RTEMS 6.1-rc5
rtems-fdt-shell.c File Reference
RTEMS Flattened Device Tree Shell Command. More...
#include <ctype.h>
#include <inttypes.h>
#include <time.h>
#include <unistd.h>
#include <rtems/shell.h>
#include <rtems/rtems-fdt-shell.h>
struct  rtems_fdt_shell_cmd
#define RTEMS_FDT_COMMANDS   (sizeof (table) / sizeof (const rtems_fdt_shell_cmd))
typedef int(* rtems_fdt_shell_handler) (int argc, char *argv[])
void rtems_fdt_add_shell_command (void)
rtems_fdt_handlertems_fdt_get_shell_handle (void)
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler (rtems_fdt_write_handler handler)
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler (rtems_fdt_read_handler handler)
Command to play with the memory in a FDT.
Typedef Documentation
◆ rtems_fdt_shell_handler
The type of the shell handlers we have.
◆ rtems_fdt_add_shell_command()
void rtems_fdt_add_shell_command ( void  )
Add a shell command to access memory and registers associated with the DTF.
◆ rtems_fdt_get_shell_handle()
rtems_fdt_handle * rtems_fdt_get_shell_handle ( void  )
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
◆ rtems_fdt_set_shell_read_handler()
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler ( rtems_fdt_read_handler  handler)
Set the read handler returning the current handler.
◆ rtems_fdt_set_shell_write_handler()
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler ( rtems_fdt_write_handler  handler)
Set the write handler returning the current handler.
