RTEMS 6.1-rc5
pwmout.h File Reference
PWM-Out controller for the mbed lpc1768 board. More...
#include <bsp.h>
#include <bsp/io.h>
#include <bsp/lpc176x.h>
rtems_status_code pwm_init (const lpc176x_pin_number pin_number)
 Initializes the PWM output device and sets an initial period of 20000us.
rtems_status_code pwm_period (const lpc176x_pin_number pin_number, const lpc176x_microseconds period)
 Sets a period for the PWM output. (Note that this changes the period for all the PWM outputs.)
rtems_status_code pwm_pulsewidth (const lpc176x_pin_number pin_number, const lpc176x_microseconds pwidth)
 Sets a pulsewidth for the PWM output.
◆ pwm_init()
rtems_status_code pwm_init ( const lpc176x_pin_number  pin_number)
Parameters
pin_numberThe PWM output pin.
Returns
RTEMS_SUCCESSFULL if the PWM initialization was OK, RTEMS_INVALID_NUMBER for a wrong parameter.
◆ pwm_period()
rtems_status_code pwm_period ( const lpc176x_pin_number  pin_number,
Parameters
pin_numberThe pin whose period we want to change.
periodThe desired period in microseconds.
Returns
RTEMS_SUCCESSFULL if the period's setting was OK, RTEMS_INVALID_NUMBER for a bad parameter.
◆ pwm_pulsewidth()
rtems_status_code pwm_pulsewidth ( const lpc176x_pin_number  pin_number,
Parameters
pin_numberThe pin whose pulsewidth we want to change.
pwidthThe desired pulsewidth in microseconds.
Returns
RTEMS_SUCCESSFULL if the pulsewidth's setting was OK, RTEMS_INVALID_NUMBER for a wrong parameter.
