDRTR_CRE_Pos)
14974#define FMC_SDRTR_CRE FMC_SDRTR_CRE_Msk
14976#define FMC_SDRTR_COUNT_Pos (1U)
14977#define FMC_SDRTR_COUNT_Msk (0x1FFFUL << FMC_SDRTR_COUNT_Pos)
14978#define FMC_SDRTR_COUNT FMC_SDRTR_COUNT_Msk
14980#define FMC_SDRTR_REIE_Pos (14U)
14981#define FMC_SDRTR_REIE_Msk (0x1UL << FMC_SDRTR_REIE_Pos)
14982#define FMC_SDRTR_REIE FMC_SDRTR_REIE_Msk
14984/****************** Bit definition for FMC_SDSR register ******************/
14985#define FMC_SDSR_RE_Pos (0U)
14986#define FMC_SDSR_RE_Msk (0x1UL << FMC_SDSR_RE_Pos)
14987#define FMC_SDSR_RE FMC_SDSR_RE_Msk
14989#define FMC_SDSR_MODES1_Pos (1U)
14990#define FMC_SDSR_MODES1_Msk (0x3UL << FMC_SDSR_MODES1_Pos)
14991#define FMC_SDSR_MODES1 FMC_SDSR_MODES1_Msk
14992#define FMC_SDSR_MODES1_0 (0x1UL << FMC_SDSR_MODES1_Pos)
14993#define FMC_SDSR_MODES1_1 (0x2UL << FMC_SDSR_MODES1_Pos)
14995#define FMC_SDSR_MODES2_Pos (3U)
14996#define FMC_SDSR_MODES2_Msk (0x3UL << FMC_SDSR_MODES2_Pos)
14997#define FMC_SDSR_MODES2 FMC_SDSR_MODES2_Msk
14998#define FMC_SDSR_MODES2_0 (0x1UL << FMC_SDSR_MODES2_Pos)
14999#define FMC_SDSR_MODES2_1 (0x2UL << FMC_SDSR_MODES2_Pos)
15001/******************************************************************************/
15002/* */
15003/* General Purpose I/O */
15004/* */
15005/******************************************************************************/
15006/****************** Bits definition for GPIO_MODER register *****************/
15007#define GPIO_MODER_MODE0_Pos (0U)
15008#define GPIO_MODER_MODE0_Msk (0x3UL << GPIO_MODER_MODE0_Pos)
15009#define GPIO_MODER_MODE0 GPIO_MODER_MODE0_Msk
15010#define GPIO_MODER_MODE0_0 (0x1UL << GPIO_MODER_MODE0_Pos)
15011#define GPIO_MODER_MODE0_1 (0x2UL << GPIO_MODER_MODE0_Pos)
15013#define GPIO_MODER_MODE1_Pos (2U)
15014#define GPIO_MODER_MODE1_Msk (0x3UL << GPIO_MODER_MODE1_Pos)
15015#define GPIO_MODER_MODE1 GPIO_MODER_MODE1_Msk
15016#define GPIO_MODER_MODE1_0 (0x1UL << GPIO_MODER_MODE1_Pos)
15017#define GPIO_MODER_MODE1_1 (0x2UL << GPIO_MODER_MODE1_Pos)
15019#define GPIO_MODER_MODE2_Pos (4U)
15020#define GPIO_MODER_MODE2_Msk (0x3UL << GPIO_MODER_MODE2_Pos)
15021#define GPIO_MODER_MODE2 GPIO_MODER_MODE2_Msk
15022#define GPIO_MODER_MODE2_0 (0x1UL << GPIO_MODER_MODE2_Pos)
15023#define GPIO_MODER_MODE2_1 (0x2UL << GPIO_MODER_MODE2_Pos)
15025#define GPIO_MODER_MODE3_Pos (6U)
15026#define GPIO_MODER_MODE3_Msk (0x3UL << GPIO_MODER_MODE3_Pos)
15027#define GPIO_MODER_MODE3 GPIO_MODER_MODE3_Msk
15028#define GPIO_MODER_MODE3_0 (0x1UL << GPIO_MODER_MODE3_Pos)
15029#define GPIO_MODER_MODE3_1 (0x2UL << GPIO_MODER_MODE3_Pos)
15031#define GPIO_MODER_MODE4_Pos (8U)
15032#define GPIO_MODER_MODE4_Msk (0x3UL << GPIO_MODER_MODE4_Pos)
15033#define GPIO_MODER_MODE4 GPIO_MODER_MODE4_Msk
15034#define GPIO_MODER_MODE4_0 (0x1UL << GPIO_MODER_MODE4_Pos)
15035#define GPIO_MODER_MODE4_1 (0x2UL << GPIO_MODER_MODE4_Pos)
15037#define GPIO_MODER_MODE5_Pos (10U)
15038#define GPIO_MODER_MODE5_Msk (0x3UL << GPIO_MODER_MODE5_Pos)
15039#define GPIO_MODER_MODE5 GPIO_MODER_MODE5_Msk
15040#define GPIO_MODER_MODE5_0 (0x1UL << GPIO_MODER_MODE5_Pos)
15041#define GPIO_MODER_MODE5_1 (0x2UL << GPIO_MODER_MODE5_Pos)
15043#define GPIO_MODER_MODE6_Pos (12U)
15044#define GPIO_MODER_MODE6_Msk (0x3UL << GPIO_MODER_MODE6_Pos)
15045#define GPIO_MODER_MODE6 GPIO_MODER_MODE6_Msk
15046#define GPIO_MODER_MODE6_0 (0x1UL << GPIO_MODER_MODE6_Pos)
15047#define GPIO_MODER_MODE6_1 (0x2UL << GPIO_MODER_MODE6_Pos)
15049#define GPIO_MODER_MODE7_Pos (14U)
15050#define GPIO_MODER_MODE7_Msk (0x3UL << GPIO_MODER_MODE7_Pos)
15051#define GPIO_MODER_MODE7 GPIO_MODER_MODE7_Msk
15052#define GPIO_MODER_MODE7_0 (0x1UL << GPIO_MODER_MODE7_Pos)
15053#define GPIO_MODER_MODE7_1 (0x2UL << GPIO_MODER_MODE7_Pos)
15055#define GPIO_MODER_MODE8_Pos (16U)
15056#define GPIO_MODER_MODE8_Msk (0x3UL << GPIO_MODER_MODE8_Pos)
15057#define GPIO_MODER_MODE8 GPIO_MODER_MODE8_Msk
15058#define GPIO_MODER_MODE8_0 (0x1UL << GPIO_MODER_MODE8_Pos)
15059#define GPIO_MODER_MODE8_1 (0x2UL << GPIO_MODER_MODE8_Pos)
15061#define GPIO_MODER_MODE9_Pos (18U)
15062#define GPIO_MODER_MODE9_Msk (0x3UL << GPIO_MODER_MODE9_Pos)
15063#define GPIO_MODER_MODE9 GPIO_MODER_MODE9_Msk
15064#define GPIO_MODER_MODE9_0 (0x1UL << GPIO_MODER_MODE9_Pos)
15065#define GPIO_MODER_MODE9_1 (0x2UL << GPIO_MODER_MODE9_Pos)
15067#define GPIO_MODER_MODE10_Pos (20U)
15068#define GPIO_MODER_MODE10_Msk (0x3UL << GPIO_MODER_MODE10_Pos)
15069#define GPIO_MODER_MODE10 GPIO_MODER_MODE10_Msk
15070#define GPIO_MODER_MODE10_0 (0x1UL << GPIO_MODER_MODE10_Pos)
15071#define GPIO_MODER_MODE10_1 (0x2UL << GPIO_MODER_MODE10_Pos)
15073#define GPIO_MODER_MODE11_Pos (22U)
15074#define GPIO_MODER_MODE11_Msk (0x3UL << GPIO_MODER_MODE11_Pos)
15075#define GPIO_MODER_MODE11 GPIO_MODER_MODE11_Msk
15076#define GPIO_MODER_MODE11_0 (0x1UL << GPIO_MODER_MODE11_Pos)
15077#define GPIO_MODER_MODE11_1 (0x2UL << GPIO_MODER_MODE11_Pos)
15079#define GPIO_MODER_MODE12_Pos (24U)
15080#define GPIO_MODER_MODE12_Msk (0x3UL << GPIO_MODER_MODE12_Pos)
15081#define GPIO_MODER_MODE12 GPIO_MODER_MODE12_Msk
15082#define GPIO_MODER_MODE12_0 (0x1UL << GPIO_MODER_MODE12_Pos)
15083#define GPIO_MODER_MODE12_1 (0x2UL << GPIO_MODER_MODE12_Pos)
15085#define GPIO_MODER_MODE13_Pos (26U)
15086#define GPIO_MODER_MODE13_Msk (0x3UL << GPIO_MODER_MODE13_Pos)
15087#define GPIO_MODER_MODE13 GPIO_MODER_MODE13_Msk
15088#define GPIO_MODER_MODE13_0 (0x1UL << GPIO_MODER_MODE13_Pos)
15089#define GPIO_MODER_MODE13_1 (0x2UL << GPIO_MODER_MODE13_Pos)
15091#define GPIO_MODER_MODE14_Pos (28U)
15092#define GPIO_MODER_MODE14_Msk (0x3UL << GPIO_MODER_MODE14_Pos)
15093#define GPIO_MODER_MODE14 GPIO_MODER_MODE14_Msk
15094#define GPIO_MODER_MODE14_0 (0x1UL << GPIO_MODER_MODE14_Pos)
15095#define GPIO_MODER_MODE14_1 (0x2UL << GPIO_MODER_MODE14_Pos)
15097#define GPIO_MODER_MODE15_Pos (30U)
15098#define GPIO_MODER_MODE15_Msk (0x3UL << GPIO_MODER_MODE15_Pos)
15099#define GPIO_MODER_MODE15 GPIO_MODER_MODE15_Msk
15100#define GPIO_MODER_MODE15_0 (0x1UL << GPIO_MODER_MODE15_Pos)
15101#define GPIO_MODER_MODE15_1 (0x2UL << GPIO_MODER_MODE15_Pos)
15103/****************** Bits definition for GPIO_OTYPER register ****************/
15104#define GPIO_OTYPER_OT0_Pos (0U)
15105#define GPIO_OTYPER_OT0_Msk (0x1UL << GPIO_OTYPER_OT0_Pos)
15106#define GPIO_OTYPER_OT0 GPIO_OTYPER_OT0_Msk
15107#define GPIO_OTYPER_OT1_Pos (1U)
15108#define GPIO_OTYPER_OT1_Msk (0x1UL << GPIO_OTYPER_OT1_Pos)
15109#define GPIO_OTYPER_OT1 GPIO_OTYPER_OT1_Msk
15110#define GPIO_OTYPER_OT2_Pos (2U)
15111#define GPIO_OTYPER_OT2_Msk (0x1UL << GPIO_OTYPER_OT2_Pos)
15112#define GPIO_OTYPER_OT2 GPIO_OTYPER_OT2_Msk
15113#define GPIO_OTYPER_OT3_Pos (3U)
15114#define GPIO_OTYPER_OT3_Msk (0x1UL << GPIO_OTYPER_OT3_Pos)
15115#define GPIO_OTYPER_OT3 GPIO_OTYPER_OT3_Msk
15116#define GPIO_OTYPER_OT4_Pos (4U)
15117#define GPIO_OTYPER_OT4_Msk (0x1UL << GPIO_OTYPER_OT4_Pos)
15118#define GPIO_OTYPER_OT4 GPIO_OTYPER_OT4_Msk
15119#define GPIO_OTYPER_OT5_Pos (5U)
15120#define GPIO_OTYPER_OT5_Msk (0x1UL << GPIO_OTYPER_OT5_Pos)
15121#define GPIO_OTYPER_OT5 GPIO_OTYPER_OT5_Msk
15122#define GPIO_OTYPER_OT6_Pos (6U)
15123#define GPIO_OTYPER_OT6_Msk (0x1UL << GPIO_OTYPER_OT6_Pos)
15124#define GPIO_OTYPER_OT6 GPIO_OTYPER_OT6_Msk
15125#define GPIO_OTYPER_OT7_Pos (7U)
15126#define GPIO_OTYPER_OT7_Msk (0x1UL << GPIO_OTYPER_OT7_Pos)
15127#define GPIO_OTYPER_OT7 GPIO_OTYPER_OT7_Msk
15128#define GPIO_OTYPER_OT8_Pos (8U)
15129#define GPIO_OTYPER_OT8_Msk (0x1UL << GPIO_OTYPER_OT8_Pos)
15130#define GPIO_OTYPER_OT8 GPIO_OTYPER_OT8_Msk
15131#define GPIO_OTYPER_OT9_Pos (9U)
15132#define GPIO_OTYPER_OT9_Msk (0x1UL << GPIO_OTYPER_OT9_Pos)
15133#define GPIO_OTYPER_OT9 GPIO_OTYPER_OT9_Msk
15134#define GPIO_OTYPER_OT10_Pos (10U)
15135#define GPIO_OTYPER_OT10_Msk (0x1UL << GPIO_OTYPER_OT10_Pos)
15136#define GPIO_OTYPER_OT10 GPIO_OTYPER_OT10_Msk
15137#define GPIO_OTYPER_OT11_Pos (11U)
15138#define GPIO_OTYPER_OT11_Msk (0x1UL << GPIO_OTYPER_OT11_Pos)
15139#define GPIO_OTYPER_OT11 GPIO_OTYPER_OT11_Msk
15140#define GPIO_OTYPER_OT12_Pos (12U)
15141#define GPIO_OTYPER_OT12_Msk (0x1UL << GPIO_OTYPER_OT12_Pos)
15142#define GPIO_OTYPER_OT12 GPIO_OTYPER_OT12_Msk
15143#define GPIO_OTYPER_OT13_Pos (13U)
15144#define GPIO_OTYPER_OT13_Msk (0x1UL << GPIO_OTYPER_OT13_Pos)
15145#define GPIO_OTYPER_OT13 GPIO_OTYPER_OT13_Msk
15146#define GPIO_OTYPER_OT14_Pos (14U)
15147#define GPIO_OTYPER_OT14_Msk (0x1UL << GPIO_OTYPER_OT14_Pos)
15148#define GPIO_OTYPER_OT14 GPIO_OTYPER_OT14_Msk
15149#define GPIO_OTYPER_OT15_Pos (15U)
15150#define GPIO_OTYPER_OT15_Msk (0x1UL << GPIO_OTYPER_OT15_Pos)
15151#define GPIO_OTYPER_OT15 GPIO_OTYPER_OT15_Msk
15152
15153/****************** Bits definition for GPIO_OSPEEDR register ***************/
15154#define GPIO_OSPEEDR_OSPEED0_Pos (0U)
15155#define GPIO_OSPEEDR_OSPEED0_Msk (0x3UL << GPIO_OSPEEDR_OSPEED0_Pos)
15156#define GPIO_OSPEEDR_OSPEED0 GPIO_OSPEEDR_OSPEED0_Msk
15157#define GPIO_OSPEEDR_OSPEED0_0 (0x1UL << GPIO_OSPEEDR_OSPEED0_Pos)
15158#define GPIO_OSPEEDR_OSPEED0_1 (0x2UL << GPIO_OSPEEDR_OSPEED0_Pos)
15160#define GPIO_OSPEEDR_OSPEED1_Pos (2U)
15161#define GPIO_OSPEEDR_OSPEED1_Msk (0x3UL << GPIO_OSPEEDR_OSPEED1_Pos)
15162#define GPIO_OSPEEDR_OSPEED1 GPIO_OSPEEDR_OSPEED1_Msk
15163#define GPIO_OSPEEDR_OSPEED1_0 (0x1UL << GPIO_OSPEEDR_OSPEED1_Pos)
15164#define GPIO_OSPEEDR_OSPEED1_1 (0x2UL << GPIO_OSPEEDR_OSPEED1_Pos)
15166#define GPIO_OSPEEDR_OSPEED2_Pos (4U)
15167#define GPIO_OSPEEDR_OSPEED2_Msk (0x3UL << GPIO_OSPEEDR_OSPEED2_Pos)
15168#define GPIO_OSPEEDR_OSPEED2 GPIO_OSPEEDR_OSPEED2_Msk
15169#define GPIO_OSPEEDR_OSPEED2_0 (0x1UL << GPIO_OSPEEDR_OSPEED2_Pos)
15170#define GPIO_OSPEEDR_OSPEED2_1 (0x2UL << GPIO_OSPEEDR_OSPEED2_Pos)
15172#define GPIO_OSPEEDR_OSPEED3_Pos (6U)
15173#define GPIO_OSPEEDR_OSPEED3_Msk (0x3UL << GPIO_OSPEEDR_OSPEED3_Pos)
15174#define GPIO_OSPEEDR_OSPEED3 GPIO_OSPEEDR_OSPEED3_Msk
15175#define GPIO_OSPEEDR_OSPEED3_0 (0x1UL << GPIO_OSPEEDR_OSPEED3_Pos)
15176#define GPIO_OSPEEDR_OSPEED3_1 (0x2UL << GPIO_OSPEEDR_OSPEED3_Pos)
15178#define GPIO_OSPEEDR_OSPEED4_Pos (8U)
15179#define GPIO_OSPEEDR_OSPEED4_Msk (0x3UL << GPIO_OSPEEDR_OSPEED4_Pos)
15180#define GPIO_OSPEEDR_OSPEED4 GPIO_OSPEEDR_OSPEED4_Msk
15181#define GPIO_OSPEEDR_OSPEED4_0 (0x1UL << GPIO_OSPEEDR_OSPEED4_Pos)
15182#define GPIO_OSPEEDR_OSPEED4_1 (0x2UL << GPIO_OSPEEDR_OSPEED4_Pos)
15184#define GPIO_OSPEEDR_OSPEED5_Pos (10U)
15185#define GPIO_OSPEEDR_OSPEED5_Msk (0x3UL << GPIO_OSPEEDR_OSPEED5_Pos)
15186#define GPIO_OSPEEDR_OSPEED5 GPIO_OSPEEDR_OSPEED5_Msk
15187#define GPIO_OSPEEDR_OSPEED5_0 (0x1UL << GPIO_OSPEEDR_OSPEED5_Pos)
15188#define GPIO_OSPEEDR_OSPEED5_1 (0x2UL << GPIO_OSPEEDR_OSPEED5_Pos)
15190#define GPIO_OSPEEDR_OSPEED6_Pos (12U)
15191#define GPIO_OSPEEDR_OSPEED6_Msk (0x3UL << GPIO_OSPEEDR_OSPEED6_Pos)
15192#define GPIO_OSPEEDR_OSPEED6 GPIO_OSPEEDR_OSPEED6_Msk
15193#define GPIO_OSPEEDR_OSPEED6_0 (0x1UL << GPIO_OSPEEDR_OSPEED6_Pos)
15194#define GPIO_OSPEEDR_OSPEED6_1 (0x2UL << GPIO_OSPEEDR_OSPEED6_Pos)
15196#define GPIO_OSPEEDR_OSPEED7_Pos (14U)
15197#define GPIO_OSPEEDR_OSPEED7_Msk (0x3UL << GPIO_OSPEEDR_OSPEED7_Pos)
15198#define GPIO_OSPEEDR_OSPEED7 GPIO_OSPEEDR_OSPEED7_Msk
15199#define GPIO_OSPEEDR_OSPEED7_0 (0x1UL << GPIO_OSPEEDR_OSPEED7_Pos)
15200#define GPIO_OSPEEDR_OSPEED7_1 (0x2UL << GPIO_OSPEEDR_OSPEED7_Pos)
15202#define GPIO_OSPEEDR_OSPEED8_Pos (16U)
15203#define GPIO_OSPEEDR_OSPEED8_Msk (0x3UL << GPIO_OSPEEDR_OSPEED8_Pos)
15204#define GPIO_OSPEEDR_OSPEED8 GPIO_OSPEEDR_OSPEED8_Msk
15205#define GPIO_OSPEEDR_OSPEED8_0 (0x1UL << GPIO_OSPEEDR_OSPEED8_Pos)
15206#define GPIO_OSPEEDR_OSPEED8_1 (0x2UL << GPIO_OSPEEDR_OSPEED8_Pos)
15208#define GPIO_OSPEEDR_OSPEED9_Pos (18U)
15209#define GPIO_OSPEEDR_OSPEED9_Msk (0x3UL << GPIO_OSPEEDR_OSPEED9_Pos)
15210#define GPIO_OSPEEDR_OSPEED9 GPIO_OSPEEDR_OSPEED9_Msk
15211#define GPIO_OSPEEDR_OSPEED9_0 (0x1UL << GPIO_OSPEEDR_OSPEED9_Pos)
15212#define GPIO_OSPEEDR_OSPEED9_1 (0x2UL << GPIO_OSPEEDR_OSPEED9_Pos)
15214#define GPIO_OSPEEDR_OSPEED10_Pos (20U)
15215#define GPIO_OSPEEDR_OSPEED10_Msk (0x3UL << GPIO_OSPEEDR_OSPEED10_Pos)
15216#define GPIO_OSPEEDR_OSPEED10 GPIO_OSPEEDR_OSPEED10_Msk
15217#define GPIO_OSPEEDR_OSPEED10_0 (0x1UL << GPIO_OSPEEDR_OSPEED10_Pos)
15218#define GPIO_OSPEEDR_OSPEED10_1 (0x2UL << GPIO_OSPEEDR_OSPEED10_Pos)
15220#define GPIO_OSPEEDR_OSPEED11_Pos (22U)
15221#define GPIO_OSPEEDR_OSPEED11_Msk (0x3UL << GPIO_OSPEEDR_OSPEED11_Pos)
15222#define GPIO_OSPEEDR_OSPEED11 GPIO_OSPEEDR_OSPEED11_Msk
15223#define GPIO_OSPEEDR_OSPEED11_0 (0x1UL << GPIO_OSPEEDR_OSPEED11_Pos)
15224#define GPIO_OSPEEDR_OSPEED11_1 (0x2UL << GPIO_OSPEEDR_OSPEED11_Pos)
15226#define GPIO_OSPEEDR_OSPEED12_Pos (24U)
15227#define GPIO_OSPEEDR_OSPEED12_Msk (0x3UL << GPIO_OSPEEDR_OSPEED12_Pos)
15228#define GPIO_OSPEEDR_OSPEED12 GPIO_OSPEEDR_OSPEED12_Msk
15229#define GPIO_OSPEEDR_OSPEED12_0 (0x1UL << GPIO_OSPEEDR_OSPEED12_Pos)
15230#define GPIO_OSPEEDR_OSPEED12_1 (0x2UL << GPIO_OSPEEDR_OSPEED12_Pos)
15232#define GPIO_OSPEEDR_OSPEED13_Pos (26U)
15233#define GPIO_OSPEEDR_OSPEED13_Msk (0x3UL << GPIO_OSPEEDR_OSPEED13_Pos)
15234#define GPIO_OSPEEDR_OSPEED13 GPIO_OSPEEDR_OSPEED13_Msk
15235#define GPIO_OSPEEDR_OSPEED13_0 (0x1UL << GPIO_OSPEEDR_OSPEED13_Pos)
15236#define GPIO_OSPEEDR_OSPEED13_1 (0x2UL << GPIO_OSPEEDR_OSPEED13_Pos)
15238#define GPIO_OSPEEDR_OSPEED14_Pos (28U)
15239#define GPIO_OSPEEDR_OSPEED14_Msk (0x3UL << GPIO_OSPEEDR_OSPEED14_Pos)
15240#define GPIO_OSPEEDR_OSPEED14 GPIO_OSPEEDR_OSPEED14_Msk
15241#define GPIO_OSPEEDR_OSPEED14_0 (0x1UL << GPIO_OSPEEDR_OSPEED14_Pos)
15242#define GPIO_OSPEEDR_OSPEED14_1 (0x2UL << GPIO_OSPEEDR_OSPEED14_Pos)
15244#define GPIO_OSPEEDR_OSPEED15_Pos (30U)
15245#define GPIO_OSPEEDR_OSPEED15_Msk (0x3UL << GPIO_OSPEEDR_OSPEED15_Pos)
15246#define GPIO_OSPEEDR_OSPEED15 GPIO_OSPEEDR_OSPEED15_Msk
15247#define GPIO_OSPEEDR_OSPEED15_0 (0x1UL << GPIO_OSPEEDR_OSPEED15_Pos)
15248#define GPIO_OSPEEDR_OSPEED15_1 (0x2UL << GPIO_OSPEEDR_OSPEED15_Pos)
15250/****************** Bits definition for GPIO_PUPDR register *****************/
15251#define GPIO_PUPDR_PUPD0_Pos (0U)
15252#define GPIO_PUPDR_PUPD0_Msk (0x3UL << GPIO_PUPDR_PUPD0_Pos)
15253#define GPIO_PUPDR_PUPD0 GPIO_PUPDR_PUPD0_Msk
15254#define GPIO_PUPDR_PUPD0_0 (0x1UL << GPIO_PUPDR_PUPD0_Pos)
15255#define GPIO_PUPDR_PUPD0_1 (0x2UL << GPIO_PUPDR_PUPD0_Pos)
15257#define GPIO_PUPDR_PUPD1_Pos (2U)
15258#define GPIO_PUPDR_PUPD1_Msk (0x3UL << GPIO_PUPDR_PUPD1_Pos)
15259#define GPIO_PUPDR_PUPD1 GPIO_PUPDR_PUPD1_Msk
15260#define GPIO_PUPDR_PUPD1_0 (0x1UL << GPIO_PUPDR_PUPD1_Pos)
15261#define GPIO_PUPDR_PUPD1_1 (0x2UL << GPIO_PUPDR_PUPD1_Pos)
15263#define GPIO_PUPDR_PUPD2_Pos (4U)
15264#define GPIO_PUPDR_PUPD2_Msk (0x3UL << GPIO_PUPDR_PUPD2_Pos)
15265#define GPIO_PUPDR_PUPD2 GPIO_PUPDR_PUPD2_Msk
15266#define GPIO_PUPDR_PUPD2_0 (0x1UL << GPIO_PUPDR_PUPD2_Pos)
15267#define GPIO_PUPDR_PUPD2_1 (0x2UL << GPIO_PUPDR_PUPD2_Pos)
15269#define GPIO_PUPDR_PUPD3_Pos (6U)
15270#define GPIO_PUPDR_PUPD3_Msk (0x3UL << GPIO_PUPDR_PUPD3_Pos)
15271#define GPIO_PUPDR_PUPD3 GPIO_PUPDR_PUPD3_Msk
15272#define GPIO_PUPDR_PUPD3_0 (0x1UL << GPIO_PUPDR_PUPD3_Pos)
15273#define GPIO_PUPDR_PUPD3_1 (0x2UL << GPIO_PUPDR_PUPD3_Pos)
15275#define GPIO_PUPDR_PUPD4_Pos (8U)
15276#define GPIO_PUPDR_PUPD4_Msk (0x3UL << GPIO_PUPDR_PUPD4_Pos)
15277#define GPIO_PUPDR_PUPD4 GPIO_PUPDR_PUPD4_Msk
15278#define GPIO_PUPDR_PUPD4_0 (0x1UL << GPIO_PUPDR_PUPD4_Pos)
15279#define GPIO_PUPDR_PUPD4_1 (0x2UL << GPIO_PUPDR_PUPD4_Pos)
15281#define GPIO_PUPDR_PUPD5_Pos (10U)
15282#define GPIO_PUPDR_PUPD5_Msk (0x3UL << GPIO_PUPDR_PUPD5_Pos)
15283#define GPIO_PUPDR_PUPD5 GPIO_PUPDR_PUPD5_Msk
15284#define GPIO_PUPDR_PUPD5_0 (0x1UL << GPIO_PUPDR_PUPD5_Pos)
15285#define GPIO_PUPDR_PUPD5_1 (0x2UL << GPIO_PUPDR_PUPD5_Pos)
15287#define GPIO_PUPDR_PUPD6_Pos (12U)
15288#define GPIO_PUPDR_PUPD6_Msk (0x3UL << GPIO_PUPDR_PUPD6_Pos)
15289#define GPIO_PUPDR_PUPD6 GPIO_PUPDR_PUPD6_Msk
15290#define GPIO_PUPDR_PUPD6_0 (0x1UL << GPIO_PUPDR_PUPD6_Pos)
15291#define GPIO_PUPDR_PUPD6_1 (0x2UL << GPIO_PUPDR_PUPD6_Pos)
15293#define GPIO_PUPDR_PUPD7_Pos (14U)
15294#define GPIO_PUPDR_PUPD7_Msk (0x3UL << GPIO_PUPDR_PUPD7_Pos)
15295#define GPIO_PUPDR_PUPD7 GPIO_PUPDR_PUPD7_Msk
15296#define GPIO_PUPDR_PUPD7_0 (0x1UL << GPIO_PUPDR_PUPD7_Pos)
15297#define GPIO_PUPDR_PUPD7_1 (0x2UL << GPIO_PUPDR_PUPD7_Pos)
15299#define GPIO_PUPDR_PUPD8_Pos (16U)
15300#define GPIO_PUPDR_PUPD8_Msk (0x3UL << GPIO_PUPDR_PUPD8_Pos)
15301#define GPIO_PUPDR_PUPD8 GPIO_PUPDR_PUPD8_Msk
15302#define GPIO_PUPDR_PUPD8_0 (0x1UL << GPIO_PUPDR_PUPD8_Pos)
15303#define GPIO_PUPDR_PUPD8_1 (0x2UL << GPIO_PUPDR_PUPD8_Pos)
15305#define GPIO_PUPDR_PUPD9_Pos (18U)
15306#define GPIO_PUPDR_PUPD9_Msk (0x3UL << GPIO_PUPDR_PUPD9_Pos)
15307#define GPIO_PUPDR_PUPD9 GPIO_PUPDR_PUPD9_Msk
15308#define GPIO_PUPDR_PUPD9_0 (0x1UL << GPIO_PUPDR_PUPD9_Pos)
15309#define GPIO_PUPDR_PUPD9_1 (0x2UL << GPIO_PUPDR_PUPD9_Pos)
15311#define GPIO_PUPDR_PUPD10_Pos (20U)
15312#define GPIO_PUPDR_PUPD10_Msk (0x3UL << GPIO_PUPDR_PUPD10_Pos)
15313#define GPIO_PUPDR_PUPD10 GPIO_PUPDR_PUPD10_Msk
15314#define GPIO_PUPDR_PUPD10_0 (0x1UL << GPIO_PUPDR_PUPD10_Pos)
15315#define GPIO_PUPDR_PUPD10_1 (0x2UL << GPIO_PUPDR_PUPD10_Pos)
15317#define GPIO_PUPDR_PUPD11_Pos (22U)
15318#define GPIO_PUPDR_PUPD11_Msk (0x3UL << GPIO_PUPDR_PUPD11_Pos)
15319#define GPIO_PUPDR_PUPD11 GPIO_PUPDR_PUPD11_Msk
15320#define GPIO_PUPDR_PUPD11_0 (0x1UL << GPIO_PUPDR_PUPD11_Pos)
15321#define GPIO_PUPDR_PUPD11_1 (0x2UL << GPIO_PUPDR_PUPD11_Pos)
15323#define GPIO_PUPDR_PUPD12_Pos (24U)
15324#define GPIO_PUPDR_PUPD12_Msk (0x3UL << GPIO_PUPDR_PUPD12_Pos)
15325#define GPIO_PUPDR_PUPD12 GPIO_PUPDR_PUPD12_Msk
15326#define GPIO_PUPDR_PUPD12_0 (0x1UL << GPIO_PUPDR_PUPD12_Pos)
15327#define GPIO_PUPDR_PUPD12_1 (0x2UL << GPIO_PUPDR_PUPD12_Pos)
15329#define GPIO_PUPDR_PUPD13_Pos (26U)
15330#define GPIO_PUPDR_PUPD13_Msk (0x3UL << GPIO_PUPDR_PUPD13_Pos)
15331#define GPIO_PUPDR_PUPD13 GPIO_PUPDR_PUPD13_Msk
15332#define GPIO_PUPDR_PUPD13_0 (0x1UL << GPIO_PUPDR_PUPD13_Pos)
15333#define GPIO_PUPDR_PUPD13_1 (0x2UL << GPIO_PUPDR_PUPD13_Pos)
15335#define GPIO_PUPDR_PUPD14_Pos (28U)
15336#define GPIO_PUPDR_PUPD14_Msk (0x3UL << GPIO_PUPDR_PUPD14_Pos)
15337#define GPIO_PUPDR_PUPD14 GPIO_PUPDR_PUPD14_Msk
15338#define GPIO_PUPDR_PUPD14_0 (0x1UL << GPIO_PUPDR_PUPD14_Pos)
15339#define GPIO_PUPDR_PUPD14_1 (0x2UL << GPIO_PUPDR_PUPD14_Pos)
15341#define GPIO_PUPDR_PUPD15_Pos (30U)
15342#define GPIO_PUPDR_PUPD15_Msk (0x3UL << GPIO_PUPDR_PUPD15_Pos)
15343#define GPIO_PUPDR_PUPD15 GPIO_PUPDR_PUPD15_Msk
15344#define GPIO_PUPDR_PUPD15_0 (0x1UL << GPIO_PUPDR_PUPD15_Pos)
15345#define GPIO_PUPDR_PUPD15_1 (0x2UL << GPIO_PUPDR_PUPD15_Pos)
15347/****************** Bits definition for GPIO_IDR register *******************/
15348#define GPIO_IDR_ID0_Pos (0U)
15349#define GPIO_IDR_ID0_Msk (0x1UL << GPIO_IDR_ID0_Pos)
15350#define GPIO_IDR_ID0 GPIO_IDR_ID0_Msk
15351#define GPIO_IDR_ID1_Pos (1U)
15352#define GPIO_IDR_ID1_Msk (0x1UL << GPIO_IDR_ID1_Pos)
15353#define GPIO_IDR_ID1 GPIO_IDR_ID1_Msk
15354#define GPIO_IDR_ID2_Pos (2U)
15355#define GPIO_IDR_ID2_Msk (0x1UL << GPIO_IDR_ID2_Pos)
15356#define GPIO_IDR_ID2 GPIO_IDR_ID2_Msk
15357#define GPIO_IDR_ID3_Pos (3U)
15358#define GPIO_IDR_ID3_Msk (0x1UL << GPIO_IDR_ID3_Pos)
15359#define GPIO_IDR_ID3 GPIO_IDR_ID3_Msk
15360#define GPIO_IDR_ID4_Pos (4U)
15361#define GPIO_IDR_ID4_Msk (0x1UL << GPIO_IDR_ID4_Pos)
15362#define GPIO_IDR_ID4 GPIO_IDR_ID4_Msk
15363#define GPIO_IDR_ID5_Pos (5U)
15364#define GPIO_IDR_ID5_Msk (0x1UL << GPIO_IDR_ID5_Pos)
15365#define GPIO_IDR_ID5 GPIO_IDR_ID5_Msk
15366#define GPIO_IDR_ID6_Pos (6U)
15367#define GPIO_IDR_ID6_Msk (0x1UL << GPIO_IDR_ID6_Pos)
15368#define GPIO_IDR_ID6 GPIO_IDR_ID6_Msk
15369#define GPIO_IDR_ID7_Pos (7U)
15370#define GPIO_IDR_ID7_Msk (0x1UL << GPIO_IDR_ID7_Pos)
15371#define GPIO_IDR_ID7 GPIO_IDR_ID7_Msk
15372#define GPIO_IDR_ID8_Pos (8U)
15373#define GPIO_IDR_ID8_Msk (0x1UL << GPIO_IDR_ID8_Pos)
15374#define GPIO_IDR_ID8 GPIO_IDR_ID8_Msk
15375#define GPIO_IDR_ID9_Pos (9U)
15376#define GPIO_IDR_ID9_Msk (0x1UL << GPIO_IDR_ID9_Pos)
15377#define GPIO_IDR_ID9 GPIO_IDR_ID9_Msk
15378#define GPIO_IDR_ID10_Pos (10U)
15379#define GPIO_IDR_ID10_Msk (0x1UL << GPIO_IDR_ID10_Pos)
15380#define GPIO_IDR_ID10 GPIO_IDR_ID10_Msk
15381#define GPIO_IDR_ID11_Pos (11U)
15382#define GPIO_IDR_ID11_Msk (0x1UL << GPIO_IDR_ID11_Pos)
15383#define GPIO_IDR_ID11 GPIO_IDR_ID11_Msk
15384#define GPIO_IDR_ID12_Pos (12U)
15385#define GPIO_IDR_ID12_Msk (0x1UL << GPIO_IDR_ID12_Pos)
15386#define GPIO_IDR_ID12 GPIO_IDR_ID12_Msk
15387#define GPIO_IDR_ID13_Pos (13U)
15388#define GPIO_IDR_ID13_Msk (0x1UL << GPIO_IDR_ID13_Pos)
15389#define GPIO_IDR_ID13 GPIO_IDR_ID13_Msk
15390#define GPIO_IDR_ID14_Pos (14U)
15391#define GPIO_IDR_ID14_Msk (0x1UL << GPIO_IDR_ID14_Pos)
15392#define GPIO_IDR_ID14 GPIO_IDR_ID14_Msk
15393#define GPIO_IDR_ID15_Pos (15U)
15394#define GPIO_IDR_ID15_Msk (0x1UL << GPIO_IDR_ID15_Pos)
15395#define GPIO_IDR_ID15 GPIO_IDR_ID15_Msk
15396
15397/****************** Bits definition for GPIO_ODR register *******************/
15398#define GPIO_ODR_OD0_Pos (0U)
15399#define GPIO_ODR_OD0_Msk (0x1UL << GPIO_ODR_OD0_Pos)
15400#define GPIO_ODR_OD0 GPIO_ODR_OD0_Msk
15401#define GPIO_ODR_OD1_Pos (1U)
15402#define GPIO_ODR_OD1_Msk (0x1UL << GPIO_ODR_OD1_Pos)
15403#define GPIO_ODR_OD1 GPIO_ODR_OD1_Msk
15404#define GPIO_ODR_OD2_Pos (2U)
15405#define GPIO_ODR_OD2_Msk (0x1UL << GPIO_ODR_OD2_Pos)
15406#define GPIO_ODR_OD2 GPIO_ODR_OD2_Msk
15407#define GPIO_ODR_OD3_Pos (3U)
15408#define GPIO_ODR_OD3_Msk (0x1UL << GPIO_ODR_OD3_Pos)
15409#define GPIO_ODR_OD3 GPIO_ODR_OD3_Msk
15410#define GPIO_ODR_OD4_Pos (4U)
15411#define GPIO_ODR_OD4_Msk (0x1UL << GPIO_ODR_OD4_Pos)
15412#define GPIO_ODR_OD4 GPIO_ODR_OD4_Msk
15413#define GPIO_ODR_OD5_Pos (5U)
15414#define GPIO_ODR_OD5_Msk (0x1UL << GPIO_ODR_OD5_Pos)
15415#define GPIO_ODR_OD5 GPIO_ODR_OD5_Msk
15416#define GPIO_ODR_OD6_Pos (6U)
15417#define GPIO_ODR_OD6_Msk (0x1UL << GPIO_ODR_OD6_Pos)
15418#define GPIO_ODR_OD6 GPIO_ODR_OD6_Msk
15419#define GPIO_ODR_OD7_Pos (7U)
15420#define GPIO_ODR_OD7_Msk (0x1UL << GPIO_ODR_OD7_Pos)
15421#define GPIO_ODR_OD7 GPIO_ODR_OD7_Msk
15422#define GPIO_ODR_OD8_Pos (8U)
15423#define GPIO_ODR_OD8_Msk (0x1UL << GPIO_ODR_OD8_Pos)
15424#define GPIO_ODR_OD8 GPIO_ODR_OD8_Msk
15425#define GPIO_ODR_OD9_Pos (9U)
15426#define GPIO_ODR_OD9_Msk (0x1UL << GPIO_ODR_OD9_Pos)
15427#define GPIO_ODR_OD9 GPIO_ODR_OD9_Msk
15428#define GPIO_ODR_OD10_Pos (10U)
15429#define GPIO_ODR_OD10_Msk (0x1UL << GPIO_ODR_OD10_Pos)
15430#define GPIO_ODR_OD10 GPIO_ODR_OD10_Msk
15431#define GPIO_ODR_OD11_Pos (11U)
15432#define GPIO_ODR_OD11_Msk (0x1UL << GPIO_ODR_OD11_Pos)
15433#define GPIO_ODR_OD11 GPIO_ODR_OD11_Msk
15434#define GPIO_ODR_OD12_Pos (12U)
15435#define GPIO_ODR_OD12_Msk (0x1UL << GPIO_ODR_OD12_Pos)
15436#define GPIO_ODR_OD12 GPIO_ODR_OD12_Msk
15437#define GPIO_ODR_OD13_Pos (13U)
15438#define GPIO_ODR_OD13_Msk (0x1UL << GPIO_ODR_OD13_Pos)
15439#define GPIO_ODR_OD13 GPIO_ODR_OD13_Msk
15440#define GPIO_ODR_OD14_Pos (14U)
15441#define GPIO_ODR_OD14_Msk (0x1UL << GPIO_ODR_OD14_Pos)
15442#define GPIO_ODR_OD14 GPIO_ODR_OD14_Msk
15443#define GPIO_ODR_OD15_Pos (15U)
15444#define GPIO_ODR_OD15_Msk (0x1UL << GPIO_ODR_OD15_Pos)
15445#define GPIO_ODR_OD15 GPIO_ODR_OD15_Msk
15446
15447/****************** Bits definition for GPIO_BSRR register ******************/
15448#define GPIO_BSRR_BS0_Pos (0U)
15449#define GPIO_BSRR_BS0_Msk (0x1UL << GPIO_BSRR_BS0_Pos)
15450#define GPIO_BSRR_BS0 GPIO_BSRR_BS0_Msk
15451#define GPIO_BSRR_BS1_Pos (1U)
15452#define GPIO_BSRR_BS1_Msk (0x1UL << GPIO_BSRR_BS1_Pos)
15453#define GPIO_BSRR_BS1 GPIO_BSRR_BS1_Msk
15454#define GPIO_BSRR_BS2_Pos (2U)
15455#define GPIO_BSRR_BS2_Msk (0x1UL << GPIO_BSRR_BS2_Pos)
15456#define GPIO_BSRR_BS2 GPIO_BSRR_BS2_Msk
15457#define GPIO_BSRR_BS3_Pos (3U)
15458#define GPIO_BSRR_BS3_Msk (0x1UL << GPIO_BSRR_BS3_Pos)
15459#define GPIO_BSRR_BS3 GPIO_BSRR_BS3_Msk
15460#define GPIO_BSRR_BS4_Pos (4U)
15461#define GPIO_BSRR_BS4_Msk (0x1UL << GPIO_BSRR_BS4_Pos)
15462#define GPIO_BSRR_BS4 GPIO_BSRR_BS4_Msk
15463#define GPIO_BSRR_BS5_Pos (5U)
15464#define GPIO_BSRR_BS5_Msk (0x1UL << GPIO_BSRR_BS5_Pos)
15465#define GPIO_BSRR_BS5 GPIO_BSRR_BS5_Msk
15466#define GPIO_BSRR_BS6_Pos (6U)
15467#define GPIO_BSRR_BS6_Msk (0x1UL << GPIO_BSRR_BS6_Pos)
15468#define GPIO_BSRR_BS6 GPIO_BSRR_BS6_Msk
15469#define GPIO_BSRR_BS7_Pos (7U)
15470#define GPIO_BSRR_BS7_Msk (0x1UL << GPIO_BSRR_BS7_Pos)
15471#define GPIO_BSRR_BS7 GPIO_BSRR_BS7_Msk
15472#define GPIO_BSRR_BS8_Pos (8U)
15473#define GPIO_BSRR_BS8_Msk (0x1UL << GPIO_BSRR_BS8_Pos)
15474#define GPIO_BSRR_BS8 GPIO_BSRR_BS8_Msk
15475#define GPIO_BSRR_BS9_Pos (9U)
15476#define GPIO_BSRR_BS9_Msk (0x1UL << GPIO_BSRR_BS9_Pos)
15477#define GPIO_BSRR_BS9 GPIO_BSRR_BS9_Msk
15478#define GPIO_BSRR_BS10_Pos (10U)
15479#define GPIO_BSRR_BS10_Msk (0x1UL << GPIO_BSRR_BS10_Pos)
15480#define GPIO_BSRR_BS10 GPIO_BSRR_BS10_Msk
15481#define GPIO_BSRR_BS11_Pos (11U)
15482#define GPIO_BSRR_BS11_Msk (0x1UL << GPIO_BSRR_BS11_Pos)
15483#define GPIO_BSRR_BS11 GPIO_BSRR_BS11_Msk
15484#define GPIO_BSRR_BS12_Pos (12U)
15485#define GPIO_BSRR_BS12_Msk (0x1UL << GPIO_BSRR_BS12_Pos)
15486#define GPIO_BSRR_BS12 GPIO_BSRR_BS12_Msk
15487#define GPIO_BSRR_BS13_Pos (13U)
15488#define GPIO_BSRR_BS13_Msk (0x1UL << GPIO_BSRR_BS13_Pos)
15489#define GPIO_BSRR_BS13 GPIO_BSRR_BS13_Msk
15490#define GPIO_BSRR_BS14_Pos (14U)
15491#define GPIO_BSRR_BS14_Msk (0x1UL << GPIO_BSRR_BS14_Pos)
15492#define GPIO_BSRR_BS14 GPIO_BSRR_BS14_Msk
15493#define GPIO_BSRR_BS15_Pos (15U)
15494#define GPIO_BSRR_BS15_Msk (0x1UL << GPIO_BSRR_BS15_Pos)
15495#define GPIO_BSRR_BS15 GPIO_BSRR_BS15_Msk
15496#define GPIO_BSRR_BR0_Pos (16U)
15497#define GPIO_BSRR_BR0_Msk (0x1UL << GPIO_BSRR_BR0_Pos)
15498#define GPIO_BSRR_BR0 GPIO_BSRR_BR0_Msk
15499#define GPIO_BSRR_BR1_Pos (17U)
15500#define GPIO_BSRR_BR1_Msk (0x1UL << GPIO_BSRR_BR1_Pos)
15501#define GPIO_BSRR_BR1 GPIO_BSRR_BR1_Msk
15502#define GPIO_BSRR_BR2_Pos (18U)
15503#define GPIO_BSRR_BR2_Msk (0x1UL << GPIO_BSRR_BR2_Pos)
15504#define GPIO_BSRR_BR2 GPIO_BSRR_BR2_Msk
15505#define GPIO_BSRR_BR3_Pos (19U)
15506#define GPIO_BSRR_BR3_Msk (0x1UL << GPIO_BSRR_BR3_Pos)
15507#define GPIO_BSRR_BR3 GPIO_BSRR_BR3_Msk
15508#define GPIO_BSRR_BR4_Pos (20U)
15509#define GPIO_BSRR_BR4_Msk (0x1UL << GPIO_BSRR_BR4_Pos)
15510#define GPIO_BSRR_BR4 GPIO_BSRR_BR4_Msk
15511#define GPIO_BSRR_BR5_Pos (21U)
15512#define GPIO_BSRR_BR5_Msk (0x1UL << GPIO_BSRR_BR5_Pos)
15513#define GPIO_BSRR_BR5 GPIO_BSRR_BR5_Msk
15514#define GPIO_BSRR_BR6_Pos (22U)
15515#define GPIO_BSRR_BR6_Msk (0x1UL << GPIO_BSRR_BR6_Pos)
15516#define GPIO_BSRR_BR6 GPIO_BSRR_BR6_Msk
15517#define GPIO_BSRR_BR7_Pos (23U)
15518#define GPIO_BSRR_BR7_Msk (0x1UL << GPIO_BSRR_BR7_Pos)
15519#define GPIO_BSRR_BR7 GPIO_BSRR_BR7_Msk
15520#define GPIO_BSRR_BR8_Pos (24U)
15521#define GPIO_BSRR_BR8_Msk (0x1UL << GPIO_BSRR_BR8_Pos)
15522#define GPIO_BSRR_BR8 GPIO_BSRR_BR8_Msk
15523#define GPIO_BSRR_BR9_Pos (25U)
15524#define GPIO_BSRR_BR9_Msk (0x1UL << GPIO_BSRR_BR9_Pos)
15525#define GPIO_BSRR_BR9 GPIO_BSRR_BR9_Msk
15526#define GPIO_BSRR_BR10_Pos (26U)
15527#define GPIO_BSRR_BR10_Msk (0x1UL << GPIO_BSRR_BR10_Pos)
15528#define GPIO_BSRR_BR10 GPIO_BSRR_BR10_Msk
15529#define GPIO_BSRR_BR11_Pos (27U)
15530#define GPIO_BSRR_BR11_Msk (0x1UL << GPIO_BSRR_BR11_Pos)
15531#define GPIO_BSRR_BR11 GPIO_BSRR_BR11_Msk
15532#define GPIO_BSRR_BR12_Pos (28U)
15533#define GPIO_BSRR_BR12_Msk (0x1UL << GPIO_BSRR_BR12_Pos)
15534#define GPIO_BSRR_BR12 GPIO_BSRR_BR12_Msk
15535#define GPIO_BSRR_BR13_Pos (29U)
15536#define GPIO_BSRR_BR13_Msk (0x1UL << GPIO_BSRR_BR13_Pos)
15537#define GPIO_BSRR_BR13 GPIO_BSRR_BR13_Msk
15538#define GPIO_BSRR_BR14_Pos (30U)
15539#define GPIO_BSRR_BR14_Msk (0x1UL << GPIO_BSRR_BR14_Pos)
15540#define GPIO_BSRR_BR14 GPIO_BSRR_BR14_Msk
15541#define GPIO_BSRR_BR15_Pos (31U)
15542#define GPIO_BSRR_BR15_Msk (0x1UL << GPIO_BSRR_BR15_Pos)
15543#define GPIO_BSRR_BR15 GPIO_BSRR_BR15_Msk
15544
15545/****************** Bit definition for GPIO_LCKR register *********************/
15546#define GPIO_LCKR_LCK0_Pos (0U)
15547#define GPIO_LCKR_LCK0_Msk (0x1UL << GPIO_LCKR_LCK0_Pos)
15548#define GPIO_LCKR_LCK0 GPIO_LCKR_LCK0_Msk
15549#define GPIO_LCKR_LCK1_Pos (1U)
15550#define GPIO_LCKR_LCK1_Msk (0x1UL << GPIO_LCKR_LCK1_Pos)
15551#define GPIO_LCKR_LCK1 GPIO_LCKR_LCK1_Msk
15552#define GPIO_LCKR_LCK2_Pos (2U)
15553#define GPIO_LCKR_LCK2_Msk (0x1UL << GPIO_LCKR_LCK2_Pos)
15554#define GPIO_LCKR_LCK2 GPIO_LCKR_LCK2_Msk
15555#define GPIO_LCKR_LCK3_Pos (3U)
15556#define GPIO_LCKR_LCK3_Msk (0x1UL << GPIO_LCKR_LCK3_Pos)
15557#define GPIO_LCKR_LCK3 GPIO_LCKR_LCK3_Msk
15558#define GPIO_LCKR_LCK4_Pos (4U)
15559#define GPIO_LCKR_LCK4_Msk (0x1UL << GPIO_LCKR_LCK4_Pos)
15560#define GPIO_LCKR_LCK4 GPIO_LCKR_LCK4_Msk
15561#define GPIO_LCKR_LCK5_Pos (5U)
15562#define GPIO_LCKR_LCK5_Msk (0x1UL << GPIO_LCKR_LCK5_Pos)
15563#define GPIO_LCKR_LCK5 GPIO_LCKR_LCK5_Msk
15564#define GPIO_LCKR_LCK6_Pos (6U)
15565#define GPIO_LCKR_LCK6_Msk (0x1UL << GPIO_LCKR_LCK6_Pos)
15566#define GPIO_LCKR_LCK6 GPIO_LCKR_LCK6_Msk
15567#define GPIO_LCKR_LCK7_Pos (7U)
15568#define GPIO_LCKR_LCK7_Msk (0x1UL << GPIO_LCKR_LCK7_Pos)
15569#define GPIO_LCKR_LCK7 GPIO_LCKR_LCK7_Msk
15570#define GPIO_LCKR_LCK8_Pos (8U)
15571#define GPIO_LCKR_LCK8_Msk (0x1UL << GPIO_LCKR_LCK8_Pos)
15572#define GPIO_LCKR_LCK8 GPIO_LCKR_LCK8_Msk
15573#define GPIO_LCKR_LCK9_Pos (9U)
15574#define GPIO_LCKR_LCK9_Msk (0x1UL << GPIO_LCKR_LCK9_Pos)
15575#define GPIO_LCKR_LCK9 GPIO_LCKR_LCK9_Msk
15576#define GPIO_LCKR_LCK10_Pos (10U)
15577#define GPIO_LCKR_LCK10_Msk (0x1UL << GPIO_LCKR_LCK10_Pos)
15578#define GPIO_LCKR_LCK10 GPIO_LCKR_LCK10_Msk
15579#define GPIO_LCKR_LCK11_Pos (11U)
15580#define GPIO_LCKR_LCK11_Msk (0x1UL << GPIO_LCKR_LCK11_Pos)
15581#define GPIO_LCKR_LCK11 GPIO_LCKR_LCK11_Msk
15582#define GPIO_LCKR_LCK12_Pos (12U)
15583#define GPIO_LCKR_LCK12_Msk (0x1UL << GPIO_LCKR_LCK12_Pos)
15584#define GPIO_LCKR_LCK12 GPIO_LCKR_LCK12_Msk
15585#define GPIO_LCKR_LCK13_Pos (13U)
15586#define GPIO_LCKR_LCK13_Msk (0x1UL << GPIO_LCKR_LCK13_Pos)
15587#define GPIO_LCKR_LCK13 GPIO_LCKR_LCK13_Msk
15588#define GPIO_LCKR_LCK14_Pos (14U)
15589#define GPIO_LCKR_LCK14_Msk (0x1UL << GPIO_LCKR_LCK14_Pos)
15590#define GPIO_LCKR_LCK14 GPIO_LCKR_LCK14_Msk
15591#define GPIO_LCKR_LCK15_Pos (15U)
15592#define GPIO_LCKR_LCK15_Msk (0x1UL << GPIO_LCKR_LCK15_Pos)
15593#define GPIO_LCKR_LCK15 GPIO_LCKR_LCK15_Msk
15594#define GPIO_LCKR_LCKK_Pos (16U)
15595#define GPIO_LCKR_LCKK_Msk (0x1UL << GPIO_LCKR_LCKK_Pos)
15596#define GPIO_LCKR_LCKK GPIO_LCKR_LCKK_Msk
15597
15598/****************** Bit definition for GPIO_AFRL register ********************/
15599#define GPIO_AFRL_AFSEL0_Pos (0U)
15600#define GPIO_AFRL_AFSEL0_Msk (0xFUL << GPIO_AFRL_AFSEL0_Pos)
15601#define GPIO_AFRL_AFSEL0 GPIO_AFRL_AFSEL0_Msk
15602#define GPIO_AFRL_AFSEL0_0 (0x1UL << GPIO_AFRL_AFSEL0_Pos)
15603#define GPIO_AFRL_AFSEL0_1 (0x2UL << GPIO_AFRL_AFSEL0_Pos)
15604#define GPIO_AFRL_AFSEL0_2 (0x4UL << GPIO_AFRL_AFSEL0_Pos)
15605#define GPIO_AFRL_AFSEL0_3 (0x8UL << GPIO_AFRL_AFSEL0_Pos)
15606#define GPIO_AFRL_AFSEL1_Pos (4U)
15607#define GPIO_AFRL_AFSEL1_Msk (0xFUL << GPIO_AFRL_AFSEL1_Pos)
15608#define GPIO_AFRL_AFSEL1 GPIO_AFRL_AFSEL1_Msk
15609#define GPIO_AFRL_AFSEL1_0 (0x1UL << GPIO_AFRL_AFSEL1_Pos)
15610#define GPIO_AFRL_AFSEL1_1 (0x2UL << GPIO_AFRL_AFSEL1_Pos)
15611#define GPIO_AFRL_AFSEL1_2 (0x4UL << GPIO_AFRL_AFSEL1_Pos)
15612#define GPIO_AFRL_AFSEL1_3 (0x8UL << GPIO_AFRL_AFSEL1_Pos)
15613#define GPIO_AFRL_AFSEL2_Pos (8U)
15614#define GPIO_AFRL_AFSEL2_Msk (0xFUL << GPIO_AFRL_AFSEL2_Pos)
15615#define GPIO_AFRL_AFSEL2 GPIO_AFRL_AFSEL2_Msk
15616#define GPIO_AFRL_AFSEL2_0 (0x1UL << GPIO_AFRL_AFSEL2_Pos)
15617#define GPIO_AFRL_AFSEL2_1 (0x2UL << GPIO_AFRL_AFSEL2_Pos)
15618#define GPIO_AFRL_AFSEL2_2 (0x4UL << GPIO_AFRL_AFSEL2_Pos)
15619#define GPIO_AFRL_AFSEL2_3 (0x8UL << GPIO_AFRL_AFSEL2_Pos)
15620#define GPIO_AFRL_AFSEL3_Pos (12U)
15621#define GPIO_AFRL_AFSEL3_Msk (0xFUL << GPIO_AFRL_AFSEL3_Pos)
15622#define GPIO_AFRL_AFSEL3 GPIO_AFRL_AFSEL3_Msk
15623#define GPIO_AFRL_AFSEL3_0 (0x1UL << GPIO_AFRL_AFSEL3_Pos)
15624#define GPIO_AFRL_AFSEL3_1 (0x2UL << GPIO_AFRL_AFSEL3_Pos)
15625#define GPIO_AFRL_AFSEL3_2 (0x4UL << GPIO_AFRL_AFSEL3_Pos)
15626#define GPIO_AFRL_AFSEL3_3 (0x8UL << GPIO_AFRL_AFSEL3_Pos)
15627#define GPIO_AFRL_AFSEL4_Pos (16U)
15628#define GPIO_AFRL_AFSEL4_Msk (0xFUL << GPIO_AFRL_AFSEL4_Pos)
15629#define GPIO_AFRL_AFSEL4 GPIO_AFRL_AFSEL4_Msk
15630#define GPIO_AFRL_AFSEL4_0 (0x1UL << GPIO_AFRL_AFSEL4_Pos)
15631#define GPIO_AFRL_AFSEL4_1 (0x2UL << GPIO_AFRL_AFSEL4_Pos)
15632#define GPIO_AFRL_AFSEL4_2 (0x4UL << GPIO_AFRL_AFSEL4_Pos)
15633#define GPIO_AFRL_AFSEL4_3 (0x8UL << GPIO_AFRL_AFSEL4_Pos)
15634#define GPIO_AFRL_AFSEL5_Pos (20U)
15635#define GPIO_AFRL_AFSEL5_Msk (0xFUL << GPIO_AFRL_AFSEL5_Pos)
15636#define GPIO_AFRL_AFSEL5 GPIO_AFRL_AFSEL5_Msk
15637#define GPIO_AFRL_AFSEL5_0 (0x1UL << GPIO_AFRL_AFSEL5_Pos)
15638#define GPIO_AFRL_AFSEL5_1 (0x2UL << GPIO_AFRL_AFSEL5_Pos)
15639#define GPIO_AFRL_AFSEL5_2 (0x4UL << GPIO_AFRL_AFSEL5_Pos)
15640#define GPIO_AFRL_AFSEL5_3 (0x8UL << GPIO_AFRL_AFSEL5_Pos)
15641#define GPIO_AFRL_AFSEL6_Pos (24U)
15642#define GPIO_AFRL_AFSEL6_Msk (0xFUL << GPIO_AFRL_AFSEL6_Pos)
15643#define GPIO_AFRL_AFSEL6 GPIO_AFRL_AFSEL6_Msk
15644#define GPIO_AFRL_AFSEL6_0 (0x1UL << GPIO_AFRL_AFSEL6_Pos)
15645#define GPIO_AFRL_AFSEL6_1 (0x2UL << GPIO_AFRL_AFSEL6_Pos)
15646#define GPIO_AFRL_AFSEL6_2 (0x4UL << GPIO_AFRL_AFSEL6_Pos)
15647#define GPIO_AFRL_AFSEL6_3 (0x8UL << GPIO_AFRL_AFSEL6_Pos)
15648#define GPIO_AFRL_AFSEL7_Pos (28U)
15649#define GPIO_AFRL_AFSEL7_Msk (0xFUL << GPIO_AFRL_AFSEL7_Pos)
15650#define GPIO_AFRL_AFSEL7 GPIO_AFRL_AFSEL7_Msk
15651#define GPIO_AFRL_AFSEL7_0 (0x1UL << GPIO_AFRL_AFSEL7_Pos)
15652#define GPIO_AFRL_AFSEL7_1 (0x2UL << GPIO_AFRL_AFSEL7_Pos)
15653#define GPIO_AFRL_AFSEL7_2 (0x4UL << GPIO_AFRL_AFSEL7_Pos)
15654#define GPIO_AFRL_AFSEL7_3 (0x8UL << GPIO_AFRL_AFSEL7_Pos)
15656/* Legacy defines */
15657#define GPIO_AFRL_AFRL0 GPIO_AFRL_AFSEL0
15658#define GPIO_AFRL_AFRL1 GPIO_AFRL_AFSEL1
15659#define GPIO_AFRL_AFRL2 GPIO_AFRL_AFSEL2
15660#define GPIO_AFRL_AFRL3 GPIO_AFRL_AFSEL3
15661#define GPIO_AFRL_AFRL4 GPIO_AFRL_AFSEL4
15662#define GPIO_AFRL_AFRL5 GPIO_AFRL_AFSEL5
15663#define GPIO_AFRL_AFRL6 GPIO_AFRL_AFSEL6
15664#define GPIO_AFRL_AFRL7 GPIO_AFRL_AFSEL7
15665
15666/****************** Bit definition for GPIO_AFRH register ********************/
15667#define GPIO_AFRH_AFSEL8_Pos (0U)
15668#define GPIO_AFRH_AFSEL8_Msk (0xFUL << GPIO_AFRH_AFSEL8_Pos)
15669#define GPIO_AFRH_AFSEL8 GPIO_AFRH_AFSEL8_Msk
15670#define GPIO_AFRH_AFSEL8_0 (0x1UL << GPIO_AFRH_AFSEL8_Pos)
15671#define GPIO_AFRH_AFSEL8_1 (0x2UL << GPIO_AFRH_AFSEL8_Pos)
15672#define GPIO_AFRH_AFSEL8_2 (0x4UL << GPIO_AFRH_AFSEL8_Pos)
15673#define GPIO_AFRH_AFSEL8_3 (0x8UL << GPIO_AFRH_AFSEL8_Pos)
15674#define GPIO_AFRH_AFSEL9_Pos (4U)
15675#define GPIO_AFRH_AFSEL9_Msk (0xFUL << GPIO_AFRH_AFSEL9_Pos)
15676#define GPIO_AFRH_AFSEL9 GPIO_AFRH_AFSEL9_Msk
15677#define GPIO_AFRH_AFSEL9_0 (0x1UL << GPIO_AFRH_AFSEL9_Pos)
15678#define GPIO_AFRH_AFSEL9_1 (0x2UL << GPIO_AFRH_AFSEL9_Pos)
15679#define GPIO_AFRH_AFSEL9_2 (0x4UL << GPIO_AFRH_AFSEL9_Pos)
15680#define GPIO_AFRH_AFSEL9_3 (0x8UL << GPIO_AFRH_AFSEL9_Pos)
15681#define GPIO_AFRH_AFSEL10_Pos (8U)
15682#define GPIO_AFRH_AFSEL10_Msk (0xFUL << GPIO_AFRH_AFSEL10_Pos)
15683#define GPIO_AFRH_AFSEL10 GPIO_AFRH_AFSEL10_Msk
15684#define GPIO_AFRH_AFSEL10_0 (0x1UL << GPIO_AFRH_AFSEL10_Pos)
15685#define GPIO_AFRH_AFSEL10_1 (0x2UL << GPIO_AFRH_AFSEL10_Pos)
15686#define GPIO_AFRH_AFSEL10_2 (0x4UL << GPIO_AFRH_AFSEL10_Pos)
15687#define GPIO_AFRH_AFSEL10_3 (0x8UL << GPIO_AFRH_AFSEL10_Pos)
15688#define GPIO_AFRH_AFSEL11_Pos (12U)
15689#define GPIO_AFRH_AFSEL11_Msk (0xFUL << GPIO_AFRH_AFSEL11_Pos)
15690#define GPIO_AFRH_AFSEL11 GPIO_AFRH_AFSEL11_Msk
15691#define GPIO_AFRH_AFSEL11_0 (0x1UL << GPIO_AFRH_AFSEL11_Pos)
15692#define GPIO_AFRH_AFSEL11_1 (0x2UL << GPIO_AFRH_AFSEL11_Pos)
15693#define GPIO_AFRH_AFSEL11_2 (0x4UL << GPIO_AFRH_AFSEL11_Pos)
15694#define GPIO_AFRH_AFSEL11_3 (0x8UL << GPIO_AFRH_AFSEL11_Pos)
15695#define GPIO_AFRH_AFSEL12_Pos (16U)
15696#define GPIO_AFRH_AFSEL12_Msk (0xFUL << GPIO_AFRH_AFSEL12_Pos)
15697#define GPIO_AFRH_AFSEL12 GPIO_AFRH_AFSEL12_Msk
15698#define GPIO_AFRH_AFSEL12_0 (0x1UL << GPIO_AFRH_AFSEL12_Pos)
15699#define GPIO_AFRH_AFSEL12_1 (0x2UL << GPIO_AFRH_AFSEL12_Pos)
15700#define GPIO_AFRH_AFSEL12_2 (0x4UL << GPIO_AFRH_AFSEL12_Pos)
15701#define GPIO_AFRH_AFSEL12_3 (0x8UL << GPIO_AFRH_AFSEL12_Pos)
15702#define GPIO_AFRH_AFSEL13_Pos (20U)
15703#define GPIO_AFRH_AFSEL13_Msk (0xFUL << GPIO_AFRH_AFSEL13_Pos)
15704#define GPIO_AFRH_AFSEL13 GPIO_AFRH_AFSEL13_Msk
15705#define GPIO_AFRH_AFSEL13_0 (0x1UL << GPIO_AFRH_AFSEL13_Pos)
15706#define GPIO_AFRH_AFSEL13_1 (0x2UL << GPIO_AFRH_AFSEL13_Pos)
15707#define GPIO_AFRH_AFSEL13_2 (0x4UL << GPIO_AFRH_AFSEL13_Pos)
15708#define GPIO_AFRH_AFSEL13_3 (0x8UL << GPIO_AFRH_AFSEL13_Pos)
15709#define GPIO_AFRH_AFSEL14_Pos (24U)
15710#define GPIO_AFRH_AFSEL14_Msk (0xFUL << GPIO_AFRH_AFSEL14_Pos)
15711#define GPIO_AFRH_AFSEL14 GPIO_AFRH_AFSEL14_Msk
15712#define GPIO_AFRH_AFSEL14_0 (0x1UL << GPIO_AFRH_AFSEL14_Pos)
15713#define GPIO_AFRH_AFSEL14_1 (0x2UL << GPIO_AFRH_AFSEL14_Pos)
15714#define GPIO_AFRH_AFSEL14_2 (0x4UL << GPIO_AFRH_AFSEL14_Pos)
15715#define GPIO_AFRH_AFSEL14_3 (0x8UL << GPIO_AFRH_AFSEL14_Pos)
15716#define GPIO_AFRH_AFSEL15_Pos (28U)
15717#define GPIO_AFRH_AFSEL15_Msk (0xFUL << GPIO_AFRH_AFSEL15_Pos)
15718#define GPIO_AFRH_AFSEL15 GPIO_AFRH_AFSEL15_Msk
15719#define GPIO_AFRH_AFSEL15_0 (0x1UL << GPIO_AFRH_AFSEL15_Pos)
15720#define GPIO_AFRH_AFSEL15_1 (0x2UL << GPIO_AFRH_AFSEL15_Pos)
15721#define GPIO_AFRH_AFSEL15_2 (0x4UL << GPIO_AFRH_AFSEL15_Pos)
15722#define GPIO_AFRH_AFSEL15_3 (0x8UL << GPIO_AFRH_AFSEL15_Pos)
15724/* Legacy defines */
15725#define GPIO_AFRH_AFRH0 GPIO_AFRH_AFSEL8
15726#define GPIO_AFRH_AFRH1 GPIO_AFRH_AFSEL9
15727#define GPIO_AFRH_AFRH2 GPIO_AFRH_AFSEL10
15728#define GPIO_AFRH_AFRH3 GPIO_AFRH_AFSEL11
15729#define GPIO_AFRH_AFRH4 GPIO_AFRH_AFSEL12
15730#define GPIO_AFRH_AFRH5 GPIO_AFRH_AFSEL13
15731#define GPIO_AFRH_AFRH6 GPIO_AFRH_AFSEL14
15732#define GPIO_AFRH_AFRH7 GPIO_AFRH_AFSEL15
15733
15734/******************************************************************************/
15735/* */
15736/* HSEM HW Semaphore */
15737/* */
15738/******************************************************************************/
15739/******************** Bit definition for HSEM_R register ********************/
15740#define HSEM_R_PROCID_Pos (0U)
15741#define HSEM_R_PROCID_Msk (0xFFUL << HSEM_R_PROCID_Pos)
15742#define HSEM_R_PROCID HSEM_R_PROCID_Msk
15743#define HSEM_R_COREID_Pos (8U)
15744#define HSEM_R_COREID_Msk (0xFFUL << HSEM_R_COREID_Pos)
15745#define HSEM_R_COREID HSEM_R_COREID_Msk
15746#define HSEM_R_LOCK_Pos (31U)
15747#define HSEM_R_LOCK_Msk (0x1UL << HSEM_R_LOCK_Pos)
15748#define HSEM_R_LOCK HSEM_R_LOCK_Msk
15750/******************** Bit definition for HSEM_RLR register ******************/
15751#define HSEM_RLR_PROCID_Pos (0U)
15752#define HSEM_RLR_PROCID_Msk (0xFFUL << HSEM_RLR_PROCID_Pos)
15753#define HSEM_RLR_PROCID HSEM_RLR_PROCID_Msk
15754#define HSEM_RLR_COREID_Pos (8U)
15755#define HSEM_RLR_COREID_Msk (0xFFUL << HSEM_RLR_COREID_Pos)
15756#define HSEM_RLR_COREID HSEM_RLR_COREID_Msk
15757#define HSEM_RLR_LOCK_Pos (31U)
15758#define HSEM_RLR_LOCK_Msk (0x1UL << HSEM_RLR_LOCK_Pos)
15759#define HSEM_RLR_LOCK HSEM_RLR_LOCK_Msk
15761/******************** Bit definition for HSEM_C1IER register *****************/
15762#define HSEM_C1IER_ISE0_Pos (0U)
15763#define HSEM_C1IER_ISE0_Msk (0x1UL << HSEM_C1IER_ISE0_Pos)
15764#define HSEM_C1IER_ISE0 HSEM_C1IER_ISE0_Msk
15765#define HSEM_C1IER_ISE1_Pos (1U)
15766#define HSEM_C1IER_ISE1_Msk (0x1UL << HSEM_C1IER_ISE1_Pos)
15767#define HSEM_C1IER_ISE1 HSEM_C1IER_ISE1_Msk
15768#define HSEM_C1IER_ISE2_Pos (2U)
15769#define HSEM_C1IER_ISE2_Msk (0x1UL << HSEM_C1IER_ISE2_Pos)
15770#define HSEM_C1IER_ISE2 HSEM_C1IER_ISE2_Msk
15771#define HSEM_C1IER_ISE3_Pos (3U)
15772#define HSEM_C1IER_ISE3_Msk (0x1UL << HSEM_C1IER_ISE3_Pos)
15773#define HSEM_C1IER_ISE3 HSEM_C1IER_ISE3_Msk
15774#define HSEM_C1IER_ISE4_Pos (4U)
15775#define HSEM_C1IER_ISE4_Msk (0x1UL << HSEM_C1IER_ISE4_Pos)
15776#define HSEM_C1IER_ISE4 HSEM_C1IER_ISE4_Msk
15777#define HSEM_C1IER_ISE5_Pos (5U)
15778#define HSEM_C1IER_ISE5_Msk (0x1UL << HSEM_C1IER_ISE5_Pos)
15779#define HSEM_C1IER_ISE5 HSEM_C1IER_ISE5_Msk
15780#define HSEM_C1IER_ISE6_Pos (6U)
15781#define HSEM_C1IER_ISE6_Msk (0x1UL << HSEM_C1IER_ISE6_Pos)
15782#define HSEM_C1IER_ISE6 HSEM_C1IER_ISE6_Msk
15783#define HSEM_C1IER_ISE7_Pos (7U)
15784#define HSEM_C1IER_ISE7_Msk (0x1UL << HSEM_C1IER_ISE7_Pos)
15785#define HSEM_C1IER_ISE7 HSEM_C1IER_ISE7_Msk
15786#define HSEM_C1IER_ISE8_Pos (8U)
15787#define HSEM_C1IER_ISE8_Msk (0x1UL << HSEM_C1IER_ISE8_Pos)
15788#define HSEM_C1IER_ISE8 HSEM_C1IER_ISE8_Msk
15789#define HSEM_C1IER_ISE9_Pos (9U)
15790#define HSEM_C1IER_ISE9_Msk (0x1UL << HSEM_C1IER_ISE9_Pos)
15791#define HSEM_C1IER_ISE9 HSEM_C1IER_ISE9_Msk
15792#define HSEM_C1IER_ISE10_Pos (10U)
15793#define HSEM_C1IER_ISE10_Msk (0x1UL << HSEM_C1IER_ISE10_Pos)
15794#define HSEM_C1IER_ISE10 HSEM_C1IER_ISE10_Msk
15795#define HSEM_C1IER_ISE11_Pos (11U)
15796#define HSEM_C1IER_ISE11_Msk (0x1UL << HSEM_C1IER_ISE11_Pos)
15797#define HSEM_C1IER_ISE11 HSEM_C1IER_ISE11_Msk
15798#define HSEM_C1IER_ISE12_Pos (12U)
15799#define HSEM_C1IER_ISE12_Msk (0x1UL << HSEM_C1IER_ISE12_Pos)
15800#define HSEM_C1IER_ISE12 HSEM_C1IER_ISE12_Msk
15801#define HSEM_C1IER_ISE13_Pos (13U)
15802#define HSEM_C1IER_ISE13_Msk (0x1UL << HSEM_C1IER_ISE13_Pos)
15803#define HSEM_C1IER_ISE13 HSEM_C1IER_ISE13_Msk
15804#define HSEM_C1IER_ISE14_Pos (14U)
15805#define HSEM_C1IER_ISE14_Msk (0x1UL << HSEM_C1IER_ISE14_Pos)
15806#define HSEM_C1IER_ISE14 HSEM_C1IER_ISE14_Msk
15807#define HSEM_C1IER_ISE15_Pos (15U)
15808#define HSEM_C1IER_ISE15_Msk (0x1UL << HSEM_C1IER_ISE15_Pos)
15809#define HSEM_C1IER_ISE15 HSEM_C1IER_ISE15_Msk
15810#define HSEM_C1IER_ISE16_Pos (16U)
15811#define HSEM_C1IER_ISE16_Msk (0x1UL << HSEM_C1IER_ISE16_Pos)
15812#define HSEM_C1IER_ISE16 HSEM_C1IER_ISE16_Msk
15813#define HSEM_C1IER_ISE17_Pos (17U)
15814#define HSEM_C1IER_ISE17_Msk (0x1UL << HSEM_C1IER_ISE17_Pos)
15815#define HSEM_C1IER_ISE17 HSEM_C1IER_ISE17_Msk
15816#define HSEM_C1IER_ISE18_Pos (18U)
15817#define HSEM_C1IER_ISE18_Msk (0x1UL << HSEM_C1IER_ISE18_Pos)
15818#define HSEM_C1IER_ISE18 HSEM_C1IER_ISE18_Msk
15819#define HSEM_C1IER_ISE19_Pos (19U)
15820#define HSEM_C1IER_ISE19_Msk (0x1UL << HSEM_C1IER_ISE19_Pos)
15821#define HSEM_C1IER_ISE19 HSEM_C1IER_ISE19_Msk
15822#define HSEM_C1IER_ISE20_Pos (20U)
15823#define HSEM_C1IER_ISE20_Msk (0x1UL << HSEM_C1IER_ISE20_Pos)
15824#define HSEM_C1IER_ISE20 HSEM_C1IER_ISE20_Msk
15825#define HSEM_C1IER_ISE21_Pos (21U)
15826#define HSEM_C1IER_ISE21_Msk (0x1UL << HSEM_C1IER_ISE21_Pos)
15827#define HSEM_C1IER_ISE21 HSEM_C1IER_ISE21_Msk
15828#define HSEM_C1IER_ISE22_Pos (22U)
15829#define HSEM_C1IER_ISE22_Msk (0x1UL << HSEM_C1IER_ISE22_Pos)
15830#define HSEM_C1IER_ISE22 HSEM_C1IER_ISE22_Msk
15831#define HSEM_C1IER_ISE23_Pos (23U)
15832#define HSEM_C1IER_ISE23_Msk (0x1UL << HSEM_C1IER_ISE23_Pos)
15833#define HSEM_C1IER_ISE23 HSEM_C1IER_ISE23_Msk
15834#define HSEM_C1IER_ISE24_Pos (24U)
15835#define HSEM_C1IER_ISE24_Msk (0x1UL << HSEM_C1IER_ISE24_Pos)
15836#define HSEM_C1IER_ISE24 HSEM_C1IER_ISE24_Msk
15837#define HSEM_C1IER_ISE25_Pos (25U)
15838#define HSEM_C1IER_ISE25_Msk (0x1UL << HSEM_C1IER_ISE25_Pos)
15839#define HSEM_C1IER_ISE25 HSEM_C1IER_ISE25_Msk
15840#define HSEM_C1IER_ISE26_Pos (26U)
15841#define HSEM_C1IER_ISE26_Msk (0x1UL << HSEM_C1IER_ISE26_Pos)
15842#define HSEM_C1IER_ISE26 HSEM_C1IER_ISE26_Msk
15843#define HSEM_C1IER_ISE27_Pos (27U)
15844#define HSEM_C1IER_ISE27_Msk (0x1UL << HSEM_C1IER_ISE27_Pos)
15845#define HSEM_C1IER_ISE27 HSEM_C1IER_ISE27_Msk
15846#define HSEM_C1IER_ISE28_Pos (28U)
15847#define HSEM_C1IER_ISE28_Msk (0x1UL << HSEM_C1IER_ISE28_Pos)
15848#define HSEM_C1IER_ISE28 HSEM_C1IER_ISE28_Msk
15849#define HSEM_C1IER_ISE29_Pos (29U)
15850#define HSEM_C1IER_ISE29_Msk (0x1UL << HSEM_C1IER_ISE29_Pos)
15851#define HSEM_C1IER_ISE29 HSEM_C1IER_ISE29_Msk
15852#define HSEM_C1IER_ISE30_Pos (30U)
15853#define HSEM_C1IER_ISE30_Msk (0x1UL << HSEM_C1IER_ISE30_Pos)
15854#define HSEM_C1IER_ISE30 HSEM_C1IER_ISE30_Msk
15855#define HSEM_C1IER_ISE31_Pos (31U)
15856#define HSEM_C1IER_ISE31_Msk (0x1UL << HSEM_C1IER_ISE31_Pos)
15857#define HSEM_C1IER_ISE31 HSEM_C1IER_ISE31_Msk
15859/******************** Bit definition for HSEM_C1ICR register *****************/
15860#define HSEM_C1ICR_ISC0_Pos (0U)
15861#define HSEM_C1ICR_ISC0_Msk (0x1UL << HSEM_C1ICR_ISC0_Pos)
15862#define HSEM_C1ICR_ISC0 HSEM_C1ICR_ISC0_Msk
15863#define HSEM_C1ICR_ISC1_Pos (1U)
15864#define HSEM_C1ICR_ISC1_Msk (0x1UL << HSEM_C1ICR_ISC1_Pos)
15865#define HSEM_C1ICR_ISC1 HSEM_C1ICR_ISC1_Msk
15866#define HSEM_C1ICR_ISC2_Pos (2U)
15867#define HSEM_C1ICR_ISC2_Msk (0x1UL << HSEM_C1ICR_ISC2_Pos)
15868#define HSEM_C1ICR_ISC2 HSEM_C1ICR_ISC2_Msk
15869#define HSEM_C1ICR_ISC3_Pos (3U)
15870#define HSEM_C1ICR_ISC3_Msk (0x1UL << HSEM_C1ICR_ISC3_Pos)
15871#define HSEM_C1ICR_ISC3 HSEM_C1ICR_ISC3_Msk
15872#define HSEM_C1ICR_ISC4_Pos (4U)
15873#define HSEM_C1ICR_ISC4_Msk (0x1UL << HSEM_C1ICR_ISC4_Pos)
15874#define HSEM_C1ICR_ISC4 HSEM_C1ICR_ISC4_Msk
15875#define HSEM_C1ICR_ISC5_Pos (5U)
15876#define HSEM_C1ICR_ISC5_Msk (0x1UL << HSEM_C1ICR_ISC5_Pos)
15877#define HSEM_C1ICR_ISC5 HSEM_C1ICR_ISC5_Msk
15878#define HSEM_C1ICR_ISC6_Pos (6U)
15879#define HSEM_C1ICR_ISC6_Msk (0x1UL << HSEM_C1ICR_ISC6_Pos)
15880#define HSEM_C1ICR_ISC6 HSEM_C1ICR_ISC6_Msk
15881#define HSEM_C1ICR_ISC7_Pos (7U)
15882#define HSEM_C1ICR_ISC7_Msk (0x1UL << HSEM_C1ICR_ISC7_Pos)
15883#define HSEM_C1ICR_ISC7 HSEM_C1ICR_ISC7_Msk
15884#define HSEM_C1ICR_ISC8_Pos (8U)
15885#define HSEM_C1ICR_ISC8_Msk (0x1UL << HSEM_C1ICR_ISC8_Pos)
15886#define HSEM_C1ICR_ISC8 HSEM_C1ICR_ISC8_Msk
15887#define HSEM_C1ICR_ISC9_Pos (9U)
15888#define HSEM_C1ICR_ISC9_Msk (0x1UL << HSEM_C1ICR_ISC9_Pos)
15889#define HSEM_C1ICR_ISC9 HSEM_C1ICR_ISC9_Msk
15890#define HSEM_C1ICR_ISC10_Pos (10U)
15891#define HSEM_C1ICR_ISC10_Msk (0x1UL << HSEM_C1ICR_ISC10_Pos)
15892#define HSEM_C1ICR_ISC10 HSEM_C1ICR_ISC10_Msk
15893#define HSEM_C1ICR_ISC11_Pos (11U)
15894#define HSEM_C1ICR_ISC11_Msk (0x1UL << HSEM_C1ICR_ISC11_Pos)
15895#define HSEM_C1ICR_ISC11 HSEM_C1ICR_ISC11_Msk
15896#define HSEM_C1ICR_ISC12_Pos (12U)
15897#define HSEM_C1ICR_ISC12_Msk (0x1UL << HSEM_C1ICR_ISC12_Pos)
15898#define HSEM_C1ICR_ISC12 HSEM_C1ICR_ISC12_Msk
15899#define HSEM_C1ICR_ISC13_Pos (13U)
15900#define HSEM_C1ICR_ISC13_Msk (0x1UL << HSEM_C1ICR_ISC13_Pos)
15901#define HSEM_C1ICR_ISC13 HSEM_C1ICR_ISC13_Msk
15902#define HSEM_C1ICR_ISC14_Pos (14U)
15903#define HSEM_C1ICR_ISC14_Msk (0x1UL << HSEM_C1ICR_ISC14_Pos)
15904#define HSEM_C1ICR_ISC14 HSEM_C1ICR_ISC14_Msk
15905#define HSEM_C1ICR_ISC15_Pos (15U)
15906#define HSEM_C1ICR_ISC15_Msk (0x1UL << HSEM_C1ICR_ISC15_Pos)
15907#define HSEM_C1ICR_ISC15 HSEM_C1ICR_ISC15_Msk
15908#define HSEM_C1ICR_ISC16_Pos (16U)
15909#define HSEM_C1ICR_ISC16_Msk (0x1UL << HSEM_C1ICR_ISC16_Pos)
15910#define HSEM_C1ICR_ISC16 HSEM_C1ICR_ISC16_Msk
15911#define HSEM_C1ICR_ISC17_Pos (17U)
15912#define HSEM_C1ICR_ISC17_Msk (0x1UL << HSEM_C1ICR_ISC17_Pos)
15913#define HSEM_C1ICR_ISC17 HSEM_C1ICR_ISC17_Msk
15914#define HSEM_C1ICR_ISC18_Pos (18U)
15915#define HSEM_C1ICR_ISC18_Msk (0x1UL << HSEM_C1ICR_ISC18_Pos)
15916#define HSEM_C1ICR_ISC18 HSEM_C1ICR_ISC18_Msk
15917#define HSEM_C1ICR_ISC19_Pos (19U)
15918#define HSEM_C1ICR_ISC19_Msk (0x1UL << HSEM_C1ICR_ISC19_Pos)
15919#define HSEM_C1ICR_ISC19 HSEM_C1ICR_ISC19_Msk
15920#define HSEM_C1ICR_ISC20_Pos (20U)
15921#define HSEM_C1ICR_ISC20_Msk (0x1UL << HSEM_C1ICR_ISC20_Pos)
15922#define HSEM_C1ICR_ISC20 HSEM_C1ICR_ISC20_Msk
15923#define HSEM_C1ICR_ISC21_Pos (21U)
15924#define HSEM_C1ICR_ISC21_Msk (0x1UL << HSEM_C1ICR_ISC21_Pos)
15925#define HSEM_C1ICR_ISC21 HSEM_C1ICR_ISC21_Msk
15926#define HSEM_C1ICR_ISC22_Pos (22U)
15927#define HSEM_C1ICR_ISC22_Msk (0x1UL << HSEM_C1ICR_ISC22_Pos)
15928#define HSEM_C1ICR_ISC22 HSEM_C1ICR_ISC22_Msk
15929#define HSEM_C1ICR_ISC23_Pos (23U)
15930#define HSEM_C1ICR_ISC23_Msk (0x1UL << HSEM_C1ICR_ISC23_Pos)
15931#define HSEM_C1ICR_ISC23 HSEM_C1ICR_ISC23_Msk
15932#define HSEM_C1ICR_ISC24_Pos (24U)
15933#define HSEM_C1ICR_ISC24_Msk (0x1UL << HSEM_C1ICR_ISC24_Pos)
15934#define HSEM_C1ICR_ISC24 HSEM_C1ICR_ISC24_Msk
15935#define HSEM_C1ICR_ISC25_Pos (25U)
15936#define HSEM_C1ICR_ISC25_Msk (0x1UL << HSEM_C1ICR_ISC25_Pos)
15937#define HSEM_C1ICR_ISC25 HSEM_C1ICR_ISC25_Msk
15938#define HSEM_C1ICR_ISC26_Pos (26U)
15939#define HSEM_C1ICR_ISC26_Msk (0x1UL << HSEM_C1ICR_ISC26_Pos)
15940#define HSEM_C1ICR_ISC26 HSEM_C1ICR_ISC26_Msk
15941#define HSEM_C1ICR_ISC27_Pos (27U)
15942#define HSEM_C1ICR_ISC27_Msk (0x1UL << HSEM_C1ICR_ISC27_Pos)
15943#define HSEM_C1ICR_ISC27 HSEM_C1ICR_ISC27_Msk
15944#define HSEM_C1ICR_ISC28_Pos (28U)
15945#define HSEM_C1ICR_ISC28_Msk (0x1UL << HSEM_C1ICR_ISC28_Pos)
15946#define HSEM_C1ICR_ISC28 HSEM_C1ICR_ISC28_Msk
15947#define HSEM_C1ICR_ISC29_Pos (29U)
15948#define HSEM_C1ICR_ISC29_Msk (0x1UL << HSEM_C1ICR_ISC29_Pos)
15949#define HSEM_C1ICR_ISC29 HSEM_C1ICR_ISC29_Msk
15950#define HSEM_C1ICR_ISC30_Pos (30U)
15951#define HSEM_C1ICR_ISC30_Msk (0x1UL << HSEM_C1ICR_ISC30_Pos)
15952#define HSEM_C1ICR_ISC30 HSEM_C1ICR_ISC30_Msk
15953#define HSEM_C1ICR_ISC31_Pos (31U)
15954#define HSEM_C1ICR_ISC31_Msk (0x1UL << HSEM_C1ICR_ISC31_Pos)
15955#define HSEM_C1ICR_ISC31 HSEM_C1ICR_ISC31_Msk
15957/******************** Bit definition for HSEM_C1ISR register *****************/
15958#define HSEM_C1ISR_ISF0_Pos (0U)
15959#define HSEM_C1ISR_ISF0_Msk (0x1UL << HSEM_C1ISR_ISF0_Pos)
15960#define HSEM_C1ISR_ISF0 HSEM_C1ISR_ISF0_Msk
15961#define HSEM_C1ISR_ISF1_Pos (1U)
15962#define HSEM_C1ISR_ISF1_Msk (0x1UL << HSEM_C1ISR_ISF1_Pos)
15963#define HSEM_C1ISR_ISF1 HSEM_C1ISR_ISF1_Msk
15964#define HSEM_C1ISR_ISF2_Pos (2U)
15965#define HSEM_C1ISR_ISF2_Msk (0x1UL << HSEM_C1ISR_ISF2_Pos)
15966#define HSEM_C1ISR_ISF2 HSEM_C1ISR_ISF2_Msk
15967#define HSEM_C1ISR_ISF3_Pos (3U)
15968#define HSEM_C1ISR_ISF3_Msk (0x1UL << HSEM_C1ISR_ISF3_Pos)
15969#define HSEM_C1ISR_ISF3 HSEM_C1ISR_ISF3_Msk
15970#define HSEM_C1ISR_ISF4_Pos (4U)
15971#define HSEM_C1ISR_ISF4_Msk (0x1UL << HSEM_C1ISR_ISF4_Pos)
15972#define HSEM_C1ISR_ISF4 HSEM_C1ISR_ISF4_Msk
15973#define HSEM_C1ISR_ISF5_Pos (5U)
15974#define HSEM_C1ISR_ISF5_Msk (0x1UL << HSEM_C1ISR_ISF5_Pos)
15975#define HSEM_C1ISR_ISF5 HSEM_C1ISR_ISF5_Msk
15976#define HSEM_C1ISR_ISF6_Pos (6U)
15977#define HSEM_C1ISR_ISF6_Msk (0x1UL << HSEM_C1ISR_ISF6_Pos)
15978#define HSEM_C1ISR_ISF6 HSEM_C1ISR_ISF6_Msk
15979#define HSEM_C1ISR_ISF7_Pos (7U)
15980#define HSEM_C1ISR_ISF7_Msk (0x1UL << HSEM_C1ISR_ISF7_Pos)
15981#define HSEM_C1ISR_ISF7 HSEM_C1ISR_ISF7_Msk
15982#define HSEM_C1ISR_ISF8_Pos (8U)
15983#define HSEM_C1ISR_ISF8_Msk (0x1UL << HSEM_C1ISR_ISF8_Pos)
15984#define HSEM_C1ISR_ISF8 HSEM_C1ISR_ISF8_Msk
15985#define HSEM_C1ISR_ISF9_Pos (9U)
15986#define HSEM_C1ISR_ISF9_Msk (0x1UL << HSEM_C1ISR_ISF9_Pos)
15987#define HSEM_C1ISR_ISF9 HSEM_C1ISR_ISF9_Msk
15988#define HSEM_C1ISR_ISF10_Pos (10U)
15989#define HSEM_C1ISR_ISF10_Msk (0x1UL << HSEM_C1ISR_ISF10_Pos)
15990#define HSEM_C1ISR_ISF10 HSEM_C1ISR_ISF10_Msk
15991#define HSEM_C1ISR_ISF11_Pos (11U)
15992#define HSEM_C1ISR_ISF11_Msk (0x1UL << HSEM_C1ISR_ISF11_Pos)
15993#define HSEM_C1ISR_ISF11 HSEM_C1ISR_ISF11_Msk
15994#define HSEM_C1ISR_ISF12_Pos (12U)
15995#define HSEM_C1ISR_ISF12_Msk (0x1UL << HSEM_C1ISR_ISF12_Pos)
15996#define HSEM_C1ISR_ISF12 HSEM_C1ISR_ISF12_Msk
15997#define HSEM_C1ISR_ISF13_Pos (13U)
15998#define HSEM_C1ISR_ISF13_Msk (0x1UL << HSEM_C1ISR_ISF13_Pos)
15999#define HSEM_C1ISR_ISF13 HSEM_C1ISR_ISF13_Msk
16000#define HSEM_C1ISR_ISF14_Pos (14U)
16001#define HSEM_C1ISR_ISF14_Msk (0x1UL << HSEM_C1ISR_ISF14_Pos)
16002#define HSEM_C1ISR_ISF14 HSEM_C1ISR_ISF14_Msk
16003#define HSEM_C1ISR_ISF15_Pos (15U)
16004#define HSEM_C1ISR_ISF15_Msk (0x1UL << HSEM_C1ISR_ISF15_Pos)
16005#define HSEM_C1ISR_ISF15 HSEM_C1ISR_ISF15_Msk
16006#define HSEM_C1ISR_ISF16_Pos (16U)
16007#define HSEM_C1ISR_ISF16_Msk (0x1UL << HSEM_C1ISR_ISF16_Pos)
16008#define HSEM_C1ISR_ISF16 HSEM_C1ISR_ISF16_Msk
16009#define HSEM_C1ISR_ISF17_Pos (17U)
16010#define HSEM_C1ISR_ISF17_Msk (0x1UL << HSEM_C1ISR_ISF17_Pos)
16011#define HSEM_C1ISR_ISF17 HSEM_C1ISR_ISF17_Msk
16012#define HSEM_C1ISR_ISF18_Pos (18U)
16013#define HSEM_C1ISR_ISF18_Msk (0x1UL << HSEM_C1ISR_ISF18_Pos)
16014#define HSEM_C1ISR_ISF18 HSEM_C1ISR_ISF18_Msk
16015#define HSEM_C1ISR_ISF19_Pos (19U)
16016#define HSEM_C1ISR_ISF19_Msk (0x1UL << HSEM_C1ISR_ISF19_Pos)
16017#define HSEM_C1ISR_ISF19 HSEM_C1ISR_ISF19_Msk
16018#define HSEM_C1ISR_ISF20_Pos (20U)
16019#define HSEM_C1ISR_ISF20_Msk (0x1UL << HSEM_C1ISR_ISF20_Pos)
16020#define HSEM_C1ISR_ISF20 HSEM_C1ISR_ISF20_Msk
16021#define HSEM_C1ISR_ISF21_Pos (21U)
16022#define HSEM_C1ISR_ISF21_Msk (0x1UL << HSEM_C1ISR_ISF21_Pos)
16023#define HSEM_C1ISR_ISF21 HSEM_C1ISR_ISF21_Msk
16024#define HSEM_C1ISR_ISF22_Pos (22U)
16025#define HSEM_C1ISR_ISF22_Msk (0x1UL << HSEM_C1ISR_ISF22_Pos)
16026#define HSEM_C1ISR_ISF22 HSEM_C1ISR_ISF22_Msk
16027#define HSEM_C1ISR_ISF23_Pos (23U)
16028#define HSEM_C1ISR_ISF23_Msk (0x1UL << HSEM_C1ISR_ISF23_Pos)
16029#define HSEM_C1ISR_ISF23 HSEM_C1ISR_ISF23_Msk
16030#define HSEM_C1ISR_ISF24_Pos (24U)
16031#define HSEM_C1ISR_ISF24_Msk (0x1UL << HSEM_C1ISR_ISF24_Pos)
16032#define HSEM_C1ISR_ISF24 HSEM_C1ISR_ISF24_Msk
16033#define HSEM_C1ISR_ISF25_Pos (25U)
16034#define HSEM_C1ISR_ISF25_Msk (0x1UL << HSEM_C1ISR_ISF25_Pos)
16035#define HSEM_C1ISR_ISF25 HSEM_C1ISR_ISF25_Msk
16036#define HSEM_C1ISR_ISF26_Pos (26U)
16037#define HSEM_C1ISR_ISF26_Msk (0x1UL << HSEM_C1ISR_ISF26_Pos)
16038#define HSEM_C1ISR_ISF26 HSEM_C1ISR_ISF26_Msk
16039#define HSEM_C1ISR_ISF27_Pos (27U)
16040#define HSEM_C1ISR_ISF27_Msk (0x1UL << HSEM_C1ISR_ISF27_Pos)
16041#define HSEM_C1ISR_ISF27 HSEM_C1ISR_ISF27_Msk
16042#define HSEM_C1ISR_ISF28_Pos (28U)
16043#define HSEM_C1ISR_ISF28_Msk (0x1UL << HSEM_C1ISR_ISF28_Pos)
16044#define HSEM_C1ISR_ISF28 HSEM_C1ISR_ISF28_Msk
16045#define HSEM_C1ISR_ISF29_Pos (29U)
16046#define HSEM_C1ISR_ISF29_Msk (0x1UL << HSEM_C1ISR_ISF29_Pos)
16047#define HSEM_C1ISR_ISF29 HSEM_C1ISR_ISF29_Msk
16048#define HSEM_C1ISR_ISF30_Pos (30U)
16049#define HSEM_C1ISR_ISF30_Msk (0x1UL << HSEM_C1ISR_ISF30_Pos)
16050#define HSEM_C1ISR_ISF30 HSEM_C1ISR_ISF30_Msk
16051#define HSEM_C1ISR_ISF31_Pos (31U)
16052#define HSEM_C1ISR_ISF31_Msk (0x1UL << HSEM_C1ISR_ISF31_Pos)
16053#define HSEM_C1ISR_ISF31 HSEM_C1ISR_ISF31_Msk
16055/******************** Bit definition for HSEM_C1MISR register *****************/
16056#define HSEM_C1MISR_MISF0_Pos (0U)
16057#define HSEM_C1MISR_MISF0_Msk (0x1UL << HSEM_C1MISR_MISF0_Pos)
16058#define HSEM_C1MISR_MISF0 HSEM_C1MISR_MISF0_Msk
16059#define HSEM_C1MISR_MISF1_Pos (1U)
16060#define HSEM_C1MISR_MISF1_Msk (0x1UL << HSEM_C1MISR_MISF1_Pos)
16061#define HSEM_C1MISR_MISF1 HSEM_C1MISR_MISF1_Msk
16062#define HSEM_C1MISR_MISF2_Pos (2U)
16063#define HSEM_C1MISR_MISF2_Msk (0x1UL << HSEM_C1MISR_MISF2_Pos)
16064#define HSEM_C1MISR_MISF2 HSEM_C1MISR_MISF2_Msk
16065#define HSEM_C1MISR_MISF3_Pos (3U)
16066#define HSEM_C1MISR_MISF3_Msk (0x1UL << HSEM_C1MISR_MISF3_Pos)
16067#define HSEM_C1MISR_MISF3 HSEM_C1MISR_MISF3_Msk
16068#define HSEM_C1MISR_MISF4_Pos (4U)
16069#define HSEM_C1MISR_MISF4_Msk (0x1UL << HSEM_C1MISR_MISF4_Pos)
16070#define HSEM_C1MISR_MISF4 HSEM_C1MISR_MISF4_Msk
16071#define HSEM_C1MISR_MISF5_Pos (5U)
16072#define HSEM_C1MISR_MISF5_Msk (0x1UL << HSEM_C1MISR_MISF5_Pos)
16073#define HSEM_C1MISR_MISF5 HSEM_C1MISR_MISF5_Msk
16074#define HSEM_C1MISR_MISF6_Pos (6U)
16075#define HSEM_C1MISR_MISF6_Msk (0x1UL << HSEM_C1MISR_MISF6_Pos)
16076#define HSEM_C1MISR_MISF6 HSEM_C1MISR_MISF6_Msk
16077#define HSEM_C1MISR_MISF7_Pos (7U)
16078#define HSEM_C1MISR_MISF7_Msk (0x1UL << HSEM_C1MISR_MISF7_Pos)
16079#define HSEM_C1MISR_MISF7 HSEM_C1MISR_MISF7_Msk
16080#define HSEM_C1MISR_MISF8_Pos (8U)
16081#define HSEM_C1MISR_MISF8_Msk (0x1UL << HSEM_C1MISR_MISF8_Pos)
16082#define HSEM_C1MISR_MISF8 HSEM_C1MISR_MISF8_Msk
16083#define HSEM_C1MISR_MISF9_Pos (9U)
16084#define HSEM_C1MISR_MISF9_Msk (0x1UL << HSEM_C1MISR_MISF9_Pos)
16085#define HSEM_C1MISR_MISF9 HSEM_C1MISR_MISF9_Msk
16086#define HSEM_C1MISR_MISF10_Pos (10U)
16087#define HSEM_C1MISR_MISF10_Msk (0x1UL << HSEM_C1MISR_MISF10_Pos)
16088#define HSEM_C1MISR_MISF10 HSEM_C1MISR_MISF10_Msk
16089#define HSEM_C1MISR_MISF11_Pos (11U)
16090#define HSEM_C1MISR_MISF11_Msk (0x1UL << HSEM_C1MISR_MISF11_Pos)
16091#define HSEM_C1MISR_MISF11 HSEM_C1MISR_MISF11_Msk
16092#define HSEM_C1MISR_MISF12_Pos (12U)
16093#define HSEM_C1MISR_MISF12_Msk (0x1UL << HSEM_C1MISR_MISF12_Pos)
16094#define HSEM_C1MISR_MISF12 HSEM_C1MISR_MISF12_Msk
16095#define HSEM_C1MISR_MISF13_Pos (13U)
16096#define HSEM_C1MISR_MISF13_Msk (0x1UL << HSEM_C1MISR_MISF13_Pos)
16097#define HSEM_C1MISR_MISF13 HSEM_C1MISR_MISF13_Msk
16098#define HSEM_C1MISR_MISF14_Pos (14U)
16099#define HSEM_C1MISR_MISF14_Msk (0x1UL << HSEM_C1MISR_MISF14_Pos)
16100#define HSEM_C1MISR_MISF14 HSEM_C1MISR_MISF14_Msk
16101#define HSEM_C1MISR_MISF15_Pos (15U)
16102#define HSEM_C1MISR_MISF15_Msk (0x1UL << HSEM_C1MISR_MISF15_Pos)
16103#define HSEM_C1MISR_MISF15 HSEM_C1MISR_MISF15_Msk
16104#define HSEM_C1MISR_MISF16_Pos (16U)
16105#define HSEM_C1MISR_MISF16_Msk (0x1UL << HSEM_C1MISR_MISF16_Pos)
16106#define HSEM_C1MISR_MISF16 HSEM_C1MISR_MISF16_Msk
16107#define HSEM_C1MISR_MISF17_Pos (17U)
16108#define HSEM_C1MISR_MISF17_Msk (0x1UL << HSEM_C1MISR_MISF17_Pos)
16109#define HSEM_C1MISR_MISF17 HSEM_C1MISR_MISF17_Msk
16110#define HSEM_C1MISR_MISF18_Pos (18U)
16111#define HSEM_C1MISR_MISF18_Msk (0x1UL << HSEM_C1MISR_MISF18_Pos)
16112#define HSEM_C1MISR_MISF18 HSEM_C1MISR_MISF18_Msk
16113#define HSEM_C1MISR_MISF19_Pos (19U)
16114#define HSEM_C1MISR_MISF19_Msk (0x1UL << HSEM_C1MISR_MISF19_Pos)
16115#define HSEM_C1MISR_MISF19 HSEM_C1MISR_MISF19_Msk
16116#define HSEM_C1MISR_MISF20_Pos (20U)
16117#define HSEM_C1MISR_MISF20_Msk (0x1UL << HSEM_C1MISR_MISF20_Pos)
16118#define HSEM_C1MISR_MISF20 HSEM_C1MISR_MISF20_Msk
16119#define HSEM_C1MISR_MISF21_Pos (21U)
16120#define HSEM_C1MISR_MISF21_Msk (0x1UL << HSEM_C1MISR_MISF21_Pos)
16121#define HSEM_C1MISR_MISF21 HSEM_C1MISR_MISF21_Msk
16122#define HSEM_C1MISR_MISF22_Pos (22U)
16123#define HSEM_C1MISR_MISF22_Msk (0x1UL << HSEM_C1MISR_MISF22_Pos)
16124#define HSEM_C1MISR_MISF22 HSEM_C1MISR_MISF22_Msk
16125#define HSEM_C1MISR_MISF23_Pos (23U)
16126#define HSEM_C1MISR_MISF23_Msk (0x1UL << HSEM_C1MISR_MISF23_Pos)
16127#define HSEM_C1MISR_MISF23 HSEM_C1MISR_MISF23_Msk
16128#define HSEM_C1MISR_MISF24_Pos (24U)
16129#define HSEM_C1MISR_MISF24_Msk (0x1UL << HSEM_C1MISR_MISF24_Pos)
16130#define HSEM_C1MISR_MISF24 HSEM_C1MISR_MISF24_Msk
16131#define HSEM_C1MISR_MISF25_Pos (25U)
16132#define HSEM_C1MISR_MISF25_Msk (0x1UL << HSEM_C1MISR_MISF25_Pos)
16133#define HSEM_C1MISR_MISF25 HSEM_C1MISR_MISF25_Msk
16134#define HSEM_C1MISR_MISF26_Pos (26U)
16135#define HSEM_C1MISR_MISF26_Msk (0x1UL << HSEM_C1MISR_MISF26_Pos)
16136#define HSEM_C1MISR_MISF26 HSEM_C1MISR_MISF26_Msk
16137#define HSEM_C1MISR_MISF27_Pos (27U)
16138#define HSEM_C1MISR_MISF27_Msk (0x1UL << HSEM_C1MISR_MISF27_Pos)
16139#define HSEM_C1MISR_MISF27 HSEM_C1MISR_MISF27_Msk
16140#define HSEM_C1MISR_MISF28_Pos (28U)
16141#define HSEM_C1MISR_MISF28_Msk (0x1UL << HSEM_C1MISR_MISF28_Pos)
16142#define HSEM_C1MISR_MISF28 HSEM_C1MISR_MISF28_Msk
16143#define HSEM_C1MISR_MISF29_Pos (29U)
16144#define HSEM_C1MISR_MISF29_Msk (0x1UL << HSEM_C1MISR_MISF29_Pos)
16145#define HSEM_C1MISR_MISF29 HSEM_C1MISR_MISF29_Msk
16146#define HSEM_C1MISR_MISF30_Pos (30U)
16147#define HSEM_C1MISR_MISF30_Msk (0x1UL << HSEM_C1MISR_MISF30_Pos)
16148#define HSEM_C1MISR_MISF30 HSEM_C1MISR_MISF30_Msk
16149#define HSEM_C1MISR_MISF31_Pos (31U)
16150#define HSEM_C1MISR_MISF31_Msk (0x1UL << HSEM_C1MISR_MISF31_Pos)
16151#define HSEM_C1MISR_MISF31 HSEM_C1MISR_MISF31_Msk
16153/******************** Bit definition for HSEM_C2IER register *****************/
16154#define HSEM_C2IER_ISE0_Pos (0U)
16155#define HSEM_C2IER_ISE0_Msk (0x1UL << HSEM_C2IER_ISE0_Pos)
16156#define HSEM_C2IER_ISE0 HSEM_C2IER_ISE0_Msk
16157#define HSEM_C2IER_ISE1_Pos (1U)
16158#define HSEM_C2IER_ISE1_Msk (0x1UL << HSEM_C2IER_ISE1_Pos)
16159#define HSEM_C2IER_ISE1 HSEM_C2IER_ISE1_Msk
16160#define HSEM_C2IER_ISE2_Pos (2U)
16161#define HSEM_C2IER_ISE2_Msk (0x1UL << HSEM_C2IER_ISE2_Pos)
16162#define HSEM_C2IER_ISE2 HSEM_C2IER_ISE2_Msk
16163#define HSEM_C2IER_ISE3_Pos (3U)
16164#define HSEM_C2IER_ISE3_Msk (0x1UL << HSEM_C2IER_ISE3_Pos)
16165#define HSEM_C2IER_ISE3 HSEM_C2IER_ISE3_Msk
16166#define HSEM_C2IER_ISE4_Pos (4U)
16167#define HSEM_C2IER_ISE4_Msk (0x1UL << HSEM_C2IER_ISE4_Pos)
16168#define HSEM_C2IER_ISE4 HSEM_C2IER_ISE4_Msk
16169#define HSEM_C2IER_ISE5_Pos (5U)
16170#define HSEM_C2IER_ISE5_Msk (0x1UL << HSEM_C2IER_ISE5_Pos)
16171#define HSEM_C2IER_ISE5 HSEM_C2IER_ISE5_Msk
16172#define HSEM_C2IER_ISE6_Pos (6U)
16173#define HSEM_C2IER_ISE6_Msk (0x1UL << HSEM_C2IER_ISE6_Pos)
16174#define HSEM_C2IER_ISE6 HSEM_C2IER_ISE6_Msk
16175#define HSEM_C2IER_ISE7_Pos (7U)
16176#define HSEM_C2IER_ISE7_Msk (0x1UL << HSEM_C2IER_ISE7_Pos)
16177#define HSEM_C2IER_ISE7 HSEM_C2IER_ISE7_Msk
16178#define HSEM_C2IER_ISE8_Pos (8U)
16179#define HSEM_C2IER_ISE8_Msk (0x1UL << HSEM_C2IER_ISE8_Pos)
16180#define HSEM_C2IER_ISE8 HSEM_C2IER_ISE8_Msk
16181#define HSEM_C2IER_ISE9_Pos (9U)
16182#define HSEM_C2IER_ISE9_Msk (0x1UL << HSEM_C2IER_ISE9_Pos)
16183#define HSEM_C2IER_ISE9 HSEM_C2IER_ISE9_Msk
16184#define HSEM_C2IER_ISE10_Pos (10U)
16185#define HSEM_C2IER_ISE10_Msk (0x1UL << HSEM_C2IER_ISE10_Pos)
16186#define HSEM_C2IER_ISE10 HSEM_C2IER_ISE10_Msk
16187#define HSEM_C2IER_ISE11_Pos (11U)
16188#define HSEM_C2IER_ISE11_Msk (0x1UL << HSEM_C2IER_ISE11_Pos)
16189#define HSEM_C2IER_ISE11 HSEM_C2IER_ISE11_Msk
16190#define HSEM_C2IER_ISE12_Pos (12U)
16191#define HSEM_C2IER_ISE12_Msk (0x1UL << HSEM_C2IER_ISE12_Pos)
16192#define HSEM_C2IER_ISE12 HSEM_C2IER_ISE12_Msk
16193#define HSEM_C2IER_ISE13_Pos (13U)
16194#define HSEM_C2IER_ISE13_Msk (0x1UL << HSEM_C2IER_ISE13_Pos)
16195#define HSEM_C2IER_ISE13 HSEM_C2IER_ISE13_Msk
16196#define HSEM_C2IER_ISE14_Pos (14U)
16197#define HSEM_C2IER_ISE14_Msk (0x1UL << HSEM_C2IER_ISE14_Pos)
16198#define HSEM_C2IER_ISE14 HSEM_C2IER_ISE14_Msk
16199#define HSEM_C2IER_ISE15_Pos (15U)
16200#define HSEM_C2IER_ISE15_Msk (0x1UL << HSEM_C2IER_ISE15_Pos)
16201#define HSEM_C2IER_ISE15 HSEM_C2IER_ISE15_Msk
16202#define HSEM_C2IER_ISE16_Pos (16U)
16203#define HSEM_C2IER_ISE16_Msk (0x1UL << HSEM_C2IER_ISE16_Pos)
16204#define HSEM_C2IER_ISE16 HSEM_C2IER_ISE16_Msk
16205#define HSEM_C2IER_ISE17_Pos (17U)
16206#define HSEM_C2IER_ISE17_Msk (0x1UL << HSEM_C2IER_ISE17_Pos)
16207#define HSEM_C2IER_ISE17 HSEM_C2IER_ISE17_Msk
16208#define HSEM_C2IER_ISE18_Pos (18U)
16209#define HSEM_C2IER_ISE18_Msk (0x1UL << HSEM_C2IER_ISE18_Pos)
16210#define HSEM_C2IER_ISE18 HSEM_C2IER_ISE18_Msk
16211#define HSEM_C2IER_ISE19_Pos (19U)
16212#define HSEM_C2IER_ISE19_Msk (0x1UL << HSEM_C2IER_ISE19_Pos)
16213#define HSEM_C2IER_ISE19 HSEM_C2IER_ISE19_Msk
16214#define HSEM_C2IER_ISE20_Pos (20U)
16215#define HSEM_C2IER_ISE20_Msk (0x1UL << HSEM_C2IER_ISE20_Pos)
16216#define HSEM_C2IER_ISE20 HSEM_C2IER_ISE20_Msk
16217#define HSEM_C2IER_ISE21_Pos (21U)
16218#define HSEM_C2IER_ISE21_Msk (0x1UL << HSEM_C2IER_ISE21_Pos)
16219#define HSEM_C2IER_ISE21 HSEM_C2IER_ISE21_Msk
16220#define HSEM_C2IER_ISE22_Pos (22U)
16221#define HSEM_C2IER_ISE22_Msk (0x1UL << HSEM_C2IER_ISE22_Pos)
16222#define HSEM_C2IER_ISE22 HSEM_C2IER_ISE22_Msk
16223#define HSEM_C2IER_ISE23_Pos (23U)
16224#define HSEM_C2IER_ISE23_Msk (0x1UL << HSEM_C2IER_ISE23_Pos)
16225#define HSEM_C2IER_ISE23 HSEM_C2IER_ISE23_Msk
16226#define HSEM_C2IER_ISE24_Pos (24U)
16227#define HSEM_C2IER_ISE24_Msk (0x1UL << HSEM_C2IER_ISE24_Pos)
16228#define HSEM_C2IER_ISE24 HSEM_C2IER_ISE24_Msk
16229#define HSEM_C2IER_ISE25_Pos (25U)
16230#define HSEM_C2IER_ISE25_Msk (0x1UL << HSEM_C2IER_ISE25_Pos)
16231#define HSEM_C2IER_ISE25 HSEM_C2IER_ISE25_Msk
16232#define HSEM_C2IER_ISE26_Pos (26U)
16233#define HSEM_C2IER_ISE26_Msk (0x1UL << HSEM_C2IER_ISE26_Pos)
16234#define HSEM_C2IER_ISE26 HSEM_C2IER_ISE26_Msk
16235#define HSEM_C2IER_ISE27_Pos (27U)
16236#define HSEM_C2IER_ISE27_Msk (0x1UL << HSEM_C2IER_ISE27_Pos)
16237#define HSEM_C2IER_ISE27 HSEM_C2IER_ISE27_Msk
16238#define HSEM_C2IER_ISE28_Pos (28U)
16239#define HSEM_C2IER_ISE28_Msk (0x1UL << HSEM_C2IER_ISE28_Pos)
16240#define HSEM_C2IER_ISE28 HSEM_C2IER_ISE28_Msk
16241#define HSEM_C2IER_ISE29_Pos (29U)
16242#define HSEM_C2IER_ISE29_Msk (0x1UL << HSEM_C2IER_ISE29_Pos)
16243#define HSEM_C2IER_ISE29 HSEM_C2IER_ISE29_Msk
16244#define HSEM_C2IER_ISE30_Pos (30U)
16245#define HSEM_C2IER_ISE30_Msk (0x1UL << HSEM_C2IER_ISE30_Pos)
16246#define HSEM_C2IER_ISE30 HSEM_C2IER_ISE30_Msk
16247#define HSEM_C2IER_ISE31_Pos (31U)
16248#define HSEM_C2IER_ISE31_Msk (0x1UL << HSEM_C2IER_ISE31_Pos)
16249#define HSEM_C2IER_ISE31 HSEM_C2IER_ISE31_Msk
16251/******************** Bit definition for HSEM_C2ICR register *****************/
16252#define HSEM_C2ICR_ISC0_Pos (0U)
16253#define HSEM_C2ICR_ISC0_Msk (0x1UL << HSEM_C2ICR_ISC0_Pos)
16254#define HSEM_C2ICR_ISC0 HSEM_C2ICR_ISC0_Msk
16255#define HSEM_C2ICR_ISC1_Pos (1U)
16256#define HSEM_C2ICR_ISC1_Msk (0x1UL << HSEM_C2ICR_ISC1_Pos)
16257#define HSEM_C2ICR_ISC1 HSEM_C2ICR_ISC1_Msk
16258#define HSEM_C2ICR_ISC2_Pos (2U)
16259#define HSEM_C2ICR_ISC2_Msk (0x1UL << HSEM_C2ICR_ISC2_Pos)
16260#define HSEM_C2ICR_ISC2 HSEM_C2ICR_ISC2_Msk
16261#define HSEM_C2ICR_ISC3_Pos (3U)
16262#define HSEM_C2ICR_ISC3_Msk (0x1UL << HSEM_C2ICR_ISC3_Pos)
16263#define HSEM_C2ICR_ISC3 HSEM_C2ICR_ISC3_Msk
16264#define HSEM_C2ICR_ISC4_Pos (4U)
16265#define HSEM_C2ICR_ISC4_Msk (0x1UL << HSEM_C2ICR_ISC4_Pos)
16266#define HSEM_C2ICR_ISC4 HSEM_C2ICR_ISC4_Msk
16267#define HSEM_C2ICR_ISC5_Pos (5U)
16268#define HSEM_C2ICR_ISC5_Msk (0x1UL << HSEM_C2ICR_ISC5_Pos)
16269#define HSEM_C2ICR_ISC5 HSEM_C2ICR_ISC5_Msk
16270#define HSEM_C2ICR_ISC6_Pos (6U)
16271#define HSEM_C2ICR_ISC6_Msk (0x1UL << HSEM_C2ICR_ISC6_Pos)
16272#define HSEM_C2ICR_ISC6 HSEM_C2ICR_ISC6_Msk
16273#define HSEM_C2ICR_ISC7_Pos (7U)
16274#define HSEM_C2ICR_ISC7_Msk (0x1UL << HSEM_C2ICR_ISC7_Pos)
16275#define HSEM_C2ICR_ISC7 HSEM_C2ICR_ISC7_Msk
16276#define HSEM_C2ICR_ISC8_Pos (8U)
16277#define HSEM_C2ICR_ISC8_Msk (0x1UL << HSEM_C2ICR_ISC8_Pos)
16278#define HSEM_C2ICR_ISC8 HSEM_C2ICR_ISC8_Msk
16279#define HSEM_C2ICR_ISC9_Pos (9U)
16280#define HSEM_C2ICR_ISC9_Msk (0x1UL << HSEM_C2ICR_ISC9_Pos)
16281#define HSEM_C2ICR_ISC9 HSEM_C2ICR_ISC9_Msk
16282#define HSEM_C2ICR_ISC10_Pos (10U)
16283#define HSEM_C2ICR_ISC10_Msk (0x1UL << HSEM_C2ICR_ISC10_Pos)
16284#define HSEM_C2ICR_ISC10 HSEM_C2ICR_ISC10_Msk
16285#define HSEM_C2ICR_ISC11_Pos (11U)
16286#define HSEM_C2ICR_ISC11_Msk (0x1UL << HSEM_C2ICR_ISC11_Pos)
16287#define HSEM_C2ICR_ISC11 HSEM_C2ICR_ISC11_Msk
16288#define HSEM_C2ICR_ISC12_Pos (12U)
16289#define HSEM_C2ICR_ISC12_Msk (0x1UL << HSEM_C2ICR_ISC12_Pos)
16290#define HSEM_C2ICR_ISC12 HSEM_C2ICR_ISC12_Msk
16291#define HSEM_C2ICR_ISC13_Pos (13U)
16292#define HSEM_C2ICR_ISC13_Msk (0x1UL << HSEM_C2ICR_ISC13_Pos)
16293#define HSEM_C2ICR_ISC13 HSEM_C2ICR_ISC13_Msk
16294#define HSEM_C2ICR_ISC14_Pos (14U)
16295#define HSEM_C2ICR_ISC14_Msk (0x1UL << HSEM_C2ICR_ISC14_Pos)
16296#define HSEM_C2ICR_ISC14 HSEM_C2ICR_ISC14_Msk
16297#define HSEM_C2ICR_ISC15_Pos (15U)
16298#define HSEM_C2ICR_ISC15_Msk (0x1UL << HSEM_C2ICR_ISC15_Pos)
16299#define HSEM_C2ICR_ISC15 HSEM_C2ICR_ISC15_Msk
16300#define HSEM_C2ICR_ISC16_Pos (16U)
16301#define HSEM_C2ICR_ISC16_Msk (0x1UL << HSEM_C2ICR_ISC16_Pos)
16302#define HSEM_C2ICR_ISC16 HSEM_C2ICR_ISC16_Msk
16303#define HSEM_C2ICR_ISC17_Pos (17U)
16304#define HSEM_C2ICR_ISC17_Msk (0x1UL << HSEM_C2ICR_ISC17_Pos)
16305#define HSEM_C2ICR_ISC17 HSEM_C2ICR_ISC17_Msk
16306#define HSEM_C2ICR_ISC18_Pos (18U)
16307#define HSEM_C2ICR_ISC18_Msk (0x1UL << HSEM_C2ICR_ISC18_Pos)
16308#define HSEM_C2ICR_ISC18 HSEM_C2ICR_ISC18_Msk
16309#define HSEM_C2ICR_ISC19_Pos (19U)
16310#define HSEM_C2ICR_ISC19_Msk (0x1UL << HSEM_C2ICR_ISC19_Pos)
16311#define HSEM_C2ICR_ISC19 HSEM_C2ICR_ISC19_Msk
16312#define HSEM_C2ICR_ISC20_Pos (20U)
16313#define HSEM_C2ICR_ISC20_Msk (0x1UL << HSEM_C2ICR_ISC20_Pos)
16314#define HSEM_C2ICR_ISC20 HSEM_C2ICR_ISC20_Msk
16315#define HSEM_C2ICR_ISC21_Pos (21U)
16316#define HSEM_C2ICR_ISC21_Msk (0x1UL << HSEM_C2ICR_ISC21_Pos)
16317#define HSEM_C2ICR_ISC21 HSEM_C2ICR_ISC21_Msk
16318#define HSEM_C2ICR_ISC22_Pos (22U)
16319#define HSEM_C2ICR_ISC22_Msk (0x1UL << HSEM_C2ICR_ISC22_Pos)
16320#define HSEM_C2ICR_ISC22 HSEM_C2ICR_ISC22_Msk
16321#define HSEM_C2ICR_ISC23_Pos (23U)
16322#define HSEM_C2ICR_ISC23_Msk (0x1UL << HSEM_C2ICR_ISC23_Pos)
16323#define HSEM_C2ICR_ISC23 HSEM_C2ICR_ISC23_Msk
16324#define HSEM_C2ICR_ISC24_Pos (24U)
16325#define HSEM_C2ICR_ISC24_Msk (0x1UL << HSEM_C2ICR_ISC24_Pos)
16326#define HSEM_C2ICR_ISC24 HSEM_C2ICR_ISC24_Msk
16327#define HSEM_C2ICR_ISC25_Pos (25U)
16328#define HSEM_C2ICR_ISC25_Msk (0x1UL << HSEM_C2ICR_ISC25_Pos)
16329#define HSEM_C2ICR_ISC25 HSEM_C2ICR_ISC25_Msk
16330#define HSEM_C2ICR_ISC26_Pos (26U)
16331#define HSEM_C2ICR_ISC26_Msk (0x1UL << HSEM_C2ICR_ISC26_Pos)
16332#define HSEM_C2ICR_ISC26 HSEM_C2ICR_ISC26_Msk
16333#define HSEM_C2ICR_ISC27_Pos (27U)
16334#define HSEM_C2ICR_ISC27_Msk (0x1UL << HSEM_C2ICR_ISC27_Pos)
16335#define HSEM_C2ICR_ISC27 HSEM_C2ICR_ISC27_Msk
16336#define HSEM_C2ICR_ISC28_Pos (28U)
16337#define HSEM_C2ICR_ISC28_Msk (0x1UL << HSEM_C2ICR_ISC28_Pos)
16338#define HSEM_C2ICR_ISC28 HSEM_C2ICR_ISC28_Msk
16339#define HSEM_C2ICR_ISC29_Pos (29U)
16340#define HSEM_C2ICR_ISC29_Msk (0x1UL << HSEM_C2ICR_ISC29_Pos)
16341#define HSEM_C2ICR_ISC29 HSEM_C2ICR_ISC29_Msk
16342#define HSEM_C2ICR_ISC30_Pos (30U)
16343#define HSEM_C2ICR_ISC30_Msk (0x1UL << HSEM_C2ICR_ISC30_Pos)
16344#define HSEM_C2ICR_ISC30 HSEM_C2ICR_ISC30_Msk
16345#define HSEM_C2ICR_ISC31_Pos (31U)
16346#define HSEM_C2ICR_ISC31_Msk (0x1UL << HSEM_C2ICR_ISC31_Pos)
16347#define HSEM_C2ICR_ISC31 HSEM_C2ICR_ISC31_Msk
16349/******************** Bit definition for HSEM_C2ISR register *****************/
16350#define HSEM_C2ISR_ISF0_Pos (0U)
16351#define HSEM_C2ISR_ISF0_Msk (0x1UL << HSEM_C2ISR_ISF0_Pos)
16352#define HSEM_C2ISR_ISF0 HSEM_C2ISR_ISF0_Msk
16353#define HSEM_C2ISR_ISF1_Pos (1U)
16354#define HSEM_C2ISR_ISF1_Msk (0x1UL << HSEM_C2ISR_ISF1_Pos)
16355#define HSEM_C2ISR_ISF1 HSEM_C2ISR_ISF1_Msk
16356#define HSEM_C2ISR_ISF2_Pos (2U)
16357#define HSEM_C2ISR_ISF2_Msk (0x1UL << HSEM_C2ISR_ISF2_Pos)
16358#define HSEM_C2ISR_ISF2 HSEM_C2ISR_ISF2_Msk
16359#define HSEM_C2ISR_ISF3_Pos (3U)
16360#define HSEM_C2ISR_ISF3_Msk (0x1UL << HSEM_C2ISR_ISF3_Pos)
16361#define HSEM_C2ISR_ISF3 HSEM_C2ISR_ISF3_Msk
16362#define HSEM_C2ISR_ISF4_Pos (4U)
16363#define HSEM_C2ISR_ISF4_Msk (0x1UL << HSEM_C2ISR_ISF4_Pos)
16364#define HSEM_C2ISR_ISF4 HSEM_C2ISR_ISF4_Msk
16365#define HSEM_C2ISR_ISF5_Pos (5U)
16366#define HSEM_C2ISR_ISF5_Msk (0x1UL << HSEM_C2ISR_ISF5_Pos)
16367#define HSEM_C2ISR_ISF5 HSEM_C2ISR_ISF5_Msk
16368#define HSEM_C2ISR_ISF6_Pos (6U)
16369#define HSEM_C2ISR_ISF6_Msk (0x1UL << HSEM_C2ISR_ISF6_Pos)
16370#define HSEM_C2ISR_ISF6 HSEM_C2ISR_ISF6_Msk
16371#define HSEM_C2ISR_ISF7_Pos (7U)
16372#define HSEM_C2ISR_ISF7_Msk (0x1UL << HSEM_C2ISR_ISF7_Pos)
16373#define HSEM_C2ISR_ISF7 HSEM_C2ISR_ISF7_Msk
16374#define HSEM_C2ISR_ISF8_Pos (8U)
16375#define HSEM_C2ISR_ISF8_Msk (0x1UL << HSEM_C2ISR_ISF8_Pos)
16376#define HSEM_C2ISR_ISF8 HSEM_C2ISR_ISF8_Msk
16377#define HSEM_C2ISR_ISF9_Pos (9U)
16378#define HSEM_C2ISR_ISF9_Msk (0x1UL << HSEM_C2ISR_ISF9_Pos)
16379#define HSEM_C2ISR_ISF9 HSEM_C2ISR_ISF9_Msk
16380#define HSEM_C2ISR_ISF10_Pos (10U)
16381#define HSEM_C2ISR_ISF10_Msk (0x1UL << HSEM_C2ISR_ISF10_Pos)
16382#define HSEM_C2ISR_ISF10 HSEM_C2ISR_ISF10_Msk
16383#define HSEM_C2ISR_ISF11_Pos (11U)
16384#define HSEM_C2ISR_ISF11_Msk (0x1UL << HSEM_C2ISR_ISF11_Pos)
16385#define HSEM_C2ISR_ISF11 HSEM_C2ISR_ISF11_Msk
16386#define HSEM_C2ISR_ISF12_Pos (12U)
16387#define HSEM_C2ISR_ISF12_Msk (0x1UL << HSEM_C2ISR_ISF12_Pos)
16388#define HSEM_C2ISR_ISF12 HSEM_C2ISR_ISF12_Msk
16389#define HSEM_C2ISR_ISF13_Pos (13U)
16390#define HSEM_C2ISR_ISF13_Msk (0x1UL << HSEM_C2ISR_ISF13_Pos)
16391#define HSEM_C2ISR_ISF13 HSEM_C2ISR_ISF13_Msk
16392#define HSEM_C2ISR_ISF14_Pos (14U)
16393#define HSEM_C2ISR_ISF14_Msk (0x1UL << HSEM_C2ISR_ISF14_Pos)
16394#define HSEM_C2ISR_ISF14 HSEM_C2ISR_ISF14_Msk
16395#define HSEM_C2ISR_ISF15_Pos (15U)
16396#define HSEM_C2ISR_ISF15_Msk (0x1UL << HSEM_C2ISR_ISF15_Pos)
16397#define HSEM_C2ISR_ISF15 HSEM_C2ISR_ISF15_Msk
16398#define HSEM_C2ISR_ISF16_Pos (16U)
16399#define HSEM_C2ISR_ISF16_Msk (0x1UL << HSEM_C2ISR_ISF16_Pos)
16400#define HSEM_C2ISR_ISF16 HSEM_C2ISR_ISF16_Msk
16401#define HSEM_C2ISR_ISF17_Pos (17U)
16402#define HSEM_C2ISR_ISF17_Msk (0x1UL << HSEM_C2ISR_ISF17_Pos)
16403#define HSEM_C2ISR_ISF17 HSEM_C2ISR_ISF17_Msk
16404#define HSEM_C2ISR_ISF18_Pos (18U)
16405#define HSEM_C2ISR_ISF18_Msk (0x1UL << HSEM_C2ISR_ISF18_Pos)
16406#define HSEM_C2ISR_ISF18 HSEM_C2ISR_ISF18_Msk
16407#define HSEM_C2ISR_ISF19_Pos (19U)
16408#define HSEM_C2ISR_ISF19_Msk (0x1UL << HSEM_C2ISR_ISF19_Pos)
16409#define HSEM_C2ISR_ISF19 HSEM_C2ISR_ISF19_Msk
16410#define HSEM_C2ISR_ISF20_Pos (20U)
16411#define HSEM_C2ISR_ISF20_Msk (0x1UL << HSEM_C2ISR_ISF20_Pos)
16412#define HSEM_C2ISR_ISF20 HSEM_C2ISR_ISF20_Msk
16413#define HSEM_C2ISR_ISF21_Pos (21U)
16414#define HSEM_C2ISR_ISF21_Msk (0x1UL << HSEM_C2ISR_ISF21_Pos)
16415#define HSEM_C2ISR_ISF21 HSEM_C2ISR_ISF21_Msk
16416#define HSEM_C2ISR_ISF22_Pos (22U)
16417#define HSEM_C2ISR_ISF22_Msk (0x1UL << HSEM_C2ISR_ISF22_Pos)
16418#define HSEM_C2ISR_ISF22 HSEM_C2ISR_ISF22_Msk
16419#define HSEM_C2ISR_ISF23_Pos (23U)
16420#define HSEM_C2ISR_ISF23_Msk (0x1UL << HSEM_C2ISR_ISF23_Pos)
16421#define HSEM_C2ISR_ISF23 HSEM_C2ISR_ISF23_Msk
16422#define HSEM_C2ISR_ISF24_Pos (24U)
16423#define HSEM_C2ISR_ISF24_Msk (0x1UL << HSEM_C2ISR_ISF24_Pos)
16424#define HSEM_C2ISR_ISF24 HSEM_C2ISR_ISF24_Msk
16425#define HSEM_C2ISR_ISF25_Pos (25U)
16426#define HSEM_C2ISR_ISF25_Msk (0x1UL << HSEM_C2ISR_ISF25_Pos)
16427#define HSEM_C2ISR_ISF25 HSEM_C2ISR_ISF25_Msk
16428#define HSEM_C2ISR_ISF26_Pos (26U)
16429#define HSEM_C2ISR_ISF26_Msk (0x1UL << HSEM_C2ISR_ISF26_Pos)
16430#define HSEM_C2ISR_ISF26 HSEM_C2ISR_ISF26_Msk
16431#define HSEM_C2ISR_ISF27_Pos (27U)
16432#define HSEM_C2ISR_ISF27_Msk (0x1UL << HSEM_C2ISR_ISF27_Pos)
16433#define HSEM_C2ISR_ISF27 HSEM_C2ISR_ISF27_Msk
16434#define HSEM_C2ISR_ISF28_Pos (28U)
16435#define HSEM_C2ISR_ISF28_Msk (0x1UL << HSEM_C2ISR_ISF28_Pos)
16436#define HSEM_C2ISR_ISF28 HSEM_C2ISR_ISF28_Msk
16437#define HSEM_C2ISR_ISF29_Pos (29U)
16438#define HSEM_C2ISR_ISF29_Msk (0x1UL << HSEM_C2ISR_ISF29_Pos)
16439#define HSEM_C2ISR_ISF29 HSEM_C2ISR_ISF29_Msk
16440#define HSEM_C2ISR_ISF30_Pos (30U)
16441#define HSEM_C2ISR_ISF30_Msk (0x1UL << HSEM_C2ISR_ISF30_Pos)
16442#define HSEM_C2ISR_ISF30 HSEM_C2ISR_ISF30_Msk
16443#define HSEM_C2ISR_ISF31_Pos (31U)
16444#define HSEM_C2ISR_ISF31_Msk (0x1UL << HSEM_C2ISR_ISF31_Pos)
16445#define HSEM_C2ISR_ISF31 HSEM_C2ISR_ISF31_Msk
16447/******************** Bit definition for HSEM_C2MISR register *****************/
16448#define HSEM_C2MISR_MISF0_Pos (0U)
16449#define HSEM_C2MISR_MISF0_Msk (0x1UL << HSEM_C2MISR_MISF0_Pos)
16450#define HSEM_C2MISR_MISF0 HSEM_C2MISR_MISF0_Msk
16451#define HSEM_C2MISR_MISF1_Pos (1U)
16452#define HSEM_C2MISR_MISF1_Msk (0x1UL << HSEM_C2MISR_MISF1_Pos)
16453#define HSEM_C2MISR_MISF1 HSEM_C2MISR_MISF1_Msk
16454#define HSEM_C2MISR_MISF2_Pos (2U)
16455#define HSEM_C2MISR_MISF2_Msk (0x1UL << HSEM_C2MISR_MISF2_Pos)
16456#define HSEM_C2MISR_MISF2 HSEM_C2MISR_MISF2_Msk
16457#define HSEM_C2MISR_MISF3_Pos (3U)
16458#define HSEM_C2MISR_MISF3_Msk (0x1UL << HSEM_C2MISR_MISF3_Pos)
16459#define HSEM_C2MISR_MISF3 HSEM_C2MISR_MISF3_Msk
16460#define HSEM_C2MISR_MISF4_Pos (4U)
16461#define HSEM_C2MISR_MISF4_Msk (0x1UL << HSEM_C2MISR_MISF4_Pos)
16462#define HSEM_C2MISR_MISF4 HSEM_C2MISR_MISF4_Msk
16463#define HSEM_C2MISR_MISF5_Pos (5U)
16464#define HSEM_C2MISR_MISF5_Msk (0x1UL << HSEM_C2MISR_MISF5_Pos)
16465#define HSEM_C2MISR_MISF5 HSEM_C2MISR_MISF5_Msk
16466#define HSEM_C2MISR_MISF6_Pos (6U)
16467#define HSEM_C2MISR_MISF6_Msk (0x1UL << HSEM_C2MISR_MISF6_Pos)
16468#define HSEM_C2MISR_MISF6 HSEM_C2MISR_MISF6_Msk
16469#define HSEM_C2MISR_MISF7_Pos (7U)
16470#define HSEM_C2MISR_MISF7_Msk (0x1UL << HSEM_C2MISR_MISF7_Pos)
16471#define HSEM_C2MISR_MISF7 HSEM_C2MISR_MISF7_Msk
16472#define HSEM_C2MISR_MISF8_Pos (8U)
16473#define HSEM_C2MISR_MISF8_Msk (0x1UL << HSEM_C2MISR_MISF8_Pos)
16474#define HSEM_C2MISR_MISF8 HSEM_C2MISR_MISF8_Msk
16475#define HSEM_C2MISR_MISF9_Pos (9U)
16476#define HSEM_C2MISR_MISF9_Msk (0x1UL << HSEM_C2MISR_MISF9_Pos)
16477#define HSEM_C2MISR_MISF9 HSEM_C2MISR_MISF9_Msk
16478#define HSEM_C2MISR_MISF10_Pos (10U)
16479#define HSEM_C2MISR_MISF10_Msk (0x1UL << HSEM_C2MISR_MISF10_Pos)
16480#define HSEM_C2MISR_MISF10 HSEM_C2MISR_MISF10_Msk
16481#define HSEM_C2MISR_MISF11_Pos (11U)
16482#define HSEM_C2MISR_MISF11_Msk (0x1UL << HSEM_C2MISR_MISF11_Pos)
16483#define HSEM_C2MISR_MISF11 HSEM_C2MISR_MISF11_Msk
16484#define HSEM_C2MISR_MISF12_Pos (12U)
16485#define HSEM_C2MISR_MISF12_Msk (0x1UL << HSEM_C2MISR_MISF12_Pos)
16486#define HSEM_C2MISR_MISF12 HSEM_C2MISR_MISF12_Msk
16487#define HSEM_C2MISR_MISF13_Pos (13U)
16488#define HSEM_C2MISR_MISF13_Msk (0x1UL << HSEM_C2MISR_MISF13_Pos)
16489#define HSEM_C2MISR_MISF13 HSEM_C2MISR_MISF13_Msk
16490#define HSEM_C2MISR_MISF14_Pos (14U)
16491#define HSEM_C2MISR_MISF14_Msk (0x1UL << HSEM_C2MISR_MISF14_Pos)
16492#define HSEM_C2MISR_MISF14 HSEM_C2MISR_MISF14_Msk
16493#define HSEM_C2MISR_MISF15_Pos (15U)
16494#define HSEM_C2MISR_MISF15_Msk (0x1UL << HSEM_C2MISR_MISF15_Pos)
16495#define HSEM_C2MISR_MISF15 HSEM_C2MISR_MISF15_Msk
16496#define HSEM_C2MISR_MISF16_Pos (16U)
16497#define HSEM_C2MISR_MISF16_Msk (0x1UL << HSEM_C2MISR_MISF16_Pos)
16498#define HSEM_C2MISR_MISF16 HSEM_C2MISR_MISF16_Msk
16499#define HSEM_C2MISR_MISF17_Pos (17U)
16500#define HSEM_C2MISR_MISF17_Msk (0x1UL << HSEM_C2MISR_MISF17_Pos)
16501#define HSEM_C2MISR_MISF17 HSEM_C2MISR_MISF17_Msk
16502#define HSEM_C2MISR_MISF18_Pos (18U)
16503#define HSEM_C2MISR_MISF18_Msk (0x1UL << HSEM_C2MISR_MISF18_Pos)
16504#define HSEM_C2MISR_MISF18 HSEM_C2MISR_MISF18_Msk
16505#define HSEM_C2MISR_MISF19_Pos (19U)
16506#define HSEM_C2MISR_MISF19_Msk (0x1UL << HSEM_C2MISR_MISF19_Pos)
16507#define HSEM_C2MISR_MISF19 HSEM_C2MISR_MISF19_Msk
16508#define HSEM_C2MISR_MISF20_Pos (20U)
16509#define HSEM_C2MISR_MISF20_Msk (0x1UL << HSEM_C2MISR_MISF20_Pos)
16510#define HSEM_C2MISR_MISF20 HSEM_C2MISR_MISF20_Msk
16511#define HSEM_C2MISR_MISF21_Pos (21U)
16512#define HSEM_C2MISR_MISF21_Msk (0x1UL << HSEM_C2MISR_MISF21_Pos)
16513#define HSEM_C2MISR_MISF21 HSEM_C2MISR_MISF21_Msk
16514#define HSEM_C2MISR_MISF22_Pos (22U)
16515#define HSEM_C2MISR_MISF22_Msk (0x1UL << HSEM_C2MISR_MISF22_Pos)
16516#define HSEM_C2MISR_MISF22 HSEM_C2MISR_MISF22_Msk
16517#define HSEM_C2MISR_MISF23_Pos (23U)
16518#define HSEM_C2MISR_MISF23_Msk (0x1UL << HSEM_C2MISR_MISF23_Pos)
16519#define HSEM_C2MISR_MISF23 HSEM_C2MISR_MISF23_Msk
16520#define HSEM_C2MISR_MISF24_Pos (24U)
16521#define HSEM_C2MISR_MISF24_Msk (0x1UL << HSEM_C2MISR_MISF24_Pos)
16522#define HSEM_C2MISR_MISF24 HSEM_C2MISR_MISF24_Msk
16523#define HSEM_C2MISR_MISF25_Pos (25U)
16524#define HSEM_C2MISR_MISF25_Msk (0x1UL << HSEM_C2MISR_MISF25_Pos)
16525#define HSEM_C2MISR_MISF25 HSEM_C2MISR_MISF25_Msk
16526#define HSEM_C2MISR_MISF26_Pos (26U)
16527#define HSEM_C2MISR_MISF26_Msk (0x1UL << HSEM_C2MISR_MISF26_Pos)
16528#define HSEM_C2MISR_MISF26 HSEM_C2MISR_MISF26_Msk
16529#define HSEM_C2MISR_MISF27_Pos (27U)
16530#define HSEM_C2MISR_MISF27_Msk (0x1UL << HSEM_C2MISR_MISF27_Pos)
16531#define HSEM_C2MISR_MISF27 HSEM_C2MISR_MISF27_Msk
16532#define HSEM_C2MISR_MISF28_Pos (28U)
16533#define HSEM_C2MISR_MISF28_Msk (0x1UL << HSEM_C2MISR_MISF28_Pos)
16534#define HSEM_C2MISR_MISF28 HSEM_C2MISR_MISF28_Msk
16535#define HSEM_C2MISR_MISF29_Pos (29U)
16536#define HSEM_C2MISR_MISF29_Msk (0x1UL << HSEM_C2MISR_MISF29_Pos)
16537#define HSEM_C2MISR_MISF29 HSEM_C2MISR_MISF29_Msk
16538#define HSEM_C2MISR_MISF30_Pos (30U)
16539#define HSEM_C2MISR_MISF30_Msk (0x1UL << HSEM_C2MISR_MISF30_Pos)
16540#define HSEM_C2MISR_MISF30 HSEM_C2MISR_MISF30_Msk
16541#define HSEM_C2MISR_MISF31_Pos (31U)
16542#define HSEM_C2MISR_MISF31_Msk (0x1UL << HSEM_C2MISR_MISF31_Pos)
16543#define HSEM_C2MISR_MISF31 HSEM_C2MISR_MISF31_Msk
16544/******************** Bit definition for HSEM_CR register *****************/
16545#define HSEM_CR_COREID_Pos (8U)
16546#define HSEM_CR_COREID_Msk (0xFFUL << HSEM_CR_COREID_Pos)
16547#define HSEM_CR_COREID HSEM_CR_COREID_Msk
16548#define HSEM_CR_KEY_Pos (16U)
16549#define HSEM_CR_KEY_Msk (0xFFFFUL << HSEM_CR_KEY_Pos)
16550#define HSEM_CR_KEY HSEM_CR_KEY_Msk
16552/******************** Bit definition for HSEM_KEYR register *****************/
16553#define HSEM_KEYR_KEY_Pos (16U)
16554#define HSEM_KEYR_KEY_Msk (0xFFFFUL << HSEM_KEYR_KEY_Pos)
16555#define HSEM_KEYR_KEY HSEM_KEYR_KEY_Msk
16557/******************************************************************************/
16558/* */
16559/* HASH */
16560/* */
16561/******************************************************************************/
16562/****************** Bits definition for HASH_CR register ********************/
16563#define HASH_CR_INIT_Pos (2U)
16564#define HASH_CR_INIT_Msk (0x1UL << HASH_CR_INIT_Pos)
16565#define HASH_CR_INIT HASH_CR_INIT_Msk
16566#define HASH_CR_DMAE_Pos (3U)
16567#define HASH_CR_DMAE_Msk (0x1UL << HASH_CR_DMAE_Pos)
16568#define HASH_CR_DMAE HASH_CR_DMAE_Msk
16569#define HASH_CR_DATATYPE_Pos (4U)
16570#define HASH_CR_DATATYPE_Msk (0x3UL << HASH_CR_DATATYPE_Pos)
16571#define HASH_CR_DATATYPE HASH_CR_DATATYPE_Msk
16572#define HASH_CR_DATATYPE_0 (0x1UL << HASH_CR_DATATYPE_Pos)
16573#define HASH_CR_DATATYPE_1 (0x2UL << HASH_CR_DATATYPE_Pos)
16574#define HASH_CR_MODE_Pos (6U)
16575#define HASH_CR_MODE_Msk (0x1UL << HASH_CR_MODE_Pos)
16576#define HASH_CR_MODE HASH_CR_MODE_Msk
16577#define HASH_CR_ALGO_Pos (7U)
16578#define HASH_CR_ALGO_Msk (0x801UL << HASH_CR_ALGO_Pos)
16579#define HASH_CR_ALGO HASH_CR_ALGO_Msk
16580#define HASH_CR_ALGO_0 (0x001UL << HASH_CR_ALGO_Pos)
16581#define HASH_CR_ALGO_1 (0x800UL << HASH_CR_ALGO_Pos)
16582#define HASH_CR_NBW_Pos (8U)
16583#define HASH_CR_NBW_Msk (0xFUL << HASH_CR_NBW_Pos)
16584#define HASH_CR_NBW HASH_CR_NBW_Msk
16585#define HASH_CR_NBW_0 (0x1UL << HASH_CR_NBW_Pos)
16586#define HASH_CR_NBW_1 (0x2UL << HASH_CR_NBW_Pos)
16587#define HASH_CR_NBW_2 (0x4UL << HASH_CR_NBW_Pos)
16588#define HASH_CR_NBW_3 (0x8UL << HASH_CR_NBW_Pos)
16589#define HASH_CR_DINNE_Pos (12U)
16590#define HASH_CR_DINNE_Msk (0x1UL << HASH_CR_DINNE_Pos)
16591#define HASH_CR_DINNE HASH_CR_DINNE_Msk
16592#define HASH_CR_MDMAT_Pos (13U)
16593#define HASH_CR_MDMAT_Msk (0x1UL << HASH_CR_MDMAT_Pos)
16594#define HASH_CR_MDMAT HASH_CR_MDMAT_Msk
16595#define HASH_CR_LKEY_Pos (16U)
16596#define HASH_CR_LKEY_Msk (0x1UL << HASH_CR_LKEY_Pos)
16597#define HASH_CR_LKEY HASH_CR_LKEY_Msk
16598
16599/****************** Bits definition for HASH_STR register *******************/
16600#define HASH_STR_NBLW_Pos (0U)
16601#define HASH_STR_NBLW_Msk (0x1FUL << HASH_STR_NBLW_Pos)
16602#define HASH_STR_NBLW HASH_STR_NBLW_Msk
16603#define HASH_STR_NBLW_0 (0x01UL << HASH_STR_NBLW_Pos)
16604#define HASH_STR_NBLW_1 (0x02UL << HASH_STR_NBLW_Pos)
16605#define HASH_STR_NBLW_2 (0x04UL << HASH_STR_NBLW_Pos)
16606#define HASH_STR_NBLW_3 (0x08UL << HASH_STR_NBLW_Pos)
16607#define HASH_STR_NBLW_4 (0x10UL << HASH_STR_NBLW_Pos)
16608#define HASH_STR_DCAL_Pos (8U)
16609#define HASH_STR_DCAL_Msk (0x1UL << HASH_STR_DCAL_Pos)
16610#define HASH_STR_DCAL HASH_STR_DCAL_Msk
16611
16612/****************** Bits definition for HASH_IMR register *******************/
16613#define HASH_IMR_DINIE_Pos (0U)
16614#define HASH_IMR_DINIE_Msk (0x1UL << HASH_IMR_DINIE_Pos)
16615#define HASH_IMR_DINIE HASH_IMR_DINIE_Msk
16616#define HASH_IMR_DCIE_Pos (1U)
16617#define HASH_IMR_DCIE_Msk (0x1UL << HASH_IMR_DCIE_Pos)
16618#define HASH_IMR_DCIE HASH_IMR_DCIE_Msk
16619
16620/****************** Bits definition for HASH_SR register ********************/
16621#define HASH_SR_DINIS_Pos (0U)
16622#define HASH_SR_DINIS_Msk (0x1UL << HASH_SR_DINIS_Pos)
16623#define HASH_SR_DINIS HASH_SR_DINIS_Msk
16624#define HASH_SR_DCIS_Pos (1U)
16625#define HASH_SR_DCIS_Msk (0x1UL << HASH_SR_DCIS_Pos)
16626#define HASH_SR_DCIS HASH_SR_DCIS_Msk
16627#define HASH_SR_DMAS_Pos (2U)
16628#define HASH_SR_DMAS_Msk (0x1UL << HASH_SR_DMAS_Pos)
16629#define HASH_SR_DMAS HASH_SR_DMAS_Msk
16630#define HASH_SR_BUSY_Pos (3U)
16631#define HASH_SR_BUSY_Msk (0x1UL << HASH_SR_BUSY_Pos)
16632#define HASH_SR_BUSY HASH_SR_BUSY_Msk
16633/******************************************************************************/
16634/* */
16635/* Inter-integrated Circuit Interface (I2C) */
16636/* */
16637/******************************************************************************/
16638/******************* Bit definition for I2C_CR1 register *******************/
16639#define I2C_CR1_PE_Pos (0U)
16640#define I2C_CR1_PE_Msk (0x1UL << I2C_CR1_PE_Pos)
16641#define I2C_CR1_PE I2C_CR1_PE_Msk
16642#define I2C_CR1_TXIE_Pos (1U)
16643#define I2C_CR1_TXIE_Msk (0x1UL << I2C_CR1_TXIE_Pos)
16644#define I2C_CR1_TXIE I2C_CR1_TXIE_Msk
16645#define I2C_CR1_RXIE_Pos (2U)
16646#define I2C_CR1_RXIE_Msk (0x1UL << I2C_CR1_RXIE_Pos)
16647#define I2C_CR1_RXIE I2C_CR1_RXIE_Msk
16648#define I2C_CR1_ADDRIE_Pos (3U)
16649#define I2C_CR1_ADDRIE_Msk (0x1UL << I2C_CR1_ADDRIE_Pos)
16650#define I2C_CR1_ADDRIE I2C_CR1_ADDRIE_Msk
16651#define I2C_CR1_NACKIE_Pos (4U)
16652#define I2C_CR1_NACKIE_Msk (0x1UL << I2C_CR1_NACKIE_Pos)
16653#define I2C_CR1_NACKIE I2C_CR1_NACKIE_Msk
16654#define I2C_CR1_STOPIE_Pos (5U)
16655#define I2C_CR1_STOPIE_Msk (0x1UL << I2C_CR1_STOPIE_Pos)
16656#define I2C_CR1_STOPIE I2C_CR1_STOPIE_Msk
16657#define I2C_CR1_TCIE_Pos (6U)
16658#define I2C_CR1_TCIE_Msk (0x1UL << I2C_CR1_TCIE_Pos)
16659#define I2C_CR1_TCIE I2C_CR1_TCIE_Msk
16660#define I2C_CR1_ERRIE_Pos (7U)
16661#define I2C_CR1_ERRIE_Msk (0x1UL << I2C_CR1_ERRIE_Pos)
16662#define I2C_CR1_ERRIE I2C_CR1_ERRIE_Msk
16663#define I2C_CR1_DNF_Pos (8U)
16664#define I2C_CR1_DNF_Msk (0xFUL << I2C_CR1_DNF_Pos)
16665#define I2C_CR1_DNF I2C_CR1_DNF_Msk
16666#define I2C_CR1_ANFOFF_Pos (12U)
16667#define I2C_CR1_ANFOFF_Msk (0x1UL << I2C_CR1_ANFOFF_Pos)
16668#define I2C_CR1_ANFOFF I2C_CR1_ANFOFF_Msk
16669#define I2C_CR1_TXDMAEN_Pos (14U)
16670#define I2C_CR1_TXDMAEN_Msk (0x1UL << I2C_CR1_TXDMAEN_Pos)
16671#define I2C_CR1_TXDMAEN I2C_CR1_TXDMAEN_Msk
16672#define I2C_CR1_RXDMAEN_Pos (15U)
16673#define I2C_CR1_RXDMAEN_Msk (0x1UL << I2C_CR1_RXDMAEN_Pos)
16674#define I2C_CR1_RXDMAEN I2C_CR1_RXDMAEN_Msk
16675#define I2C_CR1_SBC_Pos (16U)
16676#define I2C_CR1_SBC_Msk (0x1UL << I2C_CR1_SBC_Pos)
16677#define I2C_CR1_SBC I2C_CR1_SBC_Msk
16678#define I2C_CR1_NOSTRETCH_Pos (17U)
16679#define I2C_CR1_NOSTRETCH_Msk (0x1UL << I2C_CR1_NOSTRETCH_Pos)
16680#define I2C_CR1_NOSTRETCH I2C_CR1_NOSTRETCH_Msk
16681#define I2C_CR1_WUPEN_Pos (18U)
16682#define I2C_CR1_WUPEN_Msk (0x1UL << I2C_CR1_WUPEN_Pos)
16683#define I2C_CR1_WUPEN I2C_CR1_WUPEN_Msk
16684#define I2C_CR1_GCEN_Pos (19U)
16685#define I2C_CR1_GCEN_Msk (0x1UL << I2C_CR1_GCEN_Pos)
16686#define I2C_CR1_GCEN I2C_CR1_GCEN_Msk
16687#define I2C_CR1_SMBHEN_Pos (20U)
16688#define I2C_CR1_SMBHEN_Msk (0x1UL << I2C_CR1_SMBHEN_Pos)
16689#define I2C_CR1_SMBHEN I2C_CR1_SMBHEN_Msk
16690#define I2C_CR1_SMBDEN_Pos (21U)
16691#define I2C_CR1_SMBDEN_Msk (0x1UL << I2C_CR1_SMBDEN_Pos)
16692#define I2C_CR1_SMBDEN I2C_CR1_SMBDEN_Msk
16693#define I2C_CR1_ALERTEN_Pos (22U)
16694#define I2C_CR1_ALERTEN_Msk (0x1UL << I2C_CR1_ALERTEN_Pos)
16695#define I2C_CR1_ALERTEN I2C_CR1_ALERTEN_Msk
16696#define I2C_CR1_PECEN_Pos (23U)
16697#define I2C_CR1_PECEN_Msk (0x1UL << I2C_CR1_PECEN_Pos)
16698#define I2C_CR1_PECEN I2C_CR1_PECEN_Msk
16700/****************** Bit definition for I2C_CR2 register ********************/
16701#define I2C_CR2_SADD_Pos (0U)
16702#define I2C_CR2_SADD_Msk (0x3FFUL << I2C_CR2_SADD_Pos)
16703#define I2C_CR2_SADD I2C_CR2_SADD_Msk
16704#define I2C_CR2_RD_WRN_Pos (10U)
16705#define I2C_CR2_RD_WRN_Msk (0x1UL << I2C_CR2_RD_WRN_Pos)
16706#define I2C_CR2_RD_WRN I2C_CR2_RD_WRN_Msk
16707#define I2C_CR2_ADD10_Pos (11U)
16708#define I2C_CR2_ADD10_Msk (0x1UL << I2C_CR2_ADD10_Pos)
16709#define I2C_CR2_ADD10 I2C_CR2_ADD10_Msk
16710#define I2C_CR2_HEAD10R_Pos (12U)
16711#define I2C_CR2_HEAD10R_Msk (0x1UL << I2C_CR2_HEAD10R_Pos)
16712#define I2C_CR2_HEAD10R I2C_CR2_HEAD10R_Msk
16713#define I2C_CR2_START_Pos (13U)
16714#define I2C_CR2_START_Msk (0x1UL << I2C_CR2_START_Pos)
16715#define I2C_CR2_START I2C_CR2_START_Msk
16716#define I2C_CR2_STOP_Pos (14U)
16717#define I2C_CR2_STOP_Msk (0x1UL << I2C_CR2_STOP_Pos)
16718#define I2C_CR2_STOP I2C_CR2_STOP_Msk
16719#define I2C_CR2_NACK_Pos (15U)
16720#define I2C_CR2_NACK_Msk (0x1UL << I2C_CR2_NACK_Pos)
16721#define I2C_CR2_NACK I2C_CR2_NACK_Msk
16722#define I2C_CR2_NBYTES_Pos (16U)
16723#define I2C_CR2_NBYTES_Msk (0xFFUL << I2C_CR2_NBYTES_Pos)
16724#define I2C_CR2_NBYTES I2C_CR2_NBYTES_Msk
16725#define I2C_CR2_RELOAD_Pos (24U)
16726#define I2C_CR2_RELOAD_Msk (0x1UL << I2C_CR2_RELOAD_Pos)
16727#define I2C_CR2_RELOAD I2C_CR2_RELOAD_Msk
16728#define I2C_CR2_AUTOEND_Pos (25U)
16729#define I2C_CR2_AUTOEND_Msk (0x1UL << I2C_CR2_AUTOEND_Pos)
16730#define I2C_CR2_AUTOEND I2C_CR2_AUTOEND_Msk
16731#define I2C_CR2_PECBYTE_Pos (26U)
16732#define I2C_CR2_PECBYTE_Msk (0x1UL << I2C_CR2_PECBYTE_Pos)
16733#define I2C_CR2_PECBYTE I2C_CR2_PECBYTE_Msk
16735/******************* Bit definition for I2C_OAR1 register ******************/
16736#define I2C_OAR1_OA1_Pos (0U)
16737#define I2C_OAR1_OA1_Msk (0x3FFUL << I2C_OAR1_OA1_Pos)
16738#define I2C_OAR1_OA1 I2C_OAR1_OA1_Msk
16739#define I2C_OAR1_OA1MODE_Pos (10U)
16740#define I2C_OAR1_OA1MODE_Msk (0x1UL << I2C_OAR1_OA1MODE_Pos)
16741#define I2C_OAR1_OA1MODE I2C_OAR1_OA1MODE_Msk
16742#define I2C_OAR1_OA1EN_Pos (15U)
16743#define I2C_OAR1_OA1EN_Msk (0x1UL << I2C_OAR1_OA1EN_Pos)
16744#define I2C_OAR1_OA1EN I2C_OAR1_OA1EN_Msk
16746/******************* Bit definition for I2C_OAR2 register ******************/
16747#define I2C_OAR2_OA2_Pos (1U)
16748#define I2C_OAR2_OA2_Msk (0x7FUL << I2C_OAR2_OA2_Pos)
16749#define I2C_OAR2_OA2 I2C_OAR2_OA2_Msk
16750#define I2C_OAR2_OA2MSK_Pos (8U)
16751#define I2C_OAR2_OA2MSK_Msk (0x7UL << I2C_OAR2_OA2MSK_Pos)
16752#define I2C_OAR2_OA2MSK I2C_OAR2_OA2MSK_Msk
16753#define I2C_OAR2_OA2NOMASK 0x00000000UL
16754#define I2C_OAR2_OA2MASK01_Pos (8U)
16755#define I2C_OAR2_OA2MASK01_Msk (0x1UL << I2C_OAR2_OA2MASK01_Pos)
16756#define I2C_OAR2_OA2MASK01 I2C_OAR2_OA2MASK01_Msk
16757#define I2C_OAR2_OA2MASK02_Pos (9U)
16758#define I2C_OAR2_OA2MASK02_Msk (0x1UL << I2C_OAR2_OA2MASK02_Pos)
16759#define I2C_OAR2_OA2MASK02 I2C_OAR2_OA2MASK02_Msk
16760#define I2C_OAR2_OA2MASK03_Pos (8U)
16761#define I2C_OAR2_OA2MASK03_Msk (0x3UL << I2C_OAR2_OA2MASK03_Pos)
16762#define I2C_OAR2_OA2MASK03 I2C_OAR2_OA2MASK03_Msk
16763#define I2C_OAR2_OA2MASK04_Pos (10U)
16764#define I2C_OAR2_OA2MASK04_Msk (0x1UL << I2C_OAR2_OA2MASK04_Pos)
16765#define I2C_OAR2_OA2MASK04 I2C_OAR2_OA2MASK04_Msk
16766#define I2C_OAR2_OA2MASK05_Pos (8U)
16767#define I2C_OAR2_OA2MASK05_Msk (0x5UL << I2C_OAR2_OA2MASK05_Pos)
16768#define I2C_OAR2_OA2MASK05 I2C_OAR2_OA2MASK05_Msk
16769#define I2C_OAR2_OA2MASK06_Pos (9U)
16770#define I2C_OAR2_OA2MASK06_Msk (0x3UL << I2C_OAR2_OA2MASK06_Pos)
16771#define I2C_OAR2_OA2MASK06 I2C_OAR2_OA2MASK06_Msk
16772#define I2C_OAR2_OA2MASK07_Pos (8U)
16773#define I2C_OAR2_OA2MASK07_Msk (0x7UL << I2C_OAR2_OA2MASK07_Pos)
16774#define I2C_OAR2_OA2MASK07 I2C_OAR2_OA2MASK07_Msk
16775#define I2C_OAR2_OA2EN_Pos (15U)
16776#define I2C_OAR2_OA2EN_Msk (0x1UL << I2C_OAR2_OA2EN_Pos)
16777#define I2C_OAR2_OA2EN I2C_OAR2_OA2EN_Msk
16779/******************* Bit definition for I2C_TIMINGR register *******************/
16780#define I2C_TIMINGR_SCLL_Pos (0U)
16781#define I2C_TIMINGR_SCLL_Msk (0xFFUL << I2C_TIMINGR_SCLL_Pos)
16782#define I2C_TIMINGR_SCLL I2C_TIMINGR_SCLL_Msk
16783#define I2C_TIMINGR_SCLH_Pos (8U)
16784#define I2C_TIMINGR_SCLH_Msk (0xFFUL << I2C_TIMINGR_SCLH_Pos)
16785#define I2C_TIMINGR_SCLH I2C_TIMINGR_SCLH_Msk
16786#define I2C_TIMINGR_SDADEL_Pos (16U)
16787#define I2C_TIMINGR_SDADEL_Msk (0xFUL << I2C_TIMINGR_SDADEL_Pos)
16788#define I2C_TIMINGR_SDADEL I2C_TIMINGR_SDADEL_Msk
16789#define I2C_TIMINGR_SCLDEL_Pos (20U)
16790#define I2C_TIMINGR_SCLDEL_Msk (0xFUL << I2C_TIMINGR_SCLDEL_Pos)
16791#define I2C_TIMINGR_SCLDEL I2C_TIMINGR_SCLDEL_Msk
16792#define I2C_TIMINGR_PRESC_Pos (28U)
16793#define I2C_TIMINGR_PRESC_Msk (0xFUL << I2C_TIMINGR_PRESC_Pos)
16794#define I2C_TIMINGR_PRESC I2C_TIMINGR_PRESC_Msk
16796/******************* Bit definition for I2C_TIMEOUTR register *******************/
16797#define I2C_TIMEOUTR_TIMEOUTA_Pos (0U)
16798#define I2C_TIMEOUTR_TIMEOUTA_Msk (0xFFFUL << I2C_TIMEOUTR_TIMEOUTA_Pos)
16799#define I2C_TIMEOUTR_TIMEOUTA I2C_TIMEOUTR_TIMEOUTA_Msk
16800#define I2C_TIMEOUTR_TIDLE_Pos (12U)
16801#define I2C_TIMEOUTR_TIDLE_Msk (0x1UL << I2C_TIMEOUTR_TIDLE_Pos)
16802#define I2C_TIMEOUTR_TIDLE I2C_TIMEOUTR_TIDLE_Msk
16803#define I2C_TIMEOUTR_TIMOUTEN_Pos (15U)
16804#define I2C_TIMEOUTR_TIMOUTEN_Msk (0x1UL << I2C_TIMEOUTR_TIMOUTEN_Pos)
16805#define I2C_TIMEOUTR_TIMOUTEN I2C_TIMEOUTR_TIMOUTEN_Msk
16806#define I2C_TIMEOUTR_TIMEOUTB_Pos (16U)
16807#define I2C_TIMEOUTR_TIMEOUTB_Msk (0xFFFUL << I2C_TIMEOUTR_TIMEOUTB_Pos)
16808#define I2C_TIMEOUTR_TIMEOUTB I2C_TIMEOUTR_TIMEOUTB_Msk
16809#define I2C_TIMEOUTR_TEXTEN_Pos (31U)
16810#define I2C_TIMEOUTR_TEXTEN_Msk (0x1UL << I2C_TIMEOUTR_TEXTEN_Pos)
16811#define I2C_TIMEOUTR_TEXTEN I2C_TIMEOUTR_TEXTEN_Msk
16813/****************** Bit definition for I2C_ISR register *********************/
16814#define I2C_ISR_TXE_Pos (0U)
16815#define I2C_ISR_TXE_Msk (0x1UL << I2C_ISR_TXE_Pos)
16816#define I2C_ISR_TXE I2C_ISR_TXE_Msk
16817#define I2C_ISR_TXIS_Pos (1U)
16818#define I2C_ISR_TXIS_Msk (0x1UL << I2C_ISR_TXIS_Pos)
16819#define I2C_ISR_TXIS I2C_ISR_TXIS_Msk
16820#define I2C_ISR_RXNE_Pos (2U)
16821#define I2C_ISR_RXNE_Msk (0x1UL << I2C_ISR_RXNE_Pos)
16822#define I2C_ISR_RXNE I2C_ISR_RXNE_Msk
16823#define I2C_ISR_ADDR_Pos (3U)
16824#define I2C_ISR_ADDR_Msk (0x1UL << I2C_ISR_ADDR_Pos)
16825#define I2C_ISR_ADDR I2C_ISR_ADDR_Msk
16826#define I2C_ISR_NACKF_Pos (4U)
16827#define I2C_ISR_NACKF_Msk (0x1UL << I2C_ISR_NACKF_Pos)
16828#define I2C_ISR_NACKF I2C_ISR_NACKF_Msk
16829#define I2C_ISR_STOPF_Pos (5U)
16830#define I2C_ISR_STOPF_Msk (0x1UL << I2C_ISR_STOPF_Pos)
16831#define I2C_ISR_STOPF I2C_ISR_STOPF_Msk
16832#define I2C_ISR_TC_Pos (6U)
16833#define I2C_ISR_TC_Msk (0x1UL << I2C_ISR_TC_Pos)
16834#define I2C_ISR_TC I2C_ISR_TC_Msk
16835#define I2C_ISR_TCR_Pos (7U)
16836#define I2C_ISR_TCR_Msk (0x1UL << I2C_ISR_TCR_Pos)
16837#define I2C_ISR_TCR I2C_ISR_TCR_Msk
16838#define I2C_ISR_BERR_Pos (8U)
16839#define I2C_ISR_BERR_Msk (0x1UL << I2C_ISR_BERR_Pos)
16840#define I2C_ISR_BERR I2C_ISR_BERR_Msk
16841#define I2C_ISR_ARLO_Pos (9U)
16842#define I2C_ISR_ARLO_Msk (0x1UL << I2C_ISR_ARLO_Pos)
16843#define I2C_ISR_ARLO I2C_ISR_ARLO_Msk
16844#define I2C_ISR_OVR_Pos (10U)
16845#define I2C_ISR_OVR_Msk (0x1UL << I2C_ISR_OVR_Pos)
16846#define I2C_ISR_OVR I2C_ISR_OVR_Msk
16847#define I2C_ISR_PECERR_Pos (11U)
16848#define I2C_ISR_PECERR_Msk (0x1UL << I2C_ISR_PECERR_Pos)
16849#define I2C_ISR_PECERR I2C_ISR_PECERR_Msk
16850#define I2C_ISR_TIMEOUT_Pos (12U)
16851#define I2C_ISR_TIMEOUT_Msk (0x1UL << I2C_ISR_TIMEOUT_Pos)
16852#define I2C_ISR_TIMEOUT I2C_ISR_TIMEOUT_Msk
16853#define I2C_ISR_ALERT_Pos (13U)
16854#define I2C_ISR_ALERT_Msk (0x1UL << I2C_ISR_ALERT_Pos)
16855#define I2C_ISR_ALERT I2C_ISR_ALERT_Msk
16856#define I2C_ISR_BUSY_Pos (15U)
16857#define I2C_ISR_BUSY_Msk (0x1UL << I2C_ISR_BUSY_Pos)
16858#define I2C_ISR_BUSY I2C_ISR_BUSY_Msk
16859#define I2C_ISR_DIR_Pos (16U)
16860#define I2C_ISR_DIR_Msk (0x1UL << I2C_ISR_DIR_Pos)
16861#define I2C_ISR_DIR I2C_ISR_DIR_Msk
16862#define I2C_ISR_ADDCODE_Pos (17U)
16863#define I2C_ISR_ADDCODE_Msk (0x7FUL << I2C_ISR_ADDCODE_Pos)
16864#define I2C_ISR_ADDCODE I2C_ISR_ADDCODE_Msk
16866/****************** Bit definition for I2C_ICR register *********************/
16867#define I2C_ICR_ADDRCF_Pos (3U)
16868#define I2C_ICR_ADDRCF_Msk (0x1UL << I2C_ICR_ADDRCF_Pos)
16869#define I2C_ICR_ADDRCF I2C_ICR_ADDRCF_Msk
16870#define I2C_ICR_NACKCF_Pos (4U)
16871#define I2C_ICR_NACKCF_Msk (0x1UL << I2C_ICR_NACKCF_Pos)
16872#define I2C_ICR_NACKCF I2C_ICR_NACKCF_Msk
16873#define I2C_ICR_STOPCF_Pos (5U)
16874#define I2C_ICR_STOPCF_Msk (0x1UL << I2C_ICR_STOPCF_Pos)
16875#define I2C_ICR_STOPCF I2C_ICR_STOPCF_Msk
16876#define I2C_ICR_BERRCF_Pos (8U)
16877#define I2C_ICR_BERRCF_Msk (0x1UL << I2C_ICR_BERRCF_Pos)
16878#define I2C_ICR_BERRCF I2C_ICR_BERRCF_Msk
16879#define I2C_ICR_ARLOCF_Pos (9U)
16880#define I2C_ICR_ARLOCF_Msk (0x1UL << I2C_ICR_ARLOCF_Pos)
16881#define I2C_ICR_ARLOCF I2C_ICR_ARLOCF_Msk
16882#define I2C_ICR_OVRCF_Pos (10U)
16883#define I2C_ICR_OVRCF_Msk (0x1UL << I2C_ICR_OVRCF_Pos)
16884#define I2C_ICR_OVRCF I2C_ICR_OVRCF_Msk
16885#define I2C_ICR_PECCF_Pos (11U)
16886#define I2C_ICR_PECCF_Msk (0x1UL << I2C_ICR_PECCF_Pos)
16887#define I2C_ICR_PECCF I2C_ICR_PECCF_Msk
16888#define I2C_ICR_TIMOUTCF_Pos (12U)
16889#define I2C_ICR_TIMOUTCF_Msk (0x1UL << I2C_ICR_TIMOUTCF_Pos)
16890#define I2C_ICR_TIMOUTCF I2C_ICR_TIMOUTCF_Msk
16891#define I2C_ICR_ALERTCF_Pos (13U)
16892#define I2C_ICR_ALERTCF_Msk (0x1UL << I2C_ICR_ALERTCF_Pos)
16893#define I2C_ICR_ALERTCF I2C_ICR_ALERTCF_Msk
16895/****************** Bit definition for I2C_PECR register *********************/
16896#define I2C_PECR_PEC_Pos (0U)
16897#define I2C_PECR_PEC_Msk (0xFFUL << I2C_PECR_PEC_Pos)
16898#define I2C_PECR_PEC I2C_PECR_PEC_Msk
16900/****************** Bit definition for I2C_RXDR register *********************/
16901#define I2C_RXDR_RXDATA_Pos (0U)
16902#define I2C_RXDR_RXDATA_Msk (0xFFUL << I2C_RXDR_RXDATA_Pos)
16903#define I2C_RXDR_RXDATA I2C_RXDR_RXDATA_Msk
16905/****************** Bit definition for I2C_TXDR register *********************/
16906#define I2C_TXDR_TXDATA_Pos (0U)
16907#define I2C_TXDR_TXDATA_Msk (0xFFUL << I2C_TXDR_TXDATA_Pos)
16908#define I2C_TXDR_TXDATA I2C_TXDR_TXDATA_Msk
16910/******************************************************************************/
16911/* */
16912/* Independent WATCHDOG */
16913/* */
16914/******************************************************************************/
16915/******************* Bit definition for IWDG_KR register ********************/
16916#define IWDG_KR_KEY_Pos (0U)
16917#define IWDG_KR_KEY_Msk (0xFFFFUL << IWDG_KR_KEY_Pos)
16918#define IWDG_KR_KEY IWDG_KR_KEY_Msk
16920/******************* Bit definition for IWDG_PR register ********************/
16921#define IWDG_PR_PR_Pos (0U)
16922#define IWDG_PR_PR_Msk (0x7UL << IWDG_PR_PR_Pos)
16923#define IWDG_PR_PR IWDG_PR_PR_Msk
16924#define IWDG_PR_PR_0 (0x1UL << IWDG_PR_PR_Pos)
16925#define IWDG_PR_PR_1 (0x2UL << IWDG_PR_PR_Pos)
16926#define IWDG_PR_PR_2 (0x4UL << IWDG_PR_PR_Pos)
16928/******************* Bit definition for IWDG_RLR register *******************/
16929#define IWDG_RLR_RL_Pos (0U)
16930#define IWDG_RLR_RL_Msk (0xFFFUL << IWDG_RLR_RL_Pos)
16931#define IWDG_RLR_RL IWDG_RLR_RL_Msk
16933/******************* Bit definition for IWDG_SR register ********************/
16934#define IWDG_SR_PVU_Pos (0U)
16935#define IWDG_SR_PVU_Msk (0x1UL << IWDG_SR_PVU_Pos)
16936#define IWDG_SR_PVU IWDG_SR_PVU_Msk
16937#define IWDG_SR_RVU_Pos (1U)
16938#define IWDG_SR_RVU_Msk (0x1UL << IWDG_SR_RVU_Pos)
16939#define IWDG_SR_RVU IWDG_SR_RVU_Msk
16940#define IWDG_SR_WVU_Pos (2U)
16941#define IWDG_SR_WVU_Msk (0x1UL << IWDG_SR_WVU_Pos)
16942#define IWDG_SR_WVU IWDG_SR_WVU_Msk
16944/******************* Bit definition for IWDG_KR register ********************/
16945#define IWDG_WINR_WIN_Pos (0U)
16946#define IWDG_WINR_WIN_Msk (0xFFFUL << IWDG_WINR_WIN_Pos)
16947#define IWDG_WINR_WIN IWDG_WINR_WIN_Msk
16949/******************************************************************************/
16950/* */
16951/* JPEG Encoder/Decoder */
16952/* */
16953/******************************************************************************/
16954/******************** Bit definition for CONFR0 register ********************/
16955#define JPEG_CONFR0_START_Pos (0U)
16956#define JPEG_CONFR0_START_Msk (0x1UL << JPEG_CONFR0_START_Pos)
16957#define JPEG_CONFR0_START JPEG_CONFR0_START_Msk
16959/******************** Bit definition for CONFR1 register ********************/
16960#define JPEG_CONFR1_NF_Pos (0U)
16961#define JPEG_CONFR1_NF_Msk (0x3UL << JPEG_CONFR1_NF_Pos)
16962#define JPEG_CONFR1_NF JPEG_CONFR1_NF_Msk
16963#define JPEG_CONFR1_NF_0 (0x1UL << JPEG_CONFR1_NF_Pos)
16964#define JPEG_CONFR1_NF_1 (0x2UL << JPEG_CONFR1_NF_Pos)
16965#define JPEG_CONFR1_DE_Pos (3U)
16966#define JPEG_CONFR1_DE_Msk (0x1UL << JPEG_CONFR1_DE_Pos)
16967#define JPEG_CONFR1_DE JPEG_CONFR1_DE_Msk
16968#define JPEG_CONFR1_COLORSPACE_Pos (4U)
16969#define JPEG_CONFR1_COLORSPACE_Msk (0x3UL << JPEG_CONFR1_COLORSPACE_Pos)
16970#define JPEG_CONFR1_COLORSPACE JPEG_CONFR1_COLORSPACE_Msk
16971#define JPEG_CONFR1_COLORSPACE_0 (0x1UL << JPEG_CONFR1_COLORSPACE_Pos)
16972#define JPEG_CONFR1_COLORSPACE_1 (0x2UL << JPEG_CONFR1_COLORSPACE_Pos)
16973#define JPEG_CONFR1_NS_Pos (6U)
16974#define JPEG_CONFR1_NS_Msk (0x3UL << JPEG_CONFR1_NS_Pos)
16975#define JPEG_CONFR1_NS JPEG_CONFR1_NS_Msk
16976#define JPEG_CONFR1_NS_0 (0x1UL << JPEG_CONFR1_NS_Pos)
16977#define JPEG_CONFR1_NS_1 (0x2UL << JPEG_CONFR1_NS_Pos)
16978#define JPEG_CONFR1_HDR_Pos (8U)
16979#define JPEG_CONFR1_HDR_Msk (0x1UL << JPEG_CONFR1_HDR_Pos)
16980#define JPEG_CONFR1_HDR JPEG_CONFR1_HDR_Msk
16981#define JPEG_CONFR1_YSIZE_Pos (16U)
16982#define JPEG_CONFR1_YSIZE_Msk (0xFFFFUL << JPEG_CONFR1_YSIZE_Pos)
16983#define JPEG_CONFR1_YSIZE JPEG_CONFR1_YSIZE_Msk
16985/******************** Bit definition for CONFR2 register ********************/
16986#define JPEG_CONFR2_NMCU_Pos (0U)
16987#define JPEG_CONFR2_NMCU_Msk (0x3FFFFFFUL << JPEG_CONFR2_NMCU_Pos)
16988#define JPEG_CONFR2_NMCU JPEG_CONFR2_NMCU_Msk
16990/******************** Bit definition for CONFR3 register ********************/
16991#define JPEG_CONFR3_XSIZE_Pos (16U)
16992#define JPEG_CONFR3_XSIZE_Msk (0xFFFFUL << JPEG_CONFR3_XSIZE_Pos)
16993#define JPEG_CONFR3_XSIZE JPEG_CONFR3_XSIZE_Msk
16995/******************** Bit definition for CONFR4 register ********************/
16996#define JPEG_CONFR4_HD_Pos (0U)
16997#define JPEG_CONFR4_HD_Msk (0x1UL << JPEG_CONFR4_HD_Pos)
16998#define JPEG_CONFR4_HD JPEG_CONFR4_HD_Msk
16999#define JPEG_CONFR4_HA_Pos (1U)
17000#define JPEG_CONFR4_HA_Msk (0x1UL << JPEG_CONFR4_HA_Pos)
17001#define JPEG_CONFR4_HA JPEG_CONFR4_HA_Msk
17002#define JPEG_CONFR4_QT_Pos (2U)
17003#define JPEG_CONFR4_QT_Msk (0x3UL << JPEG_CONFR4_QT_Pos)
17004#define JPEG_CONFR4_QT JPEG_CONFR4_QT_Msk
17005#define JPEG_CONFR4_QT_0 (0x1UL << JPEG_CONFR4_QT_Pos)
17006#define JPEG_CONFR4_QT_1 (0x2UL << JPEG_CONFR4_QT_Pos)
17007#define JPEG_CONFR4_NB_Pos (4U)
17008#define JPEG_CONFR4_NB_Msk (0xFUL << JPEG_CONFR4_NB_Pos)
17009#define JPEG_CONFR4_NB JPEG_CONFR4_NB_Msk
17010#define JPEG_CONFR4_NB_0 (0x1UL << JPEG_CONFR4_NB_Pos)
17011#define JPEG_CONFR4_NB_1 (0x2UL << JPEG_CONFR4_NB_Pos)
17012#define JPEG_CONFR4_NB_2 (0x4UL << JPEG_CONFR4_NB_Pos)
17013#define JPEG_CONFR4_NB_3 (0x8UL << JPEG_CONFR4_NB_Pos)
17014#define JPEG_CONFR4_VSF_Pos (8U)
17015#define JPEG_CONFR4_VSF_Msk (0xFUL << JPEG_CONFR4_VSF_Pos)
17016#define JPEG_CONFR4_VSF JPEG_CONFR4_VSF_Msk
17017#define JPEG_CONFR4_VSF_0 (0x1UL << JPEG_CONFR4_VSF_Pos)
17018#define JPEG_CONFR4_VSF_1 (0x2UL << JPEG_CONFR4_VSF_Pos)
17019#define JPEG_CONFR4_VSF_2 (0x4UL << JPEG_CONFR4_VSF_Pos)
17020#define JPEG_CONFR4_VSF_3 (0x8UL << JPEG_CONFR4_VSF_Pos)
17021#define JPEG_CONFR4_HSF_Pos (12U)
17022#define JPEG_CONFR4_HSF_Msk (0xFUL << JPEG_CONFR4_HSF_Pos)
17023#define JPEG_CONFR4_HSF JPEG_CONFR4_HSF_Msk
17024#define JPEG_CONFR4_HSF_0 (0x1UL << JPEG_CONFR4_HSF_Pos)
17025#define JPEG_CONFR4_HSF_1 (0x2UL << JPEG_CONFR4_HSF_Pos)
17026#define JPEG_CONFR4_HSF_2 (0x4UL << JPEG_CONFR4_HSF_Pos)
17027#define JPEG_CONFR4_HSF_3 (0x8UL << JPEG_CONFR4_HSF_Pos)
17029/******************** Bit definition for CONFR5 register ********************/
17030#define JPEG_CONFR5_HD_Pos (0U)
17031#define JPEG_CONFR5_HD_Msk (0x1UL << JPEG_CONFR5_HD_Pos)
17032#define JPEG_CONFR5_HD JPEG_CONFR5_HD_Msk
17033#define JPEG_CONFR5_HA_Pos (1U)
17034#define JPEG_CONFR5_HA_Msk (0x1UL << JPEG_CONFR5_HA_Pos)
17035#define JPEG_CONFR5_HA JPEG_CONFR5_HA_Msk
17036#define JPEG_CONFR5_QT_Pos (2U)
17037#define JPEG_CONFR5_QT_Msk (0x3UL << JPEG_CONFR5_QT_Pos)
17038#define JPEG_CONFR5_QT JPEG_CONFR5_QT_Msk
17039#define JPEG_CONFR5_QT_0 (0x1UL << JPEG_CONFR5_QT_Pos)
17040#define JPEG_CONFR5_QT_1 (0x2UL << JPEG_CONFR5_QT_Pos)
17041#define JPEG_CONFR5_NB_Pos (4U)
17042#define JPEG_CONFR5_NB_Msk (0xFUL << JPEG_CONFR5_NB_Pos)
17043#define JPEG_CONFR5_NB JPEG_CONFR5_NB_Msk
17044#define JPEG_CONFR5_NB_0 (0x1UL << JPEG_CONFR5_NB_Pos)
17045#define JPEG_CONFR5_NB_1 (0x2UL << JPEG_CONFR5_NB_Pos)
17046#define JPEG_CONFR5_NB_2 (0x4UL << JPEG_CONFR5_NB_Pos)
17047#define JPEG_CONFR5_NB_3 (0x8UL << JPEG_CONFR5_NB_Pos)
17048#define JPEG_CONFR5_VSF_Pos (8U)
17049#define JPEG_CONFR5_VSF_Msk (0xFUL << JPEG_CONFR5_VSF_Pos)
17050#define JPEG_CONFR5_VSF JPEG_CONFR5_VSF_Msk
17051#define JPEG_CONFR5_VSF_0 (0x1UL << JPEG_CONFR5_VSF_Pos)
17052#define JPEG_CONFR5_VSF_1 (0x2UL << JPEG_CONFR5_VSF_Pos)
17053#define JPEG_CONFR5_VSF_2 (0x4UL << JPEG_CONFR5_VSF_Pos)
17054#define JPEG_CONFR5_VSF_3 (0x8UL << JPEG_CONFR5_VSF_Pos)
17055#define JPEG_CONFR5_HSF_Pos (12U)
17056#define JPEG_CONFR5_HSF_Msk (0xFUL << JPEG_CONFR5_HSF_Pos)
17057#define JPEG_CONFR5_HSF JPEG_CONFR5_HSF_Msk
17058#define JPEG_CONFR5_HSF_0 (0x1UL << JPEG_CONFR5_HSF_Pos)
17059#define JPEG_CONFR5_HSF_1 (0x2UL << JPEG_CONFR5_HSF_Pos)
17060#define JPEG_CONFR5_HSF_2 (0x4UL << JPEG_CONFR5_HSF_Pos)
17061#define JPEG_CONFR5_HSF_3 (0x8UL << JPEG_CONFR5_HSF_Pos)
17063/******************** Bit definition for CONFR6 register ********************/
17064#define JPEG_CONFR6_HD_Pos (0U)
17065#define JPEG_CONFR6_HD_Msk (0x1UL << JPEG_CONFR6_HD_Pos)
17066#define JPEG_CONFR6_HD JPEG_CONFR6_HD_Msk
17067#define JPEG_CONFR6_HA_Pos (1U)
17068#define JPEG_CONFR6_HA_Msk (0x1UL << JPEG_CONFR6_HA_Pos)
17069#define JPEG_CONFR6_HA JPEG_CONFR6_HA_Msk
17070#define JPEG_CONFR6_QT_Pos (2U)
17071#define JPEG_CONFR6_QT_Msk (0x3UL << JPEG_CONFR6_QT_Pos)
17072#define JPEG_CONFR6_QT JPEG_CONFR6_QT_Msk
17073#define JPEG_CONFR6_QT_0 (0x1UL << JPEG_CONFR6_QT_Pos)
17074#define JPEG_CONFR6_QT_1 (0x2UL << JPEG_CONFR6_QT_Pos)
17075#define JPEG_CONFR6_NB_Pos (4U)
17076#define JPEG_CONFR6_NB_Msk (0xFUL << JPEG_CONFR6_NB_Pos)
17077#define JPEG_CONFR6_NB JPEG_CONFR6_NB_Msk
17078#define JPEG_CONFR6_NB_0 (0x1UL << JPEG_CONFR6_NB_Pos)
17079#define JPEG_CONFR6_NB_1 (0x2UL << JPEG_CONFR6_NB_Pos)
17080#define JPEG_CONFR6_NB_2 (0x4UL << JPEG_CONFR6_NB_Pos)
17081#define JPEG_CONFR6_NB_3 (0x8UL << JPEG_CONFR6_NB_Pos)
17082#define JPEG_CONFR6_VSF_Pos (8U)
17083#define JPEG_CONFR6_VSF_Msk (0xFUL << JPEG_CONFR6_VSF_Pos)
17084#define JPEG_CONFR6_VSF JPEG_CONFR6_VSF_Msk
17085#define JPEG_CONFR6_VSF_0 (0x1UL << JPEG_CONFR6_VSF_Pos)
17086#define JPEG_CONFR6_VSF_1 (0x2UL << JPEG_CONFR6_VSF_Pos)
17087#define JPEG_CONFR6_VSF_2 (0x4UL << JPEG_CONFR6_VSF_Pos)
17088#define JPEG_CONFR6_VSF_3 (0x8UL << JPEG_CONFR6_VSF_Pos)
17089#define JPEG_CONFR6_HSF_Pos (12U)
17090#define JPEG_CONFR6_HSF_Msk (0xFUL << JPEG_CONFR6_HSF_Pos)
17091#define JPEG_CONFR6_HSF JPEG_CONFR6_HSF_Msk
17092#define JPEG_CONFR6_HSF_0 (0x1UL << JPEG_CONFR6_HSF_Pos)
17093#define JPEG_CONFR6_HSF_1 (0x2UL << JPEG_CONFR6_HSF_Pos)
17094#define JPEG_CONFR6_HSF_2 (0x4UL << JPEG_CONFR6_HSF_Pos)
17095#define JPEG_CONFR6_HSF_3 (0x8UL << JPEG_CONFR6_HSF_Pos)
17097/******************** Bit definition for CONFR7 register ********************/
17098#define JPEG_CONFR7_HD_Pos (0U)
17099#define JPEG_CONFR7_HD_Msk (0x1UL << JPEG_CONFR7_HD_Pos)
17100#define JPEG_CONFR7_HD JPEG_CONFR7_HD_Msk
17101#define JPEG_CONFR7_HA_Pos (1U)
17102#define JPEG_CONFR7_HA_Msk (0x1UL << JPEG_CONFR7_HA_Pos)
17103#define JPEG_CONFR7_HA JPEG_CONFR7_HA_Msk
17104#define JPEG_CONFR7_QT_Pos (2U)
17105#define JPEG_CONFR7_QT_Msk (0x3UL << JPEG_CONFR7_QT_Pos)
17106#define JPEG_CONFR7_QT JPEG_CONFR7_QT_Msk
17107#define JPEG_CONFR7_QT_0 (0x1UL << JPEG_CONFR7_QT_Pos)
17108#define JPEG_CONFR7_QT_1 (0x2UL << JPEG_CONFR7_QT_Pos)
17109#define JPEG_CONFR7_NB_Pos (4U)
17110#define JPEG_CONFR7_NB_Msk (0xFUL << JPEG_CONFR7_NB_Pos)
17111#define JPEG_CONFR7_NB JPEG_CONFR7_NB_Msk
17112#define JPEG_CONFR7_NB_0 (0x1UL << JPEG_CONFR7_NB_Pos)
17113#define JPEG_CONFR7_NB_1 (0x2UL << JPEG_CONFR7_NB_Pos)
17114#define JPEG_CONFR7_NB_2 (0x4UL << JPEG_CONFR7_NB_Pos)
17115#define JPEG_CONFR7_NB_3 (0x8UL << JPEG_CONFR7_NB_Pos)
17116#define JPEG_CONFR7_VSF_Pos (8U)
17117#define JPEG_CONFR7_VSF_Msk (0xFUL << JPEG_CONFR7_VSF_Pos)
17118#define JPEG_CONFR7_VSF JPEG_CONFR7_VSF_Msk
17119#define JPEG_CONFR7_VSF_0 (0x1UL << JPEG_CONFR7_VSF_Pos)
17120#define JPEG_CONFR7_VSF_1 (0x2UL << JPEG_CONFR7_VSF_Pos)
17121#define JPEG_CONFR7_VSF_2 (0x4UL << JPEG_CONFR7_VSF_Pos)
17122#define JPEG_CONFR7_VSF_3 (0x8UL << JPEG_CONFR7_VSF_Pos)
17123#define JPEG_CONFR7_HSF_Pos (12U)
17124#define JPEG_CONFR7_HSF_Msk (0xFUL << JPEG_CONFR7_HSF_Pos)
17125#define JPEG_CONFR7_HSF JPEG_CONFR7_HSF_Msk
17126#define JPEG_CONFR7_HSF_0 (0x1UL << JPEG_CONFR7_HSF_Pos)
17127#define JPEG_CONFR7_HSF_1 (0x2UL << JPEG_CONFR7_HSF_Pos)
17128#define JPEG_CONFR7_HSF_2 (0x4UL << JPEG_CONFR7_HSF_Pos)
17129#define JPEG_CONFR7_HSF_3 (0x8UL << JPEG_CONFR7_HSF_Pos)
17131/******************** Bit definition for CR register ********************/
17132#define JPEG_CR_JCEN_Pos (0U)
17133#define JPEG_CR_JCEN_Msk (0x1UL << JPEG_CR_JCEN_Pos)
17134#define JPEG_CR_JCEN JPEG_CR_JCEN_Msk
17135#define JPEG_CR_IFTIE_Pos (1U)
17136#define JPEG_CR_IFTIE_Msk (0x1UL << JPEG_CR_IFTIE_Pos)
17137#define JPEG_CR_IFTIE JPEG_CR_IFTIE_Msk
17138#define JPEG_CR_IFNFIE_Pos (2U)
17139#define JPEG_CR_IFNFIE_Msk (0x1UL << JPEG_CR_IFNFIE_Pos)
17140#define JPEG_CR_IFNFIE JPEG_CR_IFNFIE_Msk
17141#define JPEG_CR_OFTIE_Pos (3U)
17142#define JPEG_CR_OFTIE_Msk (0x1UL << JPEG_CR_OFTIE_Pos)
17143#define JPEG_CR_OFTIE JPEG_CR_OFTIE_Msk
17144#define JPEG_CR_OFNEIE_Pos (4U)
17145#define JPEG_CR_OFNEIE_Msk (0x1UL << JPEG_CR_OFNEIE_Pos)
17146#define JPEG_CR_OFNEIE JPEG_CR_OFNEIE_Msk
17147#define JPEG_CR_EOCIE_Pos (5U)
17148#define JPEG_CR_EOCIE_Msk (0x1UL << JPEG_CR_EOCIE_Pos)
17149#define JPEG_CR_EOCIE JPEG_CR_EOCIE_Msk
17150#define JPEG_CR_HPDIE_Pos (6U)
17151#define JPEG_CR_HPDIE_Msk (0x1UL << JPEG_CR_HPDIE_Pos)
17152#define JPEG_CR_HPDIE JPEG_CR_HPDIE_Msk
17153#define JPEG_CR_IFF_Pos (13U)
17154#define JPEG_CR_IFF_Msk (0x1UL << JPEG_CR_IFF_Pos)
17155#define JPEG_CR_IFF JPEG_CR_IFF_Msk
17156#define JPEG_CR_OFF_Pos (14U)
17157#define JPEG_CR_OFF_Msk (0x1UL << JPEG_CR_OFF_Pos)
17158#define JPEG_CR_OFF JPEG_CR_OFF_Msk
17160/******************** Bit definition for SR register ********************/
17161#define JPEG_SR_IFTF_Pos (1U)
17162#define JPEG_SR_IFTF_Msk (0x1UL << JPEG_SR_IFTF_Pos)
17163#define JPEG_SR_IFTF JPEG_SR_IFTF_Msk
17164#define JPEG_SR_IFNFF_Pos (2U)
17165#define JPEG_SR_IFNFF_Msk (0x1UL << JPEG_SR_IFNFF_Pos)
17166#define JPEG_SR_IFNFF JPEG_SR_IFNFF_Msk
17167#define JPEG_SR_OFTF_Pos (3U)
17168#define JPEG_SR_OFTF_Msk (0x1UL << JPEG_SR_OFTF_Pos)
17169#define JPEG_SR_OFTF JPEG_SR_OFTF_Msk
17170#define JPEG_SR_OFNEF_Pos (4U)
17171#define JPEG_SR_OFNEF_Msk (0x1UL << JPEG_SR_OFNEF_Pos)
17172#define JPEG_SR_OFNEF JPEG_SR_OFNEF_Msk
17173#define JPEG_SR_EOCF_Pos (5U)
17174#define JPEG_SR_EOCF_Msk (0x1UL << JPEG_SR_EOCF_Pos)
17175#define JPEG_SR_EOCF JPEG_SR_EOCF_Msk
17176#define JPEG_SR_HPDF_Pos (6U)
17177#define JPEG_SR_HPDF_Msk (0x1UL << JPEG_SR_HPDF_Pos)
17178#define JPEG_SR_HPDF JPEG_SR_HPDF_Msk
17179#define JPEG_SR_COF_Pos (7U)
17180#define JPEG_SR_COF_Msk (0x1UL << JPEG_SR_COF_Pos)
17181#define JPEG_SR_COF JPEG_SR_COF_Msk
17183/******************** Bit definition for CFR register ********************/
17184#define JPEG_CFR_CEOCF_Pos (4U)
17185#define JPEG_CFR_CEOCF_Msk (0x1UL << JPEG_CFR_CEOCF_Pos)
17186#define JPEG_CFR_CEOCF JPEG_CFR_CEOCF_Msk
17187#define JPEG_CFR_CHPDF_Pos (5U)
17188#define JPEG_CFR_CHPDF_Msk (0x1UL << JPEG_CFR_CHPDF_Pos)
17189#define JPEG_CFR_CHPDF JPEG_CFR_CHPDF_Msk
17191/******************** Bit definition for DIR register ********************/
17192#define JPEG_DIR_DATAIN_Pos (0U)
17193#define JPEG_DIR_DATAIN_Msk (0xFFFFFFFFUL << JPEG_DIR_DATAIN_Pos)
17194#define JPEG_DIR_DATAIN JPEG_DIR_DATAIN_Msk
17196/******************** Bit definition for DOR register ********************/
17197#define JPEG_DOR_DATAOUT_Pos (0U)
17198#define JPEG_DOR_DATAOUT_Msk (0xFFFFFFFFUL << JPEG_DOR_DATAOUT_Pos)
17199#define JPEG_DOR_DATAOUT JPEG_DOR_DATAOUT_Msk
17201/******************************************************************************/
17202/* */
17203/* LCD-TFT Display Controller (LTDC) */
17204/* */
17205/******************************************************************************/
17206
17207/******************** Bit definition for LTDC_SSCR register *****************/
17208
17209#define LTDC_SSCR_VSH_Pos (0U)
17210#define LTDC_SSCR_VSH_Msk (0x7FFUL << LTDC_SSCR_VSH_Pos)
17211#define LTDC_SSCR_VSH LTDC_SSCR_VSH_Msk
17212#define LTDC_SSCR_HSW_Pos (16U)
17213#define LTDC_SSCR_HSW_Msk (0xFFFUL << LTDC_SSCR_HSW_Pos)
17214#define LTDC_SSCR_HSW LTDC_SSCR_HSW_Msk
17216/******************** Bit definition for LTDC_BPCR register *****************/
17217
17218#define LTDC_BPCR_AVBP_Pos (0U)
17219#define LTDC_BPCR_AVBP_Msk (0x7FFUL << LTDC_BPCR_AVBP_Pos)
17220#define LTDC_BPCR_AVBP LTDC_BPCR_AVBP_Msk
17221#define LTDC_BPCR_AHBP_Pos (16U)
17222#define LTDC_BPCR_AHBP_Msk (0xFFFUL << LTDC_BPCR_AHBP_Pos)
17223#define LTDC_BPCR_AHBP LTDC_BPCR_AHBP_Msk
17225/******************** Bit definition for LTDC_AWCR register *****************/
17226
17227#define LTDC_AWCR_AAH_Pos (0U)
17228#define LTDC_AWCR_AAH_Msk (0x7FFUL << LTDC_AWCR_AAH_Pos)
17229#define LTDC_AWCR_AAH LTDC_AWCR_AAH_Msk
17230#define LTDC_AWCR_AAW_Pos (16U)
17231#define LTDC_AWCR_AAW_Msk (0xFFFUL << LTDC_AWCR_AAW_Pos)
17232#define LTDC_AWCR_AAW LTDC_AWCR_AAW_Msk
17234/******************** Bit definition for LTDC_TWCR register *****************/
17235
17236#define LTDC_TWCR_TOTALH_Pos (0U)
17237#define LTDC_TWCR_TOTALH_Msk (0x7FFUL << LTDC_TWCR_TOTALH_Pos)
17238#define LTDC_TWCR_TOTALH LTDC_TWCR_TOTALH_Msk
17239#define LTDC_TWCR_TOTALW_Pos (16U)
17240#define LTDC_TWCR_TOTALW_Msk (0xFFFUL << LTDC_TWCR_TOTALW_Pos)
17241#define LTDC_TWCR_TOTALW LTDC_TWCR_TOTALW_Msk
17243/******************** Bit definition for LTDC_GCR register ******************/
17244
17245#define LTDC_GCR_LTDCEN_Pos (0U)
17246#define LTDC_GCR_LTDCEN_Msk (0x1UL << LTDC_GCR_LTDCEN_Pos)
17247#define LTDC_GCR_LTDCEN LTDC_GCR_LTDCEN_Msk
17248#define LTDC_GCR_DBW_Pos (4U)
17249#define LTDC_GCR_DBW_Msk (0x7UL << LTDC_GCR_DBW_Pos)
17250#define LTDC_GCR_DBW LTDC_GCR_DBW_Msk
17251#define LTDC_GCR_DGW_Pos (8U)
17252#define LTDC_GCR_DGW_Msk (0x7UL << LTDC_GCR_DGW_Pos)
17253#define LTDC_GCR_DGW LTDC_GCR_DGW_Msk
17254#define LTDC_GCR_DRW_Pos (12U)
17255#define LTDC_GCR_DRW_Msk (0x7UL << LTDC_GCR_DRW_Pos)
17256#define LTDC_GCR_DRW LTDC_GCR_DRW_Msk
17257#define LTDC_GCR_DEN_Pos (16U)
17258#define LTDC_GCR_DEN_Msk (0x1UL << LTDC_GCR_DEN_Pos)
17259#define LTDC_GCR_DEN LTDC_GCR_DEN_Msk
17260#define LTDC_GCR_PCPOL_Pos (28U)
17261#define LTDC_GCR_PCPOL_Msk (0x1UL << LTDC_GCR_PCPOL_Pos)
17262#define LTDC_GCR_PCPOL LTDC_GCR_PCPOL_Msk
17263#define LTDC_GCR_DEPOL_Pos (29U)
17264#define LTDC_GCR_DEPOL_Msk (0x1UL << LTDC_GCR_DEPOL_Pos)
17265#define LTDC_GCR_DEPOL LTDC_GCR_DEPOL_Msk
17266#define LTDC_GCR_VSPOL_Pos (30U)
17267#define LTDC_GCR_VSPOL_Msk (0x1UL << LTDC_GCR_VSPOL_Pos)
17268#define LTDC_GCR_VSPOL LTDC_GCR_VSPOL_Msk
17269#define LTDC_GCR_HSPOL_Pos (31U)
17270#define LTDC_GCR_HSPOL_Msk (0x1UL << LTDC_GCR_HSPOL_Pos)
17271#define LTDC_GCR_HSPOL LTDC_GCR_HSPOL_Msk
17274/******************** Bit definition for LTDC_SRCR register *****************/
17275
17276#define LTDC_SRCR_IMR_Pos (0U)
17277#define LTDC_SRCR_IMR_Msk (0x1UL << LTDC_SRCR_IMR_Pos)
17278#define LTDC_SRCR_IMR LTDC_SRCR_IMR_Msk
17279#define LTDC_SRCR_VBR_Pos (1U)
17280#define LTDC_SRCR_VBR_Msk (0x1UL << LTDC_SRCR_VBR_Pos)
17281#define LTDC_SRCR_VBR LTDC_SRCR_VBR_Msk
17283/******************** Bit definition for LTDC_BCCR register *****************/
17284
17285#define LTDC_BCCR_BCBLUE_Pos (0U)
17286#define LTDC_BCCR_BCBLUE_Msk (0xFFUL << LTDC_BCCR_BCBLUE_Pos)
17287#define LTDC_BCCR_BCBLUE LTDC_BCCR_BCBLUE_Msk
17288#define LTDC_BCCR_BCGREEN_Pos (8U)
17289#define LTDC_BCCR_BCGREEN_Msk (0xFFUL << LTDC_BCCR_BCGREEN_Pos)
17290#define LTDC_BCCR_BCGREEN LTDC_BCCR_BCGREEN_Msk
17291#define LTDC_BCCR_BCRED_Pos (16U)
17292#define LTDC_BCCR_BCRED_Msk (0xFFUL << LTDC_BCCR_BCRED_Pos)
17293#define LTDC_BCCR_BCRED LTDC_BCCR_BCRED_Msk
17295/******************** Bit definition for LTDC_IER register ******************/
17296
17297#define LTDC_IER_LIE_Pos (0U)
17298#define LTDC_IER_LIE_Msk (0x1UL << LTDC_IER_LIE_Pos)
17299#define LTDC_IER_LIE LTDC_IER_LIE_Msk
17300#define LTDC_IER_FUIE_Pos (1U)
17301#define LTDC_IER_FUIE_Msk (0x1UL << LTDC_IER_FUIE_Pos)
17302#define LTDC_IER_FUIE LTDC_IER_FUIE_Msk
17303#define LTDC_IER_TERRIE_Pos (2U)
17304#define LTDC_IER_TERRIE_Msk (0x1UL << LTDC_IER_TERRIE_Pos)
17305#define LTDC_IER_TERRIE LTDC_IER_TERRIE_Msk
17306#define LTDC_IER_RRIE_Pos (3U)
17307#define LTDC_IER_RRIE_Msk (0x1UL << LTDC_IER_RRIE_Pos)
17308#define LTDC_IER_RRIE LTDC_IER_RRIE_Msk
17310/******************** Bit definition for LTDC_ISR register ******************/
17311
17312#define LTDC_ISR_LIF_Pos (0U)
17313#define LTDC_ISR_LIF_Msk (0x1UL << LTDC_ISR_LIF_Pos)
17314#define LTDC_ISR_LIF LTDC_ISR_LIF_Msk
17315#define LTDC_ISR_FUIF_Pos (1U)
17316#define LTDC_ISR_FUIF_Msk (0x1UL << LTDC_ISR_FUIF_Pos)
17317#define LTDC_ISR_FUIF LTDC_ISR_FUIF_Msk
17318#define LTDC_ISR_TERRIF_Pos (2U)
17319#define LTDC_ISR_TERRIF_Msk (0x1UL << LTDC_ISR_TERRIF_Pos)
17320#define LTDC_ISR_TERRIF LTDC_ISR_TERRIF_Msk
17321#define LTDC_ISR_RRIF_Pos (3U)
17322#define LTDC_ISR_RRIF_Msk (0x1UL << LTDC_ISR_RRIF_Pos)
17323#define LTDC_ISR_RRIF LTDC_ISR_RRIF_Msk
17325/******************** Bit definition for LTDC_ICR register ******************/
17326
17327#define LTDC_ICR_CLIF_Pos (0U)
17328#define LTDC_ICR_CLIF_Msk (0x1UL << LTDC_ICR_CLIF_Pos)
17329#define LTDC_ICR_CLIF LTDC_ICR_CLIF_Msk
17330#define LTDC_ICR_CFUIF_Pos (1U)
17331#define LTDC_ICR_CFUIF_Msk (0x1UL << LTDC_ICR_CFUIF_Pos)
17332#define LTDC_ICR_CFUIF LTDC_ICR_CFUIF_Msk
17333#define LTDC_ICR_CTERRIF_Pos (2U)
17334#define LTDC_ICR_CTERRIF_Msk (0x1UL << LTDC_ICR_CTERRIF_Pos)
17335#define LTDC_ICR_CTERRIF LTDC_ICR_CTERRIF_Msk
17336#define LTDC_ICR_CRRIF_Pos (3U)
17337#define LTDC_ICR_CRRIF_Msk (0x1UL << LTDC_ICR_CRRIF_Pos)
17338#define LTDC_ICR_CRRIF LTDC_ICR_CRRIF_Msk
17340/******************** Bit definition for LTDC_LIPCR register ****************/
17341
17342#define LTDC_LIPCR_LIPOS_Pos (0U)
17343#define LTDC_LIPCR_LIPOS_Msk (0x7FFUL << LTDC_LIPCR_LIPOS_Pos)
17344#define LTDC_LIPCR_LIPOS LTDC_LIPCR_LIPOS_Msk
17346/******************** Bit definition for LTDC_CPSR register *****************/
17347
17348#define LTDC_CPSR_CYPOS_Pos (0U)
17349#define LTDC_CPSR_CYPOS_Msk (0xFFFFUL << LTDC_CPSR_CYPOS_Pos)
17350#define LTDC_CPSR_CYPOS LTDC_CPSR_CYPOS_Msk
17351#define LTDC_CPSR_CXPOS_Pos (16U)
17352#define LTDC_CPSR_CXPOS_Msk (0xFFFFUL << LTDC_CPSR_CXPOS_Pos)
17353#define LTDC_CPSR_CXPOS LTDC_CPSR_CXPOS_Msk
17355/******************** Bit definition for LTDC_CDSR register *****************/
17356
17357#define LTDC_CDSR_VDES_Pos (0U)
17358#define LTDC_CDSR_VDES_Msk (0x1UL << LTDC_CDSR_VDES_Pos)
17359#define LTDC_CDSR_VDES LTDC_CDSR_VDES_Msk
17360#define LTDC_CDSR_HDES_Pos (1U)
17361#define LTDC_CDSR_HDES_Msk (0x1UL << LTDC_CDSR_HDES_Pos)
17362#define LTDC_CDSR_HDES LTDC_CDSR_HDES_Msk
17363#define LTDC_CDSR_VSYNCS_Pos (2U)
17364#define LTDC_CDSR_VSYNCS_Msk (0x1UL << LTDC_CDSR_VSYNCS_Pos)
17365#define LTDC_CDSR_VSYNCS LTDC_CDSR_VSYNCS_Msk
17366#define LTDC_CDSR_HSYNCS_Pos (3U)
17367#define LTDC_CDSR_HSYNCS_Msk (0x1UL << LTDC_CDSR_HSYNCS_Pos)
17368#define LTDC_CDSR_HSYNCS LTDC_CDSR_HSYNCS_Msk
17370/******************** Bit definition for LTDC_LxCR register *****************/
17371
17372#define LTDC_LxCR_LEN_Pos (0U)
17373#define LTDC_LxCR_LEN_Msk (0x1UL << LTDC_LxCR_LEN_Pos)
17374#define LTDC_LxCR_LEN LTDC_LxCR_LEN_Msk
17375#define LTDC_LxCR_COLKEN_Pos (1U)
17376#define LTDC_LxCR_COLKEN_Msk (0x1UL << LTDC_LxCR_COLKEN_Pos)
17377#define LTDC_LxCR_COLKEN LTDC_LxCR_COLKEN_Msk
17378#define LTDC_LxCR_CLUTEN_Pos (4U)
17379#define LTDC_LxCR_CLUTEN_Msk (0x1UL << LTDC_LxCR_CLUTEN_Pos)
17380#define LTDC_LxCR_CLUTEN LTDC_LxCR_CLUTEN_Msk
17382/******************** Bit definition for LTDC_LxWHPCR register **************/
17383
17384#define LTDC_LxWHPCR_WHSTPOS_Pos (0U)
17385#define LTDC_LxWHPCR_WHSTPOS_Msk (0xFFFUL << LTDC_LxWHPCR_WHSTPOS_Pos)
17386#define LTDC_LxWHPCR_WHSTPOS LTDC_LxWHPCR_WHSTPOS_Msk
17387#define LTDC_LxWHPCR_WHSPPOS_Pos (16U)
17388#define LTDC_LxWHPCR_WHSPPOS_Msk (0xFFFFUL << LTDC_LxWHPCR_WHSPPOS_Pos)
17389#define LTDC_LxWHPCR_WHSPPOS LTDC_LxWHPCR_WHSPPOS_Msk
17391/******************** Bit definition for LTDC_LxWVPCR register **************/
17392
17393#define LTDC_LxWVPCR_WVSTPOS_Pos (0U)
17394#define LTDC_LxWVPCR_WVSTPOS_Msk (0xFFFUL << LTDC_LxWVPCR_WVSTPOS_Pos)
17395#define LTDC_LxWVPCR_WVSTPOS LTDC_LxWVPCR_WVSTPOS_Msk
17396#define LTDC_LxWVPCR_WVSPPOS_Pos (16U)
17397#define LTDC_LxWVPCR_WVSPPOS_Msk (0xFFFFUL << LTDC_LxWVPCR_WVSPPOS_Pos)
17398#define LTDC_LxWVPCR_WVSPPOS LTDC_LxWVPCR_WVSPPOS_Msk
17400/******************** Bit definition for LTDC_LxCKCR register ***************/
17401
17402#define LTDC_LxCKCR_CKBLUE_Pos (0U)
17403#define LTDC_LxCKCR_CKBLUE_Msk (0xFFUL << LTDC_LxCKCR_CKBLUE_Pos)
17404#define LTDC_LxCKCR_CKBLUE LTDC_LxCKCR_CKBLUE_Msk
17405#define LTDC_LxCKCR_CKGREEN_Pos (8U)
17406#define LTDC_LxCKCR_CKGREEN_Msk (0xFFUL << LTDC_LxCKCR_CKGREEN_Pos)
17407#define LTDC_LxCKCR_CKGREEN LTDC_LxCKCR_CKGREEN_Msk
17408#define LTDC_LxCKCR_CKRED_Pos (16U)
17409#define LTDC_LxCKCR_CKRED_Msk (0xFFUL << LTDC_LxCKCR_CKRED_Pos)
17410#define LTDC_LxCKCR_CKRED LTDC_LxCKCR_CKRED_Msk
17412/******************** Bit definition for LTDC_LxPFCR register ***************/
17413
17414#define LTDC_LxPFCR_PF_Pos (0U)
17415#define LTDC_LxPFCR_PF_Msk (0x7UL << LTDC_LxPFCR_PF_Pos)
17416#define LTDC_LxPFCR_PF LTDC_LxPFCR_PF_Msk
17418/******************** Bit definition for LTDC_LxCACR register ***************/
17419
17420#define LTDC_LxCACR_CONSTA_Pos (0U)
17421#define LTDC_LxCACR_CONSTA_Msk (0xFFUL << LTDC_LxCACR_CONSTA_Pos)
17422#define LTDC_LxCACR_CONSTA LTDC_LxCACR_CONSTA_Msk
17424/******************** Bit definition for LTDC_LxDCCR register ***************/
17425
17426#define LTDC_LxDCCR_DCBLUE_Pos (0U)
17427#define LTDC_LxDCCR_DCBLUE_Msk (0xFFUL << LTDC_LxDCCR_DCBLUE_Pos)
17428#define LTDC_LxDCCR_DCBLUE LTDC_LxDCCR_DCBLUE_Msk
17429#define LTDC_LxDCCR_DCGREEN_Pos (8U)
17430#define LTDC_LxDCCR_DCGREEN_Msk (0xFFUL << LTDC_LxDCCR_DCGREEN_Pos)
17431#define LTDC_LxDCCR_DCGREEN LTDC_LxDCCR_DCGREEN_Msk
17432#define LTDC_LxDCCR_DCRED_Pos (16U)
17433#define LTDC_LxDCCR_DCRED_Msk (0xFFUL << LTDC_LxDCCR_DCRED_Pos)
17434#define LTDC_LxDCCR_DCRED LTDC_LxDCCR_DCRED_Msk
17435#define LTDC_LxDCCR_DCALPHA_Pos (24U)
17436#define LTDC_LxDCCR_DCALPHA_Msk (0xFFUL << LTDC_LxDCCR_DCALPHA_Pos)
17437#define LTDC_LxDCCR_DCALPHA LTDC_LxDCCR_DCALPHA_Msk
17439/******************** Bit definition for LTDC_LxBFCR register ***************/
17440
17441#define LTDC_LxBFCR_BF2_Pos (0U)
17442#define LTDC_LxBFCR_BF2_Msk (0x7UL << LTDC_LxBFCR_BF2_Pos)
17443#define LTDC_LxBFCR_BF2 LTDC_LxBFCR_BF2_Msk
17444#define LTDC_LxBFCR_BF1_Pos (8U)
17445#define LTDC_LxBFCR_BF1_Msk (0x7UL << LTDC_LxBFCR_BF1_Pos)
17446#define LTDC_LxBFCR_BF1 LTDC_LxBFCR_BF1_Msk
17448/******************** Bit definition for LTDC_LxCFBAR register **************/
17449
17450#define LTDC_LxCFBAR_CFBADD_Pos (0U)
17451#define LTDC_LxCFBAR_CFBADD_Msk (0xFFFFFFFFUL << LTDC_LxCFBAR_CFBADD_Pos)
17452#define LTDC_LxCFBAR_CFBADD LTDC_LxCFBAR_CFBADD_Msk
17454/******************** Bit definition for LTDC_LxCFBLR register **************/
17455
17456#define LTDC_LxCFBLR_CFBLL_Pos (0U)
17457#define LTDC_LxCFBLR_CFBLL_Msk (0x1FFFUL << LTDC_LxCFBLR_CFBLL_Pos)
17458#define LTDC_LxCFBLR_CFBLL LTDC_LxCFBLR_CFBLL_Msk
17459#define LTDC_LxCFBLR_CFBP_Pos (16U)
17460#define LTDC_LxCFBLR_CFBP_Msk (0x1FFFUL << LTDC_LxCFBLR_CFBP_Pos)
17461#define LTDC_LxCFBLR_CFBP LTDC_LxCFBLR_CFBP_Msk
17463/******************** Bit definition for LTDC_LxCFBLNR register *************/
17464
17465#define LTDC_LxCFBLNR_CFBLNBR_Pos (0U)
17466#define LTDC_LxCFBLNR_CFBLNBR_Msk (0x7FFUL << LTDC_LxCFBLNR_CFBLNBR_Pos)
17467#define LTDC_LxCFBLNR_CFBLNBR LTDC_LxCFBLNR_CFBLNBR_Msk
17469/******************** Bit definition for LTDC_LxCLUTWR register *************/
17470
17471#define LTDC_LxCLUTWR_BLUE_Pos (0U)
17472#define LTDC_LxCLUTWR_BLUE_Msk (0xFFUL << LTDC_LxCLUTWR_BLUE_Pos)
17473#define LTDC_LxCLUTWR_BLUE LTDC_LxCLUTWR_BLUE_Msk
17474#define LTDC_LxCLUTWR_GREEN_Pos (8U)
17475#define LTDC_LxCLUTWR_GREEN_Msk (0xFFUL << LTDC_LxCLUTWR_GREEN_Pos)
17476#define LTDC_LxCLUTWR_GREEN LTDC_LxCLUTWR_GREEN_Msk
17477#define LTDC_LxCLUTWR_RED_Pos (16U)
17478#define LTDC_LxCLUTWR_RED_Msk (0xFFUL << LTDC_LxCLUTWR_RED_Pos)
17479#define LTDC_LxCLUTWR_RED LTDC_LxCLUTWR_RED_Msk
17480#define LTDC_LxCLUTWR_CLUTADD_Pos (24U)
17481#define LTDC_LxCLUTWR_CLUTADD_Msk (0xFFUL << LTDC_LxCLUTWR_CLUTADD_Pos)
17482#define LTDC_LxCLUTWR_CLUTADD LTDC_LxCLUTWR_CLUTADD_Msk
17484/******************************************************************************/
17485/* */
17486/* MDMA */
17487/* */
17488/******************************************************************************/
17489/******************** Bit definition for MDMA_GISR0 register ****************/
17490#define MDMA_GISR0_GIF0_Pos (0U)
17491#define MDMA_GISR0_GIF0_Msk (0x1UL << MDMA_GISR0_GIF0_Pos)
17492#define MDMA_GISR0_GIF0 MDMA_GISR0_GIF0_Msk
17493#define MDMA_GISR0_GIF1_Pos (1U)
17494#define MDMA_GISR0_GIF1_Msk (0x1UL << MDMA_GISR0_GIF1_Pos)
17495#define MDMA_GISR0_GIF1 MDMA_GISR0_GIF1_Msk
17496#define MDMA_GISR0_GIF2_Pos (2U)
17497#define MDMA_GISR0_GIF2_Msk (0x1UL << MDMA_GISR0_GIF2_Pos)
17498#define MDMA_GISR0_GIF2 MDMA_GISR0_GIF2_Msk
17499#define MDMA_GISR0_GIF3_Pos (3U)
17500#define MDMA_GISR0_GIF3_Msk (0x1UL << MDMA_GISR0_GIF3_Pos)
17501#define MDMA_GISR0_GIF3 MDMA_GISR0_GIF3_Msk
17502#define MDMA_GISR0_GIF4_Pos (4U)
17503#define MDMA_GISR0_GIF4_Msk (0x1UL << MDMA_GISR0_GIF4_Pos)
17504#define MDMA_GISR0_GIF4 MDMA_GISR0_GIF4_Msk
17505#define MDMA_GISR0_GIF5_Pos (5U)
17506#define MDMA_GISR0_GIF5_Msk (0x1UL << MDMA_GISR0_GIF5_Pos)
17507#define MDMA_GISR0_GIF5 MDMA_GISR0_GIF5_Msk
17508#define MDMA_GISR0_GIF6_Pos (6U)
17509#define MDMA_GISR0_GIF6_Msk (0x1UL << MDMA_GISR0_GIF6_Pos)
17510#define MDMA_GISR0_GIF6 MDMA_GISR0_GIF6_Msk
17511#define MDMA_GISR0_GIF7_Pos (7U)
17512#define MDMA_GISR0_GIF7_Msk (0x1UL << MDMA_GISR0_GIF7_Pos)
17513#define MDMA_GISR0_GIF7 MDMA_GISR0_GIF7_Msk
17514#define MDMA_GISR0_GIF8_Pos (8U)
17515#define MDMA_GISR0_GIF8_Msk (0x1UL << MDMA_GISR0_GIF8_Pos)
17516#define MDMA_GISR0_GIF8 MDMA_GISR0_GIF8_Msk
17517#define MDMA_GISR0_GIF9_Pos (9U)
17518#define MDMA_GISR0_GIF9_Msk (0x1UL << MDMA_GISR0_GIF9_Pos)
17519#define MDMA_GISR0_GIF9 MDMA_GISR0_GIF9_Msk
17520#define MDMA_GISR0_GIF10_Pos (10U)
17521#define MDMA_GISR0_GIF10_Msk (0x1UL << MDMA_GISR0_GIF10_Pos)
17522#define MDMA_GISR0_GIF10 MDMA_GISR0_GIF10_Msk
17523#define MDMA_GISR0_GIF11_Pos (11U)
17524#define MDMA_GISR0_GIF11_Msk (0x1UL << MDMA_GISR0_GIF11_Pos)
17525#define MDMA_GISR0_GIF11 MDMA_GISR0_GIF11_Msk
17526#define MDMA_GISR0_GIF12_Pos (12U)
17527#define MDMA_GISR0_GIF12_Msk (0x1UL << MDMA_GISR0_GIF12_Pos)
17528#define MDMA_GISR0_GIF12 MDMA_GISR0_GIF12_Msk
17529#define MDMA_GISR0_GIF13_Pos (13U)
17530#define MDMA_GISR0_GIF13_Msk (0x1UL << MDMA_GISR0_GIF13_Pos)
17531#define MDMA_GISR0_GIF13 MDMA_GISR0_GIF13_Msk
17532#define MDMA_GISR0_GIF14_Pos (14U)
17533#define MDMA_GISR0_GIF14_Msk (0x1UL << MDMA_GISR0_GIF14_Pos)
17534#define MDMA_GISR0_GIF14 MDMA_GISR0_GIF14_Msk
17535#define MDMA_GISR0_GIF15_Pos (15U)
17536#define MDMA_GISR0_GIF15_Msk (0x1UL << MDMA_GISR0_GIF15_Pos)
17537#define MDMA_GISR0_GIF15 MDMA_GISR0_GIF15_Msk
17539/******************** Bit definition for MDMA_CxISR register ****************/
17540#define MDMA_CISR_TEIF_Pos (0U)
17541#define MDMA_CISR_TEIF_Msk (0x1UL << MDMA_CISR_TEIF_Pos)
17542#define MDMA_CISR_TEIF MDMA_CISR_TEIF_Msk
17543#define MDMA_CISR_CTCIF_Pos (1U)
17544#define MDMA_CISR_CTCIF_Msk (0x1UL << MDMA_CISR_CTCIF_Pos)
17545#define MDMA_CISR_CTCIF MDMA_CISR_CTCIF_Msk
17546#define MDMA_CISR_BRTIF_Pos (2U)
17547#define MDMA_CISR_BRTIF_Msk (0x1UL << MDMA_CISR_BRTIF_Pos)
17548#define MDMA_CISR_BRTIF MDMA_CISR_BRTIF_Msk
17549#define MDMA_CISR_BTIF_Pos (3U)
17550#define MDMA_CISR_BTIF_Msk (0x1UL << MDMA_CISR_BTIF_Pos)
17551#define MDMA_CISR_BTIF MDMA_CISR_BTIF_Msk
17552#define MDMA_CISR_TCIF_Pos (4U)
17553#define MDMA_CISR_TCIF_Msk (0x1UL << MDMA_CISR_TCIF_Pos)
17554#define MDMA_CISR_TCIF MDMA_CISR_TCIF_Msk
17555#define MDMA_CISR_CRQA_Pos (16U)
17556#define MDMA_CISR_CRQA_Msk (0x1UL << MDMA_CISR_CRQA_Pos)
17557#define MDMA_CISR_CRQA MDMA_CISR_CRQA_Msk
17559/******************** Bit definition for MDMA_CxIFCR register ****************/
17560#define MDMA_CIFCR_CTEIF_Pos (0U)
17561#define MDMA_CIFCR_CTEIF_Msk (0x1UL << MDMA_CIFCR_CTEIF_Pos)
17562#define MDMA_CIFCR_CTEIF MDMA_CIFCR_CTEIF_Msk
17563#define MDMA_CIFCR_CCTCIF_Pos (1U)
17564#define MDMA_CIFCR_CCTCIF_Msk (0x1UL << MDMA_CIFCR_CCTCIF_Pos)
17565#define MDMA_CIFCR_CCTCIF MDMA_CIFCR_CCTCIF_Msk
17566#define MDMA_CIFCR_CBRTIF_Pos (2U)
17567#define MDMA_CIFCR_CBRTIF_Msk (0x1UL << MDMA_CIFCR_CBRTIF_Pos)
17568#define MDMA_CIFCR_CBRTIF MDMA_CIFCR_CBRTIF_Msk
17569#define MDMA_CIFCR_CBTIF_Pos (3U)
17570#define MDMA_CIFCR_CBTIF_Msk (0x1UL << MDMA_CIFCR_CBTIF_Pos)
17571#define MDMA_CIFCR_CBTIF MDMA_CIFCR_CBTIF_Msk
17572#define MDMA_CIFCR_CLTCIF_Pos (4U)
17573#define MDMA_CIFCR_CLTCIF_Msk (0x1UL << MDMA_CIFCR_CLTCIF_Pos)
17574#define MDMA_CIFCR_CLTCIF MDMA_CIFCR_CLTCIF_Msk
17576/******************** Bit definition for MDMA_CxESR register ****************/
17577#define MDMA_CESR_TEA_Pos (0U)
17578#define MDMA_CESR_TEA_Msk (0x7FUL << MDMA_CESR_TEA_Pos)
17579#define MDMA_CESR_TEA MDMA_CESR_TEA_Msk
17580#define MDMA_CESR_TED_Pos (7U)
17581#define MDMA_CESR_TED_Msk (0x1UL << MDMA_CESR_TED_Pos)
17582#define MDMA_CESR_TED MDMA_CESR_TED_Msk
17583#define MDMA_CESR_TELD_Pos (8U)
17584#define MDMA_CESR_TELD_Msk (0x1UL << MDMA_CESR_TELD_Pos)
17585#define MDMA_CESR_TELD MDMA_CESR_TELD_Msk
17586#define MDMA_CESR_TEMD_Pos (9U)
17587#define MDMA_CESR_TEMD_Msk (0x1UL << MDMA_CESR_TEMD_Pos)
17588#define MDMA_CESR_TEMD MDMA_CESR_TEMD_Msk
17589#define MDMA_CESR_ASE_Pos (10U)
17590#define MDMA_CESR_ASE_Msk (0x1UL << MDMA_CESR_ASE_Pos)
17591#define MDMA_CESR_ASE MDMA_CESR_ASE_Msk
17592#define MDMA_CESR_BSE_Pos (11U)
17593#define MDMA_CESR_BSE_Msk (0x1UL << MDMA_CESR_BSE_Pos)
17594#define MDMA_CESR_BSE MDMA_CESR_BSE_Msk
17596/******************** Bit definition for MDMA_CxCR register ****************/
17597#define MDMA_CCR_EN_Pos (0U)
17598#define MDMA_CCR_EN_Msk (0x1UL << MDMA_CCR_EN_Pos)
17599#define MDMA_CCR_EN MDMA_CCR_EN_Msk
17600#define MDMA_CCR_TEIE_Pos (1U)
17601#define MDMA_CCR_TEIE_Msk (0x1UL << MDMA_CCR_TEIE_Pos)
17602#define MDMA_CCR_TEIE MDMA_CCR_TEIE_Msk
17603#define MDMA_CCR_CTCIE_Pos (2U)
17604#define MDMA_CCR_CTCIE_Msk (0x1UL << MDMA_CCR_CTCIE_Pos)
17605#define MDMA_CCR_CTCIE MDMA_CCR_CTCIE_Msk
17606#define MDMA_CCR_BRTIE_Pos (3U)
17607#define MDMA_CCR_BRTIE_Msk (0x1UL << MDMA_CCR_BRTIE_Pos)
17608#define MDMA_CCR_BRTIE MDMA_CCR_BRTIE_Msk
17609#define MDMA_CCR_BTIE_Pos (4U)
17610#define MDMA_CCR_BTIE_Msk (0x1UL << MDMA_CCR_BTIE_Pos)
17611#define MDMA_CCR_BTIE MDMA_CCR_BTIE_Msk
17612#define MDMA_CCR_TCIE_Pos (5U)
17613#define MDMA_CCR_TCIE_Msk (0x1UL << MDMA_CCR_TCIE_Pos)
17614#define MDMA_CCR_TCIE MDMA_CCR_TCIE_Msk
17615#define MDMA_CCR_PL_Pos (6U)
17616#define MDMA_CCR_PL_Msk (0x3UL << MDMA_CCR_PL_Pos)
17617#define MDMA_CCR_PL MDMA_CCR_PL_Msk
17618#define MDMA_CCR_PL_0 (0x1UL << MDMA_CCR_PL_Pos)
17619#define MDMA_CCR_PL_1 (0x2UL << MDMA_CCR_PL_Pos)
17620#define MDMA_CCR_BEX_Pos (12U)
17621#define MDMA_CCR_BEX_Msk (0x1UL << MDMA_CCR_BEX_Pos)
17622#define MDMA_CCR_BEX MDMA_CCR_BEX_Msk
17623#define MDMA_CCR_HEX_Pos (13U)
17624#define MDMA_CCR_HEX_Msk (0x1UL << MDMA_CCR_HEX_Pos)
17625#define MDMA_CCR_HEX MDMA_CCR_HEX_Msk
17626#define MDMA_CCR_WEX_Pos (14U)
17627#define MDMA_CCR_WEX_Msk (0x1UL << MDMA_CCR_WEX_Pos)
17628#define MDMA_CCR_WEX MDMA_CCR_WEX_Msk
17629#define MDMA_CCR_SWRQ_Pos (16U)
17630#define MDMA_CCR_SWRQ_Msk (0x1UL << MDMA_CCR_SWRQ_Pos)
17631#define MDMA_CCR_SWRQ MDMA_CCR_SWRQ_Msk
17633/******************** Bit definition for MDMA_CxTCR register ****************/
17634#define MDMA_CTCR_SINC_Pos (0U)
17635#define MDMA_CTCR_SINC_Msk (0x3UL << MDMA_CTCR_SINC_Pos)
17636#define MDMA_CTCR_SINC MDMA_CTCR_SINC_Msk
17637#define MDMA_CTCR_SINC_0 (0x1UL << MDMA_CTCR_SINC_Pos)
17638#define MDMA_CTCR_SINC_1 (0x2UL << MDMA_CTCR_SINC_Pos)
17639#define MDMA_CTCR_DINC_Pos (2U)
17640#define MDMA_CTCR_DINC_Msk (0x3UL << MDMA_CTCR_DINC_Pos)
17641#define MDMA_CTCR_DINC MDMA_CTCR_DINC_Msk
17642#define MDMA_CTCR_DINC_0 (0x1UL << MDMA_CTCR_DINC_Pos)
17643#define MDMA_CTCR_DINC_1 (0x2UL << MDMA_CTCR_DINC_Pos)
17644#define MDMA_CTCR_SSIZE_Pos (4U)
17645#define MDMA_CTCR_SSIZE_Msk (0x3UL << MDMA_CTCR_SSIZE_Pos)
17646#define MDMA_CTCR_SSIZE MDMA_CTCR_SSIZE_Msk
17647#define MDMA_CTCR_SSIZE_0 (0x1UL << MDMA_CTCR_SSIZE_Pos)
17648#define MDMA_CTCR_SSIZE_1 (0x2UL << MDMA_CTCR_SSIZE_Pos)
17649#define MDMA_CTCR_DSIZE_Pos (6U)
17650#define MDMA_CTCR_DSIZE_Msk (0x3UL << MDMA_CTCR_DSIZE_Pos)
17651#define MDMA_CTCR_DSIZE MDMA_CTCR_DSIZE_Msk
17652#define MDMA_CTCR_DSIZE_0 (0x1UL << MDMA_CTCR_DSIZE_Pos)
17653#define MDMA_CTCR_DSIZE_1 (0x2UL << MDMA_CTCR_DSIZE_Pos)
17654#define MDMA_CTCR_SINCOS_Pos (8U)
17655#define MDMA_CTCR_SINCOS_Msk (0x3UL << MDMA_CTCR_SINCOS_Pos)
17656#define MDMA_CTCR_SINCOS MDMA_CTCR_SINCOS_Msk
17657#define MDMA_CTCR_SINCOS_0 (0x1UL << MDMA_CTCR_SINCOS_Pos)
17658#define MDMA_CTCR_SINCOS_1 (0x2UL << MDMA_CTCR_SINCOS_Pos)
17659#define MDMA_CTCR_DINCOS_Pos (10U)
17660#define MDMA_CTCR_DINCOS_Msk (0x3UL << MDMA_CTCR_DINCOS_Pos)
17661#define MDMA_CTCR_DINCOS MDMA_CTCR_DINCOS_Msk
17662#define MDMA_CTCR_DINCOS_0 (0x1UL << MDMA_CTCR_DINCOS_Pos)
17663#define MDMA_CTCR_DINCOS_1 (0x2UL << MDMA_CTCR_DINCOS_Pos)
17664#define MDMA_CTCR_SBURST_Pos (12U)
17665#define MDMA_CTCR_SBURST_Msk (0x7UL << MDMA_CTCR_SBURST_Pos)
17666#define MDMA_CTCR_SBURST MDMA_CTCR_SBURST_Msk
17667#define MDMA_CTCR_SBURST_0 (0x1UL << MDMA_CTCR_SBURST_Pos)
17668#define MDMA_CTCR_SBURST_1 (0x2UL << MDMA_CTCR_SBURST_Pos)
17669#define MDMA_CTCR_SBURST_2 (0x4UL << MDMA_CTCR_SBURST_Pos)
17670#define MDMA_CTCR_DBURST_Pos (15U)
17671#define MDMA_CTCR_DBURST_Msk (0x7UL << MDMA_CTCR_DBURST_Pos)
17672#define MDMA_CTCR_DBURST MDMA_CTCR_DBURST_Msk
17673#define MDMA_CTCR_DBURST_0 (0x1UL << MDMA_CTCR_DBURST_Pos)
17674#define MDMA_CTCR_DBURST_1 (0x2UL << MDMA_CTCR_DBURST_Pos)
17675#define MDMA_CTCR_DBURST_2 (0x4UL << MDMA_CTCR_DBURST_Pos)
17676#define MDMA_CTCR_TLEN_Pos (18U)
17677#define MDMA_CTCR_TLEN_Msk (0x7FUL << MDMA_CTCR_TLEN_Pos)
17678#define MDMA_CTCR_TLEN MDMA_CTCR_TLEN_Msk
17679#define MDMA_CTCR_PKE_Pos (25U)
17680#define MDMA_CTCR_PKE_Msk (0x1UL << MDMA_CTCR_PKE_Pos)
17681#define MDMA_CTCR_PKE MDMA_CTCR_PKE_Msk
17682#define MDMA_CTCR_PAM_Pos (26U)
17683#define MDMA_CTCR_PAM_Msk (0x3UL << MDMA_CTCR_PAM_Pos)
17684#define MDMA_CTCR_PAM MDMA_CTCR_PAM_Msk
17685#define MDMA_CTCR_PAM_0 (0x1UL << MDMA_CTCR_PAM_Pos)
17686#define MDMA_CTCR_PAM_1 (0x2UL << MDMA_CTCR_PAM_Pos)
17687#define MDMA_CTCR_TRGM_Pos (28U)
17688#define MDMA_CTCR_TRGM_Msk (0x3UL << MDMA_CTCR_TRGM_Pos)
17689#define MDMA_CTCR_TRGM MDMA_CTCR_TRGM_Msk
17690#define MDMA_CTCR_TRGM_0 (0x1UL << MDMA_CTCR_TRGM_Pos)
17691#define MDMA_CTCR_TRGM_1 (0x2UL << MDMA_CTCR_TRGM_Pos)
17692#define MDMA_CTCR_SWRM_Pos (30U)
17693#define MDMA_CTCR_SWRM_Msk (0x1UL << MDMA_CTCR_SWRM_Pos)
17694#define MDMA_CTCR_SWRM MDMA_CTCR_SWRM_Msk
17695#define MDMA_CTCR_BWM_Pos (31U)
17696#define MDMA_CTCR_BWM_Msk (0x1UL << MDMA_CTCR_BWM_Pos)
17697#define MDMA_CTCR_BWM MDMA_CTCR_BWM_Msk
17699/******************** Bit definition for MDMA_CxBNDTR register ****************/
17700#define MDMA_CBNDTR_BNDT_Pos (0U)
17701#define MDMA_CBNDTR_BNDT_Msk (0x1FFFFUL << MDMA_CBNDTR_BNDT_Pos)
17702#define MDMA_CBNDTR_BNDT MDMA_CBNDTR_BNDT_Msk
17703#define MDMA_CBNDTR_BRSUM_Pos (18U)
17704#define MDMA_CBNDTR_BRSUM_Msk (0x1UL << MDMA_CBNDTR_BRSUM_Pos)
17705#define MDMA_CBNDTR_BRSUM MDMA_CBNDTR_BRSUM_Msk
17706#define MDMA_CBNDTR_BRDUM_Pos (19U)
17707#define MDMA_CBNDTR_BRDUM_Msk (0x1UL << MDMA_CBNDTR_BRDUM_Pos)
17708#define MDMA_CBNDTR_BRDUM MDMA_CBNDTR_BRDUM_Msk
17709#define MDMA_CBNDTR_BRC_Pos (20U)
17710#define MDMA_CBNDTR_BRC_Msk (0xFFFUL << MDMA_CBNDTR_BRC_Pos)
17711#define MDMA_CBNDTR_BRC MDMA_CBNDTR_BRC_Msk
17713/******************** Bit definition for MDMA_CxSAR register ****************/
17714#define MDMA_CSAR_SAR_Pos (0U)
17715#define MDMA_CSAR_SAR_Msk (0xFFFFFFFFUL << MDMA_CSAR_SAR_Pos)
17716#define MDMA_CSAR_SAR MDMA_CSAR_SAR_Msk
17718/******************** Bit definition for MDMA_CxDAR register ****************/
17719#define MDMA_CDAR_DAR_Pos (0U)
17720#define MDMA_CDAR_DAR_Msk (0xFFFFFFFFUL << MDMA_CDAR_DAR_Pos)
17721#define MDMA_CDAR_DAR MDMA_CDAR_DAR_Msk
17723/******************** Bit definition for MDMA_CxBRUR ************************/
17724#define MDMA_CBRUR_SUV_Pos (0U)
17725#define MDMA_CBRUR_SUV_Msk (0xFFFFUL << MDMA_CBRUR_SUV_Pos)
17726#define MDMA_CBRUR_SUV MDMA_CBRUR_SUV_Msk
17727#define MDMA_CBRUR_DUV_Pos (16U)
17728#define MDMA_CBRUR_DUV_Msk (0xFFFFUL << MDMA_CBRUR_DUV_Pos)
17729#define MDMA_CBRUR_DUV MDMA_CBRUR_DUV_Msk
17731/******************** Bit definition for MDMA_CxLAR *************************/
17732#define MDMA_CLAR_LAR_Pos (0U)
17733#define MDMA_CLAR_LAR_Msk (0xFFFFFFFFUL << MDMA_CLAR_LAR_Pos)
17734#define MDMA_CLAR_LAR MDMA_CLAR_LAR_Msk
17736/******************** Bit definition for MDMA_CxTBR) ************************/
17737#define MDMA_CTBR_TSEL_Pos (0U)
17738#define MDMA_CTBR_TSEL_Msk (0xFFUL << MDMA_CTBR_TSEL_Pos)
17739#define MDMA_CTBR_TSEL MDMA_CTBR_TSEL_Msk
17740#define MDMA_CTBR_SBUS_Pos (16U)
17741#define MDMA_CTBR_SBUS_Msk (0x1UL << MDMA_CTBR_SBUS_Pos)
17742#define MDMA_CTBR_SBUS MDMA_CTBR_SBUS_Msk
17743#define MDMA_CTBR_DBUS_Pos (17U)
17744#define MDMA_CTBR_DBUS_Msk (0x1UL << MDMA_CTBR_DBUS_Pos)
17745#define MDMA_CTBR_DBUS MDMA_CTBR_DBUS_Msk
17747/******************** Bit definition for MDMA_CxMAR) ************************/
17748#define MDMA_CMAR_MAR_Pos (0U)
17749#define MDMA_CMAR_MAR_Msk (0xFFFFFFFFUL << MDMA_CMAR_MAR_Pos)
17750#define MDMA_CMAR_MAR MDMA_CMAR_MAR_Msk
17752/******************** Bit definition for MDMA_CxMDR) ************************/
17753#define MDMA_CMDR_MDR_Pos (0U)
17754#define MDMA_CMDR_MDR_Msk (0xFFFFFFFFUL << MDMA_CMDR_MDR_Pos)
17755#define MDMA_CMDR_MDR MDMA_CMDR_MDR_Msk
17757/******************************************************************************/
17758/* */
17759/* Operational Amplifier (OPAMP) */
17760/* */
17761/******************************************************************************/
17762/********************* Bit definition for OPAMPx_CSR register ***************/
17763#define OPAMP_CSR_OPAMPxEN_Pos (0U)
17764#define OPAMP_CSR_OPAMPxEN_Msk (0x1UL << OPAMP_CSR_OPAMPxEN_Pos)
17765#define OPAMP_CSR_OPAMPxEN OPAMP_CSR_OPAMPxEN_Msk
17766#define OPAMP_CSR_FORCEVP_Pos (1U)
17767#define OPAMP_CSR_FORCEVP_Msk (0x1UL << OPAMP_CSR_FORCEVP_Pos)
17768#define OPAMP_CSR_FORCEVP OPAMP_CSR_FORCEVP_Msk
17770#define OPAMP_CSR_VPSEL_Pos (2U)
17771#define OPAMP_CSR_VPSEL_Msk (0x3UL << OPAMP_CSR_VPSEL_Pos)
17772#define OPAMP_CSR_VPSEL OPAMP_CSR_VPSEL_Msk
17773#define OPAMP_CSR_VPSEL_0 (0x1UL << OPAMP_CSR_VPSEL_Pos)
17774#define OPAMP_CSR_VPSEL_1 (0x2UL << OPAMP_CSR_VPSEL_Pos)
17776#define OPAMP_CSR_VMSEL_Pos (5U)
17777#define OPAMP_CSR_VMSEL_Msk (0x3UL << OPAMP_CSR_VMSEL_Pos)
17778#define OPAMP_CSR_VMSEL OPAMP_CSR_VMSEL_Msk
17779#define OPAMP_CSR_VMSEL_0 (0x1UL << OPAMP_CSR_VMSEL_Pos)
17780#define OPAMP_CSR_VMSEL_1 (0x2UL << OPAMP_CSR_VMSEL_Pos)
17782#define OPAMP_CSR_OPAHSM_Pos (8U)
17783#define OPAMP_CSR_OPAHSM_Msk (0x1UL << OPAMP_CSR_OPAHSM_Pos)
17784#define OPAMP_CSR_OPAHSM OPAMP_CSR_OPAHSM_Msk
17785#define OPAMP_CSR_CALON_Pos (11U)
17786#define OPAMP_CSR_CALON_Msk (0x1UL << OPAMP_CSR_CALON_Pos)
17787#define OPAMP_CSR_CALON OPAMP_CSR_CALON_Msk
17789#define OPAMP_CSR_CALSEL_Pos (12U)
17790#define OPAMP_CSR_CALSEL_Msk (0x3UL << OPAMP_CSR_CALSEL_Pos)
17791#define OPAMP_CSR_CALSEL OPAMP_CSR_CALSEL_Msk
17792#define OPAMP_CSR_CALSEL_0 (0x1UL << OPAMP_CSR_CALSEL_Pos)
17793#define OPAMP_CSR_CALSEL_1 (0x2UL << OPAMP_CSR_CALSEL_Pos)
17795#define OPAMP_CSR_PGGAIN_Pos (14U)
17796#define OPAMP_CSR_PGGAIN_Msk (0xFUL << OPAMP_CSR_PGGAIN_Pos)
17797#define OPAMP_CSR_PGGAIN OPAMP_CSR_PGGAIN_Msk
17798#define OPAMP_CSR_PGGAIN_0 (0x1UL << OPAMP_CSR_PGGAIN_Pos)
17799#define OPAMP_CSR_PGGAIN_1 (0x2UL << OPAMP_CSR_PGGAIN_Pos)
17800#define OPAMP_CSR_PGGAIN_2 (0x4UL << OPAMP_CSR_PGGAIN_Pos)
17801#define OPAMP_CSR_PGGAIN_3 (0x8UL << OPAMP_CSR_PGGAIN_Pos)
17803#define OPAMP_CSR_USERTRIM_Pos (18U)
17804#define OPAMP_CSR_USERTRIM_Msk (0x1UL << OPAMP_CSR_USERTRIM_Pos)
17805#define OPAMP_CSR_USERTRIM OPAMP_CSR_USERTRIM_Msk
17806#define OPAMP_CSR_TSTREF_Pos (29U)
17807#define OPAMP_CSR_TSTREF_Msk (0x1UL << OPAMP_CSR_TSTREF_Pos)
17808#define OPAMP_CSR_TSTREF OPAMP_CSR_TSTREF_Msk
17809#define OPAMP_CSR_CALOUT_Pos (30U)
17810#define OPAMP_CSR_CALOUT_Msk (0x1UL << OPAMP_CSR_CALOUT_Pos)
17811#define OPAMP_CSR_CALOUT OPAMP_CSR_CALOUT_Msk
17813/********************* Bit definition for OPAMP1_CSR register ***************/
17814#define OPAMP1_CSR_OPAEN_Pos (0U)
17815#define OPAMP1_CSR_OPAEN_Msk (0x1UL << OPAMP1_CSR_OPAEN_Pos)
17816#define OPAMP1_CSR_OPAEN OPAMP1_CSR_OPAEN_Msk
17817#define OPAMP1_CSR_FORCEVP_Pos (1U)
17818#define OPAMP1_CSR_FORCEVP_Msk (0x1UL << OPAMP1_CSR_FORCEVP_Pos)
17819#define OPAMP1_CSR_FORCEVP OPAMP1_CSR_FORCEVP_Msk
17821#define OPAMP1_CSR_VPSEL_Pos (2U)
17822#define OPAMP1_CSR_VPSEL_Msk (0x3UL << OPAMP1_CSR_VPSEL_Pos)
17823#define OPAMP1_CSR_VPSEL OPAMP1_CSR_VPSEL_Msk
17824#define OPAMP1_CSR_VPSEL_0 (0x1UL << OPAMP1_CSR_VPSEL_Pos)
17825#define OPAMP1_CSR_VPSEL_1 (0x2UL << OPAMP1_CSR_VPSEL_Pos)
17827#define OPAMP1_CSR_VMSEL_Pos (5U)
17828#define OPAMP1_CSR_VMSEL_Msk (0x3UL << OPAMP1_CSR_VMSEL_Pos)
17829#define OPAMP1_CSR_VMSEL OPAMP1_CSR_VMSEL_Msk
17830#define OPAMP1_CSR_VMSEL_0 (0x1UL << OPAMP1_CSR_VMSEL_Pos)
17831#define OPAMP1_CSR_VMSEL_1 (0x2UL << OPAMP1_CSR_VMSEL_Pos)
17833#define OPAMP1_CSR_OPAHSM_Pos (8U)
17834#define OPAMP1_CSR_OPAHSM_Msk (0x1UL << OPAMP1_CSR_OPAHSM_Pos)
17835#define OPAMP1_CSR_OPAHSM OPAMP1_CSR_OPAHSM_Msk
17836#define OPAMP1_CSR_CALON_Pos (11U)
17837#define OPAMP1_CSR_CALON_Msk (0x1UL << OPAMP1_CSR_CALON_Pos)
17838#define OPAMP1_CSR_CALON OPAMP1_CSR_CALON_Msk
17840#define OPAMP1_CSR_CALSEL_Pos (12U)
17841#define OPAMP1_CSR_CALSEL_Msk (0x3UL << OPAMP1_CSR_CALSEL_Pos)
17842#define OPAMP1_CSR_CALSEL OPAMP1_CSR_CALSEL_Msk
17843#define OPAMP1_CSR_CALSEL_0 (0x1UL << OPAMP1_CSR_CALSEL_Pos)
17844#define OPAMP1_CSR_CALSEL_1 (0x2UL << OPAMP1_CSR_CALSEL_Pos)
17846#define OPAMP1_CSR_PGGAIN_Pos (14U)
17847#define OPAMP1_CSR_PGGAIN_Msk (0xFUL << OPAMP1_CSR_PGGAIN_Pos)
17848#define OPAMP1_CSR_PGGAIN OPAMP1_CSR_PGGAIN_Msk
17849#define OPAMP1_CSR_PGGAIN_0 (0x1UL << OPAMP1_CSR_PGGAIN_Pos)
17850#define OPAMP1_CSR_PGGAIN_1 (0x2UL << OPAMP1_CSR_PGGAIN_Pos)
17851#define OPAMP1_CSR_PGGAIN_2 (0x4UL << OPAMP1_CSR_PGGAIN_Pos)
17852#define OPAMP1_CSR_PGGAIN_3 (0x8UL << OPAMP1_CSR_PGGAIN_Pos)
17854#define OPAMP1_CSR_USERTRIM_Pos (18U)
17855#define OPAMP1_CSR_USERTRIM_Msk (0x1UL << OPAMP1_CSR_USERTRIM_Pos)
17856#define OPAMP1_CSR_USERTRIM OPAMP1_CSR_USERTRIM_Msk
17857#define OPAMP1_CSR_TSTREF_Pos (29U)
17858#define OPAMP1_CSR_TSTREF_Msk (0x1UL << OPAMP1_CSR_TSTREF_Pos)
17859#define OPAMP1_CSR_TSTREF OPAMP1_CSR_TSTREF_Msk
17860#define OPAMP1_CSR_CALOUT_Pos (30U)
17861#define OPAMP1_CSR_CALOUT_Msk (0x1UL << OPAMP1_CSR_CALOUT_Pos)
17862#define OPAMP1_CSR_CALOUT OPAMP1_CSR_CALOUT_Msk
17864/********************* Bit definition for OPAMP2_CSR register ***************/
17865#define OPAMP2_CSR_OPAEN_Pos (0U)
17866#define OPAMP2_CSR_OPAEN_Msk (0x1UL << OPAMP2_CSR_OPAEN_Pos)
17867#define OPAMP2_CSR_OPAEN OPAMP2_CSR_OPAEN_Msk
17868#define OPAMP2_CSR_FORCEVP_Pos (1U)
17869#define OPAMP2_CSR_FORCEVP_Msk (0x1UL << OPAMP2_CSR_FORCEVP_Pos)
17870#define OPAMP2_CSR_FORCEVP OPAMP2_CSR_FORCEVP_Msk
17872#define OPAMP2_CSR_VPSEL_Pos (2U)
17873#define OPAMP2_CSR_VPSEL_Msk (0x3UL << OPAMP2_CSR_VPSEL_Pos)
17874#define OPAMP2_CSR_VPSEL OPAMP2_CSR_VPSEL_Msk
17875#define OPAMP2_CSR_VPSEL_0 (0x1UL << OPAMP2_CSR_VPSEL_Pos)
17876#define OPAMP2_CSR_VPSEL_1 (0x2UL << OPAMP2_CSR_VPSEL_Pos)
17878#define OPAMP2_CSR_VMSEL_Pos (5U)
17879#define OPAMP2_CSR_VMSEL_Msk (0x3UL << OPAMP2_CSR_VMSEL_Pos)
17880#define OPAMP2_CSR_VMSEL OPAMP2_CSR_VMSEL_Msk
17881#define OPAMP2_CSR_VMSEL_0 (0x1UL << OPAMP2_CSR_VMSEL_Pos)
17882#define OPAMP2_CSR_VMSEL_1 (0x2UL << OPAMP2_CSR_VMSEL_Pos)
17884#define OPAMP2_CSR_OPAHSM_Pos (8U)
17885#define OPAMP2_CSR_OPAHSM_Msk (0x1UL << OPAMP2_CSR_OPAHSM_Pos)
17886#define OPAMP2_CSR_OPAHSM OPAMP2_CSR_OPAHSM_Msk
17887#define OPAMP2_CSR_CALON_Pos (11U)
17888#define OPAMP2_CSR_CALON_Msk (0x1UL << OPAMP2_CSR_CALON_Pos)
17889#define OPAMP2_CSR_CALON OPAMP2_CSR_CALON_Msk
17891#define OPAMP2_CSR_CALSEL_Pos (12U)
17892#define OPAMP2_CSR_CALSEL_Msk (0x3UL << OPAMP2_CSR_CALSEL_Pos)
17893#define OPAMP2_CSR_CALSEL OPAMP2_CSR_CALSEL_Msk
17894#define OPAMP2_CSR_CALSEL_0 (0x1UL << OPAMP2_CSR_CALSEL_Pos)
17895#define OPAMP2_CSR_CALSEL_1 (0x2UL << OPAMP2_CSR_CALSEL_Pos)
17897#define OPAMP2_CSR_PGGAIN_Pos (14U)
17898#define OPAMP2_CSR_PGGAIN_Msk (0xFUL << OPAMP2_CSR_PGGAIN_Pos)
17899#define OPAMP2_CSR_PGGAIN OPAMP2_CSR_PGGAIN_Msk
17900#define OPAMP2_CSR_PGGAIN_0 (0x1UL << OPAMP2_CSR_PGGAIN_Pos)
17901#define OPAMP2_CSR_PGGAIN_1 (0x2UL << OPAMP2_CSR_PGGAIN_Pos)
17902#define OPAMP2_CSR_PGGAIN_2 (0x4UL << OPAMP2_CSR_PGGAIN_Pos)
17903#define OPAMP2_CSR_PGGAIN_3 (0x8UL << OPAMP2_CSR_PGGAIN_Pos)
17905#define OPAMP2_CSR_USERTRIM_Pos (18U)
17906#define OPAMP2_CSR_USERTRIM_Msk (0x1UL << OPAMP2_CSR_USERTRIM_Pos)
17907#define OPAMP2_CSR_USERTRIM OPAMP2_CSR_USERTRIM_Msk
17908#define OPAMP2_CSR_TSTREF_Pos (29U)
17909#define OPAMP2_CSR_TSTREF_Msk (0x1UL << OPAMP2_CSR_TSTREF_Pos)
17910#define OPAMP2_CSR_TSTREF OPAMP2_CSR_TSTREF_Msk
17911#define OPAMP2_CSR_CALOUT_Pos (30U)
17912#define OPAMP2_CSR_CALOUT_Msk (0x1UL << OPAMP2_CSR_CALOUT_Pos)
17913#define OPAMP2_CSR_CALOUT OPAMP2_CSR_CALOUT_Msk
17915/******************* Bit definition for OPAMP_OTR register ******************/
17916#define OPAMP_OTR_TRIMOFFSETN_Pos (0U)
17917#define OPAMP_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP_OTR_TRIMOFFSETN_Pos)
17918#define OPAMP_OTR_TRIMOFFSETN OPAMP_OTR_TRIMOFFSETN_Msk
17919#define OPAMP_OTR_TRIMOFFSETP_Pos (8U)
17920#define OPAMP_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP_OTR_TRIMOFFSETP_Pos)
17921#define OPAMP_OTR_TRIMOFFSETP OPAMP_OTR_TRIMOFFSETP_Msk
17923/******************* Bit definition for OPAMP1_OTR register ******************/
17924#define OPAMP1_OTR_TRIMOFFSETN_Pos (0U)
17925#define OPAMP1_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP1_OTR_TRIMOFFSETN_Pos)
17926#define OPAMP1_OTR_TRIMOFFSETN OPAMP1_OTR_TRIMOFFSETN_Msk
17927#define OPAMP1_OTR_TRIMOFFSETP_Pos (8U)
17928#define OPAMP1_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP1_OTR_TRIMOFFSETP_Pos)
17929#define OPAMP1_OTR_TRIMOFFSETP OPAMP1_OTR_TRIMOFFSETP_Msk
17931/******************* Bit definition for OPAMP2_OTR register ******************/
17932#define OPAMP2_OTR_TRIMOFFSETN_Pos (0U)
17933#define OPAMP2_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP2_OTR_TRIMOFFSETN_Pos)
17934#define OPAMP2_OTR_TRIMOFFSETN OPAMP2_OTR_TRIMOFFSETN_Msk
17935#define OPAMP2_OTR_TRIMOFFSETP_Pos (8U)
17936#define OPAMP2_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP2_OTR_TRIMOFFSETP_Pos)
17937#define OPAMP2_OTR_TRIMOFFSETP OPAMP2_OTR_TRIMOFFSETP_Msk
17939/******************* Bit definition for OPAMP_HSOTR register ****************/
17940#define OPAMP_HSOTR_TRIMHSOFFSETN_Pos (0U)
17941#define OPAMP_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETN_Pos)
17942#define OPAMP_HSOTR_TRIMHSOFFSETN OPAMP_HSOTR_TRIMHSOFFSETN_Msk
17943#define OPAMP_HSOTR_TRIMHSOFFSETP_Pos (8U)
17944#define OPAMP_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETP_Pos)
17945#define OPAMP_HSOTR_TRIMHSOFFSETP OPAMP_HSOTR_TRIMHSOFFSETP_Msk
17947/******************* Bit definition for OPAMP1_HSOTR register ****************/
17948#define OPAMP1_HSOTR_TRIMHSOFFSETN_Pos (0U)
17949#define OPAMP1_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETN_Pos)
17950#define OPAMP1_HSOTR_TRIMHSOFFSETN OPAMP1_HSOTR_TRIMHSOFFSETN_Msk
17951#define OPAMP1_HSOTR_TRIMHSOFFSETP_Pos (8U)
17952#define OPAMP1_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETP_Pos)
17953#define OPAMP1_HSOTR_TRIMHSOFFSETP OPAMP1_HSOTR_TRIMHSOFFSETP_Msk
17955/******************* Bit definition for OPAMP2_HSOTR register ****************/
17956#define OPAMP2_HSOTR_TRIMHSOFFSETN_Pos (0U)
17957#define OPAMP2_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETN_Pos)
17958#define OPAMP2_HSOTR_TRIMHSOFFSETN OPAMP2_HSOTR_TRIMHSOFFSETN_Msk
17959#define OPAMP2_HSOTR_TRIMHSOFFSETP_Pos (8U)
17960#define OPAMP2_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETP_Pos)
17961#define OPAMP2_HSOTR_TRIMHSOFFSETP OPAMP2_HSOTR_TRIMHSOFFSETP_Msk
17963/******************************************************************************/
17964/* */
17965/* Power Control */
17966/* */
17967/******************************************************************************/
17968/************************* NUMBER OF POWER DOMAINS **************************/
17969#define POWER_DOMAINS_NUMBER 3U
17971/******************** Bit definition for PWR_CR1 register *******************/
17972#define PWR_CR1_ALS_Pos (17U)
17973#define PWR_CR1_ALS_Msk (0x3UL << PWR_CR1_ALS_Pos)
17974#define PWR_CR1_ALS PWR_CR1_ALS_Msk
17975#define PWR_CR1_ALS_0 (0x1UL << PWR_CR1_ALS_Pos)
17976#define PWR_CR1_ALS_1 (0x2UL << PWR_CR1_ALS_Pos)
17977#define PWR_CR1_AVDEN_Pos (16U)
17978#define PWR_CR1_AVDEN_Msk (0x1UL << PWR_CR1_AVDEN_Pos)
17979#define PWR_CR1_AVDEN PWR_CR1_AVDEN_Msk
17980#define PWR_CR1_SVOS_Pos (14U)
17981#define PWR_CR1_SVOS_Msk (0x3UL << PWR_CR1_SVOS_Pos)
17982#define PWR_CR1_SVOS PWR_CR1_SVOS_Msk
17983#define PWR_CR1_SVOS_0 (0x1UL << PWR_CR1_SVOS_Pos)
17984#define PWR_CR1_SVOS_1 (0x2UL << PWR_CR1_SVOS_Pos)
17985#define PWR_CR1_FLPS_Pos (9U)
17986#define PWR_CR1_FLPS_Msk (0x1UL << PWR_CR1_FLPS_Pos)
17987#define PWR_CR1_FLPS PWR_CR1_FLPS_Msk
17988#define PWR_CR1_DBP_Pos (8U)
17989#define PWR_CR1_DBP_Msk (0x1UL << PWR_CR1_DBP_Pos)
17990#define PWR_CR1_DBP PWR_CR1_DBP_Msk
17991#define PWR_CR1_PLS_Pos (5U)
17992#define PWR_CR1_PLS_Msk (0x7UL << PWR_CR1_PLS_Pos)
17993#define PWR_CR1_PLS PWR_CR1_PLS_Msk
17994#define PWR_CR1_PLS_0 (0x1UL << PWR_CR1_PLS_Pos)
17995#define PWR_CR1_PLS_1 (0x2UL << PWR_CR1_PLS_Pos)
17996#define PWR_CR1_PLS_2 (0x4UL << PWR_CR1_PLS_Pos)
17997#define PWR_CR1_PVDEN_Pos (4U)
17998#define PWR_CR1_PVDEN_Msk (0x1UL << PWR_CR1_PVDEN_Pos)
17999#define PWR_CR1_PVDEN PWR_CR1_PVDEN_Msk
18000#define PWR_CR1_LPDS_Pos (0U)
18001#define PWR_CR1_LPDS_Msk (0x1UL << PWR_CR1_LPDS_Pos)
18002#define PWR_CR1_LPDS PWR_CR1_LPDS_Msk
18005#define PWR_CR1_PLS_LEV0 (0UL)
18006#define PWR_CR1_PLS_LEV1_Pos (5U)
18007#define PWR_CR1_PLS_LEV1_Msk (0x1UL << PWR_CR1_PLS_LEV1_Pos)
18008#define PWR_CR1_PLS_LEV1 PWR_CR1_PLS_LEV1_Msk
18009#define PWR_CR1_PLS_LEV2_Pos (6U)
18010#define PWR_CR1_PLS_LEV2_Msk (0x1UL << PWR_CR1_PLS_LEV2_Pos)
18011#define PWR_CR1_PLS_LEV2 PWR_CR1_PLS_LEV2_Msk
18012#define PWR_CR1_PLS_LEV3_Pos (5U)
18013#define PWR_CR1_PLS_LEV3_Msk (0x3UL << PWR_CR1_PLS_LEV3_Pos)
18014#define PWR_CR1_PLS_LEV3 PWR_CR1_PLS_LEV3_Msk
18015#define PWR_CR1_PLS_LEV4_Pos (7U)
18016#define PWR_CR1_PLS_LEV4_Msk (0x1UL << PWR_CR1_PLS_LEV4_Pos)
18017#define PWR_CR1_PLS_LEV4 PWR_CR1_PLS_LEV4_Msk
18018#define PWR_CR1_PLS_LEV5_Pos (5U)
18019#define PWR_CR1_PLS_LEV5_Msk (0x5UL << PWR_CR1_PLS_LEV5_Pos)
18020#define PWR_CR1_PLS_LEV5 PWR_CR1_PLS_LEV5_Msk
18021#define PWR_CR1_PLS_LEV6_Pos (6U)
18022#define PWR_CR1_PLS_LEV6_Msk (0x3UL << PWR_CR1_PLS_LEV6_Pos)
18023#define PWR_CR1_PLS_LEV6 PWR_CR1_PLS_LEV6_Msk
18024#define PWR_CR1_PLS_LEV7_Pos (5U)
18025#define PWR_CR1_PLS_LEV7_Msk (0x7UL << PWR_CR1_PLS_LEV7_Pos)
18026#define PWR_CR1_PLS_LEV7 PWR_CR1_PLS_LEV7_Msk
18029#define PWR_CR1_ALS_LEV0 (0UL)
18030#define PWR_CR1_ALS_LEV1_Pos (17U)
18031#define PWR_CR1_ALS_LEV1_Msk (0x1UL << PWR_CR1_ALS_LEV1_Pos)
18032#define PWR_CR1_ALS_LEV1 PWR_CR1_ALS_LEV1_Msk
18033#define PWR_CR1_ALS_LEV2_Pos (18U)
18034#define PWR_CR1_ALS_LEV2_Msk (0x1UL << PWR_CR1_ALS_LEV2_Pos)
18035#define PWR_CR1_ALS_LEV2 PWR_CR1_ALS_LEV2_Msk
18036#define PWR_CR1_ALS_LEV3_Pos (17U)
18037#define PWR_CR1_ALS_LEV3_Msk (0x3UL << PWR_CR1_ALS_LEV3_Pos)
18038#define PWR_CR1_ALS_LEV3 PWR_CR1_ALS_LEV3_Msk
18040/******************** Bit definition for PWR_CSR1 register ******************/
18041#define PWR_CSR1_AVDO_Pos (16U)
18042#define PWR_CSR1_AVDO_Msk (0x1UL << PWR_CSR1_AVDO_Pos)
18043#define PWR_CSR1_AVDO PWR_CSR1_AVDO_Msk
18044#define PWR_CSR1_ACTVOS_Pos (14U)
18045#define PWR_CSR1_ACTVOS_Msk (0x3UL << PWR_CSR1_ACTVOS_Pos)
18046#define PWR_CSR1_ACTVOS PWR_CSR1_ACTVOS_Msk
18047#define PWR_CSR1_ACTVOS_0 (0x1UL << PWR_CSR1_ACTVOS_Pos)
18048#define PWR_CSR1_ACTVOS_1 (0x2UL << PWR_CSR1_ACTVOS_Pos)
18049#define PWR_CSR1_ACTVOSRDY_Pos (13U)
18050#define PWR_CSR1_ACTVOSRDY_Msk (0x1UL << PWR_CSR1_ACTVOSRDY_Pos)
18051#define PWR_CSR1_ACTVOSRDY PWR_CSR1_ACTVOSRDY_Msk
18052#define PWR_CSR1_PVDO_Pos (4U)
18053#define PWR_CSR1_PVDO_Msk (0x1UL << PWR_CSR1_PVDO_Pos)
18054#define PWR_CSR1_PVDO PWR_CSR1_PVDO_Msk
18056/******************** Bit definition for PWR_CR2 register *******************/
18057#define PWR_CR2_TEMPH_Pos (23U)
18058#define PWR_CR2_TEMPH_Msk (0x1UL << PWR_CR2_TEMPH_Pos)
18059#define PWR_CR2_TEMPH PWR_CR2_TEMPH_Msk
18060#define PWR_CR2_TEMPL_Pos (22U)
18061#define PWR_CR2_TEMPL_Msk (0x1UL << PWR_CR2_TEMPL_Pos)
18062#define PWR_CR2_TEMPL PWR_CR2_TEMPL_Msk
18063#define PWR_CR2_VBATH_Pos (21U)
18064#define PWR_CR2_VBATH_Msk (0x1UL << PWR_CR2_VBATH_Pos)
18065#define PWR_CR2_VBATH PWR_CR2_VBATH_Msk
18066#define PWR_CR2_VBATL_Pos (20U)
18067#define PWR_CR2_VBATL_Msk (0x1UL << PWR_CR2_VBATL_Pos)
18068#define PWR_CR2_VBATL PWR_CR2_VBATL_Msk
18069#define PWR_CR2_BRRDY_Pos (16U)
18070#define PWR_CR2_BRRDY_Msk (0x1UL << PWR_CR2_BRRDY_Pos)
18071#define PWR_CR2_BRRDY PWR_CR2_BRRDY_Msk
18072#define PWR_CR2_MONEN_Pos (4U)
18073#define PWR_CR2_MONEN_Msk (0x1UL << PWR_CR2_MONEN_Pos)
18074#define PWR_CR2_MONEN PWR_CR2_MONEN_Msk
18075#define PWR_CR2_BREN_Pos (0U)
18076#define PWR_CR2_BREN_Msk (0x1UL << PWR_CR2_BREN_Pos)
18077#define PWR_CR2_BREN PWR_CR2_BREN_Msk
18079/******************** Bit definition for PWR_CR3 register *******************/
18080#define PWR_CR3_USB33RDY_Pos (26U)
18081#define PWR_CR3_USB33RDY_Msk (0x1UL << PWR_CR3_USB33RDY_Pos)
18082#define PWR_CR3_USB33RDY PWR_CR3_USB33RDY_Msk
18083#define PWR_CR3_USBREGEN_Pos (25U)
18084#define PWR_CR3_USBREGEN_Msk (0x1UL << PWR_CR3_USBREGEN_Pos)
18085#define PWR_CR3_USBREGEN PWR_CR3_USBREGEN_Msk
18086#define PWR_CR3_USB33DEN_Pos (24U)
18087#define PWR_CR3_USB33DEN_Msk (0x1UL << PWR_CR3_USB33DEN_Pos)
18088#define PWR_CR3_USB33DEN PWR_CR3_USB33DEN_Msk
18089#define PWR_CR3_SMPSEXTRDY_Pos (16U)
18090#define PWR_CR3_SMPSEXTRDY_Msk (0x1UL << PWR_CR3_SMPSEXTRDY_Pos)
18091#define PWR_CR3_SMPSEXTRDY PWR_CR3_SMPSEXTRDY_Msk
18092#define PWR_CR3_VBRS_Pos (9U)
18093#define PWR_CR3_VBRS_Msk (0x1UL << PWR_CR3_VBRS_Pos)
18094#define PWR_CR3_VBRS PWR_CR3_VBRS_Msk
18095#define PWR_CR3_VBE_Pos (8U)
18096#define PWR_CR3_VBE_Msk (0x1UL << PWR_CR3_VBE_Pos)
18097#define PWR_CR3_VBE PWR_CR3_VBE_Msk
18098#define PWR_CR3_SMPSLEVEL_Pos (4U)
18099#define PWR_CR3_SMPSLEVEL_Msk (0x3UL << PWR_CR3_SMPSLEVEL_Pos)
18100#define PWR_CR3_SMPSLEVEL PWR_CR3_SMPSLEVEL_Msk
18101#define PWR_CR3_SMPSLEVEL_0 (0x1UL << PWR_CR3_SMPSLEVEL_Pos)
18102#define PWR_CR3_SMPSLEVEL_1 (0x2UL << PWR_CR3_SMPSLEVEL_Pos)
18103#define PWR_CR3_SMPSEXTHP_Pos (3U)
18104#define PWR_CR3_SMPSEXTHP_Msk (0x1UL << PWR_CR3_SMPSEXTHP_Pos)
18105#define PWR_CR3_SMPSEXTHP PWR_CR3_SMPSEXTHP_Msk
18106#define PWR_CR3_SMPSEN_Pos (2U)
18107#define PWR_CR3_SMPSEN_Msk (0x1UL << PWR_CR3_SMPSEN_Pos)
18108#define PWR_CR3_SMPSEN PWR_CR3_SMPSEN_Msk
18109#define PWR_CR3_LDOEN_Pos (1U)
18110#define PWR_CR3_LDOEN_Msk (0x1UL << PWR_CR3_LDOEN_Pos)
18111#define PWR_CR3_LDOEN PWR_CR3_LDOEN_Msk
18112#define PWR_CR3_BYPASS_Pos (0U)
18113#define PWR_CR3_BYPASS_Msk (0x1UL << PWR_CR3_BYPASS_Pos)
18114#define PWR_CR3_BYPASS PWR_CR3_BYPASS_Msk
18116/******************** Bit definition for PWR_CPUCR register *****************/
18117#define PWR_CPUCR_RUN_D3_Pos (11U)
18118#define PWR_CPUCR_RUN_D3_Msk (0x1UL << PWR_CPUCR_RUN_D3_Pos)
18119#define PWR_CPUCR_RUN_D3 PWR_CPUCR_RUN_D3_Msk
18120#define PWR_CPUCR_HOLD2_Pos (10U)
18121#define PWR_CPUCR_HOLD2_Msk (0x1UL << PWR_CPUCR_HOLD2_Pos)
18122#define PWR_CPUCR_HOLD2 PWR_CPUCR_HOLD2_Msk
18123#define PWR_CPUCR_CSSF_Pos (9U)
18124#define PWR_CPUCR_CSSF_Msk (0x1UL << PWR_CPUCR_CSSF_Pos)
18125#define PWR_CPUCR_CSSF PWR_CPUCR_CSSF_Msk
18126#define PWR_CPUCR_SBF_D2_Pos (8U)
18127#define PWR_CPUCR_SBF_D2_Msk (0x1UL << PWR_CPUCR_SBF_D2_Pos)
18128#define PWR_CPUCR_SBF_D2 PWR_CPUCR_SBF_D2_Msk
18129#define PWR_CPUCR_SBF_D1_Pos (7U)
18130#define PWR_CPUCR_SBF_D1_Msk (0x1UL << PWR_CPUCR_SBF_D1_Pos)
18131#define PWR_CPUCR_SBF_D1 PWR_CPUCR_SBF_D1_Msk
18132#define PWR_CPUCR_SBF_Pos (6U)
18133#define PWR_CPUCR_SBF_Msk (0x1UL << PWR_CPUCR_SBF_Pos)
18134#define PWR_CPUCR_SBF PWR_CPUCR_SBF_Msk
18135#define PWR_CPUCR_STOPF_Pos (5U)
18136#define PWR_CPUCR_STOPF_Msk (0x1UL << PWR_CPUCR_STOPF_Pos)
18137#define PWR_CPUCR_STOPF PWR_CPUCR_STOPF_Msk
18138#define PWR_CPUCR_HOLD2F_Pos (4U)
18139#define PWR_CPUCR_HOLD2F_Msk (0x1UL << PWR_CPUCR_HOLD2F_Pos)
18140#define PWR_CPUCR_HOLD2F PWR_CPUCR_HOLD2F_Msk
18141#define PWR_CPUCR_PDDS_D3_Pos (2U)
18142#define PWR_CPUCR_PDDS_D3_Msk (0x1UL << PWR_CPUCR_PDDS_D3_Pos)
18143#define PWR_CPUCR_PDDS_D3 PWR_CPUCR_PDDS_D3_Msk
18144#define PWR_CPUCR_PDDS_D2_Pos (1U)
18145#define PWR_CPUCR_PDDS_D2_Msk (0x1UL << PWR_CPUCR_PDDS_D2_Pos)
18146#define PWR_CPUCR_PDDS_D2 PWR_CPUCR_PDDS_D2_Msk
18147#define PWR_CPUCR_PDDS_D1_Pos (0U)
18148#define PWR_CPUCR_PDDS_D1_Msk (0x1UL << PWR_CPUCR_PDDS_D1_Pos)
18149#define PWR_CPUCR_PDDS_D1 PWR_CPUCR_PDDS_D1_Msk
18151/******************** Bit definition for PWR_CPU2CR register ****************/
18152#define PWR_CPU2CR_RUN_D3_Pos (11U)
18153#define PWR_CPU2CR_RUN_D3_Msk (0x1UL << PWR_CPU2CR_RUN_D3_Pos)
18154#define PWR_CPU2CR_RUN_D3 PWR_CPU2CR_RUN_D3_Msk
18155#define PWR_CPU2CR_HOLD1_Pos (10U)
18156#define PWR_CPU2CR_HOLD1_Msk (0x1UL << PWR_CPU2CR_HOLD1_Pos)
18157#define PWR_CPU2CR_HOLD1 PWR_CPU2CR_HOLD1_Msk
18158#define PWR_CPU2CR_CSSF_Pos (9U)
18159#define PWR_CPU2CR_CSSF_Msk (0x1UL << PWR_CPU2CR_CSSF_Pos)
18160#define PWR_CPU2CR_CSSF PWR_CPU2CR_CSSF_Msk
18161#define PWR_CPU2CR_SBF_D2_Pos (8U)
18162#define PWR_CPU2CR_SBF_D2_Msk (0x1UL << PWR_CPU2CR_SBF_D2_Pos)
18163#define PWR_CPU2CR_SBF_D2 PWR_CPU2CR_SBF_D2_Msk
18164#define PWR_CPU2CR_SBF_D1_Pos (7U)
18165#define PWR_CPU2CR_SBF_D1_Msk (0x1UL << PWR_CPU2CR_SBF_D1_Pos)
18166#define PWR_CPU2CR_SBF_D1 PWR_CPU2CR_SBF_D1_Msk
18167#define PWR_CPU2CR_SBF_Pos (6U)
18168#define PWR_CPU2CR_SBF_Msk (0x1UL << PWR_CPU2CR_SBF_Pos)
18169#define PWR_CPU2CR_SBF PWR_CPU2CR_SBF_Msk
18170#define PWR_CPU2CR_STOPF_Pos (5U)
18171#define PWR_CPU2CR_STOPF_Msk (0x1UL << PWR_CPU2CR_STOPF_Pos)
18172#define PWR_CPU2CR_STOPF PWR_CPU2CR_STOPF_Msk
18173#define PWR_CPU2CR_HOLD1F_Pos (4U)
18174#define PWR_CPU2CR_HOLD1F_Msk (0x1UL << PWR_CPU2CR_HOLD1F_Pos)
18175#define PWR_CPU2CR_HOLD1F PWR_CPU2CR_HOLD1F_Msk
18176#define PWR_CPU2CR_PDDS_D3_Pos (2U)
18177#define PWR_CPU2CR_PDDS_D3_Msk (0x1UL << PWR_CPU2CR_PDDS_D3_Pos)
18178#define PWR_CPU2CR_PDDS_D3 PWR_CPU2CR_PDDS_D3_Msk
18179#define PWR_CPU2CR_PDDS_D2_Pos (1U)
18180#define PWR_CPU2CR_PDDS_D2_Msk (0x1UL << PWR_CPU2CR_PDDS_D2_Pos)
18181#define PWR_CPU2CR_PDDS_D2 PWR_CPU2CR_PDDS_D2_Msk
18182#define PWR_CPU2CR_PDDS_D1_Pos (0U)
18183#define PWR_CPU2CR_PDDS_D1_Msk (0x1UL << PWR_CPU2CR_PDDS_D1_Pos)
18184#define PWR_CPU2CR_PDDS_D1 PWR_CPU2CR_PDDS_D1_Msk
18187/******************** Bit definition for PWR_D3CR register ******************/
18188#define PWR_D3CR_VOS_Pos (14U)
18189#define PWR_D3CR_VOS_Msk (0x3UL << PWR_D3CR_VOS_Pos)
18190#define PWR_D3CR_VOS PWR_D3CR_VOS_Msk
18191#define PWR_D3CR_VOS_0 (0x1UL << PWR_D3CR_VOS_Pos)
18192#define PWR_D3CR_VOS_1 (0x2UL << PWR_D3CR_VOS_Pos)
18193#define PWR_D3CR_VOSRDY_Pos (13U)
18194#define PWR_D3CR_VOSRDY_Msk (0x1UL << PWR_D3CR_VOSRDY_Pos)
18195#define PWR_D3CR_VOSRDY PWR_D3CR_VOSRDY_Msk
18197/****************** Bit definition for PWR_WKUPCR register ******************/
18198#define PWR_WKUPCR_WKUPC6_Pos (5U)
18199#define PWR_WKUPCR_WKUPC6_Msk (0x1UL << PWR_WKUPCR_WKUPC6_Pos)
18200#define PWR_WKUPCR_WKUPC6 PWR_WKUPCR_WKUPC6_Msk
18201#define PWR_WKUPCR_WKUPC5_Pos (4U)
18202#define PWR_WKUPCR_WKUPC5_Msk (0x1UL << PWR_WKUPCR_WKUPC5_Pos)
18203#define PWR_WKUPCR_WKUPC5 PWR_WKUPCR_WKUPC5_Msk
18204#define PWR_WKUPCR_WKUPC4_Pos (3U)
18205#define PWR_WKUPCR_WKUPC4_Msk (0x1UL << PWR_WKUPCR_WKUPC4_Pos)
18206#define PWR_WKUPCR_WKUPC4 PWR_WKUPCR_WKUPC4_Msk
18207#define PWR_WKUPCR_WKUPC3_Pos (2U)
18208#define PWR_WKUPCR_WKUPC3_Msk (0x1UL << PWR_WKUPCR_WKUPC3_Pos)
18209#define PWR_WKUPCR_WKUPC3 PWR_WKUPCR_WKUPC3_Msk
18210#define PWR_WKUPCR_WKUPC2_Pos (1U)
18211#define PWR_WKUPCR_WKUPC2_Msk (0x1UL << PWR_WKUPCR_WKUPC2_Pos)
18212#define PWR_WKUPCR_WKUPC2 PWR_WKUPCR_WKUPC2_Msk
18213#define PWR_WKUPCR_WKUPC1_Pos (0U)
18214#define PWR_WKUPCR_WKUPC1_Msk (0x1UL << PWR_WKUPCR_WKUPC1_Pos)
18215#define PWR_WKUPCR_WKUPC1 PWR_WKUPCR_WKUPC1_Msk
18217/******************** Bit definition for PWR_WKUPFR register ****************/
18218#define PWR_WKUPFR_WKUPF6_Pos (5U)
18219#define PWR_WKUPFR_WKUPF6_Msk (0x1UL << PWR_WKUPFR_WKUPF6_Pos)
18220#define PWR_WKUPFR_WKUPF6 PWR_WKUPFR_WKUPF6_Msk
18221#define PWR_WKUPFR_WKUPF5_Pos (4U)
18222#define PWR_WKUPFR_WKUPF5_Msk (0x1UL << PWR_WKUPFR_WKUPF5_Pos)
18223#define PWR_WKUPFR_WKUPF5 PWR_WKUPFR_WKUPF5_Msk
18224#define PWR_WKUPFR_WKUPF4_Pos (3U)
18225#define PWR_WKUPFR_WKUPF4_Msk (0x1UL << PWR_WKUPFR_WKUPF4_Pos)
18226#define PWR_WKUPFR_WKUPF4 PWR_WKUPFR_WKUPF4_Msk
18227#define PWR_WKUPFR_WKUPF3_Pos (2U)
18228#define PWR_WKUPFR_WKUPF3_Msk (0x1UL << PWR_WKUPFR_WKUPF3_Pos)
18229#define PWR_WKUPFR_WKUPF3 PWR_WKUPFR_WKUPF3_Msk
18230#define PWR_WKUPFR_WKUPF2_Pos (1U)
18231#define PWR_WKUPFR_WKUPF2_Msk (0x1UL << PWR_WKUPFR_WKUPF2_Pos)
18232#define PWR_WKUPFR_WKUPF2 PWR_WKUPFR_WKUPF2_Msk
18233#define PWR_WKUPFR_WKUPF1_Pos (0U)
18234#define PWR_WKUPFR_WKUPF1_Msk (0x1UL << PWR_WKUPFR_WKUPF1_Pos)
18235#define PWR_WKUPFR_WKUPF1 PWR_WKUPFR_WKUPF1_Msk
18237/****************** Bit definition for PWR_WKUPEPR register *****************/
18238#define PWR_WKUPEPR_WKUPPUPD6_Pos (26U)
18239#define PWR_WKUPEPR_WKUPPUPD6_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
18240#define PWR_WKUPEPR_WKUPPUPD6 PWR_WKUPEPR_WKUPPUPD6_Msk
18241#define PWR_WKUPEPR_WKUPPUPD6_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
18242#define PWR_WKUPEPR_WKUPPUPD6_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
18243#define PWR_WKUPEPR_WKUPPUPD5_Pos (24U)
18244#define PWR_WKUPEPR_WKUPPUPD5_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
18245#define PWR_WKUPEPR_WKUPPUPD5 PWR_WKUPEPR_WKUPPUPD5_Msk
18246#define PWR_WKUPEPR_WKUPPUPD5_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
18247#define PWR_WKUPEPR_WKUPPUPD5_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
18248#define PWR_WKUPEPR_WKUPPUPD4_Pos (22U)
18249#define PWR_WKUPEPR_WKUPPUPD4_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
18250#define PWR_WKUPEPR_WKUPPUPD4 PWR_WKUPEPR_WKUPPUPD4_Msk
18251#define PWR_WKUPEPR_WKUPPUPD4_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
18252#define PWR_WKUPEPR_WKUPPUPD4_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
18253#define PWR_WKUPEPR_WKUPPUPD3_Pos (20U)
18254#define PWR_WKUPEPR_WKUPPUPD3_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
18255#define PWR_WKUPEPR_WKUPPUPD3 PWR_WKUPEPR_WKUPPUPD3_Msk
18256#define PWR_WKUPEPR_WKUPPUPD3_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
18257#define PWR_WKUPEPR_WKUPPUPD3_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
18258#define PWR_WKUPEPR_WKUPPUPD2_Pos (18U)
18259#define PWR_WKUPEPR_WKUPPUPD2_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
18260#define PWR_WKUPEPR_WKUPPUPD2 PWR_WKUPEPR_WKUPPUPD2_Msk
18261#define PWR_WKUPEPR_WKUPPUPD2_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
18262#define PWR_WKUPEPR_WKUPPUPD2_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
18263#define PWR_WKUPEPR_WKUPPUPD1_Pos (16U)
18264#define PWR_WKUPEPR_WKUPPUPD1_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
18265#define PWR_WKUPEPR_WKUPPUPD1 PWR_WKUPEPR_WKUPPUPD1_Msk
18266#define PWR_WKUPEPR_WKUPPUPD1_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
18267#define PWR_WKUPEPR_WKUPPUPD1_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
18268#define PWR_WKUPEPR_WKUPP6_Pos (13U)
18269#define PWR_WKUPEPR_WKUPP6_Msk (0x1UL << PWR_WKUPEPR_WKUPP6_Pos)
18270#define PWR_WKUPEPR_WKUPP6 PWR_WKUPEPR_WKUPP6_Msk
18271#define PWR_WKUPEPR_WKUPP5_Pos (12U)
18272#define PWR_WKUPEPR_WKUPP5_Msk (0x1UL << PWR_WKUPEPR_WKUPP5_Pos)
18273#define PWR_WKUPEPR_WKUPP5 PWR_WKUPEPR_WKUPP5_Msk
18274#define PWR_WKUPEPR_WKUPP4_Pos (11U)
18275#define PWR_WKUPEPR_WKUPP4_Msk (0x1UL << PWR_WKUPEPR_WKUPP4_Pos)
18276#define PWR_WKUPEPR_WKUPP4 PWR_WKUPEPR_WKUPP4_Msk
18277#define PWR_WKUPEPR_WKUPP3_Pos (10U)
18278#define PWR_WKUPEPR_WKUPP3_Msk (0x1UL << PWR_WKUPEPR_WKUPP3_Pos)
18279#define PWR_WKUPEPR_WKUPP3 PWR_WKUPEPR_WKUPP3_Msk
18280#define PWR_WKUPEPR_WKUPP2_Pos (9U)
18281#define PWR_WKUPEPR_WKUPP2_Msk (0x1UL << PWR_WKUPEPR_WKUPP2_Pos)
18282#define PWR_WKUPEPR_WKUPP2 PWR_WKUPEPR_WKUPP2_Msk
18283#define PWR_WKUPEPR_WKUPP1_Pos (8U)
18284#define PWR_WKUPEPR_WKUPP1_Msk (0x1UL << PWR_WKUPEPR_WKUPP1_Pos)
18285#define PWR_WKUPEPR_WKUPP1 PWR_WKUPEPR_WKUPP1_Msk
18286#define PWR_WKUPEPR_WKUPEN6_Pos (5U)
18287#define PWR_WKUPEPR_WKUPEN6_Msk (0x1UL << PWR_WKUPEPR_WKUPEN6_Pos)
18288#define PWR_WKUPEPR_WKUPEN6 PWR_WKUPEPR_WKUPEN6_Msk
18289#define PWR_WKUPEPR_WKUPEN5_Pos (4U)
18290#define PWR_WKUPEPR_WKUPEN5_Msk (0x1UL << PWR_WKUPEPR_WKUPEN5_Pos)
18291#define PWR_WKUPEPR_WKUPEN5 PWR_WKUPEPR_WKUPEN5_Msk
18292#define PWR_WKUPEPR_WKUPEN4_Pos (3U)
18293#define PWR_WKUPEPR_WKUPEN4_Msk (0x1UL << PWR_WKUPEPR_WKUPEN4_Pos)
18294#define PWR_WKUPEPR_WKUPEN4 PWR_WKUPEPR_WKUPEN4_Msk
18295#define PWR_WKUPEPR_WKUPEN3_Pos (2U)
18296#define PWR_WKUPEPR_WKUPEN3_Msk (0x1UL << PWR_WKUPEPR_WKUPEN3_Pos)
18297#define PWR_WKUPEPR_WKUPEN3 PWR_WKUPEPR_WKUPEN3_Msk
18298#define PWR_WKUPEPR_WKUPEN2_Pos (1U)
18299#define PWR_WKUPEPR_WKUPEN2_Msk (0x1UL << PWR_WKUPEPR_WKUPEN2_Pos)
18300#define PWR_WKUPEPR_WKUPEN2 PWR_WKUPEPR_WKUPEN2_Msk
18301#define PWR_WKUPEPR_WKUPEN1_Pos (0U)
18302#define PWR_WKUPEPR_WKUPEN1_Msk (0x1UL << PWR_WKUPEPR_WKUPEN1_Pos)
18303#define PWR_WKUPEPR_WKUPEN1 PWR_WKUPEPR_WKUPEN1_Msk
18304#define PWR_WKUPEPR_WKUPEN_Pos (0U)
18305#define PWR_WKUPEPR_WKUPEN_Msk (0x3FUL << PWR_WKUPEPR_WKUPEN_Pos)
18306#define PWR_WKUPEPR_WKUPEN PWR_WKUPEPR_WKUPEN_Msk
18308/******************************************************************************/
18309/* */
18310/* Reset and Clock Control */
18311/* */
18312/******************************************************************************/
18313/******************************* RCC VERSION ********************************/
18314#define RCC_VER_X
18315
18316/******************** Bit definition for RCC_CR register ********************/
18317#define RCC_CR_HSION_Pos (0U)
18318#define RCC_CR_HSION_Msk (0x1UL << RCC_CR_HSION_Pos)
18319#define RCC_CR_HSION RCC_CR_HSION_Msk
18320#define RCC_CR_HSIKERON_Pos (1U)
18321#define RCC_CR_HSIKERON_Msk (0x1UL << RCC_CR_HSIKERON_Pos)
18322#define RCC_CR_HSIKERON RCC_CR_HSIKERON_Msk
18323#define RCC_CR_HSIRDY_Pos (2U)
18324#define RCC_CR_HSIRDY_Msk (0x1UL << RCC_CR_HSIRDY_Pos)
18325#define RCC_CR_HSIRDY RCC_CR_HSIRDY_Msk
18326#define RCC_CR_HSIDIV_Pos (3U)
18327#define RCC_CR_HSIDIV_Msk (0x3UL << RCC_CR_HSIDIV_Pos)
18328#define RCC_CR_HSIDIV RCC_CR_HSIDIV_Msk
18329#define RCC_CR_HSIDIV_1 (0x0UL << RCC_CR_HSIDIV_Pos)
18330#define RCC_CR_HSIDIV_2 (0x1UL << RCC_CR_HSIDIV_Pos)
18331#define RCC_CR_HSIDIV_4 (0x2UL << RCC_CR_HSIDIV_Pos)
18332#define RCC_CR_HSIDIV_8 (0x3UL << RCC_CR_HSIDIV_Pos)
18334#define RCC_CR_HSIDIVF_Pos (5U)
18335#define RCC_CR_HSIDIVF_Msk (0x1UL << RCC_CR_HSIDIVF_Pos)
18336#define RCC_CR_HSIDIVF RCC_CR_HSIDIVF_Msk
18337#define RCC_CR_CSION_Pos (7U)
18338#define RCC_CR_CSION_Msk (0x1UL << RCC_CR_CSION_Pos)
18339#define RCC_CR_CSION RCC_CR_CSION_Msk
18340#define RCC_CR_CSIRDY_Pos (8U)
18341#define RCC_CR_CSIRDY_Msk (0x1UL << RCC_CR_CSIRDY_Pos)
18342#define RCC_CR_CSIRDY RCC_CR_CSIRDY_Msk
18343#define RCC_CR_CSIKERON_Pos (9U)
18344#define RCC_CR_CSIKERON_Msk (0x1UL << RCC_CR_CSIKERON_Pos)
18345#define RCC_CR_CSIKERON RCC_CR_CSIKERON_Msk
18346#define RCC_CR_HSI48ON_Pos (12U)
18347#define RCC_CR_HSI48ON_Msk (0x1UL << RCC_CR_HSI48ON_Pos)
18348#define RCC_CR_HSI48ON RCC_CR_HSI48ON_Msk
18349#define RCC_CR_HSI48RDY_Pos (13U)
18350#define RCC_CR_HSI48RDY_Msk (0x1UL << RCC_CR_HSI48RDY_Pos)
18351#define RCC_CR_HSI48RDY RCC_CR_HSI48RDY_Msk
18353#define RCC_CR_D1CKRDY_Pos (14U)
18354#define RCC_CR_D1CKRDY_Msk (0x1UL << RCC_CR_D1CKRDY_Pos)
18355#define RCC_CR_D1CKRDY RCC_CR_D1CKRDY_Msk
18356#define RCC_CR_D2CKRDY_Pos (15U)
18357#define RCC_CR_D2CKRDY_Msk (0x1UL << RCC_CR_D2CKRDY_Pos)
18358#define RCC_CR_D2CKRDY RCC_CR_D2CKRDY_Msk
18360#define RCC_CR_HSEON_Pos (16U)
18361#define RCC_CR_HSEON_Msk (0x1UL << RCC_CR_HSEON_Pos)
18362#define RCC_CR_HSEON RCC_CR_HSEON_Msk
18363#define RCC_CR_HSERDY_Pos (17U)
18364#define RCC_CR_HSERDY_Msk (0x1UL << RCC_CR_HSERDY_Pos)
18365#define RCC_CR_HSERDY RCC_CR_HSERDY_Msk
18366#define RCC_CR_HSEBYP_Pos (18U)
18367#define RCC_CR_HSEBYP_Msk (0x1UL << RCC_CR_HSEBYP_Pos)
18368#define RCC_CR_HSEBYP RCC_CR_HSEBYP_Msk
18369#define RCC_CR_CSSHSEON_Pos (19U)
18370#define RCC_CR_CSSHSEON_Msk (0x1UL << RCC_CR_CSSHSEON_Pos)
18371#define RCC_CR_CSSHSEON RCC_CR_CSSHSEON_Msk
18374#define RCC_CR_PLL1ON_Pos (24U)
18375#define RCC_CR_PLL1ON_Msk (0x1UL << RCC_CR_PLL1ON_Pos)
18376#define RCC_CR_PLL1ON RCC_CR_PLL1ON_Msk
18377#define RCC_CR_PLL1RDY_Pos (25U)
18378#define RCC_CR_PLL1RDY_Msk (0x1UL << RCC_CR_PLL1RDY_Pos)
18379#define RCC_CR_PLL1RDY RCC_CR_PLL1RDY_Msk
18380#define RCC_CR_PLL2ON_Pos (26U)
18381#define RCC_CR_PLL2ON_Msk (0x1UL << RCC_CR_PLL2ON_Pos)
18382#define RCC_CR_PLL2ON RCC_CR_PLL2ON_Msk
18383#define RCC_CR_PLL2RDY_Pos (27U)
18384#define RCC_CR_PLL2RDY_Msk (0x1UL << RCC_CR_PLL2RDY_Pos)
18385#define RCC_CR_PLL2RDY RCC_CR_PLL2RDY_Msk
18386#define RCC_CR_PLL3ON_Pos (28U)
18387#define RCC_CR_PLL3ON_Msk (0x1UL << RCC_CR_PLL3ON_Pos)
18388#define RCC_CR_PLL3ON RCC_CR_PLL3ON_Msk
18389#define RCC_CR_PLL3RDY_Pos (29U)
18390#define RCC_CR_PLL3RDY_Msk (0x1UL << RCC_CR_PLL3RDY_Pos)
18391#define RCC_CR_PLL3RDY RCC_CR_PLL3RDY_Msk
18393/*Legacy */
18394#define RCC_CR_PLLON_Pos (24U)
18395#define RCC_CR_PLLON_Msk (0x1UL << RCC_CR_PLLON_Pos)
18396#define RCC_CR_PLLON RCC_CR_PLLON_Msk
18397#define RCC_CR_PLLRDY_Pos (25U)
18398#define RCC_CR_PLLRDY_Msk (0x1UL << RCC_CR_PLLRDY_Pos)
18399#define RCC_CR_PLLRDY RCC_CR_PLLRDY_Msk
18401/******************** Bit definition for RCC_HSICFGR register ***************/
18403#define RCC_HSICFGR_HSICAL_Pos (0U)
18404#define RCC_HSICFGR_HSICAL_Msk (0xFFFUL << RCC_HSICFGR_HSICAL_Pos)
18405#define RCC_HSICFGR_HSICAL RCC_HSICFGR_HSICAL_Msk
18406#define RCC_HSICFGR_HSICAL_0 (0x001UL << RCC_HSICFGR_HSICAL_Pos)
18407#define RCC_HSICFGR_HSICAL_1 (0x002UL << RCC_HSICFGR_HSICAL_Pos)
18408#define RCC_HSICFGR_HSICAL_2 (0x004UL << RCC_HSICFGR_HSICAL_Pos)
18409#define RCC_HSICFGR_HSICAL_3 (0x008UL << RCC_HSICFGR_HSICAL_Pos)
18410#define RCC_HSICFGR_HSICAL_4 (0x010UL << RCC_HSICFGR_HSICAL_Pos)
18411#define RCC_HSICFGR_HSICAL_5 (0x020UL << RCC_HSICFGR_HSICAL_Pos)
18412#define RCC_HSICFGR_HSICAL_6 (0x040UL << RCC_HSICFGR_HSICAL_Pos)
18413#define RCC_HSICFGR_HSICAL_7 (0x080UL << RCC_HSICFGR_HSICAL_Pos)
18414#define RCC_HSICFGR_HSICAL_8 (0x100UL << RCC_HSICFGR_HSICAL_Pos)
18415#define RCC_HSICFGR_HSICAL_9 (0x200UL << RCC_HSICFGR_HSICAL_Pos)
18416#define RCC_HSICFGR_HSICAL_10 (0x400UL << RCC_HSICFGR_HSICAL_Pos)
18417#define RCC_HSICFGR_HSICAL_11 (0x800UL << RCC_HSICFGR_HSICAL_Pos)
18420#define RCC_HSICFGR_HSITRIM_Pos (24U)
18421#define RCC_HSICFGR_HSITRIM_Msk (0x7FUL << RCC_HSICFGR_HSITRIM_Pos)
18422#define RCC_HSICFGR_HSITRIM RCC_HSICFGR_HSITRIM_Msk
18423#define RCC_HSICFGR_HSITRIM_0 (0x01UL << RCC_HSICFGR_HSITRIM_Pos)
18424#define RCC_HSICFGR_HSITRIM_1 (0x02UL << RCC_HSICFGR_HSITRIM_Pos)
18425#define RCC_HSICFGR_HSITRIM_2 (0x04UL << RCC_HSICFGR_HSITRIM_Pos)
18426#define RCC_HSICFGR_HSITRIM_3 (0x08UL << RCC_HSICFGR_HSITRIM_Pos)
18427#define RCC_HSICFGR_HSITRIM_4 (0x10UL << RCC_HSICFGR_HSITRIM_Pos)
18428#define RCC_HSICFGR_HSITRIM_5 (0x20UL << RCC_HSICFGR_HSITRIM_Pos)
18429#define RCC_HSICFGR_HSITRIM_6 (0x40UL << RCC_HSICFGR_HSITRIM_Pos)
18432/******************** Bit definition for RCC_CRRCR register *****************/
18433
18435#define RCC_CRRCR_HSI48CAL_Pos (0U)
18436#define RCC_CRRCR_HSI48CAL_Msk (0x3FFUL << RCC_CRRCR_HSI48CAL_Pos)
18437#define RCC_CRRCR_HSI48CAL RCC_CRRCR_HSI48CAL_Msk
18438#define RCC_CRRCR_HSI48CAL_0 (0x001UL << RCC_CRRCR_HSI48CAL_Pos)
18439#define RCC_CRRCR_HSI48CAL_1 (0x002UL << RCC_CRRCR_HSI48CAL_Pos)
18440#define RCC_CRRCR_HSI48CAL_2 (0x004UL << RCC_CRRCR_HSI48CAL_Pos)
18441#define RCC_CRRCR_HSI48CAL_3 (0x008UL << RCC_CRRCR_HSI48CAL_Pos)
18442#define RCC_CRRCR_HSI48CAL_4 (0x010UL << RCC_CRRCR_HSI48CAL_Pos)
18443#define RCC_CRRCR_HSI48CAL_5 (0x020UL << RCC_CRRCR_HSI48CAL_Pos)
18444#define RCC_CRRCR_HSI48CAL_6 (0x040UL << RCC_CRRCR_HSI48CAL_Pos)
18445#define RCC_CRRCR_HSI48CAL_7 (0x080UL << RCC_CRRCR_HSI48CAL_Pos)
18446#define RCC_CRRCR_HSI48CAL_8 (0x100UL << RCC_CRRCR_HSI48CAL_Pos)
18447#define RCC_CRRCR_HSI48CAL_9 (0x200UL << RCC_CRRCR_HSI48CAL_Pos)
18450/******************** Bit definition for RCC_CSICFGR register *****************/
18452#define RCC_CSICFGR_CSICAL_Pos (0U)
18453#define RCC_CSICFGR_CSICAL_Msk (0xFFUL << RCC_CSICFGR_CSICAL_Pos)
18454#define RCC_CSICFGR_CSICAL RCC_CSICFGR_CSICAL_Msk
18455#define RCC_CSICFGR_CSICAL_0 (0x01UL << RCC_CSICFGR_CSICAL_Pos)
18456#define RCC_CSICFGR_CSICAL_1 (0x02UL << RCC_CSICFGR_CSICAL_Pos)
18457#define RCC_CSICFGR_CSICAL_2 (0x04UL << RCC_CSICFGR_CSICAL_Pos)
18458#define RCC_CSICFGR_CSICAL_3 (0x08UL << RCC_CSICFGR_CSICAL_Pos)
18459#define RCC_CSICFGR_CSICAL_4 (0x10UL << RCC_CSICFGR_CSICAL_Pos)
18460#define RCC_CSICFGR_CSICAL_5 (0x20UL << RCC_CSICFGR_CSICAL_Pos)
18461#define RCC_CSICFGR_CSICAL_6 (0x40UL << RCC_CSICFGR_CSICAL_Pos)
18462#define RCC_CSICFGR_CSICAL_7 (0x80UL << RCC_CSICFGR_CSICAL_Pos)
18465#define RCC_CSICFGR_CSITRIM_Pos (24U)
18466#define RCC_CSICFGR_CSITRIM_Msk (0x3FUL << RCC_CSICFGR_CSITRIM_Pos)
18467#define RCC_CSICFGR_CSITRIM RCC_CSICFGR_CSITRIM_Msk
18468#define RCC_CSICFGR_CSITRIM_0 (0x01UL << RCC_CSICFGR_CSITRIM_Pos)
18469#define RCC_CSICFGR_CSITRIM_1 (0x02UL << RCC_CSICFGR_CSITRIM_Pos)
18470#define RCC_CSICFGR_CSITRIM_2 (0x04UL << RCC_CSICFGR_CSITRIM_Pos)
18471#define RCC_CSICFGR_CSITRIM_3 (0x08UL << RCC_CSICFGR_CSITRIM_Pos)
18472#define RCC_CSICFGR_CSITRIM_4 (0x10UL << RCC_CSICFGR_CSITRIM_Pos)
18473#define RCC_CSICFGR_CSITRIM_5 (0x20UL << RCC_CSICFGR_CSITRIM_Pos)
18475/******************** Bit definition for RCC_CFGR register ******************/
18477#define RCC_CFGR_SW_Pos (0U)
18478#define RCC_CFGR_SW_Msk (0x7UL << RCC_CFGR_SW_Pos)
18479#define RCC_CFGR_SW RCC_CFGR_SW_Msk
18480#define RCC_CFGR_SW_0 (0x1UL << RCC_CFGR_SW_Pos)
18481#define RCC_CFGR_SW_1 (0x2UL << RCC_CFGR_SW_Pos)
18482#define RCC_CFGR_SW_2 (0x4UL << RCC_CFGR_SW_Pos)
18484#define RCC_CFGR_SW_HSI (0x00000000UL)
18485#define RCC_CFGR_SW_CSI (0x00000001UL)
18486#define RCC_CFGR_SW_HSE (0x00000002UL)
18487#define RCC_CFGR_SW_PLL1 (0x00000003UL)
18490#define RCC_CFGR_SWS_Pos (3U)
18491#define RCC_CFGR_SWS_Msk (0x7UL << RCC_CFGR_SWS_Pos)
18492#define RCC_CFGR_SWS RCC_CFGR_SWS_Msk
18493#define RCC_CFGR_SWS_0 (0x1UL << RCC_CFGR_SWS_Pos)
18494#define RCC_CFGR_SWS_1 (0x2UL << RCC_CFGR_SWS_Pos)
18495#define RCC_CFGR_SWS_2 (0x4UL << RCC_CFGR_SWS_Pos)
18497#define RCC_CFGR_SWS_HSI (0x00000000UL)
18498#define RCC_CFGR_SWS_CSI (0x00000008UL)
18499#define RCC_CFGR_SWS_HSE (0x00000010UL)
18500#define RCC_CFGR_SWS_PLL1 (0x00000018UL)
18502#define RCC_CFGR_STOPWUCK_Pos (6U)
18503#define RCC_CFGR_STOPWUCK_Msk (0x1UL << RCC_CFGR_STOPWUCK_Pos)
18504#define RCC_CFGR_STOPWUCK RCC_CFGR_STOPWUCK_Msk
18506#define RCC_CFGR_STOPKERWUCK_Pos (7U)
18507#define RCC_CFGR_STOPKERWUCK_Msk (0x1UL << RCC_CFGR_STOPKERWUCK_Pos)
18508#define RCC_CFGR_STOPKERWUCK RCC_CFGR_STOPKERWUCK_Msk
18511#define RCC_CFGR_RTCPRE_Pos (8U)
18512#define RCC_CFGR_RTCPRE_Msk (0x3FUL << RCC_CFGR_RTCPRE_Pos)
18513#define RCC_CFGR_RTCPRE RCC_CFGR_RTCPRE_Msk
18514#define RCC_CFGR_RTCPRE_0 (0x1UL << RCC_CFGR_RTCPRE_Pos)
18515#define RCC_CFGR_RTCPRE_1 (0x2UL << RCC_CFGR_RTCPRE_Pos)
18516#define RCC_CFGR_RTCPRE_2 (0x4UL << RCC_CFGR_RTCPRE_Pos)
18517#define RCC_CFGR_RTCPRE_3 (0x8UL << RCC_CFGR_RTCPRE_Pos)
18518#define RCC_CFGR_RTCPRE_4 (0x10UL << RCC_CFGR_RTCPRE_Pos)
18519#define RCC_CFGR_RTCPRE_5 (0x20UL << RCC_CFGR_RTCPRE_Pos)
18522#define RCC_CFGR_HRTIMSEL_Pos (14U)
18523#define RCC_CFGR_HRTIMSEL_Msk (0x1UL << RCC_CFGR_HRTIMSEL_Pos)
18524#define RCC_CFGR_HRTIMSEL RCC_CFGR_HRTIMSEL_Msk
18527#define RCC_CFGR_TIMPRE_Pos (15U)
18528#define RCC_CFGR_TIMPRE_Msk (0x1UL << RCC_CFGR_TIMPRE_Pos)
18529#define RCC_CFGR_TIMPRE RCC_CFGR_TIMPRE_Msk
18532#define RCC_CFGR_MCO1_Pos (22U)
18533#define RCC_CFGR_MCO1_Msk (0x7UL << RCC_CFGR_MCO1_Pos)
18534#define RCC_CFGR_MCO1 RCC_CFGR_MCO1_Msk
18535#define RCC_CFGR_MCO1_0 (0x1UL << RCC_CFGR_MCO1_Pos)
18536#define RCC_CFGR_MCO1_1 (0x2UL << RCC_CFGR_MCO1_Pos)
18537#define RCC_CFGR_MCO1_2 (0x4UL << RCC_CFGR_MCO1_Pos)
18539#define RCC_CFGR_MCO1PRE_Pos (18U)
18540#define RCC_CFGR_MCO1PRE_Msk (0xFUL << RCC_CFGR_MCO1PRE_Pos)
18541#define RCC_CFGR_MCO1PRE RCC_CFGR_MCO1PRE_Msk
18542#define RCC_CFGR_MCO1PRE_0 (0x1UL << RCC_CFGR_MCO1PRE_Pos)
18543#define RCC_CFGR_MCO1PRE_1 (0x2UL << RCC_CFGR_MCO1PRE_Pos)
18544#define RCC_CFGR_MCO1PRE_2 (0x4UL << RCC_CFGR_MCO1PRE_Pos)
18545#define RCC_CFGR_MCO1PRE_3 (0x8UL << RCC_CFGR_MCO1PRE_Pos)
18547#define RCC_CFGR_MCO2PRE_Pos (25U)
18548#define RCC_CFGR_MCO2PRE_Msk (0xFUL << RCC_CFGR_MCO2PRE_Pos)
18549#define RCC_CFGR_MCO2PRE RCC_CFGR_MCO2PRE_Msk
18550#define RCC_CFGR_MCO2PRE_0 (0x1UL << RCC_CFGR_MCO2PRE_Pos)
18551#define RCC_CFGR_MCO2PRE_1 (0x2UL << RCC_CFGR_MCO2PRE_Pos)
18552#define RCC_CFGR_MCO2PRE_2 (0x4UL << RCC_CFGR_MCO2PRE_Pos)
18553#define RCC_CFGR_MCO2PRE_3 (0x8UL << RCC_CFGR_MCO2PRE_Pos)
18555#define RCC_CFGR_MCO2_Pos (29U)
18556#define RCC_CFGR_MCO2_Msk (0x7UL << RCC_CFGR_MCO2_Pos)
18557#define RCC_CFGR_MCO2 RCC_CFGR_MCO2_Msk
18558#define RCC_CFGR_MCO2_0 (0x1UL << RCC_CFGR_MCO2_Pos)
18559#define RCC_CFGR_MCO2_1 (0x2UL << RCC_CFGR_MCO2_Pos)
18560#define RCC_CFGR_MCO2_2 (0x4UL << RCC_CFGR_MCO2_Pos)
18562/******************** Bit definition for RCC_D1CFGR register ******************/
18564#define RCC_D1CFGR_HPRE_Pos (0U)
18565#define RCC_D1CFGR_HPRE_Msk (0xFUL << RCC_D1CFGR_HPRE_Pos)
18566#define RCC_D1CFGR_HPRE RCC_D1CFGR_HPRE_Msk
18567#define RCC_D1CFGR_HPRE_0 (0x1UL << RCC_D1CFGR_HPRE_Pos)
18568#define RCC_D1CFGR_HPRE_1 (0x2UL << RCC_D1CFGR_HPRE_Pos)
18569#define RCC_D1CFGR_HPRE_2 (0x4UL << RCC_D1CFGR_HPRE_Pos)
18570#define RCC_D1CFGR_HPRE_3 (0x8UL << RCC_D1CFGR_HPRE_Pos)
18573#define RCC_D1CFGR_HPRE_DIV1 (0U)
18574#define RCC_D1CFGR_HPRE_DIV2_Pos (3U)
18575#define RCC_D1CFGR_HPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_HPRE_DIV2_Pos)
18576#define RCC_D1CFGR_HPRE_DIV2 RCC_D1CFGR_HPRE_DIV2_Msk
18577#define RCC_D1CFGR_HPRE_DIV4_Pos (0U)
18578#define RCC_D1CFGR_HPRE_DIV4_Msk (0x9UL << RCC_D1CFGR_HPRE_DIV4_Pos)
18579#define RCC_D1CFGR_HPRE_DIV4 RCC_D1CFGR_HPRE_DIV4_Msk
18580#define RCC_D1CFGR_HPRE_DIV8_Pos (1U)
18581#define RCC_D1CFGR_HPRE_DIV8_Msk (0x5UL << RCC_D1CFGR_HPRE_DIV8_Pos)
18582#define RCC_D1CFGR_HPRE_DIV8 RCC_D1CFGR_HPRE_DIV8_Msk
18583#define RCC_D1CFGR_HPRE_DIV16_Pos (0U)
18584#define RCC_D1CFGR_HPRE_DIV16_Msk (0xBUL << RCC_D1CFGR_HPRE_DIV16_Pos)
18585#define RCC_D1CFGR_HPRE_DIV16 RCC_D1CFGR_HPRE_DIV16_Msk
18586#define RCC_D1CFGR_HPRE_DIV64_Pos (2U)
18587#define RCC_D1CFGR_HPRE_DIV64_Msk (0x3UL << RCC_D1CFGR_HPRE_DIV64_Pos)
18588#define RCC_D1CFGR_HPRE_DIV64 RCC_D1CFGR_HPRE_DIV64_Msk
18589#define RCC_D1CFGR_HPRE_DIV128_Pos (0U)
18590#define RCC_D1CFGR_HPRE_DIV128_Msk (0xDUL << RCC_D1CFGR_HPRE_DIV128_Pos)
18591#define RCC_D1CFGR_HPRE_DIV128 RCC_D1CFGR_HPRE_DIV128_Msk
18592#define RCC_D1CFGR_HPRE_DIV256_Pos (1U)
18593#define RCC_D1CFGR_HPRE_DIV256_Msk (0x7UL << RCC_D1CFGR_HPRE_DIV256_Pos)
18594#define RCC_D1CFGR_HPRE_DIV256 RCC_D1CFGR_HPRE_DIV256_Msk
18595#define RCC_D1CFGR_HPRE_DIV512_Pos (0U)
18596#define RCC_D1CFGR_HPRE_DIV512_Msk (0xFUL << RCC_D1CFGR_HPRE_DIV512_Pos)
18597#define RCC_D1CFGR_HPRE_DIV512 RCC_D1CFGR_HPRE_DIV512_Msk
18600#define RCC_D1CFGR_D1PPRE_Pos (4U)
18601#define RCC_D1CFGR_D1PPRE_Msk (0x7UL << RCC_D1CFGR_D1PPRE_Pos)
18602#define RCC_D1CFGR_D1PPRE RCC_D1CFGR_D1PPRE_Msk
18603#define RCC_D1CFGR_D1PPRE_0 (0x1UL << RCC_D1CFGR_D1PPRE_Pos)
18604#define RCC_D1CFGR_D1PPRE_1 (0x2UL << RCC_D1CFGR_D1PPRE_Pos)
18605#define RCC_D1CFGR_D1PPRE_2 (0x4UL << RCC_D1CFGR_D1PPRE_Pos)
18607#define RCC_D1CFGR_D1PPRE_DIV1 (0U)
18608#define RCC_D1CFGR_D1PPRE_DIV2_Pos (6U)
18609#define RCC_D1CFGR_D1PPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_D1PPRE_DIV2_Pos)
18610#define RCC_D1CFGR_D1PPRE_DIV2 RCC_D1CFGR_D1PPRE_DIV2_Msk
18611#define RCC_D1CFGR_D1PPRE_DIV4_Pos (4U)
18612#define RCC_D1CFGR_D1PPRE_DIV4_Msk (0x5UL << RCC_D1CFGR_D1PPRE_DIV4_Pos)
18613#define RCC_D1CFGR_D1PPRE_DIV4 RCC_D1CFGR_D1PPRE_DIV4_Msk
18614#define RCC_D1CFGR_D1PPRE_DIV8_Pos (5U)
18615#define RCC_D1CFGR_D1PPRE_DIV8_Msk (0x3UL << RCC_D1CFGR_D1PPRE_DIV8_Pos)
18616#define RCC_D1CFGR_D1PPRE_DIV8 RCC_D1CFGR_D1PPRE_DIV8_Msk
18617#define RCC_D1CFGR_D1PPRE_DIV16_Pos (4U)
18618#define RCC_D1CFGR_D1PPRE_DIV16_Msk (0x7UL << RCC_D1CFGR_D1PPRE_DIV16_Pos)
18619#define RCC_D1CFGR_D1PPRE_DIV16 RCC_D1CFGR_D1PPRE_DIV16_Msk
18621#define RCC_D1CFGR_D1CPRE_Pos (8U)
18622#define RCC_D1CFGR_D1CPRE_Msk (0xFUL << RCC_D1CFGR_D1CPRE_Pos)
18623#define RCC_D1CFGR_D1CPRE RCC_D1CFGR_D1CPRE_Msk
18624#define RCC_D1CFGR_D1CPRE_0 (0x1UL << RCC_D1CFGR_D1CPRE_Pos)
18625#define RCC_D1CFGR_D1CPRE_1 (0x2UL << RCC_D1CFGR_D1CPRE_Pos)
18626#define RCC_D1CFGR_D1CPRE_2 (0x4UL << RCC_D1CFGR_D1CPRE_Pos)
18627#define RCC_D1CFGR_D1CPRE_3 (0x8UL << RCC_D1CFGR_D1CPRE_Pos)
18629#define RCC_D1CFGR_D1CPRE_DIV1 (0U)
18630#define RCC_D1CFGR_D1CPRE_DIV2_Pos (11U)
18631#define RCC_D1CFGR_D1CPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_D1CPRE_DIV2_Pos)
18632#define RCC_D1CFGR_D1CPRE_DIV2 RCC_D1CFGR_D1CPRE_DIV2_Msk
18633#define RCC_D1CFGR_D1CPRE_DIV4_Pos (8U)
18634#define RCC_D1CFGR_D1CPRE_DIV4_Msk (0x9UL << RCC_D1CFGR_D1CPRE_DIV4_Pos)
18635#define RCC_D1CFGR_D1CPRE_DIV4 RCC_D1CFGR_D1CPRE_DIV4_Msk
18636#define RCC_D1CFGR_D1CPRE_DIV8_Pos (9U)
18637#define RCC_D1CFGR_D1CPRE_DIV8_Msk (0x5UL << RCC_D1CFGR_D1CPRE_DIV8_Pos)
18638#define RCC_D1CFGR_D1CPRE_DIV8 RCC_D1CFGR_D1CPRE_DIV8_Msk
18639#define RCC_D1CFGR_D1CPRE_DIV16_Pos (8U)
18640#define RCC_D1CFGR_D1CPRE_DIV16_Msk (0xBUL << RCC_D1CFGR_D1CPRE_DIV16_Pos)
18641#define RCC_D1CFGR_D1CPRE_DIV16 RCC_D1CFGR_D1CPRE_DIV16_Msk
18642#define RCC_D1CFGR_D1CPRE_DIV64_Pos (10U)
18643#define RCC_D1CFGR_D1CPRE_DIV64_Msk (0x3UL << RCC_D1CFGR_D1CPRE_DIV64_Pos)
18644#define RCC_D1CFGR_D1CPRE_DIV64 RCC_D1CFGR_D1CPRE_DIV64_Msk
18645#define RCC_D1CFGR_D1CPRE_DIV128_Pos (8U)
18646#define RCC_D1CFGR_D1CPRE_DIV128_Msk (0xDUL << RCC_D1CFGR_D1CPRE_DIV128_Pos)
18647#define RCC_D1CFGR_D1CPRE_DIV128 RCC_D1CFGR_D1CPRE_DIV128_Msk
18648#define RCC_D1CFGR_D1CPRE_DIV256_Pos (9U)
18649#define RCC_D1CFGR_D1CPRE_DIV256_Msk (0x7UL << RCC_D1CFGR_D1CPRE_DIV256_Pos)
18650#define RCC_D1CFGR_D1CPRE_DIV256 RCC_D1CFGR_D1CPRE_DIV256_Msk
18651#define RCC_D1CFGR_D1CPRE_DIV512_Pos (8U)
18652#define RCC_D1CFGR_D1CPRE_DIV512_Msk (0xFUL << RCC_D1CFGR_D1CPRE_DIV512_Pos)
18653#define RCC_D1CFGR_D1CPRE_DIV512 RCC_D1CFGR_D1CPRE_DIV512_Msk
18655/******************** Bit definition for RCC_D2CFGR register ******************/
18657#define RCC_D2CFGR_D2PPRE1_Pos (4U)
18658#define RCC_D2CFGR_D2PPRE1_Msk (0x7UL << RCC_D2CFGR_D2PPRE1_Pos)
18659#define RCC_D2CFGR_D2PPRE1 RCC_D2CFGR_D2PPRE1_Msk
18660#define RCC_D2CFGR_D2PPRE1_0 (0x1UL << RCC_D2CFGR_D2PPRE1_Pos)
18661#define RCC_D2CFGR_D2PPRE1_1 (0x2UL << RCC_D2CFGR_D2PPRE1_Pos)
18662#define RCC_D2CFGR_D2PPRE1_2 (0x4UL << RCC_D2CFGR_D2PPRE1_Pos)
18664#define RCC_D2CFGR_D2PPRE1_DIV1 (0U)
18665#define RCC_D2CFGR_D2PPRE1_DIV2_Pos (6U)
18666#define RCC_D2CFGR_D2PPRE1_DIV2_Msk (0x1UL << RCC_D2CFGR_D2PPRE1_DIV2_Pos)
18667#define RCC_D2CFGR_D2PPRE1_DIV2 RCC_D2CFGR_D2PPRE1_DIV2_Msk
18668#define RCC_D2CFGR_D2PPRE1_DIV4_Pos (4U)
18669#define RCC_D2CFGR_D2PPRE1_DIV4_Msk (0x5UL << RCC_D2CFGR_D2PPRE1_DIV4_Pos)
18670#define RCC_D2CFGR_D2PPRE1_DIV4 RCC_D2CFGR_D2PPRE1_DIV4_Msk
18671#define RCC_D2CFGR_D2PPRE1_DIV8_Pos (5U)
18672#define RCC_D2CFGR_D2PPRE1_DIV8_Msk (0x3UL << RCC_D2CFGR_D2PPRE1_DIV8_Pos)
18673#define RCC_D2CFGR_D2PPRE1_DIV8 RCC_D2CFGR_D2PPRE1_DIV8_Msk
18674#define RCC_D2CFGR_D2PPRE1_DIV16_Pos (4U)
18675#define RCC_D2CFGR_D2PPRE1_DIV16_Msk (0x7UL << RCC_D2CFGR_D2PPRE1_DIV16_Pos)
18676#define RCC_D2CFGR_D2PPRE1_DIV16 RCC_D2CFGR_D2PPRE1_DIV16_Msk
18679#define RCC_D2CFGR_D2PPRE2_Pos (8U)
18680#define RCC_D2CFGR_D2PPRE2_Msk (0x7UL << RCC_D2CFGR_D2PPRE2_Pos)
18681#define RCC_D2CFGR_D2PPRE2 RCC_D2CFGR_D2PPRE2_Msk
18682#define RCC_D2CFGR_D2PPRE2_0 (0x1UL << RCC_D2CFGR_D2PPRE2_Pos)
18683#define RCC_D2CFGR_D2PPRE2_1 (0x2UL << RCC_D2CFGR_D2PPRE2_Pos)
18684#define RCC_D2CFGR_D2PPRE2_2 (0x4UL << RCC_D2CFGR_D2PPRE2_Pos)
18686#define RCC_D2CFGR_D2PPRE2_DIV1 (0U)
18687#define RCC_D2CFGR_D2PPRE2_DIV2_Pos (10U)
18688#define RCC_D2CFGR_D2PPRE2_DIV2_Msk (0x1UL << RCC_D2CFGR_D2PPRE2_DIV2_Pos)
18689#define RCC_D2CFGR_D2PPRE2_DIV2 RCC_D2CFGR_D2PPRE2_DIV2_Msk
18690#define RCC_D2CFGR_D2PPRE2_DIV4_Pos (8U)
18691#define RCC_D2CFGR_D2PPRE2_DIV4_Msk (0x5UL << RCC_D2CFGR_D2PPRE2_DIV4_Pos)
18692#define RCC_D2CFGR_D2PPRE2_DIV4 RCC_D2CFGR_D2PPRE2_DIV4_Msk
18693#define RCC_D2CFGR_D2PPRE2_DIV8_Pos (9U)
18694#define RCC_D2CFGR_D2PPRE2_DIV8_Msk (0x3UL << RCC_D2CFGR_D2PPRE2_DIV8_Pos)
18695#define RCC_D2CFGR_D2PPRE2_DIV8 RCC_D2CFGR_D2PPRE2_DIV8_Msk
18696#define RCC_D2CFGR_D2PPRE2_DIV16_Pos (8U)
18697#define RCC_D2CFGR_D2PPRE2_DIV16_Msk (0x7UL << RCC_D2CFGR_D2PPRE2_DIV16_Pos)
18698#define RCC_D2CFGR_D2PPRE2_DIV16 RCC_D2CFGR_D2PPRE2_DIV16_Msk
18700/******************** Bit definition for RCC_D3CFGR register ******************/
18702#define RCC_D3CFGR_D3PPRE_Pos (4U)
18703#define RCC_D3CFGR_D3PPRE_Msk (0x7UL << RCC_D3CFGR_D3PPRE_Pos)
18704#define RCC_D3CFGR_D3PPRE RCC_D3CFGR_D3PPRE_Msk
18705#define RCC_D3CFGR_D3PPRE_0 (0x1UL << RCC_D3CFGR_D3PPRE_Pos)
18706#define RCC_D3CFGR_D3PPRE_1 (0x2UL << RCC_D3CFGR_D3PPRE_Pos)
18707#define RCC_D3CFGR_D3PPRE_2 (0x4UL << RCC_D3CFGR_D3PPRE_Pos)
18709#define RCC_D3CFGR_D3PPRE_DIV1 (0U)
18710#define RCC_D3CFGR_D3PPRE_DIV2_Pos (6U)
18711#define RCC_D3CFGR_D3PPRE_DIV2_Msk (0x1UL << RCC_D3CFGR_D3PPRE_DIV2_Pos)
18712#define RCC_D3CFGR_D3PPRE_DIV2 RCC_D3CFGR_D3PPRE_DIV2_Msk
18713#define RCC_D3CFGR_D3PPRE_DIV4_Pos (4U)
18714#define RCC_D3CFGR_D3PPRE_DIV4_Msk (0x5UL << RCC_D3CFGR_D3PPRE_DIV4_Pos)
18715#define RCC_D3CFGR_D3PPRE_DIV4 RCC_D3CFGR_D3PPRE_DIV4_Msk
18716#define RCC_D3CFGR_D3PPRE_DIV8_Pos (5U)
18717#define RCC_D3CFGR_D3PPRE_DIV8_Msk (0x3UL << RCC_D3CFGR_D3PPRE_DIV8_Pos)
18718#define RCC_D3CFGR_D3PPRE_DIV8 RCC_D3CFGR_D3PPRE_DIV8_Msk
18719#define RCC_D3CFGR_D3PPRE_DIV16_Pos (4U)
18720#define RCC_D3CFGR_D3PPRE_DIV16_Msk (0x7UL << RCC_D3CFGR_D3PPRE_DIV16_Pos)
18721#define RCC_D3CFGR_D3PPRE_DIV16 RCC_D3CFGR_D3PPRE_DIV16_Msk
18723/******************** Bit definition for RCC_PLLCKSELR register *************/
18724
18725#define RCC_PLLCKSELR_PLLSRC_Pos (0U)
18726#define RCC_PLLCKSELR_PLLSRC_Msk (0x3UL << RCC_PLLCKSELR_PLLSRC_Pos)
18727#define RCC_PLLCKSELR_PLLSRC RCC_PLLCKSELR_PLLSRC_Msk
18728
18729#define RCC_PLLCKSELR_PLLSRC_HSI (0U)
18730#define RCC_PLLCKSELR_PLLSRC_CSI_Pos (0U)
18731#define RCC_PLLCKSELR_PLLSRC_CSI_Msk (0x1UL << RCC_PLLCKSELR_PLLSRC_CSI_Pos)
18732#define RCC_PLLCKSELR_PLLSRC_CSI RCC_PLLCKSELR_PLLSRC_CSI_Msk
18733#define RCC_PLLCKSELR_PLLSRC_HSE_Pos (1U)
18734#define RCC_PLLCKSELR_PLLSRC_HSE_Msk (0x1UL << RCC_PLLCKSELR_PLLSRC_HSE_Pos)
18735#define RCC_PLLCKSELR_PLLSRC_HSE RCC_PLLCKSELR_PLLSRC_HSE_Msk
18736#define RCC_PLLCKSELR_PLLSRC_NONE_Pos (0U)
18737#define RCC_PLLCKSELR_PLLSRC_NONE_Msk (0x3UL << RCC_PLLCKSELR_PLLSRC_NONE_Pos)
18738#define RCC_PLLCKSELR_PLLSRC_NONE RCC_PLLCKSELR_PLLSRC_NONE_Msk
18740#define RCC_PLLCKSELR_DIVM1_Pos (4U)
18741#define RCC_PLLCKSELR_DIVM1_Msk (0x3FUL << RCC_PLLCKSELR_DIVM1_Pos)
18742#define RCC_PLLCKSELR_DIVM1 RCC_PLLCKSELR_DIVM1_Msk
18743#define RCC_PLLCKSELR_DIVM1_0 (0x01UL << RCC_PLLCKSELR_DIVM1_Pos)
18744#define RCC_PLLCKSELR_DIVM1_1 (0x02UL << RCC_PLLCKSELR_DIVM1_Pos)
18745#define RCC_PLLCKSELR_DIVM1_2 (0x04UL << RCC_PLLCKSELR_DIVM1_Pos)
18746#define RCC_PLLCKSELR_DIVM1_3 (0x08UL << RCC_PLLCKSELR_DIVM1_Pos)
18747#define RCC_PLLCKSELR_DIVM1_4 (0x10UL << RCC_PLLCKSELR_DIVM1_Pos)
18748#define RCC_PLLCKSELR_DIVM1_5 (0x20UL << RCC_PLLCKSELR_DIVM1_Pos)
18750#define RCC_PLLCKSELR_DIVM2_Pos (12U)
18751#define RCC_PLLCKSELR_DIVM2_Msk (0x3FUL << RCC_PLLCKSELR_DIVM2_Pos)
18752#define RCC_PLLCKSELR_DIVM2 RCC_PLLCKSELR_DIVM2_Msk
18753#define RCC_PLLCKSELR_DIVM2_0 (0x01UL << RCC_PLLCKSELR_DIVM2_Pos)
18754#define RCC_PLLCKSELR_DIVM2_1 (0x02UL << RCC_PLLCKSELR_DIVM2_Pos)
18755#define RCC_PLLCKSELR_DIVM2_2 (0x04UL << RCC_PLLCKSELR_DIVM2_Pos)
18756#define RCC_PLLCKSELR_DIVM2_3 (0x08UL << RCC_PLLCKSELR_DIVM2_Pos)
18757#define RCC_PLLCKSELR_DIVM2_4 (0x10UL << RCC_PLLCKSELR_DIVM2_Pos)
18758#define RCC_PLLCKSELR_DIVM2_5 (0x20UL << RCC_PLLCKSELR_DIVM2_Pos)
18760#define RCC_PLLCKSELR_DIVM3_Pos (20U)
18761#define RCC_PLLCKSELR_DIVM3_Msk (0x3FUL << RCC_PLLCKSELR_DIVM3_Pos)
18762#define RCC_PLLCKSELR_DIVM3 RCC_PLLCKSELR_DIVM3_Msk
18763#define RCC_PLLCKSELR_DIVM3_0 (0x01UL << RCC_PLLCKSELR_DIVM3_Pos)
18764#define RCC_PLLCKSELR_DIVM3_1 (0x02UL << RCC_PLLCKSELR_DIVM3_Pos)
18765#define RCC_PLLCKSELR_DIVM3_2 (0x04UL << RCC_PLLCKSELR_DIVM3_Pos)
18766#define RCC_PLLCKSELR_DIVM3_3 (0x08UL << RCC_PLLCKSELR_DIVM3_Pos)
18767#define RCC_PLLCKSELR_DIVM3_4 (0x10UL << RCC_PLLCKSELR_DIVM3_Pos)
18768#define RCC_PLLCKSELR_DIVM3_5 (0x20UL << RCC_PLLCKSELR_DIVM3_Pos)
18770/******************** Bit definition for RCC_PLLCFGR register ***************/
18771
18772#define RCC_PLLCFGR_PLL1FRACEN_Pos (0U)
18773#define RCC_PLLCFGR_PLL1FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL1FRACEN_Pos)
18774#define RCC_PLLCFGR_PLL1FRACEN RCC_PLLCFGR_PLL1FRACEN_Msk
18775#define RCC_PLLCFGR_PLL1VCOSEL_Pos (1U)
18776#define RCC_PLLCFGR_PLL1VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL1VCOSEL_Pos)
18777#define RCC_PLLCFGR_PLL1VCOSEL RCC_PLLCFGR_PLL1VCOSEL_Msk
18778#define RCC_PLLCFGR_PLL1RGE_Pos (2U)
18779#define RCC_PLLCFGR_PLL1RGE_Msk (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos)
18780#define RCC_PLLCFGR_PLL1RGE RCC_PLLCFGR_PLL1RGE_Msk
18781#define RCC_PLLCFGR_PLL1RGE_0 (0x0UL << RCC_PLLCFGR_PLL1RGE_Pos)
18782#define RCC_PLLCFGR_PLL1RGE_1 (0x1UL << RCC_PLLCFGR_PLL1RGE_Pos)
18783#define RCC_PLLCFGR_PLL1RGE_2 (0x2UL << RCC_PLLCFGR_PLL1RGE_Pos)
18784#define RCC_PLLCFGR_PLL1RGE_3 (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos)
18786#define RCC_PLLCFGR_PLL2FRACEN_Pos (4U)
18787#define RCC_PLLCFGR_PLL2FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL2FRACEN_Pos)
18788#define RCC_PLLCFGR_PLL2FRACEN RCC_PLLCFGR_PLL2FRACEN_Msk
18789#define RCC_PLLCFGR_PLL2VCOSEL_Pos (5U)
18790#define RCC_PLLCFGR_PLL2VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL2VCOSEL_Pos)
18791#define RCC_PLLCFGR_PLL2VCOSEL RCC_PLLCFGR_PLL2VCOSEL_Msk
18792#define RCC_PLLCFGR_PLL2RGE_Pos (6U)
18793#define RCC_PLLCFGR_PLL2RGE_Msk (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos)
18794#define RCC_PLLCFGR_PLL2RGE RCC_PLLCFGR_PLL2RGE_Msk
18795#define RCC_PLLCFGR_PLL2RGE_0 (0x0UL << RCC_PLLCFGR_PLL2RGE_Pos)
18796#define RCC_PLLCFGR_PLL2RGE_1 (0x1UL << RCC_PLLCFGR_PLL2RGE_Pos)
18797#define RCC_PLLCFGR_PLL2RGE_2 (0x2UL << RCC_PLLCFGR_PLL2RGE_Pos)
18798#define RCC_PLLCFGR_PLL2RGE_3 (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos)
18800#define RCC_PLLCFGR_PLL3FRACEN_Pos (8U)
18801#define RCC_PLLCFGR_PLL3FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL3FRACEN_Pos)
18802#define RCC_PLLCFGR_PLL3FRACEN RCC_PLLCFGR_PLL3FRACEN_Msk
18803#define RCC_PLLCFGR_PLL3VCOSEL_Pos (9U)
18804#define RCC_PLLCFGR_PLL3VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL3VCOSEL_Pos)
18805#define RCC_PLLCFGR_PLL3VCOSEL RCC_PLLCFGR_PLL3VCOSEL_Msk
18806#define RCC_PLLCFGR_PLL3RGE_Pos (10U)
18807#define RCC_PLLCFGR_PLL3RGE_Msk (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos)
18808#define RCC_PLLCFGR_PLL3RGE RCC_PLLCFGR_PLL3RGE_Msk
18809#define RCC_PLLCFGR_PLL3RGE_0 (0x0UL << RCC_PLLCFGR_PLL3RGE_Pos)
18810#define RCC_PLLCFGR_PLL3RGE_1 (0x1UL << RCC_PLLCFGR_PLL3RGE_Pos)
18811#define RCC_PLLCFGR_PLL3RGE_2 (0x2UL << RCC_PLLCFGR_PLL3RGE_Pos)
18812#define RCC_PLLCFGR_PLL3RGE_3 (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos)
18814#define RCC_PLLCFGR_DIVP1EN_Pos (16U)
18815#define RCC_PLLCFGR_DIVP1EN_Msk (0x1UL << RCC_PLLCFGR_DIVP1EN_Pos)
18816#define RCC_PLLCFGR_DIVP1EN RCC_PLLCFGR_DIVP1EN_Msk
18817#define RCC_PLLCFGR_DIVQ1EN_Pos (17U)
18818#define RCC_PLLCFGR_DIVQ1EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ1EN_Pos)
18819#define RCC_PLLCFGR_DIVQ1EN RCC_PLLCFGR_DIVQ1EN_Msk
18820#define RCC_PLLCFGR_DIVR1EN_Pos (18U)
18821#define RCC_PLLCFGR_DIVR1EN_Msk (0x1UL << RCC_PLLCFGR_DIVR1EN_Pos)
18822#define RCC_PLLCFGR_DIVR1EN RCC_PLLCFGR_DIVR1EN_Msk
18823
18824#define RCC_PLLCFGR_DIVP2EN_Pos (19U)
18825#define RCC_PLLCFGR_DIVP2EN_Msk (0x1UL << RCC_PLLCFGR_DIVP2EN_Pos)
18826#define RCC_PLLCFGR_DIVP2EN RCC_PLLCFGR_DIVP2EN_Msk
18827#define RCC_PLLCFGR_DIVQ2EN_Pos (20U)
18828#define RCC_PLLCFGR_DIVQ2EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ2EN_Pos)
18829#define RCC_PLLCFGR_DIVQ2EN RCC_PLLCFGR_DIVQ2EN_Msk
18830#define RCC_PLLCFGR_DIVR2EN_Pos (21U)
18831#define RCC_PLLCFGR_DIVR2EN_Msk (0x1UL << RCC_PLLCFGR_DIVR2EN_Pos)
18832#define RCC_PLLCFGR_DIVR2EN RCC_PLLCFGR_DIVR2EN_Msk
18833
18834#define RCC_PLLCFGR_DIVP3EN_Pos (22U)
18835#define RCC_PLLCFGR_DIVP3EN_Msk (0x1UL << RCC_PLLCFGR_DIVP3EN_Pos)
18836#define RCC_PLLCFGR_DIVP3EN RCC_PLLCFGR_DIVP3EN_Msk
18837#define RCC_PLLCFGR_DIVQ3EN_Pos (23U)
18838#define RCC_PLLCFGR_DIVQ3EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ3EN_Pos)
18839#define RCC_PLLCFGR_DIVQ3EN RCC_PLLCFGR_DIVQ3EN_Msk
18840#define RCC_PLLCFGR_DIVR3EN_Pos (24U)
18841#define RCC_PLLCFGR_DIVR3EN_Msk (0x1UL << RCC_PLLCFGR_DIVR3EN_Pos)
18842#define RCC_PLLCFGR_DIVR3EN RCC_PLLCFGR_DIVR3EN_Msk
18843
18844
18845/******************** Bit definition for RCC_PLL1DIVR register ***************/
18846#define RCC_PLL1DIVR_N1_Pos (0U)
18847#define RCC_PLL1DIVR_N1_Msk (0x1FFUL << RCC_PLL1DIVR_N1_Pos)
18848#define RCC_PLL1DIVR_N1 RCC_PLL1DIVR_N1_Msk
18849#define RCC_PLL1DIVR_P1_Pos (9U)
18850#define RCC_PLL1DIVR_P1_Msk (0x7FUL << RCC_PLL1DIVR_P1_Pos)
18851#define RCC_PLL1DIVR_P1 RCC_PLL1DIVR_P1_Msk
18852#define RCC_PLL1DIVR_Q1_Pos (16U)
18853#define RCC_PLL1DIVR_Q1_Msk (0x7FUL << RCC_PLL1DIVR_Q1_Pos)
18854#define RCC_PLL1DIVR_Q1 RCC_PLL1DIVR_Q1_Msk
18855#define RCC_PLL1DIVR_R1_Pos (24U)
18856#define RCC_PLL1DIVR_R1_Msk (0x7FUL << RCC_PLL1DIVR_R1_Pos)
18857#define RCC_PLL1DIVR_R1 RCC_PLL1DIVR_R1_Msk
18858
18859/******************** Bit definition for RCC_PLL1FRACR register ***************/
18860#define RCC_PLL1FRACR_FRACN1_Pos (3U)
18861#define RCC_PLL1FRACR_FRACN1_Msk (0x1FFFUL << RCC_PLL1FRACR_FRACN1_Pos)
18862#define RCC_PLL1FRACR_FRACN1 RCC_PLL1FRACR_FRACN1_Msk
18863
18864/******************** Bit definition for RCC_PLL2DIVR register ***************/
18865#define RCC_PLL2DIVR_N2_Pos (0U)
18866#define RCC_PLL2DIVR_N2_Msk (0x1FFUL << RCC_PLL2DIVR_N2_Pos)
18867#define RCC_PLL2DIVR_N2 RCC_PLL2DIVR_N2_Msk
18868#define RCC_PLL2DIVR_P2_Pos (9U)
18869#define RCC_PLL2DIVR_P2_Msk (0x7FUL << RCC_PLL2DIVR_P2_Pos)
18870#define RCC_PLL2DIVR_P2 RCC_PLL2DIVR_P2_Msk
18871#define RCC_PLL2DIVR_Q2_Pos (16U)
18872#define RCC_PLL2DIVR_Q2_Msk (0x7FUL << RCC_PLL2DIVR_Q2_Pos)
18873#define RCC_PLL2DIVR_Q2 RCC_PLL2DIVR_Q2_Msk
18874#define RCC_PLL2DIVR_R2_Pos (24U)
18875#define RCC_PLL2DIVR_R2_Msk (0x7FUL << RCC_PLL2DIVR_R2_Pos)
18876#define RCC_PLL2DIVR_R2 RCC_PLL2DIVR_R2_Msk
18877
18878/******************** Bit definition for RCC_PLL2FRACR register ***************/
18879#define RCC_PLL2FRACR_FRACN2_Pos (3U)
18880#define RCC_PLL2FRACR_FRACN2_Msk (0x1FFFUL << RCC_PLL2FRACR_FRACN2_Pos)
18881#define RCC_PLL2FRACR_FRACN2 RCC_PLL2FRACR_FRACN2_Msk
18882
18883/******************** Bit definition for RCC_PLL3DIVR register ***************/
18884#define RCC_PLL3DIVR_N3_Pos (0U)
18885#define RCC_PLL3DIVR_N3_Msk (0x1FFUL << RCC_PLL3DIVR_N3_Pos)
18886#define RCC_PLL3DIVR_N3 RCC_PLL3DIVR_N3_Msk
18887#define RCC_PLL3DIVR_P3_Pos (9U)
18888#define RCC_PLL3DIVR_P3_Msk (0x7FUL << RCC_PLL3DIVR_P3_Pos)
18889#define RCC_PLL3DIVR_P3 RCC_PLL3DIVR_P3_Msk
18890#define RCC_PLL3DIVR_Q3_Pos (16U)
18891#define RCC_PLL3DIVR_Q3_Msk (0x7FUL << RCC_PLL3DIVR_Q3_Pos)
18892#define RCC_PLL3DIVR_Q3 RCC_PLL3DIVR_Q3_Msk
18893#define RCC_PLL3DIVR_R3_Pos (24U)
18894#define RCC_PLL3DIVR_R3_Msk (0x7FUL << RCC_PLL3DIVR_R3_Pos)
18895#define RCC_PLL3DIVR_R3 RCC_PLL3DIVR_R3_Msk
18896
18897/******************** Bit definition for RCC_PLL3FRACR register ***************/
18898#define RCC_PLL3FRACR_FRACN3_Pos (3U)
18899#define RCC_PLL3FRACR_FRACN3_Msk (0x1FFFUL << RCC_PLL3FRACR_FRACN3_Pos)
18900#define RCC_PLL3FRACR_FRACN3 RCC_PLL3FRACR_FRACN3_Msk
18901
18902/******************** Bit definition for RCC_D1CCIPR register ***************/
18903#define RCC_D1CCIPR_FMCSEL_Pos (0U)
18904#define RCC_D1CCIPR_FMCSEL_Msk (0x3UL << RCC_D1CCIPR_FMCSEL_Pos)
18905#define RCC_D1CCIPR_FMCSEL RCC_D1CCIPR_FMCSEL_Msk
18906#define RCC_D1CCIPR_FMCSEL_0 (0x1UL << RCC_D1CCIPR_FMCSEL_Pos)
18907#define RCC_D1CCIPR_FMCSEL_1 (0x2UL << RCC_D1CCIPR_FMCSEL_Pos)
18908#define RCC_D1CCIPR_QSPISEL_Pos (4U)
18909#define RCC_D1CCIPR_QSPISEL_Msk (0x3UL << RCC_D1CCIPR_QSPISEL_Pos)
18910#define RCC_D1CCIPR_QSPISEL RCC_D1CCIPR_QSPISEL_Msk
18911#define RCC_D1CCIPR_QSPISEL_0 (0x1UL << RCC_D1CCIPR_QSPISEL_Pos)
18912#define RCC_D1CCIPR_QSPISEL_1 (0x2UL << RCC_D1CCIPR_QSPISEL_Pos)
18913#define RCC_D1CCIPR_DSISEL_Pos (8U)
18914#define RCC_D1CCIPR_DSISEL_Msk (0x1UL << RCC_D1CCIPR_DSISEL_Pos)
18915#define RCC_D1CCIPR_DSISEL RCC_D1CCIPR_DSISEL_Msk
18916#define RCC_D1CCIPR_SDMMCSEL_Pos (16U)
18917#define RCC_D1CCIPR_SDMMCSEL_Msk (0x1UL << RCC_D1CCIPR_SDMMCSEL_Pos)
18918#define RCC_D1CCIPR_SDMMCSEL RCC_D1CCIPR_SDMMCSEL_Msk
18919#define RCC_D1CCIPR_CKPERSEL_Pos (28U)
18920#define RCC_D1CCIPR_CKPERSEL_Msk (0x3UL << RCC_D1CCIPR_CKPERSEL_Pos)
18921#define RCC_D1CCIPR_CKPERSEL RCC_D1CCIPR_CKPERSEL_Msk
18922#define RCC_D1CCIPR_CKPERSEL_0 (0x1UL << RCC_D1CCIPR_CKPERSEL_Pos)
18923#define RCC_D1CCIPR_CKPERSEL_1 (0x2UL << RCC_D1CCIPR_CKPERSEL_Pos)
18925/******************** Bit definition for RCC_D2CCIP1R register ***************/
18926#define RCC_D2CCIP1R_SAI1SEL_Pos (0U)
18927#define RCC_D2CCIP1R_SAI1SEL_Msk (0x7UL << RCC_D2CCIP1R_SAI1SEL_Pos)
18928#define RCC_D2CCIP1R_SAI1SEL RCC_D2CCIP1R_SAI1SEL_Msk
18929#define RCC_D2CCIP1R_SAI1SEL_0 (0x1UL << RCC_D2CCIP1R_SAI1SEL_Pos)
18930#define RCC_D2CCIP1R_SAI1SEL_1 (0x2UL << RCC_D2CCIP1R_SAI1SEL_Pos)
18931#define RCC_D2CCIP1R_SAI1SEL_2 (0x4UL << RCC_D2CCIP1R_SAI1SEL_Pos)
18933#define RCC_D2CCIP1R_SAI23SEL_Pos (6U)
18934#define RCC_D2CCIP1R_SAI23SEL_Msk (0x7UL << RCC_D2CCIP1R_SAI23SEL_Pos)
18935#define RCC_D2CCIP1R_SAI23SEL RCC_D2CCIP1R_SAI23SEL_Msk
18936#define RCC_D2CCIP1R_SAI23SEL_0 (0x1UL << RCC_D2CCIP1R_SAI23SEL_Pos)
18937#define RCC_D2CCIP1R_SAI23SEL_1 (0x2UL << RCC_D2CCIP1R_SAI23SEL_Pos)
18938#define RCC_D2CCIP1R_SAI23SEL_2 (0x4UL << RCC_D2CCIP1R_SAI23SEL_Pos)
18940#define RCC_D2CCIP1R_SPI123SEL_Pos (12U)
18941#define RCC_D2CCIP1R_SPI123SEL_Msk (0x7UL << RCC_D2CCIP1R_SPI123SEL_Pos)
18942#define RCC_D2CCIP1R_SPI123SEL RCC_D2CCIP1R_SPI123SEL_Msk
18943#define RCC_D2CCIP1R_SPI123SEL_0 (0x1UL << RCC_D2CCIP1R_SPI123SEL_Pos)
18944#define RCC_D2CCIP1R_SPI123SEL_1 (0x2UL << RCC_D2CCIP1R_SPI123SEL_Pos)
18945#define RCC_D2CCIP1R_SPI123SEL_2 (0x4UL << RCC_D2CCIP1R_SPI123SEL_Pos)
18947#define RCC_D2CCIP1R_SPI45SEL_Pos (16U)
18948#define RCC_D2CCIP1R_SPI45SEL_Msk (0x7UL << RCC_D2CCIP1R_SPI45SEL_Pos)
18949#define RCC_D2CCIP1R_SPI45SEL RCC_D2CCIP1R_SPI45SEL_Msk
18950#define RCC_D2CCIP1R_SPI45SEL_0 (0x1UL << RCC_D2CCIP1R_SPI45SEL_Pos)
18951#define RCC_D2CCIP1R_SPI45SEL_1 (0x2UL << RCC_D2CCIP1R_SPI45SEL_Pos)
18952#define RCC_D2CCIP1R_SPI45SEL_2 (0x4UL << RCC_D2CCIP1R_SPI45SEL_Pos)
18954#define RCC_D2CCIP1R_SPDIFSEL_Pos (20U)
18955#define RCC_D2CCIP1R_SPDIFSEL_Msk (0x3UL << RCC_D2CCIP1R_SPDIFSEL_Pos)
18956#define RCC_D2CCIP1R_SPDIFSEL RCC_D2CCIP1R_SPDIFSEL_Msk
18957#define RCC_D2CCIP1R_SPDIFSEL_0 (0x1UL << RCC_D2CCIP1R_SPDIFSEL_Pos)
18958#define RCC_D2CCIP1R_SPDIFSEL_1 (0x2UL << RCC_D2CCIP1R_SPDIFSEL_Pos)
18960#define RCC_D2CCIP1R_DFSDM1SEL_Pos (24U)
18961#define RCC_D2CCIP1R_DFSDM1SEL_Msk (0x1UL << RCC_D2CCIP1R_DFSDM1SEL_Pos)
18962#define RCC_D2CCIP1R_DFSDM1SEL RCC_D2CCIP1R_DFSDM1SEL_Msk
18963
18964#define RCC_D2CCIP1R_FDCANSEL_Pos (28U)
18965#define RCC_D2CCIP1R_FDCANSEL_Msk (0x3UL << RCC_D2CCIP1R_FDCANSEL_Pos)
18966#define RCC_D2CCIP1R_FDCANSEL RCC_D2CCIP1R_FDCANSEL_Msk
18967#define RCC_D2CCIP1R_FDCANSEL_0 (0x1UL << RCC_D2CCIP1R_FDCANSEL_Pos)
18968#define RCC_D2CCIP1R_FDCANSEL_1 (0x2UL << RCC_D2CCIP1R_FDCANSEL_Pos)
18970#define RCC_D2CCIP1R_SWPSEL_Pos (31U)
18971#define RCC_D2CCIP1R_SWPSEL_Msk (0x1UL << RCC_D2CCIP1R_SWPSEL_Pos)
18972#define RCC_D2CCIP1R_SWPSEL RCC_D2CCIP1R_SWPSEL_Msk
18973
18974/******************** Bit definition for RCC_D2CCIP2R register ***************/
18975#define RCC_D2CCIP2R_USART16SEL_Pos (3U)
18976#define RCC_D2CCIP2R_USART16SEL_Msk (0x7UL << RCC_D2CCIP2R_USART16SEL_Pos)
18977#define RCC_D2CCIP2R_USART16SEL RCC_D2CCIP2R_USART16SEL_Msk
18978#define RCC_D2CCIP2R_USART16SEL_0 (0x1UL << RCC_D2CCIP2R_USART16SEL_Pos)
18979#define RCC_D2CCIP2R_USART16SEL_1 (0x2UL << RCC_D2CCIP2R_USART16SEL_Pos)
18980#define RCC_D2CCIP2R_USART16SEL_2 (0x4UL << RCC_D2CCIP2R_USART16SEL_Pos)
18982#define RCC_D2CCIP2R_USART28SEL_Pos (0U)
18983#define RCC_D2CCIP2R_USART28SEL_Msk (0x7UL << RCC_D2CCIP2R_USART28SEL_Pos)
18984#define RCC_D2CCIP2R_USART28SEL RCC_D2CCIP2R_USART28SEL_Msk
18985#define RCC_D2CCIP2R_USART28SEL_0 (0x1UL << RCC_D2CCIP2R_USART28SEL_Pos)
18986#define RCC_D2CCIP2R_USART28SEL_1 (0x2UL << RCC_D2CCIP2R_USART28SEL_Pos)
18987#define RCC_D2CCIP2R_USART28SEL_2 (0x4UL << RCC_D2CCIP2R_USART28SEL_Pos)
18989#define RCC_D2CCIP2R_RNGSEL_Pos (8U)
18990#define RCC_D2CCIP2R_RNGSEL_Msk (0x3UL << RCC_D2CCIP2R_RNGSEL_Pos)
18991#define RCC_D2CCIP2R_RNGSEL RCC_D2CCIP2R_RNGSEL_Msk
18992#define RCC_D2CCIP2R_RNGSEL_0 (0x1UL << RCC_D2CCIP2R_RNGSEL_Pos)
18993#define RCC_D2CCIP2R_RNGSEL_1 (0x2UL << RCC_D2CCIP2R_RNGSEL_Pos)
18995#define RCC_D2CCIP2R_I2C123SEL_Pos (12U)
18996#define RCC_D2CCIP2R_I2C123SEL_Msk (0x3UL << RCC_D2CCIP2R_I2C123SEL_Pos)
18997#define RCC_D2CCIP2R_I2C123SEL RCC_D2CCIP2R_I2C123SEL_Msk
18998#define RCC_D2CCIP2R_I2C123SEL_0 (0x1UL << RCC_D2CCIP2R_I2C123SEL_Pos)
18999#define RCC_D2CCIP2R_I2C123SEL_1 (0x2UL << RCC_D2CCIP2R_I2C123SEL_Pos)
19001#define RCC_D2CCIP2R_USBSEL_Pos (20U)
19002#define RCC_D2CCIP2R_USBSEL_Msk (0x3UL << RCC_D2CCIP2R_USBSEL_Pos)
19003#define RCC_D2CCIP2R_USBSEL RCC_D2CCIP2R_USBSEL_Msk
19004#define RCC_D2CCIP2R_USBSEL_0 (0x1UL << RCC_D2CCIP2R_USBSEL_Pos)
19005#define RCC_D2CCIP2R_USBSEL_1 (0x2UL << RCC_D2CCIP2R_USBSEL_Pos)
19007#define RCC_D2CCIP2R_CECSEL_Pos (22U)
19008#define RCC_D2CCIP2R_CECSEL_Msk (0x3UL << RCC_D2CCIP2R_CECSEL_Pos)
19009#define RCC_D2CCIP2R_CECSEL RCC_D2CCIP2R_CECSEL_Msk
19010#define RCC_D2CCIP2R_CECSEL_0 (0x1UL << RCC_D2CCIP2R_CECSEL_Pos)
19011#define RCC_D2CCIP2R_CECSEL_1 (0x2UL << RCC_D2CCIP2R_CECSEL_Pos)
19013#define RCC_D2CCIP2R_LPTIM1SEL_Pos (28U)
19014#define RCC_D2CCIP2R_LPTIM1SEL_Msk (0x7UL << RCC_D2CCIP2R_LPTIM1SEL_Pos)
19015#define RCC_D2CCIP2R_LPTIM1SEL RCC_D2CCIP2R_LPTIM1SEL_Msk
19016#define RCC_D2CCIP2R_LPTIM1SEL_0 (0x1UL << RCC_D2CCIP2R_LPTIM1SEL_Pos)
19017#define RCC_D2CCIP2R_LPTIM1SEL_1 (0x2UL << RCC_D2CCIP2R_LPTIM1SEL_Pos)
19018#define RCC_D2CCIP2R_LPTIM1SEL_2 (0x4UL << RCC_D2CCIP2R_LPTIM1SEL_Pos)
19020/******************** Bit definition for RCC_D3CCIPR register ***************/
19021#define RCC_D3CCIPR_LPUART1SEL_Pos (0U)
19022#define RCC_D3CCIPR_LPUART1SEL_Msk (0x7UL << RCC_D3CCIPR_LPUART1SEL_Pos)
19023#define RCC_D3CCIPR_LPUART1SEL RCC_D3CCIPR_LPUART1SEL_Msk
19024#define RCC_D3CCIPR_LPUART1SEL_0 (0x1UL << RCC_D3CCIPR_LPUART1SEL_Pos)
19025#define RCC_D3CCIPR_LPUART1SEL_1 (0x2UL << RCC_D3CCIPR_LPUART1SEL_Pos)
19026#define RCC_D3CCIPR_LPUART1SEL_2 (0x4UL << RCC_D3CCIPR_LPUART1SEL_Pos)
19028#define RCC_D3CCIPR_I2C4SEL_Pos (8U)
19029#define RCC_D3CCIPR_I2C4SEL_Msk (0x3UL << RCC_D3CCIPR_I2C4SEL_Pos)
19030#define RCC_D3CCIPR_I2C4SEL RCC_D3CCIPR_I2C4SEL_Msk
19031#define RCC_D3CCIPR_I2C4SEL_0 (0x1UL << RCC_D3CCIPR_I2C4SEL_Pos)
19032#define RCC_D3CCIPR_I2C4SEL_1 (0x2UL << RCC_D3CCIPR_I2C4SEL_Pos)
19034#define RCC_D3CCIPR_LPTIM2SEL_Pos (10U)
19035#define RCC_D3CCIPR_LPTIM2SEL_Msk (0x7UL << RCC_D3CCIPR_LPTIM2SEL_Pos)
19036#define RCC_D3CCIPR_LPTIM2SEL RCC_D3CCIPR_LPTIM2SEL_Msk
19037#define RCC_D3CCIPR_LPTIM2SEL_0 (0x1UL << RCC_D3CCIPR_LPTIM2SEL_Pos)
19038#define RCC_D3CCIPR_LPTIM2SEL_1 (0x2UL << RCC_D3CCIPR_LPTIM2SEL_Pos)
19039#define RCC_D3CCIPR_LPTIM2SEL_2 (0x4UL << RCC_D3CCIPR_LPTIM2SEL_Pos)
19041#define RCC_D3CCIPR_LPTIM345SEL_Pos (13U)
19042#define RCC_D3CCIPR_LPTIM345SEL_Msk (0x7UL << RCC_D3CCIPR_LPTIM345SEL_Pos)
19043#define RCC_D3CCIPR_LPTIM345SEL RCC_D3CCIPR_LPTIM345SEL_Msk
19044#define RCC_D3CCIPR_LPTIM345SEL_0 (0x1UL << RCC_D3CCIPR_LPTIM345SEL_Pos)
19045#define RCC_D3CCIPR_LPTIM345SEL_1 (0x2UL << RCC_D3CCIPR_LPTIM345SEL_Pos)
19046#define RCC_D3CCIPR_LPTIM345SEL_2 (0x4UL << RCC_D3CCIPR_LPTIM345SEL_Pos)
19048#define RCC_D3CCIPR_SAI4ASEL_Pos (21U)
19049#define RCC_D3CCIPR_SAI4ASEL_Msk (0x7UL << RCC_D3CCIPR_SAI4ASEL_Pos)
19050#define RCC_D3CCIPR_SAI4ASEL RCC_D3CCIPR_SAI4ASEL_Msk
19051#define RCC_D3CCIPR_SAI4ASEL_0 (0x1UL << RCC_D3CCIPR_SAI4ASEL_Pos)
19052#define RCC_D3CCIPR_SAI4ASEL_1 (0x2UL << RCC_D3CCIPR_SAI4ASEL_Pos)
19053#define RCC_D3CCIPR_SAI4ASEL_2 (0x4UL << RCC_D3CCIPR_SAI4ASEL_Pos)
19055#define RCC_D3CCIPR_SAI4BSEL_Pos (24U)
19056#define RCC_D3CCIPR_SAI4BSEL_Msk (0x7UL << RCC_D3CCIPR_SAI4BSEL_Pos)
19057#define RCC_D3CCIPR_SAI4BSEL RCC_D3CCIPR_SAI4BSEL_Msk
19058#define RCC_D3CCIPR_SAI4BSEL_0 (0x1UL << RCC_D3CCIPR_SAI4BSEL_Pos)
19059#define RCC_D3CCIPR_SAI4BSEL_1 (0x2UL << RCC_D3CCIPR_SAI4BSEL_Pos)
19060#define RCC_D3CCIPR_SAI4BSEL_2 (0x4UL << RCC_D3CCIPR_SAI4BSEL_Pos)
19062#define RCC_D3CCIPR_ADCSEL_Pos (16U)
19063#define RCC_D3CCIPR_ADCSEL_Msk (0x3UL << RCC_D3CCIPR_ADCSEL_Pos)
19064#define RCC_D3CCIPR_ADCSEL RCC_D3CCIPR_ADCSEL_Msk
19065#define RCC_D3CCIPR_ADCSEL_0 (0x1UL << RCC_D3CCIPR_ADCSEL_Pos)
19066#define RCC_D3CCIPR_ADCSEL_1 (0x2UL << RCC_D3CCIPR_ADCSEL_Pos)
19068#define RCC_D3CCIPR_SPI6SEL_Pos (28U)
19069#define RCC_D3CCIPR_SPI6SEL_Msk (0x7UL << RCC_D3CCIPR_SPI6SEL_Pos)
19070#define RCC_D3CCIPR_SPI6SEL RCC_D3CCIPR_SPI6SEL_Msk
19071#define RCC_D3CCIPR_SPI6SEL_0 (0x1UL << RCC_D3CCIPR_SPI6SEL_Pos)
19072#define RCC_D3CCIPR_SPI6SEL_1 (0x2UL << RCC_D3CCIPR_SPI6SEL_Pos)
19073#define RCC_D3CCIPR_SPI6SEL_2 (0x4UL << RCC_D3CCIPR_SPI6SEL_Pos)
19074/******************** Bit definition for RCC_CIER register ******************/
19075#define RCC_CIER_LSIRDYIE_Pos (0U)
19076#define RCC_CIER_LSIRDYIE_Msk (0x1UL << RCC_CIER_LSIRDYIE_Pos)
19077#define RCC_CIER_LSIRDYIE RCC_CIER_LSIRDYIE_Msk
19078#define RCC_CIER_LSERDYIE_Pos (1U)
19079#define RCC_CIER_LSERDYIE_Msk (0x1UL << RCC_CIER_LSERDYIE_Pos)
19080#define RCC_CIER_LSERDYIE RCC_CIER_LSERDYIE_Msk
19081#define RCC_CIER_HSIRDYIE_Pos (2U)
19082#define RCC_CIER_HSIRDYIE_Msk (0x1UL << RCC_CIER_HSIRDYIE_Pos)
19083#define RCC_CIER_HSIRDYIE RCC_CIER_HSIRDYIE_Msk
19084#define RCC_CIER_HSERDYIE_Pos (3U)
19085#define RCC_CIER_HSERDYIE_Msk (0x1UL << RCC_CIER_HSERDYIE_Pos)
19086#define RCC_CIER_HSERDYIE RCC_CIER_HSERDYIE_Msk
19087#define RCC_CIER_CSIRDYIE_Pos (4U)
19088#define RCC_CIER_CSIRDYIE_Msk (0x1UL << RCC_CIER_CSIRDYIE_Pos)
19089#define RCC_CIER_CSIRDYIE RCC_CIER_CSIRDYIE_Msk
19090#define RCC_CIER_HSI48RDYIE_Pos (5U)
19091#define RCC_CIER_HSI48RDYIE_Msk (0x1UL << RCC_CIER_HSI48RDYIE_Pos)
19092#define RCC_CIER_HSI48RDYIE RCC_CIER_HSI48RDYIE_Msk
19093#define RCC_CIER_PLL1RDYIE_Pos (6U)
19094#define RCC_CIER_PLL1RDYIE_Msk (0x1UL << RCC_CIER_PLL1RDYIE_Pos)
19095#define RCC_CIER_PLL1RDYIE RCC_CIER_PLL1RDYIE_Msk
19096#define RCC_CIER_PLL2RDYIE_Pos (7U)
19097#define RCC_CIER_PLL2RDYIE_Msk (0x1UL << RCC_CIER_PLL2RDYIE_Pos)
19098#define RCC_CIER_PLL2RDYIE RCC_CIER_PLL2RDYIE_Msk
19099#define RCC_CIER_PLL3RDYIE_Pos (8U)
19100#define RCC_CIER_PLL3RDYIE_Msk (0x1UL << RCC_CIER_PLL3RDYIE_Pos)
19101#define RCC_CIER_PLL3RDYIE RCC_CIER_PLL3RDYIE_Msk
19102#define RCC_CIER_LSECSSIE_Pos (9U)
19103#define RCC_CIER_LSECSSIE_Msk (0x1UL << RCC_CIER_LSECSSIE_Pos)
19104#define RCC_CIER_LSECSSIE RCC_CIER_LSECSSIE_Msk
19105
19106/******************** Bit definition for RCC_CIFR register ******************/
19107#define RCC_CIFR_LSIRDYF_Pos (0U)
19108#define RCC_CIFR_LSIRDYF_Msk (0x1UL << RCC_CIFR_LSIRDYF_Pos)
19109#define RCC_CIFR_LSIRDYF RCC_CIFR_LSIRDYF_Msk
19110#define RCC_CIFR_LSERDYF_Pos (1U)
19111#define RCC_CIFR_LSERDYF_Msk (0x1UL << RCC_CIFR_LSERDYF_Pos)
19112#define RCC_CIFR_LSERDYF RCC_CIFR_LSERDYF_Msk
19113#define RCC_CIFR_HSIRDYF_Pos (2U)
19114#define RCC_CIFR_HSIRDYF_Msk (0x1UL << RCC_CIFR_HSIRDYF_Pos)
19115#define RCC_CIFR_HSIRDYF RCC_CIFR_HSIRDYF_Msk
19116#define RCC_CIFR_HSERDYF_Pos (3U)
19117#define RCC_CIFR_HSERDYF_Msk (0x1UL << RCC_CIFR_HSERDYF_Pos)
19118#define RCC_CIFR_HSERDYF RCC_CIFR_HSERDYF_Msk
19119#define RCC_CIFR_CSIRDYF_Pos (4U)
19120#define RCC_CIFR_CSIRDYF_Msk (0x1UL << RCC_CIFR_CSIRDYF_Pos)
19121#define RCC_CIFR_CSIRDYF RCC_CIFR_CSIRDYF_Msk
19122#define RCC_CIFR_HSI48RDYF_Pos (5U)
19123#define RCC_CIFR_HSI48RDYF_Msk (0x1UL << RCC_CIFR_HSI48RDYF_Pos)
19124#define RCC_CIFR_HSI48RDYF RCC_CIFR_HSI48RDYF_Msk
19125#define RCC_CIFR_PLLRDYF_Pos (6U)
19126#define RCC_CIFR_PLLRDYF_Msk (0x1UL << RCC_CIFR_PLLRDYF_Pos)
19127#define RCC_CIFR_PLLRDYF RCC_CIFR_PLLRDYF_Msk
19128#define RCC_CIFR_PLL2RDYF_Pos (7U)
19129#define RCC_CIFR_PLL2RDYF_Msk (0x1UL << RCC_CIFR_PLL2RDYF_Pos)
19130#define RCC_CIFR_PLL2RDYF RCC_CIFR_PLL2RDYF_Msk
19131#define RCC_CIFR_PLL3RDYF_Pos (8U)
19132#define RCC_CIFR_PLL3RDYF_Msk (0x1UL << RCC_CIFR_PLL3RDYF_Pos)
19133#define RCC_CIFR_PLL3RDYF RCC_CIFR_PLL3RDYF_Msk
19134#define RCC_CIFR_LSECSSF_Pos (9U)
19135#define RCC_CIFR_LSECSSF_Msk (0x1UL << RCC_CIFR_LSECSSF_Pos)
19136#define RCC_CIFR_LSECSSF RCC_CIFR_LSECSSF_Msk
19137#define RCC_CIFR_HSECSSF_Pos (10U)
19138#define RCC_CIFR_HSECSSF_Msk (0x1UL << RCC_CIFR_HSECSSF_Pos)
19139#define RCC_CIFR_HSECSSF RCC_CIFR_HSECSSF_Msk
19140
19141/******************** Bit definition for RCC_CICR register ******************/
19142#define RCC_CICR_LSIRDYC_Pos (0U)
19143#define RCC_CICR_LSIRDYC_Msk (0x1UL << RCC_CICR_LSIRDYC_Pos)
19144#define RCC_CICR_LSIRDYC RCC_CICR_LSIRDYC_Msk
19145#define RCC_CICR_LSERDYC_Pos (1U)
19146#define RCC_CICR_LSERDYC_Msk (0x1UL << RCC_CICR_LSERDYC_Pos)
19147#define RCC_CICR_LSERDYC RCC_CICR_LSERDYC_Msk
19148#define RCC_CICR_HSIRDYC_Pos (2U)
19149#define RCC_CICR_HSIRDYC_Msk (0x1UL << RCC_CICR_HSIRDYC_Pos)
19150#define RCC_CICR_HSIRDYC RCC_CICR_HSIRDYC_Msk
19151#define RCC_CICR_HSERDYC_Pos (3U)
19152#define RCC_CICR_HSERDYC_Msk (0x1UL << RCC_CICR_HSERDYC_Pos)
19153#define RCC_CICR_HSERDYC RCC_CICR_HSERDYC_Msk
19154#define RCC_CICR_CSIRDYC_Pos (4U)
19155#define RCC_CICR_CSIRDYC_Msk (0x1UL << RCC_CICR_CSIRDYC_Pos)
19156#define RCC_CICR_CSIRDYC RCC_CICR_CSIRDYC_Msk
19157#define RCC_CICR_HSI48RDYC_Pos (5U)
19158#define RCC_CICR_HSI48RDYC_Msk (0x1UL << RCC_CICR_HSI48RDYC_Pos)
19159#define RCC_CICR_HSI48RDYC RCC_CICR_HSI48RDYC_Msk
19160#define RCC_CICR_PLLRDYC_Pos (6U)
19161#define RCC_CICR_PLLRDYC_Msk (0x1UL << RCC_CICR_PLLRDYC_Pos)
19162#define RCC_CICR_PLLRDYC RCC_CICR_PLLRDYC_Msk
19163#define RCC_CICR_PLL2RDYC_Pos (7U)
19164#define RCC_CICR_PLL2RDYC_Msk (0x1UL << RCC_CICR_PLL2RDYC_Pos)
19165#define RCC_CICR_PLL2RDYC RCC_CICR_PLL2RDYC_Msk
19166#define RCC_CICR_PLL3RDYC_Pos (8U)
19167#define RCC_CICR_PLL3RDYC_Msk (0x1UL << RCC_CICR_PLL3RDYC_Pos)
19168#define RCC_CICR_PLL3RDYC RCC_CICR_PLL3RDYC_Msk
19169#define RCC_CICR_LSECSSC_Pos (9U)
19170#define RCC_CICR_LSECSSC_Msk (0x1UL << RCC_CICR_LSECSSC_Pos)
19171#define RCC_CICR_LSECSSC RCC_CICR_LSECSSC_Msk
19172#define RCC_CICR_HSECSSC_Pos (10U)
19173#define RCC_CICR_HSECSSC_Msk (0x1UL << RCC_CICR_HSECSSC_Pos)
19174#define RCC_CICR_HSECSSC RCC_CICR_HSECSSC_Msk
19175
19176/******************** Bit definition for RCC_BDCR register ******************/
19177#define RCC_BDCR_LSEON_Pos (0U)
19178#define RCC_BDCR_LSEON_Msk (0x1UL << RCC_BDCR_LSEON_Pos)
19179#define RCC_BDCR_LSEON RCC_BDCR_LSEON_Msk
19180#define RCC_BDCR_LSERDY_Pos (1U)
19181#define RCC_BDCR_LSERDY_Msk (0x1UL << RCC_BDCR_LSERDY_Pos)
19182#define RCC_BDCR_LSERDY RCC_BDCR_LSERDY_Msk
19183#define RCC_BDCR_LSEBYP_Pos (2U)
19184#define RCC_BDCR_LSEBYP_Msk (0x1UL << RCC_BDCR_LSEBYP_Pos)
19185#define RCC_BDCR_LSEBYP RCC_BDCR_LSEBYP_Msk
19186
19187#define RCC_BDCR_LSEDRV_Pos (3U)
19188#define RCC_BDCR_LSEDRV_Msk (0x3UL << RCC_BDCR_LSEDRV_Pos)
19189#define RCC_BDCR_LSEDRV RCC_BDCR_LSEDRV_Msk
19190#define RCC_BDCR_LSEDRV_0 (0x1UL << RCC_BDCR_LSEDRV_Pos)
19191#define RCC_BDCR_LSEDRV_1 (0x2UL << RCC_BDCR_LSEDRV_Pos)
19193#define RCC_BDCR_LSECSSON_Pos (5U)
19194#define RCC_BDCR_LSECSSON_Msk (0x1UL << RCC_BDCR_LSECSSON_Pos)
19195#define RCC_BDCR_LSECSSON RCC_BDCR_LSECSSON_Msk
19196#define RCC_BDCR_LSECSSD_Pos (6U)
19197#define RCC_BDCR_LSECSSD_Msk (0x1UL << RCC_BDCR_LSECSSD_Pos)
19198#define RCC_BDCR_LSECSSD RCC_BDCR_LSECSSD_Msk
19199
19200#define RCC_BDCR_RTCSEL_Pos (8U)
19201#define RCC_BDCR_RTCSEL_Msk (0x3UL << RCC_BDCR_RTCSEL_Pos)
19202#define RCC_BDCR_RTCSEL RCC_BDCR_RTCSEL_Msk
19203#define RCC_BDCR_RTCSEL_0 (0x1UL << RCC_BDCR_RTCSEL_Pos)
19204#define RCC_BDCR_RTCSEL_1 (0x2UL << RCC_BDCR_RTCSEL_Pos)
19206#define RCC_BDCR_RTCEN_Pos (15U)
19207#define RCC_BDCR_RTCEN_Msk (0x1UL << RCC_BDCR_RTCEN_Pos)
19208#define RCC_BDCR_RTCEN RCC_BDCR_RTCEN_Msk
19209#define RCC_BDCR_BDRST_Pos (16U)
19210#define RCC_BDCR_BDRST_Msk (0x1UL << RCC_BDCR_BDRST_Pos)
19211#define RCC_BDCR_BDRST RCC_BDCR_BDRST_Msk
19212/******************** Bit definition for RCC_CSR register *******************/
19213#define RCC_CSR_LSION_Pos (0U)
19214#define RCC_CSR_LSION_Msk (0x1UL << RCC_CSR_LSION_Pos)
19215#define RCC_CSR_LSION RCC_CSR_LSION_Msk
19216#define RCC_CSR_LSIRDY_Pos (1U)
19217#define RCC_CSR_LSIRDY_Msk (0x1UL << RCC_CSR_LSIRDY_Pos)
19218#define RCC_CSR_LSIRDY RCC_CSR_LSIRDY_Msk
19219
19220
19221/******************** Bit definition for RCC_AHB3ENR register **************/
19222#define RCC_AHB3ENR_MDMAEN_Pos (0U)
19223#define RCC_AHB3ENR_MDMAEN_Msk (0x1UL << RCC_AHB3ENR_MDMAEN_Pos)
19224#define RCC_AHB3ENR_MDMAEN RCC_AHB3ENR_MDMAEN_Msk
19225#define RCC_AHB3ENR_DMA2DEN_Pos (4U)
19226#define RCC_AHB3ENR_DMA2DEN_Msk (0x1UL << RCC_AHB3ENR_DMA2DEN_Pos)
19227#define RCC_AHB3ENR_DMA2DEN RCC_AHB3ENR_DMA2DEN_Msk
19228#define RCC_AHB3ENR_JPGDECEN_Pos (5U)
19229#define RCC_AHB3ENR_JPGDECEN_Msk (0x1UL << RCC_AHB3ENR_JPGDECEN_Pos)
19230#define RCC_AHB3ENR_JPGDECEN RCC_AHB3ENR_JPGDECEN_Msk
19231#define RCC_AHB3ENR_FMCEN_Pos (12U)
19232#define RCC_AHB3ENR_FMCEN_Msk (0x1UL << RCC_AHB3ENR_FMCEN_Pos)
19233#define RCC_AHB3ENR_FMCEN RCC_AHB3ENR_FMCEN_Msk
19234#define RCC_AHB3ENR_QSPIEN_Pos (14U)
19235#define RCC_AHB3ENR_QSPIEN_Msk (0x1UL << RCC_AHB3ENR_QSPIEN_Pos)
19236#define RCC_AHB3ENR_QSPIEN RCC_AHB3ENR_QSPIEN_Msk
19237#define RCC_AHB3ENR_SDMMC1EN_Pos (16U)
19238#define RCC_AHB3ENR_SDMMC1EN_Msk (0x1UL << RCC_AHB3ENR_SDMMC1EN_Pos)
19239#define RCC_AHB3ENR_SDMMC1EN RCC_AHB3ENR_SDMMC1EN_Msk
19240#define RCC_AHB3ENR_FLASHEN_Pos (8U)
19241#define RCC_AHB3ENR_FLASHEN_Msk (0x1UL << RCC_AHB3ENR_FLASHEN_Pos)
19242#define RCC_AHB3ENR_FLASHEN RCC_AHB3ENR_FLASHEN_Msk
19243#define RCC_AHB3ENR_DTCM1EN_Pos (28U)
19244#define RCC_AHB3ENR_DTCM1EN_Msk (0x1UL << RCC_AHB3ENR_DTCM1EN_Pos)
19245#define RCC_AHB3ENR_DTCM1EN RCC_AHB3ENR_DTCM1EN_Msk
19246#define RCC_AHB3ENR_DTCM2EN_Pos (29U)
19247#define RCC_AHB3ENR_DTCM2EN_Msk (0x1UL << RCC_AHB3ENR_DTCM2EN_Pos)
19248#define RCC_AHB3ENR_DTCM2EN RCC_AHB3ENR_DTCM2EN_Msk
19249#define RCC_AHB3ENR_ITCMEN_Pos (30U)
19250#define RCC_AHB3ENR_ITCMEN_Msk (0x1UL << RCC_AHB3ENR_ITCMEN_Pos)
19251#define RCC_AHB3ENR_ITCMEN RCC_AHB3ENR_ITCMEN_Msk
19252#define RCC_AHB3ENR_AXISRAMEN_Pos (31U)
19253#define RCC_AHB3ENR_AXISRAMEN_Msk (0x1UL << RCC_AHB3ENR_AXISRAMEN_Pos)
19254#define RCC_AHB3ENR_AXISRAMEN RCC_AHB3ENR_AXISRAMEN_Msk
19255
19256/* Legacy define */
19257#define RCC_AHB3ENR_D1SRAM1EN_Pos RCC_AHB3ENR_AXISRAMEN_Pos
19258#define RCC_AHB3ENR_D1SRAM1EN_Msk RCC_AHB3ENR_AXISRAMEN_Msk
19259#define RCC_AHB3ENR_D1SRAM1EN RCC_AHB3ENR_AXISRAMEN
19260
19261/******************** Bit definition for RCC_AHB1ENR register ***************/
19262#define RCC_AHB1ENR_DMA1EN_Pos (0U)
19263#define RCC_AHB1ENR_DMA1EN_Msk (0x1UL << RCC_AHB1ENR_DMA1EN_Pos)
19264#define RCC_AHB1ENR_DMA1EN RCC_AHB1ENR_DMA1EN_Msk
19265#define RCC_AHB1ENR_DMA2EN_Pos (1U)
19266#define RCC_AHB1ENR_DMA2EN_Msk (0x1UL << RCC_AHB1ENR_DMA2EN_Pos)
19267#define RCC_AHB1ENR_DMA2EN RCC_AHB1ENR_DMA2EN_Msk
19268#define RCC_AHB1ENR_ADC12EN_Pos (5U)
19269#define RCC_AHB1ENR_ADC12EN_Msk (0x1UL << RCC_AHB1ENR_ADC12EN_Pos)
19270#define RCC_AHB1ENR_ADC12EN RCC_AHB1ENR_ADC12EN_Msk
19271#define RCC_AHB1ENR_ARTEN_Pos (14U)
19272#define RCC_AHB1ENR_ARTEN_Msk (0x1UL << RCC_AHB1ENR_ARTEN_Pos)
19273#define RCC_AHB1ENR_ARTEN RCC_AHB1ENR_ARTEN_Msk
19274#define RCC_AHB1ENR_ETH1MACEN_Pos (15U)
19275#define RCC_AHB1ENR_ETH1MACEN_Msk (0x1UL << RCC_AHB1ENR_ETH1MACEN_Pos)
19276#define RCC_AHB1ENR_ETH1MACEN RCC_AHB1ENR_ETH1MACEN_Msk
19277#define RCC_AHB1ENR_ETH1TXEN_Pos (16U)
19278#define RCC_AHB1ENR_ETH1TXEN_Msk (0x1UL << RCC_AHB1ENR_ETH1TXEN_Pos)
19279#define RCC_AHB1ENR_ETH1TXEN RCC_AHB1ENR_ETH1TXEN_Msk
19280#define RCC_AHB1ENR_ETH1RXEN_Pos (17U)
19281#define RCC_AHB1ENR_ETH1RXEN_Msk (0x1UL << RCC_AHB1ENR_ETH1RXEN_Pos)
19282#define RCC_AHB1ENR_ETH1RXEN RCC_AHB1ENR_ETH1RXEN_Msk
19283#define RCC_AHB1ENR_USB1OTGHSEN_Pos (25U)
19284#define RCC_AHB1ENR_USB1OTGHSEN_Msk (0x1UL << RCC_AHB1ENR_USB1OTGHSEN_Pos)
19285#define RCC_AHB1ENR_USB1OTGHSEN RCC_AHB1ENR_USB1OTGHSEN_Msk
19286#define RCC_AHB1ENR_USB1OTGHSULPIEN_Pos (26U)
19287#define RCC_AHB1ENR_USB1OTGHSULPIEN_Msk (0x1UL << RCC_AHB1ENR_USB1OTGHSULPIEN_Pos)
19288#define RCC_AHB1ENR_USB1OTGHSULPIEN RCC_AHB1ENR_USB1OTGHSULPIEN_Msk
19289#define RCC_AHB1ENR_USB2OTGFSEN_Pos (27U)
19290#define RCC_AHB1ENR_USB2OTGFSEN_Msk (0x1UL << RCC_AHB1ENR_USB2OTGFSEN_Pos)
19291#define RCC_AHB1ENR_USB2OTGFSEN RCC_AHB1ENR_USB2OTGFSEN_Msk
19292#define RCC_AHB1ENR_USB2OTGFSULPIEN_Pos (28U)
19293#define RCC_AHB1ENR_USB2OTGFSULPIEN_Msk (0x1UL << RCC_AHB1ENR_USB2OTGFSULPIEN_Pos)
19294#define RCC_AHB1ENR_USB2OTGFSULPIEN RCC_AHB1ENR_USB2OTGFSULPIEN_Msk
19295
19296/* Legacy define */
19297#define RCC_AHB1ENR_USB2OTGHSEN_Pos RCC_AHB1ENR_USB2OTGFSEN_Pos
19298#define RCC_AHB1ENR_USB2OTGHSEN_Msk RCC_AHB1ENR_USB2OTGFSEN_Msk
19299#define RCC_AHB1ENR_USB2OTGHSEN RCC_AHB1ENR_USB2OTGFSEN
19300#define RCC_AHB1ENR_USB2OTGHSULPIEN_Pos RCC_AHB1ENR_USB2OTGFSULPIEN_Pos
19301#define RCC_AHB1ENR_USB2OTGHSULPIEN_Msk RCC_AHB1ENR_USB2OTGFSULPIEN_Msk
19302#define RCC_AHB1ENR_USB2OTGHSULPIEN RCC_AHB1ENR_USB2OTGFSULPIEN
19303
19304
19305/******************** Bit definition for RCC_AHB2ENR register ***************/
19306#define RCC_AHB2ENR_DCMIEN_Pos (0U)
19307#define RCC_AHB2ENR_DCMIEN_Msk (0x1UL << RCC_AHB2ENR_DCMIEN_Pos)
19308#define RCC_AHB2ENR_DCMIEN RCC_AHB2ENR_DCMIEN_Msk
19309#define RCC_AHB2ENR_CRYPEN_Pos (4U)
19310#define RCC_AHB2ENR_CRYPEN_Msk (0x1UL << RCC_AHB2ENR_CRYPEN_Pos)
19311#define RCC_AHB2ENR_CRYPEN RCC_AHB2ENR_CRYPEN_Msk
19312#define RCC_AHB2ENR_HASHEN_Pos (5U)
19313#define RCC_AHB2ENR_HASHEN_Msk (0x1UL << RCC_AHB2ENR_HASHEN_Pos)
19314#define RCC_AHB2ENR_HASHEN RCC_AHB2ENR_HASHEN_Msk
19315#define RCC_AHB2ENR_RNGEN_Pos (6U)
19316#define RCC_AHB2ENR_RNGEN_Msk (0x1UL << RCC_AHB2ENR_RNGEN_Pos)
19317#define RCC_AHB2ENR_RNGEN RCC_AHB2ENR_RNGEN_Msk
19318#define RCC_AHB2ENR_SDMMC2EN_Pos (9U)
19319#define RCC_AHB2ENR_SDMMC2EN_Msk (0x1UL << RCC_AHB2ENR_SDMMC2EN_Pos)
19320#define RCC_AHB2ENR_SDMMC2EN RCC_AHB2ENR_SDMMC2EN_Msk
19321#define RCC_AHB2ENR_SRAM1EN_Pos (29U)
19322#define RCC_AHB2ENR_SRAM1EN_Msk (0x1UL << RCC_AHB2ENR_SRAM1EN_Pos)
19323#define RCC_AHB2ENR_SRAM1EN RCC_AHB2ENR_SRAM1EN_Msk
19324#define RCC_AHB2ENR_SRAM2EN_Pos (30U)
19325#define RCC_AHB2ENR_SRAM2EN_Msk (0x1UL << RCC_AHB2ENR_SRAM2EN_Pos)
19326#define RCC_AHB2ENR_SRAM2EN RCC_AHB2ENR_SRAM2EN_Msk
19327#define RCC_AHB2ENR_SRAM3EN_Pos (31U)
19328#define RCC_AHB2ENR_SRAM3EN_Msk (0x1UL << RCC_AHB2ENR_SRAM3EN_Pos)
19329#define RCC_AHB2ENR_SRAM3EN RCC_AHB2ENR_SRAM3EN_Msk
19330
19331/* Legacy define */
19332#define RCC_AHB2ENR_D2SRAM1EN_Pos RCC_AHB2ENR_SRAM1EN_Pos
19333#define RCC_AHB2ENR_D2SRAM1EN_Msk RCC_AHB2ENR_SRAM1EN_Msk
19334#define RCC_AHB2ENR_D2SRAM1EN RCC_AHB2ENR_SRAM1EN
19335#define RCC_AHB2ENR_D2SRAM2EN_Pos RCC_AHB2ENR_SRAM2EN_Pos
19336#define RCC_AHB2ENR_D2SRAM2EN_Msk RCC_AHB2ENR_SRAM2EN_Msk
19337#define RCC_AHB2ENR_D2SRAM2EN RCC_AHB2ENR_SRAM2EN
19338#define RCC_AHB2ENR_D2SRAM3EN_Pos RCC_AHB2ENR_SRAM3EN_Pos
19339#define RCC_AHB2ENR_D2SRAM3EN_Msk RCC_AHB2ENR_SRAM3EN_Msk
19340#define RCC_AHB2ENR_D2SRAM3EN RCC_AHB2ENR_SRAM3EN
19341
19342/******************** Bit definition for RCC_AHB4ENR register ******************/
19343#define RCC_AHB4ENR_GPIOAEN_Pos (0U)
19344#define RCC_AHB4ENR_GPIOAEN_Msk (0x1UL << RCC_AHB4ENR_GPIOAEN_Pos)
19345#define RCC_AHB4ENR_GPIOAEN RCC_AHB4ENR_GPIOAEN_Msk
19346#define RCC_AHB4ENR_GPIOBEN_Pos (1U)
19347#define RCC_AHB4ENR_GPIOBEN_Msk (0x1UL << RCC_AHB4ENR_GPIOBEN_Pos)
19348#define RCC_AHB4ENR_GPIOBEN RCC_AHB4ENR_GPIOBEN_Msk
19349#define RCC_AHB4ENR_GPIOCEN_Pos (2U)
19350#define RCC_AHB4ENR_GPIOCEN_Msk (0x1UL << RCC_AHB4ENR_GPIOCEN_Pos)
19351#define RCC_AHB4ENR_GPIOCEN RCC_AHB4ENR_GPIOCEN_Msk
19352#define RCC_AHB4ENR_GPIODEN_Pos (3U)
19353#define RCC_AHB4ENR_GPIODEN_Msk (0x1UL << RCC_AHB4ENR_GPIODEN_Pos)
19354#define RCC_AHB4ENR_GPIODEN RCC_AHB4ENR_GPIODEN_Msk
19355#define RCC_AHB4ENR_GPIOEEN_Pos (4U)
19356#define RCC_AHB4ENR_GPIOEEN_Msk (0x1UL << RCC_AHB4ENR_GPIOEEN_Pos)
19357#define RCC_AHB4ENR_GPIOEEN RCC_AHB4ENR_GPIOEEN_Msk
19358#define RCC_AHB4ENR_GPIOFEN_Pos (5U)
19359#define RCC_AHB4ENR_GPIOFEN_Msk (0x1UL << RCC_AHB4ENR_GPIOFEN_Pos)
19360#define RCC_AHB4ENR_GPIOFEN RCC_AHB4ENR_GPIOFEN_Msk
19361#define RCC_AHB4ENR_GPIOGEN_Pos (6U)
19362#define RCC_AHB4ENR_GPIOGEN_Msk (0x1UL << RCC_AHB4ENR_GPIOGEN_Pos)
19363#define RCC_AHB4ENR_GPIOGEN RCC_AHB4ENR_GPIOGEN_Msk
19364#define RCC_AHB4ENR_GPIOHEN_Pos (7U)
19365#define RCC_AHB4ENR_GPIOHEN_Msk (0x1UL << RCC_AHB4ENR_GPIOHEN_Pos)
19366#define RCC_AHB4ENR_GPIOHEN RCC_AHB4ENR_GPIOHEN_Msk
19367#define RCC_AHB4ENR_GPIOIEN_Pos (8U)
19368#define RCC_AHB4ENR_GPIOIEN_Msk (0x1UL << RCC_AHB4ENR_GPIOIEN_Pos)
19369#define RCC_AHB4ENR_GPIOIEN RCC_AHB4ENR_GPIOIEN_Msk
19370#define RCC_AHB4ENR_GPIOJEN_Pos (9U)
19371#define RCC_AHB4ENR_GPIOJEN_Msk (0x1UL << RCC_AHB4ENR_GPIOJEN_Pos)
19372#define RCC_AHB4ENR_GPIOJEN RCC_AHB4ENR_GPIOJEN_Msk
19373#define RCC_AHB4ENR_GPIOKEN_Pos (10U)
19374#define RCC_AHB4ENR_GPIOKEN_Msk (0x1UL << RCC_AHB4ENR_GPIOKEN_Pos)
19375#define RCC_AHB4ENR_GPIOKEN RCC_AHB4ENR_GPIOKEN_Msk
19376#define RCC_AHB4ENR_CRCEN_Pos (19U)
19377#define RCC_AHB4ENR_CRCEN_Msk (0x1UL << RCC_AHB4ENR_CRCEN_Pos)
19378#define RCC_AHB4ENR_CRCEN RCC_AHB4ENR_CRCEN_Msk
19379#define RCC_AHB4ENR_BDMAEN_Pos (21U)
19380#define RCC_AHB4ENR_BDMAEN_Msk (0x1UL << RCC_AHB4ENR_BDMAEN_Pos)
19381#define RCC_AHB4ENR_BDMAEN RCC_AHB4ENR_BDMAEN_Msk
19382#define RCC_AHB4ENR_ADC3EN_Pos (24U)
19383#define RCC_AHB4ENR_ADC3EN_Msk (0x1UL << RCC_AHB4ENR_ADC3EN_Pos)
19384#define RCC_AHB4ENR_ADC3EN RCC_AHB4ENR_ADC3EN_Msk
19385#define RCC_AHB4ENR_HSEMEN_Pos (25U)
19386#define RCC_AHB4ENR_HSEMEN_Msk (0x1UL << RCC_AHB4ENR_HSEMEN_Pos)
19387#define RCC_AHB4ENR_HSEMEN RCC_AHB4ENR_HSEMEN_Msk
19388#define RCC_AHB4ENR_BKPRAMEN_Pos (28U)
19389#define RCC_AHB4ENR_BKPRAMEN_Msk (0x1UL << RCC_AHB4ENR_BKPRAMEN_Pos)
19390#define RCC_AHB4ENR_BKPRAMEN RCC_AHB4ENR_BKPRAMEN_Msk
19391
19392/******************** Bit definition for RCC_APB3ENR register ******************/
19393#define RCC_APB3ENR_LTDCEN_Pos (3U)
19394#define RCC_APB3ENR_LTDCEN_Msk (0x1UL << RCC_APB3ENR_LTDCEN_Pos)
19395#define RCC_APB3ENR_LTDCEN RCC_APB3ENR_LTDCEN_Msk
19396#define RCC_APB3ENR_DSIEN_Pos (4U)
19397#define RCC_APB3ENR_DSIEN_Msk (0x1UL << RCC_APB3ENR_DSIEN_Pos)
19398#define RCC_APB3ENR_DSIEN RCC_APB3ENR_DSIEN_Msk
19399#define RCC_APB3ENR_WWDG1EN_Pos (6U)
19400#define RCC_APB3ENR_WWDG1EN_Msk (0x1UL << RCC_APB3ENR_WWDG1EN_Pos)
19401#define RCC_APB3ENR_WWDG1EN RCC_APB3ENR_WWDG1EN_Msk
19402
19403/******************** Bit definition for RCC_APB1LENR register ******************/
19404
19405#define RCC_APB1LENR_TIM2EN_Pos (0U)
19406#define RCC_APB1LENR_TIM2EN_Msk (0x1UL << RCC_APB1LENR_TIM2EN_Pos)
19407#define RCC_APB1LENR_TIM2EN RCC_APB1LENR_TIM2EN_Msk
19408#define RCC_APB1LENR_TIM3EN_Pos (1U)
19409#define RCC_APB1LENR_TIM3EN_Msk (0x1UL << RCC_APB1LENR_TIM3EN_Pos)
19410#define RCC_APB1LENR_TIM3EN RCC_APB1LENR_TIM3EN_Msk
19411#define RCC_APB1LENR_TIM4EN_Pos (2U)
19412#define RCC_APB1LENR_TIM4EN_Msk (0x1UL << RCC_APB1LENR_TIM4EN_Pos)
19413#define RCC_APB1LENR_TIM4EN RCC_APB1LENR_TIM4EN_Msk
19414#define RCC_APB1LENR_TIM5EN_Pos (3U)
19415#define RCC_APB1LENR_TIM5EN_Msk (0x1UL << RCC_APB1LENR_TIM5EN_Pos)
19416#define RCC_APB1LENR_TIM5EN RCC_APB1LENR_TIM5EN_Msk
19417#define RCC_APB1LENR_TIM6EN_Pos (4U)
19418#define RCC_APB1LENR_TIM6EN_Msk (0x1UL << RCC_APB1LENR_TIM6EN_Pos)
19419#define RCC_APB1LENR_TIM6EN RCC_APB1LENR_TIM6EN_Msk
19420#define RCC_APB1LENR_TIM7EN_Pos (5U)
19421#define RCC_APB1LENR_TIM7EN_Msk (0x1UL << RCC_APB1LENR_TIM7EN_Pos)
19422#define RCC_APB1LENR_TIM7EN RCC_APB1LENR_TIM7EN_Msk
19423#define RCC_APB1LENR_TIM12EN_Pos (6U)
19424#define RCC_APB1LENR_TIM12EN_Msk (0x1UL << RCC_APB1LENR_TIM12EN_Pos)
19425#define RCC_APB1LENR_TIM12EN RCC_APB1LENR_TIM12EN_Msk
19426#define RCC_APB1LENR_TIM13EN_Pos (7U)
19427#define RCC_APB1LENR_TIM13EN_Msk (0x1UL << RCC_APB1LENR_TIM13EN_Pos)
19428#define RCC_APB1LENR_TIM13EN RCC_APB1LENR_TIM13EN_Msk
19429#define RCC_APB1LENR_TIM14EN_Pos (8U)
19430#define RCC_APB1LENR_TIM14EN_Msk (0x1UL << RCC_APB1LENR_TIM14EN_Pos)
19431#define RCC_APB1LENR_TIM14EN RCC_APB1LENR_TIM14EN_Msk
19432#define RCC_APB1LENR_LPTIM1EN_Pos (9U)
19433#define RCC_APB1LENR_LPTIM1EN_Msk (0x1UL << RCC_APB1LENR_LPTIM1EN_Pos)
19434#define RCC_APB1LENR_LPTIM1EN RCC_APB1LENR_LPTIM1EN_Msk
19435
19436#define RCC_APB1LENR_WWDG2EN_Pos (11U)
19437#define RCC_APB1LENR_WWDG2EN_Msk (0x1UL << RCC_APB1LENR_WWDG2EN_Pos)
19438#define RCC_APB1LENR_WWDG2EN RCC_APB1LENR_WWDG2EN_Msk
19439
19440#define RCC_APB1LENR_SPI2EN_Pos (14U)
19441#define RCC_APB1LENR_SPI2EN_Msk (0x1UL << RCC_APB1LENR_SPI2EN_Pos)
19442#define RCC_APB1LENR_SPI2EN RCC_APB1LENR_SPI2EN_Msk
19443#define RCC_APB1LENR_SPI3EN_Pos (15U)
19444#define RCC_APB1LENR_SPI3EN_Msk (0x1UL << RCC_APB1LENR_SPI3EN_Pos)
19445#define RCC_APB1LENR_SPI3EN RCC_APB1LENR_SPI3EN_Msk
19446#define RCC_APB1LENR_SPDIFRXEN_Pos (16U)
19447#define RCC_APB1LENR_SPDIFRXEN_Msk (0x1UL << RCC_APB1LENR_SPDIFRXEN_Pos)
19448#define RCC_APB1LENR_SPDIFRXEN RCC_APB1LENR_SPDIFRXEN_Msk
19449#define RCC_APB1LENR_USART2EN_Pos (17U)
19450#define RCC_APB1LENR_USART2EN_Msk (0x1UL << RCC_APB1LENR_USART2EN_Pos)
19451#define RCC_APB1LENR_USART2EN RCC_APB1LENR_USART2EN_Msk
19452#define RCC_APB1LENR_USART3EN_Pos (18U)
19453#define RCC_APB1LENR_USART3EN_Msk (0x1UL << RCC_APB1LENR_USART3EN_Pos)
19454#define RCC_APB1LENR_USART3EN RCC_APB1LENR_USART3EN_Msk
19455#define RCC_APB1LENR_UART4EN_Pos (19U)
19456#define RCC_APB1LENR_UART4EN_Msk (0x1UL << RCC_APB1LENR_UART4EN_Pos)
19457#define RCC_APB1LENR_UART4EN RCC_APB1LENR_UART4EN_Msk
19458#define RCC_APB1LENR_UART5EN_Pos (20U)
19459#define RCC_APB1LENR_UART5EN_Msk (0x1UL << RCC_APB1LENR_UART5EN_Pos)
19460#define RCC_APB1LENR_UART5EN RCC_APB1LENR_UART5EN_Msk
19461#define RCC_APB1LENR_I2C1EN_Pos (21U)
19462#define RCC_APB1LENR_I2C1EN_Msk (0x1UL << RCC_APB1LENR_I2C1EN_Pos)
19463#define RCC_APB1LENR_I2C1EN RCC_APB1LENR_I2C1EN_Msk
19464#define RCC_APB1LENR_I2C2EN_Pos (22U)
19465#define RCC_APB1LENR_I2C2EN_Msk (0x1UL << RCC_APB1LENR_I2C2EN_Pos)
19466#define RCC_APB1LENR_I2C2EN RCC_APB1LENR_I2C2EN_Msk
19467#define RCC_APB1LENR_I2C3EN_Pos (23U)
19468#define RCC_APB1LENR_I2C3EN_Msk (0x1UL << RCC_APB1LENR_I2C3EN_Pos)
19469#define RCC_APB1LENR_I2C3EN RCC_APB1LENR_I2C3EN_Msk
19470#define RCC_APB1LENR_CECEN_Pos (27U)
19471#define RCC_APB1LENR_CECEN_Msk (0x1UL << RCC_APB1LENR_CECEN_Pos)
19472#define RCC_APB1LENR_CECEN RCC_APB1LENR_CECEN_Msk
19473#define RCC_APB1LENR_DAC12EN_Pos (29U)
19474#define RCC_APB1LENR_DAC12EN_Msk (0x1UL << RCC_APB1LENR_DAC12EN_Pos)
19475#define RCC_APB1LENR_DAC12EN RCC_APB1LENR_DAC12EN_Msk
19476#define RCC_APB1LENR_UART7EN_Pos (30U)
19477#define RCC_APB1LENR_UART7EN_Msk (0x1UL << RCC_APB1LENR_UART7EN_Pos)
19478#define RCC_APB1LENR_UART7EN RCC_APB1LENR_UART7EN_Msk
19479#define RCC_APB1LENR_UART8EN_Pos (31U)
19480#define RCC_APB1LENR_UART8EN_Msk (0x1UL << RCC_APB1LENR_UART8EN_Pos)
19481#define RCC_APB1LENR_UART8EN RCC_APB1LENR_UART8EN_Msk
19482
19483/* Legacy define */
19484#define RCC_APB1LENR_HDMICECEN_Pos RCC_APB1LENR_CECEN_Pos
19485#define RCC_APB1LENR_HDMICECEN_Msk RCC_APB1LENR_CECEN_Msk
19486#define RCC_APB1LENR_HDMICECEN RCC_APB1LENR_CECEN
19487/******************** Bit definition for RCC_APB1HENR register ******************/
19488#define RCC_APB1HENR_CRSEN_Pos (1U)
19489#define RCC_APB1HENR_CRSEN_Msk (0x1UL << RCC_APB1HENR_CRSEN_Pos)
19490#define RCC_APB1HENR_CRSEN RCC_APB1HENR_CRSEN_Msk
19491#define RCC_APB1HENR_SWPMIEN_Pos (2U)
19492#define RCC_APB1HENR_SWPMIEN_Msk (0x1UL << RCC_APB1HENR_SWPMIEN_Pos)
19493#define RCC_APB1HENR_SWPMIEN RCC_APB1HENR_SWPMIEN_Msk
19494#define RCC_APB1HENR_OPAMPEN_Pos (4U)
19495#define RCC_APB1HENR_OPAMPEN_Msk (0x1UL << RCC_APB1HENR_OPAMPEN_Pos)
19496#define RCC_APB1HENR_OPAMPEN RCC_APB1HENR_OPAMPEN_Msk
19497#define RCC_APB1HENR_MDIOSEN_Pos (5U)
19498#define RCC_APB1HENR_MDIOSEN_Msk (0x1UL << RCC_APB1HENR_MDIOSEN_Pos)
19499#define RCC_APB1HENR_MDIOSEN RCC_APB1HENR_MDIOSEN_Msk
19500#define RCC_APB1HENR_FDCANEN_Pos (8U)
19501#define RCC_APB1HENR_FDCANEN_Msk (0x1UL << RCC_APB1HENR_FDCANEN_Pos)
19502#define RCC_APB1HENR_FDCANEN RCC_APB1HENR_FDCANEN_Msk
19503
19504/******************** Bit definition for RCC_APB2ENR register ******************/
19505#define RCC_APB2ENR_TIM1EN_Pos (0U)
19506#define RCC_APB2ENR_TIM1EN_Msk (0x1UL << RCC_APB2ENR_TIM1EN_Pos)
19507#define RCC_APB2ENR_TIM1EN RCC_APB2ENR_TIM1EN_Msk
19508#define RCC_APB2ENR_TIM8EN_Pos (1U)
19509#define RCC_APB2ENR_TIM8EN_Msk (0x1UL << RCC_APB2ENR_TIM8EN_Pos)
19510#define RCC_APB2ENR_TIM8EN RCC_APB2ENR_TIM8EN_Msk
19511#define RCC_APB2ENR_USART1EN_Pos (4U)
19512#define RCC_APB2ENR_USART1EN_Msk (0x1UL << RCC_APB2ENR_USART1EN_Pos)
19513#define RCC_APB2ENR_USART1EN RCC_APB2ENR_USART1EN_Msk
19514#define RCC_APB2ENR_USART6EN_Pos (5U)
19515#define RCC_APB2ENR_USART6EN_Msk (0x1UL << RCC_APB2ENR_USART6EN_Pos)
19516#define RCC_APB2ENR_USART6EN RCC_APB2ENR_USART6EN_Msk
19517#define RCC_APB2ENR_SPI1EN_Pos (12U)
19518#define RCC_APB2ENR_SPI1EN_Msk (0x1UL << RCC_APB2ENR_SPI1EN_Pos)
19519#define RCC_APB2ENR_SPI1EN RCC_APB2ENR_SPI1EN_Msk
19520#define RCC_APB2ENR_SPI4EN_Pos (13U)
19521#define RCC_APB2ENR_SPI4EN_Msk (0x1UL << RCC_APB2ENR_SPI4EN_Pos)
19522#define RCC_APB2ENR_SPI4EN RCC_APB2ENR_SPI4EN_Msk
19523#define RCC_APB2ENR_TIM15EN_Pos (16U)
19524#define RCC_APB2ENR_TIM15EN_Msk (0x1UL << RCC_APB2ENR_TIM15EN_Pos)
19525#define RCC_APB2ENR_TIM15EN RCC_APB2ENR_TIM15EN_Msk
19526#define RCC_APB2ENR_TIM16EN_Pos (17U)
19527#define RCC_APB2ENR_TIM16EN_Msk (0x1UL << RCC_APB2ENR_TIM16EN_Pos)
19528#define RCC_APB2ENR_TIM16EN RCC_APB2ENR_TIM16EN_Msk
19529#define RCC_APB2ENR_TIM17EN_Pos (18U)
19530#define RCC_APB2ENR_TIM17EN_Msk (0x1UL << RCC_APB2ENR_TIM17EN_Pos)
19531#define RCC_APB2ENR_TIM17EN RCC_APB2ENR_TIM17EN_Msk
19532#define RCC_APB2ENR_SPI5EN_Pos (20U)
19533#define RCC_APB2ENR_SPI5EN_Msk (0x1UL << RCC_APB2ENR_SPI5EN_Pos)
19534#define RCC_APB2ENR_SPI5EN RCC_APB2ENR_SPI5EN_Msk
19535#define RCC_APB2ENR_SAI1EN_Pos (22U)
19536#define RCC_APB2ENR_SAI1EN_Msk (0x1UL << RCC_APB2ENR_SAI1EN_Pos)
19537#define RCC_APB2ENR_SAI1EN RCC_APB2ENR_SAI1EN_Msk
19538#define RCC_APB2ENR_SAI2EN_Pos (23U)
19539#define RCC_APB2ENR_SAI2EN_Msk (0x1UL << RCC_APB2ENR_SAI2EN_Pos)
19540#define RCC_APB2ENR_SAI2EN RCC_APB2ENR_SAI2EN_Msk
19541#define RCC_APB2ENR_SAI3EN_Pos (24U)
19542#define RCC_APB2ENR_SAI3EN_Msk (0x1UL << RCC_APB2ENR_SAI3EN_Pos)
19543#define RCC_APB2ENR_SAI3EN RCC_APB2ENR_SAI3EN_Msk
19544#define RCC_APB2ENR_DFSDM1EN_Pos (28U)
19545#define RCC_APB2ENR_DFSDM1EN_Msk (0x1UL << RCC_APB2ENR_DFSDM1EN_Pos)
19546#define RCC_APB2ENR_DFSDM1EN RCC_APB2ENR_DFSDM1EN_Msk
19547#define RCC_APB2ENR_HRTIMEN_Pos (29U)
19548#define RCC_APB2ENR_HRTIMEN_Msk (0x1UL << RCC_APB2ENR_HRTIMEN_Pos)
19549#define RCC_APB2ENR_HRTIMEN RCC_APB2ENR_HRTIMEN_Msk
19550
19551/******************** Bit definition for RCC_APB4ENR register ******************/
19552#define RCC_APB4ENR_SYSCFGEN_Pos (1U)
19553#define RCC_APB4ENR_SYSCFGEN_Msk (0x1UL << RCC_APB4ENR_SYSCFGEN_Pos)
19554#define RCC_APB4ENR_SYSCFGEN RCC_APB4ENR_SYSCFGEN_Msk
19555#define RCC_APB4ENR_LPUART1EN_Pos (3U)
19556#define RCC_APB4ENR_LPUART1EN_Msk (0x1UL << RCC_APB4ENR_LPUART1EN_Pos)
19557#define RCC_APB4ENR_LPUART1EN RCC_APB4ENR_LPUART1EN_Msk
19558#define RCC_APB4ENR_SPI6EN_Pos (5U)
19559#define RCC_APB4ENR_SPI6EN_Msk (0x1UL << RCC_APB4ENR_SPI6EN_Pos)
19560#define RCC_APB4ENR_SPI6EN RCC_APB4ENR_SPI6EN_Msk
19561#define RCC_APB4ENR_I2C4EN_Pos (7U)
19562#define RCC_APB4ENR_I2C4EN_Msk (0x1UL << RCC_APB4ENR_I2C4EN_Pos)
19563#define RCC_APB4ENR_I2C4EN RCC_APB4ENR_I2C4EN_Msk
19564#define RCC_APB4ENR_LPTIM2EN_Pos (9U)
19565#define RCC_APB4ENR_LPTIM2EN_Msk (0x1UL << RCC_APB4ENR_LPTIM2EN_Pos)
19566#define RCC_APB4ENR_LPTIM2EN RCC_APB4ENR_LPTIM2EN_Msk
19567#define RCC_APB4ENR_LPTIM3EN_Pos (10U)
19568#define RCC_APB4ENR_LPTIM3EN_Msk (0x1UL << RCC_APB4ENR_LPTIM3EN_Pos)
19569#define RCC_APB4ENR_LPTIM3EN RCC_APB4ENR_LPTIM3EN_Msk
19570#define RCC_APB4ENR_LPTIM4EN_Pos (11U)
19571#define RCC_APB4ENR_LPTIM4EN_Msk (0x1UL << RCC_APB4ENR_LPTIM4EN_Pos)
19572#define RCC_APB4ENR_LPTIM4EN RCC_APB4ENR_LPTIM4EN_Msk
19573#define RCC_APB4ENR_LPTIM5EN_Pos (12U)
19574#define RCC_APB4ENR_LPTIM5EN_Msk (0x1UL << RCC_APB4ENR_LPTIM5EN_Pos)
19575#define RCC_APB4ENR_LPTIM5EN RCC_APB4ENR_LPTIM5EN_Msk
19576#define RCC_APB4ENR_COMP12EN_Pos (14U)
19577#define RCC_APB4ENR_COMP12EN_Msk (0x1UL << RCC_APB4ENR_COMP12EN_Pos)
19578#define RCC_APB4ENR_COMP12EN RCC_APB4ENR_COMP12EN_Msk
19579#define RCC_APB4ENR_VREFEN_Pos (15U)
19580#define RCC_APB4ENR_VREFEN_Msk (0x1UL << RCC_APB4ENR_VREFEN_Pos)
19581#define RCC_APB4ENR_VREFEN RCC_APB4ENR_VREFEN_Msk
19582#define RCC_APB4ENR_RTCAPBEN_Pos (16U)
19583#define RCC_APB4ENR_RTCAPBEN_Msk (0x1UL << RCC_APB4ENR_RTCAPBEN_Pos)
19584#define RCC_APB4ENR_RTCAPBEN RCC_APB4ENR_RTCAPBEN_Msk
19585#define RCC_APB4ENR_SAI4EN_Pos (21U)
19586#define RCC_APB4ENR_SAI4EN_Msk (0x1UL << RCC_APB4ENR_SAI4EN_Pos)
19587#define RCC_APB4ENR_SAI4EN RCC_APB4ENR_SAI4EN_Msk
19588
19589
19590/******************** Bit definition for RCC_AHB3RSTR register ***************/
19591#define RCC_AHB3RSTR_MDMARST_Pos (0U)
19592#define RCC_AHB3RSTR_MDMARST_Msk (0x1UL << RCC_AHB3RSTR_MDMARST_Pos)
19593#define RCC_AHB3RSTR_MDMARST RCC_AHB3RSTR_MDMARST_Msk
19594#define RCC_AHB3RSTR_DMA2DRST_Pos (4U)
19595#define RCC_AHB3RSTR_DMA2DRST_Msk (0x1UL << RCC_AHB3RSTR_DMA2DRST_Pos)
19596#define RCC_AHB3RSTR_DMA2DRST RCC_AHB3RSTR_DMA2DRST_Msk
19597#define RCC_AHB3RSTR_JPGDECRST_Pos (5U)
19598#define RCC_AHB3RSTR_JPGDECRST_Msk (0x1UL << RCC_AHB3RSTR_JPGDECRST_Pos)
19599#define RCC_AHB3RSTR_JPGDECRST RCC_AHB3RSTR_JPGDECRST_Msk
19600#define RCC_AHB3RSTR_FMCRST_Pos (12U)
19601#define RCC_AHB3RSTR_FMCRST_Msk (0x1UL << RCC_AHB3RSTR_FMCRST_Pos)
19602#define RCC_AHB3RSTR_FMCRST RCC_AHB3RSTR_FMCRST_Msk
19603#define RCC_AHB3RSTR_QSPIRST_Pos (14U)
19604#define RCC_AHB3RSTR_QSPIRST_Msk (0x1UL << RCC_AHB3RSTR_QSPIRST_Pos)
19605#define RCC_AHB3RSTR_QSPIRST RCC_AHB3RSTR_QSPIRST_Msk
19606#define RCC_AHB3RSTR_SDMMC1RST_Pos (16U)
19607#define RCC_AHB3RSTR_SDMMC1RST_Msk (0x1UL << RCC_AHB3RSTR_SDMMC1RST_Pos)
19608#define RCC_AHB3RSTR_SDMMC1RST RCC_AHB3RSTR_SDMMC1RST_Msk
19609
19610
19611/******************** Bit definition for RCC_AHB1RSTR register ***************/
19612#define RCC_AHB1RSTR_DMA1RST_Pos (0U)
19613#define RCC_AHB1RSTR_DMA1RST_Msk (0x1UL << RCC_AHB1RSTR_DMA1RST_Pos)
19614#define RCC_AHB1RSTR_DMA1RST RCC_AHB1RSTR_DMA1RST_Msk
19615#define RCC_AHB1RSTR_DMA2RST_Pos (1U)
19616#define RCC_AHB1RSTR_DMA2RST_Msk (0x1UL << RCC_AHB1RSTR_DMA2RST_Pos)
19617#define RCC_AHB1RSTR_DMA2RST RCC_AHB1RSTR_DMA2RST_Msk
19618#define RCC_AHB1RSTR_ADC12RST_Pos (5U)
19619#define RCC_AHB1RSTR_ADC12RST_Msk (0x1UL << RCC_AHB1RSTR_ADC12RST_Pos)
19620#define RCC_AHB1RSTR_ADC12RST RCC_AHB1RSTR_ADC12RST_Msk
19621#define RCC_AHB1RSTR_ARTRST_Pos (14U)
19622#define RCC_AHB1RSTR_ARTRST_Msk (0x1UL << RCC_AHB1RSTR_ARTRST_Pos)
19623#define RCC_AHB1RSTR_ARTRST RCC_AHB1RSTR_ARTRST_Msk
19624#define RCC_AHB1RSTR_ETH1MACRST_Pos (15U)
19625#define RCC_AHB1RSTR_ETH1MACRST_Msk (0x1UL << RCC_AHB1RSTR_ETH1MACRST_Pos)
19626#define RCC_AHB1RSTR_ETH1MACRST RCC_AHB1RSTR_ETH1MACRST_Msk
19627#define RCC_AHB1RSTR_USB1OTGHSRST_Pos (25U)
19628#define RCC_AHB1RSTR_USB1OTGHSRST_Msk (0x1UL << RCC_AHB1RSTR_USB1OTGHSRST_Pos)
19629#define RCC_AHB1RSTR_USB1OTGHSRST RCC_AHB1RSTR_USB1OTGHSRST_Msk
19630#define RCC_AHB1RSTR_USB2OTGFSRST_Pos (27U)
19631#define RCC_AHB1RSTR_USB2OTGFSRST_Msk (0x1UL << RCC_AHB1RSTR_USB2OTGFSRST_Pos)
19632#define RCC_AHB1RSTR_USB2OTGFSRST RCC_AHB1RSTR_USB2OTGFSRST_Msk
19633
19634/* Legacy define */
19635#define RCC_AHB1RSTR_USB2OTGHSRST_Pos RCC_AHB1RSTR_USB2OTGFSRST_Pos
19636#define RCC_AHB1RSTR_USB2OTGHSRST_Msk RCC_AHB1RSTR_USB2OTGFSRST_Msk
19637#define RCC_AHB1RSTR_USB2OTGHSRST RCC_AHB1RSTR_USB2OTGFSRST
19638
19639/******************** Bit definition for RCC_AHB2RSTR register ***************/
19640#define RCC_AHB2RSTR_DCMIRST_Pos (0U)
19641#define RCC_AHB2RSTR_DCMIRST_Msk (0x1UL << RCC_AHB2RSTR_DCMIRST_Pos)
19642#define RCC_AHB2RSTR_DCMIRST RCC_AHB2RSTR_DCMIRST_Msk
19643#define RCC_AHB2RSTR_CRYPRST_Pos (4U)
19644#define RCC_AHB2RSTR_CRYPRST_Msk (0x1UL << RCC_AHB2RSTR_CRYPRST_Pos)
19645#define RCC_AHB2RSTR_CRYPRST RCC_AHB2RSTR_CRYPRST_Msk
19646#define RCC_AHB2RSTR_HASHRST_Pos (5U)
19647#define RCC_AHB2RSTR_HASHRST_Msk (0x1UL << RCC_AHB2RSTR_HASHRST_Pos)
19648#define RCC_AHB2RSTR_HASHRST RCC_AHB2RSTR_HASHRST_Msk
19649#define RCC_AHB2RSTR_RNGRST_Pos (6U)
19650#define RCC_AHB2RSTR_RNGRST_Msk (0x1UL << RCC_AHB2RSTR_RNGRST_Pos)
19651#define RCC_AHB2RSTR_RNGRST RCC_AHB2RSTR_RNGRST_Msk
19652#define RCC_AHB2RSTR_SDMMC2RST_Pos (9U)
19653#define RCC_AHB2RSTR_SDMMC2RST_Msk (0x1UL << RCC_AHB2RSTR_SDMMC2RST_Pos)
19654#define RCC_AHB2RSTR_SDMMC2RST RCC_AHB2RSTR_SDMMC2RST_Msk
19655
19656/******************** Bit definition for RCC_AHB4RSTR register ******************/
19657#define RCC_AHB4RSTR_GPIOARST_Pos (0U)
19658#define RCC_AHB4RSTR_GPIOARST_Msk (0x1UL << RCC_AHB4RSTR_GPIOARST_Pos)
19659#define RCC_AHB4RSTR_GPIOARST RCC_AHB4RSTR_GPIOARST_Msk
19660#define RCC_AHB4RSTR_GPIOBRST_Pos (1U)
19661#define RCC_AHB4RSTR_GPIOBRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOBRST_Pos)
19662#define RCC_AHB4RSTR_GPIOBRST RCC_AHB4RSTR_GPIOBRST_Msk
19663#define RCC_AHB4RSTR_GPIOCRST_Pos (2U)
19664#define RCC_AHB4RSTR_GPIOCRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOCRST_Pos)
19665#define RCC_AHB4RSTR_GPIOCRST RCC_AHB4RSTR_GPIOCRST_Msk
19666#define RCC_AHB4RSTR_GPIODRST_Pos (3U)
19667#define RCC_AHB4RSTR_GPIODRST_Msk (0x1UL << RCC_AHB4RSTR_GPIODRST_Pos)
19668#define RCC_AHB4RSTR_GPIODRST RCC_AHB4RSTR_GPIODRST_Msk
19669#define RCC_AHB4RSTR_GPIOERST_Pos (4U)
19670#define RCC_AHB4RSTR_GPIOERST_Msk (0x1UL << RCC_AHB4RSTR_GPIOERST_Pos)
19671#define RCC_AHB4RSTR_GPIOERST RCC_AHB4RSTR_GPIOERST_Msk
19672#define RCC_AHB4RSTR_GPIOFRST_Pos (5U)
19673#define RCC_AHB4RSTR_GPIOFRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOFRST_Pos)
19674#define RCC_AHB4RSTR_GPIOFRST RCC_AHB4RSTR_GPIOFRST_Msk
19675#define RCC_AHB4RSTR_GPIOGRST_Pos (6U)
19676#define RCC_AHB4RSTR_GPIOGRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOGRST_Pos)
19677#define RCC_AHB4RSTR_GPIOGRST RCC_AHB4RSTR_GPIOGRST_Msk
19678#define RCC_AHB4RSTR_GPIOHRST_Pos (7U)
19679#define RCC_AHB4RSTR_GPIOHRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOHRST_Pos)
19680#define RCC_AHB4RSTR_GPIOHRST RCC_AHB4RSTR_GPIOHRST_Msk
19681#define RCC_AHB4RSTR_GPIOIRST_Pos (8U)
19682#define RCC_AHB4RSTR_GPIOIRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOIRST_Pos)
19683#define RCC_AHB4RSTR_GPIOIRST RCC_AHB4RSTR_GPIOIRST_Msk
19684#define RCC_AHB4RSTR_GPIOJRST_Pos (9U)
19685#define RCC_AHB4RSTR_GPIOJRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOJRST_Pos)
19686#define RCC_AHB4RSTR_GPIOJRST RCC_AHB4RSTR_GPIOJRST_Msk
19687#define RCC_AHB4RSTR_GPIOKRST_Pos (10U)
19688#define RCC_AHB4RSTR_GPIOKRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOKRST_Pos)
19689#define RCC_AHB4RSTR_GPIOKRST RCC_AHB4RSTR_GPIOKRST_Msk
19690#define RCC_AHB4RSTR_CRCRST_Pos (19U)
19691#define RCC_AHB4RSTR_CRCRST_Msk (0x1UL << RCC_AHB4RSTR_CRCRST_Pos)
19692#define RCC_AHB4RSTR_CRCRST RCC_AHB4RSTR_CRCRST_Msk
19693#define RCC_AHB4RSTR_BDMARST_Pos (21U)
19694#define RCC_AHB4RSTR_BDMARST_Msk (0x1UL << RCC_AHB4RSTR_BDMARST_Pos)
19695#define RCC_AHB4RSTR_BDMARST RCC_AHB4RSTR_BDMARST_Msk
19696#define RCC_AHB4RSTR_ADC3RST_Pos (24U)
19697#define RCC_AHB4RSTR_ADC3RST_Msk (0x1UL << RCC_AHB4RSTR_ADC3RST_Pos)
19698#define RCC_AHB4RSTR_ADC3RST RCC_AHB4RSTR_ADC3RST_Msk
19699#define RCC_AHB4RSTR_HSEMRST_Pos (25U)
19700#define RCC_AHB4RSTR_HSEMRST_Msk (0x1UL << RCC_AHB4RSTR_HSEMRST_Pos)
19701#define RCC_AHB4RSTR_HSEMRST RCC_AHB4RSTR_HSEMRST_Msk
19702
19703
19704/******************** Bit definition for RCC_APB3RSTR register ******************/
19705#define RCC_APB3RSTR_LTDCRST_Pos (3U)
19706#define RCC_APB3RSTR_LTDCRST_Msk (0x1UL << RCC_APB3RSTR_LTDCRST_Pos)
19707#define RCC_APB3RSTR_LTDCRST RCC_APB3RSTR_LTDCRST_Msk
19708#define RCC_APB3RSTR_DSIRST_Pos (4U)
19709#define RCC_APB3RSTR_DSIRST_Msk (0x1UL << RCC_APB3RSTR_DSIRST_Pos)
19710#define RCC_APB3RSTR_DSIRST RCC_APB3RSTR_DSIRST_Msk
19711
19712/******************** Bit definition for RCC_APB1LRSTR register ******************/
19713
19714#define RCC_APB1LRSTR_TIM2RST_Pos (0U)
19715#define RCC_APB1LRSTR_TIM2RST_Msk (0x1UL << RCC_APB1LRSTR_TIM2RST_Pos)
19716#define RCC_APB1LRSTR_TIM2RST RCC_APB1LRSTR_TIM2RST_Msk
19717#define RCC_APB1LRSTR_TIM3RST_Pos (1U)
19718#define RCC_APB1LRSTR_TIM3RST_Msk (0x1UL << RCC_APB1LRSTR_TIM3RST_Pos)
19719#define RCC_APB1LRSTR_TIM3RST RCC_APB1LRSTR_TIM3RST_Msk
19720#define RCC_APB1LRSTR_TIM4RST_Pos (2U)
19721#define RCC_APB1LRSTR_TIM4RST_Msk (0x1UL << RCC_APB1LRSTR_TIM4RST_Pos)
19722#define RCC_APB1LRSTR_TIM4RST RCC_APB1LRSTR_TIM4RST_Msk
19723#define RCC_APB1LRSTR_TIM5RST_Pos (3U)
19724#define RCC_APB1LRSTR_TIM5RST_Msk (0x1UL << RCC_APB1LRSTR_TIM5RST_Pos)
19725#define RCC_APB1LRSTR_TIM5RST RCC_APB1LRSTR_TIM5RST_Msk
19726#define RCC_APB1LRSTR_TIM6RST_Pos (4U)
19727#define RCC_APB1LRSTR_TIM6RST_Msk (0x1UL << RCC_APB1LRSTR_TIM6RST_Pos)
19728#define RCC_APB1LRSTR_TIM6RST RCC_APB1LRSTR_TIM6RST_Msk
19729#define RCC_APB1LRSTR_TIM7RST_Pos (5U)
19730#define RCC_APB1LRSTR_TIM7RST_Msk (0x1UL << RCC_APB1LRSTR_TIM7RST_Pos)
19731#define RCC_APB1LRSTR_TIM7RST RCC_APB1LRSTR_TIM7RST_Msk
19732#define RCC_APB1LRSTR_TIM12RST_Pos (6U)
19733#define RCC_APB1LRSTR_TIM12RST_Msk (0x1UL << RCC_APB1LRSTR_TIM12RST_Pos)
19734#define RCC_APB1LRSTR_TIM12RST RCC_APB1LRSTR_TIM12RST_Msk
19735#define RCC_APB1LRSTR_TIM13RST_Pos (7U)
19736#define RCC_APB1LRSTR_TIM13RST_Msk (0x1UL << RCC_APB1LRSTR_TIM13RST_Pos)
19737#define RCC_APB1LRSTR_TIM13RST RCC_APB1LRSTR_TIM13RST_Msk
19738#define RCC_APB1LRSTR_TIM14RST_Pos (8U)
19739#define RCC_APB1LRSTR_TIM14RST_Msk (0x1UL << RCC_APB1LRSTR_TIM14RST_Pos)
19740#define RCC_APB1LRSTR_TIM14RST RCC_APB1LRSTR_TIM14RST_Msk
19741#define RCC_APB1LRSTR_LPTIM1RST_Pos (9U)
19742#define RCC_APB1LRSTR_LPTIM1RST_Msk (0x1UL << RCC_APB1LRSTR_LPTIM1RST_Pos)
19743#define RCC_APB1LRSTR_LPTIM1RST RCC_APB1LRSTR_LPTIM1RST_Msk
19744#define RCC_APB1LRSTR_SPI2RST_Pos (14U)
19745#define RCC_APB1LRSTR_SPI2RST_Msk (0x1UL << RCC_APB1LRSTR_SPI2RST_Pos)
19746#define RCC_APB1LRSTR_SPI2RST RCC_APB1LRSTR_SPI2RST_Msk
19747#define RCC_APB1LRSTR_SPI3RST_Pos (15U)
19748#define RCC_APB1LRSTR_SPI3RST_Msk (0x1UL << RCC_APB1LRSTR_SPI3RST_Pos)
19749#define RCC_APB1LRSTR_SPI3RST RCC_APB1LRSTR_SPI3RST_Msk
19750#define RCC_APB1LRSTR_SPDIFRXRST_Pos (16U)
19751#define RCC_APB1LRSTR_SPDIFRXRST_Msk (0x1UL << RCC_APB1LRSTR_SPDIFRXRST_Pos)
19752#define RCC_APB1LRSTR_SPDIFRXRST RCC_APB1LRSTR_SPDIFRXRST_Msk
19753#define RCC_APB1LRSTR_USART2RST_Pos (17U)
19754#define RCC_APB1LRSTR_USART2RST_Msk (0x1UL << RCC_APB1LRSTR_USART2RST_Pos)
19755#define RCC_APB1LRSTR_USART2RST RCC_APB1LRSTR_USART2RST_Msk
19756#define RCC_APB1LRSTR_USART3RST_Pos (18U)
19757#define RCC_APB1LRSTR_USART3RST_Msk (0x1UL << RCC_APB1LRSTR_USART3RST_Pos)
19758#define RCC_APB1LRSTR_USART3RST RCC_APB1LRSTR_USART3RST_Msk
19759#define RCC_APB1LRSTR_UART4RST_Pos (19U)
19760#define RCC_APB1LRSTR_UART4RST_Msk (0x1UL << RCC_APB1LRSTR_UART4RST_Pos)
19761#define RCC_APB1LRSTR_UART4RST RCC_APB1LRSTR_UART4RST_Msk
19762#define RCC_APB1LRSTR_UART5RST_Pos (20U)
19763#define RCC_APB1LRSTR_UART5RST_Msk (0x1UL << RCC_APB1LRSTR_UART5RST_Pos)
19764#define RCC_APB1LRSTR_UART5RST RCC_APB1LRSTR_UART5RST_Msk
19765#define RCC_APB1LRSTR_I2C1RST_Pos (21U)
19766#define RCC_APB1LRSTR_I2C1RST_Msk (0x1UL << RCC_APB1LRSTR_I2C1RST_Pos)
19767#define RCC_APB1LRSTR_I2C1RST RCC_APB1LRSTR_I2C1RST_Msk
19768#define RCC_APB1LRSTR_I2C2RST_Pos (22U)
19769#define RCC_APB1LRSTR_I2C2RST_Msk (0x1UL << RCC_APB1LRSTR_I2C2RST_Pos)
19770#define RCC_APB1LRSTR_I2C2RST RCC_APB1LRSTR_I2C2RST_Msk
19771#define RCC_APB1LRSTR_I2C3RST_Pos (23U)
19772#define RCC_APB1LRSTR_I2C3RST_Msk (0x1UL << RCC_APB1LRSTR_I2C3RST_Pos)
19773#define RCC_APB1LRSTR_I2C3RST RCC_APB1LRSTR_I2C3RST_Msk
19774#define RCC_APB1LRSTR_CECRST_Pos (27U)
19775#define RCC_APB1LRSTR_CECRST_Msk (0x1UL << RCC_APB1LRSTR_CECRST_Pos)
19776#define RCC_APB1LRSTR_CECRST RCC_APB1LRSTR_CECRST_Msk
19777#define RCC_APB1LRSTR_DAC12RST_Pos (29U)
19778#define RCC_APB1LRSTR_DAC12RST_Msk (0x1UL << RCC_APB1LRSTR_DAC12RST_Pos)
19779#define RCC_APB1LRSTR_DAC12RST RCC_APB1LRSTR_DAC12RST_Msk
19780#define RCC_APB1LRSTR_UART7RST_Pos (30U)
19781#define RCC_APB1LRSTR_UART7RST_Msk (0x1UL << RCC_APB1LRSTR_UART7RST_Pos)
19782#define RCC_APB1LRSTR_UART7RST RCC_APB1LRSTR_UART7RST_Msk
19783#define RCC_APB1LRSTR_UART8RST_Pos (31U)
19784#define RCC_APB1LRSTR_UART8RST_Msk (0x1UL << RCC_APB1LRSTR_UART8RST_Pos)
19785#define RCC_APB1LRSTR_UART8RST RCC_APB1LRSTR_UART8RST_Msk
19786
19787/* Legacy define */
19788#define RCC_APB1LRSTR_HDMICECRST_Pos RCC_APB1LRSTR_CECRST_Pos
19789#define RCC_APB1LRSTR_HDMICECRST_Msk RCC_APB1LRSTR_CECRST_Msk
19790#define RCC_APB1LRSTR_HDMICECRST RCC_APB1LRSTR_CECRST
19791/******************** Bit definition for RCC_APB1HRSTR register ******************/
19792#define RCC_APB1HRSTR_CRSRST_Pos (1U)
19793#define RCC_APB1HRSTR_CRSRST_Msk (0x1UL << RCC_APB1HRSTR_CRSRST_Pos)
19794#define RCC_APB1HRSTR_CRSRST RCC_APB1HRSTR_CRSRST_Msk
19795#define RCC_APB1HRSTR_SWPMIRST_Pos (2U)
19796#define RCC_APB1HRSTR_SWPMIRST_Msk (0x1UL << RCC_APB1HRSTR_SWPMIRST_Pos)
19797#define RCC_APB1HRSTR_SWPMIRST RCC_APB1HRSTR_SWPMIRST_Msk
19798#define RCC_APB1HRSTR_OPAMPRST_Pos (4U)
19799#define RCC_APB1HRSTR_OPAMPRST_Msk (0x1UL << RCC_APB1HRSTR_OPAMPRST_Pos)
19800#define RCC_APB1HRSTR_OPAMPRST RCC_APB1HRSTR_OPAMPRST_Msk
19801#define RCC_APB1HRSTR_MDIOSRST_Pos (5U)
19802#define RCC_APB1HRSTR_MDIOSRST_Msk (0x1UL << RCC_APB1HRSTR_MDIOSRST_Pos)
19803#define RCC_APB1HRSTR_MDIOSRST RCC_APB1HRSTR_MDIOSRST_Msk
19804#define RCC_APB1HRSTR_FDCANRST_Pos (8U)
19805#define RCC_APB1HRSTR_FDCANRST_Msk (0x1UL << RCC_APB1HRSTR_FDCANRST_Pos)
19806#define RCC_APB1HRSTR_FDCANRST RCC_APB1HRSTR_FDCANRST_Msk
19807
19808/******************** Bit definition for RCC_APB2RSTR register ******************/
19809#define RCC_APB2RSTR_TIM1RST_Pos (0U)
19810#define RCC_APB2RSTR_TIM1RST_Msk (0x1UL << RCC_APB2RSTR_TIM1RST_Pos)
19811#define RCC_APB2RSTR_TIM1RST RCC_APB2RSTR_TIM1RST_Msk
19812#define RCC_APB2RSTR_TIM8RST_Pos (1U)
19813#define RCC_APB2RSTR_TIM8RST_Msk (0x1UL << RCC_APB2RSTR_TIM8RST_Pos)
19814#define RCC_APB2RSTR_TIM8RST RCC_APB2RSTR_TIM8RST_Msk
19815#define RCC_APB2RSTR_USART1RST_Pos (4U)
19816#define RCC_APB2RSTR_USART1RST_Msk (0x1UL << RCC_APB2RSTR_USART1RST_Pos)
19817#define RCC_APB2RSTR_USART1RST RCC_APB2RSTR_USART1RST_Msk
19818#define RCC_APB2RSTR_USART6RST_Pos (5U)
19819#define RCC_APB2RSTR_USART6RST_Msk (0x1UL << RCC_APB2RSTR_USART6RST_Pos)
19820#define RCC_APB2RSTR_USART6RST RCC_APB2RSTR_USART6RST_Msk
19821#define RCC_APB2RSTR_SPI1RST_Pos (12U)
19822#define RCC_APB2RSTR_SPI1RST_Msk (0x1UL << RCC_APB2RSTR_SPI1RST_Pos)
19823#define RCC_APB2RSTR_SPI1RST RCC_APB2RSTR_SPI1RST_Msk
19824#define RCC_APB2RSTR_SPI4RST_Pos (13U)
19825#define RCC_APB2RSTR_SPI4RST_Msk (0x1UL << RCC_APB2RSTR_SPI4RST_Pos)
19826#define RCC_APB2RSTR_SPI4RST RCC_APB2RSTR_SPI4RST_Msk
19827#define RCC_APB2RSTR_TIM15RST_Pos (16U)
19828#define RCC_APB2RSTR_TIM15RST_Msk (0x1UL << RCC_APB2RSTR_TIM15RST_Pos)
19829#define RCC_APB2RSTR_TIM15RST RCC_APB2RSTR_TIM15RST_Msk
19830#define RCC_APB2RSTR_TIM16RST_Pos (17U)
19831#define RCC_APB2RSTR_TIM16RST_Msk (0x1UL << RCC_APB2RSTR_TIM16RST_Pos)
19832#define RCC_APB2RSTR_TIM16RST RCC_APB2RSTR_TIM16RST_Msk
19833#define RCC_APB2RSTR_TIM17RST_Pos (18U)
19834#define RCC_APB2RSTR_TIM17RST_Msk (0x1UL << RCC_APB2RSTR_TIM17RST_Pos)
19835#define RCC_APB2RSTR_TIM17RST RCC_APB2RSTR_TIM17RST_Msk
19836#define RCC_APB2RSTR_SPI5RST_Pos (20U)
19837#define RCC_APB2RSTR_SPI5RST_Msk (0x1UL << RCC_APB2RSTR_SPI5RST_Pos)
19838#define RCC_APB2RSTR_SPI5RST RCC_APB2RSTR_SPI5RST_Msk
19839#define RCC_APB2RSTR_SAI1RST_Pos (22U)
19840#define RCC_APB2RSTR_SAI1RST_Msk (0x1UL << RCC_APB2RSTR_SAI1RST_Pos)
19841#define RCC_APB2RSTR_SAI1RST RCC_APB2RSTR_SAI1RST_Msk
19842#define RCC_APB2RSTR_SAI2RST_Pos (23U)
19843#define RCC_APB2RSTR_SAI2RST_Msk (0x1UL << RCC_APB2RSTR_SAI2RST_Pos)
19844#define RCC_APB2RSTR_SAI2RST RCC_APB2RSTR_SAI2RST_Msk
19845#define RCC_APB2RSTR_SAI3RST_Pos (24U)
19846#define RCC_APB2RSTR_SAI3RST_Msk (0x1UL << RCC_APB2RSTR_SAI3RST_Pos)
19847#define RCC_APB2RSTR_SAI3RST RCC_APB2RSTR_SAI3RST_Msk
19848#define RCC_APB2RSTR_DFSDM1RST_Pos (28U)
19849#define RCC_APB2RSTR_DFSDM1RST_Msk (0x1UL << RCC_APB2RSTR_DFSDM1RST_Pos)
19850#define RCC_APB2RSTR_DFSDM1RST RCC_APB2RSTR_DFSDM1RST_Msk
19851#define RCC_APB2RSTR_HRTIMRST_Pos (29U)
19852#define RCC_APB2RSTR_HRTIMRST_Msk (0x1UL << RCC_APB2RSTR_HRTIMRST_Pos)
19853#define RCC_APB2RSTR_HRTIMRST RCC_APB2RSTR_HRTIMRST_Msk
19854
19855/******************** Bit definition for RCC_APB4RSTR register ******************/
19856#define RCC_APB4RSTR_SYSCFGRST_Pos (1U)
19857#define RCC_APB4RSTR_SYSCFGRST_Msk (0x1UL << RCC_APB4RSTR_SYSCFGRST_Pos)
19858#define RCC_APB4RSTR_SYSCFGRST RCC_APB4RSTR_SYSCFGRST_Msk
19859#define RCC_APB4RSTR_LPUART1RST_Pos (3U)
19860#define RCC_APB4RSTR_LPUART1RST_Msk (0x1UL << RCC_APB4RSTR_LPUART1RST_Pos)
19861#define RCC_APB4RSTR_LPUART1RST RCC_APB4RSTR_LPUART1RST_Msk
19862#define RCC_APB4RSTR_SPI6RST_Pos (5U)
19863#define RCC_APB4RSTR_SPI6RST_Msk (0x1UL << RCC_APB4RSTR_SPI6RST_Pos)
19864#define RCC_APB4RSTR_SPI6RST RCC_APB4RSTR_SPI6RST_Msk
19865#define RCC_APB4RSTR_I2C4RST_Pos (7U)
19866#define RCC_APB4RSTR_I2C4RST_Msk (0x1UL << RCC_APB4RSTR_I2C4RST_Pos)
19867#define RCC_APB4RSTR_I2C4RST RCC_APB4RSTR_I2C4RST_Msk
19868#define RCC_APB4RSTR_LPTIM2RST_Pos (9U)
19869#define RCC_APB4RSTR_LPTIM2RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM2RST_Pos)
19870#define RCC_APB4RSTR_LPTIM2RST RCC_APB4RSTR_LPTIM2RST_Msk
19871#define RCC_APB4RSTR_LPTIM3RST_Pos (10U)
19872#define RCC_APB4RSTR_LPTIM3RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM3RST_Pos)
19873#define RCC_APB4RSTR_LPTIM3RST RCC_APB4RSTR_LPTIM3RST_Msk
19874#define RCC_APB4RSTR_LPTIM4RST_Pos (11U)
19875#define RCC_APB4RSTR_LPTIM4RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM4RST_Pos)
19876#define RCC_APB4RSTR_LPTIM4RST RCC_APB4RSTR_LPTIM4RST_Msk
19877#define RCC_APB4RSTR_LPTIM5RST_Pos (12U)
19878#define RCC_APB4RSTR_LPTIM5RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM5RST_Pos)
19879#define RCC_APB4RSTR_LPTIM5RST RCC_APB4RSTR_LPTIM5RST_Msk
19880#define RCC_APB4RSTR_COMP12RST_Pos (14U)
19881#define RCC_APB4RSTR_COMP12RST_Msk (0x1UL << RCC_APB4RSTR_COMP12RST_Pos)
19882#define RCC_APB4RSTR_COMP12RST RCC_APB4RSTR_COMP12RST_Msk
19883#define RCC_APB4RSTR_VREFRST_Pos (15U)
19884#define RCC_APB4RSTR_VREFRST_Msk (0x1UL << RCC_APB4RSTR_VREFRST_Pos)
19885#define RCC_APB4RSTR_VREFRST RCC_APB4RSTR_VREFRST_Msk
19886#define RCC_APB4RSTR_SAI4RST_Pos (21U)
19887#define RCC_APB4RSTR_SAI4RST_Msk (0x1UL << RCC_APB4RSTR_SAI4RST_Pos)
19888#define RCC_APB4RSTR_SAI4RST RCC_APB4RSTR_SAI4RST_Msk
19889
19890
19891/******************** Bit definition for RCC_GCR register ********************/
19892#define RCC_GCR_WW1RSC_Pos (0U)
19893#define RCC_GCR_WW1RSC_Msk (0x1UL << RCC_GCR_WW1RSC_Pos)
19894#define RCC_GCR_WW1RSC RCC_GCR_WW1RSC_Msk
19895#define RCC_GCR_WW2RSC_Pos (1U)
19896#define RCC_GCR_WW2RSC_Msk (0x1UL << RCC_GCR_WW2RSC_Pos)
19897#define RCC_GCR_WW2RSC RCC_GCR_WW2RSC_Msk
19898#define RCC_GCR_BOOT_C1_Pos (2U)
19899#define RCC_GCR_BOOT_C1_Msk (0x1UL << RCC_GCR_BOOT_C1_Pos)
19900#define RCC_GCR_BOOT_C1 RCC_GCR_BOOT_C1_Msk
19901#define RCC_GCR_BOOT_C2_Pos (3U)
19902#define RCC_GCR_BOOT_C2_Msk (0x1UL << RCC_GCR_BOOT_C2_Pos)
19903#define RCC_GCR_BOOT_C2 RCC_GCR_BOOT_C2_Msk
19904
19905/******************** Bit definition for RCC_D3AMR register ********************/
19906#define RCC_D3AMR_BDMAAMEN_Pos (0U)
19907#define RCC_D3AMR_BDMAAMEN_Msk (0x1UL << RCC_D3AMR_BDMAAMEN_Pos)
19908#define RCC_D3AMR_BDMAAMEN RCC_D3AMR_BDMAAMEN_Msk
19909#define RCC_D3AMR_LPUART1AMEN_Pos (3U)
19910#define RCC_D3AMR_LPUART1AMEN_Msk (0x1UL << RCC_D3AMR_LPUART1AMEN_Pos)
19911#define RCC_D3AMR_LPUART1AMEN RCC_D3AMR_LPUART1AMEN_Msk
19912#define RCC_D3AMR_SPI6AMEN_Pos (5U)
19913#define RCC_D3AMR_SPI6AMEN_Msk (0x1UL << RCC_D3AMR_SPI6AMEN_Pos)
19914#define RCC_D3AMR_SPI6AMEN RCC_D3AMR_SPI6AMEN_Msk
19915#define RCC_D3AMR_I2C4AMEN_Pos (7U)
19916#define RCC_D3AMR_I2C4AMEN_Msk (0x1UL << RCC_D3AMR_I2C4AMEN_Pos)
19917#define RCC_D3AMR_I2C4AMEN RCC_D3AMR_I2C4AMEN_Msk
19918#define RCC_D3AMR_LPTIM2AMEN_Pos (9U)
19919#define RCC_D3AMR_LPTIM2AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM2AMEN_Pos)
19920#define RCC_D3AMR_LPTIM2AMEN RCC_D3AMR_LPTIM2AMEN_Msk
19921#define RCC_D3AMR_LPTIM3AMEN_Pos (10U)
19922#define RCC_D3AMR_LPTIM3AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM3AMEN_Pos)
19923#define RCC_D3AMR_LPTIM3AMEN RCC_D3AMR_LPTIM3AMEN_Msk
19924#define RCC_D3AMR_LPTIM4AMEN_Pos (11U)
19925#define RCC_D3AMR_LPTIM4AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM4AMEN_Pos)
19926#define RCC_D3AMR_LPTIM4AMEN RCC_D3AMR_LPTIM4AMEN_Msk
19927#define RCC_D3AMR_LPTIM5AMEN_Pos (12U)
19928#define RCC_D3AMR_LPTIM5AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM5AMEN_Pos)
19929#define RCC_D3AMR_LPTIM5AMEN RCC_D3AMR_LPTIM5AMEN_Msk
19930#define RCC_D3AMR_COMP12AMEN_Pos (14U)
19931#define RCC_D3AMR_COMP12AMEN_Msk (0x1UL << RCC_D3AMR_COMP12AMEN_Pos)
19932#define RCC_D3AMR_COMP12AMEN RCC_D3AMR_COMP12AMEN_Msk
19933#define RCC_D3AMR_VREFAMEN_Pos (15U)
19934#define RCC_D3AMR_VREFAMEN_Msk (0x1UL << RCC_D3AMR_VREFAMEN_Pos)
19935#define RCC_D3AMR_VREFAMEN RCC_D3AMR_VREFAMEN_Msk
19936#define RCC_D3AMR_RTCAMEN_Pos (16U)
19937#define RCC_D3AMR_RTCAMEN_Msk (0x1UL << RCC_D3AMR_RTCAMEN_Pos)
19938#define RCC_D3AMR_RTCAMEN RCC_D3AMR_RTCAMEN_Msk
19939#define RCC_D3AMR_CRCAMEN_Pos (19U)
19940#define RCC_D3AMR_CRCAMEN_Msk (0x1UL << RCC_D3AMR_CRCAMEN_Pos)
19941#define RCC_D3AMR_CRCAMEN RCC_D3AMR_CRCAMEN_Msk
19942#define RCC_D3AMR_SAI4AMEN_Pos (21U)
19943#define RCC_D3AMR_SAI4AMEN_Msk (0x1UL << RCC_D3AMR_SAI4AMEN_Pos)
19944#define RCC_D3AMR_SAI4AMEN RCC_D3AMR_SAI4AMEN_Msk
19945#define RCC_D3AMR_ADC3AMEN_Pos (24U)
19946#define RCC_D3AMR_ADC3AMEN_Msk (0x1UL << RCC_D3AMR_ADC3AMEN_Pos)
19947#define RCC_D3AMR_ADC3AMEN RCC_D3AMR_ADC3AMEN_Msk
19948
19949
19950#define RCC_D3AMR_BKPRAMAMEN_Pos (28U)
19951#define RCC_D3AMR_BKPRAMAMEN_Msk (0x1UL << RCC_D3AMR_BKPRAMAMEN_Pos)
19952#define RCC_D3AMR_BKPRAMAMEN RCC_D3AMR_BKPRAMAMEN_Msk
19953#define RCC_D3AMR_SRAM4AMEN_Pos (29U)
19954#define RCC_D3AMR_SRAM4AMEN_Msk (0x1UL << RCC_D3AMR_SRAM4AMEN_Pos)
19955#define RCC_D3AMR_SRAM4AMEN RCC_D3AMR_SRAM4AMEN_Msk
19956/******************** Bit definition for RCC_AHB3LPENR register **************/
19957#define RCC_AHB3LPENR_MDMALPEN_Pos (0U)
19958#define RCC_AHB3LPENR_MDMALPEN_Msk (0x1UL << RCC_AHB3LPENR_MDMALPEN_Pos)
19959#define RCC_AHB3LPENR_MDMALPEN RCC_AHB3LPENR_MDMALPEN_Msk
19960#define RCC_AHB3LPENR_DMA2DLPEN_Pos (4U)
19961#define RCC_AHB3LPENR_DMA2DLPEN_Msk (0x1UL << RCC_AHB3LPENR_DMA2DLPEN_Pos)
19962#define RCC_AHB3LPENR_DMA2DLPEN RCC_AHB3LPENR_DMA2DLPEN_Msk
19963#define RCC_AHB3LPENR_JPGDECLPEN_Pos (5U)
19964#define RCC_AHB3LPENR_JPGDECLPEN_Msk (0x1UL << RCC_AHB3LPENR_JPGDECLPEN_Pos)
19965#define RCC_AHB3LPENR_JPGDECLPEN RCC_AHB3LPENR_JPGDECLPEN_Msk
19966#define RCC_AHB3LPENR_FLASHLPEN_Pos (8U)
19967#define RCC_AHB3LPENR_FLASHLPEN_Msk (0x1UL << RCC_AHB3LPENR_FLASHLPEN_Pos)
19968#define RCC_AHB3LPENR_FLASHLPEN RCC_AHB3LPENR_FLASHLPEN_Msk
19969#define RCC_AHB3LPENR_FMCLPEN_Pos (12U)
19970#define RCC_AHB3LPENR_FMCLPEN_Msk (0x1UL << RCC_AHB3LPENR_FMCLPEN_Pos)
19971#define RCC_AHB3LPENR_FMCLPEN RCC_AHB3LPENR_FMCLPEN_Msk
19972#define RCC_AHB3LPENR_QSPILPEN_Pos (14U)
19973#define RCC_AHB3LPENR_QSPILPEN_Msk (0x1UL << RCC_AHB3LPENR_QSPILPEN_Pos)
19974#define RCC_AHB3LPENR_QSPILPEN RCC_AHB3LPENR_QSPILPEN_Msk
19975#define RCC_AHB3LPENR_SDMMC1LPEN_Pos (16U)
19976#define RCC_AHB3LPENR_SDMMC1LPEN_Msk (0x1UL << RCC_AHB3LPENR_SDMMC1LPEN_Pos)
19977#define RCC_AHB3LPENR_SDMMC1LPEN RCC_AHB3LPENR_SDMMC1LPEN_Msk
19978#define RCC_AHB3LPENR_DTCM1LPEN_Pos (28U)
19979#define RCC_AHB3LPENR_DTCM1LPEN_Msk (0x1UL << RCC_AHB3LPENR_DTCM1LPEN_Pos)
19980#define RCC_AHB3LPENR_DTCM1LPEN RCC_AHB3LPENR_DTCM1LPEN_Msk
19981#define RCC_AHB3LPENR_DTCM2LPEN_Pos (29U)
19982#define RCC_AHB3LPENR_DTCM2LPEN_Msk (0x1UL << RCC_AHB3LPENR_DTCM2LPEN_Pos)
19983#define RCC_AHB3LPENR_DTCM2LPEN RCC_AHB3LPENR_DTCM2LPEN_Msk
19984#define RCC_AHB3LPENR_ITCMLPEN_Pos (30U)
19985#define RCC_AHB3LPENR_ITCMLPEN_Msk (0x1UL << RCC_AHB3LPENR_ITCMLPEN_Pos)
19986#define RCC_AHB3LPENR_ITCMLPEN RCC_AHB3LPENR_ITCMLPEN_Msk
19987#define RCC_AHB3LPENR_AXISRAMLPEN_Pos (31U)
19988#define RCC_AHB3LPENR_AXISRAMLPEN_Msk (0x1UL << RCC_AHB3LPENR_AXISRAMLPEN_Pos)
19989#define RCC_AHB3LPENR_AXISRAMLPEN RCC_AHB3LPENR_AXISRAMLPEN_Msk
19990
19991
19992/******************** Bit definition for RCC_AHB1LPENR register ***************/
19993#define RCC_AHB1LPENR_DMA1LPEN_Pos (0U)
19994#define RCC_AHB1LPENR_DMA1LPEN_Msk (0x1UL << RCC_AHB1LPENR_DMA1LPEN_Pos)
19995#define RCC_AHB1LPENR_DMA1LPEN RCC_AHB1LPENR_DMA1LPEN_Msk
19996#define RCC_AHB1LPENR_DMA2LPEN_Pos (1U)
19997#define RCC_AHB1LPENR_DMA2LPEN_Msk (0x1UL << RCC_AHB1LPENR_DMA2LPEN_Pos)
19998#define RCC_AHB1LPENR_DMA2LPEN RCC_AHB1LPENR_DMA2LPEN_Msk
19999#define RCC_AHB1LPENR_ADC12LPEN_Pos (5U)
20000#define RCC_AHB1LPENR_ADC12LPEN_Msk (0x1UL << RCC_AHB1LPENR_ADC12LPEN_Pos)
20001#define RCC_AHB1LPENR_ADC12LPEN RCC_AHB1LPENR_ADC12LPEN_Msk
20002#define RCC_AHB1LPENR_ARTLPEN_Pos (14U)
20003#define RCC_AHB1LPENR_ARTLPEN_Msk (0x1UL << RCC_AHB1LPENR_ARTLPEN_Pos)
20004#define RCC_AHB1LPENR_ARTLPEN RCC_AHB1LPENR_ARTLPEN_Msk
20005#define RCC_AHB1LPENR_ETH1MACLPEN_Pos (15U)
20006#define RCC_AHB1LPENR_ETH1MACLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1MACLPEN_Pos)
20007#define RCC_AHB1LPENR_ETH1MACLPEN RCC_AHB1LPENR_ETH1MACLPEN_Msk
20008#define RCC_AHB1LPENR_ETH1TXLPEN_Pos (16U)
20009#define RCC_AHB1LPENR_ETH1TXLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1TXLPEN_Pos)
20010#define RCC_AHB1LPENR_ETH1TXLPEN RCC_AHB1LPENR_ETH1TXLPEN_Msk
20011#define RCC_AHB1LPENR_ETH1RXLPEN_Pos (17U)
20012#define RCC_AHB1LPENR_ETH1RXLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1RXLPEN_Pos)
20013#define RCC_AHB1LPENR_ETH1RXLPEN RCC_AHB1LPENR_ETH1RXLPEN_Msk
20014#define RCC_AHB1LPENR_USB1OTGHSLPEN_Pos (25U)
20015#define RCC_AHB1LPENR_USB1OTGHSLPEN_Msk (0x1UL << RCC_AHB1LPENR_USB1OTGHSLPEN_Pos)
20016#define RCC_AHB1LPENR_USB1OTGHSLPEN RCC_AHB1LPENR_USB1OTGHSLPEN_Msk
20017#define RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos (26U)
20018#define RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk (0x1UL << RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos)
20019#define RCC_AHB1LPENR_USB1OTGHSULPILPEN RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk
20020#define RCC_AHB1LPENR_USB2OTGFSLPEN_Pos (27U)
20021#define RCC_AHB1LPENR_USB2OTGFSLPEN_Msk (0x1UL << RCC_AHB1LPENR_USB2OTGFSLPEN_Pos)
20022#define RCC_AHB1LPENR_USB2OTGFSLPEN RCC_AHB1LPENR_USB2OTGFSLPEN_Msk
20023#define RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos (28U)
20024#define RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk (0x1UL << RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos)
20025#define RCC_AHB1LPENR_USB2OTGFSULPILPEN RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk
20026
20027/* Legacy define */
20028#define RCC_AHB1LPENR_USB2OTGHSLPEN_Pos RCC_AHB1LPENR_USB2OTGFSLPEN_Pos
20029#define RCC_AHB1LPENR_USB2OTGHSLPEN_Msk RCC_AHB1LPENR_USB2OTGFSLPEN_Msk
20030#define RCC_AHB1LPENR_USB2OTGHSLPEN RCC_AHB1LPENR_USB2OTGFSLPEN
20031#define RCC_AHB1LPENR_USB2OTGHSULPILPEN_Pos RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos
20032#define RCC_AHB1LPENR_USB2OTGHSULPILPEN_Msk RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk
20033#define RCC_AHB1LPENR_USB2OTGHSULPILPEN RCC_AHB1LPENR_USB2OTGFSULPILPEN
20034
20035/******************** Bit definition for RCC_AHB2LPENR register ***************/
20036#define RCC_AHB2LPENR_DCMILPEN_Pos (0U)
20037#define RCC_AHB2LPENR_DCMILPEN_Msk (0x1UL << RCC_AHB2LPENR_DCMILPEN_Pos)
20038#define RCC_AHB2LPENR_DCMILPEN RCC_AHB2LPENR_DCMILPEN_Msk
20039#define RCC_AHB2LPENR_CRYPLPEN_Pos (4U)
20040#define RCC_AHB2LPENR_CRYPLPEN_Msk (0x1UL << RCC_AHB2LPENR_CRYPLPEN_Pos)
20041#define RCC_AHB2LPENR_CRYPLPEN RCC_AHB2LPENR_CRYPLPEN_Msk
20042#define RCC_AHB2LPENR_HASHLPEN_Pos (5U)
20043#define RCC_AHB2LPENR_HASHLPEN_Msk (0x1UL << RCC_AHB2LPENR_HASHLPEN_Pos)
20044#define RCC_AHB2LPENR_HASHLPEN RCC_AHB2LPENR_HASHLPEN_Msk
20045#define RCC_AHB2LPENR_RNGLPEN_Pos (6U)
20046#define RCC_AHB2LPENR_RNGLPEN_Msk (0x1UL << RCC_AHB2LPENR_RNGLPEN_Pos)
20047#define RCC_AHB2LPENR_RNGLPEN RCC_AHB2LPENR_RNGLPEN_Msk
20048#define RCC_AHB2LPENR_SDMMC2LPEN_Pos (9U)
20049#define RCC_AHB2LPENR_SDMMC2LPEN_Msk (0x1UL << RCC_AHB2LPENR_SDMMC2LPEN_Pos)
20050#define RCC_AHB2LPENR_SDMMC2LPEN RCC_AHB2LPENR_SDMMC2LPEN_Msk
20051#define RCC_AHB2LPENR_SRAM1LPEN_Pos (29U)
20052#define RCC_AHB2LPENR_SRAM1LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM1LPEN_Pos)
20053#define RCC_AHB2LPENR_SRAM1LPEN RCC_AHB2LPENR_SRAM1LPEN_Msk
20054#define RCC_AHB2LPENR_SRAM2LPEN_Pos (30U)
20055#define RCC_AHB2LPENR_SRAM2LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM2LPEN_Pos)
20056#define RCC_AHB2LPENR_SRAM2LPEN RCC_AHB2LPENR_SRAM2LPEN_Msk
20057#define RCC_AHB2LPENR_SRAM3LPEN_Pos (31U)
20058#define RCC_AHB2LPENR_SRAM3LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM3LPEN_Pos)
20059#define RCC_AHB2LPENR_SRAM3LPEN RCC_AHB2LPENR_SRAM3LPEN_Msk
20060
20061/* Legacy define */
20062#define RCC_AHB2LPENR_D2SRAM1LPEN_Pos RCC_AHB2LPENR_SRAM1LPEN_Pos
20063#define RCC_AHB2LPENR_D2SRAM1LPEN_Msk RCC_AHB2LPENR_SRAM1LPEN_Msk
20064#define RCC_AHB2LPENR_D2SRAM1LPEN RCC_AHB2LPENR_SRAM1LPEN
20065#define RCC_AHB2LPENR_D2SRAM2LPEN_Pos RCC_AHB2LPENR_SRAM2LPEN_Pos
20066#define RCC_AHB2LPENR_D2SRAM2LPEN_Msk RCC_AHB2LPENR_SRAM2LPEN_Msk
20067#define RCC_AHB2LPENR_D2SRAM2LPEN RCC_AHB2LPENR_SRAM2LPEN
20068#define RCC_AHB2LPENR_D2SRAM3LPEN_Pos RCC_AHB2LPENR_SRAM3LPEN_Pos
20069#define RCC_AHB2LPENR_D2SRAM3LPEN_Msk RCC_AHB2LPENR_SRAM3LPEN_Msk
20070#define RCC_AHB2LPENR_D2SRAM3LPEN RCC_AHB2LPENR_SRAM3LPEN
20071
20072/******************** Bit definition for RCC_AHB4LPENR register ******************/
20073#define RCC_AHB4LPENR_GPIOALPEN_Pos (0U)
20074#define RCC_AHB4LPENR_GPIOALPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOALPEN_Pos)
20075#define RCC_AHB4LPENR_GPIOALPEN RCC_AHB4LPENR_GPIOALPEN_Msk
20076#define RCC_AHB4LPENR_GPIOBLPEN_Pos (1U)
20077#define RCC_AHB4LPENR_GPIOBLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOBLPEN_Pos)
20078#define RCC_AHB4LPENR_GPIOBLPEN RCC_AHB4LPENR_GPIOBLPEN_Msk
20079#define RCC_AHB4LPENR_GPIOCLPEN_Pos (2U)
20080#define RCC_AHB4LPENR_GPIOCLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOCLPEN_Pos)
20081#define RCC_AHB4LPENR_GPIOCLPEN RCC_AHB4LPENR_GPIOCLPEN_Msk
20082#define RCC_AHB4LPENR_GPIODLPEN_Pos (3U)
20083#define RCC_AHB4LPENR_GPIODLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIODLPEN_Pos)
20084#define RCC_AHB4LPENR_GPIODLPEN RCC_AHB4LPENR_GPIODLPEN_Msk
20085#define RCC_AHB4LPENR_GPIOELPEN_Pos (4U)
20086#define RCC_AHB4LPENR_GPIOELPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOELPEN_Pos)
20087#define RCC_AHB4LPENR_GPIOELPEN RCC_AHB4LPENR_GPIOELPEN_Msk
20088#define RCC_AHB4LPENR_GPIOFLPEN_Pos (5U)
20089#define RCC_AHB4LPENR_GPIOFLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOFLPEN_Pos)
20090#define RCC_AHB4LPENR_GPIOFLPEN RCC_AHB4LPENR_GPIOFLPEN_Msk
20091#define RCC_AHB4LPENR_GPIOGLPEN_Pos (6U)
20092#define RCC_AHB4LPENR_GPIOGLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOGLPEN_Pos)
20093#define RCC_AHB4LPENR_GPIOGLPEN RCC_AHB4LPENR_GPIOGLPEN_Msk
20094#define RCC_AHB4LPENR_GPIOHLPEN_Pos (7U)
20095#define RCC_AHB4LPENR_GPIOHLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOHLPEN_Pos)
20096#define RCC_AHB4LPENR_GPIOHLPEN RCC_AHB4LPENR_GPIOHLPEN_Msk
20097#define RCC_AHB4LPENR_GPIOILPEN_Pos (8U)
20098#define RCC_AHB4LPENR_GPIOILPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOILPEN_Pos)
20099#define RCC_AHB4LPENR_GPIOILPEN RCC_AHB4LPENR_GPIOILPEN_Msk
20100#define RCC_AHB4LPENR_GPIOJLPEN_Pos (9U)
20101#define RCC_AHB4LPENR_GPIOJLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOJLPEN_Pos)
20102#define RCC_AHB4LPENR_GPIOJLPEN RCC_AHB4LPENR_GPIOJLPEN_Msk
20103#define RCC_AHB4LPENR_GPIOKLPEN_Pos (10U)
20104#define RCC_AHB4LPENR_GPIOKLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOKLPEN_Pos)
20105#define RCC_AHB4LPENR_GPIOKLPEN RCC_AHB4LPENR_GPIOKLPEN_Msk
20106#define RCC_AHB4LPENR_CRCLPEN_Pos (19U)
20107#define RCC_AHB4LPENR_CRCLPEN_Msk (0x1UL << RCC_AHB4LPENR_CRCLPEN_Pos)
20108#define RCC_AHB4LPENR_CRCLPEN RCC_AHB4LPENR_CRCLPEN_Msk
20109#define RCC_AHB4LPENR_BDMALPEN_Pos (21U)
20110#define RCC_AHB4LPENR_BDMALPEN_Msk (0x1UL << RCC_AHB4LPENR_BDMALPEN_Pos)
20111#define RCC_AHB4LPENR_BDMALPEN RCC_AHB4LPENR_BDMALPEN_Msk
20112#define RCC_AHB4LPENR_ADC3LPEN_Pos (24U)
20113#define RCC_AHB4LPENR_ADC3LPEN_Msk (0x1UL << RCC_AHB4LPENR_ADC3LPEN_Pos)
20114#define RCC_AHB4LPENR_ADC3LPEN RCC_AHB4LPENR_ADC3LPEN_Msk
20115#define RCC_AHB4LPENR_BKPRAMLPEN_Pos (28U)
20116#define RCC_AHB4LPENR_BKPRAMLPEN_Msk (0x1UL << RCC_AHB4LPENR_BKPRAMLPEN_Pos)
20117#define RCC_AHB4LPENR_BKPRAMLPEN RCC_AHB4LPENR_BKPRAMLPEN_Msk
20118#define RCC_AHB4LPENR_SRAM4LPEN_Pos (29U)
20119#define RCC_AHB4LPENR_SRAM4LPEN_Msk (0x1UL << RCC_AHB4LPENR_SRAM4LPEN_Pos)
20120#define RCC_AHB4LPENR_SRAM4LPEN RCC_AHB4LPENR_SRAM4LPEN_Msk
20121
20122/* Legacy define */
20123#define RCC_AHB4LPENR_D3SRAM1LPEN_Pos RCC_AHB4LPENR_SRAM4LPEN_Pos
20124#define RCC_AHB4LPENR_D3SRAM1LPEN_Msk RCC_AHB4LPENR_SRAM4LPEN_Msk
20125#define RCC_AHB4LPENR_D3SRAM1LPEN RCC_AHB4LPENR_SRAM4LPEN
20126/******************** Bit definition for RCC_APB3LPENR register ******************/
20127#define RCC_APB3LPENR_LTDCLPEN_Pos (3U)
20128#define RCC_APB3LPENR_LTDCLPEN_Msk (0x1UL << RCC_APB3LPENR_LTDCLPEN_Pos)
20129#define RCC_APB3LPENR_LTDCLPEN RCC_APB3LPENR_LTDCLPEN_Msk
20130#define RCC_APB3LPENR_DSILPEN_Pos (4U)
20131#define RCC_APB3LPENR_DSILPEN_Msk (0x1UL << RCC_APB3LPENR_DSILPEN_Pos)
20132#define RCC_APB3LPENR_DSILPEN RCC_APB3LPENR_DSILPEN_Msk
20133#define RCC_APB3LPENR_WWDG1LPEN_Pos (6U)
20134#define RCC_APB3LPENR_WWDG1LPEN_Msk (0x1UL << RCC_APB3LPENR_WWDG1LPEN_Pos)
20135#define RCC_APB3LPENR_WWDG1LPEN RCC_APB3LPENR_WWDG1LPEN_Msk
20136
20137/******************** Bit definition for RCC_APB1LLPENR register ******************/
20138
20139#define RCC_APB1LLPENR_TIM2LPEN_Pos (0U)
20140#define RCC_APB1LLPENR_TIM2LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM2LPEN_Pos)
20141#define RCC_APB1LLPENR_TIM2LPEN RCC_APB1LLPENR_TIM2LPEN_Msk
20142#define RCC_APB1LLPENR_TIM3LPEN_Pos (1U)
20143#define RCC_APB1LLPENR_TIM3LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM3LPEN_Pos)
20144#define RCC_APB1LLPENR_TIM3LPEN RCC_APB1LLPENR_TIM3LPEN_Msk
20145#define RCC_APB1LLPENR_TIM4LPEN_Pos (2U)
20146#define RCC_APB1LLPENR_TIM4LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM4LPEN_Pos)
20147#define RCC_APB1LLPENR_TIM4LPEN RCC_APB1LLPENR_TIM4LPEN_Msk
20148#define RCC_APB1LLPENR_TIM5LPEN_Pos (3U)
20149#define RCC_APB1LLPENR_TIM5LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM5LPEN_Pos)
20150#define RCC_APB1LLPENR_TIM5LPEN RCC_APB1LLPENR_TIM5LPEN_Msk
20151#define RCC_APB1LLPENR_TIM6LPEN_Pos (4U)
20152#define RCC_APB1LLPENR_TIM6LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM6LPEN_Pos)
20153#define RCC_APB1LLPENR_TIM6LPEN RCC_APB1LLPENR_TIM6LPEN_Msk
20154#define RCC_APB1LLPENR_TIM7LPEN_Pos (5U)
20155#define RCC_APB1LLPENR_TIM7LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM7LPEN_Pos)
20156#define RCC_APB1LLPENR_TIM7LPEN RCC_APB1LLPENR_TIM7LPEN_Msk
20157#define RCC_APB1LLPENR_TIM12LPEN_Pos (6U)
20158#define RCC_APB1LLPENR_TIM12LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM12LPEN_Pos)
20159#define RCC_APB1LLPENR_TIM12LPEN RCC_APB1LLPENR_TIM12LPEN_Msk
20160#define RCC_APB1LLPENR_TIM13LPEN_Pos (7U)
20161#define RCC_APB1LLPENR_TIM13LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM13LPEN_Pos)
20162#define RCC_APB1LLPENR_TIM13LPEN RCC_APB1LLPENR_TIM13LPEN_Msk
20163#define RCC_APB1LLPENR_TIM14LPEN_Pos (8U)
20164#define RCC_APB1LLPENR_TIM14LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM14LPEN_Pos)
20165#define RCC_APB1LLPENR_TIM14LPEN RCC_APB1LLPENR_TIM14LPEN_Msk
20166#define RCC_APB1LLPENR_LPTIM1LPEN_Pos (9U)
20167#define RCC_APB1LLPENR_LPTIM1LPEN_Msk (0x1UL << RCC_APB1LLPENR_LPTIM1LPEN_Pos)
20168#define RCC_APB1LLPENR_LPTIM1LPEN RCC_APB1LLPENR_LPTIM1LPEN_Msk
20169
20170#define RCC_APB1LLPENR_WWDG2LPEN_Pos (11U)
20171#define RCC_APB1LLPENR_WWDG2LPEN_Msk (0x1UL << RCC_APB1LLPENR_WWDG2LPEN_Pos)
20172#define RCC_APB1LLPENR_WWDG2LPEN RCC_APB1LLPENR_WWDG2LPEN_Msk
20173
20174#define RCC_APB1LLPENR_SPI2LPEN_Pos (14U)
20175#define RCC_APB1LLPENR_SPI2LPEN_Msk (0x1UL << RCC_APB1LLPENR_SPI2LPEN_Pos)
20176#define RCC_APB1LLPENR_SPI2LPEN RCC_APB1LLPENR_SPI2LPEN_Msk
20177#define RCC_APB1LLPENR_SPI3LPEN_Pos (15U)
20178#define RCC_APB1LLPENR_SPI3LPEN_Msk (0x1UL << RCC_APB1LLPENR_SPI3LPEN_Pos)
20179#define RCC_APB1LLPENR_SPI3LPEN RCC_APB1LLPENR_SPI3LPEN_Msk
20180#define RCC_APB1LLPENR_SPDIFRXLPEN_Pos (16U)
20181#define RCC_APB1LLPENR_SPDIFRXLPEN_Msk (0x1UL << RCC_APB1LLPENR_SPDIFRXLPEN_Pos)
20182#define RCC_APB1LLPENR_SPDIFRXLPEN RCC_APB1LLPENR_SPDIFRXLPEN_Msk
20183#define RCC_APB1LLPENR_USART2LPEN_Pos (17U)
20184#define RCC_APB1LLPENR_USART2LPEN_Msk (0x1UL << RCC_APB1LLPENR_USART2LPEN_Pos)
20185#define RCC_APB1LLPENR_USART2LPEN RCC_APB1LLPENR_USART2LPEN_Msk
20186#define RCC_APB1LLPENR_USART3LPEN_Pos (18U)
20187#define RCC_APB1LLPENR_USART3LPEN_Msk (0x1UL << RCC_APB1LLPENR_USART3LPEN_Pos)
20188#define RCC_APB1LLPENR_USART3LPEN RCC_APB1LLPENR_USART3LPEN_Msk
20189#define RCC_APB1LLPENR_UART4LPEN_Pos (19U)
20190#define RCC_APB1LLPENR_UART4LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART4LPEN_Pos)
20191#define RCC_APB1LLPENR_UART4LPEN RCC_APB1LLPENR_UART4LPEN_Msk
20192#define RCC_APB1LLPENR_UART5LPEN_Pos (20U)
20193#define RCC_APB1LLPENR_UART5LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART5LPEN_Pos)
20194#define RCC_APB1LLPENR_UART5LPEN RCC_APB1LLPENR_UART5LPEN_Msk
20195#define RCC_APB1LLPENR_I2C1LPEN_Pos (21U)
20196#define RCC_APB1LLPENR_I2C1LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C1LPEN_Pos)
20197#define RCC_APB1LLPENR_I2C1LPEN RCC_APB1LLPENR_I2C1LPEN_Msk
20198#define RCC_APB1LLPENR_I2C2LPEN_Pos (22U)
20199#define RCC_APB1LLPENR_I2C2LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C2LPEN_Pos)
20200#define RCC_APB1LLPENR_I2C2LPEN RCC_APB1LLPENR_I2C2LPEN_Msk
20201#define RCC_APB1LLPENR_I2C3LPEN_Pos (23U)
20202#define RCC_APB1LLPENR_I2C3LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C3LPEN_Pos)
20203#define RCC_APB1LLPENR_I2C3LPEN RCC_APB1LLPENR_I2C3LPEN_Msk
20204#define RCC_APB1LLPENR_CECLPEN_Pos (27U)
20205#define RCC_APB1LLPENR_CECLPEN_Msk (0x1UL << RCC_APB1LLPENR_CECLPEN_Pos)
20206#define RCC_APB1LLPENR_CECLPEN RCC_APB1LLPENR_CECLPEN_Msk
20207#define RCC_APB1LLPENR_DAC12LPEN_Pos (29U)
20208#define RCC_APB1LLPENR_DAC12LPEN_Msk (0x1UL << RCC_APB1LLPENR_DAC12LPEN_Pos)
20209#define RCC_APB1LLPENR_DAC12LPEN RCC_APB1LLPENR_DAC12LPEN_Msk
20210#define RCC_APB1LLPENR_UART7LPEN_Pos (30U)
20211#define RCC_APB1LLPENR_UART7LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART7LPEN_Pos)
20212#define RCC_APB1LLPENR_UART7LPEN RCC_APB1LLPENR_UART7LPEN_Msk
20213#define RCC_APB1LLPENR_UART8LPEN_Pos (31U)
20214#define RCC_APB1LLPENR_UART8LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART8LPEN_Pos)
20215#define RCC_APB1LLPENR_UART8LPEN RCC_APB1LLPENR_UART8LPEN_Msk
20216
20217/* Legacy define */
20218#define RCC_APB1LLPENR_HDMICECEN_Pos RCC_APB1LLPENR_CECLPEN_Pos
20219#define RCC_APB1LLPENR_HDMICECEN_Msk RCC_APB1LLPENR_CECLPEN_Msk
20220#define RCC_APB1LLPENR_HDMICECEN RCC_APB1LLPENR_CECLPEN
20221/******************** Bit definition for RCC_APB1HLPENR register ******************/
20222#define RCC_APB1HLPENR_CRSLPEN_Pos (1U)
20223#define RCC_APB1HLPENR_CRSLPEN_Msk (0x1UL << RCC_APB1HLPENR_CRSLPEN_Pos)
20224#define RCC_APB1HLPENR_CRSLPEN RCC_APB1HLPENR_CRSLPEN_Msk
20225#define RCC_APB1HLPENR_SWPMILPEN_Pos (2U)
20226#define RCC_APB1HLPENR_SWPMILPEN_Msk (0x1UL << RCC_APB1HLPENR_SWPMILPEN_Pos)
20227#define RCC_APB1HLPENR_SWPMILPEN RCC_APB1HLPENR_SWPMILPEN_Msk
20228#define RCC_APB1HLPENR_OPAMPLPEN_Pos (4U)
20229#define RCC_APB1HLPENR_OPAMPLPEN_Msk (0x1UL << RCC_APB1HLPENR_OPAMPLPEN_Pos)
20230#define RCC_APB1HLPENR_OPAMPLPEN RCC_APB1HLPENR_OPAMPLPEN_Msk
20231#define RCC_APB1HLPENR_MDIOSLPEN_Pos (5U)
20232#define RCC_APB1HLPENR_MDIOSLPEN_Msk (0x1UL << RCC_APB1HLPENR_MDIOSLPEN_Pos)
20233#define RCC_APB1HLPENR_MDIOSLPEN RCC_APB1HLPENR_MDIOSLPEN_Msk
20234#define RCC_APB1HLPENR_FDCANLPEN_Pos (8U)
20235#define RCC_APB1HLPENR_FDCANLPEN_Msk (0x1UL << RCC_APB1HLPENR_FDCANLPEN_Pos)
20236#define RCC_APB1HLPENR_FDCANLPEN RCC_APB1HLPENR_FDCANLPEN_Msk
20237
20238/******************** Bit definition for RCC_APB2LPENR register ******************/
20239#define RCC_APB2LPENR_TIM1LPEN_Pos (0U)
20240#define RCC_APB2LPENR_TIM1LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM1LPEN_Pos)
20241#define RCC_APB2LPENR_TIM1LPEN RCC_APB2LPENR_TIM1LPEN_Msk
20242#define RCC_APB2LPENR_TIM8LPEN_Pos (1U)
20243#define RCC_APB2LPENR_TIM8LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM8LPEN_Pos)
20244#define RCC_APB2LPENR_TIM8LPEN RCC_APB2LPENR_TIM8LPEN_Msk
20245#define RCC_APB2LPENR_USART1LPEN_Pos (4U)
20246#define RCC_APB2LPENR_USART1LPEN_Msk (0x1UL << RCC_APB2LPENR_USART1LPEN_Pos)
20247#define RCC_APB2LPENR_USART1LPEN RCC_APB2LPENR_USART1LPEN_Msk
20248#define RCC_APB2LPENR_USART6LPEN_Pos (5U)
20249#define RCC_APB2LPENR_USART6LPEN_Msk (0x1UL << RCC_APB2LPENR_USART6LPEN_Pos)
20250#define RCC_APB2LPENR_USART6LPEN RCC_APB2LPENR_USART6LPEN_Msk
20251#define RCC_APB2LPENR_SPI1LPEN_Pos (12U)
20252#define RCC_APB2LPENR_SPI1LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI1LPEN_Pos)
20253#define RCC_APB2LPENR_SPI1LPEN RCC_APB2LPENR_SPI1LPEN_Msk
20254#define RCC_APB2LPENR_SPI4LPEN_Pos (13U)
20255#define RCC_APB2LPENR_SPI4LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI4LPEN_Pos)
20256#define RCC_APB2LPENR_SPI4LPEN RCC_APB2LPENR_SPI4LPEN_Msk
20257#define RCC_APB2LPENR_TIM15LPEN_Pos (16U)
20258#define RCC_APB2LPENR_TIM15LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM15LPEN_Pos)
20259#define RCC_APB2LPENR_TIM15LPEN RCC_APB2LPENR_TIM15LPEN_Msk
20260#define RCC_APB2LPENR_TIM16LPEN_Pos (17U)
20261#define RCC_APB2LPENR_TIM16LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM16LPEN_Pos)
20262#define RCC_APB2LPENR_TIM16LPEN RCC_APB2LPENR_TIM16LPEN_Msk
20263#define RCC_APB2LPENR_TIM17LPEN_Pos (18U)
20264#define RCC_APB2LPENR_TIM17LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM17LPEN_Pos)
20265#define RCC_APB2LPENR_TIM17LPEN RCC_APB2LPENR_TIM17LPEN_Msk
20266#define RCC_APB2LPENR_SPI5LPEN_Pos (20U)
20267#define RCC_APB2LPENR_SPI5LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI5LPEN_Pos)
20268#define RCC_APB2LPENR_SPI5LPEN RCC_APB2LPENR_SPI5LPEN_Msk
20269#define RCC_APB2LPENR_SAI1LPEN_Pos (22U)
20270#define RCC_APB2LPENR_SAI1LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI1LPEN_Pos)
20271#define RCC_APB2LPENR_SAI1LPEN RCC_APB2LPENR_SAI1LPEN_Msk
20272#define RCC_APB2LPENR_SAI2LPEN_Pos (23U)
20273#define RCC_APB2LPENR_SAI2LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI2LPEN_Pos)
20274#define RCC_APB2LPENR_SAI2LPEN RCC_APB2LPENR_SAI2LPEN_Msk
20275#define RCC_APB2LPENR_SAI3LPEN_Pos (24U)
20276#define RCC_APB2LPENR_SAI3LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI3LPEN_Pos)
20277#define RCC_APB2LPENR_SAI3LPEN RCC_APB2LPENR_SAI3LPEN_Msk
20278#define RCC_APB2LPENR_DFSDM1LPEN_Pos (28U)
20279#define RCC_APB2LPENR_DFSDM1LPEN_Msk (0x1UL << RCC_APB2LPENR_DFSDM1LPEN_Pos)
20280#define RCC_APB2LPENR_DFSDM1LPEN RCC_APB2LPENR_DFSDM1LPEN_Msk
20281#define RCC_APB2LPENR_HRTIMLPEN_Pos (29U)
20282#define RCC_APB2LPENR_HRTIMLPEN_Msk (0x1UL << RCC_APB2LPENR_HRTIMLPEN_Pos)
20283#define RCC_APB2LPENR_HRTIMLPEN RCC_APB2LPENR_HRTIMLPEN_Msk
20284
20285/******************** Bit definition for RCC_APB4LPENR register ******************/
20286#define RCC_APB4LPENR_SYSCFGLPEN_Pos (1U)
20287#define RCC_APB4LPENR_SYSCFGLPEN_Msk (0x1UL << RCC_APB4LPENR_SYSCFGLPEN_Pos)
20288#define RCC_APB4LPENR_SYSCFGLPEN RCC_APB4LPENR_SYSCFGLPEN_Msk
20289#define RCC_APB4LPENR_LPUART1LPEN_Pos (3U)
20290#define RCC_APB4LPENR_LPUART1LPEN_Msk (0x1UL << RCC_APB4LPENR_LPUART1LPEN_Pos)
20291#define RCC_APB4LPENR_LPUART1LPEN RCC_APB4LPENR_LPUART1LPEN_Msk
20292#define RCC_APB4LPENR_SPI6LPEN_Pos (5U)
20293#define RCC_APB4LPENR_SPI6LPEN_Msk (0x1UL << RCC_APB4LPENR_SPI6LPEN_Pos)
20294#define RCC_APB4LPENR_SPI6LPEN RCC_APB4LPENR_SPI6LPEN_Msk
20295#define RCC_APB4LPENR_I2C4LPEN_Pos (7U)
20296#define RCC_APB4LPENR_I2C4LPEN_Msk (0x1UL << RCC_APB4LPENR_I2C4LPEN_Pos)
20297#define RCC_APB4LPENR_I2C4LPEN RCC_APB4LPENR_I2C4LPEN_Msk
20298#define RCC_APB4LPENR_LPTIM2LPEN_Pos (9U)
20299#define RCC_APB4LPENR_LPTIM2LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM2LPEN_Pos)
20300#define RCC_APB4LPENR_LPTIM2LPEN RCC_APB4LPENR_LPTIM2LPEN_Msk
20301#define RCC_APB4LPENR_LPTIM3LPEN_Pos (10U)
20302#define RCC_APB4LPENR_LPTIM3LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM3LPEN_Pos)
20303#define RCC_APB4LPENR_LPTIM3LPEN RCC_APB4LPENR_LPTIM3LPEN_Msk
20304#define RCC_APB4LPENR_LPTIM4LPEN_Pos (11U)
20305#define RCC_APB4LPENR_LPTIM4LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM4LPEN_Pos)
20306#define RCC_APB4LPENR_LPTIM4LPEN RCC_APB4LPENR_LPTIM4LPEN_Msk
20307#define RCC_APB4LPENR_LPTIM5LPEN_Pos (12U)
20308#define RCC_APB4LPENR_LPTIM5LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM5LPEN_Pos)
20309#define RCC_APB4LPENR_LPTIM5LPEN RCC_APB4LPENR_LPTIM5LPEN_Msk
20310#define RCC_APB4LPENR_COMP12LPEN_Pos (14U)
20311#define RCC_APB4LPENR_COMP12LPEN_Msk (0x1UL << RCC_APB4LPENR_COMP12LPEN_Pos)
20312#define RCC_APB4LPENR_COMP12LPEN RCC_APB4LPENR_COMP12LPEN_Msk
20313#define RCC_APB4LPENR_VREFLPEN_Pos (15U)
20314#define RCC_APB4LPENR_VREFLPEN_Msk (0x1UL << RCC_APB4LPENR_VREFLPEN_Pos)
20315#define RCC_APB4LPENR_VREFLPEN RCC_APB4LPENR_VREFLPEN_Msk
20316#define RCC_APB4LPENR_RTCAPBLPEN_Pos (16U)
20317#define RCC_APB4LPENR_RTCAPBLPEN_Msk (0x1UL << RCC_APB4LPENR_RTCAPBLPEN_Pos)
20318#define RCC_APB4LPENR_RTCAPBLPEN RCC_APB4LPENR_RTCAPBLPEN_Msk
20319#define RCC_APB4LPENR_SAI4LPEN_Pos (21U)
20320#define RCC_APB4LPENR_SAI4LPEN_Msk (0x1UL << RCC_APB4LPENR_SAI4LPEN_Pos)
20321#define RCC_APB4LPENR_SAI4LPEN RCC_APB4LPENR_SAI4LPEN_Msk
20322
20323/******************** Bit definition for RCC_D1CCIPR register ****************/
20324#define RCC_D1CCIPR_DSISRC_Pos (8U)
20325#define RCC_D1CCIPR_DSISRC_Msk (0x1UL << RCC_D1CCIPR_DSISRC_Pos)
20326#define RCC_D1CCIPR_DSISRC RCC_D1CCIPR_DSISRC_Msk
20327
20328/******************** Bit definition for RCC_RSR register *******************/
20329#define RCC_RSR_RMVF_Pos (16U)
20330#define RCC_RSR_RMVF_Msk (0x1UL << RCC_RSR_RMVF_Pos)
20331#define RCC_RSR_RMVF RCC_RSR_RMVF_Msk
20332#define RCC_RSR_C1RSTF_Pos (17U)
20333#define RCC_RSR_C1RSTF_Msk (0x1UL << RCC_RSR_C1RSTF_Pos)
20334#define RCC_RSR_C1RSTF RCC_RSR_C1RSTF_Msk
20335#define RCC_RSR_D1RSTF_Pos (19U)
20336#define RCC_RSR_D1RSTF_Msk (0x1UL << RCC_RSR_D1RSTF_Pos)
20337#define RCC_RSR_D1RSTF RCC_RSR_D1RSTF_Msk
20338#define RCC_RSR_D2RSTF_Pos (20U)
20339#define RCC_RSR_D2RSTF_Msk (0x1UL << RCC_RSR_D2RSTF_Pos)
20340#define RCC_RSR_D2RSTF RCC_RSR_D2RSTF_Msk
20341#define RCC_RSR_BORRSTF_Pos (21U)
20342#define RCC_RSR_BORRSTF_Msk (0x1UL << RCC_RSR_BORRSTF_Pos)
20343#define RCC_RSR_BORRSTF RCC_RSR_BORRSTF_Msk
20344#define RCC_RSR_PINRSTF_Pos (22U)
20345#define RCC_RSR_PINRSTF_Msk (0x1UL << RCC_RSR_PINRSTF_Pos)
20346#define RCC_RSR_PINRSTF RCC_RSR_PINRSTF_Msk
20347#define RCC_RSR_PORRSTF_Pos (23U)
20348#define RCC_RSR_PORRSTF_Msk (0x1UL << RCC_RSR_PORRSTF_Pos)
20349#define RCC_RSR_PORRSTF RCC_RSR_PORRSTF_Msk
20350#define RCC_RSR_SFT1RSTF_Pos (24U)
20351#define RCC_RSR_SFT1RSTF_Msk (0x1UL << RCC_RSR_SFT1RSTF_Pos)
20352#define RCC_RSR_SFT1RSTF RCC_RSR_SFT1RSTF_Msk
20353#define RCC_RSR_IWDG1RSTF_Pos (26U)
20354#define RCC_RSR_IWDG1RSTF_Msk (0x1UL << RCC_RSR_IWDG1RSTF_Pos)
20355#define RCC_RSR_IWDG1RSTF RCC_RSR_IWDG1RSTF_Msk
20356#define RCC_RSR_WWDG1RSTF_Pos (28U)
20357#define RCC_RSR_WWDG1RSTF_Msk (0x1UL << RCC_RSR_WWDG1RSTF_Pos)
20358#define RCC_RSR_WWDG1RSTF RCC_RSR_WWDG1RSTF_Msk
20359
20360#define RCC_RSR_WWDG2RSTF_Pos (29U)
20361#define RCC_RSR_WWDG2RSTF_Msk (0x1UL << RCC_RSR_WWDG2RSTF_Pos)
20362#define RCC_RSR_WWDG2RSTF RCC_RSR_WWDG2RSTF_Msk
20363#define RCC_RSR_IWDG2RSTF_Pos (27U)
20364#define RCC_RSR_IWDG2RSTF_Msk (0x1UL << RCC_RSR_IWDG2RSTF_Pos)
20365#define RCC_RSR_IWDG2RSTF RCC_RSR_IWDG2RSTF_Msk
20366#define RCC_RSR_SFT2RSTF_Pos (25U)
20367#define RCC_RSR_SFT2RSTF_Msk (0x1UL << RCC_RSR_SFT2RSTF_Pos)
20368#define RCC_RSR_SFT2RSTF RCC_RSR_SFT2RSTF_Msk
20369#define RCC_RSR_C2RSTF_Pos (18U)
20370#define RCC_RSR_C2RSTF_Msk (0x1UL << RCC_RSR_C2RSTF_Pos)
20371#define RCC_RSR_C2RSTF RCC_RSR_C2RSTF_Msk
20372#define RCC_RSR_LPWR1RSTF_Pos (30U)
20373#define RCC_RSR_LPWR1RSTF_Msk (0x1UL << RCC_RSR_LPWR1RSTF_Pos)
20374#define RCC_RSR_LPWR1RSTF RCC_RSR_LPWR1RSTF_Msk
20375#define RCC_RSR_LPWR2RSTF_Pos (31U)
20376#define RCC_RSR_LPWR2RSTF_Msk (0x1UL << RCC_RSR_LPWR2RSTF_Pos)
20377#define RCC_RSR_LPWR2RSTF RCC_RSR_LPWR2RSTF_Msk
20378
20379
20380/******************************************************************************/
20381/* */
20382/* RNG */
20383/* */
20384/******************************************************************************/
20385/******************** Bits definition for RNG_CR register *******************/
20386#define RNG_CR_RNGEN_Pos (2U)
20387#define RNG_CR_RNGEN_Msk (0x1UL << RNG_CR_RNGEN_Pos)
20388#define RNG_CR_RNGEN RNG_CR_RNGEN_Msk
20389#define RNG_CR_IE_Pos (3U)
20390#define RNG_CR_IE_Msk (0x1UL << RNG_CR_IE_Pos)
20391#define RNG_CR_IE RNG_CR_IE_Msk
20392#define RNG_CR_CED_Pos (5U)
20393#define RNG_CR_CED_Msk (0x1UL << RNG_CR_CED_Pos)
20394#define RNG_CR_CED RNG_CR_CED_Msk
20395
20396/******************** Bits definition for RNG_SR register *******************/
20397#define RNG_SR_DRDY_Pos (0U)
20398#define RNG_SR_DRDY_Msk (0x1UL << RNG_SR_DRDY_Pos)
20399#define RNG_SR_DRDY RNG_SR_DRDY_Msk
20400#define RNG_SR_CECS_Pos (1U)
20401#define RNG_SR_CECS_Msk (0x1UL << RNG_SR_CECS_Pos)
20402#define RNG_SR_CECS RNG_SR_CECS_Msk
20403#define RNG_SR_SECS_Pos (2U)
20404#define RNG_SR_SECS_Msk (0x1UL << RNG_SR_SECS_Pos)
20405#define RNG_SR_SECS RNG_SR_SECS_Msk
20406#define RNG_SR_CEIS_Pos (5U)
20407#define RNG_SR_CEIS_Msk (0x1UL << RNG_SR_CEIS_Pos)
20408#define RNG_SR_CEIS RNG_SR_CEIS_Msk
20409#define RNG_SR_SEIS_Pos (6U)
20410#define RNG_SR_SEIS_Msk (0x1UL << RNG_SR_SEIS_Pos)
20411#define RNG_SR_SEIS RNG_SR_SEIS_Msk
20412
20413/******************************************************************************/
20414/* */
20415/* Real-Time Clock (RTC) */
20416/* */
20417/******************************************************************************/
20418/******************** Bits definition for RTC_TR register *******************/
20419#define RTC_TR_PM_Pos (22U)
20420#define RTC_TR_PM_Msk (0x1UL << RTC_TR_PM_Pos)
20421#define RTC_TR_PM RTC_TR_PM_Msk
20422#define RTC_TR_HT_Pos (20U)
20423#define RTC_TR_HT_Msk (0x3UL << RTC_TR_HT_Pos)
20424#define RTC_TR_HT RTC_TR_HT_Msk
20425#define RTC_TR_HT_0 (0x1UL << RTC_TR_HT_Pos)
20426#define RTC_TR_HT_1 (0x2UL << RTC_TR_HT_Pos)
20427#define RTC_TR_HU_Pos (16U)
20428#define RTC_TR_HU_Msk (0xFUL << RTC_TR_HU_Pos)
20429#define RTC_TR_HU RTC_TR_HU_Msk
20430#define RTC_TR_HU_0 (0x1UL << RTC_TR_HU_Pos)
20431#define RTC_TR_HU_1 (0x2UL << RTC_TR_HU_Pos)
20432#define RTC_TR_HU_2 (0x4UL << RTC_TR_HU_Pos)
20433#define RTC_TR_HU_3 (0x8UL << RTC_TR_HU_Pos)
20434#define RTC_TR_MNT_Pos (12U)
20435#define RTC_TR_MNT_Msk (0x7UL << RTC_TR_MNT_Pos)
20436#define RTC_TR_MNT RTC_TR_MNT_Msk
20437#define RTC_TR_MNT_0 (0x1UL << RTC_TR_MNT_Pos)
20438#define RTC_TR_MNT_1 (0x2UL << RTC_TR_MNT_Pos)
20439#define RTC_TR_MNT_2 (0x4UL << RTC_TR_MNT_Pos)
20440#define RTC_TR_MNU_Pos (8U)
20441#define RTC_TR_MNU_Msk (0xFUL << RTC_TR_MNU_Pos)
20442#define RTC_TR_MNU RTC_TR_MNU_Msk
20443#define RTC_TR_MNU_0 (0x1UL << RTC_TR_MNU_Pos)
20444#define RTC_TR_MNU_1 (0x2UL << RTC_TR_MNU_Pos)
20445#define RTC_TR_MNU_2 (0x4UL << RTC_TR_MNU_Pos)
20446#define RTC_TR_MNU_3 (0x8UL << RTC_TR_MNU_Pos)
20447#define RTC_TR_ST_Pos (4U)
20448#define RTC_TR_ST_Msk (0x7UL << RTC_TR_ST_Pos)
20449#define RTC_TR_ST RTC_TR_ST_Msk
20450#define RTC_TR_ST_0 (0x1UL << RTC_TR_ST_Pos)
20451#define RTC_TR_ST_1 (0x2UL << RTC_TR_ST_Pos)
20452#define RTC_TR_ST_2 (0x4UL << RTC_TR_ST_Pos)
20453#define RTC_TR_SU_Pos (0U)
20454#define RTC_TR_SU_Msk (0xFUL << RTC_TR_SU_Pos)
20455#define RTC_TR_SU RTC_TR_SU_Msk
20456#define RTC_TR_SU_0 (0x1UL << RTC_TR_SU_Pos)
20457#define RTC_TR_SU_1 (0x2UL << RTC_TR_SU_Pos)
20458#define RTC_TR_SU_2 (0x4UL << RTC_TR_SU_Pos)
20459#define RTC_TR_SU_3 (0x8UL << RTC_TR_SU_Pos)
20461/******************** Bits definition for RTC_DR register *******************/
20462#define RTC_DR_YT_Pos (20U)
20463#define RTC_DR_YT_Msk (0xFUL << RTC_DR_YT_Pos)
20464#define RTC_DR_YT RTC_DR_YT_Msk
20465#define RTC_DR_YT_0 (0x1UL << RTC_DR_YT_Pos)
20466#define RTC_DR_YT_1 (0x2UL << RTC_DR_YT_Pos)
20467#define RTC_DR_YT_2 (0x4UL << RTC_DR_YT_Pos)
20468#define RTC_DR_YT_3 (0x8UL << RTC_DR_YT_Pos)
20469#define RTC_DR_YU_Pos (16U)
20470#define RTC_DR_YU_Msk (0xFUL << RTC_DR_YU_Pos)
20471#define RTC_DR_YU RTC_DR_YU_Msk
20472#define RTC_DR_YU_0 (0x1UL << RTC_DR_YU_Pos)
20473#define RTC_DR_YU_1 (0x2UL << RTC_DR_YU_Pos)
20474#define RTC_DR_YU_2 (0x4UL << RTC_DR_YU_Pos)
20475#define RTC_DR_YU_3 (0x8UL << RTC_DR_YU_Pos)
20476#define RTC_DR_WDU_Pos (13U)
20477#define RTC_DR_WDU_Msk (0x7UL << RTC_DR_WDU_Pos)
20478#define RTC_DR_WDU RTC_DR_WDU_Msk
20479#define RTC_DR_WDU_0 (0x1UL << RTC_DR_WDU_Pos)
20480#define RTC_DR_WDU_1 (0x2UL << RTC_DR_WDU_Pos)
20481#define RTC_DR_WDU_2 (0x4UL << RTC_DR_WDU_Pos)
20482#define RTC_DR_MT_Pos (12U)
20483#define RTC_DR_MT_Msk (0x1UL << RTC_DR_MT_Pos)
20484#define RTC_DR_MT RTC_DR_MT_Msk
20485#define RTC_DR_MU_Pos (8U)
20486#define RTC_DR_MU_Msk (0xFUL << RTC_DR_MU_Pos)
20487#define RTC_DR_MU RTC_DR_MU_Msk
20488#define RTC_DR_MU_0 (0x1UL << RTC_DR_MU_Pos)
20489#define RTC_DR_MU_1 (0x2UL << RTC_DR_MU_Pos)
20490#define RTC_DR_MU_2 (0x4UL << RTC_DR_MU_Pos)
20491#define RTC_DR_MU_3 (0x8UL << RTC_DR_MU_Pos)
20492#define RTC_DR_DT_Pos (4U)
20493#define RTC_DR_DT_Msk (0x3UL << RTC_DR_DT_Pos)
20494#define RTC_DR_DT RTC_DR_DT_Msk
20495#define RTC_DR_DT_0 (0x1UL << RTC_DR_DT_Pos)
20496#define RTC_DR_DT_1 (0x2UL << RTC_DR_DT_Pos)
20497#define RTC_DR_DU_Pos (0U)
20498#define RTC_DR_DU_Msk (0xFUL << RTC_DR_DU_Pos)
20499#define RTC_DR_DU RTC_DR_DU_Msk
20500#define RTC_DR_DU_0 (0x1UL << RTC_DR_DU_Pos)
20501#define RTC_DR_DU_1 (0x2UL << RTC_DR_DU_Pos)
20502#define RTC_DR_DU_2 (0x4UL << RTC_DR_DU_Pos)
20503#define RTC_DR_DU_3 (0x8UL << RTC_DR_DU_Pos)
20505/******************** Bits definition for RTC_CR register *******************/
20506#define RTC_CR_ITSE_Pos (24U)
20507#define RTC_CR_ITSE_Msk (0x1UL << RTC_CR_ITSE_Pos)
20508#define RTC_CR_ITSE RTC_CR_ITSE_Msk
20509#define RTC_CR_COE_Pos (23U)
20510#define RTC_CR_COE_Msk (0x1UL << RTC_CR_COE_Pos)
20511#define RTC_CR_COE RTC_CR_COE_Msk
20512#define RTC_CR_OSEL_Pos (21U)
20513#define RTC_CR_OSEL_Msk (0x3UL << RTC_CR_OSEL_Pos)
20514#define RTC_CR_OSEL RTC_CR_OSEL_Msk
20515#define RTC_CR_OSEL_0 (0x1UL << RTC_CR_OSEL_Pos)
20516#define RTC_CR_OSEL_1 (0x2UL << RTC_CR_OSEL_Pos)
20517#define RTC_CR_POL_Pos (20U)
20518#define RTC_CR_POL_Msk (0x1UL << RTC_CR_POL_Pos)
20519#define RTC_CR_POL RTC_CR_POL_Msk
20520#define RTC_CR_COSEL_Pos (19U)
20521#define RTC_CR_COSEL_Msk (0x1UL << RTC_CR_COSEL_Pos)
20522#define RTC_CR_COSEL RTC_CR_COSEL_Msk
20523#define RTC_CR_BKP_Pos (18U)
20524#define RTC_CR_BKP_Msk (0x1UL << RTC_CR_BKP_Pos)
20525#define RTC_CR_BKP RTC_CR_BKP_Msk
20526#define RTC_CR_SUB1H_Pos (17U)
20527#define RTC_CR_SUB1H_Msk (0x1UL << RTC_CR_SUB1H_Pos)
20528#define RTC_CR_SUB1H RTC_CR_SUB1H_Msk
20529#define RTC_CR_ADD1H_Pos (16U)
20530#define RTC_CR_ADD1H_Msk (0x1UL << RTC_CR_ADD1H_Pos)
20531#define RTC_CR_ADD1H RTC_CR_ADD1H_Msk
20532#define RTC_CR_TSIE_Pos (15U)
20533#define RTC_CR_TSIE_Msk (0x1UL << RTC_CR_TSIE_Pos)
20534#define RTC_CR_TSIE RTC_CR_TSIE_Msk
20535#define RTC_CR_WUTIE_Pos (14U)
20536#define RTC_CR_WUTIE_Msk (0x1UL << RTC_CR_WUTIE_Pos)
20537#define RTC_CR_WUTIE RTC_CR_WUTIE_Msk
20538#define RTC_CR_ALRBIE_Pos (13U)
20539#define RTC_CR_ALRBIE_Msk (0x1UL << RTC_CR_ALRBIE_Pos)
20540#define RTC_CR_ALRBIE RTC_CR_ALRBIE_Msk
20541#define RTC_CR_ALRAIE_Pos (12U)
20542#define RTC_CR_ALRAIE_Msk (0x1UL << RTC_CR_ALRAIE_Pos)
20543#define RTC_CR_ALRAIE RTC_CR_ALRAIE_Msk
20544#define RTC_CR_TSE_Pos (11U)
20545#define RTC_CR_TSE_Msk (0x1UL << RTC_CR_TSE_Pos)
20546#define RTC_CR_TSE RTC_CR_TSE_Msk
20547#define RTC_CR_WUTE_Pos (10U)
20548#define RTC_CR_WUTE_Msk (0x1UL << RTC_CR_WUTE_Pos)
20549#define RTC_CR_WUTE RTC_CR_WUTE_Msk
20550#define RTC_CR_ALRBE_Pos (9U)
20551#define RTC_CR_ALRBE_Msk (0x1UL << RTC_CR_ALRBE_Pos)
20552#define RTC_CR_ALRBE RTC_CR_ALRBE_Msk
20553#define RTC_CR_ALRAE_Pos (8U)
20554#define RTC_CR_ALRAE_Msk (0x1UL << RTC_CR_ALRAE_Pos)
20555#define RTC_CR_ALRAE RTC_CR_ALRAE_Msk
20556#define RTC_CR_FMT_Pos (6U)
20557#define RTC_CR_FMT_Msk (0x1UL << RTC_CR_FMT_Pos)
20558#define RTC_CR_FMT RTC_CR_FMT_Msk
20559#define RTC_CR_BYPSHAD_Pos (5U)
20560#define RTC_CR_BYPSHAD_Msk (0x1UL << RTC_CR_BYPSHAD_Pos)
20561#define RTC_CR_BYPSHAD RTC_CR_BYPSHAD_Msk
20562#define RTC_CR_REFCKON_Pos (4U)
20563#define RTC_CR_REFCKON_Msk (0x1UL << RTC_CR_REFCKON_Pos)
20564#define RTC_CR_REFCKON RTC_CR_REFCKON_Msk
20565#define RTC_CR_TSEDGE_Pos (3U)
20566#define RTC_CR_TSEDGE_Msk (0x1UL << RTC_CR_TSEDGE_Pos)
20567#define RTC_CR_TSEDGE RTC_CR_TSEDGE_Msk
20568#define RTC_CR_WUCKSEL_Pos (0U)
20569#define RTC_CR_WUCKSEL_Msk (0x7UL << RTC_CR_WUCKSEL_Pos)
20570#define RTC_CR_WUCKSEL RTC_CR_WUCKSEL_Msk
20571#define RTC_CR_WUCKSEL_0 (0x1UL << RTC_CR_WUCKSEL_Pos)
20572#define RTC_CR_WUCKSEL_1 (0x2UL << RTC_CR_WUCKSEL_Pos)
20573#define RTC_CR_WUCKSEL_2 (0x4UL << RTC_CR_WUCKSEL_Pos)
20575/******************** Bits definition for RTC_ISR register ******************/
20576#define RTC_ISR_ITSF_Pos (17U)
20577#define RTC_ISR_ITSF_Msk (0x1UL << RTC_ISR_ITSF_Pos)
20578#define RTC_ISR_ITSF RTC_ISR_ITSF_Msk
20579#define RTC_ISR_RECALPF_Pos (16U)
20580#define RTC_ISR_RECALPF_Msk (0x1UL << RTC_ISR_RECALPF_Pos)
20581#define RTC_ISR_RECALPF RTC_ISR_RECALPF_Msk
20582#define RTC_ISR_TAMP3F_Pos (15U)
20583#define RTC_ISR_TAMP3F_Msk (0x1UL << RTC_ISR_TAMP3F_Pos)
20584#define RTC_ISR_TAMP3F RTC_ISR_TAMP3F_Msk
20585#define RTC_ISR_TAMP2F_Pos (14U)
20586#define RTC_ISR_TAMP2F_Msk (0x1UL << RTC_ISR_TAMP2F_Pos)
20587#define RTC_ISR_TAMP2F RTC_ISR_TAMP2F_Msk
20588#define RTC_ISR_TAMP1F_Pos (13U)
20589#define RTC_ISR_TAMP1F_Msk (0x1UL << RTC_ISR_TAMP1F_Pos)
20590#define RTC_ISR_TAMP1F RTC_ISR_TAMP1F_Msk
20591#define RTC_ISR_TSOVF_Pos (12U)
20592#define RTC_ISR_TSOVF_Msk (0x1UL << RTC_ISR_TSOVF_Pos)
20593#define RTC_ISR_TSOVF RTC_ISR_TSOVF_Msk
20594#define RTC_ISR_TSF_Pos (11U)
20595#define RTC_ISR_TSF_Msk (0x1UL << RTC_ISR_TSF_Pos)
20596#define RTC_ISR_TSF RTC_ISR_TSF_Msk
20597#define RTC_ISR_WUTF_Pos (10U)
20598#define RTC_ISR_WUTF_Msk (0x1UL << RTC_ISR_WUTF_Pos)
20599#define RTC_ISR_WUTF RTC_ISR_WUTF_Msk
20600#define RTC_ISR_ALRBF_Pos (9U)
20601#define RTC_ISR_ALRBF_Msk (0x1UL << RTC_ISR_ALRBF_Pos)
20602#define RTC_ISR_ALRBF RTC_ISR_ALRBF_Msk
20603#define RTC_ISR_ALRAF_Pos (8U)
20604#define RTC_ISR_ALRAF_Msk (0x1UL << RTC_ISR_ALRAF_Pos)
20605#define RTC_ISR_ALRAF RTC_ISR_ALRAF_Msk
20606#define RTC_ISR_INIT_Pos (7U)
20607#define RTC_ISR_INIT_Msk (0x1UL << RTC_ISR_INIT_Pos)
20608#define RTC_ISR_INIT RTC_ISR_INIT_Msk
20609#define RTC_ISR_INITF_Pos (6U)
20610#define RTC_ISR_INITF_Msk (0x1UL << RTC_ISR_INITF_Pos)
20611#define RTC_ISR_INITF RTC_ISR_INITF_Msk
20612#define RTC_ISR_RSF_Pos (5U)
20613#define RTC_ISR_RSF_Msk (0x1UL << RTC_ISR_RSF_Pos)
20614#define RTC_ISR_RSF RTC_ISR_RSF_Msk
20615#define RTC_ISR_INITS_Pos (4U)
20616#define RTC_ISR_INITS_Msk (0x1UL << RTC_ISR_INITS_Pos)
20617#define RTC_ISR_INITS RTC_ISR_INITS_Msk
20618#define RTC_ISR_SHPF_Pos (3U)
20619#define RTC_ISR_SHPF_Msk (0x1UL << RTC_ISR_SHPF_Pos)
20620#define RTC_ISR_SHPF RTC_ISR_SHPF_Msk
20621#define RTC_ISR_WUTWF_Pos (2U)
20622#define RTC_ISR_WUTWF_Msk (0x1UL << RTC_ISR_WUTWF_Pos)
20623#define RTC_ISR_WUTWF RTC_ISR_WUTWF_Msk
20624#define RTC_ISR_ALRBWF_Pos (1U)
20625#define RTC_ISR_ALRBWF_Msk (0x1UL << RTC_ISR_ALRBWF_Pos)
20626#define RTC_ISR_ALRBWF RTC_ISR_ALRBWF_Msk
20627#define RTC_ISR_ALRAWF_Pos (0U)
20628#define RTC_ISR_ALRAWF_Msk (0x1UL << RTC_ISR_ALRAWF_Pos)
20629#define RTC_ISR_ALRAWF RTC_ISR_ALRAWF_Msk
20630
20631/******************** Bits definition for RTC_PRER register *****************/
20632#define RTC_PRER_PREDIV_A_Pos (16U)
20633#define RTC_PRER_PREDIV_A_Msk (0x7FUL << RTC_PRER_PREDIV_A_Pos)
20634#define RTC_PRER_PREDIV_A RTC_PRER_PREDIV_A_Msk
20635#define RTC_PRER_PREDIV_S_Pos (0U)
20636#define RTC_PRER_PREDIV_S_Msk (0x7FFFUL << RTC_PRER_PREDIV_S_Pos)
20637#define RTC_PRER_PREDIV_S RTC_PRER_PREDIV_S_Msk
20638
20639/******************** Bits definition for RTC_WUTR register *****************/
20640#define RTC_WUTR_WUT_Pos (0U)
20641#define RTC_WUTR_WUT_Msk (0xFFFFUL << RTC_WUTR_WUT_Pos)
20642#define RTC_WUTR_WUT RTC_WUTR_WUT_Msk
20643
20644/******************** Bits definition for RTC_ALRMAR register ***************/
20645#define RTC_ALRMAR_MSK4_Pos (31U)
20646#define RTC_ALRMAR_MSK4_Msk (0x1UL << RTC_ALRMAR_MSK4_Pos)
20647#define RTC_ALRMAR_MSK4 RTC_ALRMAR_MSK4_Msk
20648#define RTC_ALRMAR_WDSEL_Pos (30U)
20649#define RTC_ALRMAR_WDSEL_Msk (0x1UL << RTC_ALRMAR_WDSEL_Pos)
20650#define RTC_ALRMAR_WDSEL RTC_ALRMAR_WDSEL_Msk
20651#define RTC_ALRMAR_DT_Pos (28U)
20652#define RTC_ALRMAR_DT_Msk (0x3UL << RTC_ALRMAR_DT_Pos)
20653#define RTC_ALRMAR_DT RTC_ALRMAR_DT_Msk
20654#define RTC_ALRMAR_DT_0 (0x1UL << RTC_ALRMAR_DT_Pos)
20655#define RTC_ALRMAR_DT_1 (0x2UL << RTC_ALRMAR_DT_Pos)
20656#define RTC_ALRMAR_DU_Pos (24U)
20657#define RTC_ALRMAR_DU_Msk (0xFUL << RTC_ALRMAR_DU_Pos)
20658#define RTC_ALRMAR_DU RTC_ALRMAR_DU_Msk
20659#define RTC_ALRMAR_DU_0 (0x1UL << RTC_ALRMAR_DU_Pos)
20660#define RTC_ALRMAR_DU_1 (0x2UL << RTC_ALRMAR_DU_Pos)
20661#define RTC_ALRMAR_DU_2 (0x4UL << RTC_ALRMAR_DU_Pos)
20662#define RTC_ALRMAR_DU_3 (0x8UL << RTC_ALRMAR_DU_Pos)
20663#define RTC_ALRMAR_MSK3_Pos (23U)
20664#define RTC_ALRMAR_MSK3_Msk (0x1UL << RTC_ALRMAR_MSK3_Pos)
20665#define RTC_ALRMAR_MSK3 RTC_ALRMAR_MSK3_Msk
20666#define RTC_ALRMAR_PM_Pos (22U)
20667#define RTC_ALRMAR_PM_Msk (0x1UL << RTC_ALRMAR_PM_Pos)
20668#define RTC_ALRMAR_PM RTC_ALRMAR_PM_Msk
20669#define RTC_ALRMAR_HT_Pos (20U)
20670#define RTC_ALRMAR_HT_Msk (0x3UL << RTC_ALRMAR_HT_Pos)
20671#define RTC_ALRMAR_HT RTC_ALRMAR_HT_Msk
20672#define RTC_ALRMAR_HT_0 (0x1UL << RTC_ALRMAR_HT_Pos)
20673#define RTC_ALRMAR_HT_1 (0x2UL << RTC_ALRMAR_HT_Pos)
20674#define RTC_ALRMAR_HU_Pos (16U)
20675#define RTC_ALRMAR_HU_Msk (0xFUL << RTC_ALRMAR_HU_Pos)
20676#define RTC_ALRMAR_HU RTC_ALRMAR_HU_Msk
20677#define RTC_ALRMAR_HU_0 (0x1UL << RTC_ALRMAR_HU_Pos)
20678#define RTC_ALRMAR_HU_1 (0x2UL << RTC_ALRMAR_HU_Pos)
20679#define RTC_ALRMAR_HU_2 (0x4UL << RTC_ALRMAR_HU_Pos)
20680#define RTC_ALRMAR_HU_3 (0x8UL << RTC_ALRMAR_HU_Pos)
20681#define RTC_ALRMAR_MSK2_Pos (15U)
20682#define RTC_ALRMAR_MSK2_Msk (0x1UL << RTC_ALRMAR_MSK2_Pos)
20683#define RTC_ALRMAR_MSK2 RTC_ALRMAR_MSK2_Msk
20684#define RTC_ALRMAR_MNT_Pos (12U)
20685#define RTC_ALRMAR_MNT_Msk (0x7UL << RTC_ALRMAR_MNT_Pos)
20686#define RTC_ALRMAR_MNT RTC_ALRMAR_MNT_Msk
20687#define RTC_ALRMAR_MNT_0 (0x1UL << RTC_ALRMAR_MNT_Pos)
20688#define RTC_ALRMAR_MNT_1 (0x2UL << RTC_ALRMAR_MNT_Pos)
20689#define RTC_ALRMAR_MNT_2 (0x4UL << RTC_ALRMAR_MNT_Pos)
20690#define RTC_ALRMAR_MNU_Pos (8U)
20691#define RTC_ALRMAR_MNU_Msk (0xFUL << RTC_ALRMAR_MNU_Pos)
20692#define RTC_ALRMAR_MNU RTC_ALRMAR_MNU_Msk
20693#define RTC_ALRMAR_MNU_0 (0x1UL << RTC_ALRMAR_MNU_Pos)
20694#define RTC_ALRMAR_MNU_1 (0x2UL << RTC_ALRMAR_MNU_Pos)
20695#define RTC_ALRMAR_MNU_2 (0x4UL << RTC_ALRMAR_MNU_Pos)
20696#define RTC_ALRMAR_MNU_3 (0x8UL << RTC_ALRMAR_MNU_Pos)
20697#define RTC_ALRMAR_MSK1_Pos (7U)
20698#define RTC_ALRMAR_MSK1_Msk (0x1UL << RTC_ALRMAR_MSK1_Pos)
20699#define RTC_ALRMAR_MSK1 RTC_ALRMAR_MSK1_Msk
20700#define RTC_ALRMAR_ST_Pos (4U)
20701#define RTC_ALRMAR_ST_Msk (0x7UL << RTC_ALRMAR_ST_Pos)
20702#define RTC_ALRMAR_ST RTC_ALRMAR_ST_Msk
20703#define RTC_ALRMAR_ST_0 (0x1UL << RTC_ALRMAR_ST_Pos)
20704#define RTC_ALRMAR_ST_1 (0x2UL << RTC_ALRMAR_ST_Pos)
20705#define RTC_ALRMAR_ST_2 (0x4UL << RTC_ALRMAR_ST_Pos)
20706#define RTC_ALRMAR_SU_Pos (0U)
20707#define RTC_ALRMAR_SU_Msk (0xFUL << RTC_ALRMAR_SU_Pos)
20708#define RTC_ALRMAR_SU RTC_ALRMAR_SU_Msk
20709#define RTC_ALRMAR_SU_0 (0x1UL << RTC_ALRMAR_SU_Pos)
20710#define RTC_ALRMAR_SU_1 (0x2UL << RTC_ALRMAR_SU_Pos)
20711#define RTC_ALRMAR_SU_2 (0x4UL << RTC_ALRMAR_SU_Pos)
20712#define RTC_ALRMAR_SU_3 (0x8UL << RTC_ALRMAR_SU_Pos)
20714/******************** Bits definition for RTC_ALRMBR register ***************/
20715#define RTC_ALRMBR_MSK4_Pos (31U)
20716#define RTC_ALRMBR_MSK4_Msk (0x1UL << RTC_ALRMBR_MSK4_Pos)
20717#define RTC_ALRMBR_MSK4 RTC_ALRMBR_MSK4_Msk
20718#define RTC_ALRMBR_WDSEL_Pos (30U)
20719#define RTC_ALRMBR_WDSEL_Msk (0x1UL << RTC_ALRMBR_WDSEL_Pos)
20720#define RTC_ALRMBR_WDSEL RTC_ALRMBR_WDSEL_Msk
20721#define RTC_ALRMBR_DT_Pos (28U)
20722#define RTC_ALRMBR_DT_Msk (0x3UL << RTC_ALRMBR_DT_Pos)
20723#define RTC_ALRMBR_DT RTC_ALRMBR_DT_Msk
20724#define RTC_ALRMBR_DT_0 (0x1UL << RTC_ALRMBR_DT_Pos)
20725#define RTC_ALRMBR_DT_1 (0x2UL << RTC_ALRMBR_DT_Pos)
20726#define RTC_ALRMBR_DU_Pos (24U)
20727#define RTC_ALRMBR_DU_Msk (0xFUL << RTC_ALRMBR_DU_Pos)
20728#define RTC_ALRMBR_DU RTC_ALRMBR_DU_Msk
20729#define RTC_ALRMBR_DU_0 (0x1UL << RTC_ALRMBR_DU_Pos)
20730#define RTC_ALRMBR_DU_1 (0x2UL << RTC_ALRMBR_DU_Pos)
20731#define RTC_ALRMBR_DU_2 (0x4UL << RTC_ALRMBR_DU_Pos)
20732#define RTC_ALRMBR_DU_3 (0x8UL << RTC_ALRMBR_DU_Pos)
20733#define RTC_ALRMBR_MSK3_Pos (23U)
20734#define RTC_ALRMBR_MSK3_Msk (0x1UL << RTC_ALRMBR_MSK3_Pos)
20735#define RTC_ALRMBR_MSK3 RTC_ALRMBR_MSK3_Msk
20736#define RTC_ALRMBR_PM_Pos (22U)
20737#define RTC_ALRMBR_PM_Msk (0x1UL << RTC_ALRMBR_PM_Pos)
20738#define RTC_ALRMBR_PM RTC_ALRMBR_PM_Msk
20739#define RTC_ALRMBR_HT_Pos (20U)
20740#define RTC_ALRMBR_HT_Msk (0x3UL << RTC_ALRMBR_HT_Pos)
20741#define RTC_ALRMBR_HT RTC_ALRMBR_HT_Msk
20742#define RTC_ALRMBR_HT_0 (0x1UL << RTC_ALRMBR_HT_Pos)
20743#define RTC_ALRMBR_HT_1 (0x2UL << RTC_ALRMBR_HT_Pos)
20744#define RTC_ALRMBR_HU_Pos (16U)
20745#define RTC_ALRMBR_HU_Msk (0xFUL << RTC_ALRMBR_HU_Pos)
20746#define RTC_ALRMBR_HU RTC_ALRMBR_HU_Msk
20747#define RTC_ALRMBR_HU_0 (0x1UL << RTC_ALRMBR_HU_Pos)
20748#define RTC_ALRMBR_HU_1 (0x2UL << RTC_ALRMBR_HU_Pos)
20749#define RTC_ALRMBR_HU_2 (0x4UL << RTC_ALRMBR_HU_Pos)
20750#define RTC_ALRMBR_HU_3 (0x8UL << RTC_ALRMBR_HU_Pos)
20751#define RTC_ALRMBR_MSK2_Pos (15U)
20752#define RTC_ALRMBR_MSK2_Msk (0x1UL << RTC_ALRMBR_MSK2_Pos)
20753#define RTC_ALRMBR_MSK2 RTC_ALRMBR_MSK2_Msk
20754#define RTC_ALRMBR_MNT_Pos (12U)
20755#define RTC_ALRMBR_MNT_Msk (0x7UL << RTC_ALRMBR_MNT_Pos)
20756#define RTC_ALRMBR_MNT RTC_ALRMBR_MNT_Msk
20757#define RTC_ALRMBR_MNT_0 (0x1UL << RTC_ALRMBR_MNT_Pos)
20758#define RTC_ALRMBR_MNT_1 (0x2UL << RTC_ALRMBR_MNT_Pos)
20759#define RTC_ALRMBR_MNT_2 (0x4UL << RTC_ALRMBR_MNT_Pos)
20760#define RTC_ALRMBR_MNU_Pos (8U)
20761#define RTC_ALRMBR_MNU_Msk (0xFUL << RTC_ALRMBR_MNU_Pos)
20762#define RTC_ALRMBR_MNU RTC_ALRMBR_MNU_Msk
20763#define RTC_ALRMBR_MNU_0 (0x1UL << RTC_ALRMBR_MNU_Pos)
20764#define RTC_ALRMBR_MNU_1 (0x2UL << RTC_ALRMBR_MNU_Pos)
20765#define RTC_ALRMBR_MNU_2 (0x4UL << RTC_ALRMBR_MNU_Pos)
20766#define RTC_ALRMBR_MNU_3 (0x8UL << RTC_ALRMBR_MNU_Pos)
20767#define RTC_ALRMBR_MSK1_Pos (7U)
20768#define RTC_ALRMBR_MSK1_Msk (0x1UL << RTC_ALRMBR_MSK1_Pos)
20769#define RTC_ALRMBR_MSK1 RTC_ALRMBR_MSK1_Msk
20770#define RTC_ALRMBR_ST_Pos (4U)
20771#define RTC_ALRMBR_ST_Msk (0x7UL << RTC_ALRMBR_ST_Pos)
20772#define RTC_ALRMBR_ST RTC_ALRMBR_ST_Msk
20773#define RTC_ALRMBR_ST_0 (0x1UL << RTC_ALRMBR_ST_Pos)
20774#define RTC_ALRMBR_ST_1 (0x2UL << RTC_ALRMBR_ST_Pos)
20775#define RTC_ALRMBR_ST_2 (0x4UL << RTC_ALRMBR_ST_Pos)
20776#define RTC_ALRMBR_SU_Pos (0U)
20777#define RTC_ALRMBR_SU_Msk (0xFUL << RTC_ALRMBR_SU_Pos)
20778#define RTC_ALRMBR_SU RTC_ALRMBR_SU_Msk
20779#define RTC_ALRMBR_SU_0 (0x1UL << RTC_ALRMBR_SU_Pos)
20780#define RTC_ALRMBR_SU_1 (0x2UL << RTC_ALRMBR_SU_Pos)
20781#define RTC_ALRMBR_SU_2 (0x4UL << RTC_ALRMBR_SU_Pos)
20782#define RTC_ALRMBR_SU_3 (0x8UL << RTC_ALRMBR_SU_Pos)
20784/******************** Bits definition for RTC_WPR register ******************/
20785#define RTC_WPR_KEY_Pos (0U)
20786#define RTC_WPR_KEY_Msk (0xFFUL << RTC_WPR_KEY_Pos)
20787#define RTC_WPR_KEY RTC_WPR_KEY_Msk
20788
20789/******************** Bits definition for RTC_SSR register ******************/
20790#define RTC_SSR_SS_Pos (0U)
20791#define RTC_SSR_SS_Msk (0xFFFFUL << RTC_SSR_SS_Pos)
20792#define RTC_SSR_SS RTC_SSR_SS_Msk
20793
20794/******************** Bits definition for RTC_SHIFTR register ***************/
20795#define RTC_SHIFTR_SUBFS_Pos (0U)
20796#define RTC_SHIFTR_SUBFS_Msk (0x7FFFUL << RTC_SHIFTR_SUBFS_Pos)
20797#define RTC_SHIFTR_SUBFS RTC_SHIFTR_SUBFS_Msk
20798#define RTC_SHIFTR_ADD1S_Pos (31U)
20799#define RTC_SHIFTR_ADD1S_Msk (0x1UL << RTC_SHIFTR_ADD1S_Pos)
20800#define RTC_SHIFTR_ADD1S RTC_SHIFTR_ADD1S_Msk
20801
20802/******************** Bits definition for RTC_TSTR register *****************/
20803#define RTC_TSTR_PM_Pos (22U)
20804#define RTC_TSTR_PM_Msk (0x1UL << RTC_TSTR_PM_Pos)
20805#define RTC_TSTR_PM RTC_TSTR_PM_Msk
20806#define RTC_TSTR_HT_Pos (20U)
20807#define RTC_TSTR_HT_Msk (0x3UL << RTC_TSTR_HT_Pos)
20808#define RTC_TSTR_HT RTC_TSTR_HT_Msk
20809#define RTC_TSTR_HT_0 (0x1UL << RTC_TSTR_HT_Pos)
20810#define RTC_TSTR_HT_1 (0x2UL << RTC_TSTR_HT_Pos)
20811#define RTC_TSTR_HU_Pos (16U)
20812#define RTC_TSTR_HU_Msk (0xFUL << RTC_TSTR_HU_Pos)
20813#define RTC_TSTR_HU RTC_TSTR_HU_Msk
20814#define RTC_TSTR_HU_0 (0x1UL << RTC_TSTR_HU_Pos)
20815#define RTC_TSTR_HU_1 (0x2UL << RTC_TSTR_HU_Pos)
20816#define RTC_TSTR_HU_2 (0x4UL << RTC_TSTR_HU_Pos)
20817#define RTC_TSTR_HU_3 (0x8UL << RTC_TSTR_HU_Pos)
20818#define RTC_TSTR_MNT_Pos (12U)
20819#define RTC_TSTR_MNT_Msk (0x7UL << RTC_TSTR_MNT_Pos)
20820#define RTC_TSTR_MNT RTC_TSTR_MNT_Msk
20821#define RTC_TSTR_MNT_0 (0x1UL << RTC_TSTR_MNT_Pos)
20822#define RTC_TSTR_MNT_1 (0x2UL << RTC_TSTR_MNT_Pos)
20823#define RTC_TSTR_MNT_2 (0x4UL << RTC_TSTR_MNT_Pos)
20824#define RTC_TSTR_MNU_Pos (8U)
20825#define RTC_TSTR_MNU_Msk (0xFUL << RTC_TSTR_MNU_Pos)
20826#define RTC_TSTR_MNU RTC_TSTR_MNU_Msk
20827#define RTC_TSTR_MNU_0 (0x1UL << RTC_TSTR_MNU_Pos)
20828#define RTC_TSTR_MNU_1 (0x2UL << RTC_TSTR_MNU_Pos)
20829#define RTC_TSTR_MNU_2 (0x4UL << RTC_TSTR_MNU_Pos)
20830#define RTC_TSTR_MNU_3 (0x8UL << RTC_TSTR_MNU_Pos)
20831#define RTC_TSTR_ST_Pos (4U)
20832#define RTC_TSTR_ST_Msk (0x7UL << RTC_TSTR_ST_Pos)
20833#define RTC_TSTR_ST RTC_TSTR_ST_Msk
20834#define RTC_TSTR_ST_0 (0x1UL << RTC_TSTR_ST_Pos)
20835#define RTC_TSTR_ST_1 (0x2UL << RTC_TSTR_ST_Pos)
20836#define RTC_TSTR_ST_2 (0x4UL << RTC_TSTR_ST_Pos)
20837#define RTC_TSTR_SU_Pos (0U)
20838#define RTC_TSTR_SU_Msk (0xFUL << RTC_TSTR_SU_Pos)
20839#define RTC_TSTR_SU RTC_TSTR_SU_Msk
20840#define RTC_TSTR_SU_0 (0x1UL << RTC_TSTR_SU_Pos)
20841#define RTC_TSTR_SU_1 (0x2UL << RTC_TSTR_SU_Pos)
20842#define RTC_TSTR_SU_2 (0x4UL << RTC_TSTR_SU_Pos)
20843#define RTC_TSTR_SU_3 (0x8UL << RTC_TSTR_SU_Pos)
20845/******************** Bits definition for RTC_TSDR register *****************/
20846#define RTC_TSDR_WDU_Pos (13U)
20847#define RTC_TSDR_WDU_Msk (0x7UL << RTC_TSDR_WDU_Pos)
20848#define RTC_TSDR_WDU RTC_TSDR_WDU_Msk
20849#define RTC_TSDR_WDU_0 (0x1UL << RTC_TSDR_WDU_Pos)
20850#define RTC_TSDR_WDU_1 (0x2UL << RTC_TSDR_WDU_Pos)
20851#define RTC_TSDR_WDU_2 (0x4UL << RTC_TSDR_WDU_Pos)
20852#define RTC_TSDR_MT_Pos (12U)
20853#define RTC_TSDR_MT_Msk (0x1UL << RTC_TSDR_MT_Pos)
20854#define RTC_TSDR_MT RTC_TSDR_MT_Msk
20855#define RTC_TSDR_MU_Pos (8U)
20856#define RTC_TSDR_MU_Msk (0xFUL << RTC_TSDR_MU_Pos)
20857#define RTC_TSDR_MU RTC_TSDR_MU_Msk
20858#define RTC_TSDR_MU_0 (0x1UL << RTC_TSDR_MU_Pos)
20859#define RTC_TSDR_MU_1 (0x2UL << RTC_TSDR_MU_Pos)
20860#define RTC_TSDR_MU_2 (0x4UL << RTC_TSDR_MU_Pos)
20861#define RTC_TSDR_MU_3 (0x8UL << RTC_TSDR_MU_Pos)
20862#define RTC_TSDR_DT_Pos (4U)
20863#define RTC_TSDR_DT_Msk (0x3UL << RTC_TSDR_DT_Pos)
20864#define RTC_TSDR_DT RTC_TSDR_DT_Msk
20865#define RTC_TSDR_DT_0 (0x1UL << RTC_TSDR_DT_Pos)
20866#define RTC_TSDR_DT_1 (0x2UL << RTC_TSDR_DT_Pos)
20867#define RTC_TSDR_DU_Pos (0U)
20868#define RTC_TSDR_DU_Msk (0xFUL << RTC_TSDR_DU_Pos)
20869#define RTC_TSDR_DU RTC_TSDR_DU_Msk
20870#define RTC_TSDR_DU_0 (0x1UL << RTC_TSDR_DU_Pos)
20871#define RTC_TSDR_DU_1 (0x2UL << RTC_TSDR_DU_Pos)
20872#define RTC_TSDR_DU_2 (0x4UL << RTC_TSDR_DU_Pos)
20873#define RTC_TSDR_DU_3 (0x8UL << RTC_TSDR_DU_Pos)
20875/******************** Bits definition for RTC_TSSSR register ****************/
20876#define RTC_TSSSR_SS_Pos (0U)
20877#define RTC_TSSSR_SS_Msk (0xFFFFUL << RTC_TSSSR_SS_Pos)
20878#define RTC_TSSSR_SS RTC_TSSSR_SS_Msk
20879
20880/******************** Bits definition for RTC_CALR register *****************/
20881#define RTC_CALR_CALP_Pos (15U)
20882#define RTC_CALR_CALP_Msk (0x1UL << RTC_CALR_CALP_Pos)
20883#define RTC_CALR_CALP RTC_CALR_CALP_Msk
20884#define RTC_CALR_CALW8_Pos (14U)
20885#define RTC_CALR_CALW8_Msk (0x1UL << RTC_CALR_CALW8_Pos)
20886#define RTC_CALR_CALW8 RTC_CALR_CALW8_Msk
20887#define RTC_CALR_CALW16_Pos (13U)
20888#define RTC_CALR_CALW16_Msk (0x1UL << RTC_CALR_CALW16_Pos)
20889#define RTC_CALR_CALW16 RTC_CALR_CALW16_Msk
20890#define RTC_CALR_CALM_Pos (0U)
20891#define RTC_CALR_CALM_Msk (0x1FFUL << RTC_CALR_CALM_Pos)
20892#define RTC_CALR_CALM RTC_CALR_CALM_Msk
20893#define RTC_CALR_CALM_0 (0x001UL << RTC_CALR_CALM_Pos)
20894#define RTC_CALR_CALM_1 (0x002UL << RTC_CALR_CALM_Pos)
20895#define RTC_CALR_CALM_2 (0x004UL << RTC_CALR_CALM_Pos)
20896#define RTC_CALR_CALM_3 (0x008UL << RTC_CALR_CALM_Pos)
20897#define RTC_CALR_CALM_4 (0x010UL << RTC_CALR_CALM_Pos)
20898#define RTC_CALR_CALM_5 (0x020UL << RTC_CALR_CALM_Pos)
20899#define RTC_CALR_CALM_6 (0x040UL << RTC_CALR_CALM_Pos)
20900#define RTC_CALR_CALM_7 (0x080UL << RTC_CALR_CALM_Pos)
20901#define RTC_CALR_CALM_8 (0x100UL << RTC_CALR_CALM_Pos)
20903/******************** Bits definition for RTC_TAMPCR register ***************/
20904#define RTC_TAMPCR_TAMP3MF_Pos (24U)
20905#define RTC_TAMPCR_TAMP3MF_Msk (0x1UL << RTC_TAMPCR_TAMP3MF_Pos)
20906#define RTC_TAMPCR_TAMP3MF RTC_TAMPCR_TAMP3MF_Msk
20907#define RTC_TAMPCR_TAMP3NOERASE_Pos (23U)
20908#define RTC_TAMPCR_TAMP3NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP3NOERASE_Pos)
20909#define RTC_TAMPCR_TAMP3NOERASE RTC_TAMPCR_TAMP3NOERASE_Msk
20910#define RTC_TAMPCR_TAMP3IE_Pos (22U)
20911#define RTC_TAMPCR_TAMP3IE_Msk (0x1UL << RTC_TAMPCR_TAMP3IE_Pos)
20912#define RTC_TAMPCR_TAMP3IE RTC_TAMPCR_TAMP3IE_Msk
20913#define RTC_TAMPCR_TAMP2MF_Pos (21U)
20914#define RTC_TAMPCR_TAMP2MF_Msk (0x1UL << RTC_TAMPCR_TAMP2MF_Pos)
20915#define RTC_TAMPCR_TAMP2MF RTC_TAMPCR_TAMP2MF_Msk
20916#define RTC_TAMPCR_TAMP2NOERASE_Pos (20U)
20917#define RTC_TAMPCR_TAMP2NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP2NOERASE_Pos)
20918#define RTC_TAMPCR_TAMP2NOERASE RTC_TAMPCR_TAMP2NOERASE_Msk
20919#define RTC_TAMPCR_TAMP2IE_Pos (19U)
20920#define RTC_TAMPCR_TAMP2IE_Msk (0x1UL << RTC_TAMPCR_TAMP2IE_Pos)
20921#define RTC_TAMPCR_TAMP2IE RTC_TAMPCR_TAMP2IE_Msk
20922#define RTC_TAMPCR_TAMP1MF_Pos (18U)
20923#define RTC_TAMPCR_TAMP1MF_Msk (0x1UL << RTC_TAMPCR_TAMP1MF_Pos)
20924#define RTC_TAMPCR_TAMP1MF RTC_TAMPCR_TAMP1MF_Msk
20925#define RTC_TAMPCR_TAMP1NOERASE_Pos (17U)
20926#define RTC_TAMPCR_TAMP1NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP1NOERASE_Pos)
20927#define RTC_TAMPCR_TAMP1NOERASE RTC_TAMPCR_TAMP1NOERASE_Msk
20928#define RTC_TAMPCR_TAMP1IE_Pos (16U)
20929#define RTC_TAMPCR_TAMP1IE_Msk (0x1UL << RTC_TAMPCR_TAMP1IE_Pos)
20930#define RTC_TAMPCR_TAMP1IE RTC_TAMPCR_TAMP1IE_Msk
20931#define RTC_TAMPCR_TAMPPUDIS_Pos (15U)
20932#define RTC_TAMPCR_TAMPPUDIS_Msk (0x1UL << RTC_TAMPCR_TAMPPUDIS_Pos)
20933#define RTC_TAMPCR_TAMPPUDIS RTC_TAMPCR_TAMPPUDIS_Msk
20934#define RTC_TAMPCR_TAMPPRCH_Pos (13U)
20935#define RTC_TAMPCR_TAMPPRCH_Msk (0x3UL << RTC_TAMPCR_TAMPPRCH_Pos)
20936#define RTC_TAMPCR_TAMPPRCH RTC_TAMPCR_TAMPPRCH_Msk
20937#define RTC_TAMPCR_TAMPPRCH_0 (0x1UL << RTC_TAMPCR_TAMPPRCH_Pos)
20938#define RTC_TAMPCR_TAMPPRCH_1 (0x2UL << RTC_TAMPCR_TAMPPRCH_Pos)
20939#define RTC_TAMPCR_TAMPFLT_Pos (11U)
20940#define RTC_TAMPCR_TAMPFLT_Msk (0x3UL << RTC_TAMPCR_TAMPFLT_Pos)
20941#define RTC_TAMPCR_TAMPFLT RTC_TAMPCR_TAMPFLT_Msk
20942#define RTC_TAMPCR_TAMPFLT_0 (0x1UL << RTC_TAMPCR_TAMPFLT_Pos)
20943#define RTC_TAMPCR_TAMPFLT_1 (0x2UL << RTC_TAMPCR_TAMPFLT_Pos)
20944#define RTC_TAMPCR_TAMPFREQ_Pos (8U)
20945#define RTC_TAMPCR_TAMPFREQ_Msk (0x7UL << RTC_TAMPCR_TAMPFREQ_Pos)
20946#define RTC_TAMPCR_TAMPFREQ RTC_TAMPCR_TAMPFREQ_Msk
20947#define RTC_TAMPCR_TAMPFREQ_0 (0x1UL << RTC_TAMPCR_TAMPFREQ_Pos)
20948#define RTC_TAMPCR_TAMPFREQ_1 (0x2UL << RTC_TAMPCR_TAMPFREQ_Pos)
20949#define RTC_TAMPCR_TAMPFREQ_2 (0x4UL << RTC_TAMPCR_TAMPFREQ_Pos)
20950#define RTC_TAMPCR_TAMPTS_Pos (7U)
20951#define RTC_TAMPCR_TAMPTS_Msk (0x1UL << RTC_TAMPCR_TAMPTS_Pos)
20952#define RTC_TAMPCR_TAMPTS RTC_TAMPCR_TAMPTS_Msk
20953#define RTC_TAMPCR_TAMP3TRG_Pos (6U)
20954#define RTC_TAMPCR_TAMP3TRG_Msk (0x1UL << RTC_TAMPCR_TAMP3TRG_Pos)
20955#define RTC_TAMPCR_TAMP3TRG RTC_TAMPCR_TAMP3TRG_Msk
20956#define RTC_TAMPCR_TAMP3E_Pos (5U)
20957#define RTC_TAMPCR_TAMP3E_Msk (0x1UL << RTC_TAMPCR_TAMP3E_Pos)
20958#define RTC_TAMPCR_TAMP3E RTC_TAMPCR_TAMP3E_Msk
20959#define RTC_TAMPCR_TAMP2TRG_Pos (4U)
20960#define RTC_TAMPCR_TAMP2TRG_Msk (0x1UL << RTC_TAMPCR_TAMP2TRG_Pos)
20961#define RTC_TAMPCR_TAMP2TRG RTC_TAMPCR_TAMP2TRG_Msk
20962#define RTC_TAMPCR_TAMP2E_Pos (3U)
20963#define RTC_TAMPCR_TAMP2E_Msk (0x1UL << RTC_TAMPCR_TAMP2E_Pos)
20964#define RTC_TAMPCR_TAMP2E RTC_TAMPCR_TAMP2E_Msk
20965#define RTC_TAMPCR_TAMPIE_Pos (2U)
20966#define RTC_TAMPCR_TAMPIE_Msk (0x1UL << RTC_TAMPCR_TAMPIE_Pos)
20967#define RTC_TAMPCR_TAMPIE RTC_TAMPCR_TAMPIE_Msk
20968#define RTC_TAMPCR_TAMP1TRG_Pos (1U)
20969#define RTC_TAMPCR_TAMP1TRG_Msk (0x1UL << RTC_TAMPCR_TAMP1TRG_Pos)
20970#define RTC_TAMPCR_TAMP1TRG RTC_TAMPCR_TAMP1TRG_Msk
20971#define RTC_TAMPCR_TAMP1E_Pos (0U)
20972#define RTC_TAMPCR_TAMP1E_Msk (0x1UL << RTC_TAMPCR_TAMP1E_Pos)
20973#define RTC_TAMPCR_TAMP1E RTC_TAMPCR_TAMP1E_Msk
20974
20975/******************** Bits definition for RTC_ALRMASSR register *************/
20976#define RTC_ALRMASSR_MASKSS_Pos (24U)
20977#define RTC_ALRMASSR_MASKSS_Msk (0xFUL << RTC_ALRMASSR_MASKSS_Pos)
20978#define RTC_ALRMASSR_MASKSS RTC_ALRMASSR_MASKSS_Msk
20979#define RTC_ALRMASSR_MASKSS_0 (0x1UL << RTC_ALRMASSR_MASKSS_Pos)
20980#define RTC_ALRMASSR_MASKSS_1 (0x2UL << RTC_ALRMASSR_MASKSS_Pos)
20981#define RTC_ALRMASSR_MASKSS_2 (0x4UL << RTC_ALRMASSR_MASKSS_Pos)
20982#define RTC_ALRMASSR_MASKSS_3 (0x8UL << RTC_ALRMASSR_MASKSS_Pos)
20983#define RTC_ALRMASSR_SS_Pos (0U)
20984#define RTC_ALRMASSR_SS_Msk (0x7FFFUL << RTC_ALRMASSR_SS_Pos)
20985#define RTC_ALRMASSR_SS RTC_ALRMASSR_SS_Msk
20986
20987/******************** Bits definition for RTC_ALRMBSSR register *************/
20988#define RTC_ALRMBSSR_MASKSS_Pos (24U)
20989#define RTC_ALRMBSSR_MASKSS_Msk (0xFUL << RTC_ALRMBSSR_MASKSS_Pos)
20990#define RTC_ALRMBSSR_MASKSS RTC_ALRMBSSR_MASKSS_Msk
20991#define RTC_ALRMBSSR_MASKSS_0 (0x1UL << RTC_ALRMBSSR_MASKSS_Pos)
20992#define RTC_ALRMBSSR_MASKSS_1 (0x2UL << RTC_ALRMBSSR_MASKSS_Pos)
20993#define RTC_ALRMBSSR_MASKSS_2 (0x4UL << RTC_ALRMBSSR_MASKSS_Pos)
20994#define RTC_ALRMBSSR_MASKSS_3 (0x8UL << RTC_ALRMBSSR_MASKSS_Pos)
20995#define RTC_ALRMBSSR_SS_Pos (0U)
20996#define RTC_ALRMBSSR_SS_Msk (0x7FFFUL << RTC_ALRMBSSR_SS_Pos)
20997#define RTC_ALRMBSSR_SS RTC_ALRMBSSR_SS_Msk
20998
20999/******************** Bits definition for RTC_OR register *******************/
21000#define RTC_OR_OUT_RMP_Pos (1U)
21001#define RTC_OR_OUT_RMP_Msk (0x1UL << RTC_OR_OUT_RMP_Pos)
21002#define RTC_OR_OUT_RMP RTC_OR_OUT_RMP_Msk
21003#define RTC_OR_ALARMOUTTYPE_Pos (0U)
21004#define RTC_OR_ALARMOUTTYPE_Msk (0x1UL << RTC_OR_ALARMOUTTYPE_Pos)
21005#define RTC_OR_ALARMOUTTYPE RTC_OR_ALARMOUTTYPE_Msk
21006
21007/******************** Bits definition for RTC_BKP0R register ****************/
21008#define RTC_BKP0R_Pos (0U)
21009#define RTC_BKP0R_Msk (0xFFFFFFFFUL << RTC_BKP0R_Pos)
21010#define RTC_BKP0R RTC_BKP0R_Msk
21011
21012/******************** Bits definition for RTC_BKP1R register ****************/
21013#define RTC_BKP1R_Pos (0U)
21014#define RTC_BKP1R_Msk (0xFFFFFFFFUL << RTC_BKP1R_Pos)
21015#define RTC_BKP1R RTC_BKP1R_Msk
21016
21017/******************** Bits definition for RTC_BKP2R register ****************/
21018#define RTC_BKP2R_Pos (0U)
21019#define RTC_BKP2R_Msk (0xFFFFFFFFUL << RTC_BKP2R_Pos)
21020#define RTC_BKP2R RTC_BKP2R_Msk
21021
21022/******************** Bits definition for RTC_BKP3R register ****************/
21023#define RTC_BKP3R_Pos (0U)
21024#define RTC_BKP3R_Msk (0xFFFFFFFFUL << RTC_BKP3R_Pos)
21025#define RTC_BKP3R RTC_BKP3R_Msk
21026
21027/******************** Bits definition for RTC_BKP4R register ****************/
21028#define RTC_BKP4R_Pos (0U)
21029#define RTC_BKP4R_Msk (0xFFFFFFFFUL << RTC_BKP4R_Pos)
21030#define RTC_BKP4R RTC_BKP4R_Msk
21031
21032/******************** Bits definition for RTC_BKP5R register ****************/
21033#define RTC_BKP5R_Pos (0U)
21034#define RTC_BKP5R_Msk (0xFFFFFFFFUL << RTC_BKP5R_Pos)
21035#define RTC_BKP5R RTC_BKP5R_Msk
21036
21037/******************** Bits definition for RTC_BKP6R register ****************/
21038#define RTC_BKP6R_Pos (0U)
21039#define RTC_BKP6R_Msk (0xFFFFFFFFUL << RTC_BKP6R_Pos)
21040#define RTC_BKP6R RTC_BKP6R_Msk
21041
21042/******************** Bits definition for RTC_BKP7R register ****************/
21043#define RTC_BKP7R_Pos (0U)
21044#define RTC_BKP7R_Msk (0xFFFFFFFFUL << RTC_BKP7R_Pos)
21045#define RTC_BKP7R RTC_BKP7R_Msk
21046
21047/******************** Bits definition for RTC_BKP8R register ****************/
21048#define RTC_BKP8R_Pos (0U)
21049#define RTC_BKP8R_Msk (0xFFFFFFFFUL << RTC_BKP8R_Pos)
21050#define RTC_BKP8R RTC_BKP8R_Msk
21051
21052/******************** Bits definition for RTC_BKP9R register ****************/
21053#define RTC_BKP9R_Pos (0U)
21054#define RTC_BKP9R_Msk (0xFFFFFFFFUL << RTC_BKP9R_Pos)
21055#define RTC_BKP9R RTC_BKP9R_Msk
21056
21057/******************** Bits definition for RTC_BKP10R register ***************/
21058#define RTC_BKP10R_Pos (0U)
21059#define RTC_BKP10R_Msk (0xFFFFFFFFUL << RTC_BKP10R_Pos)
21060#define RTC_BKP10R RTC_BKP10R_Msk
21061
21062/******************** Bits definition for RTC_BKP11R register ***************/
21063#define RTC_BKP11R_Pos (0U)
21064#define RTC_BKP11R_Msk (0xFFFFFFFFUL << RTC_BKP11R_Pos)
21065#define RTC_BKP11R RTC_BKP11R_Msk
21066
21067/******************** Bits definition for RTC_BKP12R register ***************/
21068#define RTC_BKP12R_Pos (0U)
21069#define RTC_BKP12R_Msk (0xFFFFFFFFUL << RTC_BKP12R_Pos)
21070#define RTC_BKP12R RTC_BKP12R_Msk
21071
21072/******************** Bits definition for RTC_BKP13R register ***************/
21073#define RTC_BKP13R_Pos (0U)
21074#define RTC_BKP13R_Msk (0xFFFFFFFFUL << RTC_BKP13R_Pos)
21075#define RTC_BKP13R RTC_BKP13R_Msk
21076
21077/******************** Bits definition for RTC_BKP14R register ***************/
21078#define RTC_BKP14R_Pos (0U)
21079#define RTC_BKP14R_Msk (0xFFFFFFFFUL << RTC_BKP14R_Pos)
21080#define RTC_BKP14R RTC_BKP14R_Msk
21081
21082/******************** Bits definition for RTC_BKP15R register ***************/
21083#define RTC_BKP15R_Pos (0U)
21084#define RTC_BKP15R_Msk (0xFFFFFFFFUL << RTC_BKP15R_Pos)
21085#define RTC_BKP15R RTC_BKP15R_Msk
21086
21087/******************** Bits definition for RTC_BKP16R register ***************/
21088#define RTC_BKP16R_Pos (0U)
21089#define RTC_BKP16R_Msk (0xFFFFFFFFUL << RTC_BKP16R_Pos)
21090#define RTC_BKP16R RTC_BKP16R_Msk
21091
21092/******************** Bits definition for RTC_BKP17R register ***************/
21093#define RTC_BKP17R_Pos (0U)
21094#define RTC_BKP17R_Msk (0xFFFFFFFFUL << RTC_BKP17R_Pos)
21095#define RTC_BKP17R RTC_BKP17R_Msk
21096
21097/******************** Bits definition for RTC_BKP18R register ***************/
21098#define RTC_BKP18R_Pos (0U)
21099#define RTC_BKP18R_Msk (0xFFFFFFFFUL << RTC_BKP18R_Pos)
21100#define RTC_BKP18R RTC_BKP18R_Msk
21101
21102/******************** Bits definition for RTC_BKP19R register ***************/
21103#define RTC_BKP19R_Pos (0U)
21104#define RTC_BKP19R_Msk (0xFFFFFFFFUL << RTC_BKP19R_Pos)
21105#define RTC_BKP19R RTC_BKP19R_Msk
21106
21107/******************** Bits definition for RTC_BKP20R register ***************/
21108#define RTC_BKP20R_Pos (0U)
21109#define RTC_BKP20R_Msk (0xFFFFFFFFUL << RTC_BKP20R_Pos)
21110#define RTC_BKP20R RTC_BKP20R_Msk
21111
21112/******************** Bits definition for RTC_BKP21R register ***************/
21113#define RTC_BKP21R_Pos (0U)
21114#define RTC_BKP21R_Msk (0xFFFFFFFFUL << RTC_BKP21R_Pos)
21115#define RTC_BKP21R RTC_BKP21R_Msk
21116
21117/******************** Bits definition for RTC_BKP22R register ***************/
21118#define RTC_BKP22R_Pos (0U)
21119#define RTC_BKP22R_Msk (0xFFFFFFFFUL << RTC_BKP22R_Pos)
21120#define RTC_BKP22R RTC_BKP22R_Msk
21121
21122/******************** Bits definition for RTC_BKP23R register ***************/
21123#define RTC_BKP23R_Pos (0U)
21124#define RTC_BKP23R_Msk (0xFFFFFFFFUL << RTC_BKP23R_Pos)
21125#define RTC_BKP23R RTC_BKP23R_Msk
21126
21127/******************** Bits definition for RTC_BKP24R register ***************/
21128#define RTC_BKP24R_Pos (0U)
21129#define RTC_BKP24R_Msk (0xFFFFFFFFUL << RTC_BKP24R_Pos)
21130#define RTC_BKP24R RTC_BKP24R_Msk
21131
21132/******************** Bits definition for RTC_BKP25R register ***************/
21133#define RTC_BKP25R_Pos (0U)
21134#define RTC_BKP25R_Msk (0xFFFFFFFFUL << RTC_BKP25R_Pos)
21135#define RTC_BKP25R RTC_BKP25R_Msk
21136
21137/******************** Bits definition for RTC_BKP26R register ***************/
21138#define RTC_BKP26R_Pos (0U)
21139#define RTC_BKP26R_Msk (0xFFFFFFFFUL << RTC_BKP26R_Pos)
21140#define RTC_BKP26R RTC_BKP26R_Msk
21141
21142/******************** Bits definition for RTC_BKP27R register ***************/
21143#define RTC_BKP27R_Pos (0U)
21144#define RTC_BKP27R_Msk (0xFFFFFFFFUL << RTC_BKP27R_Pos)
21145#define RTC_BKP27R RTC_BKP27R_Msk
21146
21147/******************** Bits definition for RTC_BKP28R register ***************/
21148#define RTC_BKP28R_Pos (0U)
21149#define RTC_BKP28R_Msk (0xFFFFFFFFUL << RTC_BKP28R_Pos)
21150#define RTC_BKP28R RTC_BKP28R_Msk
21151
21152/******************** Bits definition for RTC_BKP29R register ***************/
21153#define RTC_BKP29R_Pos (0U)
21154#define RTC_BKP29R_Msk (0xFFFFFFFFUL << RTC_BKP29R_Pos)
21155#define RTC_BKP29R RTC_BKP29R_Msk
21156
21157/******************** Bits definition for RTC_BKP30R register ***************/
21158#define RTC_BKP30R_Pos (0U)
21159#define RTC_BKP30R_Msk (0xFFFFFFFFUL << RTC_BKP30R_Pos)
21160#define RTC_BKP30R RTC_BKP30R_Msk
21161
21162/******************** Bits definition for RTC_BKP31R register ***************/
21163#define RTC_BKP31R_Pos (0U)
21164#define RTC_BKP31R_Msk (0xFFFFFFFFUL << RTC_BKP31R_Pos)
21165#define RTC_BKP31R RTC_BKP31R_Msk
21166
21167/******************** Number of backup registers ******************************/
21168#define RTC_BKP_NUMBER_Pos (5U)
21169#define RTC_BKP_NUMBER_Msk (0x1UL << RTC_BKP_NUMBER_Pos)
21170#define RTC_BKP_NUMBER RTC_BKP_NUMBER_Msk
21171
21172/******************************************************************************/
21173/* */
21174/* SPDIF-RX Interface */
21175/* */
21176/******************************************************************************/
21177/******************** Bit definition for SPDIF_CR register ******************/
21178#define SPDIFRX_CR_SPDIFEN_Pos (0U)
21179#define SPDIFRX_CR_SPDIFEN_Msk (0x3UL << SPDIFRX_CR_SPDIFEN_Pos)
21180#define SPDIFRX_CR_SPDIFEN SPDIFRX_CR_SPDIFEN_Msk
21181#define SPDIFRX_CR_RXDMAEN_Pos (2U)
21182#define SPDIFRX_CR_RXDMAEN_Msk (0x1UL << SPDIFRX_CR_RXDMAEN_Pos)
21183#define SPDIFRX_CR_RXDMAEN SPDIFRX_CR_RXDMAEN_Msk
21184#define SPDIFRX_CR_RXSTEO_Pos (3U)
21185#define SPDIFRX_CR_RXSTEO_Msk (0x1UL << SPDIFRX_CR_RXSTEO_Pos)
21186#define SPDIFRX_CR_RXSTEO SPDIFRX_CR_RXSTEO_Msk
21187#define SPDIFRX_CR_DRFMT_Pos (4U)
21188#define SPDIFRX_CR_DRFMT_Msk (0x3UL << SPDIFRX_CR_DRFMT_Pos)
21189#define SPDIFRX_CR_DRFMT SPDIFRX_CR_DRFMT_Msk
21190#define SPDIFRX_CR_PMSK_Pos (6U)
21191#define SPDIFRX_CR_PMSK_Msk (0x1UL << SPDIFRX_CR_PMSK_Pos)
21192#define SPDIFRX_CR_PMSK SPDIFRX_CR_PMSK_Msk
21193#define SPDIFRX_CR_VMSK_Pos (7U)
21194#define SPDIFRX_CR_VMSK_Msk (0x1UL << SPDIFRX_CR_VMSK_Pos)
21195#define SPDIFRX_CR_VMSK SPDIFRX_CR_VMSK_Msk
21196#define SPDIFRX_CR_CUMSK_Pos (8U)
21197#define SPDIFRX_CR_CUMSK_Msk (0x1UL << SPDIFRX_CR_CUMSK_Pos)
21198#define SPDIFRX_CR_CUMSK SPDIFRX_CR_CUMSK_Msk
21199#define SPDIFRX_CR_PTMSK_Pos (9U)
21200#define SPDIFRX_CR_PTMSK_Msk (0x1UL << SPDIFRX_CR_PTMSK_Pos)
21201#define SPDIFRX_CR_PTMSK SPDIFRX_CR_PTMSK_Msk
21202#define SPDIFRX_CR_CBDMAEN_Pos (10U)
21203#define SPDIFRX_CR_CBDMAEN_Msk (0x1UL << SPDIFRX_CR_CBDMAEN_Pos)
21204#define SPDIFRX_CR_CBDMAEN SPDIFRX_CR_CBDMAEN_Msk
21205#define SPDIFRX_CR_CHSEL_Pos (11U)
21206#define SPDIFRX_CR_CHSEL_Msk (0x1UL << SPDIFRX_CR_CHSEL_Pos)
21207#define SPDIFRX_CR_CHSEL SPDIFRX_CR_CHSEL_Msk
21208#define SPDIFRX_CR_NBTR_Pos (12U)
21209#define SPDIFRX_CR_NBTR_Msk (0x3UL << SPDIFRX_CR_NBTR_Pos)
21210#define SPDIFRX_CR_NBTR SPDIFRX_CR_NBTR_Msk
21211#define SPDIFRX_CR_WFA_Pos (14U)
21212#define SPDIFRX_CR_WFA_Msk (0x1UL << SPDIFRX_CR_WFA_Pos)
21213#define SPDIFRX_CR_WFA SPDIFRX_CR_WFA_Msk
21214#define SPDIFRX_CR_INSEL_Pos (16U)
21215#define SPDIFRX_CR_INSEL_Msk (0x7UL << SPDIFRX_CR_INSEL_Pos)
21216#define SPDIFRX_CR_INSEL SPDIFRX_CR_INSEL_Msk
21217#define SPDIFRX_CR_CKSEN_Pos (20U)
21218#define SPDIFRX_CR_CKSEN_Msk (0x1UL << SPDIFRX_CR_CKSEN_Pos)
21219#define SPDIFRX_CR_CKSEN SPDIFRX_CR_CKSEN_Msk
21220#define SPDIFRX_CR_CKSBKPEN_Pos (21U)
21221#define SPDIFRX_CR_CKSBKPEN_Msk (0x1UL << SPDIFRX_CR_CKSBKPEN_Pos)
21222#define SPDIFRX_CR_CKSBKPEN SPDIFRX_CR_CKSBKPEN_Msk
21224/******************* Bit definition for SPDIFRX_IMR register *******************/
21225#define SPDIFRX_IMR_RXNEIE_Pos (0U)
21226#define SPDIFRX_IMR_RXNEIE_Msk (0x1UL << SPDIFRX_IMR_RXNEIE_Pos)
21227#define SPDIFRX_IMR_RXNEIE SPDIFRX_IMR_RXNEIE_Msk
21228#define SPDIFRX_IMR_CSRNEIE_Pos (1U)
21229#define SPDIFRX_IMR_CSRNEIE_Msk (0x1UL << SPDIFRX_IMR_CSRNEIE_Pos)
21230#define SPDIFRX_IMR_CSRNEIE SPDIFRX_IMR_CSRNEIE_Msk
21231#define SPDIFRX_IMR_PERRIE_Pos (2U)
21232#define SPDIFRX_IMR_PERRIE_Msk (0x1UL << SPDIFRX_IMR_PERRIE_Pos)
21233#define SPDIFRX_IMR_PERRIE SPDIFRX_IMR_PERRIE_Msk
21234#define SPDIFRX_IMR_OVRIE_Pos (3U)
21235#define SPDIFRX_IMR_OVRIE_Msk (0x1UL << SPDIFRX_IMR_OVRIE_Pos)
21236#define SPDIFRX_IMR_OVRIE SPDIFRX_IMR_OVRIE_Msk
21237#define SPDIFRX_IMR_SBLKIE_Pos (4U)
21238#define SPDIFRX_IMR_SBLKIE_Msk (0x1UL << SPDIFRX_IMR_SBLKIE_Pos)
21239#define SPDIFRX_IMR_SBLKIE SPDIFRX_IMR_SBLKIE_Msk
21240#define SPDIFRX_IMR_SYNCDIE_Pos (5U)
21241#define SPDIFRX_IMR_SYNCDIE_Msk (0x1UL << SPDIFRX_IMR_SYNCDIE_Pos)
21242#define SPDIFRX_IMR_SYNCDIE SPDIFRX_IMR_SYNCDIE_Msk
21243#define SPDIFRX_IMR_IFEIE_Pos (6U)
21244#define SPDIFRX_IMR_IFEIE_Msk (0x1UL << SPDIFRX_IMR_IFEIE_Pos)
21245#define SPDIFRX_IMR_IFEIE SPDIFRX_IMR_IFEIE_Msk
21247/******************* Bit definition for SPDIFRX_SR register *******************/
21248#define SPDIFRX_SR_RXNE_Pos (0U)
21249#define SPDIFRX_SR_RXNE_Msk (0x1UL << SPDIFRX_SR_RXNE_Pos)
21250#define SPDIFRX_SR_RXNE SPDIFRX_SR_RXNE_Msk
21251#define SPDIFRX_SR_CSRNE_Pos (1U)
21252#define SPDIFRX_SR_CSRNE_Msk (0x1UL << SPDIFRX_SR_CSRNE_Pos)
21253#define SPDIFRX_SR_CSRNE SPDIFRX_SR_CSRNE_Msk
21254#define SPDIFRX_SR_PERR_Pos (2U)
21255#define SPDIFRX_SR_PERR_Msk (0x1UL << SPDIFRX_SR_PERR_Pos)
21256#define SPDIFRX_SR_PERR SPDIFRX_SR_PERR_Msk
21257#define SPDIFRX_SR_OVR_Pos (3U)
21258#define SPDIFRX_SR_OVR_Msk (0x1UL << SPDIFRX_SR_OVR_Pos)
21259#define SPDIFRX_SR_OVR SPDIFRX_SR_OVR_Msk
21260#define SPDIFRX_SR_SBD_Pos (4U)
21261#define SPDIFRX_SR_SBD_Msk (0x1UL << SPDIFRX_SR_SBD_Pos)
21262#define SPDIFRX_SR_SBD SPDIFRX_SR_SBD_Msk
21263#define SPDIFRX_SR_SYNCD_Pos (5U)
21264#define SPDIFRX_SR_SYNCD_Msk (0x1UL << SPDIFRX_SR_SYNCD_Pos)
21265#define SPDIFRX_SR_SYNCD SPDIFRX_SR_SYNCD_Msk
21266#define SPDIFRX_SR_FERR_Pos (6U)
21267#define SPDIFRX_SR_FERR_Msk (0x1UL << SPDIFRX_SR_FERR_Pos)
21268#define SPDIFRX_SR_FERR SPDIFRX_SR_FERR_Msk
21269#define SPDIFRX_SR_SERR_Pos (7U)
21270#define SPDIFRX_SR_SERR_Msk (0x1UL << SPDIFRX_SR_SERR_Pos)
21271#define SPDIFRX_SR_SERR SPDIFRX_SR_SERR_Msk
21272#define SPDIFRX_SR_TERR_Pos (8U)
21273#define SPDIFRX_SR_TERR_Msk (0x1UL << SPDIFRX_SR_TERR_Pos)
21274#define SPDIFRX_SR_TERR SPDIFRX_SR_TERR_Msk
21275#define SPDIFRX_SR_WIDTH5_Pos (16U)
21276#define SPDIFRX_SR_WIDTH5_Msk (0x7FFFUL << SPDIFRX_SR_WIDTH5_Pos)
21277#define SPDIFRX_SR_WIDTH5 SPDIFRX_SR_WIDTH5_Msk
21279/******************* Bit definition for SPDIFRX_IFCR register *******************/
21280#define SPDIFRX_IFCR_PERRCF_Pos (2U)
21281#define SPDIFRX_IFCR_PERRCF_Msk (0x1UL << SPDIFRX_IFCR_PERRCF_Pos)
21282#define SPDIFRX_IFCR_PERRCF SPDIFRX_IFCR_PERRCF_Msk
21283#define SPDIFRX_IFCR_OVRCF_Pos (3U)
21284#define SPDIFRX_IFCR_OVRCF_Msk (0x1UL << SPDIFRX_IFCR_OVRCF_Pos)
21285#define SPDIFRX_IFCR_OVRCF SPDIFRX_IFCR_OVRCF_Msk
21286#define SPDIFRX_IFCR_SBDCF_Pos (4U)
21287#define SPDIFRX_IFCR_SBDCF_Msk (0x1UL << SPDIFRX_IFCR_SBDCF_Pos)
21288#define SPDIFRX_IFCR_SBDCF SPDIFRX_IFCR_SBDCF_Msk
21289#define SPDIFRX_IFCR_SYNCDCF_Pos (5U)
21290#define SPDIFRX_IFCR_SYNCDCF_Msk (0x1UL << SPDIFRX_IFCR_SYNCDCF_Pos)
21291#define SPDIFRX_IFCR_SYNCDCF SPDIFRX_IFCR_SYNCDCF_Msk
21293/******************* Bit definition for SPDIFRX_DR register (DRFMT = 0b00 case) *******************/
21294#define SPDIFRX_DR0_DR_Pos (0U)
21295#define SPDIFRX_DR0_DR_Msk (0xFFFFFFUL << SPDIFRX_DR0_DR_Pos)
21296#define SPDIFRX_DR0_DR SPDIFRX_DR0_DR_Msk
21297#define SPDIFRX_DR0_PE_Pos (24U)
21298#define SPDIFRX_DR0_PE_Msk (0x1UL << SPDIFRX_DR0_PE_Pos)
21299#define SPDIFRX_DR0_PE SPDIFRX_DR0_PE_Msk
21300#define SPDIFRX_DR0_V_Pos (25U)
21301#define SPDIFRX_DR0_V_Msk (0x1UL << SPDIFRX_DR0_V_Pos)
21302#define SPDIFRX_DR0_V SPDIFRX_DR0_V_Msk
21303#define SPDIFRX_DR0_U_Pos (26U)
21304#define SPDIFRX_DR0_U_Msk (0x1UL << SPDIFRX_DR0_U_Pos)
21305#define SPDIFRX_DR0_U SPDIFRX_DR0_U_Msk
21306#define SPDIFRX_DR0_C_Pos (27U)
21307#define SPDIFRX_DR0_C_Msk (0x1UL << SPDIFRX_DR0_C_Pos)
21308#define SPDIFRX_DR0_C SPDIFRX_DR0_C_Msk
21309#define SPDIFRX_DR0_PT_Pos (28U)
21310#define SPDIFRX_DR0_PT_Msk (0x3UL << SPDIFRX_DR0_PT_Pos)
21311#define SPDIFRX_DR0_PT SPDIFRX_DR0_PT_Msk
21313/******************* Bit definition for SPDIFRX_DR register (DRFMT = 0b01 case) *******************/
21314#define SPDIFRX_DR1_DR_Pos (8U)
21315#define SPDIFRX_DR1_DR_Msk (0xFFFFFFUL << SPDIFRX_DR1_DR_Pos)
21316#define SPDIFRX_DR1_DR SPDIFRX_DR1_DR_Msk
21317#define SPDIFRX_DR1_PT_Pos (4U)
21318#define SPDIFRX_DR1_PT_Msk (0x3UL << SPDIFRX_DR1_PT_Pos)
21319#define SPDIFRX_DR1_PT SPDIFRX_DR1_PT_Msk
21320#define SPDIFRX_DR1_C_Pos (3U)
21321#define SPDIFRX_DR1_C_Msk (0x1UL << SPDIFRX_DR1_C_Pos)
21322#define SPDIFRX_DR1_C SPDIFRX_DR1_C_Msk
21323#define SPDIFRX_DR1_U_Pos (2U)
21324#define SPDIFRX_DR1_U_Msk (0x1UL << SPDIFRX_DR1_U_Pos)
21325#define SPDIFRX_DR1_U SPDIFRX_DR1_U_Msk
21326#define SPDIFRX_DR1_V_Pos (1U)
21327#define SPDIFRX_DR1_V_Msk (0x1UL << SPDIFRX_DR1_V_Pos)
21328#define SPDIFRX_DR1_V SPDIFRX_DR1_V_Msk
21329#define SPDIFRX_DR1_PE_Pos (0U)
21330#define SPDIFRX_DR1_PE_Msk (0x1UL << SPDIFRX_DR1_PE_Pos)
21331#define SPDIFRX_DR1_PE SPDIFRX_DR1_PE_Msk
21333/******************* Bit definition for SPDIFRX_DR register (DRFMT = 0b10 case) *******************/
21334#define SPDIFRX_DR1_DRNL1_Pos (16U)
21335#define SPDIFRX_DR1_DRNL1_Msk (0xFFFFUL << SPDIFRX_DR1_DRNL1_Pos)
21336#define SPDIFRX_DR1_DRNL1 SPDIFRX_DR1_DRNL1_Msk
21337#define SPDIFRX_DR1_DRNL2_Pos (0U)
21338#define SPDIFRX_DR1_DRNL2_Msk (0xFFFFUL << SPDIFRX_DR1_DRNL2_Pos)
21339#define SPDIFRX_DR1_DRNL2 SPDIFRX_DR1_DRNL2_Msk
21341/******************* Bit definition for SPDIFRX_CSR register *******************/
21342#define SPDIFRX_CSR_USR_Pos (0U)
21343#define SPDIFRX_CSR_USR_Msk (0xFFFFUL << SPDIFRX_CSR_USR_Pos)
21344#define SPDIFRX_CSR_USR SPDIFRX_CSR_USR_Msk
21345#define SPDIFRX_CSR_CS_Pos (16U)
21346#define SPDIFRX_CSR_CS_Msk (0xFFUL << SPDIFRX_CSR_CS_Pos)
21347#define SPDIFRX_CSR_CS SPDIFRX_CSR_CS_Msk
21348#define SPDIFRX_CSR_SOB_Pos (24U)
21349#define SPDIFRX_CSR_SOB_Msk (0x1UL << SPDIFRX_CSR_SOB_Pos)
21350#define SPDIFRX_CSR_SOB SPDIFRX_CSR_SOB_Msk
21352/******************* Bit definition for SPDIFRX_DIR register *******************/
21353#define SPDIFRX_DIR_THI_Pos (0U)
21354#define SPDIFRX_DIR_THI_Msk (0x1FFFUL << SPDIFRX_DIR_THI_Pos)
21355#define SPDIFRX_DIR_THI SPDIFRX_DIR_THI_Msk
21356#define SPDIFRX_DIR_TLO_Pos (16U)
21357#define SPDIFRX_DIR_TLO_Msk (0x1FFFUL << SPDIFRX_DIR_TLO_Pos)
21358#define SPDIFRX_DIR_TLO SPDIFRX_DIR_TLO_Msk
21360/******************* Bit definition for SPDIFRX_VERR register *******************/
21361#define SPDIFRX_VERR_MINREV_Pos (0U)
21362#define SPDIFRX_VERR_MINREV_Msk (0xFUL << SPDIFRX_VERR_MINREV_Pos)
21363#define SPDIFRX_VERR_MINREV SPDIFRX_VERR_MINREV_Msk
21364#define SPDIFRX_VERR_MAJREV_Pos (4U)
21365#define SPDIFRX_VERR_MAJREV_Msk (0xFUL << SPDIFRX_VERR_MAJREV_Pos)
21366#define SPDIFRX_VERR_MAJREV SPDIFRX_VERR_MAJREV_Msk
21368/******************* Bit definition for SPDIFRX_IDR register *******************/
21369#define SPDIFRX_IDR_ID_Pos (0U)
21370#define SPDIFRX_IDR_ID_Msk (0xFFFFFFFFUL << SPDIFRX_IDR_ID_Pos)
21371#define SPDIFRX_IDR_ID SPDIFRX_IDR_ID_Msk
21373/******************* Bit definition for SPDIFRX_SIDR register *******************/
21374#define SPDIFRX_SIDR_SID_Pos (0U)
21375#define SPDIFRX_SIDR_SID_Msk (0xFFFFFFFFUL << SPDIFRX_SIDR_SID_Pos)
21376#define SPDIFRX_SIDR_SID SPDIFRX_SIDR_SID_Msk
21378/******************************************************************************/
21379/* */
21380/* Serial Audio Interface */
21381/* */
21382/******************************************************************************/
21383/******************************* SAI VERSION ********************************/
21384#define SAI_VER_V2_X
21385
21386/******************** Bit definition for SAI_GCR register *******************/
21387#define SAI_GCR_SYNCIN_Pos (0U)
21388#define SAI_GCR_SYNCIN_Msk (0x3UL << SAI_GCR_SYNCIN_Pos)
21389#define SAI_GCR_SYNCIN SAI_GCR_SYNCIN_Msk
21390#define SAI_GCR_SYNCIN_0 (0x1UL << SAI_GCR_SYNCIN_Pos)
21391#define SAI_GCR_SYNCIN_1 (0x2UL << SAI_GCR_SYNCIN_Pos)
21393#define SAI_GCR_SYNCOUT_Pos (4U)
21394#define SAI_GCR_SYNCOUT_Msk (0x3UL << SAI_GCR_SYNCOUT_Pos)
21395#define SAI_GCR_SYNCOUT SAI_GCR_SYNCOUT_Msk
21396#define SAI_GCR_SYNCOUT_0 (0x1UL << SAI_GCR_SYNCOUT_Pos)
21397#define SAI_GCR_SYNCOUT_1 (0x2UL << SAI_GCR_SYNCOUT_Pos)
21399/******************* Bit definition for SAI_xCR1 register *******************/
21400#define SAI_xCR1_MODE_Pos (0U)
21401#define SAI_xCR1_MODE_Msk (0x3UL << SAI_xCR1_MODE_Pos)
21402#define SAI_xCR1_MODE SAI_xCR1_MODE_Msk
21403#define SAI_xCR1_MODE_0 (0x1UL << SAI_xCR1_MODE_Pos)
21404#define SAI_xCR1_MODE_1 (0x2UL << SAI_xCR1_MODE_Pos)
21406#define SAI_xCR1_PRTCFG_Pos (2U)
21407#define SAI_xCR1_PRTCFG_Msk (0x3UL << SAI_xCR1_PRTCFG_Pos)
21408#define SAI_xCR1_PRTCFG SAI_xCR1_PRTCFG_Msk
21409#define SAI_xCR1_PRTCFG_0 (0x1UL << SAI_xCR1_PRTCFG_Pos)
21410#define SAI_xCR1_PRTCFG_1 (0x2UL << SAI_xCR1_PRTCFG_Pos)
21412#define SAI_xCR1_DS_Pos (5U)
21413#define SAI_xCR1_DS_Msk (0x7UL << SAI_xCR1_DS_Pos)
21414#define SAI_xCR1_DS SAI_xCR1_DS_Msk
21415#define SAI_xCR1_DS_0 (0x1UL << SAI_xCR1_DS_Pos)
21416#define SAI_xCR1_DS_1 (0x2UL << SAI_xCR1_DS_Pos)
21417#define SAI_xCR1_DS_2 (0x4UL << SAI_xCR1_DS_Pos)
21419#define SAI_xCR1_LSBFIRST_Pos (8U)
21420#define SAI_xCR1_LSBFIRST_Msk (0x1UL << SAI_xCR1_LSBFIRST_Pos)
21421#define SAI_xCR1_LSBFIRST SAI_xCR1_LSBFIRST_Msk
21422#define SAI_xCR1_CKSTR_Pos (9U)
21423#define SAI_xCR1_CKSTR_Msk (0x1UL << SAI_xCR1_CKSTR_Pos)
21424#define SAI_xCR1_CKSTR SAI_xCR1_CKSTR_Msk
21426#define SAI_xCR1_SYNCEN_Pos (10U)
21427#define SAI_xCR1_SYNCEN_Msk (0x3UL << SAI_xCR1_SYNCEN_Pos)
21428#define SAI_xCR1_SYNCEN SAI_xCR1_SYNCEN_Msk
21429#define SAI_xCR1_SYNCEN_0 (0x1UL << SAI_xCR1_SYNCEN_Pos)
21430#define SAI_xCR1_SYNCEN_1 (0x2UL << SAI_xCR1_SYNCEN_Pos)
21432#define SAI_xCR1_MONO_Pos (12U)
21433#define SAI_xCR1_MONO_Msk (0x1UL << SAI_xCR1_MONO_Pos)
21434#define SAI_xCR1_MONO SAI_xCR1_MONO_Msk
21435#define SAI_xCR1_OUTDRIV_Pos (13U)
21436#define SAI_xCR1_OUTDRIV_Msk (0x1UL << SAI_xCR1_OUTDRIV_Pos)
21437#define SAI_xCR1_OUTDRIV SAI_xCR1_OUTDRIV_Msk
21438#define SAI_xCR1_SAIEN_Pos (16U)
21439#define SAI_xCR1_SAIEN_Msk (0x1UL << SAI_xCR1_SAIEN_Pos)
21440#define SAI_xCR1_SAIEN SAI_xCR1_SAIEN_Msk
21441#define SAI_xCR1_DMAEN_Pos (17U)
21442#define SAI_xCR1_DMAEN_Msk (0x1UL << SAI_xCR1_DMAEN_Pos)
21443#define SAI_xCR1_DMAEN SAI_xCR1_DMAEN_Msk
21444#define SAI_xCR1_NODIV_Pos (19U)
21445#define SAI_xCR1_NODIV_Msk (0x1UL << SAI_xCR1_NODIV_Pos)
21446#define SAI_xCR1_NODIV SAI_xCR1_NODIV_Msk
21448#define SAI_xCR1_MCKDIV_Pos (20U)
21449#define SAI_xCR1_MCKDIV_Msk (0x3FUL << SAI_xCR1_MCKDIV_Pos)
21450#define SAI_xCR1_MCKDIV SAI_xCR1_MCKDIV_Msk
21451#define SAI_xCR1_MCKDIV_0 (0x01UL << SAI_xCR1_MCKDIV_Pos)
21452#define SAI_xCR1_MCKDIV_1 (0x02UL << SAI_xCR1_MCKDIV_Pos)
21453#define SAI_xCR1_MCKDIV_2 (0x04UL << SAI_xCR1_MCKDIV_Pos)
21454#define SAI_xCR1_MCKDIV_3 (0x08UL << SAI_xCR1_MCKDIV_Pos)
21455#define SAI_xCR1_MCKDIV_4 (0x10UL << SAI_xCR1_MCKDIV_Pos)
21456#define SAI_xCR1_MCKDIV_5 (0x20UL << SAI_xCR1_MCKDIV_Pos)
21458#define SAI_xCR1_MCKEN_Pos (27U)
21459#define SAI_xCR1_MCKEN_Msk (0x1UL << SAI_xCR1_MCKEN_Pos)
21460#define SAI_xCR1_MCKEN SAI_xCR1_MCKEN_Msk
21462#define SAI_xCR1_OSR_Pos (26U)
21463#define SAI_xCR1_OSR_Msk (0x1UL << SAI_xCR1_OSR_Pos)
21464#define SAI_xCR1_OSR SAI_xCR1_OSR_Msk
21466/* Legacy define */
21467#define SAI_xCR1_NOMCK SAI_xCR1_NODIV
21468
21469/******************* Bit definition for SAI_xCR2 register *******************/
21470#define SAI_xCR2_FTH_Pos (0U)
21471#define SAI_xCR2_FTH_Msk (0x7UL << SAI_xCR2_FTH_Pos)
21472#define SAI_xCR2_FTH SAI_xCR2_FTH_Msk
21473#define SAI_xCR2_FTH_0 (0x1UL << SAI_xCR2_FTH_Pos)
21474#define SAI_xCR2_FTH_1 (0x2UL << SAI_xCR2_FTH_Pos)
21475#define SAI_xCR2_FTH_2 (0x4UL << SAI_xCR2_FTH_Pos)
21477#define SAI_xCR2_FFLUSH_Pos (3U)
21478#define SAI_xCR2_FFLUSH_Msk (0x1UL << SAI_xCR2_FFLUSH_Pos)
21479#define SAI_xCR2_FFLUSH SAI_xCR2_FFLUSH_Msk
21480#define SAI_xCR2_TRIS_Pos (4U)
21481#define SAI_xCR2_TRIS_Msk (0x1UL << SAI_xCR2_TRIS_Pos)
21482#define SAI_xCR2_TRIS SAI_xCR2_TRIS_Msk
21483#define SAI_xCR2_MUTE_Pos (5U)
21484#define SAI_xCR2_MUTE_Msk (0x1UL << SAI_xCR2_MUTE_Pos)
21485#define SAI_xCR2_MUTE SAI_xCR2_MUTE_Msk
21486#define SAI_xCR2_MUTEVAL_Pos (6U)
21487#define SAI_xCR2_MUTEVAL_Msk (0x1UL << SAI_xCR2_MUTEVAL_Pos)
21488#define SAI_xCR2_MUTEVAL SAI_xCR2_MUTEVAL_Msk
21490#define SAI_xCR2_MUTECNT_Pos (7U)
21491#define SAI_xCR2_MUTECNT_Msk (0x3FUL << SAI_xCR2_MUTECNT_Pos)
21492#define SAI_xCR2_MUTECNT SAI_xCR2_MUTECNT_Msk
21493#define SAI_xCR2_MUTECNT_0 (0x01UL << SAI_xCR2_MUTECNT_Pos)
21494#define SAI_xCR2_MUTECNT_1 (0x02UL << SAI_xCR2_MUTECNT_Pos)
21495#define SAI_xCR2_MUTECNT_2 (0x04UL << SAI_xCR2_MUTECNT_Pos)
21496#define SAI_xCR2_MUTECNT_3 (0x08UL << SAI_xCR2_MUTECNT_Pos)
21497#define SAI_xCR2_MUTECNT_4 (0x10UL << SAI_xCR2_MUTECNT_Pos)
21498#define SAI_xCR2_MUTECNT_5 (0x20UL << SAI_xCR2_MUTECNT_Pos)
21500#define SAI_xCR2_CPL_Pos (13U)
21501#define SAI_xCR2_CPL_Msk (0x1UL << SAI_xCR2_CPL_Pos)
21502#define SAI_xCR2_CPL SAI_xCR2_CPL_Msk
21504#define SAI_xCR2_COMP_Pos (14U)
21505#define SAI_xCR2_COMP_Msk (0x3UL << SAI_xCR2_COMP_Pos)
21506#define SAI_xCR2_COMP SAI_xCR2_COMP_Msk
21507#define SAI_xCR2_COMP_0 (0x1UL << SAI_xCR2_COMP_Pos)
21508#define SAI_xCR2_COMP_1 (0x2UL << SAI_xCR2_COMP_Pos)
21510/****************** Bit definition for SAI_xFRCR register *******************/
21511#define SAI_xFRCR_FRL_Pos (0U)
21512#define SAI_xFRCR_FRL_Msk (0xFFUL << SAI_xFRCR_FRL_Pos)
21513#define SAI_xFRCR_FRL SAI_xFRCR_FRL_Msk
21514#define SAI_xFRCR_FRL_0 (0x01UL << SAI_xFRCR_FRL_Pos)
21515#define SAI_xFRCR_FRL_1 (0x02UL << SAI_xFRCR_FRL_Pos)
21516#define SAI_xFRCR_FRL_2 (0x04UL << SAI_xFRCR_FRL_Pos)
21517#define SAI_xFRCR_FRL_3 (0x08UL << SAI_xFRCR_FRL_Pos)
21518#define SAI_xFRCR_FRL_4 (0x10UL << SAI_xFRCR_FRL_Pos)
21519#define SAI_xFRCR_FRL_5 (0x20UL << SAI_xFRCR_FRL_Pos)
21520#define SAI_xFRCR_FRL_6 (0x40UL << SAI_xFRCR_FRL_Pos)
21521#define SAI_xFRCR_FRL_7 (0x80UL << SAI_xFRCR_FRL_Pos)
21523#define SAI_xFRCR_FSALL_Pos (8U)
21524#define SAI_xFRCR_FSALL_Msk (0x7FUL << SAI_xFRCR_FSALL_Pos)
21525#define SAI_xFRCR_FSALL SAI_xFRCR_FSALL_Msk
21526#define SAI_xFRCR_FSALL_0 (0x01UL << SAI_xFRCR_FSALL_Pos)
21527#define SAI_xFRCR_FSALL_1 (0x02UL << SAI_xFRCR_FSALL_Pos)
21528#define SAI_xFRCR_FSALL_2 (0x04UL << SAI_xFRCR_FSALL_Pos)
21529#define SAI_xFRCR_FSALL_3 (0x08UL << SAI_xFRCR_FSALL_Pos)
21530#define SAI_xFRCR_FSALL_4 (0x10UL << SAI_xFRCR_FSALL_Pos)
21531#define SAI_xFRCR_FSALL_5 (0x20UL << SAI_xFRCR_FSALL_Pos)
21532#define SAI_xFRCR_FSALL_6 (0x40UL << SAI_xFRCR_FSALL_Pos)
21534#define SAI_xFRCR_FSDEF_Pos (16U)
21535#define SAI_xFRCR_FSDEF_Msk (0x1UL << SAI_xFRCR_FSDEF_Pos)
21536#define SAI_xFRCR_FSDEF SAI_xFRCR_FSDEF_Msk
21537#define SAI_xFRCR_FSPOL_Pos (17U)
21538#define SAI_xFRCR_FSPOL_Msk (0x1UL << SAI_xFRCR_FSPOL_Pos)
21539#define SAI_xFRCR_FSPOL SAI_xFRCR_FSPOL_Msk
21540#define SAI_xFRCR_FSOFF_Pos (18U)
21541#define SAI_xFRCR_FSOFF_Msk (0x1UL << SAI_xFRCR_FSOFF_Pos)
21542#define SAI_xFRCR_FSOFF SAI_xFRCR_FSOFF_Msk
21544/* Legacy define */
21545#define SAI_xFRCR_FSPO SAI_xFRCR_FSPOL
21546
21547/****************** Bit definition for SAI_xSLOTR register *******************/
21548#define SAI_xSLOTR_FBOFF_Pos (0U)
21549#define SAI_xSLOTR_FBOFF_Msk (0x1FUL << SAI_xSLOTR_FBOFF_Pos)
21550#define SAI_xSLOTR_FBOFF SAI_xSLOTR_FBOFF_Msk
21551#define SAI_xSLOTR_FBOFF_0 (0x01UL << SAI_xSLOTR_FBOFF_Pos)
21552#define SAI_xSLOTR_FBOFF_1 (0x02UL << SAI_xSLOTR_FBOFF_Pos)
21553#define SAI_xSLOTR_FBOFF_2 (0x04UL << SAI_xSLOTR_FBOFF_Pos)
21554#define SAI_xSLOTR_FBOFF_3 (0x08UL << SAI_xSLOTR_FBOFF_Pos)
21555#define SAI_xSLOTR_FBOFF_4 (0x10UL << SAI_xSLOTR_FBOFF_Pos)
21557#define SAI_xSLOTR_SLOTSZ_Pos (6U)
21558#define SAI_xSLOTR_SLOTSZ_Msk (0x3UL << SAI_xSLOTR_SLOTSZ_Pos)
21559#define SAI_xSLOTR_SLOTSZ SAI_xSLOTR_SLOTSZ_Msk
21560#define SAI_xSLOTR_SLOTSZ_0 (0x1UL << SAI_xSLOTR_SLOTSZ_Pos)
21561#define SAI_xSLOTR_SLOTSZ_1 (0x2UL << SAI_xSLOTR_SLOTSZ_Pos)
21563#define SAI_xSLOTR_NBSLOT_Pos (8U)
21564#define SAI_xSLOTR_NBSLOT_Msk (0xFUL << SAI_xSLOTR_NBSLOT_Pos)
21565#define SAI_xSLOTR_NBSLOT SAI_xSLOTR_NBSLOT_Msk
21566#define SAI_xSLOTR_NBSLOT_0 (0x1UL << SAI_xSLOTR_NBSLOT_Pos)
21567#define SAI_xSLOTR_NBSLOT_1 (0x2UL << SAI_xSLOTR_NBSLOT_Pos)
21568#define SAI_xSLOTR_NBSLOT_2 (0x4UL << SAI_xSLOTR_NBSLOT_Pos)
21569#define SAI_xSLOTR_NBSLOT_3 (0x8UL << SAI_xSLOTR_NBSLOT_Pos)
21571#define SAI_xSLOTR_SLOTEN_Pos (16U)
21572#define SAI_xSLOTR_SLOTEN_Msk (0xFFFFUL << SAI_xSLOTR_SLOTEN_Pos)
21573#define SAI_xSLOTR_SLOTEN SAI_xSLOTR_SLOTEN_Msk
21575/******************* Bit definition for SAI_xIMR register *******************/
21576#define SAI_xIMR_OVRUDRIE_Pos (0U)
21577#define SAI_xIMR_OVRUDRIE_Msk (0x1UL << SAI_xIMR_OVRUDRIE_Pos)
21578#define SAI_xIMR_OVRUDRIE SAI_xIMR_OVRUDRIE_Msk
21579#define SAI_xIMR_MUTEDETIE_Pos (1U)
21580#define SAI_xIMR_MUTEDETIE_Msk (0x1UL << SAI_xIMR_MUTEDETIE_Pos)
21581#define SAI_xIMR_MUTEDETIE SAI_xIMR_MUTEDETIE_Msk
21582#define SAI_xIMR_WCKCFGIE_Pos (2U)
21583#define SAI_xIMR_WCKCFGIE_Msk (0x1UL << SAI_xIMR_WCKCFGIE_Pos)
21584#define SAI_xIMR_WCKCFGIE SAI_xIMR_WCKCFGIE_Msk
21585#define SAI_xIMR_FREQIE_Pos (3U)
21586#define SAI_xIMR_FREQIE_Msk (0x1UL << SAI_xIMR_FREQIE_Pos)
21587#define SAI_xIMR_FREQIE SAI_xIMR_FREQIE_Msk
21588#define SAI_xIMR_CNRDYIE_Pos (4U)
21589#define SAI_xIMR_CNRDYIE_Msk (0x1UL << SAI_xIMR_CNRDYIE_Pos)
21590#define SAI_xIMR_CNRDYIE SAI_xIMR_CNRDYIE_Msk
21591#define SAI_xIMR_AFSDETIE_Pos (5U)
21592#define SAI_xIMR_AFSDETIE_Msk (0x1UL << SAI_xIMR_AFSDETIE_Pos)
21593#define SAI_xIMR_AFSDETIE SAI_xIMR_AFSDETIE_Msk
21594#define SAI_xIMR_LFSDETIE_Pos (6U)
21595#define SAI_xIMR_LFSDETIE_Msk (0x1UL << SAI_xIMR_LFSDETIE_Pos)
21596#define SAI_xIMR_LFSDETIE SAI_xIMR_LFSDETIE_Msk
21598/******************** Bit definition for SAI_xSR register *******************/
21599#define SAI_xSR_OVRUDR_Pos (0U)
21600#define SAI_xSR_OVRUDR_Msk (0x1UL << SAI_xSR_OVRUDR_Pos)
21601#define SAI_xSR_OVRUDR SAI_xSR_OVRUDR_Msk
21602#define SAI_xSR_MUTEDET_Pos (1U)
21603#define SAI_xSR_MUTEDET_Msk (0x1UL << SAI_xSR_MUTEDET_Pos)
21604#define SAI_xSR_MUTEDET SAI_xSR_MUTEDET_Msk
21605#define SAI_xSR_WCKCFG_Pos (2U)
21606#define SAI_xSR_WCKCFG_Msk (0x1UL << SAI_xSR_WCKCFG_Pos)
21607#define SAI_xSR_WCKCFG SAI_xSR_WCKCFG_Msk
21608#define SAI_xSR_FREQ_Pos (3U)
21609#define SAI_xSR_FREQ_Msk (0x1UL << SAI_xSR_FREQ_Pos)
21610#define SAI_xSR_FREQ SAI_xSR_FREQ_Msk
21611#define SAI_xSR_CNRDY_Pos (4U)
21612#define SAI_xSR_CNRDY_Msk (0x1UL << SAI_xSR_CNRDY_Pos)
21613#define SAI_xSR_CNRDY SAI_xSR_CNRDY_Msk
21614#define SAI_xSR_AFSDET_Pos (5U)
21615#define SAI_xSR_AFSDET_Msk (0x1UL << SAI_xSR_AFSDET_Pos)
21616#define SAI_xSR_AFSDET SAI_xSR_AFSDET_Msk
21617#define SAI_xSR_LFSDET_Pos (6U)
21618#define SAI_xSR_LFSDET_Msk (0x1UL << SAI_xSR_LFSDET_Pos)
21619#define SAI_xSR_LFSDET SAI_xSR_LFSDET_Msk
21621#define SAI_xSR_FLVL_Pos (16U)
21622#define SAI_xSR_FLVL_Msk (0x7UL << SAI_xSR_FLVL_Pos)
21623#define SAI_xSR_FLVL SAI_xSR_FLVL_Msk
21624#define SAI_xSR_FLVL_0 (0x1UL << SAI_xSR_FLVL_Pos)
21625#define SAI_xSR_FLVL_1 (0x2UL << SAI_xSR_FLVL_Pos)
21626#define SAI_xSR_FLVL_2 (0x4UL << SAI_xSR_FLVL_Pos)
21628/****************** Bit definition for SAI_xCLRFR register ******************/
21629#define SAI_xCLRFR_COVRUDR_Pos (0U)
21630#define SAI_xCLRFR_COVRUDR_Msk (0x1UL << SAI_xCLRFR_COVRUDR_Pos)
21631#define SAI_xCLRFR_COVRUDR SAI_xCLRFR_COVRUDR_Msk
21632#define SAI_xCLRFR_CMUTEDET_Pos (1U)
21633#define SAI_xCLRFR_CMUTEDET_Msk (0x1UL << SAI_xCLRFR_CMUTEDET_Pos)
21634#define SAI_xCLRFR_CMUTEDET SAI_xCLRFR_CMUTEDET_Msk
21635#define SAI_xCLRFR_CWCKCFG_Pos (2U)
21636#define SAI_xCLRFR_CWCKCFG_Msk (0x1UL << SAI_xCLRFR_CWCKCFG_Pos)
21637#define SAI_xCLRFR_CWCKCFG SAI_xCLRFR_CWCKCFG_Msk
21638#define SAI_xCLRFR_CFREQ_Pos (3U)
21639#define SAI_xCLRFR_CFREQ_Msk (0x1UL << SAI_xCLRFR_CFREQ_Pos)
21640#define SAI_xCLRFR_CFREQ SAI_xCLRFR_CFREQ_Msk
21641#define SAI_xCLRFR_CCNRDY_Pos (4U)
21642#define SAI_xCLRFR_CCNRDY_Msk (0x1UL << SAI_xCLRFR_CCNRDY_Pos)
21643#define SAI_xCLRFR_CCNRDY SAI_xCLRFR_CCNRDY_Msk
21644#define SAI_xCLRFR_CAFSDET_Pos (5U)
21645#define SAI_xCLRFR_CAFSDET_Msk (0x1UL << SAI_xCLRFR_CAFSDET_Pos)
21646#define SAI_xCLRFR_CAFSDET SAI_xCLRFR_CAFSDET_Msk
21647#define SAI_xCLRFR_CLFSDET_Pos (6U)
21648#define SAI_xCLRFR_CLFSDET_Msk (0x1UL << SAI_xCLRFR_CLFSDET_Pos)
21649#define SAI_xCLRFR_CLFSDET SAI_xCLRFR_CLFSDET_Msk
21651/****************** Bit definition for SAI_xDR register *********************/
21652#define SAI_xDR_DATA_Pos (0U)
21653#define SAI_xDR_DATA_Msk (0xFFFFFFFFUL << SAI_xDR_DATA_Pos)
21654#define SAI_xDR_DATA SAI_xDR_DATA_Msk
21655
21656/******************* Bit definition for SAI_PDMCR register ******************/
21657#define SAI_PDMCR_PDMEN_Pos (0U)
21658#define SAI_PDMCR_PDMEN_Msk (0x1UL << SAI_PDMCR_PDMEN_Pos)
21659#define SAI_PDMCR_PDMEN SAI_PDMCR_PDMEN_Msk
21661#define SAI_PDMCR_MICNBR_Pos (4U)
21662#define SAI_PDMCR_MICNBR_Msk (0x3UL << SAI_PDMCR_MICNBR_Pos)
21663#define SAI_PDMCR_MICNBR SAI_PDMCR_MICNBR_Msk
21664#define SAI_PDMCR_MICNBR_0 (0x1UL << SAI_PDMCR_MICNBR_Pos)
21665#define SAI_PDMCR_MICNBR_1 (0x2UL << SAI_PDMCR_MICNBR_Pos)
21667#define SAI_PDMCR_CKEN1_Pos (8U)
21668#define SAI_PDMCR_CKEN1_Msk (0x1UL << SAI_PDMCR_CKEN1_Pos)
21669#define SAI_PDMCR_CKEN1 SAI_PDMCR_CKEN1_Msk
21670#define SAI_PDMCR_CKEN2_Pos (9U)
21671#define SAI_PDMCR_CKEN2_Msk (0x1UL << SAI_PDMCR_CKEN2_Pos)
21672#define SAI_PDMCR_CKEN2 SAI_PDMCR_CKEN2_Msk
21673#define SAI_PDMCR_CKEN3_Pos (10U)
21674#define SAI_PDMCR_CKEN3_Msk (0x1UL << SAI_PDMCR_CKEN3_Pos)
21675#define SAI_PDMCR_CKEN3 SAI_PDMCR_CKEN3_Msk
21676#define SAI_PDMCR_CKEN4_Pos (11U)
21677#define SAI_PDMCR_CKEN4_Msk (0x1UL << SAI_PDMCR_CKEN4_Pos)
21678#define SAI_PDMCR_CKEN4 SAI_PDMCR_CKEN4_Msk
21680/****************** Bit definition for SAI_PDMDLY register ******************/
21681#define SAI_PDMDLY_DLYM1L_Pos (0U)
21682#define SAI_PDMDLY_DLYM1L_Msk (0x7UL << SAI_PDMDLY_DLYM1L_Pos)
21683#define SAI_PDMDLY_DLYM1L SAI_PDMDLY_DLYM1L_Msk
21684#define SAI_PDMDLY_DLYM1L_0 (0x1UL << SAI_PDMDLY_DLYM1L_Pos)
21685#define SAI_PDMDLY_DLYM1L_1 (0x2UL << SAI_PDMDLY_DLYM1L_Pos)
21686#define SAI_PDMDLY_DLYM1L_2 (0x4UL << SAI_PDMDLY_DLYM1L_Pos)
21688#define SAI_PDMDLY_DLYM1R_Pos (4U)
21689#define SAI_PDMDLY_DLYM1R_Msk (0x7UL << SAI_PDMDLY_DLYM1R_Pos)
21690#define SAI_PDMDLY_DLYM1R SAI_PDMDLY_DLYM1R_Msk
21691#define SAI_PDMDLY_DLYM1R_0 (0x1UL << SAI_PDMDLY_DLYM1R_Pos)
21692#define SAI_PDMDLY_DLYM1R_1 (0x2UL << SAI_PDMDLY_DLYM1R_Pos)
21693#define SAI_PDMDLY_DLYM1R_2 (0x4UL << SAI_PDMDLY_DLYM1R_Pos)
21695#define SAI_PDMDLY_DLYM2L_Pos (8U)
21696#define SAI_PDMDLY_DLYM2L_Msk (0x7UL << SAI_PDMDLY_DLYM2L_Pos)
21697#define SAI_PDMDLY_DLYM2L SAI_PDMDLY_DLYM2L_Msk
21698#define SAI_PDMDLY_DLYM2L_0 (0x1UL << SAI_PDMDLY_DLYM2L_Pos)
21699#define SAI_PDMDLY_DLYM2L_1 (0x2UL << SAI_PDMDLY_DLYM2L_Pos)
21700#define SAI_PDMDLY_DLYM2L_2 (0x4UL << SAI_PDMDLY_DLYM2L_Pos)
21702#define SAI_PDMDLY_DLYM2R_Pos (12U)
21703#define SAI_PDMDLY_DLYM2R_Msk (0x7UL << SAI_PDMDLY_DLYM2R_Pos)
21704#define SAI_PDMDLY_DLYM2R SAI_PDMDLY_DLYM2R_Msk
21705#define SAI_PDMDLY_DLYM2R_0 (0x1UL << SAI_PDMDLY_DLYM2R_Pos)
21706#define SAI_PDMDLY_DLYM2R_1 (0x2UL << SAI_PDMDLY_DLYM2R_Pos)
21707#define SAI_PDMDLY_DLYM2R_2 (0x4UL << SAI_PDMDLY_DLYM2R_Pos)
21709#define SAI_PDMDLY_DLYM3L_Pos (16U)
21710#define SAI_PDMDLY_DLYM3L_Msk (0x7UL << SAI_PDMDLY_DLYM3L_Pos)
21711#define SAI_PDMDLY_DLYM3L SAI_PDMDLY_DLYM3L_Msk
21712#define SAI_PDMDLY_DLYM3L_0 (0x1UL << SAI_PDMDLY_DLYM3L_Pos)
21713#define SAI_PDMDLY_DLYM3L_1 (0x2UL << SAI_PDMDLY_DLYM3L_Pos)
21714#define SAI_PDMDLY_DLYM3L_2 (0x4UL << SAI_PDMDLY_DLYM3L_Pos)
21716#define SAI_PDMDLY_DLYM3R_Pos (20U)
21717#define SAI_PDMDLY_DLYM3R_Msk (0x7UL << SAI_PDMDLY_DLYM3R_Pos)
21718#define SAI_PDMDLY_DLYM3R SAI_PDMDLY_DLYM3R_Msk
21719#define SAI_PDMDLY_DLYM3R_0 (0x1UL << SAI_PDMDLY_DLYM3R_Pos)
21720#define SAI_PDMDLY_DLYM3R_1 (0x2UL << SAI_PDMDLY_DLYM3R_Pos)
21721#define SAI_PDMDLY_DLYM3R_2 (0x4UL << SAI_PDMDLY_DLYM3R_Pos)
21723#define SAI_PDMDLY_DLYM4L_Pos (24U)
21724#define SAI_PDMDLY_DLYM4L_Msk (0x7UL << SAI_PDMDLY_DLYM4L_Pos)
21725#define SAI_PDMDLY_DLYM4L SAI_PDMDLY_DLYM4L_Msk
21726#define SAI_PDMDLY_DLYM4L_0 (0x1UL << SAI_PDMDLY_DLYM4L_Pos)
21727#define SAI_PDMDLY_DLYM4L_1 (0x2UL << SAI_PDMDLY_DLYM4L_Pos)
21728#define SAI_PDMDLY_DLYM4L_2 (0x4UL << SAI_PDMDLY_DLYM4L_Pos)
21730#define SAI_PDMDLY_DLYM4R_Pos (28U)
21731#define SAI_PDMDLY_DLYM4R_Msk (0x7UL << SAI_PDMDLY_DLYM4R_Pos)
21732#define SAI_PDMDLY_DLYM4R SAI_PDMDLY_DLYM4R_Msk
21733#define SAI_PDMDLY_DLYM4R_0 (0x1UL << SAI_PDMDLY_DLYM4R_Pos)
21734#define SAI_PDMDLY_DLYM4R_1 (0x2UL << SAI_PDMDLY_DLYM4R_Pos)
21735#define SAI_PDMDLY_DLYM4R_2 (0x4UL << SAI_PDMDLY_DLYM4R_Pos)
21737/******************************************************************************/
21738/* */
21739/* SDMMC Interface */
21740/* */
21741/******************************************************************************/
21742/****************** Bit definition for SDMMC_POWER register ******************/
21743#define SDMMC_POWER_PWRCTRL_Pos (0U)
21744#define SDMMC_POWER_PWRCTRL_Msk (0x3UL << SDMMC_POWER_PWRCTRL_Pos)
21745#define SDMMC_POWER_PWRCTRL SDMMC_POWER_PWRCTRL_Msk
21746#define SDMMC_POWER_PWRCTRL_0 (0x1UL << SDMMC_POWER_PWRCTRL_Pos)
21747#define SDMMC_POWER_PWRCTRL_1 (0x2UL << SDMMC_POWER_PWRCTRL_Pos)
21748#define SDMMC_POWER_VSWITCH_Pos (2U)
21749#define SDMMC_POWER_VSWITCH_Msk (0x1UL << SDMMC_POWER_VSWITCH_Pos)
21750#define SDMMC_POWER_VSWITCH SDMMC_POWER_VSWITCH_Msk
21751#define SDMMC_POWER_VSWITCHEN_Pos (3U)
21752#define SDMMC_POWER_VSWITCHEN_Msk (0x1UL << SDMMC_POWER_VSWITCHEN_Pos)
21753#define SDMMC_POWER_VSWITCHEN SDMMC_POWER_VSWITCHEN_Msk
21754#define SDMMC_POWER_DIRPOL_Pos (4U)
21755#define SDMMC_POWER_DIRPOL_Msk (0x1UL << SDMMC_POWER_DIRPOL_Pos)
21756#define SDMMC_POWER_DIRPOL SDMMC_POWER_DIRPOL_Msk
21758/****************** Bit definition for SDMMC_CLKCR register ******************/
21759#define SDMMC_CLKCR_CLKDIV_Pos (0U)
21760#define SDMMC_CLKCR_CLKDIV_Msk (0x3FFUL << SDMMC_CLKCR_CLKDIV_Pos)
21761#define SDMMC_CLKCR_CLKDIV SDMMC_CLKCR_CLKDIV_Msk
21762#define SDMMC_CLKCR_PWRSAV_Pos (12U)
21763#define SDMMC_CLKCR_PWRSAV_Msk (0x1UL << SDMMC_CLKCR_PWRSAV_Pos)
21764#define SDMMC_CLKCR_PWRSAV SDMMC_CLKCR_PWRSAV_Msk
21766#define SDMMC_CLKCR_WIDBUS_Pos (14U)
21767#define SDMMC_CLKCR_WIDBUS_Msk (0x3UL << SDMMC_CLKCR_WIDBUS_Pos)
21768#define SDMMC_CLKCR_WIDBUS SDMMC_CLKCR_WIDBUS_Msk
21769#define SDMMC_CLKCR_WIDBUS_0 (0x1UL << SDMMC_CLKCR_WIDBUS_Pos)
21770#define SDMMC_CLKCR_WIDBUS_1 (0x2UL << SDMMC_CLKCR_WIDBUS_Pos)
21772#define SDMMC_CLKCR_NEGEDGE_Pos (16U)
21773#define SDMMC_CLKCR_NEGEDGE_Msk (0x1UL << SDMMC_CLKCR_NEGEDGE_Pos)
21774#define SDMMC_CLKCR_NEGEDGE SDMMC_CLKCR_NEGEDGE_Msk
21775#define SDMMC_CLKCR_HWFC_EN_Pos (17U)
21776#define SDMMC_CLKCR_HWFC_EN_Msk (0x1UL << SDMMC_CLKCR_HWFC_EN_Pos)
21777#define SDMMC_CLKCR_HWFC_EN SDMMC_CLKCR_HWFC_EN_Msk
21778#define SDMMC_CLKCR_DDR_Pos (18U)
21779#define SDMMC_CLKCR_DDR_Msk (0x1UL << SDMMC_CLKCR_DDR_Pos)
21780#define SDMMC_CLKCR_DDR SDMMC_CLKCR_DDR_Msk
21781#define SDMMC_CLKCR_BUSSPEED_Pos (19U)
21782#define SDMMC_CLKCR_BUSSPEED_Msk (0x1UL << SDMMC_CLKCR_BUSSPEED_Pos)
21783#define SDMMC_CLKCR_BUSSPEED SDMMC_CLKCR_BUSSPEED_Msk
21784#define SDMMC_CLKCR_SELCLKRX_Pos (20U)
21785#define SDMMC_CLKCR_SELCLKRX_Msk (0x3UL << SDMMC_CLKCR_SELCLKRX_Pos)
21786#define SDMMC_CLKCR_SELCLKRX SDMMC_CLKCR_SELCLKRX_Msk
21787#define SDMMC_CLKCR_SELCLKRX_0 (0x1UL << SDMMC_CLKCR_SELCLKRX_Pos)
21788#define SDMMC_CLKCR_SELCLKRX_1 (0x2UL << SDMMC_CLKCR_SELCLKRX_Pos)
21790/******************* Bit definition for SDMMC_ARG register *******************/
21791#define SDMMC_ARG_CMDARG_Pos (0U)
21792#define SDMMC_ARG_CMDARG_Msk (0xFFFFFFFFUL << SDMMC_ARG_CMDARG_Pos)
21793#define SDMMC_ARG_CMDARG SDMMC_ARG_CMDARG_Msk
21795/******************* Bit definition for SDMMC_CMD register *******************/
21796#define SDMMC_CMD_CMDINDEX_Pos (0U)
21797#define SDMMC_CMD_CMDINDEX_Msk (0x3FUL << SDMMC_CMD_CMDINDEX_Pos)
21798#define SDMMC_CMD_CMDINDEX SDMMC_CMD_CMDINDEX_Msk
21799#define SDMMC_CMD_CMDTRANS_Pos (6U)
21800#define SDMMC_CMD_CMDTRANS_Msk (0x1UL << SDMMC_CMD_CMDTRANS_Pos)
21801#define SDMMC_CMD_CMDTRANS SDMMC_CMD_CMDTRANS_Msk
21802#define SDMMC_CMD_CMDSTOP_Pos (7U)
21803#define SDMMC_CMD_CMDSTOP_Msk (0x1UL << SDMMC_CMD_CMDSTOP_Pos)
21804#define SDMMC_CMD_CMDSTOP SDMMC_CMD_CMDSTOP_Msk
21806#define SDMMC_CMD_WAITRESP_Pos (8U)
21807#define SDMMC_CMD_WAITRESP_Msk (0x3UL << SDMMC_CMD_WAITRESP_Pos)
21808#define SDMMC_CMD_WAITRESP SDMMC_CMD_WAITRESP_Msk
21809#define SDMMC_CMD_WAITRESP_0 (0x1UL << SDMMC_CMD_WAITRESP_Pos)
21810#define SDMMC_CMD_WAITRESP_1 (0x2UL << SDMMC_CMD_WAITRESP_Pos)
21812#define SDMMC_CMD_WAITINT_Pos (10U)
21813#define SDMMC_CMD_WAITINT_Msk (0x1UL << SDMMC_CMD_WAITINT_Pos)
21814#define SDMMC_CMD_WAITINT SDMMC_CMD_WAITINT_Msk
21815#define SDMMC_CMD_WAITPEND_Pos (11U)
21816#define SDMMC_CMD_WAITPEND_Msk (0x1UL << SDMMC_CMD_WAITPEND_Pos)
21817#define SDMMC_CMD_WAITPEND SDMMC_CMD_WAITPEND_Msk
21818#define SDMMC_CMD_CPSMEN_Pos (12U)
21819#define SDMMC_CMD_CPSMEN_Msk (0x1UL << SDMMC_CMD_CPSMEN_Pos)
21820#define SDMMC_CMD_CPSMEN SDMMC_CMD_CPSMEN_Msk
21821#define SDMMC_CMD_DTHOLD_Pos (13U)
21822#define SDMMC_CMD_DTHOLD_Msk (0x1UL << SDMMC_CMD_DTHOLD_Pos)
21823#define SDMMC_CMD_DTHOLD SDMMC_CMD_DTHOLD_Msk
21824#define SDMMC_CMD_BOOTMODE_Pos (14U)
21825#define SDMMC_CMD_BOOTMODE_Msk (0x1UL << SDMMC_CMD_BOOTMODE_Pos)
21826#define SDMMC_CMD_BOOTMODE SDMMC_CMD_BOOTMODE_Msk
21827#define SDMMC_CMD_BOOTEN_Pos (15U)
21828#define SDMMC_CMD_BOOTEN_Msk (0x1UL << SDMMC_CMD_BOOTEN_Pos)
21829#define SDMMC_CMD_BOOTEN SDMMC_CMD_BOOTEN_Msk
21830#define SDMMC_CMD_CMDSUSPEND_Pos (16U)
21831#define SDMMC_CMD_CMDSUSPEND_Msk (0x1UL << SDMMC_CMD_CMDSUSPEND_Pos)
21832#define SDMMC_CMD_CMDSUSPEND SDMMC_CMD_CMDSUSPEND_Msk
21834/***************** Bit definition for SDMMC_RESPCMD register *****************/
21835#define SDMMC_RESPCMD_RESPCMD_Pos (0U)
21836#define SDMMC_RESPCMD_RESPCMD_Msk (0x3FUL << SDMMC_RESPCMD_RESPCMD_Pos)
21837#define SDMMC_RESPCMD_RESPCMD SDMMC_RESPCMD_RESPCMD_Msk
21839/****************** Bit definition for SDMMC_RESP0 register ******************/
21840#define SDMMC_RESP0_CARDSTATUS0_Pos (0U)
21841#define SDMMC_RESP0_CARDSTATUS0_Msk (0xFFFFFFFFUL << SDMMC_RESP0_CARDSTATUS0_Pos)
21842#define SDMMC_RESP0_CARDSTATUS0 SDMMC_RESP0_CARDSTATUS0_Msk
21844/****************** Bit definition for SDMMC_RESP1 register ******************/
21845#define SDMMC_RESP1_CARDSTATUS1_Pos (0U)
21846#define SDMMC_RESP1_CARDSTATUS1_Msk (0xFFFFFFFFUL << SDMMC_RESP1_CARDSTATUS1_Pos)
21847#define SDMMC_RESP1_CARDSTATUS1 SDMMC_RESP1_CARDSTATUS1_Msk
21849/****************** Bit definition for SDMMC_RESP2 register ******************/
21850#define SDMMC_RESP2_CARDSTATUS2_Pos (0U)
21851#define SDMMC_RESP2_CARDSTATUS2_Msk (0xFFFFFFFFUL << SDMMC_RESP2_CARDSTATUS2_Pos)
21852#define SDMMC_RESP2_CARDSTATUS2 SDMMC_RESP2_CARDSTATUS2_Msk
21854/****************** Bit definition for SDMMC_RESP3 register ******************/
21855#define SDMMC_RESP3_CARDSTATUS3_Pos (0U)
21856#define SDMMC_RESP3_CARDSTATUS3_Msk (0xFFFFFFFFUL << SDMMC_RESP3_CARDSTATUS3_Pos)
21857#define SDMMC_RESP3_CARDSTATUS3 SDMMC_RESP3_CARDSTATUS3_Msk
21859/****************** Bit definition for SDMMC_RESP4 register ******************/
21860#define SDMMC_RESP4_CARDSTATUS4_Pos (0U)
21861#define SDMMC_RESP4_CARDSTATUS4_Msk (0xFFFFFFFFUL << SDMMC_RESP4_CARDSTATUS4_Pos)
21862#define SDMMC_RESP4_CARDSTATUS4 SDMMC_RESP4_CARDSTATUS4_Msk
21864/****************** Bit definition for SDMMC_DTIMER register *****************/
21865#define SDMMC_DTIMER_DATATIME_Pos (0U)
21866#define SDMMC_DTIMER_DATATIME_Msk (0xFFFFFFFFUL << SDMMC_DTIMER_DATATIME_Pos)
21867#define SDMMC_DTIMER_DATATIME SDMMC_DTIMER_DATATIME_Msk
21869/****************** Bit definition for SDMMC_DLEN register *******************/
21870#define SDMMC_DLEN_DATALENGTH_Pos (0U)
21871#define SDMMC_DLEN_DATALENGTH_Msk (0x1FFFFFFUL << SDMMC_DLEN_DATALENGTH_Pos)
21872#define SDMMC_DLEN_DATALENGTH SDMMC_DLEN_DATALENGTH_Msk
21874/****************** Bit definition for SDMMC_DCTRL register ******************/
21875#define SDMMC_DCTRL_DTEN_Pos (0U)
21876#define SDMMC_DCTRL_DTEN_Msk (0x1UL << SDMMC_DCTRL_DTEN_Pos)
21877#define SDMMC_DCTRL_DTEN SDMMC_DCTRL_DTEN_Msk
21878#define SDMMC_DCTRL_DTDIR_Pos (1U)
21879#define SDMMC_DCTRL_DTDIR_Msk (0x1UL << SDMMC_DCTRL_DTDIR_Pos)
21880#define SDMMC_DCTRL_DTDIR SDMMC_DCTRL_DTDIR_Msk
21881#define SDMMC_DCTRL_DTMODE_Pos (2U)
21882#define SDMMC_DCTRL_DTMODE_Msk (0x3UL << SDMMC_DCTRL_DTMODE_Pos)
21883#define SDMMC_DCTRL_DTMODE SDMMC_DCTRL_DTMODE_Msk
21884#define SDMMC_DCTRL_DTMODE_0 (0x1UL << SDMMC_DCTRL_DTMODE_Pos)
21885#define SDMMC_DCTRL_DTMODE_1 (0x2UL << SDMMC_DCTRL_DTMODE_Pos)
21887#define SDMMC_DCTRL_DBLOCKSIZE_Pos (4U)
21888#define SDMMC_DCTRL_DBLOCKSIZE_Msk (0xFUL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
21889#define SDMMC_DCTRL_DBLOCKSIZE SDMMC_DCTRL_DBLOCKSIZE_Msk
21890#define SDMMC_DCTRL_DBLOCKSIZE_0 (0x1UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
21891#define SDMMC_DCTRL_DBLOCKSIZE_1 (0x2UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
21892#define SDMMC_DCTRL_DBLOCKSIZE_2 (0x4UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
21893#define SDMMC_DCTRL_DBLOCKSIZE_3 (0x8UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
21895#define SDMMC_DCTRL_RWSTART_Pos (8U)
21896#define SDMMC_DCTRL_RWSTART_Msk (0x1UL << SDMMC_DCTRL_RWSTART_Pos)
21897#define SDMMC_DCTRL_RWSTART SDMMC_DCTRL_RWSTART_Msk
21898#define SDMMC_DCTRL_RWSTOP_Pos (9U)
21899#define SDMMC_DCTRL_RWSTOP_Msk (0x1UL << SDMMC_DCTRL_RWSTOP_Pos)
21900#define SDMMC_DCTRL_RWSTOP SDMMC_DCTRL_RWSTOP_Msk
21901#define SDMMC_DCTRL_RWMOD_Pos (10U)
21902#define SDMMC_DCTRL_RWMOD_Msk (0x1UL << SDMMC_DCTRL_RWMOD_Pos)
21903#define SDMMC_DCTRL_RWMOD SDMMC_DCTRL_RWMOD_Msk
21904#define SDMMC_DCTRL_SDIOEN_Pos (11U)
21905#define SDMMC_DCTRL_SDIOEN_Msk (0x1UL << SDMMC_DCTRL_SDIOEN_Pos)
21906#define SDMMC_DCTRL_SDIOEN SDMMC_DCTRL_SDIOEN_Msk
21907#define SDMMC_DCTRL_BOOTACKEN_Pos (12U)
21908#define SDMMC_DCTRL_BOOTACKEN_Msk (0x1UL << SDMMC_DCTRL_BOOTACKEN_Pos)
21909#define SDMMC_DCTRL_BOOTACKEN SDMMC_DCTRL_BOOTACKEN_Msk
21910#define SDMMC_DCTRL_FIFORST_Pos (13U)
21911#define SDMMC_DCTRL_FIFORST_Msk (0x1UL << SDMMC_DCTRL_FIFORST_Pos)
21912#define SDMMC_DCTRL_FIFORST SDMMC_DCTRL_FIFORST_Msk
21914/****************** Bit definition for SDMMC_DCOUNT register *****************/
21915#define SDMMC_DCOUNT_DATACOUNT_Pos (0U)
21916#define SDMMC_DCOUNT_DATACOUNT_Msk (0x1FFFFFFUL << SDMMC_DCOUNT_DATACOUNT_Pos)
21917#define SDMMC_DCOUNT_DATACOUNT SDMMC_DCOUNT_DATACOUNT_Msk
21919/****************** Bit definition for SDMMC_STA register ********************/
21920#define SDMMC_STA_CCRCFAIL_Pos (0U)
21921#define SDMMC_STA_CCRCFAIL_Msk (0x1UL << SDMMC_STA_CCRCFAIL_Pos)
21922#define SDMMC_STA_CCRCFAIL SDMMC_STA_CCRCFAIL_Msk
21923#define SDMMC_STA_DCRCFAIL_Pos (1U)
21924#define SDMMC_STA_DCRCFAIL_Msk (0x1UL << SDMMC_STA_DCRCFAIL_Pos)
21925#define SDMMC_STA_DCRCFAIL SDMMC_STA_DCRCFAIL_Msk
21926#define SDMMC_STA_CTIMEOUT_Pos (2U)
21927#define SDMMC_STA_CTIMEOUT_Msk (0x1UL << SDMMC_STA_CTIMEOUT_Pos)
21928#define SDMMC_STA_CTIMEOUT SDMMC_STA_CTIMEOUT_Msk
21929#define SDMMC_STA_DTIMEOUT_Pos (3U)
21930#define SDMMC_STA_DTIMEOUT_Msk (0x1UL << SDMMC_STA_DTIMEOUT_Pos)
21931#define SDMMC_STA_DTIMEOUT SDMMC_STA_DTIMEOUT_Msk
21932#define SDMMC_STA_TXUNDERR_Pos (4U)
21933#define SDMMC_STA_TXUNDERR_Msk (0x1UL << SDMMC_STA_TXUNDERR_Pos)
21934#define SDMMC_STA_TXUNDERR SDMMC_STA_TXUNDERR_Msk
21935#define SDMMC_STA_RXOVERR_Pos (5U)
21936#define SDMMC_STA_RXOVERR_Msk (0x1UL << SDMMC_STA_RXOVERR_Pos)
21937#define SDMMC_STA_RXOVERR SDMMC_STA_RXOVERR_Msk
21938#define SDMMC_STA_CMDREND_Pos (6U)
21939#define SDMMC_STA_CMDREND_Msk (0x1UL << SDMMC_STA_CMDREND_Pos)
21940#define SDMMC_STA_CMDREND SDMMC_STA_CMDREND_Msk
21941#define SDMMC_STA_CMDSENT_Pos (7U)
21942#define SDMMC_STA_CMDSENT_Msk (0x1UL << SDMMC_STA_CMDSENT_Pos)
21943#define SDMMC_STA_CMDSENT SDMMC_STA_CMDSENT_Msk
21944#define SDMMC_STA_DATAEND_Pos (8U)
21945#define SDMMC_STA_DATAEND_Msk (0x1UL << SDMMC_STA_DATAEND_Pos)
21946#define SDMMC_STA_DATAEND SDMMC_STA_DATAEND_Msk
21947#define SDMMC_STA_DHOLD_Pos (9U)
21948#define SDMMC_STA_DHOLD_Msk (0x1UL << SDMMC_STA_DHOLD_Pos)
21949#define SDMMC_STA_DHOLD SDMMC_STA_DHOLD_Msk
21950#define SDMMC_STA_DBCKEND_Pos (10U)
21951#define SDMMC_STA_DBCKEND_Msk (0x1UL << SDMMC_STA_DBCKEND_Pos)
21952#define SDMMC_STA_DBCKEND SDMMC_STA_DBCKEND_Msk
21953#define SDMMC_STA_DABORT_Pos (11U)
21954#define SDMMC_STA_DABORT_Msk (0x1UL << SDMMC_STA_DABORT_Pos)
21955#define SDMMC_STA_DABORT SDMMC_STA_DABORT_Msk
21956#define SDMMC_STA_DPSMACT_Pos (12U)
21957#define SDMMC_STA_DPSMACT_Msk (0x1UL << SDMMC_STA_DPSMACT_Pos)
21958#define SDMMC_STA_DPSMACT SDMMC_STA_DPSMACT_Msk
21959#define SDMMC_STA_CPSMACT_Pos (13U)
21960#define SDMMC_STA_CPSMACT_Msk (0x1UL << SDMMC_STA_CPSMACT_Pos)
21961#define SDMMC_STA_CPSMACT SDMMC_STA_CPSMACT_Msk
21962#define SDMMC_STA_TXFIFOHE_Pos (14U)
21963#define SDMMC_STA_TXFIFOHE_Msk (0x1UL << SDMMC_STA_TXFIFOHE_Pos)
21964#define SDMMC_STA_TXFIFOHE SDMMC_STA_TXFIFOHE_Msk
21965#define SDMMC_STA_RXFIFOHF_Pos (15U)
21966#define SDMMC_STA_RXFIFOHF_Msk (0x1UL << SDMMC_STA_RXFIFOHF_Pos)
21967#define SDMMC_STA_RXFIFOHF SDMMC_STA_RXFIFOHF_Msk
21968#define SDMMC_STA_TXFIFOF_Pos (16U)
21969#define SDMMC_STA_TXFIFOF_Msk (0x1UL << SDMMC_STA_TXFIFOF_Pos)
21970#define SDMMC_STA_TXFIFOF SDMMC_STA_TXFIFOF_Msk
21971#define SDMMC_STA_RXFIFOF_Pos (17U)
21972#define SDMMC_STA_RXFIFOF_Msk (0x1UL << SDMMC_STA_RXFIFOF_Pos)
21973#define SDMMC_STA_RXFIFOF SDMMC_STA_RXFIFOF_Msk
21974#define SDMMC_STA_TXFIFOE_Pos (18U)
21975#define SDMMC_STA_TXFIFOE_Msk (0x1UL << SDMMC_STA_TXFIFOE_Pos)
21976#define SDMMC_STA_TXFIFOE SDMMC_STA_TXFIFOE_Msk
21977#define SDMMC_STA_RXFIFOE_Pos (19U)
21978#define SDMMC_STA_RXFIFOE_Msk (0x1UL << SDMMC_STA_RXFIFOE_Pos)
21979#define SDMMC_STA_RXFIFOE SDMMC_STA_RXFIFOE_Msk
21980#define SDMMC_STA_BUSYD0_Pos (20U)
21981#define SDMMC_STA_BUSYD0_Msk (0x1UL << SDMMC_STA_BUSYD0_Pos)
21982#define SDMMC_STA_BUSYD0 SDMMC_STA_BUSYD0_Msk
21983#define SDMMC_STA_BUSYD0END_Pos (21U)
21984#define SDMMC_STA_BUSYD0END_Msk (0x1UL << SDMMC_STA_BUSYD0END_Pos)
21985#define SDMMC_STA_BUSYD0END SDMMC_STA_BUSYD0END_Msk
21986#define SDMMC_STA_SDIOIT_Pos (22U)
21987#define SDMMC_STA_SDIOIT_Msk (0x1UL << SDMMC_STA_SDIOIT_Pos)
21988#define SDMMC_STA_SDIOIT SDMMC_STA_SDIOIT_Msk
21989#define SDMMC_STA_ACKFAIL_Pos (23U)
21990#define SDMMC_STA_ACKFAIL_Msk (0x1UL << SDMMC_STA_ACKFAIL_Pos)
21991#define SDMMC_STA_ACKFAIL SDMMC_STA_ACKFAIL_Msk
21992#define SDMMC_STA_ACKTIMEOUT_Pos (24U)
21993#define SDMMC_STA_ACKTIMEOUT_Msk (0x1UL << SDMMC_STA_ACKTIMEOUT_Pos)
21994#define SDMMC_STA_ACKTIMEOUT SDMMC_STA_ACKTIMEOUT_Msk
21995#define SDMMC_STA_VSWEND_Pos (25U)
21996#define SDMMC_STA_VSWEND_Msk (0x1UL << SDMMC_STA_VSWEND_Pos)
21997#define SDMMC_STA_VSWEND SDMMC_STA_VSWEND_Msk
21998#define SDMMC_STA_CKSTOP_Pos (26U)
21999#define SDMMC_STA_CKSTOP_Msk (0x1UL << SDMMC_STA_CKSTOP_Pos)
22000#define SDMMC_STA_CKSTOP SDMMC_STA_CKSTOP_Msk
22001#define SDMMC_STA_IDMATE_Pos (27U)
22002#define SDMMC_STA_IDMATE_Msk (0x1UL << SDMMC_STA_IDMATE_Pos)
22003#define SDMMC_STA_IDMATE SDMMC_STA_IDMATE_Msk
22004#define SDMMC_STA_IDMABTC_Pos (28U)
22005#define SDMMC_STA_IDMABTC_Msk (0x1UL << SDMMC_STA_IDMABTC_Pos)
22006#define SDMMC_STA_IDMABTC SDMMC_STA_IDMABTC_Msk
22008/******************* Bit definition for SDMMC_ICR register *******************/
22009#define SDMMC_ICR_CCRCFAILC_Pos (0U)
22010#define SDMMC_ICR_CCRCFAILC_Msk (0x1UL << SDMMC_ICR_CCRCFAILC_Pos)
22011#define SDMMC_ICR_CCRCFAILC SDMMC_ICR_CCRCFAILC_Msk
22012#define SDMMC_ICR_DCRCFAILC_Pos (1U)
22013#define SDMMC_ICR_DCRCFAILC_Msk (0x1UL << SDMMC_ICR_DCRCFAILC_Pos)
22014#define SDMMC_ICR_DCRCFAILC SDMMC_ICR_DCRCFAILC_Msk
22015#define SDMMC_ICR_CTIMEOUTC_Pos (2U)
22016#define SDMMC_ICR_CTIMEOUTC_Msk (0x1UL << SDMMC_ICR_CTIMEOUTC_Pos)
22017#define SDMMC_ICR_CTIMEOUTC SDMMC_ICR_CTIMEOUTC_Msk
22018#define SDMMC_ICR_DTIMEOUTC_Pos (3U)
22019#define SDMMC_ICR_DTIMEOUTC_Msk (0x1UL << SDMMC_ICR_DTIMEOUTC_Pos)
22020#define SDMMC_ICR_DTIMEOUTC SDMMC_ICR_DTIMEOUTC_Msk
22021#define SDMMC_ICR_TXUNDERRC_Pos (4U)
22022#define SDMMC_ICR_TXUNDERRC_Msk (0x1UL << SDMMC_ICR_TXUNDERRC_Pos)
22023#define SDMMC_ICR_TXUNDERRC SDMMC_ICR_TXUNDERRC_Msk
22024#define SDMMC_ICR_RXOVERRC_Pos (5U)
22025#define SDMMC_ICR_RXOVERRC_Msk (0x1UL << SDMMC_ICR_RXOVERRC_Pos)
22026#define SDMMC_ICR_RXOVERRC SDMMC_ICR_RXOVERRC_Msk
22027#define SDMMC_ICR_CMDRENDC_Pos (6U)
22028#define SDMMC_ICR_CMDRENDC_Msk (0x1UL << SDMMC_ICR_CMDRENDC_Pos)
22029#define SDMMC_ICR_CMDRENDC SDMMC_ICR_CMDRENDC_Msk
22030#define SDMMC_ICR_CMDSENTC_Pos (7U)
22031#define SDMMC_ICR_CMDSENTC_Msk (0x1UL << SDMMC_ICR_CMDSENTC_Pos)
22032#define SDMMC_ICR_CMDSENTC SDMMC_ICR_CMDSENTC_Msk
22033#define SDMMC_ICR_DATAENDC_Pos (8U)
22034#define SDMMC_ICR_DATAENDC_Msk (0x1UL << SDMMC_ICR_DATAENDC_Pos)
22035#define SDMMC_ICR_DATAENDC SDMMC_ICR_DATAENDC_Msk
22036#define SDMMC_ICR_DHOLDC_Pos (9U)
22037#define SDMMC_ICR_DHOLDC_Msk (0x1UL << SDMMC_ICR_DHOLDC_Pos)
22038#define SDMMC_ICR_DHOLDC SDMMC_ICR_DHOLDC_Msk
22039#define SDMMC_ICR_DBCKENDC_Pos (10U)
22040#define SDMMC_ICR_DBCKENDC_Msk (0x1UL << SDMMC_ICR_DBCKENDC_Pos)
22041#define SDMMC_ICR_DBCKENDC SDMMC_ICR_DBCKENDC_Msk
22042#define SDMMC_ICR_DABORTC_Pos (11U)
22043#define SDMMC_ICR_DABORTC_Msk (0x1UL << SDMMC_ICR_DABORTC_Pos)
22044#define SDMMC_ICR_DABORTC SDMMC_ICR_DABORTC_Msk
22045#define SDMMC_ICR_BUSYD0ENDC_Pos (21U)
22046#define SDMMC_ICR_BUSYD0ENDC_Msk (0x1UL << SDMMC_ICR_BUSYD0ENDC_Pos)
22047#define SDMMC_ICR_BUSYD0ENDC SDMMC_ICR_BUSYD0ENDC_Msk
22048#define SDMMC_ICR_SDIOITC_Pos (22U)
22049#define SDMMC_ICR_SDIOITC_Msk (0x1UL << SDMMC_ICR_SDIOITC_Pos)
22050#define SDMMC_ICR_SDIOITC SDMMC_ICR_SDIOITC_Msk
22051#define SDMMC_ICR_ACKFAILC_Pos (23U)
22052#define SDMMC_ICR_ACKFAILC_Msk (0x1UL << SDMMC_ICR_ACKFAILC_Pos)
22053#define SDMMC_ICR_ACKFAILC SDMMC_ICR_ACKFAILC_Msk
22054#define SDMMC_ICR_ACKTIMEOUTC_Pos (24U)
22055#define SDMMC_ICR_ACKTIMEOUTC_Msk (0x1UL << SDMMC_ICR_ACKTIMEOUTC_Pos)
22056#define SDMMC_ICR_ACKTIMEOUTC SDMMC_ICR_ACKTIMEOUTC_Msk
22057#define SDMMC_ICR_VSWENDC_Pos (25U)
22058#define SDMMC_ICR_VSWENDC_Msk (0x1UL << SDMMC_ICR_VSWENDC_Pos)
22059#define SDMMC_ICR_VSWENDC SDMMC_ICR_VSWENDC_Msk
22060#define SDMMC_ICR_CKSTOPC_Pos (26U)
22061#define SDMMC_ICR_CKSTOPC_Msk (0x1UL << SDMMC_ICR_CKSTOPC_Pos)
22062#define SDMMC_ICR_CKSTOPC SDMMC_ICR_CKSTOPC_Msk
22063#define SDMMC_ICR_IDMATEC_Pos (27U)
22064#define SDMMC_ICR_IDMATEC_Msk (0x1UL << SDMMC_ICR_IDMATEC_Pos)
22065#define SDMMC_ICR_IDMATEC SDMMC_ICR_IDMATEC_Msk
22066#define SDMMC_ICR_IDMABTCC_Pos (28U)
22067#define SDMMC_ICR_IDMABTCC_Msk (0x1UL << SDMMC_ICR_IDMABTCC_Pos)
22068#define SDMMC_ICR_IDMABTCC SDMMC_ICR_IDMABTCC_Msk
22070/****************** Bit definition for SDMMC_MASK register *******************/
22071#define SDMMC_MASK_CCRCFAILIE_Pos (0U)
22072#define SDMMC_MASK_CCRCFAILIE_Msk (0x1UL << SDMMC_MASK_CCRCFAILIE_Pos)
22073#define SDMMC_MASK_CCRCFAILIE SDMMC_MASK_CCRCFAILIE_Msk
22074#define SDMMC_MASK_DCRCFAILIE_Pos (1U)
22075#define SDMMC_MASK_DCRCFAILIE_Msk (0x1UL << SDMMC_MASK_DCRCFAILIE_Pos)
22076#define SDMMC_MASK_DCRCFAILIE SDMMC_MASK_DCRCFAILIE_Msk
22077#define SDMMC_MASK_CTIMEOUTIE_Pos (2U)
22078#define SDMMC_MASK_CTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_CTIMEOUTIE_Pos)
22079#define SDMMC_MASK_CTIMEOUTIE SDMMC_MASK_CTIMEOUTIE_Msk
22080#define SDMMC_MASK_DTIMEOUTIE_Pos (3U)
22081#define SDMMC_MASK_DTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_DTIMEOUTIE_Pos)
22082#define SDMMC_MASK_DTIMEOUTIE SDMMC_MASK_DTIMEOUTIE_Msk
22083#define SDMMC_MASK_TXUNDERRIE_Pos (4U)
22084#define SDMMC_MASK_TXUNDERRIE_Msk (0x1UL << SDMMC_MASK_TXUNDERRIE_Pos)
22085#define SDMMC_MASK_TXUNDERRIE SDMMC_MASK_TXUNDERRIE_Msk
22086#define SDMMC_MASK_RXOVERRIE_Pos (5U)
22087#define SDMMC_MASK_RXOVERRIE_Msk (0x1UL << SDMMC_MASK_RXOVERRIE_Pos)
22088#define SDMMC_MASK_RXOVERRIE SDMMC_MASK_RXOVERRIE_Msk
22089#define SDMMC_MASK_CMDRENDIE_Pos (6U)
22090#define SDMMC_MASK_CMDRENDIE_Msk (0x1UL << SDMMC_MASK_CMDRENDIE_Pos)
22091#define SDMMC_MASK_CMDRENDIE SDMMC_MASK_CMDRENDIE_Msk
22092#define SDMMC_MASK_CMDSENTIE_Pos (7U)
22093#define SDMMC_MASK_CMDSENTIE_Msk (0x1UL << SDMMC_MASK_CMDSENTIE_Pos)
22094#define SDMMC_MASK_CMDSENTIE SDMMC_MASK_CMDSENTIE_Msk
22095#define SDMMC_MASK_DATAENDIE_Pos (8U)
22096#define SDMMC_MASK_DATAENDIE_Msk (0x1UL << SDMMC_MASK_DATAENDIE_Pos)
22097#define SDMMC_MASK_DATAENDIE SDMMC_MASK_DATAENDIE_Msk
22098#define SDMMC_MASK_DHOLDIE_Pos (9U)
22099#define SDMMC_MASK_DHOLDIE_Msk (0x1UL << SDMMC_MASK_DHOLDIE_Pos)
22100#define SDMMC_MASK_DHOLDIE SDMMC_MASK_DHOLDIE_Msk
22101#define SDMMC_MASK_DBCKENDIE_Pos (10U)
22102#define SDMMC_MASK_DBCKENDIE_Msk (0x1UL << SDMMC_MASK_DBCKENDIE_Pos)
22103#define SDMMC_MASK_DBCKENDIE SDMMC_MASK_DBCKENDIE_Msk
22104#define SDMMC_MASK_DABORTIE_Pos (11U)
22105#define SDMMC_MASK_DABORTIE_Msk (0x1UL << SDMMC_MASK_DABORTIE_Pos)
22106#define SDMMC_MASK_DABORTIE SDMMC_MASK_DABORTIE_Msk
22108#define SDMMC_MASK_TXFIFOHEIE_Pos (14U)
22109#define SDMMC_MASK_TXFIFOHEIE_Msk (0x1UL << SDMMC_MASK_TXFIFOHEIE_Pos)
22110#define SDMMC_MASK_TXFIFOHEIE SDMMC_MASK_TXFIFOHEIE_Msk
22111#define SDMMC_MASK_RXFIFOHFIE_Pos (15U)
22112#define SDMMC_MASK_RXFIFOHFIE_Msk (0x1UL << SDMMC_MASK_RXFIFOHFIE_Pos)
22113#define SDMMC_MASK_RXFIFOHFIE SDMMC_MASK_RXFIFOHFIE_Msk
22115#define SDMMC_MASK_RXFIFOFIE_Pos (17U)
22116#define SDMMC_MASK_RXFIFOFIE_Msk (0x1UL << SDMMC_MASK_RXFIFOFIE_Pos)
22117#define SDMMC_MASK_RXFIFOFIE SDMMC_MASK_RXFIFOFIE_Msk
22118#define SDMMC_MASK_TXFIFOEIE_Pos (18U)
22119#define SDMMC_MASK_TXFIFOEIE_Msk (0x1UL << SDMMC_MASK_TXFIFOEIE_Pos)
22120#define SDMMC_MASK_TXFIFOEIE SDMMC_MASK_TXFIFOEIE_Msk
22122#define SDMMC_MASK_BUSYD0ENDIE_Pos (21U)
22123#define SDMMC_MASK_BUSYD0ENDIE_Msk (0x1UL << SDMMC_MASK_BUSYD0ENDIE_Pos)
22124#define SDMMC_MASK_BUSYD0ENDIE SDMMC_MASK_BUSYD0ENDIE_Msk
22125#define SDMMC_MASK_SDIOITIE_Pos (22U)
22126#define SDMMC_MASK_SDIOITIE_Msk (0x1UL << SDMMC_MASK_SDIOITIE_Pos)
22127#define SDMMC_MASK_SDIOITIE SDMMC_MASK_SDIOITIE_Msk
22128#define SDMMC_MASK_ACKFAILIE_Pos (23U)
22129#define SDMMC_MASK_ACKFAILIE_Msk (0x1UL << SDMMC_MASK_ACKFAILIE_Pos)
22130#define SDMMC_MASK_ACKFAILIE SDMMC_MASK_ACKFAILIE_Msk
22131#define SDMMC_MASK_ACKTIMEOUTIE_Pos (24U)
22132#define SDMMC_MASK_ACKTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_ACKTIMEOUTIE_Pos)
22133#define SDMMC_MASK_ACKTIMEOUTIE SDMMC_MASK_ACKTIMEOUTIE_Msk
22134#define SDMMC_MASK_VSWENDIE_Pos (25U)
22135#define SDMMC_MASK_VSWENDIE_Msk (0x1UL << SDMMC_MASK_VSWENDIE_Pos)
22136#define SDMMC_MASK_VSWENDIE SDMMC_MASK_VSWENDIE_Msk
22137#define SDMMC_MASK_CKSTOPIE_Pos (26U)
22138#define SDMMC_MASK_CKSTOPIE_Msk (0x1UL << SDMMC_MASK_CKSTOPIE_Pos)
22139#define SDMMC_MASK_CKSTOPIE SDMMC_MASK_CKSTOPIE_Msk
22140#define SDMMC_MASK_IDMABTCIE_Pos (28U)
22141#define SDMMC_MASK_IDMABTCIE_Msk (0x1UL << SDMMC_MASK_IDMABTCIE_Pos)
22142#define SDMMC_MASK_IDMABTCIE SDMMC_MASK_IDMABTCIE_Msk
22144/***************** Bit definition for SDMMC_ACKTIME register *****************/
22145#define SDMMC_ACKTIME_ACKTIME_Pos (0U)
22146#define SDMMC_ACKTIME_ACKTIME_Msk (0x1FFFFFFUL << SDMMC_ACKTIME_ACKTIME_Pos)
22147#define SDMMC_ACKTIME_ACKTIME SDMMC_ACKTIME_ACKTIME_Msk
22149/****************** Bit definition for SDMMC_FIFO register *******************/
22150#define SDMMC_FIFO_FIFODATA_Pos (0U)
22151#define SDMMC_FIFO_FIFODATA_Msk (0xFFFFFFFFUL << SDMMC_FIFO_FIFODATA_Pos)
22152#define SDMMC_FIFO_FIFODATA SDMMC_FIFO_FIFODATA_Msk
22154/****************** Bit definition for SDMMC_IDMACTRL register ****************/
22155#define SDMMC_IDMA_IDMAEN_Pos (0U)
22156#define SDMMC_IDMA_IDMAEN_Msk (0x1UL << SDMMC_IDMA_IDMAEN_Pos)
22157#define SDMMC_IDMA_IDMAEN SDMMC_IDMA_IDMAEN_Msk
22158#define SDMMC_IDMA_IDMABMODE_Pos (1U)
22159#define SDMMC_IDMA_IDMABMODE_Msk (0x1UL << SDMMC_IDMA_IDMABMODE_Pos)
22160#define SDMMC_IDMA_IDMABMODE SDMMC_IDMA_IDMABMODE_Msk
22161#define SDMMC_IDMA_IDMABACT_Pos (2U)
22162#define SDMMC_IDMA_IDMABACT_Msk (0x1UL << SDMMC_IDMA_IDMABACT_Pos)
22163#define SDMMC_IDMA_IDMABACT SDMMC_IDMA_IDMABACT_Msk
22165/***************** Bit definition for SDMMC_IDMABSIZE register ***************/
22166#define SDMMC_IDMABSIZE_IDMABNDT_Pos (5U)
22167#define SDMMC_IDMABSIZE_IDMABNDT_Msk (0xFFUL << SDMMC_IDMABSIZE_IDMABNDT_Pos)
22168#define SDMMC_IDMABSIZE_IDMABNDT SDMMC_IDMABSIZE_IDMABNDT_Msk
22170/***************** Bit definition for SDMMC_IDMABASE0 register ***************/
22171#define SDMMC_IDMABASE0_IDMABASE0 (0xFFFFFFFFU)
22173/***************** Bit definition for SDMMC_IDMABASE1 register ***************/
22174#define SDMMC_IDMABASE1_IDMABASE1 (0xFFFFFFFFU)
22176/******************************************************************************/
22177/* */
22178/* Delay Block Interface (DLYB) */
22179/* */
22180/******************************************************************************/
22181/******************* Bit definition for DLYB_CR register ********************/
22182#define DLYB_CR_DEN_Pos (0U)
22183#define DLYB_CR_DEN_Msk (0x1UL << DLYB_CR_DEN_Pos)
22184#define DLYB_CR_DEN DLYB_CR_DEN_Msk
22185#define DLYB_CR_SEN_Pos (1U)
22186#define DLYB_CR_SEN_Msk (0x1UL << DLYB_CR_SEN_Pos)
22187#define DLYB_CR_SEN DLYB_CR_SEN_Msk
22190/******************* Bit definition for DLYB_CFGR register ********************/
22191#define DLYB_CFGR_SEL_Pos (0U)
22192#define DLYB_CFGR_SEL_Msk (0xFUL << DLYB_CFGR_SEL_Pos)
22193#define DLYB_CFGR_SEL DLYB_CFGR_SEL_Msk
22194#define DLYB_CFGR_SEL_0 (0x1UL << DLYB_CFGR_SEL_Pos)
22195#define DLYB_CFGR_SEL_1 (0x2UL << DLYB_CFGR_SEL_Pos)
22196#define DLYB_CFGR_SEL_2 (0x3UL << DLYB_CFGR_SEL_Pos)
22197#define DLYB_CFGR_SEL_3 (0x8UL << DLYB_CFGR_SEL_Pos)
22199#define DLYB_CFGR_UNIT_Pos (8U)
22200#define DLYB_CFGR_UNIT_Msk (0x7FUL << DLYB_CFGR_UNIT_Pos)
22201#define DLYB_CFGR_UNIT DLYB_CFGR_UNIT_Msk
22202#define DLYB_CFGR_UNIT_0 (0x01UL << DLYB_CFGR_UNIT_Pos)
22203#define DLYB_CFGR_UNIT_1 (0x02UL << DLYB_CFGR_UNIT_Pos)
22204#define DLYB_CFGR_UNIT_2 (0x04UL << DLYB_CFGR_UNIT_Pos)
22205#define DLYB_CFGR_UNIT_3 (0x08UL << DLYB_CFGR_UNIT_Pos)
22206#define DLYB_CFGR_UNIT_4 (0x10UL << DLYB_CFGR_UNIT_Pos)
22207#define DLYB_CFGR_UNIT_5 (0x20UL << DLYB_CFGR_UNIT_Pos)
22208#define DLYB_CFGR_UNIT_6 (0x40UL << DLYB_CFGR_UNIT_Pos)
22210#define DLYB_CFGR_LNG_Pos (16U)
22211#define DLYB_CFGR_LNG_Msk (0xFFFUL << DLYB_CFGR_LNG_Pos)
22212#define DLYB_CFGR_LNG DLYB_CFGR_LNG_Msk
22213#define DLYB_CFGR_LNG_0 (0x001UL << DLYB_CFGR_LNG_Pos)
22214#define DLYB_CFGR_LNG_1 (0x002UL << DLYB_CFGR_LNG_Pos)
22215#define DLYB_CFGR_LNG_2 (0x004UL << DLYB_CFGR_LNG_Pos)
22216#define DLYB_CFGR_LNG_3 (0x008UL << DLYB_CFGR_LNG_Pos)
22217#define DLYB_CFGR_LNG_4 (0x010UL << DLYB_CFGR_LNG_Pos)
22218#define DLYB_CFGR_LNG_5 (0x020UL << DLYB_CFGR_LNG_Pos)
22219#define DLYB_CFGR_LNG_6 (0x040UL << DLYB_CFGR_LNG_Pos)
22220#define DLYB_CFGR_LNG_7 (0x080UL << DLYB_CFGR_LNG_Pos)
22221#define DLYB_CFGR_LNG_8 (0x100UL << DLYB_CFGR_LNG_Pos)
22222#define DLYB_CFGR_LNG_9 (0x200UL << DLYB_CFGR_LNG_Pos)
22223#define DLYB_CFGR_LNG_10 (0x400UL << DLYB_CFGR_LNG_Pos)
22224#define DLYB_CFGR_LNG_11 (0x800UL << DLYB_CFGR_LNG_Pos)
22226#define DLYB_CFGR_LNGF_Pos (31U)
22227#define DLYB_CFGR_LNGF_Msk (0x1UL << DLYB_CFGR_LNGF_Pos)
22228#define DLYB_CFGR_LNGF DLYB_CFGR_LNGF_Msk
22230/******************************************************************************/
22231/* */
22232/* Serial Peripheral Interface (SPI/I2S) */
22233/* */
22234/******************************************************************************/
22235/******************* Bit definition for SPI_CR1 register ********************/
22236#define SPI_CR1_SPE_Pos (0U)
22237#define SPI_CR1_SPE_Msk (0x1UL << SPI_CR1_SPE_Pos)
22238#define SPI_CR1_SPE SPI_CR1_SPE_Msk
22239#define SPI_CR1_MASRX_Pos (8U)
22240#define SPI_CR1_MASRX_Msk (0x1UL << SPI_CR1_MASRX_Pos)
22241#define SPI_CR1_MASRX SPI_CR1_MASRX_Msk
22242#define SPI_CR1_CSTART_Pos (9U)
22243#define SPI_CR1_CSTART_Msk (0x1UL << SPI_CR1_CSTART_Pos)
22244#define SPI_CR1_CSTART SPI_CR1_CSTART_Msk
22245#define SPI_CR1_CSUSP_Pos (10U)
22246#define SPI_CR1_CSUSP_Msk (0x1UL << SPI_CR1_CSUSP_Pos)
22247#define SPI_CR1_CSUSP SPI_CR1_CSUSP_Msk
22248#define SPI_CR1_HDDIR_Pos (11U)
22249#define SPI_CR1_HDDIR_Msk (0x1UL << SPI_CR1_HDDIR_Pos)
22250#define SPI_CR1_HDDIR SPI_CR1_HDDIR_Msk
22251#define SPI_CR1_SSI_Pos (12U)
22252#define SPI_CR1_SSI_Msk (0x1UL << SPI_CR1_SSI_Pos)
22253#define SPI_CR1_SSI SPI_CR1_SSI_Msk
22254#define SPI_CR1_CRC33_17_Pos (13U)
22255#define SPI_CR1_CRC33_17_Msk (0x1UL << SPI_CR1_CRC33_17_Pos)
22256#define SPI_CR1_CRC33_17 SPI_CR1_CRC33_17_Msk
22257#define SPI_CR1_RCRCINI_Pos (14U)
22258#define SPI_CR1_RCRCINI_Msk (0x1UL << SPI_CR1_RCRCINI_Pos)
22259#define SPI_CR1_RCRCINI SPI_CR1_RCRCINI_Msk
22260#define SPI_CR1_TCRCINI_Pos (15U)
22261#define SPI_CR1_TCRCINI_Msk (0x1UL << SPI_CR1_TCRCINI_Pos)
22262#define SPI_CR1_TCRCINI SPI_CR1_TCRCINI_Msk
22263#define SPI_CR1_IOLOCK_Pos (16U)
22264#define SPI_CR1_IOLOCK_Msk (0x1UL << SPI_CR1_IOLOCK_Pos)
22265#define SPI_CR1_IOLOCK SPI_CR1_IOLOCK_Msk
22267/******************* Bit definition for SPI_CR2 register ********************/
22268#define SPI_CR2_TSER_Pos (16U)
22269#define SPI_CR2_TSER_Msk (0xFFFFUL << SPI_CR2_TSER_Pos)
22270#define SPI_CR2_TSER SPI_CR2_TSER_Msk
22271#define SPI_CR2_TSIZE_Pos (0U)
22272#define SPI_CR2_TSIZE_Msk (0xFFFFUL << SPI_CR2_TSIZE_Pos)
22273#define SPI_CR2_TSIZE SPI_CR2_TSIZE_Msk
22275/******************* Bit definition for SPI_CFG1 register ********************/
22276#define SPI_CFG1_DSIZE_Pos (0U)
22277#define SPI_CFG1_DSIZE_Msk (0x1FUL << SPI_CFG1_DSIZE_Pos)
22278#define SPI_CFG1_DSIZE SPI_CFG1_DSIZE_Msk
22279#define SPI_CFG1_DSIZE_0 (0x01UL << SPI_CFG1_DSIZE_Pos)
22280#define SPI_CFG1_DSIZE_1 (0x02UL << SPI_CFG1_DSIZE_Pos)
22281#define SPI_CFG1_DSIZE_2 (0x04UL << SPI_CFG1_DSIZE_Pos)
22282#define SPI_CFG1_DSIZE_3 (0x08UL << SPI_CFG1_DSIZE_Pos)
22283#define SPI_CFG1_DSIZE_4 (0x10UL << SPI_CFG1_DSIZE_Pos)
22285#define SPI_CFG1_FTHLV_Pos (5U)
22286#define SPI_CFG1_FTHLV_Msk (0xFUL << SPI_CFG1_FTHLV_Pos)
22287#define SPI_CFG1_FTHLV SPI_CFG1_FTHLV_Msk
22288#define SPI_CFG1_FTHLV_0 (0x1UL << SPI_CFG1_FTHLV_Pos)
22289#define SPI_CFG1_FTHLV_1 (0x2UL << SPI_CFG1_FTHLV_Pos)
22290#define SPI_CFG1_FTHLV_2 (0x4UL << SPI_CFG1_FTHLV_Pos)
22291#define SPI_CFG1_FTHLV_3 (0x8UL << SPI_CFG1_FTHLV_Pos)
22293#define SPI_CFG1_UDRCFG_Pos (9U)
22294#define SPI_CFG1_UDRCFG_Msk (0x3UL << SPI_CFG1_UDRCFG_Pos)
22295#define SPI_CFG1_UDRCFG SPI_CFG1_UDRCFG_Msk
22296#define SPI_CFG1_UDRCFG_0 (0x1UL << SPI_CFG1_UDRCFG_Pos)
22297#define SPI_CFG1_UDRCFG_1 (0x2UL << SPI_CFG1_UDRCFG_Pos)
22300#define SPI_CFG1_UDRDET_Pos (11U)
22301#define SPI_CFG1_UDRDET_Msk (0x3UL << SPI_CFG1_UDRDET_Pos)
22302#define SPI_CFG1_UDRDET SPI_CFG1_UDRDET_Msk
22303#define SPI_CFG1_UDRDET_0 (0x1UL << SPI_CFG1_UDRDET_Pos)
22304#define SPI_CFG1_UDRDET_1 (0x2UL << SPI_CFG1_UDRDET_Pos)
22306#define SPI_CFG1_RXDMAEN_Pos (14U)
22307#define SPI_CFG1_RXDMAEN_Msk (0x1UL << SPI_CFG1_RXDMAEN_Pos)
22308#define SPI_CFG1_RXDMAEN SPI_CFG1_RXDMAEN_Msk
22309#define SPI_CFG1_TXDMAEN_Pos (15U)
22310#define SPI_CFG1_TXDMAEN_Msk (0x1UL << SPI_CFG1_TXDMAEN_Pos)
22311#define SPI_CFG1_TXDMAEN SPI_CFG1_TXDMAEN_Msk
22313#define SPI_CFG1_CRCSIZE_Pos (16U)
22314#define SPI_CFG1_CRCSIZE_Msk (0x1FUL << SPI_CFG1_CRCSIZE_Pos)
22315#define SPI_CFG1_CRCSIZE SPI_CFG1_CRCSIZE_Msk
22316#define SPI_CFG1_CRCSIZE_0 (0x01UL << SPI_CFG1_CRCSIZE_Pos)
22317#define SPI_CFG1_CRCSIZE_1 (0x02UL << SPI_CFG1_CRCSIZE_Pos)
22318#define SPI_CFG1_CRCSIZE_2 (0x04UL << SPI_CFG1_CRCSIZE_Pos)
22319#define SPI_CFG1_CRCSIZE_3 (0x08UL << SPI_CFG1_CRCSIZE_Pos)
22320#define SPI_CFG1_CRCSIZE_4 (0x10UL << SPI_CFG1_CRCSIZE_Pos)
22322#define SPI_CFG1_CRCEN_Pos (22U)
22323#define SPI_CFG1_CRCEN_Msk (0x1UL << SPI_CFG1_CRCEN_Pos)
22324#define SPI_CFG1_CRCEN SPI_CFG1_CRCEN_Msk
22326#define SPI_CFG1_MBR_Pos (28U)
22327#define SPI_CFG1_MBR_Msk (0x7UL << SPI_CFG1_MBR_Pos)
22328#define SPI_CFG1_MBR SPI_CFG1_MBR_Msk
22329#define SPI_CFG1_MBR_0 (0x1UL << SPI_CFG1_MBR_Pos)
22330#define SPI_CFG1_MBR_1 (0x2UL << SPI_CFG1_MBR_Pos)
22331#define SPI_CFG1_MBR_2 (0x4UL << SPI_CFG1_MBR_Pos)
22333/******************* Bit definition for SPI_CFG2 register ********************/
22334#define SPI_CFG2_MSSI_Pos (0U)
22335#define SPI_CFG2_MSSI_Msk (0xFUL << SPI_CFG2_MSSI_Pos)
22336#define SPI_CFG2_MSSI SPI_CFG2_MSSI_Msk
22337#define SPI_CFG2_MSSI_0 (0x1UL << SPI_CFG2_MSSI_Pos)
22338#define SPI_CFG2_MSSI_1 (0x2UL << SPI_CFG2_MSSI_Pos)
22339#define SPI_CFG2_MSSI_2 (0x4UL << SPI_CFG2_MSSI_Pos)
22340#define SPI_CFG2_MSSI_3 (0x8UL << SPI_CFG2_MSSI_Pos)
22342#define SPI_CFG2_MIDI_Pos (4U)
22343#define SPI_CFG2_MIDI_Msk (0xFUL << SPI_CFG2_MIDI_Pos)
22344#define SPI_CFG2_MIDI SPI_CFG2_MIDI_Msk
22345#define SPI_CFG2_MIDI_0 (0x1UL << SPI_CFG2_MIDI_Pos)
22346#define SPI_CFG2_MIDI_1 (0x2UL << SPI_CFG2_MIDI_Pos)
22347#define SPI_CFG2_MIDI_2 (0x4UL << SPI_CFG2_MIDI_Pos)
22348#define SPI_CFG2_MIDI_3 (0x8UL << SPI_CFG2_MIDI_Pos)
22350#define SPI_CFG2_IOSWP_Pos (15U)
22351#define SPI_CFG2_IOSWP_Msk (0x1UL << SPI_CFG2_IOSWP_Pos)
22352#define SPI_CFG2_IOSWP SPI_CFG2_IOSWP_Msk
22354#define SPI_CFG2_COMM_Pos (17U)
22355#define SPI_CFG2_COMM_Msk (0x3UL << SPI_CFG2_COMM_Pos)
22356#define SPI_CFG2_COMM SPI_CFG2_COMM_Msk
22357#define SPI_CFG2_COMM_0 (0x1UL << SPI_CFG2_COMM_Pos)
22358#define SPI_CFG2_COMM_1 (0x2UL << SPI_CFG2_COMM_Pos)
22360#define SPI_CFG2_SP_Pos (19U)
22361#define SPI_CFG2_SP_Msk (0x7UL << SPI_CFG2_SP_Pos)
22362#define SPI_CFG2_SP SPI_CFG2_SP_Msk
22363#define SPI_CFG2_SP_0 (0x1UL << SPI_CFG2_SP_Pos)
22364#define SPI_CFG2_SP_1 (0x2UL << SPI_CFG2_SP_Pos)
22365#define SPI_CFG2_SP_2 (0x4UL << SPI_CFG2_SP_Pos)
22367#define SPI_CFG2_MASTER_Pos (22U)
22368#define SPI_CFG2_MASTER_Msk (0x1UL << SPI_CFG2_MASTER_Pos)
22369#define SPI_CFG2_MASTER SPI_CFG2_MASTER_Msk
22370#define SPI_CFG2_LSBFRST_Pos (23U)
22371#define SPI_CFG2_LSBFRST_Msk (0x1UL << SPI_CFG2_LSBFRST_Pos)
22372#define SPI_CFG2_LSBFRST SPI_CFG2_LSBFRST_Msk
22373#define SPI_CFG2_CPHA_Pos (24U)
22374#define SPI_CFG2_CPHA_Msk (0x1UL << SPI_CFG2_CPHA_Pos)
22375#define SPI_CFG2_CPHA SPI_CFG2_CPHA_Msk
22376#define SPI_CFG2_CPOL_Pos (25U)
22377#define SPI_CFG2_CPOL_Msk (0x1UL << SPI_CFG2_CPOL_Pos)
22378#define SPI_CFG2_CPOL SPI_CFG2_CPOL_Msk
22379#define SPI_CFG2_SSM_Pos (26U)
22380#define SPI_CFG2_SSM_Msk (0x1UL << SPI_CFG2_SSM_Pos)
22381#define SPI_CFG2_SSM SPI_CFG2_SSM_Msk
22383#define SPI_CFG2_SSIOP_Pos (28U)
22384#define SPI_CFG2_SSIOP_Msk (0x1UL << SPI_CFG2_SSIOP_Pos)
22385#define SPI_CFG2_SSIOP SPI_CFG2_SSIOP_Msk
22386#define SPI_CFG2_SSOE_Pos (29U)
22387#define SPI_CFG2_SSOE_Msk (0x1UL << SPI_CFG2_SSOE_Pos)
22388#define SPI_CFG2_SSOE SPI_CFG2_SSOE_Msk
22389#define SPI_CFG2_SSOM_Pos (30U)
22390#define SPI_CFG2_SSOM_Msk (0x1UL << SPI_CFG2_SSOM_Pos)
22391#define SPI_CFG2_SSOM SPI_CFG2_SSOM_Msk
22393#define SPI_CFG2_AFCNTR_Pos (31U)
22394#define SPI_CFG2_AFCNTR_Msk (0x1UL << SPI_CFG2_AFCNTR_Pos)
22395#define SPI_CFG2_AFCNTR SPI_CFG2_AFCNTR_Msk
22397/******************* Bit definition for SPI_IER register ********************/
22398#define SPI_IER_RXPIE_Pos (0U)
22399#define SPI_IER_RXPIE_Msk (0x1UL << SPI_IER_RXPIE_Pos)
22400#define SPI_IER_RXPIE SPI_IER_RXPIE_Msk
22401#define SPI_IER_TXPIE_Pos (1U)
22402#define SPI_IER_TXPIE_Msk (0x1UL << SPI_IER_TXPIE_Pos)
22403#define SPI_IER_TXPIE SPI_IER_TXPIE_Msk
22404#define SPI_IER_DXPIE_Pos (2U)
22405#define SPI_IER_DXPIE_Msk (0x1UL << SPI_IER_DXPIE_Pos)
22406#define SPI_IER_DXPIE SPI_IER_DXPIE_Msk
22407#define SPI_IER_EOTIE_Pos (3U)
22408#define SPI_IER_EOTIE_Msk (0x1UL << SPI_IER_EOTIE_Pos)
22409#define SPI_IER_EOTIE SPI_IER_EOTIE_Msk
22410#define SPI_IER_TXTFIE_Pos (4U)
22411#define SPI_IER_TXTFIE_Msk (0x1UL << SPI_IER_TXTFIE_Pos)
22412#define SPI_IER_TXTFIE SPI_IER_TXTFIE_Msk
22413#define SPI_IER_UDRIE_Pos (5U)
22414#define SPI_IER_UDRIE_Msk (0x1UL << SPI_IER_UDRIE_Pos)
22415#define SPI_IER_UDRIE SPI_IER_UDRIE_Msk
22416#define SPI_IER_OVRIE_Pos (6U)
22417#define SPI_IER_OVRIE_Msk (0x1UL << SPI_IER_OVRIE_Pos)
22418#define SPI_IER_OVRIE SPI_IER_OVRIE_Msk
22419#define SPI_IER_CRCEIE_Pos (7U)
22420#define SPI_IER_CRCEIE_Msk (0x1UL << SPI_IER_CRCEIE_Pos)
22421#define SPI_IER_CRCEIE SPI_IER_CRCEIE_Msk
22422#define SPI_IER_TIFREIE_Pos (8U)
22423#define SPI_IER_TIFREIE_Msk (0x1UL << SPI_IER_TIFREIE_Pos)
22424#define SPI_IER_TIFREIE SPI_IER_TIFREIE_Msk
22425#define SPI_IER_MODFIE_Pos (9U)
22426#define SPI_IER_MODFIE_Msk (0x1UL << SPI_IER_MODFIE_Pos)
22427#define SPI_IER_MODFIE SPI_IER_MODFIE_Msk
22428#define SPI_IER_TSERFIE_Pos (10U)
22429#define SPI_IER_TSERFIE_Msk (0x1UL << SPI_IER_TSERFIE_Pos)
22430#define SPI_IER_TSERFIE SPI_IER_TSERFIE_Msk
22432/******************* Bit definition for SPI_SR register ********************/
22433#define SPI_SR_RXP_Pos (0U)
22434#define SPI_SR_RXP_Msk (0x1UL << SPI_SR_RXP_Pos)
22435#define SPI_SR_RXP SPI_SR_RXP_Msk
22436#define SPI_SR_TXP_Pos (1U)
22437#define SPI_SR_TXP_Msk (0x1UL << SPI_SR_TXP_Pos)
22438#define SPI_SR_TXP SPI_SR_TXP_Msk
22439#define SPI_SR_DXP_Pos (2U)
22440#define SPI_SR_DXP_Msk (0x1UL << SPI_SR_DXP_Pos)
22441#define SPI_SR_DXP SPI_SR_DXP_Msk
22442#define SPI_SR_EOT_Pos (3U)
22443#define SPI_SR_EOT_Msk (0x1UL << SPI_SR_EOT_Pos)
22444#define SPI_SR_EOT SPI_SR_EOT_Msk
22445#define SPI_SR_TXTF_Pos (4U)
22446#define SPI_SR_TXTF_Msk (0x1UL << SPI_SR_TXTF_Pos)
22447#define SPI_SR_TXTF SPI_SR_TXTF_Msk
22448#define SPI_SR_UDR_Pos (5U)
22449#define SPI_SR_UDR_Msk (0x1UL << SPI_SR_UDR_Pos)
22450#define SPI_SR_UDR SPI_SR_UDR_Msk
22451#define SPI_SR_OVR_Pos (6U)
22452#define SPI_SR_OVR_Msk (0x1UL << SPI_SR_OVR_Pos)
22453#define SPI_SR_OVR SPI_SR_OVR_Msk
22454#define SPI_SR_CRCE_Pos (7U)
22455#define SPI_SR_CRCE_Msk (0x1UL << SPI_SR_CRCE_Pos)
22456#define SPI_SR_CRCE SPI_SR_CRCE_Msk
22457#define SPI_SR_TIFRE_Pos (8U)
22458#define SPI_SR_TIFRE_Msk (0x1UL << SPI_SR_TIFRE_Pos)
22459#define SPI_SR_TIFRE SPI_SR_TIFRE_Msk
22460#define SPI_SR_MODF_Pos (9U)
22461#define SPI_SR_MODF_Msk (0x1UL << SPI_SR_MODF_Pos)
22462#define SPI_SR_MODF SPI_SR_MODF_Msk
22463#define SPI_SR_TSERF_Pos (10U)
22464#define SPI_SR_TSERF_Msk (0x1UL << SPI_SR_TSERF_Pos)
22465#define SPI_SR_TSERF SPI_SR_TSERF_Msk
22466#define SPI_SR_SUSP_Pos (11U)
22467#define SPI_SR_SUSP_Msk (0x1UL << SPI_SR_SUSP_Pos)
22468#define SPI_SR_SUSP SPI_SR_SUSP_Msk
22469#define SPI_SR_TXC_Pos (12U)
22470#define SPI_SR_TXC_Msk (0x1UL << SPI_SR_TXC_Pos)
22471#define SPI_SR_TXC SPI_SR_TXC_Msk
22472#define SPI_SR_RXPLVL_Pos (13U)
22473#define SPI_SR_RXPLVL_Msk (0x3UL << SPI_SR_RXPLVL_Pos)
22474#define SPI_SR_RXPLVL SPI_SR_RXPLVL_Msk
22475#define SPI_SR_RXPLVL_0 (0x1UL << SPI_SR_RXPLVL_Pos)
22476#define SPI_SR_RXPLVL_1 (0x2UL << SPI_SR_RXPLVL_Pos)
22477#define SPI_SR_RXWNE_Pos (15U)
22478#define SPI_SR_RXWNE_Msk (0x1UL << SPI_SR_RXWNE_Pos)
22479#define SPI_SR_RXWNE SPI_SR_RXWNE_Msk
22480#define SPI_SR_CTSIZE_Pos (16U)
22481#define SPI_SR_CTSIZE_Msk (0xFFFFUL << SPI_SR_CTSIZE_Pos)
22482#define SPI_SR_CTSIZE SPI_SR_CTSIZE_Msk
22484/******************* Bit definition for SPI_IFCR register ********************/
22485#define SPI_IFCR_EOTC_Pos (3U)
22486#define SPI_IFCR_EOTC_Msk (0x1UL << SPI_IFCR_EOTC_Pos)
22487#define SPI_IFCR_EOTC SPI_IFCR_EOTC_Msk
22488#define SPI_IFCR_TXTFC_Pos (4U)
22489#define SPI_IFCR_TXTFC_Msk (0x1UL << SPI_IFCR_TXTFC_Pos)
22490#define SPI_IFCR_TXTFC SPI_IFCR_TXTFC_Msk
22491#define SPI_IFCR_UDRC_Pos (5U)
22492#define SPI_IFCR_UDRC_Msk (0x1UL << SPI_IFCR_UDRC_Pos)
22493#define SPI_IFCR_UDRC SPI_IFCR_UDRC_Msk
22494#define SPI_IFCR_OVRC_Pos (6U)
22495#define SPI_IFCR_OVRC_Msk (0x1UL << SPI_IFCR_OVRC_Pos)
22496#define SPI_IFCR_OVRC SPI_IFCR_OVRC_Msk
22497#define SPI_IFCR_CRCEC_Pos (7U)
22498#define SPI_IFCR_CRCEC_Msk (0x1UL << SPI_IFCR_CRCEC_Pos)
22499#define SPI_IFCR_CRCEC SPI_IFCR_CRCEC_Msk
22500#define SPI_IFCR_TIFREC_Pos (8U)
22501#define SPI_IFCR_TIFREC_Msk (0x1UL << SPI_IFCR_TIFREC_Pos)
22502#define SPI_IFCR_TIFREC SPI_IFCR_TIFREC_Msk
22503#define SPI_IFCR_MODFC_Pos (9U)
22504#define SPI_IFCR_MODFC_Msk (0x1UL << SPI_IFCR_MODFC_Pos)
22505#define SPI_IFCR_MODFC SPI_IFCR_MODFC_Msk
22506#define SPI_IFCR_TSERFC_Pos (10U)
22507#define SPI_IFCR_TSERFC_Msk (0x1UL << SPI_IFCR_TSERFC_Pos)
22508#define SPI_IFCR_TSERFC SPI_IFCR_TSERFC_Msk
22509#define SPI_IFCR_SUSPC_Pos (11U)
22510#define SPI_IFCR_SUSPC_Msk (0x1UL << SPI_IFCR_SUSPC_Pos)
22511#define SPI_IFCR_SUSPC SPI_IFCR_SUSPC_Msk
22513/******************* Bit definition for SPI_TXDR register ********************/
22514#define SPI_TXDR_TXDR_Pos (0U)
22515#define SPI_TXDR_TXDR_Msk (0xFFFFFFFFUL << SPI_TXDR_TXDR_Pos)
22516#define SPI_TXDR_TXDR SPI_TXDR_TXDR_Msk /* Transmit Data Register */
22517
22518/******************* Bit definition for SPI_RXDR register ********************/
22519#define SPI_RXDR_RXDR_Pos (0U)
22520#define SPI_RXDR_RXDR_Msk (0xFFFFFFFFUL << SPI_RXDR_RXDR_Pos)
22521#define SPI_RXDR_RXDR SPI_RXDR_RXDR_Msk /* Receive Data Register */
22522
22523/******************* Bit definition for SPI_CRCPOLY register ********************/
22524#define SPI_CRCPOLY_CRCPOLY_Pos (0U)
22525#define SPI_CRCPOLY_CRCPOLY_Msk (0xFFFFFFFFUL << SPI_CRCPOLY_CRCPOLY_Pos)
22526#define SPI_CRCPOLY_CRCPOLY SPI_CRCPOLY_CRCPOLY_Msk /* CRC Polynomial register */
22527
22528/******************* Bit definition for SPI_TXCRC register ********************/
22529#define SPI_TXCRC_TXCRC_Pos (0U)
22530#define SPI_TXCRC_TXCRC_Msk (0xFFFFFFFFUL << SPI_TXCRC_TXCRC_Pos)
22531#define SPI_TXCRC_TXCRC SPI_TXCRC_TXCRC_Msk /* CRCRegister for transmitter */
22532
22533/******************* Bit definition for SPI_RXCRC register ********************/
22534#define SPI_RXCRC_RXCRC_Pos (0U)
22535#define SPI_RXCRC_RXCRC_Msk (0xFFFFFFFFUL << SPI_RXCRC_RXCRC_Pos)
22536#define SPI_RXCRC_RXCRC SPI_RXCRC_RXCRC_Msk /* CRCRegister for receiver */
22537
22538/******************* Bit definition for SPI_UDRDR register ********************/
22539#define SPI_UDRDR_UDRDR_Pos (0U)
22540#define SPI_UDRDR_UDRDR_Msk (0xFFFFFFFFUL << SPI_UDRDR_UDRDR_Pos)
22541#define SPI_UDRDR_UDRDR SPI_UDRDR_UDRDR_Msk /* Data at slave underrun condition */
22542
22543/****************** Bit definition for SPI_I2SCFGR register *****************/
22544#define SPI_I2SCFGR_I2SMOD_Pos (0U)
22545#define SPI_I2SCFGR_I2SMOD_Msk (0x1UL << SPI_I2SCFGR_I2SMOD_Pos)
22546#define SPI_I2SCFGR_I2SMOD SPI_I2SCFGR_I2SMOD_Msk
22547#define SPI_I2SCFGR_I2SCFG_Pos (1U)
22548#define SPI_I2SCFGR_I2SCFG_Msk (0x7UL << SPI_I2SCFGR_I2SCFG_Pos)
22549#define SPI_I2SCFGR_I2SCFG SPI_I2SCFGR_I2SCFG_Msk
22550#define SPI_I2SCFGR_I2SCFG_0 (0x1UL << SPI_I2SCFGR_I2SCFG_Pos)
22551#define SPI_I2SCFGR_I2SCFG_1 (0x2UL << SPI_I2SCFGR_I2SCFG_Pos)
22552#define SPI_I2SCFGR_I2SCFG_2 (0x4UL << SPI_I2SCFGR_I2SCFG_Pos)
22553#define SPI_I2SCFGR_I2SSTD_Pos (4U)
22554#define SPI_I2SCFGR_I2SSTD_Msk (0x3UL << SPI_I2SCFGR_I2SSTD_Pos)
22555#define SPI_I2SCFGR_I2SSTD SPI_I2SCFGR_I2SSTD_Msk
22556#define SPI_I2SCFGR_I2SSTD_0 (0x1UL << SPI_I2SCFGR_I2SSTD_Pos)
22557#define SPI_I2SCFGR_I2SSTD_1 (0x2UL << SPI_I2SCFGR_I2SSTD_Pos)
22558#define SPI_I2SCFGR_PCMSYNC_Pos (7U)
22559#define SPI_I2SCFGR_PCMSYNC_Msk (0x1UL << SPI_I2SCFGR_PCMSYNC_Pos)
22560#define SPI_I2SCFGR_PCMSYNC SPI_I2SCFGR_PCMSYNC_Msk
22561#define SPI_I2SCFGR_DATLEN_Pos (8U)
22562#define SPI_I2SCFGR_DATLEN_Msk (0x3UL << SPI_I2SCFGR_DATLEN_Pos)
22563#define SPI_I2SCFGR_DATLEN SPI_I2SCFGR_DATLEN_Msk
22564#define SPI_I2SCFGR_DATLEN_0 (0x1UL << SPI_I2SCFGR_DATLEN_Pos)
22565#define SPI_I2SCFGR_DATLEN_1 (0x2UL << SPI_I2SCFGR_DATLEN_Pos)
22566#define SPI_I2SCFGR_CHLEN_Pos (10U)
22567#define SPI_I2SCFGR_CHLEN_Msk (0x1UL << SPI_I2SCFGR_CHLEN_Pos)
22568#define SPI_I2SCFGR_CHLEN SPI_I2SCFGR_CHLEN_Msk
22569#define SPI_I2SCFGR_CKPOL_Pos (11U)
22570#define SPI_I2SCFGR_CKPOL_Msk (0x1UL << SPI_I2SCFGR_CKPOL_Pos)
22571#define SPI_I2SCFGR_CKPOL SPI_I2SCFGR_CKPOL_Msk
22572#define SPI_I2SCFGR_FIXCH_Pos (12U)
22573#define SPI_I2SCFGR_FIXCH_Msk (0x1UL << SPI_I2SCFGR_FIXCH_Pos)
22574#define SPI_I2SCFGR_FIXCH SPI_I2SCFGR_FIXCH_Msk
22575#define SPI_I2SCFGR_WSINV_Pos (13U)
22576#define SPI_I2SCFGR_WSINV_Msk (0x1UL << SPI_I2SCFGR_WSINV_Pos)
22577#define SPI_I2SCFGR_WSINV SPI_I2SCFGR_WSINV_Msk
22578#define SPI_I2SCFGR_DATFMT_Pos (14U)
22579#define SPI_I2SCFGR_DATFMT_Msk (0x1UL << SPI_I2SCFGR_DATFMT_Pos)
22580#define SPI_I2SCFGR_DATFMT SPI_I2SCFGR_DATFMT_Msk
22581#define SPI_I2SCFGR_I2SDIV_Pos (16U)
22582#define SPI_I2SCFGR_I2SDIV_Msk (0xFFUL << SPI_I2SCFGR_I2SDIV_Pos)
22583#define SPI_I2SCFGR_I2SDIV SPI_I2SCFGR_I2SDIV_Msk
22584#define SPI_I2SCFGR_ODD_Pos (24U)
22585#define SPI_I2SCFGR_ODD_Msk (0x1UL << SPI_I2SCFGR_ODD_Pos)
22586#define SPI_I2SCFGR_ODD SPI_I2SCFGR_ODD_Msk
22587#define SPI_I2SCFGR_MCKOE_Pos (25U)
22588#define SPI_I2SCFGR_MCKOE_Msk (0x1UL << SPI_I2SCFGR_MCKOE_Pos)
22589#define SPI_I2SCFGR_MCKOE SPI_I2SCFGR_MCKOE_Msk
22592/******************************************************************************/
22593/* */
22594/* QUADSPI */
22595/* */
22596/******************************************************************************/
22597/***************** Bit definition for QUADSPI_CR register *******************/
22598#define QUADSPI_CR_EN_Pos (0U)
22599#define QUADSPI_CR_EN_Msk (0x1UL << QUADSPI_CR_EN_Pos)
22600#define QUADSPI_CR_EN QUADSPI_CR_EN_Msk
22601#define QUADSPI_CR_ABORT_Pos (1U)
22602#define QUADSPI_CR_ABORT_Msk (0x1UL << QUADSPI_CR_ABORT_Pos)
22603#define QUADSPI_CR_ABORT QUADSPI_CR_ABORT_Msk
22604#define QUADSPI_CR_DMAEN_Pos (2U)
22605#define QUADSPI_CR_DMAEN_Msk (0x1UL << QUADSPI_CR_DMAEN_Pos)
22606#define QUADSPI_CR_DMAEN QUADSPI_CR_DMAEN_Msk
22607#define QUADSPI_CR_TCEN_Pos (3U)
22608#define QUADSPI_CR_TCEN_Msk (0x1UL << QUADSPI_CR_TCEN_Pos)
22609#define QUADSPI_CR_TCEN QUADSPI_CR_TCEN_Msk
22610#define QUADSPI_CR_SSHIFT_Pos (4U)
22611#define QUADSPI_CR_SSHIFT_Msk (0x1UL << QUADSPI_CR_SSHIFT_Pos)
22612#define QUADSPI_CR_SSHIFT QUADSPI_CR_SSHIFT_Msk
22613#define QUADSPI_CR_DFM_Pos (6U)
22614#define QUADSPI_CR_DFM_Msk (0x1UL << QUADSPI_CR_DFM_Pos)
22615#define QUADSPI_CR_DFM QUADSPI_CR_DFM_Msk
22616#define QUADSPI_CR_FSEL_Pos (7U)
22617#define QUADSPI_CR_FSEL_Msk (0x1UL << QUADSPI_CR_FSEL_Pos)
22618#define QUADSPI_CR_FSEL QUADSPI_CR_FSEL_Msk
22619#define QUADSPI_CR_FTHRES_Pos (8U)
22620#define QUADSPI_CR_FTHRES_Msk (0x1FUL << QUADSPI_CR_FTHRES_Pos)
22621#define QUADSPI_CR_FTHRES QUADSPI_CR_FTHRES_Msk
22622#define QUADSPI_CR_FTHRES_0 (0x1UL << QUADSPI_CR_FTHRES_Pos)
22623#define QUADSPI_CR_FTHRES_1 (0x2UL << QUADSPI_CR_FTHRES_Pos)
22624#define QUADSPI_CR_FTHRES_2 (0x4UL << QUADSPI_CR_FTHRES_Pos)
22625#define QUADSPI_CR_FTHRES_3 (0x8UL << QUADSPI_CR_FTHRES_Pos)
22626#define QUADSPI_CR_FTHRES_4 (0x10UL << QUADSPI_CR_FTHRES_Pos)
22627#define QUADSPI_CR_TEIE_Pos (16U)
22628#define QUADSPI_CR_TEIE_Msk (0x1UL << QUADSPI_CR_TEIE_Pos)
22629#define QUADSPI_CR_TEIE QUADSPI_CR_TEIE_Msk
22630#define QUADSPI_CR_TCIE_Pos (17U)
22631#define QUADSPI_CR_TCIE_Msk (0x1UL << QUADSPI_CR_TCIE_Pos)
22632#define QUADSPI_CR_TCIE QUADSPI_CR_TCIE_Msk
22633#define QUADSPI_CR_FTIE_Pos (18U)
22634#define QUADSPI_CR_FTIE_Msk (0x1UL << QUADSPI_CR_FTIE_Pos)
22635#define QUADSPI_CR_FTIE QUADSPI_CR_FTIE_Msk
22636#define QUADSPI_CR_SMIE_Pos (19U)
22637#define QUADSPI_CR_SMIE_Msk (0x1UL << QUADSPI_CR_SMIE_Pos)
22638#define QUADSPI_CR_SMIE QUADSPI_CR_SMIE_Msk
22639#define QUADSPI_CR_TOIE_Pos (20U)
22640#define QUADSPI_CR_TOIE_Msk (0x1UL << QUADSPI_CR_TOIE_Pos)
22641#define QUADSPI_CR_TOIE QUADSPI_CR_TOIE_Msk
22642#define QUADSPI_CR_APMS_Pos (22U)
22643#define QUADSPI_CR_APMS_Msk (0x1UL << QUADSPI_CR_APMS_Pos)
22644#define QUADSPI_CR_APMS QUADSPI_CR_APMS_Msk
22645#define QUADSPI_CR_PMM_Pos (23U)
22646#define QUADSPI_CR_PMM_Msk (0x1UL << QUADSPI_CR_PMM_Pos)
22647#define QUADSPI_CR_PMM QUADSPI_CR_PMM_Msk
22648#define QUADSPI_CR_PRESCALER_Pos (24U)
22649#define QUADSPI_CR_PRESCALER_Msk (0xFFUL << QUADSPI_CR_PRESCALER_Pos)
22650#define QUADSPI_CR_PRESCALER QUADSPI_CR_PRESCALER_Msk
22651#define QUADSPI_CR_PRESCALER_0 (0x01UL << QUADSPI_CR_PRESCALER_Pos)
22652#define QUADSPI_CR_PRESCALER_1 (0x02UL << QUADSPI_CR_PRESCALER_Pos)
22653#define QUADSPI_CR_PRESCALER_2 (0x04UL << QUADSPI_CR_PRESCALER_Pos)
22654#define QUADSPI_CR_PRESCALER_3 (0x08UL << QUADSPI_CR_PRESCALER_Pos)
22655#define QUADSPI_CR_PRESCALER_4 (0x10UL << QUADSPI_CR_PRESCALER_Pos)
22656#define QUADSPI_CR_PRESCALER_5 (0x20UL << QUADSPI_CR_PRESCALER_Pos)
22657#define QUADSPI_CR_PRESCALER_6 (0x40UL << QUADSPI_CR_PRESCALER_Pos)
22658#define QUADSPI_CR_PRESCALER_7 (0x80UL << QUADSPI_CR_PRESCALER_Pos)
22660/***************** Bit definition for QUADSPI_DCR register ******************/
22661#define QUADSPI_DCR_CKMODE_Pos (0U)
22662#define QUADSPI_DCR_CKMODE_Msk (0x1UL << QUADSPI_DCR_CKMODE_Pos)
22663#define QUADSPI_DCR_CKMODE QUADSPI_DCR_CKMODE_Msk
22664#define QUADSPI_DCR_CSHT_Pos (8U)
22665#define QUADSPI_DCR_CSHT_Msk (0x7UL << QUADSPI_DCR_CSHT_Pos)
22666#define QUADSPI_DCR_CSHT QUADSPI_DCR_CSHT_Msk
22667#define QUADSPI_DCR_CSHT_0 (0x1UL << QUADSPI_DCR_CSHT_Pos)
22668#define QUADSPI_DCR_CSHT_1 (0x2UL << QUADSPI_DCR_CSHT_Pos)
22669#define QUADSPI_DCR_CSHT_2 (0x4UL << QUADSPI_DCR_CSHT_Pos)
22670#define QUADSPI_DCR_FSIZE_Pos (16U)
22671#define QUADSPI_DCR_FSIZE_Msk (0x1FUL << QUADSPI_DCR_FSIZE_Pos)
22672#define QUADSPI_DCR_FSIZE QUADSPI_DCR_FSIZE_Msk
22673#define QUADSPI_DCR_FSIZE_0 (0x01UL << QUADSPI_DCR_FSIZE_Pos)
22674#define QUADSPI_DCR_FSIZE_1 (0x02UL << QUADSPI_DCR_FSIZE_Pos)
22675#define QUADSPI_DCR_FSIZE_2 (0x04UL << QUADSPI_DCR_FSIZE_Pos)
22676#define QUADSPI_DCR_FSIZE_3 (0x08UL << QUADSPI_DCR_FSIZE_Pos)
22677#define QUADSPI_DCR_FSIZE_4 (0x10UL << QUADSPI_DCR_FSIZE_Pos)
22679/****************** Bit definition for QUADSPI_SR register *******************/
22680#define QUADSPI_SR_TEF_Pos (0U)
22681#define QUADSPI_SR_TEF_Msk (0x1UL << QUADSPI_SR_TEF_Pos)
22682#define QUADSPI_SR_TEF QUADSPI_SR_TEF_Msk
22683#define QUADSPI_SR_TCF_Pos (1U)
22684#define QUADSPI_SR_TCF_Msk (0x1UL << QUADSPI_SR_TCF_Pos)
22685#define QUADSPI_SR_TCF QUADSPI_SR_TCF_Msk
22686#define QUADSPI_SR_FTF_Pos (2U)
22687#define QUADSPI_SR_FTF_Msk (0x1UL << QUADSPI_SR_FTF_Pos)
22688#define QUADSPI_SR_FTF QUADSPI_SR_FTF_Msk
22689#define QUADSPI_SR_SMF_Pos (3U)
22690#define QUADSPI_SR_SMF_Msk (0x1UL << QUADSPI_SR_SMF_Pos)
22691#define QUADSPI_SR_SMF QUADSPI_SR_SMF_Msk
22692#define QUADSPI_SR_TOF_Pos (4U)
22693#define QUADSPI_SR_TOF_Msk (0x1UL << QUADSPI_SR_TOF_Pos)
22694#define QUADSPI_SR_TOF QUADSPI_SR_TOF_Msk
22695#define QUADSPI_SR_BUSY_Pos (5U)
22696#define QUADSPI_SR_BUSY_Msk (0x1UL << QUADSPI_SR_BUSY_Pos)
22697#define QUADSPI_SR_BUSY QUADSPI_SR_BUSY_Msk
22698#define QUADSPI_SR_FLEVEL_Pos (8U)
22699#define QUADSPI_SR_FLEVEL_Msk (0x3FUL << QUADSPI_SR_FLEVEL_Pos)
22700#define QUADSPI_SR_FLEVEL QUADSPI_SR_FLEVEL_Msk
22701#define QUADSPI_SR_FLEVEL_0 (0x01UL << QUADSPI_SR_FLEVEL_Pos)
22702#define QUADSPI_SR_FLEVEL_1 (0x02UL << QUADSPI_SR_FLEVEL_Pos)
22703#define QUADSPI_SR_FLEVEL_2 (0x04UL << QUADSPI_SR_FLEVEL_Pos)
22704#define QUADSPI_SR_FLEVEL_3 (0x08UL << QUADSPI_SR_FLEVEL_Pos)
22705#define QUADSPI_SR_FLEVEL_4 (0x10UL << QUADSPI_SR_FLEVEL_Pos)
22706#define QUADSPI_SR_FLEVEL_5 (0x20UL << QUADSPI_SR_FLEVEL_Pos)
22708/****************** Bit definition for QUADSPI_FCR register ******************/
22709#define QUADSPI_FCR_CTEF_Pos (0U)
22710#define QUADSPI_FCR_CTEF_Msk (0x1UL << QUADSPI_FCR_CTEF_Pos)
22711#define QUADSPI_FCR_CTEF QUADSPI_FCR_CTEF_Msk
22712#define QUADSPI_FCR_CTCF_Pos (1U)
22713#define QUADSPI_FCR_CTCF_Msk (0x1UL << QUADSPI_FCR_CTCF_Pos)
22714#define QUADSPI_FCR_CTCF QUADSPI_FCR_CTCF_Msk
22715#define QUADSPI_FCR_CSMF_Pos (3U)
22716#define QUADSPI_FCR_CSMF_Msk (0x1UL << QUADSPI_FCR_CSMF_Pos)
22717#define QUADSPI_FCR_CSMF QUADSPI_FCR_CSMF_Msk
22718#define QUADSPI_FCR_CTOF_Pos (4U)
22719#define QUADSPI_FCR_CTOF_Msk (0x1UL << QUADSPI_FCR_CTOF_Pos)
22720#define QUADSPI_FCR_CTOF QUADSPI_FCR_CTOF_Msk
22722/****************** Bit definition for QUADSPI_DLR register ******************/
22723#define QUADSPI_DLR_DL_Pos (0U)
22724#define QUADSPI_DLR_DL_Msk (0xFFFFFFFFUL << QUADSPI_DLR_DL_Pos)
22725#define QUADSPI_DLR_DL QUADSPI_DLR_DL_Msk
22727/****************** Bit definition for QUADSPI_CCR register ******************/
22728#define QUADSPI_CCR_INSTRUCTION_Pos (0U)
22729#define QUADSPI_CCR_INSTRUCTION_Msk (0xFFUL << QUADSPI_CCR_INSTRUCTION_Pos)
22730#define QUADSPI_CCR_INSTRUCTION QUADSPI_CCR_INSTRUCTION_Msk
22731#define QUADSPI_CCR_INSTRUCTION_0 (0x01UL << QUADSPI_CCR_INSTRUCTION_Pos)
22732#define QUADSPI_CCR_INSTRUCTION_1 (0x02UL << QUADSPI_CCR_INSTRUCTION_Pos)
22733#define QUADSPI_CCR_INSTRUCTION_2 (0x04UL << QUADSPI_CCR_INSTRUCTION_Pos)
22734#define QUADSPI_CCR_INSTRUCTION_3 (0x08UL << QUADSPI_CCR_INSTRUCTION_Pos)
22735#define QUADSPI_CCR_INSTRUCTION_4 (0x10UL << QUADSPI_CCR_INSTRUCTION_Pos)
22736#define QUADSPI_CCR_INSTRUCTION_5 (0x20UL << QUADSPI_CCR_INSTRUCTION_Pos)
22737#define QUADSPI_CCR_INSTRUCTION_6 (0x40UL << QUADSPI_CCR_INSTRUCTION_Pos)
22738#define QUADSPI_CCR_INSTRUCTION_7 (0x80UL << QUADSPI_CCR_INSTRUCTION_Pos)
22739#define QUADSPI_CCR_IMODE_Pos (8U)
22740#define QUADSPI_CCR_IMODE_Msk (0x3UL << QUADSPI_CCR_IMODE_Pos)
22741#define QUADSPI_CCR_IMODE QUADSPI_CCR_IMODE_Msk
22742#define QUADSPI_CCR_IMODE_0 (0x1UL << QUADSPI_CCR_IMODE_Pos)
22743#define QUADSPI_CCR_IMODE_1 (0x2UL << QUADSPI_CCR_IMODE_Pos)
22744#define QUADSPI_CCR_ADMODE_Pos (10U)
22745#define QUADSPI_CCR_ADMODE_Msk (0x3UL << QUADSPI_CCR_ADMODE_Pos)
22746#define QUADSPI_CCR_ADMODE QUADSPI_CCR_ADMODE_Msk
22747#define QUADSPI_CCR_ADMODE_0 (0x1UL << QUADSPI_CCR_ADMODE_Pos)
22748#define QUADSPI_CCR_ADMODE_1 (0x2UL << QUADSPI_CCR_ADMODE_Pos)
22749#define QUADSPI_CCR_ADSIZE_Pos (12U)
22750#define QUADSPI_CCR_ADSIZE_Msk (0x3UL << QUADSPI_CCR_ADSIZE_Pos)
22751#define QUADSPI_CCR_ADSIZE QUADSPI_CCR_ADSIZE_Msk
22752#define QUADSPI_CCR_ADSIZE_0 (0x1UL << QUADSPI_CCR_ADSIZE_Pos)
22753#define QUADSPI_CCR_ADSIZE_1 (0x2UL << QUADSPI_CCR_ADSIZE_Pos)
22754#define QUADSPI_CCR_ABMODE_Pos (14U)
22755#define QUADSPI_CCR_ABMODE_Msk (0x3UL << QUADSPI_CCR_ABMODE_Pos)
22756#define QUADSPI_CCR_ABMODE QUADSPI_CCR_ABMODE_Msk
22757#define QUADSPI_CCR_ABMODE_0 (0x1UL << QUADSPI_CCR_ABMODE_Pos)
22758#define QUADSPI_CCR_ABMODE_1 (0x2UL << QUADSPI_CCR_ABMODE_Pos)
22759#define QUADSPI_CCR_ABSIZE_Pos (16U)
22760#define QUADSPI_CCR_ABSIZE_Msk (0x3UL << QUADSPI_CCR_ABSIZE_Pos)
22761#define QUADSPI_CCR_ABSIZE QUADSPI_CCR_ABSIZE_Msk
22762#define QUADSPI_CCR_ABSIZE_0 (0x1UL << QUADSPI_CCR_ABSIZE_Pos)
22763#define QUADSPI_CCR_ABSIZE_1 (0x2UL << QUADSPI_CCR_ABSIZE_Pos)
22764#define QUADSPI_CCR_DCYC_Pos (18U)
22765#define QUADSPI_CCR_DCYC_Msk (0x1FUL << QUADSPI_CCR_DCYC_Pos)
22766#define QUADSPI_CCR_DCYC QUADSPI_CCR_DCYC_Msk
22767#define QUADSPI_CCR_DCYC_0 (0x01UL << QUADSPI_CCR_DCYC_Pos)
22768#define QUADSPI_CCR_DCYC_1 (0x02UL << QUADSPI_CCR_DCYC_Pos)
22769#define QUADSPI_CCR_DCYC_2 (0x04UL << QUADSPI_CCR_DCYC_Pos)
22770#define QUADSPI_CCR_DCYC_3 (0x08UL << QUADSPI_CCR_DCYC_Pos)
22771#define QUADSPI_CCR_DCYC_4 (0x10UL << QUADSPI_CCR_DCYC_Pos)
22772#define QUADSPI_CCR_DMODE_Pos (24U)
22773#define QUADSPI_CCR_DMODE_Msk (0x3UL << QUADSPI_CCR_DMODE_Pos)
22774#define QUADSPI_CCR_DMODE QUADSPI_CCR_DMODE_Msk
22775#define QUADSPI_CCR_DMODE_0 (0x1UL << QUADSPI_CCR_DMODE_Pos)
22776#define QUADSPI_CCR_DMODE_1 (0x2UL << QUADSPI_CCR_DMODE_Pos)
22777#define QUADSPI_CCR_FMODE_Pos (26U)
22778#define QUADSPI_CCR_FMODE_Msk (0x3UL << QUADSPI_CCR_FMODE_Pos)
22779#define QUADSPI_CCR_FMODE QUADSPI_CCR_FMODE_Msk
22780#define QUADSPI_CCR_FMODE_0 (0x1UL << QUADSPI_CCR_FMODE_Pos)
22781#define QUADSPI_CCR_FMODE_1 (0x2UL << QUADSPI_CCR_FMODE_Pos)
22782#define QUADSPI_CCR_SIOO_Pos (28U)
22783#define QUADSPI_CCR_SIOO_Msk (0x1UL << QUADSPI_CCR_SIOO_Pos)
22784#define QUADSPI_CCR_SIOO QUADSPI_CCR_SIOO_Msk
22785#define QUADSPI_CCR_DHHC_Pos (30U)
22786#define QUADSPI_CCR_DHHC_Msk (0x1UL << QUADSPI_CCR_DHHC_Pos)
22787#define QUADSPI_CCR_DHHC QUADSPI_CCR_DHHC_Msk
22788#define QUADSPI_CCR_DDRM_Pos (31U)
22789#define QUADSPI_CCR_DDRM_Msk (0x1UL << QUADSPI_CCR_DDRM_Pos)
22790#define QUADSPI_CCR_DDRM QUADSPI_CCR_DDRM_Msk
22792/****************** Bit definition for QUADSPI_AR register *******************/
22793#define QUADSPI_AR_ADDRESS_Pos (0U)
22794#define QUADSPI_AR_ADDRESS_Msk (0xFFFFFFFFUL << QUADSPI_AR_ADDRESS_Pos)
22795#define QUADSPI_AR_ADDRESS QUADSPI_AR_ADDRESS_Msk
22797/****************** Bit definition for QUADSPI_ABR register ******************/
22798#define QUADSPI_ABR_ALTERNATE_Pos (0U)
22799#define QUADSPI_ABR_ALTERNATE_Msk (0xFFFFFFFFUL << QUADSPI_ABR_ALTERNATE_Pos)
22800#define QUADSPI_ABR_ALTERNATE QUADSPI_ABR_ALTERNATE_Msk
22802/****************** Bit definition for QUADSPI_DR register *******************/
22803#define QUADSPI_DR_DATA_Pos (0U)
22804#define QUADSPI_DR_DATA_Msk (0xFFFFFFFFUL << QUADSPI_DR_DATA_Pos)
22805#define QUADSPI_DR_DATA QUADSPI_DR_DATA_Msk
22807/****************** Bit definition for QUADSPI_PSMKR register ****************/
22808#define QUADSPI_PSMKR_MASK_Pos (0U)
22809#define QUADSPI_PSMKR_MASK_Msk (0xFFFFFFFFUL << QUADSPI_PSMKR_MASK_Pos)
22810#define QUADSPI_PSMKR_MASK QUADSPI_PSMKR_MASK_Msk
22812/****************** Bit definition for QUADSPI_PSMAR register ****************/
22813#define QUADSPI_PSMAR_MATCH_Pos (0U)
22814#define QUADSPI_PSMAR_MATCH_Msk (0xFFFFFFFFUL << QUADSPI_PSMAR_MATCH_Pos)
22815#define QUADSPI_PSMAR_MATCH QUADSPI_PSMAR_MATCH_Msk
22817/****************** Bit definition for QUADSPI_PIR register *****************/
22818#define QUADSPI_PIR_INTERVAL_Pos (0U)
22819#define QUADSPI_PIR_INTERVAL_Msk (0xFFFFUL << QUADSPI_PIR_INTERVAL_Pos)
22820#define QUADSPI_PIR_INTERVAL QUADSPI_PIR_INTERVAL_Msk
22822/****************** Bit definition for QUADSPI_LPTR register *****************/
22823#define QUADSPI_LPTR_TIMEOUT_Pos (0U)
22824#define QUADSPI_LPTR_TIMEOUT_Msk (0xFFFFUL << QUADSPI_LPTR_TIMEOUT_Pos)
22825#define QUADSPI_LPTR_TIMEOUT QUADSPI_LPTR_TIMEOUT_Msk
22827/******************************************************************************/
22828/* */
22829/* SYSCFG */
22830/* */
22831/******************************************************************************/
22832
22833/****************** Bit definition for SYSCFG_PMCR register ******************/
22834#define SYSCFG_PMCR_I2C1_FMP_Pos (0U)
22835#define SYSCFG_PMCR_I2C1_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C1_FMP_Pos)
22836#define SYSCFG_PMCR_I2C1_FMP SYSCFG_PMCR_I2C1_FMP_Msk
22837#define SYSCFG_PMCR_I2C2_FMP_Pos (1U)
22838#define SYSCFG_PMCR_I2C2_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C2_FMP_Pos)
22839#define SYSCFG_PMCR_I2C2_FMP SYSCFG_PMCR_I2C2_FMP_Msk
22840#define SYSCFG_PMCR_I2C3_FMP_Pos (2U)
22841#define SYSCFG_PMCR_I2C3_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C3_FMP_Pos)
22842#define SYSCFG_PMCR_I2C3_FMP SYSCFG_PMCR_I2C3_FMP_Msk
22843#define SYSCFG_PMCR_I2C4_FMP_Pos (3U)
22844#define SYSCFG_PMCR_I2C4_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C4_FMP_Pos)
22845#define SYSCFG_PMCR_I2C4_FMP SYSCFG_PMCR_I2C4_FMP_Msk
22846#define SYSCFG_PMCR_I2C_PB6_FMP_Pos (4U)
22847#define SYSCFG_PMCR_I2C_PB6_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB6_FMP_Pos)
22848#define SYSCFG_PMCR_I2C_PB6_FMP SYSCFG_PMCR_I2C_PB6_FMP_Msk
22849#define SYSCFG_PMCR_I2C_PB7_FMP_Pos (5U)
22850#define SYSCFG_PMCR_I2C_PB7_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB7_FMP_Pos)
22851#define SYSCFG_PMCR_I2C_PB7_FMP SYSCFG_PMCR_I2C_PB7_FMP_Msk
22852#define SYSCFG_PMCR_I2C_PB8_FMP_Pos (6U)
22853#define SYSCFG_PMCR_I2C_PB8_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB8_FMP_Pos)
22854#define SYSCFG_PMCR_I2C_PB8_FMP SYSCFG_PMCR_I2C_PB8_FMP_Msk
22855#define SYSCFG_PMCR_I2C_PB9_FMP_Pos (7U)
22856#define SYSCFG_PMCR_I2C_PB9_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB9_FMP_Pos)
22857#define SYSCFG_PMCR_I2C_PB9_FMP SYSCFG_PMCR_I2C_PB9_FMP_Msk
22858#define SYSCFG_PMCR_BOOSTEN_Pos (8U)
22859#define SYSCFG_PMCR_BOOSTEN_Msk (0x1UL << SYSCFG_PMCR_BOOSTEN_Pos)
22860#define SYSCFG_PMCR_BOOSTEN SYSCFG_PMCR_BOOSTEN_Msk
22862#define SYSCFG_PMCR_BOOSTVDDSEL_Pos (9U)
22863#define SYSCFG_PMCR_BOOSTVDDSEL_Msk (0x1UL << SYSCFG_PMCR_BOOSTVDDSEL_Pos)
22864#define SYSCFG_PMCR_BOOSTVDDSEL SYSCFG_PMCR_BOOSTVDDSEL_Msk
22866#define SYSCFG_PMCR_EPIS_SEL_Pos (21U)
22867#define SYSCFG_PMCR_EPIS_SEL_Msk (0x7UL << SYSCFG_PMCR_EPIS_SEL_Pos)
22868#define SYSCFG_PMCR_EPIS_SEL SYSCFG_PMCR_EPIS_SEL_Msk
22869#define SYSCFG_PMCR_EPIS_SEL_0 (0x1UL << SYSCFG_PMCR_EPIS_SEL_Pos)
22870#define SYSCFG_PMCR_EPIS_SEL_1 (0x2UL << SYSCFG_PMCR_EPIS_SEL_Pos)
22871#define SYSCFG_PMCR_EPIS_SEL_2 (0x4UL << SYSCFG_PMCR_EPIS_SEL_Pos)
22872#define SYSCFG_PMCR_PA0SO_Pos (24U)
22873#define SYSCFG_PMCR_PA0SO_Msk (0x1UL << SYSCFG_PMCR_PA0SO_Pos)
22874#define SYSCFG_PMCR_PA0SO SYSCFG_PMCR_PA0SO_Msk
22875#define SYSCFG_PMCR_PA1SO_Pos (25U)
22876#define SYSCFG_PMCR_PA1SO_Msk (0x1UL << SYSCFG_PMCR_PA1SO_Pos)
22877#define SYSCFG_PMCR_PA1SO SYSCFG_PMCR_PA1SO_Msk
22878#define SYSCFG_PMCR_PC2SO_Pos (26U)
22879#define SYSCFG_PMCR_PC2SO_Msk (0x1UL << SYSCFG_PMCR_PC2SO_Pos)
22880#define SYSCFG_PMCR_PC2SO SYSCFG_PMCR_PC2SO_Msk
22881#define SYSCFG_PMCR_PC3SO_Pos (27U)
22882#define SYSCFG_PMCR_PC3SO_Msk (0x1UL << SYSCFG_PMCR_PC3SO_Pos)
22883#define SYSCFG_PMCR_PC3SO SYSCFG_PMCR_PC3SO_Msk
22885/***************** Bit definition for SYSCFG_EXTICR1 register ***************/
22886#define SYSCFG_EXTICR1_EXTI0_Pos (0U)
22887#define SYSCFG_EXTICR1_EXTI0_Msk (0xFUL << SYSCFG_EXTICR1_EXTI0_Pos)
22888#define SYSCFG_EXTICR1_EXTI0 SYSCFG_EXTICR1_EXTI0_Msk
22889#define SYSCFG_EXTICR1_EXTI1_Pos (4U)
22890#define SYSCFG_EXTICR1_EXTI1_Msk (0xFUL << SYSCFG_EXTICR1_EXTI1_Pos)
22891#define SYSCFG_EXTICR1_EXTI1 SYSCFG_EXTICR1_EXTI1_Msk
22892#define SYSCFG_EXTICR1_EXTI2_Pos (8U)
22893#define SYSCFG_EXTICR1_EXTI2_Msk (0xFUL << SYSCFG_EXTICR1_EXTI2_Pos)
22894#define SYSCFG_EXTICR1_EXTI2 SYSCFG_EXTICR1_EXTI2_Msk
22895#define SYSCFG_EXTICR1_EXTI3_Pos (12U)
22896#define SYSCFG_EXTICR1_EXTI3_Msk (0xFUL << SYSCFG_EXTICR1_EXTI3_Pos)
22897#define SYSCFG_EXTICR1_EXTI3 SYSCFG_EXTICR1_EXTI3_Msk
22901#define SYSCFG_EXTICR1_EXTI0_PA (0U)
22902#define SYSCFG_EXTICR1_EXTI0_PB (0x00000001U)
22903#define SYSCFG_EXTICR1_EXTI0_PC (0x00000002U)
22904#define SYSCFG_EXTICR1_EXTI0_PD (0x00000003U)
22905#define SYSCFG_EXTICR1_EXTI0_PE (0x00000004U)
22906#define SYSCFG_EXTICR1_EXTI0_PF (0x00000005U)
22907#define SYSCFG_EXTICR1_EXTI0_PG (0x00000006U)
22908#define SYSCFG_EXTICR1_EXTI0_PH (0x00000007U)
22909#define SYSCFG_EXTICR1_EXTI0_PI (0x00000008U)
22910#define SYSCFG_EXTICR1_EXTI0_PJ (0x00000009U)
22911#define SYSCFG_EXTICR1_EXTI0_PK (0x0000000AU)
22916#define SYSCFG_EXTICR1_EXTI1_PA (0U)
22917#define SYSCFG_EXTICR1_EXTI1_PB (0x00000010U)
22918#define SYSCFG_EXTICR1_EXTI1_PC (0x00000020U)
22919#define SYSCFG_EXTICR1_EXTI1_PD (0x00000030U)
22920#define SYSCFG_EXTICR1_EXTI1_PE (0x00000040U)
22921#define SYSCFG_EXTICR1_EXTI1_PF (0x00000050U)
22922#define SYSCFG_EXTICR1_EXTI1_PG (0x00000060U)
22923#define SYSCFG_EXTICR1_EXTI1_PH (0x00000070U)
22924#define SYSCFG_EXTICR1_EXTI1_PI (0x00000080U)
22925#define SYSCFG_EXTICR1_EXTI1_PJ (0x00000090U)
22926#define SYSCFG_EXTICR1_EXTI1_PK (0x000000A0U)
22930#define SYSCFG_EXTICR1_EXTI2_PA (0U)
22931#define SYSCFG_EXTICR1_EXTI2_PB (0x00000100U)
22932#define SYSCFG_EXTICR1_EXTI2_PC (0x00000200U)
22933#define SYSCFG_EXTICR1_EXTI2_PD (0x00000300U)
22934#define SYSCFG_EXTICR1_EXTI2_PE (0x00000400U)
22935#define SYSCFG_EXTICR1_EXTI2_PF (0x00000500U)
22936#define SYSCFG_EXTICR1_EXTI2_PG (0x00000600U)
22937#define SYSCFG_EXTICR1_EXTI2_PH (0x00000700U)
22938#define SYSCFG_EXTICR1_EXTI2_PI (0x00000800U)
22939#define SYSCFG_EXTICR1_EXTI2_PJ (0x00000900U)
22940#define SYSCFG_EXTICR1_EXTI2_PK (0x00000A00U)
22945#define SYSCFG_EXTICR1_EXTI3_PA (0U)
22946#define SYSCFG_EXTICR1_EXTI3_PB (0x00001000U)
22947#define SYSCFG_EXTICR1_EXTI3_PC (0x00002000U)
22948#define SYSCFG_EXTICR1_EXTI3_PD (0x00003000U)
22949#define SYSCFG_EXTICR1_EXTI3_PE (0x00004000U)
22950#define SYSCFG_EXTICR1_EXTI3_PF (0x00005000U)
22951#define SYSCFG_EXTICR1_EXTI3_PG (0x00006000U)
22952#define SYSCFG_EXTICR1_EXTI3_PH (0x00007000U)
22953#define SYSCFG_EXTICR1_EXTI3_PI (0x00008000U)
22954#define SYSCFG_EXTICR1_EXTI3_PJ (0x00009000U)
22955#define SYSCFG_EXTICR1_EXTI3_PK (0x0000A000U)
22957/***************** Bit definition for SYSCFG_EXTICR2 register ***************/
22958#define SYSCFG_EXTICR2_EXTI4_Pos (0U)
22959#define SYSCFG_EXTICR2_EXTI4_Msk (0xFUL << SYSCFG_EXTICR2_EXTI4_Pos)
22960#define SYSCFG_EXTICR2_EXTI4 SYSCFG_EXTICR2_EXTI4_Msk
22961#define SYSCFG_EXTICR2_EXTI5_Pos (4U)
22962#define SYSCFG_EXTICR2_EXTI5_Msk (0xFUL << SYSCFG_EXTICR2_EXTI5_Pos)
22963#define SYSCFG_EXTICR2_EXTI5 SYSCFG_EXTICR2_EXTI5_Msk
22964#define SYSCFG_EXTICR2_EXTI6_Pos (8U)
22965#define SYSCFG_EXTICR2_EXTI6_Msk (0xFUL << SYSCFG_EXTICR2_EXTI6_Pos)
22966#define SYSCFG_EXTICR2_EXTI6 SYSCFG_EXTICR2_EXTI6_Msk
22967#define SYSCFG_EXTICR2_EXTI7_Pos (12U)
22968#define SYSCFG_EXTICR2_EXTI7_Msk (0xFUL << SYSCFG_EXTICR2_EXTI7_Pos)
22969#define SYSCFG_EXTICR2_EXTI7 SYSCFG_EXTICR2_EXTI7_Msk
22973#define SYSCFG_EXTICR2_EXTI4_PA (0U)
22974#define SYSCFG_EXTICR2_EXTI4_PB (0x00000001U)
22975#define SYSCFG_EXTICR2_EXTI4_PC (0x00000002U)
22976#define SYSCFG_EXTICR2_EXTI4_PD (0x00000003U)
22977#define SYSCFG_EXTICR2_EXTI4_PE (0x00000004U)
22978#define SYSCFG_EXTICR2_EXTI4_PF (0x00000005U)
22979#define SYSCFG_EXTICR2_EXTI4_PG (0x00000006U)
22980#define SYSCFG_EXTICR2_EXTI4_PH (0x00000007U)
22981#define SYSCFG_EXTICR2_EXTI4_PI (0x00000008U)
22982#define SYSCFG_EXTICR2_EXTI4_PJ (0x00000009U)
22983#define SYSCFG_EXTICR2_EXTI4_PK (0x0000000AU)
22987#define SYSCFG_EXTICR2_EXTI5_PA (0U)
22988#define SYSCFG_EXTICR2_EXTI5_PB (0x00000010U)
22989#define SYSCFG_EXTICR2_EXTI5_PC (0x00000020U)
22990#define SYSCFG_EXTICR2_EXTI5_PD (0x00000030U)
22991#define SYSCFG_EXTICR2_EXTI5_PE (0x00000040U)
22992#define SYSCFG_EXTICR2_EXTI5_PF (0x00000050U)
22993#define SYSCFG_EXTICR2_EXTI5_PG (0x00000060U)
22994#define SYSCFG_EXTICR2_EXTI5_PH (0x00000070U)
22995#define SYSCFG_EXTICR2_EXTI5_PI (0x00000080U)
22996#define SYSCFG_EXTICR2_EXTI5_PJ (0x00000090U)
22997#define SYSCFG_EXTICR2_EXTI5_PK (0x000000A0U)
23001#define SYSCFG_EXTICR2_EXTI6_PA (0U)
23002#define SYSCFG_EXTICR2_EXTI6_PB (0x00000100U)
23003#define SYSCFG_EXTICR2_EXTI6_PC (0x00000200U)
23004#define SYSCFG_EXTICR2_EXTI6_PD (0x00000300U)
23005#define SYSCFG_EXTICR2_EXTI6_PE (0x00000400U)
23006#define SYSCFG_EXTICR2_EXTI6_PF (0x00000500U)
23007#define SYSCFG_EXTICR2_EXTI6_PG (0x00000600U)
23008#define SYSCFG_EXTICR2_EXTI6_PH (0x00000700U)
23009#define SYSCFG_EXTICR2_EXTI6_PI (0x00000800U)
23010#define SYSCFG_EXTICR2_EXTI6_PJ (0x00000900U)
23011#define SYSCFG_EXTICR2_EXTI6_PK (0x00000A00U)
23016#define SYSCFG_EXTICR2_EXTI7_PA (0U)
23017#define SYSCFG_EXTICR2_EXTI7_PB (0x00001000U)
23018#define SYSCFG_EXTICR2_EXTI7_PC (0x00002000U)
23019#define SYSCFG_EXTICR2_EXTI7_PD (0x00003000U)
23020#define SYSCFG_EXTICR2_EXTI7_PE (0x00004000U)
23021#define SYSCFG_EXTICR2_EXTI7_PF (0x00005000U)
23022#define SYSCFG_EXTICR2_EXTI7_PG (0x00006000U)
23023#define SYSCFG_EXTICR2_EXTI7_PH (0x00007000U)
23024#define SYSCFG_EXTICR2_EXTI7_PI (0x00008000U)
23025#define SYSCFG_EXTICR2_EXTI7_PJ (0x00009000U)
23026#define SYSCFG_EXTICR2_EXTI7_PK (0x0000A000U)
23028/***************** Bit definition for SYSCFG_EXTICR3 register ***************/
23029#define SYSCFG_EXTICR3_EXTI8_Pos (0U)
23030#define SYSCFG_EXTICR3_EXTI8_Msk (0xFUL << SYSCFG_EXTICR3_EXTI8_Pos)
23031#define SYSCFG_EXTICR3_EXTI8 SYSCFG_EXTICR3_EXTI8_Msk
23032#define SYSCFG_EXTICR3_EXTI9_Pos (4U)
23033#define SYSCFG_EXTICR3_EXTI9_Msk (0xFUL << SYSCFG_EXTICR3_EXTI9_Pos)
23034#define SYSCFG_EXTICR3_EXTI9 SYSCFG_EXTICR3_EXTI9_Msk
23035#define SYSCFG_EXTICR3_EXTI10_Pos (8U)
23036#define SYSCFG_EXTICR3_EXTI10_Msk (0xFUL << SYSCFG_EXTICR3_EXTI10_Pos)
23037#define SYSCFG_EXTICR3_EXTI10 SYSCFG_EXTICR3_EXTI10_Msk
23038#define SYSCFG_EXTICR3_EXTI11_Pos (12U)
23039#define SYSCFG_EXTICR3_EXTI11_Msk (0xFUL << SYSCFG_EXTICR3_EXTI11_Pos)
23040#define SYSCFG_EXTICR3_EXTI11 SYSCFG_EXTICR3_EXTI11_Msk
23045#define SYSCFG_EXTICR3_EXTI8_PA (0U)
23046#define SYSCFG_EXTICR3_EXTI8_PB (0x00000001U)
23047#define SYSCFG_EXTICR3_EXTI8_PC (0x00000002U)
23048#define SYSCFG_EXTICR3_EXTI8_PD (0x00000003U)
23049#define SYSCFG_EXTICR3_EXTI8_PE (0x00000004U)
23050#define SYSCFG_EXTICR3_EXTI8_PF (0x00000005U)
23051#define SYSCFG_EXTICR3_EXTI8_PG (0x00000006U)
23052#define SYSCFG_EXTICR3_EXTI8_PH (0x00000007U)
23053#define SYSCFG_EXTICR3_EXTI8_PI (0x00000008U)
23054#define SYSCFG_EXTICR3_EXTI8_PJ (0x00000009U)
23055#define SYSCFG_EXTICR3_EXTI8_PK (0x0000000AU)
23060#define SYSCFG_EXTICR3_EXTI9_PA (0U)
23061#define SYSCFG_EXTICR3_EXTI9_PB (0x00000010U)
23062#define SYSCFG_EXTICR3_EXTI9_PC (0x00000020U)
23063#define SYSCFG_EXTICR3_EXTI9_PD (0x00000030U)
23064#define SYSCFG_EXTICR3_EXTI9_PE (0x00000040U)
23065#define SYSCFG_EXTICR3_EXTI9_PF (0x00000050U)
23066#define SYSCFG_EXTICR3_EXTI9_PG (0x00000060U)
23067#define SYSCFG_EXTICR3_EXTI9_PH (0x00000070U)
23068#define SYSCFG_EXTICR3_EXTI9_PI (0x00000080U)
23069#define SYSCFG_EXTICR3_EXTI9_PJ (0x00000090U)
23070#define SYSCFG_EXTICR3_EXTI9_PK (0x000000A0U)
23075#define SYSCFG_EXTICR3_EXTI10_PA (0U)
23076#define SYSCFG_EXTICR3_EXTI10_PB (0x00000100U)
23077#define SYSCFG_EXTICR3_EXTI10_PC (0x00000200U)
23078#define SYSCFG_EXTICR3_EXTI10_PD (0x00000300U)
23079#define SYSCFG_EXTICR3_EXTI10_PE (0x00000400U)
23080#define SYSCFG_EXTICR3_EXTI10_PF (0x00000500U)
23081#define SYSCFG_EXTICR3_EXTI10_PG (0x00000600U)
23082#define SYSCFG_EXTICR3_EXTI10_PH (0x00000700U)
23083#define SYSCFG_EXTICR3_EXTI10_PI (0x00000800U)
23084#define SYSCFG_EXTICR3_EXTI10_PJ (0x00000900U)
23085#define SYSCFG_EXTICR3_EXTI10_PK (0x00000A00U)
23090#define SYSCFG_EXTICR3_EXTI11_PA (0U)
23091#define SYSCFG_EXTICR3_EXTI11_PB (0x00001000U)
23092#define SYSCFG_EXTICR3_EXTI11_PC (0x00002000U)
23093#define SYSCFG_EXTICR3_EXTI11_PD (0x00003000U)
23094#define SYSCFG_EXTICR3_EXTI11_PE (0x00004000U)
23095#define SYSCFG_EXTICR3_EXTI11_PF (0x00005000U)
23096#define SYSCFG_EXTICR3_EXTI11_PG (0x00006000U)
23097#define SYSCFG_EXTICR3_EXTI11_PH (0x00007000U)
23098#define SYSCFG_EXTICR3_EXTI11_PI (0x00008000U)
23099#define SYSCFG_EXTICR3_EXTI11_PJ (0x00009000U)
23100#define SYSCFG_EXTICR3_EXTI11_PK (0x0000A000U)
23102/***************** Bit definition for SYSCFG_EXTICR4 register ***************/
23103#define SYSCFG_EXTICR4_EXTI12_Pos (0U)
23104#define SYSCFG_EXTICR4_EXTI12_Msk (0xFUL << SYSCFG_EXTICR4_EXTI12_Pos)
23105#define SYSCFG_EXTICR4_EXTI12 SYSCFG_EXTICR4_EXTI12_Msk
23106#define SYSCFG_EXTICR4_EXTI13_Pos (4U)
23107#define SYSCFG_EXTICR4_EXTI13_Msk (0xFUL << SYSCFG_EXTICR4_EXTI13_Pos)
23108#define SYSCFG_EXTICR4_EXTI13 SYSCFG_EXTICR4_EXTI13_Msk
23109#define SYSCFG_EXTICR4_EXTI14_Pos (8U)
23110#define SYSCFG_EXTICR4_EXTI14_Msk (0xFUL << SYSCFG_EXTICR4_EXTI14_Pos)
23111#define SYSCFG_EXTICR4_EXTI14 SYSCFG_EXTICR4_EXTI14_Msk
23112#define SYSCFG_EXTICR4_EXTI15_Pos (12U)
23113#define SYSCFG_EXTICR4_EXTI15_Msk (0xFUL << SYSCFG_EXTICR4_EXTI15_Pos)
23114#define SYSCFG_EXTICR4_EXTI15 SYSCFG_EXTICR4_EXTI15_Msk
23118#define SYSCFG_EXTICR4_EXTI12_PA (0U)
23119#define SYSCFG_EXTICR4_EXTI12_PB (0x00000001U)
23120#define SYSCFG_EXTICR4_EXTI12_PC (0x00000002U)
23121#define SYSCFG_EXTICR4_EXTI12_PD (0x00000003U)
23122#define SYSCFG_EXTICR4_EXTI12_PE (0x00000004U)
23123#define SYSCFG_EXTICR4_EXTI12_PF (0x00000005U)
23124#define SYSCFG_EXTICR4_EXTI12_PG (0x00000006U)
23125#define SYSCFG_EXTICR4_EXTI12_PH (0x00000007U)
23126#define SYSCFG_EXTICR4_EXTI12_PI (0x00000008U)
23127#define SYSCFG_EXTICR4_EXTI12_PJ (0x00000009U)
23128#define SYSCFG_EXTICR4_EXTI12_PK (0x0000000AU)
23132#define SYSCFG_EXTICR4_EXTI13_PA (0U)
23133#define SYSCFG_EXTICR4_EXTI13_PB (0x00000010U)
23134#define SYSCFG_EXTICR4_EXTI13_PC (0x00000020U)
23135#define SYSCFG_EXTICR4_EXTI13_PD (0x00000030U)
23136#define SYSCFG_EXTICR4_EXTI13_PE (0x00000040U)
23137#define SYSCFG_EXTICR4_EXTI13_PF (0x00000050U)
23138#define SYSCFG_EXTICR4_EXTI13_PG (0x00000060U)
23139#define SYSCFG_EXTICR4_EXTI13_PH (0x00000070U)
23140#define SYSCFG_EXTICR4_EXTI13_PI (0x00000080U)
23141#define SYSCFG_EXTICR4_EXTI13_PJ (0x00000090U)
23142#define SYSCFG_EXTICR4_EXTI13_PK (0x000000A0U)
23146#define SYSCFG_EXTICR4_EXTI14_PA (0U)
23147#define SYSCFG_EXTICR4_EXTI14_PB (0x00000100U)
23148#define SYSCFG_EXTICR4_EXTI14_PC (0x00000200U)
23149#define SYSCFG_EXTICR4_EXTI14_PD (0x00000300U)
23150#define SYSCFG_EXTICR4_EXTI14_PE (0x00000400U)
23151#define SYSCFG_EXTICR4_EXTI14_PF (0x00000500U)
23152#define SYSCFG_EXTICR4_EXTI14_PG (0x00000600U)
23153#define SYSCFG_EXTICR4_EXTI14_PH (0x00000700U)
23154#define SYSCFG_EXTICR4_EXTI14_PI (0x00000800U)
23155#define SYSCFG_EXTICR4_EXTI14_PJ (0x00000900U)
23156#define SYSCFG_EXTICR4_EXTI14_PK (0x00000A00U)
23160#define SYSCFG_EXTICR4_EXTI15_PA (0U)
23161#define SYSCFG_EXTICR4_EXTI15_PB (0x00001000U)
23162#define SYSCFG_EXTICR4_EXTI15_PC (0x00002000U)
23163#define SYSCFG_EXTICR4_EXTI15_PD (0x00003000U)
23164#define SYSCFG_EXTICR4_EXTI15_PE (0x00004000U)
23165#define SYSCFG_EXTICR4_EXTI15_PF (0x00005000U)
23166#define SYSCFG_EXTICR4_EXTI15_PG (0x00006000U)
23167#define SYSCFG_EXTICR4_EXTI15_PH (0x00007000U)
23168#define SYSCFG_EXTICR4_EXTI15_PI (0x00008000U)
23169#define SYSCFG_EXTICR4_EXTI15_PJ (0x00009000U)
23170#define SYSCFG_EXTICR4_EXTI15_PK (0x0000A000U)
23172/****************** Bit definition for SYSCFG_CFGR register ******************/
23173#define SYSCFG_CFGR_CM4L_Pos (0U)
23174#define SYSCFG_CFGR_CM4L_Msk (0x1UL << SYSCFG_CFGR_CM4L_Pos)
23175#define SYSCFG_CFGR_CM4L SYSCFG_CFGR_CM4L_Msk
23176#define SYSCFG_CFGR_PVDL_Pos (2U)
23177#define SYSCFG_CFGR_PVDL_Msk (0x1UL << SYSCFG_CFGR_PVDL_Pos)
23178#define SYSCFG_CFGR_PVDL SYSCFG_CFGR_PVDL_Msk
23179#define SYSCFG_CFGR_FLASHL_Pos (3U)
23180#define SYSCFG_CFGR_FLASHL_Msk (0x1UL << SYSCFG_CFGR_FLASHL_Pos)
23181#define SYSCFG_CFGR_FLASHL SYSCFG_CFGR_FLASHL_Msk
23182#define SYSCFG_CFGR_CM7L_Pos (6U)
23183#define SYSCFG_CFGR_CM7L_Msk (0x1UL << SYSCFG_CFGR_CM7L_Pos)
23184#define SYSCFG_CFGR_CM7L SYSCFG_CFGR_CM7L_Msk
23185#define SYSCFG_CFGR_BKRAML_Pos (7U)
23186#define SYSCFG_CFGR_BKRAML_Msk (0x1UL << SYSCFG_CFGR_BKRAML_Pos)
23187#define SYSCFG_CFGR_BKRAML SYSCFG_CFGR_BKRAML_Msk
23188#define SYSCFG_CFGR_SRAM4L_Pos (9U)
23189#define SYSCFG_CFGR_SRAM4L_Msk (0x1UL << SYSCFG_CFGR_SRAM4L_Pos)
23190#define SYSCFG_CFGR_SRAM4L SYSCFG_CFGR_SRAM4L_Msk
23191#define SYSCFG_CFGR_SRAM3L_Pos (10U)
23192#define SYSCFG_CFGR_SRAM3L_Msk (0x1UL << SYSCFG_CFGR_SRAM3L_Pos)
23193#define SYSCFG_CFGR_SRAM3L SYSCFG_CFGR_SRAM3L_Msk
23194#define SYSCFG_CFGR_SRAM2L_Pos (11U)
23195#define SYSCFG_CFGR_SRAM2L_Msk (0x1UL << SYSCFG_CFGR_SRAM2L_Pos)
23196#define SYSCFG_CFGR_SRAM2L SYSCFG_CFGR_SRAM2L_Msk
23197#define SYSCFG_CFGR_SRAM1L_Pos (12U)
23198#define SYSCFG_CFGR_SRAM1L_Msk (0x1UL << SYSCFG_CFGR_SRAM1L_Pos)
23199#define SYSCFG_CFGR_SRAM1L SYSCFG_CFGR_SRAM1L_Msk
23200#define SYSCFG_CFGR_DTCML_Pos (13U)
23201#define SYSCFG_CFGR_DTCML_Msk (0x1UL << SYSCFG_CFGR_DTCML_Pos)
23202#define SYSCFG_CFGR_DTCML SYSCFG_CFGR_DTCML_Msk
23203#define SYSCFG_CFGR_ITCML_Pos (14U)
23204#define SYSCFG_CFGR_ITCML_Msk (0x1UL << SYSCFG_CFGR_ITCML_Pos)
23205#define SYSCFG_CFGR_ITCML SYSCFG_CFGR_ITCML_Msk
23206#define SYSCFG_CFGR_AXISRAML_Pos (15U)
23207#define SYSCFG_CFGR_AXISRAML_Msk (0x1UL << SYSCFG_CFGR_AXISRAML_Pos)
23208#define SYSCFG_CFGR_AXISRAML SYSCFG_CFGR_AXISRAML_Msk
23210/****************** Bit definition for SYSCFG_CCCSR register ******************/
23211#define SYSCFG_CCCSR_EN_Pos (0U)
23212#define SYSCFG_CCCSR_EN_Msk (0x1UL << SYSCFG_CCCSR_EN_Pos)
23213#define SYSCFG_CCCSR_EN SYSCFG_CCCSR_EN_Msk
23214#define SYSCFG_CCCSR_CS_Pos (1U)
23215#define SYSCFG_CCCSR_CS_Msk (0x1UL << SYSCFG_CCCSR_CS_Pos)
23216#define SYSCFG_CCCSR_CS SYSCFG_CCCSR_CS_Msk
23217#define SYSCFG_CCCSR_READY_Pos (8U)
23218#define SYSCFG_CCCSR_READY_Msk (0x1UL << SYSCFG_CCCSR_READY_Pos)
23219#define SYSCFG_CCCSR_READY SYSCFG_CCCSR_READY_Msk
23220#define SYSCFG_CCCSR_HSLV_Pos (16U)
23221#define SYSCFG_CCCSR_HSLV_Msk (0x1UL << SYSCFG_CCCSR_HSLV_Pos)
23222#define SYSCFG_CCCSR_HSLV SYSCFG_CCCSR_HSLV_Msk
23224/****************** Bit definition for SYSCFG_CCVR register *******************/
23225#define SYSCFG_CCVR_NCV_Pos (0U)
23226#define SYSCFG_CCVR_NCV_Msk (0xFUL << SYSCFG_CCVR_NCV_Pos)
23227#define SYSCFG_CCVR_NCV SYSCFG_CCVR_NCV_Msk
23228#define SYSCFG_CCVR_PCV_Pos (4U)
23229#define SYSCFG_CCVR_PCV_Msk (0xFUL << SYSCFG_CCVR_PCV_Pos)
23230#define SYSCFG_CCVR_PCV SYSCFG_CCVR_PCV_Msk
23232/****************** Bit definition for SYSCFG_CCCR register *******************/
23233#define SYSCFG_CCCR_NCC_Pos (0U)
23234#define SYSCFG_CCCR_NCC_Msk (0xFUL << SYSCFG_CCCR_NCC_Pos)
23235#define SYSCFG_CCCR_NCC SYSCFG_CCCR_NCC_Msk
23236#define SYSCFG_CCCR_PCC_Pos (4U)
23237#define SYSCFG_CCCR_PCC_Msk (0xFUL << SYSCFG_CCCR_PCC_Pos)
23238#define SYSCFG_CCCR_PCC SYSCFG_CCCR_PCC_Msk
23239/****************** Bit definition for SYSCFG_PWRCR register *******************/
23240#define SYSCFG_PWRCR_ODEN_Pos (0U)
23241#define SYSCFG_PWRCR_ODEN_Msk (0x1UL << SYSCFG_PWRCR_ODEN_Pos)
23242#define SYSCFG_PWRCR_ODEN SYSCFG_PWRCR_ODEN_Msk
23244/****************** Bit definition for SYSCFG_PKGR register *******************/
23245#define SYSCFG_PKGR_PKG_Pos (0U)
23246#define SYSCFG_PKGR_PKG_Msk (0xFUL << SYSCFG_PKGR_PKG_Pos)
23247#define SYSCFG_PKGR_PKG SYSCFG_PKGR_PKG_Msk
23249/****************** Bit definition for SYSCFG_UR0 register *******************/
23250#define SYSCFG_UR0_BKS_Pos (0U)
23251#define SYSCFG_UR0_BKS_Msk (0x1UL << SYSCFG_UR0_BKS_Pos)
23252#define SYSCFG_UR0_BKS SYSCFG_UR0_BKS_Msk
23253#define SYSCFG_UR0_RDP_Pos (16U)
23254#define SYSCFG_UR0_RDP_Msk (0xFFUL << SYSCFG_UR0_RDP_Pos)
23255#define SYSCFG_UR0_RDP SYSCFG_UR0_RDP_Msk
23257/****************** Bit definition for SYSCFG_UR1 register *******************/
23258#define SYSCFG_UR1_BCM4_Pos (0U)
23259#define SYSCFG_UR1_BCM4_Msk (0x1UL << SYSCFG_UR1_BCM4_Pos)
23260#define SYSCFG_UR1_BCM4 SYSCFG_UR1_BCM4_Msk
23261#define SYSCFG_UR1_BCM7_Pos (16U)
23262#define SYSCFG_UR1_BCM7_Msk (0x1UL << SYSCFG_UR1_BCM7_Pos)
23263#define SYSCFG_UR1_BCM7 SYSCFG_UR1_BCM7_Msk
23264/****************** Bit definition for SYSCFG_UR2 register *******************/
23265#define SYSCFG_UR2_BORH_Pos (0U)
23266#define SYSCFG_UR2_BORH_Msk (0x3UL << SYSCFG_UR2_BORH_Pos)
23267#define SYSCFG_UR2_BORH SYSCFG_UR2_BORH_Msk
23268#define SYSCFG_UR2_BORH_0 (0x1UL << SYSCFG_UR2_BORH_Pos)
23269#define SYSCFG_UR2_BORH_1 (0x2UL << SYSCFG_UR2_BORH_Pos)
23270#define SYSCFG_UR2_BCM7_ADD0_Pos (16U)
23271#define SYSCFG_UR2_BCM7_ADD0_Msk (0xFFFFUL << SYSCFG_UR2_BCM7_ADD0_Pos)
23272#define SYSCFG_UR2_BCM7_ADD0 SYSCFG_UR2_BCM7_ADD0_Msk
23273/****************** Bit definition for SYSCFG_UR3 register *******************/
23274#define SYSCFG_UR3_BCM7_ADD1_Pos (0U)
23275#define SYSCFG_UR3_BCM7_ADD1_Msk (0xFFFFUL << SYSCFG_UR3_BCM7_ADD1_Pos)
23276#define SYSCFG_UR3_BCM7_ADD1 SYSCFG_UR3_BCM7_ADD1_Msk
23278#define SYSCFG_UR3_BCM4_ADD0_Pos (16U)
23279#define SYSCFG_UR3_BCM4_ADD0_Msk (0xFFFFUL << SYSCFG_UR3_BCM4_ADD0_Pos)
23280#define SYSCFG_UR3_BCM4_ADD0 SYSCFG_UR3_BCM4_ADD0_Msk
23282/****************** Bit definition for SYSCFG_UR4 register *******************/
23283
23284#define SYSCFG_UR4_BCM4_ADD1_Pos (0U)
23285#define SYSCFG_UR4_BCM4_ADD1_Msk (0xFFFFUL << SYSCFG_UR4_BCM4_ADD1_Pos)
23286#define SYSCFG_UR4_BCM4_ADD1 SYSCFG_UR4_BCM4_ADD1_Msk
23288#define SYSCFG_UR4_MEPAD_BANK1_Pos (16U)
23289#define SYSCFG_UR4_MEPAD_BANK1_Msk (0x1UL << SYSCFG_UR4_MEPAD_BANK1_Pos)
23290#define SYSCFG_UR4_MEPAD_BANK1 SYSCFG_UR4_MEPAD_BANK1_Msk
23292/****************** Bit definition for SYSCFG_UR5 register *******************/
23293#define SYSCFG_UR5_MESAD_BANK1_Pos (0U)
23294#define SYSCFG_UR5_MESAD_BANK1_Msk (0x1UL << SYSCFG_UR5_MESAD_BANK1_Pos)
23295#define SYSCFG_UR5_MESAD_BANK1 SYSCFG_UR5_MESAD_BANK1_Msk
23296#define SYSCFG_UR5_WRPN_BANK1_Pos (16U)
23297#define SYSCFG_UR5_WRPN_BANK1_Msk (0xFFUL << SYSCFG_UR5_WRPN_BANK1_Pos)
23298#define SYSCFG_UR5_WRPN_BANK1 SYSCFG_UR5_WRPN_BANK1_Msk
23300/****************** Bit definition for SYSCFG_UR6 register *******************/
23301#define SYSCFG_UR6_PABEG_BANK1_Pos (0U)
23302#define SYSCFG_UR6_PABEG_BANK1_Msk (0xFFFUL << SYSCFG_UR6_PABEG_BANK1_Pos)
23303#define SYSCFG_UR6_PABEG_BANK1 SYSCFG_UR6_PABEG_BANK1_Msk
23304#define SYSCFG_UR6_PAEND_BANK1_Pos (16U)
23305#define SYSCFG_UR6_PAEND_BANK1_Msk (0xFFFUL << SYSCFG_UR6_PAEND_BANK1_Pos)
23306#define SYSCFG_UR6_PAEND_BANK1 SYSCFG_UR6_PAEND_BANK1_Msk
23308/****************** Bit definition for SYSCFG_UR7 register *******************/
23309#define SYSCFG_UR7_SABEG_BANK1_Pos (0U)
23310#define SYSCFG_UR7_SABEG_BANK1_Msk (0xFFFUL << SYSCFG_UR7_SABEG_BANK1_Pos)
23311#define SYSCFG_UR7_SABEG_BANK1 SYSCFG_UR7_SABEG_BANK1_Msk
23312#define SYSCFG_UR7_SAEND_BANK1_Pos (16U)
23313#define SYSCFG_UR7_SAEND_BANK1_Msk (0xFFFUL << SYSCFG_UR7_SAEND_BANK1_Pos)
23314#define SYSCFG_UR7_SAEND_BANK1 SYSCFG_UR7_SAEND_BANK1_Msk
23316/****************** Bit definition for SYSCFG_UR8 register *******************/
23317#define SYSCFG_UR8_MEPAD_BANK2_Pos (0U)
23318#define SYSCFG_UR8_MEPAD_BANK2_Msk (0x1UL << SYSCFG_UR8_MEPAD_BANK2_Pos)
23319#define SYSCFG_UR8_MEPAD_BANK2 SYSCFG_UR8_MEPAD_BANK2_Msk
23320#define SYSCFG_UR8_MESAD_BANK2_Pos (16U)
23321#define SYSCFG_UR8_MESAD_BANK2_Msk (0x1UL << SYSCFG_UR8_MESAD_BANK2_Pos)
23322#define SYSCFG_UR8_MESAD_BANK2 SYSCFG_UR8_MESAD_BANK2_Msk
23324/****************** Bit definition for SYSCFG_UR9 register *******************/
23325#define SYSCFG_UR9_WRPN_BANK2_Pos (0U)
23326#define SYSCFG_UR9_WRPN_BANK2_Msk (0xFFUL << SYSCFG_UR9_WRPN_BANK2_Pos)
23327#define SYSCFG_UR9_WRPN_BANK2 SYSCFG_UR9_WRPN_BANK2_Msk
23328#define SYSCFG_UR9_PABEG_BANK2_Pos (16U)
23329#define SYSCFG_UR9_PABEG_BANK2_Msk (0xFFFUL << SYSCFG_UR9_PABEG_BANK2_Pos)
23330#define SYSCFG_UR9_PABEG_BANK2 SYSCFG_UR9_PABEG_BANK2_Msk
23332/****************** Bit definition for SYSCFG_UR10 register *******************/
23333#define SYSCFG_UR10_PAEND_BANK2_Pos (0U)
23334#define SYSCFG_UR10_PAEND_BANK2_Msk (0xFFFUL << SYSCFG_UR10_PAEND_BANK2_Pos)
23335#define SYSCFG_UR10_PAEND_BANK2 SYSCFG_UR10_PAEND_BANK2_Msk
23336#define SYSCFG_UR10_SABEG_BANK2_Pos (16U)
23337#define SYSCFG_UR10_SABEG_BANK2_Msk (0xFFFUL << SYSCFG_UR10_SABEG_BANK2_Pos)
23338#define SYSCFG_UR10_SABEG_BANK2 SYSCFG_UR10_SABEG_BANK2_Msk
23340/****************** Bit definition for SYSCFG_UR11 register *******************/
23341#define SYSCFG_UR11_SAEND_BANK2_Pos (0U)
23342#define SYSCFG_UR11_SAEND_BANK2_Msk (0xFFFUL << SYSCFG_UR11_SAEND_BANK2_Pos)
23343#define SYSCFG_UR11_SAEND_BANK2 SYSCFG_UR11_SAEND_BANK2_Msk
23344#define SYSCFG_UR11_IWDG1M_Pos (16U)
23345#define SYSCFG_UR11_IWDG1M_Msk (0x1UL << SYSCFG_UR11_IWDG1M_Pos)
23346#define SYSCFG_UR11_IWDG1M SYSCFG_UR11_IWDG1M_Msk
23348/****************** Bit definition for SYSCFG_UR12 register *******************/
23349#define SYSCFG_UR12_IWDG2M_Pos (0U)
23350#define SYSCFG_UR12_IWDG2M_Msk (0x1UL << SYSCFG_UR12_IWDG2M_Pos)
23351#define SYSCFG_UR12_IWDG2M SYSCFG_UR12_IWDG2M_Msk
23353#define SYSCFG_UR12_SECURE_Pos (16U)
23354#define SYSCFG_UR12_SECURE_Msk (0x1UL << SYSCFG_UR12_SECURE_Pos)
23355#define SYSCFG_UR12_SECURE SYSCFG_UR12_SECURE_Msk
23357/****************** Bit definition for SYSCFG_UR13 register *******************/
23358#define SYSCFG_UR13_SDRS_Pos (0U)
23359#define SYSCFG_UR13_SDRS_Msk (0x3UL << SYSCFG_UR13_SDRS_Pos)
23360#define SYSCFG_UR13_SDRS SYSCFG_UR13_SDRS_Msk
23361#define SYSCFG_UR13_D1SBRST_Pos (16U)
23362#define SYSCFG_UR13_D1SBRST_Msk (0x1UL << SYSCFG_UR13_D1SBRST_Pos)
23363#define SYSCFG_UR13_D1SBRST SYSCFG_UR13_D1SBRST_Msk
23365/****************** Bit definition for SYSCFG_UR14 register *******************/
23366#define SYSCFG_UR14_D1STPRST_Pos (0U)
23367#define SYSCFG_UR14_D1STPRST_Msk (0x1UL << SYSCFG_UR14_D1STPRST_Pos)
23368#define SYSCFG_UR14_D1STPRST SYSCFG_UR14_D1STPRST_Msk
23369#define SYSCFG_UR14_D2SBRST_Pos (16U)
23370#define SYSCFG_UR14_D2SBRST_Msk (0x1UL << SYSCFG_UR14_D2SBRST_Pos)
23371#define SYSCFG_UR14_D2SBRST SYSCFG_UR14_D2SBRST_Msk
23373/****************** Bit definition for SYSCFG_UR15 register *******************/
23374#define SYSCFG_UR15_D2STPRST_Pos (0U)
23375#define SYSCFG_UR15_D2STPRST_Msk (0x1UL << SYSCFG_UR15_D2STPRST_Pos)
23376#define SYSCFG_UR15_D2STPRST SYSCFG_UR15_D2STPRST_Msk
23377#define SYSCFG_UR15_FZIWDGSTB_Pos (16U)
23378#define SYSCFG_UR15_FZIWDGSTB_Msk (0x1UL << SYSCFG_UR15_FZIWDGSTB_Pos)
23379#define SYSCFG_UR15_FZIWDGSTB SYSCFG_UR15_FZIWDGSTB_Msk
23381/****************** Bit definition for SYSCFG_UR16 register *******************/
23382#define SYSCFG_UR16_FZIWDGSTP_Pos (0U)
23383#define SYSCFG_UR16_FZIWDGSTP_Msk (0x1UL << SYSCFG_UR16_FZIWDGSTP_Pos)
23384#define SYSCFG_UR16_FZIWDGSTP SYSCFG_UR16_FZIWDGSTP_Msk
23385#define SYSCFG_UR16_PKP_Pos (16U)
23386#define SYSCFG_UR16_PKP_Msk (0x1UL << SYSCFG_UR16_PKP_Pos)
23387#define SYSCFG_UR16_PKP SYSCFG_UR16_PKP_Msk
23389/****************** Bit definition for SYSCFG_UR17 register *******************/
23390#define SYSCFG_UR17_IOHSLV_Pos (0U)
23391#define SYSCFG_UR17_IOHSLV_Msk (0x1UL << SYSCFG_UR17_IOHSLV_Pos)
23392#define SYSCFG_UR17_IOHSLV SYSCFG_UR17_IOHSLV_Msk
23395/******************************************************************************/
23396/* */
23397/* TIM */
23398/* */
23399/******************************************************************************/
23400#define TIM_BREAK_INPUT_SUPPORT
23402/******************* Bit definition for TIM_CR1 register ********************/
23403#define TIM_CR1_CEN_Pos (0U)
23404#define TIM_CR1_CEN_Msk (0x1UL << TIM_CR1_CEN_Pos)
23405#define TIM_CR1_CEN TIM_CR1_CEN_Msk
23406#define TIM_CR1_UDIS_Pos (1U)
23407#define TIM_CR1_UDIS_Msk (0x1UL << TIM_CR1_UDIS_Pos)
23408#define TIM_CR1_UDIS TIM_CR1_UDIS_Msk
23409#define TIM_CR1_URS_Pos (2U)
23410#define TIM_CR1_URS_Msk (0x1UL << TIM_CR1_URS_Pos)
23411#define TIM_CR1_URS TIM_CR1_URS_Msk
23412#define TIM_CR1_OPM_Pos (3U)
23413#define TIM_CR1_OPM_Msk (0x1UL << TIM_CR1_OPM_Pos)
23414#define TIM_CR1_OPM TIM_CR1_OPM_Msk
23415#define TIM_CR1_DIR_Pos (4U)
23416#define TIM_CR1_DIR_Msk (0x1UL << TIM_CR1_DIR_Pos)
23417#define TIM_CR1_DIR TIM_CR1_DIR_Msk
23419#define TIM_CR1_CMS_Pos (5U)
23420#define TIM_CR1_CMS_Msk (0x3UL << TIM_CR1_CMS_Pos)
23421#define TIM_CR1_CMS TIM_CR1_CMS_Msk
23422#define TIM_CR1_CMS_0 (0x1UL << TIM_CR1_CMS_Pos)
23423#define TIM_CR1_CMS_1 (0x2UL << TIM_CR1_CMS_Pos)
23425#define TIM_CR1_ARPE_Pos (7U)
23426#define TIM_CR1_ARPE_Msk (0x1UL << TIM_CR1_ARPE_Pos)
23427#define TIM_CR1_ARPE TIM_CR1_ARPE_Msk
23429#define TIM_CR1_CKD_Pos (8U)
23430#define TIM_CR1_CKD_Msk (0x3UL << TIM_CR1_CKD_Pos)
23431#define TIM_CR1_CKD TIM_CR1_CKD_Msk
23432#define TIM_CR1_CKD_0 (0x1UL << TIM_CR1_CKD_Pos)
23433#define TIM_CR1_CKD_1 (0x2UL << TIM_CR1_CKD_Pos)
23435#define TIM_CR1_UIFREMAP_Pos (11U)
23436#define TIM_CR1_UIFREMAP_Msk (0x1UL << TIM_CR1_UIFREMAP_Pos)
23437#define TIM_CR1_UIFREMAP TIM_CR1_UIFREMAP_Msk
23439/******************* Bit definition for TIM_CR2 register ********************/
23440#define TIM_CR2_CCPC_Pos (0U)
23441#define TIM_CR2_CCPC_Msk (0x1UL << TIM_CR2_CCPC_Pos)
23442#define TIM_CR2_CCPC TIM_CR2_CCPC_Msk
23443#define TIM_CR2_CCUS_Pos (2U)
23444#define TIM_CR2_CCUS_Msk (0x1UL << TIM_CR2_CCUS_Pos)
23445#define TIM_CR2_CCUS TIM_CR2_CCUS_Msk
23446#define TIM_CR2_CCDS_Pos (3U)
23447#define TIM_CR2_CCDS_Msk (0x1UL << TIM_CR2_CCDS_Pos)
23448#define TIM_CR2_CCDS TIM_CR2_CCDS_Msk
23450#define TIM_CR2_MMS_Pos (4U)
23451#define TIM_CR2_MMS_Msk (0x7UL << TIM_CR2_MMS_Pos)
23452#define TIM_CR2_MMS TIM_CR2_MMS_Msk
23453#define TIM_CR2_MMS_0 (0x1UL << TIM_CR2_MMS_Pos)
23454#define TIM_CR2_MMS_1 (0x2UL << TIM_CR2_MMS_Pos)
23455#define TIM_CR2_MMS_2 (0x4UL << TIM_CR2_MMS_Pos)
23457#define TIM_CR2_TI1S_Pos (7U)
23458#define TIM_CR2_TI1S_Msk (0x1UL << TIM_CR2_TI1S_Pos)
23459#define TIM_CR2_TI1S TIM_CR2_TI1S_Msk
23460#define TIM_CR2_OIS1_Pos (8U)
23461#define TIM_CR2_OIS1_Msk (0x1UL << TIM_CR2_OIS1_Pos)
23462#define TIM_CR2_OIS1 TIM_CR2_OIS1_Msk
23463#define TIM_CR2_OIS1N_Pos (9U)
23464#define TIM_CR2_OIS1N_Msk (0x1UL << TIM_CR2_OIS1N_Pos)
23465#define TIM_CR2_OIS1N TIM_CR2_OIS1N_Msk
23466#define TIM_CR2_OIS2_Pos (10U)
23467#define TIM_CR2_OIS2_Msk (0x1UL << TIM_CR2_OIS2_Pos)
23468#define TIM_CR2_OIS2 TIM_CR2_OIS2_Msk
23469#define TIM_CR2_OIS2N_Pos (11U)
23470#define TIM_CR2_OIS2N_Msk (0x1UL << TIM_CR2_OIS2N_Pos)
23471#define TIM_CR2_OIS2N TIM_CR2_OIS2N_Msk
23472#define TIM_CR2_OIS3_Pos (12U)
23473#define TIM_CR2_OIS3_Msk (0x1UL << TIM_CR2_OIS3_Pos)
23474#define TIM_CR2_OIS3 TIM_CR2_OIS3_Msk
23475#define TIM_CR2_OIS3N_Pos (13U)
23476#define TIM_CR2_OIS3N_Msk (0x1UL << TIM_CR2_OIS3N_Pos)
23477#define TIM_CR2_OIS3N TIM_CR2_OIS3N_Msk
23478#define TIM_CR2_OIS4_Pos (14U)
23479#define TIM_CR2_OIS4_Msk (0x1UL << TIM_CR2_OIS4_Pos)
23480#define TIM_CR2_OIS4 TIM_CR2_OIS4_Msk
23481#define TIM_CR2_OIS5_Pos (16U)
23482#define TIM_CR2_OIS5_Msk (0x1UL << TIM_CR2_OIS5_Pos)
23483#define TIM_CR2_OIS5 TIM_CR2_OIS5_Msk
23484#define TIM_CR2_OIS6_Pos (18U)
23485#define TIM_CR2_OIS6_Msk (0x1UL << TIM_CR2_OIS6_Pos)
23486#define TIM_CR2_OIS6 TIM_CR2_OIS6_Msk
23488#define TIM_CR2_MMS2_Pos (20U)
23489#define TIM_CR2_MMS2_Msk (0xFUL << TIM_CR2_MMS2_Pos)
23490#define TIM_CR2_MMS2 TIM_CR2_MMS2_Msk
23491#define TIM_CR2_MMS2_0 (0x1UL << TIM_CR2_MMS2_Pos)
23492#define TIM_CR2_MMS2_1 (0x2UL << TIM_CR2_MMS2_Pos)
23493#define TIM_CR2_MMS2_2 (0x4UL << TIM_CR2_MMS2_Pos)
23494#define TIM_CR2_MMS2_3 (0x8UL << TIM_CR2_MMS2_Pos)
23496/******************* Bit definition for TIM_SMCR register *******************/
23497#define TIM_SMCR_SMS_Pos (0U)
23498#define TIM_SMCR_SMS_Msk (0x10007UL << TIM_SMCR_SMS_Pos)
23499#define TIM_SMCR_SMS TIM_SMCR_SMS_Msk
23500#define TIM_SMCR_SMS_0 (0x00001UL << TIM_SMCR_SMS_Pos)
23501#define TIM_SMCR_SMS_1 (0x00002UL << TIM_SMCR_SMS_Pos)
23502#define TIM_SMCR_SMS_2 (0x00004UL << TIM_SMCR_SMS_Pos)
23503#define TIM_SMCR_SMS_3 (0x10000UL << TIM_SMCR_SMS_Pos)
23505#define TIM_SMCR_TS_Pos (4U)
23506#define TIM_SMCR_TS_Msk (0x30007UL << TIM_SMCR_TS_Pos)
23507#define TIM_SMCR_TS TIM_SMCR_TS_Msk
23508#define TIM_SMCR_TS_0 (0x00001UL << TIM_SMCR_TS_Pos)
23509#define TIM_SMCR_TS_1 (0x00002UL << TIM_SMCR_TS_Pos)
23510#define TIM_SMCR_TS_2 (0x00004UL << TIM_SMCR_TS_Pos)
23511#define TIM_SMCR_TS_3 (0x10000UL << TIM_SMCR_TS_Pos)
23512#define TIM_SMCR_TS_4 (0x20000UL << TIM_SMCR_TS_Pos)
23514#define TIM_SMCR_MSM_Pos (7U)
23515#define TIM_SMCR_MSM_Msk (0x1UL << TIM_SMCR_MSM_Pos)
23516#define TIM_SMCR_MSM TIM_SMCR_MSM_Msk
23518#define TIM_SMCR_ETF_Pos (8U)
23519#define TIM_SMCR_ETF_Msk (0xFUL << TIM_SMCR_ETF_Pos)
23520#define TIM_SMCR_ETF TIM_SMCR_ETF_Msk
23521#define TIM_SMCR_ETF_0 (0x1UL << TIM_SMCR_ETF_Pos)
23522#define TIM_SMCR_ETF_1 (0x2UL << TIM_SMCR_ETF_Pos)
23523#define TIM_SMCR_ETF_2 (0x4UL << TIM_SMCR_ETF_Pos)
23524#define TIM_SMCR_ETF_3 (0x8UL << TIM_SMCR_ETF_Pos)
23526#define TIM_SMCR_ETPS_Pos (12U)
23527#define TIM_SMCR_ETPS_Msk (0x3UL << TIM_SMCR_ETPS_Pos)
23528#define TIM_SMCR_ETPS TIM_SMCR_ETPS_Msk
23529#define TIM_SMCR_ETPS_0 (0x1UL << TIM_SMCR_ETPS_Pos)
23530#define TIM_SMCR_ETPS_1 (0x2UL << TIM_SMCR_ETPS_Pos)
23532#define TIM_SMCR_ECE_Pos (14U)
23533#define TIM_SMCR_ECE_Msk (0x1UL << TIM_SMCR_ECE_Pos)
23534#define TIM_SMCR_ECE TIM_SMCR_ECE_Msk
23535#define TIM_SMCR_ETP_Pos (15U)
23536#define TIM_SMCR_ETP_Msk (0x1UL << TIM_SMCR_ETP_Pos)
23537#define TIM_SMCR_ETP TIM_SMCR_ETP_Msk
23539/******************* Bit definition for TIM_DIER register *******************/
23540#define TIM_DIER_UIE_Pos (0U)
23541#define TIM_DIER_UIE_Msk (0x1UL << TIM_DIER_UIE_Pos)
23542#define TIM_DIER_UIE TIM_DIER_UIE_Msk
23543#define TIM_DIER_CC1IE_Pos (1U)
23544#define TIM_DIER_CC1IE_Msk (0x1UL << TIM_DIER_CC1IE_Pos)
23545#define TIM_DIER_CC1IE TIM_DIER_CC1IE_Msk
23546#define TIM_DIER_CC2IE_Pos (2U)
23547#define TIM_DIER_CC2IE_Msk (0x1UL << TIM_DIER_CC2IE_Pos)
23548#define TIM_DIER_CC2IE TIM_DIER_CC2IE_Msk
23549#define TIM_DIER_CC3IE_Pos (3U)
23550#define TIM_DIER_CC3IE_Msk (0x1UL << TIM_DIER_CC3IE_Pos)
23551#define TIM_DIER_CC3IE TIM_DIER_CC3IE_Msk
23552#define TIM_DIER_CC4IE_Pos (4U)
23553#define TIM_DIER_CC4IE_Msk (0x1UL << TIM_DIER_CC4IE_Pos)
23554#define TIM_DIER_CC4IE TIM_DIER_CC4IE_Msk
23555#define TIM_DIER_COMIE_Pos (5U)
23556#define TIM_DIER_COMIE_Msk (0x1UL << TIM_DIER_COMIE_Pos)
23557#define TIM_DIER_COMIE TIM_DIER_COMIE_Msk
23558#define TIM_DIER_TIE_Pos (6U)
23559#define TIM_DIER_TIE_Msk (0x1UL << TIM_DIER_TIE_Pos)
23560#define TIM_DIER_TIE TIM_DIER_TIE_Msk
23561#define TIM_DIER_BIE_Pos (7U)
23562#define TIM_DIER_BIE_Msk (0x1UL << TIM_DIER_BIE_Pos)
23563#define TIM_DIER_BIE TIM_DIER_BIE_Msk
23564#define TIM_DIER_UDE_Pos (8U)
23565#define TIM_DIER_UDE_Msk (0x1UL << TIM_DIER_UDE_Pos)
23566#define TIM_DIER_UDE TIM_DIER_UDE_Msk
23567#define TIM_DIER_CC1DE_Pos (9U)
23568#define TIM_DIER_CC1DE_Msk (0x1UL << TIM_DIER_CC1DE_Pos)
23569#define TIM_DIER_CC1DE TIM_DIER_CC1DE_Msk
23570#define TIM_DIER_CC2DE_Pos (10U)
23571#define TIM_DIER_CC2DE_Msk (0x1UL << TIM_DIER_CC2DE_Pos)
23572#define TIM_DIER_CC2DE TIM_DIER_CC2DE_Msk
23573#define TIM_DIER_CC3DE_Pos (11U)
23574#define TIM_DIER_CC3DE_Msk (0x1UL << TIM_DIER_CC3DE_Pos)
23575#define TIM_DIER_CC3DE TIM_DIER_CC3DE_Msk
23576#define TIM_DIER_CC4DE_Pos (12U)
23577#define TIM_DIER_CC4DE_Msk (0x1UL << TIM_DIER_CC4DE_Pos)
23578#define TIM_DIER_CC4DE TIM_DIER_CC4DE_Msk
23579#define TIM_DIER_COMDE_Pos (13U)
23580#define TIM_DIER_COMDE_Msk (0x1UL << TIM_DIER_COMDE_Pos)
23581#define TIM_DIER_COMDE TIM_DIER_COMDE_Msk
23582#define TIM_DIER_TDE_Pos (14U)
23583#define TIM_DIER_TDE_Msk (0x1UL << TIM_DIER_TDE_Pos)
23584#define TIM_DIER_TDE TIM_DIER_TDE_Msk
23586/******************** Bit definition for TIM_SR register ********************/
23587#define TIM_SR_UIF_Pos (0U)
23588#define TIM_SR_UIF_Msk (0x1UL << TIM_SR_UIF_Pos)
23589#define TIM_SR_UIF TIM_SR_UIF_Msk
23590#define TIM_SR_CC1IF_Pos (1U)
23591#define TIM_SR_CC1IF_Msk (0x1UL << TIM_SR_CC1IF_Pos)
23592#define TIM_SR_CC1IF TIM_SR_CC1IF_Msk
23593#define TIM_SR_CC2IF_Pos (2U)
23594#define TIM_SR_CC2IF_Msk (0x1UL << TIM_SR_CC2IF_Pos)
23595#define TIM_SR_CC2IF TIM_SR_CC2IF_Msk
23596#define TIM_SR_CC3IF_Pos (3U)
23597#define TIM_SR_CC3IF_Msk (0x1UL << TIM_SR_CC3IF_Pos)
23598#define TIM_SR_CC3IF TIM_SR_CC3IF_Msk
23599#define TIM_SR_CC4IF_Pos (4U)
23600#define TIM_SR_CC4IF_Msk (0x1UL << TIM_SR_CC4IF_Pos)
23601#define TIM_SR_CC4IF TIM_SR_CC4IF_Msk
23602#define TIM_SR_COMIF_Pos (5U)
23603#define TIM_SR_COMIF_Msk (0x1UL << TIM_SR_COMIF_Pos)
23604#define TIM_SR_COMIF TIM_SR_COMIF_Msk
23605#define TIM_SR_TIF_Pos (6U)
23606#define TIM_SR_TIF_Msk (0x1UL << TIM_SR_TIF_Pos)
23607#define TIM_SR_TIF TIM_SR_TIF_Msk
23608#define TIM_SR_BIF_Pos (7U)
23609#define TIM_SR_BIF_Msk (0x1UL << TIM_SR_BIF_Pos)
23610#define TIM_SR_BIF TIM_SR_BIF_Msk
23611#define TIM_SR_B2IF_Pos (8U)
23612#define TIM_SR_B2IF_Msk (0x1UL << TIM_SR_B2IF_Pos)
23613#define TIM_SR_B2IF TIM_SR_B2IF_Msk
23614#define TIM_SR_CC1OF_Pos (9U)
23615#define TIM_SR_CC1OF_Msk (0x1UL << TIM_SR_CC1OF_Pos)
23616#define TIM_SR_CC1OF TIM_SR_CC1OF_Msk
23617#define TIM_SR_CC2OF_Pos (10U)
23618#define TIM_SR_CC2OF_Msk (0x1UL << TIM_SR_CC2OF_Pos)
23619#define TIM_SR_CC2OF TIM_SR_CC2OF_Msk
23620#define TIM_SR_CC3OF_Pos (11U)
23621#define TIM_SR_CC3OF_Msk (0x1UL << TIM_SR_CC3OF_Pos)
23622#define TIM_SR_CC3OF TIM_SR_CC3OF_Msk
23623#define TIM_SR_CC4OF_Pos (12U)
23624#define TIM_SR_CC4OF_Msk (0x1UL << TIM_SR_CC4OF_Pos)
23625#define TIM_SR_CC4OF TIM_SR_CC4OF_Msk
23626#define TIM_SR_CC5IF_Pos (16U)
23627#define TIM_SR_CC5IF_Msk (0x1UL << TIM_SR_CC5IF_Pos)
23628#define TIM_SR_CC5IF TIM_SR_CC5IF_Msk
23629#define TIM_SR_CC6IF_Pos (17U)
23630#define TIM_SR_CC6IF_Msk (0x1UL << TIM_SR_CC6IF_Pos)
23631#define TIM_SR_CC6IF TIM_SR_CC6IF_Msk
23632#define TIM_SR_SBIF_Pos (13U)
23633#define TIM_SR_SBIF_Msk (0x1UL << TIM_SR_SBIF_Pos)
23634#define TIM_SR_SBIF TIM_SR_SBIF_Msk
23636/******************* Bit definition for TIM_EGR register ********************/
23637#define TIM_EGR_UG_Pos (0U)
23638#define TIM_EGR_UG_Msk (0x1UL << TIM_EGR_UG_Pos)
23639#define TIM_EGR_UG TIM_EGR_UG_Msk
23640#define TIM_EGR_CC1G_Pos (1U)
23641#define TIM_EGR_CC1G_Msk (0x1UL << TIM_EGR_CC1G_Pos)
23642#define TIM_EGR_CC1G TIM_EGR_CC1G_Msk
23643#define TIM_EGR_CC2G_Pos (2U)
23644#define TIM_EGR_CC2G_Msk (0x1UL << TIM_EGR_CC2G_Pos)
23645#define TIM_EGR_CC2G TIM_EGR_CC2G_Msk
23646#define TIM_EGR_CC3G_Pos (3U)
23647#define TIM_EGR_CC3G_Msk (0x1UL << TIM_EGR_CC3G_Pos)
23648#define TIM_EGR_CC3G TIM_EGR_CC3G_Msk
23649#define TIM_EGR_CC4G_Pos (4U)
23650#define TIM_EGR_CC4G_Msk (0x1UL << TIM_EGR_CC4G_Pos)
23651#define TIM_EGR_CC4G TIM_EGR_CC4G_Msk
23652#define TIM_EGR_COMG_Pos (5U)
23653#define TIM_EGR_COMG_Msk (0x1UL << TIM_EGR_COMG_Pos)
23654#define TIM_EGR_COMG TIM_EGR_COMG_Msk
23655#define TIM_EGR_TG_Pos (6U)
23656#define TIM_EGR_TG_Msk (0x1UL << TIM_EGR_TG_Pos)
23657#define TIM_EGR_TG TIM_EGR_TG_Msk
23658#define TIM_EGR_BG_Pos (7U)
23659#define TIM_EGR_BG_Msk (0x1UL << TIM_EGR_BG_Pos)
23660#define TIM_EGR_BG TIM_EGR_BG_Msk
23661#define TIM_EGR_B2G_Pos (8U)
23662#define TIM_EGR_B2G_Msk (0x1UL << TIM_EGR_B2G_Pos)
23663#define TIM_EGR_B2G TIM_EGR_B2G_Msk
23666/****************** Bit definition for TIM_CCMR1 register *******************/
23667#define TIM_CCMR1_CC1S_Pos (0U)
23668#define TIM_CCMR1_CC1S_Msk (0x3UL << TIM_CCMR1_CC1S_Pos)
23669#define TIM_CCMR1_CC1S TIM_CCMR1_CC1S_Msk
23670#define TIM_CCMR1_CC1S_0 (0x1UL << TIM_CCMR1_CC1S_Pos)
23671#define TIM_CCMR1_CC1S_1 (0x2UL << TIM_CCMR1_CC1S_Pos)
23673#define TIM_CCMR1_OC1FE_Pos (2U)
23674#define TIM_CCMR1_OC1FE_Msk (0x1UL << TIM_CCMR1_OC1FE_Pos)
23675#define TIM_CCMR1_OC1FE TIM_CCMR1_OC1FE_Msk
23676#define TIM_CCMR1_OC1PE_Pos (3U)
23677#define TIM_CCMR1_OC1PE_Msk (0x1UL << TIM_CCMR1_OC1PE_Pos)
23678#define TIM_CCMR1_OC1PE TIM_CCMR1_OC1PE_Msk
23680#define TIM_CCMR1_OC1M_Pos (4U)
23681#define TIM_CCMR1_OC1M_Msk (0x1007UL << TIM_CCMR1_OC1M_Pos)
23682#define TIM_CCMR1_OC1M TIM_CCMR1_OC1M_Msk
23683#define TIM_CCMR1_OC1M_0 (0x0001UL << TIM_CCMR1_OC1M_Pos)
23684#define TIM_CCMR1_OC1M_1 (0x0002UL << TIM_CCMR1_OC1M_Pos)
23685#define TIM_CCMR1_OC1M_2 (0x0004UL << TIM_CCMR1_OC1M_Pos)
23686#define TIM_CCMR1_OC1M_3 (0x1000UL << TIM_CCMR1_OC1M_Pos)
23688#define TIM_CCMR1_OC1CE_Pos (7U)
23689#define TIM_CCMR1_OC1CE_Msk (0x1UL << TIM_CCMR1_OC1CE_Pos)
23690#define TIM_CCMR1_OC1CE TIM_CCMR1_OC1CE_Msk
23692#define TIM_CCMR1_CC2S_Pos (8U)
23693#define TIM_CCMR1_CC2S_Msk (0x3UL << TIM_CCMR1_CC2S_Pos)
23694#define TIM_CCMR1_CC2S TIM_CCMR1_CC2S_Msk
23695#define TIM_CCMR1_CC2S_0 (0x1UL << TIM_CCMR1_CC2S_Pos)
23696#define TIM_CCMR1_CC2S_1 (0x2UL << TIM_CCMR1_CC2S_Pos)
23698#define TIM_CCMR1_OC2FE_Pos (10U)
23699#define TIM_CCMR1_OC2FE_Msk (0x1UL << TIM_CCMR1_OC2FE_Pos)
23700#define TIM_CCMR1_OC2FE TIM_CCMR1_OC2FE_Msk
23701#define TIM_CCMR1_OC2PE_Pos (11U)
23702#define TIM_CCMR1_OC2PE_Msk (0x1UL << TIM_CCMR1_OC2PE_Pos)
23703#define TIM_CCMR1_OC2PE TIM_CCMR1_OC2PE_Msk
23705#define TIM_CCMR1_OC2M_Pos (12U)
23706#define TIM_CCMR1_OC2M_Msk (0x1007UL << TIM_CCMR1_OC2M_Pos)
23707#define TIM_CCMR1_OC2M TIM_CCMR1_OC2M_Msk
23708#define TIM_CCMR1_OC2M_0 (0x0001UL << TIM_CCMR1_OC2M_Pos)
23709#define TIM_CCMR1_OC2M_1 (0x0002UL << TIM_CCMR1_OC2M_Pos)
23710#define TIM_CCMR1_OC2M_2 (0x0004UL << TIM_CCMR1_OC2M_Pos)
23711#define TIM_CCMR1_OC2M_3 (0x1000UL << TIM_CCMR1_OC2M_Pos)
23713#define TIM_CCMR1_OC2CE_Pos (15U)
23714#define TIM_CCMR1_OC2CE_Msk (0x1UL << TIM_CCMR1_OC2CE_Pos)
23715#define TIM_CCMR1_OC2CE TIM_CCMR1_OC2CE_Msk
23717/*----------------------------------------------------------------------------*/
23718
23719#define TIM_CCMR1_IC1PSC_Pos (2U)
23720#define TIM_CCMR1_IC1PSC_Msk (0x3UL << TIM_CCMR1_IC1PSC_Pos)
23721#define TIM_CCMR1_IC1PSC TIM_CCMR1_IC1PSC_Msk
23722#define TIM_CCMR1_IC1PSC_0 (0x1UL << TIM_CCMR1_IC1PSC_Pos)
23723#define TIM_CCMR1_IC1PSC_1 (0x2UL << TIM_CCMR1_IC1PSC_Pos)
23725#define TIM_CCMR1_IC1F_Pos (4U)
23726#define TIM_CCMR1_IC1F_Msk (0xFUL << TIM_CCMR1_IC1F_Pos)
23727#define TIM_CCMR1_IC1F TIM_CCMR1_IC1F_Msk
23728#define TIM_CCMR1_IC1F_0 (0x1UL << TIM_CCMR1_IC1F_Pos)
23729#define TIM_CCMR1_IC1F_1 (0x2UL << TIM_CCMR1_IC1F_Pos)
23730#define TIM_CCMR1_IC1F_2 (0x4UL << TIM_CCMR1_IC1F_Pos)
23731#define TIM_CCMR1_IC1F_3 (0x8UL << TIM_CCMR1_IC1F_Pos)
23733#define TIM_CCMR1_IC2PSC_Pos (10U)
23734#define TIM_CCMR1_IC2PSC_Msk (0x3UL << TIM_CCMR1_IC2PSC_Pos)
23735#define TIM_CCMR1_IC2PSC TIM_CCMR1_IC2PSC_Msk
23736#define TIM_CCMR1_IC2PSC_0 (0x1UL << TIM_CCMR1_IC2PSC_Pos)
23737#define TIM_CCMR1_IC2PSC_1 (0x2UL << TIM_CCMR1_IC2PSC_Pos)
23739#define TIM_CCMR1_IC2F_Pos (12U)
23740#define TIM_CCMR1_IC2F_Msk (0xFUL << TIM_CCMR1_IC2F_Pos)
23741#define TIM_CCMR1_IC2F TIM_CCMR1_IC2F_Msk
23742#define TIM_CCMR1_IC2F_0 (0x1UL << TIM_CCMR1_IC2F_Pos)
23743#define TIM_CCMR1_IC2F_1 (0x2UL << TIM_CCMR1_IC2F_Pos)
23744#define TIM_CCMR1_IC2F_2 (0x4UL << TIM_CCMR1_IC2F_Pos)
23745#define TIM_CCMR1_IC2F_3 (0x8UL << TIM_CCMR1_IC2F_Pos)
23747/****************** Bit definition for TIM_CCMR2 register *******************/
23748#define TIM_CCMR2_CC3S_Pos (0U)
23749#define TIM_CCMR2_CC3S_Msk (0x3UL << TIM_CCMR2_CC3S_Pos)
23750#define TIM_CCMR2_CC3S TIM_CCMR2_CC3S_Msk
23751#define TIM_CCMR2_CC3S_0 (0x1UL << TIM_CCMR2_CC3S_Pos)
23752#define TIM_CCMR2_CC3S_1 (0x2UL << TIM_CCMR2_CC3S_Pos)
23754#define TIM_CCMR2_OC3FE_Pos (2U)
23755#define TIM_CCMR2_OC3FE_Msk (0x1UL << TIM_CCMR2_OC3FE_Pos)
23756#define TIM_CCMR2_OC3FE TIM_CCMR2_OC3FE_Msk
23757#define TIM_CCMR2_OC3PE_Pos (3U)
23758#define TIM_CCMR2_OC3PE_Msk (0x1UL << TIM_CCMR2_OC3PE_Pos)
23759#define TIM_CCMR2_OC3PE TIM_CCMR2_OC3PE_Msk
23761#define TIM_CCMR2_OC3M_Pos (4U)
23762#define TIM_CCMR2_OC3M_Msk (0x1007UL << TIM_CCMR2_OC3M_Pos)
23763#define TIM_CCMR2_OC3M TIM_CCMR2_OC3M_Msk
23764#define TIM_CCMR2_OC3M_0 (0x1UL << TIM_CCMR2_OC3M_Pos)
23765#define TIM_CCMR2_OC3M_1 (0x2UL << TIM_CCMR2_OC3M_Pos)
23766#define TIM_CCMR2_OC3M_2 (0x4UL << TIM_CCMR2_OC3M_Pos)
23767#define TIM_CCMR2_OC3M_3 (0x1000UL << TIM_CCMR2_OC3M_Pos)
23769#define TIM_CCMR2_OC3CE_Pos (7U)
23770#define TIM_CCMR2_OC3CE_Msk (0x1UL << TIM_CCMR2_OC3CE_Pos)
23771#define TIM_CCMR2_OC3CE TIM_CCMR2_OC3CE_Msk
23773#define TIM_CCMR2_CC4S_Pos (8U)
23774#define TIM_CCMR2_CC4S_Msk (0x3UL << TIM_CCMR2_CC4S_Pos)
23775#define TIM_CCMR2_CC4S TIM_CCMR2_CC4S_Msk
23776#define TIM_CCMR2_CC4S_0 (0x1UL << TIM_CCMR2_CC4S_Pos)
23777#define TIM_CCMR2_CC4S_1 (0x2UL << TIM_CCMR2_CC4S_Pos)
23779#define TIM_CCMR2_OC4FE_Pos (10U)
23780#define TIM_CCMR2_OC4FE_Msk (0x1UL << TIM_CCMR2_OC4FE_Pos)
23781#define TIM_CCMR2_OC4FE TIM_CCMR2_OC4FE_Msk
23782#define TIM_CCMR2_OC4PE_Pos (11U)
23783#define TIM_CCMR2_OC4PE_Msk (0x1UL << TIM_CCMR2_OC4PE_Pos)
23784#define TIM_CCMR2_OC4PE TIM_CCMR2_OC4PE_Msk
23786#define TIM_CCMR2_OC4M_Pos (12U)
23787#define TIM_CCMR2_OC4M_Msk (0x1007UL << TIM_CCMR2_OC4M_Pos)
23788#define TIM_CCMR2_OC4M TIM_CCMR2_OC4M_Msk
23789#define TIM_CCMR2_OC4M_0 (0x1UL << TIM_CCMR2_OC4M_Pos)
23790#define TIM_CCMR2_OC4M_1 (0x2UL << TIM_CCMR2_OC4M_Pos)
23791#define TIM_CCMR2_OC4M_2 (0x4UL << TIM_CCMR2_OC4M_Pos)
23792#define TIM_CCMR2_OC4M_3 (0x1000UL << TIM_CCMR2_OC4M_Pos)
23794#define TIM_CCMR2_OC4CE_Pos (15U)
23795#define TIM_CCMR2_OC4CE_Msk (0x1UL << TIM_CCMR2_OC4CE_Pos)
23796#define TIM_CCMR2_OC4CE TIM_CCMR2_OC4CE_Msk
23798/*----------------------------------------------------------------------------*/
23799
23800#define TIM_CCMR2_IC3PSC_Pos (2U)
23801#define TIM_CCMR2_IC3PSC_Msk (0x3UL << TIM_CCMR2_IC3PSC_Pos)
23802#define TIM_CCMR2_IC3PSC TIM_CCMR2_IC3PSC_Msk
23803#define TIM_CCMR2_IC3PSC_0 (0x1UL << TIM_CCMR2_IC3PSC_Pos)
23804#define TIM_CCMR2_IC3PSC_1 (0x2UL << TIM_CCMR2_IC3PSC_Pos)
23806#define TIM_CCMR2_IC3F_Pos (4U)
23807#define TIM_CCMR2_IC3F_Msk (0xFUL << TIM_CCMR2_IC3F_Pos)
23808#define TIM_CCMR2_IC3F TIM_CCMR2_IC3F_Msk
23809#define TIM_CCMR2_IC3F_0 (0x1UL << TIM_CCMR2_IC3F_Pos)
23810#define TIM_CCMR2_IC3F_1 (0x2UL << TIM_CCMR2_IC3F_Pos)
23811#define TIM_CCMR2_IC3F_2 (0x4UL << TIM_CCMR2_IC3F_Pos)
23812#define TIM_CCMR2_IC3F_3 (0x8UL << TIM_CCMR2_IC3F_Pos)
23814#define TIM_CCMR2_IC4PSC_Pos (10U)
23815#define TIM_CCMR2_IC4PSC_Msk (0x3UL << TIM_CCMR2_IC4PSC_Pos)
23816#define TIM_CCMR2_IC4PSC TIM_CCMR2_IC4PSC_Msk
23817#define TIM_CCMR2_IC4PSC_0 (0x1UL << TIM_CCMR2_IC4PSC_Pos)
23818#define TIM_CCMR2_IC4PSC_1 (0x2UL << TIM_CCMR2_IC4PSC_Pos)
23820#define TIM_CCMR2_IC4F_Pos (12U)
23821#define TIM_CCMR2_IC4F_Msk (0xFUL << TIM_CCMR2_IC4F_Pos)
23822#define TIM_CCMR2_IC4F TIM_CCMR2_IC4F_Msk
23823#define TIM_CCMR2_IC4F_0 (0x1UL << TIM_CCMR2_IC4F_Pos)
23824#define TIM_CCMR2_IC4F_1 (0x2UL << TIM_CCMR2_IC4F_Pos)
23825#define TIM_CCMR2_IC4F_2 (0x4UL << TIM_CCMR2_IC4F_Pos)
23826#define TIM_CCMR2_IC4F_3 (0x8UL << TIM_CCMR2_IC4F_Pos)
23828/******************* Bit definition for TIM_CCER register *******************/
23829#define TIM_CCER_CC1E_Pos (0U)
23830#define TIM_CCER_CC1E_Msk (0x1UL << TIM_CCER_CC1E_Pos)
23831#define TIM_CCER_CC1E TIM_CCER_CC1E_Msk
23832#define TIM_CCER_CC1P_Pos (1U)
23833#define TIM_CCER_CC1P_Msk (0x1UL << TIM_CCER_CC1P_Pos)
23834#define TIM_CCER_CC1P TIM_CCER_CC1P_Msk
23835#define TIM_CCER_CC1NE_Pos (2U)
23836#define TIM_CCER_CC1NE_Msk (0x1UL << TIM_CCER_CC1NE_Pos)
23837#define TIM_CCER_CC1NE TIM_CCER_CC1NE_Msk
23838#define TIM_CCER_CC1NP_Pos (3U)
23839#define TIM_CCER_CC1NP_Msk (0x1UL << TIM_CCER_CC1NP_Pos)
23840#define TIM_CCER_CC1NP TIM_CCER_CC1NP_Msk
23841#define TIM_CCER_CC2E_Pos (4U)
23842#define TIM_CCER_CC2E_Msk (0x1UL << TIM_CCER_CC2E_Pos)
23843#define TIM_CCER_CC2E TIM_CCER_CC2E_Msk
23844#define TIM_CCER_CC2P_Pos (5U)
23845#define TIM_CCER_CC2P_Msk (0x1UL << TIM_CCER_CC2P_Pos)
23846#define TIM_CCER_CC2P TIM_CCER_CC2P_Msk
23847#define TIM_CCER_CC2NE_Pos (6U)
23848#define TIM_CCER_CC2NE_Msk (0x1UL << TIM_CCER_CC2NE_Pos)
23849#define TIM_CCER_CC2NE TIM_CCER_CC2NE_Msk
23850#define TIM_CCER_CC2NP_Pos (7U)
23851#define TIM_CCER_CC2NP_Msk (0x1UL << TIM_CCER_CC2NP_Pos)
23852#define TIM_CCER_CC2NP TIM_CCER_CC2NP_Msk
23853#define TIM_CCER_CC3E_Pos (8U)
23854#define TIM_CCER_CC3E_Msk (0x1UL << TIM_CCER_CC3E_Pos)
23855#define TIM_CCER_CC3E TIM_CCER_CC3E_Msk
23856#define TIM_CCER_CC3P_Pos (9U)
23857#define TIM_CCER_CC3P_Msk (0x1UL << TIM_CCER_CC3P_Pos)
23858#define TIM_CCER_CC3P TIM_CCER_CC3P_Msk
23859#define TIM_CCER_CC3NE_Pos (10U)
23860#define TIM_CCER_CC3NE_Msk (0x1UL << TIM_CCER_CC3NE_Pos)
23861#define TIM_CCER_CC3NE TIM_CCER_CC3NE_Msk
23862#define TIM_CCER_CC3NP_Pos (11U)
23863#define TIM_CCER_CC3NP_Msk (0x1UL << TIM_CCER_CC3NP_Pos)
23864#define TIM_CCER_CC3NP TIM_CCER_CC3NP_Msk
23865#define TIM_CCER_CC4E_Pos (12U)
23866#define TIM_CCER_CC4E_Msk (0x1UL << TIM_CCER_CC4E_Pos)
23867#define TIM_CCER_CC4E TIM_CCER_CC4E_Msk
23868#define TIM_CCER_CC4P_Pos (13U)
23869#define TIM_CCER_CC4P_Msk (0x1UL << TIM_CCER_CC4P_Pos)
23870#define TIM_CCER_CC4P TIM_CCER_CC4P_Msk
23871#define TIM_CCER_CC4NP_Pos (15U)
23872#define TIM_CCER_CC4NP_Msk (0x1UL << TIM_CCER_CC4NP_Pos)
23873#define TIM_CCER_CC4NP TIM_CCER_CC4NP_Msk
23874#define TIM_CCER_CC5E_Pos (16U)
23875#define TIM_CCER_CC5E_Msk (0x1UL << TIM_CCER_CC5E_Pos)
23876#define TIM_CCER_CC5E TIM_CCER_CC5E_Msk
23877#define TIM_CCER_CC5P_Pos (17U)
23878#define TIM_CCER_CC5P_Msk (0x1UL << TIM_CCER_CC5P_Pos)
23879#define TIM_CCER_CC5P TIM_CCER_CC5P_Msk
23880#define TIM_CCER_CC6E_Pos (20U)
23881#define TIM_CCER_CC6E_Msk (0x1UL << TIM_CCER_CC6E_Pos)
23882#define TIM_CCER_CC6E TIM_CCER_CC6E_Msk
23883#define TIM_CCER_CC6P_Pos (21U)
23884#define TIM_CCER_CC6P_Msk (0x1UL << TIM_CCER_CC6P_Pos)
23885#define TIM_CCER_CC6P TIM_CCER_CC6P_Msk
23886/******************* Bit definition for TIM_CNT register ********************/
23887#define TIM_CNT_CNT_Pos (0U)
23888#define TIM_CNT_CNT_Msk (0xFFFFFFFFUL << TIM_CNT_CNT_Pos)
23889#define TIM_CNT_CNT TIM_CNT_CNT_Msk
23890#define TIM_CNT_UIFCPY_Pos (31U)
23891#define TIM_CNT_UIFCPY_Msk (0x1UL << TIM_CNT_UIFCPY_Pos)
23892#define TIM_CNT_UIFCPY TIM_CNT_UIFCPY_Msk
23893/******************* Bit definition for TIM_PSC register ********************/
23894#define TIM_PSC_PSC_Pos (0U)
23895#define TIM_PSC_PSC_Msk (0xFFFFUL << TIM_PSC_PSC_Pos)
23896#define TIM_PSC_PSC TIM_PSC_PSC_Msk
23898/******************* Bit definition for TIM_ARR register ********************/
23899#define TIM_ARR_ARR_Pos (0U)
23900#define TIM_ARR_ARR_Msk (0xFFFFFFFFUL << TIM_ARR_ARR_Pos)
23901#define TIM_ARR_ARR TIM_ARR_ARR_Msk
23903/******************* Bit definition for TIM_RCR register ********************/
23904#define TIM_RCR_REP_Pos (0U)
23905#define TIM_RCR_REP_Msk (0xFFUL << TIM_RCR_REP_Pos)
23906#define TIM_RCR_REP TIM_RCR_REP_Msk
23908/******************* Bit definition for TIM_CCR1 register *******************/
23909#define TIM_CCR1_CCR1_Pos (0U)
23910#define TIM_CCR1_CCR1_Msk (0xFFFFUL << TIM_CCR1_CCR1_Pos)
23911#define TIM_CCR1_CCR1 TIM_CCR1_CCR1_Msk
23913/******************* Bit definition for TIM_CCR2 register *******************/
23914#define TIM_CCR2_CCR2_Pos (0U)
23915#define TIM_CCR2_CCR2_Msk (0xFFFFUL << TIM_CCR2_CCR2_Pos)
23916#define TIM_CCR2_CCR2 TIM_CCR2_CCR2_Msk
23918/******************* Bit definition for TIM_CCR3 register *******************/
23919#define TIM_CCR3_CCR3_Pos (0U)
23920#define TIM_CCR3_CCR3_Msk (0xFFFFUL << TIM_CCR3_CCR3_Pos)
23921#define TIM_CCR3_CCR3 TIM_CCR3_CCR3_Msk
23923/******************* Bit definition for TIM_CCR4 register *******************/
23924#define TIM_CCR4_CCR4_Pos (0U)
23925#define TIM_CCR4_CCR4_Msk (0xFFFFUL << TIM_CCR4_CCR4_Pos)
23926#define TIM_CCR4_CCR4 TIM_CCR4_CCR4_Msk
23928/******************* Bit definition for TIM_CCR5 register *******************/
23929#define TIM_CCR5_CCR5_Pos (0U)
23930#define TIM_CCR5_CCR5_Msk (0xFFFFFFFFUL << TIM_CCR5_CCR5_Pos)
23931#define TIM_CCR5_CCR5 TIM_CCR5_CCR5_Msk
23932#define TIM_CCR5_GC5C1_Pos (29U)
23933#define TIM_CCR5_GC5C1_Msk (0x1UL << TIM_CCR5_GC5C1_Pos)
23934#define TIM_CCR5_GC5C1 TIM_CCR5_GC5C1_Msk
23935#define TIM_CCR5_GC5C2_Pos (30U)
23936#define TIM_CCR5_GC5C2_Msk (0x1UL << TIM_CCR5_GC5C2_Pos)
23937#define TIM_CCR5_GC5C2 TIM_CCR5_GC5C2_Msk
23938#define TIM_CCR5_GC5C3_Pos (31U)
23939#define TIM_CCR5_GC5C3_Msk (0x1UL << TIM_CCR5_GC5C3_Pos)
23940#define TIM_CCR5_GC5C3 TIM_CCR5_GC5C3_Msk
23942/******************* Bit definition for TIM_CCR6 register *******************/
23943#define TIM_CCR6_CCR6_Pos (0U)
23944#define TIM_CCR6_CCR6_Msk (0xFFFFUL << TIM_CCR6_CCR6_Pos)
23945#define TIM_CCR6_CCR6 TIM_CCR6_CCR6_Msk
23947/******************* Bit definition for TIM_BDTR register *******************/
23948#define TIM_BDTR_DTG_Pos (0U)
23949#define TIM_BDTR_DTG_Msk (0xFFUL << TIM_BDTR_DTG_Pos)
23950#define TIM_BDTR_DTG TIM_BDTR_DTG_Msk
23951#define TIM_BDTR_DTG_0 (0x01UL << TIM_BDTR_DTG_Pos)
23952#define TIM_BDTR_DTG_1 (0x02UL << TIM_BDTR_DTG_Pos)
23953#define TIM_BDTR_DTG_2 (0x04UL << TIM_BDTR_DTG_Pos)
23954#define TIM_BDTR_DTG_3 (0x08UL << TIM_BDTR_DTG_Pos)
23955#define TIM_BDTR_DTG_4 (0x10UL << TIM_BDTR_DTG_Pos)
23956#define TIM_BDTR_DTG_5 (0x20UL << TIM_BDTR_DTG_Pos)
23957#define TIM_BDTR_DTG_6 (0x40UL << TIM_BDTR_DTG_Pos)
23958#define TIM_BDTR_DTG_7 (0x80UL << TIM_BDTR_DTG_Pos)
23960#define TIM_BDTR_LOCK_Pos (8U)
23961#define TIM_BDTR_LOCK_Msk (0x3UL << TIM_BDTR_LOCK_Pos)
23962#define TIM_BDTR_LOCK TIM_BDTR_LOCK_Msk
23963#define TIM_BDTR_LOCK_0 (0x1UL << TIM_BDTR_LOCK_Pos)
23964#define TIM_BDTR_LOCK_1 (0x2UL << TIM_BDTR_LOCK_Pos)
23966#define TIM_BDTR_OSSI_Pos (10U)
23967#define TIM_BDTR_OSSI_Msk (0x1UL << TIM_BDTR_OSSI_Pos)
23968#define TIM_BDTR_OSSI TIM_BDTR_OSSI_Msk
23969#define TIM_BDTR_OSSR_Pos (11U)
23970#define TIM_BDTR_OSSR_Msk (0x1UL << TIM_BDTR_OSSR_Pos)
23971#define TIM_BDTR_OSSR TIM_BDTR_OSSR_Msk
23972#define TIM_BDTR_BKE_Pos (12U)
23973#define TIM_BDTR_BKE_Msk (0x1UL << TIM_BDTR_BKE_Pos)
23974#define TIM_BDTR_BKE TIM_BDTR_BKE_Msk
23975#define TIM_BDTR_BKP_Pos (13U)
23976#define TIM_BDTR_BKP_Msk (0x1UL << TIM_BDTR_BKP_Pos)
23977#define TIM_BDTR_BKP TIM_BDTR_BKP_Msk
23978#define TIM_BDTR_AOE_Pos (14U)
23979#define TIM_BDTR_AOE_Msk (0x1UL << TIM_BDTR_AOE_Pos)
23980#define TIM_BDTR_AOE TIM_BDTR_AOE_Msk
23981#define TIM_BDTR_MOE_Pos (15U)
23982#define TIM_BDTR_MOE_Msk (0x1UL << TIM_BDTR_MOE_Pos)
23983#define TIM_BDTR_MOE TIM_BDTR_MOE_Msk
23985#define TIM_BDTR_BKF_Pos (16U)
23986#define TIM_BDTR_BKF_Msk (0xFUL << TIM_BDTR_BKF_Pos)
23987#define TIM_BDTR_BKF TIM_BDTR_BKF_Msk
23988#define TIM_BDTR_BK2F_Pos (20U)
23989#define TIM_BDTR_BK2F_Msk (0xFUL << TIM_BDTR_BK2F_Pos)
23990#define TIM_BDTR_BK2F TIM_BDTR_BK2F_Msk
23992#define TIM_BDTR_BK2E_Pos (24U)
23993#define TIM_BDTR_BK2E_Msk (0x1UL << TIM_BDTR_BK2E_Pos)
23994#define TIM_BDTR_BK2E TIM_BDTR_BK2E_Msk
23995#define TIM_BDTR_BK2P_Pos (25U)
23996#define TIM_BDTR_BK2P_Msk (0x1UL << TIM_BDTR_BK2P_Pos)
23997#define TIM_BDTR_BK2P TIM_BDTR_BK2P_Msk
23999/******************* Bit definition for TIM_DCR register ********************/
24000#define TIM_DCR_DBA_Pos (0U)
24001#define TIM_DCR_DBA_Msk (0x1FUL << TIM_DCR_DBA_Pos)
24002#define TIM_DCR_DBA TIM_DCR_DBA_Msk
24003#define TIM_DCR_DBA_0 (0x01UL << TIM_DCR_DBA_Pos)
24004#define TIM_DCR_DBA_1 (0x02UL << TIM_DCR_DBA_Pos)
24005#define TIM_DCR_DBA_2 (0x04UL << TIM_DCR_DBA_Pos)
24006#define TIM_DCR_DBA_3 (0x08UL << TIM_DCR_DBA_Pos)
24007#define TIM_DCR_DBA_4 (0x10UL << TIM_DCR_DBA_Pos)
24009#define TIM_DCR_DBL_Pos (8U)
24010#define TIM_DCR_DBL_Msk (0x1FUL << TIM_DCR_DBL_Pos)
24011#define TIM_DCR_DBL TIM_DCR_DBL_Msk
24012#define TIM_DCR_DBL_0 (0x01UL << TIM_DCR_DBL_Pos)
24013#define TIM_DCR_DBL_1 (0x02UL << TIM_DCR_DBL_Pos)
24014#define TIM_DCR_DBL_2 (0x04UL << TIM_DCR_DBL_Pos)
24015#define TIM_DCR_DBL_3 (0x08UL << TIM_DCR_DBL_Pos)
24016#define TIM_DCR_DBL_4 (0x10UL << TIM_DCR_DBL_Pos)
24018/******************* Bit definition for TIM_DMAR register *******************/
24019#define TIM_DMAR_DMAB_Pos (0U)
24020#define TIM_DMAR_DMAB_Msk (0xFFFFUL << TIM_DMAR_DMAB_Pos)
24021#define TIM_DMAR_DMAB TIM_DMAR_DMAB_Msk
24023/****************** Bit definition for TIM_CCMR3 register *******************/
24024#define TIM_CCMR3_OC5FE_Pos (2U)
24025#define TIM_CCMR3_OC5FE_Msk (0x1UL << TIM_CCMR3_OC5FE_Pos)
24026#define TIM_CCMR3_OC5FE TIM_CCMR3_OC5FE_Msk
24027#define TIM_CCMR3_OC5PE_Pos (3U)
24028#define TIM_CCMR3_OC5PE_Msk (0x1UL << TIM_CCMR3_OC5PE_Pos)
24029#define TIM_CCMR3_OC5PE TIM_CCMR3_OC5PE_Msk
24031#define TIM_CCMR3_OC5M_Pos (4U)
24032#define TIM_CCMR3_OC5M_Msk (0x1007UL << TIM_CCMR3_OC5M_Pos)
24033#define TIM_CCMR3_OC5M TIM_CCMR3_OC5M_Msk
24034#define TIM_CCMR3_OC5M_0 (0x1UL << TIM_CCMR3_OC5M_Pos)
24035#define TIM_CCMR3_OC5M_1 (0x2UL << TIM_CCMR3_OC5M_Pos)
24036#define TIM_CCMR3_OC5M_2 (0x4UL << TIM_CCMR3_OC5M_Pos)
24037#define TIM_CCMR3_OC5M_3 (0x1000UL << TIM_CCMR3_OC5M_Pos)
24039#define TIM_CCMR3_OC5CE_Pos (7U)
24040#define TIM_CCMR3_OC5CE_Msk (0x1UL << TIM_CCMR3_OC5CE_Pos)
24041#define TIM_CCMR3_OC5CE TIM_CCMR3_OC5CE_Msk
24043#define TIM_CCMR3_OC6FE_Pos (10U)
24044#define TIM_CCMR3_OC6FE_Msk (0x1UL << TIM_CCMR3_OC6FE_Pos)
24045#define TIM_CCMR3_OC6FE TIM_CCMR3_OC6FE_Msk
24046#define TIM_CCMR3_OC6PE_Pos (11U)
24047#define TIM_CCMR3_OC6PE_Msk (0x1UL << TIM_CCMR3_OC6PE_Pos)
24048#define TIM_CCMR3_OC6PE TIM_CCMR3_OC6PE_Msk
24050#define TIM_CCMR3_OC6M_Pos (12U)
24051#define TIM_CCMR3_OC6M_Msk (0x1007UL << TIM_CCMR3_OC6M_Pos)
24052#define TIM_CCMR3_OC6M TIM_CCMR3_OC6M_Msk
24053#define TIM_CCMR3_OC6M_0 (0x1UL << TIM_CCMR3_OC6M_Pos)
24054#define TIM_CCMR3_OC6M_1 (0x2UL << TIM_CCMR3_OC6M_Pos)
24055#define TIM_CCMR3_OC6M_2 (0x4UL << TIM_CCMR3_OC6M_Pos)
24056#define TIM_CCMR3_OC6M_3 (0x1000UL << TIM_CCMR3_OC6M_Pos)
24058#define TIM_CCMR3_OC6CE_Pos (15U)
24059#define TIM_CCMR3_OC6CE_Msk (0x1UL << TIM_CCMR3_OC6CE_Pos)
24060#define TIM_CCMR3_OC6CE TIM_CCMR3_OC6CE_Msk
24061/******************* Bit definition for TIM1_AF1 register *********************/
24062#define TIM1_AF1_BKINE_Pos (0U)
24063#define TIM1_AF1_BKINE_Msk (0x1UL << TIM1_AF1_BKINE_Pos)
24064#define TIM1_AF1_BKINE TIM1_AF1_BKINE_Msk
24065#define TIM1_AF1_BKCMP1E_Pos (1U)
24066#define TIM1_AF1_BKCMP1E_Msk (0x1UL << TIM1_AF1_BKCMP1E_Pos)
24067#define TIM1_AF1_BKCMP1E TIM1_AF1_BKCMP1E_Msk
24068#define TIM1_AF1_BKCMP2E_Pos (2U)
24069#define TIM1_AF1_BKCMP2E_Msk (0x1UL << TIM1_AF1_BKCMP2E_Pos)
24070#define TIM1_AF1_BKCMP2E TIM1_AF1_BKCMP2E_Msk
24071#define TIM1_AF1_BKDF1BK0E_Pos (8U)
24072#define TIM1_AF1_BKDF1BK0E_Msk (0x1UL << TIM1_AF1_BKDF1BK0E_Pos)
24073#define TIM1_AF1_BKDF1BK0E TIM1_AF1_BKDF1BK0E_Msk
24074#define TIM1_AF1_BKINP_Pos (9U)
24075#define TIM1_AF1_BKINP_Msk (0x1UL << TIM1_AF1_BKINP_Pos)
24076#define TIM1_AF1_BKINP TIM1_AF1_BKINP_Msk
24077#define TIM1_AF1_BKCMP1P_Pos (10U)
24078#define TIM1_AF1_BKCMP1P_Msk (0x1UL << TIM1_AF1_BKCMP1P_Pos)
24079#define TIM1_AF1_BKCMP1P TIM1_AF1_BKCMP1P_Msk
24080#define TIM1_AF1_BKCMP2P_Pos (11U)
24081#define TIM1_AF1_BKCMP2P_Msk (0x1UL << TIM1_AF1_BKCMP2P_Pos)
24082#define TIM1_AF1_BKCMP2P TIM1_AF1_BKCMP2P_Msk
24084#define TIM1_AF1_ETRSEL_Pos (14U)
24085#define TIM1_AF1_ETRSEL_Msk (0xFUL << TIM1_AF1_ETRSEL_Pos)
24086#define TIM1_AF1_ETRSEL TIM1_AF1_ETRSEL_Msk
24087#define TIM1_AF1_ETRSEL_0 (0x1UL << TIM1_AF1_ETRSEL_Pos)
24088#define TIM1_AF1_ETRSEL_1 (0x2UL << TIM1_AF1_ETRSEL_Pos)
24089#define TIM1_AF1_ETRSEL_2 (0x4UL << TIM1_AF1_ETRSEL_Pos)
24090#define TIM1_AF1_ETRSEL_3 (0x8UL << TIM1_AF1_ETRSEL_Pos)
24092/******************* Bit definition for TIM1_AF2 register *********************/
24093#define TIM1_AF2_BK2INE_Pos (0U)
24094#define TIM1_AF2_BK2INE_Msk (0x1UL << TIM1_AF2_BK2INE_Pos)
24095#define TIM1_AF2_BK2INE TIM1_AF2_BK2INE_Msk
24096#define TIM1_AF2_BK2CMP1E_Pos (1U)
24097#define TIM1_AF2_BK2CMP1E_Msk (0x1UL << TIM1_AF2_BK2CMP1E_Pos)
24098#define TIM1_AF2_BK2CMP1E TIM1_AF2_BK2CMP1E_Msk
24099#define TIM1_AF2_BK2CMP2E_Pos (2U)
24100#define TIM1_AF2_BK2CMP2E_Msk (0x1UL << TIM1_AF2_BK2CMP2E_Pos)
24101#define TIM1_AF2_BK2CMP2E TIM1_AF2_BK2CMP2E_Msk
24102#define TIM1_AF2_BK2DFBK1E_Pos (8U)
24103#define TIM1_AF2_BK2DFBK1E_Msk (0x1UL << TIM1_AF2_BK2DFBK1E_Pos)
24104#define TIM1_AF2_BK2DFBK1E TIM1_AF2_BK2DFBK1E_Msk
24105#define TIM1_AF2_BK2INP_Pos (9U)
24106#define TIM1_AF2_BK2INP_Msk (0x1UL << TIM1_AF2_BK2INP_Pos)
24107#define TIM1_AF2_BK2INP TIM1_AF2_BK2INP_Msk
24108#define TIM1_AF2_BK2CMP1P_Pos (10U)
24109#define TIM1_AF2_BK2CMP1P_Msk (0x1UL << TIM1_AF2_BK2CMP1P_Pos)
24110#define TIM1_AF2_BK2CMP1P TIM1_AF2_BK2CMP1P_Msk
24111#define TIM1_AF2_BK2CMP2P_Pos (11U)
24112#define TIM1_AF2_BK2CMP2P_Msk (0x1UL << TIM1_AF2_BK2CMP2P_Pos)
24113#define TIM1_AF2_BK2CMP2P TIM1_AF2_BK2CMP2P_Msk
24115/******************* Bit definition for TIM_TISEL register *********************/
24116#define TIM_TISEL_TI1SEL_Pos (0U)
24117#define TIM_TISEL_TI1SEL_Msk (0xFUL << TIM_TISEL_TI1SEL_Pos)
24118#define TIM_TISEL_TI1SEL TIM_TISEL_TI1SEL_Msk
24119#define TIM_TISEL_TI1SEL_0 (0x1UL << TIM_TISEL_TI1SEL_Pos)
24120#define TIM_TISEL_TI1SEL_1 (0x2UL << TIM_TISEL_TI1SEL_Pos)
24121#define TIM_TISEL_TI1SEL_2 (0x4UL << TIM_TISEL_TI1SEL_Pos)
24122#define TIM_TISEL_TI1SEL_3 (0x8UL << TIM_TISEL_TI1SEL_Pos)
24124#define TIM_TISEL_TI2SEL_Pos (8U)
24125#define TIM_TISEL_TI2SEL_Msk (0xFUL << TIM_TISEL_TI2SEL_Pos)
24126#define TIM_TISEL_TI2SEL TIM_TISEL_TI2SEL_Msk
24127#define TIM_TISEL_TI2SEL_0 (0x1UL << TIM_TISEL_TI2SEL_Pos)
24128#define TIM_TISEL_TI2SEL_1 (0x2UL << TIM_TISEL_TI2SEL_Pos)
24129#define TIM_TISEL_TI2SEL_2 (0x4UL << TIM_TISEL_TI2SEL_Pos)
24130#define TIM_TISEL_TI2SEL_3 (0x8UL << TIM_TISEL_TI2SEL_Pos)
24132#define TIM_TISEL_TI3SEL_Pos (16U)
24133#define TIM_TISEL_TI3SEL_Msk (0xFUL << TIM_TISEL_TI3SEL_Pos)
24134#define TIM_TISEL_TI3SEL TIM_TISEL_TI3SEL_Msk
24135#define TIM_TISEL_TI3SEL_0 (0x1UL << TIM_TISEL_TI3SEL_Pos)
24136#define TIM_TISEL_TI3SEL_1 (0x2UL << TIM_TISEL_TI3SEL_Pos)
24137#define TIM_TISEL_TI3SEL_2 (0x4UL << TIM_TISEL_TI3SEL_Pos)
24138#define TIM_TISEL_TI3SEL_3 (0x8UL << TIM_TISEL_TI3SEL_Pos)
24140#define TIM_TISEL_TI4SEL_Pos (24U)
24141#define TIM_TISEL_TI4SEL_Msk (0xFUL << TIM_TISEL_TI4SEL_Pos)
24142#define TIM_TISEL_TI4SEL TIM_TISEL_TI4SEL_Msk
24143#define TIM_TISEL_TI4SEL_0 (0x1UL << TIM_TISEL_TI4SEL_Pos)
24144#define TIM_TISEL_TI4SEL_1 (0x2UL << TIM_TISEL_TI4SEL_Pos)
24145#define TIM_TISEL_TI4SEL_2 (0x4UL << TIM_TISEL_TI4SEL_Pos)
24146#define TIM_TISEL_TI4SEL_3 (0x8UL << TIM_TISEL_TI4SEL_Pos)
24148/******************* Bit definition for TIM8_AF1 register *********************/
24149#define TIM8_AF1_BKINE_Pos (0U)
24150#define TIM8_AF1_BKINE_Msk (0x1UL << TIM8_AF1_BKINE_Pos)
24151#define TIM8_AF1_BKINE TIM8_AF1_BKINE_Msk
24152#define TIM8_AF1_BKCMP1E_Pos (1U)
24153#define TIM8_AF1_BKCMP1E_Msk (0x1UL << TIM8_AF1_BKCMP1E_Pos)
24154#define TIM8_AF1_BKCMP1E TIM8_AF1_BKCMP1E_Msk
24155#define TIM8_AF1_BKCMP2E_Pos (2U)
24156#define TIM8_AF1_BKCMP2E_Msk (0x1UL << TIM8_AF1_BKCMP2E_Pos)
24157#define TIM8_AF1_BKCMP2E TIM8_AF1_BKCMP2E_Msk
24158#define TIM8_AF1_BKDFBK2E_Pos (8U)
24159#define TIM8_AF1_BKDFBK2E_Msk (0x1UL << TIM8_AF1_BKDFBK2E_Pos)
24160#define TIM8_AF1_BKDFBK2E TIM8_AF1_BKDFBK2E_Msk
24161#define TIM8_AF1_BKINP_Pos (9U)
24162#define TIM8_AF1_BKINP_Msk (0x1UL << TIM8_AF1_BKINP_Pos)
24163#define TIM8_AF1_BKINP TIM8_AF1_BKINP_Msk
24164#define TIM8_AF1_BKCMP1P_Pos (10U)
24165#define TIM8_AF1_BKCMP1P_Msk (0x1UL << TIM8_AF1_BKCMP1P_Pos)
24166#define TIM8_AF1_BKCMP1P TIM8_AF1_BKCMP1P_Msk
24167#define TIM8_AF1_BKCMP2P_Pos (11U)
24168#define TIM8_AF1_BKCMP2P_Msk (0x1UL << TIM8_AF1_BKCMP2P_Pos)
24169#define TIM8_AF1_BKCMP2P TIM8_AF1_BKCMP2P_Msk
24171#define TIM8_AF1_ETRSEL_Pos (14U)
24172#define TIM8_AF1_ETRSEL_Msk (0xFUL << TIM8_AF1_ETRSEL_Pos)
24173#define TIM8_AF1_ETRSEL TIM8_AF1_ETRSEL_Msk
24174#define TIM8_AF1_ETRSEL_0 (0x1UL << TIM8_AF1_ETRSEL_Pos)
24175#define TIM8_AF1_ETRSEL_1 (0x2UL << TIM8_AF1_ETRSEL_Pos)
24176#define TIM8_AF1_ETRSEL_2 (0x4UL << TIM8_AF1_ETRSEL_Pos)
24177#define TIM8_AF1_ETRSEL_3 (0x8UL << TIM8_AF1_ETRSEL_Pos)
24178/******************* Bit definition for TIM8_AF2 register *********************/
24179#define TIM8_AF2_BK2INE_Pos (0U)
24180#define TIM8_AF2_BK2INE_Msk (0x1UL << TIM8_AF2_BK2INE_Pos)
24181#define TIM8_AF2_BK2INE TIM8_AF2_BK2INE_Msk
24182#define TIM8_AF2_BK2CMP1E_Pos (1U)
24183#define TIM8_AF2_BK2CMP1E_Msk (0x1UL << TIM8_AF2_BK2CMP1E_Pos)
24184#define TIM8_AF2_BK2CMP1E TIM8_AF2_BK2CMP1E_Msk
24185#define TIM8_AF2_BK2CMP2E_Pos (2U)
24186#define TIM8_AF2_BK2CMP2E_Msk (0x1UL << TIM8_AF2_BK2CMP2E_Pos)
24187#define TIM8_AF2_BK2CMP2E TIM8_AF2_BK2CMP2E_Msk
24188#define TIM8_AF2_BK2DFBK3E_Pos (8U)
24189#define TIM8_AF2_BK2DFBK3E_Msk (0x1UL << TIM8_AF2_BK2DFBK3E_Pos)
24190#define TIM8_AF2_BK2DFBK3E TIM8_AF2_BK2DFBK3E_Msk
24191#define TIM8_AF2_BK2INP_Pos (9U)
24192#define TIM8_AF2_BK2INP_Msk (0x1UL << TIM8_AF2_BK2INP_Pos)
24193#define TIM8_AF2_BK2INP TIM8_AF2_BK2INP_Msk
24194#define TIM8_AF2_BK2CMP1P_Pos (10U)
24195#define TIM8_AF2_BK2CMP1P_Msk (0x1UL << TIM8_AF2_BK2CMP1P_Pos)
24196#define TIM8_AF2_BK2CMP1P TIM8_AF2_BK2CMP1P_Msk
24197#define TIM8_AF2_BK2CMP2P_Pos (11U)
24198#define TIM8_AF2_BK2CMP2P_Msk (0x1UL << TIM8_AF2_BK2CMP2P_Pos)
24199#define TIM8_AF2_BK2CMP2P TIM8_AF2_BK2CMP2P_Msk
24201/******************* Bit definition for TIM2_AF1 register *********************/
24202#define TIM2_AF1_ETRSEL_Pos (14U)
24203#define TIM2_AF1_ETRSEL_Msk (0xFUL << TIM2_AF1_ETRSEL_Pos)
24204#define TIM2_AF1_ETRSEL TIM2_AF1_ETRSEL_Msk
24205#define TIM2_AF1_ETRSEL_0 (0x1UL << TIM2_AF1_ETRSEL_Pos)
24206#define TIM2_AF1_ETRSEL_1 (0x2UL << TIM2_AF1_ETRSEL_Pos)
24207#define TIM2_AF1_ETRSEL_2 (0x4UL << TIM2_AF1_ETRSEL_Pos)
24208#define TIM2_AF1_ETRSEL_3 (0x8UL << TIM2_AF1_ETRSEL_Pos)
24210/******************* Bit definition for TIM3_AF1 register *********************/
24211#define TIM3_AF1_ETRSEL_Pos (14U)
24212#define TIM3_AF1_ETRSEL_Msk (0xFUL << TIM3_AF1_ETRSEL_Pos)
24213#define TIM3_AF1_ETRSEL TIM3_AF1_ETRSEL_Msk
24214#define TIM3_AF1_ETRSEL_0 (0x1UL << TIM3_AF1_ETRSEL_Pos)
24215#define TIM3_AF1_ETRSEL_1 (0x2UL << TIM3_AF1_ETRSEL_Pos)
24216#define TIM3_AF1_ETRSEL_2 (0x4UL << TIM3_AF1_ETRSEL_Pos)
24217#define TIM3_AF1_ETRSEL_3 (0x8UL << TIM3_AF1_ETRSEL_Pos)
24219/******************* Bit definition for TIM5_AF1 register *********************/
24220#define TIM5_AF1_ETRSEL_Pos (14U)
24221#define TIM5_AF1_ETRSEL_Msk (0xFUL << TIM5_AF1_ETRSEL_Pos)
24222#define TIM5_AF1_ETRSEL TIM5_AF1_ETRSEL_Msk
24223#define TIM5_AF1_ETRSEL_0 (0x1UL << TIM5_AF1_ETRSEL_Pos)
24224#define TIM5_AF1_ETRSEL_1 (0x2UL << TIM5_AF1_ETRSEL_Pos)
24225#define TIM5_AF1_ETRSEL_2 (0x4UL << TIM5_AF1_ETRSEL_Pos)
24226#define TIM5_AF1_ETRSEL_3 (0x8UL << TIM5_AF1_ETRSEL_Pos)
24228/******************* Bit definition for TIM15_AF1 register *********************/
24229#define TIM15_AF1_BKINE_Pos (0U)
24230#define TIM15_AF1_BKINE_Msk (0x1UL << TIM15_AF1_BKINE_Pos)
24231#define TIM15_AF1_BKINE TIM15_AF1_BKINE_Msk
24232#define TIM15_AF1_BKCMP1E_Pos (1U)
24233#define TIM15_AF1_BKCMP1E_Msk (0x1UL << TIM15_AF1_BKCMP1E_Pos)
24234#define TIM15_AF1_BKCMP1E TIM15_AF1_BKCMP1E_Msk
24235#define TIM15_AF1_BKCMP2E_Pos (2U)
24236#define TIM15_AF1_BKCMP2E_Msk (0x1UL << TIM15_AF1_BKCMP2E_Pos)
24237#define TIM15_AF1_BKCMP2E TIM15_AF1_BKCMP2E_Msk
24238#define TIM15_AF1_BKDF1BK2E_Pos (8U)
24239#define TIM15_AF1_BKDF1BK2E_Msk (0x1UL << TIM15_AF1_BKDF1BK2E_Pos)
24240#define TIM15_AF1_BKDF1BK2E TIM15_AF1_BKDF1BK2E_Msk
24241#define TIM15_AF1_BKINP_Pos (9U)
24242#define TIM15_AF1_BKINP_Msk (0x1UL << TIM15_AF1_BKINP_Pos)
24243#define TIM15_AF1_BKINP TIM15_AF1_BKINP_Msk
24244#define TIM15_AF1_BKCMP1P_Pos (10U)
24245#define TIM15_AF1_BKCMP1P_Msk (0x1UL << TIM15_AF1_BKCMP1P_Pos)
24246#define TIM15_AF1_BKCMP1P TIM15_AF1_BKCMP1P_Msk
24247#define TIM15_AF1_BKCMP2P_Pos (11U)
24248#define TIM15_AF1_BKCMP2P_Msk (0x1UL << TIM15_AF1_BKCMP2P_Pos)
24249#define TIM15_AF1_BKCMP2P TIM15_AF1_BKCMP2P_Msk
24251/******************* Bit definition for TIM16_ register *********************/
24252#define TIM16_AF1_BKINE_Pos (0U)
24253#define TIM16_AF1_BKINE_Msk (0x1UL << TIM16_AF1_BKINE_Pos)
24254#define TIM16_AF1_BKINE TIM16_AF1_BKINE_Msk
24255#define TIM16_AF1_BKCMP1E_Pos (1U)
24256#define TIM16_AF1_BKCMP1E_Msk (0x1UL << TIM16_AF1_BKCMP1E_Pos)
24257#define TIM16_AF1_BKCMP1E TIM16_AF1_BKCMP1E_Msk
24258#define TIM16_AF1_BKCMP2E_Pos (2U)
24259#define TIM16_AF1_BKCMP2E_Msk (0x1UL << TIM16_AF1_BKCMP2E_Pos)
24260#define TIM16_AF1_BKCMP2E TIM16_AF1_BKCMP2E_Msk
24261#define TIM16_AF1_BKDF1BK2E_Pos (8U)
24262#define TIM16_AF1_BKDF1BK2E_Msk (0x1UL << TIM16_AF1_BKDF1BK2E_Pos)
24263#define TIM16_AF1_BKDF1BK2E TIM16_AF1_BKDF1BK2E_Msk
24264#define TIM16_AF1_BKINP_Pos (9U)
24265#define TIM16_AF1_BKINP_Msk (0x1UL << TIM16_AF1_BKINP_Pos)
24266#define TIM16_AF1_BKINP TIM16_AF1_BKINP_Msk
24267#define TIM16_AF1_BKCMP1P_Pos (10U)
24268#define TIM16_AF1_BKCMP1P_Msk (0x1UL << TIM16_AF1_BKCMP1P_Pos)
24269#define TIM16_AF1_BKCMP1P TIM16_AF1_BKCMP1P_Msk
24270#define TIM16_AF1_BKCMP2P_Pos (11U)
24271#define TIM16_AF1_BKCMP2P_Msk (0x1UL << TIM16_AF1_BKCMP2P_Pos)
24272#define TIM16_AF1_BKCMP2P TIM16_AF1_BKCMP2P_Msk
24274/******************* Bit definition for TIM17_AF1 register *********************/
24275#define TIM17_AF1_BKINE_Pos (0U)
24276#define TIM17_AF1_BKINE_Msk (0x1UL << TIM17_AF1_BKINE_Pos)
24277#define TIM17_AF1_BKINE TIM17_AF1_BKINE_Msk
24278#define TIM17_AF1_BKCMP1E_Pos (1U)
24279#define TIM17_AF1_BKCMP1E_Msk (0x1UL << TIM17_AF1_BKCMP1E_Pos)
24280#define TIM17_AF1_BKCMP1E TIM17_AF1_BKCMP1E_Msk
24281#define TIM17_AF1_BKCMP2E_Pos (2U)
24282#define TIM17_AF1_BKCMP2E_Msk (0x1UL << TIM17_AF1_BKCMP2E_Pos)
24283#define TIM17_AF1_BKCMP2E TIM17_AF1_BKCMP2E_Msk
24284#define TIM17_AF1_BKDF1BK2E_Pos (8U)
24285#define TIM17_AF1_BKDF1BK2E_Msk (0x1UL << TIM17_AF1_BKDF1BK2E_Pos)
24286#define TIM17_AF1_BKDF1BK2E TIM17_AF1_BKDF1BK2E_Msk
24287#define TIM17_AF1_BKINP_Pos (9U)
24288#define TIM17_AF1_BKINP_Msk (0x1UL << TIM17_AF1_BKINP_Pos)
24289#define TIM17_AF1_BKINP TIM17_AF1_BKINP_Msk
24290#define TIM17_AF1_BKCMP1P_Pos (10U)
24291#define TIM17_AF1_BKCMP1P_Msk (0x1UL << TIM17_AF1_BKCMP1P_Pos)
24292#define TIM17_AF1_BKCMP1P TIM17_AF1_BKCMP1P_Msk
24293#define TIM17_AF1_BKCMP2P_Pos (11U)
24294#define TIM17_AF1_BKCMP2P_Msk (0x1UL << TIM17_AF1_BKCMP2P_Pos)
24295#define TIM17_AF1_BKCMP2P TIM17_AF1_BKCMP2P_Msk
24297/******************************************************************************/
24298/* */
24299/* Low Power Timer (LPTTIM) */
24300/* */
24301/******************************************************************************/
24302/****************** Bit definition for LPTIM_ISR register *******************/
24303#define LPTIM_ISR_CMPM_Pos (0U)
24304#define LPTIM_ISR_CMPM_Msk (0x1UL << LPTIM_ISR_CMPM_Pos)
24305#define LPTIM_ISR_CMPM LPTIM_ISR_CMPM_Msk
24306#define LPTIM_ISR_ARRM_Pos (1U)
24307#define LPTIM_ISR_ARRM_Msk (0x1UL << LPTIM_ISR_ARRM_Pos)
24308#define LPTIM_ISR_ARRM LPTIM_ISR_ARRM_Msk
24309#define LPTIM_ISR_EXTTRIG_Pos (2U)
24310#define LPTIM_ISR_EXTTRIG_Msk (0x1UL << LPTIM_ISR_EXTTRIG_Pos)
24311#define LPTIM_ISR_EXTTRIG LPTIM_ISR_EXTTRIG_Msk
24312#define LPTIM_ISR_CMPOK_Pos (3U)
24313#define LPTIM_ISR_CMPOK_Msk (0x1UL << LPTIM_ISR_CMPOK_Pos)
24314#define LPTIM_ISR_CMPOK LPTIM_ISR_CMPOK_Msk
24315#define LPTIM_ISR_ARROK_Pos (4U)
24316#define LPTIM_ISR_ARROK_Msk (0x1UL << LPTIM_ISR_ARROK_Pos)
24317#define LPTIM_ISR_ARROK LPTIM_ISR_ARROK_Msk
24318#define LPTIM_ISR_UP_Pos (5U)
24319#define LPTIM_ISR_UP_Msk (0x1UL << LPTIM_ISR_UP_Pos)
24320#define LPTIM_ISR_UP LPTIM_ISR_UP_Msk
24321#define LPTIM_ISR_DOWN_Pos (6U)
24322#define LPTIM_ISR_DOWN_Msk (0x1UL << LPTIM_ISR_DOWN_Pos)
24323#define LPTIM_ISR_DOWN LPTIM_ISR_DOWN_Msk
24325/****************** Bit definition for LPTIM_ICR register *******************/
24326#define LPTIM_ICR_CMPMCF_Pos (0U)
24327#define LPTIM_ICR_CMPMCF_Msk (0x1UL << LPTIM_ICR_CMPMCF_Pos)
24328#define LPTIM_ICR_CMPMCF LPTIM_ICR_CMPMCF_Msk
24329#define LPTIM_ICR_ARRMCF_Pos (1U)
24330#define LPTIM_ICR_ARRMCF_Msk (0x1UL << LPTIM_ICR_ARRMCF_Pos)
24331#define LPTIM_ICR_ARRMCF LPTIM_ICR_ARRMCF_Msk
24332#define LPTIM_ICR_EXTTRIGCF_Pos (2U)
24333#define LPTIM_ICR_EXTTRIGCF_Msk (0x1UL << LPTIM_ICR_EXTTRIGCF_Pos)
24334#define LPTIM_ICR_EXTTRIGCF LPTIM_ICR_EXTTRIGCF_Msk
24335#define LPTIM_ICR_CMPOKCF_Pos (3U)
24336#define LPTIM_ICR_CMPOKCF_Msk (0x1UL << LPTIM_ICR_CMPOKCF_Pos)
24337#define LPTIM_ICR_CMPOKCF LPTIM_ICR_CMPOKCF_Msk
24338#define LPTIM_ICR_ARROKCF_Pos (4U)
24339#define LPTIM_ICR_ARROKCF_Msk (0x1UL << LPTIM_ICR_ARROKCF_Pos)
24340#define LPTIM_ICR_ARROKCF LPTIM_ICR_ARROKCF_Msk
24341#define LPTIM_ICR_UPCF_Pos (5U)
24342#define LPTIM_ICR_UPCF_Msk (0x1UL << LPTIM_ICR_UPCF_Pos)
24343#define LPTIM_ICR_UPCF LPTIM_ICR_UPCF_Msk
24344#define LPTIM_ICR_DOWNCF_Pos (6U)
24345#define LPTIM_ICR_DOWNCF_Msk (0x1UL << LPTIM_ICR_DOWNCF_Pos)
24346#define LPTIM_ICR_DOWNCF LPTIM_ICR_DOWNCF_Msk
24348/****************** Bit definition for LPTIM_IER register ********************/
24349#define LPTIM_IER_CMPMIE_Pos (0U)
24350#define LPTIM_IER_CMPMIE_Msk (0x1UL << LPTIM_IER_CMPMIE_Pos)
24351#define LPTIM_IER_CMPMIE LPTIM_IER_CMPMIE_Msk
24352#define LPTIM_IER_ARRMIE_Pos (1U)
24353#define LPTIM_IER_ARRMIE_Msk (0x1UL << LPTIM_IER_ARRMIE_Pos)
24354#define LPTIM_IER_ARRMIE LPTIM_IER_ARRMIE_Msk
24355#define LPTIM_IER_EXTTRIGIE_Pos (2U)
24356#define LPTIM_IER_EXTTRIGIE_Msk (0x1UL << LPTIM_IER_EXTTRIGIE_Pos)
24357#define LPTIM_IER_EXTTRIGIE LPTIM_IER_EXTTRIGIE_Msk
24358#define LPTIM_IER_CMPOKIE_Pos (3U)
24359#define LPTIM_IER_CMPOKIE_Msk (0x1UL << LPTIM_IER_CMPOKIE_Pos)
24360#define LPTIM_IER_CMPOKIE LPTIM_IER_CMPOKIE_Msk
24361#define LPTIM_IER_ARROKIE_Pos (4U)
24362#define LPTIM_IER_ARROKIE_Msk (0x1UL << LPTIM_IER_ARROKIE_Pos)
24363#define LPTIM_IER_ARROKIE LPTIM_IER_ARROKIE_Msk
24364#define LPTIM_IER_UPIE_Pos (5U)
24365#define LPTIM_IER_UPIE_Msk (0x1UL << LPTIM_IER_UPIE_Pos)
24366#define LPTIM_IER_UPIE LPTIM_IER_UPIE_Msk
24367#define LPTIM_IER_DOWNIE_Pos (6U)
24368#define LPTIM_IER_DOWNIE_Msk (0x1UL << LPTIM_IER_DOWNIE_Pos)
24369#define LPTIM_IER_DOWNIE LPTIM_IER_DOWNIE_Msk
24371/****************** Bit definition for LPTIM_CFGR register *******************/
24372#define LPTIM_CFGR_CKSEL_Pos (0U)
24373#define LPTIM_CFGR_CKSEL_Msk (0x1UL << LPTIM_CFGR_CKSEL_Pos)
24374#define LPTIM_CFGR_CKSEL LPTIM_CFGR_CKSEL_Msk
24376#define LPTIM_CFGR_CKPOL_Pos (1U)
24377#define LPTIM_CFGR_CKPOL_Msk (0x3UL << LPTIM_CFGR_CKPOL_Pos)
24378#define LPTIM_CFGR_CKPOL LPTIM_CFGR_CKPOL_Msk
24379#define LPTIM_CFGR_CKPOL_0 (0x1UL << LPTIM_CFGR_CKPOL_Pos)
24380#define LPTIM_CFGR_CKPOL_1 (0x2UL << LPTIM_CFGR_CKPOL_Pos)
24382#define LPTIM_CFGR_CKFLT_Pos (3U)
24383#define LPTIM_CFGR_CKFLT_Msk (0x3UL << LPTIM_CFGR_CKFLT_Pos)
24384#define LPTIM_CFGR_CKFLT LPTIM_CFGR_CKFLT_Msk
24385#define LPTIM_CFGR_CKFLT_0 (0x1UL << LPTIM_CFGR_CKFLT_Pos)
24386#define LPTIM_CFGR_CKFLT_1 (0x2UL << LPTIM_CFGR_CKFLT_Pos)
24388#define LPTIM_CFGR_TRGFLT_Pos (6U)
24389#define LPTIM_CFGR_TRGFLT_Msk (0x3UL << LPTIM_CFGR_TRGFLT_Pos)
24390#define LPTIM_CFGR_TRGFLT LPTIM_CFGR_TRGFLT_Msk
24391#define LPTIM_CFGR_TRGFLT_0 (0x1UL << LPTIM_CFGR_TRGFLT_Pos)
24392#define LPTIM_CFGR_TRGFLT_1 (0x2UL << LPTIM_CFGR_TRGFLT_Pos)
24394#define LPTIM_CFGR_PRESC_Pos (9U)
24395#define LPTIM_CFGR_PRESC_Msk (0x7UL << LPTIM_CFGR_PRESC_Pos)
24396#define LPTIM_CFGR_PRESC LPTIM_CFGR_PRESC_Msk
24397#define LPTIM_CFGR_PRESC_0 (0x1UL << LPTIM_CFGR_PRESC_Pos)
24398#define LPTIM_CFGR_PRESC_1 (0x2UL << LPTIM_CFGR_PRESC_Pos)
24399#define LPTIM_CFGR_PRESC_2 (0x4UL << LPTIM_CFGR_PRESC_Pos)
24401#define LPTIM_CFGR_TRIGSEL_Pos (13U)
24402#define LPTIM_CFGR_TRIGSEL_Msk (0x7UL << LPTIM_CFGR_TRIGSEL_Pos)
24403#define LPTIM_CFGR_TRIGSEL LPTIM_CFGR_TRIGSEL_Msk
24404#define LPTIM_CFGR_TRIGSEL_0 (0x1UL << LPTIM_CFGR_TRIGSEL_Pos)
24405#define LPTIM_CFGR_TRIGSEL_1 (0x2UL << LPTIM_CFGR_TRIGSEL_Pos)
24406#define LPTIM_CFGR_TRIGSEL_2 (0x4UL << LPTIM_CFGR_TRIGSEL_Pos)
24408#define LPTIM_CFGR_TRIGEN_Pos (17U)
24409#define LPTIM_CFGR_TRIGEN_Msk (0x3UL << LPTIM_CFGR_TRIGEN_Pos)
24410#define LPTIM_CFGR_TRIGEN LPTIM_CFGR_TRIGEN_Msk
24411#define LPTIM_CFGR_TRIGEN_0 (0x1UL << LPTIM_CFGR_TRIGEN_Pos)
24412#define LPTIM_CFGR_TRIGEN_1 (0x2UL << LPTIM_CFGR_TRIGEN_Pos)
24414#define LPTIM_CFGR_TIMOUT_Pos (19U)
24415#define LPTIM_CFGR_TIMOUT_Msk (0x1UL << LPTIM_CFGR_TIMOUT_Pos)
24416#define LPTIM_CFGR_TIMOUT LPTIM_CFGR_TIMOUT_Msk
24417#define LPTIM_CFGR_WAVE_Pos (20U)
24418#define LPTIM_CFGR_WAVE_Msk (0x1UL << LPTIM_CFGR_WAVE_Pos)
24419#define LPTIM_CFGR_WAVE LPTIM_CFGR_WAVE_Msk
24420#define LPTIM_CFGR_WAVPOL_Pos (21U)
24421#define LPTIM_CFGR_WAVPOL_Msk (0x1UL << LPTIM_CFGR_WAVPOL_Pos)
24422#define LPTIM_CFGR_WAVPOL LPTIM_CFGR_WAVPOL_Msk
24423#define LPTIM_CFGR_PRELOAD_Pos (22U)
24424#define LPTIM_CFGR_PRELOAD_Msk (0x1UL << LPTIM_CFGR_PRELOAD_Pos)
24425#define LPTIM_CFGR_PRELOAD LPTIM_CFGR_PRELOAD_Msk
24426#define LPTIM_CFGR_COUNTMODE_Pos (23U)
24427#define LPTIM_CFGR_COUNTMODE_Msk (0x1UL << LPTIM_CFGR_COUNTMODE_Pos)
24428#define LPTIM_CFGR_COUNTMODE LPTIM_CFGR_COUNTMODE_Msk
24429#define LPTIM_CFGR_ENC_Pos (24U)
24430#define LPTIM_CFGR_ENC_Msk (0x1UL << LPTIM_CFGR_ENC_Pos)
24431#define LPTIM_CFGR_ENC LPTIM_CFGR_ENC_Msk
24433/****************** Bit definition for LPTIM_CR register ********************/
24434#define LPTIM_CR_ENABLE_Pos (0U)
24435#define LPTIM_CR_ENABLE_Msk (0x1UL << LPTIM_CR_ENABLE_Pos)
24436#define LPTIM_CR_ENABLE LPTIM_CR_ENABLE_Msk
24437#define LPTIM_CR_SNGSTRT_Pos (1U)
24438#define LPTIM_CR_SNGSTRT_Msk (0x40001UL << LPTIM_CR_SNGSTRT_Pos)
24439#define LPTIM_CR_SNGSTRT LPTIM_CR_SNGSTRT_Msk
24440#define LPTIM_CR_CNTSTRT_Pos (2U)
24441#define LPTIM_CR_CNTSTRT_Msk (0x1UL << LPTIM_CR_CNTSTRT_Pos)
24442#define LPTIM_CR_CNTSTRT LPTIM_CR_CNTSTRT_Msk
24443#define LPTIM_CR_COUNTRST_Pos (3U)
24444#define LPTIM_CR_COUNTRST_Msk (0x1UL << LPTIM_CR_COUNTRST_Pos)
24445#define LPTIM_CR_COUNTRST LPTIM_CR_COUNTRST_Msk
24446#define LPTIM_CR_RSTARE_Pos (4U)
24447#define LPTIM_CR_RSTARE_Msk (0x1UL << LPTIM_CR_RSTARE_Pos)
24448#define LPTIM_CR_RSTARE LPTIM_CR_RSTARE_Msk
24451/****************** Bit definition for LPTIM_CMP register *******************/
24452#define LPTIM_CMP_CMP_Pos (0U)
24453#define LPTIM_CMP_CMP_Msk (0xFFFFUL << LPTIM_CMP_CMP_Pos)
24454#define LPTIM_CMP_CMP LPTIM_CMP_CMP_Msk
24456/****************** Bit definition for LPTIM_ARR register *******************/
24457#define LPTIM_ARR_ARR_Pos (0U)
24458#define LPTIM_ARR_ARR_Msk (0xFFFFUL << LPTIM_ARR_ARR_Pos)
24459#define LPTIM_ARR_ARR LPTIM_ARR_ARR_Msk
24461/****************** Bit definition for LPTIM_CNT register *******************/
24462#define LPTIM_CNT_CNT_Pos (0U)
24463#define LPTIM_CNT_CNT_Msk (0xFFFFUL << LPTIM_CNT_CNT_Pos)
24464#define LPTIM_CNT_CNT LPTIM_CNT_CNT_Msk
24466/****************** Bit definition for LPTIM_CFGR2 register *****************/
24467#define LPTIM_CFGR2_IN1SEL_Pos (0U)
24468#define LPTIM_CFGR2_IN1SEL_Msk (0x3UL << LPTIM_CFGR2_IN1SEL_Pos)
24469#define LPTIM_CFGR2_IN1SEL LPTIM_CFGR2_IN1SEL_Msk
24470#define LPTIM_CFGR2_IN1SEL_0 (0x1UL << LPTIM_CFGR2_IN1SEL_Pos)
24471#define LPTIM_CFGR2_IN1SEL_1 (0x2UL << LPTIM_CFGR2_IN1SEL_Pos)
24472#define LPTIM_CFGR2_IN2SEL_Pos (4U)
24473#define LPTIM_CFGR2_IN2SEL_Msk (0x3UL << LPTIM_CFGR2_IN2SEL_Pos)
24474#define LPTIM_CFGR2_IN2SEL LPTIM_CFGR2_IN2SEL_Msk
24475#define LPTIM_CFGR2_IN2SEL_0 (0x1UL << LPTIM_CFGR2_IN2SEL_Pos)
24476#define LPTIM_CFGR2_IN2SEL_1 (0x2UL << LPTIM_CFGR2_IN2SEL_Pos)
24478/******************************************************************************/
24479/* */
24480/* Analog Comparators (COMP) */
24481/* */
24482/******************************************************************************/
24483
24484/******************* Bit definition for COMP_SR register ********************/
24485#define COMP_SR_C1VAL_Pos (0U)
24486#define COMP_SR_C1VAL_Msk (0x1UL << COMP_SR_C1VAL_Pos)
24487#define COMP_SR_C1VAL COMP_SR_C1VAL_Msk
24488#define COMP_SR_C2VAL_Pos (1U)
24489#define COMP_SR_C2VAL_Msk (0x1UL << COMP_SR_C2VAL_Pos)
24490#define COMP_SR_C2VAL COMP_SR_C2VAL_Msk
24491#define COMP_SR_C1IF_Pos (16U)
24492#define COMP_SR_C1IF_Msk (0x1UL << COMP_SR_C1IF_Pos)
24493#define COMP_SR_C1IF COMP_SR_C1IF_Msk
24494#define COMP_SR_C2IF_Pos (17U)
24495#define COMP_SR_C2IF_Msk (0x1UL << COMP_SR_C2IF_Pos)
24496#define COMP_SR_C2IF COMP_SR_C2IF_Msk
24497/******************* Bit definition for COMP_ICFR register ********************/
24498#define COMP_ICFR_C1IF_Pos (16U)
24499#define COMP_ICFR_C1IF_Msk (0x1UL << COMP_ICFR_C1IF_Pos)
24500#define COMP_ICFR_C1IF COMP_ICFR_C1IF_Msk
24501#define COMP_ICFR_C2IF_Pos (17U)
24502#define COMP_ICFR_C2IF_Msk (0x1UL << COMP_ICFR_C2IF_Pos)
24503#define COMP_ICFR_C2IF COMP_ICFR_C2IF_Msk
24504/******************* Bit definition for COMP_OR register ********************/
24505#define COMP_OR_AFOPA6_Pos (0U)
24506#define COMP_OR_AFOPA6_Msk (0x1UL << COMP_OR_AFOPA6_Pos)
24507#define COMP_OR_AFOPA6 COMP_OR_AFOPA6_Msk
24508#define COMP_OR_AFOPA8_Pos (1U)
24509#define COMP_OR_AFOPA8_Msk (0x1UL << COMP_OR_AFOPA8_Pos)
24510#define COMP_OR_AFOPA8 COMP_OR_AFOPA8_Msk
24511#define COMP_OR_AFOPB12_Pos (2U)
24512#define COMP_OR_AFOPB12_Msk (0x1UL << COMP_OR_AFOPB12_Pos)
24513#define COMP_OR_AFOPB12 COMP_OR_AFOPB12_Msk
24514#define COMP_OR_AFOPE6_Pos (3U)
24515#define COMP_OR_AFOPE6_Msk (0x1UL << COMP_OR_AFOPE6_Pos)
24516#define COMP_OR_AFOPE6 COMP_OR_AFOPE6_Msk
24517#define COMP_OR_AFOPE15_Pos (4U)
24518#define COMP_OR_AFOPE15_Msk (0x1UL << COMP_OR_AFOPE15_Pos)
24519#define COMP_OR_AFOPE15 COMP_OR_AFOPE15_Msk
24520#define COMP_OR_AFOPG2_Pos (5U)
24521#define COMP_OR_AFOPG2_Msk (0x1UL << COMP_OR_AFOPG2_Pos)
24522#define COMP_OR_AFOPG2 COMP_OR_AFOPG2_Msk
24523#define COMP_OR_AFOPG3_Pos (6U)
24524#define COMP_OR_AFOPG3_Msk (0x1UL << COMP_OR_AFOPG3_Pos)
24525#define COMP_OR_AFOPG3 COMP_OR_AFOPG3_Msk
24526#define COMP_OR_AFOPG4_Pos (7U)
24527#define COMP_OR_AFOPG4_Msk (0x1UL << COMP_OR_AFOPG4_Pos)
24528#define COMP_OR_AFOPG4 COMP_OR_AFOPG4_Msk
24529#define COMP_OR_AFOPI1_Pos (8U)
24530#define COMP_OR_AFOPI1_Msk (0x1UL << COMP_OR_AFOPI1_Pos)
24531#define COMP_OR_AFOPI1 COMP_OR_AFOPI1_Msk
24532#define COMP_OR_AFOPI4_Pos (9U)
24533#define COMP_OR_AFOPI4_Msk (0x1UL << COMP_OR_AFOPI4_Pos)
24534#define COMP_OR_AFOPI4 COMP_OR_AFOPI4_Msk
24535#define COMP_OR_AFOPK2_Pos (10U)
24536#define COMP_OR_AFOPK2_Msk (0x1UL << COMP_OR_AFOPK2_Pos)
24537#define COMP_OR_AFOPK2 COMP_OR_AFOPK2_Msk
24538
24540#define COMP_CFGRx_EN_Pos (0U)
24541#define COMP_CFGRx_EN_Msk (0x1UL << COMP_CFGRx_EN_Pos)
24542#define COMP_CFGRx_EN COMP_CFGRx_EN_Msk
24543#define COMP_CFGRx_BRGEN_Pos (1U)
24544#define COMP_CFGRx_BRGEN_Msk (0x1UL << COMP_CFGRx_BRGEN_Pos)
24545#define COMP_CFGRx_BRGEN COMP_CFGRx_BRGEN_Msk
24546#define COMP_CFGRx_SCALEN_Pos (2U)
24547#define COMP_CFGRx_SCALEN_Msk (0x1UL << COMP_CFGRx_SCALEN_Pos)
24548#define COMP_CFGRx_SCALEN COMP_CFGRx_SCALEN_Msk
24549#define COMP_CFGRx_POLARITY_Pos (3U)
24550#define COMP_CFGRx_POLARITY_Msk (0x1UL << COMP_CFGRx_POLARITY_Pos)
24551#define COMP_CFGRx_POLARITY COMP_CFGRx_POLARITY_Msk
24552#define COMP_CFGRx_WINMODE_Pos (4U)
24553#define COMP_CFGRx_WINMODE_Msk (0x1UL << COMP_CFGRx_WINMODE_Pos)
24554#define COMP_CFGRx_WINMODE COMP_CFGRx_WINMODE_Msk
24555#define COMP_CFGRx_ITEN_Pos (6U)
24556#define COMP_CFGRx_ITEN_Msk (0x1UL << COMP_CFGRx_ITEN_Pos)
24557#define COMP_CFGRx_ITEN COMP_CFGRx_ITEN_Msk
24558#define COMP_CFGRx_HYST_Pos (8U)
24559#define COMP_CFGRx_HYST_Msk (0x3UL << COMP_CFGRx_HYST_Pos)
24560#define COMP_CFGRx_HYST COMP_CFGRx_HYST_Msk
24561#define COMP_CFGRx_HYST_0 (0x1UL << COMP_CFGRx_HYST_Pos)
24562#define COMP_CFGRx_HYST_1 (0x2UL << COMP_CFGRx_HYST_Pos)
24563#define COMP_CFGRx_PWRMODE_Pos (12U)
24564#define COMP_CFGRx_PWRMODE_Msk (0x3UL << COMP_CFGRx_PWRMODE_Pos)
24565#define COMP_CFGRx_PWRMODE COMP_CFGRx_PWRMODE_Msk
24566#define COMP_CFGRx_PWRMODE_0 (0x1UL << COMP_CFGRx_PWRMODE_Pos)
24567#define COMP_CFGRx_PWRMODE_1 (0x2UL << COMP_CFGRx_PWRMODE_Pos)
24568#define COMP_CFGRx_INMSEL_Pos (16U)
24569#define COMP_CFGRx_INMSEL_Msk (0x7UL << COMP_CFGRx_INMSEL_Pos)
24570#define COMP_CFGRx_INMSEL COMP_CFGRx_INMSEL_Msk
24571#define COMP_CFGRx_INMSEL_0 (0x1UL << COMP_CFGRx_INMSEL_Pos)
24572#define COMP_CFGRx_INMSEL_1 (0x2UL << COMP_CFGRx_INMSEL_Pos)
24573#define COMP_CFGRx_INMSEL_2 (0x4UL << COMP_CFGRx_INMSEL_Pos)
24574#define COMP_CFGRx_INPSEL_Pos (20U)
24575#define COMP_CFGRx_INPSEL_Msk (0x1UL << COMP_CFGRx_INPSEL_Pos)
24576#define COMP_CFGRx_INPSEL COMP_CFGRx_INPSEL_Msk
24577#define COMP_CFGRx_BLANKING_Pos (24U)
24578#define COMP_CFGRx_BLANKING_Msk (0xFUL << COMP_CFGRx_BLANKING_Pos)
24579#define COMP_CFGRx_BLANKING COMP_CFGRx_BLANKING_Msk
24580#define COMP_CFGRx_BLANKING_0 (0x1UL << COMP_CFGRx_BLANKING_Pos)
24581#define COMP_CFGRx_BLANKING_1 (0x2UL << COMP_CFGRx_BLANKING_Pos)
24582#define COMP_CFGRx_BLANKING_2 (0x4UL << COMP_CFGRx_BLANKING_Pos)
24583#define COMP_CFGRx_LOCK_Pos (31U)
24584#define COMP_CFGRx_LOCK_Msk (0x1UL << COMP_CFGRx_LOCK_Pos)
24585#define COMP_CFGRx_LOCK COMP_CFGRx_LOCK_Msk
24588/******************************************************************************/
24589/* */
24590/* Universal Synchronous Asynchronous Receiver Transmitter (USART) */
24591/* */
24592/******************************************************************************/
24593/****************** Bit definition for USART_CR1 register *******************/
24594#define USART_CR1_UE_Pos (0U)
24595#define USART_CR1_UE_Msk (0x1UL << USART_CR1_UE_Pos)
24596#define USART_CR1_UE USART_CR1_UE_Msk
24597#define USART_CR1_UESM_Pos (1U)
24598#define USART_CR1_UESM_Msk (0x1UL << USART_CR1_UESM_Pos)
24599#define USART_CR1_UESM USART_CR1_UESM_Msk
24600#define USART_CR1_RE_Pos (2U)
24601#define USART_CR1_RE_Msk (0x1UL << USART_CR1_RE_Pos)
24602#define USART_CR1_RE USART_CR1_RE_Msk
24603#define USART_CR1_TE_Pos (3U)
24604#define USART_CR1_TE_Msk (0x1UL << USART_CR1_TE_Pos)
24605#define USART_CR1_TE USART_CR1_TE_Msk
24606#define USART_CR1_IDLEIE_Pos (4U)
24607#define USART_CR1_IDLEIE_Msk (0x1UL << USART_CR1_IDLEIE_Pos)
24608#define USART_CR1_IDLEIE USART_CR1_IDLEIE_Msk
24609#define USART_CR1_RXNEIE_RXFNEIE_Pos (5U)
24610#define USART_CR1_RXNEIE_RXFNEIE_Msk (0x1UL << USART_CR1_RXNEIE_RXFNEIE_Pos)
24611#define USART_CR1_RXNEIE_RXFNEIE USART_CR1_RXNEIE_RXFNEIE_Msk
24612#define USART_CR1_TCIE_Pos (6U)
24613#define USART_CR1_TCIE_Msk (0x1UL << USART_CR1_TCIE_Pos)
24614#define USART_CR1_TCIE USART_CR1_TCIE_Msk
24615#define USART_CR1_TXEIE_TXFNFIE_Pos (7U)
24616#define USART_CR1_TXEIE_TXFNFIE_Msk (0x1UL << USART_CR1_TXEIE_TXFNFIE_Pos)
24617#define USART_CR1_TXEIE_TXFNFIE USART_CR1_TXEIE_TXFNFIE_Msk
24618#define USART_CR1_PEIE_Pos (8U)
24619#define USART_CR1_PEIE_Msk (0x1UL << USART_CR1_PEIE_Pos)
24620#define USART_CR1_PEIE USART_CR1_PEIE_Msk
24621#define USART_CR1_PS_Pos (9U)
24622#define USART_CR1_PS_Msk (0x1UL << USART_CR1_PS_Pos)
24623#define USART_CR1_PS USART_CR1_PS_Msk
24624#define USART_CR1_PCE_Pos (10U)
24625#define USART_CR1_PCE_Msk (0x1UL << USART_CR1_PCE_Pos)
24626#define USART_CR1_PCE USART_CR1_PCE_Msk
24627#define USART_CR1_WAKE_Pos (11U)
24628#define USART_CR1_WAKE_Msk (0x1UL << USART_CR1_WAKE_Pos)
24629#define USART_CR1_WAKE USART_CR1_WAKE_Msk
24630#define USART_CR1_M_Pos (12U)
24631#define USART_CR1_M_Msk (0x10001UL << USART_CR1_M_Pos)
24632#define USART_CR1_M USART_CR1_M_Msk
24633#define USART_CR1_M0_Pos (12U)
24634#define USART_CR1_M0_Msk (0x1UL << USART_CR1_M0_Pos)
24635#define USART_CR1_M0 USART_CR1_M0_Msk
24636#define USART_CR1_MME_Pos (13U)
24637#define USART_CR1_MME_Msk (0x1UL << USART_CR1_MME_Pos)
24638#define USART_CR1_MME USART_CR1_MME_Msk
24639#define USART_CR1_CMIE_Pos (14U)
24640#define USART_CR1_CMIE_Msk (0x1UL << USART_CR1_CMIE_Pos)
24641#define USART_CR1_CMIE USART_CR1_CMIE_Msk
24642#define USART_CR1_OVER8_Pos (15U)
24643#define USART_CR1_OVER8_Msk (0x1UL << USART_CR1_OVER8_Pos)
24644#define USART_CR1_OVER8 USART_CR1_OVER8_Msk
24645#define USART_CR1_DEDT_Pos (16U)
24646#define USART_CR1_DEDT_Msk (0x1FUL << USART_CR1_DEDT_Pos)
24647#define USART_CR1_DEDT USART_CR1_DEDT_Msk
24648#define USART_CR1_DEDT_0 (0x01UL << USART_CR1_DEDT_Pos)
24649#define USART_CR1_DEDT_1 (0x02UL << USART_CR1_DEDT_Pos)
24650#define USART_CR1_DEDT_2 (0x04UL << USART_CR1_DEDT_Pos)
24651#define USART_CR1_DEDT_3 (0x08UL << USART_CR1_DEDT_Pos)
24652#define USART_CR1_DEDT_4 (0x10UL << USART_CR1_DEDT_Pos)
24653#define USART_CR1_DEAT_Pos (21U)
24654#define USART_CR1_DEAT_Msk (0x1FUL << USART_CR1_DEAT_Pos)
24655#define USART_CR1_DEAT USART_CR1_DEAT_Msk
24656#define USART_CR1_DEAT_0 (0x01UL << USART_CR1_DEAT_Pos)
24657#define USART_CR1_DEAT_1 (0x02UL << USART_CR1_DEAT_Pos)
24658#define USART_CR1_DEAT_2 (0x04UL << USART_CR1_DEAT_Pos)
24659#define USART_CR1_DEAT_3 (0x08UL << USART_CR1_DEAT_Pos)
24660#define USART_CR1_DEAT_4 (0x10UL << USART_CR1_DEAT_Pos)
24661#define USART_CR1_RTOIE_Pos (26U)
24662#define USART_CR1_RTOIE_Msk (0x1UL << USART_CR1_RTOIE_Pos)
24663#define USART_CR1_RTOIE USART_CR1_RTOIE_Msk
24664#define USART_CR1_EOBIE_Pos (27U)
24665#define USART_CR1_EOBIE_Msk (0x1UL << USART_CR1_EOBIE_Pos)
24666#define USART_CR1_EOBIE USART_CR1_EOBIE_Msk
24667#define USART_CR1_M1_Pos (28U)
24668#define USART_CR1_M1_Msk (0x1UL << USART_CR1_M1_Pos)
24669#define USART_CR1_M1 USART_CR1_M1_Msk
24670#define USART_CR1_FIFOEN_Pos (29U)
24671#define USART_CR1_FIFOEN_Msk (0x1UL << USART_CR1_FIFOEN_Pos)
24672#define USART_CR1_FIFOEN USART_CR1_FIFOEN_Msk
24673#define USART_CR1_TXFEIE_Pos (30U)
24674#define USART_CR1_TXFEIE_Msk (0x1UL << USART_CR1_TXFEIE_Pos)
24675#define USART_CR1_TXFEIE USART_CR1_TXFEIE_Msk
24676#define USART_CR1_RXFFIE_Pos (31U)
24677#define USART_CR1_RXFFIE_Msk (0x1UL << USART_CR1_RXFFIE_Pos)
24678#define USART_CR1_RXFFIE USART_CR1_RXFFIE_Msk
24680/* Legacy define */
24681#define USART_CR1_RXNEIE USART_CR1_RXNEIE_RXFNEIE
24682#define USART_CR1_TXEIE USART_CR1_TXEIE_TXFNFIE
24683
24684/****************** Bit definition for USART_CR2 register *******************/
24685#define USART_CR2_SLVEN_Pos (0U)
24686#define USART_CR2_SLVEN_Msk (0x1UL << USART_CR2_SLVEN_Pos)
24687#define USART_CR2_SLVEN USART_CR2_SLVEN_Msk
24688#define USART_CR2_DIS_NSS_Pos (3U)
24689#define USART_CR2_DIS_NSS_Msk (0x1UL << USART_CR2_DIS_NSS_Pos)
24690#define USART_CR2_DIS_NSS USART_CR2_DIS_NSS_Msk
24691#define USART_CR2_ADDM7_Pos (4U)
24692#define USART_CR2_ADDM7_Msk (0x1UL << USART_CR2_ADDM7_Pos)
24693#define USART_CR2_ADDM7 USART_CR2_ADDM7_Msk
24694#define USART_CR2_LBDL_Pos (5U)
24695#define USART_CR2_LBDL_Msk (0x1UL << USART_CR2_LBDL_Pos)
24696#define USART_CR2_LBDL USART_CR2_LBDL_Msk
24697#define USART_CR2_LBDIE_Pos (6U)
24698#define USART_CR2_LBDIE_Msk (0x1UL << USART_CR2_LBDIE_Pos)
24699#define USART_CR2_LBDIE USART_CR2_LBDIE_Msk
24700#define USART_CR2_LBCL_Pos (8U)
24701#define USART_CR2_LBCL_Msk (0x1UL << USART_CR2_LBCL_Pos)
24702#define USART_CR2_LBCL USART_CR2_LBCL_Msk
24703#define USART_CR2_CPHA_Pos (9U)
24704#define USART_CR2_CPHA_Msk (0x1UL << USART_CR2_CPHA_Pos)
24705#define USART_CR2_CPHA USART_CR2_CPHA_Msk
24706#define USART_CR2_CPOL_Pos (10U)
24707#define USART_CR2_CPOL_Msk (0x1UL << USART_CR2_CPOL_Pos)
24708#define USART_CR2_CPOL USART_CR2_CPOL_Msk
24709#define USART_CR2_CLKEN_Pos (11U)
24710#define USART_CR2_CLKEN_Msk (0x1UL << USART_CR2_CLKEN_Pos)
24711#define USART_CR2_CLKEN USART_CR2_CLKEN_Msk
24712#define USART_CR2_STOP_Pos (12U)
24713#define USART_CR2_STOP_Msk (0x3UL << USART_CR2_STOP_Pos)
24714#define USART_CR2_STOP USART_CR2_STOP_Msk
24715#define USART_CR2_STOP_0 (0x1UL << USART_CR2_STOP_Pos)
24716#define USART_CR2_STOP_1 (0x2UL << USART_CR2_STOP_Pos)
24717#define USART_CR2_LINEN_Pos (14U)
24718#define USART_CR2_LINEN_Msk (0x1UL << USART_CR2_LINEN_Pos)
24719#define USART_CR2_LINEN USART_CR2_LINEN_Msk
24720#define USART_CR2_SWAP_Pos (15U)
24721#define USART_CR2_SWAP_Msk (0x1UL << USART_CR2_SWAP_Pos)
24722#define USART_CR2_SWAP USART_CR2_SWAP_Msk
24723#define USART_CR2_RXINV_Pos (16U)
24724#define USART_CR2_RXINV_Msk (0x1UL << USART_CR2_RXINV_Pos)
24725#define USART_CR2_RXINV USART_CR2_RXINV_Msk
24726#define USART_CR2_TXINV_Pos (17U)
24727#define USART_CR2_TXINV_Msk (0x1UL << USART_CR2_TXINV_Pos)
24728#define USART_CR2_TXINV USART_CR2_TXINV_Msk
24729#define USART_CR2_DATAINV_Pos (18U)
24730#define USART_CR2_DATAINV_Msk (0x1UL << USART_CR2_DATAINV_Pos)
24731#define USART_CR2_DATAINV USART_CR2_DATAINV_Msk
24732#define USART_CR2_MSBFIRST_Pos (19U)
24733#define USART_CR2_MSBFIRST_Msk (0x1UL << USART_CR2_MSBFIRST_Pos)
24734#define USART_CR2_MSBFIRST USART_CR2_MSBFIRST_Msk
24735#define USART_CR2_ABREN_Pos (20U)
24736#define USART_CR2_ABREN_Msk (0x1UL << USART_CR2_ABREN_Pos)
24737#define USART_CR2_ABREN USART_CR2_ABREN_Msk
24738#define USART_CR2_ABRMODE_Pos (21U)
24739#define USART_CR2_ABRMODE_Msk (0x3UL << USART_CR2_ABRMODE_Pos)
24740#define USART_CR2_ABRMODE USART_CR2_ABRMODE_Msk
24741#define USART_CR2_ABRMODE_0 (0x1UL << USART_CR2_ABRMODE_Pos)
24742#define USART_CR2_ABRMODE_1 (0x2UL << USART_CR2_ABRMODE_Pos)
24743#define USART_CR2_RTOEN_Pos (23U)
24744#define USART_CR2_RTOEN_Msk (0x1UL << USART_CR2_RTOEN_Pos)
24745#define USART_CR2_RTOEN USART_CR2_RTOEN_Msk
24746#define USART_CR2_ADD_Pos (24U)
24747#define USART_CR2_ADD_Msk (0xFFUL << USART_CR2_ADD_Pos)
24748#define USART_CR2_ADD USART_CR2_ADD_Msk
24750/****************** Bit definition for USART_CR3 register *******************/
24751#define USART_CR3_EIE_Pos (0U)
24752#define USART_CR3_EIE_Msk (0x1UL << USART_CR3_EIE_Pos)
24753#define USART_CR3_EIE USART_CR3_EIE_Msk
24754#define USART_CR3_IREN_Pos (1U)
24755#define USART_CR3_IREN_Msk (0x1UL << USART_CR3_IREN_Pos)
24756#define USART_CR3_IREN USART_CR3_IREN_Msk
24757#define USART_CR3_IRLP_Pos (2U)
24758#define USART_CR3_IRLP_Msk (0x1UL << USART_CR3_IRLP_Pos)
24759#define USART_CR3_IRLP USART_CR3_IRLP_Msk
24760#define USART_CR3_HDSEL_Pos (3U)
24761#define USART_CR3_HDSEL_Msk (0x1UL << USART_CR3_HDSEL_Pos)
24762#define USART_CR3_HDSEL USART_CR3_HDSEL_Msk
24763#define USART_CR3_NACK_Pos (4U)
24764#define USART_CR3_NACK_Msk (0x1UL << USART_CR3_NACK_Pos)
24765#define USART_CR3_NACK USART_CR3_NACK_Msk
24766#define USART_CR3_SCEN_Pos (5U)
24767#define USART_CR3_SCEN_Msk (0x1UL << USART_CR3_SCEN_Pos)
24768#define USART_CR3_SCEN USART_CR3_SCEN_Msk
24769#define USART_CR3_DMAR_Pos (6U)
24770#define USART_CR3_DMAR_Msk (0x1UL << USART_CR3_DMAR_Pos)
24771#define USART_CR3_DMAR USART_CR3_DMAR_Msk
24772#define USART_CR3_DMAT_Pos (7U)
24773#define USART_CR3_DMAT_Msk (0x1UL << USART_CR3_DMAT_Pos)
24774#define USART_CR3_DMAT USART_CR3_DMAT_Msk
24775#define USART_CR3_RTSE_Pos (8U)
24776#define USART_CR3_RTSE_Msk (0x1UL << USART_CR3_RTSE_Pos)
24777#define USART_CR3_RTSE USART_CR3_RTSE_Msk
24778#define USART_CR3_CTSE_Pos (9U)
24779#define USART_CR3_CTSE_Msk (0x1UL << USART_CR3_CTSE_Pos)
24780#define USART_CR3_CTSE USART_CR3_CTSE_Msk
24781#define USART_CR3_CTSIE_Pos (10U)
24782#define USART_CR3_CTSIE_Msk (0x1UL << USART_CR3_CTSIE_Pos)
24783#define USART_CR3_CTSIE USART_CR3_CTSIE_Msk
24784#define USART_CR3_ONEBIT_Pos (11U)
24785#define USART_CR3_ONEBIT_Msk (0x1UL << USART_CR3_ONEBIT_Pos)
24786#define USART_CR3_ONEBIT USART_CR3_ONEBIT_Msk
24787#define USART_CR3_OVRDIS_Pos (12U)
24788#define USART_CR3_OVRDIS_Msk (0x1UL << USART_CR3_OVRDIS_Pos)
24789#define USART_CR3_OVRDIS USART_CR3_OVRDIS_Msk
24790#define USART_CR3_DDRE_Pos (13U)
24791#define USART_CR3_DDRE_Msk (0x1UL << USART_CR3_DDRE_Pos)
24792#define USART_CR3_DDRE USART_CR3_DDRE_Msk
24793#define USART_CR3_DEM_Pos (14U)
24794#define USART_CR3_DEM_Msk (0x1UL << USART_CR3_DEM_Pos)
24795#define USART_CR3_DEM USART_CR3_DEM_Msk
24796#define USART_CR3_DEP_Pos (15U)
24797#define USART_CR3_DEP_Msk (0x1UL << USART_CR3_DEP_Pos)
24798#define USART_CR3_DEP USART_CR3_DEP_Msk
24799#define USART_CR3_SCARCNT_Pos (17U)
24800#define USART_CR3_SCARCNT_Msk (0x7UL << USART_CR3_SCARCNT_Pos)
24801#define USART_CR3_SCARCNT USART_CR3_SCARCNT_Msk
24802#define USART_CR3_SCARCNT_0 (0x1UL << USART_CR3_SCARCNT_Pos)
24803#define USART_CR3_SCARCNT_1 (0x2UL << USART_CR3_SCARCNT_Pos)
24804#define USART_CR3_SCARCNT_2 (0x4UL << USART_CR3_SCARCNT_Pos)
24805#define USART_CR3_WUS_Pos (20U)
24806#define USART_CR3_WUS_Msk (0x3UL << USART_CR3_WUS_Pos)
24807#define USART_CR3_WUS USART_CR3_WUS_Msk
24808#define USART_CR3_WUS_0 (0x1UL << USART_CR3_WUS_Pos)
24809#define USART_CR3_WUS_1 (0x2UL << USART_CR3_WUS_Pos)
24810#define USART_CR3_WUFIE_Pos (22U)
24811#define USART_CR3_WUFIE_Msk (0x1UL << USART_CR3_WUFIE_Pos)
24812#define USART_CR3_WUFIE USART_CR3_WUFIE_Msk
24813#define USART_CR3_TXFTIE_Pos (23U)
24814#define USART_CR3_TXFTIE_Msk (0x1UL << USART_CR3_TXFTIE_Pos)
24815#define USART_CR3_TXFTIE USART_CR3_TXFTIE_Msk
24816#define USART_CR3_TCBGTIE_Pos (24U)
24817#define USART_CR3_TCBGTIE_Msk (0x1UL << USART_CR3_TCBGTIE_Pos)
24818#define USART_CR3_TCBGTIE USART_CR3_TCBGTIE_Msk
24819#define USART_CR3_RXFTCFG_Pos (25U)
24820#define USART_CR3_RXFTCFG_Msk (0x7UL << USART_CR3_RXFTCFG_Pos)
24821#define USART_CR3_RXFTCFG USART_CR3_RXFTCFG_Msk
24822#define USART_CR3_RXFTCFG_0 (0x1UL << USART_CR3_RXFTCFG_Pos)
24823#define USART_CR3_RXFTCFG_1 (0x2UL << USART_CR3_RXFTCFG_Pos)
24824#define USART_CR3_RXFTCFG_2 (0x4UL << USART_CR3_RXFTCFG_Pos)
24825#define USART_CR3_RXFTIE_Pos (28U)
24826#define USART_CR3_RXFTIE_Msk (0x1UL << USART_CR3_RXFTIE_Pos)
24827#define USART_CR3_RXFTIE USART_CR3_RXFTIE_Msk
24828#define USART_CR3_TXFTCFG_Pos (29U)
24829#define USART_CR3_TXFTCFG_Msk (0x7UL << USART_CR3_TXFTCFG_Pos)
24830#define USART_CR3_TXFTCFG USART_CR3_TXFTCFG_Msk
24831#define USART_CR3_TXFTCFG_0 (0x1UL << USART_CR3_TXFTCFG_Pos)
24832#define USART_CR3_TXFTCFG_1 (0x2UL << USART_CR3_TXFTCFG_Pos)
24833#define USART_CR3_TXFTCFG_2 (0x4UL << USART_CR3_TXFTCFG_Pos)
24835/****************** Bit definition for USART_BRR register *******************/
24836#define USART_BRR_DIV_FRACTION_Pos (0U)
24837#define USART_BRR_DIV_FRACTION_Msk (0xFUL << USART_BRR_DIV_FRACTION_Pos)
24838#define USART_BRR_DIV_FRACTION USART_BRR_DIV_FRACTION_Msk
24839#define USART_BRR_DIV_MANTISSA_Pos (4U)
24840#define USART_BRR_DIV_MANTISSA_Msk (0xFFFUL << USART_BRR_DIV_MANTISSA_Pos)
24841#define USART_BRR_DIV_MANTISSA USART_BRR_DIV_MANTISSA_Msk
24843/****************** Bit definition for USART_GTPR register ******************/
24844#define USART_GTPR_PSC_Pos (0U)
24845#define USART_GTPR_PSC_Msk (0xFFUL << USART_GTPR_PSC_Pos)
24846#define USART_GTPR_PSC USART_GTPR_PSC_Msk
24847#define USART_GTPR_GT_Pos (8U)
24848#define USART_GTPR_GT_Msk (0xFFUL << USART_GTPR_GT_Pos)
24849#define USART_GTPR_GT USART_GTPR_GT_Msk
24851/******************* Bit definition for USART_RTOR register *****************/
24852#define USART_RTOR_RTO_Pos (0U)
24853#define USART_RTOR_RTO_Msk (0xFFFFFFUL << USART_RTOR_RTO_Pos)
24854#define USART_RTOR_RTO USART_RTOR_RTO_Msk
24855#define USART_RTOR_BLEN_Pos (24U)
24856#define USART_RTOR_BLEN_Msk (0xFFUL << USART_RTOR_BLEN_Pos)
24857#define USART_RTOR_BLEN USART_RTOR_BLEN_Msk
24859/******************* Bit definition for USART_RQR register ******************/
24860#define USART_RQR_ABRRQ_Pos (0U)
24861#define USART_RQR_ABRRQ_Msk (0x1UL << USART_RQR_ABRRQ_Pos)
24862#define USART_RQR_ABRRQ USART_RQR_ABRRQ_Msk
24863#define USART_RQR_SBKRQ_Pos (1U)
24864#define USART_RQR_SBKRQ_Msk (0x1UL << USART_RQR_SBKRQ_Pos)
24865#define USART_RQR_SBKRQ USART_RQR_SBKRQ_Msk
24866#define USART_RQR_MMRQ_Pos (2U)
24867#define USART_RQR_MMRQ_Msk (0x1UL << USART_RQR_MMRQ_Pos)
24868#define USART_RQR_MMRQ USART_RQR_MMRQ_Msk
24869#define USART_RQR_RXFRQ_Pos (3U)
24870#define USART_RQR_RXFRQ_Msk (0x1UL << USART_RQR_RXFRQ_Pos)
24871#define USART_RQR_RXFRQ USART_RQR_RXFRQ_Msk
24872#define USART_RQR_TXFRQ_Pos (4U)
24873#define USART_RQR_TXFRQ_Msk (0x1UL << USART_RQR_TXFRQ_Pos)
24874#define USART_RQR_TXFRQ USART_RQR_TXFRQ_Msk
24876/******************* Bit definition for USART_ISR register ******************/
24877#define USART_ISR_PE_Pos (0U)
24878#define USART_ISR_PE_Msk (0x1UL << USART_ISR_PE_Pos)
24879#define USART_ISR_PE USART_ISR_PE_Msk
24880#define USART_ISR_FE_Pos (1U)
24881#define USART_ISR_FE_Msk (0x1UL << USART_ISR_FE_Pos)
24882#define USART_ISR_FE USART_ISR_FE_Msk
24883#define USART_ISR_NE_Pos (2U)
24884#define USART_ISR_NE_Msk (0x1UL << USART_ISR_NE_Pos)
24885#define USART_ISR_NE USART_ISR_NE_Msk
24886#define USART_ISR_ORE_Pos (3U)
24887#define USART_ISR_ORE_Msk (0x1UL << USART_ISR_ORE_Pos)
24888#define USART_ISR_ORE USART_ISR_ORE_Msk
24889#define USART_ISR_IDLE_Pos (4U)
24890#define USART_ISR_IDLE_Msk (0x1UL << USART_ISR_IDLE_Pos)
24891#define USART_ISR_IDLE USART_ISR_IDLE_Msk
24892#define USART_ISR_RXNE_RXFNE_Pos (5U)
24893#define USART_ISR_RXNE_RXFNE_Msk (0x1UL << USART_ISR_RXNE_RXFNE_Pos)
24894#define USART_ISR_RXNE_RXFNE USART_ISR_RXNE_RXFNE_Msk
24895#define USART_ISR_TC_Pos (6U)
24896#define USART_ISR_TC_Msk (0x1UL << USART_ISR_TC_Pos)
24897#define USART_ISR_TC USART_ISR_TC_Msk
24898#define USART_ISR_TXE_TXFNF_Pos (7U)
24899#define USART_ISR_TXE_TXFNF_Msk (0x1UL << USART_ISR_TXE_TXFNF_Pos)
24900#define USART_ISR_TXE_TXFNF USART_ISR_TXE_TXFNF_Msk
24901#define USART_ISR_LBDF_Pos (8U)
24902#define USART_ISR_LBDF_Msk (0x1UL << USART_ISR_LBDF_Pos)
24903#define USART_ISR_LBDF USART_ISR_LBDF_Msk
24904#define USART_ISR_CTSIF_Pos (9U)
24905#define USART_ISR_CTSIF_Msk (0x1UL << USART_ISR_CTSIF_Pos)
24906#define USART_ISR_CTSIF USART_ISR_CTSIF_Msk
24907#define USART_ISR_CTS_Pos (10U)
24908#define USART_ISR_CTS_Msk (0x1UL << USART_ISR_CTS_Pos)
24909#define USART_ISR_CTS USART_ISR_CTS_Msk
24910#define USART_ISR_RTOF_Pos (11U)
24911#define USART_ISR_RTOF_Msk (0x1UL << USART_ISR_RTOF_Pos)
24912#define USART_ISR_RTOF USART_ISR_RTOF_Msk
24913#define USART_ISR_EOBF_Pos (12U)
24914#define USART_ISR_EOBF_Msk (0x1UL << USART_ISR_EOBF_Pos)
24915#define USART_ISR_EOBF USART_ISR_EOBF_Msk
24916#define USART_ISR_UDR_Pos (13U)
24917#define USART_ISR_UDR_Msk (0x1UL << USART_ISR_UDR_Pos)
24918#define USART_ISR_UDR USART_ISR_UDR_Msk
24919#define USART_ISR_ABRE_Pos (14U)
24920#define USART_ISR_ABRE_Msk (0x1UL << USART_ISR_ABRE_Pos)
24921#define USART_ISR_ABRE USART_ISR_ABRE_Msk
24922#define USART_ISR_ABRF_Pos (15U)
24923#define USART_ISR_ABRF_Msk (0x1UL << USART_ISR_ABRF_Pos)
24924#define USART_ISR_ABRF USART_ISR_ABRF_Msk
24925#define USART_ISR_BUSY_Pos (16U)
24926#define USART_ISR_BUSY_Msk (0x1UL << USART_ISR_BUSY_Pos)
24927#define USART_ISR_BUSY USART_ISR_BUSY_Msk
24928#define USART_ISR_CMF_Pos (17U)
24929#define USART_ISR_CMF_Msk (0x1UL << USART_ISR_CMF_Pos)
24930#define USART_ISR_CMF USART_ISR_CMF_Msk
24931#define USART_ISR_SBKF_Pos (18U)
24932#define USART_ISR_SBKF_Msk (0x1UL << USART_ISR_SBKF_Pos)
24933#define USART_ISR_SBKF USART_ISR_SBKF_Msk
24934#define USART_ISR_RWU_Pos (19U)
24935#define USART_ISR_RWU_Msk (0x1UL << USART_ISR_RWU_Pos)
24936#define USART_ISR_RWU USART_ISR_RWU_Msk
24937#define USART_ISR_WUF_Pos (20U)
24938#define USART_ISR_WUF_Msk (0x1UL << USART_ISR_WUF_Pos)
24939#define USART_ISR_WUF USART_ISR_WUF_Msk
24940#define USART_ISR_TEACK_Pos (21U)
24941#define USART_ISR_TEACK_Msk (0x1UL << USART_ISR_TEACK_Pos)
24942#define USART_ISR_TEACK USART_ISR_TEACK_Msk
24943#define USART_ISR_REACK_Pos (22U)
24944#define USART_ISR_REACK_Msk (0x1UL << USART_ISR_REACK_Pos)
24945#define USART_ISR_REACK USART_ISR_REACK_Msk
24946#define USART_ISR_TXFE_Pos (23U)
24947#define USART_ISR_TXFE_Msk (0x1UL << USART_ISR_TXFE_Pos)
24948#define USART_ISR_TXFE USART_ISR_TXFE_Msk
24949#define USART_ISR_RXFF_Pos (24U)
24950#define USART_ISR_RXFF_Msk (0x1UL << USART_ISR_RXFF_Pos)
24951#define USART_ISR_RXFF USART_ISR_RXFF_Msk
24952#define USART_ISR_TCBGT_Pos (25U)
24953#define USART_ISR_TCBGT_Msk (0x1UL << USART_ISR_TCBGT_Pos)
24954#define USART_ISR_TCBGT USART_ISR_TCBGT_Msk
24955#define USART_ISR_RXFT_Pos (26U)
24956#define USART_ISR_RXFT_Msk (0x1UL << USART_ISR_RXFT_Pos)
24957#define USART_ISR_RXFT USART_ISR_RXFT_Msk
24958#define USART_ISR_TXFT_Pos (27U)
24959#define USART_ISR_TXFT_Msk (0x1UL << USART_ISR_TXFT_Pos)
24960#define USART_ISR_TXFT USART_ISR_TXFT_Msk
24962/******************* Bit definition for USART_ICR register ******************/
24963#define USART_ICR_PECF_Pos (0U)
24964#define USART_ICR_PECF_Msk (0x1UL << USART_ICR_PECF_Pos)
24965#define USART_ICR_PECF USART_ICR_PECF_Msk
24966#define USART_ICR_FECF_Pos (1U)
24967#define USART_ICR_FECF_Msk (0x1UL << USART_ICR_FECF_Pos)
24968#define USART_ICR_FECF USART_ICR_FECF_Msk
24969#define USART_ICR_NECF_Pos (2U)
24970#define USART_ICR_NECF_Msk (0x1UL << USART_ICR_NECF_Pos)
24971#define USART_ICR_NECF USART_ICR_NECF_Msk
24972#define USART_ICR_ORECF_Pos (3U)
24973#define USART_ICR_ORECF_Msk (0x1UL << USART_ICR_ORECF_Pos)
24974#define USART_ICR_ORECF USART_ICR_ORECF_Msk
24975#define USART_ICR_IDLECF_Pos (4U)
24976#define USART_ICR_IDLECF_Msk (0x1UL << USART_ICR_IDLECF_Pos)
24977#define USART_ICR_IDLECF USART_ICR_IDLECF_Msk
24978#define USART_ICR_TXFECF_Pos (5U)
24979#define USART_ICR_TXFECF_Msk (0x1UL << USART_ICR_TXFECF_Pos)
24980#define USART_ICR_TXFECF USART_ICR_TXFECF_Msk
24981#define USART_ICR_TCCF_Pos (6U)
24982#define USART_ICR_TCCF_Msk (0x1UL << USART_ICR_TCCF_Pos)
24983#define USART_ICR_TCCF USART_ICR_TCCF_Msk
24984#define USART_ICR_TCBGTCF_Pos (7U)
24985#define USART_ICR_TCBGTCF_Msk (0x1UL << USART_ICR_TCBGTCF_Pos)
24986#define USART_ICR_TCBGTCF USART_ICR_TCBGTCF_Msk
24987#define USART_ICR_LBDCF_Pos (8U)
24988#define USART_ICR_LBDCF_Msk (0x1UL << USART_ICR_LBDCF_Pos)
24989#define USART_ICR_LBDCF USART_ICR_LBDCF_Msk
24990#define USART_ICR_CTSCF_Pos (9U)
24991#define USART_ICR_CTSCF_Msk (0x1UL << USART_ICR_CTSCF_Pos)
24992#define USART_ICR_CTSCF USART_ICR_CTSCF_Msk
24993#define USART_ICR_RTOCF_Pos (11U)
24994#define USART_ICR_RTOCF_Msk (0x1UL << USART_ICR_RTOCF_Pos)
24995#define USART_ICR_RTOCF USART_ICR_RTOCF_Msk
24996#define USART_ICR_EOBCF_Pos (12U)
24997#define USART_ICR_EOBCF_Msk (0x1UL << USART_ICR_EOBCF_Pos)
24998#define USART_ICR_EOBCF USART_ICR_EOBCF_Msk
24999#define USART_ICR_UDRCF_Pos (13U)
25000#define USART_ICR_UDRCF_Msk (0x1UL << USART_ICR_UDRCF_Pos)
25001#define USART_ICR_UDRCF USART_ICR_UDRCF_Msk
25002#define USART_ICR_CMCF_Pos (17U)
25003#define USART_ICR_CMCF_Msk (0x1UL << USART_ICR_CMCF_Pos)
25004#define USART_ICR_CMCF USART_ICR_CMCF_Msk
25005#define USART_ICR_WUCF_Pos (20U)
25006#define USART_ICR_WUCF_Msk (0x1UL << USART_ICR_WUCF_Pos)
25007#define USART_ICR_WUCF USART_ICR_WUCF_Msk
25009/******************* Bit definition for USART_RDR register ******************/
25010#define USART_RDR_RDR_Pos (0U)
25011#define USART_RDR_RDR_Msk (0x1FFUL << USART_RDR_RDR_Pos)
25012#define USART_RDR_RDR USART_RDR_RDR_Msk
25014/******************* Bit definition for USART_TDR register ******************/
25015#define USART_TDR_TDR_Pos (0U)
25016#define USART_TDR_TDR_Msk (0x1FFUL << USART_TDR_TDR_Pos)
25017#define USART_TDR_TDR USART_TDR_TDR_Msk
25019/******************* Bit definition for USART_PRESC register ******************/
25020#define USART_PRESC_PRESCALER_Pos (0U)
25021#define USART_PRESC_PRESCALER_Msk (0xFUL << USART_PRESC_PRESCALER_Pos)
25022#define USART_PRESC_PRESCALER USART_PRESC_PRESCALER_Msk
25023#define USART_PRESC_PRESCALER_0 (0x1UL << USART_PRESC_PRESCALER_Pos)
25024#define USART_PRESC_PRESCALER_1 (0x2UL << USART_PRESC_PRESCALER_Pos)
25025#define USART_PRESC_PRESCALER_2 (0x4UL << USART_PRESC_PRESCALER_Pos)
25026#define USART_PRESC_PRESCALER_3 (0x8UL << USART_PRESC_PRESCALER_Pos)
25028/******************************************************************************/
25029/* */
25030/* Single Wire Protocol Master Interface (SWPMI) */
25031/* */
25032/******************************************************************************/
25033
25034/******************* Bit definition for SWPMI_CR register ********************/
25035#define SWPMI_CR_RXDMA_Pos (0U)
25036#define SWPMI_CR_RXDMA_Msk (0x1UL << SWPMI_CR_RXDMA_Pos)
25037#define SWPMI_CR_RXDMA SWPMI_CR_RXDMA_Msk
25038#define SWPMI_CR_TXDMA_Pos (1U)
25039#define SWPMI_CR_TXDMA_Msk (0x1UL << SWPMI_CR_TXDMA_Pos)
25040#define SWPMI_CR_TXDMA SWPMI_CR_TXDMA_Msk
25041#define SWPMI_CR_RXMODE_Pos (2U)
25042#define SWPMI_CR_RXMODE_Msk (0x1UL << SWPMI_CR_RXMODE_Pos)
25043#define SWPMI_CR_RXMODE SWPMI_CR_RXMODE_Msk
25044#define SWPMI_CR_TXMODE_Pos (3U)
25045#define SWPMI_CR_TXMODE_Msk (0x1UL << SWPMI_CR_TXMODE_Pos)
25046#define SWPMI_CR_TXMODE SWPMI_CR_TXMODE_Msk
25047#define SWPMI_CR_LPBK_Pos (4U)
25048#define SWPMI_CR_LPBK_Msk (0x1UL << SWPMI_CR_LPBK_Pos)
25049#define SWPMI_CR_LPBK SWPMI_CR_LPBK_Msk
25050#define SWPMI_CR_SWPACT_Pos (5U)
25051#define SWPMI_CR_SWPACT_Msk (0x1UL << SWPMI_CR_SWPACT_Pos)
25052#define SWPMI_CR_SWPACT SWPMI_CR_SWPACT_Msk
25053#define SWPMI_CR_DEACT_Pos (10U)
25054#define SWPMI_CR_DEACT_Msk (0x1UL << SWPMI_CR_DEACT_Pos)
25055#define SWPMI_CR_DEACT SWPMI_CR_DEACT_Msk
25056#define SWPMI_CR_SWPEN_Pos (11U)
25057#define SWPMI_CR_SWPEN_Msk (0x1UL << SWPMI_CR_SWPEN_Pos)
25058#define SWPMI_CR_SWPEN SWPMI_CR_SWPEN_Msk
25060/******************* Bit definition for SWPMI_BRR register ********************/
25061#define SWPMI_BRR_BR_Pos (0U)
25062#define SWPMI_BRR_BR_Msk (0xFFUL << SWPMI_BRR_BR_Pos)
25063#define SWPMI_BRR_BR SWPMI_BRR_BR_Msk
25065/******************* Bit definition for SWPMI_ISR register ********************/
25066#define SWPMI_ISR_RXBFF_Pos (0U)
25067#define SWPMI_ISR_RXBFF_Msk (0x1UL << SWPMI_ISR_RXBFF_Pos)
25068#define SWPMI_ISR_RXBFF SWPMI_ISR_RXBFF_Msk
25069#define SWPMI_ISR_TXBEF_Pos (1U)
25070#define SWPMI_ISR_TXBEF_Msk (0x1UL << SWPMI_ISR_TXBEF_Pos)
25071#define SWPMI_ISR_TXBEF SWPMI_ISR_TXBEF_Msk
25072#define SWPMI_ISR_RXBERF_Pos (2U)
25073#define SWPMI_ISR_RXBERF_Msk (0x1UL << SWPMI_ISR_RXBERF_Pos)
25074#define SWPMI_ISR_RXBERF SWPMI_ISR_RXBERF_Msk
25075#define SWPMI_ISR_RXOVRF_Pos (3U)
25076#define SWPMI_ISR_RXOVRF_Msk (0x1UL << SWPMI_ISR_RXOVRF_Pos)
25077#define SWPMI_ISR_RXOVRF SWPMI_ISR_RXOVRF_Msk
25078#define SWPMI_ISR_TXUNRF_Pos (4U)
25079#define SWPMI_ISR_TXUNRF_Msk (0x1UL << SWPMI_ISR_TXUNRF_Pos)
25080#define SWPMI_ISR_TXUNRF SWPMI_ISR_TXUNRF_Msk
25081#define SWPMI_ISR_RXNE_Pos (5U)
25082#define SWPMI_ISR_RXNE_Msk (0x1UL << SWPMI_ISR_RXNE_Pos)
25083#define SWPMI_ISR_RXNE SWPMI_ISR_RXNE_Msk
25084#define SWPMI_ISR_TXE_Pos (6U)
25085#define SWPMI_ISR_TXE_Msk (0x1UL << SWPMI_ISR_TXE_Pos)
25086#define SWPMI_ISR_TXE SWPMI_ISR_TXE_Msk
25087#define SWPMI_ISR_TCF_Pos (7U)
25088#define SWPMI_ISR_TCF_Msk (0x1UL << SWPMI_ISR_TCF_Pos)
25089#define SWPMI_ISR_TCF SWPMI_ISR_TCF_Msk
25090#define SWPMI_ISR_SRF_Pos (8U)
25091#define SWPMI_ISR_SRF_Msk (0x1UL << SWPMI_ISR_SRF_Pos)
25092#define SWPMI_ISR_SRF SWPMI_ISR_SRF_Msk
25093#define SWPMI_ISR_SUSP_Pos (9U)
25094#define SWPMI_ISR_SUSP_Msk (0x1UL << SWPMI_ISR_SUSP_Pos)
25095#define SWPMI_ISR_SUSP SWPMI_ISR_SUSP_Msk
25096#define SWPMI_ISR_DEACTF_Pos (10U)
25097#define SWPMI_ISR_DEACTF_Msk (0x1UL << SWPMI_ISR_DEACTF_Pos)
25098#define SWPMI_ISR_DEACTF SWPMI_ISR_DEACTF_Msk
25099#define SWPMI_ISR_RDYF_Pos (11U)
25100#define SWPMI_ISR_RDYF_Msk (0x1UL << SWPMI_ISR_RDYF_Pos)
25101#define SWPMI_ISR_RDYF SWPMI_ISR_RDYF_Msk
25103/******************* Bit definition for SWPMI_ICR register ********************/
25104#define SWPMI_ICR_CRXBFF_Pos (0U)
25105#define SWPMI_ICR_CRXBFF_Msk (0x1UL << SWPMI_ICR_CRXBFF_Pos)
25106#define SWPMI_ICR_CRXBFF SWPMI_ICR_CRXBFF_Msk
25107#define SWPMI_ICR_CTXBEF_Pos (1U)
25108#define SWPMI_ICR_CTXBEF_Msk (0x1UL << SWPMI_ICR_CTXBEF_Pos)
25109#define SWPMI_ICR_CTXBEF SWPMI_ICR_CTXBEF_Msk
25110#define SWPMI_ICR_CRXBERF_Pos (2U)
25111#define SWPMI_ICR_CRXBERF_Msk (0x1UL << SWPMI_ICR_CRXBERF_Pos)
25112#define SWPMI_ICR_CRXBERF SWPMI_ICR_CRXBERF_Msk
25113#define SWPMI_ICR_CRXOVRF_Pos (3U)
25114#define SWPMI_ICR_CRXOVRF_Msk (0x1UL << SWPMI_ICR_CRXOVRF_Pos)
25115#define SWPMI_ICR_CRXOVRF SWPMI_ICR_CRXOVRF_Msk
25116#define SWPMI_ICR_CTXUNRF_Pos (4U)
25117#define SWPMI_ICR_CTXUNRF_Msk (0x1UL << SWPMI_ICR_CTXUNRF_Pos)
25118#define SWPMI_ICR_CTXUNRF SWPMI_ICR_CTXUNRF_Msk
25119#define SWPMI_ICR_CTCF_Pos (7U)
25120#define SWPMI_ICR_CTCF_Msk (0x1UL << SWPMI_ICR_CTCF_Pos)
25121#define SWPMI_ICR_CTCF SWPMI_ICR_CTCF_Msk
25122#define SWPMI_ICR_CSRF_Pos (8U)
25123#define SWPMI_ICR_CSRF_Msk (0x1UL << SWPMI_ICR_CSRF_Pos)
25124#define SWPMI_ICR_CSRF SWPMI_ICR_CSRF_Msk
25125#define SWPMI_ICR_CRDYF_Pos (11U)
25126#define SWPMI_ICR_CRDYF_Msk (0x1UL << SWPMI_ICR_CRDYF_Pos)
25127#define SWPMI_ICR_CRDYF SWPMI_ICR_CRDYF_Msk
25129/******************* Bit definition for SWPMI_IER register ********************/
25130#define SWPMI_IER_RXBFIE_Pos (0U)
25131#define SWPMI_IER_RXBFIE_Msk (0x1UL << SWPMI_IER_RXBFIE_Pos)
25132#define SWPMI_IER_RXBFIE SWPMI_IER_RXBFIE_Msk
25133#define SWPMI_IER_TXBEIE_Pos (1U)
25134#define SWPMI_IER_TXBEIE_Msk (0x1UL << SWPMI_IER_TXBEIE_Pos)
25135#define SWPMI_IER_TXBEIE SWPMI_IER_TXBEIE_Msk
25136#define SWPMI_IER_RXBERIE_Pos (2U)
25137#define SWPMI_IER_RXBERIE_Msk (0x1UL << SWPMI_IER_RXBERIE_Pos)
25138#define SWPMI_IER_RXBERIE SWPMI_IER_RXBERIE_Msk
25139#define SWPMI_IER_RXOVRIE_Pos (3U)
25140#define SWPMI_IER_RXOVRIE_Msk (0x1UL << SWPMI_IER_RXOVRIE_Pos)
25141#define SWPMI_IER_RXOVRIE SWPMI_IER_RXOVRIE_Msk
25142#define SWPMI_IER_TXUNRIE_Pos (4U)
25143#define SWPMI_IER_TXUNRIE_Msk (0x1UL << SWPMI_IER_TXUNRIE_Pos)
25144#define SWPMI_IER_TXUNRIE SWPMI_IER_TXUNRIE_Msk
25145#define SWPMI_IER_RIE_Pos (5U)
25146#define SWPMI_IER_RIE_Msk (0x1UL << SWPMI_IER_RIE_Pos)
25147#define SWPMI_IER_RIE SWPMI_IER_RIE_Msk
25148#define SWPMI_IER_TIE_Pos (6U)
25149#define SWPMI_IER_TIE_Msk (0x1UL << SWPMI_IER_TIE_Pos)
25150#define SWPMI_IER_TIE SWPMI_IER_TIE_Msk
25151#define SWPMI_IER_TCIE_Pos (7U)
25152#define SWPMI_IER_TCIE_Msk (0x1UL << SWPMI_IER_TCIE_Pos)
25153#define SWPMI_IER_TCIE SWPMI_IER_TCIE_Msk
25154#define SWPMI_IER_SRIE_Pos (8U)
25155#define SWPMI_IER_SRIE_Msk (0x1UL << SWPMI_IER_SRIE_Pos)
25156#define SWPMI_IER_SRIE SWPMI_IER_SRIE_Msk
25157#define SWPMI_IER_RDYIE_Pos (11U)
25158#define SWPMI_IER_RDYIE_Msk (0x1UL << SWPMI_IER_RDYIE_Pos)
25159#define SWPMI_IER_RDYIE SWPMI_IER_RDYIE_Msk
25161/******************* Bit definition for SWPMI_RFL register ********************/
25162#define SWPMI_RFL_RFL_Pos (0U)
25163#define SWPMI_RFL_RFL_Msk (0x1FUL << SWPMI_RFL_RFL_Pos)
25164#define SWPMI_RFL_RFL SWPMI_RFL_RFL_Msk
25165#define SWPMI_RFL_RFL_0_1 (0x00000003U)
25167/******************* Bit definition for SWPMI_TDR register ********************/
25168#define SWPMI_TDR_TD_Pos (0U)
25169#define SWPMI_TDR_TD_Msk (0xFFFFFFFFUL << SWPMI_TDR_TD_Pos)
25170#define SWPMI_TDR_TD SWPMI_TDR_TD_Msk
25172/******************* Bit definition for SWPMI_RDR register ********************/
25173#define SWPMI_RDR_RD_Pos (0U)
25174#define SWPMI_RDR_RD_Msk (0xFFFFFFFFUL << SWPMI_RDR_RD_Pos)
25175#define SWPMI_RDR_RD SWPMI_RDR_RD_Msk
25178/******************* Bit definition for SWPMI_OR register ********************/
25179#define SWPMI_OR_TBYP_Pos (0U)
25180#define SWPMI_OR_TBYP_Msk (0x1UL << SWPMI_OR_TBYP_Pos)
25181#define SWPMI_OR_TBYP SWPMI_OR_TBYP_Msk
25182#define SWPMI_OR_CLASS_Pos (1U)
25183#define SWPMI_OR_CLASS_Msk (0x1UL << SWPMI_OR_CLASS_Pos)
25184#define SWPMI_OR_CLASS SWPMI_OR_CLASS_Msk
25186/******************************************************************************/
25187/* */
25188/* Window WATCHDOG */
25189/* */
25190/******************************************************************************/
25191/******************* Bit definition for WWDG_CR register ********************/
25192#define WWDG_CR_T_Pos (0U)
25193#define WWDG_CR_T_Msk (0x7FUL << WWDG_CR_T_Pos)
25194#define WWDG_CR_T WWDG_CR_T_Msk
25195#define WWDG_CR_T_0 (0x01UL << WWDG_CR_T_Pos)
25196#define WWDG_CR_T_1 (0x02UL << WWDG_CR_T_Pos)
25197#define WWDG_CR_T_2 (0x04UL << WWDG_CR_T_Pos)
25198#define WWDG_CR_T_3 (0x08UL << WWDG_CR_T_Pos)
25199#define WWDG_CR_T_4 (0x10UL << WWDG_CR_T_Pos)
25200#define WWDG_CR_T_5 (0x20UL << WWDG_CR_T_Pos)
25201#define WWDG_CR_T_6 (0x40UL << WWDG_CR_T_Pos)
25203#define WWDG_CR_WDGA_Pos (7U)
25204#define WWDG_CR_WDGA_Msk (0x1UL << WWDG_CR_WDGA_Pos)
25205#define WWDG_CR_WDGA WWDG_CR_WDGA_Msk
25207/******************* Bit definition for WWDG_CFR register *******************/
25208#define WWDG_CFR_W_Pos (0U)
25209#define WWDG_CFR_W_Msk (0x7FUL << WWDG_CFR_W_Pos)
25210#define WWDG_CFR_W WWDG_CFR_W_Msk
25211#define WWDG_CFR_W_0 (0x01UL << WWDG_CFR_W_Pos)
25212#define WWDG_CFR_W_1 (0x02UL << WWDG_CFR_W_Pos)
25213#define WWDG_CFR_W_2 (0x04UL << WWDG_CFR_W_Pos)
25214#define WWDG_CFR_W_3 (0x08UL << WWDG_CFR_W_Pos)
25215#define WWDG_CFR_W_4 (0x10UL << WWDG_CFR_W_Pos)
25216#define WWDG_CFR_W_5 (0x20UL << WWDG_CFR_W_Pos)
25217#define WWDG_CFR_W_6 (0x40UL << WWDG_CFR_W_Pos)
25219#define WWDG_CFR_EWI_Pos (9U)
25220#define WWDG_CFR_EWI_Msk (0x1UL << WWDG_CFR_EWI_Pos)
25221#define WWDG_CFR_EWI WWDG_CFR_EWI_Msk
25223#define WWDG_CFR_WDGTB_Pos (11U)
25224#define WWDG_CFR_WDGTB_Msk (0x7UL << WWDG_CFR_WDGTB_Pos)
25225#define WWDG_CFR_WDGTB WWDG_CFR_WDGTB_Msk
25226#define WWDG_CFR_WDGTB_0 (0x1UL << WWDG_CFR_WDGTB_Pos)
25227#define WWDG_CFR_WDGTB_1 (0x2UL << WWDG_CFR_WDGTB_Pos)
25228#define WWDG_CFR_WDGTB_2 (0x4UL << WWDG_CFR_WDGTB_Pos)
25230/******************* Bit definition for WWDG_SR register ********************/
25231#define WWDG_SR_EWIF_Pos (0U)
25232#define WWDG_SR_EWIF_Msk (0x1UL << WWDG_SR_EWIF_Pos)
25233#define WWDG_SR_EWIF WWDG_SR_EWIF_Msk
25236/******************************************************************************/
25237/* */
25238/* DBG */
25239/* */
25240/******************************************************************************/
25241/********************************* DEVICE ID ********************************/
25242#define STM32H7_DEV_ID 0x450UL
25243
25244/******************** Bit definition for DBGMCU_IDCODE register *************/
25245#define DBGMCU_IDCODE_DEV_ID_Pos (0U)
25246#define DBGMCU_IDCODE_DEV_ID_Msk (0xFFFUL << DBGMCU_IDCODE_DEV_ID_Pos)
25247#define DBGMCU_IDCODE_DEV_ID DBGMCU_IDCODE_DEV_ID_Msk
25248#define DBGMCU_IDCODE_REV_ID_Pos (16U)
25249#define DBGMCU_IDCODE_REV_ID_Msk (0xFFFFUL << DBGMCU_IDCODE_REV_ID_Pos)
25250#define DBGMCU_IDCODE_REV_ID DBGMCU_IDCODE_REV_ID_Msk
25251
25252/******************** Bit definition for DBGMCU_CR register *****************/
25253#define DBGMCU_CR_DBG_SLEEPD1_Pos (0U)
25254#define DBGMCU_CR_DBG_SLEEPD1_Msk (0x1UL << DBGMCU_CR_DBG_SLEEPD1_Pos)
25255#define DBGMCU_CR_DBG_SLEEPD1 DBGMCU_CR_DBG_SLEEPD1_Msk
25256#define DBGMCU_CR_DBG_STOPD1_Pos (1U)
25257#define DBGMCU_CR_DBG_STOPD1_Msk (0x1UL << DBGMCU_CR_DBG_STOPD1_Pos)
25258#define DBGMCU_CR_DBG_STOPD1 DBGMCU_CR_DBG_STOPD1_Msk
25259#define DBGMCU_CR_DBG_STANDBYD1_Pos (2U)
25260#define DBGMCU_CR_DBG_STANDBYD1_Msk (0x1UL << DBGMCU_CR_DBG_STANDBYD1_Pos)
25261#define DBGMCU_CR_DBG_STANDBYD1 DBGMCU_CR_DBG_STANDBYD1_Msk
25262#define DBGMCU_CR_DBG_SLEEPD2_Pos (3U)
25263#define DBGMCU_CR_DBG_SLEEPD2_Msk (0x1UL << DBGMCU_CR_DBG_SLEEPD2_Pos)
25264#define DBGMCU_CR_DBG_SLEEPD2 DBGMCU_CR_DBG_SLEEPD2_Msk
25265#define DBGMCU_CR_DBG_STOPD2_Pos (4U)
25266#define DBGMCU_CR_DBG_STOPD2_Msk (0x1UL << DBGMCU_CR_DBG_STOPD2_Pos)
25267#define DBGMCU_CR_DBG_STOPD2 DBGMCU_CR_DBG_STOPD2_Msk
25268#define DBGMCU_CR_DBG_STANDBYD2_Pos (5U)
25269#define DBGMCU_CR_DBG_STANDBYD2_Msk (0x1UL << DBGMCU_CR_DBG_STANDBYD2_Pos)
25270#define DBGMCU_CR_DBG_STANDBYD2 DBGMCU_CR_DBG_STANDBYD2_Msk
25271#define DBGMCU_CR_DBG_TRACECKEN_Pos (20U)
25272#define DBGMCU_CR_DBG_TRACECKEN_Msk (0x1UL << DBGMCU_CR_DBG_TRACECKEN_Pos)
25273#define DBGMCU_CR_DBG_TRACECKEN DBGMCU_CR_DBG_TRACECKEN_Msk
25274#define DBGMCU_CR_DBG_CKD1EN_Pos (21U)
25275#define DBGMCU_CR_DBG_CKD1EN_Msk (0x1UL << DBGMCU_CR_DBG_CKD1EN_Pos)
25276#define DBGMCU_CR_DBG_CKD1EN DBGMCU_CR_DBG_CKD1EN_Msk
25277#define DBGMCU_CR_DBG_CKD3EN_Pos (22U)
25278#define DBGMCU_CR_DBG_CKD3EN_Msk (0x1UL << DBGMCU_CR_DBG_CKD3EN_Pos)
25279#define DBGMCU_CR_DBG_CKD3EN DBGMCU_CR_DBG_CKD3EN_Msk
25280#define DBGMCU_CR_DBG_TRGOEN_Pos (28U)
25281#define DBGMCU_CR_DBG_TRGOEN_Msk (0x1UL << DBGMCU_CR_DBG_TRGOEN_Pos)
25282#define DBGMCU_CR_DBG_TRGOEN DBGMCU_CR_DBG_TRGOEN_Msk
25283
25284/******************** Bit definition for APB3FZ1 register ************/
25285#define DBGMCU_APB3FZ1_DBG_WWDG1_Pos (6U)
25286#define DBGMCU_APB3FZ1_DBG_WWDG1_Msk (0x1UL << DBGMCU_APB3FZ1_DBG_WWDG1_Pos)
25287#define DBGMCU_APB3FZ1_DBG_WWDG1 DBGMCU_APB3FZ1_DBG_WWDG1_Msk
25288/******************** Bit definition for APB3FZ2 register ************/
25289#define DBGMCU_APB3FZ2_DBG_WWDG1_Pos (6U)
25290#define DBGMCU_APB3FZ2_DBG_WWDG1_Msk (0x1UL << DBGMCU_APB3FZ2_DBG_WWDG1_Pos)
25291#define DBGMCU_APB3FZ2_DBG_WWDG1 DBGMCU_APB3FZ2_DBG_WWDG1_Msk
25292/******************** Bit definition for APB1LFZ1 register ************/
25293#define DBGMCU_APB1LFZ1_DBG_TIM2_Pos (0U)
25294#define DBGMCU_APB1LFZ1_DBG_TIM2_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM2_Pos)
25295#define DBGMCU_APB1LFZ1_DBG_TIM2 DBGMCU_APB1LFZ1_DBG_TIM2_Msk
25296#define DBGMCU_APB1LFZ1_DBG_TIM3_Pos (1U)
25297#define DBGMCU_APB1LFZ1_DBG_TIM3_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM3_Pos)
25298#define DBGMCU_APB1LFZ1_DBG_TIM3 DBGMCU_APB1LFZ1_DBG_TIM3_Msk
25299#define DBGMCU_APB1LFZ1_DBG_TIM4_Pos (2U)
25300#define DBGMCU_APB1LFZ1_DBG_TIM4_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM4_Pos)
25301#define DBGMCU_APB1LFZ1_DBG_TIM4 DBGMCU_APB1LFZ1_DBG_TIM4_Msk
25302#define DBGMCU_APB1LFZ1_DBG_TIM5_Pos (3U)
25303#define DBGMCU_APB1LFZ1_DBG_TIM5_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM5_Pos)
25304#define DBGMCU_APB1LFZ1_DBG_TIM5 DBGMCU_APB1LFZ1_DBG_TIM5_Msk
25305#define DBGMCU_APB1LFZ1_DBG_TIM6_Pos (4U)
25306#define DBGMCU_APB1LFZ1_DBG_TIM6_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM6_Pos)
25307#define DBGMCU_APB1LFZ1_DBG_TIM6 DBGMCU_APB1LFZ1_DBG_TIM6_Msk
25308#define DBGMCU_APB1LFZ1_DBG_TIM7_Pos (5U)
25309#define DBGMCU_APB1LFZ1_DBG_TIM7_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM7_Pos)
25310#define DBGMCU_APB1LFZ1_DBG_TIM7 DBGMCU_APB1LFZ1_DBG_TIM7_Msk
25311#define DBGMCU_APB1LFZ1_DBG_TIM12_Pos (6U)
25312#define DBGMCU_APB1LFZ1_DBG_TIM12_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM12_Pos)
25313#define DBGMCU_APB1LFZ1_DBG_TIM12 DBGMCU_APB1LFZ1_DBG_TIM12_Msk
25314#define DBGMCU_APB1LFZ1_DBG_TIM13_Pos (7U)
25315#define DBGMCU_APB1LFZ1_DBG_TIM13_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM13_Pos)
25316#define DBGMCU_APB1LFZ1_DBG_TIM13 DBGMCU_APB1LFZ1_DBG_TIM13_Msk
25317#define DBGMCU_APB1LFZ1_DBG_TIM14_Pos (8U)
25318#define DBGMCU_APB1LFZ1_DBG_TIM14_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM14_Pos)
25319#define DBGMCU_APB1LFZ1_DBG_TIM14 DBGMCU_APB1LFZ1_DBG_TIM14_Msk
25320#define DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos (9U)
25321#define DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos)
25322#define DBGMCU_APB1LFZ1_DBG_LPTIM1 DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk
25323#define DBGMCU_APB1LFZ1_DBG_WWDG2_Pos (11U)
25324#define DBGMCU_APB1LFZ1_DBG_WWDG2_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_WWDG2_Pos)
25325#define DBGMCU_APB1LFZ1_DBG_WWDG2 DBGMCU_APB1LFZ1_DBG_WWDG2_Msk
25326#define DBGMCU_APB1LFZ1_DBG_I2C1_Pos (21U)
25327#define DBGMCU_APB1LFZ1_DBG_I2C1_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C1_Pos)
25328#define DBGMCU_APB1LFZ1_DBG_I2C1 DBGMCU_APB1LFZ1_DBG_I2C1_Msk
25329#define DBGMCU_APB1LFZ1_DBG_I2C2_Pos (22U)
25330#define DBGMCU_APB1LFZ1_DBG_I2C2_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C2_Pos)
25331#define DBGMCU_APB1LFZ1_DBG_I2C2 DBGMCU_APB1LFZ1_DBG_I2C2_Msk
25332#define DBGMCU_APB1LFZ1_DBG_I2C3_Pos (23U)
25333#define DBGMCU_APB1LFZ1_DBG_I2C3_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C3_Pos)
25334#define DBGMCU_APB1LFZ1_DBG_I2C3 DBGMCU_APB1LFZ1_DBG_I2C3_Msk
25335
25336/******************** Bit definition for APB1LFZ2 register ************/
25337#define DBGMCU_APB1LFZ2_DBG_TIM2_Pos (0U)
25338#define DBGMCU_APB1LFZ2_DBG_TIM2_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM2_Pos)
25339#define DBGMCU_APB1LFZ2_DBG_TIM2 DBGMCU_APB1LFZ2_DBG_TIM2_Msk
25340#define DBGMCU_APB1LFZ2_DBG_TIM3_Pos (1U)
25341#define DBGMCU_APB1LFZ2_DBG_TIM3_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM3_Pos)
25342#define DBGMCU_APB1LFZ2_DBG_TIM3 DBGMCU_APB1LFZ2_DBG_TIM3_Msk
25343#define DBGMCU_APB1LFZ2_DBG_TIM4_Pos (2U)
25344#define DBGMCU_APB1LFZ2_DBG_TIM4_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM4_Pos)
25345#define DBGMCU_APB1LFZ2_DBG_TIM4 DBGMCU_APB1LFZ2_DBG_TIM4_Msk
25346#define DBGMCU_APB1LFZ2_DBG_TIM5_Pos (3U)
25347#define DBGMCU_APB1LFZ2_DBG_TIM5_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM5_Pos)
25348#define DBGMCU_APB1LFZ2_DBG_TIM5 DBGMCU_APB1LFZ2_DBG_TIM5_Msk
25349#define DBGMCU_APB1LFZ2_DBG_TIM6_Pos (4U)
25350#define DBGMCU_APB1LFZ2_DBG_TIM6_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM6_Pos)
25351#define DBGMCU_APB1LFZ2_DBG_TIM6 DBGMCU_APB1LFZ2_DBG_TIM6_Msk
25352#define DBGMCU_APB1LFZ2_DBG_TIM7_Pos (5U)
25353#define DBGMCU_APB1LFZ2_DBG_TIM7_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM7_Pos)
25354#define DBGMCU_APB1LFZ2_DBG_TIM7 DBGMCU_APB1LFZ2_DBG_TIM7_Msk
25355#define DBGMCU_APB1LFZ2_DBG_TIM12_Pos (6U)
25356#define DBGMCU_APB1LFZ2_DBG_TIM12_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM12_Pos)
25357#define DBGMCU_APB1LFZ2_DBG_TIM12 DBGMCU_APB1LFZ2_DBG_TIM12_Msk
25358#define DBGMCU_APB1LFZ2_DBG_TIM13_Pos (7U)
25359#define DBGMCU_APB1LFZ2_DBG_TIM13_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM13_Pos)
25360#define DBGMCU_APB1LFZ2_DBG_TIM13 DBGMCU_APB1LFZ2_DBG_TIM13_Msk
25361#define DBGMCU_APB1LFZ2_DBG_TIM14_Pos (8U)
25362#define DBGMCU_APB1LFZ2_DBG_TIM14_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_TIM14_Pos)
25363#define DBGMCU_APB1LFZ2_DBG_TIM14 DBGMCU_APB1LFZ2_DBG_TIM14_Msk
25364#define DBGMCU_APB1LFZ2_DBG_LPTIM1_Pos (9U)
25365#define DBGMCU_APB1LFZ2_DBG_LPTIM1_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_LPTIM1_Pos)
25366#define DBGMCU_APB1LFZ2_DBG_LPTIM1 DBGMCU_APB1LFZ2_DBG_LPTIM1_Msk
25367#define DBGMCU_APB1LFZ2_DBG_WWDG2_Pos (11U)
25368#define DBGMCU_APB1LFZ2_DBG_WWDG2_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_WWDG2_Pos)
25369#define DBGMCU_APB1LFZ2_DBG_WWDG2 DBGMCU_APB1LFZ2_DBG_WWDG2_Msk
25370#define DBGMCU_APB1LFZ2_DBG_I2C1_Pos (21U)
25371#define DBGMCU_APB1LFZ2_DBG_I2C1_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_I2C1_Pos)
25372#define DBGMCU_APB1LFZ2_DBG_I2C1 DBGMCU_APB1LFZ2_DBG_I2C1_Msk
25373#define DBGMCU_APB1LFZ2_DBG_I2C2_Pos (22U)
25374#define DBGMCU_APB1LFZ2_DBG_I2C2_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_I2C2_Pos)
25375#define DBGMCU_APB1LFZ2_DBG_I2C2 DBGMCU_APB1LFZ2_DBG_I2C2_Msk
25376#define DBGMCU_APB1LFZ2_DBG_I2C3_Pos (23U)
25377#define DBGMCU_APB1LFZ2_DBG_I2C3_Msk (0x1UL << DBGMCU_APB1LFZ2_DBG_I2C3_Pos)
25378#define DBGMCU_APB1LFZ2_DBG_I2C3 DBGMCU_APB1LFZ2_DBG_I2C3_Msk
25379/******************** Bit definition for APB1HFZ1 register ************/
25380#define DBGMCU_APB1HFZ1_DBG_FDCAN_Pos (8U)
25381#define DBGMCU_APB1HFZ1_DBG_FDCAN_Msk (0x1UL << DBGMCU_APB1HFZ1_DBG_FDCAN_Pos)
25382#define DBGMCU_APB1HFZ1_DBG_FDCAN DBGMCU_APB1HFZ1_DBG_FDCAN_Msk
25383/******************** Bit definition for APB1HFZ2 register ************/
25384#define DBGMCU_APB1HFZ2_DBG_FDCAN_Pos (8U)
25385#define DBGMCU_APB1HFZ2_DBG_FDCAN_Msk (0x1UL << DBGMCU_APB1HFZ2_DBG_FDCAN_Pos)
25386#define DBGMCU_APB1HFZ2_DBG_FDCAN DBGMCU_APB1HFZ2_DBG_FDCAN_Msk
25387
25388/******************** Bit definition for APB2FZ1 register ************/
25389#define DBGMCU_APB2FZ1_DBG_TIM1_Pos (0U)
25390#define DBGMCU_APB2FZ1_DBG_TIM1_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM1_Pos)
25391#define DBGMCU_APB2FZ1_DBG_TIM1 DBGMCU_APB2FZ1_DBG_TIM1_Msk
25392#define DBGMCU_APB2FZ1_DBG_TIM8_Pos (1U)
25393#define DBGMCU_APB2FZ1_DBG_TIM8_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM8_Pos)
25394#define DBGMCU_APB2FZ1_DBG_TIM8 DBGMCU_APB2FZ1_DBG_TIM8_Msk
25395#define DBGMCU_APB2FZ1_DBG_TIM15_Pos (16U)
25396#define DBGMCU_APB2FZ1_DBG_TIM15_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM15_Pos)
25397#define DBGMCU_APB2FZ1_DBG_TIM15 DBGMCU_APB2FZ1_DBG_TIM15_Msk
25398#define DBGMCU_APB2FZ1_DBG_TIM16_Pos (17U)
25399#define DBGMCU_APB2FZ1_DBG_TIM16_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM16_Pos)
25400#define DBGMCU_APB2FZ1_DBG_TIM16 DBGMCU_APB2FZ1_DBG_TIM16_Msk
25401#define DBGMCU_APB2FZ1_DBG_TIM17_Pos (18U)
25402#define DBGMCU_APB2FZ1_DBG_TIM17_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM17_Pos)
25403#define DBGMCU_APB2FZ1_DBG_TIM17 DBGMCU_APB2FZ1_DBG_TIM17_Msk
25404#define DBGMCU_APB2FZ1_DBG_HRTIM_Pos (29U)
25405#define DBGMCU_APB2FZ1_DBG_HRTIM_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_HRTIM_Pos)
25406#define DBGMCU_APB2FZ1_DBG_HRTIM DBGMCU_APB2FZ1_DBG_HRTIM_Msk
25407
25408/******************** Bit definition for APB2FZ2 register ************/
25409#define DBGMCU_APB2FZ2_DBG_TIM1_Pos (0U)
25410#define DBGMCU_APB2FZ2_DBG_TIM1_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_TIM1_Pos)
25411#define DBGMCU_APB2FZ2_DBG_TIM1 DBGMCU_APB2FZ2_DBG_TIM1_Msk
25412#define DBGMCU_APB2FZ2_DBG_TIM8_Pos (1U)
25413#define DBGMCU_APB2FZ2_DBG_TIM8_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_TIM8_Pos)
25414#define DBGMCU_APB2FZ2_DBG_TIM8 DBGMCU_APB2FZ2_DBG_TIM8_Msk
25415#define DBGMCU_APB2FZ2_DBG_TIM15_Pos (16U)
25416#define DBGMCU_APB2FZ2_DBG_TIM15_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_TIM15_Pos)
25417#define DBGMCU_APB2FZ2_DBG_TIM15 DBGMCU_APB2FZ2_DBG_TIM15_Msk
25418#define DBGMCU_APB2FZ2_DBG_TIM16_Pos (17U)
25419#define DBGMCU_APB2FZ2_DBG_TIM16_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_TIM16_Pos)
25420#define DBGMCU_APB2FZ2_DBG_TIM16 DBGMCU_APB2FZ2_DBG_TIM16_Msk
25421#define DBGMCU_APB2FZ2_DBG_TIM17_Pos (18U)
25422#define DBGMCU_APB2FZ2_DBG_TIM17_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_TIM17_Pos)
25423#define DBGMCU_APB2FZ2_DBG_TIM17 DBGMCU_APB2FZ2_DBG_TIM17_Msk
25424#define DBGMCU_APB2FZ2_DBG_HRTIM_Pos (29U)
25425#define DBGMCU_APB2FZ2_DBG_HRTIM_Msk (0x1UL << DBGMCU_APB2FZ2_DBG_HRTIM_Pos)
25426#define DBGMCU_APB2FZ2_DBG_HRTIM DBGMCU_APB2FZ2_DBG_HRTIM_Msk
25427/******************** Bit definition for APB4FZ1 register ************/
25428#define DBGMCU_APB4FZ1_DBG_I2C4_Pos (7U)
25429#define DBGMCU_APB4FZ1_DBG_I2C4_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_I2C4_Pos)
25430#define DBGMCU_APB4FZ1_DBG_I2C4 DBGMCU_APB4FZ1_DBG_I2C4_Msk
25431#define DBGMCU_APB4FZ1_DBG_LPTIM2_Pos (9U)
25432#define DBGMCU_APB4FZ1_DBG_LPTIM2_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM2_Pos)
25433#define DBGMCU_APB4FZ1_DBG_LPTIM2 DBGMCU_APB4FZ1_DBG_LPTIM2_Msk
25434#define DBGMCU_APB4FZ1_DBG_LPTIM3_Pos (10U)
25435#define DBGMCU_APB4FZ1_DBG_LPTIM3_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM3_Pos)
25436#define DBGMCU_APB4FZ1_DBG_LPTIM3 DBGMCU_APB4FZ1_DBG_LPTIM3_Msk
25437#define DBGMCU_APB4FZ1_DBG_LPTIM4_Pos (11U)
25438#define DBGMCU_APB4FZ1_DBG_LPTIM4_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM4_Pos)
25439#define DBGMCU_APB4FZ1_DBG_LPTIM4 DBGMCU_APB4FZ1_DBG_LPTIM4_Msk
25440#define DBGMCU_APB4FZ1_DBG_LPTIM5_Pos (12U)
25441#define DBGMCU_APB4FZ1_DBG_LPTIM5_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM5_Pos)
25442#define DBGMCU_APB4FZ1_DBG_LPTIM5 DBGMCU_APB4FZ1_DBG_LPTIM5_Msk
25443#define DBGMCU_APB4FZ1_DBG_RTC_Pos (16U)
25444#define DBGMCU_APB4FZ1_DBG_RTC_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_RTC_Pos)
25445#define DBGMCU_APB4FZ1_DBG_RTC DBGMCU_APB4FZ1_DBG_RTC_Msk
25446#define DBGMCU_APB4FZ1_DBG_IWDG1_Pos (18U)
25447#define DBGMCU_APB4FZ1_DBG_IWDG1_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_IWDG1_Pos)
25448#define DBGMCU_APB4FZ1_DBG_IWDG1 DBGMCU_APB4FZ1_DBG_IWDG1_Msk
25449#define DBGMCU_APB4FZ1_DBG_IWDG2_Pos (19U)
25450#define DBGMCU_APB4FZ1_DBG_IWDG2_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_IWDG2_Pos)
25451#define DBGMCU_APB4FZ1_DBG_IWDG2 DBGMCU_APB4FZ1_DBG_IWDG2_Msk
25452/******************** Bit definition for APB4FZ2 register ************/
25453#define DBGMCU_APB4FZ2_DBG_I2C4_Pos (7U)
25454#define DBGMCU_APB4FZ2_DBG_I2C4_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_I2C4_Pos)
25455#define DBGMCU_APB4FZ2_DBG_I2C4 DBGMCU_APB4FZ2_DBG_I2C4_Msk
25456#define DBGMCU_APB4FZ2_DBG_LPTIM2_Pos (9U)
25457#define DBGMCU_APB4FZ2_DBG_LPTIM2_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_LPTIM2_Pos)
25458#define DBGMCU_APB4FZ2_DBG_LPTIM2 DBGMCU_APB4FZ2_DBG_LPTIM2_Msk
25459#define DBGMCU_APB4FZ2_DBG_LPTIM3_Pos (10U)
25460#define DBGMCU_APB4FZ2_DBG_LPTIM3_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_LPTIM3_Pos)
25461#define DBGMCU_APB4FZ2_DBG_LPTIM3 DBGMCU_APB4FZ2_DBG_LPTIM3_Msk
25462#define DBGMCU_APB4FZ2_DBG_LPTIM4_Pos (11U)
25463#define DBGMCU_APB4FZ2_DBG_LPTIM4_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_LPTIM4_Pos)
25464#define DBGMCU_APB4FZ2_DBG_LPTIM4 DBGMCU_APB4FZ2_DBG_LPTIM4_Msk
25465#define DBGMCU_APB4FZ2_DBG_LPTIM5_Pos (12U)
25466#define DBGMCU_APB4FZ2_DBG_LPTIM5_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_LPTIM5_Pos)
25467#define DBGMCU_APB4FZ2_DBG_LPTIM5 DBGMCU_APB4FZ2_DBG_LPTIM5_Msk
25468#define DBGMCU_APB4FZ2_DBG_RTC_Pos (16U)
25469#define DBGMCU_APB4FZ2_DBG_RTC_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_RTC_Pos)
25470#define DBGMCU_APB4FZ2_DBG_RTC DBGMCU_APB4FZ2_DBG_RTC_Msk
25471#define DBGMCU_APB4FZ2_DBG_IWDG1_Pos (18U)
25472#define DBGMCU_APB4FZ2_DBG_IWDG1_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_IWDG1_Pos)
25473#define DBGMCU_APB4FZ2_DBG_IWDG1 DBGMCU_APB4FZ2_DBG_IWDG1_Msk
25474#define DBGMCU_APB4FZ2_DBG_IWDG2_Pos (19U)
25475#define DBGMCU_APB4FZ2_DBG_IWDG2_Msk (0x1UL << DBGMCU_APB4FZ2_DBG_IWDG2_Pos)
25476#define DBGMCU_APB4FZ2_DBG_IWDG2 DBGMCU_APB4FZ2_DBG_IWDG2_Msk
25477/******************************************************************************/
25478/* */
25479/* High Resolution Timer (HRTIM) */
25480/* */
25481/******************************************************************************/
25482/******************** Master Timer control register ***************************/
25483#define HRTIM_MCR_CK_PSC_Pos (0U)
25484#define HRTIM_MCR_CK_PSC_Msk (0x7UL << HRTIM_MCR_CK_PSC_Pos)
25485#define HRTIM_MCR_CK_PSC HRTIM_MCR_CK_PSC_Msk
25486#define HRTIM_MCR_CK_PSC_0 (0x1UL << HRTIM_MCR_CK_PSC_Pos)
25487#define HRTIM_MCR_CK_PSC_1 (0x2UL << HRTIM_MCR_CK_PSC_Pos)
25488#define HRTIM_MCR_CK_PSC_2 (0x4UL << HRTIM_MCR_CK_PSC_Pos)
25490#define HRTIM_MCR_CONT_Pos (3U)
25491#define HRTIM_MCR_CONT_Msk (0x1UL << HRTIM_MCR_CONT_Pos)
25492#define HRTIM_MCR_CONT HRTIM_MCR_CONT_Msk
25493#define HRTIM_MCR_RETRIG_Pos (4U)
25494#define HRTIM_MCR_RETRIG_Msk (0x1UL << HRTIM_MCR_RETRIG_Pos)
25495#define HRTIM_MCR_RETRIG HRTIM_MCR_RETRIG_Msk
25496#define HRTIM_MCR_HALF_Pos (5U)
25497#define HRTIM_MCR_HALF_Msk (0x1UL << HRTIM_MCR_HALF_Pos)
25498#define HRTIM_MCR_HALF HRTIM_MCR_HALF_Msk
25500#define HRTIM_MCR_SYNC_IN_Pos (8U)
25501#define HRTIM_MCR_SYNC_IN_Msk (0x3UL << HRTIM_MCR_SYNC_IN_Pos)
25502#define HRTIM_MCR_SYNC_IN HRTIM_MCR_SYNC_IN_Msk
25503#define HRTIM_MCR_SYNC_IN_0 (0x1UL << HRTIM_MCR_SYNC_IN_Pos)
25504#define HRTIM_MCR_SYNC_IN_1 (0x2UL << HRTIM_MCR_SYNC_IN_Pos)
25505#define HRTIM_MCR_SYNCRSTM_Pos (10U)
25506#define HRTIM_MCR_SYNCRSTM_Msk (0x1UL << HRTIM_MCR_SYNCRSTM_Pos)
25507#define HRTIM_MCR_SYNCRSTM HRTIM_MCR_SYNCRSTM_Msk
25508#define HRTIM_MCR_SYNCSTRTM_Pos (11U)
25509#define HRTIM_MCR_SYNCSTRTM_Msk (0x1UL << HRTIM_MCR_SYNCSTRTM_Pos)
25510#define HRTIM_MCR_SYNCSTRTM HRTIM_MCR_SYNCSTRTM_Msk
25511#define HRTIM_MCR_SYNC_OUT_Pos (12U)
25512#define HRTIM_MCR_SYNC_OUT_Msk (0x3UL << HRTIM_MCR_SYNC_OUT_Pos)
25513#define HRTIM_MCR_SYNC_OUT HRTIM_MCR_SYNC_OUT_Msk
25514#define HRTIM_MCR_SYNC_OUT_0 (0x1UL << HRTIM_MCR_SYNC_OUT_Pos)
25515#define HRTIM_MCR_SYNC_OUT_1 (0x2UL << HRTIM_MCR_SYNC_OUT_Pos)
25516#define HRTIM_MCR_SYNC_SRC_Pos (14U)
25517#define HRTIM_MCR_SYNC_SRC_Msk (0x3UL << HRTIM_MCR_SYNC_SRC_Pos)
25518#define HRTIM_MCR_SYNC_SRC HRTIM_MCR_SYNC_SRC_Msk
25519#define HRTIM_MCR_SYNC_SRC_0 (0x1UL << HRTIM_MCR_SYNC_SRC_Pos)
25520#define HRTIM_MCR_SYNC_SRC_1 (0x2UL << HRTIM_MCR_SYNC_SRC_Pos)
25522#define HRTIM_MCR_MCEN_Pos (16U)
25523#define HRTIM_MCR_MCEN_Msk (0x1UL << HRTIM_MCR_MCEN_Pos)
25524#define HRTIM_MCR_MCEN HRTIM_MCR_MCEN_Msk
25525#define HRTIM_MCR_TACEN_Pos (17U)
25526#define HRTIM_MCR_TACEN_Msk (0x1UL << HRTIM_MCR_TACEN_Pos)
25527#define HRTIM_MCR_TACEN HRTIM_MCR_TACEN_Msk
25528#define HRTIM_MCR_TBCEN_Pos (18U)
25529#define HRTIM_MCR_TBCEN_Msk (0x1UL << HRTIM_MCR_TBCEN_Pos)
25530#define HRTIM_MCR_TBCEN HRTIM_MCR_TBCEN_Msk
25531#define HRTIM_MCR_TCCEN_Pos (19U)
25532#define HRTIM_MCR_TCCEN_Msk (0x1UL << HRTIM_MCR_TCCEN_Pos)
25533#define HRTIM_MCR_TCCEN HRTIM_MCR_TCCEN_Msk
25534#define HRTIM_MCR_TDCEN_Pos (20U)
25535#define HRTIM_MCR_TDCEN_Msk (0x1UL << HRTIM_MCR_TDCEN_Pos)
25536#define HRTIM_MCR_TDCEN HRTIM_MCR_TDCEN_Msk
25537#define HRTIM_MCR_TECEN_Pos (21U)
25538#define HRTIM_MCR_TECEN_Msk (0x1UL << HRTIM_MCR_TECEN_Pos)
25539#define HRTIM_MCR_TECEN HRTIM_MCR_TECEN_Msk
25541#define HRTIM_MCR_DACSYNC_Pos (25U)
25542#define HRTIM_MCR_DACSYNC_Msk (0x3UL << HRTIM_MCR_DACSYNC_Pos)
25543#define HRTIM_MCR_DACSYNC HRTIM_MCR_DACSYNC_Msk
25544#define HRTIM_MCR_DACSYNC_0 (0x1UL << HRTIM_MCR_DACSYNC_Pos)
25545#define HRTIM_MCR_DACSYNC_1 (0x2UL << HRTIM_MCR_DACSYNC_Pos)
25547#define HRTIM_MCR_PREEN_Pos (27U)
25548#define HRTIM_MCR_PREEN_Msk (0x1UL << HRTIM_MCR_PREEN_Pos)
25549#define HRTIM_MCR_PREEN HRTIM_MCR_PREEN_Msk
25550#define HRTIM_MCR_MREPU_Pos (29U)
25551#define HRTIM_MCR_MREPU_Msk (0x1UL << HRTIM_MCR_MREPU_Pos)
25552#define HRTIM_MCR_MREPU HRTIM_MCR_MREPU_Msk
25554#define HRTIM_MCR_BRSTDMA_Pos (30U)
25555#define HRTIM_MCR_BRSTDMA_Msk (0x3UL << HRTIM_MCR_BRSTDMA_Pos)
25556#define HRTIM_MCR_BRSTDMA HRTIM_MCR_BRSTDMA_Msk
25557#define HRTIM_MCR_BRSTDMA_0 (0x1UL << HRTIM_MCR_BRSTDMA_Pos)
25558#define HRTIM_MCR_BRSTDMA_1 (0x2UL << HRTIM_MCR_BRSTDMA_Pos)
25560/******************** Master Timer Interrupt status register ******************/
25561#define HRTIM_MISR_MCMP1_Pos (0U)
25562#define HRTIM_MISR_MCMP1_Msk (0x1UL << HRTIM_MISR_MCMP1_Pos)
25563#define HRTIM_MISR_MCMP1 HRTIM_MISR_MCMP1_Msk
25564#define HRTIM_MISR_MCMP2_Pos (1U)
25565#define HRTIM_MISR_MCMP2_Msk (0x1UL << HRTIM_MISR_MCMP2_Pos)
25566#define HRTIM_MISR_MCMP2 HRTIM_MISR_MCMP2_Msk
25567#define HRTIM_MISR_MCMP3_Pos (2U)
25568#define HRTIM_MISR_MCMP3_Msk (0x1UL << HRTIM_MISR_MCMP3_Pos)
25569#define HRTIM_MISR_MCMP3 HRTIM_MISR_MCMP3_Msk
25570#define HRTIM_MISR_MCMP4_Pos (3U)
25571#define HRTIM_MISR_MCMP4_Msk (0x1UL << HRTIM_MISR_MCMP4_Pos)
25572#define HRTIM_MISR_MCMP4 HRTIM_MISR_MCMP4_Msk
25573#define HRTIM_MISR_MREP_Pos (4U)
25574#define HRTIM_MISR_MREP_Msk (0x1UL << HRTIM_MISR_MREP_Pos)
25575#define HRTIM_MISR_MREP HRTIM_MISR_MREP_Msk
25576#define HRTIM_MISR_SYNC_Pos (5U)
25577#define HRTIM_MISR_SYNC_Msk (0x1UL << HRTIM_MISR_SYNC_Pos)
25578#define HRTIM_MISR_SYNC HRTIM_MISR_SYNC_Msk
25579#define HRTIM_MISR_MUPD_Pos (6U)
25580#define HRTIM_MISR_MUPD_Msk (0x1UL << HRTIM_MISR_MUPD_Pos)
25581#define HRTIM_MISR_MUPD HRTIM_MISR_MUPD_Msk
25583/******************** Master Timer Interrupt clear register *******************/
25584#define HRTIM_MICR_MCMP1_Pos (0U)
25585#define HRTIM_MICR_MCMP1_Msk (0x1UL << HRTIM_MICR_MCMP1_Pos)
25586#define HRTIM_MICR_MCMP1 HRTIM_MICR_MCMP1_Msk
25587#define HRTIM_MICR_MCMP2_Pos (1U)
25588#define HRTIM_MICR_MCMP2_Msk (0x1UL << HRTIM_MICR_MCMP2_Pos)
25589#define HRTIM_MICR_MCMP2 HRTIM_MICR_MCMP2_Msk
25590#define HRTIM_MICR_MCMP3_Pos (2U)
25591#define HRTIM_MICR_MCMP3_Msk (0x1UL << HRTIM_MICR_MCMP3_Pos)
25592#define HRTIM_MICR_MCMP3 HRTIM_MICR_MCMP3_Msk
25593#define HRTIM_MICR_MCMP4_Pos (3U)
25594#define HRTIM_MICR_MCMP4_Msk (0x1UL << HRTIM_MICR_MCMP4_Pos)
25595#define HRTIM_MICR_MCMP4 HRTIM_MICR_MCMP4_Msk
25596#define HRTIM_MICR_MREP_Pos (4U)
25597#define HRTIM_MICR_MREP_Msk (0x1UL << HRTIM_MICR_MREP_Pos)
25598#define HRTIM_MICR_MREP HRTIM_MICR_MREP_Msk
25599#define HRTIM_MICR_SYNC_Pos (5U)
25600#define HRTIM_MICR_SYNC_Msk (0x1UL << HRTIM_MICR_SYNC_Pos)
25601#define HRTIM_MICR_SYNC HRTIM_MICR_SYNC_Msk
25602#define HRTIM_MICR_MUPD_Pos (6U)
25603#define HRTIM_MICR_MUPD_Msk (0x1UL << HRTIM_MICR_MUPD_Pos)
25604#define HRTIM_MICR_MUPD HRTIM_MICR_MUPD_Msk
25606/******************** Master Timer DMA/Interrupt enable register **************/
25607#define HRTIM_MDIER_MCMP1IE_Pos (0U)
25608#define HRTIM_MDIER_MCMP1IE_Msk (0x1UL << HRTIM_MDIER_MCMP1IE_Pos)
25609#define HRTIM_MDIER_MCMP1IE HRTIM_MDIER_MCMP1IE_Msk
25610#define HRTIM_MDIER_MCMP2IE_Pos (1U)
25611#define HRTIM_MDIER_MCMP2IE_Msk (0x1UL << HRTIM_MDIER_MCMP2IE_Pos)
25612#define HRTIM_MDIER_MCMP2IE HRTIM_MDIER_MCMP2IE_Msk
25613#define HRTIM_MDIER_MCMP3IE_Pos (2U)
25614#define HRTIM_MDIER_MCMP3IE_Msk (0x1UL << HRTIM_MDIER_MCMP3IE_Pos)
25615#define HRTIM_MDIER_MCMP3IE HRTIM_MDIER_MCMP3IE_Msk
25616#define HRTIM_MDIER_MCMP4IE_Pos (3U)
25617#define HRTIM_MDIER_MCMP4IE_Msk (0x1UL << HRTIM_MDIER_MCMP4IE_Pos)
25618#define HRTIM_MDIER_MCMP4IE HRTIM_MDIER_MCMP4IE_Msk
25619#define HRTIM_MDIER_MREPIE_Pos (4U)
25620#define HRTIM_MDIER_MREPIE_Msk (0x1UL << HRTIM_MDIER_MREPIE_Pos)
25621#define HRTIM_MDIER_MREPIE HRTIM_MDIER_MREPIE_Msk
25622#define HRTIM_MDIER_SYNCIE_Pos (5U)
25623#define HRTIM_MDIER_SYNCIE_Msk (0x1UL << HRTIM_MDIER_SYNCIE_Pos)
25624#define HRTIM_MDIER_SYNCIE HRTIM_MDIER_SYNCIE_Msk
25625#define HRTIM_MDIER_MUPDIE_Pos (6U)
25626#define HRTIM_MDIER_MUPDIE_Msk (0x1UL << HRTIM_MDIER_MUPDIE_Pos)
25627#define HRTIM_MDIER_MUPDIE HRTIM_MDIER_MUPDIE_Msk
25629#define HRTIM_MDIER_MCMP1DE_Pos (16U)
25630#define HRTIM_MDIER_MCMP1DE_Msk (0x1UL << HRTIM_MDIER_MCMP1DE_Pos)
25631#define HRTIM_MDIER_MCMP1DE HRTIM_MDIER_MCMP1DE_Msk
25632#define HRTIM_MDIER_MCMP2DE_Pos (17U)
25633#define HRTIM_MDIER_MCMP2DE_Msk (0x1UL << HRTIM_MDIER_MCMP2DE_Pos)
25634#define HRTIM_MDIER_MCMP2DE HRTIM_MDIER_MCMP2DE_Msk
25635#define HRTIM_MDIER_MCMP3DE_Pos (18U)
25636#define HRTIM_MDIER_MCMP3DE_Msk (0x1UL << HRTIM_MDIER_MCMP3DE_Pos)
25637#define HRTIM_MDIER_MCMP3DE HRTIM_MDIER_MCMP3DE_Msk
25638#define HRTIM_MDIER_MCMP4DE_Pos (19U)
25639#define HRTIM_MDIER_MCMP4DE_Msk (0x1UL << HRTIM_MDIER_MCMP4DE_Pos)
25640#define HRTIM_MDIER_MCMP4DE HRTIM_MDIER_MCMP4DE_Msk
25641#define HRTIM_MDIER_MREPDE_Pos (20U)
25642#define HRTIM_MDIER_MREPDE_Msk (0x1UL << HRTIM_MDIER_MREPDE_Pos)
25643#define HRTIM_MDIER_MREPDE HRTIM_MDIER_MREPDE_Msk
25644#define HRTIM_MDIER_SYNCDE_Pos (21U)
25645#define HRTIM_MDIER_SYNCDE_Msk (0x1UL << HRTIM_MDIER_SYNCDE_Pos)
25646#define HRTIM_MDIER_SYNCDE HRTIM_MDIER_SYNCDE_Msk
25647#define HRTIM_MDIER_MUPDDE_Pos (22U)
25648#define HRTIM_MDIER_MUPDDE_Msk (0x1UL << HRTIM_MDIER_MUPDDE_Pos)
25649#define HRTIM_MDIER_MUPDDE HRTIM_MDIER_MUPDDE_Msk
25651/******************* Bit definition for HRTIM_MCNTR register ****************/
25652#define HRTIM_MCNTR_MCNTR_Pos (0U)
25653#define HRTIM_MCNTR_MCNTR_Msk (0xFFFFUL << HRTIM_MCNTR_MCNTR_Pos)
25654#define HRTIM_MCNTR_MCNTR HRTIM_MCNTR_MCNTR_Msk
25656/******************* Bit definition for HRTIM_MPER register *****************/
25657#define HRTIM_MPER_MPER_Pos (0U)
25658#define HRTIM_MPER_MPER_Msk (0xFFFFUL << HRTIM_MPER_MPER_Pos)
25659#define HRTIM_MPER_MPER HRTIM_MPER_MPER_Msk
25661/******************* Bit definition for HRTIM_MREP register *****************/
25662#define HRTIM_MREP_MREP_Pos (0U)
25663#define HRTIM_MREP_MREP_Msk (0xFFUL << HRTIM_MREP_MREP_Pos)
25664#define HRTIM_MREP_MREP HRTIM_MREP_MREP_Msk
25666/******************* Bit definition for HRTIM_MCMP1R register *****************/
25667#define HRTIM_MCMP1R_MCMP1R_Pos (0U)
25668#define HRTIM_MCMP1R_MCMP1R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP1R_Pos)
25669#define HRTIM_MCMP1R_MCMP1R HRTIM_MCMP1R_MCMP1R_Msk
25671/******************* Bit definition for HRTIM_MCMP2R register *****************/
25672#define HRTIM_MCMP1R_MCMP2R_Pos (0U)
25673#define HRTIM_MCMP1R_MCMP2R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP2R_Pos)
25674#define HRTIM_MCMP1R_MCMP2R HRTIM_MCMP1R_MCMP2R_Msk
25676/******************* Bit definition for HRTIM_MCMP3R register *****************/
25677#define HRTIM_MCMP1R_MCMP3R_Pos (0U)
25678#define HRTIM_MCMP1R_MCMP3R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP3R_Pos)
25679#define HRTIM_MCMP1R_MCMP3R HRTIM_MCMP1R_MCMP3R_Msk
25681/******************* Bit definition for HRTIM_MCMP4R register *****************/
25682#define HRTIM_MCMP1R_MCMP4R_Pos (0U)
25683#define HRTIM_MCMP1R_MCMP4R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP4R_Pos)
25684#define HRTIM_MCMP1R_MCMP4R HRTIM_MCMP1R_MCMP4R_Msk
25686/******************** Slave control register **********************************/
25687#define HRTIM_TIMCR_CK_PSC_Pos (0U)
25688#define HRTIM_TIMCR_CK_PSC_Msk (0x7UL << HRTIM_TIMCR_CK_PSC_Pos)
25689#define HRTIM_TIMCR_CK_PSC HRTIM_TIMCR_CK_PSC_Msk
25690#define HRTIM_TIMCR_CK_PSC_0 (0x1UL << HRTIM_TIMCR_CK_PSC_Pos)
25691#define HRTIM_TIMCR_CK_PSC_1 (0x2UL << HRTIM_TIMCR_CK_PSC_Pos)
25692#define HRTIM_TIMCR_CK_PSC_2 (0x4UL << HRTIM_TIMCR_CK_PSC_Pos)
25694#define HRTIM_TIMCR_CONT_Pos (3U)
25695#define HRTIM_TIMCR_CONT_Msk (0x1UL << HRTIM_TIMCR_CONT_Pos)
25696#define HRTIM_TIMCR_CONT HRTIM_TIMCR_CONT_Msk
25697#define HRTIM_TIMCR_RETRIG_Pos (4U)
25698#define HRTIM_TIMCR_RETRIG_Msk (0x1UL << HRTIM_TIMCR_RETRIG_Pos)
25699#define HRTIM_TIMCR_RETRIG HRTIM_TIMCR_RETRIG_Msk
25700#define HRTIM_TIMCR_HALF_Pos (5U)
25701#define HRTIM_TIMCR_HALF_Msk (0x1UL << HRTIM_TIMCR_HALF_Pos)
25702#define HRTIM_TIMCR_HALF HRTIM_TIMCR_HALF_Msk
25703#define HRTIM_TIMCR_PSHPLL_Pos (6U)
25704#define HRTIM_TIMCR_PSHPLL_Msk (0x1UL << HRTIM_TIMCR_PSHPLL_Pos)
25705#define HRTIM_TIMCR_PSHPLL HRTIM_TIMCR_PSHPLL_Msk
25707#define HRTIM_TIMCR_SYNCRST_Pos (10U)
25708#define HRTIM_TIMCR_SYNCRST_Msk (0x1UL << HRTIM_TIMCR_SYNCRST_Pos)
25709#define HRTIM_TIMCR_SYNCRST HRTIM_TIMCR_SYNCRST_Msk
25710#define HRTIM_TIMCR_SYNCSTRT_Pos (11U)
25711#define HRTIM_TIMCR_SYNCSTRT_Msk (0x1UL << HRTIM_TIMCR_SYNCSTRT_Pos)
25712#define HRTIM_TIMCR_SYNCSTRT HRTIM_TIMCR_SYNCSTRT_Msk
25714#define HRTIM_TIMCR_DELCMP2_Pos (12U)
25715#define HRTIM_TIMCR_DELCMP2_Msk (0x3UL << HRTIM_TIMCR_DELCMP2_Pos)
25716#define HRTIM_TIMCR_DELCMP2 HRTIM_TIMCR_DELCMP2_Msk
25717#define HRTIM_TIMCR_DELCMP2_0 (0x1UL << HRTIM_TIMCR_DELCMP2_Pos)
25718#define HRTIM_TIMCR_DELCMP2_1 (0x2UL << HRTIM_TIMCR_DELCMP2_Pos)
25719#define HRTIM_TIMCR_DELCMP4_Pos (14U)
25720#define HRTIM_TIMCR_DELCMP4_Msk (0x3UL << HRTIM_TIMCR_DELCMP4_Pos)
25721#define HRTIM_TIMCR_DELCMP4 HRTIM_TIMCR_DELCMP4_Msk
25722#define HRTIM_TIMCR_DELCMP4_0 (0x1UL << HRTIM_TIMCR_DELCMP4_Pos)
25723#define HRTIM_TIMCR_DELCMP4_1 (0x2UL << HRTIM_TIMCR_DELCMP4_Pos)
25725#define HRTIM_TIMCR_TREPU_Pos (17U)
25726#define HRTIM_TIMCR_TREPU_Msk (0x1UL << HRTIM_TIMCR_TREPU_Pos)
25727#define HRTIM_TIMCR_TREPU HRTIM_TIMCR_TREPU_Msk
25728#define HRTIM_TIMCR_TRSTU_Pos (18U)
25729#define HRTIM_TIMCR_TRSTU_Msk (0x1UL << HRTIM_TIMCR_TRSTU_Pos)
25730#define HRTIM_TIMCR_TRSTU HRTIM_TIMCR_TRSTU_Msk
25731#define HRTIM_TIMCR_TAU_Pos (19U)
25732#define HRTIM_TIMCR_TAU_Msk (0x1UL << HRTIM_TIMCR_TAU_Pos)
25733#define HRTIM_TIMCR_TAU HRTIM_TIMCR_TAU_Msk
25734#define HRTIM_TIMCR_TBU_Pos (20U)
25735#define HRTIM_TIMCR_TBU_Msk (0x1UL << HRTIM_TIMCR_TBU_Pos)
25736#define HRTIM_TIMCR_TBU HRTIM_TIMCR_TBU_Msk
25737#define HRTIM_TIMCR_TCU_Pos (21U)
25738#define HRTIM_TIMCR_TCU_Msk (0x1UL << HRTIM_TIMCR_TCU_Pos)
25739#define HRTIM_TIMCR_TCU HRTIM_TIMCR_TCU_Msk
25740#define HRTIM_TIMCR_TDU_Pos (22U)
25741#define HRTIM_TIMCR_TDU_Msk (0x1UL << HRTIM_TIMCR_TDU_Pos)
25742#define HRTIM_TIMCR_TDU HRTIM_TIMCR_TDU_Msk
25743#define HRTIM_TIMCR_TEU_Pos (23U)
25744#define HRTIM_TIMCR_TEU_Msk (0x1UL << HRTIM_TIMCR_TEU_Pos)
25745#define HRTIM_TIMCR_TEU HRTIM_TIMCR_TEU_Msk
25746#define HRTIM_TIMCR_MSTU_Pos (24U)
25747#define HRTIM_TIMCR_MSTU_Msk (0x1UL << HRTIM_TIMCR_MSTU_Pos)
25748#define HRTIM_TIMCR_MSTU HRTIM_TIMCR_MSTU_Msk
25750#define HRTIM_TIMCR_DACSYNC_Pos (25U)
25751#define HRTIM_TIMCR_DACSYNC_Msk (0x3UL << HRTIM_TIMCR_DACSYNC_Pos)
25752#define HRTIM_TIMCR_DACSYNC HRTIM_TIMCR_DACSYNC_Msk
25753#define HRTIM_TIMCR_DACSYNC_0 (0x1UL << HRTIM_TIMCR_DACSYNC_Pos)
25754#define HRTIM_TIMCR_DACSYNC_1 (0x2UL << HRTIM_TIMCR_DACSYNC_Pos)
25755#define HRTIM_TIMCR_PREEN_Pos (27U)
25756#define HRTIM_TIMCR_PREEN_Msk (0x1UL << HRTIM_TIMCR_PREEN_Pos)
25757#define HRTIM_TIMCR_PREEN HRTIM_TIMCR_PREEN_Msk
25759#define HRTIM_TIMCR_UPDGAT_Pos (28U)
25760#define HRTIM_TIMCR_UPDGAT_Msk (0xFUL << HRTIM_TIMCR_UPDGAT_Pos)
25761#define HRTIM_TIMCR_UPDGAT HRTIM_TIMCR_UPDGAT_Msk
25762#define HRTIM_TIMCR_UPDGAT_0 (0x1UL << HRTIM_TIMCR_UPDGAT_Pos)
25763#define HRTIM_TIMCR_UPDGAT_1 (0x2UL << HRTIM_TIMCR_UPDGAT_Pos)
25764#define HRTIM_TIMCR_UPDGAT_2 (0x4UL << HRTIM_TIMCR_UPDGAT_Pos)
25765#define HRTIM_TIMCR_UPDGAT_3 (0x8UL << HRTIM_TIMCR_UPDGAT_Pos)
25767/******************** Slave Interrupt status register **************************/
25768#define HRTIM_TIMISR_CMP1_Pos (0U)
25769#define HRTIM_TIMISR_CMP1_Msk (0x1UL << HRTIM_TIMISR_CMP1_Pos)
25770#define HRTIM_TIMISR_CMP1 HRTIM_TIMISR_CMP1_Msk
25771#define HRTIM_TIMISR_CMP2_Pos (1U)
25772#define HRTIM_TIMISR_CMP2_Msk (0x1UL << HRTIM_TIMISR_CMP2_Pos)
25773#define HRTIM_TIMISR_CMP2 HRTIM_TIMISR_CMP2_Msk
25774#define HRTIM_TIMISR_CMP3_Pos (2U)
25775#define HRTIM_TIMISR_CMP3_Msk (0x1UL << HRTIM_TIMISR_CMP3_Pos)
25776#define HRTIM_TIMISR_CMP3 HRTIM_TIMISR_CMP3_Msk
25777#define HRTIM_TIMISR_CMP4_Pos (3U)
25778#define HRTIM_TIMISR_CMP4_Msk (0x1UL << HRTIM_TIMISR_CMP4_Pos)
25779#define HRTIM_TIMISR_CMP4 HRTIM_TIMISR_CMP4_Msk
25780#define HRTIM_TIMISR_REP_Pos (4U)
25781#define HRTIM_TIMISR_REP_Msk (0x1UL << HRTIM_TIMISR_REP_Pos)
25782#define HRTIM_TIMISR_REP HRTIM_TIMISR_REP_Msk
25783#define HRTIM_TIMISR_UPD_Pos (6U)
25784#define HRTIM_TIMISR_UPD_Msk (0x1UL << HRTIM_TIMISR_UPD_Pos)
25785#define HRTIM_TIMISR_UPD HRTIM_TIMISR_UPD_Msk
25786#define HRTIM_TIMISR_CPT1_Pos (7U)
25787#define HRTIM_TIMISR_CPT1_Msk (0x1UL << HRTIM_TIMISR_CPT1_Pos)
25788#define HRTIM_TIMISR_CPT1 HRTIM_TIMISR_CPT1_Msk
25789#define HRTIM_TIMISR_CPT2_Pos (8U)
25790#define HRTIM_TIMISR_CPT2_Msk (0x1UL << HRTIM_TIMISR_CPT2_Pos)
25791#define HRTIM_TIMISR_CPT2 HRTIM_TIMISR_CPT2_Msk
25792#define HRTIM_TIMISR_SET1_Pos (9U)
25793#define HRTIM_TIMISR_SET1_Msk (0x1UL << HRTIM_TIMISR_SET1_Pos)
25794#define HRTIM_TIMISR_SET1 HRTIM_TIMISR_SET1_Msk
25795#define HRTIM_TIMISR_RST1_Pos (10U)
25796#define HRTIM_TIMISR_RST1_Msk (0x1UL << HRTIM_TIMISR_RST1_Pos)
25797#define HRTIM_TIMISR_RST1 HRTIM_TIMISR_RST1_Msk
25798#define HRTIM_TIMISR_SET2_Pos (11U)
25799#define HRTIM_TIMISR_SET2_Msk (0x1UL << HRTIM_TIMISR_SET2_Pos)
25800#define HRTIM_TIMISR_SET2 HRTIM_TIMISR_SET2_Msk
25801#define HRTIM_TIMISR_RST2_Pos (12U)
25802#define HRTIM_TIMISR_RST2_Msk (0x1UL << HRTIM_TIMISR_RST2_Pos)
25803#define HRTIM_TIMISR_RST2 HRTIM_TIMISR_RST2_Msk
25804#define HRTIM_TIMISR_RST_Pos (13U)
25805#define HRTIM_TIMISR_RST_Msk (0x1UL << HRTIM_TIMISR_RST_Pos)
25806#define HRTIM_TIMISR_RST HRTIM_TIMISR_RST_Msk
25807#define HRTIM_TIMISR_DLYPRT_Pos (14U)
25808#define HRTIM_TIMISR_DLYPRT_Msk (0x1UL << HRTIM_TIMISR_DLYPRT_Pos)
25809#define HRTIM_TIMISR_DLYPRT HRTIM_TIMISR_DLYPRT_Msk
25810#define HRTIM_TIMISR_CPPSTAT_Pos (16U)
25811#define HRTIM_TIMISR_CPPSTAT_Msk (0x1UL << HRTIM_TIMISR_CPPSTAT_Pos)
25812#define HRTIM_TIMISR_CPPSTAT HRTIM_TIMISR_CPPSTAT_Msk
25813#define HRTIM_TIMISR_IPPSTAT_Pos (17U)
25814#define HRTIM_TIMISR_IPPSTAT_Msk (0x1UL << HRTIM_TIMISR_IPPSTAT_Pos)
25815#define HRTIM_TIMISR_IPPSTAT HRTIM_TIMISR_IPPSTAT_Msk
25816#define HRTIM_TIMISR_O1STAT_Pos (18U)
25817#define HRTIM_TIMISR_O1STAT_Msk (0x1UL << HRTIM_TIMISR_O1STAT_Pos)
25818#define HRTIM_TIMISR_O1STAT HRTIM_TIMISR_O1STAT_Msk
25819#define HRTIM_TIMISR_O2STAT_Pos (19U)
25820#define HRTIM_TIMISR_O2STAT_Msk (0x1UL << HRTIM_TIMISR_O2STAT_Pos)
25821#define HRTIM_TIMISR_O2STAT HRTIM_TIMISR_O2STAT_Msk
25822#define HRTIM_TIMISR_O1CPY_Pos (20U)
25823#define HRTIM_TIMISR_O1CPY_Msk (0x1UL << HRTIM_TIMISR_O1CPY_Pos)
25824#define HRTIM_TIMISR_O1CPY HRTIM_TIMISR_O1CPY_Msk
25825#define HRTIM_TIMISR_O2CPY_Pos (21U)
25826#define HRTIM_TIMISR_O2CPY_Msk (0x1UL << HRTIM_TIMISR_O2CPY_Pos)
25827#define HRTIM_TIMISR_O2CPY HRTIM_TIMISR_O2CPY_Msk
25829/******************** Slave Interrupt clear register **************************/
25830#define HRTIM_TIMICR_CMP1C_Pos (0U)
25831#define HRTIM_TIMICR_CMP1C_Msk (0x1UL << HRTIM_TIMICR_CMP1C_Pos)
25832#define HRTIM_TIMICR_CMP1C HRTIM_TIMICR_CMP1C_Msk
25833#define HRTIM_TIMICR_CMP2C_Pos (1U)
25834#define HRTIM_TIMICR_CMP2C_Msk (0x1UL << HRTIM_TIMICR_CMP2C_Pos)
25835#define HRTIM_TIMICR_CMP2C HRTIM_TIMICR_CMP2C_Msk
25836#define HRTIM_TIMICR_CMP3C_Pos (2U)
25837#define HRTIM_TIMICR_CMP3C_Msk (0x1UL << HRTIM_TIMICR_CMP3C_Pos)
25838#define HRTIM_TIMICR_CMP3C HRTIM_TIMICR_CMP3C_Msk
25839#define HRTIM_TIMICR_CMP4C_Pos (3U)
25840#define HRTIM_TIMICR_CMP4C_Msk (0x1UL << HRTIM_TIMICR_CMP4C_Pos)
25841#define HRTIM_TIMICR_CMP4C HRTIM_TIMICR_CMP4C_Msk
25842#define HRTIM_TIMICR_REPC_Pos (4U)
25843#define HRTIM_TIMICR_REPC_Msk (0x1UL << HRTIM_TIMICR_REPC_Pos)
25844#define HRTIM_TIMICR_REPC HRTIM_TIMICR_REPC_Msk
25845#define HRTIM_TIMICR_UPDC_Pos (6U)
25846#define HRTIM_TIMICR_UPDC_Msk (0x1UL << HRTIM_TIMICR_UPDC_Pos)
25847#define HRTIM_TIMICR_UPDC HRTIM_TIMICR_UPDC_Msk
25848#define HRTIM_TIMICR_CPT1C_Pos (7U)
25849#define HRTIM_TIMICR_CPT1C_Msk (0x1UL << HRTIM_TIMICR_CPT1C_Pos)
25850#define HRTIM_TIMICR_CPT1C HRTIM_TIMICR_CPT1C_Msk
25851#define HRTIM_TIMICR_CPT2C_Pos (8U)
25852#define HRTIM_TIMICR_CPT2C_Msk (0x1UL << HRTIM_TIMICR_CPT2C_Pos)
25853#define HRTIM_TIMICR_CPT2C HRTIM_TIMICR_CPT2C_Msk
25854#define HRTIM_TIMICR_SET1C_Pos (9U)
25855#define HRTIM_TIMICR_SET1C_Msk (0x1UL << HRTIM_TIMICR_SET1C_Pos)
25856#define HRTIM_TIMICR_SET1C HRTIM_TIMICR_SET1C_Msk
25857#define HRTIM_TIMICR_RST1C_Pos (10U)
25858#define HRTIM_TIMICR_RST1C_Msk (0x1UL << HRTIM_TIMICR_RST1C_Pos)
25859#define HRTIM_TIMICR_RST1C HRTIM_TIMICR_RST1C_Msk
25860#define HRTIM_TIMICR_SET2C_Pos (11U)
25861#define HRTIM_TIMICR_SET2C_Msk (0x1UL << HRTIM_TIMICR_SET2C_Pos)
25862#define HRTIM_TIMICR_SET2C HRTIM_TIMICR_SET2C_Msk
25863#define HRTIM_TIMICR_RST2C_Pos (12U)
25864#define HRTIM_TIMICR_RST2C_Msk (0x1UL << HRTIM_TIMICR_RST2C_Pos)
25865#define HRTIM_TIMICR_RST2C HRTIM_TIMICR_RST2C_Msk
25866#define HRTIM_TIMICR_RSTC_Pos (13U)
25867#define HRTIM_TIMICR_RSTC_Msk (0x1UL << HRTIM_TIMICR_RSTC_Pos)
25868#define HRTIM_TIMICR_RSTC HRTIM_TIMICR_RSTC_Msk
25869#define HRTIM_TIMICR_DLYPRTC_Pos (14U)
25870#define HRTIM_TIMICR_DLYPRTC_Msk (0x1UL << HRTIM_TIMICR_DLYPRTC_Pos)
25871#define HRTIM_TIMICR_DLYPRTC HRTIM_TIMICR_DLYPRTC_Msk
25873/******************** Slave DMA/Interrupt enable register *********************/
25874#define HRTIM_TIMDIER_CMP1IE_Pos (0U)
25875#define HRTIM_TIMDIER_CMP1IE_Msk (0x1UL << HRTIM_TIMDIER_CMP1IE_Pos)
25876#define HRTIM_TIMDIER_CMP1IE HRTIM_TIMDIER_CMP1IE_Msk
25877#define HRTIM_TIMDIER_CMP2IE_Pos (1U)
25878#define HRTIM_TIMDIER_CMP2IE_Msk (0x1UL << HRTIM_TIMDIER_CMP2IE_Pos)
25879#define HRTIM_TIMDIER_CMP2IE HRTIM_TIMDIER_CMP2IE_Msk
25880#define HRTIM_TIMDIER_CMP3IE_Pos (2U)
25881#define HRTIM_TIMDIER_CMP3IE_Msk (0x1UL << HRTIM_TIMDIER_CMP3IE_Pos)
25882#define HRTIM_TIMDIER_CMP3IE HRTIM_TIMDIER_CMP3IE_Msk
25883#define HRTIM_TIMDIER_CMP4IE_Pos (3U)
25884#define HRTIM_TIMDIER_CMP4IE_Msk (0x1UL << HRTIM_TIMDIER_CMP4IE_Pos)
25885#define HRTIM_TIMDIER_CMP4IE HRTIM_TIMDIER_CMP4IE_Msk
25886#define HRTIM_TIMDIER_REPIE_Pos (4U)
25887#define HRTIM_TIMDIER_REPIE_Msk (0x1UL << HRTIM_TIMDIER_REPIE_Pos)
25888#define HRTIM_TIMDIER_REPIE HRTIM_TIMDIER_REPIE_Msk
25889#define HRTIM_TIMDIER_UPDIE_Pos (6U)
25890#define HRTIM_TIMDIER_UPDIE_Msk (0x1UL << HRTIM_TIMDIER_UPDIE_Pos)
25891#define HRTIM_TIMDIER_UPDIE HRTIM_TIMDIER_UPDIE_Msk
25892#define HRTIM_TIMDIER_CPT1IE_Pos (7U)
25893#define HRTIM_TIMDIER_CPT1IE_Msk (0x1UL << HRTIM_TIMDIER_CPT1IE_Pos)
25894#define HRTIM_TIMDIER_CPT1IE HRTIM_TIMDIER_CPT1IE_Msk
25895#define HRTIM_TIMDIER_CPT2IE_Pos (8U)
25896#define HRTIM_TIMDIER_CPT2IE_Msk (0x1UL << HRTIM_TIMDIER_CPT2IE_Pos)
25897#define HRTIM_TIMDIER_CPT2IE HRTIM_TIMDIER_CPT2IE_Msk
25898#define HRTIM_TIMDIER_SET1IE_Pos (9U)
25899#define HRTIM_TIMDIER_SET1IE_Msk (0x1UL << HRTIM_TIMDIER_SET1IE_Pos)
25900#define HRTIM_TIMDIER_SET1IE HRTIM_TIMDIER_SET1IE_Msk
25901#define HRTIM_TIMDIER_RST1IE_Pos (10U)
25902#define HRTIM_TIMDIER_RST1IE_Msk (0x1UL << HRTIM_TIMDIER_RST1IE_Pos)
25903#define HRTIM_TIMDIER_RST1IE HRTIM_TIMDIER_RST1IE_Msk
25904#define HRTIM_TIMDIER_SET2IE_Pos (11U)
25905#define HRTIM_TIMDIER_SET2IE_Msk (0x1UL << HRTIM_TIMDIER_SET2IE_Pos)
25906#define HRTIM_TIMDIER_SET2IE HRTIM_TIMDIER_SET2IE_Msk
25907#define HRTIM_TIMDIER_RST2IE_Pos (12U)
25908#define HRTIM_TIMDIER_RST2IE_Msk (0x1UL << HRTIM_TIMDIER_RST2IE_Pos)
25909#define HRTIM_TIMDIER_RST2IE HRTIM_TIMDIER_RST2IE_Msk
25910#define HRTIM_TIMDIER_RSTIE_Pos (13U)
25911#define HRTIM_TIMDIER_RSTIE_Msk (0x1UL << HRTIM_TIMDIER_RSTIE_Pos)
25912#define HRTIM_TIMDIER_RSTIE HRTIM_TIMDIER_RSTIE_Msk
25913#define HRTIM_TIMDIER_DLYPRTIE_Pos (14U)
25914#define HRTIM_TIMDIER_DLYPRTIE_Msk (0x1UL << HRTIM_TIMDIER_DLYPRTIE_Pos)
25915#define HRTIM_TIMDIER_DLYPRTIE HRTIM_TIMDIER_DLYPRTIE_Msk
25917#define HRTIM_TIMDIER_CMP1DE_Pos (16U)
25918#define HRTIM_TIMDIER_CMP1DE_Msk (0x1UL << HRTIM_TIMDIER_CMP1DE_Pos)
25919#define HRTIM_TIMDIER_CMP1DE HRTIM_TIMDIER_CMP1DE_Msk
25920#define HRTIM_TIMDIER_CMP2DE_Pos (17U)
25921#define HRTIM_TIMDIER_CMP2DE_Msk (0x1UL << HRTIM_TIMDIER_CMP2DE_Pos)
25922#define HRTIM_TIMDIER_CMP2DE HRTIM_TIMDIER_CMP2DE_Msk
25923#define HRTIM_TIMDIER_CMP3DE_Pos (18U)
25924#define HRTIM_TIMDIER_CMP3DE_Msk (0x1UL << HRTIM_TIMDIER_CMP3DE_Pos)
25925#define HRTIM_TIMDIER_CMP3DE HRTIM_TIMDIER_CMP3DE_Msk
25926#define HRTIM_TIMDIER_CMP4DE_Pos (19U)
25927#define HRTIM_TIMDIER_CMP4DE_Msk (0x1UL << HRTIM_TIMDIER_CMP4DE_Pos)
25928#define HRTIM_TIMDIER_CMP4DE HRTIM_TIMDIER_CMP4DE_Msk
25929#define HRTIM_TIMDIER_REPDE_Pos (20U)
25930#define HRTIM_TIMDIER_REPDE_Msk (0x1UL << HRTIM_TIMDIER_REPDE_Pos)
25931#define HRTIM_TIMDIER_REPDE HRTIM_TIMDIER_REPDE_Msk
25932#define HRTIM_TIMDIER_UPDDE_Pos (22U)
25933#define HRTIM_TIMDIER_UPDDE_Msk (0x1UL << HRTIM_TIMDIER_UPDDE_Pos)
25934#define HRTIM_TIMDIER_UPDDE HRTIM_TIMDIER_UPDDE_Msk
25935#define HRTIM_TIMDIER_CPT1DE_Pos (23U)
25936#define HRTIM_TIMDIER_CPT1DE_Msk (0x1UL << HRTIM_TIMDIER_CPT1DE_Pos)
25937#define HRTIM_TIMDIER_CPT1DE HRTIM_TIMDIER_CPT1DE_Msk
25938#define HRTIM_TIMDIER_CPT2DE_Pos (24U)
25939#define HRTIM_TIMDIER_CPT2DE_Msk (0x1UL << HRTIM_TIMDIER_CPT2DE_Pos)
25940#define HRTIM_TIMDIER_CPT2DE HRTIM_TIMDIER_CPT2DE_Msk
25941#define HRTIM_TIMDIER_SET1DE_Pos (25U)
25942#define HRTIM_TIMDIER_SET1DE_Msk (0x1UL << HRTIM_TIMDIER_SET1DE_Pos)
25943#define HRTIM_TIMDIER_SET1DE HRTIM_TIMDIER_SET1DE_Msk
25944#define HRTIM_TIMDIER_RST1DE_Pos (26U)
25945#define HRTIM_TIMDIER_RST1DE_Msk (0x1UL << HRTIM_TIMDIER_RST1DE_Pos)
25946#define HRTIM_TIMDIER_RST1DE HRTIM_TIMDIER_RST1DE_Msk
25947#define HRTIM_TIMDIER_SET2DE_Pos (27U)
25948#define HRTIM_TIMDIER_SET2DE_Msk (0x1UL << HRTIM_TIMDIER_SET2DE_Pos)
25949#define HRTIM_TIMDIER_SET2DE HRTIM_TIMDIER_SET2DE_Msk
25950#define HRTIM_TIMDIER_RST2DE_Pos (28U)
25951#define HRTIM_TIMDIER_RST2DE_Msk (0x1UL << HRTIM_TIMDIER_RST2DE_Pos)
25952#define HRTIM_TIMDIER_RST2DE HRTIM_TIMDIER_RST2DE_Msk
25953#define HRTIM_TIMDIER_RSTDE_Pos (29U)
25954#define HRTIM_TIMDIER_RSTDE_Msk (0x1UL << HRTIM_TIMDIER_RSTDE_Pos)
25955#define HRTIM_TIMDIER_RSTDE HRTIM_TIMDIER_RSTDE_Msk
25956#define HRTIM_TIMDIER_DLYPRTDE_Pos (30U)
25957#define HRTIM_TIMDIER_DLYPRTDE_Msk (0x1UL << HRTIM_TIMDIER_DLYPRTDE_Pos)
25958#define HRTIM_TIMDIER_DLYPRTDE HRTIM_TIMDIER_DLYPRTDE_Msk
25960/****************** Bit definition for HRTIM_CNTR register ****************/
25961#define HRTIM_CNTR_CNTR_Pos (0U)
25962#define HRTIM_CNTR_CNTR_Msk (0xFFFFUL << HRTIM_CNTR_CNTR_Pos)
25963#define HRTIM_CNTR_CNTR HRTIM_CNTR_CNTR_Msk
25965/******************* Bit definition for HRTIM_PER register *****************/
25966#define HRTIM_PER_PER_Pos (0U)
25967#define HRTIM_PER_PER_Msk (0xFFFFUL << HRTIM_PER_PER_Pos)
25968#define HRTIM_PER_PER HRTIM_PER_PER_Msk
25970/******************* Bit definition for HRTIM_REP register *****************/
25971#define HRTIM_REP_REP_Pos (0U)
25972#define HRTIM_REP_REP_Msk (0xFFUL << HRTIM_REP_REP_Pos)
25973#define HRTIM_REP_REP HRTIM_REP_REP_Msk
25975/******************* Bit definition for HRTIM_CMP1R register *****************/
25976#define HRTIM_CMP1R_CMP1R_Pos (0U)
25977#define HRTIM_CMP1R_CMP1R_Msk (0xFFFFUL << HRTIM_CMP1R_CMP1R_Pos)
25978#define HRTIM_CMP1R_CMP1R HRTIM_CMP1R_CMP1R_Msk
25980/******************* Bit definition for HRTIM_CMP1CR register *****************/
25981#define HRTIM_CMP1CR_CMP1CR_Pos (0U)
25982#define HRTIM_CMP1CR_CMP1CR_Msk (0xFFFFFFFFUL << HRTIM_CMP1CR_CMP1CR_Pos)
25983#define HRTIM_CMP1CR_CMP1CR HRTIM_CMP1CR_CMP1CR_Msk
25985/******************* Bit definition for HRTIM_CMP2R register *****************/
25986#define HRTIM_CMP2R_CMP2R_Pos (0U)
25987#define HRTIM_CMP2R_CMP2R_Msk (0xFFFFUL << HRTIM_CMP2R_CMP2R_Pos)
25988#define HRTIM_CMP2R_CMP2R HRTIM_CMP2R_CMP2R_Msk
25990/******************* Bit definition for HRTIM_CMP3R register *****************/
25991#define HRTIM_CMP3R_CMP3R_Pos (0U)
25992#define HRTIM_CMP3R_CMP3R_Msk (0xFFFFUL << HRTIM_CMP3R_CMP3R_Pos)
25993#define HRTIM_CMP3R_CMP3R HRTIM_CMP3R_CMP3R_Msk
25995/******************* Bit definition for HRTIM_CMP4R register *****************/
25996#define HRTIM_CMP4R_CMP4R_Pos (0U)
25997#define HRTIM_CMP4R_CMP4R_Msk (0xFFFFUL << HRTIM_CMP4R_CMP4R_Pos)
25998#define HRTIM_CMP4R_CMP4R HRTIM_CMP4R_CMP4R_Msk
26000/******************* Bit definition for HRTIM_CPT1R register ****************/
26001#define HRTIM_CPT1R_CPT1R_Pos (0U)
26002#define HRTIM_CPT1R_CPT1R_Msk (0xFFFFUL << HRTIM_CPT1R_CPT1R_Pos)
26003#define HRTIM_CPT1R_CPT1R HRTIM_CPT1R_CPT1R_Msk
26005/******************* Bit definition for HRTIM_CPT2R register ****************/
26006#define HRTIM_CPT2R_CPT2R_Pos (0U)
26007#define HRTIM_CPT2R_CPT2R_Msk (0xFFFFUL << HRTIM_CPT2R_CPT2R_Pos)
26008#define HRTIM_CPT2R_CPT2R HRTIM_CPT2R_CPT2R_Msk
26010/******************** Bit definition for Slave Deadtime register **************/
26011#define HRTIM_DTR_DTR_Pos (0U)
26012#define HRTIM_DTR_DTR_Msk (0x1FFUL << HRTIM_DTR_DTR_Pos)
26013#define HRTIM_DTR_DTR HRTIM_DTR_DTR_Msk
26014#define HRTIM_DTR_DTR_0 (0x001UL << HRTIM_DTR_DTR_Pos)
26015#define HRTIM_DTR_DTR_1 (0x002UL << HRTIM_DTR_DTR_Pos)
26016#define HRTIM_DTR_DTR_2 (0x004UL << HRTIM_DTR_DTR_Pos)
26017#define HRTIM_DTR_DTR_3 (0x008UL << HRTIM_DTR_DTR_Pos)
26018#define HRTIM_DTR_DTR_4 (0x010UL << HRTIM_DTR_DTR_Pos)
26019#define HRTIM_DTR_DTR_5 (0x020UL << HRTIM_DTR_DTR_Pos)
26020#define HRTIM_DTR_DTR_6 (0x040UL << HRTIM_DTR_DTR_Pos)
26021#define HRTIM_DTR_DTR_7 (0x080UL << HRTIM_DTR_DTR_Pos)
26022#define HRTIM_DTR_DTR_8 (0x100UL << HRTIM_DTR_DTR_Pos)
26023#define HRTIM_DTR_SDTR_Pos (9U)
26024#define HRTIM_DTR_SDTR_Msk (0x1UL << HRTIM_DTR_SDTR_Pos)
26025#define HRTIM_DTR_SDTR HRTIM_DTR_SDTR_Msk
26026#define HRTIM_DTR_DTPRSC_Pos (10U)
26027#define HRTIM_DTR_DTPRSC_Msk (0x7UL << HRTIM_DTR_DTPRSC_Pos)
26028#define HRTIM_DTR_DTPRSC HRTIM_DTR_DTPRSC_Msk
26029#define HRTIM_DTR_DTPRSC_0 (0x1UL << HRTIM_DTR_DTPRSC_Pos)
26030#define HRTIM_DTR_DTPRSC_1 (0x2UL << HRTIM_DTR_DTPRSC_Pos)
26031#define HRTIM_DTR_DTPRSC_2 (0x4UL << HRTIM_DTR_DTPRSC_Pos)
26032#define HRTIM_DTR_DTRSLK_Pos (14U)
26033#define HRTIM_DTR_DTRSLK_Msk (0x1UL << HRTIM_DTR_DTRSLK_Pos)
26034#define HRTIM_DTR_DTRSLK HRTIM_DTR_DTRSLK_Msk
26035#define HRTIM_DTR_DTRLK_Pos (15U)
26036#define HRTIM_DTR_DTRLK_Msk (0x1UL << HRTIM_DTR_DTRLK_Pos)
26037#define HRTIM_DTR_DTRLK HRTIM_DTR_DTRLK_Msk
26038#define HRTIM_DTR_DTF_Pos (16U)
26039#define HRTIM_DTR_DTF_Msk (0x1FFUL << HRTIM_DTR_DTF_Pos)
26040#define HRTIM_DTR_DTF HRTIM_DTR_DTF_Msk
26041#define HRTIM_DTR_DTF_0 (0x001UL << HRTIM_DTR_DTF_Pos)
26042#define HRTIM_DTR_DTF_1 (0x002UL << HRTIM_DTR_DTF_Pos)
26043#define HRTIM_DTR_DTF_2 (0x004UL << HRTIM_DTR_DTF_Pos)
26044#define HRTIM_DTR_DTF_3 (0x008UL << HRTIM_DTR_DTF_Pos)
26045#define HRTIM_DTR_DTF_4 (0x010UL << HRTIM_DTR_DTF_Pos)
26046#define HRTIM_DTR_DTF_5 (0x020UL << HRTIM_DTR_DTF_Pos)
26047#define HRTIM_DTR_DTF_6 (0x040UL << HRTIM_DTR_DTF_Pos)
26048#define HRTIM_DTR_DTF_7 (0x080UL << HRTIM_DTR_DTF_Pos)
26049#define HRTIM_DTR_DTF_8 (0x100UL << HRTIM_DTR_DTF_Pos)
26050#define HRTIM_DTR_SDTF_Pos (25U)
26051#define HRTIM_DTR_SDTF_Msk (0x1UL << HRTIM_DTR_SDTF_Pos)
26052#define HRTIM_DTR_SDTF HRTIM_DTR_SDTF_Msk
26053#define HRTIM_DTR_DTFSLK_Pos (30U)
26054#define HRTIM_DTR_DTFSLK_Msk (0x1UL << HRTIM_DTR_DTFSLK_Pos)
26055#define HRTIM_DTR_DTFSLK HRTIM_DTR_DTFSLK_Msk
26056#define HRTIM_DTR_DTFLK_Pos (31U)
26057#define HRTIM_DTR_DTFLK_Msk (0x1UL << HRTIM_DTR_DTFLK_Pos)
26058#define HRTIM_DTR_DTFLK HRTIM_DTR_DTFLK_Msk
26060/**** Bit definition for Slave Output 1 set register **************************/
26061#define HRTIM_SET1R_SST_Pos (0U)
26062#define HRTIM_SET1R_SST_Msk (0x1UL << HRTIM_SET1R_SST_Pos)
26063#define HRTIM_SET1R_SST HRTIM_SET1R_SST_Msk
26064#define HRTIM_SET1R_RESYNC_Pos (1U)
26065#define HRTIM_SET1R_RESYNC_Msk (0x1UL << HRTIM_SET1R_RESYNC_Pos)
26066#define HRTIM_SET1R_RESYNC HRTIM_SET1R_RESYNC_Msk
26067#define HRTIM_SET1R_PER_Pos (2U)
26068#define HRTIM_SET1R_PER_Msk (0x1UL << HRTIM_SET1R_PER_Pos)
26069#define HRTIM_SET1R_PER HRTIM_SET1R_PER_Msk
26070#define HRTIM_SET1R_CMP1_Pos (3U)
26071#define HRTIM_SET1R_CMP1_Msk (0x1UL << HRTIM_SET1R_CMP1_Pos)
26072#define HRTIM_SET1R_CMP1 HRTIM_SET1R_CMP1_Msk
26073#define HRTIM_SET1R_CMP2_Pos (4U)
26074#define HRTIM_SET1R_CMP2_Msk (0x1UL << HRTIM_SET1R_CMP2_Pos)
26075#define HRTIM_SET1R_CMP2 HRTIM_SET1R_CMP2_Msk
26076#define HRTIM_SET1R_CMP3_Pos (5U)
26077#define HRTIM_SET1R_CMP3_Msk (0x1UL << HRTIM_SET1R_CMP3_Pos)
26078#define HRTIM_SET1R_CMP3 HRTIM_SET1R_CMP3_Msk
26079#define HRTIM_SET1R_CMP4_Pos (6U)
26080#define HRTIM_SET1R_CMP4_Msk (0x1UL << HRTIM_SET1R_CMP4_Pos)
26081#define HRTIM_SET1R_CMP4 HRTIM_SET1R_CMP4_Msk
26083#define HRTIM_SET1R_MSTPER_Pos (7U)
26084#define HRTIM_SET1R_MSTPER_Msk (0x1UL << HRTIM_SET1R_MSTPER_Pos)
26085#define HRTIM_SET1R_MSTPER HRTIM_SET1R_MSTPER_Msk
26086#define HRTIM_SET1R_MSTCMP1_Pos (8U)
26087#define HRTIM_SET1R_MSTCMP1_Msk (0x1UL << HRTIM_SET1R_MSTCMP1_Pos)
26088#define HRTIM_SET1R_MSTCMP1 HRTIM_SET1R_MSTCMP1_Msk
26089#define HRTIM_SET1R_MSTCMP2_Pos (9U)
26090#define HRTIM_SET1R_MSTCMP2_Msk (0x1UL << HRTIM_SET1R_MSTCMP2_Pos)
26091#define HRTIM_SET1R_MSTCMP2 HRTIM_SET1R_MSTCMP2_Msk
26092#define HRTIM_SET1R_MSTCMP3_Pos (10U)
26093#define HRTIM_SET1R_MSTCMP3_Msk (0x1UL << HRTIM_SET1R_MSTCMP3_Pos)
26094#define HRTIM_SET1R_MSTCMP3 HRTIM_SET1R_MSTCMP3_Msk
26095#define HRTIM_SET1R_MSTCMP4_Pos (11U)
26096#define HRTIM_SET1R_MSTCMP4_Msk (0x1UL << HRTIM_SET1R_MSTCMP4_Pos)
26097#define HRTIM_SET1R_MSTCMP4 HRTIM_SET1R_MSTCMP4_Msk
26099#define HRTIM_SET1R_TIMEVNT1_Pos (12U)
26100#define HRTIM_SET1R_TIMEVNT1_Msk (0x1UL << HRTIM_SET1R_TIMEVNT1_Pos)
26101#define HRTIM_SET1R_TIMEVNT1 HRTIM_SET1R_TIMEVNT1_Msk
26102#define HRTIM_SET1R_TIMEVNT2_Pos (13U)
26103#define HRTIM_SET1R_TIMEVNT2_Msk (0x1UL << HRTIM_SET1R_TIMEVNT2_Pos)
26104#define HRTIM_SET1R_TIMEVNT2 HRTIM_SET1R_TIMEVNT2_Msk
26105#define HRTIM_SET1R_TIMEVNT3_Pos (14U)
26106#define HRTIM_SET1R_TIMEVNT3_Msk (0x1UL << HRTIM_SET1R_TIMEVNT3_Pos)
26107#define HRTIM_SET1R_TIMEVNT3 HRTIM_SET1R_TIMEVNT3_Msk
26108#define HRTIM_SET1R_TIMEVNT4_Pos (15U)
26109#define HRTIM_SET1R_TIMEVNT4_Msk (0x1UL << HRTIM_SET1R_TIMEVNT4_Pos)
26110#define HRTIM_SET1R_TIMEVNT4 HRTIM_SET1R_TIMEVNT4_Msk
26111#define HRTIM_SET1R_TIMEVNT5_Pos (16U)
26112#define HRTIM_SET1R_TIMEVNT5_Msk (0x1UL << HRTIM_SET1R_TIMEVNT5_Pos)
26113#define HRTIM_SET1R_TIMEVNT5 HRTIM_SET1R_TIMEVNT5_Msk
26114#define HRTIM_SET1R_TIMEVNT6_Pos (17U)
26115#define HRTIM_SET1R_TIMEVNT6_Msk (0x1UL << HRTIM_SET1R_TIMEVNT6_Pos)
26116#define HRTIM_SET1R_TIMEVNT6 HRTIM_SET1R_TIMEVNT6_Msk
26117#define HRTIM_SET1R_TIMEVNT7_Pos (18U)
26118#define HRTIM_SET1R_TIMEVNT7_Msk (0x1UL << HRTIM_SET1R_TIMEVNT7_Pos)
26119#define HRTIM_SET1R_TIMEVNT7 HRTIM_SET1R_TIMEVNT7_Msk
26120#define HRTIM_SET1R_TIMEVNT8_Pos (19U)
26121#define HRTIM_SET1R_TIMEVNT8_Msk (0x1UL << HRTIM_SET1R_TIMEVNT8_Pos)
26122#define HRTIM_SET1R_TIMEVNT8 HRTIM_SET1R_TIMEVNT8_Msk
26123#define HRTIM_SET1R_TIMEVNT9_Pos (20U)
26124#define HRTIM_SET1R_TIMEVNT9_Msk (0x1UL << HRTIM_SET1R_TIMEVNT9_Pos)
26125#define HRTIM_SET1R_TIMEVNT9 HRTIM_SET1R_TIMEVNT9_Msk
26127#define HRTIM_SET1R_EXTVNT1_Pos (21U)
26128#define HRTIM_SET1R_EXTVNT1_Msk (0x1UL << HRTIM_SET1R_EXTVNT1_Pos)
26129#define HRTIM_SET1R_EXTVNT1 HRTIM_SET1R_EXTVNT1_Msk
26130#define HRTIM_SET1R_EXTVNT2_Pos (22U)
26131#define HRTIM_SET1R_EXTVNT2_Msk (0x1UL << HRTIM_SET1R_EXTVNT2_Pos)
26132#define HRTIM_SET1R_EXTVNT2 HRTIM_SET1R_EXTVNT2_Msk
26133#define HRTIM_SET1R_EXTVNT3_Pos (23U)
26134#define HRTIM_SET1R_EXTVNT3_Msk (0x1UL << HRTIM_SET1R_EXTVNT3_Pos)
26135#define HRTIM_SET1R_EXTVNT3 HRTIM_SET1R_EXTVNT3_Msk
26136#define HRTIM_SET1R_EXTVNT4_Pos (24U)
26137#define HRTIM_SET1R_EXTVNT4_Msk (0x1UL << HRTIM_SET1R_EXTVNT4_Pos)
26138#define HRTIM_SET1R_EXTVNT4 HRTIM_SET1R_EXTVNT4_Msk
26139#define HRTIM_SET1R_EXTVNT5_Pos (25U)
26140#define HRTIM_SET1R_EXTVNT5_Msk (0x1UL << HRTIM_SET1R_EXTVNT5_Pos)
26141#define HRTIM_SET1R_EXTVNT5 HRTIM_SET1R_EXTVNT5_Msk
26142#define HRTIM_SET1R_EXTVNT6_Pos (26U)
26143#define HRTIM_SET1R_EXTVNT6_Msk (0x1UL << HRTIM_SET1R_EXTVNT6_Pos)
26144#define HRTIM_SET1R_EXTVNT6 HRTIM_SET1R_EXTVNT6_Msk
26145#define HRTIM_SET1R_EXTVNT7_Pos (27U)
26146#define HRTIM_SET1R_EXTVNT7_Msk (0x1UL << HRTIM_SET1R_EXTVNT7_Pos)
26147#define HRTIM_SET1R_EXTVNT7 HRTIM_SET1R_EXTVNT7_Msk
26148#define HRTIM_SET1R_EXTVNT8_Pos (28U)
26149#define HRTIM_SET1R_EXTVNT8_Msk (0x1UL << HRTIM_SET1R_EXTVNT8_Pos)
26150#define HRTIM_SET1R_EXTVNT8 HRTIM_SET1R_EXTVNT8_Msk
26151#define HRTIM_SET1R_EXTVNT9_Pos (29U)
26152#define HRTIM_SET1R_EXTVNT9_Msk (0x1UL << HRTIM_SET1R_EXTVNT9_Pos)
26153#define HRTIM_SET1R_EXTVNT9 HRTIM_SET1R_EXTVNT9_Msk
26154#define HRTIM_SET1R_EXTVNT10_Pos (30U)
26155#define HRTIM_SET1R_EXTVNT10_Msk (0x1UL << HRTIM_SET1R_EXTVNT10_Pos)
26156#define HRTIM_SET1R_EXTVNT10 HRTIM_SET1R_EXTVNT10_Msk
26158#define HRTIM_SET1R_UPDATE_Pos (31U)
26159#define HRTIM_SET1R_UPDATE_Msk (0x1UL << HRTIM_SET1R_UPDATE_Pos)
26160#define HRTIM_SET1R_UPDATE HRTIM_SET1R_UPDATE_Msk
26162/**** Bit definition for Slave Output 1 reset register ************************/
26163#define HRTIM_RST1R_SRT_Pos (0U)
26164#define HRTIM_RST1R_SRT_Msk (0x1UL << HRTIM_RST1R_SRT_Pos)
26165#define HRTIM_RST1R_SRT HRTIM_RST1R_SRT_Msk
26166#define HRTIM_RST1R_RESYNC_Pos (1U)
26167#define HRTIM_RST1R_RESYNC_Msk (0x1UL << HRTIM_RST1R_RESYNC_Pos)
26168#define HRTIM_RST1R_RESYNC HRTIM_RST1R_RESYNC_Msk
26169#define HRTIM_RST1R_PER_Pos (2U)
26170#define HRTIM_RST1R_PER_Msk (0x1UL << HRTIM_RST1R_PER_Pos)
26171#define HRTIM_RST1R_PER HRTIM_RST1R_PER_Msk
26172#define HRTIM_RST1R_CMP1_Pos (3U)
26173#define HRTIM_RST1R_CMP1_Msk (0x1UL << HRTIM_RST1R_CMP1_Pos)
26174#define HRTIM_RST1R_CMP1 HRTIM_RST1R_CMP1_Msk
26175#define HRTIM_RST1R_CMP2_Pos (4U)
26176#define HRTIM_RST1R_CMP2_Msk (0x1UL << HRTIM_RST1R_CMP2_Pos)
26177#define HRTIM_RST1R_CMP2 HRTIM_RST1R_CMP2_Msk
26178#define HRTIM_RST1R_CMP3_Pos (5U)
26179#define HRTIM_RST1R_CMP3_Msk (0x1UL << HRTIM_RST1R_CMP3_Pos)
26180#define HRTIM_RST1R_CMP3 HRTIM_RST1R_CMP3_Msk
26181#define HRTIM_RST1R_CMP4_Pos (6U)
26182#define HRTIM_RST1R_CMP4_Msk (0x1UL << HRTIM_RST1R_CMP4_Pos)
26183#define HRTIM_RST1R_CMP4 HRTIM_RST1R_CMP4_Msk
26185#define HRTIM_RST1R_MSTPER_Pos (7U)
26186#define HRTIM_RST1R_MSTPER_Msk (0x1UL << HRTIM_RST1R_MSTPER_Pos)
26187#define HRTIM_RST1R_MSTPER HRTIM_RST1R_MSTPER_Msk
26188#define HRTIM_RST1R_MSTCMP1_Pos (8U)
26189#define HRTIM_RST1R_MSTCMP1_Msk (0x1UL << HRTIM_RST1R_MSTCMP1_Pos)
26190#define HRTIM_RST1R_MSTCMP1 HRTIM_RST1R_MSTCMP1_Msk
26191#define HRTIM_RST1R_MSTCMP2_Pos (9U)
26192#define HRTIM_RST1R_MSTCMP2_Msk (0x1UL << HRTIM_RST1R_MSTCMP2_Pos)
26193#define HRTIM_RST1R_MSTCMP2 HRTIM_RST1R_MSTCMP2_Msk
26194#define HRTIM_RST1R_MSTCMP3_Pos (10U)
26195#define HRTIM_RST1R_MSTCMP3_Msk (0x1UL << HRTIM_RST1R_MSTCMP3_Pos)
26196#define HRTIM_RST1R_MSTCMP3 HRTIM_RST1R_MSTCMP3_Msk
26197#define HRTIM_RST1R_MSTCMP4_Pos (11U)
26198#define HRTIM_RST1R_MSTCMP4_Msk (0x1UL << HRTIM_RST1R_MSTCMP4_Pos)
26199#define HRTIM_RST1R_MSTCMP4 HRTIM_RST1R_MSTCMP4_Msk
26201#define HRTIM_RST1R_TIMEVNT1_Pos (12U)
26202#define HRTIM_RST1R_TIMEVNT1_Msk (0x1UL << HRTIM_RST1R_TIMEVNT1_Pos)
26203#define HRTIM_RST1R_TIMEVNT1 HRTIM_RST1R_TIMEVNT1_Msk
26204#define HRTIM_RST1R_TIMEVNT2_Pos (13U)
26205#define HRTIM_RST1R_TIMEVNT2_Msk (0x1UL << HRTIM_RST1R_TIMEVNT2_Pos)
26206#define HRTIM_RST1R_TIMEVNT2 HRTIM_RST1R_TIMEVNT2_Msk
26207#define HRTIM_RST1R_TIMEVNT3_Pos (14U)
26208#define HRTIM_RST1R_TIMEVNT3_Msk (0x1UL << HRTIM_RST1R_TIMEVNT3_Pos)
26209#define HRTIM_RST1R_TIMEVNT3 HRTIM_RST1R_TIMEVNT3_Msk
26210#define HRTIM_RST1R_TIMEVNT4_Pos (15U)
26211#define HRTIM_RST1R_TIMEVNT4_Msk (0x1UL << HRTIM_RST1R_TIMEVNT4_Pos)
26212#define HRTIM_RST1R_TIMEVNT4 HRTIM_RST1R_TIMEVNT4_Msk
26213#define HRTIM_RST1R_TIMEVNT5_Pos (16U)
26214#define HRTIM_RST1R_TIMEVNT5_Msk (0x1UL << HRTIM_RST1R_TIMEVNT5_Pos)
26215#define HRTIM_RST1R_TIMEVNT5 HRTIM_RST1R_TIMEVNT5_Msk
26216#define HRTIM_RST1R_TIMEVNT6_Pos (17U)
26217#define HRTIM_RST1R_TIMEVNT6_Msk (0x1UL << HRTIM_RST1R_TIMEVNT6_Pos)
26218#define HRTIM_RST1R_TIMEVNT6 HRTIM_RST1R_TIMEVNT6_Msk
26219#define HRTIM_RST1R_TIMEVNT7_Pos (18U)
26220#define HRTIM_RST1R_TIMEVNT7_Msk (0x1UL << HRTIM_RST1R_TIMEVNT7_Pos)
26221#define HRTIM_RST1R_TIMEVNT7 HRTIM_RST1R_TIMEVNT7_Msk
26222#define HRTIM_RST1R_TIMEVNT8_Pos (19U)
26223#define HRTIM_RST1R_TIMEVNT8_Msk (0x1UL << HRTIM_RST1R_TIMEVNT8_Pos)
26224#define HRTIM_RST1R_TIMEVNT8 HRTIM_RST1R_TIMEVNT8_Msk
26225#define HRTIM_RST1R_TIMEVNT9_Pos (20U)
26226#define HRTIM_RST1R_TIMEVNT9_Msk (0x1UL << HRTIM_RST1R_TIMEVNT9_Pos)
26227#define HRTIM_RST1R_TIMEVNT9 HRTIM_RST1R_TIMEVNT9_Msk
26229#define HRTIM_RST1R_EXTVNT1_Pos (21U)
26230#define HRTIM_RST1R_EXTVNT1_Msk (0x1UL << HRTIM_RST1R_EXTVNT1_Pos)
26231#define HRTIM_RST1R_EXTVNT1 HRTIM_RST1R_EXTVNT1_Msk
26232#define HRTIM_RST1R_EXTVNT2_Pos (22U)
26233#define HRTIM_RST1R_EXTVNT2_Msk (0x1UL << HRTIM_RST1R_EXTVNT2_Pos)
26234#define HRTIM_RST1R_EXTVNT2 HRTIM_RST1R_EXTVNT2_Msk
26235#define HRTIM_RST1R_EXTVNT3_Pos (23U)
26236#define HRTIM_RST1R_EXTVNT3_Msk (0x1UL << HRTIM_RST1R_EXTVNT3_Pos)
26237#define HRTIM_RST1R_EXTVNT3 HRTIM_RST1R_EXTVNT3_Msk
26238#define HRTIM_RST1R_EXTVNT4_Pos (24U)
26239#define HRTIM_RST1R_EXTVNT4_Msk (0x1UL << HRTIM_RST1R_EXTVNT4_Pos)
26240#define HRTIM_RST1R_EXTVNT4 HRTIM_RST1R_EXTVNT4_Msk
26241#define HRTIM_RST1R_EXTVNT5_Pos (25U)
26242#define HRTIM_RST1R_EXTVNT5_Msk (0x1UL << HRTIM_RST1R_EXTVNT5_Pos)
26243#define HRTIM_RST1R_EXTVNT5 HRTIM_RST1R_EXTVNT5_Msk
26244#define HRTIM_RST1R_EXTVNT6_Pos (26U)
26245#define HRTIM_RST1R_EXTVNT6_Msk (0x1UL << HRTIM_RST1R_EXTVNT6_Pos)
26246#define HRTIM_RST1R_EXTVNT6 HRTIM_RST1R_EXTVNT6_Msk
26247#define HRTIM_RST1R_EXTVNT7_Pos (27U)
26248#define HRTIM_RST1R_EXTVNT7_Msk (0x1UL << HRTIM_RST1R_EXTVNT7_Pos)
26249#define HRTIM_RST1R_EXTVNT7 HRTIM_RST1R_EXTVNT7_Msk
26250#define HRTIM_RST1R_EXTVNT8_Pos (28U)
26251#define HRTIM_RST1R_EXTVNT8_Msk (0x1UL << HRTIM_RST1R_EXTVNT8_Pos)
26252#define HRTIM_RST1R_EXTVNT8 HRTIM_RST1R_EXTVNT8_Msk
26253#define HRTIM_RST1R_EXTVNT9_Pos (29U)
26254#define HRTIM_RST1R_EXTVNT9_Msk (0x1UL << HRTIM_RST1R_EXTVNT9_Pos)
26255#define HRTIM_RST1R_EXTVNT9 HRTIM_RST1R_EXTVNT9_Msk
26256#define HRTIM_RST1R_EXTVNT10_Pos (30U)
26257#define HRTIM_RST1R_EXTVNT10_Msk (0x1UL << HRTIM_RST1R_EXTVNT10_Pos)
26258#define HRTIM_RST1R_EXTVNT10 HRTIM_RST1R_EXTVNT10_Msk
26260#define HRTIM_RST1R_UPDATE_Pos (31U)
26261#define HRTIM_RST1R_UPDATE_Msk (0x1UL << HRTIM_RST1R_UPDATE_Pos)
26262#define HRTIM_RST1R_UPDATE HRTIM_RST1R_UPDATE_Msk
26265/**** Bit definition for Slave Output 2 set register **************************/
26266#define HRTIM_SET2R_SST_Pos (0U)
26267#define HRTIM_SET2R_SST_Msk (0x1UL << HRTIM_SET2R_SST_Pos)
26268#define HRTIM_SET2R_SST HRTIM_SET2R_SST_Msk
26269#define HRTIM_SET2R_RESYNC_Pos (1U)
26270#define HRTIM_SET2R_RESYNC_Msk (0x1UL << HRTIM_SET2R_RESYNC_Pos)
26271#define HRTIM_SET2R_RESYNC HRTIM_SET2R_RESYNC_Msk
26272#define HRTIM_SET2R_PER_Pos (2U)
26273#define HRTIM_SET2R_PER_Msk (0x1UL << HRTIM_SET2R_PER_Pos)
26274#define HRTIM_SET2R_PER HRTIM_SET2R_PER_Msk
26275#define HRTIM_SET2R_CMP1_Pos (3U)
26276#define HRTIM_SET2R_CMP1_Msk (0x1UL << HRTIM_SET2R_CMP1_Pos)
26277#define HRTIM_SET2R_CMP1 HRTIM_SET2R_CMP1_Msk
26278#define HRTIM_SET2R_CMP2_Pos (4U)
26279#define HRTIM_SET2R_CMP2_Msk (0x1UL << HRTIM_SET2R_CMP2_Pos)
26280#define HRTIM_SET2R_CMP2 HRTIM_SET2R_CMP2_Msk
26281#define HRTIM_SET2R_CMP3_Pos (5U)
26282#define HRTIM_SET2R_CMP3_Msk (0x1UL << HRTIM_SET2R_CMP3_Pos)
26283#define HRTIM_SET2R_CMP3 HRTIM_SET2R_CMP3_Msk
26284#define HRTIM_SET2R_CMP4_Pos (6U)
26285#define HRTIM_SET2R_CMP4_Msk (0x1UL << HRTIM_SET2R_CMP4_Pos)
26286#define HRTIM_SET2R_CMP4 HRTIM_SET2R_CMP4_Msk
26288#define HRTIM_SET2R_MSTPER_Pos (7U)
26289#define HRTIM_SET2R_MSTPER_Msk (0x1UL << HRTIM_SET2R_MSTPER_Pos)
26290#define HRTIM_SET2R_MSTPER HRTIM_SET2R_MSTPER_Msk
26291#define HRTIM_SET2R_MSTCMP1_Pos (8U)
26292#define HRTIM_SET2R_MSTCMP1_Msk (0x1UL << HRTIM_SET2R_MSTCMP1_Pos)
26293#define HRTIM_SET2R_MSTCMP1 HRTIM_SET2R_MSTCMP1_Msk
26294#define HRTIM_SET2R_MSTCMP2_Pos (9U)
26295#define HRTIM_SET2R_MSTCMP2_Msk (0x1UL << HRTIM_SET2R_MSTCMP2_Pos)
26296#define HRTIM_SET2R_MSTCMP2 HRTIM_SET2R_MSTCMP2_Msk
26297#define HRTIM_SET2R_MSTCMP3_Pos (10U)
26298#define HRTIM_SET2R_MSTCMP3_Msk (0x1UL << HRTIM_SET2R_MSTCMP3_Pos)
26299#define HRTIM_SET2R_MSTCMP3 HRTIM_SET2R_MSTCMP3_Msk
26300#define HRTIM_SET2R_MSTCMP4_Pos (11U)
26301#define HRTIM_SET2R_MSTCMP4_Msk (0x1UL << HRTIM_SET2R_MSTCMP4_Pos)
26302#define HRTIM_SET2R_MSTCMP4 HRTIM_SET2R_MSTCMP4_Msk
26304#define HRTIM_SET2R_TIMEVNT1_Pos (12U)
26305#define HRTIM_SET2R_TIMEVNT1_Msk (0x1UL << HRTIM_SET2R_TIMEVNT1_Pos)
26306#define HRTIM_SET2R_TIMEVNT1 HRTIM_SET2R_TIMEVNT1_Msk
26307#define HRTIM_SET2R_TIMEVNT2_Pos (13U)
26308#define HRTIM_SET2R_TIMEVNT2_Msk (0x1UL << HRTIM_SET2R_TIMEVNT2_Pos)
26309#define HRTIM_SET2R_TIMEVNT2 HRTIM_SET2R_TIMEVNT2_Msk
26310#define HRTIM_SET2R_TIMEVNT3_Pos (14U)
26311#define HRTIM_SET2R_TIMEVNT3_Msk (0x1UL << HRTIM_SET2R_TIMEVNT3_Pos)
26312#define HRTIM_SET2R_TIMEVNT3 HRTIM_SET2R_TIMEVNT3_Msk
26313#define HRTIM_SET2R_TIMEVNT4_Pos (15U)
26314#define HRTIM_SET2R_TIMEVNT4_Msk (0x1UL << HRTIM_SET2R_TIMEVNT4_Pos)
26315#define HRTIM_SET2R_TIMEVNT4 HRTIM_SET2R_TIMEVNT4_Msk
26316#define HRTIM_SET2R_TIMEVNT5_Pos (16U)
26317#define HRTIM_SET2R_TIMEVNT5_Msk (0x1UL << HRTIM_SET2R_TIMEVNT5_Pos)
26318#define HRTIM_SET2R_TIMEVNT5 HRTIM_SET2R_TIMEVNT5_Msk
26319#define HRTIM_SET2R_TIMEVNT6_Pos (17U)
26320#define HRTIM_SET2R_TIMEVNT6_Msk (0x1UL << HRTIM_SET2R_TIMEVNT6_Pos)
26321#define HRTIM_SET2R_TIMEVNT6 HRTIM_SET2R_TIMEVNT6_Msk
26322#define HRTIM_SET2R_TIMEVNT7_Pos (18U)
26323#define HRTIM_SET2R_TIMEVNT7_Msk (0x1UL << HRTIM_SET2R_TIMEVNT7_Pos)
26324#define HRTIM_SET2R_TIMEVNT7 HRTIM_SET2R_TIMEVNT7_Msk
26325#define HRTIM_SET2R_TIMEVNT8_Pos (19U)
26326#define HRTIM_SET2R_TIMEVNT8_Msk (0x1UL << HRTIM_SET2R_TIMEVNT8_Pos)
26327#define HRTIM_SET2R_TIMEVNT8 HRTIM_SET2R_TIMEVNT8_Msk
26328#define HRTIM_SET2R_TIMEVNT9_Pos (20U)
26329#define HRTIM_SET2R_TIMEVNT9_Msk (0x1UL << HRTIM_SET2R_TIMEVNT9_Pos)
26330#define HRTIM_SET2R_TIMEVNT9 HRTIM_SET2R_TIMEVNT9_Msk
26332#define HRTIM_SET2R_EXTVNT1_Pos (21U)
26333#define HRTIM_SET2R_EXTVNT1_Msk (0x1UL << HRTIM_SET2R_EXTVNT1_Pos)
26334#define HRTIM_SET2R_EXTVNT1 HRTIM_SET2R_EXTVNT1_Msk
26335#define HRTIM_SET2R_EXTVNT2_Pos (22U)
26336#define HRTIM_SET2R_EXTVNT2_Msk (0x1UL << HRTIM_SET2R_EXTVNT2_Pos)
26337#define HRTIM_SET2R_EXTVNT2 HRTIM_SET2R_EXTVNT2_Msk
26338#define HRTIM_SET2R_EXTVNT3_Pos (23U)
26339#define HRTIM_SET2R_EXTVNT3_Msk (0x1UL << HRTIM_SET2R_EXTVNT3_Pos)
26340#define HRTIM_SET2R_EXTVNT3 HRTIM_SET2R_EXTVNT3_Msk
26341#define HRTIM_SET2R_EXTVNT4_Pos (24U)
26342#define HRTIM_SET2R_EXTVNT4_Msk (0x1UL << HRTIM_SET2R_EXTVNT4_Pos)
26343#define HRTIM_SET2R_EXTVNT4 HRTIM_SET2R_EXTVNT4_Msk
26344#define HRTIM_SET2R_EXTVNT5_Pos (25U)
26345#define HRTIM_SET2R_EXTVNT5_Msk (0x1UL << HRTIM_SET2R_EXTVNT5_Pos)
26346#define HRTIM_SET2R_EXTVNT5 HRTIM_SET2R_EXTVNT5_Msk
26347#define HRTIM_SET2R_EXTVNT6_Pos (26U)
26348#define HRTIM_SET2R_EXTVNT6_Msk (0x1UL << HRTIM_SET2R_EXTVNT6_Pos)
26349#define HRTIM_SET2R_EXTVNT6 HRTIM_SET2R_EXTVNT6_Msk
26350#define HRTIM_SET2R_EXTVNT7_Pos (27U)
26351#define HRTIM_SET2R_EXTVNT7_Msk (0x1UL << HRTIM_SET2R_EXTVNT7_Pos)
26352#define HRTIM_SET2R_EXTVNT7 HRTIM_SET2R_EXTVNT7_Msk
26353#define HRTIM_SET2R_EXTVNT8_Pos (28U)
26354#define HRTIM_SET2R_EXTVNT8_Msk (0x1UL << HRTIM_SET2R_EXTVNT8_Pos)
26355#define HRTIM_SET2R_EXTVNT8 HRTIM_SET2R_EXTVNT8_Msk
26356#define HRTIM_SET2R_EXTVNT9_Pos (29U)
26357#define HRTIM_SET2R_EXTVNT9_Msk (0x1UL << HRTIM_SET2R_EXTVNT9_Pos)
26358#define HRTIM_SET2R_EXTVNT9 HRTIM_SET2R_EXTVNT9_Msk
26359#define HRTIM_SET2R_EXTVNT10_Pos (30U)
26360#define HRTIM_SET2R_EXTVNT10_Msk (0x1UL << HRTIM_SET2R_EXTVNT10_Pos)
26361#define HRTIM_SET2R_EXTVNT10 HRTIM_SET2R_EXTVNT10_Msk
26363#define HRTIM_SET2R_UPDATE_Pos (31U)
26364#define HRTIM_SET2R_UPDATE_Msk (0x1UL << HRTIM_SET2R_UPDATE_Pos)
26365#define HRTIM_SET2R_UPDATE HRTIM_SET2R_UPDATE_Msk
26367/**** Bit definition for Slave Output 2 reset register ************************/
26368#define HRTIM_RST2R_SRT_Pos (0U)
26369#define HRTIM_RST2R_SRT_Msk (0x1UL << HRTIM_RST2R_SRT_Pos)
26370#define HRTIM_RST2R_SRT HRTIM_RST2R_SRT_Msk
26371#define HRTIM_RST2R_RESYNC_Pos (1U)
26372#define HRTIM_RST2R_RESYNC_Msk (0x1UL << HRTIM_RST2R_RESYNC_Pos)
26373#define HRTIM_RST2R_RESYNC HRTIM_RST2R_RESYNC_Msk
26374#define HRTIM_RST2R_PER_Pos (2U)
26375#define HRTIM_RST2R_PER_Msk (0x1UL << HRTIM_RST2R_PER_Pos)
26376#define HRTIM_RST2R_PER HRTIM_RST2R_PER_Msk
26377#define HRTIM_RST2R_CMP1_Pos (3U)
26378#define HRTIM_RST2R_CMP1_Msk (0x1UL << HRTIM_RST2R_CMP1_Pos)
26379#define HRTIM_RST2R_CMP1 HRTIM_RST2R_CMP1_Msk
26380#define HRTIM_RST2R_CMP2_Pos (4U)
26381#define HRTIM_RST2R_CMP2_Msk (0x1UL << HRTIM_RST2R_CMP2_Pos)
26382#define HRTIM_RST2R_CMP2 HRTIM_RST2R_CMP2_Msk
26383#define HRTIM_RST2R_CMP3_Pos (5U)
26384#define HRTIM_RST2R_CMP3_Msk (0x1UL << HRTIM_RST2R_CMP3_Pos)
26385#define HRTIM_RST2R_CMP3 HRTIM_RST2R_CMP3_Msk
26386#define HRTIM_RST2R_CMP4_Pos (6U)
26387#define HRTIM_RST2R_CMP4_Msk (0x1UL << HRTIM_RST2R_CMP4_Pos)
26388#define HRTIM_RST2R_CMP4 HRTIM_RST2R_CMP4_Msk
26390#define HRTIM_RST2R_MSTPER_Pos (7U)
26391#define HRTIM_RST2R_MSTPER_Msk (0x1UL << HRTIM_RST2R_MSTPER_Pos)
26392#define HRTIM_RST2R_MSTPER HRTIM_RST2R_MSTPER_Msk
26393#define HRTIM_RST2R_MSTCMP1_Pos (8U)
26394#define HRTIM_RST2R_MSTCMP1_Msk (0x1UL << HRTIM_RST2R_MSTCMP1_Pos)
26395#define HRTIM_RST2R_MSTCMP1 HRTIM_RST2R_MSTCMP1_Msk
26396#define HRTIM_RST2R_MSTCMP2_Pos (9U)
26397#define HRTIM_RST2R_MSTCMP2_Msk (0x1UL << HRTIM_RST2R_MSTCMP2_Pos)
26398#define HRTIM_RST2R_MSTCMP2 HRTIM_RST2R_MSTCMP2_Msk
26399#define HRTIM_RST2R_MSTCMP3_Pos (10U)
26400#define HRTIM_RST2R_MSTCMP3_Msk (0x1UL << HRTIM_RST2R_MSTCMP3_Pos)
26401#define HRTIM_RST2R_MSTCMP3 HRTIM_RST2R_MSTCMP3_Msk
26402#define HRTIM_RST2R_MSTCMP4_Pos (11U)
26403#define HRTIM_RST2R_MSTCMP4_Msk (0x1UL << HRTIM_RST2R_MSTCMP4_Pos)
26404#define HRTIM_RST2R_MSTCMP4 HRTIM_RST2R_MSTCMP4_Msk
26406#define HRTIM_RST2R_TIMEVNT1_Pos (12U)
26407#define HRTIM_RST2R_TIMEVNT1_Msk (0x1UL << HRTIM_RST2R_TIMEVNT1_Pos)
26408#define HRTIM_RST2R_TIMEVNT1 HRTIM_RST2R_TIMEVNT1_Msk
26409#define HRTIM_RST2R_TIMEVNT2_Pos (13U)
26410#define HRTIM_RST2R_TIMEVNT2_Msk (0x1UL << HRTIM_RST2R_TIMEVNT2_Pos)
26411#define HRTIM_RST2R_TIMEVNT2 HRTIM_RST2R_TIMEVNT2_Msk
26412#define HRTIM_RST2R_TIMEVNT3_Pos (14U)
26413#define HRTIM_RST2R_TIMEVNT3_Msk (0x1UL << HRTIM_RST2R_TIMEVNT3_Pos)
26414#define HRTIM_RST2R_TIMEVNT3 HRTIM_RST2R_TIMEVNT3_Msk
26415#define HRTIM_RST2R_TIMEVNT4_Pos (15U)
26416#define HRTIM_RST2R_TIMEVNT4_Msk (0x1UL << HRTIM_RST2R_TIMEVNT4_Pos)
26417#define HRTIM_RST2R_TIMEVNT4 HRTIM_RST2R_TIMEVNT4_Msk
26418#define HRTIM_RST2R_TIMEVNT5_Pos (16U)
26419#define HRTIM_RST2R_TIMEVNT5_Msk (0x1UL << HRTIM_RST2R_TIMEVNT5_Pos)
26420#define HRTIM_RST2R_TIMEVNT5 HRTIM_RST2R_TIMEVNT5_Msk
26421#define HRTIM_RST2R_TIMEVNT6_Pos (17U)
26422#define HRTIM_RST2R_TIMEVNT6_Msk (0x1UL << HRTIM_RST2R_TIMEVNT6_Pos)
26423#define HRTIM_RST2R_TIMEVNT6 HRTIM_RST2R_TIMEVNT6_Msk
26424#define HRTIM_RST2R_TIMEVNT7_Pos (18U)
26425#define HRTIM_RST2R_TIMEVNT7_Msk (0x1UL << HRTIM_RST2R_TIMEVNT7_Pos)
26426#define HRTIM_RST2R_TIMEVNT7 HRTIM_RST2R_TIMEVNT7_Msk
26427#define HRTIM_RST2R_TIMEVNT8_Pos (19U)
26428#define HRTIM_RST2R_TIMEVNT8_Msk (0x1UL << HRTIM_RST2R_TIMEVNT8_Pos)
26429#define HRTIM_RST2R_TIMEVNT8 HRTIM_RST2R_TIMEVNT8_Msk
26430#define HRTIM_RST2R_TIMEVNT9_Pos (20U)
26431#define HRTIM_RST2R_TIMEVNT9_Msk (0x1UL << HRTIM_RST2R_TIMEVNT9_Pos)
26432#define HRTIM_RST2R_TIMEVNT9 HRTIM_RST2R_TIMEVNT9_Msk
26434#define HRTIM_RST2R_EXTVNT1_Pos (21U)
26435#define HRTIM_RST2R_EXTVNT1_Msk (0x1UL << HRTIM_RST2R_EXTVNT1_Pos)
26436#define HRTIM_RST2R_EXTVNT1 HRTIM_RST2R_EXTVNT1_Msk
26437#define HRTIM_RST2R_EXTVNT2_Pos (22U)
26438#define HRTIM_RST2R_EXTVNT2_Msk (0x1UL << HRTIM_RST2R_EXTVNT2_Pos)
26439#define HRTIM_RST2R_EXTVNT2 HRTIM_RST2R_EXTVNT2_Msk
26440#define HRTIM_RST2R_EXTVNT3_Pos (23U)
26441#define HRTIM_RST2R_EXTVNT3_Msk (0x1UL << HRTIM_RST2R_EXTVNT3_Pos)
26442#define HRTIM_RST2R_EXTVNT3 HRTIM_RST2R_EXTVNT3_Msk
26443#define HRTIM_RST2R_EXTVNT4_Pos (24U)
26444#define HRTIM_RST2R_EXTVNT4_Msk (0x1UL << HRTIM_RST2R_EXTVNT4_Pos)
26445#define HRTIM_RST2R_EXTVNT4 HRTIM_RST2R_EXTVNT4_Msk
26446#define HRTIM_RST2R_EXTVNT5_Pos (25U)
26447#define HRTIM_RST2R_EXTVNT5_Msk (0x1UL << HRTIM_RST2R_EXTVNT5_Pos)
26448#define HRTIM_RST2R_EXTVNT5 HRTIM_RST2R_EXTVNT5_Msk
26449#define HRTIM_RST2R_EXTVNT6_Pos (26U)
26450#define HRTIM_RST2R_EXTVNT6_Msk (0x1UL << HRTIM_RST2R_EXTVNT6_Pos)
26451#define HRTIM_RST2R_EXTVNT6 HRTIM_RST2R_EXTVNT6_Msk
26452#define HRTIM_RST2R_EXTVNT7_Pos (27U)
26453#define HRTIM_RST2R_EXTVNT7_Msk (0x1UL << HRTIM_RST2R_EXTVNT7_Pos)
26454#define HRTIM_RST2R_EXTVNT7 HRTIM_RST2R_EXTVNT7_Msk
26455#define HRTIM_RST2R_EXTVNT8_Pos (28U)
26456#define HRTIM_RST2R_EXTVNT8_Msk (0x1UL << HRTIM_RST2R_EXTVNT8_Pos)
26457#define HRTIM_RST2R_EXTVNT8 HRTIM_RST2R_EXTVNT8_Msk
26458#define HRTIM_RST2R_EXTVNT9_Pos (29U)
26459#define HRTIM_RST2R_EXTVNT9_Msk (0x1UL << HRTIM_RST2R_EXTVNT9_Pos)
26460#define HRTIM_RST2R_EXTVNT9 HRTIM_RST2R_EXTVNT9_Msk
26461#define HRTIM_RST2R_EXTVNT10_Pos (30U)
26462#define HRTIM_RST2R_EXTVNT10_Msk (0x1UL << HRTIM_RST2R_EXTVNT10_Pos)
26463#define HRTIM_RST2R_EXTVNT10 HRTIM_RST2R_EXTVNT10_Msk
26465#define HRTIM_RST2R_UPDATE_Pos (31U)
26466#define HRTIM_RST2R_UPDATE_Msk (0x1UL << HRTIM_RST2R_UPDATE_Pos)
26467#define HRTIM_RST2R_UPDATE HRTIM_RST2R_UPDATE_Msk
26469/**** Bit definition for Slave external event filtering register 1 ***********/
26470#define HRTIM_EEFR1_EE1LTCH_Pos (0U)
26471#define HRTIM_EEFR1_EE1LTCH_Msk (0x1UL << HRTIM_EEFR1_EE1LTCH_Pos)
26472#define HRTIM_EEFR1_EE1LTCH HRTIM_EEFR1_EE1LTCH_Msk
26473#define HRTIM_EEFR1_EE1FLTR_Pos (1U)
26474#define HRTIM_EEFR1_EE1FLTR_Msk (0xFUL << HRTIM_EEFR1_EE1FLTR_Pos)
26475#define HRTIM_EEFR1_EE1FLTR HRTIM_EEFR1_EE1FLTR_Msk
26476#define HRTIM_EEFR1_EE1FLTR_0 (0x1UL << HRTIM_EEFR1_EE1FLTR_Pos)
26477#define HRTIM_EEFR1_EE1FLTR_1 (0x2UL << HRTIM_EEFR1_EE1FLTR_Pos)
26478#define HRTIM_EEFR1_EE1FLTR_2 (0x4UL << HRTIM_EEFR1_EE1FLTR_Pos)
26479#define HRTIM_EEFR1_EE1FLTR_3 (0x8UL << HRTIM_EEFR1_EE1FLTR_Pos)
26481#define HRTIM_EEFR1_EE2LTCH_Pos (6U)
26482#define HRTIM_EEFR1_EE2LTCH_Msk (0x1UL << HRTIM_EEFR1_EE2LTCH_Pos)
26483#define HRTIM_EEFR1_EE2LTCH HRTIM_EEFR1_EE2LTCH_Msk
26484#define HRTIM_EEFR1_EE2FLTR_Pos (7U)
26485#define HRTIM_EEFR1_EE2FLTR_Msk (0xFUL << HRTIM_EEFR1_EE2FLTR_Pos)
26486#define HRTIM_EEFR1_EE2FLTR HRTIM_EEFR1_EE2FLTR_Msk
26487#define HRTIM_EEFR1_EE2FLTR_0 (0x1UL << HRTIM_EEFR1_EE2FLTR_Pos)
26488#define HRTIM_EEFR1_EE2FLTR_1 (0x2UL << HRTIM_EEFR1_EE2FLTR_Pos)
26489#define HRTIM_EEFR1_EE2FLTR_2 (0x4UL << HRTIM_EEFR1_EE2FLTR_Pos)
26490#define HRTIM_EEFR1_EE2FLTR_3 (0x8UL << HRTIM_EEFR1_EE2FLTR_Pos)
26492#define HRTIM_EEFR1_EE3LTCH_Pos (12U)
26493#define HRTIM_EEFR1_EE3LTCH_Msk (0x1UL << HRTIM_EEFR1_EE3LTCH_Pos)
26494#define HRTIM_EEFR1_EE3LTCH HRTIM_EEFR1_EE3LTCH_Msk
26495#define HRTIM_EEFR1_EE3FLTR_Pos (13U)
26496#define HRTIM_EEFR1_EE3FLTR_Msk (0xFUL << HRTIM_EEFR1_EE3FLTR_Pos)
26497#define HRTIM_EEFR1_EE3FLTR HRTIM_EEFR1_EE3FLTR_Msk
26498#define HRTIM_EEFR1_EE3FLTR_0 (0x1UL << HRTIM_EEFR1_EE3FLTR_Pos)
26499#define HRTIM_EEFR1_EE3FLTR_1 (0x2UL << HRTIM_EEFR1_EE3FLTR_Pos)
26500#define HRTIM_EEFR1_EE3FLTR_2 (0x4UL << HRTIM_EEFR1_EE3FLTR_Pos)
26501#define HRTIM_EEFR1_EE3FLTR_3 (0x8UL << HRTIM_EEFR1_EE3FLTR_Pos)
26503#define HRTIM_EEFR1_EE4LTCH_Pos (18U)
26504#define HRTIM_EEFR1_EE4LTCH_Msk (0x1UL << HRTIM_EEFR1_EE4LTCH_Pos)
26505#define HRTIM_EEFR1_EE4LTCH HRTIM_EEFR1_EE4LTCH_Msk
26506#define HRTIM_EEFR1_EE4FLTR_Pos (19U)
26507#define HRTIM_EEFR1_EE4FLTR_Msk (0xFUL << HRTIM_EEFR1_EE4FLTR_Pos)
26508#define HRTIM_EEFR1_EE4FLTR HRTIM_EEFR1_EE4FLTR_Msk
26509#define HRTIM_EEFR1_EE4FLTR_0 (0x1UL << HRTIM_EEFR1_EE4FLTR_Pos)
26510#define HRTIM_EEFR1_EE4FLTR_1 (0x2UL << HRTIM_EEFR1_EE4FLTR_Pos)
26511#define HRTIM_EEFR1_EE4FLTR_2 (0x4UL << HRTIM_EEFR1_EE4FLTR_Pos)
26512#define HRTIM_EEFR1_EE4FLTR_3 (0x8UL << HRTIM_EEFR1_EE4FLTR_Pos)
26514#define HRTIM_EEFR1_EE5LTCH_Pos (24U)
26515#define HRTIM_EEFR1_EE5LTCH_Msk (0x1UL << HRTIM_EEFR1_EE5LTCH_Pos)
26516#define HRTIM_EEFR1_EE5LTCH HRTIM_EEFR1_EE5LTCH_Msk
26517#define HRTIM_EEFR1_EE5FLTR_Pos (25U)
26518#define HRTIM_EEFR1_EE5FLTR_Msk (0xFUL << HRTIM_EEFR1_EE5FLTR_Pos)
26519#define HRTIM_EEFR1_EE5FLTR HRTIM_EEFR1_EE5FLTR_Msk
26520#define HRTIM_EEFR1_EE5FLTR_0 (0x1UL << HRTIM_EEFR1_EE5FLTR_Pos)
26521#define HRTIM_EEFR1_EE5FLTR_1 (0x2UL << HRTIM_EEFR1_EE5FLTR_Pos)
26522#define HRTIM_EEFR1_EE5FLTR_2 (0x4UL << HRTIM_EEFR1_EE5FLTR_Pos)
26523#define HRTIM_EEFR1_EE5FLTR_3 (0x8UL << HRTIM_EEFR1_EE5FLTR_Pos)
26525/**** Bit definition for Slave external event filtering register 2 ***********/
26526#define HRTIM_EEFR2_EE6LTCH_Pos (0U)
26527#define HRTIM_EEFR2_EE6LTCH_Msk (0x1UL << HRTIM_EEFR2_EE6LTCH_Pos)
26528#define HRTIM_EEFR2_EE6LTCH HRTIM_EEFR2_EE6LTCH_Msk
26529#define HRTIM_EEFR2_EE6FLTR_Pos (1U)
26530#define HRTIM_EEFR2_EE6FLTR_Msk (0xFUL << HRTIM_EEFR2_EE6FLTR_Pos)
26531#define HRTIM_EEFR2_EE6FLTR HRTIM_EEFR2_EE6FLTR_Msk
26532#define HRTIM_EEFR2_EE6FLTR_0 (0x1UL << HRTIM_EEFR2_EE6FLTR_Pos)
26533#define HRTIM_EEFR2_EE6FLTR_1 (0x2UL << HRTIM_EEFR2_EE6FLTR_Pos)
26534#define HRTIM_EEFR2_EE6FLTR_2 (0x4UL << HRTIM_EEFR2_EE6FLTR_Pos)
26535#define HRTIM_EEFR2_EE6FLTR_3 (0x8UL << HRTIM_EEFR2_EE6FLTR_Pos)
26537#define HRTIM_EEFR2_EE7LTCH_Pos (6U)
26538#define HRTIM_EEFR2_EE7LTCH_Msk (0x1UL << HRTIM_EEFR2_EE7LTCH_Pos)
26539#define HRTIM_EEFR2_EE7LTCH HRTIM_EEFR2_EE7LTCH_Msk
26540#define HRTIM_EEFR2_EE7FLTR_Pos (7U)
26541#define HRTIM_EEFR2_EE7FLTR_Msk (0xFUL << HRTIM_EEFR2_EE7FLTR_Pos)
26542#define HRTIM_EEFR2_EE7FLTR HRTIM_EEFR2_EE7FLTR_Msk
26543#define HRTIM_EEFR2_EE7FLTR_0 (0x1UL << HRTIM_EEFR2_EE7FLTR_Pos)
26544#define HRTIM_EEFR2_EE7FLTR_1 (0x2UL << HRTIM_EEFR2_EE7FLTR_Pos)
26545#define HRTIM_EEFR2_EE7FLTR_2 (0x4UL << HRTIM_EEFR2_EE7FLTR_Pos)
26546#define HRTIM_EEFR2_EE7FLTR_3 (0x8UL << HRTIM_EEFR2_EE7FLTR_Pos)
26548#define HRTIM_EEFR2_EE8LTCH_Pos (12U)
26549#define HRTIM_EEFR2_EE8LTCH_Msk (0x1UL << HRTIM_EEFR2_EE8LTCH_Pos)
26550#define HRTIM_EEFR2_EE8LTCH HRTIM_EEFR2_EE8LTCH_Msk
26551#define HRTIM_EEFR2_EE8FLTR_Pos (13U)
26552#define HRTIM_EEFR2_EE8FLTR_Msk (0xFUL << HRTIM_EEFR2_EE8FLTR_Pos)
26553#define HRTIM_EEFR2_EE8FLTR HRTIM_EEFR2_EE8FLTR_Msk
26554#define HRTIM_EEFR2_EE8FLTR_0 (0x1UL << HRTIM_EEFR2_EE8FLTR_Pos)
26555#define HRTIM_EEFR2_EE8FLTR_1 (0x2UL << HRTIM_EEFR2_EE8FLTR_Pos)
26556#define HRTIM_EEFR2_EE8FLTR_2 (0x4UL << HRTIM_EEFR2_EE8FLTR_Pos)
26557#define HRTIM_EEFR2_EE8FLTR_3 (0x8UL << HRTIM_EEFR2_EE8FLTR_Pos)
26559#define HRTIM_EEFR2_EE9LTCH_Pos (18U)
26560#define HRTIM_EEFR2_EE9LTCH_Msk (0x1UL << HRTIM_EEFR2_EE9LTCH_Pos)
26561#define HRTIM_EEFR2_EE9LTCH HRTIM_EEFR2_EE9LTCH_Msk
26562#define HRTIM_EEFR2_EE9FLTR_Pos (19U)
26563#define HRTIM_EEFR2_EE9FLTR_Msk (0xFUL << HRTIM_EEFR2_EE9FLTR_Pos)
26564#define HRTIM_EEFR2_EE9FLTR HRTIM_EEFR2_EE9FLTR_Msk
26565#define HRTIM_EEFR2_EE9FLTR_0 (0x1UL << HRTIM_EEFR2_EE9FLTR_Pos)
26566#define HRTIM_EEFR2_EE9FLTR_1 (0x2UL << HRTIM_EEFR2_EE9FLTR_Pos)
26567#define HRTIM_EEFR2_EE9FLTR_2 (0x4UL << HRTIM_EEFR2_EE9FLTR_Pos)
26568#define HRTIM_EEFR2_EE9FLTR_3 (0x8UL << HRTIM_EEFR2_EE9FLTR_Pos)
26570#define HRTIM_EEFR2_EE10LTCH_Pos (24U)
26571#define HRTIM_EEFR2_EE10LTCH_Msk (0x1UL << HRTIM_EEFR2_EE10LTCH_Pos)
26572#define HRTIM_EEFR2_EE10LTCH HRTIM_EEFR2_EE10LTCH_Msk
26573#define HRTIM_EEFR2_EE10FLTR_Pos (25U)
26574#define HRTIM_EEFR2_EE10FLTR_Msk (0xFUL << HRTIM_EEFR2_EE10FLTR_Pos)
26575#define HRTIM_EEFR2_EE10FLTR HRTIM_EEFR2_EE10FLTR_Msk
26576#define HRTIM_EEFR2_EE10FLTR_0 (0x1UL << HRTIM_EEFR2_EE10FLTR_Pos)
26577#define HRTIM_EEFR2_EE10FLTR_1 (0x2UL << HRTIM_EEFR2_EE10FLTR_Pos)
26578#define HRTIM_EEFR2_EE10FLTR_2 (0x4UL << HRTIM_EEFR2_EE10FLTR_Pos)
26579#define HRTIM_EEFR2_EE10FLTR_3 (0x8UL << HRTIM_EEFR2_EE10FLTR_Pos)
26581/**** Bit definition for Slave Timer reset register ***************************/
26582#define HRTIM_RSTR_UPDATE_Pos (1U)
26583#define HRTIM_RSTR_UPDATE_Msk (0x1UL << HRTIM_RSTR_UPDATE_Pos)
26584#define HRTIM_RSTR_UPDATE HRTIM_RSTR_UPDATE_Msk
26585#define HRTIM_RSTR_CMP2_Pos (2U)
26586#define HRTIM_RSTR_CMP2_Msk (0x1UL << HRTIM_RSTR_CMP2_Pos)
26587#define HRTIM_RSTR_CMP2 HRTIM_RSTR_CMP2_Msk
26588#define HRTIM_RSTR_CMP4_Pos (3U)
26589#define HRTIM_RSTR_CMP4_Msk (0x1UL << HRTIM_RSTR_CMP4_Pos)
26590#define HRTIM_RSTR_CMP4 HRTIM_RSTR_CMP4_Msk
26592#define HRTIM_RSTR_MSTPER_Pos (4U)
26593#define HRTIM_RSTR_MSTPER_Msk (0x1UL << HRTIM_RSTR_MSTPER_Pos)
26594#define HRTIM_RSTR_MSTPER HRTIM_RSTR_MSTPER_Msk
26595#define HRTIM_RSTR_MSTCMP1_Pos (5U)
26596#define HRTIM_RSTR_MSTCMP1_Msk (0x1UL << HRTIM_RSTR_MSTCMP1_Pos)
26597#define HRTIM_RSTR_MSTCMP1 HRTIM_RSTR_MSTCMP1_Msk
26598#define HRTIM_RSTR_MSTCMP2_Pos (6U)
26599#define HRTIM_RSTR_MSTCMP2_Msk (0x1UL << HRTIM_RSTR_MSTCMP2_Pos)
26600#define HRTIM_RSTR_MSTCMP2 HRTIM_RSTR_MSTCMP2_Msk
26601#define HRTIM_RSTR_MSTCMP3_Pos (7U)
26602#define HRTIM_RSTR_MSTCMP3_Msk (0x1UL << HRTIM_RSTR_MSTCMP3_Pos)
26603#define HRTIM_RSTR_MSTCMP3 HRTIM_RSTR_MSTCMP3_Msk
26604#define HRTIM_RSTR_MSTCMP4_Pos (8U)
26605#define HRTIM_RSTR_MSTCMP4_Msk (0x1UL << HRTIM_RSTR_MSTCMP4_Pos)
26606#define HRTIM_RSTR_MSTCMP4 HRTIM_RSTR_MSTCMP4_Msk
26608#define HRTIM_RSTR_EXTEVNT1_Pos (9U)
26609#define HRTIM_RSTR_EXTEVNT1_Msk (0x1UL << HRTIM_RSTR_EXTEVNT1_Pos)
26610#define HRTIM_RSTR_EXTEVNT1 HRTIM_RSTR_EXTEVNT1_Msk
26611#define HRTIM_RSTR_EXTEVNT2_Pos (10U)
26612#define HRTIM_RSTR_EXTEVNT2_Msk (0x1UL << HRTIM_RSTR_EXTEVNT2_Pos)
26613#define HRTIM_RSTR_EXTEVNT2 HRTIM_RSTR_EXTEVNT2_Msk
26614#define HRTIM_RSTR_EXTEVNT3_Pos (11U)
26615#define HRTIM_RSTR_EXTEVNT3_Msk (0x1UL << HRTIM_RSTR_EXTEVNT3_Pos)
26616#define HRTIM_RSTR_EXTEVNT3 HRTIM_RSTR_EXTEVNT3_Msk
26617#define HRTIM_RSTR_EXTEVNT4_Pos (12U)
26618#define HRTIM_RSTR_EXTEVNT4_Msk (0x1UL << HRTIM_RSTR_EXTEVNT4_Pos)
26619#define HRTIM_RSTR_EXTEVNT4 HRTIM_RSTR_EXTEVNT4_Msk
26620#define HRTIM_RSTR_EXTEVNT5_Pos (13U)
26621#define HRTIM_RSTR_EXTEVNT5_Msk (0x1UL << HRTIM_RSTR_EXTEVNT5_Pos)
26622#define HRTIM_RSTR_EXTEVNT5 HRTIM_RSTR_EXTEVNT5_Msk
26623#define HRTIM_RSTR_EXTEVNT6_Pos (14U)
26624#define HRTIM_RSTR_EXTEVNT6_Msk (0x1UL << HRTIM_RSTR_EXTEVNT6_Pos)
26625#define HRTIM_RSTR_EXTEVNT6 HRTIM_RSTR_EXTEVNT6_Msk
26626#define HRTIM_RSTR_EXTEVNT7_Pos (15U)
26627#define HRTIM_RSTR_EXTEVNT7_Msk (0x1UL << HRTIM_RSTR_EXTEVNT7_Pos)
26628#define HRTIM_RSTR_EXTEVNT7 HRTIM_RSTR_EXTEVNT7_Msk
26629#define HRTIM_RSTR_EXTEVNT8_Pos (16U)
26630#define HRTIM_RSTR_EXTEVNT8_Msk (0x1UL << HRTIM_RSTR_EXTEVNT8_Pos)
26631#define HRTIM_RSTR_EXTEVNT8 HRTIM_RSTR_EXTEVNT8_Msk
26632#define HRTIM_RSTR_EXTEVNT9_Pos (17U)
26633#define HRTIM_RSTR_EXTEVNT9_Msk (0x1UL << HRTIM_RSTR_EXTEVNT9_Pos)
26634#define HRTIM_RSTR_EXTEVNT9 HRTIM_RSTR_EXTEVNT9_Msk
26635#define HRTIM_RSTR_EXTEVNT10_Pos (18U)
26636#define HRTIM_RSTR_EXTEVNT10_Msk (0x1UL << HRTIM_RSTR_EXTEVNT10_Pos)
26637#define HRTIM_RSTR_EXTEVNT10 HRTIM_RSTR_EXTEVNT10_Msk
26639/* Slave Timer A reset enable bits upon other slave timers events */
26640#define HRTIM_RSTR_TIMBCMP1_Pos (19U)
26641#define HRTIM_RSTR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTR_TIMBCMP1_Pos)
26642#define HRTIM_RSTR_TIMBCMP1 HRTIM_RSTR_TIMBCMP1_Msk
26643#define HRTIM_RSTR_TIMBCMP2_Pos (20U)
26644#define HRTIM_RSTR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTR_TIMBCMP2_Pos)
26645#define HRTIM_RSTR_TIMBCMP2 HRTIM_RSTR_TIMBCMP2_Msk
26646#define HRTIM_RSTR_TIMBCMP4_Pos (21U)
26647#define HRTIM_RSTR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTR_TIMBCMP4_Pos)
26648#define HRTIM_RSTR_TIMBCMP4 HRTIM_RSTR_TIMBCMP4_Msk
26650#define HRTIM_RSTR_TIMCCMP1_Pos (22U)
26651#define HRTIM_RSTR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTR_TIMCCMP1_Pos)
26652#define HRTIM_RSTR_TIMCCMP1 HRTIM_RSTR_TIMCCMP1_Msk
26653#define HRTIM_RSTR_TIMCCMP2_Pos (23U)
26654#define HRTIM_RSTR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTR_TIMCCMP2_Pos)
26655#define HRTIM_RSTR_TIMCCMP2 HRTIM_RSTR_TIMCCMP2_Msk
26656#define HRTIM_RSTR_TIMCCMP4_Pos (24U)
26657#define HRTIM_RSTR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTR_TIMCCMP4_Pos)
26658#define HRTIM_RSTR_TIMCCMP4 HRTIM_RSTR_TIMCCMP4_Msk
26660#define HRTIM_RSTR_TIMDCMP1_Pos (25U)
26661#define HRTIM_RSTR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTR_TIMDCMP1_Pos)
26662#define HRTIM_RSTR_TIMDCMP1 HRTIM_RSTR_TIMDCMP1_Msk
26663#define HRTIM_RSTR_TIMDCMP2_Pos (26U)
26664#define HRTIM_RSTR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTR_TIMDCMP2_Pos)
26665#define HRTIM_RSTR_TIMDCMP2 HRTIM_RSTR_TIMDCMP2_Msk
26666#define HRTIM_RSTR_TIMDCMP4_Pos (27U)
26667#define HRTIM_RSTR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTR_TIMDCMP4_Pos)
26668#define HRTIM_RSTR_TIMDCMP4 HRTIM_RSTR_TIMDCMP4_Msk
26670#define HRTIM_RSTR_TIMECMP1_Pos (28U)
26671#define HRTIM_RSTR_TIMECMP1_Msk (0x1UL << HRTIM_RSTR_TIMECMP1_Pos)
26672#define HRTIM_RSTR_TIMECMP1 HRTIM_RSTR_TIMECMP1_Msk
26673#define HRTIM_RSTR_TIMECMP2_Pos (29U)
26674#define HRTIM_RSTR_TIMECMP2_Msk (0x1UL << HRTIM_RSTR_TIMECMP2_Pos)
26675#define HRTIM_RSTR_TIMECMP2 HRTIM_RSTR_TIMECMP2_Msk
26676#define HRTIM_RSTR_TIMECMP4_Pos (30U)
26677#define HRTIM_RSTR_TIMECMP4_Msk (0x1UL << HRTIM_RSTR_TIMECMP4_Pos)
26678#define HRTIM_RSTR_TIMECMP4 HRTIM_RSTR_TIMECMP4_Msk
26680/* Slave Timer B reset enable bits upon other slave timers events */
26681#define HRTIM_RSTBR_TIMACMP1_Pos (19U)
26682#define HRTIM_RSTBR_TIMACMP1_Msk (0x1UL << HRTIM_RSTBR_TIMACMP1_Pos)
26683#define HRTIM_RSTBR_TIMACMP1 HRTIM_RSTBR_TIMACMP1_Msk
26684#define HRTIM_RSTBR_TIMACMP2_Pos (20U)
26685#define HRTIM_RSTBR_TIMACMP2_Msk (0x1UL << HRTIM_RSTBR_TIMACMP2_Pos)
26686#define HRTIM_RSTBR_TIMACMP2 HRTIM_RSTBR_TIMACMP2_Msk
26687#define HRTIM_RSTBR_TIMACMP4_Pos (21U)
26688#define HRTIM_RSTBR_TIMACMP4_Msk (0x1UL << HRTIM_RSTBR_TIMACMP4_Pos)
26689#define HRTIM_RSTBR_TIMACMP4 HRTIM_RSTBR_TIMACMP4_Msk
26691#define HRTIM_RSTBR_TIMCCMP1_Pos (22U)
26692#define HRTIM_RSTBR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP1_Pos)
26693#define HRTIM_RSTBR_TIMCCMP1 HRTIM_RSTBR_TIMCCMP1_Msk
26694#define HRTIM_RSTBR_TIMCCMP2_Pos (23U)
26695#define HRTIM_RSTBR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP2_Pos)
26696#define HRTIM_RSTBR_TIMCCMP2 HRTIM_RSTBR_TIMCCMP2_Msk
26697#define HRTIM_RSTBR_TIMCCMP4_Pos (24U)
26698#define HRTIM_RSTBR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP4_Pos)
26699#define HRTIM_RSTBR_TIMCCMP4 HRTIM_RSTBR_TIMCCMP4_Msk
26701#define HRTIM_RSTBR_TIMDCMP1_Pos (25U)
26702#define HRTIM_RSTBR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP1_Pos)
26703#define HRTIM_RSTBR_TIMDCMP1 HRTIM_RSTBR_TIMDCMP1_Msk
26704#define HRTIM_RSTBR_TIMDCMP2_Pos (26U)
26705#define HRTIM_RSTBR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP2_Pos)
26706#define HRTIM_RSTBR_TIMDCMP2 HRTIM_RSTBR_TIMDCMP2_Msk
26707#define HRTIM_RSTBR_TIMDCMP4_Pos (27U)
26708#define HRTIM_RSTBR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP4_Pos)
26709#define HRTIM_RSTBR_TIMDCMP4 HRTIM_RSTBR_TIMDCMP4_Msk
26711#define HRTIM_RSTBR_TIMECMP1_Pos (28U)
26712#define HRTIM_RSTBR_TIMECMP1_Msk (0x1UL << HRTIM_RSTBR_TIMECMP1_Pos)
26713#define HRTIM_RSTBR_TIMECMP1 HRTIM_RSTBR_TIMECMP1_Msk
26714#define HRTIM_RSTBR_TIMECMP2_Pos (29U)
26715#define HRTIM_RSTBR_TIMECMP2_Msk (0x1UL << HRTIM_RSTBR_TIMECMP2_Pos)
26716#define HRTIM_RSTBR_TIMECMP2 HRTIM_RSTBR_TIMECMP2_Msk
26717#define HRTIM_RSTBR_TIMECMP4_Pos (30U)
26718#define HRTIM_RSTBR_TIMECMP4_Msk (0x1UL << HRTIM_RSTBR_TIMECMP4_Pos)
26719#define HRTIM_RSTBR_TIMECMP4 HRTIM_RSTBR_TIMECMP4_Msk
26721/* Slave Timer C reset enable bits upon other slave timers events */
26722#define HRTIM_RSTCR_TIMACMP1_Pos (19U)
26723#define HRTIM_RSTCR_TIMACMP1_Msk (0x1UL << HRTIM_RSTCR_TIMACMP1_Pos)
26724#define HRTIM_RSTCR_TIMACMP1 HRTIM_RSTCR_TIMACMP1_Msk
26725#define HRTIM_RSTCR_TIMACMP2_Pos (20U)
26726#define HRTIM_RSTCR_TIMACMP2_Msk (0x1UL << HRTIM_RSTCR_TIMACMP2_Pos)
26727#define HRTIM_RSTCR_TIMACMP2 HRTIM_RSTCR_TIMACMP2_Msk
26728#define HRTIM_RSTCR_TIMACMP4_Pos (21U)
26729#define HRTIM_RSTCR_TIMACMP4_Msk (0x1UL << HRTIM_RSTCR_TIMACMP4_Pos)
26730#define HRTIM_RSTCR_TIMACMP4 HRTIM_RSTCR_TIMACMP4_Msk
26732#define HRTIM_RSTCR_TIMBCMP1_Pos (22U)
26733#define HRTIM_RSTCR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP1_Pos)
26734#define HRTIM_RSTCR_TIMBCMP1 HRTIM_RSTCR_TIMBCMP1_Msk
26735#define HRTIM_RSTCR_TIMBCMP2_Pos (23U)
26736#define HRTIM_RSTCR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP2_Pos)
26737#define HRTIM_RSTCR_TIMBCMP2 HRTIM_RSTCR_TIMBCMP2_Msk
26738#define HRTIM_RSTCR_TIMBCMP4_Pos (24U)
26739#define HRTIM_RSTCR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP4_Pos)
26740#define HRTIM_RSTCR_TIMBCMP4 HRTIM_RSTCR_TIMBCMP4_Msk
26742#define HRTIM_RSTCR_TIMDCMP1_Pos (25U)
26743#define HRTIM_RSTCR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP1_Pos)
26744#define HRTIM_RSTCR_TIMDCMP1 HRTIM_RSTCR_TIMDCMP1_Msk
26745#define HRTIM_RSTCR_TIMDCMP2_Pos (26U)
26746#define HRTIM_RSTCR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP2_Pos)
26747#define HRTIM_RSTCR_TIMDCMP2 HRTIM_RSTCR_TIMDCMP2_Msk
26748#define HRTIM_RSTCR_TIMDCMP4_Pos (27U)
26749#define HRTIM_RSTCR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP4_Pos)
26750#define HRTIM_RSTCR_TIMDCMP4 HRTIM_RSTCR_TIMDCMP4_Msk
26752#define HRTIM_RSTCR_TIMECMP1_Pos (28U)
26753#define HRTIM_RSTCR_TIMECMP1_Msk (0x1UL << HRTIM_RSTCR_TIMECMP1_Pos)
26754#define HRTIM_RSTCR_TIMECMP1 HRTIM_RSTCR_TIMECMP1_Msk
26755#define HRTIM_RSTCR_TIMECMP2_Pos (29U)
26756#define HRTIM_RSTCR_TIMECMP2_Msk (0x1UL << HRTIM_RSTCR_TIMECMP2_Pos)
26757#define HRTIM_RSTCR_TIMECMP2 HRTIM_RSTCR_TIMECMP2_Msk
26758#define HRTIM_RSTCR_TIMECMP4_Pos (30U)
26759#define HRTIM_RSTCR_TIMECMP4_Msk (0x1UL << HRTIM_RSTCR_TIMECMP4_Pos)
26760#define HRTIM_RSTCR_TIMECMP4 HRTIM_RSTCR_TIMECMP4_Msk
26762/* Slave Timer D reset enable bits upon other slave timers events */
26763#define HRTIM_RSTDR_TIMACMP1_Pos (19U)
26764#define HRTIM_RSTDR_TIMACMP1_Msk (0x1UL << HRTIM_RSTDR_TIMACMP1_Pos)
26765#define HRTIM_RSTDR_TIMACMP1 HRTIM_RSTDR_TIMACMP1_Msk
26766#define HRTIM_RSTDR_TIMACMP2_Pos (20U)
26767#define HRTIM_RSTDR_TIMACMP2_Msk (0x1UL << HRTIM_RSTDR_TIMACMP2_Pos)
26768#define HRTIM_RSTDR_TIMACMP2 HRTIM_RSTDR_TIMACMP2_Msk
26769#define HRTIM_RSTDR_TIMACMP4_Pos (21U)
26770#define HRTIM_RSTDR_TIMACMP4_Msk (0x1UL << HRTIM_RSTDR_TIMACMP4_Pos)
26771#define HRTIM_RSTDR_TIMACMP4 HRTIM_RSTDR_TIMACMP4_Msk
26773#define HRTIM_RSTDR_TIMBCMP1_Pos (22U)
26774#define HRTIM_RSTDR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP1_Pos)
26775#define HRTIM_RSTDR_TIMBCMP1 HRTIM_RSTDR_TIMBCMP1_Msk
26776#define HRTIM_RSTDR_TIMBCMP2_Pos (23U)
26777#define HRTIM_RSTDR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP2_Pos)
26778#define HRTIM_RSTDR_TIMBCMP2 HRTIM_RSTDR_TIMBCMP2_Msk
26779#define HRTIM_RSTDR_TIMBCMP4_Pos (24U)
26780#define HRTIM_RSTDR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP4_Pos)
26781#define HRTIM_RSTDR_TIMBCMP4 HRTIM_RSTDR_TIMBCMP4_Msk
26783#define HRTIM_RSTDR_TIMCCMP1_Pos (25U)
26784#define HRTIM_RSTDR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP1_Pos)
26785#define HRTIM_RSTDR_TIMCCMP1 HRTIM_RSTDR_TIMCCMP1_Msk
26786#define HRTIM_RSTDR_TIMCCMP2_Pos (26U)
26787#define HRTIM_RSTDR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP2_Pos)
26788#define HRTIM_RSTDR_TIMCCMP2 HRTIM_RSTDR_TIMCCMP2_Msk
26789#define HRTIM_RSTDR_TIMCCMP4_Pos (27U)
26790#define HRTIM_RSTDR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP4_Pos)
26791#define HRTIM_RSTDR_TIMCCMP4 HRTIM_RSTDR_TIMCCMP4_Msk
26793#define HRTIM_RSTDR_TIMECMP1_Pos (28U)
26794#define HRTIM_RSTDR_TIMECMP1_Msk (0x1UL << HRTIM_RSTDR_TIMECMP1_Pos)
26795#define HRTIM_RSTDR_TIMECMP1 HRTIM_RSTDR_TIMECMP1_Msk
26796#define HRTIM_RSTDR_TIMECMP2_Pos (29U)
26797#define HRTIM_RSTDR_TIMECMP2_Msk (0x1UL << HRTIM_RSTDR_TIMECMP2_Pos)
26798#define HRTIM_RSTDR_TIMECMP2 HRTIM_RSTDR_TIMECMP2_Msk
26799#define HRTIM_RSTDR_TIMECMP4_Pos (30U)
26800#define HRTIM_RSTDR_TIMECMP4_Msk (0x1UL << HRTIM_RSTDR_TIMECMP4_Pos)
26801#define HRTIM_RSTDR_TIMECMP4 HRTIM_RSTDR_TIMECMP4_Msk
26803/* Slave Timer E reset enable bits upon other slave timers events */
26804#define HRTIM_RSTER_TIMACMP1_Pos (19U)
26805#define HRTIM_RSTER_TIMACMP1_Msk (0x1UL << HRTIM_RSTER_TIMACMP1_Pos)
26806#define HRTIM_RSTER_TIMACMP1 HRTIM_RSTER_TIMACMP1_Msk
26807#define HRTIM_RSTER_TIMACMP2_Pos (20U)
26808#define HRTIM_RSTER_TIMACMP2_Msk (0x1UL << HRTIM_RSTER_TIMACMP2_Pos)
26809#define HRTIM_RSTER_TIMACMP2 HRTIM_RSTER_TIMACMP2_Msk
26810#define HRTIM_RSTER_TIMACMP4_Pos (21U)
26811#define HRTIM_RSTER_TIMACMP4_Msk (0x1UL << HRTIM_RSTER_TIMACMP4_Pos)
26812#define HRTIM_RSTER_TIMACMP4 HRTIM_RSTER_TIMACMP4_Msk
26814#define HRTIM_RSTER_TIMBCMP1_Pos (22U)
26815#define HRTIM_RSTER_TIMBCMP1_Msk (0x1UL << HRTIM_RSTER_TIMBCMP1_Pos)
26816#define HRTIM_RSTER_TIMBCMP1 HRTIM_RSTER_TIMBCMP1_Msk
26817#define HRTIM_RSTER_TIMBCMP2_Pos (23U)
26818#define HRTIM_RSTER_TIMBCMP2_Msk (0x1UL << HRTIM_RSTER_TIMBCMP2_Pos)
26819#define HRTIM_RSTER_TIMBCMP2 HRTIM_RSTER_TIMBCMP2_Msk
26820#define HRTIM_RSTER_TIMBCMP4_Pos (24U)
26821#define HRTIM_RSTER_TIMBCMP4_Msk (0x1UL << HRTIM_RSTER_TIMBCMP4_Pos)
26822#define HRTIM_RSTER_TIMBCMP4 HRTIM_RSTER_TIMBCMP4_Msk
26824#define HRTIM_RSTER_TIMCCMP1_Pos (25U)
26825#define HRTIM_RSTER_TIMCCMP1_Msk (0x1UL << HRTIM_RSTER_TIMCCMP1_Pos)
26826#define HRTIM_RSTER_TIMCCMP1 HRTIM_RSTER_TIMCCMP1_Msk
26827#define HRTIM_RSTER_TIMCCMP2_Pos (26U)
26828#define HRTIM_RSTER_TIMCCMP2_Msk (0x1UL << HRTIM_RSTER_TIMCCMP2_Pos)
26829#define HRTIM_RSTER_TIMCCMP2 HRTIM_RSTER_TIMCCMP2_Msk
26830#define HRTIM_RSTER_TIMCCMP4_Pos (27U)
26831#define HRTIM_RSTER_TIMCCMP4_Msk (0x1UL << HRTIM_RSTER_TIMCCMP4_Pos)
26832#define HRTIM_RSTER_TIMCCMP4 HRTIM_RSTER_TIMCCMP4_Msk
26834#define HRTIM_RSTER_TIMDCMP1_Pos (28U)
26835#define HRTIM_RSTER_TIMDCMP1_Msk (0x1UL << HRTIM_RSTER_TIMDCMP1_Pos)
26836#define HRTIM_RSTER_TIMDCMP1 HRTIM_RSTER_TIMDCMP1_Msk
26837#define HRTIM_RSTER_TIMDCMP2_Pos (29U)
26838#define HRTIM_RSTER_TIMDCMP2_Msk (0x1UL << HRTIM_RSTER_TIMDCMP2_Pos)
26839#define HRTIM_RSTER_TIMDCMP2 HRTIM_RSTER_TIMDCMP2_Msk
26840#define HRTIM_RSTER_TIMDCMP4_Pos (30U)
26841#define HRTIM_RSTER_TIMDCMP4_Msk (0x1UL << HRTIM_RSTER_TIMDCMP4_Pos)
26842#define HRTIM_RSTER_TIMDCMP4 HRTIM_RSTER_TIMDCMP4_Msk
26844/**** Bit definition for Slave Timer Chopper register *************************/
26845#define HRTIM_CHPR_CARFRQ_Pos (0U)
26846#define HRTIM_CHPR_CARFRQ_Msk (0xFUL << HRTIM_CHPR_CARFRQ_Pos)
26847#define HRTIM_CHPR_CARFRQ HRTIM_CHPR_CARFRQ_Msk
26848#define HRTIM_CHPR_CARFRQ_0 (0x1UL << HRTIM_CHPR_CARFRQ_Pos)
26849#define HRTIM_CHPR_CARFRQ_1 (0x2UL << HRTIM_CHPR_CARFRQ_Pos)
26850#define HRTIM_CHPR_CARFRQ_2 (0x4UL << HRTIM_CHPR_CARFRQ_Pos)
26851#define HRTIM_CHPR_CARFRQ_3 (0x8UL << HRTIM_CHPR_CARFRQ_Pos)
26853#define HRTIM_CHPR_CARDTY_Pos (4U)
26854#define HRTIM_CHPR_CARDTY_Msk (0x7UL << HRTIM_CHPR_CARDTY_Pos)
26855#define HRTIM_CHPR_CARDTY HRTIM_CHPR_CARDTY_Msk
26856#define HRTIM_CHPR_CARDTY_0 (0x1UL << HRTIM_CHPR_CARDTY_Pos)
26857#define HRTIM_CHPR_CARDTY_1 (0x2UL << HRTIM_CHPR_CARDTY_Pos)
26858#define HRTIM_CHPR_CARDTY_2 (0x4UL << HRTIM_CHPR_CARDTY_Pos)
26860#define HRTIM_CHPR_STRPW_Pos (7U)
26861#define HRTIM_CHPR_STRPW_Msk (0xFUL << HRTIM_CHPR_STRPW_Pos)
26862#define HRTIM_CHPR_STRPW HRTIM_CHPR_STRPW_Msk
26863#define HRTIM_CHPR_STRPW_0 (0x1UL << HRTIM_CHPR_STRPW_Pos)
26864#define HRTIM_CHPR_STRPW_1 (0x2UL << HRTIM_CHPR_STRPW_Pos)
26865#define HRTIM_CHPR_STRPW_2 (0x4UL << HRTIM_CHPR_STRPW_Pos)
26866#define HRTIM_CHPR_STRPW_3 (0x8UL << HRTIM_CHPR_STRPW_Pos)
26868/**** Bit definition for Slave Timer Capture 1 control register ***************/
26869#define HRTIM_CPT1CR_SWCPT_Pos (0U)
26870#define HRTIM_CPT1CR_SWCPT_Msk (0x1UL << HRTIM_CPT1CR_SWCPT_Pos)
26871#define HRTIM_CPT1CR_SWCPT HRTIM_CPT1CR_SWCPT_Msk
26872#define HRTIM_CPT1CR_UPDCPT_Pos (1U)
26873#define HRTIM_CPT1CR_UPDCPT_Msk (0x1UL << HRTIM_CPT1CR_UPDCPT_Pos)
26874#define HRTIM_CPT1CR_UPDCPT HRTIM_CPT1CR_UPDCPT_Msk
26875#define HRTIM_CPT1CR_EXEV1CPT_Pos (2U)
26876#define HRTIM_CPT1CR_EXEV1CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV1CPT_Pos)
26877#define HRTIM_CPT1CR_EXEV1CPT HRTIM_CPT1CR_EXEV1CPT_Msk
26878#define HRTIM_CPT1CR_EXEV2CPT_Pos (3U)
26879#define HRTIM_CPT1CR_EXEV2CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV2CPT_Pos)
26880#define HRTIM_CPT1CR_EXEV2CPT HRTIM_CPT1CR_EXEV2CPT_Msk
26881#define HRTIM_CPT1CR_EXEV3CPT_Pos (4U)
26882#define HRTIM_CPT1CR_EXEV3CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV3CPT_Pos)
26883#define HRTIM_CPT1CR_EXEV3CPT HRTIM_CPT1CR_EXEV3CPT_Msk
26884#define HRTIM_CPT1CR_EXEV4CPT_Pos (5U)
26885#define HRTIM_CPT1CR_EXEV4CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV4CPT_Pos)
26886#define HRTIM_CPT1CR_EXEV4CPT HRTIM_CPT1CR_EXEV4CPT_Msk
26887#define HRTIM_CPT1CR_EXEV5CPT_Pos (6U)
26888#define HRTIM_CPT1CR_EXEV5CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV5CPT_Pos)
26889#define HRTIM_CPT1CR_EXEV5CPT HRTIM_CPT1CR_EXEV5CPT_Msk
26890#define HRTIM_CPT1CR_EXEV6CPT_Pos (7U)
26891#define HRTIM_CPT1CR_EXEV6CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV6CPT_Pos)
26892#define HRTIM_CPT1CR_EXEV6CPT HRTIM_CPT1CR_EXEV6CPT_Msk
26893#define HRTIM_CPT1CR_EXEV7CPT_Pos (8U)
26894#define HRTIM_CPT1CR_EXEV7CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV7CPT_Pos)
26895#define HRTIM_CPT1CR_EXEV7CPT HRTIM_CPT1CR_EXEV7CPT_Msk
26896#define HRTIM_CPT1CR_EXEV8CPT_Pos (9U)
26897#define HRTIM_CPT1CR_EXEV8CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV8CPT_Pos)
26898#define HRTIM_CPT1CR_EXEV8CPT HRTIM_CPT1CR_EXEV8CPT_Msk
26899#define HRTIM_CPT1CR_EXEV9CPT_Pos (10U)
26900#define HRTIM_CPT1CR_EXEV9CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV9CPT_Pos)
26901#define HRTIM_CPT1CR_EXEV9CPT HRTIM_CPT1CR_EXEV9CPT_Msk
26902#define HRTIM_CPT1CR_EXEV10CPT_Pos (11U)
26903#define HRTIM_CPT1CR_EXEV10CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV10CPT_Pos)
26904#define HRTIM_CPT1CR_EXEV10CPT HRTIM_CPT1CR_EXEV10CPT_Msk
26906#define HRTIM_CPT1CR_TA1SET_Pos (12U)
26907#define HRTIM_CPT1CR_TA1SET_Msk (0x1UL << HRTIM_CPT1CR_TA1SET_Pos)
26908#define HRTIM_CPT1CR_TA1SET HRTIM_CPT1CR_TA1SET_Msk
26909#define HRTIM_CPT1CR_TA1RST_Pos (13U)
26910#define HRTIM_CPT1CR_TA1RST_Msk (0x1UL << HRTIM_CPT1CR_TA1RST_Pos)
26911#define HRTIM_CPT1CR_TA1RST HRTIM_CPT1CR_TA1RST_Msk
26912#define HRTIM_CPT1CR_TIMACMP1_Pos (14U)
26913#define HRTIM_CPT1CR_TIMACMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMACMP1_Pos)
26914#define HRTIM_CPT1CR_TIMACMP1 HRTIM_CPT1CR_TIMACMP1_Msk
26915#define HRTIM_CPT1CR_TIMACMP2_Pos (15U)
26916#define HRTIM_CPT1CR_TIMACMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMACMP2_Pos)
26917#define HRTIM_CPT1CR_TIMACMP2 HRTIM_CPT1CR_TIMACMP2_Msk
26919#define HRTIM_CPT1CR_TB1SET_Pos (16U)
26920#define HRTIM_CPT1CR_TB1SET_Msk (0x1UL << HRTIM_CPT1CR_TB1SET_Pos)
26921#define HRTIM_CPT1CR_TB1SET HRTIM_CPT1CR_TB1SET_Msk
26922#define HRTIM_CPT1CR_TB1RST_Pos (17U)
26923#define HRTIM_CPT1CR_TB1RST_Msk (0x1UL << HRTIM_CPT1CR_TB1RST_Pos)
26924#define HRTIM_CPT1CR_TB1RST HRTIM_CPT1CR_TB1RST_Msk
26925#define HRTIM_CPT1CR_TIMBCMP1_Pos (18U)
26926#define HRTIM_CPT1CR_TIMBCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMBCMP1_Pos)
26927#define HRTIM_CPT1CR_TIMBCMP1 HRTIM_CPT1CR_TIMBCMP1_Msk
26928#define HRTIM_CPT1CR_TIMBCMP2_Pos (19U)
26929#define HRTIM_CPT1CR_TIMBCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMBCMP2_Pos)
26930#define HRTIM_CPT1CR_TIMBCMP2 HRTIM_CPT1CR_TIMBCMP2_Msk
26932#define HRTIM_CPT1CR_TC1SET_Pos (20U)
26933#define HRTIM_CPT1CR_TC1SET_Msk (0x1UL << HRTIM_CPT1CR_TC1SET_Pos)
26934#define HRTIM_CPT1CR_TC1SET HRTIM_CPT1CR_TC1SET_Msk
26935#define HRTIM_CPT1CR_TC1RST_Pos (21U)
26936#define HRTIM_CPT1CR_TC1RST_Msk (0x1UL << HRTIM_CPT1CR_TC1RST_Pos)
26937#define HRTIM_CPT1CR_TC1RST HRTIM_CPT1CR_TC1RST_Msk
26938#define HRTIM_CPT1CR_TIMCCMP1_Pos (22U)
26939#define HRTIM_CPT1CR_TIMCCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMCCMP1_Pos)
26940#define HRTIM_CPT1CR_TIMCCMP1 HRTIM_CPT1CR_TIMCCMP1_Msk
26941#define HRTIM_CPT1CR_TIMCCMP2_Pos (23U)
26942#define HRTIM_CPT1CR_TIMCCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMCCMP2_Pos)
26943#define HRTIM_CPT1CR_TIMCCMP2 HRTIM_CPT1CR_TIMCCMP2_Msk
26945#define HRTIM_CPT1CR_TD1SET_Pos (24U)
26946#define HRTIM_CPT1CR_TD1SET_Msk (0x1UL << HRTIM_CPT1CR_TD1SET_Pos)
26947#define HRTIM_CPT1CR_TD1SET HRTIM_CPT1CR_TD1SET_Msk
26948#define HRTIM_CPT1CR_TD1RST_Pos (25U)
26949#define HRTIM_CPT1CR_TD1RST_Msk (0x1UL << HRTIM_CPT1CR_TD1RST_Pos)
26950#define HRTIM_CPT1CR_TD1RST HRTIM_CPT1CR_TD1RST_Msk
26951#define HRTIM_CPT1CR_TIMDCMP1_Pos (26U)
26952#define HRTIM_CPT1CR_TIMDCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMDCMP1_Pos)
26953#define HRTIM_CPT1CR_TIMDCMP1 HRTIM_CPT1CR_TIMDCMP1_Msk
26954#define HRTIM_CPT1CR_TIMDCMP2_Pos (27U)
26955#define HRTIM_CPT1CR_TIMDCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMDCMP2_Pos)
26956#define HRTIM_CPT1CR_TIMDCMP2 HRTIM_CPT1CR_TIMDCMP2_Msk
26958#define HRTIM_CPT1CR_TE1SET_Pos (28U)
26959#define HRTIM_CPT1CR_TE1SET_Msk (0x1UL << HRTIM_CPT1CR_TE1SET_Pos)
26960#define HRTIM_CPT1CR_TE1SET HRTIM_CPT1CR_TE1SET_Msk
26961#define HRTIM_CPT1CR_TE1RST_Pos (29U)
26962#define HRTIM_CPT1CR_TE1RST_Msk (0x1UL << HRTIM_CPT1CR_TE1RST_Pos)
26963#define HRTIM_CPT1CR_TE1RST HRTIM_CPT1CR_TE1RST_Msk
26964#define HRTIM_CPT1CR_TIMECMP1_Pos (30U)
26965#define HRTIM_CPT1CR_TIMECMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMECMP1_Pos)
26966#define HRTIM_CPT1CR_TIMECMP1 HRTIM_CPT1CR_TIMECMP1_Msk
26967#define HRTIM_CPT1CR_TIMECMP2_Pos (31U)
26968#define HRTIM_CPT1CR_TIMECMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMECMP2_Pos)
26969#define HRTIM_CPT1CR_TIMECMP2 HRTIM_CPT1CR_TIMECMP2_Msk
26971/**** Bit definition for Slave Timer Capture 2 control register ***************/
26972#define HRTIM_CPT2CR_SWCPT_Pos (0U)
26973#define HRTIM_CPT2CR_SWCPT_Msk (0x1UL << HRTIM_CPT2CR_SWCPT_Pos)
26974#define HRTIM_CPT2CR_SWCPT HRTIM_CPT2CR_SWCPT_Msk
26975#define HRTIM_CPT2CR_UPDCPT_Pos (1U)
26976#define HRTIM_CPT2CR_UPDCPT_Msk (0x1UL << HRTIM_CPT2CR_UPDCPT_Pos)
26977#define HRTIM_CPT2CR_UPDCPT HRTIM_CPT2CR_UPDCPT_Msk
26978#define HRTIM_CPT2CR_EXEV1CPT_Pos (2U)
26979#define HRTIM_CPT2CR_EXEV1CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV1CPT_Pos)
26980#define HRTIM_CPT2CR_EXEV1CPT HRTIM_CPT2CR_EXEV1CPT_Msk
26981#define HRTIM_CPT2CR_EXEV2CPT_Pos (3U)
26982#define HRTIM_CPT2CR_EXEV2CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV2CPT_Pos)
26983#define HRTIM_CPT2CR_EXEV2CPT HRTIM_CPT2CR_EXEV2CPT_Msk
26984#define HRTIM_CPT2CR_EXEV3CPT_Pos (4U)
26985#define HRTIM_CPT2CR_EXEV3CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV3CPT_Pos)
26986#define HRTIM_CPT2CR_EXEV3CPT HRTIM_CPT2CR_EXEV3CPT_Msk
26987#define HRTIM_CPT2CR_EXEV4CPT_Pos (5U)
26988#define HRTIM_CPT2CR_EXEV4CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV4CPT_Pos)
26989#define HRTIM_CPT2CR_EXEV4CPT HRTIM_CPT2CR_EXEV4CPT_Msk
26990#define HRTIM_CPT2CR_EXEV5CPT_Pos (6U)
26991#define HRTIM_CPT2CR_EXEV5CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV5CPT_Pos)
26992#define HRTIM_CPT2CR_EXEV5CPT HRTIM_CPT2CR_EXEV5CPT_Msk
26993#define HRTIM_CPT2CR_EXEV6CPT_Pos (7U)
26994#define HRTIM_CPT2CR_EXEV6CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV6CPT_Pos)
26995#define HRTIM_CPT2CR_EXEV6CPT HRTIM_CPT2CR_EXEV6CPT_Msk
26996#define HRTIM_CPT2CR_EXEV7CPT_Pos (8U)
26997#define HRTIM_CPT2CR_EXEV7CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV7CPT_Pos)
26998#define HRTIM_CPT2CR_EXEV7CPT HRTIM_CPT2CR_EXEV7CPT_Msk
26999#define HRTIM_CPT2CR_EXEV8CPT_Pos (9U)
27000#define HRTIM_CPT2CR_EXEV8CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV8CPT_Pos)
27001#define HRTIM_CPT2CR_EXEV8CPT HRTIM_CPT2CR_EXEV8CPT_Msk
27002#define HRTIM_CPT2CR_EXEV9CPT_Pos (10U)
27003#define HRTIM_CPT2CR_EXEV9CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV9CPT_Pos)
27004#define HRTIM_CPT2CR_EXEV9CPT HRTIM_CPT2CR_EXEV9CPT_Msk
27005#define HRTIM_CPT2CR_EXEV10CPT_Pos (11U)
27006#define HRTIM_CPT2CR_EXEV10CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV10CPT_Pos)
27007#define HRTIM_CPT2CR_EXEV10CPT HRTIM_CPT2CR_EXEV10CPT_Msk
27009#define HRTIM_CPT2CR_TA1SET_Pos (12U)
27010#define HRTIM_CPT2CR_TA1SET_Msk (0x1UL << HRTIM_CPT2CR_TA1SET_Pos)
27011#define HRTIM_CPT2CR_TA1SET HRTIM_CPT2CR_TA1SET_Msk
27012#define HRTIM_CPT2CR_TA1RST_Pos (13U)
27013#define HRTIM_CPT2CR_TA1RST_Msk (0x1UL << HRTIM_CPT2CR_TA1RST_Pos)
27014#define HRTIM_CPT2CR_TA1RST HRTIM_CPT2CR_TA1RST_Msk
27015#define HRTIM_CPT2CR_TIMACMP1_Pos (14U)
27016#define HRTIM_CPT2CR_TIMACMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMACMP1_Pos)
27017#define HRTIM_CPT2CR_TIMACMP1 HRTIM_CPT2CR_TIMACMP1_Msk
27018#define HRTIM_CPT2CR_TIMACMP2_Pos (15U)
27019#define HRTIM_CPT2CR_TIMACMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMACMP2_Pos)
27020#define HRTIM_CPT2CR_TIMACMP2 HRTIM_CPT2CR_TIMACMP2_Msk
27022#define HRTIM_CPT2CR_TB1SET_Pos (16U)
27023#define HRTIM_CPT2CR_TB1SET_Msk (0x1UL << HRTIM_CPT2CR_TB1SET_Pos)
27024#define HRTIM_CPT2CR_TB1SET HRTIM_CPT2CR_TB1SET_Msk
27025#define HRTIM_CPT2CR_TB1RST_Pos (17U)
27026#define HRTIM_CPT2CR_TB1RST_Msk (0x1UL << HRTIM_CPT2CR_TB1RST_Pos)
27027#define HRTIM_CPT2CR_TB1RST HRTIM_CPT2CR_TB1RST_Msk
27028#define HRTIM_CPT2CR_TIMBCMP1_Pos (18U)
27029#define HRTIM_CPT2CR_TIMBCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMBCMP1_Pos)
27030#define HRTIM_CPT2CR_TIMBCMP1 HRTIM_CPT2CR_TIMBCMP1_Msk
27031#define HRTIM_CPT2CR_TIMBCMP2_Pos (19U)
27032#define HRTIM_CPT2CR_TIMBCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMBCMP2_Pos)
27033#define HRTIM_CPT2CR_TIMBCMP2 HRTIM_CPT2CR_TIMBCMP2_Msk
27035#define HRTIM_CPT2CR_TC1SET_Pos (20U)
27036#define HRTIM_CPT2CR_TC1SET_Msk (0x1UL << HRTIM_CPT2CR_TC1SET_Pos)
27037#define HRTIM_CPT2CR_TC1SET HRTIM_CPT2CR_TC1SET_Msk
27038#define HRTIM_CPT2CR_TC1RST_Pos (21U)
27039#define HRTIM_CPT2CR_TC1RST_Msk (0x1UL << HRTIM_CPT2CR_TC1RST_Pos)
27040#define HRTIM_CPT2CR_TC1RST HRTIM_CPT2CR_TC1RST_Msk
27041#define HRTIM_CPT2CR_TIMCCMP1_Pos (22U)
27042#define HRTIM_CPT2CR_TIMCCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMCCMP1_Pos)
27043#define HRTIM_CPT2CR_TIMCCMP1 HRTIM_CPT2CR_TIMCCMP1_Msk
27044#define HRTIM_CPT2CR_TIMCCMP2_Pos (23U)
27045#define HRTIM_CPT2CR_TIMCCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMCCMP2_Pos)
27046#define HRTIM_CPT2CR_TIMCCMP2 HRTIM_CPT2CR_TIMCCMP2_Msk
27048#define HRTIM_CPT2CR_TD1SET_Pos (24U)
27049#define HRTIM_CPT2CR_TD1SET_Msk (0x1UL << HRTIM_CPT2CR_TD1SET_Pos)
27050#define HRTIM_CPT2CR_TD1SET HRTIM_CPT2CR_TD1SET_Msk
27051#define HRTIM_CPT2CR_TD1RST_Pos (25U)
27052#define HRTIM_CPT2CR_TD1RST_Msk (0x1UL << HRTIM_CPT2CR_TD1RST_Pos)
27053#define HRTIM_CPT2CR_TD1RST HRTIM_CPT2CR_TD1RST_Msk
27054#define HRTIM_CPT2CR_TIMDCMP1_Pos (26U)
27055#define HRTIM_CPT2CR_TIMDCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMDCMP1_Pos)
27056#define HRTIM_CPT2CR_TIMDCMP1 HRTIM_CPT2CR_TIMDCMP1_Msk
27057#define HRTIM_CPT2CR_TIMDCMP2_Pos (27U)
27058#define HRTIM_CPT2CR_TIMDCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMDCMP2_Pos)
27059#define HRTIM_CPT2CR_TIMDCMP2 HRTIM_CPT2CR_TIMDCMP2_Msk
27061#define HRTIM_CPT2CR_TE1SET_Pos (28U)
27062#define HRTIM_CPT2CR_TE1SET_Msk (0x1UL << HRTIM_CPT2CR_TE1SET_Pos)
27063#define HRTIM_CPT2CR_TE1SET HRTIM_CPT2CR_TE1SET_Msk
27064#define HRTIM_CPT2CR_TE1RST_Pos (29U)
27065#define HRTIM_CPT2CR_TE1RST_Msk (0x1UL << HRTIM_CPT2CR_TE1RST_Pos)
27066#define HRTIM_CPT2CR_TE1RST HRTIM_CPT2CR_TE1RST_Msk
27067#define HRTIM_CPT2CR_TIMECMP1_Pos (30U)
27068#define HRTIM_CPT2CR_TIMECMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMECMP1_Pos)
27069#define HRTIM_CPT2CR_TIMECMP1 HRTIM_CPT2CR_TIMECMP1_Msk
27070#define HRTIM_CPT2CR_TIMECMP2_Pos (31U)
27071#define HRTIM_CPT2CR_TIMECMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMECMP2_Pos)
27072#define HRTIM_CPT2CR_TIMECMP2 HRTIM_CPT2CR_TIMECMP2_Msk
27074/**** Bit definition for Slave Timer Output register **************************/
27075#define HRTIM_OUTR_POL1_Pos (1U)
27076#define HRTIM_OUTR_POL1_Msk (0x1UL << HRTIM_OUTR_POL1_Pos)
27077#define HRTIM_OUTR_POL1 HRTIM_OUTR_POL1_Msk
27078#define HRTIM_OUTR_IDLM1_Pos (2U)
27079#define HRTIM_OUTR_IDLM1_Msk (0x1UL << HRTIM_OUTR_IDLM1_Pos)
27080#define HRTIM_OUTR_IDLM1 HRTIM_OUTR_IDLM1_Msk
27081#define HRTIM_OUTR_IDLES1_Pos (3U)
27082#define HRTIM_OUTR_IDLES1_Msk (0x1UL << HRTIM_OUTR_IDLES1_Pos)
27083#define HRTIM_OUTR_IDLES1 HRTIM_OUTR_IDLES1_Msk
27084#define HRTIM_OUTR_FAULT1_Pos (4U)
27085#define HRTIM_OUTR_FAULT1_Msk (0x3UL << HRTIM_OUTR_FAULT1_Pos)
27086#define HRTIM_OUTR_FAULT1 HRTIM_OUTR_FAULT1_Msk
27087#define HRTIM_OUTR_FAULT1_0 (0x1UL << HRTIM_OUTR_FAULT1_Pos)
27088#define HRTIM_OUTR_FAULT1_1 (0x2UL << HRTIM_OUTR_FAULT1_Pos)
27089#define HRTIM_OUTR_CHP1_Pos (6U)
27090#define HRTIM_OUTR_CHP1_Msk (0x1UL << HRTIM_OUTR_CHP1_Pos)
27091#define HRTIM_OUTR_CHP1 HRTIM_OUTR_CHP1_Msk
27092#define HRTIM_OUTR_DIDL1_Pos (7U)
27093#define HRTIM_OUTR_DIDL1_Msk (0x1UL << HRTIM_OUTR_DIDL1_Pos)
27094#define HRTIM_OUTR_DIDL1 HRTIM_OUTR_DIDL1_Msk
27096#define HRTIM_OUTR_DTEN_Pos (8U)
27097#define HRTIM_OUTR_DTEN_Msk (0x1UL << HRTIM_OUTR_DTEN_Pos)
27098#define HRTIM_OUTR_DTEN HRTIM_OUTR_DTEN_Msk
27099#define HRTIM_OUTR_DLYPRTEN_Pos (9U)
27100#define HRTIM_OUTR_DLYPRTEN_Msk (0x1UL << HRTIM_OUTR_DLYPRTEN_Pos)
27101#define HRTIM_OUTR_DLYPRTEN HRTIM_OUTR_DLYPRTEN_Msk
27102#define HRTIM_OUTR_DLYPRT_Pos (10U)
27103#define HRTIM_OUTR_DLYPRT_Msk (0x7UL << HRTIM_OUTR_DLYPRT_Pos)
27104#define HRTIM_OUTR_DLYPRT HRTIM_OUTR_DLYPRT_Msk
27105#define HRTIM_OUTR_DLYPRT_0 (0x1UL << HRTIM_OUTR_DLYPRT_Pos)
27106#define HRTIM_OUTR_DLYPRT_1 (0x2UL << HRTIM_OUTR_DLYPRT_Pos)
27107#define HRTIM_OUTR_DLYPRT_2 (0x4UL << HRTIM_OUTR_DLYPRT_Pos)
27109#define HRTIM_OUTR_POL2_Pos (17U)
27110#define HRTIM_OUTR_POL2_Msk (0x1UL << HRTIM_OUTR_POL2_Pos)
27111#define HRTIM_OUTR_POL2 HRTIM_OUTR_POL2_Msk
27112#define HRTIM_OUTR_IDLM2_Pos (18U)
27113#define HRTIM_OUTR_IDLM2_Msk (0x1UL << HRTIM_OUTR_IDLM2_Pos)
27114#define HRTIM_OUTR_IDLM2 HRTIM_OUTR_IDLM2_Msk
27115#define HRTIM_OUTR_IDLES2_Pos (19U)
27116#define HRTIM_OUTR_IDLES2_Msk (0x1UL << HRTIM_OUTR_IDLES2_Pos)
27117#define HRTIM_OUTR_IDLES2 HRTIM_OUTR_IDLES2_Msk
27118#define HRTIM_OUTR_FAULT2_Pos (20U)
27119#define HRTIM_OUTR_FAULT2_Msk (0x3UL << HRTIM_OUTR_FAULT2_Pos)
27120#define HRTIM_OUTR_FAULT2 HRTIM_OUTR_FAULT2_Msk
27121#define HRTIM_OUTR_FAULT2_0 (0x1UL << HRTIM_OUTR_FAULT2_Pos)
27122#define HRTIM_OUTR_FAULT2_1 (0x2UL << HRTIM_OUTR_FAULT2_Pos)
27123#define HRTIM_OUTR_CHP2_Pos (22U)
27124#define HRTIM_OUTR_CHP2_Msk (0x1UL << HRTIM_OUTR_CHP2_Pos)
27125#define HRTIM_OUTR_CHP2 HRTIM_OUTR_CHP2_Msk
27126#define HRTIM_OUTR_DIDL2_Pos (23U)
27127#define HRTIM_OUTR_DIDL2_Msk (0x1UL << HRTIM_OUTR_DIDL2_Pos)
27128#define HRTIM_OUTR_DIDL2 HRTIM_OUTR_DIDL2_Msk
27130/**** Bit definition for Slave Timer Fault register ***************************/
27131#define HRTIM_FLTR_FLT1EN_Pos (0U)
27132#define HRTIM_FLTR_FLT1EN_Msk (0x1UL << HRTIM_FLTR_FLT1EN_Pos)
27133#define HRTIM_FLTR_FLT1EN HRTIM_FLTR_FLT1EN_Msk
27134#define HRTIM_FLTR_FLT2EN_Pos (1U)
27135#define HRTIM_FLTR_FLT2EN_Msk (0x1UL << HRTIM_FLTR_FLT2EN_Pos)
27136#define HRTIM_FLTR_FLT2EN HRTIM_FLTR_FLT2EN_Msk
27137#define HRTIM_FLTR_FLT3EN_Pos (2U)
27138#define HRTIM_FLTR_FLT3EN_Msk (0x1UL << HRTIM_FLTR_FLT3EN_Pos)
27139#define HRTIM_FLTR_FLT3EN HRTIM_FLTR_FLT3EN_Msk
27140#define HRTIM_FLTR_FLT4EN_Pos (3U)
27141#define HRTIM_FLTR_FLT4EN_Msk (0x1UL << HRTIM_FLTR_FLT4EN_Pos)
27142#define HRTIM_FLTR_FLT4EN HRTIM_FLTR_FLT4EN_Msk
27143#define HRTIM_FLTR_FLT5EN_Pos (4U)
27144#define HRTIM_FLTR_FLT5EN_Msk (0x1UL << HRTIM_FLTR_FLT5EN_Pos)
27145#define HRTIM_FLTR_FLT5EN HRTIM_FLTR_FLT5EN_Msk
27146#define HRTIM_FLTR_FLTLCK_Pos (31U)
27147#define HRTIM_FLTR_FLTLCK_Msk (0x1UL << HRTIM_FLTR_FLTLCK_Pos)
27148#define HRTIM_FLTR_FLTLCK HRTIM_FLTR_FLTLCK_Msk
27150/**** Bit definition for Common HRTIM Timer control register 1 ****************/
27151#define HRTIM_CR1_MUDIS_Pos (0U)
27152#define HRTIM_CR1_MUDIS_Msk (0x1UL << HRTIM_CR1_MUDIS_Pos)
27153#define HRTIM_CR1_MUDIS HRTIM_CR1_MUDIS_Msk
27154#define HRTIM_CR1_TAUDIS_Pos (1U)
27155#define HRTIM_CR1_TAUDIS_Msk (0x1UL << HRTIM_CR1_TAUDIS_Pos)
27156#define HRTIM_CR1_TAUDIS HRTIM_CR1_TAUDIS_Msk
27157#define HRTIM_CR1_TBUDIS_Pos (2U)
27158#define HRTIM_CR1_TBUDIS_Msk (0x1UL << HRTIM_CR1_TBUDIS_Pos)
27159#define HRTIM_CR1_TBUDIS HRTIM_CR1_TBUDIS_Msk
27160#define HRTIM_CR1_TCUDIS_Pos (3U)
27161#define HRTIM_CR1_TCUDIS_Msk (0x1UL << HRTIM_CR1_TCUDIS_Pos)
27162#define HRTIM_CR1_TCUDIS HRTIM_CR1_TCUDIS_Msk
27163#define HRTIM_CR1_TDUDIS_Pos (4U)
27164#define HRTIM_CR1_TDUDIS_Msk (0x1UL << HRTIM_CR1_TDUDIS_Pos)
27165#define HRTIM_CR1_TDUDIS HRTIM_CR1_TDUDIS_Msk
27166#define HRTIM_CR1_TEUDIS_Pos (5U)
27167#define HRTIM_CR1_TEUDIS_Msk (0x1UL << HRTIM_CR1_TEUDIS_Pos)
27168#define HRTIM_CR1_TEUDIS HRTIM_CR1_TEUDIS_Msk
27169#define HRTIM_CR1_ADC1USRC_Pos (16U)
27170#define HRTIM_CR1_ADC1USRC_Msk (0x7UL << HRTIM_CR1_ADC1USRC_Pos)
27171#define HRTIM_CR1_ADC1USRC HRTIM_CR1_ADC1USRC_Msk
27172#define HRTIM_CR1_ADC1USRC_0 (0x1UL << HRTIM_CR1_ADC1USRC_Pos)
27173#define HRTIM_CR1_ADC1USRC_1 (0x2UL << HRTIM_CR1_ADC1USRC_Pos)
27174#define HRTIM_CR1_ADC1USRC_2 (0x4UL << HRTIM_CR1_ADC1USRC_Pos)
27175#define HRTIM_CR1_ADC2USRC_Pos (19U)
27176#define HRTIM_CR1_ADC2USRC_Msk (0x7UL << HRTIM_CR1_ADC2USRC_Pos)
27177#define HRTIM_CR1_ADC2USRC HRTIM_CR1_ADC2USRC_Msk
27178#define HRTIM_CR1_ADC2USRC_0 (0x1UL << HRTIM_CR1_ADC2USRC_Pos)
27179#define HRTIM_CR1_ADC2USRC_1 (0x2UL << HRTIM_CR1_ADC2USRC_Pos)
27180#define HRTIM_CR1_ADC2USRC_2 (0x4UL << HRTIM_CR1_ADC2USRC_Pos)
27181#define HRTIM_CR1_ADC3USRC_Pos (22U)
27182#define HRTIM_CR1_ADC3USRC_Msk (0x7UL << HRTIM_CR1_ADC3USRC_Pos)
27183#define HRTIM_CR1_ADC3USRC HRTIM_CR1_ADC3USRC_Msk
27184#define HRTIM_CR1_ADC3USRC_0 (0x1UL << HRTIM_CR1_ADC3USRC_Pos)
27185#define HRTIM_CR1_ADC3USRC_1 (0x2UL << HRTIM_CR1_ADC3USRC_Pos)
27186#define HRTIM_CR1_ADC3USRC_2 (0x4UL << HRTIM_CR1_ADC3USRC_Pos)
27187#define HRTIM_CR1_ADC4USRC_Pos (25U)
27188#define HRTIM_CR1_ADC4USRC_Msk (0x7UL << HRTIM_CR1_ADC4USRC_Pos)
27189#define HRTIM_CR1_ADC4USRC HRTIM_CR1_ADC4USRC_Msk
27190#define HRTIM_CR1_ADC4USRC_0 (0x1UL << HRTIM_CR1_ADC4USRC_Pos)
27191#define HRTIM_CR1_ADC4USRC_1 (0x2UL << HRTIM_CR1_ADC4USRC_Pos)
27192#define HRTIM_CR1_ADC4USRC_2 (0x0UL << HRTIM_CR1_ADC4USRC_Pos)
27194/**** Bit definition for Common HRTIM Timer control register 2 ****************/
27195#define HRTIM_CR2_MSWU_Pos (0U)
27196#define HRTIM_CR2_MSWU_Msk (0x1UL << HRTIM_CR2_MSWU_Pos)
27197#define HRTIM_CR2_MSWU HRTIM_CR2_MSWU_Msk
27198#define HRTIM_CR2_TASWU_Pos (1U)
27199#define HRTIM_CR2_TASWU_Msk (0x1UL << HRTIM_CR2_TASWU_Pos)
27200#define HRTIM_CR2_TASWU HRTIM_CR2_TASWU_Msk
27201#define HRTIM_CR2_TBSWU_Pos (2U)
27202#define HRTIM_CR2_TBSWU_Msk (0x1UL << HRTIM_CR2_TBSWU_Pos)
27203#define HRTIM_CR2_TBSWU HRTIM_CR2_TBSWU_Msk
27204#define HRTIM_CR2_TCSWU_Pos (3U)
27205#define HRTIM_CR2_TCSWU_Msk (0x1UL << HRTIM_CR2_TCSWU_Pos)
27206#define HRTIM_CR2_TCSWU HRTIM_CR2_TCSWU_Msk
27207#define HRTIM_CR2_TDSWU_Pos (4U)
27208#define HRTIM_CR2_TDSWU_Msk (0x1UL << HRTIM_CR2_TDSWU_Pos)
27209#define HRTIM_CR2_TDSWU HRTIM_CR2_TDSWU_Msk
27210#define HRTIM_CR2_TESWU_Pos (5U)
27211#define HRTIM_CR2_TESWU_Msk (0x1UL << HRTIM_CR2_TESWU_Pos)
27212#define HRTIM_CR2_TESWU HRTIM_CR2_TESWU_Msk
27213#define HRTIM_CR2_MRST_Pos (8U)
27214#define HRTIM_CR2_MRST_Msk (0x1UL << HRTIM_CR2_MRST_Pos)
27215#define HRTIM_CR2_MRST HRTIM_CR2_MRST_Msk
27216#define HRTIM_CR2_TARST_Pos (9U)
27217#define HRTIM_CR2_TARST_Msk (0x1UL << HRTIM_CR2_TARST_Pos)
27218#define HRTIM_CR2_TARST HRTIM_CR2_TARST_Msk
27219#define HRTIM_CR2_TBRST_Pos (10U)
27220#define HRTIM_CR2_TBRST_Msk (0x1UL << HRTIM_CR2_TBRST_Pos)
27221#define HRTIM_CR2_TBRST HRTIM_CR2_TBRST_Msk
27222#define HRTIM_CR2_TCRST_Pos (11U)
27223#define HRTIM_CR2_TCRST_Msk (0x1UL << HRTIM_CR2_TCRST_Pos)
27224#define HRTIM_CR2_TCRST HRTIM_CR2_TCRST_Msk
27225#define HRTIM_CR2_TDRST_Pos (12U)
27226#define HRTIM_CR2_TDRST_Msk (0x1UL << HRTIM_CR2_TDRST_Pos)
27227#define HRTIM_CR2_TDRST HRTIM_CR2_TDRST_Msk
27228#define HRTIM_CR2_TERST_Pos (13U)
27229#define HRTIM_CR2_TERST_Msk (0x1UL << HRTIM_CR2_TERST_Pos)
27230#define HRTIM_CR2_TERST HRTIM_CR2_TERST_Msk
27232/**** Bit definition for Common HRTIM Timer interrupt status register *********/
27233#define HRTIM_ISR_FLT1_Pos (0U)
27234#define HRTIM_ISR_FLT1_Msk (0x1UL << HRTIM_ISR_FLT1_Pos)
27235#define HRTIM_ISR_FLT1 HRTIM_ISR_FLT1_Msk
27236#define HRTIM_ISR_FLT2_Pos (1U)
27237#define HRTIM_ISR_FLT2_Msk (0x1UL << HRTIM_ISR_FLT2_Pos)
27238#define HRTIM_ISR_FLT2 HRTIM_ISR_FLT2_Msk
27239#define HRTIM_ISR_FLT3_Pos (2U)
27240#define HRTIM_ISR_FLT3_Msk (0x1UL << HRTIM_ISR_FLT3_Pos)
27241#define HRTIM_ISR_FLT3 HRTIM_ISR_FLT3_Msk
27242#define HRTIM_ISR_FLT4_Pos (3U)
27243#define HRTIM_ISR_FLT4_Msk (0x1UL << HRTIM_ISR_FLT4_Pos)
27244#define HRTIM_ISR_FLT4 HRTIM_ISR_FLT4_Msk
27245#define HRTIM_ISR_FLT5_Pos (4U)
27246#define HRTIM_ISR_FLT5_Msk (0x1UL << HRTIM_ISR_FLT5_Pos)
27247#define HRTIM_ISR_FLT5 HRTIM_ISR_FLT5_Msk
27248#define HRTIM_ISR_SYSFLT_Pos (5U)
27249#define HRTIM_ISR_SYSFLT_Msk (0x1UL << HRTIM_ISR_SYSFLT_Pos)
27250#define HRTIM_ISR_SYSFLT HRTIM_ISR_SYSFLT_Msk
27251#define HRTIM_ISR_BMPER_Pos (17U)
27252#define HRTIM_ISR_BMPER_Msk (0x1UL << HRTIM_ISR_BMPER_Pos)
27253#define HRTIM_ISR_BMPER HRTIM_ISR_BMPER_Msk
27255/**** Bit definition for Common HRTIM Timer interrupt clear register **********/
27256#define HRTIM_ICR_FLT1C_Pos (0U)
27257#define HRTIM_ICR_FLT1C_Msk (0x1UL << HRTIM_ICR_FLT1C_Pos)
27258#define HRTIM_ICR_FLT1C HRTIM_ICR_FLT1C_Msk
27259#define HRTIM_ICR_FLT2C_Pos (1U)
27260#define HRTIM_ICR_FLT2C_Msk (0x1UL << HRTIM_ICR_FLT2C_Pos)
27261#define HRTIM_ICR_FLT2C HRTIM_ICR_FLT2C_Msk
27262#define HRTIM_ICR_FLT3C_Pos (2U)
27263#define HRTIM_ICR_FLT3C_Msk (0x1UL << HRTIM_ICR_FLT3C_Pos)
27264#define HRTIM_ICR_FLT3C HRTIM_ICR_FLT3C_Msk
27265#define HRTIM_ICR_FLT4C_Pos (3U)
27266#define HRTIM_ICR_FLT4C_Msk (0x1UL << HRTIM_ICR_FLT4C_Pos)
27267#define HRTIM_ICR_FLT4C HRTIM_ICR_FLT4C_Msk
27268#define HRTIM_ICR_FLT5C_Pos (4U)
27269#define HRTIM_ICR_FLT5C_Msk (0x1UL << HRTIM_ICR_FLT5C_Pos)
27270#define HRTIM_ICR_FLT5C HRTIM_ICR_FLT5C_Msk
27271#define HRTIM_ICR_SYSFLTC_Pos (5U)
27272#define HRTIM_ICR_SYSFLTC_Msk (0x1UL << HRTIM_ICR_SYSFLTC_Pos)
27273#define HRTIM_ICR_SYSFLTC HRTIM_ICR_SYSFLTC_Msk
27274#define HRTIM_ICR_BMPERC_Pos (17U)
27275#define HRTIM_ICR_BMPERC_Msk (0x1UL << HRTIM_ICR_BMPERC_Pos)
27276#define HRTIM_ICR_BMPERC HRTIM_ICR_BMPERC_Msk
27278/**** Bit definition for Common HRTIM Timer interrupt enable register *********/
27279#define HRTIM_IER_FLT1_Pos (0U)
27280#define HRTIM_IER_FLT1_Msk (0x1UL << HRTIM_IER_FLT1_Pos)
27281#define HRTIM_IER_FLT1 HRTIM_IER_FLT1_Msk
27282#define HRTIM_IER_FLT2_Pos (1U)
27283#define HRTIM_IER_FLT2_Msk (0x1UL << HRTIM_IER_FLT2_Pos)
27284#define HRTIM_IER_FLT2 HRTIM_IER_FLT2_Msk
27285#define HRTIM_IER_FLT3_Pos (2U)
27286#define HRTIM_IER_FLT3_Msk (0x1UL << HRTIM_IER_FLT3_Pos)
27287#define HRTIM_IER_FLT3 HRTIM_IER_FLT3_Msk
27288#define HRTIM_IER_FLT4_Pos (3U)
27289#define HRTIM_IER_FLT4_Msk (0x1UL << HRTIM_IER_FLT4_Pos)
27290#define HRTIM_IER_FLT4 HRTIM_IER_FLT4_Msk
27291#define HRTIM_IER_FLT5_Pos (4U)
27292#define HRTIM_IER_FLT5_Msk (0x1UL << HRTIM_IER_FLT5_Pos)
27293#define HRTIM_IER_FLT5 HRTIM_IER_FLT5_Msk
27294#define HRTIM_IER_SYSFLT_Pos (5U)
27295#define HRTIM_IER_SYSFLT_Msk (0x1UL << HRTIM_IER_SYSFLT_Pos)
27296#define HRTIM_IER_SYSFLT HRTIM_IER_SYSFLT_Msk
27297#define HRTIM_IER_BMPER_Pos (17U)
27298#define HRTIM_IER_BMPER_Msk (0x1UL << HRTIM_IER_BMPER_Pos)
27299#define HRTIM_IER_BMPER HRTIM_IER_BMPER_Msk
27301/**** Bit definition for Common HRTIM Timer output enable register ************/
27302#define HRTIM_OENR_TA1OEN_Pos (0U)
27303#define HRTIM_OENR_TA1OEN_Msk (0x1UL << HRTIM_OENR_TA1OEN_Pos)
27304#define HRTIM_OENR_TA1OEN HRTIM_OENR_TA1OEN_Msk
27305#define HRTIM_OENR_TA2OEN_Pos (1U)
27306#define HRTIM_OENR_TA2OEN_Msk (0x1UL << HRTIM_OENR_TA2OEN_Pos)
27307#define HRTIM_OENR_TA2OEN HRTIM_OENR_TA2OEN_Msk
27308#define HRTIM_OENR_TB1OEN_Pos (2U)
27309#define HRTIM_OENR_TB1OEN_Msk (0x1UL << HRTIM_OENR_TB1OEN_Pos)
27310#define HRTIM_OENR_TB1OEN HRTIM_OENR_TB1OEN_Msk
27311#define HRTIM_OENR_TB2OEN_Pos (3U)
27312#define HRTIM_OENR_TB2OEN_Msk (0x1UL << HRTIM_OENR_TB2OEN_Pos)
27313#define HRTIM_OENR_TB2OEN HRTIM_OENR_TB2OEN_Msk
27314#define HRTIM_OENR_TC1OEN_Pos (4U)
27315#define HRTIM_OENR_TC1OEN_Msk (0x1UL << HRTIM_OENR_TC1OEN_Pos)
27316#define HRTIM_OENR_TC1OEN HRTIM_OENR_TC1OEN_Msk
27317#define HRTIM_OENR_TC2OEN_Pos (5U)
27318#define HRTIM_OENR_TC2OEN_Msk (0x1UL << HRTIM_OENR_TC2OEN_Pos)
27319#define HRTIM_OENR_TC2OEN HRTIM_OENR_TC2OEN_Msk
27320#define HRTIM_OENR_TD1OEN_Pos (6U)
27321#define HRTIM_OENR_TD1OEN_Msk (0x1UL << HRTIM_OENR_TD1OEN_Pos)
27322#define HRTIM_OENR_TD1OEN HRTIM_OENR_TD1OEN_Msk
27323#define HRTIM_OENR_TD2OEN_Pos (7U)
27324#define HRTIM_OENR_TD2OEN_Msk (0x1UL << HRTIM_OENR_TD2OEN_Pos)
27325#define HRTIM_OENR_TD2OEN HRTIM_OENR_TD2OEN_Msk
27326#define HRTIM_OENR_TE1OEN_Pos (8U)
27327#define HRTIM_OENR_TE1OEN_Msk (0x1UL << HRTIM_OENR_TE1OEN_Pos)
27328#define HRTIM_OENR_TE1OEN HRTIM_OENR_TE1OEN_Msk
27329#define HRTIM_OENR_TE2OEN_Pos (9U)
27330#define HRTIM_OENR_TE2OEN_Msk (0x1UL << HRTIM_OENR_TE2OEN_Pos)
27331#define HRTIM_OENR_TE2OEN HRTIM_OENR_TE2OEN_Msk
27333/**** Bit definition for Common HRTIM Timer output disable register ***********/
27334#define HRTIM_ODISR_TA1ODIS_Pos (0U)
27335#define HRTIM_ODISR_TA1ODIS_Msk (0x1UL << HRTIM_ODISR_TA1ODIS_Pos)
27336#define HRTIM_ODISR_TA1ODIS HRTIM_ODISR_TA1ODIS_Msk
27337#define HRTIM_ODISR_TA2ODIS_Pos (1U)
27338#define HRTIM_ODISR_TA2ODIS_Msk (0x1UL << HRTIM_ODISR_TA2ODIS_Pos)
27339#define HRTIM_ODISR_TA2ODIS HRTIM_ODISR_TA2ODIS_Msk
27340#define HRTIM_ODISR_TB1ODIS_Pos (2U)
27341#define HRTIM_ODISR_TB1ODIS_Msk (0x1UL << HRTIM_ODISR_TB1ODIS_Pos)
27342#define HRTIM_ODISR_TB1ODIS HRTIM_ODISR_TB1ODIS_Msk
27343#define HRTIM_ODISR_TB2ODIS_Pos (3U)
27344#define HRTIM_ODISR_TB2ODIS_Msk (0x1UL << HRTIM_ODISR_TB2ODIS_Pos)
27345#define HRTIM_ODISR_TB2ODIS HRTIM_ODISR_TB2ODIS_Msk
27346#define HRTIM_ODISR_TC1ODIS_Pos (4U)
27347#define HRTIM_ODISR_TC1ODIS_Msk (0x1UL << HRTIM_ODISR_TC1ODIS_Pos)
27348#define HRTIM_ODISR_TC1ODIS HRTIM_ODISR_TC1ODIS_Msk
27349#define HRTIM_ODISR_TC2ODIS_Pos (5U)
27350#define HRTIM_ODISR_TC2ODIS_Msk (0x1UL << HRTIM_ODISR_TC2ODIS_Pos)
27351#define HRTIM_ODISR_TC2ODIS HRTIM_ODISR_TC2ODIS_Msk
27352#define HRTIM_ODISR_TD1ODIS_Pos (6U)
27353#define HRTIM_ODISR_TD1ODIS_Msk (0x1UL << HRTIM_ODISR_TD1ODIS_Pos)
27354#define HRTIM_ODISR_TD1ODIS HRTIM_ODISR_TD1ODIS_Msk
27355#define HRTIM_ODISR_TD2ODIS_Pos (7U)
27356#define HRTIM_ODISR_TD2ODIS_Msk (0x1UL << HRTIM_ODISR_TD2ODIS_Pos)
27357#define HRTIM_ODISR_TD2ODIS HRTIM_ODISR_TD2ODIS_Msk
27358#define HRTIM_ODISR_TE1ODIS_Pos (8U)
27359#define HRTIM_ODISR_TE1ODIS_Msk (0x1UL << HRTIM_ODISR_TE1ODIS_Pos)
27360#define HRTIM_ODISR_TE1ODIS HRTIM_ODISR_TE1ODIS_Msk
27361#define HRTIM_ODISR_TE2ODIS_Pos (9U)
27362#define HRTIM_ODISR_TE2ODIS_Msk (0x1UL << HRTIM_ODISR_TE2ODIS_Pos)
27363#define HRTIM_ODISR_TE2ODIS HRTIM_ODISR_TE2ODIS_Msk
27365/**** Bit definition for Common HRTIM Timer output disable status register *****/
27366#define HRTIM_ODSR_TA1ODS_Pos (0U)
27367#define HRTIM_ODSR_TA1ODS_Msk (0x1UL << HRTIM_ODSR_TA1ODS_Pos)
27368#define HRTIM_ODSR_TA1ODS HRTIM_ODSR_TA1ODS_Msk
27369#define HRTIM_ODSR_TA2ODS_Pos (1U)
27370#define HRTIM_ODSR_TA2ODS_Msk (0x1UL << HRTIM_ODSR_TA2ODS_Pos)
27371#define HRTIM_ODSR_TA2ODS HRTIM_ODSR_TA2ODS_Msk
27372#define HRTIM_ODSR_TB1ODS_Pos (2U)
27373#define HRTIM_ODSR_TB1ODS_Msk (0x1UL << HRTIM_ODSR_TB1ODS_Pos)
27374#define HRTIM_ODSR_TB1ODS HRTIM_ODSR_TB1ODS_Msk
27375#define HRTIM_ODSR_TB2ODS_Pos (3U)
27376#define HRTIM_ODSR_TB2ODS_Msk (0x1UL << HRTIM_ODSR_TB2ODS_Pos)
27377#define HRTIM_ODSR_TB2ODS HRTIM_ODSR_TB2ODS_Msk
27378#define HRTIM_ODSR_TC1ODS_Pos (4U)
27379#define HRTIM_ODSR_TC1ODS_Msk (0x1UL << HRTIM_ODSR_TC1ODS_Pos)
27380#define HRTIM_ODSR_TC1ODS HRTIM_ODSR_TC1ODS_Msk
27381#define HRTIM_ODSR_TC2ODS_Pos (5U)
27382#define HRTIM_ODSR_TC2ODS_Msk (0x1UL << HRTIM_ODSR_TC2ODS_Pos)
27383#define HRTIM_ODSR_TC2ODS HRTIM_ODSR_TC2ODS_Msk
27384#define HRTIM_ODSR_TD1ODS_Pos (6U)
27385#define HRTIM_ODSR_TD1ODS_Msk (0x1UL << HRTIM_ODSR_TD1ODS_Pos)
27386#define HRTIM_ODSR_TD1ODS HRTIM_ODSR_TD1ODS_Msk
27387#define HRTIM_ODSR_TD2ODS_Pos (7U)
27388#define HRTIM_ODSR_TD2ODS_Msk (0x1UL << HRTIM_ODSR_TD2ODS_Pos)
27389#define HRTIM_ODSR_TD2ODS HRTIM_ODSR_TD2ODS_Msk
27390#define HRTIM_ODSR_TE1ODS_Pos (8U)
27391#define HRTIM_ODSR_TE1ODS_Msk (0x1UL << HRTIM_ODSR_TE1ODS_Pos)
27392#define HRTIM_ODSR_TE1ODS HRTIM_ODSR_TE1ODS_Msk
27393#define HRTIM_ODSR_TE2ODS_Pos (9U)
27394#define HRTIM_ODSR_TE2ODS_Msk (0x1UL << HRTIM_ODSR_TE2ODS_Pos)
27395#define HRTIM_ODSR_TE2ODS HRTIM_ODSR_TE2ODS_Msk
27397/**** Bit definition for Common HRTIM Timer Burst mode control register ********/
27398#define HRTIM_BMCR_BME_Pos (0U)
27399#define HRTIM_BMCR_BME_Msk (0x1UL << HRTIM_BMCR_BME_Pos)
27400#define HRTIM_BMCR_BME HRTIM_BMCR_BME_Msk
27401#define HRTIM_BMCR_BMOM_Pos (1U)
27402#define HRTIM_BMCR_BMOM_Msk (0x1UL << HRTIM_BMCR_BMOM_Pos)
27403#define HRTIM_BMCR_BMOM HRTIM_BMCR_BMOM_Msk
27404#define HRTIM_BMCR_BMCLK_Pos (2U)
27405#define HRTIM_BMCR_BMCLK_Msk (0xFUL << HRTIM_BMCR_BMCLK_Pos)
27406#define HRTIM_BMCR_BMCLK HRTIM_BMCR_BMCLK_Msk
27407#define HRTIM_BMCR_BMCLK_0 (0x1UL << HRTIM_BMCR_BMCLK_Pos)
27408#define HRTIM_BMCR_BMCLK_1 (0x2UL << HRTIM_BMCR_BMCLK_Pos)
27409#define HRTIM_BMCR_BMCLK_2 (0x4UL << HRTIM_BMCR_BMCLK_Pos)
27410#define HRTIM_BMCR_BMCLK_3 (0x8UL << HRTIM_BMCR_BMCLK_Pos)
27411#define HRTIM_BMCR_BMPRSC_Pos (6U)
27412#define HRTIM_BMCR_BMPRSC_Msk (0xFUL << HRTIM_BMCR_BMPRSC_Pos)
27413#define HRTIM_BMCR_BMPRSC HRTIM_BMCR_BMPRSC_Msk
27414#define HRTIM_BMCR_BMPRSC_0 (0x1UL << HRTIM_BMCR_BMPRSC_Pos)
27415#define HRTIM_BMCR_BMPRSC_1 (0x2UL << HRTIM_BMCR_BMPRSC_Pos)
27416#define HRTIM_BMCR_BMPRSC_2 (0x4UL << HRTIM_BMCR_BMPRSC_Pos)
27417#define HRTIM_BMCR_BMPRSC_3 (0x8UL << HRTIM_BMCR_BMPRSC_Pos)
27418#define HRTIM_BMCR_BMPREN_Pos (10U)
27419#define HRTIM_BMCR_BMPREN_Msk (0x1UL << HRTIM_BMCR_BMPREN_Pos)
27420#define HRTIM_BMCR_BMPREN HRTIM_BMCR_BMPREN_Msk
27421#define HRTIM_BMCR_MTBM_Pos (16U)
27422#define HRTIM_BMCR_MTBM_Msk (0x1UL << HRTIM_BMCR_MTBM_Pos)
27423#define HRTIM_BMCR_MTBM HRTIM_BMCR_MTBM_Msk
27424#define HRTIM_BMCR_TABM_Pos (17U)
27425#define HRTIM_BMCR_TABM_Msk (0x1UL << HRTIM_BMCR_TABM_Pos)
27426#define HRTIM_BMCR_TABM HRTIM_BMCR_TABM_Msk
27427#define HRTIM_BMCR_TBBM_Pos (18U)
27428#define HRTIM_BMCR_TBBM_Msk (0x1UL << HRTIM_BMCR_TBBM_Pos)
27429#define HRTIM_BMCR_TBBM HRTIM_BMCR_TBBM_Msk
27430#define HRTIM_BMCR_TCBM_Pos (19U)
27431#define HRTIM_BMCR_TCBM_Msk (0x1UL << HRTIM_BMCR_TCBM_Pos)
27432#define HRTIM_BMCR_TCBM HRTIM_BMCR_TCBM_Msk
27433#define HRTIM_BMCR_TDBM_Pos (20U)
27434#define HRTIM_BMCR_TDBM_Msk (0x1UL << HRTIM_BMCR_TDBM_Pos)
27435#define HRTIM_BMCR_TDBM HRTIM_BMCR_TDBM_Msk
27436#define HRTIM_BMCR_TEBM_Pos (21U)
27437#define HRTIM_BMCR_TEBM_Msk (0x1UL << HRTIM_BMCR_TEBM_Pos)
27438#define HRTIM_BMCR_TEBM HRTIM_BMCR_TEBM_Msk
27439#define HRTIM_BMCR_BMSTAT_Pos (31U)
27440#define HRTIM_BMCR_BMSTAT_Msk (0x1UL << HRTIM_BMCR_BMSTAT_Pos)
27441#define HRTIM_BMCR_BMSTAT HRTIM_BMCR_BMSTAT_Msk
27443/**** Bit definition for Common HRTIM Timer Burst mode Trigger register *******/
27444#define HRTIM_BMTRGR_SW_Pos (0U)
27445#define HRTIM_BMTRGR_SW_Msk (0x1UL << HRTIM_BMTRGR_SW_Pos)
27446#define HRTIM_BMTRGR_SW HRTIM_BMTRGR_SW_Msk
27447#define HRTIM_BMTRGR_MSTRST_Pos (1U)
27448#define HRTIM_BMTRGR_MSTRST_Msk (0x1UL << HRTIM_BMTRGR_MSTRST_Pos)
27449#define HRTIM_BMTRGR_MSTRST HRTIM_BMTRGR_MSTRST_Msk
27450#define HRTIM_BMTRGR_MSTREP_Pos (2U)
27451#define HRTIM_BMTRGR_MSTREP_Msk (0x1UL << HRTIM_BMTRGR_MSTREP_Pos)
27452#define HRTIM_BMTRGR_MSTREP HRTIM_BMTRGR_MSTREP_Msk
27453#define HRTIM_BMTRGR_MSTCMP1_Pos (3U)
27454#define HRTIM_BMTRGR_MSTCMP1_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP1_Pos)
27455#define HRTIM_BMTRGR_MSTCMP1 HRTIM_BMTRGR_MSTCMP1_Msk
27456#define HRTIM_BMTRGR_MSTCMP2_Pos (4U)
27457#define HRTIM_BMTRGR_MSTCMP2_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP2_Pos)
27458#define HRTIM_BMTRGR_MSTCMP2 HRTIM_BMTRGR_MSTCMP2_Msk
27459#define HRTIM_BMTRGR_MSTCMP3_Pos (5U)
27460#define HRTIM_BMTRGR_MSTCMP3_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP3_Pos)
27461#define HRTIM_BMTRGR_MSTCMP3 HRTIM_BMTRGR_MSTCMP3_Msk
27462#define HRTIM_BMTRGR_MSTCMP4_Pos (6U)
27463#define HRTIM_BMTRGR_MSTCMP4_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP4_Pos)
27464#define HRTIM_BMTRGR_MSTCMP4 HRTIM_BMTRGR_MSTCMP4_Msk
27465#define HRTIM_BMTRGR_TARST_Pos (7U)
27466#define HRTIM_BMTRGR_TARST_Msk (0x1UL << HRTIM_BMTRGR_TARST_Pos)
27467#define HRTIM_BMTRGR_TARST HRTIM_BMTRGR_TARST_Msk
27468#define HRTIM_BMTRGR_TAREP_Pos (8U)
27469#define HRTIM_BMTRGR_TAREP_Msk (0x1UL << HRTIM_BMTRGR_TAREP_Pos)
27470#define HRTIM_BMTRGR_TAREP HRTIM_BMTRGR_TAREP_Msk
27471#define HRTIM_BMTRGR_TACMP1_Pos (9U)
27472#define HRTIM_BMTRGR_TACMP1_Msk (0x1UL << HRTIM_BMTRGR_TACMP1_Pos)
27473#define HRTIM_BMTRGR_TACMP1 HRTIM_BMTRGR_TACMP1_Msk
27474#define HRTIM_BMTRGR_TACMP2_Pos (10U)
27475#define HRTIM_BMTRGR_TACMP2_Msk (0x1UL << HRTIM_BMTRGR_TACMP2_Pos)
27476#define HRTIM_BMTRGR_TACMP2 HRTIM_BMTRGR_TACMP2_Msk
27477#define HRTIM_BMTRGR_TBRST_Pos (11U)
27478#define HRTIM_BMTRGR_TBRST_Msk (0x1UL << HRTIM_BMTRGR_TBRST_Pos)
27479#define HRTIM_BMTRGR_TBRST HRTIM_BMTRGR_TBRST_Msk
27480#define HRTIM_BMTRGR_TBREP_Pos (12U)
27481#define HRTIM_BMTRGR_TBREP_Msk (0x1UL << HRTIM_BMTRGR_TBREP_Pos)
27482#define HRTIM_BMTRGR_TBREP HRTIM_BMTRGR_TBREP_Msk
27483#define HRTIM_BMTRGR_TBCMP1_Pos (13U)
27484#define HRTIM_BMTRGR_TBCMP1_Msk (0x1UL << HRTIM_BMTRGR_TBCMP1_Pos)
27485#define HRTIM_BMTRGR_TBCMP1 HRTIM_BMTRGR_TBCMP1_Msk
27486#define HRTIM_BMTRGR_TBCMP2_Pos (14U)
27487#define HRTIM_BMTRGR_TBCMP2_Msk (0x1UL << HRTIM_BMTRGR_TBCMP2_Pos)
27488#define HRTIM_BMTRGR_TBCMP2 HRTIM_BMTRGR_TBCMP2_Msk
27489#define HRTIM_BMTRGR_TCRST_Pos (15U)
27490#define HRTIM_BMTRGR_TCRST_Msk (0x1UL << HRTIM_BMTRGR_TCRST_Pos)
27491#define HRTIM_BMTRGR_TCRST HRTIM_BMTRGR_TCRST_Msk
27492#define HRTIM_BMTRGR_TCREP_Pos (16U)
27493#define HRTIM_BMTRGR_TCREP_Msk (0x1UL << HRTIM_BMTRGR_TCREP_Pos)
27494#define HRTIM_BMTRGR_TCREP HRTIM_BMTRGR_TCREP_Msk
27495#define HRTIM_BMTRGR_TCCMP1_Pos (17U)
27496#define HRTIM_BMTRGR_TCCMP1_Msk (0x1UL << HRTIM_BMTRGR_TCCMP1_Pos)
27497#define HRTIM_BMTRGR_TCCMP1 HRTIM_BMTRGR_TCCMP1_Msk
27498#define HRTIM_BMTRGR_TCCMP2_Pos (18U)
27499#define HRTIM_BMTRGR_TCCMP2_Msk (0x1UL << HRTIM_BMTRGR_TCCMP2_Pos)
27500#define HRTIM_BMTRGR_TCCMP2 HRTIM_BMTRGR_TCCMP2_Msk
27501#define HRTIM_BMTRGR_TDRST_Pos (19U)
27502#define HRTIM_BMTRGR_TDRST_Msk (0x1UL << HRTIM_BMTRGR_TDRST_Pos)
27503#define HRTIM_BMTRGR_TDRST HRTIM_BMTRGR_TDRST_Msk
27504#define HRTIM_BMTRGR_TDREP_Pos (20U)
27505#define HRTIM_BMTRGR_TDREP_Msk (0x1UL << HRTIM_BMTRGR_TDREP_Pos)
27506#define HRTIM_BMTRGR_TDREP HRTIM_BMTRGR_TDREP_Msk
27507#define HRTIM_BMTRGR_TDCMP1_Pos (21U)
27508#define HRTIM_BMTRGR_TDCMP1_Msk (0x1UL << HRTIM_BMTRGR_TDCMP1_Pos)
27509#define HRTIM_BMTRGR_TDCMP1 HRTIM_BMTRGR_TDCMP1_Msk
27510#define HRTIM_BMTRGR_TDCMP2_Pos (22U)
27511#define HRTIM_BMTRGR_TDCMP2_Msk (0x1UL << HRTIM_BMTRGR_TDCMP2_Pos)
27512#define HRTIM_BMTRGR_TDCMP2 HRTIM_BMTRGR_TDCMP2_Msk
27513#define HRTIM_BMTRGR_TERST_Pos (23U)
27514#define HRTIM_BMTRGR_TERST_Msk (0x1UL << HRTIM_BMTRGR_TERST_Pos)
27515#define HRTIM_BMTRGR_TERST HRTIM_BMTRGR_TERST_Msk
27516#define HRTIM_BMTRGR_TEREP_Pos (24U)
27517#define HRTIM_BMTRGR_TEREP_Msk (0x1UL << HRTIM_BMTRGR_TEREP_Pos)
27518#define HRTIM_BMTRGR_TEREP HRTIM_BMTRGR_TEREP_Msk
27519#define HRTIM_BMTRGR_TECMP1_Pos (25U)
27520#define HRTIM_BMTRGR_TECMP1_Msk (0x1UL << HRTIM_BMTRGR_TECMP1_Pos)
27521#define HRTIM_BMTRGR_TECMP1 HRTIM_BMTRGR_TECMP1_Msk
27522#define HRTIM_BMTRGR_TECMP2_Pos (26U)
27523#define HRTIM_BMTRGR_TECMP2_Msk (0x1UL << HRTIM_BMTRGR_TECMP2_Pos)
27524#define HRTIM_BMTRGR_TECMP2 HRTIM_BMTRGR_TECMP2_Msk
27525#define HRTIM_BMTRGR_TAEEV7_Pos (27U)
27526#define HRTIM_BMTRGR_TAEEV7_Msk (0x1UL << HRTIM_BMTRGR_TAEEV7_Pos)
27527#define HRTIM_BMTRGR_TAEEV7 HRTIM_BMTRGR_TAEEV7_Msk
27528#define HRTIM_BMTRGR_TDEEV8_Pos (28U)
27529#define HRTIM_BMTRGR_TDEEV8_Msk (0x1UL << HRTIM_BMTRGR_TDEEV8_Pos)
27530#define HRTIM_BMTRGR_TDEEV8 HRTIM_BMTRGR_TDEEV8_Msk
27531#define HRTIM_BMTRGR_EEV7_Pos (29U)
27532#define HRTIM_BMTRGR_EEV7_Msk (0x1UL << HRTIM_BMTRGR_EEV7_Pos)
27533#define HRTIM_BMTRGR_EEV7 HRTIM_BMTRGR_EEV7_Msk
27534#define HRTIM_BMTRGR_EEV8_Pos (30U)
27535#define HRTIM_BMTRGR_EEV8_Msk (0x1UL << HRTIM_BMTRGR_EEV8_Pos)
27536#define HRTIM_BMTRGR_EEV8 HRTIM_BMTRGR_EEV8_Msk
27537#define HRTIM_BMTRGR_OCHPEV_Pos (31U)
27538#define HRTIM_BMTRGR_OCHPEV_Msk (0x1UL << HRTIM_BMTRGR_OCHPEV_Pos)
27539#define HRTIM_BMTRGR_OCHPEV HRTIM_BMTRGR_OCHPEV_Msk
27541/******************* Bit definition for HRTIM_BMCMPR register ***************/
27542#define HRTIM_BMCMPR_BMCMPR_Pos (0U)
27543#define HRTIM_BMCMPR_BMCMPR_Msk (0xFFFFUL << HRTIM_BMCMPR_BMCMPR_Pos)
27544#define HRTIM_BMCMPR_BMCMPR HRTIM_BMCMPR_BMCMPR_Msk
27546/******************* Bit definition for HRTIM_BMPER register ****************/
27547#define HRTIM_BMPER_BMPER_Pos (0U)
27548#define HRTIM_BMPER_BMPER_Msk (0xFFFFUL << HRTIM_BMPER_BMPER_Pos)
27549#define HRTIM_BMPER_BMPER HRTIM_BMPER_BMPER_Msk
27551/******************* Bit definition for HRTIM_EECR1 register ****************/
27552#define HRTIM_EECR1_EE1SRC_Pos (0U)
27553#define HRTIM_EECR1_EE1SRC_Msk (0x3UL << HRTIM_EECR1_EE1SRC_Pos)
27554#define HRTIM_EECR1_EE1SRC HRTIM_EECR1_EE1SRC_Msk
27555#define HRTIM_EECR1_EE1SRC_0 (0x1UL << HRTIM_EECR1_EE1SRC_Pos)
27556#define HRTIM_EECR1_EE1SRC_1 (0x2UL << HRTIM_EECR1_EE1SRC_Pos)
27557#define HRTIM_EECR1_EE1POL_Pos (2U)
27558#define HRTIM_EECR1_EE1POL_Msk (0x1UL << HRTIM_EECR1_EE1POL_Pos)
27559#define HRTIM_EECR1_EE1POL HRTIM_EECR1_EE1POL_Msk
27560#define HRTIM_EECR1_EE1SNS_Pos (3U)
27561#define HRTIM_EECR1_EE1SNS_Msk (0x3UL << HRTIM_EECR1_EE1SNS_Pos)
27562#define HRTIM_EECR1_EE1SNS HRTIM_EECR1_EE1SNS_Msk
27563#define HRTIM_EECR1_EE1SNS_0 (0x1UL << HRTIM_EECR1_EE1SNS_Pos)
27564#define HRTIM_EECR1_EE1SNS_1 (0x2UL << HRTIM_EECR1_EE1SNS_Pos)
27565#define HRTIM_EECR1_EE1FAST_Pos (5U)
27566#define HRTIM_EECR1_EE1FAST_Msk (0x1UL << HRTIM_EECR1_EE1FAST_Pos)
27567#define HRTIM_EECR1_EE1FAST HRTIM_EECR1_EE1FAST_Msk
27569#define HRTIM_EECR1_EE2SRC_Pos (6U)
27570#define HRTIM_EECR1_EE2SRC_Msk (0x3UL << HRTIM_EECR1_EE2SRC_Pos)
27571#define HRTIM_EECR1_EE2SRC HRTIM_EECR1_EE2SRC_Msk
27572#define HRTIM_EECR1_EE2SRC_0 (0x1UL << HRTIM_EECR1_EE2SRC_Pos)
27573#define HRTIM_EECR1_EE2SRC_1 (0x2UL << HRTIM_EECR1_EE2SRC_Pos)
27574#define HRTIM_EECR1_EE2POL_Pos (8U)
27575#define HRTIM_EECR1_EE2POL_Msk (0x1UL << HRTIM_EECR1_EE2POL_Pos)
27576#define HRTIM_EECR1_EE2POL HRTIM_EECR1_EE2POL_Msk
27577#define HRTIM_EECR1_EE2SNS_Pos (9U)
27578#define HRTIM_EECR1_EE2SNS_Msk (0x3UL << HRTIM_EECR1_EE2SNS_Pos)
27579#define HRTIM_EECR1_EE2SNS HRTIM_EECR1_EE2SNS_Msk
27580#define HRTIM_EECR1_EE2SNS_0 (0x1UL << HRTIM_EECR1_EE2SNS_Pos)
27581#define HRTIM_EECR1_EE2SNS_1 (0x2UL << HRTIM_EECR1_EE2SNS_Pos)
27582#define HRTIM_EECR1_EE2FAST_Pos (11U)
27583#define HRTIM_EECR1_EE2FAST_Msk (0x1UL << HRTIM_EECR1_EE2FAST_Pos)
27584#define HRTIM_EECR1_EE2FAST HRTIM_EECR1_EE2FAST_Msk
27586#define HRTIM_EECR1_EE3SRC_Pos (12U)
27587#define HRTIM_EECR1_EE3SRC_Msk (0x3UL << HRTIM_EECR1_EE3SRC_Pos)
27588#define HRTIM_EECR1_EE3SRC HRTIM_EECR1_EE3SRC_Msk
27589#define HRTIM_EECR1_EE3SRC_0 (0x1UL << HRTIM_EECR1_EE3SRC_Pos)
27590#define HRTIM_EECR1_EE3SRC_1 (0x2UL << HRTIM_EECR1_EE3SRC_Pos)
27591#define HRTIM_EECR1_EE3POL_Pos (14U)
27592#define HRTIM_EECR1_EE3POL_Msk (0x1UL << HRTIM_EECR1_EE3POL_Pos)
27593#define HRTIM_EECR1_EE3POL HRTIM_EECR1_EE3POL_Msk
27594#define HRTIM_EECR1_EE3SNS_Pos (15U)
27595#define HRTIM_EECR1_EE3SNS_Msk (0x3UL << HRTIM_EECR1_EE3SNS_Pos)
27596#define HRTIM_EECR1_EE3SNS HRTIM_EECR1_EE3SNS_Msk
27597#define HRTIM_EECR1_EE3SNS_0 (0x1UL << HRTIM_EECR1_EE3SNS_Pos)
27598#define HRTIM_EECR1_EE3SNS_1 (0x2UL << HRTIM_EECR1_EE3SNS_Pos)
27599#define HRTIM_EECR1_EE3FAST_Pos (17U)
27600#define HRTIM_EECR1_EE3FAST_Msk (0x1UL << HRTIM_EECR1_EE3FAST_Pos)
27601#define HRTIM_EECR1_EE3FAST HRTIM_EECR1_EE3FAST_Msk
27603#define HRTIM_EECR1_EE4SRC_Pos (18U)
27604#define HRTIM_EECR1_EE4SRC_Msk (0x3UL << HRTIM_EECR1_EE4SRC_Pos)
27605#define HRTIM_EECR1_EE4SRC HRTIM_EECR1_EE4SRC_Msk
27606#define HRTIM_EECR1_EE4SRC_0 (0x1UL << HRTIM_EECR1_EE4SRC_Pos)
27607#define HRTIM_EECR1_EE4SRC_1 (0x2UL << HRTIM_EECR1_EE4SRC_Pos)
27608#define HRTIM_EECR1_EE4POL_Pos (20U)
27609#define HRTIM_EECR1_EE4POL_Msk (0x1UL << HRTIM_EECR1_EE4POL_Pos)
27610#define HRTIM_EECR1_EE4POL HRTIM_EECR1_EE4POL_Msk
27611#define HRTIM_EECR1_EE4SNS_Pos (21U)
27612#define HRTIM_EECR1_EE4SNS_Msk (0x3UL << HRTIM_EECR1_EE4SNS_Pos)
27613#define HRTIM_EECR1_EE4SNS HRTIM_EECR1_EE4SNS_Msk
27614#define HRTIM_EECR1_EE4SNS_0 (0x1UL << HRTIM_EECR1_EE4SNS_Pos)
27615#define HRTIM_EECR1_EE4SNS_1 (0x2UL << HRTIM_EECR1_EE4SNS_Pos)
27616#define HRTIM_EECR1_EE4FAST_Pos (23U)
27617#define HRTIM_EECR1_EE4FAST_Msk (0x1UL << HRTIM_EECR1_EE4FAST_Pos)
27618#define HRTIM_EECR1_EE4FAST HRTIM_EECR1_EE4FAST_Msk
27620#define HRTIM_EECR1_EE5SRC_Pos (24U)
27621#define HRTIM_EECR1_EE5SRC_Msk (0x3UL << HRTIM_EECR1_EE5SRC_Pos)
27622#define HRTIM_EECR1_EE5SRC HRTIM_EECR1_EE5SRC_Msk
27623#define HRTIM_EECR1_EE5SRC_0 (0x1UL << HRTIM_EECR1_EE5SRC_Pos)
27624#define HRTIM_EECR1_EE5SRC_1 (0x2UL << HRTIM_EECR1_EE5SRC_Pos)
27625#define HRTIM_EECR1_EE5POL_Pos (26U)
27626#define HRTIM_EECR1_EE5POL_Msk (0x1UL << HRTIM_EECR1_EE5POL_Pos)
27627#define HRTIM_EECR1_EE5POL HRTIM_EECR1_EE5POL_Msk
27628#define HRTIM_EECR1_EE5SNS_Pos (27U)
27629#define HRTIM_EECR1_EE5SNS_Msk (0x3UL << HRTIM_EECR1_EE5SNS_Pos)
27630#define HRTIM_EECR1_EE5SNS HRTIM_EECR1_EE5SNS_Msk
27631#define HRTIM_EECR1_EE5SNS_0 (0x1UL << HRTIM_EECR1_EE5SNS_Pos)
27632#define HRTIM_EECR1_EE5SNS_1 (0x2UL << HRTIM_EECR1_EE5SNS_Pos)
27633#define HRTIM_EECR1_EE5FAST_Pos (29U)
27634#define HRTIM_EECR1_EE5FAST_Msk (0x1UL << HRTIM_EECR1_EE5FAST_Pos)
27635#define HRTIM_EECR1_EE5FAST HRTIM_EECR1_EE5FAST_Msk
27637/******************* Bit definition for HRTIM_EECR2 register ****************/
27638#define HRTIM_EECR2_EE6SRC_Pos (0U)
27639#define HRTIM_EECR2_EE6SRC_Msk (0x3UL << HRTIM_EECR2_EE6SRC_Pos)
27640#define HRTIM_EECR2_EE6SRC HRTIM_EECR2_EE6SRC_Msk
27641#define HRTIM_EECR2_EE6SRC_0 (0x1UL << HRTIM_EECR2_EE6SRC_Pos)
27642#define HRTIM_EECR2_EE6SRC_1 (0x2UL << HRTIM_EECR2_EE6SRC_Pos)
27643#define HRTIM_EECR2_EE6POL_Pos (2U)
27644#define HRTIM_EECR2_EE6POL_Msk (0x1UL << HRTIM_EECR2_EE6POL_Pos)
27645#define HRTIM_EECR2_EE6POL HRTIM_EECR2_EE6POL_Msk
27646#define HRTIM_EECR2_EE6SNS_Pos (3U)
27647#define HRTIM_EECR2_EE6SNS_Msk (0x3UL << HRTIM_EECR2_EE6SNS_Pos)
27648#define HRTIM_EECR2_EE6SNS HRTIM_EECR2_EE6SNS_Msk
27649#define HRTIM_EECR2_EE6SNS_0 (0x1UL << HRTIM_EECR2_EE6SNS_Pos)
27650#define HRTIM_EECR2_EE6SNS_1 (0x2UL << HRTIM_EECR2_EE6SNS_Pos)
27652#define HRTIM_EECR2_EE7SRC_Pos (6U)
27653#define HRTIM_EECR2_EE7SRC_Msk (0x3UL << HRTIM_EECR2_EE7SRC_Pos)
27654#define HRTIM_EECR2_EE7SRC HRTIM_EECR2_EE7SRC_Msk
27655#define HRTIM_EECR2_EE7SRC_0 (0x1UL << HRTIM_EECR2_EE7SRC_Pos)
27656#define HRTIM_EECR2_EE7SRC_1 (0x2UL << HRTIM_EECR2_EE7SRC_Pos)
27657#define HRTIM_EECR2_EE7POL_Pos (8U)
27658#define HRTIM_EECR2_EE7POL_Msk (0x1UL << HRTIM_EECR2_EE7POL_Pos)
27659#define HRTIM_EECR2_EE7POL HRTIM_EECR2_EE7POL_Msk
27660#define HRTIM_EECR2_EE7SNS_Pos (9U)
27661#define HRTIM_EECR2_EE7SNS_Msk (0x3UL << HRTIM_EECR2_EE7SNS_Pos)
27662#define HRTIM_EECR2_EE7SNS HRTIM_EECR2_EE7SNS_Msk
27663#define HRTIM_EECR2_EE7SNS_0 (0x1UL << HRTIM_EECR2_EE7SNS_Pos)
27664#define HRTIM_EECR2_EE7SNS_1 (0x2UL << HRTIM_EECR2_EE7SNS_Pos)
27666#define HRTIM_EECR2_EE8SRC_Pos (12U)
27667#define HRTIM_EECR2_EE8SRC_Msk (0x3UL << HRTIM_EECR2_EE8SRC_Pos)
27668#define HRTIM_EECR2_EE8SRC HRTIM_EECR2_EE8SRC_Msk
27669#define HRTIM_EECR2_EE8SRC_0 (0x1UL << HRTIM_EECR2_EE8SRC_Pos)
27670#define HRTIM_EECR2_EE8SRC_1 (0x2UL << HRTIM_EECR2_EE8SRC_Pos)
27671#define HRTIM_EECR2_EE8POL_Pos (14U)
27672#define HRTIM_EECR2_EE8POL_Msk (0x1UL << HRTIM_EECR2_EE8POL_Pos)
27673#define HRTIM_EECR2_EE8POL HRTIM_EECR2_EE8POL_Msk
27674#define HRTIM_EECR2_EE8SNS_Pos (15U)
27675#define HRTIM_EECR2_EE8SNS_Msk (0x3UL << HRTIM_EECR2_EE8SNS_Pos)
27676#define HRTIM_EECR2_EE8SNS HRTIM_EECR2_EE8SNS_Msk
27677#define HRTIM_EECR2_EE8SNS_0 (0x1UL << HRTIM_EECR2_EE8SNS_Pos)
27678#define HRTIM_EECR2_EE8SNS_1 (0x2UL << HRTIM_EECR2_EE8SNS_Pos)
27680#define HRTIM_EECR2_EE9SRC_Pos (18U)
27681#define HRTIM_EECR2_EE9SRC_Msk (0x3UL << HRTIM_EECR2_EE9SRC_Pos)
27682#define HRTIM_EECR2_EE9SRC HRTIM_EECR2_EE9SRC_Msk
27683#define HRTIM_EECR2_EE9SRC_0 (0x1UL << HRTIM_EECR2_EE9SRC_Pos)
27684#define HRTIM_EECR2_EE9SRC_1 (0x2UL << HRTIM_EECR2_EE9SRC_Pos)
27685#define HRTIM_EECR2_EE9POL_Pos (20U)
27686#define HRTIM_EECR2_EE9POL_Msk (0x1UL << HRTIM_EECR2_EE9POL_Pos)
27687#define HRTIM_EECR2_EE9POL HRTIM_EECR2_EE9POL_Msk
27688#define HRTIM_EECR2_EE9SNS_Pos (21U)
27689#define HRTIM_EECR2_EE9SNS_Msk (0x3UL << HRTIM_EECR2_EE9SNS_Pos)
27690#define HRTIM_EECR2_EE9SNS HRTIM_EECR2_EE9SNS_Msk
27691#define HRTIM_EECR2_EE9SNS_0 (0x1UL << HRTIM_EECR2_EE9SNS_Pos)
27692#define HRTIM_EECR2_EE9SNS_1 (0x2UL << HRTIM_EECR2_EE9SNS_Pos)
27694#define HRTIM_EECR2_EE10SRC_Pos (24U)
27695#define HRTIM_EECR2_EE10SRC_Msk (0x3UL << HRTIM_EECR2_EE10SRC_Pos)
27696#define HRTIM_EECR2_EE10SRC HRTIM_EECR2_EE10SRC_Msk
27697#define HRTIM_EECR2_EE10SRC_0 (0x1UL << HRTIM_EECR2_EE10SRC_Pos)
27698#define HRTIM_EECR2_EE10SRC_1 (0x2UL << HRTIM_EECR2_EE10SRC_Pos)
27699#define HRTIM_EECR2_EE10POL_Pos (26U)
27700#define HRTIM_EECR2_EE10POL_Msk (0x1UL << HRTIM_EECR2_EE10POL_Pos)
27701#define HRTIM_EECR2_EE10POL HRTIM_EECR2_EE10POL_Msk
27702#define HRTIM_EECR2_EE10SNS_Pos (27U)
27703#define HRTIM_EECR2_EE10SNS_Msk (0x3UL << HRTIM_EECR2_EE10SNS_Pos)
27704#define HRTIM_EECR2_EE10SNS HRTIM_EECR2_EE10SNS_Msk
27705#define HRTIM_EECR2_EE10SNS_0 (0x1UL << HRTIM_EECR2_EE10SNS_Pos)
27706#define HRTIM_EECR2_EE10SNS_1 (0x2UL << HRTIM_EECR2_EE10SNS_Pos)
27708/******************* Bit definition for HRTIM_EECR3 register ****************/
27709#define HRTIM_EECR3_EE6F_Pos (0U)
27710#define HRTIM_EECR3_EE6F_Msk (0xFUL << HRTIM_EECR3_EE6F_Pos)
27711#define HRTIM_EECR3_EE6F HRTIM_EECR3_EE6F_Msk
27712#define HRTIM_EECR3_EE6F_0 (0x1UL << HRTIM_EECR3_EE6F_Pos)
27713#define HRTIM_EECR3_EE6F_1 (0x2UL << HRTIM_EECR3_EE6F_Pos)
27714#define HRTIM_EECR3_EE6F_2 (0x4UL << HRTIM_EECR3_EE6F_Pos)
27715#define HRTIM_EECR3_EE6F_3 (0x8UL << HRTIM_EECR3_EE6F_Pos)
27716#define HRTIM_EECR3_EE7F_Pos (6U)
27717#define HRTIM_EECR3_EE7F_Msk (0xFUL << HRTIM_EECR3_EE7F_Pos)
27718#define HRTIM_EECR3_EE7F HRTIM_EECR3_EE7F_Msk
27719#define HRTIM_EECR3_EE7F_0 (0x1UL << HRTIM_EECR3_EE7F_Pos)
27720#define HRTIM_EECR3_EE7F_1 (0x2UL << HRTIM_EECR3_EE7F_Pos)
27721#define HRTIM_EECR3_EE7F_2 (0x4UL << HRTIM_EECR3_EE7F_Pos)
27722#define HRTIM_EECR3_EE7F_3 (0x8UL << HRTIM_EECR3_EE7F_Pos)
27723#define HRTIM_EECR3_EE8F_Pos (12U)
27724#define HRTIM_EECR3_EE8F_Msk (0xFUL << HRTIM_EECR3_EE8F_Pos)
27725#define HRTIM_EECR3_EE8F HRTIM_EECR3_EE8F_Msk
27726#define HRTIM_EECR3_EE8F_0 (0x1UL << HRTIM_EECR3_EE8F_Pos)
27727#define HRTIM_EECR3_EE8F_1 (0x2UL << HRTIM_EECR3_EE8F_Pos)
27728#define HRTIM_EECR3_EE8F_2 (0x4UL << HRTIM_EECR3_EE8F_Pos)
27729#define HRTIM_EECR3_EE8F_3 (0x8UL << HRTIM_EECR3_EE8F_Pos)
27730#define HRTIM_EECR3_EE9F_Pos (18U)
27731#define HRTIM_EECR3_EE9F_Msk (0xFUL << HRTIM_EECR3_EE9F_Pos)
27732#define HRTIM_EECR3_EE9F HRTIM_EECR3_EE9F_Msk
27733#define HRTIM_EECR3_EE9F_0 (0x1UL << HRTIM_EECR3_EE9F_Pos)
27734#define HRTIM_EECR3_EE9F_1 (0x2UL << HRTIM_EECR3_EE9F_Pos)
27735#define HRTIM_EECR3_EE9F_2 (0x4UL << HRTIM_EECR3_EE9F_Pos)
27736#define HRTIM_EECR3_EE9F_3 (0x8UL << HRTIM_EECR3_EE9F_Pos)
27737#define HRTIM_EECR3_EE10F_Pos (24U)
27738#define HRTIM_EECR3_EE10F_Msk (0xFUL << HRTIM_EECR3_EE10F_Pos)
27739#define HRTIM_EECR3_EE10F HRTIM_EECR3_EE10F_Msk
27740#define HRTIM_EECR3_EE10F_0 (0x1UL << HRTIM_EECR3_EE10F_Pos)
27741#define HRTIM_EECR3_EE10F_1 (0x2UL << HRTIM_EECR3_EE10F_Pos)
27742#define HRTIM_EECR3_EE10F_2 (0x4UL << HRTIM_EECR3_EE10F_Pos)
27743#define HRTIM_EECR3_EE10F_3 (0x8UL << HRTIM_EECR3_EE10F_Pos)
27744#define HRTIM_EECR3_EEVSD_Pos (30U)
27745#define HRTIM_EECR3_EEVSD_Msk (0x3UL << HRTIM_EECR3_EEVSD_Pos)
27746#define HRTIM_EECR3_EEVSD HRTIM_EECR3_EEVSD_Msk
27747#define HRTIM_EECR3_EEVSD_0 (0x1UL << HRTIM_EECR3_EEVSD_Pos)
27748#define HRTIM_EECR3_EEVSD_1 (0x2UL << HRTIM_EECR3_EEVSD_Pos)
27750/******************* Bit definition for HRTIM_ADC1R register ****************/
27751#define HRTIM_ADC1R_AD1MC1_Pos (0U)
27752#define HRTIM_ADC1R_AD1MC1_Msk (0x1UL << HRTIM_ADC1R_AD1MC1_Pos)
27753#define HRTIM_ADC1R_AD1MC1 HRTIM_ADC1R_AD1MC1_Msk
27754#define HRTIM_ADC1R_AD1MC2_Pos (1U)
27755#define HRTIM_ADC1R_AD1MC2_Msk (0x1UL << HRTIM_ADC1R_AD1MC2_Pos)
27756#define HRTIM_ADC1R_AD1MC2 HRTIM_ADC1R_AD1MC2_Msk
27757#define HRTIM_ADC1R_AD1MC3_Pos (2U)
27758#define HRTIM_ADC1R_AD1MC3_Msk (0x1UL << HRTIM_ADC1R_AD1MC3_Pos)
27759#define HRTIM_ADC1R_AD1MC3 HRTIM_ADC1R_AD1MC3_Msk
27760#define HRTIM_ADC1R_AD1MC4_Pos (3U)
27761#define HRTIM_ADC1R_AD1MC4_Msk (0x1UL << HRTIM_ADC1R_AD1MC4_Pos)
27762#define HRTIM_ADC1R_AD1MC4 HRTIM_ADC1R_AD1MC4_Msk
27763#define HRTIM_ADC1R_AD1MPER_Pos (4U)
27764#define HRTIM_ADC1R_AD1MPER_Msk (0x1UL << HRTIM_ADC1R_AD1MPER_Pos)
27765#define HRTIM_ADC1R_AD1MPER HRTIM_ADC1R_AD1MPER_Msk
27766#define HRTIM_ADC1R_AD1EEV1_Pos (5U)
27767#define HRTIM_ADC1R_AD1EEV1_Msk (0x1UL << HRTIM_ADC1R_AD1EEV1_Pos)
27768#define HRTIM_ADC1R_AD1EEV1 HRTIM_ADC1R_AD1EEV1_Msk
27769#define HRTIM_ADC1R_AD1EEV2_Pos (6U)
27770#define HRTIM_ADC1R_AD1EEV2_Msk (0x1UL << HRTIM_ADC1R_AD1EEV2_Pos)
27771#define HRTIM_ADC1R_AD1EEV2 HRTIM_ADC1R_AD1EEV2_Msk
27772#define HRTIM_ADC1R_AD1EEV3_Pos (7U)
27773#define HRTIM_ADC1R_AD1EEV3_Msk (0x1UL << HRTIM_ADC1R_AD1EEV3_Pos)
27774#define HRTIM_ADC1R_AD1EEV3 HRTIM_ADC1R_AD1EEV3_Msk
27775#define HRTIM_ADC1R_AD1EEV4_Pos (8U)
27776#define HRTIM_ADC1R_AD1EEV4_Msk (0x1UL << HRTIM_ADC1R_AD1EEV4_Pos)
27777#define HRTIM_ADC1R_AD1EEV4 HRTIM_ADC1R_AD1EEV4_Msk
27778#define HRTIM_ADC1R_AD1EEV5_Pos (9U)
27779#define HRTIM_ADC1R_AD1EEV5_Msk (0x1UL << HRTIM_ADC1R_AD1EEV5_Pos)
27780#define HRTIM_ADC1R_AD1EEV5 HRTIM_ADC1R_AD1EEV5_Msk
27781#define HRTIM_ADC1R_AD1TAC2_Pos (10U)
27782#define HRTIM_ADC1R_AD1TAC2_Msk (0x1UL << HRTIM_ADC1R_AD1TAC2_Pos)
27783#define HRTIM_ADC1R_AD1TAC2 HRTIM_ADC1R_AD1TAC2_Msk
27784#define HRTIM_ADC1R_AD1TAC3_Pos (11U)
27785#define HRTIM_ADC1R_AD1TAC3_Msk (0x1UL << HRTIM_ADC1R_AD1TAC3_Pos)
27786#define HRTIM_ADC1R_AD1TAC3 HRTIM_ADC1R_AD1TAC3_Msk
27787#define HRTIM_ADC1R_AD1TAC4_Pos (12U)
27788#define HRTIM_ADC1R_AD1TAC4_Msk (0x1UL << HRTIM_ADC1R_AD1TAC4_Pos)
27789#define HRTIM_ADC1R_AD1TAC4 HRTIM_ADC1R_AD1TAC4_Msk
27790#define HRTIM_ADC1R_AD1TAPER_Pos (13U)
27791#define HRTIM_ADC1R_AD1TAPER_Msk (0x1UL << HRTIM_ADC1R_AD1TAPER_Pos)
27792#define HRTIM_ADC1R_AD1TAPER HRTIM_ADC1R_AD1TAPER_Msk
27793#define HRTIM_ADC1R_AD1TARST_Pos (14U)
27794#define HRTIM_ADC1R_AD1TARST_Msk (0x1UL << HRTIM_ADC1R_AD1TARST_Pos)
27795#define HRTIM_ADC1R_AD1TARST HRTIM_ADC1R_AD1TARST_Msk
27796#define HRTIM_ADC1R_AD1TBC2_Pos (15U)
27797#define HRTIM_ADC1R_AD1TBC2_Msk (0x1UL << HRTIM_ADC1R_AD1TBC2_Pos)
27798#define HRTIM_ADC1R_AD1TBC2 HRTIM_ADC1R_AD1TBC2_Msk
27799#define HRTIM_ADC1R_AD1TBC3_Pos (16U)
27800#define HRTIM_ADC1R_AD1TBC3_Msk (0x1UL << HRTIM_ADC1R_AD1TBC3_Pos)
27801#define HRTIM_ADC1R_AD1TBC3 HRTIM_ADC1R_AD1TBC3_Msk
27802#define HRTIM_ADC1R_AD1TBC4_Pos (17U)
27803#define HRTIM_ADC1R_AD1TBC4_Msk (0x1UL << HRTIM_ADC1R_AD1TBC4_Pos)
27804#define HRTIM_ADC1R_AD1TBC4 HRTIM_ADC1R_AD1TBC4_Msk
27805#define HRTIM_ADC1R_AD1TBPER_Pos (18U)
27806#define HRTIM_ADC1R_AD1TBPER_Msk (0x1UL << HRTIM_ADC1R_AD1TBPER_Pos)
27807#define HRTIM_ADC1R_AD1TBPER HRTIM_ADC1R_AD1TBPER_Msk
27808#define HRTIM_ADC1R_AD1TBRST_Pos (19U)
27809#define HRTIM_ADC1R_AD1TBRST_Msk (0x1UL << HRTIM_ADC1R_AD1TBRST_Pos)
27810#define HRTIM_ADC1R_AD1TBRST HRTIM_ADC1R_AD1TBRST_Msk
27811#define HRTIM_ADC1R_AD1TCC2_Pos (20U)
27812#define HRTIM_ADC1R_AD1TCC2_Msk (0x1UL << HRTIM_ADC1R_AD1TCC2_Pos)
27813#define HRTIM_ADC1R_AD1TCC2 HRTIM_ADC1R_AD1TCC2_Msk
27814#define HRTIM_ADC1R_AD1TCC3_Pos (21U)
27815#define HRTIM_ADC1R_AD1TCC3_Msk (0x1UL << HRTIM_ADC1R_AD1TCC3_Pos)
27816#define HRTIM_ADC1R_AD1TCC3 HRTIM_ADC1R_AD1TCC3_Msk
27817#define HRTIM_ADC1R_AD1TCC4_Pos (22U)
27818#define HRTIM_ADC1R_AD1TCC4_Msk (0x1UL << HRTIM_ADC1R_AD1TCC4_Pos)
27819#define HRTIM_ADC1R_AD1TCC4 HRTIM_ADC1R_AD1TCC4_Msk
27820#define HRTIM_ADC1R_AD1TCPER_Pos (23U)
27821#define HRTIM_ADC1R_AD1TCPER_Msk (0x1UL << HRTIM_ADC1R_AD1TCPER_Pos)
27822#define HRTIM_ADC1R_AD1TCPER HRTIM_ADC1R_AD1TCPER_Msk
27823#define HRTIM_ADC1R_AD1TDC2_Pos (24U)
27824#define HRTIM_ADC1R_AD1TDC2_Msk (0x1UL << HRTIM_ADC1R_AD1TDC2_Pos)
27825#define HRTIM_ADC1R_AD1TDC2 HRTIM_ADC1R_AD1TDC2_Msk
27826#define HRTIM_ADC1R_AD1TDC3_Pos (25U)
27827#define HRTIM_ADC1R_AD1TDC3_Msk (0x1UL << HRTIM_ADC1R_AD1TDC3_Pos)
27828#define HRTIM_ADC1R_AD1TDC3 HRTIM_ADC1R_AD1TDC3_Msk
27829#define HRTIM_ADC1R_AD1TDC4_Pos (26U)
27830#define HRTIM_ADC1R_AD1TDC4_Msk (0x1UL << HRTIM_ADC1R_AD1TDC4_Pos)
27831#define HRTIM_ADC1R_AD1TDC4 HRTIM_ADC1R_AD1TDC4_Msk
27832#define HRTIM_ADC1R_AD1TDPER_Pos (27U)
27833#define HRTIM_ADC1R_AD1TDPER_Msk (0x1UL << HRTIM_ADC1R_AD1TDPER_Pos)
27834#define HRTIM_ADC1R_AD1TDPER HRTIM_ADC1R_AD1TDPER_Msk
27835#define HRTIM_ADC1R_AD1TEC2_Pos (28U)
27836#define HRTIM_ADC1R_AD1TEC2_Msk (0x1UL << HRTIM_ADC1R_AD1TEC2_Pos)
27837#define HRTIM_ADC1R_AD1TEC2 HRTIM_ADC1R_AD1TEC2_Msk
27838#define HRTIM_ADC1R_AD1TEC3_Pos (29U)
27839#define HRTIM_ADC1R_AD1TEC3_Msk (0x1UL << HRTIM_ADC1R_AD1TEC3_Pos)
27840#define HRTIM_ADC1R_AD1TEC3 HRTIM_ADC1R_AD1TEC3_Msk
27841#define HRTIM_ADC1R_AD1TEC4_Pos (30U)
27842#define HRTIM_ADC1R_AD1TEC4_Msk (0x1UL << HRTIM_ADC1R_AD1TEC4_Pos)
27843#define HRTIM_ADC1R_AD1TEC4 HRTIM_ADC1R_AD1TEC4_Msk
27844#define HRTIM_ADC1R_AD1TEPER_Pos (31U)
27845#define HRTIM_ADC1R_AD1TEPER_Msk (0x1UL << HRTIM_ADC1R_AD1TEPER_Pos)
27846#define HRTIM_ADC1R_AD1TEPER HRTIM_ADC1R_AD1TEPER_Msk
27848/******************* Bit definition for HRTIM_ADC2R register ****************/
27849#define HRTIM_ADC2R_AD2MC1_Pos (0U)
27850#define HRTIM_ADC2R_AD2MC1_Msk (0x1UL << HRTIM_ADC2R_AD2MC1_Pos)
27851#define HRTIM_ADC2R_AD2MC1 HRTIM_ADC2R_AD2MC1_Msk
27852#define HRTIM_ADC2R_AD2MC2_Pos (1U)
27853#define HRTIM_ADC2R_AD2MC2_Msk (0x1UL << HRTIM_ADC2R_AD2MC2_Pos)
27854#define HRTIM_ADC2R_AD2MC2 HRTIM_ADC2R_AD2MC2_Msk
27855#define HRTIM_ADC2R_AD2MC3_Pos (2U)
27856#define HRTIM_ADC2R_AD2MC3_Msk (0x1UL << HRTIM_ADC2R_AD2MC3_Pos)
27857#define HRTIM_ADC2R_AD2MC3 HRTIM_ADC2R_AD2MC3_Msk
27858#define HRTIM_ADC2R_AD2MC4_Pos (3U)
27859#define HRTIM_ADC2R_AD2MC4_Msk (0x1UL << HRTIM_ADC2R_AD2MC4_Pos)
27860#define HRTIM_ADC2R_AD2MC4 HRTIM_ADC2R_AD2MC4_Msk
27861#define HRTIM_ADC2R_AD2MPER_Pos (4U)
27862#define HRTIM_ADC2R_AD2MPER_Msk (0x1UL << HRTIM_ADC2R_AD2MPER_Pos)
27863#define HRTIM_ADC2R_AD2MPER HRTIM_ADC2R_AD2MPER_Msk
27864#define HRTIM_ADC2R_AD2EEV6_Pos (5U)
27865#define HRTIM_ADC2R_AD2EEV6_Msk (0x1UL << HRTIM_ADC2R_AD2EEV6_Pos)
27866#define HRTIM_ADC2R_AD2EEV6 HRTIM_ADC2R_AD2EEV6_Msk
27867#define HRTIM_ADC2R_AD2EEV7_Pos (6U)
27868#define HRTIM_ADC2R_AD2EEV7_Msk (0x1UL << HRTIM_ADC2R_AD2EEV7_Pos)
27869#define HRTIM_ADC2R_AD2EEV7 HRTIM_ADC2R_AD2EEV7_Msk
27870#define HRTIM_ADC2R_AD2EEV8_Pos (7U)
27871#define HRTIM_ADC2R_AD2EEV8_Msk (0x1UL << HRTIM_ADC2R_AD2EEV8_Pos)
27872#define HRTIM_ADC2R_AD2EEV8 HRTIM_ADC2R_AD2EEV8_Msk
27873#define HRTIM_ADC2R_AD2EEV9_Pos (8U)
27874#define HRTIM_ADC2R_AD2EEV9_Msk (0x1UL << HRTIM_ADC2R_AD2EEV9_Pos)
27875#define HRTIM_ADC2R_AD2EEV9 HRTIM_ADC2R_AD2EEV9_Msk
27876#define HRTIM_ADC2R_AD2EEV10_Pos (9U)
27877#define HRTIM_ADC2R_AD2EEV10_Msk (0x1UL << HRTIM_ADC2R_AD2EEV10_Pos)
27878#define HRTIM_ADC2R_AD2EEV10 HRTIM_ADC2R_AD2EEV10_Msk
27879#define HRTIM_ADC2R_AD2TAC2_Pos (10U)
27880#define HRTIM_ADC2R_AD2TAC2_Msk (0x1UL << HRTIM_ADC2R_AD2TAC2_Pos)
27881#define HRTIM_ADC2R_AD2TAC2 HRTIM_ADC2R_AD2TAC2_Msk
27882#define HRTIM_ADC2R_AD2TAC3_Pos (11U)
27883#define HRTIM_ADC2R_AD2TAC3_Msk (0x1UL << HRTIM_ADC2R_AD2TAC3_Pos)
27884#define HRTIM_ADC2R_AD2TAC3 HRTIM_ADC2R_AD2TAC3_Msk
27885#define HRTIM_ADC2R_AD2TAC4_Pos (12U)
27886#define HRTIM_ADC2R_AD2TAC4_Msk (0x1UL << HRTIM_ADC2R_AD2TAC4_Pos)
27887#define HRTIM_ADC2R_AD2TAC4 HRTIM_ADC2R_AD2TAC4_Msk
27888#define HRTIM_ADC2R_AD2TAPER_Pos (13U)
27889#define HRTIM_ADC2R_AD2TAPER_Msk (0x1UL << HRTIM_ADC2R_AD2TAPER_Pos)
27890#define HRTIM_ADC2R_AD2TAPER HRTIM_ADC2R_AD2TAPER_Msk
27891#define HRTIM_ADC2R_AD2TBC2_Pos (14U)
27892#define HRTIM_ADC2R_AD2TBC2_Msk (0x1UL << HRTIM_ADC2R_AD2TBC2_Pos)
27893#define HRTIM_ADC2R_AD2TBC2 HRTIM_ADC2R_AD2TBC2_Msk
27894#define HRTIM_ADC2R_AD2TBC3_Pos (15U)
27895#define HRTIM_ADC2R_AD2TBC3_Msk (0x1UL << HRTIM_ADC2R_AD2TBC3_Pos)
27896#define HRTIM_ADC2R_AD2TBC3 HRTIM_ADC2R_AD2TBC3_Msk
27897#define HRTIM_ADC2R_AD2TBC4_Pos (16U)
27898#define HRTIM_ADC2R_AD2TBC4_Msk (0x1UL << HRTIM_ADC2R_AD2TBC4_Pos)
27899#define HRTIM_ADC2R_AD2TBC4 HRTIM_ADC2R_AD2TBC4_Msk
27900#define HRTIM_ADC2R_AD2TBPER_Pos (17U)
27901#define HRTIM_ADC2R_AD2TBPER_Msk (0x1UL << HRTIM_ADC2R_AD2TBPER_Pos)
27902#define HRTIM_ADC2R_AD2TBPER HRTIM_ADC2R_AD2TBPER_Msk
27903#define HRTIM_ADC2R_AD2TCC2_Pos (18U)
27904#define HRTIM_ADC2R_AD2TCC2_Msk (0x1UL << HRTIM_ADC2R_AD2TCC2_Pos)
27905#define HRTIM_ADC2R_AD2TCC2 HRTIM_ADC2R_AD2TCC2_Msk
27906#define HRTIM_ADC2R_AD2TCC3_Pos (19U)
27907#define HRTIM_ADC2R_AD2TCC3_Msk (0x1UL << HRTIM_ADC2R_AD2TCC3_Pos)
27908#define HRTIM_ADC2R_AD2TCC3 HRTIM_ADC2R_AD2TCC3_Msk
27909#define HRTIM_ADC2R_AD2TCC4_Pos (20U)
27910#define HRTIM_ADC2R_AD2TCC4_Msk (0x1UL << HRTIM_ADC2R_AD2TCC4_Pos)
27911#define HRTIM_ADC2R_AD2TCC4 HRTIM_ADC2R_AD2TCC4_Msk
27912#define HRTIM_ADC2R_AD2TCPER_Pos (21U)
27913#define HRTIM_ADC2R_AD2TCPER_Msk (0x1UL << HRTIM_ADC2R_AD2TCPER_Pos)
27914#define HRTIM_ADC2R_AD2TCPER HRTIM_ADC2R_AD2TCPER_Msk
27915#define HRTIM_ADC2R_AD2TCRST_Pos (22U)
27916#define HRTIM_ADC2R_AD2TCRST_Msk (0x1UL << HRTIM_ADC2R_AD2TCRST_Pos)
27917#define HRTIM_ADC2R_AD2TCRST HRTIM_ADC2R_AD2TCRST_Msk
27918#define HRTIM_ADC2R_AD2TDC2_Pos (23U)
27919#define HRTIM_ADC2R_AD2TDC2_Msk (0x1UL << HRTIM_ADC2R_AD2TDC2_Pos)
27920#define HRTIM_ADC2R_AD2TDC2 HRTIM_ADC2R_AD2TDC2_Msk
27921#define HRTIM_ADC2R_AD2TDC3_Pos (24U)
27922#define HRTIM_ADC2R_AD2TDC3_Msk (0x1UL << HRTIM_ADC2R_AD2TDC3_Pos)
27923#define HRTIM_ADC2R_AD2TDC3 HRTIM_ADC2R_AD2TDC3_Msk
27924#define HRTIM_ADC2R_AD2TDC4_Pos (25U)
27925#define HRTIM_ADC2R_AD2TDC4_Msk (0x1UL << HRTIM_ADC2R_AD2TDC4_Pos)
27926#define HRTIM_ADC2R_AD2TDC4 HRTIM_ADC2R_AD2TDC4_Msk
27927#define HRTIM_ADC2R_AD2TDPER_Pos (26U)
27928#define HRTIM_ADC2R_AD2TDPER_Msk (0x1UL << HRTIM_ADC2R_AD2TDPER_Pos)
27929#define HRTIM_ADC2R_AD2TDPER HRTIM_ADC2R_AD2TDPER_Msk
27930#define HRTIM_ADC2R_AD2TDRST_Pos (27U)
27931#define HRTIM_ADC2R_AD2TDRST_Msk (0x1UL << HRTIM_ADC2R_AD2TDRST_Pos)
27932#define HRTIM_ADC2R_AD2TDRST HRTIM_ADC2R_AD2TDRST_Msk
27933#define HRTIM_ADC2R_AD2TEC2_Pos (28U)
27934#define HRTIM_ADC2R_AD2TEC2_Msk (0x1UL << HRTIM_ADC2R_AD2TEC2_Pos)
27935#define HRTIM_ADC2R_AD2TEC2 HRTIM_ADC2R_AD2TEC2_Msk
27936#define HRTIM_ADC2R_AD2TEC3_Pos (29U)
27937#define HRTIM_ADC2R_AD2TEC3_Msk (0x1UL << HRTIM_ADC2R_AD2TEC3_Pos)
27938#define HRTIM_ADC2R_AD2TEC3 HRTIM_ADC2R_AD2TEC3_Msk
27939#define HRTIM_ADC2R_AD2TEC4_Pos (30U)
27940#define HRTIM_ADC2R_AD2TEC4_Msk (0x1UL << HRTIM_ADC2R_AD2TEC4_Pos)
27941#define HRTIM_ADC2R_AD2TEC4 HRTIM_ADC2R_AD2TEC4_Msk
27942#define HRTIM_ADC2R_AD2TERST_Pos (31U)
27943#define HRTIM_ADC2R_AD2TERST_Msk (0x1UL << HRTIM_ADC2R_AD2TERST_Pos)
27944#define HRTIM_ADC2R_AD2TERST HRTIM_ADC2R_AD2TERST_Msk
27946/******************* Bit definition for HRTIM_ADC3R register ****************/
27947#define HRTIM_ADC3R_AD3MC1_Pos (0U)
27948#define HRTIM_ADC3R_AD3MC1_Msk (0x1UL << HRTIM_ADC3R_AD3MC1_Pos)
27949#define HRTIM_ADC3R_AD3MC1 HRTIM_ADC3R_AD3MC1_Msk
27950#define HRTIM_ADC3R_AD3MC2_Pos (1U)
27951#define HRTIM_ADC3R_AD3MC2_Msk (0x1UL << HRTIM_ADC3R_AD3MC2_Pos)
27952#define HRTIM_ADC3R_AD3MC2 HRTIM_ADC3R_AD3MC2_Msk
27953#define HRTIM_ADC3R_AD3MC3_Pos (2U)
27954#define HRTIM_ADC3R_AD3MC3_Msk (0x1UL << HRTIM_ADC3R_AD3MC3_Pos)
27955#define HRTIM_ADC3R_AD3MC3 HRTIM_ADC3R_AD3MC3_Msk
27956#define HRTIM_ADC3R_AD3MC4_Pos (3U)
27957#define HRTIM_ADC3R_AD3MC4_Msk (0x1UL << HRTIM_ADC3R_AD3MC4_Pos)
27958#define HRTIM_ADC3R_AD3MC4 HRTIM_ADC3R_AD3MC4_Msk
27959#define HRTIM_ADC3R_AD3MPER_Pos (4U)
27960#define HRTIM_ADC3R_AD3MPER_Msk (0x1UL << HRTIM_ADC3R_AD3MPER_Pos)
27961#define HRTIM_ADC3R_AD3MPER HRTIM_ADC3R_AD3MPER_Msk
27962#define HRTIM_ADC3R_AD3EEV1_Pos (5U)
27963#define HRTIM_ADC3R_AD3EEV1_Msk (0x1UL << HRTIM_ADC3R_AD3EEV1_Pos)
27964#define HRTIM_ADC3R_AD3EEV1 HRTIM_ADC3R_AD3EEV1_Msk
27965#define HRTIM_ADC3R_AD3EEV2_Pos (6U)
27966#define HRTIM_ADC3R_AD3EEV2_Msk (0x1UL << HRTIM_ADC3R_AD3EEV2_Pos)
27967#define HRTIM_ADC3R_AD3EEV2 HRTIM_ADC3R_AD3EEV2_Msk
27968#define HRTIM_ADC3R_AD3EEV3_Pos (7U)
27969#define HRTIM_ADC3R_AD3EEV3_Msk (0x1UL << HRTIM_ADC3R_AD3EEV3_Pos)
27970#define HRTIM_ADC3R_AD3EEV3 HRTIM_ADC3R_AD3EEV3_Msk
27971#define HRTIM_ADC3R_AD3EEV4_Pos (8U)
27972#define HRTIM_ADC3R_AD3EEV4_Msk (0x1UL << HRTIM_ADC3R_AD3EEV4_Pos)
27973#define HRTIM_ADC3R_AD3EEV4 HRTIM_ADC3R_AD3EEV4_Msk
27974#define HRTIM_ADC3R_AD3EEV5_Pos (9U)
27975#define HRTIM_ADC3R_AD3EEV5_Msk (0x1UL << HRTIM_ADC3R_AD3EEV5_Pos)
27976#define HRTIM_ADC3R_AD3EEV5 HRTIM_ADC3R_AD3EEV5_Msk
27977#define HRTIM_ADC3R_AD3TAC2_Pos (10U)
27978#define HRTIM_ADC3R_AD3TAC2_Msk (0x1UL << HRTIM_ADC3R_AD3TAC2_Pos)
27979#define HRTIM_ADC3R_AD3TAC2 HRTIM_ADC3R_AD3TAC2_Msk
27980#define HRTIM_ADC3R_AD3TAC3_Pos (11U)
27981#define HRTIM_ADC3R_AD3TAC3_Msk (0x1UL << HRTIM_ADC3R_AD3TAC3_Pos)
27982#define HRTIM_ADC3R_AD3TAC3 HRTIM_ADC3R_AD3TAC3_Msk
27983#define HRTIM_ADC3R_AD3TAC4_Pos (12U)
27984#define HRTIM_ADC3R_AD3TAC4_Msk (0x1UL << HRTIM_ADC3R_AD3TAC4_Pos)
27985#define HRTIM_ADC3R_AD3TAC4 HRTIM_ADC3R_AD3TAC4_Msk
27986#define HRTIM_ADC3R_AD3TAPER_Pos (13U)
27987#define HRTIM_ADC3R_AD3TAPER_Msk (0x1UL << HRTIM_ADC3R_AD3TAPER_Pos)
27988#define HRTIM_ADC3R_AD3TAPER HRTIM_ADC3R_AD3TAPER_Msk
27989#define HRTIM_ADC3R_AD3TARST_Pos (14U)
27990#define HRTIM_ADC3R_AD3TARST_Msk (0x1UL << HRTIM_ADC3R_AD3TARST_Pos)
27991#define HRTIM_ADC3R_AD3TARST HRTIM_ADC3R_AD3TARST_Msk
27992#define HRTIM_ADC3R_AD3TBC2_Pos (15U)
27993#define HRTIM_ADC3R_AD3TBC2_Msk (0x1UL << HRTIM_ADC3R_AD3TBC2_Pos)
27994#define HRTIM_ADC3R_AD3TBC2 HRTIM_ADC3R_AD3TBC2_Msk
27995#define HRTIM_ADC3R_AD3TBC3_Pos (16U)
27996#define HRTIM_ADC3R_AD3TBC3_Msk (0x1UL << HRTIM_ADC3R_AD3TBC3_Pos)
27997#define HRTIM_ADC3R_AD3TBC3 HRTIM_ADC3R_AD3TBC3_Msk
27998#define HRTIM_ADC3R_AD3TBC4_Pos (17U)
27999#define HRTIM_ADC3R_AD3TBC4_Msk (0x1UL << HRTIM_ADC3R_AD3TBC4_Pos)
28000#define HRTIM_ADC3R_AD3TBC4 HRTIM_ADC3R_AD3TBC4_Msk
28001#define HRTIM_ADC3R_AD3TBPER_Pos (18U)
28002#define HRTIM_ADC3R_AD3TBPER_Msk (0x1UL << HRTIM_ADC3R_AD3TBPER_Pos)
28003#define HRTIM_ADC3R_AD3TBPER HRTIM_ADC3R_AD3TBPER_Msk
28004#define HRTIM_ADC3R_AD3TBRST_Pos (19U)
28005#define HRTIM_ADC3R_AD3TBRST_Msk (0x1UL << HRTIM_ADC3R_AD3TBRST_Pos)
28006#define HRTIM_ADC3R_AD3TBRST HRTIM_ADC3R_AD3TBRST_Msk
28007#define HRTIM_ADC3R_AD3TCC2_Pos (20U)
28008#define HRTIM_ADC3R_AD3TCC2_Msk (0x1UL << HRTIM_ADC3R_AD3TCC2_Pos)
28009#define HRTIM_ADC3R_AD3TCC2 HRTIM_ADC3R_AD3TCC2_Msk
28010#define HRTIM_ADC3R_AD3TCC3_Pos (21U)
28011#define HRTIM_ADC3R_AD3TCC3_Msk (0x1UL << HRTIM_ADC3R_AD3TCC3_Pos)
28012#define HRTIM_ADC3R_AD3TCC3 HRTIM_ADC3R_AD3TCC3_Msk
28013#define HRTIM_ADC3R_AD3TCC4_Pos (22U)
28014#define HRTIM_ADC3R_AD3TCC4_Msk (0x1UL << HRTIM_ADC3R_AD3TCC4_Pos)
28015#define HRTIM_ADC3R_AD3TCC4 HRTIM_ADC3R_AD3TCC4_Msk
28016#define HRTIM_ADC3R_AD3TCPER_Pos (23U)
28017#define HRTIM_ADC3R_AD3TCPER_Msk (0x1UL << HRTIM_ADC3R_AD3TCPER_Pos)
28018#define HRTIM_ADC3R_AD3TCPER HRTIM_ADC3R_AD3TCPER_Msk
28019#define HRTIM_ADC3R_AD3TDC2_Pos (24U)
28020#define HRTIM_ADC3R_AD3TDC2_Msk (0x1UL << HRTIM_ADC3R_AD3TDC2_Pos)
28021#define HRTIM_ADC3R_AD3TDC2 HRTIM_ADC3R_AD3TDC2_Msk
28022#define HRTIM_ADC3R_AD3TDC3_Pos (25U)
28023#define HRTIM_ADC3R_AD3TDC3_Msk (0x1UL << HRTIM_ADC3R_AD3TDC3_Pos)
28024#define HRTIM_ADC3R_AD3TDC3 HRTIM_ADC3R_AD3TDC3_Msk
28025#define HRTIM_ADC3R_AD3TDC4_Pos (26U)
28026#define HRTIM_ADC3R_AD3TDC4_Msk (0x1UL << HRTIM_ADC3R_AD3TDC4_Pos)
28027#define HRTIM_ADC3R_AD3TDC4 HRTIM_ADC3R_AD3TDC4_Msk
28028#define HRTIM_ADC3R_AD3TDPER_Pos (27U)
28029#define HRTIM_ADC3R_AD3TDPER_Msk (0x1UL << HRTIM_ADC3R_AD3TDPER_Pos)
28030#define HRTIM_ADC3R_AD3TDPER HRTIM_ADC3R_AD3TDPER_Msk
28031#define HRTIM_ADC3R_AD3TEC2_Pos (28U)
28032#define HRTIM_ADC3R_AD3TEC2_Msk (0x1UL << HRTIM_ADC3R_AD3TEC2_Pos)
28033#define HRTIM_ADC3R_AD3TEC2 HRTIM_ADC3R_AD3TEC2_Msk
28034#define HRTIM_ADC3R_AD3TEC3_Pos (29U)
28035#define HRTIM_ADC3R_AD3TEC3_Msk (0x1UL << HRTIM_ADC3R_AD3TEC3_Pos)
28036#define HRTIM_ADC3R_AD3TEC3 HRTIM_ADC3R_AD3TEC3_Msk
28037#define HRTIM_ADC3R_AD3TEC4_Pos (30U)
28038#define HRTIM_ADC3R_AD3TEC4_Msk (0x1UL << HRTIM_ADC3R_AD3TEC4_Pos)
28039#define HRTIM_ADC3R_AD3TEC4 HRTIM_ADC3R_AD3TEC4_Msk
28040#define HRTIM_ADC3R_AD3TEPER_Pos (31U)
28041#define HRTIM_ADC3R_AD3TEPER_Msk (0x1UL << HRTIM_ADC3R_AD3TEPER_Pos)
28042#define HRTIM_ADC3R_AD3TEPER HRTIM_ADC3R_AD3TEPER_Msk
28044/******************* Bit definition for HRTIM_ADC4R register ****************/
28045#define HRTIM_ADC4R_AD4MC1_Pos (0U)
28046#define HRTIM_ADC4R_AD4MC1_Msk (0x1UL << HRTIM_ADC4R_AD4MC1_Pos)
28047#define HRTIM_ADC4R_AD4MC1 HRTIM_ADC4R_AD4MC1_Msk
28048#define HRTIM_ADC4R_AD4MC2_Pos (1U)
28049#define HRTIM_ADC4R_AD4MC2_Msk (0x1UL << HRTIM_ADC4R_AD4MC2_Pos)
28050#define HRTIM_ADC4R_AD4MC2 HRTIM_ADC4R_AD4MC2_Msk
28051#define HRTIM_ADC4R_AD4MC3_Pos (2U)
28052#define HRTIM_ADC4R_AD4MC3_Msk (0x1UL << HRTIM_ADC4R_AD4MC3_Pos)
28053#define HRTIM_ADC4R_AD4MC3 HRTIM_ADC4R_AD4MC3_Msk
28054#define HRTIM_ADC4R_AD4MC4_Pos (3U)
28055#define HRTIM_ADC4R_AD4MC4_Msk (0x1UL << HRTIM_ADC4R_AD4MC4_Pos)
28056#define HRTIM_ADC4R_AD4MC4 HRTIM_ADC4R_AD4MC4_Msk
28057#define HRTIM_ADC4R_AD4MPER_Pos (4U)
28058#define HRTIM_ADC4R_AD4MPER_Msk (0x1UL << HRTIM_ADC4R_AD4MPER_Pos)
28059#define HRTIM_ADC4R_AD4MPER HRTIM_ADC4R_AD4MPER_Msk
28060#define HRTIM_ADC4R_AD4EEV6_Pos (5U)
28061#define HRTIM_ADC4R_AD4EEV6_Msk (0x1UL << HRTIM_ADC4R_AD4EEV6_Pos)
28062#define HRTIM_ADC4R_AD4EEV6 HRTIM_ADC4R_AD4EEV6_Msk
28063#define HRTIM_ADC4R_AD4EEV7_Pos (6U)
28064#define HRTIM_ADC4R_AD4EEV7_Msk (0x1UL << HRTIM_ADC4R_AD4EEV7_Pos)
28065#define HRTIM_ADC4R_AD4EEV7 HRTIM_ADC4R_AD4EEV7_Msk
28066#define HRTIM_ADC4R_AD4EEV8_Pos (7U)
28067#define HRTIM_ADC4R_AD4EEV8_Msk (0x1UL << HRTIM_ADC4R_AD4EEV8_Pos)
28068#define HRTIM_ADC4R_AD4EEV8 HRTIM_ADC4R_AD4EEV8_Msk
28069#define HRTIM_ADC4R_AD4EEV9_Pos (8U)
28070#define HRTIM_ADC4R_AD4EEV9_Msk (0x1UL << HRTIM_ADC4R_AD4EEV9_Pos)
28071#define HRTIM_ADC4R_AD4EEV9 HRTIM_ADC4R_AD4EEV9_Msk
28072#define HRTIM_ADC4R_AD4EEV10_Pos (9U)
28073#define HRTIM_ADC4R_AD4EEV10_Msk (0x1UL << HRTIM_ADC4R_AD4EEV10_Pos)
28074#define HRTIM_ADC4R_AD4EEV10 HRTIM_ADC4R_AD4EEV10_Msk
28075#define HRTIM_ADC4R_AD4TAC2_Pos (10U)
28076#define HRTIM_ADC4R_AD4TAC2_Msk (0x1UL << HRTIM_ADC4R_AD4TAC2_Pos)
28077#define HRTIM_ADC4R_AD4TAC2 HRTIM_ADC4R_AD4TAC2_Msk
28078#define HRTIM_ADC4R_AD4TAC3_Pos (11U)
28079#define HRTIM_ADC4R_AD4TAC3_Msk (0x1UL << HRTIM_ADC4R_AD4TAC3_Pos)
28080#define HRTIM_ADC4R_AD4TAC3 HRTIM_ADC4R_AD4TAC3_Msk
28081#define HRTIM_ADC4R_AD4TAC4_Pos (12U)
28082#define HRTIM_ADC4R_AD4TAC4_Msk (0x1UL << HRTIM_ADC4R_AD4TAC4_Pos)
28083#define HRTIM_ADC4R_AD4TAC4 HRTIM_ADC4R_AD4TAC4_Msk
28084#define HRTIM_ADC4R_AD4TAPER_Pos (13U)
28085#define HRTIM_ADC4R_AD4TAPER_Msk (0x1UL << HRTIM_ADC4R_AD4TAPER_Pos)
28086#define HRTIM_ADC4R_AD4TAPER HRTIM_ADC4R_AD4TAPER_Msk
28087#define HRTIM_ADC4R_AD4TBC2_Pos (14U)
28088#define HRTIM_ADC4R_AD4TBC2_Msk (0x1UL << HRTIM_ADC4R_AD4TBC2_Pos)
28089#define HRTIM_ADC4R_AD4TBC2 HRTIM_ADC4R_AD4TBC2_Msk
28090#define HRTIM_ADC4R_AD4TBC3_Pos (15U)
28091#define HRTIM_ADC4R_AD4TBC3_Msk (0x1UL << HRTIM_ADC4R_AD4TBC3_Pos)
28092#define HRTIM_ADC4R_AD4TBC3 HRTIM_ADC4R_AD4TBC3_Msk
28093#define HRTIM_ADC4R_AD4TBC4_Pos (16U)
28094#define HRTIM_ADC4R_AD4TBC4_Msk (0x1UL << HRTIM_ADC4R_AD4TBC4_Pos)
28095#define HRTIM_ADC4R_AD4TBC4 HRTIM_ADC4R_AD4TBC4_Msk
28096#define HRTIM_ADC4R_AD4TBPER_Pos (17U)
28097#define HRTIM_ADC4R_AD4TBPER_Msk (0x1UL << HRTIM_ADC4R_AD4TBPER_Pos)
28098#define HRTIM_ADC4R_AD4TBPER HRTIM_ADC4R_AD4TBPER_Msk
28099#define HRTIM_ADC4R_AD4TCC2_Pos (18U)
28100#define HRTIM_ADC4R_AD4TCC2_Msk (0x1UL << HRTIM_ADC4R_AD4TCC2_Pos)
28101#define HRTIM_ADC4R_AD4TCC2 HRTIM_ADC4R_AD4TCC2_Msk
28102#define HRTIM_ADC4R_AD4TCC3_Pos (19U)
28103#define HRTIM_ADC4R_AD4TCC3_Msk (0x1UL << HRTIM_ADC4R_AD4TCC3_Pos)
28104#define HRTIM_ADC4R_AD4TCC3 HRTIM_ADC4R_AD4TCC3_Msk
28105#define HRTIM_ADC4R_AD4TCC4_Pos (20U)
28106#define HRTIM_ADC4R_AD4TCC4_Msk (0x1UL << HRTIM_ADC4R_AD4TCC4_Pos)
28107#define HRTIM_ADC4R_AD4TCC4 HRTIM_ADC4R_AD4TCC4_Msk
28108#define HRTIM_ADC4R_AD4TCPER_Pos (21U)
28109#define HRTIM_ADC4R_AD4TCPER_Msk (0x1UL << HRTIM_ADC4R_AD4TCPER_Pos)
28110#define HRTIM_ADC4R_AD4TCPER HRTIM_ADC4R_AD4TCPER_Msk
28111#define HRTIM_ADC4R_AD4TCRST_Pos (22U)
28112#define HRTIM_ADC4R_AD4TCRST_Msk (0x1UL << HRTIM_ADC4R_AD4TCRST_Pos)
28113#define HRTIM_ADC4R_AD4TCRST HRTIM_ADC4R_AD4TCRST_Msk
28114#define HRTIM_ADC4R_AD4TDC2_Pos (23U)
28115#define HRTIM_ADC4R_AD4TDC2_Msk (0x1UL << HRTIM_ADC4R_AD4TDC2_Pos)
28116#define HRTIM_ADC4R_AD4TDC2 HRTIM_ADC4R_AD4TDC2_Msk
28117#define HRTIM_ADC4R_AD4TDC3_Pos (24U)
28118#define HRTIM_ADC4R_AD4TDC3_Msk (0x1UL << HRTIM_ADC4R_AD4TDC3_Pos)
28119#define HRTIM_ADC4R_AD4TDC3 HRTIM_ADC4R_AD4TDC3_Msk
28120#define HRTIM_ADC4R_AD4TDC4_Pos (25U)
28121#define HRTIM_ADC4R_AD4TDC4_Msk (0x1UL << HRTIM_ADC4R_AD4TDC4_Pos)
28122#define HRTIM_ADC4R_AD4TDC4 HRTIM_ADC4R_AD4TDC4_Msk
28123#define HRTIM_ADC4R_AD4TDPER_Pos (26U)
28124#define HRTIM_ADC4R_AD4TDPER_Msk (0x1UL << HRTIM_ADC4R_AD4TDPER_Pos)
28125#define HRTIM_ADC4R_AD4TDPER HRTIM_ADC4R_AD4TDPER_Msk
28126#define HRTIM_ADC4R_AD4TDRST_Pos (27U)
28127#define HRTIM_ADC4R_AD4TDRST_Msk (0x1UL << HRTIM_ADC4R_AD4TDRST_Pos)
28128#define HRTIM_ADC4R_AD4TDRST HRTIM_ADC4R_AD4TDRST_Msk
28129#define HRTIM_ADC4R_AD4TEC2_Pos (28U)
28130#define HRTIM_ADC4R_AD4TEC2_Msk (0x1UL << HRTIM_ADC4R_AD4TEC2_Pos)
28131#define HRTIM_ADC4R_AD4TEC2 HRTIM_ADC4R_AD4TEC2_Msk
28132#define HRTIM_ADC4R_AD4TEC3_Pos (29U)
28133#define HRTIM_ADC4R_AD4TEC3_Msk (0x1UL << HRTIM_ADC4R_AD4TEC3_Pos)
28134#define HRTIM_ADC4R_AD4TEC3 HRTIM_ADC4R_AD4TEC3_Msk
28135#define HRTIM_ADC4R_AD4TEC4_Pos (30U)
28136#define HRTIM_ADC4R_AD4TEC4_Msk (0x1UL << HRTIM_ADC4R_AD4TEC4_Pos)
28137#define HRTIM_ADC4R_AD4TEC4 HRTIM_ADC4R_AD4TEC4_Msk
28138#define HRTIM_ADC4R_AD4TERST_Pos (31U)
28139#define HRTIM_ADC4R_AD4TERST_Msk (0x1UL << HRTIM_ADC4R_AD4TERST_Pos)
28140#define HRTIM_ADC4R_AD4TERST HRTIM_ADC4R_AD4TERST_Msk
28142/******************* Bit definition for HRTIM_FLTINR1 register ***************/
28143#define HRTIM_FLTINR1_FLT1E_Pos (0U)
28144#define HRTIM_FLTINR1_FLT1E_Msk (0x1UL << HRTIM_FLTINR1_FLT1E_Pos)
28145#define HRTIM_FLTINR1_FLT1E HRTIM_FLTINR1_FLT1E_Msk
28146#define HRTIM_FLTINR1_FLT1P_Pos (1U)
28147#define HRTIM_FLTINR1_FLT1P_Msk (0x1UL << HRTIM_FLTINR1_FLT1P_Pos)
28148#define HRTIM_FLTINR1_FLT1P HRTIM_FLTINR1_FLT1P_Msk
28149#define HRTIM_FLTINR1_FLT1SRC_Pos (2U)
28150#define HRTIM_FLTINR1_FLT1SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT1SRC_Pos)
28151#define HRTIM_FLTINR1_FLT1SRC HRTIM_FLTINR1_FLT1SRC_Msk
28152#define HRTIM_FLTINR1_FLT1F_Pos (3U)
28153#define HRTIM_FLTINR1_FLT1F_Msk (0xFUL << HRTIM_FLTINR1_FLT1F_Pos)
28154#define HRTIM_FLTINR1_FLT1F HRTIM_FLTINR1_FLT1F_Msk
28155#define HRTIM_FLTINR1_FLT1F_0 (0x1UL << HRTIM_FLTINR1_FLT1F_Pos)
28156#define HRTIM_FLTINR1_FLT1F_1 (0x2UL << HRTIM_FLTINR1_FLT1F_Pos)
28157#define HRTIM_FLTINR1_FLT1F_2 (0x4UL << HRTIM_FLTINR1_FLT1F_Pos)
28158#define HRTIM_FLTINR1_FLT1F_3 (0x8UL << HRTIM_FLTINR1_FLT1F_Pos)
28159#define HRTIM_FLTINR1_FLT1LCK_Pos (7U)
28160#define HRTIM_FLTINR1_FLT1LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT1LCK_Pos)
28161#define HRTIM_FLTINR1_FLT1LCK HRTIM_FLTINR1_FLT1LCK_Msk
28163#define HRTIM_FLTINR1_FLT2E_Pos (8U)
28164#define HRTIM_FLTINR1_FLT2E_Msk (0x1UL << HRTIM_FLTINR1_FLT2E_Pos)
28165#define HRTIM_FLTINR1_FLT2E HRTIM_FLTINR1_FLT2E_Msk
28166#define HRTIM_FLTINR1_FLT2P_Pos (9U)
28167#define HRTIM_FLTINR1_FLT2P_Msk (0x1UL << HRTIM_FLTINR1_FLT2P_Pos)
28168#define HRTIM_FLTINR1_FLT2P HRTIM_FLTINR1_FLT2P_Msk
28169#define HRTIM_FLTINR1_FLT2SRC_Pos (10U)
28170#define HRTIM_FLTINR1_FLT2SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT2SRC_Pos)
28171#define HRTIM_FLTINR1_FLT2SRC HRTIM_FLTINR1_FLT2SRC_Msk
28172#define HRTIM_FLTINR1_FLT2F_Pos (11U)
28173#define HRTIM_FLTINR1_FLT2F_Msk (0xFUL << HRTIM_FLTINR1_FLT2F_Pos)
28174#define HRTIM_FLTINR1_FLT2F HRTIM_FLTINR1_FLT2F_Msk
28175#define HRTIM_FLTINR1_FLT2F_0 (0x1UL << HRTIM_FLTINR1_FLT2F_Pos)
28176#define HRTIM_FLTINR1_FLT2F_1 (0x2UL << HRTIM_FLTINR1_FLT2F_Pos)
28177#define HRTIM_FLTINR1_FLT2F_2 (0x4UL << HRTIM_FLTINR1_FLT2F_Pos)
28178#define HRTIM_FLTINR1_FLT2F_3 (0x8UL << HRTIM_FLTINR1_FLT2F_Pos)
28179#define HRTIM_FLTINR1_FLT2LCK_Pos (15U)
28180#define HRTIM_FLTINR1_FLT2LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT2LCK_Pos)
28181#define HRTIM_FLTINR1_FLT2LCK HRTIM_FLTINR1_FLT2LCK_Msk
28183#define HRTIM_FLTINR1_FLT3E_Pos (16U)
28184#define HRTIM_FLTINR1_FLT3E_Msk (0x1UL << HRTIM_FLTINR1_FLT3E_Pos)
28185#define HRTIM_FLTINR1_FLT3E HRTIM_FLTINR1_FLT3E_Msk
28186#define HRTIM_FLTINR1_FLT3P_Pos (17U)
28187#define HRTIM_FLTINR1_FLT3P_Msk (0x1UL << HRTIM_FLTINR1_FLT3P_Pos)
28188#define HRTIM_FLTINR1_FLT3P HRTIM_FLTINR1_FLT3P_Msk
28189#define HRTIM_FLTINR1_FLT3SRC_Pos (18U)
28190#define HRTIM_FLTINR1_FLT3SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT3SRC_Pos)
28191#define HRTIM_FLTINR1_FLT3SRC HRTIM_FLTINR1_FLT3SRC_Msk
28192#define HRTIM_FLTINR1_FLT3F_Pos (19U)
28193#define HRTIM_FLTINR1_FLT3F_Msk (0xFUL << HRTIM_FLTINR1_FLT3F_Pos)
28194#define HRTIM_FLTINR1_FLT3F HRTIM_FLTINR1_FLT3F_Msk
28195#define HRTIM_FLTINR1_FLT3F_0 (0x1UL << HRTIM_FLTINR1_FLT3F_Pos)
28196#define HRTIM_FLTINR1_FLT3F_1 (0x2UL << HRTIM_FLTINR1_FLT3F_Pos)
28197#define HRTIM_FLTINR1_FLT3F_2 (0x4UL << HRTIM_FLTINR1_FLT3F_Pos)
28198#define HRTIM_FLTINR1_FLT3F_3 (0x8UL << HRTIM_FLTINR1_FLT3F_Pos)
28199#define HRTIM_FLTINR1_FLT3LCK_Pos (23U)
28200#define HRTIM_FLTINR1_FLT3LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT3LCK_Pos)
28201#define HRTIM_FLTINR1_FLT3LCK HRTIM_FLTINR1_FLT3LCK_Msk
28203#define HRTIM_FLTINR1_FLT4E_Pos (24U)
28204#define HRTIM_FLTINR1_FLT4E_Msk (0x1UL << HRTIM_FLTINR1_FLT4E_Pos)
28205#define HRTIM_FLTINR1_FLT4E HRTIM_FLTINR1_FLT4E_Msk
28206#define HRTIM_FLTINR1_FLT4P_Pos (25U)
28207#define HRTIM_FLTINR1_FLT4P_Msk (0x1UL << HRTIM_FLTINR1_FLT4P_Pos)
28208#define HRTIM_FLTINR1_FLT4P HRTIM_FLTINR1_FLT4P_Msk
28209#define HRTIM_FLTINR1_FLT4SRC_Pos (26U)
28210#define HRTIM_FLTINR1_FLT4SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT4SRC_Pos)
28211#define HRTIM_FLTINR1_FLT4SRC HRTIM_FLTINR1_FLT4SRC_Msk
28212#define HRTIM_FLTINR1_FLT4F_Pos (27U)
28213#define HRTIM_FLTINR1_FLT4F_Msk (0xFUL << HRTIM_FLTINR1_FLT4F_Pos)
28214#define HRTIM_FLTINR1_FLT4F HRTIM_FLTINR1_FLT4F_Msk
28215#define HRTIM_FLTINR1_FLT4F_0 (0x1UL << HRTIM_FLTINR1_FLT4F_Pos)
28216#define HRTIM_FLTINR1_FLT4F_1 (0x2UL << HRTIM_FLTINR1_FLT4F_Pos)
28217#define HRTIM_FLTINR1_FLT4F_2 (0x4UL << HRTIM_FLTINR1_FLT4F_Pos)
28218#define HRTIM_FLTINR1_FLT4F_3 (0x8UL << HRTIM_FLTINR1_FLT4F_Pos)
28219#define HRTIM_FLTINR1_FLT4LCK_Pos (31U)
28220#define HRTIM_FLTINR1_FLT4LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT4LCK_Pos)
28221#define HRTIM_FLTINR1_FLT4LCK HRTIM_FLTINR1_FLT4LCK_Msk
28223/******************* Bit definition for HRTIM_FLTINR2 register ***************/
28224#define HRTIM_FLTINR2_FLT5E_Pos (0U)
28225#define HRTIM_FLTINR2_FLT5E_Msk (0x1UL << HRTIM_FLTINR2_FLT5E_Pos)
28226#define HRTIM_FLTINR2_FLT5E HRTIM_FLTINR2_FLT5E_Msk
28227#define HRTIM_FLTINR2_FLT5P_Pos (1U)
28228#define HRTIM_FLTINR2_FLT5P_Msk (0x1UL << HRTIM_FLTINR2_FLT5P_Pos)
28229#define HRTIM_FLTINR2_FLT5P HRTIM_FLTINR2_FLT5P_Msk
28230#define HRTIM_FLTINR2_FLT5SRC_Pos (2U)
28231#define HRTIM_FLTINR2_FLT5SRC_Msk (0x1UL << HRTIM_FLTINR2_FLT5SRC_Pos)
28232#define HRTIM_FLTINR2_FLT5SRC HRTIM_FLTINR2_FLT5SRC_Msk
28233#define HRTIM_FLTINR2_FLT5F_Pos (3U)
28234#define HRTIM_FLTINR2_FLT5F_Msk (0xFUL << HRTIM_FLTINR2_FLT5F_Pos)
28235#define HRTIM_FLTINR2_FLT5F HRTIM_FLTINR2_FLT5F_Msk
28236#define HRTIM_FLTINR2_FLT5F_0 (0x1UL << HRTIM_FLTINR2_FLT5F_Pos)
28237#define HRTIM_FLTINR2_FLT5F_1 (0x2UL << HRTIM_FLTINR2_FLT5F_Pos)
28238#define HRTIM_FLTINR2_FLT5F_2 (0x4UL << HRTIM_FLTINR2_FLT5F_Pos)
28239#define HRTIM_FLTINR2_FLT5F_3 (0x8UL << HRTIM_FLTINR2_FLT5F_Pos)
28240#define HRTIM_FLTINR2_FLT5LCK_Pos (7U)
28241#define HRTIM_FLTINR2_FLT5LCK_Msk (0x1UL << HRTIM_FLTINR2_FLT5LCK_Pos)
28242#define HRTIM_FLTINR2_FLT5LCK HRTIM_FLTINR2_FLT5LCK_Msk
28243#define HRTIM_FLTINR2_FLTSD_Pos (24U)
28244#define HRTIM_FLTINR2_FLTSD_Msk (0x3UL << HRTIM_FLTINR2_FLTSD_Pos)
28245#define HRTIM_FLTINR2_FLTSD HRTIM_FLTINR2_FLTSD_Msk
28246#define HRTIM_FLTINR2_FLTSD_0 (0x1UL << HRTIM_FLTINR2_FLTSD_Pos)
28247#define HRTIM_FLTINR2_FLTSD_1 (0x2UL << HRTIM_FLTINR2_FLTSD_Pos)
28249/******************* Bit definition for HRTIM_BDMUPR register ***************/
28250#define HRTIM_BDMUPR_MCR_Pos (0U)
28251#define HRTIM_BDMUPR_MCR_Msk (0x1UL << HRTIM_BDMUPR_MCR_Pos)
28252#define HRTIM_BDMUPR_MCR HRTIM_BDMUPR_MCR_Msk
28253#define HRTIM_BDMUPR_MICR_Pos (1U)
28254#define HRTIM_BDMUPR_MICR_Msk (0x1UL << HRTIM_BDMUPR_MICR_Pos)
28255#define HRTIM_BDMUPR_MICR HRTIM_BDMUPR_MICR_Msk
28256#define HRTIM_BDMUPR_MDIER_Pos (2U)
28257#define HRTIM_BDMUPR_MDIER_Msk (0x1UL << HRTIM_BDMUPR_MDIER_Pos)
28258#define HRTIM_BDMUPR_MDIER HRTIM_BDMUPR_MDIER_Msk
28259#define HRTIM_BDMUPR_MCNT_Pos (3U)
28260#define HRTIM_BDMUPR_MCNT_Msk (0x1UL << HRTIM_BDMUPR_MCNT_Pos)
28261#define HRTIM_BDMUPR_MCNT HRTIM_BDMUPR_MCNT_Msk
28262#define HRTIM_BDMUPR_MPER_Pos (4U)
28263#define HRTIM_BDMUPR_MPER_Msk (0x1UL << HRTIM_BDMUPR_MPER_Pos)
28264#define HRTIM_BDMUPR_MPER HRTIM_BDMUPR_MPER_Msk
28265#define HRTIM_BDMUPR_MREP_Pos (5U)
28266#define HRTIM_BDMUPR_MREP_Msk (0x1UL << HRTIM_BDMUPR_MREP_Pos)
28267#define HRTIM_BDMUPR_MREP HRTIM_BDMUPR_MREP_Msk
28268#define HRTIM_BDMUPR_MCMP1_Pos (6U)
28269#define HRTIM_BDMUPR_MCMP1_Msk (0x1UL << HRTIM_BDMUPR_MCMP1_Pos)
28270#define HRTIM_BDMUPR_MCMP1 HRTIM_BDMUPR_MCMP1_Msk
28271#define HRTIM_BDMUPR_MCMP2_Pos (7U)
28272#define HRTIM_BDMUPR_MCMP2_Msk (0x1UL << HRTIM_BDMUPR_MCMP2_Pos)
28273#define HRTIM_BDMUPR_MCMP2 HRTIM_BDMUPR_MCMP2_Msk
28274#define HRTIM_BDMUPR_MCMP3_Pos (8U)
28275#define HRTIM_BDMUPR_MCMP3_Msk (0x1UL << HRTIM_BDMUPR_MCMP3_Pos)
28276#define HRTIM_BDMUPR_MCMP3 HRTIM_BDMUPR_MCMP3_Msk
28277#define HRTIM_BDMUPR_MCMP4_Pos (9U)
28278#define HRTIM_BDMUPR_MCMP4_Msk (0x1UL << HRTIM_BDMUPR_MCMP4_Pos)
28279#define HRTIM_BDMUPR_MCMP4 HRTIM_BDMUPR_MCMP4_Msk
28281/******************* Bit definition for HRTIM_BDTUPR register ***************/
28282#define HRTIM_BDTUPR_TIMCR_Pos (0U)
28283#define HRTIM_BDTUPR_TIMCR_Msk (0x1UL << HRTIM_BDTUPR_TIMCR_Pos)
28284#define HRTIM_BDTUPR_TIMCR HRTIM_BDTUPR_TIMCR_Msk
28285#define HRTIM_BDTUPR_TIMICR_Pos (1U)
28286#define HRTIM_BDTUPR_TIMICR_Msk (0x1UL << HRTIM_BDTUPR_TIMICR_Pos)
28287#define HRTIM_BDTUPR_TIMICR HRTIM_BDTUPR_TIMICR_Msk
28288#define HRTIM_BDTUPR_TIMDIER_Pos (2U)
28289#define HRTIM_BDTUPR_TIMDIER_Msk (0x1UL << HRTIM_BDTUPR_TIMDIER_Pos)
28290#define HRTIM_BDTUPR_TIMDIER HRTIM_BDTUPR_TIMDIER_Msk
28291#define HRTIM_BDTUPR_TIMCNT_Pos (3U)
28292#define HRTIM_BDTUPR_TIMCNT_Msk (0x1UL << HRTIM_BDTUPR_TIMCNT_Pos)
28293#define HRTIM_BDTUPR_TIMCNT HRTIM_BDTUPR_TIMCNT_Msk
28294#define HRTIM_BDTUPR_TIMPER_Pos (4U)
28295#define HRTIM_BDTUPR_TIMPER_Msk (0x1UL << HRTIM_BDTUPR_TIMPER_Pos)
28296#define HRTIM_BDTUPR_TIMPER HRTIM_BDTUPR_TIMPER_Msk
28297#define HRTIM_BDTUPR_TIMREP_Pos (5U)
28298#define HRTIM_BDTUPR_TIMREP_Msk (0x1UL << HRTIM_BDTUPR_TIMREP_Pos)
28299#define HRTIM_BDTUPR_TIMREP HRTIM_BDTUPR_TIMREP_Msk
28300#define HRTIM_BDTUPR_TIMCMP1_Pos (6U)
28301#define HRTIM_BDTUPR_TIMCMP1_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP1_Pos)
28302#define HRTIM_BDTUPR_TIMCMP1 HRTIM_BDTUPR_TIMCMP1_Msk
28303#define HRTIM_BDTUPR_TIMCMP2_Pos (7U)
28304#define HRTIM_BDTUPR_TIMCMP2_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP2_Pos)
28305#define HRTIM_BDTUPR_TIMCMP2 HRTIM_BDTUPR_TIMCMP2_Msk
28306#define HRTIM_BDTUPR_TIMCMP3_Pos (8U)
28307#define HRTIM_BDTUPR_TIMCMP3_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP3_Pos)
28308#define HRTIM_BDTUPR_TIMCMP3 HRTIM_BDTUPR_TIMCMP3_Msk
28309#define HRTIM_BDTUPR_TIMCMP4_Pos (9U)
28310#define HRTIM_BDTUPR_TIMCMP4_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP4_Pos)
28311#define HRTIM_BDTUPR_TIMCMP4 HRTIM_BDTUPR_TIMCMP4_Msk
28312#define HRTIM_BDTUPR_TIMDTR_Pos (10U)
28313#define HRTIM_BDTUPR_TIMDTR_Msk (0x1UL << HRTIM_BDTUPR_TIMDTR_Pos)
28314#define HRTIM_BDTUPR_TIMDTR HRTIM_BDTUPR_TIMDTR_Msk
28315#define HRTIM_BDTUPR_TIMSET1R_Pos (11U)
28316#define HRTIM_BDTUPR_TIMSET1R_Msk (0x1UL << HRTIM_BDTUPR_TIMSET1R_Pos)
28317#define HRTIM_BDTUPR_TIMSET1R HRTIM_BDTUPR_TIMSET1R_Msk
28318#define HRTIM_BDTUPR_TIMRST1R_Pos (12U)
28319#define HRTIM_BDTUPR_TIMRST1R_Msk (0x1UL << HRTIM_BDTUPR_TIMRST1R_Pos)
28320#define HRTIM_BDTUPR_TIMRST1R HRTIM_BDTUPR_TIMRST1R_Msk
28321#define HRTIM_BDTUPR_TIMSET2R_Pos (13U)
28322#define HRTIM_BDTUPR_TIMSET2R_Msk (0x1UL << HRTIM_BDTUPR_TIMSET2R_Pos)
28323#define HRTIM_BDTUPR_TIMSET2R HRTIM_BDTUPR_TIMSET2R_Msk
28324#define HRTIM_BDTUPR_TIMRST2R_Pos (14U)
28325#define HRTIM_BDTUPR_TIMRST2R_Msk (0x1UL << HRTIM_BDTUPR_TIMRST2R_Pos)
28326#define HRTIM_BDTUPR_TIMRST2R HRTIM_BDTUPR_TIMRST2R_Msk
28327#define HRTIM_BDTUPR_TIMEEFR1_Pos (15U)
28328#define HRTIM_BDTUPR_TIMEEFR1_Msk (0x1UL << HRTIM_BDTUPR_TIMEEFR1_Pos)
28329#define HRTIM_BDTUPR_TIMEEFR1 HRTIM_BDTUPR_TIMEEFR1_Msk
28330#define HRTIM_BDTUPR_TIMEEFR2_Pos (16U)
28331#define HRTIM_BDTUPR_TIMEEFR2_Msk (0x1UL << HRTIM_BDTUPR_TIMEEFR2_Pos)
28332#define HRTIM_BDTUPR_TIMEEFR2 HRTIM_BDTUPR_TIMEEFR2_Msk
28333#define HRTIM_BDTUPR_TIMRSTR_Pos (17U)
28334#define HRTIM_BDTUPR_TIMRSTR_Msk (0x1UL << HRTIM_BDTUPR_TIMRSTR_Pos)
28335#define HRTIM_BDTUPR_TIMRSTR HRTIM_BDTUPR_TIMRSTR_Msk
28336#define HRTIM_BDTUPR_TIMCHPR_Pos (18U)
28337#define HRTIM_BDTUPR_TIMCHPR_Msk (0x1UL << HRTIM_BDTUPR_TIMCHPR_Pos)
28338#define HRTIM_BDTUPR_TIMCHPR HRTIM_BDTUPR_TIMCHPR_Msk
28339#define HRTIM_BDTUPR_TIMOUTR_Pos (19U)
28340#define HRTIM_BDTUPR_TIMOUTR_Msk (0x1UL << HRTIM_BDTUPR_TIMOUTR_Pos)
28341#define HRTIM_BDTUPR_TIMOUTR HRTIM_BDTUPR_TIMOUTR_Msk
28342#define HRTIM_BDTUPR_TIMFLTR_Pos (20U)
28343#define HRTIM_BDTUPR_TIMFLTR_Msk (0x1UL << HRTIM_BDTUPR_TIMFLTR_Pos)
28344#define HRTIM_BDTUPR_TIMFLTR HRTIM_BDTUPR_TIMFLTR_Msk
28346/******************* Bit definition for HRTIM_BDMADR register ***************/
28347#define HRTIM_BDMADR_BDMADR_Pos (0U)
28348#define HRTIM_BDMADR_BDMADR_Msk (0xFFFFFFFFUL << HRTIM_BDMADR_BDMADR_Pos)
28349#define HRTIM_BDMADR_BDMADR HRTIM_BDMADR_BDMADR_Msk
28351/******************************************************************************/
28352/* */
28353/* RAM ECC monitoring */
28354/* */
28355/******************************************************************************/
28356/****************** Bit definition for RAMECC_IER register ******************/
28357#define RAMECC_IER_GECCDEBWIE_Pos (3U)
28358#define RAMECC_IER_GECCDEBWIE_Msk (0x1UL << RAMECC_IER_GECCDEBWIE_Pos)
28359#define RAMECC_IER_GECCDEBWIE RAMECC_IER_GECCDEBWIE_Msk
28360#define RAMECC_IER_GECCDEIE_Pos (2U)
28361#define RAMECC_IER_GECCDEIE_Msk (0x1UL << RAMECC_IER_GECCDEIE_Pos)
28362#define RAMECC_IER_GECCDEIE RAMECC_IER_GECCDEIE_Msk
28363#define RAMECC_IER_GECCSEIE_Pos (1U)
28364#define RAMECC_IER_GECCSEIE_Msk (0x1UL << RAMECC_IER_GECCSEIE_Pos)
28365#define RAMECC_IER_GECCSEIE RAMECC_IER_GECCSEIE_Msk
28366#define RAMECC_IER_GIE_Pos (0U)
28367#define RAMECC_IER_GIE_Msk (0x1UL << RAMECC_IER_GIE_Pos)
28368#define RAMECC_IER_GIE RAMECC_IER_GIE_Msk
28370/******************* Bit definition for RAMECC_CR register ******************/
28371#define RAMECC_CR_ECCELEN_Pos (5U)
28372#define RAMECC_CR_ECCELEN_Msk (0x1UL << RAMECC_CR_ECCELEN_Pos)
28373#define RAMECC_CR_ECCELEN RAMECC_CR_ECCELEN_Msk
28374#define RAMECC_CR_ECCDEBWIE_Pos (4U)
28375#define RAMECC_CR_ECCDEBWIE_Msk (0x1UL << RAMECC_CR_ECCDEBWIE_Pos)
28376#define RAMECC_CR_ECCDEBWIE RAMECC_CR_ECCDEBWIE_Msk
28377#define RAMECC_CR_ECCDEIE_Pos (3U)
28378#define RAMECC_CR_ECCDEIE_Msk (0x1UL << RAMECC_CR_ECCDEIE_Pos)
28379#define RAMECC_CR_ECCDEIE RAMECC_CR_ECCDEIE_Msk
28380#define RAMECC_CR_ECCSEIE_Pos (2U)
28381#define RAMECC_CR_ECCSEIE_Msk (0x1UL << RAMECC_CR_ECCSEIE_Pos)
28382#define RAMECC_CR_ECCSEIE RAMECC_CR_ECCSEIE_Msk
28384/******************* Bit definition for RAMECC_SR register ******************/
28385#define RAMECC_SR_DEBWDF_Pos (2U)
28386#define RAMECC_SR_DEBWDF_Msk (0x1UL << RAMECC_SR_DEBWDF_Pos)
28387#define RAMECC_SR_DEBWDF RAMECC_SR_DEBWDF_Msk
28388#define RAMECC_SR_DEDF_Pos (1U)
28389#define RAMECC_SR_DEDF_Msk (0x1UL << RAMECC_SR_DEDF_Pos)
28390#define RAMECC_SR_DEDF RAMECC_SR_DEDF_Msk
28391#define RAMECC_SR_SEDCF_Pos (0U)
28392#define RAMECC_SR_SEDCF_Msk (0x1UL << RAMECC_SR_SEDCF_Pos)
28393#define RAMECC_SR_SEDCF RAMECC_SR_SEDCF_Msk
28395/****************** Bit definition for RAMECC_FAR register ******************/
28396#define RAMECC_FAR_FADD_Pos (0U)
28397#define RAMECC_FAR_FADD_Msk (0xFFFFFFFFUL << RAMECC_FAR_FADD_Pos)
28398#define RAMECC_FAR_FADD RAMECC_FAR_FADD_Msk
28400/****************** Bit definition for RAMECC_FDRL register *****************/
28401#define RAMECC_FAR_FDATAL_Pos (0U)
28402#define RAMECC_FAR_FDATAL_Msk (0xFFFFFFFFUL << RAMECC_FAR_FDATAL_Pos)
28403#define RAMECC_FAR_FDATAL RAMECC_FAR_FDATAL_Msk
28405/****************** Bit definition for RAMECC_FDRH register *****************/
28406#define RAMECC_FAR_FDATAH_Pos (0U)
28407#define RAMECC_FAR_FDATAH_Msk (0xFFFFFFFFUL << RAMECC_FAR_FDATAH_Pos)
28408#define RAMECC_FAR_FDATAH RAMECC_FAR_FDATAH_Msk /* Failing data high (64-bit memory) */
28409
28410/***************** Bit definition for RAMECC_FECR register ******************/
28411#define RAMECC_FECR_FEC_Pos (0U)
28412#define RAMECC_FECR_FEC_Msk (0xFFFFFFFFUL << RAMECC_FECR_FEC_Pos)
28413#define RAMECC_FECR_FEC RAMECC_FECR_FEC_Msk
28415/******************************************************************************/
28416/* */
28417/* MDIOS */
28418/* */
28419/******************************************************************************/
28420/******************** Bit definition for MDIOS_CR register *******************/
28421#define MDIOS_CR_EN_Pos (0U)
28422#define MDIOS_CR_EN_Msk (0x1UL << MDIOS_CR_EN_Pos)
28423#define MDIOS_CR_EN MDIOS_CR_EN_Msk
28424#define MDIOS_CR_WRIE_Pos (1U)
28425#define MDIOS_CR_WRIE_Msk (0x1UL << MDIOS_CR_WRIE_Pos)
28426#define MDIOS_CR_WRIE MDIOS_CR_WRIE_Msk
28427#define MDIOS_CR_RDIE_Pos (2U)
28428#define MDIOS_CR_RDIE_Msk (0x1UL << MDIOS_CR_RDIE_Pos)
28429#define MDIOS_CR_RDIE MDIOS_CR_RDIE_Msk
28430#define MDIOS_CR_EIE_Pos (3U)
28431#define MDIOS_CR_EIE_Msk (0x1UL << MDIOS_CR_EIE_Pos)
28432#define MDIOS_CR_EIE MDIOS_CR_EIE_Msk
28433#define MDIOS_CR_DPC_Pos (7U)
28434#define MDIOS_CR_DPC_Msk (0x1UL << MDIOS_CR_DPC_Pos)
28435#define MDIOS_CR_DPC MDIOS_CR_DPC_Msk
28436#define MDIOS_CR_PORT_ADDRESS_Pos (8U)
28437#define MDIOS_CR_PORT_ADDRESS_Msk (0x1FUL << MDIOS_CR_PORT_ADDRESS_Pos)
28438#define MDIOS_CR_PORT_ADDRESS MDIOS_CR_PORT_ADDRESS_Msk
28439#define MDIOS_CR_PORT_ADDRESS_0 (0x01UL << MDIOS_CR_PORT_ADDRESS_Pos)
28440#define MDIOS_CR_PORT_ADDRESS_1 (0x02UL << MDIOS_CR_PORT_ADDRESS_Pos)
28441#define MDIOS_CR_PORT_ADDRESS_2 (0x04UL << MDIOS_CR_PORT_ADDRESS_Pos)
28442#define MDIOS_CR_PORT_ADDRESS_3 (0x08UL << MDIOS_CR_PORT_ADDRESS_Pos)
28443#define MDIOS_CR_PORT_ADDRESS_4 (0x10UL << MDIOS_CR_PORT_ADDRESS_Pos)
28445/******************** Bit definition for MDIOS_SR register *******************/
28446#define MDIOS_SR_PERF_Pos (0U)
28447#define MDIOS_SR_PERF_Msk (0x1UL << MDIOS_SR_PERF_Pos)
28448#define MDIOS_SR_PERF MDIOS_SR_PERF_Msk
28449#define MDIOS_SR_SERF_Pos (1U)
28450#define MDIOS_SR_SERF_Msk (0x1UL << MDIOS_SR_SERF_Pos)
28451#define MDIOS_SR_SERF MDIOS_SR_SERF_Msk
28452#define MDIOS_SR_TERF_Pos (2U)
28453#define MDIOS_SR_TERF_Msk (0x1UL << MDIOS_SR_TERF_Pos)
28454#define MDIOS_SR_TERF MDIOS_SR_TERF_Msk
28456/******************** Bit definition for MDIOS_CLRFR register *******************/
28457#define MDIOS_SR_CPERF_Pos (0U)
28458#define MDIOS_SR_CPERF_Msk (0x1UL << MDIOS_SR_CPERF_Pos)
28459#define MDIOS_SR_CPERF MDIOS_SR_CPERF_Msk
28460#define MDIOS_SR_CSERF_Pos (1U)
28461#define MDIOS_SR_CSERF_Msk (0x1UL << MDIOS_SR_CSERF_Pos)
28462#define MDIOS_SR_CSERF MDIOS_SR_CSERF_Msk
28463#define MDIOS_SR_CTERF_Pos (2U)
28464#define MDIOS_SR_CTERF_Msk (0x1UL << MDIOS_SR_CTERF_Pos)
28465#define MDIOS_SR_CTERF MDIOS_SR_CTERF_Msk
28467/******************************************************************************/
28468/* */
28469/* USB_OTG */
28470/* */
28471/******************************************************************************/
28472/******************** Bit definition forUSB_OTG_GOTGCTL register ********************/
28473#define USB_OTG_GOTGCTL_SRQSCS_Pos (0U)
28474#define USB_OTG_GOTGCTL_SRQSCS_Msk (0x1UL << USB_OTG_GOTGCTL_SRQSCS_Pos)
28475#define USB_OTG_GOTGCTL_SRQSCS USB_OTG_GOTGCTL_SRQSCS_Msk
28476#define USB_OTG_GOTGCTL_SRQ_Pos (1U)
28477#define USB_OTG_GOTGCTL_SRQ_Msk (0x1UL << USB_OTG_GOTGCTL_SRQ_Pos)
28478#define USB_OTG_GOTGCTL_SRQ USB_OTG_GOTGCTL_SRQ_Msk
28479#define USB_OTG_GOTGCTL_VBVALOEN_Pos (2U)
28480#define USB_OTG_GOTGCTL_VBVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_VBVALOEN_Pos)
28481#define USB_OTG_GOTGCTL_VBVALOEN USB_OTG_GOTGCTL_VBVALOEN_Msk
28482#define USB_OTG_GOTGCTL_VBVALOVAL_Pos (3U)
28483#define USB_OTG_GOTGCTL_VBVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_VBVALOVAL_Pos)
28484#define USB_OTG_GOTGCTL_VBVALOVAL USB_OTG_GOTGCTL_VBVALOVAL_Msk
28485#define USB_OTG_GOTGCTL_AVALOEN_Pos (4U)
28486#define USB_OTG_GOTGCTL_AVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_AVALOEN_Pos)
28487#define USB_OTG_GOTGCTL_AVALOEN USB_OTG_GOTGCTL_AVALOEN_Msk
28488#define USB_OTG_GOTGCTL_AVALOVAL_Pos (5U)
28489#define USB_OTG_GOTGCTL_AVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_AVALOVAL_Pos)
28490#define USB_OTG_GOTGCTL_AVALOVAL USB_OTG_GOTGCTL_AVALOVAL_Msk
28491#define USB_OTG_GOTGCTL_BVALOEN_Pos (6U)
28492#define USB_OTG_GOTGCTL_BVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_BVALOEN_Pos)
28493#define USB_OTG_GOTGCTL_BVALOEN USB_OTG_GOTGCTL_BVALOEN_Msk
28494#define USB_OTG_GOTGCTL_BVALOVAL_Pos (7U)
28495#define USB_OTG_GOTGCTL_BVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_BVALOVAL_Pos)
28496#define USB_OTG_GOTGCTL_BVALOVAL USB_OTG_GOTGCTL_BVALOVAL_Msk
28497#define USB_OTG_GOTGCTL_HNGSCS_Pos (8U)
28498#define USB_OTG_GOTGCTL_HNGSCS_Msk (0x1UL << USB_OTG_GOTGCTL_HNGSCS_Pos)
28499#define USB_OTG_GOTGCTL_HNGSCS USB_OTG_GOTGCTL_HNGSCS_Msk
28500#define USB_OTG_GOTGCTL_HNPRQ_Pos (9U)
28501#define USB_OTG_GOTGCTL_HNPRQ_Msk (0x1UL << USB_OTG_GOTGCTL_HNPRQ_Pos)
28502#define USB_OTG_GOTGCTL_HNPRQ USB_OTG_GOTGCTL_HNPRQ_Msk
28503#define USB_OTG_GOTGCTL_HSHNPEN_Pos (10U)
28504#define USB_OTG_GOTGCTL_HSHNPEN_Msk (0x1UL << USB_OTG_GOTGCTL_HSHNPEN_Pos)
28505#define USB_OTG_GOTGCTL_HSHNPEN USB_OTG_GOTGCTL_HSHNPEN_Msk
28506#define USB_OTG_GOTGCTL_DHNPEN_Pos (11U)
28507#define USB_OTG_GOTGCTL_DHNPEN_Msk (0x1UL << USB_OTG_GOTGCTL_DHNPEN_Pos)
28508#define USB_OTG_GOTGCTL_DHNPEN USB_OTG_GOTGCTL_DHNPEN_Msk
28509#define USB_OTG_GOTGCTL_EHEN_Pos (12U)
28510#define USB_OTG_GOTGCTL_EHEN_Msk (0x1UL << USB_OTG_GOTGCTL_EHEN_Pos)
28511#define USB_OTG_GOTGCTL_EHEN USB_OTG_GOTGCTL_EHEN_Msk
28512#define USB_OTG_GOTGCTL_CIDSTS_Pos (16U)
28513#define USB_OTG_GOTGCTL_CIDSTS_Msk (0x1UL << USB_OTG_GOTGCTL_CIDSTS_Pos)
28514#define USB_OTG_GOTGCTL_CIDSTS USB_OTG_GOTGCTL_CIDSTS_Msk
28515#define USB_OTG_GOTGCTL_DBCT_Pos (17U)
28516#define USB_OTG_GOTGCTL_DBCT_Msk (0x1UL << USB_OTG_GOTGCTL_DBCT_Pos)
28517#define USB_OTG_GOTGCTL_DBCT USB_OTG_GOTGCTL_DBCT_Msk
28518#define USB_OTG_GOTGCTL_ASVLD_Pos (18U)
28519#define USB_OTG_GOTGCTL_ASVLD_Msk (0x1UL << USB_OTG_GOTGCTL_ASVLD_Pos)
28520#define USB_OTG_GOTGCTL_ASVLD USB_OTG_GOTGCTL_ASVLD_Msk
28521#define USB_OTG_GOTGCTL_BSESVLD_Pos (19U)
28522#define USB_OTG_GOTGCTL_BSESVLD_Msk (0x1UL << USB_OTG_GOTGCTL_BSESVLD_Pos)
28523#define USB_OTG_GOTGCTL_BSESVLD USB_OTG_GOTGCTL_BSESVLD_Msk
28524#define USB_OTG_GOTGCTL_OTGVER_Pos (20U)
28525#define USB_OTG_GOTGCTL_OTGVER_Msk (0x1UL << USB_OTG_GOTGCTL_OTGVER_Pos)
28526#define USB_OTG_GOTGCTL_OTGVER USB_OTG_GOTGCTL_OTGVER_Msk
28527#define USB_OTG_GOTGCTL_CURMOD_Pos (21U)
28528#define USB_OTG_GOTGCTL_CURMOD_Msk (0x1UL << USB_OTG_GOTGCTL_CURMOD_Pos)
28529#define USB_OTG_GOTGCTL_CURMOD USB_OTG_GOTGCTL_CURMOD_Msk
28531/******************** Bit definition forUSB_OTG_HCFG register ********************/
28532
28533#define USB_OTG_HCFG_FSLSPCS_Pos (0U)
28534#define USB_OTG_HCFG_FSLSPCS_Msk (0x3UL << USB_OTG_HCFG_FSLSPCS_Pos)
28535#define USB_OTG_HCFG_FSLSPCS USB_OTG_HCFG_FSLSPCS_Msk
28536#define USB_OTG_HCFG_FSLSPCS_0 (0x1UL << USB_OTG_HCFG_FSLSPCS_Pos)
28537#define USB_OTG_HCFG_FSLSPCS_1 (0x2UL << USB_OTG_HCFG_FSLSPCS_Pos)
28538#define USB_OTG_HCFG_FSLSS_Pos (2U)
28539#define USB_OTG_HCFG_FSLSS_Msk (0x1UL << USB_OTG_HCFG_FSLSS_Pos)
28540#define USB_OTG_HCFG_FSLSS USB_OTG_HCFG_FSLSS_Msk
28542/******************** Bit definition forUSB_OTG_DCFG register ********************/
28543
28544#define USB_OTG_DCFG_DSPD_Pos (0U)
28545#define USB_OTG_DCFG_DSPD_Msk (0x3UL << USB_OTG_DCFG_DSPD_Pos)
28546#define USB_OTG_DCFG_DSPD USB_OTG_DCFG_DSPD_Msk
28547#define USB_OTG_DCFG_DSPD_0 (0x1UL << USB_OTG_DCFG_DSPD_Pos)
28548#define USB_OTG_DCFG_DSPD_1 (0x2UL << USB_OTG_DCFG_DSPD_Pos)
28549#define USB_OTG_DCFG_NZLSOHSK_Pos (2U)
28550#define USB_OTG_DCFG_NZLSOHSK_Msk (0x1UL << USB_OTG_DCFG_NZLSOHSK_Pos)
28551#define USB_OTG_DCFG_NZLSOHSK USB_OTG_DCFG_NZLSOHSK_Msk
28553#define USB_OTG_DCFG_DAD_Pos (4U)
28554#define USB_OTG_DCFG_DAD_Msk (0x7FUL << USB_OTG_DCFG_DAD_Pos)
28555#define USB_OTG_DCFG_DAD USB_OTG_DCFG_DAD_Msk
28556#define USB_OTG_DCFG_DAD_0 (0x01UL << USB_OTG_DCFG_DAD_Pos)
28557#define USB_OTG_DCFG_DAD_1 (0x02UL << USB_OTG_DCFG_DAD_Pos)
28558#define USB_OTG_DCFG_DAD_2 (0x04UL << USB_OTG_DCFG_DAD_Pos)
28559#define USB_OTG_DCFG_DAD_3 (0x08UL << USB_OTG_DCFG_DAD_Pos)
28560#define USB_OTG_DCFG_DAD_4 (0x10UL << USB_OTG_DCFG_DAD_Pos)
28561#define USB_OTG_DCFG_DAD_5 (0x20UL << USB_OTG_DCFG_DAD_Pos)
28562#define USB_OTG_DCFG_DAD_6 (0x40UL << USB_OTG_DCFG_DAD_Pos)
28564#define USB_OTG_DCFG_PFIVL_Pos (11U)
28565#define USB_OTG_DCFG_PFIVL_Msk (0x3UL << USB_OTG_DCFG_PFIVL_Pos)
28566#define USB_OTG_DCFG_PFIVL USB_OTG_DCFG_PFIVL_Msk
28567#define USB_OTG_DCFG_PFIVL_0 (0x1UL << USB_OTG_DCFG_PFIVL_Pos)
28568#define USB_OTG_DCFG_PFIVL_1 (0x2UL << USB_OTG_DCFG_PFIVL_Pos)
28570#define USB_OTG_DCFG_XCVRDLY_Pos (14U)
28571#define USB_OTG_DCFG_XCVRDLY_Msk (0x1UL << USB_OTG_DCFG_XCVRDLY_Pos)
28572#define USB_OTG_DCFG_XCVRDLY USB_OTG_DCFG_XCVRDLY_Msk
28574#define USB_OTG_DCFG_ERRATIM_Pos (15U)
28575#define USB_OTG_DCFG_ERRATIM_Msk (0x1UL << USB_OTG_DCFG_ERRATIM_Pos)
28576#define USB_OTG_DCFG_ERRATIM USB_OTG_DCFG_ERRATIM_Msk
28578#define USB_OTG_DCFG_PERSCHIVL_Pos (24U)
28579#define USB_OTG_DCFG_PERSCHIVL_Msk (0x3UL << USB_OTG_DCFG_PERSCHIVL_Pos)
28580#define USB_OTG_DCFG_PERSCHIVL USB_OTG_DCFG_PERSCHIVL_Msk
28581#define USB_OTG_DCFG_PERSCHIVL_0 (0x1UL << USB_OTG_DCFG_PERSCHIVL_Pos)
28582#define USB_OTG_DCFG_PERSCHIVL_1 (0x2UL << USB_OTG_DCFG_PERSCHIVL_Pos)
28584/******************** Bit definition forUSB_OTG_PCGCR register ********************/
28585#define USB_OTG_PCGCR_STPPCLK_Pos (0U)
28586#define USB_OTG_PCGCR_STPPCLK_Msk (0x1UL << USB_OTG_PCGCR_STPPCLK_Pos)
28587#define USB_OTG_PCGCR_STPPCLK USB_OTG_PCGCR_STPPCLK_Msk
28588#define USB_OTG_PCGCR_GATEHCLK_Pos (1U)
28589#define USB_OTG_PCGCR_GATEHCLK_Msk (0x1UL << USB_OTG_PCGCR_GATEHCLK_Pos)
28590#define USB_OTG_PCGCR_GATEHCLK USB_OTG_PCGCR_GATEHCLK_Msk
28591#define USB_OTG_PCGCR_PHYSUSP_Pos (4U)
28592#define USB_OTG_PCGCR_PHYSUSP_Msk (0x1UL << USB_OTG_PCGCR_PHYSUSP_Pos)
28593#define USB_OTG_PCGCR_PHYSUSP USB_OTG_PCGCR_PHYSUSP_Msk
28595/******************** Bit definition forUSB_OTG_GOTGINT register ********************/
28596#define USB_OTG_GOTGINT_SEDET_Pos (2U)
28597#define USB_OTG_GOTGINT_SEDET_Msk (0x1UL << USB_OTG_GOTGINT_SEDET_Pos)
28598#define USB_OTG_GOTGINT_SEDET USB_OTG_GOTGINT_SEDET_Msk
28599#define USB_OTG_GOTGINT_SRSSCHG_Pos (8U)
28600#define USB_OTG_GOTGINT_SRSSCHG_Msk (0x1UL << USB_OTG_GOTGINT_SRSSCHG_Pos)
28601#define USB_OTG_GOTGINT_SRSSCHG USB_OTG_GOTGINT_SRSSCHG_Msk
28602#define USB_OTG_GOTGINT_HNSSCHG_Pos (9U)
28603#define USB_OTG_GOTGINT_HNSSCHG_Msk (0x1UL << USB_OTG_GOTGINT_HNSSCHG_Pos)
28604#define USB_OTG_GOTGINT_HNSSCHG USB_OTG_GOTGINT_HNSSCHG_Msk
28605#define USB_OTG_GOTGINT_HNGDET_Pos (17U)
28606#define USB_OTG_GOTGINT_HNGDET_Msk (0x1UL << USB_OTG_GOTGINT_HNGDET_Pos)
28607#define USB_OTG_GOTGINT_HNGDET USB_OTG_GOTGINT_HNGDET_Msk
28608#define USB_OTG_GOTGINT_ADTOCHG_Pos (18U)
28609#define USB_OTG_GOTGINT_ADTOCHG_Msk (0x1UL << USB_OTG_GOTGINT_ADTOCHG_Pos)
28610#define USB_OTG_GOTGINT_ADTOCHG USB_OTG_GOTGINT_ADTOCHG_Msk
28611#define USB_OTG_GOTGINT_DBCDNE_Pos (19U)
28612#define USB_OTG_GOTGINT_DBCDNE_Msk (0x1UL << USB_OTG_GOTGINT_DBCDNE_Pos)
28613#define USB_OTG_GOTGINT_DBCDNE USB_OTG_GOTGINT_DBCDNE_Msk
28615/******************** Bit definition forUSB_OTG_DCTL register ********************/
28616#define USB_OTG_DCTL_RWUSIG_Pos (0U)
28617#define USB_OTG_DCTL_RWUSIG_Msk (0x1UL << USB_OTG_DCTL_RWUSIG_Pos)
28618#define USB_OTG_DCTL_RWUSIG USB_OTG_DCTL_RWUSIG_Msk
28619#define USB_OTG_DCTL_SDIS_Pos (1U)
28620#define USB_OTG_DCTL_SDIS_Msk (0x1UL << USB_OTG_DCTL_SDIS_Pos)
28621#define USB_OTG_DCTL_SDIS USB_OTG_DCTL_SDIS_Msk
28622#define USB_OTG_DCTL_GINSTS_Pos (2U)
28623#define USB_OTG_DCTL_GINSTS_Msk (0x1UL << USB_OTG_DCTL_GINSTS_Pos)
28624#define USB_OTG_DCTL_GINSTS USB_OTG_DCTL_GINSTS_Msk
28625#define USB_OTG_DCTL_GONSTS_Pos (3U)
28626#define USB_OTG_DCTL_GONSTS_Msk (0x1UL << USB_OTG_DCTL_GONSTS_Pos)
28627#define USB_OTG_DCTL_GONSTS USB_OTG_DCTL_GONSTS_Msk
28629#define USB_OTG_DCTL_TCTL_Pos (4U)
28630#define USB_OTG_DCTL_TCTL_Msk (0x7UL << USB_OTG_DCTL_TCTL_Pos)
28631#define USB_OTG_DCTL_TCTL USB_OTG_DCTL_TCTL_Msk
28632#define USB_OTG_DCTL_TCTL_0 (0x1UL << USB_OTG_DCTL_TCTL_Pos)
28633#define USB_OTG_DCTL_TCTL_1 (0x2UL << USB_OTG_DCTL_TCTL_Pos)
28634#define USB_OTG_DCTL_TCTL_2 (0x4UL << USB_OTG_DCTL_TCTL_Pos)
28635#define USB_OTG_DCTL_SGINAK_Pos (7U)
28636#define USB_OTG_DCTL_SGINAK_Msk (0x1UL << USB_OTG_DCTL_SGINAK_Pos)
28637#define USB_OTG_DCTL_SGINAK USB_OTG_DCTL_SGINAK_Msk
28638#define USB_OTG_DCTL_CGINAK_Pos (8U)
28639#define USB_OTG_DCTL_CGINAK_Msk (0x1UL << USB_OTG_DCTL_CGINAK_Pos)
28640#define USB_OTG_DCTL_CGINAK USB_OTG_DCTL_CGINAK_Msk
28641#define USB_OTG_DCTL_SGONAK_Pos (9U)
28642#define USB_OTG_DCTL_SGONAK_Msk (0x1UL << USB_OTG_DCTL_SGONAK_Pos)
28643#define USB_OTG_DCTL_SGONAK USB_OTG_DCTL_SGONAK_Msk
28644#define USB_OTG_DCTL_CGONAK_Pos (10U)
28645#define USB_OTG_DCTL_CGONAK_Msk (0x1UL << USB_OTG_DCTL_CGONAK_Pos)
28646#define USB_OTG_DCTL_CGONAK USB_OTG_DCTL_CGONAK_Msk
28647#define USB_OTG_DCTL_POPRGDNE_Pos (11U)
28648#define USB_OTG_DCTL_POPRGDNE_Msk (0x1UL << USB_OTG_DCTL_POPRGDNE_Pos)
28649#define USB_OTG_DCTL_POPRGDNE USB_OTG_DCTL_POPRGDNE_Msk
28650#define USB_OTG_DCTL_ENCONTONBNA_Pos (17U)
28651#define USB_OTG_DCTL_ENCONTONBNA_Msk (0x1UL << USB_OTG_DCTL_ENCONTONBNA_Pos)
28652#define USB_OTG_DCTL_ENCONTONBNA USB_OTG_DCTL_ENCONTONBNA_Msk
28653#define USB_OTG_DCTL_DSBESLRJCT_Pos (18U)
28654#define USB_OTG_DCTL_DSBESLRJCT_Msk (0x1UL << USB_OTG_DCTL_DSBESLRJCT_Pos)
28655#define USB_OTG_DCTL_DSBESLRJCT USB_OTG_DCTL_DSBESLRJCT_Msk
28657/******************** Bit definition forUSB_OTG_HFIR register ********************/
28658#define USB_OTG_HFIR_FRIVL_Pos (0U)
28659#define USB_OTG_HFIR_FRIVL_Msk (0xFFFFUL << USB_OTG_HFIR_FRIVL_Pos)
28660#define USB_OTG_HFIR_FRIVL USB_OTG_HFIR_FRIVL_Msk
28662/******************** Bit definition forUSB_OTG_HFNUM register ********************/
28663#define USB_OTG_HFNUM_FRNUM_Pos (0U)
28664#define USB_OTG_HFNUM_FRNUM_Msk (0xFFFFUL << USB_OTG_HFNUM_FRNUM_Pos)
28665#define USB_OTG_HFNUM_FRNUM USB_OTG_HFNUM_FRNUM_Msk
28666#define USB_OTG_HFNUM_FTREM_Pos (16U)
28667#define USB_OTG_HFNUM_FTREM_Msk (0xFFFFUL << USB_OTG_HFNUM_FTREM_Pos)
28668#define USB_OTG_HFNUM_FTREM USB_OTG_HFNUM_FTREM_Msk
28670/******************** Bit definition forUSB_OTG_DSTS register ********************/
28671#define USB_OTG_DSTS_SUSPSTS_Pos (0U)
28672#define USB_OTG_DSTS_SUSPSTS_Msk (0x1UL << USB_OTG_DSTS_SUSPSTS_Pos)
28673#define USB_OTG_DSTS_SUSPSTS USB_OTG_DSTS_SUSPSTS_Msk
28675#define USB_OTG_DSTS_ENUMSPD_Pos (1U)
28676#define USB_OTG_DSTS_ENUMSPD_Msk (0x3UL << USB_OTG_DSTS_ENUMSPD_Pos)
28677#define USB_OTG_DSTS_ENUMSPD USB_OTG_DSTS_ENUMSPD_Msk
28678#define USB_OTG_DSTS_ENUMSPD_0 (0x1UL << USB_OTG_DSTS_ENUMSPD_Pos)
28679#define USB_OTG_DSTS_ENUMSPD_1 (0x2UL << USB_OTG_DSTS_ENUMSPD_Pos)
28680#define USB_OTG_DSTS_EERR_Pos (3U)
28681#define USB_OTG_DSTS_EERR_Msk (0x1UL << USB_OTG_DSTS_EERR_Pos)
28682#define USB_OTG_DSTS_EERR USB_OTG_DSTS_EERR_Msk
28683#define USB_OTG_DSTS_FNSOF_Pos (8U)
28684#define USB_OTG_DSTS_FNSOF_Msk (0x3FFFUL << USB_OTG_DSTS_FNSOF_Pos)
28685#define USB_OTG_DSTS_FNSOF USB_OTG_DSTS_FNSOF_Msk
28687/******************** Bit definition forUSB_OTG_GAHBCFG register ********************/
28688#define USB_OTG_GAHBCFG_GINT_Pos (0U)
28689#define USB_OTG_GAHBCFG_GINT_Msk (0x1UL << USB_OTG_GAHBCFG_GINT_Pos)
28690#define USB_OTG_GAHBCFG_GINT USB_OTG_GAHBCFG_GINT_Msk
28692#define USB_OTG_GAHBCFG_HBSTLEN_Pos (1U)
28693#define USB_OTG_GAHBCFG_HBSTLEN_Msk (0xFUL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28694#define USB_OTG_GAHBCFG_HBSTLEN USB_OTG_GAHBCFG_HBSTLEN_Msk
28695#define USB_OTG_GAHBCFG_HBSTLEN_0 (0x0UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28696#define USB_OTG_GAHBCFG_HBSTLEN_1 (0x1UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28697#define USB_OTG_GAHBCFG_HBSTLEN_2 (0x3UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28698#define USB_OTG_GAHBCFG_HBSTLEN_3 (0x5UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28699#define USB_OTG_GAHBCFG_HBSTLEN_4 (0x7UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
28700#define USB_OTG_GAHBCFG_DMAEN_Pos (5U)
28701#define USB_OTG_GAHBCFG_DMAEN_Msk (0x1UL << USB_OTG_GAHBCFG_DMAEN_Pos)
28702#define USB_OTG_GAHBCFG_DMAEN USB_OTG_GAHBCFG_DMAEN_Msk
28703#define USB_OTG_GAHBCFG_TXFELVL_Pos (7U)
28704#define USB_OTG_GAHBCFG_TXFELVL_Msk (0x1UL << USB_OTG_GAHBCFG_TXFELVL_Pos)
28705#define USB_OTG_GAHBCFG_TXFELVL USB_OTG_GAHBCFG_TXFELVL_Msk
28706#define USB_OTG_GAHBCFG_PTXFELVL_Pos (8U)
28707#define USB_OTG_GAHBCFG_PTXFELVL_Msk (0x1UL << USB_OTG_GAHBCFG_PTXFELVL_Pos)
28708#define USB_OTG_GAHBCFG_PTXFELVL USB_OTG_GAHBCFG_PTXFELVL_Msk
28710/******************** Bit definition forUSB_OTG_GUSBCFG register ********************/
28711
28712#define USB_OTG_GUSBCFG_TOCAL_Pos (0U)
28713#define USB_OTG_GUSBCFG_TOCAL_Msk (0x7UL << USB_OTG_GUSBCFG_TOCAL_Pos)
28714#define USB_OTG_GUSBCFG_TOCAL USB_OTG_GUSBCFG_TOCAL_Msk
28715#define USB_OTG_GUSBCFG_TOCAL_0 (0x1UL << USB_OTG_GUSBCFG_TOCAL_Pos)
28716#define USB_OTG_GUSBCFG_TOCAL_1 (0x2UL << USB_OTG_GUSBCFG_TOCAL_Pos)
28717#define USB_OTG_GUSBCFG_TOCAL_2 (0x4UL << USB_OTG_GUSBCFG_TOCAL_Pos)
28718#define USB_OTG_GUSBCFG_PHYSEL_Pos (6U)
28719#define USB_OTG_GUSBCFG_PHYSEL_Msk (0x1UL << USB_OTG_GUSBCFG_PHYSEL_Pos)
28720#define USB_OTG_GUSBCFG_PHYSEL USB_OTG_GUSBCFG_PHYSEL_Msk
28721#define USB_OTG_GUSBCFG_SRPCAP_Pos (8U)
28722#define USB_OTG_GUSBCFG_SRPCAP_Msk (0x1UL << USB_OTG_GUSBCFG_SRPCAP_Pos)
28723#define USB_OTG_GUSBCFG_SRPCAP USB_OTG_GUSBCFG_SRPCAP_Msk
28724#define USB_OTG_GUSBCFG_HNPCAP_Pos (9U)
28725#define USB_OTG_GUSBCFG_HNPCAP_Msk (0x1UL << USB_OTG_GUSBCFG_HNPCAP_Pos)
28726#define USB_OTG_GUSBCFG_HNPCAP USB_OTG_GUSBCFG_HNPCAP_Msk
28728#define USB_OTG_GUSBCFG_TRDT_Pos (10U)
28729#define USB_OTG_GUSBCFG_TRDT_Msk (0xFUL << USB_OTG_GUSBCFG_TRDT_Pos)
28730#define USB_OTG_GUSBCFG_TRDT USB_OTG_GUSBCFG_TRDT_Msk
28731#define USB_OTG_GUSBCFG_TRDT_0 (0x1UL << USB_OTG_GUSBCFG_TRDT_Pos)
28732#define USB_OTG_GUSBCFG_TRDT_1 (0x2UL << USB_OTG_GUSBCFG_TRDT_Pos)
28733#define USB_OTG_GUSBCFG_TRDT_2 (0x4UL << USB_OTG_GUSBCFG_TRDT_Pos)
28734#define USB_OTG_GUSBCFG_TRDT_3 (0x8UL << USB_OTG_GUSBCFG_TRDT_Pos)
28735#define USB_OTG_GUSBCFG_PHYLPCS_Pos (15U)
28736#define USB_OTG_GUSBCFG_PHYLPCS_Msk (0x1UL << USB_OTG_GUSBCFG_PHYLPCS_Pos)
28737#define USB_OTG_GUSBCFG_PHYLPCS USB_OTG_GUSBCFG_PHYLPCS_Msk
28738#define USB_OTG_GUSBCFG_ULPIFSLS_Pos (17U)
28739#define USB_OTG_GUSBCFG_ULPIFSLS_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIFSLS_Pos)
28740#define USB_OTG_GUSBCFG_ULPIFSLS USB_OTG_GUSBCFG_ULPIFSLS_Msk
28741#define USB_OTG_GUSBCFG_ULPIAR_Pos (18U)
28742#define USB_OTG_GUSBCFG_ULPIAR_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIAR_Pos)
28743#define USB_OTG_GUSBCFG_ULPIAR USB_OTG_GUSBCFG_ULPIAR_Msk
28744#define USB_OTG_GUSBCFG_ULPICSM_Pos (19U)
28745#define USB_OTG_GUSBCFG_ULPICSM_Msk (0x1UL << USB_OTG_GUSBCFG_ULPICSM_Pos)
28746#define USB_OTG_GUSBCFG_ULPICSM USB_OTG_GUSBCFG_ULPICSM_Msk
28747#define USB_OTG_GUSBCFG_ULPIEVBUSD_Pos (20U)
28748#define USB_OTG_GUSBCFG_ULPIEVBUSD_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSD_Pos)
28749#define USB_OTG_GUSBCFG_ULPIEVBUSD USB_OTG_GUSBCFG_ULPIEVBUSD_Msk
28750#define USB_OTG_GUSBCFG_ULPIEVBUSI_Pos (21U)
28751#define USB_OTG_GUSBCFG_ULPIEVBUSI_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSI_Pos)
28752#define USB_OTG_GUSBCFG_ULPIEVBUSI USB_OTG_GUSBCFG_ULPIEVBUSI_Msk
28753#define USB_OTG_GUSBCFG_TSDPS_Pos (22U)
28754#define USB_OTG_GUSBCFG_TSDPS_Msk (0x1UL << USB_OTG_GUSBCFG_TSDPS_Pos)
28755#define USB_OTG_GUSBCFG_TSDPS USB_OTG_GUSBCFG_TSDPS_Msk
28756#define USB_OTG_GUSBCFG_PCCI_Pos (23U)
28757#define USB_OTG_GUSBCFG_PCCI_Msk (0x1UL << USB_OTG_GUSBCFG_PCCI_Pos)
28758#define USB_OTG_GUSBCFG_PCCI USB_OTG_GUSBCFG_PCCI_Msk
28759#define USB_OTG_GUSBCFG_PTCI_Pos (24U)
28760#define USB_OTG_GUSBCFG_PTCI_Msk (0x1UL << USB_OTG_GUSBCFG_PTCI_Pos)
28761#define USB_OTG_GUSBCFG_PTCI USB_OTG_GUSBCFG_PTCI_Msk
28762#define USB_OTG_GUSBCFG_ULPIIPD_Pos (25U)
28763#define USB_OTG_GUSBCFG_ULPIIPD_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIIPD_Pos)
28764#define USB_OTG_GUSBCFG_ULPIIPD USB_OTG_GUSBCFG_ULPIIPD_Msk
28765#define USB_OTG_GUSBCFG_FHMOD_Pos (29U)
28766#define USB_OTG_GUSBCFG_FHMOD_Msk (0x1UL << USB_OTG_GUSBCFG_FHMOD_Pos)
28767#define USB_OTG_GUSBCFG_FHMOD USB_OTG_GUSBCFG_FHMOD_Msk
28768#define USB_OTG_GUSBCFG_FDMOD_Pos (30U)
28769#define USB_OTG_GUSBCFG_FDMOD_Msk (0x1UL << USB_OTG_GUSBCFG_FDMOD_Pos)
28770#define USB_OTG_GUSBCFG_FDMOD USB_OTG_GUSBCFG_FDMOD_Msk
28771#define USB_OTG_GUSBCFG_CTXPKT_Pos (31U)
28772#define USB_OTG_GUSBCFG_CTXPKT_Msk (0x1UL << USB_OTG_GUSBCFG_CTXPKT_Pos)
28773#define USB_OTG_GUSBCFG_CTXPKT USB_OTG_GUSBCFG_CTXPKT_Msk
28775/******************** Bit definition forUSB_OTG_GRSTCTL register ********************/
28776#define USB_OTG_GRSTCTL_CSRST_Pos (0U)
28777#define USB_OTG_GRSTCTL_CSRST_Msk (0x1UL << USB_OTG_GRSTCTL_CSRST_Pos)
28778#define USB_OTG_GRSTCTL_CSRST USB_OTG_GRSTCTL_CSRST_Msk
28779#define USB_OTG_GRSTCTL_HSRST_Pos (1U)
28780#define USB_OTG_GRSTCTL_HSRST_Msk (0x1UL << USB_OTG_GRSTCTL_HSRST_Pos)
28781#define USB_OTG_GRSTCTL_HSRST USB_OTG_GRSTCTL_HSRST_Msk
28782#define USB_OTG_GRSTCTL_FCRST_Pos (2U)
28783#define USB_OTG_GRSTCTL_FCRST_Msk (0x1UL << USB_OTG_GRSTCTL_FCRST_Pos)
28784#define USB_OTG_GRSTCTL_FCRST USB_OTG_GRSTCTL_FCRST_Msk
28785#define USB_OTG_GRSTCTL_RXFFLSH_Pos (4U)
28786#define USB_OTG_GRSTCTL_RXFFLSH_Msk (0x1UL << USB_OTG_GRSTCTL_RXFFLSH_Pos)
28787#define USB_OTG_GRSTCTL_RXFFLSH USB_OTG_GRSTCTL_RXFFLSH_Msk
28788#define USB_OTG_GRSTCTL_TXFFLSH_Pos (5U)
28789#define USB_OTG_GRSTCTL_TXFFLSH_Msk (0x1UL << USB_OTG_GRSTCTL_TXFFLSH_Pos)
28790#define USB_OTG_GRSTCTL_TXFFLSH USB_OTG_GRSTCTL_TXFFLSH_Msk
28792#define USB_OTG_GRSTCTL_TXFNUM_Pos (6U)
28793#define USB_OTG_GRSTCTL_TXFNUM_Msk (0x1FUL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28794#define USB_OTG_GRSTCTL_TXFNUM USB_OTG_GRSTCTL_TXFNUM_Msk
28795#define USB_OTG_GRSTCTL_TXFNUM_0 (0x01UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28796#define USB_OTG_GRSTCTL_TXFNUM_1 (0x02UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28797#define USB_OTG_GRSTCTL_TXFNUM_2 (0x04UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28798#define USB_OTG_GRSTCTL_TXFNUM_3 (0x08UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28799#define USB_OTG_GRSTCTL_TXFNUM_4 (0x10UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
28800#define USB_OTG_GRSTCTL_DMAREQ_Pos (30U)
28801#define USB_OTG_GRSTCTL_DMAREQ_Msk (0x1UL << USB_OTG_GRSTCTL_DMAREQ_Pos)
28802#define USB_OTG_GRSTCTL_DMAREQ USB_OTG_GRSTCTL_DMAREQ_Msk
28803#define USB_OTG_GRSTCTL_AHBIDL_Pos (31U)
28804#define USB_OTG_GRSTCTL_AHBIDL_Msk (0x1UL << USB_OTG_GRSTCTL_AHBIDL_Pos)
28805#define USB_OTG_GRSTCTL_AHBIDL USB_OTG_GRSTCTL_AHBIDL_Msk
28807/******************** Bit definition forUSB_OTG_DIEPMSK register ********************/
28808#define USB_OTG_DIEPMSK_XFRCM_Pos (0U)
28809#define USB_OTG_DIEPMSK_XFRCM_Msk (0x1UL << USB_OTG_DIEPMSK_XFRCM_Pos)
28810#define USB_OTG_DIEPMSK_XFRCM USB_OTG_DIEPMSK_XFRCM_Msk
28811#define USB_OTG_DIEPMSK_EPDM_Pos (1U)
28812#define USB_OTG_DIEPMSK_EPDM_Msk (0x1UL << USB_OTG_DIEPMSK_EPDM_Pos)
28813#define USB_OTG_DIEPMSK_EPDM USB_OTG_DIEPMSK_EPDM_Msk
28814#define USB_OTG_DIEPMSK_TOM_Pos (3U)
28815#define USB_OTG_DIEPMSK_TOM_Msk (0x1UL << USB_OTG_DIEPMSK_TOM_Pos)
28816#define USB_OTG_DIEPMSK_TOM USB_OTG_DIEPMSK_TOM_Msk
28817#define USB_OTG_DIEPMSK_ITTXFEMSK_Pos (4U)
28818#define USB_OTG_DIEPMSK_ITTXFEMSK_Msk (0x1UL << USB_OTG_DIEPMSK_ITTXFEMSK_Pos)
28819#define USB_OTG_DIEPMSK_ITTXFEMSK USB_OTG_DIEPMSK_ITTXFEMSK_Msk
28820#define USB_OTG_DIEPMSK_INEPNMM_Pos (5U)
28821#define USB_OTG_DIEPMSK_INEPNMM_Msk (0x1UL << USB_OTG_DIEPMSK_INEPNMM_Pos)
28822#define USB_OTG_DIEPMSK_INEPNMM USB_OTG_DIEPMSK_INEPNMM_Msk
28823#define USB_OTG_DIEPMSK_INEPNEM_Pos (6U)
28824#define USB_OTG_DIEPMSK_INEPNEM_Msk (0x1UL << USB_OTG_DIEPMSK_INEPNEM_Pos)
28825#define USB_OTG_DIEPMSK_INEPNEM USB_OTG_DIEPMSK_INEPNEM_Msk
28826#define USB_OTG_DIEPMSK_TXFURM_Pos (8U)
28827#define USB_OTG_DIEPMSK_TXFURM_Msk (0x1UL << USB_OTG_DIEPMSK_TXFURM_Pos)
28828#define USB_OTG_DIEPMSK_TXFURM USB_OTG_DIEPMSK_TXFURM_Msk
28829#define USB_OTG_DIEPMSK_BIM_Pos (9U)
28830#define USB_OTG_DIEPMSK_BIM_Msk (0x1UL << USB_OTG_DIEPMSK_BIM_Pos)
28831#define USB_OTG_DIEPMSK_BIM USB_OTG_DIEPMSK_BIM_Msk
28833/******************** Bit definition forUSB_OTG_HPTXSTS register ********************/
28834#define USB_OTG_HPTXSTS_PTXFSAVL_Pos (0U)
28835#define USB_OTG_HPTXSTS_PTXFSAVL_Msk (0xFFFFUL << USB_OTG_HPTXSTS_PTXFSAVL_Pos)
28836#define USB_OTG_HPTXSTS_PTXFSAVL USB_OTG_HPTXSTS_PTXFSAVL_Msk
28838#define USB_OTG_HPTXSTS_PTXQSAV_Pos (16U)
28839#define USB_OTG_HPTXSTS_PTXQSAV_Msk (0xFFUL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28840#define USB_OTG_HPTXSTS_PTXQSAV USB_OTG_HPTXSTS_PTXQSAV_Msk
28841#define USB_OTG_HPTXSTS_PTXQSAV_0 (0x01UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28842#define USB_OTG_HPTXSTS_PTXQSAV_1 (0x02UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28843#define USB_OTG_HPTXSTS_PTXQSAV_2 (0x04UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28844#define USB_OTG_HPTXSTS_PTXQSAV_3 (0x08UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28845#define USB_OTG_HPTXSTS_PTXQSAV_4 (0x10UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28846#define USB_OTG_HPTXSTS_PTXQSAV_5 (0x20UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28847#define USB_OTG_HPTXSTS_PTXQSAV_6 (0x40UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28848#define USB_OTG_HPTXSTS_PTXQSAV_7 (0x80UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
28850#define USB_OTG_HPTXSTS_PTXQTOP_Pos (24U)
28851#define USB_OTG_HPTXSTS_PTXQTOP_Msk (0xFFUL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28852#define USB_OTG_HPTXSTS_PTXQTOP USB_OTG_HPTXSTS_PTXQTOP_Msk
28853#define USB_OTG_HPTXSTS_PTXQTOP_0 (0x01UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28854#define USB_OTG_HPTXSTS_PTXQTOP_1 (0x02UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28855#define USB_OTG_HPTXSTS_PTXQTOP_2 (0x04UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28856#define USB_OTG_HPTXSTS_PTXQTOP_3 (0x08UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28857#define USB_OTG_HPTXSTS_PTXQTOP_4 (0x10UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28858#define USB_OTG_HPTXSTS_PTXQTOP_5 (0x20UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28859#define USB_OTG_HPTXSTS_PTXQTOP_6 (0x40UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28860#define USB_OTG_HPTXSTS_PTXQTOP_7 (0x80UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
28862/******************** Bit definition forUSB_OTG_HAINT register ********************/
28863#define USB_OTG_HAINT_HAINT_Pos (0U)
28864#define USB_OTG_HAINT_HAINT_Msk (0xFFFFUL << USB_OTG_HAINT_HAINT_Pos)
28865#define USB_OTG_HAINT_HAINT USB_OTG_HAINT_HAINT_Msk
28867/******************** Bit definition forUSB_OTG_DOEPMSK register ********************/
28868#define USB_OTG_DOEPMSK_XFRCM_Pos (0U)
28869#define USB_OTG_DOEPMSK_XFRCM_Msk (0x1UL << USB_OTG_DOEPMSK_XFRCM_Pos)
28870#define USB_OTG_DOEPMSK_XFRCM USB_OTG_DOEPMSK_XFRCM_Msk
28871#define USB_OTG_DOEPMSK_EPDM_Pos (1U)
28872#define USB_OTG_DOEPMSK_EPDM_Msk (0x1UL << USB_OTG_DOEPMSK_EPDM_Pos)
28873#define USB_OTG_DOEPMSK_EPDM USB_OTG_DOEPMSK_EPDM_Msk
28874#define USB_OTG_DOEPMSK_AHBERRM_Pos (2U)
28875#define USB_OTG_DOEPMSK_AHBERRM_Msk (0x1UL << USB_OTG_DOEPMSK_AHBERRM_Pos)
28876#define USB_OTG_DOEPMSK_AHBERRM USB_OTG_DOEPMSK_AHBERRM_Msk
28877#define USB_OTG_DOEPMSK_STUPM_Pos (3U)
28878#define USB_OTG_DOEPMSK_STUPM_Msk (0x1UL << USB_OTG_DOEPMSK_STUPM_Pos)
28879#define USB_OTG_DOEPMSK_STUPM USB_OTG_DOEPMSK_STUPM_Msk
28880#define USB_OTG_DOEPMSK_OTEPDM_Pos (4U)
28881#define USB_OTG_DOEPMSK_OTEPDM_Msk (0x1UL << USB_OTG_DOEPMSK_OTEPDM_Pos)
28882#define USB_OTG_DOEPMSK_OTEPDM USB_OTG_DOEPMSK_OTEPDM_Msk
28883#define USB_OTG_DOEPMSK_OTEPSPRM_Pos (5U)
28884#define USB_OTG_DOEPMSK_OTEPSPRM_Msk (0x1UL << USB_OTG_DOEPMSK_OTEPSPRM_Pos)
28885#define USB_OTG_DOEPMSK_OTEPSPRM USB_OTG_DOEPMSK_OTEPSPRM_Msk
28886#define USB_OTG_DOEPMSK_B2BSTUP_Pos (6U)
28887#define USB_OTG_DOEPMSK_B2BSTUP_Msk (0x1UL << USB_OTG_DOEPMSK_B2BSTUP_Pos)
28888#define USB_OTG_DOEPMSK_B2BSTUP USB_OTG_DOEPMSK_B2BSTUP_Msk
28889#define USB_OTG_DOEPMSK_OPEM_Pos (8U)
28890#define USB_OTG_DOEPMSK_OPEM_Msk (0x1UL << USB_OTG_DOEPMSK_OPEM_Pos)
28891#define USB_OTG_DOEPMSK_OPEM USB_OTG_DOEPMSK_OPEM_Msk
28892#define USB_OTG_DOEPMSK_BOIM_Pos (9U)
28893#define USB_OTG_DOEPMSK_BOIM_Msk (0x1UL << USB_OTG_DOEPMSK_BOIM_Pos)
28894#define USB_OTG_DOEPMSK_BOIM USB_OTG_DOEPMSK_BOIM_Msk
28895#define USB_OTG_DOEPMSK_BERRM_Pos (12U)
28896#define USB_OTG_DOEPMSK_BERRM_Msk (0x1UL << USB_OTG_DOEPMSK_BERRM_Pos)
28897#define USB_OTG_DOEPMSK_BERRM USB_OTG_DOEPMSK_BERRM_Msk
28898#define USB_OTG_DOEPMSK_NAKM_Pos (13U)
28899#define USB_OTG_DOEPMSK_NAKM_Msk (0x1UL << USB_OTG_DOEPMSK_NAKM_Pos)
28900#define USB_OTG_DOEPMSK_NAKM USB_OTG_DOEPMSK_NAKM_Msk
28901#define USB_OTG_DOEPMSK_NYETM_Pos (14U)
28902#define USB_OTG_DOEPMSK_NYETM_Msk (0x1UL << USB_OTG_DOEPMSK_NYETM_Pos)
28903#define USB_OTG_DOEPMSK_NYETM USB_OTG_DOEPMSK_NYETM_Msk
28905/******************** Bit definition forUSB_OTG_GINTSTS register ********************/
28906#define USB_OTG_GINTSTS_CMOD_Pos (0U)
28907#define USB_OTG_GINTSTS_CMOD_Msk (0x1UL << USB_OTG_GINTSTS_CMOD_Pos)
28908#define USB_OTG_GINTSTS_CMOD USB_OTG_GINTSTS_CMOD_Msk
28909#define USB_OTG_GINTSTS_MMIS_Pos (1U)
28910#define USB_OTG_GINTSTS_MMIS_Msk (0x1UL << USB_OTG_GINTSTS_MMIS_Pos)
28911#define USB_OTG_GINTSTS_MMIS USB_OTG_GINTSTS_MMIS_Msk
28912#define USB_OTG_GINTSTS_OTGINT_Pos (2U)
28913#define USB_OTG_GINTSTS_OTGINT_Msk (0x1UL << USB_OTG_GINTSTS_OTGINT_Pos)
28914#define USB_OTG_GINTSTS_OTGINT USB_OTG_GINTSTS_OTGINT_Msk
28915#define USB_OTG_GINTSTS_SOF_Pos (3U)
28916#define USB_OTG_GINTSTS_SOF_Msk (0x1UL << USB_OTG_GINTSTS_SOF_Pos)
28917#define USB_OTG_GINTSTS_SOF USB_OTG_GINTSTS_SOF_Msk
28918#define USB_OTG_GINTSTS_RXFLVL_Pos (4U)
28919#define USB_OTG_GINTSTS_RXFLVL_Msk (0x1UL << USB_OTG_GINTSTS_RXFLVL_Pos)
28920#define USB_OTG_GINTSTS_RXFLVL USB_OTG_GINTSTS_RXFLVL_Msk
28921#define USB_OTG_GINTSTS_NPTXFE_Pos (5U)
28922#define USB_OTG_GINTSTS_NPTXFE_Msk (0x1UL << USB_OTG_GINTSTS_NPTXFE_Pos)
28923#define USB_OTG_GINTSTS_NPTXFE USB_OTG_GINTSTS_NPTXFE_Msk
28924#define USB_OTG_GINTSTS_GINAKEFF_Pos (6U)
28925#define USB_OTG_GINTSTS_GINAKEFF_Msk (0x1UL << USB_OTG_GINTSTS_GINAKEFF_Pos)
28926#define USB_OTG_GINTSTS_GINAKEFF USB_OTG_GINTSTS_GINAKEFF_Msk
28927#define USB_OTG_GINTSTS_BOUTNAKEFF_Pos (7U)
28928#define USB_OTG_GINTSTS_BOUTNAKEFF_Msk (0x1UL << USB_OTG_GINTSTS_BOUTNAKEFF_Pos)
28929#define USB_OTG_GINTSTS_BOUTNAKEFF USB_OTG_GINTSTS_BOUTNAKEFF_Msk
28930#define USB_OTG_GINTSTS_ESUSP_Pos (10U)
28931#define USB_OTG_GINTSTS_ESUSP_Msk (0x1UL << USB_OTG_GINTSTS_ESUSP_Pos)
28932#define USB_OTG_GINTSTS_ESUSP USB_OTG_GINTSTS_ESUSP_Msk
28933#define USB_OTG_GINTSTS_USBSUSP_Pos (11U)
28934#define USB_OTG_GINTSTS_USBSUSP_Msk (0x1UL << USB_OTG_GINTSTS_USBSUSP_Pos)
28935#define USB_OTG_GINTSTS_USBSUSP USB_OTG_GINTSTS_USBSUSP_Msk
28936#define USB_OTG_GINTSTS_USBRST_Pos (12U)
28937#define USB_OTG_GINTSTS_USBRST_Msk (0x1UL << USB_OTG_GINTSTS_USBRST_Pos)
28938#define USB_OTG_GINTSTS_USBRST USB_OTG_GINTSTS_USBRST_Msk
28939#define USB_OTG_GINTSTS_ENUMDNE_Pos (13U)
28940#define USB_OTG_GINTSTS_ENUMDNE_Msk (0x1UL << USB_OTG_GINTSTS_ENUMDNE_Pos)
28941#define USB_OTG_GINTSTS_ENUMDNE USB_OTG_GINTSTS_ENUMDNE_Msk
28942#define USB_OTG_GINTSTS_ISOODRP_Pos (14U)
28943#define USB_OTG_GINTSTS_ISOODRP_Msk (0x1UL << USB_OTG_GINTSTS_ISOODRP_Pos)
28944#define USB_OTG_GINTSTS_ISOODRP USB_OTG_GINTSTS_ISOODRP_Msk
28945#define USB_OTG_GINTSTS_EOPF_Pos (15U)
28946#define USB_OTG_GINTSTS_EOPF_Msk (0x1UL << USB_OTG_GINTSTS_EOPF_Pos)
28947#define USB_OTG_GINTSTS_EOPF USB_OTG_GINTSTS_EOPF_Msk
28948#define USB_OTG_GINTSTS_IEPINT_Pos (18U)
28949#define USB_OTG_GINTSTS_IEPINT_Msk (0x1UL << USB_OTG_GINTSTS_IEPINT_Pos)
28950#define USB_OTG_GINTSTS_IEPINT USB_OTG_GINTSTS_IEPINT_Msk
28951#define USB_OTG_GINTSTS_OEPINT_Pos (19U)
28952#define USB_OTG_GINTSTS_OEPINT_Msk (0x1UL << USB_OTG_GINTSTS_OEPINT_Pos)
28953#define USB_OTG_GINTSTS_OEPINT USB_OTG_GINTSTS_OEPINT_Msk
28954#define USB_OTG_GINTSTS_IISOIXFR_Pos (20U)
28955#define USB_OTG_GINTSTS_IISOIXFR_Msk (0x1UL << USB_OTG_GINTSTS_IISOIXFR_Pos)
28956#define USB_OTG_GINTSTS_IISOIXFR USB_OTG_GINTSTS_IISOIXFR_Msk
28957#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos (21U)
28958#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk (0x1UL << USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos)
28959#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk
28960#define USB_OTG_GINTSTS_DATAFSUSP_Pos (22U)
28961#define USB_OTG_GINTSTS_DATAFSUSP_Msk (0x1UL << USB_OTG_GINTSTS_DATAFSUSP_Pos)
28962#define USB_OTG_GINTSTS_DATAFSUSP USB_OTG_GINTSTS_DATAFSUSP_Msk
28963#define USB_OTG_GINTSTS_RSTDET_Pos (23U)
28964#define USB_OTG_GINTSTS_RSTDET_Msk (0x1UL << USB_OTG_GINTSTS_RSTDET_Pos)
28965#define USB_OTG_GINTSTS_RSTDET USB_OTG_GINTSTS_RSTDET_Msk
28966#define USB_OTG_GINTSTS_HPRTINT_Pos (24U)
28967#define USB_OTG_GINTSTS_HPRTINT_Msk (0x1UL << USB_OTG_GINTSTS_HPRTINT_Pos)
28968#define USB_OTG_GINTSTS_HPRTINT USB_OTG_GINTSTS_HPRTINT_Msk
28969#define USB_OTG_GINTSTS_HCINT_Pos (25U)
28970#define USB_OTG_GINTSTS_HCINT_Msk (0x1UL << USB_OTG_GINTSTS_HCINT_Pos)
28971#define USB_OTG_GINTSTS_HCINT USB_OTG_GINTSTS_HCINT_Msk
28972#define USB_OTG_GINTSTS_PTXFE_Pos (26U)
28973#define USB_OTG_GINTSTS_PTXFE_Msk (0x1UL << USB_OTG_GINTSTS_PTXFE_Pos)
28974#define USB_OTG_GINTSTS_PTXFE USB_OTG_GINTSTS_PTXFE_Msk
28975#define USB_OTG_GINTSTS_LPMINT_Pos (27U)
28976#define USB_OTG_GINTSTS_LPMINT_Msk (0x1UL << USB_OTG_GINTSTS_LPMINT_Pos)
28977#define USB_OTG_GINTSTS_LPMINT USB_OTG_GINTSTS_LPMINT_Msk
28978#define USB_OTG_GINTSTS_CIDSCHG_Pos (28U)
28979#define USB_OTG_GINTSTS_CIDSCHG_Msk (0x1UL << USB_OTG_GINTSTS_CIDSCHG_Pos)
28980#define USB_OTG_GINTSTS_CIDSCHG USB_OTG_GINTSTS_CIDSCHG_Msk
28981#define USB_OTG_GINTSTS_DISCINT_Pos (29U)
28982#define USB_OTG_GINTSTS_DISCINT_Msk (0x1UL << USB_OTG_GINTSTS_DISCINT_Pos)
28983#define USB_OTG_GINTSTS_DISCINT USB_OTG_GINTSTS_DISCINT_Msk
28984#define USB_OTG_GINTSTS_SRQINT_Pos (30U)
28985#define USB_OTG_GINTSTS_SRQINT_Msk (0x1UL << USB_OTG_GINTSTS_SRQINT_Pos)
28986#define USB_OTG_GINTSTS_SRQINT USB_OTG_GINTSTS_SRQINT_Msk
28987#define USB_OTG_GINTSTS_WKUINT_Pos (31U)
28988#define USB_OTG_GINTSTS_WKUINT_Msk (0x1UL << USB_OTG_GINTSTS_WKUINT_Pos)
28989#define USB_OTG_GINTSTS_WKUINT USB_OTG_GINTSTS_WKUINT_Msk
28991/******************** Bit definition forUSB_OTG_GINTMSK register ********************/
28992#define USB_OTG_GINTMSK_MMISM_Pos (1U)
28993#define USB_OTG_GINTMSK_MMISM_Msk (0x1UL << USB_OTG_GINTMSK_MMISM_Pos)
28994#define USB_OTG_GINTMSK_MMISM USB_OTG_GINTMSK_MMISM_Msk
28995#define USB_OTG_GINTMSK_OTGINT_Pos (2U)
28996#define USB_OTG_GINTMSK_OTGINT_Msk (0x1UL << USB_OTG_GINTMSK_OTGINT_Pos)
28997#define USB_OTG_GINTMSK_OTGINT USB_OTG_GINTMSK_OTGINT_Msk
28998#define USB_OTG_GINTMSK_SOFM_Pos (3U)
28999#define USB_OTG_GINTMSK_SOFM_Msk (0x1UL << USB_OTG_GINTMSK_SOFM_Pos)
29000#define USB_OTG_GINTMSK_SOFM USB_OTG_GINTMSK_SOFM_Msk
29001#define USB_OTG_GINTMSK_RXFLVLM_Pos (4U)
29002#define USB_OTG_GINTMSK_RXFLVLM_Msk (0x1UL << USB_OTG_GINTMSK_RXFLVLM_Pos)
29003#define USB_OTG_GINTMSK_RXFLVLM USB_OTG_GINTMSK_RXFLVLM_Msk
29004#define USB_OTG_GINTMSK_NPTXFEM_Pos (5U)
29005#define USB_OTG_GINTMSK_NPTXFEM_Msk (0x1UL << USB_OTG_GINTMSK_NPTXFEM_Pos)
29006#define USB_OTG_GINTMSK_NPTXFEM USB_OTG_GINTMSK_NPTXFEM_Msk
29007#define USB_OTG_GINTMSK_GINAKEFFM_Pos (6U)
29008#define USB_OTG_GINTMSK_GINAKEFFM_Msk (0x1UL << USB_OTG_GINTMSK_GINAKEFFM_Pos)
29009#define USB_OTG_GINTMSK_GINAKEFFM USB_OTG_GINTMSK_GINAKEFFM_Msk
29010#define USB_OTG_GINTMSK_GONAKEFFM_Pos (7U)
29011#define USB_OTG_GINTMSK_GONAKEFFM_Msk (0x1UL << USB_OTG_GINTMSK_GONAKEFFM_Pos)
29012#define USB_OTG_GINTMSK_GONAKEFFM USB_OTG_GINTMSK_GONAKEFFM_Msk
29013#define USB_OTG_GINTMSK_ESUSPM_Pos (10U)
29014#define USB_OTG_GINTMSK_ESUSPM_Msk (0x1UL << USB_OTG_GINTMSK_ESUSPM_Pos)
29015#define USB_OTG_GINTMSK_ESUSPM USB_OTG_GINTMSK_ESUSPM_Msk
29016#define USB_OTG_GINTMSK_USBSUSPM_Pos (11U)
29017#define USB_OTG_GINTMSK_USBSUSPM_Msk (0x1UL << USB_OTG_GINTMSK_USBSUSPM_Pos)
29018#define USB_OTG_GINTMSK_USBSUSPM USB_OTG_GINTMSK_USBSUSPM_Msk
29019#define USB_OTG_GINTMSK_USBRST_Pos (12U)
29020#define USB_OTG_GINTMSK_USBRST_Msk (0x1UL << USB_OTG_GINTMSK_USBRST_Pos)
29021#define USB_OTG_GINTMSK_USBRST USB_OTG_GINTMSK_USBRST_Msk
29022#define USB_OTG_GINTMSK_ENUMDNEM_Pos (13U)
29023#define USB_OTG_GINTMSK_ENUMDNEM_Msk (0x1UL << USB_OTG_GINTMSK_ENUMDNEM_Pos)
29024#define USB_OTG_GINTMSK_ENUMDNEM USB_OTG_GINTMSK_ENUMDNEM_Msk
29025#define USB_OTG_GINTMSK_ISOODRPM_Pos (14U)
29026#define USB_OTG_GINTMSK_ISOODRPM_Msk (0x1UL << USB_OTG_GINTMSK_ISOODRPM_Pos)
29027#define USB_OTG_GINTMSK_ISOODRPM USB_OTG_GINTMSK_ISOODRPM_Msk
29028#define USB_OTG_GINTMSK_EOPFM_Pos (15U)
29029#define USB_OTG_GINTMSK_EOPFM_Msk (0x1UL << USB_OTG_GINTMSK_EOPFM_Pos)
29030#define USB_OTG_GINTMSK_EOPFM USB_OTG_GINTMSK_EOPFM_Msk
29031#define USB_OTG_GINTMSK_EPMISM_Pos (17U)
29032#define USB_OTG_GINTMSK_EPMISM_Msk (0x1UL << USB_OTG_GINTMSK_EPMISM_Pos)
29033#define USB_OTG_GINTMSK_EPMISM USB_OTG_GINTMSK_EPMISM_Msk
29034#define USB_OTG_GINTMSK_IEPINT_Pos (18U)
29035#define USB_OTG_GINTMSK_IEPINT_Msk (0x1UL << USB_OTG_GINTMSK_IEPINT_Pos)
29036#define USB_OTG_GINTMSK_IEPINT USB_OTG_GINTMSK_IEPINT_Msk
29037#define USB_OTG_GINTMSK_OEPINT_Pos (19U)
29038#define USB_OTG_GINTMSK_OEPINT_Msk (0x1UL << USB_OTG_GINTMSK_OEPINT_Pos)
29039#define USB_OTG_GINTMSK_OEPINT USB_OTG_GINTMSK_OEPINT_Msk
29040#define USB_OTG_GINTMSK_IISOIXFRM_Pos (20U)
29041#define USB_OTG_GINTMSK_IISOIXFRM_Msk (0x1UL << USB_OTG_GINTMSK_IISOIXFRM_Pos)
29042#define USB_OTG_GINTMSK_IISOIXFRM USB_OTG_GINTMSK_IISOIXFRM_Msk
29043#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos (21U)
29044#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk (0x1UL << USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos)
29045#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk
29046#define USB_OTG_GINTMSK_FSUSPM_Pos (22U)
29047#define USB_OTG_GINTMSK_FSUSPM_Msk (0x1UL << USB_OTG_GINTMSK_FSUSPM_Pos)
29048#define USB_OTG_GINTMSK_FSUSPM USB_OTG_GINTMSK_FSUSPM_Msk
29049#define USB_OTG_GINTMSK_RSTDEM_Pos (23U)
29050#define USB_OTG_GINTMSK_RSTDEM_Msk (0x1UL << USB_OTG_GINTMSK_RSTDEM_Pos)
29051#define USB_OTG_GINTMSK_RSTDEM USB_OTG_GINTMSK_RSTDEM_Msk
29052#define USB_OTG_GINTMSK_PRTIM_Pos (24U)
29053#define USB_OTG_GINTMSK_PRTIM_Msk (0x1UL << USB_OTG_GINTMSK_PRTIM_Pos)
29054#define USB_OTG_GINTMSK_PRTIM USB_OTG_GINTMSK_PRTIM_Msk
29055#define USB_OTG_GINTMSK_HCIM_Pos (25U)
29056#define USB_OTG_GINTMSK_HCIM_Msk (0x1UL << USB_OTG_GINTMSK_HCIM_Pos)
29057#define USB_OTG_GINTMSK_HCIM USB_OTG_GINTMSK_HCIM_Msk
29058#define USB_OTG_GINTMSK_PTXFEM_Pos (26U)
29059#define USB_OTG_GINTMSK_PTXFEM_Msk (0x1UL << USB_OTG_GINTMSK_PTXFEM_Pos)
29060#define USB_OTG_GINTMSK_PTXFEM USB_OTG_GINTMSK_PTXFEM_Msk
29061#define USB_OTG_GINTMSK_LPMINTM_Pos (27U)
29062#define USB_OTG_GINTMSK_LPMINTM_Msk (0x1UL << USB_OTG_GINTMSK_LPMINTM_Pos)
29063#define USB_OTG_GINTMSK_LPMINTM USB_OTG_GINTMSK_LPMINTM_Msk
29064#define USB_OTG_GINTMSK_CIDSCHGM_Pos (28U)
29065#define USB_OTG_GINTMSK_CIDSCHGM_Msk (0x1UL << USB_OTG_GINTMSK_CIDSCHGM_Pos)
29066#define USB_OTG_GINTMSK_CIDSCHGM USB_OTG_GINTMSK_CIDSCHGM_Msk
29067#define USB_OTG_GINTMSK_DISCINT_Pos (29U)
29068#define USB_OTG_GINTMSK_DISCINT_Msk (0x1UL << USB_OTG_GINTMSK_DISCINT_Pos)
29069#define USB_OTG_GINTMSK_DISCINT USB_OTG_GINTMSK_DISCINT_Msk
29070#define USB_OTG_GINTMSK_SRQIM_Pos (30U)
29071#define USB_OTG_GINTMSK_SRQIM_Msk (0x1UL << USB_OTG_GINTMSK_SRQIM_Pos)
29072#define USB_OTG_GINTMSK_SRQIM USB_OTG_GINTMSK_SRQIM_Msk
29073#define USB_OTG_GINTMSK_WUIM_Pos (31U)
29074#define USB_OTG_GINTMSK_WUIM_Msk (0x1UL << USB_OTG_GINTMSK_WUIM_Pos)
29075#define USB_OTG_GINTMSK_WUIM USB_OTG_GINTMSK_WUIM_Msk
29077/******************** Bit definition forUSB_OTG_DAINT register ********************/
29078#define USB_OTG_DAINT_IEPINT_Pos (0U)
29079#define USB_OTG_DAINT_IEPINT_Msk (0xFFFFUL << USB_OTG_DAINT_IEPINT_Pos)
29080#define USB_OTG_DAINT_IEPINT USB_OTG_DAINT_IEPINT_Msk
29081#define USB_OTG_DAINT_OEPINT_Pos (16U)
29082#define USB_OTG_DAINT_OEPINT_Msk (0xFFFFUL << USB_OTG_DAINT_OEPINT_Pos)
29083#define USB_OTG_DAINT_OEPINT USB_OTG_DAINT_OEPINT_Msk
29085/******************** Bit definition forUSB_OTG_HAINTMSK register ********************/
29086#define USB_OTG_HAINTMSK_HAINTM_Pos (0U)
29087#define USB_OTG_HAINTMSK_HAINTM_Msk (0xFFFFUL << USB_OTG_HAINTMSK_HAINTM_Pos)
29088#define USB_OTG_HAINTMSK_HAINTM USB_OTG_HAINTMSK_HAINTM_Msk
29090/******************** Bit definition for USB_OTG_GRXSTSP register ********************/
29091#define USB_OTG_GRXSTSP_EPNUM_Pos (0U)
29092#define USB_OTG_GRXSTSP_EPNUM_Msk (0xFUL << USB_OTG_GRXSTSP_EPNUM_Pos)
29093#define USB_OTG_GRXSTSP_EPNUM USB_OTG_GRXSTSP_EPNUM_Msk
29094#define USB_OTG_GRXSTSP_BCNT_Pos (4U)
29095#define USB_OTG_GRXSTSP_BCNT_Msk (0x7FFUL << USB_OTG_GRXSTSP_BCNT_Pos)
29096#define USB_OTG_GRXSTSP_BCNT USB_OTG_GRXSTSP_BCNT_Msk
29097#define USB_OTG_GRXSTSP_DPID_Pos (15U)
29098#define USB_OTG_GRXSTSP_DPID_Msk (0x3UL << USB_OTG_GRXSTSP_DPID_Pos)
29099#define USB_OTG_GRXSTSP_DPID USB_OTG_GRXSTSP_DPID_Msk
29100#define USB_OTG_GRXSTSP_PKTSTS_Pos (17U)
29101#define USB_OTG_GRXSTSP_PKTSTS_Msk (0xFUL << USB_OTG_GRXSTSP_PKTSTS_Pos)
29102#define USB_OTG_GRXSTSP_PKTSTS USB_OTG_GRXSTSP_PKTSTS_Msk
29104/******************** Bit definition forUSB_OTG_DAINTMSK register ********************/
29105#define USB_OTG_DAINTMSK_IEPM_Pos (0U)
29106#define USB_OTG_DAINTMSK_IEPM_Msk (0xFFFFUL << USB_OTG_DAINTMSK_IEPM_Pos)
29107#define USB_OTG_DAINTMSK_IEPM USB_OTG_DAINTMSK_IEPM_Msk
29108#define USB_OTG_DAINTMSK_OEPM_Pos (16U)
29109#define USB_OTG_DAINTMSK_OEPM_Msk (0xFFFFUL << USB_OTG_DAINTMSK_OEPM_Pos)
29110#define USB_OTG_DAINTMSK_OEPM USB_OTG_DAINTMSK_OEPM_Msk
29112/******************** Bit definition for OTG register ********************/
29113
29114#define USB_OTG_CHNUM_Pos (0U)
29115#define USB_OTG_CHNUM_Msk (0xFUL << USB_OTG_CHNUM_Pos)
29116#define USB_OTG_CHNUM USB_OTG_CHNUM_Msk
29117#define USB_OTG_CHNUM_0 (0x1UL << USB_OTG_CHNUM_Pos)
29118#define USB_OTG_CHNUM_1 (0x2UL << USB_OTG_CHNUM_Pos)
29119#define USB_OTG_CHNUM_2 (0x4UL << USB_OTG_CHNUM_Pos)
29120#define USB_OTG_CHNUM_3 (0x8UL << USB_OTG_CHNUM_Pos)
29121#define USB_OTG_BCNT_Pos (4U)
29122#define USB_OTG_BCNT_Msk (0x7FFUL << USB_OTG_BCNT_Pos)
29123#define USB_OTG_BCNT USB_OTG_BCNT_Msk
29125#define USB_OTG_DPID_Pos (15U)
29126#define USB_OTG_DPID_Msk (0x3UL << USB_OTG_DPID_Pos)
29127#define USB_OTG_DPID USB_OTG_DPID_Msk
29128#define USB_OTG_DPID_0 (0x1UL << USB_OTG_DPID_Pos)
29129#define USB_OTG_DPID_1 (0x2UL << USB_OTG_DPID_Pos)
29131#define USB_OTG_PKTSTS_Pos (17U)
29132#define USB_OTG_PKTSTS_Msk (0xFUL << USB_OTG_PKTSTS_Pos)
29133#define USB_OTG_PKTSTS USB_OTG_PKTSTS_Msk
29134#define USB_OTG_PKTSTS_0 (0x1UL << USB_OTG_PKTSTS_Pos)
29135#define USB_OTG_PKTSTS_1 (0x2UL << USB_OTG_PKTSTS_Pos)
29136#define USB_OTG_PKTSTS_2 (0x4UL << USB_OTG_PKTSTS_Pos)
29137#define USB_OTG_PKTSTS_3 (0x8UL << USB_OTG_PKTSTS_Pos)
29139#define USB_OTG_EPNUM_Pos (0U)
29140#define USB_OTG_EPNUM_Msk (0xFUL << USB_OTG_EPNUM_Pos)
29141#define USB_OTG_EPNUM USB_OTG_EPNUM_Msk
29142#define USB_OTG_EPNUM_0 (0x1UL << USB_OTG_EPNUM_Pos)
29143#define USB_OTG_EPNUM_1 (0x2UL << USB_OTG_EPNUM_Pos)
29144#define USB_OTG_EPNUM_2 (0x4UL << USB_OTG_EPNUM_Pos)
29145#define USB_OTG_EPNUM_3 (0x8UL << USB_OTG_EPNUM_Pos)
29147#define USB_OTG_FRMNUM_Pos (21U)
29148#define USB_OTG_FRMNUM_Msk (0xFUL << USB_OTG_FRMNUM_Pos)
29149#define USB_OTG_FRMNUM USB_OTG_FRMNUM_Msk
29150#define USB_OTG_FRMNUM_0 (0x1UL << USB_OTG_FRMNUM_Pos)
29151#define USB_OTG_FRMNUM_1 (0x2UL << USB_OTG_FRMNUM_Pos)
29152#define USB_OTG_FRMNUM_2 (0x4UL << USB_OTG_FRMNUM_Pos)
29153#define USB_OTG_FRMNUM_3 (0x8UL << USB_OTG_FRMNUM_Pos)
29155/******************** Bit definition forUSB_OTG_GRXFSIZ register ********************/
29156#define USB_OTG_GRXFSIZ_RXFD_Pos (0U)
29157#define USB_OTG_GRXFSIZ_RXFD_Msk (0xFFFFUL << USB_OTG_GRXFSIZ_RXFD_Pos)
29158#define USB_OTG_GRXFSIZ_RXFD USB_OTG_GRXFSIZ_RXFD_Msk
29160/******************** Bit definition forUSB_OTG_DVBUSDIS register ********************/
29161#define USB_OTG_DVBUSDIS_VBUSDT_Pos (0U)
29162#define USB_OTG_DVBUSDIS_VBUSDT_Msk (0xFFFFUL << USB_OTG_DVBUSDIS_VBUSDT_Pos)
29163#define USB_OTG_DVBUSDIS_VBUSDT USB_OTG_DVBUSDIS_VBUSDT_Msk
29165/******************** Bit definition for OTG register ********************/
29166#define USB_OTG_NPTXFSA_Pos (0U)
29167#define USB_OTG_NPTXFSA_Msk (0xFFFFUL << USB_OTG_NPTXFSA_Pos)
29168#define USB_OTG_NPTXFSA USB_OTG_NPTXFSA_Msk
29169#define USB_OTG_NPTXFD_Pos (16U)
29170#define USB_OTG_NPTXFD_Msk (0xFFFFUL << USB_OTG_NPTXFD_Pos)
29171#define USB_OTG_NPTXFD USB_OTG_NPTXFD_Msk
29172#define USB_OTG_TX0FSA_Pos (0U)
29173#define USB_OTG_TX0FSA_Msk (0xFFFFUL << USB_OTG_TX0FSA_Pos)
29174#define USB_OTG_TX0FSA USB_OTG_TX0FSA_Msk
29175#define USB_OTG_TX0FD_Pos (16U)
29176#define USB_OTG_TX0FD_Msk (0xFFFFUL << USB_OTG_TX0FD_Pos)
29177#define USB_OTG_TX0FD USB_OTG_TX0FD_Msk
29179/******************** Bit definition forUSB_OTG_DVBUSPULSE register ********************/
29180#define USB_OTG_DVBUSPULSE_DVBUSP_Pos (0U)
29181#define USB_OTG_DVBUSPULSE_DVBUSP_Msk (0xFFFUL << USB_OTG_DVBUSPULSE_DVBUSP_Pos)
29182#define USB_OTG_DVBUSPULSE_DVBUSP USB_OTG_DVBUSPULSE_DVBUSP_Msk
29184/******************** Bit definition forUSB_OTG_GNPTXSTS register ********************/
29185#define USB_OTG_GNPTXSTS_NPTXFSAV_Pos (0U)
29186#define USB_OTG_GNPTXSTS_NPTXFSAV_Msk (0xFFFFUL << USB_OTG_GNPTXSTS_NPTXFSAV_Pos)
29187#define USB_OTG_GNPTXSTS_NPTXFSAV USB_OTG_GNPTXSTS_NPTXFSAV_Msk
29189#define USB_OTG_GNPTXSTS_NPTQXSAV_Pos (16U)
29190#define USB_OTG_GNPTXSTS_NPTQXSAV_Msk (0xFFUL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29191#define USB_OTG_GNPTXSTS_NPTQXSAV USB_OTG_GNPTXSTS_NPTQXSAV_Msk
29192#define USB_OTG_GNPTXSTS_NPTQXSAV_0 (0x01UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29193#define USB_OTG_GNPTXSTS_NPTQXSAV_1 (0x02UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29194#define USB_OTG_GNPTXSTS_NPTQXSAV_2 (0x04UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29195#define USB_OTG_GNPTXSTS_NPTQXSAV_3 (0x08UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29196#define USB_OTG_GNPTXSTS_NPTQXSAV_4 (0x10UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29197#define USB_OTG_GNPTXSTS_NPTQXSAV_5 (0x20UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29198#define USB_OTG_GNPTXSTS_NPTQXSAV_6 (0x40UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29199#define USB_OTG_GNPTXSTS_NPTQXSAV_7 (0x80UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
29201#define USB_OTG_GNPTXSTS_NPTXQTOP_Pos (24U)
29202#define USB_OTG_GNPTXSTS_NPTXQTOP_Msk (0x7FUL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29203#define USB_OTG_GNPTXSTS_NPTXQTOP USB_OTG_GNPTXSTS_NPTXQTOP_Msk
29204#define USB_OTG_GNPTXSTS_NPTXQTOP_0 (0x01UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29205#define USB_OTG_GNPTXSTS_NPTXQTOP_1 (0x02UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29206#define USB_OTG_GNPTXSTS_NPTXQTOP_2 (0x04UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29207#define USB_OTG_GNPTXSTS_NPTXQTOP_3 (0x08UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29208#define USB_OTG_GNPTXSTS_NPTXQTOP_4 (0x10UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29209#define USB_OTG_GNPTXSTS_NPTXQTOP_5 (0x20UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29210#define USB_OTG_GNPTXSTS_NPTXQTOP_6 (0x40UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
29212/******************** Bit definition forUSB_OTG_DTHRCTL register ********************/
29213#define USB_OTG_DTHRCTL_NONISOTHREN_Pos (0U)
29214#define USB_OTG_DTHRCTL_NONISOTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_NONISOTHREN_Pos)
29215#define USB_OTG_DTHRCTL_NONISOTHREN USB_OTG_DTHRCTL_NONISOTHREN_Msk
29216#define USB_OTG_DTHRCTL_ISOTHREN_Pos (1U)
29217#define USB_OTG_DTHRCTL_ISOTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_ISOTHREN_Pos)
29218#define USB_OTG_DTHRCTL_ISOTHREN USB_OTG_DTHRCTL_ISOTHREN_Msk
29220#define USB_OTG_DTHRCTL_TXTHRLEN_Pos (2U)
29221#define USB_OTG_DTHRCTL_TXTHRLEN_Msk (0x1FFUL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29222#define USB_OTG_DTHRCTL_TXTHRLEN USB_OTG_DTHRCTL_TXTHRLEN_Msk
29223#define USB_OTG_DTHRCTL_TXTHRLEN_0 (0x001UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29224#define USB_OTG_DTHRCTL_TXTHRLEN_1 (0x002UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29225#define USB_OTG_DTHRCTL_TXTHRLEN_2 (0x004UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29226#define USB_OTG_DTHRCTL_TXTHRLEN_3 (0x008UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29227#define USB_OTG_DTHRCTL_TXTHRLEN_4 (0x010UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29228#define USB_OTG_DTHRCTL_TXTHRLEN_5 (0x020UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29229#define USB_OTG_DTHRCTL_TXTHRLEN_6 (0x040UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29230#define USB_OTG_DTHRCTL_TXTHRLEN_7 (0x080UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29231#define USB_OTG_DTHRCTL_TXTHRLEN_8 (0x100UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
29232#define USB_OTG_DTHRCTL_RXTHREN_Pos (16U)
29233#define USB_OTG_DTHRCTL_RXTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_RXTHREN_Pos)
29234#define USB_OTG_DTHRCTL_RXTHREN USB_OTG_DTHRCTL_RXTHREN_Msk
29236#define USB_OTG_DTHRCTL_RXTHRLEN_Pos (17U)
29237#define USB_OTG_DTHRCTL_RXTHRLEN_Msk (0x1FFUL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29238#define USB_OTG_DTHRCTL_RXTHRLEN USB_OTG_DTHRCTL_RXTHRLEN_Msk
29239#define USB_OTG_DTHRCTL_RXTHRLEN_0 (0x001UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29240#define USB_OTG_DTHRCTL_RXTHRLEN_1 (0x002UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29241#define USB_OTG_DTHRCTL_RXTHRLEN_2 (0x004UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29242#define USB_OTG_DTHRCTL_RXTHRLEN_3 (0x008UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29243#define USB_OTG_DTHRCTL_RXTHRLEN_4 (0x010UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29244#define USB_OTG_DTHRCTL_RXTHRLEN_5 (0x020UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29245#define USB_OTG_DTHRCTL_RXTHRLEN_6 (0x040UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29246#define USB_OTG_DTHRCTL_RXTHRLEN_7 (0x080UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29247#define USB_OTG_DTHRCTL_RXTHRLEN_8 (0x100UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
29248#define USB_OTG_DTHRCTL_ARPEN_Pos (27U)
29249#define USB_OTG_DTHRCTL_ARPEN_Msk (0x1UL << USB_OTG_DTHRCTL_ARPEN_Pos)
29250#define USB_OTG_DTHRCTL_ARPEN USB_OTG_DTHRCTL_ARPEN_Msk
29252/******************** Bit definition forUSB_OTG_DIEPEMPMSK register ********************/
29253#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos (0U)
29254#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk (0xFFFFUL << USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos)
29255#define USB_OTG_DIEPEMPMSK_INEPTXFEM USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk
29257/******************** Bit definition forUSB_OTG_DEACHINT register ********************/
29258#define USB_OTG_DEACHINT_IEP1INT_Pos (1U)
29259#define USB_OTG_DEACHINT_IEP1INT_Msk (0x1UL << USB_OTG_DEACHINT_IEP1INT_Pos)
29260#define USB_OTG_DEACHINT_IEP1INT USB_OTG_DEACHINT_IEP1INT_Msk
29261#define USB_OTG_DEACHINT_OEP1INT_Pos (17U)
29262#define USB_OTG_DEACHINT_OEP1INT_Msk (0x1UL << USB_OTG_DEACHINT_OEP1INT_Pos)
29263#define USB_OTG_DEACHINT_OEP1INT USB_OTG_DEACHINT_OEP1INT_Msk
29265/******************** Bit definition forUSB_OTG_GCCFG register ********************/
29266#define USB_OTG_GCCFG_DCDET_Pos (0U)
29267#define USB_OTG_GCCFG_DCDET_Msk (0x1UL << USB_OTG_GCCFG_DCDET_Pos)
29268#define USB_OTG_GCCFG_DCDET USB_OTG_GCCFG_DCDET_Msk
29269#define USB_OTG_GCCFG_PDET_Pos (1U)
29270#define USB_OTG_GCCFG_PDET_Msk (0x1UL << USB_OTG_GCCFG_PDET_Pos)
29271#define USB_OTG_GCCFG_PDET USB_OTG_GCCFG_PDET_Msk
29272#define USB_OTG_GCCFG_SDET_Pos (2U)
29273#define USB_OTG_GCCFG_SDET_Msk (0x1UL << USB_OTG_GCCFG_SDET_Pos)
29274#define USB_OTG_GCCFG_SDET USB_OTG_GCCFG_SDET_Msk
29275#define USB_OTG_GCCFG_PS2DET_Pos (3U)
29276#define USB_OTG_GCCFG_PS2DET_Msk (0x1UL << USB_OTG_GCCFG_PS2DET_Pos)
29277#define USB_OTG_GCCFG_PS2DET USB_OTG_GCCFG_PS2DET_Msk
29278#define USB_OTG_GCCFG_PWRDWN_Pos (16U)
29279#define USB_OTG_GCCFG_PWRDWN_Msk (0x1UL << USB_OTG_GCCFG_PWRDWN_Pos)
29280#define USB_OTG_GCCFG_PWRDWN USB_OTG_GCCFG_PWRDWN_Msk
29281#define USB_OTG_GCCFG_BCDEN_Pos (17U)
29282#define USB_OTG_GCCFG_BCDEN_Msk (0x1UL << USB_OTG_GCCFG_BCDEN_Pos)
29283#define USB_OTG_GCCFG_BCDEN USB_OTG_GCCFG_BCDEN_Msk
29284#define USB_OTG_GCCFG_DCDEN_Pos (18U)
29285#define USB_OTG_GCCFG_DCDEN_Msk (0x1UL << USB_OTG_GCCFG_DCDEN_Pos)
29286#define USB_OTG_GCCFG_DCDEN USB_OTG_GCCFG_DCDEN_Msk
29287#define USB_OTG_GCCFG_PDEN_Pos (19U)
29288#define USB_OTG_GCCFG_PDEN_Msk (0x1UL << USB_OTG_GCCFG_PDEN_Pos)
29289#define USB_OTG_GCCFG_PDEN USB_OTG_GCCFG_PDEN_Msk
29290#define USB_OTG_GCCFG_SDEN_Pos (20U)
29291#define USB_OTG_GCCFG_SDEN_Msk (0x1UL << USB_OTG_GCCFG_SDEN_Pos)
29292#define USB_OTG_GCCFG_SDEN USB_OTG_GCCFG_SDEN_Msk
29293#define USB_OTG_GCCFG_VBDEN_Pos (21U)
29294#define USB_OTG_GCCFG_VBDEN_Msk (0x1UL << USB_OTG_GCCFG_VBDEN_Pos)
29295#define USB_OTG_GCCFG_VBDEN USB_OTG_GCCFG_VBDEN_Msk
29297/******************** Bit definition forUSB_OTG_GPWRDN) register ********************/
29298#define USB_OTG_GPWRDN_ADPMEN_Pos (0U)
29299#define USB_OTG_GPWRDN_ADPMEN_Msk (0x1UL << USB_OTG_GPWRDN_ADPMEN_Pos)
29300#define USB_OTG_GPWRDN_ADPMEN USB_OTG_GPWRDN_ADPMEN_Msk
29301#define USB_OTG_GPWRDN_ADPIF_Pos (23U)
29302#define USB_OTG_GPWRDN_ADPIF_Msk (0x1UL << USB_OTG_GPWRDN_ADPIF_Pos)
29303#define USB_OTG_GPWRDN_ADPIF USB_OTG_GPWRDN_ADPIF_Msk
29305/******************** Bit definition forUSB_OTG_DEACHINTMSK register ********************/
29306#define USB_OTG_DEACHINTMSK_IEP1INTM_Pos (1U)
29307#define USB_OTG_DEACHINTMSK_IEP1INTM_Msk (0x1UL << USB_OTG_DEACHINTMSK_IEP1INTM_Pos)
29308#define USB_OTG_DEACHINTMSK_IEP1INTM USB_OTG_DEACHINTMSK_IEP1INTM_Msk
29309#define USB_OTG_DEACHINTMSK_OEP1INTM_Pos (17U)
29310#define USB_OTG_DEACHINTMSK_OEP1INTM_Msk (0x1UL << USB_OTG_DEACHINTMSK_OEP1INTM_Pos)
29311#define USB_OTG_DEACHINTMSK_OEP1INTM USB_OTG_DEACHINTMSK_OEP1INTM_Msk
29313/******************** Bit definition forUSB_OTG_CID register ********************/
29314#define USB_OTG_CID_PRODUCT_ID_Pos (0U)
29315#define USB_OTG_CID_PRODUCT_ID_Msk (0xFFFFFFFFUL << USB_OTG_CID_PRODUCT_ID_Pos)
29316#define USB_OTG_CID_PRODUCT_ID USB_OTG_CID_PRODUCT_ID_Msk
29318/******************** Bit definition for USB_OTG_GLPMCFG register ********************/
29319#define USB_OTG_GLPMCFG_LPMEN_Pos (0U)
29320#define USB_OTG_GLPMCFG_LPMEN_Msk (0x1UL << USB_OTG_GLPMCFG_LPMEN_Pos)
29321#define USB_OTG_GLPMCFG_LPMEN USB_OTG_GLPMCFG_LPMEN_Msk
29322#define USB_OTG_GLPMCFG_LPMACK_Pos (1U)
29323#define USB_OTG_GLPMCFG_LPMACK_Msk (0x1UL << USB_OTG_GLPMCFG_LPMACK_Pos)
29324#define USB_OTG_GLPMCFG_LPMACK USB_OTG_GLPMCFG_LPMACK_Msk
29325#define USB_OTG_GLPMCFG_BESL_Pos (2U)
29326#define USB_OTG_GLPMCFG_BESL_Msk (0xFUL << USB_OTG_GLPMCFG_BESL_Pos)
29327#define USB_OTG_GLPMCFG_BESL USB_OTG_GLPMCFG_BESL_Msk
29328#define USB_OTG_GLPMCFG_REMWAKE_Pos (6U)
29329#define USB_OTG_GLPMCFG_REMWAKE_Msk (0x1UL << USB_OTG_GLPMCFG_REMWAKE_Pos)
29330#define USB_OTG_GLPMCFG_REMWAKE USB_OTG_GLPMCFG_REMWAKE_Msk
29331#define USB_OTG_GLPMCFG_L1SSEN_Pos (7U)
29332#define USB_OTG_GLPMCFG_L1SSEN_Msk (0x1UL << USB_OTG_GLPMCFG_L1SSEN_Pos)
29333#define USB_OTG_GLPMCFG_L1SSEN USB_OTG_GLPMCFG_L1SSEN_Msk
29334#define USB_OTG_GLPMCFG_BESLTHRS_Pos (8U)
29335#define USB_OTG_GLPMCFG_BESLTHRS_Msk (0xFUL << USB_OTG_GLPMCFG_BESLTHRS_Pos)
29336#define USB_OTG_GLPMCFG_BESLTHRS USB_OTG_GLPMCFG_BESLTHRS_Msk
29337#define USB_OTG_GLPMCFG_L1DSEN_Pos (12U)
29338#define USB_OTG_GLPMCFG_L1DSEN_Msk (0x1UL << USB_OTG_GLPMCFG_L1DSEN_Pos)
29339#define USB_OTG_GLPMCFG_L1DSEN USB_OTG_GLPMCFG_L1DSEN_Msk
29340#define USB_OTG_GLPMCFG_LPMRSP_Pos (13U)
29341#define USB_OTG_GLPMCFG_LPMRSP_Msk (0x3UL << USB_OTG_GLPMCFG_LPMRSP_Pos)
29342#define USB_OTG_GLPMCFG_LPMRSP USB_OTG_GLPMCFG_LPMRSP_Msk
29343#define USB_OTG_GLPMCFG_SLPSTS_Pos (15U)
29344#define USB_OTG_GLPMCFG_SLPSTS_Msk (0x1UL << USB_OTG_GLPMCFG_SLPSTS_Pos)
29345#define USB_OTG_GLPMCFG_SLPSTS USB_OTG_GLPMCFG_SLPSTS_Msk
29346#define USB_OTG_GLPMCFG_L1RSMOK_Pos (16U)
29347#define USB_OTG_GLPMCFG_L1RSMOK_Msk (0x1UL << USB_OTG_GLPMCFG_L1RSMOK_Pos)
29348#define USB_OTG_GLPMCFG_L1RSMOK USB_OTG_GLPMCFG_L1RSMOK_Msk
29349#define USB_OTG_GLPMCFG_LPMCHIDX_Pos (17U)
29350#define USB_OTG_GLPMCFG_LPMCHIDX_Msk (0xFUL << USB_OTG_GLPMCFG_LPMCHIDX_Pos)
29351#define USB_OTG_GLPMCFG_LPMCHIDX USB_OTG_GLPMCFG_LPMCHIDX_Msk
29352#define USB_OTG_GLPMCFG_LPMRCNT_Pos (21U)
29353#define USB_OTG_GLPMCFG_LPMRCNT_Msk (0x7UL << USB_OTG_GLPMCFG_LPMRCNT_Pos)
29354#define USB_OTG_GLPMCFG_LPMRCNT USB_OTG_GLPMCFG_LPMRCNT_Msk
29355#define USB_OTG_GLPMCFG_SNDLPM_Pos (24U)
29356#define USB_OTG_GLPMCFG_SNDLPM_Msk (0x1UL << USB_OTG_GLPMCFG_SNDLPM_Pos)
29357#define USB_OTG_GLPMCFG_SNDLPM USB_OTG_GLPMCFG_SNDLPM_Msk
29358#define USB_OTG_GLPMCFG_LPMRCNTSTS_Pos (25U)
29359#define USB_OTG_GLPMCFG_LPMRCNTSTS_Msk (0x7UL << USB_OTG_GLPMCFG_LPMRCNTSTS_Pos)
29360#define USB_OTG_GLPMCFG_LPMRCNTSTS USB_OTG_GLPMCFG_LPMRCNTSTS_Msk
29361#define USB_OTG_GLPMCFG_ENBESL_Pos (28U)
29362#define USB_OTG_GLPMCFG_ENBESL_Msk (0x1UL << USB_OTG_GLPMCFG_ENBESL_Pos)
29363#define USB_OTG_GLPMCFG_ENBESL USB_OTG_GLPMCFG_ENBESL_Msk
29365/******************** Bit definition forUSB_OTG_DIEPEACHMSK1 register ********************/
29366#define USB_OTG_DIEPEACHMSK1_XFRCM_Pos (0U)
29367#define USB_OTG_DIEPEACHMSK1_XFRCM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_XFRCM_Pos)
29368#define USB_OTG_DIEPEACHMSK1_XFRCM USB_OTG_DIEPEACHMSK1_XFRCM_Msk
29369#define USB_OTG_DIEPEACHMSK1_EPDM_Pos (1U)
29370#define USB_OTG_DIEPEACHMSK1_EPDM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_EPDM_Pos)
29371#define USB_OTG_DIEPEACHMSK1_EPDM USB_OTG_DIEPEACHMSK1_EPDM_Msk
29372#define USB_OTG_DIEPEACHMSK1_TOM_Pos (3U)
29373#define USB_OTG_DIEPEACHMSK1_TOM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_TOM_Pos)
29374#define USB_OTG_DIEPEACHMSK1_TOM USB_OTG_DIEPEACHMSK1_TOM_Msk
29375#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos (4U)
29376#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos)
29377#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk
29378#define USB_OTG_DIEPEACHMSK1_INEPNMM_Pos (5U)
29379#define USB_OTG_DIEPEACHMSK1_INEPNMM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNMM_Pos)
29380#define USB_OTG_DIEPEACHMSK1_INEPNMM USB_OTG_DIEPEACHMSK1_INEPNMM_Msk
29381#define USB_OTG_DIEPEACHMSK1_INEPNEM_Pos (6U)
29382#define USB_OTG_DIEPEACHMSK1_INEPNEM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNEM_Pos)
29383#define USB_OTG_DIEPEACHMSK1_INEPNEM USB_OTG_DIEPEACHMSK1_INEPNEM_Msk
29384#define USB_OTG_DIEPEACHMSK1_TXFURM_Pos (8U)
29385#define USB_OTG_DIEPEACHMSK1_TXFURM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_TXFURM_Pos)
29386#define USB_OTG_DIEPEACHMSK1_TXFURM USB_OTG_DIEPEACHMSK1_TXFURM_Msk
29387#define USB_OTG_DIEPEACHMSK1_BIM_Pos (9U)
29388#define USB_OTG_DIEPEACHMSK1_BIM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_BIM_Pos)
29389#define USB_OTG_DIEPEACHMSK1_BIM USB_OTG_DIEPEACHMSK1_BIM_Msk
29390#define USB_OTG_DIEPEACHMSK1_NAKM_Pos (13U)
29391#define USB_OTG_DIEPEACHMSK1_NAKM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_NAKM_Pos)
29392#define USB_OTG_DIEPEACHMSK1_NAKM USB_OTG_DIEPEACHMSK1_NAKM_Msk
29394/******************** Bit definition forUSB_OTG_HPRT register ********************/
29395#define USB_OTG_HPRT_PCSTS_Pos (0U)
29396#define USB_OTG_HPRT_PCSTS_Msk (0x1UL << USB_OTG_HPRT_PCSTS_Pos)
29397#define USB_OTG_HPRT_PCSTS USB_OTG_HPRT_PCSTS_Msk
29398#define USB_OTG_HPRT_PCDET_Pos (1U)
29399#define USB_OTG_HPRT_PCDET_Msk (0x1UL << USB_OTG_HPRT_PCDET_Pos)
29400#define USB_OTG_HPRT_PCDET USB_OTG_HPRT_PCDET_Msk
29401#define USB_OTG_HPRT_PENA_Pos (2U)
29402#define USB_OTG_HPRT_PENA_Msk (0x1UL << USB_OTG_HPRT_PENA_Pos)
29403#define USB_OTG_HPRT_PENA USB_OTG_HPRT_PENA_Msk
29404#define USB_OTG_HPRT_PENCHNG_Pos (3U)
29405#define USB_OTG_HPRT_PENCHNG_Msk (0x1UL << USB_OTG_HPRT_PENCHNG_Pos)
29406#define USB_OTG_HPRT_PENCHNG USB_OTG_HPRT_PENCHNG_Msk
29407#define USB_OTG_HPRT_POCA_Pos (4U)
29408#define USB_OTG_HPRT_POCA_Msk (0x1UL << USB_OTG_HPRT_POCA_Pos)
29409#define USB_OTG_HPRT_POCA USB_OTG_HPRT_POCA_Msk
29410#define USB_OTG_HPRT_POCCHNG_Pos (5U)
29411#define USB_OTG_HPRT_POCCHNG_Msk (0x1UL << USB_OTG_HPRT_POCCHNG_Pos)
29412#define USB_OTG_HPRT_POCCHNG USB_OTG_HPRT_POCCHNG_Msk
29413#define USB_OTG_HPRT_PRES_Pos (6U)
29414#define USB_OTG_HPRT_PRES_Msk (0x1UL << USB_OTG_HPRT_PRES_Pos)
29415#define USB_OTG_HPRT_PRES USB_OTG_HPRT_PRES_Msk
29416#define USB_OTG_HPRT_PSUSP_Pos (7U)
29417#define USB_OTG_HPRT_PSUSP_Msk (0x1UL << USB_OTG_HPRT_PSUSP_Pos)
29418#define USB_OTG_HPRT_PSUSP USB_OTG_HPRT_PSUSP_Msk
29419#define USB_OTG_HPRT_PRST_Pos (8U)
29420#define USB_OTG_HPRT_PRST_Msk (0x1UL << USB_OTG_HPRT_PRST_Pos)
29421#define USB_OTG_HPRT_PRST USB_OTG_HPRT_PRST_Msk
29423#define USB_OTG_HPRT_PLSTS_Pos (10U)
29424#define USB_OTG_HPRT_PLSTS_Msk (0x3UL << USB_OTG_HPRT_PLSTS_Pos)
29425#define USB_OTG_HPRT_PLSTS USB_OTG_HPRT_PLSTS_Msk
29426#define USB_OTG_HPRT_PLSTS_0 (0x1UL << USB_OTG_HPRT_PLSTS_Pos)
29427#define USB_OTG_HPRT_PLSTS_1 (0x2UL << USB_OTG_HPRT_PLSTS_Pos)
29428#define USB_OTG_HPRT_PPWR_Pos (12U)
29429#define USB_OTG_HPRT_PPWR_Msk (0x1UL << USB_OTG_HPRT_PPWR_Pos)
29430#define USB_OTG_HPRT_PPWR USB_OTG_HPRT_PPWR_Msk
29432#define USB_OTG_HPRT_PTCTL_Pos (13U)
29433#define USB_OTG_HPRT_PTCTL_Msk (0xFUL << USB_OTG_HPRT_PTCTL_Pos)
29434#define USB_OTG_HPRT_PTCTL USB_OTG_HPRT_PTCTL_Msk
29435#define USB_OTG_HPRT_PTCTL_0 (0x1UL << USB_OTG_HPRT_PTCTL_Pos)
29436#define USB_OTG_HPRT_PTCTL_1 (0x2UL << USB_OTG_HPRT_PTCTL_Pos)
29437#define USB_OTG_HPRT_PTCTL_2 (0x4UL << USB_OTG_HPRT_PTCTL_Pos)
29438#define USB_OTG_HPRT_PTCTL_3 (0x8UL << USB_OTG_HPRT_PTCTL_Pos)
29440#define USB_OTG_HPRT_PSPD_Pos (17U)
29441#define USB_OTG_HPRT_PSPD_Msk (0x3UL << USB_OTG_HPRT_PSPD_Pos)
29442#define USB_OTG_HPRT_PSPD USB_OTG_HPRT_PSPD_Msk
29443#define USB_OTG_HPRT_PSPD_0 (0x1UL << USB_OTG_HPRT_PSPD_Pos)
29444#define USB_OTG_HPRT_PSPD_1 (0x2UL << USB_OTG_HPRT_PSPD_Pos)
29446/******************** Bit definition forUSB_OTG_DOEPEACHMSK1 register ********************/
29447#define USB_OTG_DOEPEACHMSK1_XFRCM_Pos (0U)
29448#define USB_OTG_DOEPEACHMSK1_XFRCM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_XFRCM_Pos)
29449#define USB_OTG_DOEPEACHMSK1_XFRCM USB_OTG_DOEPEACHMSK1_XFRCM_Msk
29450#define USB_OTG_DOEPEACHMSK1_EPDM_Pos (1U)
29451#define USB_OTG_DOEPEACHMSK1_EPDM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_EPDM_Pos)
29452#define USB_OTG_DOEPEACHMSK1_EPDM USB_OTG_DOEPEACHMSK1_EPDM_Msk
29453#define USB_OTG_DOEPEACHMSK1_TOM_Pos (3U)
29454#define USB_OTG_DOEPEACHMSK1_TOM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_TOM_Pos)
29455#define USB_OTG_DOEPEACHMSK1_TOM USB_OTG_DOEPEACHMSK1_TOM_Msk
29456#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos (4U)
29457#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos)
29458#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk
29459#define USB_OTG_DOEPEACHMSK1_INEPNMM_Pos (5U)
29460#define USB_OTG_DOEPEACHMSK1_INEPNMM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNMM_Pos)
29461#define USB_OTG_DOEPEACHMSK1_INEPNMM USB_OTG_DOEPEACHMSK1_INEPNMM_Msk
29462#define USB_OTG_DOEPEACHMSK1_INEPNEM_Pos (6U)
29463#define USB_OTG_DOEPEACHMSK1_INEPNEM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNEM_Pos)
29464#define USB_OTG_DOEPEACHMSK1_INEPNEM USB_OTG_DOEPEACHMSK1_INEPNEM_Msk
29465#define USB_OTG_DOEPEACHMSK1_TXFURM_Pos (8U)
29466#define USB_OTG_DOEPEACHMSK1_TXFURM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_TXFURM_Pos)
29467#define USB_OTG_DOEPEACHMSK1_TXFURM USB_OTG_DOEPEACHMSK1_TXFURM_Msk
29468#define USB_OTG_DOEPEACHMSK1_BIM_Pos (9U)
29469#define USB_OTG_DOEPEACHMSK1_BIM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_BIM_Pos)
29470#define USB_OTG_DOEPEACHMSK1_BIM USB_OTG_DOEPEACHMSK1_BIM_Msk
29471#define USB_OTG_DOEPEACHMSK1_BERRM_Pos (12U)
29472#define USB_OTG_DOEPEACHMSK1_BERRM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_BERRM_Pos)
29473#define USB_OTG_DOEPEACHMSK1_BERRM USB_OTG_DOEPEACHMSK1_BERRM_Msk
29474#define USB_OTG_DOEPEACHMSK1_NAKM_Pos (13U)
29475#define USB_OTG_DOEPEACHMSK1_NAKM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_NAKM_Pos)
29476#define USB_OTG_DOEPEACHMSK1_NAKM USB_OTG_DOEPEACHMSK1_NAKM_Msk
29477#define USB_OTG_DOEPEACHMSK1_NYETM_Pos (14U)
29478#define USB_OTG_DOEPEACHMSK1_NYETM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_NYETM_Pos)
29479#define USB_OTG_DOEPEACHMSK1_NYETM USB_OTG_DOEPEACHMSK1_NYETM_Msk
29481/******************** Bit definition forUSB_OTG_HPTXFSIZ register ********************/
29482#define USB_OTG_HPTXFSIZ_PTXSA_Pos (0U)
29483#define USB_OTG_HPTXFSIZ_PTXSA_Msk (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXSA_Pos)
29484#define USB_OTG_HPTXFSIZ_PTXSA USB_OTG_HPTXFSIZ_PTXSA_Msk
29485#define USB_OTG_HPTXFSIZ_PTXFD_Pos (16U)
29486#define USB_OTG_HPTXFSIZ_PTXFD_Msk (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXFD_Pos)
29487#define USB_OTG_HPTXFSIZ_PTXFD USB_OTG_HPTXFSIZ_PTXFD_Msk
29489/******************** Bit definition forUSB_OTG_DIEPCTL register ********************/
29490#define USB_OTG_DIEPCTL_MPSIZ_Pos (0U)
29491#define USB_OTG_DIEPCTL_MPSIZ_Msk (0x7FFUL << USB_OTG_DIEPCTL_MPSIZ_Pos)
29492#define USB_OTG_DIEPCTL_MPSIZ USB_OTG_DIEPCTL_MPSIZ_Msk
29493#define USB_OTG_DIEPCTL_USBAEP_Pos (15U)
29494#define USB_OTG_DIEPCTL_USBAEP_Msk (0x1UL << USB_OTG_DIEPCTL_USBAEP_Pos)
29495#define USB_OTG_DIEPCTL_USBAEP USB_OTG_DIEPCTL_USBAEP_Msk
29496#define USB_OTG_DIEPCTL_EONUM_DPID_Pos (16U)
29497#define USB_OTG_DIEPCTL_EONUM_DPID_Msk (0x1UL << USB_OTG_DIEPCTL_EONUM_DPID_Pos)
29498#define USB_OTG_DIEPCTL_EONUM_DPID USB_OTG_DIEPCTL_EONUM_DPID_Msk
29499#define USB_OTG_DIEPCTL_NAKSTS_Pos (17U)
29500#define USB_OTG_DIEPCTL_NAKSTS_Msk (0x1UL << USB_OTG_DIEPCTL_NAKSTS_Pos)
29501#define USB_OTG_DIEPCTL_NAKSTS USB_OTG_DIEPCTL_NAKSTS_Msk
29503#define USB_OTG_DIEPCTL_EPTYP_Pos (18U)
29504#define USB_OTG_DIEPCTL_EPTYP_Msk (0x3UL << USB_OTG_DIEPCTL_EPTYP_Pos)
29505#define USB_OTG_DIEPCTL_EPTYP USB_OTG_DIEPCTL_EPTYP_Msk
29506#define USB_OTG_DIEPCTL_EPTYP_0 (0x1UL << USB_OTG_DIEPCTL_EPTYP_Pos)
29507#define USB_OTG_DIEPCTL_EPTYP_1 (0x2UL << USB_OTG_DIEPCTL_EPTYP_Pos)
29508#define USB_OTG_DIEPCTL_STALL_Pos (21U)
29509#define USB_OTG_DIEPCTL_STALL_Msk (0x1UL << USB_OTG_DIEPCTL_STALL_Pos)
29510#define USB_OTG_DIEPCTL_STALL USB_OTG_DIEPCTL_STALL_Msk
29512#define USB_OTG_DIEPCTL_TXFNUM_Pos (22U)
29513#define USB_OTG_DIEPCTL_TXFNUM_Msk (0xFUL << USB_OTG_DIEPCTL_TXFNUM_Pos)
29514#define USB_OTG_DIEPCTL_TXFNUM USB_OTG_DIEPCTL_TXFNUM_Msk
29515#define USB_OTG_DIEPCTL_TXFNUM_0 (0x1UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
29516#define USB_OTG_DIEPCTL_TXFNUM_1 (0x2UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
29517#define USB_OTG_DIEPCTL_TXFNUM_2 (0x4UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
29518#define USB_OTG_DIEPCTL_TXFNUM_3 (0x8UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
29519#define USB_OTG_DIEPCTL_CNAK_Pos (26U)
29520#define USB_OTG_DIEPCTL_CNAK_Msk (0x1UL << USB_OTG_DIEPCTL_CNAK_Pos)
29521#define USB_OTG_DIEPCTL_CNAK USB_OTG_DIEPCTL_CNAK_Msk
29522#define USB_OTG_DIEPCTL_SNAK_Pos (27U)
29523#define USB_OTG_DIEPCTL_SNAK_Msk (0x1UL << USB_OTG_DIEPCTL_SNAK_Pos)
29524#define USB_OTG_DIEPCTL_SNAK USB_OTG_DIEPCTL_SNAK_Msk
29525#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos (28U)
29526#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk (0x1UL << USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos)
29527#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk
29528#define USB_OTG_DIEPCTL_SODDFRM_Pos (29U)
29529#define USB_OTG_DIEPCTL_SODDFRM_Msk (0x1UL << USB_OTG_DIEPCTL_SODDFRM_Pos)
29530#define USB_OTG_DIEPCTL_SODDFRM USB_OTG_DIEPCTL_SODDFRM_Msk
29531#define USB_OTG_DIEPCTL_EPDIS_Pos (30U)
29532#define USB_OTG_DIEPCTL_EPDIS_Msk (0x1UL << USB_OTG_DIEPCTL_EPDIS_Pos)
29533#define USB_OTG_DIEPCTL_EPDIS USB_OTG_DIEPCTL_EPDIS_Msk
29534#define USB_OTG_DIEPCTL_EPENA_Pos (31U)
29535#define USB_OTG_DIEPCTL_EPENA_Msk (0x1UL << USB_OTG_DIEPCTL_EPENA_Pos)
29536#define USB_OTG_DIEPCTL_EPENA USB_OTG_DIEPCTL_EPENA_Msk
29538/******************** Bit definition forUSB_OTG_HCCHAR register ********************/
29539#define USB_OTG_HCCHAR_MPSIZ_Pos (0U)
29540#define USB_OTG_HCCHAR_MPSIZ_Msk (0x7FFUL << USB_OTG_HCCHAR_MPSIZ_Pos)
29541#define USB_OTG_HCCHAR_MPSIZ USB_OTG_HCCHAR_MPSIZ_Msk
29543#define USB_OTG_HCCHAR_EPNUM_Pos (11U)
29544#define USB_OTG_HCCHAR_EPNUM_Msk (0xFUL << USB_OTG_HCCHAR_EPNUM_Pos)
29545#define USB_OTG_HCCHAR_EPNUM USB_OTG_HCCHAR_EPNUM_Msk
29546#define USB_OTG_HCCHAR_EPNUM_0 (0x1UL << USB_OTG_HCCHAR_EPNUM_Pos)
29547#define USB_OTG_HCCHAR_EPNUM_1 (0x2UL << USB_OTG_HCCHAR_EPNUM_Pos)
29548#define USB_OTG_HCCHAR_EPNUM_2 (0x4UL << USB_OTG_HCCHAR_EPNUM_Pos)
29549#define USB_OTG_HCCHAR_EPNUM_3 (0x8UL << USB_OTG_HCCHAR_EPNUM_Pos)
29550#define USB_OTG_HCCHAR_EPDIR_Pos (15U)
29551#define USB_OTG_HCCHAR_EPDIR_Msk (0x1UL << USB_OTG_HCCHAR_EPDIR_Pos)
29552#define USB_OTG_HCCHAR_EPDIR USB_OTG_HCCHAR_EPDIR_Msk
29553#define USB_OTG_HCCHAR_LSDEV_Pos (17U)
29554#define USB_OTG_HCCHAR_LSDEV_Msk (0x1UL << USB_OTG_HCCHAR_LSDEV_Pos)
29555#define USB_OTG_HCCHAR_LSDEV USB_OTG_HCCHAR_LSDEV_Msk
29557#define USB_OTG_HCCHAR_EPTYP_Pos (18U)
29558#define USB_OTG_HCCHAR_EPTYP_Msk (0x3UL << USB_OTG_HCCHAR_EPTYP_Pos)
29559#define USB_OTG_HCCHAR_EPTYP USB_OTG_HCCHAR_EPTYP_Msk
29560#define USB_OTG_HCCHAR_EPTYP_0 (0x1UL << USB_OTG_HCCHAR_EPTYP_Pos)
29561#define USB_OTG_HCCHAR_EPTYP_1 (0x2UL << USB_OTG_HCCHAR_EPTYP_Pos)
29563#define USB_OTG_HCCHAR_MC_Pos (20U)
29564#define USB_OTG_HCCHAR_MC_Msk (0x3UL << USB_OTG_HCCHAR_MC_Pos)
29565#define USB_OTG_HCCHAR_MC USB_OTG_HCCHAR_MC_Msk
29566#define USB_OTG_HCCHAR_MC_0 (0x1UL << USB_OTG_HCCHAR_MC_Pos)
29567#define USB_OTG_HCCHAR_MC_1 (0x2UL << USB_OTG_HCCHAR_MC_Pos)
29569#define USB_OTG_HCCHAR_DAD_Pos (22U)
29570#define USB_OTG_HCCHAR_DAD_Msk (0x7FUL << USB_OTG_HCCHAR_DAD_Pos)
29571#define USB_OTG_HCCHAR_DAD USB_OTG_HCCHAR_DAD_Msk
29572#define USB_OTG_HCCHAR_DAD_0 (0x01UL << USB_OTG_HCCHAR_DAD_Pos)
29573#define USB_OTG_HCCHAR_DAD_1 (0x02UL << USB_OTG_HCCHAR_DAD_Pos)
29574#define USB_OTG_HCCHAR_DAD_2 (0x04UL << USB_OTG_HCCHAR_DAD_Pos)
29575#define USB_OTG_HCCHAR_DAD_3 (0x08UL << USB_OTG_HCCHAR_DAD_Pos)
29576#define USB_OTG_HCCHAR_DAD_4 (0x10UL << USB_OTG_HCCHAR_DAD_Pos)
29577#define USB_OTG_HCCHAR_DAD_5 (0x20UL << USB_OTG_HCCHAR_DAD_Pos)
29578#define USB_OTG_HCCHAR_DAD_6 (0x40UL << USB_OTG_HCCHAR_DAD_Pos)
29579#define USB_OTG_HCCHAR_ODDFRM_Pos (29U)
29580#define USB_OTG_HCCHAR_ODDFRM_Msk (0x1UL << USB_OTG_HCCHAR_ODDFRM_Pos)
29581#define USB_OTG_HCCHAR_ODDFRM USB_OTG_HCCHAR_ODDFRM_Msk
29582#define USB_OTG_HCCHAR_CHDIS_Pos (30U)
29583#define USB_OTG_HCCHAR_CHDIS_Msk (0x1UL << USB_OTG_HCCHAR_CHDIS_Pos)
29584#define USB_OTG_HCCHAR_CHDIS USB_OTG_HCCHAR_CHDIS_Msk
29585#define USB_OTG_HCCHAR_CHENA_Pos (31U)
29586#define USB_OTG_HCCHAR_CHENA_Msk (0x1UL << USB_OTG_HCCHAR_CHENA_Pos)
29587#define USB_OTG_HCCHAR_CHENA USB_OTG_HCCHAR_CHENA_Msk
29589/******************** Bit definition forUSB_OTG_HCSPLT register ********************/
29590
29591#define USB_OTG_HCSPLT_PRTADDR_Pos (0U)
29592#define USB_OTG_HCSPLT_PRTADDR_Msk (0x7FUL << USB_OTG_HCSPLT_PRTADDR_Pos)
29593#define USB_OTG_HCSPLT_PRTADDR USB_OTG_HCSPLT_PRTADDR_Msk
29594#define USB_OTG_HCSPLT_PRTADDR_0 (0x01UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29595#define USB_OTG_HCSPLT_PRTADDR_1 (0x02UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29596#define USB_OTG_HCSPLT_PRTADDR_2 (0x04UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29597#define USB_OTG_HCSPLT_PRTADDR_3 (0x08UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29598#define USB_OTG_HCSPLT_PRTADDR_4 (0x10UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29599#define USB_OTG_HCSPLT_PRTADDR_5 (0x20UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29600#define USB_OTG_HCSPLT_PRTADDR_6 (0x40UL << USB_OTG_HCSPLT_PRTADDR_Pos)
29602#define USB_OTG_HCSPLT_HUBADDR_Pos (7U)
29603#define USB_OTG_HCSPLT_HUBADDR_Msk (0x7FUL << USB_OTG_HCSPLT_HUBADDR_Pos)
29604#define USB_OTG_HCSPLT_HUBADDR USB_OTG_HCSPLT_HUBADDR_Msk
29605#define USB_OTG_HCSPLT_HUBADDR_0 (0x01UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29606#define USB_OTG_HCSPLT_HUBADDR_1 (0x02UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29607#define USB_OTG_HCSPLT_HUBADDR_2 (0x04UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29608#define USB_OTG_HCSPLT_HUBADDR_3 (0x08UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29609#define USB_OTG_HCSPLT_HUBADDR_4 (0x10UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29610#define USB_OTG_HCSPLT_HUBADDR_5 (0x20UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29611#define USB_OTG_HCSPLT_HUBADDR_6 (0x40UL << USB_OTG_HCSPLT_HUBADDR_Pos)
29613#define USB_OTG_HCSPLT_XACTPOS_Pos (14U)
29614#define USB_OTG_HCSPLT_XACTPOS_Msk (0x3UL << USB_OTG_HCSPLT_XACTPOS_Pos)
29615#define USB_OTG_HCSPLT_XACTPOS USB_OTG_HCSPLT_XACTPOS_Msk
29616#define USB_OTG_HCSPLT_XACTPOS_0 (0x1UL << USB_OTG_HCSPLT_XACTPOS_Pos)
29617#define USB_OTG_HCSPLT_XACTPOS_1 (0x2UL << USB_OTG_HCSPLT_XACTPOS_Pos)
29618#define USB_OTG_HCSPLT_COMPLSPLT_Pos (16U)
29619#define USB_OTG_HCSPLT_COMPLSPLT_Msk (0x1UL << USB_OTG_HCSPLT_COMPLSPLT_Pos)
29620#define USB_OTG_HCSPLT_COMPLSPLT USB_OTG_HCSPLT_COMPLSPLT_Msk
29621#define USB_OTG_HCSPLT_SPLITEN_Pos (31U)
29622#define USB_OTG_HCSPLT_SPLITEN_Msk (0x1UL << USB_OTG_HCSPLT_SPLITEN_Pos)
29623#define USB_OTG_HCSPLT_SPLITEN USB_OTG_HCSPLT_SPLITEN_Msk
29625/******************** Bit definition forUSB_OTG_HCINT register ********************/
29626#define USB_OTG_HCINT_XFRC_Pos (0U)
29627#define USB_OTG_HCINT_XFRC_Msk (0x1UL << USB_OTG_HCINT_XFRC_Pos)
29628#define USB_OTG_HCINT_XFRC USB_OTG_HCINT_XFRC_Msk
29629#define USB_OTG_HCINT_CHH_Pos (1U)
29630#define USB_OTG_HCINT_CHH_Msk (0x1UL << USB_OTG_HCINT_CHH_Pos)
29631#define USB_OTG_HCINT_CHH USB_OTG_HCINT_CHH_Msk
29632#define USB_OTG_HCINT_AHBERR_Pos (2U)
29633#define USB_OTG_HCINT_AHBERR_Msk (0x1UL << USB_OTG_HCINT_AHBERR_Pos)
29634#define USB_OTG_HCINT_AHBERR USB_OTG_HCINT_AHBERR_Msk
29635#define USB_OTG_HCINT_STALL_Pos (3U)
29636#define USB_OTG_HCINT_STALL_Msk (0x1UL << USB_OTG_HCINT_STALL_Pos)
29637#define USB_OTG_HCINT_STALL USB_OTG_HCINT_STALL_Msk
29638#define USB_OTG_HCINT_NAK_Pos (4U)
29639#define USB_OTG_HCINT_NAK_Msk (0x1UL << USB_OTG_HCINT_NAK_Pos)
29640#define USB_OTG_HCINT_NAK USB_OTG_HCINT_NAK_Msk
29641#define USB_OTG_HCINT_ACK_Pos (5U)
29642#define USB_OTG_HCINT_ACK_Msk (0x1UL << USB_OTG_HCINT_ACK_Pos)
29643#define USB_OTG_HCINT_ACK USB_OTG_HCINT_ACK_Msk
29644#define USB_OTG_HCINT_NYET_Pos (6U)
29645#define USB_OTG_HCINT_NYET_Msk (0x1UL << USB_OTG_HCINT_NYET_Pos)
29646#define USB_OTG_HCINT_NYET USB_OTG_HCINT_NYET_Msk
29647#define USB_OTG_HCINT_TXERR_Pos (7U)
29648#define USB_OTG_HCINT_TXERR_Msk (0x1UL << USB_OTG_HCINT_TXERR_Pos)
29649#define USB_OTG_HCINT_TXERR USB_OTG_HCINT_TXERR_Msk
29650#define USB_OTG_HCINT_BBERR_Pos (8U)
29651#define USB_OTG_HCINT_BBERR_Msk (0x1UL << USB_OTG_HCINT_BBERR_Pos)
29652#define USB_OTG_HCINT_BBERR USB_OTG_HCINT_BBERR_Msk
29653#define USB_OTG_HCINT_FRMOR_Pos (9U)
29654#define USB_OTG_HCINT_FRMOR_Msk (0x1UL << USB_OTG_HCINT_FRMOR_Pos)
29655#define USB_OTG_HCINT_FRMOR USB_OTG_HCINT_FRMOR_Msk
29656#define USB_OTG_HCINT_DTERR_Pos (10U)
29657#define USB_OTG_HCINT_DTERR_Msk (0x1UL << USB_OTG_HCINT_DTERR_Pos)
29658#define USB_OTG_HCINT_DTERR USB_OTG_HCINT_DTERR_Msk
29660/******************** Bit definition forUSB_OTG_DIEPINT register ********************/
29661#define USB_OTG_DIEPINT_XFRC_Pos (0U)
29662#define USB_OTG_DIEPINT_XFRC_Msk (0x1UL << USB_OTG_DIEPINT_XFRC_Pos)
29663#define USB_OTG_DIEPINT_XFRC USB_OTG_DIEPINT_XFRC_Msk
29664#define USB_OTG_DIEPINT_EPDISD_Pos (1U)
29665#define USB_OTG_DIEPINT_EPDISD_Msk (0x1UL << USB_OTG_DIEPINT_EPDISD_Pos)
29666#define USB_OTG_DIEPINT_EPDISD USB_OTG_DIEPINT_EPDISD_Msk
29667#define USB_OTG_DIEPINT_AHBERR_Pos (2U)
29668#define USB_OTG_DIEPINT_AHBERR_Msk (0x1UL << USB_OTG_DIEPINT_AHBERR_Pos)
29669#define USB_OTG_DIEPINT_AHBERR USB_OTG_DIEPINT_AHBERR_Msk
29670#define USB_OTG_DIEPINT_TOC_Pos (3U)
29671#define USB_OTG_DIEPINT_TOC_Msk (0x1UL << USB_OTG_DIEPINT_TOC_Pos)
29672#define USB_OTG_DIEPINT_TOC USB_OTG_DIEPINT_TOC_Msk
29673#define USB_OTG_DIEPINT_ITTXFE_Pos (4U)
29674#define USB_OTG_DIEPINT_ITTXFE_Msk (0x1UL << USB_OTG_DIEPINT_ITTXFE_Pos)
29675#define USB_OTG_DIEPINT_ITTXFE USB_OTG_DIEPINT_ITTXFE_Msk
29676#define USB_OTG_DIEPINT_INEPNM_Pos (5U)
29677#define USB_OTG_DIEPINT_INEPNM_Msk (0x1UL << USB_OTG_DIEPINT_INEPNM_Pos)
29678#define USB_OTG_DIEPINT_INEPNM USB_OTG_DIEPINT_INEPNM_Msk
29679#define USB_OTG_DIEPINT_INEPNE_Pos (6U)
29680#define USB_OTG_DIEPINT_INEPNE_Msk (0x1UL << USB_OTG_DIEPINT_INEPNE_Pos)
29681#define USB_OTG_DIEPINT_INEPNE USB_OTG_DIEPINT_INEPNE_Msk
29682#define USB_OTG_DIEPINT_TXFE_Pos (7U)
29683#define USB_OTG_DIEPINT_TXFE_Msk (0x1UL << USB_OTG_DIEPINT_TXFE_Pos)
29684#define USB_OTG_DIEPINT_TXFE USB_OTG_DIEPINT_TXFE_Msk
29685#define USB_OTG_DIEPINT_TXFIFOUDRN_Pos (8U)
29686#define USB_OTG_DIEPINT_TXFIFOUDRN_Msk (0x1UL << USB_OTG_DIEPINT_TXFIFOUDRN_Pos)
29687#define USB_OTG_DIEPINT_TXFIFOUDRN USB_OTG_DIEPINT_TXFIFOUDRN_Msk
29688#define USB_OTG_DIEPINT_BNA_Pos (9U)
29689#define USB_OTG_DIEPINT_BNA_Msk (0x1UL << USB_OTG_DIEPINT_BNA_Pos)
29690#define USB_OTG_DIEPINT_BNA USB_OTG_DIEPINT_BNA_Msk
29691#define USB_OTG_DIEPINT_PKTDRPSTS_Pos (11U)
29692#define USB_OTG_DIEPINT_PKTDRPSTS_Msk (0x1UL << USB_OTG_DIEPINT_PKTDRPSTS_Pos)
29693#define USB_OTG_DIEPINT_PKTDRPSTS USB_OTG_DIEPINT_PKTDRPSTS_Msk
29694#define USB_OTG_DIEPINT_BERR_Pos (12U)
29695#define USB_OTG_DIEPINT_BERR_Msk (0x1UL << USB_OTG_DIEPINT_BERR_Pos)
29696#define USB_OTG_DIEPINT_BERR USB_OTG_DIEPINT_BERR_Msk
29697#define USB_OTG_DIEPINT_NAK_Pos (13U)
29698#define USB_OTG_DIEPINT_NAK_Msk (0x1UL << USB_OTG_DIEPINT_NAK_Pos)
29699#define USB_OTG_DIEPINT_NAK USB_OTG_DIEPINT_NAK_Msk
29701/******************** Bit definition forUSB_OTG_HCINTMSK register ********************/
29702#define USB_OTG_HCINTMSK_XFRCM_Pos (0U)
29703#define USB_OTG_HCINTMSK_XFRCM_Msk (0x1UL << USB_OTG_HCINTMSK_XFRCM_Pos)
29704#define USB_OTG_HCINTMSK_XFRCM USB_OTG_HCINTMSK_XFRCM_Msk
29705#define USB_OTG_HCINTMSK_CHHM_Pos (1U)
29706#define USB_OTG_HCINTMSK_CHHM_Msk (0x1UL << USB_OTG_HCINTMSK_CHHM_Pos)
29707#define USB_OTG_HCINTMSK_CHHM USB_OTG_HCINTMSK_CHHM_Msk
29708#define USB_OTG_HCINTMSK_AHBERR_Pos (2U)
29709#define USB_OTG_HCINTMSK_AHBERR_Msk (0x1UL << USB_OTG_HCINTMSK_AHBERR_Pos)
29710#define USB_OTG_HCINTMSK_AHBERR USB_OTG_HCINTMSK_AHBERR_Msk
29711#define USB_OTG_HCINTMSK_STALLM_Pos (3U)
29712#define USB_OTG_HCINTMSK_STALLM_Msk (0x1UL << USB_OTG_HCINTMSK_STALLM_Pos)
29713#define USB_OTG_HCINTMSK_STALLM USB_OTG_HCINTMSK_STALLM_Msk
29714#define USB_OTG_HCINTMSK_NAKM_Pos (4U)
29715#define USB_OTG_HCINTMSK_NAKM_Msk (0x1UL << USB_OTG_HCINTMSK_NAKM_Pos)
29716#define USB_OTG_HCINTMSK_NAKM USB_OTG_HCINTMSK_NAKM_Msk
29717#define USB_OTG_HCINTMSK_ACKM_Pos (5U)
29718#define USB_OTG_HCINTMSK_ACKM_Msk (0x1UL << USB_OTG_HCINTMSK_ACKM_Pos)
29719#define USB_OTG_HCINTMSK_ACKM USB_OTG_HCINTMSK_ACKM_Msk
29720#define USB_OTG_HCINTMSK_NYET_Pos (6U)
29721#define USB_OTG_HCINTMSK_NYET_Msk (0x1UL << USB_OTG_HCINTMSK_NYET_Pos)
29722#define USB_OTG_HCINTMSK_NYET USB_OTG_HCINTMSK_NYET_Msk
29723#define USB_OTG_HCINTMSK_TXERRM_Pos (7U)
29724#define USB_OTG_HCINTMSK_TXERRM_Msk (0x1UL << USB_OTG_HCINTMSK_TXERRM_Pos)
29725#define USB_OTG_HCINTMSK_TXERRM USB_OTG_HCINTMSK_TXERRM_Msk
29726#define USB_OTG_HCINTMSK_BBERRM_Pos (8U)
29727#define USB_OTG_HCINTMSK_BBERRM_Msk (0x1UL << USB_OTG_HCINTMSK_BBERRM_Pos)
29728#define USB_OTG_HCINTMSK_BBERRM USB_OTG_HCINTMSK_BBERRM_Msk
29729#define USB_OTG_HCINTMSK_FRMORM_Pos (9U)
29730#define USB_OTG_HCINTMSK_FRMORM_Msk (0x1UL << USB_OTG_HCINTMSK_FRMORM_Pos)
29731#define USB_OTG_HCINTMSK_FRMORM USB_OTG_HCINTMSK_FRMORM_Msk
29732#define USB_OTG_HCINTMSK_DTERRM_Pos (10U)
29733#define USB_OTG_HCINTMSK_DTERRM_Msk (0x1UL << USB_OTG_HCINTMSK_DTERRM_Pos)
29734#define USB_OTG_HCINTMSK_DTERRM USB_OTG_HCINTMSK_DTERRM_Msk
29736/******************** Bit definition for USB_OTG_DIEPTSIZ register ********************/
29737
29738#define USB_OTG_DIEPTSIZ_XFRSIZ_Pos (0U)
29739#define USB_OTG_DIEPTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_DIEPTSIZ_XFRSIZ_Pos)
29740#define USB_OTG_DIEPTSIZ_XFRSIZ USB_OTG_DIEPTSIZ_XFRSIZ_Msk
29741#define USB_OTG_DIEPTSIZ_PKTCNT_Pos (19U)
29742#define USB_OTG_DIEPTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_DIEPTSIZ_PKTCNT_Pos)
29743#define USB_OTG_DIEPTSIZ_PKTCNT USB_OTG_DIEPTSIZ_PKTCNT_Msk
29744#define USB_OTG_DIEPTSIZ_MULCNT_Pos (29U)
29745#define USB_OTG_DIEPTSIZ_MULCNT_Msk (0x3UL << USB_OTG_DIEPTSIZ_MULCNT_Pos)
29746#define USB_OTG_DIEPTSIZ_MULCNT USB_OTG_DIEPTSIZ_MULCNT_Msk
29747/******************** Bit definition forUSB_OTG_HCTSIZ register ********************/
29748#define USB_OTG_HCTSIZ_XFRSIZ_Pos (0U)
29749#define USB_OTG_HCTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_HCTSIZ_XFRSIZ_Pos)
29750#define USB_OTG_HCTSIZ_XFRSIZ USB_OTG_HCTSIZ_XFRSIZ_Msk
29751#define USB_OTG_HCTSIZ_PKTCNT_Pos (19U)
29752#define USB_OTG_HCTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_HCTSIZ_PKTCNT_Pos)
29753#define USB_OTG_HCTSIZ_PKTCNT USB_OTG_HCTSIZ_PKTCNT_Msk
29754#define USB_OTG_HCTSIZ_DOPING_Pos (31U)
29755#define USB_OTG_HCTSIZ_DOPING_Msk (0x1UL << USB_OTG_HCTSIZ_DOPING_Pos)
29756#define USB_OTG_HCTSIZ_DOPING USB_OTG_HCTSIZ_DOPING_Msk
29757#define USB_OTG_HCTSIZ_DPID_Pos (29U)
29758#define USB_OTG_HCTSIZ_DPID_Msk (0x3UL << USB_OTG_HCTSIZ_DPID_Pos)
29759#define USB_OTG_HCTSIZ_DPID USB_OTG_HCTSIZ_DPID_Msk
29760#define USB_OTG_HCTSIZ_DPID_0 (0x1UL << USB_OTG_HCTSIZ_DPID_Pos)
29761#define USB_OTG_HCTSIZ_DPID_1 (0x2UL << USB_OTG_HCTSIZ_DPID_Pos)
29763/******************** Bit definition forUSB_OTG_DIEPDMA register ********************/
29764#define USB_OTG_DIEPDMA_DMAADDR_Pos (0U)
29765#define USB_OTG_DIEPDMA_DMAADDR_Msk (0xFFFFFFFFUL << USB_OTG_DIEPDMA_DMAADDR_Pos)
29766#define USB_OTG_DIEPDMA_DMAADDR USB_OTG_DIEPDMA_DMAADDR_Msk
29768/******************** Bit definition forUSB_OTG_HCDMA register ********************/
29769#define USB_OTG_HCDMA_DMAADDR_Pos (0U)
29770#define USB_OTG_HCDMA_DMAADDR_Msk (0xFFFFFFFFUL << USB_OTG_HCDMA_DMAADDR_Pos)
29771#define USB_OTG_HCDMA_DMAADDR USB_OTG_HCDMA_DMAADDR_Msk
29773/******************** Bit definition forUSB_OTG_DTXFSTS register ********************/
29774#define USB_OTG_DTXFSTS_INEPTFSAV_Pos (0U)
29775#define USB_OTG_DTXFSTS_INEPTFSAV_Msk (0xFFFFUL << USB_OTG_DTXFSTS_INEPTFSAV_Pos)
29776#define USB_OTG_DTXFSTS_INEPTFSAV USB_OTG_DTXFSTS_INEPTFSAV_Msk
29778/******************** Bit definition forUSB_OTG_DIEPTXF register ********************/
29779#define USB_OTG_DIEPTXF_INEPTXSA_Pos (0U)
29780#define USB_OTG_DIEPTXF_INEPTXSA_Msk (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXSA_Pos)
29781#define USB_OTG_DIEPTXF_INEPTXSA USB_OTG_DIEPTXF_INEPTXSA_Msk
29782#define USB_OTG_DIEPTXF_INEPTXFD_Pos (16U)
29783#define USB_OTG_DIEPTXF_INEPTXFD_Msk (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXFD_Pos)
29784#define USB_OTG_DIEPTXF_INEPTXFD USB_OTG_DIEPTXF_INEPTXFD_Msk
29786/******************** Bit definition forUSB_OTG_DOEPCTL register ********************/
29787
29788#define USB_OTG_DOEPCTL_MPSIZ_Pos (0U)
29789#define USB_OTG_DOEPCTL_MPSIZ_Msk (0x7FFUL << USB_OTG_DOEPCTL_MPSIZ_Pos)
29790#define USB_OTG_DOEPCTL_MPSIZ USB_OTG_DOEPCTL_MPSIZ_Msk
29791#define USB_OTG_DOEPCTL_USBAEP_Pos (15U)
29792#define USB_OTG_DOEPCTL_USBAEP_Msk (0x1UL << USB_OTG_DOEPCTL_USBAEP_Pos)
29793#define USB_OTG_DOEPCTL_USBAEP USB_OTG_DOEPCTL_USBAEP_Msk
29794#define USB_OTG_DOEPCTL_NAKSTS_Pos (17U)
29795#define USB_OTG_DOEPCTL_NAKSTS_Msk (0x1UL << USB_OTG_DOEPCTL_NAKSTS_Pos)
29796#define USB_OTG_DOEPCTL_NAKSTS USB_OTG_DOEPCTL_NAKSTS_Msk
29797#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos (28U)
29798#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk (0x1UL << USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos)
29799#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk
29800#define USB_OTG_DOEPCTL_SODDFRM_Pos (29U)
29801#define USB_OTG_DOEPCTL_SODDFRM_Msk (0x1UL << USB_OTG_DOEPCTL_SODDFRM_Pos)
29802#define USB_OTG_DOEPCTL_SODDFRM USB_OTG_DOEPCTL_SODDFRM_Msk
29803#define USB_OTG_DOEPCTL_EPTYP_Pos (18U)
29804#define USB_OTG_DOEPCTL_EPTYP_Msk (0x3UL << USB_OTG_DOEPCTL_EPTYP_Pos)
29805#define USB_OTG_DOEPCTL_EPTYP USB_OTG_DOEPCTL_EPTYP_Msk
29806#define USB_OTG_DOEPCTL_EPTYP_0 (0x1UL << USB_OTG_DOEPCTL_EPTYP_Pos)
29807#define USB_OTG_DOEPCTL_EPTYP_1 (0x2UL << USB_OTG_DOEPCTL_EPTYP_Pos)
29808#define USB_OTG_DOEPCTL_SNPM_Pos (20U)
29809#define USB_OTG_DOEPCTL_SNPM_Msk (0x1UL << USB_OTG_DOEPCTL_SNPM_Pos)
29810#define USB_OTG_DOEPCTL_SNPM USB_OTG_DOEPCTL_SNPM_Msk
29811#define USB_OTG_DOEPCTL_STALL_Pos (21U)
29812#define USB_OTG_DOEPCTL_STALL_Msk (0x1UL << USB_OTG_DOEPCTL_STALL_Pos)
29813#define USB_OTG_DOEPCTL_STALL USB_OTG_DOEPCTL_STALL_Msk
29814#define USB_OTG_DOEPCTL_CNAK_Pos (26U)
29815#define USB_OTG_DOEPCTL_CNAK_Msk (0x1UL << USB_OTG_DOEPCTL_CNAK_Pos)
29816#define USB_OTG_DOEPCTL_CNAK USB_OTG_DOEPCTL_CNAK_Msk
29817#define USB_OTG_DOEPCTL_SNAK_Pos (27U)
29818#define USB_OTG_DOEPCTL_SNAK_Msk (0x1UL << USB_OTG_DOEPCTL_SNAK_Pos)
29819#define USB_OTG_DOEPCTL_SNAK USB_OTG_DOEPCTL_SNAK_Msk
29820#define USB_OTG_DOEPCTL_EPDIS_Pos (30U)
29821#define USB_OTG_DOEPCTL_EPDIS_Msk (0x1UL << USB_OTG_DOEPCTL_EPDIS_Pos)
29822#define USB_OTG_DOEPCTL_EPDIS USB_OTG_DOEPCTL_EPDIS_Msk
29823#define USB_OTG_DOEPCTL_EPENA_Pos (31U)
29824#define USB_OTG_DOEPCTL_EPENA_Msk (0x1UL << USB_OTG_DOEPCTL_EPENA_Pos)
29825#define USB_OTG_DOEPCTL_EPENA USB_OTG_DOEPCTL_EPENA_Msk
29827/******************** Bit definition forUSB_OTG_DOEPINT register ********************/
29828#define USB_OTG_DOEPINT_XFRC_Pos (0U)
29829#define USB_OTG_DOEPINT_XFRC_Msk (0x1UL << USB_OTG_DOEPINT_XFRC_Pos)
29830#define USB_OTG_DOEPINT_XFRC USB_OTG_DOEPINT_XFRC_Msk
29831#define USB_OTG_DOEPINT_EPDISD_Pos (1U)
29832#define USB_OTG_DOEPINT_EPDISD_Msk (0x1UL << USB_OTG_DOEPINT_EPDISD_Pos)
29833#define USB_OTG_DOEPINT_EPDISD USB_OTG_DOEPINT_EPDISD_Msk
29834#define USB_OTG_DOEPINT_AHBERR_Pos (2U)
29835#define USB_OTG_DOEPINT_AHBERR_Msk (0x1UL << USB_OTG_DOEPINT_AHBERR_Pos)
29836#define USB_OTG_DOEPINT_AHBERR USB_OTG_DOEPINT_AHBERR_Msk
29837#define USB_OTG_DOEPINT_STUP_Pos (3U)
29838#define USB_OTG_DOEPINT_STUP_Msk (0x1UL << USB_OTG_DOEPINT_STUP_Pos)
29839#define USB_OTG_DOEPINT_STUP USB_OTG_DOEPINT_STUP_Msk
29840#define USB_OTG_DOEPINT_OTEPDIS_Pos (4U)
29841#define USB_OTG_DOEPINT_OTEPDIS_Msk (0x1UL << USB_OTG_DOEPINT_OTEPDIS_Pos)
29842#define USB_OTG_DOEPINT_OTEPDIS USB_OTG_DOEPINT_OTEPDIS_Msk
29843#define USB_OTG_DOEPINT_OTEPSPR_Pos (5U)
29844#define USB_OTG_DOEPINT_OTEPSPR_Msk (0x1UL << USB_OTG_DOEPINT_OTEPSPR_Pos)
29845#define USB_OTG_DOEPINT_OTEPSPR USB_OTG_DOEPINT_OTEPSPR_Msk
29846#define USB_OTG_DOEPINT_B2BSTUP_Pos (6U)
29847#define USB_OTG_DOEPINT_B2BSTUP_Msk (0x1UL << USB_OTG_DOEPINT_B2BSTUP_Pos)
29848#define USB_OTG_DOEPINT_B2BSTUP USB_OTG_DOEPINT_B2BSTUP_Msk
29849#define USB_OTG_DOEPINT_OUTPKTERR_Pos (8U)
29850#define USB_OTG_DOEPINT_OUTPKTERR_Msk (0x1UL << USB_OTG_DOEPINT_OUTPKTERR_Pos)
29851#define USB_OTG_DOEPINT_OUTPKTERR USB_OTG_DOEPINT_OUTPKTERR_Msk
29852#define USB_OTG_DOEPINT_BERR_Pos (12U)
29853#define USB_OTG_DOEPINT_BERR_Msk (0x1UL << USB_OTG_DOEPINT_BERR_Pos)
29854#define USB_OTG_DOEPINT_BERR USB_OTG_DOEPINT_BERR_Msk
29855#define USB_OTG_DOEPINT_NAK_Pos (13U)
29856#define USB_OTG_DOEPINT_NAK_Msk (0x1UL << USB_OTG_DOEPINT_NAK_Pos)
29857#define USB_OTG_DOEPINT_NAK USB_OTG_DOEPINT_NAK_Msk
29858#define USB_OTG_DOEPINT_NYET_Pos (14U)
29859#define USB_OTG_DOEPINT_NYET_Msk (0x1UL << USB_OTG_DOEPINT_NYET_Pos)
29860#define USB_OTG_DOEPINT_NYET USB_OTG_DOEPINT_NYET_Msk
29861#define USB_OTG_DOEPINT_STPKTRX_Pos (15U)
29862#define USB_OTG_DOEPINT_STPKTRX_Msk (0x1UL << USB_OTG_DOEPINT_STPKTRX_Pos)
29863#define USB_OTG_DOEPINT_STPKTRX USB_OTG_DOEPINT_STPKTRX_Msk
29865/******************** Bit definition forUSB_OTG_DOEPTSIZ register ********************/
29866
29867#define USB_OTG_DOEPTSIZ_XFRSIZ_Pos (0U)
29868#define USB_OTG_DOEPTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_DOEPTSIZ_XFRSIZ_Pos)
29869#define USB_OTG_DOEPTSIZ_XFRSIZ USB_OTG_DOEPTSIZ_XFRSIZ_Msk
29870#define USB_OTG_DOEPTSIZ_PKTCNT_Pos (19U)
29871#define USB_OTG_DOEPTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_DOEPTSIZ_PKTCNT_Pos)
29872#define USB_OTG_DOEPTSIZ_PKTCNT USB_OTG_DOEPTSIZ_PKTCNT_Msk
29874#define USB_OTG_DOEPTSIZ_STUPCNT_Pos (29U)
29875#define USB_OTG_DOEPTSIZ_STUPCNT_Msk (0x3UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
29876#define USB_OTG_DOEPTSIZ_STUPCNT USB_OTG_DOEPTSIZ_STUPCNT_Msk
29877#define USB_OTG_DOEPTSIZ_STUPCNT_0 (0x1UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
29878#define USB_OTG_DOEPTSIZ_STUPCNT_1 (0x2UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
29880/******************** Bit definition for PCGCCTL register ********************/
29881#define USB_OTG_PCGCCTL_STOPCLK_Pos (0U)
29882#define USB_OTG_PCGCCTL_STOPCLK_Msk (0x1UL << USB_OTG_PCGCCTL_STOPCLK_Pos)
29883#define USB_OTG_PCGCCTL_STOPCLK USB_OTG_PCGCCTL_STOPCLK_Msk
29884#define USB_OTG_PCGCCTL_GATECLK_Pos (1U)
29885#define USB_OTG_PCGCCTL_GATECLK_Msk (0x1UL << USB_OTG_PCGCCTL_GATECLK_Pos)
29886#define USB_OTG_PCGCCTL_GATECLK USB_OTG_PCGCCTL_GATECLK_Msk
29887#define USB_OTG_PCGCCTL_PHYSUSP_Pos (4U)
29888#define USB_OTG_PCGCCTL_PHYSUSP_Msk (0x1UL << USB_OTG_PCGCCTL_PHYSUSP_Pos)
29889#define USB_OTG_PCGCCTL_PHYSUSP USB_OTG_PCGCCTL_PHYSUSP_Msk
29903/******************************* ADC Instances ********************************/
29904#define IS_ADC_ALL_INSTANCE(INSTANCE) (((INSTANCE) == ADC1) || \
29905 ((INSTANCE) == ADC2) || \
29906 ((INSTANCE) == ADC3))
29907
29908#define IS_ADC_MULTIMODE_MASTER_INSTANCE(INSTANCE) ((INSTANCE) == ADC1)
29909
29910#define IS_ADC_COMMON_INSTANCE(INSTANCE) (((INSTANCE) == ADC12_COMMON) ||\
29911 ((INSTANCE) == ADC3_COMMON))
29912
29913/******************************** COMP Instances ******************************/
29914#define IS_COMP_ALL_INSTANCE(INSTANCE) (((INSTANCE) == COMP1) || \
29915 ((INSTANCE) == COMP2))
29916
29917#define IS_COMP_COMMON_INSTANCE(INSTANCE) ((INSTANCE) == COMP12_COMMON)
29918/******************** COMP Instances with window mode capability **************/
29919#define IS_COMP_WINDOWMODE_INSTANCE(INSTANCE) ((INSTANCE) == COMP2)
29920
29921
29922/******************************* CRC Instances ********************************/
29923#define IS_CRC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == CRC)
29924
29925/******************************* DAC Instances ********************************/
29926#define IS_DAC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == DAC1)
29927/******************************* DCMI Instances *******************************/
29928#define IS_DCMI_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == DCMI)
29929
29930/******************************* DELAYBLOCK Instances *******************************/
29931#define IS_DLYB_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DLYB_SDMMC1) || \
29932 ((INSTANCE) == DLYB_SDMMC2) || \
29933 ((INSTANCE) == DLYB_QUADSPI))
29934/****************************** DFSDM Instances *******************************/
29935#define IS_DFSDM_FILTER_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DFSDM1_Filter0) || \
29936 ((INSTANCE) == DFSDM1_Filter1) || \
29937 ((INSTANCE) == DFSDM1_Filter2) || \
29938 ((INSTANCE) == DFSDM1_Filter3))
29939
29940#define IS_DFSDM_CHANNEL_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DFSDM1_Channel0) || \
29941 ((INSTANCE) == DFSDM1_Channel1) || \
29942 ((INSTANCE) == DFSDM1_Channel2) || \
29943 ((INSTANCE) == DFSDM1_Channel3) || \
29944 ((INSTANCE) == DFSDM1_Channel4) || \
29945 ((INSTANCE) == DFSDM1_Channel5) || \
29946 ((INSTANCE) == DFSDM1_Channel6) || \
29947 ((INSTANCE) == DFSDM1_Channel7))
29948/****************************** RAMECC Instances ******************************/
29949#define IS_RAMECC_MONITOR_ALL_INSTANCE(INSTANCE) (((INSTANCE) == RAMECC1_Monitor1) || \
29950 ((INSTANCE) == RAMECC1_Monitor2) || \
29951 ((INSTANCE) == RAMECC1_Monitor3) || \
29952 ((INSTANCE) == RAMECC1_Monitor4) || \
29953 ((INSTANCE) == RAMECC1_Monitor5) || \
29954 ((INSTANCE) == RAMECC2_Monitor1) || \
29955 ((INSTANCE) == RAMECC2_Monitor2) || \
29956 ((INSTANCE) == RAMECC2_Monitor3) || \
29957 ((INSTANCE) == RAMECC2_Monitor4) || \
29958 ((INSTANCE) == RAMECC2_Monitor5) || \
29959 ((INSTANCE) == RAMECC3_Monitor1) || \
29960 ((INSTANCE) == RAMECC3_Monitor2))
29961
29962/******************************** DMA Instances *******************************/
29963#define IS_DMA_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DMA1_Stream0) || \
29964 ((INSTANCE) == DMA1_Stream1) || \
29965 ((INSTANCE) == DMA1_Stream2) || \
29966 ((INSTANCE) == DMA1_Stream3) || \
29967 ((INSTANCE) == DMA1_Stream4) || \
29968 ((INSTANCE) == DMA1_Stream5) || \
29969 ((INSTANCE) == DMA1_Stream6) || \
29970 ((INSTANCE) == DMA1_Stream7) || \
29971 ((INSTANCE) == DMA2_Stream0) || \
29972 ((INSTANCE) == DMA2_Stream1) || \
29973 ((INSTANCE) == DMA2_Stream2) || \
29974 ((INSTANCE) == DMA2_Stream3) || \
29975 ((INSTANCE) == DMA2_Stream4) || \
29976 ((INSTANCE) == DMA2_Stream5) || \
29977 ((INSTANCE) == DMA2_Stream6) || \
29978 ((INSTANCE) == DMA2_Stream7) || \
29979 ((INSTANCE) == BDMA_Channel0) || \
29980 ((INSTANCE) == BDMA_Channel1) || \
29981 ((INSTANCE) == BDMA_Channel2) || \
29982 ((INSTANCE) == BDMA_Channel3) || \
29983 ((INSTANCE) == BDMA_Channel4) || \
29984 ((INSTANCE) == BDMA_Channel5) || \
29985 ((INSTANCE) == BDMA_Channel6) || \
29986 ((INSTANCE) == BDMA_Channel7))
29987
29988/****************************** BDMA CHANNEL Instances ***************************/
29989#define IS_BDMA_CHANNEL_INSTANCE(INSTANCE) (((INSTANCE) == BDMA_Channel0) || \
29990 ((INSTANCE) == BDMA_Channel1) || \
29991 ((INSTANCE) == BDMA_Channel2) || \
29992 ((INSTANCE) == BDMA_Channel3) || \
29993 ((INSTANCE) == BDMA_Channel4) || \
29994 ((INSTANCE) == BDMA_Channel5) || \
29995 ((INSTANCE) == BDMA_Channel6) || \
29996 ((INSTANCE) == BDMA_Channel7))
29997
29998/****************************** DMA DMAMUX ALL Instances ***************************/
29999#define IS_DMA_DMAMUX_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DMA1_Stream0) || \
30000 ((INSTANCE) == DMA1_Stream1) || \
30001 ((INSTANCE) == DMA1_Stream2) || \
30002 ((INSTANCE) == DMA1_Stream3) || \
30003 ((INSTANCE) == DMA1_Stream4) || \
30004 ((INSTANCE) == DMA1_Stream5) || \
30005 ((INSTANCE) == DMA1_Stream6) || \
30006 ((INSTANCE) == DMA1_Stream7) || \
30007 ((INSTANCE) == DMA2_Stream0) || \
30008 ((INSTANCE) == DMA2_Stream1) || \
30009 ((INSTANCE) == DMA2_Stream2) || \
30010 ((INSTANCE) == DMA2_Stream3) || \
30011 ((INSTANCE) == DMA2_Stream4) || \
30012 ((INSTANCE) == DMA2_Stream5) || \
30013 ((INSTANCE) == DMA2_Stream6) || \
30014 ((INSTANCE) == DMA2_Stream7) || \
30015 ((INSTANCE) == BDMA_Channel0) || \
30016 ((INSTANCE) == BDMA_Channel1) || \
30017 ((INSTANCE) == BDMA_Channel2) || \
30018 ((INSTANCE) == BDMA_Channel3) || \
30019 ((INSTANCE) == BDMA_Channel4) || \
30020 ((INSTANCE) == BDMA_Channel5) || \
30021 ((INSTANCE) == BDMA_Channel6) || \
30022 ((INSTANCE) == BDMA_Channel7))
30023
30024/****************************** BDMA DMAMUX Instances ***************************/
30025#define IS_BDMA_CHANNEL_DMAMUX_INSTANCE(INSTANCE) (((INSTANCE) == BDMA_Channel0) || \
30026 ((INSTANCE) == BDMA_Channel1) || \
30027 ((INSTANCE) == BDMA_Channel2) || \
30028 ((INSTANCE) == BDMA_Channel3) || \
30029 ((INSTANCE) == BDMA_Channel4) || \
30030 ((INSTANCE) == BDMA_Channel5) || \
30031 ((INSTANCE) == BDMA_Channel6) || \
30032 ((INSTANCE) == BDMA_Channel7))
30033
30034/****************************** DMA STREAM Instances ***************************/
30035#define IS_DMA_STREAM_INSTANCE(INSTANCE) (((INSTANCE) == DMA1_Stream0) || \
30036 ((INSTANCE) == DMA1_Stream1) || \
30037 ((INSTANCE) == DMA1_Stream2) || \
30038 ((INSTANCE) == DMA1_Stream3) || \
30039 ((INSTANCE) == DMA1_Stream4) || \
30040 ((INSTANCE) == DMA1_Stream5) || \
30041 ((INSTANCE) == DMA1_Stream6) || \
30042 ((INSTANCE) == DMA1_Stream7) || \
30043 ((INSTANCE) == DMA2_Stream0) || \
30044 ((INSTANCE) == DMA2_Stream1) || \
30045 ((INSTANCE) == DMA2_Stream2) || \
30046 ((INSTANCE) == DMA2_Stream3) || \
30047 ((INSTANCE) == DMA2_Stream4) || \
30048 ((INSTANCE) == DMA2_Stream5) || \
30049 ((INSTANCE) == DMA2_Stream6) || \
30050 ((INSTANCE) == DMA2_Stream7))
30051
30052/****************************** DMA DMAMUX Instances ***************************/
30053#define IS_DMA_STREAM_DMAMUX_INSTANCE(INSTANCE) (((INSTANCE) == DMA1_Stream0) || \
30054 ((INSTANCE) == DMA1_Stream1) || \
30055 ((INSTANCE) == DMA1_Stream2) || \
30056 ((INSTANCE) == DMA1_Stream3) || \
30057 ((INSTANCE) == DMA1_Stream4) || \
30058 ((INSTANCE) == DMA1_Stream5) || \
30059 ((INSTANCE) == DMA1_Stream6) || \
30060 ((INSTANCE) == DMA1_Stream7) || \
30061 ((INSTANCE) == DMA2_Stream0) || \
30062 ((INSTANCE) == DMA2_Stream1) || \
30063 ((INSTANCE) == DMA2_Stream2) || \
30064 ((INSTANCE) == DMA2_Stream3) || \
30065 ((INSTANCE) == DMA2_Stream4) || \
30066 ((INSTANCE) == DMA2_Stream5) || \
30067 ((INSTANCE) == DMA2_Stream6) || \
30068 ((INSTANCE) == DMA2_Stream7))
30069
30070/******************************** DMA Request Generator Instances **************/
30071#define IS_DMA_REQUEST_GEN_ALL_INSTANCE(INSTANCE) (((INSTANCE) == DMAMUX1_RequestGenerator0) || \
30072 ((INSTANCE) == DMAMUX1_RequestGenerator1) || \
30073 ((INSTANCE) == DMAMUX1_RequestGenerator2) || \
30074 ((INSTANCE) == DMAMUX1_RequestGenerator3) || \
30075 ((INSTANCE) == DMAMUX1_RequestGenerator4) || \
30076 ((INSTANCE) == DMAMUX1_RequestGenerator5) || \
30077 ((INSTANCE) == DMAMUX1_RequestGenerator6) || \
30078 ((INSTANCE) == DMAMUX1_RequestGenerator7) || \
30079 ((INSTANCE) == DMAMUX2_RequestGenerator0) || \
30080 ((INSTANCE) == DMAMUX2_RequestGenerator1) || \
30081 ((INSTANCE) == DMAMUX2_RequestGenerator2) || \
30082 ((INSTANCE) == DMAMUX2_RequestGenerator3) || \
30083 ((INSTANCE) == DMAMUX2_RequestGenerator4) || \
30084 ((INSTANCE) == DMAMUX2_RequestGenerator5) || \
30085 ((INSTANCE) == DMAMUX2_RequestGenerator6) || \
30086 ((INSTANCE) == DMAMUX2_RequestGenerator7))
30087
30088/******************************* DMA2D Instances *******************************/
30089#define IS_DMA2D_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == DMA2D)
30090
30091/******************************** MDMA Request Generator Instances **************/
30092#define IS_MDMA_STREAM_ALL_INSTANCE(INSTANCE) (((INSTANCE) == MDMA_Channel0) || \
30093 ((INSTANCE) == MDMA_Channel1) || \
30094 ((INSTANCE) == MDMA_Channel2) || \
30095 ((INSTANCE) == MDMA_Channel3) || \
30096 ((INSTANCE) == MDMA_Channel4) || \
30097 ((INSTANCE) == MDMA_Channel5) || \
30098 ((INSTANCE) == MDMA_Channel6) || \
30099 ((INSTANCE) == MDMA_Channel7) || \
30100 ((INSTANCE) == MDMA_Channel8) || \
30101 ((INSTANCE) == MDMA_Channel9) || \
30102 ((INSTANCE) == MDMA_Channel10) || \
30103 ((INSTANCE) == MDMA_Channel11) || \
30104 ((INSTANCE) == MDMA_Channel12) || \
30105 ((INSTANCE) == MDMA_Channel13) || \
30106 ((INSTANCE) == MDMA_Channel14) || \
30107 ((INSTANCE) == MDMA_Channel15))
30108
30109/******************************* QUADSPI Instances *******************************/
30110#define IS_QSPI_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == QUADSPI)
30111
30112/******************************* FDCAN Instances ******************************/
30113#define IS_FDCAN_ALL_INSTANCE(__INSTANCE__) (((__INSTANCE__) == FDCAN1) || \
30114 ((__INSTANCE__) == FDCAN2))
30115
30116#define IS_FDCAN_TT_INSTANCE(__INSTANCE__) ((__INSTANCE__) == FDCAN1)
30117
30118/******************************* GPIO Instances *******************************/
30119#define IS_GPIO_ALL_INSTANCE(INSTANCE) (((INSTANCE) == GPIOA) || \
30120 ((INSTANCE) == GPIOB) || \
30121 ((INSTANCE) == GPIOC) || \
30122 ((INSTANCE) == GPIOD) || \
30123 ((INSTANCE) == GPIOE) || \
30124 ((INSTANCE) == GPIOF) || \
30125 ((INSTANCE) == GPIOG) || \
30126 ((INSTANCE) == GPIOH) || \
30127 ((INSTANCE) == GPIOI) || \
30128 ((INSTANCE) == GPIOJ) || \
30129 ((INSTANCE) == GPIOK))
30130
30131/******************************* GPIO AF Instances ****************************/
30132#define IS_GPIO_AF_INSTANCE(INSTANCE) IS_GPIO_ALL_INSTANCE(INSTANCE)
30133
30134/**************************** GPIO Lock Instances *****************************/
30135/* On H7, all GPIO Bank support the Lock mechanism */
30136#define IS_GPIO_LOCK_INSTANCE(INSTANCE) IS_GPIO_ALL_INSTANCE(INSTANCE)
30137
30138/******************************** HSEM Instances *******************************/
30139#define IS_HSEM_ALL_INSTANCE(INSTANCE) ((INSTANCE) == HSEM)
30140/******************** Bit definition for HSEM_CR register *****************/
30141#define HSEM_CPU1_COREID (0x00000003U) /* Semaphore Core CM7 ID */
30142#define HSEM_CPU2_COREID (0x00000001U) /* Semaphore Core CM4 ID */
30143#define HSEM_CR_COREID_CPU1 (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos)
30144#define HSEM_CR_COREID_CPU2 (HSEM_CPU2_COREID << HSEM_CR_COREID_Pos)
30145#if defined(CORE_CM4)
30146#define HSEM_CR_COREID_CURRENT (HSEM_CPU2_COREID << HSEM_CR_COREID_Pos)
30147#else /* CORE_CM7 */
30148#define HSEM_CR_COREID_CURRENT (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos)
30149#endif /* CORE_CM4 */
30150
30151#define HSEM_SEMID_MIN (0U) /* HSEM ID Min*/
30152#define HSEM_SEMID_MAX (31U) /* HSEM ID Max */
30153
30154#define HSEM_PROCESSID_MIN (0U) /* HSEM Process ID Min */
30155#define HSEM_PROCESSID_MAX (255U) /* HSEM Process ID Max */
30156
30157#define HSEM_CLEAR_KEY_MIN (0U) /* HSEM clear Key Min value */
30158#define HSEM_CLEAR_KEY_MAX (0xFFFFU) /* HSEM clear Key Max value */
30159
30160/******************************** I2C Instances *******************************/
30161#define IS_I2C_ALL_INSTANCE(INSTANCE) (((INSTANCE) == I2C1) || \
30162 ((INSTANCE) == I2C2) || \
30163 ((INSTANCE) == I2C3) || \
30164 ((INSTANCE) == I2C4))
30165
30166/****************************** SMBUS Instances *******************************/
30167#define IS_SMBUS_ALL_INSTANCE(INSTANCE) (((INSTANCE) == I2C1) || \
30168 ((INSTANCE) == I2C2) || \
30169 ((INSTANCE) == I2C3) || \
30170 ((INSTANCE) == I2C4))
30171
30172/************** I2C Instances : wakeup capability from stop modes *************/
30173#define IS_I2C_WAKEUP_FROMSTOP_INSTANCE(INSTANCE) IS_I2C_ALL_INSTANCE(INSTANCE)
30174
30175/******************************** I2S Instances *******************************/
30176#define IS_I2S_ALL_INSTANCE(INSTANCE) (((INSTANCE) == SPI1) || \
30177 ((INSTANCE) == SPI2) || \
30178 ((INSTANCE) == SPI3))
30179
30180/****************************** LTDC Instances ********************************/
30181#define IS_LTDC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == LTDC)
30182
30183/******************************* RNG Instances ********************************/
30184#define IS_RNG_ALL_INSTANCE(INSTANCE) ((INSTANCE) == RNG)
30185
30186/****************************** RTC Instances *********************************/
30187#define IS_RTC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == RTC)
30188
30189/****************************** SDMMC Instances *********************************/
30190#define IS_SDMMC_ALL_INSTANCE(_INSTANCE_) (((_INSTANCE_) == SDMMC1) || \
30191 ((_INSTANCE_) == SDMMC2))
30192
30193/******************************** SPI Instances *******************************/
30194#define IS_SPI_ALL_INSTANCE(INSTANCE) (((INSTANCE) == SPI1) || \
30195 ((INSTANCE) == SPI2) || \
30196 ((INSTANCE) == SPI3) || \
30197 ((INSTANCE) == SPI4) || \
30198 ((INSTANCE) == SPI5) || \
30199 ((INSTANCE) == SPI6))
30200
30201#define IS_SPI_HIGHEND_INSTANCE(INSTANCE) (((INSTANCE) == SPI1) || \
30202 ((INSTANCE) == SPI2) || \
30203 ((INSTANCE) == SPI3))
30204
30205/******************************** SWPMI Instances *****************************/
30206#define IS_SWPMI_INSTANCE(INSTANCE) ((INSTANCE) == SWPMI1)
30207
30208/****************** LPTIM Instances : All supported instances *****************/
30209#define IS_LPTIM_INSTANCE(INSTANCE) (((INSTANCE) == LPTIM1) || \
30210 ((INSTANCE) == LPTIM2) || \
30211 ((INSTANCE) == LPTIM3) || \
30212 ((INSTANCE) == LPTIM4) || \
30213 ((INSTANCE) == LPTIM5))
30214
30215/****************** LPTIM Instances : supporting encoder interface **************/
30216#define IS_LPTIM_ENCODER_INTERFACE_INSTANCE(INSTANCE) (((INSTANCE) == LPTIM1) || \
30217 ((INSTANCE) == LPTIM2))
30218
30219/****************** TIM Instances : All supported instances *******************/
30220#define IS_TIM_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30221 ((INSTANCE) == TIM2) || \
30222 ((INSTANCE) == TIM3) || \
30223 ((INSTANCE) == TIM4) || \
30224 ((INSTANCE) == TIM5) || \
30225 ((INSTANCE) == TIM6) || \
30226 ((INSTANCE) == TIM7) || \
30227 ((INSTANCE) == TIM8) || \
30228 ((INSTANCE) == TIM12) || \
30229 ((INSTANCE) == TIM13) || \
30230 ((INSTANCE) == TIM14) || \
30231 ((INSTANCE) == TIM15) || \
30232 ((INSTANCE) == TIM16) || \
30233 ((INSTANCE) == TIM17))
30234
30235/************* TIM Instances : at least 1 capture/compare channel *************/
30236#define IS_TIM_CC1_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30237 ((INSTANCE) == TIM2) || \
30238 ((INSTANCE) == TIM3) || \
30239 ((INSTANCE) == TIM4) || \
30240 ((INSTANCE) == TIM5) || \
30241 ((INSTANCE) == TIM8) || \
30242 ((INSTANCE) == TIM12) || \
30243 ((INSTANCE) == TIM13) || \
30244 ((INSTANCE) == TIM14) || \
30245 ((INSTANCE) == TIM15) || \
30246 ((INSTANCE) == TIM16) || \
30247 ((INSTANCE) == TIM17))
30248
30249/************ TIM Instances : at least 2 capture/compare channels *************/
30250#define IS_TIM_CC2_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30251 ((INSTANCE) == TIM2) || \
30252 ((INSTANCE) == TIM3) || \
30253 ((INSTANCE) == TIM4) || \
30254 ((INSTANCE) == TIM5) || \
30255 ((INSTANCE) == TIM8) || \
30256 ((INSTANCE) == TIM12) || \
30257 ((INSTANCE) == TIM15))
30258
30259/************ TIM Instances : at least 3 capture/compare channels *************/
30260#define IS_TIM_CC3_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30261 ((INSTANCE) == TIM2) || \
30262 ((INSTANCE) == TIM3) || \
30263 ((INSTANCE) == TIM4) || \
30264 ((INSTANCE) == TIM5) || \
30265 ((INSTANCE) == TIM8))
30266
30267/************ TIM Instances : at least 4 capture/compare channels *************/
30268#define IS_TIM_CC4_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30269 ((INSTANCE) == TIM2) || \
30270 ((INSTANCE) == TIM3) || \
30271 ((INSTANCE) == TIM4) || \
30272 ((INSTANCE) == TIM5) || \
30273 ((INSTANCE) == TIM8))
30274
30275/************ TIM Instances : at least 5 capture/compare channels *************/
30276#define IS_TIM_CC5_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30277 ((INSTANCE) == TIM8))
30278/************ TIM Instances : at least 6 capture/compare channels *************/
30279#define IS_TIM_CC6_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30280 ((INSTANCE) == TIM8))
30281
30282/******************** TIM Instances : Advanced-control timers *****************/
30283#define IS_TIM_ADVANCED_INSTANCE(__INSTANCE__) (((__INSTANCE__) == TIM1) || \
30284 ((__INSTANCE__) == TIM8))
30285
30286/******************** TIM Instances : Advanced-control timers *****************/
30287
30288/******************* TIM Instances : Timer input XOR function *****************/
30289#define IS_TIM_XOR_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30290 ((INSTANCE) == TIM2) || \
30291 ((INSTANCE) == TIM3) || \
30292 ((INSTANCE) == TIM4) || \
30293 ((INSTANCE) == TIM5) || \
30294 ((INSTANCE) == TIM8) || \
30295 ((INSTANCE) == TIM15))
30296
30297/****************** TIM Instances : DMA requests generation (UDE) *************/
30298#define IS_TIM_DMA_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30299 ((INSTANCE) == TIM2) || \
30300 ((INSTANCE) == TIM3) || \
30301 ((INSTANCE) == TIM4) || \
30302 ((INSTANCE) == TIM5) || \
30303 ((INSTANCE) == TIM6) || \
30304 ((INSTANCE) == TIM7) || \
30305 ((INSTANCE) == TIM8) || \
30306 ((INSTANCE) == TIM15) || \
30307 ((INSTANCE) == TIM16) || \
30308 ((INSTANCE) == TIM17))
30309
30310/************ TIM Instances : DMA requests generation (CCxDE) *****************/
30311#define IS_TIM_DMA_CC_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30312 ((INSTANCE) == TIM2) || \
30313 ((INSTANCE) == TIM3) || \
30314 ((INSTANCE) == TIM4) || \
30315 ((INSTANCE) == TIM5) || \
30316 ((INSTANCE) == TIM8) || \
30317 ((INSTANCE) == TIM15) || \
30318 ((INSTANCE) == TIM16) || \
30319 ((INSTANCE) == TIM17))
30320
30321/************ TIM Instances : DMA requests generation (COMDE) *****************/
30322#define IS_TIM_CCDMA_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30323 ((INSTANCE) == TIM2) || \
30324 ((INSTANCE) == TIM3) || \
30325 ((INSTANCE) == TIM4) || \
30326 ((INSTANCE) == TIM5) || \
30327 ((INSTANCE) == TIM8) || \
30328 ((INSTANCE) == TIM15))
30329
30330/******************** TIM Instances : DMA burst feature ***********************/
30331#define IS_TIM_DMABURST_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30332 ((INSTANCE) == TIM2) || \
30333 ((INSTANCE) == TIM3) || \
30334 ((INSTANCE) == TIM4) || \
30335 ((INSTANCE) == TIM5) || \
30336 ((INSTANCE) == TIM8))
30337
30338/*************** TIM Instances : external trigger reamp input available *******/
30339#define IS_TIM_ETR_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30340 ((INSTANCE) == TIM2) || \
30341 ((INSTANCE) == TIM3) || \
30342 ((INSTANCE) == TIM4) || \
30343 ((INSTANCE) == TIM5) || \
30344 ((INSTANCE) == TIM8))
30345
30346/****************** TIM Instances : remapping capability **********************/
30347#define IS_TIM_REMAP_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30348 ((INSTANCE) == TIM2) || \
30349 ((INSTANCE) == TIM3) || \
30350 ((INSTANCE) == TIM5) || \
30351 ((INSTANCE) == TIM8) || \
30352 ((INSTANCE) == TIM16) || \
30353 ((INSTANCE) == TIM17))
30354
30355/*************** TIM Instances : external trigger reamp input available *******/
30356#define IS_TIM_ETRSEL_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30357 ((INSTANCE) == TIM2) || \
30358 ((INSTANCE) == TIM3) || \
30359 ((INSTANCE) == TIM5) || \
30360 ((INSTANCE) == TIM8))
30361
30362/****** TIM Instances : master mode available (TIMx_CR2.MMS available )********/
30363#define IS_TIM_MASTER_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30364 ((INSTANCE) == TIM2) || \
30365 ((INSTANCE) == TIM3) || \
30366 ((INSTANCE) == TIM4) || \
30367 ((INSTANCE) == TIM5) || \
30368 ((INSTANCE) == TIM6) || \
30369 ((INSTANCE) == TIM7) || \
30370 ((INSTANCE) == TIM8) || \
30371 ((INSTANCE) == TIM12) || \
30372 ((INSTANCE) == TIM15))
30373
30374/****** TIM Instances : Salve mode available (TIMx_SMCR.TS available )*********/
30375#define IS_TIM_SLAVE_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30376 ((INSTANCE) == TIM2) || \
30377 ((INSTANCE) == TIM3) || \
30378 ((INSTANCE) == TIM4) || \
30379 ((INSTANCE) == TIM5) || \
30380 ((INSTANCE) == TIM8) || \
30381 ((INSTANCE) == TIM12) || \
30382 ((INSTANCE) == TIM15))
30383
30384/****** TIM Instances : TRGO2 available (TIMx_CR2.MMS2 available )*********/
30385#define IS_TIM_TRGO2_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30386 ((INSTANCE) == TIM8))
30387
30388/****** TIM Instances : TISEL available (TIMx_TISEL available )*********/
30389#define IS_TIM_TISEL_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30390 ((INSTANCE) == TIM2) || \
30391 ((INSTANCE) == TIM3) || \
30392 ((INSTANCE) == TIM4) || \
30393 ((INSTANCE) == TIM5) || \
30394 ((INSTANCE) == TIM8) || \
30395 ((INSTANCE) == TIM15) || \
30396 ((INSTANCE) == TIM16) || \
30397 ((INSTANCE) == TIM17))
30398
30399/****************** TIM Instances : supporting commutation event *************/
30400#define IS_TIM_COMMUTATION_EVENT_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30401 ((INSTANCE) == TIM8) || \
30402 ((INSTANCE) == TIM15) || \
30403 ((INSTANCE) == TIM16) || \
30404 ((INSTANCE) == TIM17))
30405
30406/****************** TIM Instances : supporting encoder interface **************/
30407#define IS_TIM_ENCODER_INTERFACE_INSTANCE(__INSTANCE__) (((__INSTANCE__) == TIM1) || \
30408 ((__INSTANCE__) == TIM2) || \
30409 ((__INSTANCE__) == TIM3) || \
30410 ((__INSTANCE__) == TIM4) || \
30411 ((__INSTANCE__) == TIM5) || \
30412 ((__INSTANCE__) == TIM8))
30413
30414/****** TIM Instances : TIM_CCR5_GC5C available (TIMx_CCR5.GC5C available )*********/
30415#define IS_TIM_COMBINED3PHASEPWM_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30416 ((INSTANCE) == TIM8))
30417/******************* TIM Instances : output(s) available **********************/
30418#define IS_TIM_CCX_INSTANCE(INSTANCE, CHANNEL) \
30419 ((((INSTANCE) == TIM1) && \
30420 (((CHANNEL) == TIM_CHANNEL_1) || \
30421 ((CHANNEL) == TIM_CHANNEL_2) || \
30422 ((CHANNEL) == TIM_CHANNEL_3) || \
30423 ((CHANNEL) == TIM_CHANNEL_4) || \
30424 ((CHANNEL) == TIM_CHANNEL_5) || \
30425 ((CHANNEL) == TIM_CHANNEL_6))) \
30426 || \
30427 (((INSTANCE) == TIM2) && \
30428 (((CHANNEL) == TIM_CHANNEL_1) || \
30429 ((CHANNEL) == TIM_CHANNEL_2) || \
30430 ((CHANNEL) == TIM_CHANNEL_3) || \
30431 ((CHANNEL) == TIM_CHANNEL_4))) \
30432 || \
30433 (((INSTANCE) == TIM3) && \
30434 (((CHANNEL) == TIM_CHANNEL_1)|| \
30435 ((CHANNEL) == TIM_CHANNEL_2) || \
30436 ((CHANNEL) == TIM_CHANNEL_3) || \
30437 ((CHANNEL) == TIM_CHANNEL_4))) \
30438 || \
30439 (((INSTANCE) == TIM4) && \
30440 (((CHANNEL) == TIM_CHANNEL_1) || \
30441 ((CHANNEL) == TIM_CHANNEL_2) || \
30442 ((CHANNEL) == TIM_CHANNEL_3) || \
30443 ((CHANNEL) == TIM_CHANNEL_4))) \
30444 || \
30445 (((INSTANCE) == TIM5) && \
30446 (((CHANNEL) == TIM_CHANNEL_1) || \
30447 ((CHANNEL) == TIM_CHANNEL_2) || \
30448 ((CHANNEL) == TIM_CHANNEL_3) || \
30449 ((CHANNEL) == TIM_CHANNEL_4))) \
30450 || \
30451 (((INSTANCE) == TIM8) && \
30452 (((CHANNEL) == TIM_CHANNEL_1) || \
30453 ((CHANNEL) == TIM_CHANNEL_2) || \
30454 ((CHANNEL) == TIM_CHANNEL_3) || \
30455 ((CHANNEL) == TIM_CHANNEL_4) || \
30456 ((CHANNEL) == TIM_CHANNEL_5) || \
30457 ((CHANNEL) == TIM_CHANNEL_6))) \
30458 || \
30459 (((INSTANCE) == TIM12) && \
30460 (((CHANNEL) == TIM_CHANNEL_1) || \
30461 ((CHANNEL) == TIM_CHANNEL_2))) \
30462 || \
30463 (((INSTANCE) == TIM13) && \
30464 (((CHANNEL) == TIM_CHANNEL_1))) \
30465 || \
30466 (((INSTANCE) == TIM14) && \
30467 (((CHANNEL) == TIM_CHANNEL_1))) \
30468 || \
30469 (((INSTANCE) == TIM15) && \
30470 (((CHANNEL) == TIM_CHANNEL_1) || \
30471 ((CHANNEL) == TIM_CHANNEL_2))) \
30472 || \
30473 (((INSTANCE) == TIM16) && \
30474 (((CHANNEL) == TIM_CHANNEL_1))) \
30475 || \
30476 (((INSTANCE) == TIM17) && \
30477 (((CHANNEL) == TIM_CHANNEL_1))))
30478
30479/****************** TIM Instances : supporting the break function *************/
30480#define IS_TIM_BREAK_INSTANCE(INSTANCE)\
30481 (((INSTANCE) == TIM1) || \
30482 ((INSTANCE) == TIM8) || \
30483 ((INSTANCE) == TIM15) || \
30484 ((INSTANCE) == TIM16) || \
30485 ((INSTANCE) == TIM17))
30486
30487/************** TIM Instances : supporting Break source selection *************/
30488#define IS_TIM_BREAKSOURCE_INSTANCE(INSTANCE) (((INSTANCE) == TIM1) || \
30489 ((INSTANCE) == TIM8))
30490
30491/****************** TIM Instances : supporting complementary output(s) ********/
30492#define IS_TIM_CCXN_INSTANCE(INSTANCE, CHANNEL) \
30493 ((((INSTANCE) == TIM1) && \
30494 (((CHANNEL) == TIM_CHANNEL_1) || \
30495 ((CHANNEL) == TIM_CHANNEL_2) || \
30496 ((CHANNEL) == TIM_CHANNEL_3))) \
30497 || \
30498 (((INSTANCE) == TIM8) && \
30499 (((CHANNEL) == TIM_CHANNEL_1) || \
30500 ((CHANNEL) == TIM_CHANNEL_2) || \
30501 ((CHANNEL) == TIM_CHANNEL_3))) \
30502 || \
30503 (((INSTANCE) == TIM15) && \
30504 ((CHANNEL) == TIM_CHANNEL_1)) \
30505 || \
30506 (((INSTANCE) == TIM16) && \
30507 ((CHANNEL) == TIM_CHANNEL_1)) \
30508 || \
30509 (((INSTANCE) == TIM17) && \
30510 ((CHANNEL) == TIM_CHANNEL_1)))
30511
30512/****************** TIM Instances : supporting counting mode selection ********/
30513#define IS_TIM_COUNTER_MODE_SELECT_INSTANCE(INSTANCE)\
30514 (((INSTANCE) == TIM1) || \
30515 ((INSTANCE) == TIM2) || \
30516 ((INSTANCE) == TIM3) || \
30517 ((INSTANCE) == TIM4) || \
30518 ((INSTANCE) == TIM5) || \
30519 ((INSTANCE) == TIM8))
30520
30521/****************** TIM Instances : supporting repetition counter *************/
30522#define IS_TIM_REPETITION_COUNTER_INSTANCE(INSTANCE)\
30523 (((INSTANCE) == TIM1) || \
30524 ((INSTANCE) == TIM8) || \
30525 ((INSTANCE) == TIM15) || \
30526 ((INSTANCE) == TIM16) || \
30527 ((INSTANCE) == TIM17))
30528
30529/****************** TIM Instances : supporting synchronization ****************/
30530#define IS_TIM_SYNCHRO_INSTANCE(__INSTANCE__)\
30531 (((__INSTANCE__) == TIM1) || \
30532 ((__INSTANCE__) == TIM2) || \
30533 ((__INSTANCE__) == TIM3) || \
30534 ((__INSTANCE__) == TIM4) || \
30535 ((__INSTANCE__) == TIM5) || \
30536 ((__INSTANCE__) == TIM6) || \
30537 ((__INSTANCE__) == TIM8) || \
30538 ((__INSTANCE__) == TIM12) || \
30539 ((__INSTANCE__) == TIM15))
30540
30541/****************** TIM Instances : supporting clock division *****************/
30542#define IS_TIM_CLOCK_DIVISION_INSTANCE(INSTANCE)\
30543 (((INSTANCE) == TIM1) || \
30544 ((INSTANCE) == TIM2) || \
30545 ((INSTANCE) == TIM3) || \
30546 ((INSTANCE) == TIM4) || \
30547 ((INSTANCE) == TIM5) || \
30548 ((INSTANCE) == TIM8) || \
30549 ((INSTANCE) == TIM15) || \
30550 ((INSTANCE) == TIM16) || \
30551 ((INSTANCE) == TIM17))
30552
30553/****************** TIM Instances : supporting external clock mode 1 for ETRF input */
30554#define IS_TIM_CLOCKSOURCE_ETRMODE1_INSTANCE(INSTANCE)\
30555 (((INSTANCE) == TIM1) || \
30556 ((INSTANCE) == TIM2) || \
30557 ((INSTANCE) == TIM3) || \
30558 ((INSTANCE) == TIM4) || \
30559 ((INSTANCE) == TIM5) || \
30560 ((INSTANCE) == TIM8))
30561
30562/****************** TIM Instances : supporting external clock mode 2 **********/
30563#define IS_TIM_CLOCKSOURCE_ETRMODE2_INSTANCE(INSTANCE)\
30564 (((INSTANCE) == TIM1) || \
30565 ((INSTANCE) == TIM2) || \
30566 ((INSTANCE) == TIM3) || \
30567 ((INSTANCE) == TIM4) || \
30568 ((INSTANCE) == TIM5) || \
30569 ((INSTANCE) == TIM8))
30570
30571/****************** TIM Instances : supporting external clock mode 1 for TIX inputs*/
30572#define IS_TIM_CLOCKSOURCE_TIX_INSTANCE(INSTANCE)\
30573 (((INSTANCE) == TIM1) || \
30574 ((INSTANCE) == TIM2) || \
30575 ((INSTANCE) == TIM3) || \
30576 ((INSTANCE) == TIM4) || \
30577 ((INSTANCE) == TIM5) || \
30578 ((INSTANCE) == TIM8) || \
30579 ((INSTANCE) == TIM12) || \
30580 ((INSTANCE) == TIM15))
30581
30582/****************** TIM Instances : supporting internal trigger inputs(ITRX) *******/
30583#define IS_TIM_CLOCKSOURCE_ITRX_INSTANCE(INSTANCE)\
30584 (((INSTANCE) == TIM1) || \
30585 ((INSTANCE) == TIM2) || \
30586 ((INSTANCE) == TIM3) || \
30587 ((INSTANCE) == TIM4) || \
30588 ((INSTANCE) == TIM5) || \
30589 ((INSTANCE) == TIM8) || \
30590 ((INSTANCE) == TIM12) || \
30591 ((INSTANCE) == TIM15))
30592
30593/****************** TIM Instances : supporting OCxREF clear *******************/
30594#define IS_TIM_OCXREF_CLEAR_INSTANCE(INSTANCE)\
30595 (((INSTANCE) == TIM1) || \
30596 ((INSTANCE) == TIM2) || \
30597 ((INSTANCE) == TIM3))
30598
30599/****************** TIM Instances : TIM_32B_COUNTER ***************************/
30600#define IS_TIM_32B_COUNTER_INSTANCE(INSTANCE)\
30601 (((INSTANCE) == TIM2) || \
30602 ((INSTANCE) == TIM5))
30603
30604/****************** TIM Instances : TIM_BKIN2 ***************************/
30605#define IS_TIM_BKIN2_INSTANCE(INSTANCE)\
30606 (((INSTANCE) == TIM1) || \
30607 ((INSTANCE) == TIM8))
30608
30609/****************** TIM Instances : supporting Hall sensor interface **********/
30610#define IS_TIM_HALL_SENSOR_INTERFACE_INSTANCE(__INSTANCE__) (((__INSTANCE__) == TIM1) || \
30611 ((__INSTANCE__) == TIM2) || \
30612 ((__INSTANCE__) == TIM3) || \
30613 ((__INSTANCE__) == TIM4) || \
30614 ((__INSTANCE__) == TIM5) || \
30615 ((__INSTANCE__) == TIM15) || \
30616 ((__INSTANCE__) == TIM8))
30617
30618/****************************** HRTIM Instances *******************************/
30619#define IS_HRTIM_ALL_INSTANCE(INSTANCE) (((INSTANCE) == HRTIM1))
30620
30621/******************** USART Instances : Synchronous mode **********************/
30622#define IS_USART_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30623 ((INSTANCE) == USART2) || \
30624 ((INSTANCE) == USART3) || \
30625 ((INSTANCE) == USART6))
30626
30627/******************** USART Instances : SPI slave mode ************************/
30628#define IS_UART_SPI_SLAVE_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30629 ((INSTANCE) == USART2) || \
30630 ((INSTANCE) == USART3) || \
30631 ((INSTANCE) == USART6))
30632
30633/******************** UART Instances : Asynchronous mode **********************/
30634#define IS_UART_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30635 ((INSTANCE) == USART2) || \
30636 ((INSTANCE) == USART3) || \
30637 ((INSTANCE) == UART4) || \
30638 ((INSTANCE) == UART5) || \
30639 ((INSTANCE) == USART6) || \
30640 ((INSTANCE) == UART7) || \
30641 ((INSTANCE) == UART8))
30642
30643/******************** UART Instances : FIFO mode.******************************/
30644#define IS_UART_FIFO_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30645 ((INSTANCE) == USART2) || \
30646 ((INSTANCE) == USART3) || \
30647 ((INSTANCE) == UART4) || \
30648 ((INSTANCE) == UART5) || \
30649 ((INSTANCE) == USART6) || \
30650 ((INSTANCE) == UART7) || \
30651 ((INSTANCE) == UART8))
30652
30653/****************** UART Instances : Auto Baud Rate detection *****************/
30654#define IS_USART_AUTOBAUDRATE_DETECTION_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30655 ((INSTANCE) == USART2) || \
30656 ((INSTANCE) == USART3) || \
30657 ((INSTANCE) == UART4) || \
30658 ((INSTANCE) == UART5) || \
30659 ((INSTANCE) == USART6) || \
30660 ((INSTANCE) == UART7) || \
30661 ((INSTANCE) == UART8))
30662
30663/*********************** UART Instances : Driver Enable ***********************/
30664#define IS_UART_DRIVER_ENABLE_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30665 ((INSTANCE) == USART2) || \
30666 ((INSTANCE) == USART3) || \
30667 ((INSTANCE) == UART4) || \
30668 ((INSTANCE) == UART5) || \
30669 ((INSTANCE) == USART6) || \
30670 ((INSTANCE) == UART7) || \
30671 ((INSTANCE) == UART8) || \
30672 ((INSTANCE) == LPUART1))
30673
30674/********************* UART Instances : Half-Duplex mode **********************/
30675#define IS_UART_HALFDUPLEX_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30676 ((INSTANCE) == USART2) || \
30677 ((INSTANCE) == USART3) || \
30678 ((INSTANCE) == UART4) || \
30679 ((INSTANCE) == UART5) || \
30680 ((INSTANCE) == USART6) || \
30681 ((INSTANCE) == UART7) || \
30682 ((INSTANCE) == UART8) || \
30683 ((INSTANCE) == LPUART1))
30684
30685/******************* UART Instances : Hardware Flow control *******************/
30686#define IS_UART_HWFLOW_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30687 ((INSTANCE) == USART2) || \
30688 ((INSTANCE) == USART3) || \
30689 ((INSTANCE) == UART4) || \
30690 ((INSTANCE) == UART5) || \
30691 ((INSTANCE) == USART6) || \
30692 ((INSTANCE) == UART7) || \
30693 ((INSTANCE) == UART8) || \
30694 ((INSTANCE) == LPUART1))
30695
30696/************************* UART Instances : LIN mode **************************/
30697#define IS_UART_LIN_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30698 ((INSTANCE) == USART2) || \
30699 ((INSTANCE) == USART3) || \
30700 ((INSTANCE) == UART4) || \
30701 ((INSTANCE) == UART5) || \
30702 ((INSTANCE) == USART6) || \
30703 ((INSTANCE) == UART7) || \
30704 ((INSTANCE) == UART8))
30705
30706/****************** UART Instances : Wake-up from Stop mode *******************/
30707#define IS_UART_WAKEUP_FROMSTOP_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30708 ((INSTANCE) == USART2) || \
30709 ((INSTANCE) == USART3) || \
30710 ((INSTANCE) == UART4) || \
30711 ((INSTANCE) == UART5) || \
30712 ((INSTANCE) == USART6) || \
30713 ((INSTANCE) == UART7) || \
30714 ((INSTANCE) == UART8) || \
30715 ((INSTANCE) == LPUART1))
30716
30717/************************* UART Instances : IRDA mode *************************/
30718#define IS_IRDA_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30719 ((INSTANCE) == USART2) || \
30720 ((INSTANCE) == USART3) || \
30721 ((INSTANCE) == UART4) || \
30722 ((INSTANCE) == UART5) || \
30723 ((INSTANCE) == USART6) || \
30724 ((INSTANCE) == UART7) || \
30725 ((INSTANCE) == UART8))
30726
30727/********************* USART Instances : Smard card mode **********************/
30728#define IS_SMARTCARD_INSTANCE(INSTANCE) (((INSTANCE) == USART1) || \
30729 ((INSTANCE) == USART2) || \
30730 ((INSTANCE) == USART3) || \
30731 ((INSTANCE) == USART6))
30732
30733/****************************** LPUART Instance *******************************/
30734#define IS_LPUART_INSTANCE(INSTANCE) ((INSTANCE) == LPUART1)
30735
30736/****************************** IWDG Instances ********************************/
30737#define IS_IWDG_ALL_INSTANCE(INSTANCE) (((INSTANCE) == IWDG1) || ((INSTANCE) == IWDG2))
30738/****************************** USB Instances ********************************/
30739#define IS_USB_ALL_INSTANCE(INSTANCE) ((INSTANCE) == USB)
30740
30741/****************************** WWDG Instances ********************************/
30742#define IS_WWDG_ALL_INSTANCE(INSTANCE) (((INSTANCE) == WWDG1) || \
30743 ((INSTANCE) == WWDG2))
30744/****************************** MDIOS Instances ********************************/
30745#define IS_MDIOS_ALL_INSTANCE(INSTANCE) ((INSTANCE) == MDIOS)
30746
30747/****************************** CEC Instances *********************************/
30748#define IS_CEC_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == CEC)
30749
30750/****************************** SAI Instances ********************************/
30751#define IS_SAI_ALL_INSTANCE(INSTANCE) (((INSTANCE) == SAI1_Block_A) || \
30752 ((INSTANCE) == SAI1_Block_B) || \
30753 ((INSTANCE) == SAI2_Block_A) || \
30754 ((INSTANCE) == SAI2_Block_B) || \
30755 ((INSTANCE) == SAI3_Block_A) || \
30756 ((INSTANCE) == SAI3_Block_B) || \
30757 ((INSTANCE) == SAI4_Block_A) || \
30758 ((INSTANCE) == SAI4_Block_B))
30759
30760/****************************** SPDIFRX Instances ********************************/
30761#define IS_SPDIFRX_ALL_INSTANCE(INSTANCE) ((INSTANCE) == SPDIFRX)
30762
30763/****************************** OPAMP Instances *******************************/
30764#define IS_OPAMP_ALL_INSTANCE(INSTANCE) (((INSTANCE) == OPAMP1) || \
30765 ((INSTANCE) == OPAMP2))
30766
30767#define IS_OPAMP_COMMON_INSTANCE(COMMON_INSTANCE) ((COMMON_INSTANCE) == OPAMP12_COMMON)
30768
30769/*********************** USB OTG PCD Instances ********************************/
30770#define IS_PCD_ALL_INSTANCE(INSTANCE) (((INSTANCE) == USB_OTG_FS) || \
30771 ((INSTANCE) == USB_OTG_HS))
30772
30773/*********************** USB OTG HCD Instances ********************************/
30774#define IS_HCD_ALL_INSTANCE(INSTANCE) (((INSTANCE) == USB_OTG_FS) || \
30775 ((INSTANCE) == USB_OTG_HS))
30776
30777/******************************************************************************/
30778/* For a painless codes migration between the STM32H7xx device product */
30779/* lines, or with STM32F7xx devices the aliases defined below are put */
30780/* in place to overcome the differences in the interrupt handlers and IRQn */
30781/* definitions. No need to update developed interrupt code when moving */
30782/* across product lines within the same STM32H7 Family */
30783/******************************************************************************/
30784
30785/* Aliases for __IRQn */
30786#define RNG_IRQn HASH_RNG_IRQn
30787#define TIM1_BRK_TIM9_IRQn TIM1_BRK_IRQn
30788#define TIM1_UP_TIM10_IRQn TIM1_UP_IRQn
30789#define TIM1_TRG_COM_TIM11_IRQn TIM1_TRG_COM_IRQn
30790#define PVD_IRQn PVD_AVD_IRQn
30791
30792
30793
30794/* Aliases for __IRQHandler */
30795#define RNG_IRQHandler HASH_RNG_IRQHandler
30796#define TIM1_BRK_TIM9_IRQHandler TIM1_BRK_IRQHandler
30797#define TIM1_UP_TIM9_IRQHandler TIM1_UP_IRQHandler
30798#define TIM1_TRG_COM_TIM11_IRQHandler TIM1_TRG_COM_IRQHandler
30799#define PVD_IRQHandler PVD_AVD_IRQHandler
30800
30801/* Aliases for COMP __IRQHandler */
30802#define COMP_IRQHandler COMP1_IRQHandler
30803
30816#ifdef __cplusplus
30817}
30818#endif /* __cplusplus */
30819
30820#endif /* STM32H757xx_H */
30821
CMSIS Cortex-M4 Core Peripheral Access Layer Header File.
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
CMSIS Cortex-M7 Core Peripheral Access Layer Header File.
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition: stm32h757xx.h:49
@ CRS_IRQn
Definition: stm32h757xx.h:202
@ PendSV_IRQn
Definition: stm32h757xx.h:58
@ ETH_WKUP_IRQn
Definition: stm32h757xx.h:122
@ EXTI2_IRQn
Definition: stm32h757xx.h:69
@ MDIOS_IRQn
Definition: stm32h757xx.h:178
@ DMA1_Stream2_IRQn
Definition: stm32h757xx.h:74
@ HRTIM1_TIMB_IRQn
Definition: stm32h757xx.h:163
@ BDMA_Channel7_IRQn
Definition: stm32h757xx.h:194
@ RTC_WKUP_IRQn
Definition: stm32h757xx.h:64
@ SPDIF_RX_IRQn
Definition: stm32h757xx.h:155
@ OTG_HS_EP1_IN_IRQn
Definition: stm32h757xx.h:133
@ HRTIM1_Master_IRQn
Definition: stm32h757xx.h:161
@ DMA2_Stream0_IRQn
Definition: stm32h757xx.h:116
@ BDMA_Channel3_IRQn
Definition: stm32h757xx.h:190
@ DMA2_Stream6_IRQn
Definition: stm32h757xx.h:127
@ LPTIM3_IRQn
Definition: stm32h757xx.h:197
@ LPTIM4_IRQn
Definition: stm32h757xx.h:198
@ TIM15_IRQn
Definition: stm32h757xx.h:174
@ BDMA_Channel1_IRQn
Definition: stm32h757xx.h:188
@ OTG_FS_EP1_IN_IRQn
Definition: stm32h757xx.h:157
@ UART7_IRQn
Definition: stm32h757xx.h:140
@ I2C1_ER_IRQn
Definition: stm32h757xx.h:93
@ I2C2_EV_IRQn
Definition: stm32h757xx.h:94
@ MemoryManagement_IRQn
Definition: stm32h757xx.h:53
@ TIM17_IRQn
Definition: stm32h757xx.h:176
@ SAI1_IRQn
Definition: stm32h757xx.h:145
@ TIM4_IRQn
Definition: stm32h757xx.h:91
@ TIM2_IRQn
Definition: stm32h757xx.h:89
@ LTDC_ER_IRQn
Definition: stm32h757xx.h:147
@ DMA2_Stream7_IRQn
Definition: stm32h757xx.h:128
@ TIM8_BRK_TIM12_IRQn
Definition: stm32h757xx.h:103
@ FDCAN1_IT0_IRQn
Definition: stm32h757xx.h:80
@ USART2_IRQn
Definition: stm32h757xx.h:99
@ DMA2_Stream3_IRQn
Definition: stm32h757xx.h:119
@ HOLD_CORE_IRQn
Definition: stm32h757xx.h:205
@ HRTIM1_FLT_IRQn
Definition: stm32h757xx.h:167
@ BDMA_Channel4_IRQn
Definition: stm32h757xx.h:191
@ SVCall_IRQn
Definition: stm32h757xx.h:56
@ ADC_IRQn
Definition: stm32h757xx.h:79
@ SPI3_IRQn
Definition: stm32h757xx.h:111
@ SPI2_IRQn
Definition: stm32h757xx.h:97
@ TIM1_BRK_IRQn
Definition: stm32h757xx.h:85
@ TIM7_IRQn
Definition: stm32h757xx.h:115
@ UART8_IRQn
Definition: stm32h757xx.h:141
@ FDCAN2_IT0_IRQn
Definition: stm32h757xx.h:81
@ RCC_IRQn
Definition: stm32h757xx.h:66
@ ADC3_IRQn
Definition: stm32h757xx.h:185
@ LPTIM2_IRQn
Definition: stm32h757xx.h:196
@ TIM6_DAC_IRQn
Definition: stm32h757xx.h:114
@ OTG_HS_EP1_OUT_IRQn
Definition: stm32h757xx.h:132
@ I2C2_ER_IRQn
Definition: stm32h757xx.h:95
@ QUADSPI_IRQn
Definition: stm32h757xx.h:150
@ DFSDM1_FLT0_IRQn
Definition: stm32h757xx.h:168
@ TIM8_CC_IRQn
Definition: stm32h757xx.h:106
@ JPEG_IRQn
Definition: stm32h757xx.h:179
@ UsageFault_IRQn
Definition: stm32h757xx.h:55
@ DMAMUX2_OVR_IRQn
Definition: stm32h757xx.h:186
@ I2C4_ER_IRQn
Definition: stm32h757xx.h:154
@ SysTick_IRQn
Definition: stm32h757xx.h:59
@ I2C3_ER_IRQn
Definition: stm32h757xx.h:131
@ SAI4_IRQn
Definition: stm32h757xx.h:204
@ CRYP_IRQn
Definition: stm32h757xx.h:137
@ DFSDM1_FLT3_IRQn
Definition: stm32h757xx.h:171
@ TIM1_UP_IRQn
Definition: stm32h757xx.h:86
@ I2C3_EV_IRQn
Definition: stm32h757xx.h:130
@ BusFault_IRQn
Definition: stm32h757xx.h:54
@ HASH_RNG_IRQn
Definition: stm32h757xx.h:138
@ DMAMUX1_OVR_IRQn
Definition: stm32h757xx.h:160
@ CEC_IRQn
Definition: stm32h757xx.h:152
@ LPTIM5_IRQn
Definition: stm32h757xx.h:199
@ SPI5_IRQn
Definition: stm32h757xx.h:143
@ DebugMonitor_IRQn
Definition: stm32h757xx.h:57
@ FLASH_IRQn
Definition: stm32h757xx.h:65
@ SWPMI1_IRQn
Definition: stm32h757xx.h:173
@ DMA2_Stream5_IRQn
Definition: stm32h757xx.h:126
@ WWDG_IRQn
Definition: stm32h757xx.h:61
@ HRTIM1_TIMA_IRQn
Definition: stm32h757xx.h:162
@ I2C1_EV_IRQn
Definition: stm32h757xx.h:92
@ TIM3_IRQn
Definition: stm32h757xx.h:90
@ DMA2_Stream1_IRQn
Definition: stm32h757xx.h:117
@ OTG_HS_WKUP_IRQn
Definition: stm32h757xx.h:134
@ SDMMC1_IRQn
Definition: stm32h757xx.h:109
@ DMA1_Stream0_IRQn
Definition: stm32h757xx.h:72
@ EXTI15_10_IRQn
Definition: stm32h757xx.h:101
@ SPI4_IRQn
Definition: stm32h757xx.h:142
@ EXTI9_5_IRQn
Definition: stm32h757xx.h:84
@ DMA1_Stream1_IRQn
Definition: stm32h757xx.h:73
@ LPTIM1_IRQn
Definition: stm32h757xx.h:151
@ SPI6_IRQn
Definition: stm32h757xx.h:144
@ OTG_FS_IRQn
Definition: stm32h757xx.h:159
@ OTG_FS_WKUP_IRQn
Definition: stm32h757xx.h:158
@ FPU_IRQn
Definition: stm32h757xx.h:139
@ TIM8_UP_TIM13_IRQn
Definition: stm32h757xx.h:104
@ USART6_IRQn
Definition: stm32h757xx.h:129
@ SPI1_IRQn
Definition: stm32h757xx.h:96
@ OTG_HS_IRQn
Definition: stm32h757xx.h:135
@ HSEM1_IRQn
Definition: stm32h757xx.h:183
@ OTG_FS_EP1_OUT_IRQn
Definition: stm32h757xx.h:156
@ DFSDM1_FLT2_IRQn
Definition: stm32h757xx.h:170
@ HardFault_IRQn
Definition: stm32h757xx.h:52
@ BDMA_Channel6_IRQn
Definition: stm32h757xx.h:193
@ CM7_SEV_IRQn
Definition: stm32h757xx.h:124
@ FMC_IRQn
Definition: stm32h757xx.h:108
@ EXTI0_IRQn
Definition: stm32h757xx.h:67
@ EXTI4_IRQn
Definition: stm32h757xx.h:71
@ CM4_SEV_IRQn
Definition: stm32h757xx.h:125
@ DSI_IRQn
Definition: stm32h757xx.h:181
@ HRTIM1_TIMD_IRQn
Definition: stm32h757xx.h:165
@ SAI2_IRQn
Definition: stm32h757xx.h:149
@ HRTIM1_TIMC_IRQn
Definition: stm32h757xx.h:164
@ FDCAN_CAL_IRQn
Definition: stm32h757xx.h:123
@ DMA2_Stream2_IRQn
Definition: stm32h757xx.h:118
@ TAMP_STAMP_IRQn
Definition: stm32h757xx.h:63
@ TIM1_TRG_COM_IRQn
Definition: stm32h757xx.h:87
@ UART5_IRQn
Definition: stm32h757xx.h:113
@ DMA1_Stream5_IRQn
Definition: stm32h757xx.h:77
@ DMA2D_IRQn
Definition: stm32h757xx.h:148
@ DCMI_IRQn
Definition: stm32h757xx.h:136
@ WWDG_RST_IRQn
Definition: stm32h757xx.h:201
@ WAKEUP_PIN_IRQn
Definition: stm32h757xx.h:206
@ HSEM2_IRQn
Definition: stm32h757xx.h:184
@ I2C4_EV_IRQn
Definition: stm32h757xx.h:153
@ ECC_IRQn
Definition: stm32h757xx.h:203
@ BDMA_Channel5_IRQn
Definition: stm32h757xx.h:192
@ ETH_IRQn
Definition: stm32h757xx.h:121
@ MDIOS_WKUP_IRQn
Definition: stm32h757xx.h:177
@ USART1_IRQn
Definition: stm32h757xx.h:98
@ PVD_AVD_IRQn
Definition: stm32h757xx.h:62
@ COMP_IRQn
Definition: stm32h757xx.h:195
@ MDMA_IRQn
Definition: stm32h757xx.h:180
@ EXTI3_IRQn
Definition: stm32h757xx.h:70
@ BDMA_Channel0_IRQn
Definition: stm32h757xx.h:187
@ NonMaskableInt_IRQn
Definition: stm32h757xx.h:51
@ UART4_IRQn
Definition: stm32h757xx.h:112
@ TIM8_TRG_COM_TIM14_IRQn
Definition: stm32h757xx.h:105
@ EXTI1_IRQn
Definition: stm32h757xx.h:68
@ DMA2_Stream4_IRQn
Definition: stm32h757xx.h:120
@ TIM5_IRQn
Definition: stm32h757xx.h:110
@ DMA1_Stream7_IRQn
Definition: stm32h757xx.h:107
@ DMA1_Stream4_IRQn
Definition: stm32h757xx.h:76
@ HRTIM1_TIME_IRQn
Definition: stm32h757xx.h:166
@ DMA1_Stream6_IRQn
Definition: stm32h757xx.h:78
@ TIM1_CC_IRQn
Definition: stm32h757xx.h:88
@ LTDC_IRQn
Definition: stm32h757xx.h:146
@ SAI3_IRQn
Definition: stm32h757xx.h:172
@ FDCAN1_IT1_IRQn
Definition: stm32h757xx.h:82
@ LPUART1_IRQn
Definition: stm32h757xx.h:200
@ DMA1_Stream3_IRQn
Definition: stm32h757xx.h:75
@ SDMMC2_IRQn
Definition: stm32h757xx.h:182
@ BDMA_Channel2_IRQn
Definition: stm32h757xx.h:189
@ USART3_IRQn
Definition: stm32h757xx.h:100
@ RTC_Alarm_IRQn
Definition: stm32h757xx.h:102
@ DFSDM1_FLT1_IRQn
Definition: stm32h757xx.h:169
@ FDCAN2_IT1_IRQn
Definition: stm32h757xx.h:83
@ TIM16_IRQn
Definition: stm32h757xx.h:175
#define MCR
Modem Control Register.
Definition: uart.h:91
#define AFR
Alternate Function register.
Definition: uart.h:99
Definition: stm32h723xx.h:289
Analog to Digital Converter.
Definition: stm32h723xx.h:242
ART.
Definition: stm32h745xg.h:326
Definition: stm32h723xx.h:619
Definition: stm32h723xx.h:628
Consumer Electronics Control.
Definition: stm32h723xx.h:418
Comparator.
Definition: stm32h723xx.h:1576
Definition: stm32h723xx.h:1588
Definition: stm32h723xx.h:1583
CRC calculation unit.
Definition: stm32h723xx.h:442
Clock Recovery System.
Definition: stm32h723xx.h:456
Crypto Processor.
Definition: stm32h730xx.h:1670
Digital to Analog Converter.
Definition: stm32h723xx.h:469
Debug MCU.
Definition: stm32h723xx.h:531
DCMI.
Definition: stm32h723xx.h:561
DFSDM channel configuration registers.
Definition: stm32h723xx.h:518
DFSDM module registers.
Definition: stm32h723xx.h:496
Delay Block DLYB.
Definition: stm32h723xx.h:1443
DMA2D Controller.
Definition: stm32h723xx.h:686
Definition: stm32h723xx.h:639
Definition: stm32h723xx.h:634
Definition: stm32h723xx.h:650
Definition: stm32h723xx.h:645
DMA Controller.
Definition: stm32h723xx.h:601
Definition: stm32h723xx.h:611
DSI Controller.
Definition: stm32h747xg.h:709
Ethernet MAC.
Definition: stm32h723xx.h:717
This structure registers corresponds to EXTI_Typdef CPU1/CPU2 registers subset (IMRx,...
Definition: stm32h723xx.h:936
External Interrupt/Event Controller.
Definition: stm32h723xx.h:891
FD Controller Area Network.
Definition: stm32h723xx.h:403
Definition: stm32h723xx.h:315
FLASH Registers.
Definition: stm32h723xx.h:956
Flexible Memory Controller Bank1E.
Definition: stm32h723xx.h:1015
Flexible Memory Controller.
Definition: stm32h723xx.h:1006
Flexible Memory Controller Bank2.
Definition: stm32h723xx.h:1024
Flexible Memory Controller Bank3.
Definition: stm32h723xx.h:1038
Flexible Memory Controller Bank5 and 6.
Definition: stm32h723xx.h:1053
General Purpose I/O.
Definition: stm32h723xx.h:1066
Global Programmer View.
Definition: stm32h723xx.h:1966
HASH_DIGEST.
Definition: stm32h730xx.h:1730
HASH.
Definition: stm32h730xx.h:1714
Definition: stm32h742xx.h:1629
High resolution Timer (HRTIM)
Definition: stm32h742xx.h:1578
Definition: stm32h742xx.h:1596
Definition: stm32h742xx.h:1662
Definition: stm32h723xx.h:1467
HW Semaphore HSEM.
Definition: stm32h723xx.h:1453
Inter-integrated Circuit Interface.
Definition: stm32h723xx.h:1133
Independent WATCHDOG.
Definition: stm32h723xx.h:1152
JPEG Codec.
Definition: stm32h743xx.h:1125
LPTIMIMER.
Definition: stm32h723xx.h:1559
LCD-TFT Display layer x Controller.
Definition: stm32h723xx.h:1191
LCD-TFT Display Controller.
Definition: stm32h723xx.h:1166
MDIOS.
Definition: stm32h723xx.h:1681
Definition: stm32h723xx.h:664
MDMA Controller.
Definition: stm32h723xx.h:659
Operational Amplifier (OPAMP)
Definition: stm32h723xx.h:1083
Power Control.
Definition: stm32h723xx.h:1214
QUAD Serial Peripheral Interface.
Definition: stm32h742xx.h:1414
RAM_ECC_Specific_Registers.
Definition: stm32h723xx.h:1644
Definition: stm32h723xx.h:1654
Definition: stm32h745xg.h:1346
Reset and Clock Control.
Definition: stm32h723xx.h:1233
RNG.
Definition: stm32h723xx.h:1668
Real-Time Clock.
Definition: stm32h723xx.h:1307
Definition: stm32h723xx.h:1375
Serial Audio Interface.
Definition: stm32h723xx.h:1367
Secure digital input/output Interface.
Definition: stm32h723xx.h:1408
SPDIF-RX Interface.
Definition: stm32h723xx.h:1391
Definition: stm32h723xx.h:1479
Single Wire Protocol Master Interface SPWMI.
Definition: stm32h723xx.h:1615
System configuration controller.
Definition: stm32h723xx.h:1094
TIM.
Definition: stm32h723xx.h:1525
TTFD Controller Area Network.
Definition: stm32h723xx.h:376
Universal Synchronous Asynchronous Receiver Transmitter.
Definition: stm32h723xx.h:1596
USB_OTG_device_Registers.
Definition: stm32h723xx.h:1796
USB_OTG_Core_Registers.
Definition: stm32h723xx.h:1761
USB_OTG_Host_Channel_Specific_Registers.
Definition: stm32h723xx.h:1869
USB_OTG_Host_Mode_Register_Structures.
Definition: stm32h723xx.h:1855
USB_OTG_IN_Endpoint-Specific_Register.
Definition: stm32h723xx.h:1824
USB_OTG_OUT_Endpoint-Specific_Registers.
Definition: stm32h723xx.h:1840
VREFBUF.
Definition: stm32h723xx.h:304
Window WATCHDOG.
Definition: stm32h723xx.h:1633
Definition: hexdump.h:39
CMSIS Cortex-Mx Device System Source File for STM32H7xx devices.
